- Aug 5, 2026
- 6
- 3
- Mercer, PA, USA
- C?ID=116081
Hello from Mercer PA: ran into a snag with the ABS module. I have had this car for 15 years and this is the first problem I haven't been able to sort. The issues became apparent on 8/3/2026.
I painted the hood and roof and it sat for a couple weeks during the process. As a consequence, it suffered a bout of low battery voltage and I had to jump the car (the car had power but not enough to start). When this has happened in the past with low voltage or a disconnected battery, the steering wheel, ABS, and EPS lights come on but go out once I drive the car down the road. But not this time.
To clarify what occurred just prior to the faults:
1. Painted car-- car sat unused for 2 weeks
2. Low battery voltage leading to a no start and a jump
3. I deleted the sat/nav shark fin antenna -- not needed/obsolete and didn't want to reinstall on fresh paint (clear coat). I also broke some of its plastic terminals. But it can be reinstalled with some tape on the terminals.
As of now (8/6), both ABS and EPS lights won't go out. For some reason, the ABS lost its soft coding and all zeros appeared in the coding section. I found my coding from a previous scan. I entered it and it was accepted, but it continues to throw the 01044 code no matter what I do. I did go into the CAN gateway and deleted digital radio. NAV was already unchecked. I checked that it wasn't listed under long coding either. The antenna's part number is 1k5 035 507 E.
The vehicle's VIN is not appearing in the scan which is also different from previous scans. 3VWST71K46M719103
It looks like the radio sat/nav might be the issue as stupid as it sounds because it is a module-- just not a major body module? 01044 appears under 56 radio and 01044 appears under 03 ABS Brakes.
It has been a tool throwing and hair pulling episode. Help appreciated
Help appreciated
Wednesday,05,August,2026,21:30:24:49198
VCDS Version: 26.3.0.0 (x64)
VIN: XXXXXXXXXXXXXXXXX License Plate:
Chassis Type: XX (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: XXXXXXXXXXXXXXXXX Mileage: 407720km-253345miles
Address 01: Engine Labels: 038-906-016-BEW.clb
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: XXXXXXXXXXXXXX
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 63CF5F56A2959687BE-8036
VINID: A28A28A28A28A28A28A28A28A0617BF560
Readiness: 0 0 0 0 X
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Revision: 00T12001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 4085B0DA1343ED9F83-8014
Part No: 1K0 820 047 DL
Component: Climatic PQ35 090 0505
VCID: 71E3251E686934173C-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000207271
Coding: 0401860701040000000A00000F000000000951035C
Shop #: WSC 22231 444 54614
VCID: 2A51F272853F07CFBD-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00063445
Shop #: WSC 22231
00061 - Footwell Lights
Fault Status: 01101100
Reset counter: 249
Mileage: 407729 km
Voltage: 11.40 V
Reset counter: 249
Mileage: 407729 km
Voltage: 11.40 V
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 39 AIRBAG VW8R 032 6800
Revision: 02032000 Serial number: 0038FD02JRHI
Coding: 0013113
VCID: 3973DD3E7099BC57C4-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0C061F229
Subsystem 3 - Serial number: 6342MSME0B604E48J
Subsystem 4 - Serial number: 6351HSME085D6066B
Subsystem 5 - Serial number: 6361HSME0854486CF
Subsystem 6 - Serial number: 63727SME077B424C7
Subsystem 7 - Serial number: 63827SME07740074X
Address 16: Steering wheel Labels: 1K0-953-549-MY8.clb
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000021
VCID: 78F5183A0B13655FFB-802C
Part No: 1K0 920 952 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0021207
VCID: 2B5FF7768AC51EC746-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105A03863B
Coding: 3D3F0B40071002
Shop #: WSC 00066 123 12345
Address 25: Immobilizer
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 3669D6024187532F29-8062
00120 - Outside Warning Light/Door exit Light Driver Side
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3261EA12ADEF4F0F05-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 1A7803083F3F058C480F048051A0
VCID: 74ED2C0A177B013FD7-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 3777DB06468DAA2732-8062
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio ZSW 016 0017
Revision: 00016000 Serial number: VWZ5Z7E6013409
Coding: 0040400
VCID: 2045105AF303CD9FE3-8074
02218 - Satellite Radio (R146)
Reset counter: 249
Mileage: 407729 km
Time: 21:11:24
Reset counter: 249
Mileage: 407729 km
Time: 21:11:17
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 3163E51EA8E974177C-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Component: PTC-Element 0404
VCID: 2D5BF96EB4D110F758-8078
End-------------------------(Elapsed Time: 01:39)--------------------------
------------------------------6 Faults Found-------------------------------
Help appreciated
