Missing ASAM/ROD on brand new D6 module
golfi_vend
Tartu, Estonia
C?ID=195131
Following is rather observation, not an issue.
Brand new D6 module, no ROD file, also ASAM presented by module differs from D7.
Wednesday,05,August,2026,18:50:57:21782
VCDS Version: 26.3.0.0 (x64)  HEX-NET CB: 0.4711.4
Data version: 20260624 DS375.2
VIN: TMBLC7NS0J8   License Plate: 812BXB
Mileage: 183698km-114144mi   Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 4B 52 5F 69
          6C 6D 75 D6 D7
VIN: TMBLC7NS0J8   Mileage: 183698km-114144miles
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 LD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3433
   Revision: R7H26---    CVN: 8C8B690C
   Coding: 011D007223661D083000
   Shop #: WSC 33361 790 00144
   ASAM Dataset: EV_ECM14TFS01104E906027LD 001002
   ROD: EV_ECM14TFS01104E906027LD.rod
   VCID: 71AADEFBA0FC0C173C-8024
   VINID: 91D49C4C77A301A2001070491C17AE522D
Readiness: 0010 0001
   Part No SW: 0D9 300 014 S    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01709191476 CVN: 0000586C
   ROD: EV_TCMDQ250021.rod
   VCID: 281CF39F53A60DDFAB-807C
   Revision: 00000000    Serial number: 63047000000946
   Coding: 60076A9F442423734778070962CA49065622C4E2E046927D38215078E2094200002F641A1B13111435351919323200
   VCID: 77BEE0E3CE985227F2-8022
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0460688846 Dataset Number: V03935268ZS 0001
   Coding: 032C0C070F
   ROD: EV_KessyHellaMQBAB_004_SK37.rod
   VCID: 3E3035C7A122A36FF1-806A
   Power rear lid opening control module:
   Part No SW: 565 907 044 BJ    HW: 565 907 044 BJ
   Component: Climatronic   H04 2001
   Revision: 00001K00
   Coding: 16010004000410011005000900101022
   Shop #: WSC 33361 790 00115
   VCID: 6484A7AF6F0EA9BF47-8030
   Air quality sensor:
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 62214046
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 8658051117005J Dataset Number: V03935433UG 0001
   Shop #: WSC 33361 790 00122
   ROD: EV_BCMBOSCH_018_SK37.rod
   VCID: 06409D27B9723BAFF9-8052
   Subsystem 1 - Part No SW: 566 955 119     HW: 566 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS326 171014  051 0907
   Serial number: 887353F0401728701892
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: S8Y17M11D10H08M16S03
   Coding: 0088DF
   Serial number: 000000000ZY172831E6Z
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223972824906
   Humidity sensor: interior:
569092 - Databus
          [LCM links - LCM_Feh_LM_L_alt aktiv]
                    Reset counter: 123
                    Mileage: 183676 km
                    Date: 2026.08.05
                    Time: 10:51:46
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 13.5 V
                    Outside temperature: 23.0 °C
567062 - Databus
          [LCM links - Tagfahrlicht defekt]
                    Reset counter: 163
                    Mileage: 183676 km
                    Date: 2026.08.03
                    Time: 16:09:20
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 11.9 V
                    Outside temperature: 29.0 °C
568086 - Databus
          [LCM links - Blinker defekt]
                    Reset counter: 164
                    Mileage: 183676 km
                    Date: 2026.08.03
                    Time: 16:09:20
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
   Part No SW: 3Q0 919 294 B    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H08 0029
   Serial number: 002410177478020 Dataset Number: V03935257YW 0001
   Coding: 0071551911
   Shop #: WSC 41088 002 1048576
   ASAM Dataset: EV_EPHBO18VW3260000 007018
   ROD: EV_EPHBO18VW3260000.rod
   VCID: 383C23DF83069D5F3B-806C
   Component: ACCCONTIMQB   H02 0233
   Dataset Number: V03935259TS 0001
   Coding: 3200678910FF8728749C8145304087
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4PNH39C% Dataset Number: V03935257XC 0001
   Coding: 98CCC0C0000000005C5400CF000840000065
   ROD: EV_AirbaVW21TS6VW48X_SK37.rod
   VCID: 05429A2B847430B7F0-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 001 510 17
   Serial number: 357000000008EBB4592-
   Subsystem 2 - Part No SW: -----------    HW: 454 001 710 17
   Serial number: 35800000000099E4992T
   Subsystem 3 - Part No SW: -----------    HW: 454 802 710 17
   Serial number: 3510091752E120000007
   Subsystem 4 - Part No SW: -----------    HW: 454 802 510 17
   Serial number: 35200E2473A12000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 801 610 17
   Serial number: 35500339528120000003
   Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20171107501094 Dataset Number: V03935250KY 0001
   Coding: 6414
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BB6FCD3F2B0764796-802E
   Part No SW: 565 920 740 A    HW: 565 920 740 A
   Component: KOMBI         204 0312
   Coding: 07A4001CAF800008018C2A011001000800000000
   Shop #: WSC 73430 031 00144
   VCID: 177EC063EED8B22712-8042
   Component: GW MQB High   518 5323
   Serial number: 05111710524875 Dataset Number: V03935272QN 0001
   Coding: 0B0100347F085700EB03225A1E0F00010001070000000000000000000000
   GVL: 01D63C0008000600C00C80008002C80000000000000200000000000000000000
   ROD: EV_GatewNF_SK37.rod
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000D2336281017
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75886100001711040F74
   Inverter for socket:
   Subsystem 4 - Part No SW: 5Q0 907 155 H    HW: 5Q0 907 155 H
   Component: U13DCAC  H25 0780
   Serial number: 0041029
   Serial number: HA1-00024.08.17 Dataset Number: v1260x015G0 0000
   Coding: 0101
   VCID: 4CD46F0FE79E01FF6F-8018
   Serial number: 17000309049013
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Serial number: 0000287360180  Dataset Number: V03935262NS 0001
   Coding: 00150820D000040000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 47DE5023FEF8E2A742-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000017243090
   Coding: 010200
   Revision: 00000000    Serial number: 0002139858 Dataset Number: V03935255DC 0001
   Coding: 01000010004001
   ROD: EV_SteerAssisVWBSMQBA_009.rod
   VCID: 40CC4B3FDBD6D59F83-8014
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 09111710522518 Dataset Number: V03935265KZ 0001
   Coding: 000000070100037200002D00190000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_001_VW37.rod
   VCID: 72A8D1F7A5FA370FC5-8026
66672 - Control Module for Light Activation/Adjustment; Left
          U116E 00 [10001001] - No Communications
          [LCM_Feh_LM_L no communication]
                    Reset counter: 123
                    Mileage: 183676 km
                    Date: 2026.08.05
                    Time: 10:51:45
66881 - Databus
          U1123 00 [10001001] - Received Error Message
          [LED_L_falsch_codiert received error value]
                    Reset counter: 123
                    Mileage: 183676 km
                    Date: 2026.08.05
                    Time: 10:51:43
   Serial number: 0000287331128  Dataset Number: V03935262NT 0001
   Coding: 00150020D000040000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 46C05D27F9F2FBAFB9-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000017314289
   Coding: 190200
   Part No SW: 5Q0 035 840 C    HW: 5Q0 035 840 C
   Component: MU-S--ER      H41 0468
   Serial number: SKZAZ2T5441906 Dataset Number: V03935273FG 0001
   Coding: 03231600FF0000004111000100010A002F020AC40120850002
   ROD: EV_MUStd4CTSAT_SK37.rod
   VCID: 2D12028B7C4428F758-8078
   Subsystem 1 - Part No SW: 565 919 605 C    HW: 565 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: SKZ6ZHT2972113
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0468807358 Dataset Number: 55A124t____ 0002
   Coding: 0100000202000000
   VCID: 42C84137D5DAC78F95-8016
   Dataset Number: V03935242LD 0001
   Coding: 04231601A3002017000040
   VCID: 393A26DBB80C8457C4-806C
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31623016300000 Dataset Number: V03935259NH 0001
   Coding: 1B88
   VCID: 41CA4E3BD0DCDC978C-8014
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0717
   Revision: --------    Dataset Number: V03935265GS 0001
   Coding: 03231601EA161A0D3B1C9E020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3C343FCFB73EB17FDF-8068
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: N/A
   VCID: 7EB0F5C7E1A2636FB1-802A
No ASAM data for: "EV_LEDMinMaxL_KEBODAVW481" (SK37)
0017 - ROD - Unknown Error Code
          - 00 [10101111]
                    Fault Frequency: 9
                    Reset counter: 0
0257 - ROD - Unknown Error Code
          - 00 [01101000]
                    Reset counter: 0
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
End----------(Elapsed Time: 02:03, VBatt start/end: 12.2V/12.2V)-----------
------------------------------7 Faults Found-------------------------------
And after loading parameters with ODIS. PS! Even ODIS complained that ASAM is unknown.
Wednesday,05,August,2026,19:26:14:63851
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4714.5
VIN: TMBLC7NS0J8   License Plate: AFTER_PARAM
          6C 6D 75 D6 D7
   VCID: 71B4BE8C31268C3230D-8024
Readiness: 1110 0001
   VCID: 280293E8C27C8DFAA73-807C
   VCID: 77A080945F42D202FE9-8022
   Coding: 032C0C070F
   VCID: 3E2E55B030F8234AFDF-806A
   Revision: 00001K00
   VCID: 649AC7D8FED4299A4BB-8030
   Air quality sensor:
   VCID: 065EFD5028A8BB8AF5F-8052
   Coding: 164DDD
   Coding: 0088DF
   Coding: 0071551911
   VCID: 382243A812DC1D7A373-806C
   VCID: 055CFA5C15AEB092FC5-8050
   Coding: 6414
   VCID: 7BA89CA4636AF6629A1-802E
   VCID: 1760A0147F0232021E9-8042
   Generator:
   Coding: 0101
   VCID: 4CCA0F78764481DA63B-8018
   VCID: 47C030546F2262824E9-8012
   Coding: 010200
   VCID: 40D22B484A0C55BA8F3-8014
   VCID: 72B6B1803420B72AC97-8026
   VCID: 46DE3D5068287B8AB5F-8012
   Coding: 190200
   VCID: 2D0C62FCED9EA8D2545-8078
   VCID: 42D62140440047AA997-8016
   VCID: 392446AC29D60472C8D-806C
   Coding: 1B88
   VCID: 41D42E4C41065CB280D-8014
   VCID: 3C2A5FB826E4315AD3B-8068
   Dataset Number: V03935300PV 0001
   VCID: 7EAE95B07078E34ABDF-802A
End----(Elapsed Time: 02:17, VBatt start/end: 11.9V/11.8V. VIgn 12.0V)-----
---------------------------No fault code found.----------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I'm looking at a workaround for this, though since this isn't exactly a normal case for now it's also not a truly high priority item. Considering that parameterization etc. are still being done by ODIS w/o the proper ASAM match, we can assume the "missing" ID represents what the module identifies as w/o a proper dataset.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Turns out, this is a Skoda-only issue. VW has these covered and I made the necessary adjustment so this should be fine in future as well. Let us know if you experience this again... Data Version 20260806+ will include a workaround.
