Hi Everyone, need help with scirocco 2.0tsi dsg
badhero32
Suffolk, UK
C?ID=604717
So i brought a project scirocco thinking it was a simple fix up job as it ran and was tatty, wouldn't go into gear either but was told that was because it needed a new shifter (auto dq250) turns out it runs because of an immo off jobby. the front can lines are down, fuses are fine and i have terminal 15 and power to ecu and dsg plug. i did notice steering rack had gotten hot and pyrofuse melted. but not sure if that is anymore to do with it. appreciate any help that will be given
VIN: WVWZZZ13Z9V005304   License Plate:
Chassis Type: 13 (1K0)
Scan: 01 02 03 08 09 14 15 16 17 19 25 2E 42 44 46 52 56
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 69886292F57FDD2278D-803C
            013 - Check DTC Memory
            009 - Open or Short to Ground
            014 - Defective
   Revision: 00H54000    Serial number: 00000008708833
   Coding: E50E9E0300041A00679600006400000000587F076440012C000000000000
   Shop #: WSC 00326 210 84578
   VCID: 3334C0FAE73357F2021-8066
   Subsystem 1 - Part No: 1K8 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 020708 022  0602
   Coding: 00038805
   Shop #: WSC 00326
   Component: RLS     180708 054  0402
   Coding: 00208936
   Shop #: WSC 00326
10 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 24
                    Mileage: 144207 km
                    Voltage: 11.60 V
                    Reset counter: 24
                    Mileage: 144207 km
                    Voltage: 11.60 V
                    Reset counter: 24
                    Mileage: 144207 km
                    Voltage: 11.60 V
                    Reset counter: 24
                    Mileage: 144207 km
                    Voltage: 11.60 V
00984 - Left Tail Light (M4)
                    Reset counter: 24
                    Mileage: 144207 km
                    Voltage: 11.60 V
                    Fault Status: 01101001
                    Reset counter: 24
                    Voltage: 11.70 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 24
                    Mileage: 144207 km
                    Voltage: 11.60 V
                    Reset counter: 24
                    Mileage: 144207 km
                    Voltage: 11.60 V
                    Reset counter: 24
                    Mileage: 144207 km
                    Voltage: 13.15 V
02390 - Control / Regulation for Ambience Lighting (E400)
                    Reset counter: 24
                    Voltage: 11.70 V
Address 14: Susp. Elect.
Address 15: Airbags
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.clb
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Coding: 0012122
   Shop #: WSC 00158 210 93579
   VCID: 04565326F21D204AEBB-8050
00002 - Transmission Control Unit
Address 17: Instruments
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K08804026C
   Coding: ED881F060002124001
   Shop #: WSC 12786 000 1048576
   VCID: 3530FEE2E94749C22C5-8060
03272 - Control Module for Audio Interface
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:00:05
01312 - Powertrain Data Bus
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 9
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:00:56
   Part No SW: 1K8 920 970 F    HW: 1K8 920 970 F
   Component: IMMO            VDD 2444
   Revision: V0003000    Serial number: VWX7Z0H53NP0ZR
02241 - Engine Control Module; Immobilizer Data not Adapted
                    Mileage: 144207 km
                    Time: 00:24:19
Address 2E: Media Player 3
   Part No SW: 1Q0 959 701 F    HW: 1Q0 959 701 F
   Component: Tuer-SG         008 2018
   Coding: 0016949
   Shop #: WSC 00020 790 00000
   VCID: 372CF4EAF34BBBD23E9-8062
Address 44: Steering Assist
   Component:    KSG PQ35 G2  020 0205
   Coding: 80900A0002830C7F3F04850570085ACE903C00
   Shop #: WSC 00020 790 12345
   VCID: 0354503AF7132772D21-8056
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:20:26
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:20:26
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:20:26
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:00:56
00625 - Vehicle Speed Signal
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:04:24
   Part No SW: 1Q0 959 702 F    HW: 1Q0 959 702 F
   Coding: 0016948
   VCID: 382EF7D6FE55B4AA373-806C
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
   Component: Radio RCD510  040 0166
   Revision: 00000001    Serial number: VWZ1Z3K8986008
   Coding: 0100040004
   Shop #: WSC 00028 028 00001
   VCID: 261229AE28E1325A95F-8072
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:20:49
00856 - Radio Antenna
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:20:54
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:20:54
02877 - Digital Radio Antenna (R183)
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:20:54
                    Reset counter: 24
                    Mileage: 144207 km
                    Time: 00:20:44
End----(Elapsed Time: 00:56, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
------------------------------29 Faults Found------------------------------
Jef
HQ
Please do not edit down the Auto-Scan... the start of the Auto-Scan report is missing.. no time/date info, version info...ect.
014 - Defective
So all the modules that come up as "Cannot be reached" in the report, those are on the Powertrain Data Bus and it is possible one of them is pulling down the whole bus. You can see about unplugging them one at a time and then if the other modules are able to talk.
It is also possible there could be a wiring issue for the Powertrain Data Bus but IMHO, more likely a bad module screwing with you.
badhero32
Suffolk, UK
C?ID=604717
Really sorry about that,
I tried unplugging abs, dsg, airbag measured ohms at the dsg socket on can got 60ohm im thinking I need to get the steering rack unplugged as it has signs of getting hot
