Hello Everyone.
Quite new here, so here we gp:
I have a 2011 V6 diesel Touareg SE Bluemotion. My first mistake was letting the car stand for 3 years without any use.
When I tried to re-use the car there were so many problems with it, mostly relating to water ingress and a flat battery.
It has taken me at least 18 months to get the car into a useable condition, although there are still issues that need resolving. The steering angle sensor fault is at the route of quite
a few of the faults, but my current focus is on the radio.
The car is equipped with an RNS85 Dynaudio unit. The radio had an issue with the head unit in the luggage compartment. I looped out the optic fibre link with a patch and the remaining features of the infotainment system worked as it should. I then sourced a used unit with identical numbers and fitted it.
The radio came to life immediately but with issues.
1.. The radio cuts out for 2 seconds every 2 seconds (only the radio, the media, bluetooth and telephone all work as they should.)
2.. Only the right front channel of the audio works (passenger front and both rear speakers are silent)
Initially, I thought that the used unit was faulty, but on further reading through many internet articles, I discovered that this exact issue has been experienced by others.
As for a resolution to the issue, there are more than enough opinions but none seem definitive.
Therefore, I am hoping that there is an answer waiting on this forum.
I have included below a full autoscan carried out yesterday.
Any help would be greatly appreciated.
Cheers
Chris
Cheers
Chris
Tuesday,04,August,2026,11:02:52:54841
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4713.5
VIN: WVGZZZ7PZBD028505 License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 69 72
VIN: WVGZZZ7PZBD028505 Mileage: 196718km-122234miles
04-Steering Angle -- Status: Malfunction 0010
17-Instruments -- Status: Not registered 0001
56-Radio -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Not registered 0011
Address 01: Engine (J623-CASA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 HW: 7P0 907 401
Component: 3.0TDI EDC17 H17 0008
Revision: 51H17--- CVN: AA8C9129
Coding: 292A4012232601020000
ASAM Dataset: EV_ECM30TDI0117P0907401 002010
ROD: EV_ECM30TDI0117P0907311.rod
VCID: 6C861B7BF60694FA03B-8038
VINID: 9E65EAAAA1E0A92500088140142C208B6E
4807 - EGR System
P0401 00 [01100000] - Insufficient Flow
Mileage: 196622 km
Date: 2025.02.15
Time: 05:07:44
Engine speed: 1696.50 /min
Normed load value: 69.0 %
Vehicle speed: 70 km/h
Coolant temperature: 92 C
Intake air temperature: 29 C
Voltage terminal 30: 14.040 V
Unlearning counter according OBD: 33
Mean injection quantity: 22.50 mg/stroke
Control Module temperature: 50.8 C
EGR_governor_deviation: -133.5 mg/stroke
Inj Ctl q Curr: 22.28 mg/stroke
Mass_air_flow_sensor_drift: 1.2871
Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 155.3 kg/h
Actual charge pressure: 1267 hPa
5120 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [01101101] - Signal too High (Rich)
Mileage: 196610 km
Date: 2025.02.15
Time: 02:48:07
Engine speed: 1367.00 /min
Vehicle speed: 31 km/h
Coolant temperature: 88 C
Intake air temperature: 38 C
Voltage terminal 30: 14.260 V
Air mass: actual value (mg/stroke): 571.8 mg/stroke
Mean injection quantity: 0.00 mg/stroke
Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-Bits 0-7: 0
Oxygen sensor 1 bank 1: voltage raw value O2 signal: 592.4 mV
Oxygen sensor 1 bank 1: voltage value Ri-signal filtered: 1003.8 mV
O2 sensor 1 bank 1: duty cycle O2 heater: 48.77 %
LSU r O2 Adap 0: 0.10389
7150 - Please Check DTC Memory of Steering Wheel Electronics
P1698 00 [00101111] - -
Fault Frequency: 42
Mileage: 196610 km
Date: 2025.02.15
Time: 00:18:14
Engine speed: 0.00 /min
Coolant temperature: 29 C
Intake air temperature: 27 C
Voltage terminal 30: 11.720 V
CAN TimeOut meter - battery manager-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 12
CAN TimeOut meter - gateway-Bits 0-7: 0
CAN TimeOut meter - steering angle-Bits 0-7: 0
CAN TimeOut meter - parking brake-Bits 0-7: 0
CAN TimeOut meter - transmission-Bits 0-7: 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 H HW: 0C8 927 750 H
Component: AL1000 AISIN 001 1885
Serial number: CVN: 953CCF74
Coding: 001568
Shop #: WSC 00078 790 12345
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001.rod
VCID: 3138CA0F11A4391270D-8064
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 E HW: 7P0 907 379 A
Component: MK25A H33 0416
Revision: -------- Serial number: 434600010EC010 Dataset Number: 7P0012v____ 7P09
Coding: 5B6B13C30926255BDAF9C89390D7A4507700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 3FDC9C37D7F0DF62F69-806A
199176 - Steering angle sensor
B1168 29 [10001001] - Signal Implausible
Reset counter: 101
Mileage: 196610 km
Date: 2025.02.15
Time: 00:19:05
Standard Freeze Frame Dynamic: 00 3A 00 00 00 00 00 02 00 00 01 20 18
199173 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 101
Mileage: 196610 km
Date: 2025.02.15
Time: 00:19:05
Standard Freeze Frame Dynamic: 00 3A 00 00 00 00 00 02 00 00 01 20 17
199182 - Steering angle sensor
B1168 04 [10001001] - Internal System Fault
Reset counter: 101
Mileage: 196610 km
Date: 2025.02.15
Time: 00:19:05
Standard Freeze Frame Dynamic: 00 3A 00 00 00 00 00 02 00 00 01 01 24
Part No SW: 4H0 907 064 AL HW: 4H0 907 064 AL
Component: BCM2 2.0 H23 0208
Coding: 01B60000000000000000
VCID: 73B40007ABB84B02C21-8026
Subsystem 1 - Part No SW: 7P6 959 754 AA HW: 7P6 959 754 AA
Component: FBSTOUAREGIDG H05 0051
Serial number: 0810000113515003
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000048510006
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0613
Coding: B626000890
VCID: 79A8322F8954315288D-802C
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
Reset counter: 146
Mileage: 196692 km
Date: 2025.02.16
Time: 18:43:09
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000737571
Coding: 6908809181347F010005080300005F5F431D670807000241000000000000
VCID: 3138CA0F1124391270D-8064
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 101121 31 0020
Serial number: 90243401101201224053
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10099629
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 B HW: 7P6 941 431 B
Component: E1 - LDS H04 0031
Serial number: 00000000000612100397
Fault Status: 01101100
Reset counter: 110
Mileage: 196702 km
Date: 2025.02.17
Time: 01:14:00
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 HW: 7P6 919 475
Component: PARKHILFE 8K H03 0016
Revision: -------- Serial number: 55931034016011
Coding: 118501
ASAM Dataset: EV_VW526ParkiAssis2 001008
ROD: EV_VW526ParkiAssis2.rod
VCID: 55F05E9F458C3532CC5-8000
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag00K H05 0023
Revision: -------- Serial number: 003JX0011GZM Dataset Number: 7P6003v____ 0731
Coding: 00000000000000000000000000000000304B
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 40DE9FCBAA0EA09A8F3-8014
Serial number: 3575LRB405907USIEPHL
Serial number: 3585LRB405H07USIG15$
Serial number: 3515RRB404P053R4FOQ1
Serial number: 3525RRB404R053R4H0RQ
Serial number: 3555NRB404T04QRO71QG
Serial number: 3565NRB404P0891I2GOJ
Part No SW: 4H0 953 568 A HW: 7P6 953 507
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KB80004M
Coding: 000015
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0044600
Fault Status: 01100101
Fault Frequency: 43
Reset counter: 110
Mileage: 196610 km
Date: 2025.02.15
Time: 00:18:11
(no units): 36.0
Text: 24A41C017A001F0006
1 %
-248.32
Text: 2B71FFFFFFDFFFB7FF
(no units): 323.85
Raw, Index/Key Err.: 255 223 255
Raw, Index/Key Err.: 183 255 118
00886 - Turn Signal Switch (E2)
Reset counter: 144
Mileage: 196665 km
Date: 2025.02.15
Time: 21:26:19
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 981 HW: 7P6 920 981
Component: Kombi H12 0235
Revision: 10240060 Serial number: 658091210593031
Coding: 3327310022002600010004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 7AAA2D238C523A4A817-802E
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000072125
Coding: 000D077500
GVL: FB4E40051A29000000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 382EF72BF2DEE85A373-806C
Control module for battery monitoring:
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650324647
Voltage stabilizer:
Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
Component: J532_DCDCStab H17 0042
Serial number: 10340000409011200181
5712 - Radio
U1066 00 [00001001] - No Communication
Reset counter: 101
Mileage: 196610 km
Date: 2025.02.15
Time: 00:18:13
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.8 V
Control Module temperature: 35 C
System status: Terminal 15 on
IN ESP_standstill flag: no standstill detected
Engine is running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
0022 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
[Steuerger t falsch codiert (MOST)]
Fault Frequency: 15
Reset counter: 109
Mileage: 196610 km
Date: 2025.02.15
Time: 00:19:07
IN ZAS_Te_X: On
Datenfeld: 0
U140B 00 [00001000] - -
[Powermanagement active]
Reset counter: 150
Mileage: 196657 km
Date: 2025.02.15
Time: 18:22:39
Voltage terminal 30: 12.5 V
Voltage terminal 15: 0.0 V
Control Module temperature: 18 C
System status: Awake_Timer_active
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 1
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000110306323
Coding: 011D0620D001451005080002
VCID: 3C26EB3BC666C47AD3B-8068
Revision: 00002001 Serial number: 0140043907
Coding: 011F162228B900828320062C200000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
014 - Defective
Fault Status: 01101110
Reset counter: 101
Mileage: 196610 km
Date: 2025.02.15
Time: 00:18:23
03622 - Control Module 2 for Roof Shade
Reset counter: 101
Mileage: 196610 km
Date: 2025.02.15
Time: 00:18:23
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000110360050
Coding: 011D0620D001451005080000
VCID: 3B24E827C368C342DA1-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 D HW: 7P0 907 801 D
Component: EPB H51 1000
Revision: 00000000 Serial number: A10B23004F6 Dataset Number: A001
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: 3436C31BEEB60C3A1BB-8060
Slave 3:
Address 56: Radio
Part No SW: 7P6 035 666 HW: 7P6 035 666
Component: H-BN-EU H43 0203
Revision: -------- Serial number: 446L40A7516818
Coding: 020101050340C2ED05000F0E650F0001F0000101
VCID: 77AC3417BFC02722FE9-8022
Subsystem 1 - Part No: 8R0 060 884 R
Component: EUR 2010 1106
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H24 0045
Serial number: VWZ8Z9K2800JSL
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: CD-Database 1886
03389 - Data Set Implausible
Reset counter: 101
Mileage: 196610 km
Date: 2025.02.15
Time: 00:18:31
Voltage: 11.50 V
Bin. Bits: 010
Reset counter: 101
Mileage: 196610 km
Date: 2025.02.15
Time: 00:18:35
Bin. Bits: 00000000 00001000
Bin. Bits: 00000000 00000000
00822 - Connection DSP to Radio
Reset counter: 101
Mileage: 196610 km
Date: 2025.02.15
Time: 00:18:34
Voltage: 11.60 V
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000110944411
Coding: 011C06200001251005080000
VCID: 3A2AED23CC52FA4AC17-806E
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 C HW: 7P0 907 383 C
Component: Towbar module H07 0100
Coding: 0100000100000000
VCID: 382EF72BF25EE85A373-806C
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000110944123
End----------(Elapsed Time: 02:00, VBatt start/end: 12.2V/12.1V)-----------
------------------------------18 Faults Found-
