2019 Golf 1.5TSI gearbox update
ionicamis
Romania
C?ID=94230
Hello!
My sister's car started juddering when changing from 1 gear to second and i wonder if there's any software update which fixes that cause if you use sport mode the problem dissapears.
Also which tool should i buy to upgrade the software?
Thank you!
Monday,03,August,2026,10:52:03:46277
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4713.5
VIN: WVWZZZAUZKP547828   License Plate: ID DSG
Mileage: 114218km-70971mi   Repair Order:
                Address 02: Auto Trans
Control Module Part Number: 0CW 300 043 C
  Component and/or Version: GSG DQ200G2_M H05 1602
           Software Coding: 0014
            Work Shop Code: WSC 00028
                      VCID: 3720457A4FC6C8E23E9-8062
Advanced Identification/FAZIT
     Serial number: CU501901055811
     Identification: CU5-072
     Revision: 00005008
     Date: 05.01.19
     Manufacturer number: 0000
     Test stand number: 5811
Flash Status
     Programming Attempts(application): 1/1/3
     Flash Date-Workshop ID-Status:
     19.01.05 00000 000 00000 (OK) | 19.01.16 00001 001 05000 (OK) | 19.01.24 00284 028 00028 (OK)
Misc.
     Hardware number: 0AM 927 769 E
     Workshop System Name: J743
     Workshop ID (Adaptation): 00284 028 00028
     Workshop ID (Coding): 00066 028 00028
     Equipment/PR Code: FFFFFFFFFFFFFFFFFFFFFFFF
     ASAM Dataset: EV_TCMDQ200021
     ASAM Dataset Revision: 001001
Car Info
     Chassis Number: WVWZZZAUZKP547828
Immobilizer
     General immobilizer info :
          Life status: 2
          Identity counter: 1
          Brand identification: 3
          Power class: 0
          Power class 2: 77
          Power class supported: 00 00 00 00 00 05 04 00 00
          Count of adapted keys: 0
          Count of keys to be adapted by adaptation: 0
          Minutes remaining for Terminal 15 ON: 0
          Configuration status: 0
          Reserved: 0
     Lock times in minutes :
          Lock time password reset: 0
          Lock time login/Terminal 15 ON: 0
          Lock time key adaptation: 0
          Lock time leaving key adaptation: 0
          Lock time login special function: 0
     Immo Challenge: 77FACAC8
VCDS Info:
     Labels: 0CW-927-769.clb
     ROD: EV_TCMDQ200021.rod
Monday,03,August,2026,10:20:56:46277
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 29 2B 39 42 44 4B 52 5F 80
          A5 D6 D7
VIN: WVWZZZAUZKP547828   Mileage: 114218km-70971miles
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DACA)       Labels: Redir Fail!
   Part No SW: 05E 906 018 AK    HW: 05E 907 309
   Component: R4 1.5l TFS   H22 6323
   Revision: 81H22000    CVN: 5056196C
   Coding: 012500322364050870000200000000000000000000000000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM15TFS01105E906018AK 003003
   ROD: EV_ECM15TFS01105E906018AK.rod
   VCID: 6E8EA01E701C492A2DF-803A
   VINID: 9E69EAAAA465A9B8051072022042D1107B
   Radiator shutter:
   Subsystem 1 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V544KJS1  H12 0109
   Serial number: 20181110020103051735
5604 - Park/Neutral Switch Input Circuit
          P0850 00 [00100000] - Open or Short to Plus
33830 - No Communication with HV Battery Energy Control Module
          U0112 00 [00100000] - -
                    Mileage: 112519 km
                    Date: 2026.06.27
                    Time: 18:23:36
                    Engine speed: 1326.00 /min
                    Normed load value: 4.7 %
                    Coolant temperature: 50  C
                    Intake air temperature: 46  C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 11.640 V
                    Unlearning counter according OBD: 26
                    Outside temperature: 215  C
                    Absolute intake pressure: 23 kPa abs
                    Engine torque: 14.5 Nm
                    Fuel: tank fill level: 31.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0012
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
40592 - ROD - Unknown Error Code
          - 00 [00101111]
                    Fault Frequency: 80
                    Mileage: 114077 km
                    Date: 2026.07.30
                    Time: 14:18:46
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 99  C
                    Intake air temperature: 57  C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 12.220 V
                    Absolute intake pressure: 92 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 0.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
   Part No SW: 0CW 300 043 C    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1602
   Revision: 00005008    Serial number: CU501901055811 CVN: A61CF3B0
   Shop #: WSC 00028 028 00066
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 60069000004096
   Coding: 04FA6AA120242173477F060260CB2920560484E26006947338225078D2024B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79A4834239521E9288D-802C
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0503501416 Dataset Number: V03935272JC 0001
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43D821AA0B1E9442921-8016
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 02020004200110011105000000101022
   VCID: 6D8CA7127D1AB232145-8038
   Air quality sensor:
   Part No SW: 5Q0 937 086 BQ    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: 865804121800FX Dataset Number: V03935280NU 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0A46CC8E6CB4050A917-805E
   Component: WWS    181202  043 0551
   Serial number:         181220052110
   Component: RLHS  052 0107
   Serial number: S5Y19M01D17H02M10S02
   Coding: 00A8DD
   Serial number: 000000000ZY183301U4Z
   Serial number: 00000000000046001225
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100100120190C100137
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [00001000] - No Release by Immobilizer
                    Reset counter: 13
                    Mileage: 113618 km
                    Date: 2026.07.20
                    Time: 13:29:27
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 13.8 V
                    Outside temperature: 22.0  C
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019004 Dataset Number: V03935287MF 0001
   Coding: 0471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CCA0A9626405B3A63B-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Dataset Number: V03935282JS 0001
   Coding: 3300674159FFC728949C834580400600000000000000000004
   VCID: 44DA22B60E10937AABB-8010
   Part No SW: 5Q0 959 655 BS    HW: 5Q0 959 655 BS
   Component: AirbagVW21    007 0403
   Serial number: 003FMR4XPB6H Dataset Number: V03935279BA 0001
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00057
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 1276D4EE04E4CDCA697-8046
   Subsystem 1 - Part No SW: -----------    HW: 480 001 201 19
   Serial number: 3570000000060B25D73J
   Subsystem 2 - Part No SW: -----------    HW: 480 001 201 19
   Serial number: 3580000000008569D73O
   Subsystem 3 - Part No SW: -----------    HW: 480 401 501 19
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011E2B72272473T
   Subsystem 4 - Part No SW: -----------    HW: 480 401 501 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001082B72275E71Y
   Subsystem 5 - Part No SW: -----------    HW: 480 400 301 19
   Serial number: 3550001182C00982655T
Address 17: Instruments
   Serial number: 19121810522872 Dataset Number: V03935293G  0001
   Coding: 030100047F085702FA0802481C0F00000001070000000000000000000000
   GVL: 01463C0000000600408C80000000C80000000000004200000000000000000000
   ROD: EV_GatewNF_VW48.rod (VIN: N/A)
   Generator:
   Component: 1-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180002469750118493
   Coding: 2DFFFF
   Serial number: 7939590205
8531970 - Quiescent Current
          U1406 00 [00001000] - Too High
          [Ruhestrom oberer Grenzwert  berschritten]
                    Fault Frequency: 81
                    Reset counter: 27
                    Mileage: 110784 km
                    Date: 2026.06.09
                    Time: 00:36:43
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: OFF
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47C035BA3F26B8624E9-8012
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000417885003
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 31347B62A1A216D270D-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000360928550  Dataset Number: V03935289CG 0001
   Coding: 00311220D000040000001000
   VCID: 48C236863238B71A473-801C
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000010994973
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 917013 00  Dataset Number: V03935289AS 0001
   Coding: 0100001000400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2.rod
   VCID: 2B08690A838E7C024A1-807E
   Component: FCM MQB Low   002 0345
   Serial number: 10121810802888 Dataset Number: V03935286KS 0001
   Coding: 00000005090019CA00204F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353C4F7255CA3AF22C5-8060
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000360732917  Dataset Number: V03935289CK 0001
   Coding: 00311020DE00040000001000
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000011035074
   Coding: 090000
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     853 0879
   Serial number:                Dataset Number: V03935282VN 0001
   Coding: 02731201FF0000004111000100080A231F0500F4012004008F
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHW0172565
   Subsystem 2 - Part No SW: 5NA 919 866 BG    HW: -----------
   Component: ECE AS 2021  --- 1520
Address 80: Batt. reg. aux. accum. (A8)       Labels: None
   Part No SW: 5Q0 915 089     HW: 5Q0 915 089
   Component: FMA H46 1074
   Serial number: 770252-00021
   Coding: 2F968A00
   ASAM Dataset: EV_FMACATLVW37X 003010
   ROD: EV_FMACATLVW37X_003.rod
   VCID: 76BE887E084C71EAE5F-8022
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 04091815P10259 Dataset Number: V03935273UR 0001
   Coding: 0003070200000401002213448140A90010000E300040
   VCID: 3C2A5A5676E0EBBAD3B-8068
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481_VW37.rod
   VCID: 0052EEA65A884F5ACF3-8054
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481_VW37.rod
End----------(Elapsed Time: 02:14, VBatt start/end: 13.9V/14.5V)-----------
------------------------------5 Faults Found-------------------------------
TTT
C?ID=547002
The software update needed is a new clutch and flywheel while you are at it. Don't forget the needle bearing in the crankshaft.
Vdub
C?ID=57533
the Sportmode doesnt judder because its in mucht higher rev range, you need a new clutch and better also need the gearbox tuned with at least a modified 1>2 rev-change to approx 12-16kmh
ionicamis
Romania
C?ID=94230
i agree about the clutch but flywheel at 115k km is a bit extreme cause first gear is fine even on a ramp.
Vdub
C?ID=57533
flywheels don't go that often on a dq200
ionicamis
Romania
C?ID=94230
i found out exactly what you said by driving the car. 2nd gear clutch slip in D is just bad design. checked clutch slip history and torque reduction in ecu and there were none. so i'm thinking doing the software now can maybe postpone clutch replacement for a bit. can u help with that?
Vdub
C?ID=57533
there probably will be a tuner in Romania that can tune the DQ200 properly
Vdub
C?ID=57533
Try mcchip.dkr very good tuner in DL
