Security access required
AndreasHGW
C?ID=212944
If I want to activate the Developer mode I get this message. Is this OK? Or where can I set the security access code?ScreenHunter 04.png
What car is this? I was thinking it was likely to be Tiguan your posted here, but the part numbers don't match. That was Part No SW: 572 035 816 / Component: MU-O-ND-EU H10 2460. So either it's a different car, or you've swapped out the 5F module?
Show us an Adaptation Channel Map, with this module unlocked.
AndreasHGW
C?ID=212944
It's a VW Tiguan and I did not changed any module. I got this car directly 2024 at the official delivery center for new Volkswagen vehicles in Wolfsburg.
Eric
HC800000
See the [EXTD] in front of the adaptation channel name? That means it's locked behind an Extended SFD token, which you normally can't get (at least not by legal 3rd party scan tools or ODIS-S). Other special SFD1 tokens can be SUSR (SuperUser), EPTI (emissions testing), PROD (production) and OTA (Over The Air update).
Rocky53
England
C?ID=565102
MIB3 Service Mode:
Press and hold "menu"
AndreasHGW
C?ID=212944
What does that mean?
It means you can't modify that channel because the tokens that VW is willing to give us do not have sufficient privileges to do so. They only give us regular "Service" tokens. You would need a token with "Extended" privileges in order to modify that channel.
