- Aug 2, 2026
- 6
- 2
- Bellville, OH, USA
- C?ID=635186
Hello everyone,
I'm hoping someone can help me recover the coding on my ABS module.
Vehicle:
ABS Module
A while back I attempted a cluster swap. Unfortunately I made the mistake of leaving the battery connected with the key on during the process.
After reinstalling my original cluster, the ABS module coding was gone and now shows all zeros.
The original cluster is back in the vehicle.
The ABS module communicates normally in VCDS.
I have tried several coding strings generated from VIN/equipment information.
With ignition on I receive:
With the engine running I receive:
I'm hoping someone can either:
I've attached my complete Auto-Scan.
Thank you in advance for any help.
Vehicle:
- 2011 Volkswagen Jetta SportWagen TDI
- VIN: 3VWPL7AJXBM647145
- Engine: CJAA
- Transmission: DSG
- Front brakes: 312 mm
- Rear brakes: believed to be 272 mm (factory)
- Standard cruise control (not ACC)
- Factory TPMS (indirect/ABS based)
- No trailer hitch
- No hill hold (as far as I know)
ABS Module
- Part Number: 1K0 907 379 BC
- Component: ESP MK60EC1 H30 0106
What happened
Current status
- Current coding is all zeros.
- Security Access 40168 is accepted.
- Module responds normally otherwise.
- Tried coding with:
- Ignition ON
- Engine OFF
- Also tried:
- Engine RUNNING
Coding attempts
Coding rejected
Error 31: Request out of range
Coding rejected
Error 00: Unknown (0x00)
What I'm looking for
- Generate the correct long coding for this ABS module, or
- Help determine why the module is rejecting every coding attempt.
Sunday,02,August,2026,18:31:14:35266
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4713.5
Workshop Code: 444 12345 000001
VIN: 3VWPL7AJXBM649145 License Plate: TD EYE
Mileage: 283810km-176351mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJXBM649145 Mileage: 283810km-176351miles
Part No SW: 03L 906 019 DB HW: 03L 906 019 DA
Component: R4 2,0L EDC G000AG 9971
Revision: 12H13--- Serial number:
Coding: 0050078
Shop #: WSC 23116 035 00000
VCID: 6E82120F8C9F995A2DF-803A
VINID: 0E69E070745AA1274610904414DB4365F2
000897 - Glow Plug/Heater Indicator Circuit
P0381 - 000 - Implausible Signal - Intermittent
Temperature: 6.3 C
Voltage: 10.94 V
Bin. Bits: 01000000
Torque: 219.0 Nm
Temperature: 6.3 C
Readiness: 0 0 0 0 X
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2267
Revision: 05151112 Serial number: 00001009151239
Shop #: WSC 00066 000 00000
VCID: 186E14D7DE9B37EA173-804C
17252 - Transmission Fluid Pressure Adaptation at Limit
P0868 - 001 - - Intermittent
Fault Status: 00100001
Fault Frequency: 255
Reset counter: 2
Mileage: 282022 km
Date: 2025.11.29.
Time: 15:30:19
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V1.clb
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Revision: 00H30001
Shop #: WSC 03743 444 03099
VCID: 74B60067EEB3B38ADBB-8020
Reset counter: 136
Mileage: 283475 km
Date: 2026.03.30.
Time: 08:16:22
Count: 7
Count: 13
Count: 20480
Count: 128
Count: 25344
Count: 512
01486 - System Function Test Activated
Reset counter: 108
Mileage: 282022 km
Date: 2025.11.29.
Time: 12:52:33
Count: 3
Count: 12
Count: 4096
Count: 320
Count: 41984
Reset counter: 52
Date: 2025.11.29.
Time: 12:52:34
Count: 7
Count: 12
Count: 4096
Count: 195
Count: 41728
Fault Status: 01100101
Reset counter: 52
Mileage: 282022 km
Date: 2025.11.29.
Time: 12:52:33
Count: 3
Count: 12
Count: 4096
Count: 295
Count: 41984
Reset counter: 52
Mileage: 282022 km
Date: 2025.11.29.
Time: 12:52:33
Count: 3
Count: 12
Count: 4096
Count: 270
Count: 41984
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00148
ROD: EV_ClimaBasis_VW36.rod
VCID: 75B03D63E549AA82EC5-8020
13635840 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 137
Mileage: 283507 km
Date: 2026.04.11.
Time: 00:01:08
9479441 - Control Circuit for Front Right Seat Heater
B10A5 11 [00001000] - Short to Ground
Reset counter: 112
Mileage: 282513 km
Date: 2026.01.04.
Time: 02:07:55
9479697 - Control Circuit for Front Left Seat Heater
B10A6 11 [00001000] - Short to Ground
Fault Frequency: 19
Reset counter: 135
Mileage: 282109 km
Date: 2025.12.04.
Time: 16:28:56
Part No SW: 5K0 937 084 E HW: 5K0 937 084 E
Component: BCM PQ35 B 011 0035
Revision: BG011001
Coding: 2D380E1A902F3EC400880081600000440100008C535D8560648020000040
Shop #: WSC 12345 123 61029
VCID: 3436C067AE33F38A1BB-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 17111 21 0512
Coding: 009795
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 137
Mileage: 283507 km
Date: 2026.04.11.
Time: 04:29:09
Term 15 Off
Voltage: 9.15 V
Fault Frequency: 15
Reset counter: 137
Mileage: 282453 km
Date: 2025.12.27.
Time: 21:54:04
Voltage: 10.10 V
Reset counter: 137
Mileage: 283507 km
Date: 2026.04.11.
Time: 00:00:30
Term 15 Off
Voltage: 5.95 V
Reset counter: 111
Mileage: 283819 km
Date: 2026.08.02.
Time: 18:03:33
Voltage: 11.75 V
Fault Status: 00101010
Fault Frequency: 67
Reset counter: 150
Mileage: 282022 km
Date: 2025.11.29.
Time: 15:30:25
Voltage: 13.95 V
Fault Frequency: 64
Reset counter: 150
Mileage: 282022 km
Date: 2025.11.29.
Time: 15:30:25
Voltage: 14.05 V
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R014EP4 Dataset Number: 1KM003v__B_ 0027
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3928F15389D10EE2C8D-806C
Seat occupant detection:
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0005GZEG00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME241A6257ZZZU
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME193A6257ZZZ.
Serial number: 3511HSME47336324ZZZD
Serial number: 3521HSME7D286324ZZZR
Serial number: 35527SME5A0B4B23ZZZM
Serial number: 35627SME5C094C23ZZZO
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [10001000] - Open or Short to Ground
Mileage: 282475 km
Date: 2026.01.02.
Time: 23:16:06
B10B4 00 [00001000] - Function Restriction due to Undervoltage
Reset counter: 137
Mileage: 283507 km
Date: 2026.04.11.
Time: 01:26:05
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JJ5000W5 Dataset Number: 5K0953507AH D005
Coding: 1882140000
ROD: EV_SMLSNGKUDS_A05_VW32.rod
VCID: 76B23A6FF84FA19AE5F-8022
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Serial number: 0084550
Coding: 820000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
Reset counter: 137
136194 - Supply voltage
Reset counter: 137
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H23 0206
Revision: X0023007 Serial number:
Coding: 270E01
ASAM Dataset: EV_KombiUDSMM9RM10 A04203
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 2F3CCF0B4795D052669-807A
[Supply voltage too low]
Reset counter: 137
Mileage: 283508 km
Date: 2026.04.11.
Time: 14:17:19
Reset counter: 137
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Steuerger t f r Komfortsysteme: keine Kommunikation]
Reset counter: 142
Mileage: 282626 km
Date: 2026.01.09.
Time: 03:33:50
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 14111001211156
Coding: ED807F0600160200002002
VCID: 6D80150381996242145-8038
Reset counter: 137
Mileage: 283508 km
Date: 2026.04.11.
Time: 17:54:09
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RACYW06
Coding: 0000002
VCID: 7EA2224FDCFFE9DABDF-802A
Part No SW: 5K0 953 234 HW: 5K0 920 971 C
Component: IMMO H23 0206
ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
VCID: 6A8A1E1FBCF7757A717-803E
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001503959
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide.rod
VCID: 270C272B6F658812AE9-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005193123
Coding: 000490
65793 - Supply voltage
[Front DCU undervoltage]
Reset counter: 137
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3138C9735D21C6A270D-8064
Fault Status: 11100101
Mileage: 282022 km
Date: 2025.11.29.
Time: 12:52:34
Battery Volts: 11.8 V
DD
Temperature: 18.0 C
Count: 3
Steering Angle: 0.00
Count: 1
SteerAng n.Init
00750 - Warning Lamp
Fault Status: 00101101
Voltage: 9.75 V
PD
Temperature: 24.0 C
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001481788
Coding: 0004B4
ROD: EV_DCU52BrosePasseSide.rod
VCID: 280E2417627B876AA73-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005191940
Coding: 000490
B11EC 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 115
Reset counter: 137
131584 - Motor for Rear Window Regulator
B11EE 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 138
Mileage: 283513 km
Date: 2026.05.12.
Time: 17:17:20
131585 - Motor for Rear Window Regulator
B11EE 01 [00001000] - Electrical Failure
Reset counter: 137
Mileage: 283513 km
Date: 2026.05.12.
Time: 17:17:21
Address 56: Radio Labels:
VCID: 55F05DE30C09CA82CC5-FFFE
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668526161 Dataset Number: 7P6035730C 0001
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 323AC67F54A7FDBA097-8066
B104F 13 [00001001] - Short to GND
Reset counter: 111
Mileage: 282022 km
Date: 2025.11.29.
Time: 12:52:36
B104E 13 [00001001] - Short to GND
Reset counter: 52
Mileage: 282022 km
Date: 2025.11.29.
Time: 12:52:36
End----(Elapsed Time: 01:33, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
------------------------------37 Faults Found-------------------------
