SFD unlock token retrieval falis , error TR-1
AndreasHGW
C?ID=212944
Hello
I tried to unlock the SFD within the 19-CAN Gateway, but it does not work.
I get an error message SFD unlock token retrieval falis , error TR-1
What is the reason? Did I something wrong?
Eric
HC800000
Please post the SFDLog.csv . How is your laptop connected to the internet?
AndreasHGW
C?ID=212944
My laptop is connected via Wifi to the internet.
Here is my SFD log
,,,Start SFD Session,Tuesday,04,August,2026,08:47:28,H18-001742,SFD session start successful
WVGZZZCT6RW026xxx,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08:52:45,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW026xxx,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08:52:52,H18-001742,SFD unlock token retrieval fail, error TR-1
WVGZZZCT6RW026xxx,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08:56:20,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW026xxx,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08:56:22,H18-001742,SFD unlock token retrieval success, 852 bytes
WVGZZZCT6RW026xxx,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08:56:22,H18-001742,SFD unlock token transmit fail, error TT-30
Eric
HC800000
It's possible there was a momentary glitch on your first attempt, or that your wifi connection took too long to transmit and retrieve; what's sure is that VCDS timed out after 7 seconds waiting for the token. In addition, your PC time is off by several seconds, as our server indicates your first and second tokens were sent at 08:52:37 and 08:56:07 your time, respectively, which is before the challenges could be retrieved in your SFDLog. Because of this, I cannot tell what the latency of your connection is.
The second attempt failed because the server sent two tokens but your interface only saw the second one. At that point, you have to restart the SFD session, as server and interface are out of sync (that's the cause of the error TT-30). On the bright side, you got your second token within two seconds, which is well within the VCDS receive window of 6-7 seconds.
This is what a normal SFD session looks like in SFDLog:
WA124BGF9SA020645,,,Start SFD Session,Tuesday,04,August,2026,12:49:14,HN0-000104,SFD session start successful
WA124BGF9SA020645,Address 0x19,85F 907 468 F,Online SFD,Tuesday,04,August,2026,12:49:21,HN0-000104,SFD challenge retrieval success, 583 bytes
WA124BGF9SA020645,Address 0x19,85F 907 468 F,Online SFD,Tuesday,04,August,2026,12:49:23,HN0-000104,SFD unlock token retrieval success, 532 bytes
WA124BGF9SA020645,Address 0x19,85F 907 468 F,Online SFD,Tuesday,04,August,2026,12:49:23,HN0-000104,SFD unlock token transmitted to controller
WA124BGF9SA020645,Address 0x19,85F 907 468 F,Online SFD,Tuesday,04,August,2026,12:49:23,HN0-000104,Unlock_successful
WA124BGF9SA020645,Address 0x19,85F 907 468 F,Online SFD,Tuesday,04,August,2026,12:49:24,HN0-000104,Diagnostic filter deactivated
WA124BGF9SA020645,Address 0x09,V04 007 000 PK,Online SFD,Tuesday,04,August,2026,12:49:51,HN0-000104,SFD challenge retrieval success, 583 bytes
WA124BGF9SA020645,Address 0x09,V04 007 000 PK,Online SFD,Tuesday,04,August,2026,12:49:53,HN0-000104,SFD unlock token retrieval success, 532 bytes
WA124BGF9SA020645,Address 0x09,V04 007 000 PK,Online SFD,Tuesday,04,August,2026,12:49:53,HN0-000104,SFD unlock token transmitted to controller
WA124BGF9SA020645,Address 0x09,V04 007 000 PK,Online SFD,Tuesday,04,August,2026,12:49:54,HN0-000104,Unlock_successful
WA124BGF9SA020645,Address 0x29,95C 941 591 AE,Online SFD,Tuesday,04,August,2026,12:50:17,HN0-000104,SFD challenge retrieval success, 583 bytes
WA124BGF9SA020645,Address 0x29,95C 941 591 AE,Online SFD,Tuesday,04,August,2026,12:50:19,HN0-000104,SFD unlock token retrieval success, 852 bytes
WA124BGF9SA020645,Address 0x29,95C 941 591 AE,Online SFD,Tuesday,04,August,2026,12:50:19,HN0-000104,SFD unlock token transmitted to controller
WA124BGF9SA020645,Address 0x29,95C 941 591 AE,Online SFD,Tuesday,04,August,2026,12:50:21,HN0-000104,Unlock_successful
WA124BGF9SA020645,Address 0x8C,0Z3 909 107 S,Online SFD,Tuesday,04,August,2026,12:50:45,HN0-000104,SFD challenge retrieval success, 583 bytes
WA124BGF9SA020645,Address 0x8C,0Z3 909 107 S,Online SFD,Tuesday,04,August,2026,12:50:46,HN0-000104,SFD unlock token retrieval success, 852 bytes
WA124BGF9SA020645,Address 0x8C,0Z3 909 107 S,Online SFD,Tuesday,04,August,2026,12:50:47,HN0-000104,SFD unlock token transmitted to controller
WA124BGF9SA020645,Address 0x8C,0Z3 909 107 S,Online SFD,Tuesday,04,August,2026,12:50:48,HN0-000104,Unlock_successful
and on our server:
Notice how the timestamps match within one second between VCDS token retrieval and server request. That's also with a laptop on wifi, inside the car, on the driveway.
Eric
HC800000
PS: If you update to VCDS 26.7.2 for your next attempt, it should auto-disable the diagnostic filter for you.
AndreasHGW
C?ID=212944
AndreasHGW
C?ID=212944
Thanks, I have updated the software.
Now I'm able to unlock the SFD. But maybe there is still a problem with the diagnostic filter. Or is this message OK?ScreenHunter 03.png
AndreasHGW
C?ID=212944
And if I have a look in the error log I can see this. Is this because of the auto-disable the diagnostic filter?
8417280 - Diagnostic Filter
U17A0 00 [00101111] - Not Activated
[Filter_is_not_active]
Mileage: 25097 km
Date: 2026.08.05
Time: 08:49:47
AndreasHGW
C?ID=212944
Wednesday,05,August,2026,08:53:10:20132
VCDS Version: 26.7.2.1 (x64)  HEX-V2 CB: 0.4713.5
Data version: 20260708 DS378.0
VIN: VIN: xxxx    License Plate: xxxxx
Mileage: 25097km-15594mi   Repair Order:
Chassis Type: CT-VW38P PA* (5QS)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 4B 52 5F 61
          69 6C 75 82 A5 BB BC C4 CC D1 D6 D7 D8 D9 DE 8107 8109 810A 810B 810C
          8117 81D0 C002 C003
VIN: xxxx   Mileage: 25097km-15594miles
C4-DC/DC Converter -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
D1-Disp/Oper. unit Front Center -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D8-LED HeadL. Pwr Left -- Status: Malfunction 0010
D9-LED HeadL. Pwr Right -- Status: OK 0000
8107-Antenna -- Status: OK 0000
8109-Close Rge Radar 1 -- Status: OK 0000
810A-Close Rge Radar 2 -- Status: OK 0000
810B-Close Rge Radar 3 -- Status: OK 0000
810C-Close Rge Radar 4 -- Status: Malfunction 0010
8117-Rear surroundings cam -- Status: Malfunction 0010
81D0-Digit. Matrix Light -- Status: OK 0000
Address 01: Engine (J623-DXDB)       Labels: Redir Fail!
   Part No SW: 05E 906 019 ED    HW: 05E 907 309 CA
   Component: R4 1.5l TFS   H80 4181
   Revision: KNH80000    Dataset Number: V03935404LB 0001 CVN: 71D78490
   Coding: 0125003223741D0870086000001000000000000000000000
   Shop #: WSC 99999 999 2097151
   ASAM Dataset: EV_ECM15TFS01105E906019ED 001006
   ROD: EV_ECM15TFS01105E906019BD_VW38P.rod
   VCID: 6C85093BF60F1D2A12A-8038 SFD+SFD2 [x]
   VINID: 9E65EAAAA4E41A29C008618914C83A7977
   Radiator shutter:
   Subsystem 1 - Part No SW: 5QS 965 501 E    HW: 5QS 965 501 E
   Component: V544_SAB_XS_1  H03 0003
   Serial number: 20240228060506056625
   Active oil separating system:
23765 - Control unit for information electronics 1
          U1054 00 [00100100] - No Communication
          [Information electronics control module 1No Communication]
                    Mileage: 25097 km
                    Date: 2026.08.03
                    Time: 20:29:14
                    Engine speed: 0.00 /min
                    Coolant temperature: 23 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 11.880 V
                    Outside temperature: 23 °C
                    Absolute intake pressure: 101 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 34.6 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off: False result
                    Overrun cut-off-Test_Program_B TRUE UBYTE: 0
   Part No SW: 0GC 906 556 AR    HW: 0GC 300 058 H
   Component: GSG DQ381     H06 0661
   CVN: FA7D0A2A
   ASAM Dataset: EV_TCMDQ381064 001011
   ROD: EV_TCMDQ381064.rod
   VCID: 0C4569BBD6CFBD2AB2A-8058 SFD [x]
   Parking lock:
   Subsystem 1 - Part No SW: 5QS 907 483 A    HW: 5QS 907 483
   Component: SB_Auto        H02 0060
   Serial number: 9126879000338002
   MTF pump:
   Subsystem 2 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700006438079
Address 03: ABS Brakes (J104)       Labels: 3WA-614-517-V1.clb
   Part No SW: 3WA 614 517 AL    HW: 3WA 614 517 E
   Component: EBC470IESCH08 0390
   Serial number: 0000000         Dataset Number: V03935469XB 0001 CVN: AA7F52
   Coding: 2C185124C49C399E410799AC9EB7010C0583952149A8
   ASAM Dataset: EV_Brake1ZFESCEPBMQB48W 002068
   ROD: EV_Brake1ZFESCEPBMQB48W_002.rod
   VCID: 107D7DCBBAE799CA4E2-8044 SFD+SFD2 [x]
593168 - Development code 1
          B2F01 00 [00100000] - -
          [HMS_INCONSISTENCY_PA]
82320 - Diagnostic Gateway Module
          U0447 00 [00100000] - Implausible Signal
          [MSG_MOTOR_55_TS_STATUS_MOMRAD_IST_QM_FEHLERFREI]
                    Fault Frequency: 53
                    Reset counter: 37
                    Mileage: 22717 km
                    Date: 2026.05.26
                    Time: 11:15:47
70000 - No Communications with Parking Assist Control Module A
          U0159 00 [00100000] - -
          [MSG_PARKEN_01_TIMEOUT]
70032 - Rear View Camera System Control Module
          U104C 00 [00101000] - No communication
          [MSG_REAR_VIEW_05_TIMEOUT]
                    Fault Frequency: 40
                    Mileage: 22742 km
                    Date: 2026.05.30
                    Time: 09:04:13
590992 - Delay Function
          C11EE 00 [00101000] - -
          [VZM_INCONSISTENCY_CAMERA]
                    Fault Frequency: 40
                    Mileage: 22742 km
                    Date: 2026.05.30
                    Time: 09:04:13
590848 - Delay Function
          C11EE 00 [00100000] - -
          [VZM_INCONSISTENCY_PARKING_SYSTEMS]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 AC    HW: 5WA 959 436 M
   Component: Kessy IOBOX   122 0771
   Serial number: --------------- Dataset Number: V03935394SD 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w_005_VW38.rod
   VCID: 15730CDF85057CE21D4-8040
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 3WA 907 007 F    HW: 3WA 907 007
   Component: Climatronic   H01 5089
   Serial number: 221122301133360 Dataset Number: V03935469UG 0001
   Coding: 622000010211120010000000101011110000132100200000000000000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002062
   ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
   VCID: 48CD95AB8237110A562-801C SFD+SFD2 [x]
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002030424015002517
   Air quality sensor:
   Subsystem 2 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000003139753
   Subsystem 3 - Part No SW: 11A 907 049     HW: 11A 907 049
   Component: E265 KPH       H02 0183
   Serial number: G07S03.04.2400971988
329475 - Motor for Fresh Air / Recirculated Air Flap
          B108B 13 [01101100] - Open Circuit
                    Fault Frequency: 46
                    Mileage: 22727 km
                    Date: 2026.05.27
                    Time: 09:51:15
                    Voltage terminal 30: 11.70 V
                    Inside temperature: 0.00 °C
                    Outside temperature: 17.00 °C
                    Fresh air/recirculating air/back pressure door specified value: 632
                    Actual value for fresh air/recirculation air flow flap: 848
                    Actual value for fresh air/recirculation air flow flap: 99.0 %
590082 - Control Circuit for A/C Compressor
          B10A9 15 [00100000] - Open or Short to Plus
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [01101000] - -
                    Fault Frequency: 26
                    Reset counter: 39
                    Mileage: 22740 km
                    Date: 2026.05.29
                    Time: 09:53:25
                    Voltage terminal 30: 14.30 V
                    Compressor shut-off condition: Engine stop active in Start/Stop mode
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 084 AE    HW: 5WA 937 084 P
   Component: BCM37w_H      H26 0326
   Serial number: 051024106002910 Dataset Number: V03935461FH 0001
   ASAM Dataset: EV_BCMwBL 004001
   ROD: EV_BCMwBL_004.rod
   VCID: 127977C3B4EB6BDA786-8046 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 571 955 113     HW: 571 955 113
   Component: WISCHER_MYJTL  006 0093
   Serial number: VZ1SKA07042442005700
   Subsystem 2 - Part No SW: 85E 955 555 A    HW: 85E 955 555
   Component: G397_RLFSS     H09 0009
   Serial number: 40030132X85E955555A0
   Subsystem 3 - Part No SW: 571 941 633 A    HW: 571 941 633 A
   Component: E1 - LiAM      H05 0070
   Serial number:  07S09.04.2426791317
   Subsystem 4 - Part No SW: 571 959 561     HW: 571 959 561
   Component: -VW----LINDA-  504 0831
   Serial number: SYLLND14042400020746
   Left taillight 1:
   Subsystem 5 - Part No SW: 571 945 423     HW: 571 945 423
   Component: SHL_li1        H05 0051
   Serial number: ZYWX6E02DB40027D06K3
   Left taillight 2:
   Subsystem 6 - Part No SW: 571 945 429     HW: 571 945 429
   Component: SHL_li2        H05 0053
   Serial number: ZXFU6EPEDJ5108BB063B
   Right taillight 1:
   Subsystem 7 - Part No SW: 571 945 424     HW: 571 945 424
   Component: SHL_re1        H05 0051
   Serial number: ZYWY6E02UF40017D06K3
   Right taillight 2:
   Subsystem 8 - Part No SW: 571 945 430     HW: 571 945 430
   Component: SHL_re2        H05 0053
   Serial number: ZXFV6EP5GK5101BB063B
947214 - Windshield Wiper Motor; Driver Side
          B1390 04 [01101000] - Internal System Fault
                    Reset counter: 39
                    Mileage: 25003 km
                    Date: 2026.08.01
                    Time: 10:17:20
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Engine run: OFF
                    Status drive readiness: not ready to drive
                    Status of brake lamp switch: discrete: On
                    Brake lamp switch via CAN: status: On
                    Operating State: Normal mode
                    Voltage: 13.30 V
                    Outside temperature: 28.00 °C
                    Light switch position: automatic
15401472 - Secure Onboard Communication
          U14FF 00 [00101100] - Signature Generation Failed
          [Sichere on-board Kommunikation: Signaturerstellung fehlgeschlagen]
                    Fault Frequency: 128
                    Mileage: 25097 km
                    Date: 2026.08.04
                    Time: 09:06:29
                    Terminal 15 status: OFF
                    Engine run: On
                    Voltage: 13.00 V
                    Outside temperature: 21.00 °C
   Part No SW: 5QS 919 300 B    HW: 5QS 919 300
   Component: IPA 12ch high H01 0179
   Serial number: 000026032494630 Dataset Number: V03935448JG 0001
   Coding: 8A10026111
   ASAM Dataset: EV_EPHBO3CVW3360000 001014
   ROD: EV_EPHBO3CVW3360000_VW42.rod
   VCID: 51FBB8CF716DD0C201C-8004
1114113 - Driver Assistance Systems Audio Output
          B1AE2 F0 [00101100] - Infotainment System; Implausible Signal
          [sound_output_MIB_totally_disturbed]
                    Reset counter: 38
                    Mileage: 25097 km
                    Date: 2026.08.03
                    Time: 20:29:15
12587143 - Databus
          U1121 00 [00101100] - Missing Message
          [MIB - MainUnit_01 - kein Signal/keine Kommunikation]
                    Reset counter: 38
                    Mileage: 25097 km
                    Date: 2026.08.03
                    Time: 20:29:14
13640960 - Implausible Data Received from ESP Control Module
          U0416 00 [00100000] - -
          [Rollrichtung unplausible Werte]
13640962 - Implausible Data Received from ESP Control Module
          U0416 00 [01100000] - -
          [Wegimpulszähler unplausible Werte]
13640965 - Control Module for Parking Aid
          B1B17 06 [01101101] - Algorithm Failure
          [Program flow SW error]
   Part No SW: 1N3 907 567 D    HW: 1N3 907 819
   Component: ACC Bosch MQB H02 0436
   Dataset Number: V03935485SA 0001
   Coding: 0E8930EF4071404040020008000040C0010020008004000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW412 002016
   ROD: EV_FRONTRADARBOSCHVW412_002_VW41.rod
   VCID: 382DE56BF2D7618A262-806C SFD+SFD2 [x]
0322 - Databus
          U1122 00 [00101000] - Implausible Message
          [FAULT_SWA_MODE_SYSTEM_NOT_AVAILABLE]
                    Fault Frequency: 27
                    Mileage: 22742 km
                    Date: 2026.05.30
                    Time: 09:04:14
                    Outside temperature: 16.00 °C
                    Control Module temperature: 16 °C
                    Voltage terminal 30: 12.8 V
                    Vehicle speed: -0.00 m/s
                    Longitudinal acceleration: -0.00 m/s²
                    Adaptive distance regulation: status: initialized
                    kilometer reading: 22742 km
                    Monitoring_debug_information: 00 00 00 00 00 00 00 00
                    Event_Id: 02 30
0790 - Databus
          [FAULT_RB_PER_HV_SERVICE_OOS]
                    Reset counter: 27
                    Mileage: 23854 km
                    Date: 2026.06.24
                    Time: 15:52:19
                    Outside temperature: 43.00 °C
                    Control Module temperature: 52 °C
                    kilometer reading: 23854 km
                    Event_Id: 01 F3
1127 - Databus
          U1121 00 [00101000] - Missing Message
          [FAULT_TIMEOUT_PSD_04]
                    Mileage: 25097 km
                    Date: 2026.08.03
                    Time: 20:29:14
                    Outside temperature: 23.00 °C
                    Control Module temperature: 36 °C
                    Voltage terminal 30: 11.6 V
                    Adaptive distance regulation: status: Readiness
                    kilometer reading: 25097 km
                    Event_Id: 01 2E
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Mileage: 25097 km
                    Date: 2026.08.03
                    Time: 20:29:14
                    Voltage terminal 30: 11.5 V
                    Event_Id: 01 2F
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Mileage: 25097 km
                    Date: 2026.08.03
                    Time: 20:29:14
                    Event_Id: 01 30
2065 - Databus
          [FAULT_TSK_HANDSHAKE]
                    Reset counter: 27
                    Mileage: 23854 km
                    Date: 2026.06.24
                    Time: 15:52:19
                    Voltage terminal 30: 12.6 V
                    Adaptive distance regulation: status: Reversible error
                    Event_Id: 02 3A
Address 15: Airbags (J234)       Labels:| 5QS-959-655.clb
   Part No SW: 5QS 959 655 AA    HW: 5QS 959 655 B
   Component: AirbagVW50    004 0131
   Serial number: 000000003C0N0RB Dataset Number: V03935458WK 0001
   Coding: 88FC008000F0C000000000400000000051540000A1540000C000F680002B00A7
   ASAM Dataset: EV_AirbaVW50SMEVW49X 001014
   ROD: EV_AirbaVW50SMEVW49X.rod
   VCID: 22192703444B1B5AE86-8076 SFD+SFD2 [x]
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 85E 980 945 B    HW: 85E 980 945 B
   Component: BeltPretRevFL  005 0052
   Serial number: 00E22024095060100000
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 85E 980 946 B    HW: 85E 980 946 B
   Component: BeltPretRevFR  005 0052
   Serial number: 00E22024095015800000
   Subsystem 3 - Part No SW: -----------    HW: 480 001 502 18
   Serial number: 35700008D38904786F50
   Subsystem 4 - Part No SW: -----------    HW: 480 000 803 18
   Serial number: 3580000FE4854B5F4610
   Subsystem 5 - Part No SW: -----------    HW: 480 050 504 18
   Component: SideSensor_Dr  000 0189
   Serial number: 3510000C8CF3ED592860
   Subsystem 6 - Part No SW: -----------    HW: 480 050 504 18
   Component: SideSensor_Pr  000 0189
   Serial number: 3520000C6CF3ED52C760
   Subsystem 7 - Part No SW: -----------    HW: 480 050 E03 18
   Component: FrontSensor_D  000 014A
   Serial number: 3550000BAD1F284A6490
   Subsystem 8 - Part No SW: -----------    HW: 480 050 E03 18
   Component: FrontSensor_P  000 014A
   Serial number: 356000098CEFB4520B40
Address 16: Steering wheel (J527)       Labels: 1EE-953-507.clb
   Part No SW: 1EE 953 507 N    HW: 1EE 953 507 N
   Component: GSMMEB        005 0066
   Serial number: 000000110424260
   ASAM Dataset: EV_SMLSKLOGEN2 009005
   ROD: EV_SMLSKLOGEN2_009_VWE3.rod
   VCID: 46D19B938823077AA4E-8012 SFD [x]
131396 - Databus
          U1121 00 [00100000] - Missing Message
          [Getriebe_16_no_communication]
   Part No SW: 571 920 340 A    HW: 571 920 340
   Component: KOMBI         304 9460
   Dataset Number: V03935429DR 0001
   Coding: 042400406B9C00080180620B2000080810385C0800
   ASAM Dataset: EV_DashBoardVDDMQB37W 005050
   ROD: EV_DashBoardVDDMQB37W_005_VW42.rod
   VCID: 107D7DCBBAE799CA4E2-8044 SFD [x]
16777018 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 6
                    Mileage: 24841 km
                    Date: 2026.07.24
                    Time: 08:37:56
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 6
                    Mileage: 24841 km
                    Date: 2026.07.24
                    Time: 08:37:56
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 6
                    Mileage: 24841 km
                    Date: 2026.07.24
                    Time: 08:37:56
8667138 - Distance
          U197A 00 [00001000] - Plausibility Check
          [Wegstrecke Plausibilisierung ist fehlerhaft]
                    Fault Frequency: 28
                    Reset counter: 6
                    Mileage: 22932 km
                    Date: 2026.06.06
                    Time: 09:01:11
   Part No SW: 5QS 907 530 B    HW: 5QS 907 530
   Component: GW MQB 23     005 3093
   Serial number: SMERBG110324007 Dataset Number: V03935467YE 0001
   Coding: 000000000000000000000000000000000000000000000300030000000000000000000000000000000000000000000000
   GVL: 3D08000002E8C28C80408042C80020400C186002007C00020200000000000054
   ASAM Dataset: EV_GatewMQBwBL 001018
   ROD: EV_GatewMQBwBL_VW41.rod
   VCID: 53F7B2C74B71A2D2330-8006 SFD+SFD2 [ ]
   Subsystem 1 - Part No SW: 5QS 915 181     HW: 5QS 915 181
   Component: J367-BDMHella  H01 2362
   Serial number: 0704434106
   Subsystem 2 - Part No SW: 571 959 442 B    HW: 571 959 442 B
   Component: E221__MFL-PR6  H07 0130
   Serial number: PR6-0440066143233623
   Subsystem 3 - Part No SW: 3G0 959 542 B    HW: 3G0 959 542 B
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230500409574
8 Faults Found:
1049252 - Ethernet Databus Branch 4
          U122F 00 [00100000] - No Communication
          [Ethernet_databus_no_communication_branch_4_/_port_5]
                    Reset counter: 27
                    Mileage: 24167 km
                    Date: 2026.07.01
                    Time: 09:46:59
2502759 - Ethernet Module for Emergency Call
          U1642 00 [00101000] - No Communication
          [Emergency-call_module_no_communication_vlan]
                    Reset counter: 27
                    Mileage: 24167 km
                    Date: 2026.07.01
                    Time: 09:46:54
2097338 - Ethernet Antenna Module
          U1646 00 [00101000] - No Communication
          [Antenna_control_module_1_no_communication_vlan]
                    Reset counter: 27
                    Mileage: 24167 km
                    Date: 2026.07.01
                    Time: 09:46:59
8397579 - 12V Battery
          U183C 00 [00101000] - Discharged
          [12V_battery_empty]
                    Reset counter: 27
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 18:46:27
                    Specified voltage: 10.6 V
                    Generator actual voltage: 8.0 V
                    Voltage difference generator battery: 0.0 V
                    Generator speed: 0 /min
                    Generator chip temperature: -40 °C
                    Mileage: 25097 km
                    Date: 2026.08.05
                    Time: 08:49:47
8450315 - Predictive Route Data
          B1630 02 [00100000] - Signal Failure
          [PSD_GW_message_order_inconsistent]
                    Mileage: 24699 km
                    Date: 2026.07.19
                    Time: 10:22:38
          B184C 00 [00100111] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Mileage: 25097 km
                    Date: 2026.08.05
                    Time: 08:49:47
1048996 - Ethernet Databus Branch 4
          U11BE 00 [00100000] - Electrical Malfunction
          [Ethernet_databus_electric_fault_branch_4_/_port_5]
   Part No SW: 3WA 909 059 R    HW: 3WA 909 059 B
   Component: EBB-ZF-Gen1   H06 0486
   Serial number: 6100014         Dataset Number: V03935476RL 0001
   Coding: 601010200080E8
   ASAM Dataset: EV_BrakeBoostZFMQB48W 001072
   ROD: EV_BrakeBoostZFMQB48W_001.rod
   VCID: 5DE354FF3DB564A2954-8008 SFD+SFD2 [x]
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000092736002 Dataset Number: V03935396MA 0001
   Coding: 8820000000000000
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 084D55ABC2B7D10A962-805C SFD+SFD2 [x]
   Part No SW: 3WA 959 593 A    HW: 3WA 959 593
   Component: TSG FS        001 0222
   Serial number: YG007XB704326   Dataset Number: V03935447SX 0001
   Coding: 003D0320D000008102003030
   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
   ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod
   VCID: 54F5B1DB4E7FA5EA2AA-8000 SFD+SFD2 [x]
          B1487 54 [01100000] - Missing Calibration / Basic Setting
196711 - Motor for Window Regulator
          B1487 29 [01100000] - Signal Implausible
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb
   Part No SW: 5QS 907 146 D    HW: 5QS 907 146
   Component: BASGEN1MQB37  263 2122
   Serial number: 00303901 Dataset Number: V03935442GV 0001
   Coding: 00000000000001010001020101000100000001010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37_017.rod
   VCID: 58ED45EB5297818AC62-800C SFD+SFD2 [x]
   Part No SW: 5QS 907 338 D    HW: 5QS 907 338 B
   Component: FCM Baseline  019 3094
   Serial number: 780542040024074 Dataset Number: V03935445XS 0001
   Coding: 0000000009001BCA00102F11090003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiWBL 001008
   ROD: EV_MultiModulContiWBL.rod
   VCID: 5BE75AE723A16A92EB0-800E SFD [x]
13705489 - Databus
          [PSD_04 data bus missing message]
                    Mileage: 25097 km
                    Date: 2026.08.03
                    Time: 20:29:14
   Part No SW: 3WA 959 592 A    HW: 3WA 959 592
   Component: TSG BFS       001 0222
   Serial number: YG007XAK09014   Dataset Number: V03935447DS 0001
   Coding: 003D0120DC00008002003030
   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
   ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
   VCID: 53F7B2C74B71A2D2330-8006 SFD+SFD2 [x]
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 572 035 816 B    HW: 572 035 816
   Component: MU-O-ND-EU    H10 2650
   Serial number: WG8LGM050424000 Dataset Number: V03935464PG 0001
   Coding: 23360006000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 002001
   ROD: EV_MUOIMQB37w_002_VW38P.rod
   VCID: 176F06D79F094EF20F8-8042 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 14A 919 605 M    HW: 14A 919 605
   Component: ABT-E3_13      H43 4047
   Serial number: CKS00716042411531299
   Subsystem 2 - Part No: V03 959 820 GG
   Component: EUR 2024       0095
0021 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
          [Function restriction via shutoff stage Q2]
                    Fault Priority: 9
                    Reset counter: 20
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 19:11:18
Address 61: Battery Regul. (A6)       Labels: 5QA-915-107.clb
   Part No SW: 5QA 915 107 C    HW: 5QA 915 107
   Component: BMS 48V       H07 0537
   Serial number: 000000000000000
   ASAM Dataset: EV_BMSmHevGen2CATL 002020
   ROD: EV_BMSmHevGen2CATL_VW27.rod
   VCID: 41DB888FA10D204291C-8014 SFD+SFD2 [x]
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H2 907 383 D    HW: 5H2 907 383
   Component: Anhaenger     H12 0204
   Serial number: 000000000006422 Dataset Number: V03935395PE 0001
   Coding: 0100000202001200
   ASAM Dataset: EV_TrailFunctG3MPFMHella 001009
   ROD: EV_TrailFunctG3MPFMHella_VW49.rod
   VCID: 313BD84F11ADB0C261C-8064 SFD+SFD2 [x]
   Part No SW: 5QS 907 556 A    HW: 5WA 907 556 D
   Component: TV eEntry     H32 0675
   Serial number: FZ6ESP260324000 Dataset Number: V03935433SP 0001
   Coding: 0203C0003F0D3080
   ASAM Dataset: EV_CamSysTVFicosBL 001004
   ROD: EV_CamSysTVFicosBL_VW41.rod
   VCID: 5AE95FE32C9B939AF06-800E
   Front peripheral camera slave:
   Subsystem 1 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R243 UmfKamSV  H23 0070
   Serial number: FCLMAR08032401052449
   Peripheral camera slave: left:
   Subsystem 2 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R244 UmfKamSL  H23 0070
   Serial number: FCLMAR0502240109DA10
   Right peripheral camera slave:
   Subsystem 3 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R245 UmfKamSR  H23 0070
   Serial number: FCLMAR0202240106C874
   Part No SW: 571 035 284 B    HW: 571 035 284
   Component: OCUMQBW2023_H H07 0626
   Serial number: 0000000401VINV0 Dataset Number: V03935444PB 0001
   Coding: 02010601000000210000010113002607101112111012111110
   ASAM Dataset: EV_OCUMWB2023 001066
   ROD: EV_OCUMWB2023_VW42.rod
   VCID: 15730CDF85057CE21D4-8040 SFD+SFD2 [x]
7259 - Function Restricted due to Missing Message(s)
          U1111 00 [01101101] - -
          [Road Experience Management (0x5B) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Fault Frequency: 30
                    Mileage: 22742 km
                    Date: 2026.05.30
                    Time: 09:04:17
                    Voltage terminal 30: 13.0 V
7265 - Function Restricted due to Missing Message(s)
          U1111 00 [01101100] - -
          [Car2X_0x61 - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 24579 km
                    Date: 2026.07.16
                    Time: 10:05:58
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 571 919 608 A    HW: 571 919 608
   Component: HeadupDisplay H09 2417
   Dataset Number: V03935383ZD 0001
   Coding: 5700E000
   ASAM Dataset: EV_HUDMQBwBL 002013
   ROD: EV_HUDMQBwBL_002.rod
   VCID: 1F1F2EF7773936B2C78-804A SFD+SFD2 [x]
13894400 - Function limitation due to excessive temperature
          B1050 00 [00001000] - -
          [ECU_function_restriction_overtemperature]
                    Reset counter: 9
                    Mileage: 23842 km
                    Date: 2026.06.24
                    Time: 15:16:13
16776974 - Databus
          [PSD_06_communication_error_can_error_timeout]
                    Mileage: 25097 km
                    Date: 2026.08.03
                    Time: 20:29:14
16777040 - Function Restricted due to Interrupted Communications
          U1110 00 [00101111] - -
          [Navigation_0x32_timing_error_bap_timeout_heartbeat]
                    Fault Frequency: 190
                    Mileage: 22717 km
                    Date: 2026.05.26
                    Time: 10:33:03
   Part No SW: 3WA 907 217 C    HW: 3WA 907 217
   Component: MFK120        H18 1423
   Dataset Number: V03935484GU 0001
   Coding: 0005000000000000000000BAF940C00400000000206580000000FE00000038FE43F040004000000000800000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK120MAGNAMQBWB 001024
   ROD: EV_MFK120MAGNAMQBWB_001.rod
10 Faults Found:
3145845 - Databus
          [TIMEOUT_POS_GNSS_03_Status]
                    Reset counter: 11
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 20:12:22
3145846 - Databus
          [TIMEOUT_POS_GNSS_04_Guete]
                    Reset counter: 22
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 20:12:22
3145847 - Databus
          [TIMEOUT_POS_GNSS_08_Zeit]
                    Reset counter: 22
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 20:12:22
3145848 - Databus
          [TIMEOUT_POS_GNSS_10]
                    Reset counter: 22
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 20:12:22
1048909 - Databus
          [TIMEOUT_POS_GNSS_01_Ortung]
                    Reset counter: 22
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 20:12:22
1048910 - Databus
          [TIMEOUT_POS_GNSS_02_Geschw]
                    Reset counter: 22
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 20:12:22
1048913 - Databus
          [TIMEOUT_POS_GNSS_05_Position]
                    Reset counter: 22
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 20:12:22
1048914 - Databus
          [TIMEOUT_POS_GNSS_07_Sat_konf]
                    Reset counter: 22
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 20:12:22
3146032 - Databus
          U1123 00 [00101110] - Received Error Message
          [NR_RL_Blindness_ERROR]
                    Fault Frequency: 60
                    Mileage: 25097 km
                    Date: 2026.08.05
                    Time: 08:47:09
3146033 - Databus
          U1123 00 [00101111] - Received Error Message
          [NR_RS_Blindness_ERROR]
                    Fault Frequency: 80
                    Mileage: 25097 km
                    Date: 2026.08.05
                    Time: 08:47:09
Address BB: Door Rear Drv (J388)       Labels:* Redir Fail!
   Part No SW: 3WA 959 395 A    HW: 3WA 959 395
   Component: TSG HFS       001 0222
   Serial number: YG007XBP02065   Dataset Number: V03935447DU 0001
   Coding: 000801200100008100003020
   ASAM Dataset: EV_DCU4RearDriveMAXHKLO 001016
   ROD: EV_DCU4RearDriveMAXHBRO_VW42.rod
Address BC: Door Rear Pass (J389)       Labels:* Redir Fail!
   Part No SW: 3WA 959 394 A    HW: 3WA 959 394
   Component: TSG HBFS      001 0222
   Serial number: YG007XBP0380C   Dataset Number: V03935447DT 0001
   ASAM Dataset: EV_DCU4RearPasseMAXHKLO 001016
   ROD: EV_DCU4RearPasseMAXHBRO_VW42.rod
Address C4: DC/DC Converter (A7)       Labels: 5QS-959-663.clb
   Part No SW: 5QS 959 663 D    HW: 5QS 959 663 B
   Component: DCDC48VGen2.5 H19 0312
   Serial number: 202405200000000 Dataset Number: V03935415XC 0001
   ASAM Dataset: EV_DCDC48VHellaAU336 001005
   ROD: EV_DCDC48VHellaAU336_001_AU38P.rod
   VCID: 639762071BD15252A30-8036
Address CC: Starter-Generator (C29)       Labels: None
   Part No SW: 05E 903 019 K    HW: 05E 903 019 F
   Component: 48BSG_2P0_H   H12 0026
   Serial number: 917320403190022 Dataset Number: X150A000
   ASAM Dataset: EV_SGCM624323105E903019K 005001
   ROD: EV_SGCM624323105E903019K.rod
   VCID: 2B07CA273381DA125B0-807E SFD [x]
Address D1: Disp/Oper. unit Front Center (E946)       Labels: None
   Part No SW: 5QS 927 531 A    HW: 5QS 927 531 A
   Component: E946 FES 2.0  H08 0028
   Dataset Number: V03935404BN 0001
   ASAM Dataset: EV_RotarKnobMiddlBCS38xPA 002045
   ROD: EV_RotarKnobMiddlBCS38xPA.rod
   VCID: 55F34CDF4585BCE2DD4-8000 SFD+SFD2 [x]
   Part No SW: 992 941 571 AG    HW: 992 941 571 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 678F7617EFE93E727F8-8032
151552 - Control Module for Projector in Matrix Headlights
          C13CA 92 [00101000] - Performance or Incorrect Operation
          [SSL - global electrical malfunction]
                    Reset counter: 12
                    Mileage: 24838 km
                    Date: 2026.07.23
                    Time: 10:47:56
   Component: LED1R         H17 9104
   Dataset Number: V03935430AA 0001
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address D8: LED HeadL. Pwr Left (J1233)       Labels: None
   Part No SW: 9Y0 941 597 BA    HW: 9Y0 941 597 B
   Component: SSL_L         H07 0020
   Serial number: 10150036214419 Dataset Number: V03935459SK 0001
   ASAM Dataset: EV_MatriLightLHella 001010
   ROD: EV_MatriLightLHella_VW42.rod
15362094 - Reset of Control Module
          B16CE 00 [00100000] - -
          [software ECU reset]
15362098 - Video Cable
          B125C F1 [00101000] - Implausible Message
          [video in - GMSL CRC error]
                    Reset counter: 208
                    Mileage: 24838 km
                    Date: 2026.07.23
                    Time: 10:47:56
15362176 - Limp Mode
          C10CA 00 [00101000] - -
          [FailSafe active (Prefield + SSL)]
                    Reset counter: 208
                    Mileage: 24838 km
                    Date: 2026.07.23
                    Time: 10:47:56
Address D9: LED HeadL. Pwr Right (J1232)       Labels: None
   Component: SSL_R         H07 0020
   Serial number: 10150036498871 Dataset Number: V03935459SP 0001
   ASAM Dataset: EV_MatriLightRHella 001010
   ROD: EV_MatriLightRHella_VW41.rod
Address DE: Charger 1 for mobile dev (J0000)       Labels:* None
   Part No SW: 57H 035 502 B    HW: 57H 035 502
   Component: COUPLING BOX  004 0270
   Serial number: 324000000000016 Dataset Number: V03935406HY 0001
   Coding: 800000
   ASAM Dataset: EV_DualCouplBoxSK336 001006
   ROD: EV_DualCouplBoxSK336.rod
   VCID: 25133C1F5565EC628D4-8070 SFD+SFD2 [x]
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5QS 035 741 A    HW: 5QS 035 741
   Component: TrxModulHigh  H04 0610
   Dataset Number: V03935432UL 0001
   Coding: 02336001010100010000010000010100000000
   ASAM Dataset: EV_TrxMLGEMQBWBL 001026
   ROD: EV_TrxMLGEMQBWBL_VW49.rod
   VCID: 4EC1A3B36053CF3A1CE-801A SFD+SFD2 [x]
0080 - Databus
          U1121 00 [01100000] - Missing Message
          [Ethernet-Datenbus - fehlende Botschaft- Systeminfo_01]
0081 - Databus
          [Ethernet-Datenbus - fehlende Botschaft- POS_GNSS_05_Position]
0083 - Ethernet Databus
          U1541 00 [01100000] - Missing Message from Information Electronics
          [Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
Address 8109: Close Rge Radar 1 (J1088)       Labels:* None
   Part No SW: 3WA 907 541 J    HW: 95C 907 541
   Component: Nanoradar 1   H08 0138
   Serial number: 14520044305084  Dataset Number: V03935467NK 0001
   Coding: 59955A1529C405000000
   ASAM Dataset: EV_NR1HELLAVW38X 001112
   ROD: EV_NR1HELLAVW38X_001_VW38.rod
   VCID: 4FFFBEB76759C632178-801A SFD+SFD2 [x]
Address 810A: Close Rge Radar 2 (J1089)       Labels:* None
   Component: Nanoradar 2   H08 0138
   Serial number: 14520044305035  Dataset Number: V03935467NM 0001
   ASAM Dataset: EV_NR2HELLAVW38X 001112
   ROD: EV_NR2HELLAVW38X_001_VW38.rod
Address 810B: Close Rge Radar 3 (J770)       Labels:* None
   Component: Nanoradar 3   H08 0138
   Serial number: 14520044009673  Dataset Number: V03935467NN 0001
   Coding: 59565A1529C405000000
   ASAM Dataset: EV_NR3HELLAVW38X 001112
   ROD: EV_NR3HELLAVW38X_001_VW38.rod
Address 810C: Close Rge Radar 4 (J769)       Labels:* None
   Component: Nanoradar 4   H08 0138
   Serial number: 14520043834480  Dataset Number: V03935467NQ 0001
   Coding: 99696A1631C40F000000
   ASAM Dataset: EV_NR4HELLAVW38X 001112
   ROD: EV_NR4HELLAVW38X_001_VW38.rod
Address 8117: Rear surroundings cam (J772)       Labels:* None
   Part No SW: 5R3 980 568 F    HW: 1EA 980 568 B
   Component: RV eSmart     H20 0445
   Serial number: FCLK20140324000 Dataset Number: V03935461HB 0001
   Coding: 0203C400270D2080
   ASAM Dataset: EV_AVCamerRearFicosBL 004029
   ROD: EV_AVCamerRearFicosBL_004_VW49.rod
   VCID: 44D5819BBE1F356ABAA-8010 SFD+SFD2 [x]
9445394 - Image Processing
          B1B71 06 [00100100] - Algorithm Failure
          [Error in IP software]
                    Fault Frequency: 9
                    Mileage: 24838 km
                    Date: 2026.07.22
                    Time: 20:13:53
Address 81D0: Digit. Matrix Light (J1231)       Labels:* None
   Part No SW: 4KE 907 397 B    HW: 4KE 907 399 A
   Component: zDML_G2 H22 0410
   Dataset Number: V03935445WU 0001
   Coding: 0100020000000000
   ASAM Dataset: EV_DigitMatriLightVW336 003002
   ROD: EV_DigitMatriLightVW336.rod
   VCID: 49CB90AF993DE80249C-801C
1333 - Databus
          [eth message PSD_04 missing]
                    Reset counter: 6
                    Mileage: 25097 km
                    Date: 2026.08.03
                    Time: 20:29:14
1537 - Internal Fault
          B200F F1 [00001000] - -
          [SPI-communication to controllers failure]
                    Reset counter: 249
                    Mileage: 24777 km
                    Date: 2026.07.21
                    Time: 17:41:36
End----(Elapsed Time: 02:24, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------66 Faults Found------------------------------
AndreasHGW
C?ID=212944
It's a VW Tiguan and I got this car 2024 directly at the official delivery center for new Volkswagen vehicles in Wolfburg.
Eric
HC800000
You didn't post the SFDLog.csv, but the new version of VCDS should have unlocked the filter at the same time you did the SFD unlock. I think what you're trying to do in the screenshot above is to turn it back on manually, but that's the wrong channel for that, and reactivating the filter is probably not what you intended to do. The idea with 26.7.2 and newer is to unlock SFD in 19 and not have to worry about the filter, since VCDS should have given you a notice it already de-activated it for you.
AndreasHGW
C?ID=212944
here is the sfdlog
,,,Start SFD Session,Tuesday,04,August,2026,08    47    28,H18-001742,SFD session start successful
WVGZZZCT6RW026695,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08    52    45,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW026695,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08    52    52,H18-001742,SFD unlock token retrieval fail, error TR-1
WVGZZZCT6RW026695,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08    56    20,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW026695,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08    56    22,H18-001742,SFD unlock token retrieval success, 852 bytes
WVGZZZCT6RW026695,Address 0x19,5QS 907 530 B,Online SFD,Tuesday,04,August,2026,08    56    22,H18-001742,SFD unlock token transmit fail, error TT-30
,,,Start SFD Session,Wednesday,05,August,2026,08    48    56,H18-001742,SFD session start successful
WVGZZZCT6RW0xxxx5,Address 0x19,5QS 907 530 B,Online SFD,Wednesday,05,August,2026,08    49    43,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW0xxxx5,Address 0x19,5QS 907 530 B,Online SFD,Wednesday,05,August,2026,08    49    46,H18-001742,SFD unlock token retrieval success, 852 bytes
WVGZZZCT6RW0xxxx5,Address 0x19,5QS 907 530 B,Online SFD,Wednesday,05,August,2026,08    49    46,H18-001742,SFD unlock token transmitted to controller
WVGZZZCT6RW0xxxx5,Address 0x19,5QS 907 530 B,Online SFD,Wednesday,05,August,2026,08    49    47,H18-001742,Unlock_successful
WVGZZZCT6RW0xxxx5,Address 0x19,5QS 907 530 B,Online SFD,Wednesday,05,August,2026,08    49    49,H18-001742,Diagnostic filter deactivated
WVGZZZCT6RW0xxxx5,Address 0x5F,572 035 816 B,Online SFD,Wednesday,05,August,2026,08    56    53,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW0xxxx5,Address 0x5F,572 035 816 B,Online SFD,Wednesday,05,August,2026,08    56    55,H18-001742,SFD unlock token retrieval success, 852 bytes
WVGZZZCT6RW0xxxx5,Address 0x5F,572 035 816 B,Online SFD,Wednesday,05,August,2026,08    56    55,H18-001742,SFD unlock token transmitted to controller
WVGZZZCT6RW0xxxx5,Address 0x5F,572 035 816 B,Online SFD,Wednesday,05,August,2026,08    56    57,H18-001742,Unlock_successful
WVGZZZCT6RW0xxxx5,Address 0x17,571 920 340 A,Online SFD,Wednesday,05,August,2026,09    6    04,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW0xxxx5,Address 0x17,571 920 340 A,Online SFD,Wednesday,05,August,2026,09    6    07,H18-001742,SFD unlock token retrieval success, 852 bytes
WVGZZZCT6RW0xxxx5,Address 0x17,571 920 340 A,Online SFD,Wednesday,05,August,2026,09    6    07,H18-001742,SFD unlock token transmitted to controller
WVGZZZCT6RW0xxxx5,Address 0x17,571 920 340 A,Online SFD,Wednesday,05,August,2026,09    6    08,H18-001742,Unlock_successful
,,,Start SFD Session,Wednesday,05,August,2026,09    20    24,H18-001742,SFD session start successful
WVGZZZCT6RW0xxxx5,Address 0x08,3WA 907 007 F,Online SFD,Wednesday,05,August,2026,09    20    53,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW0xxxx5,Address 0x08,3WA 907 007 F,Online SFD,Wednesday,05,August,2026,09    20    55,H18-001742,SFD unlock token retrieval success, 532 bytes
WVGZZZCT6RW0xxxx5,Address 0x08,3WA 907 007 F,Online SFD,Wednesday,05,August,2026,09    20    55,H18-001742,SFD unlock token transmitted to controller
WVGZZZCT6RW0xxxx5,Address 0x08,3WA 907 007 F,Online SFD,Wednesday,05,August,2026,09    20    57,H18-001742,Unlock_successful
WVGZZZCT6RW0xxxx5,Address 0x82,571 919 608 A,Online SFD,Wednesday,05,August,2026,09    23    58,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW0xxxx5,Address 0x82,571 919 608 A,Online SFD,Wednesday,05,August,2026,09    24    00,H18-001742,SFD unlock token retrieval success, 852 bytes
WVGZZZCT6RW0xxxx5,Address 0x82,571 919 608 A,Online SFD,Wednesday,05,August,2026,09    24    00,H18-001742,SFD unlock token transmitted to controller
WVGZZZCT6RW0xxxx5,Address 0x82,571 919 608 A,Online SFD,Wednesday,05,August,2026,09    24    01,H18-001742,Unlock_successful
WVGZZZCT6RW0xxxx5,Address 0x42,3WA 959 593 A,river,  Online SFD,Wednesday,05,August,2026,09    28    22,H18-001742,SFD challenge retrieval success, 583 bytes
WVGZZZCT6RW0xxxx5,Address 0x42,3WA 959 593 A,river,  Online SFD,Wednesday,05,August,2026,09    28    28,H18-001742,SFD unlock token retrieval success, 852 bytes
WVGZZZCT6RW0xxxx5,Address 0x42,3WA 959 593 A,river,  Online SFD,Wednesday,05,August,2026,09    28    28,H18-001742,SFD unlock token transmitted to controller
WVGZZZCT6RW0xxxx5,Address 0x42,3WA 959 593 A,river,  Online SFD,Wednesday,05,August,2026,09    28    30,H18-001742,Unlock_successful
Eric
HC800000
That's your cue that VCDS deactivated the filter for you. You may have seen the adaptation screen flicker on and off, and after that VCDS checked the measuring values in the background to make sure the filter is indeed off. The red circled items are new in Beta 26.7.2:
