I'm unable to run service regeneration of particle filter on my 2012 Passat with CAYC engine. As part of my troubleshooting I am now trying to figure out the decode of the following 32 bits.
IDE00423-ENG103230 Service regeneration: Release conditions 2-Binary 32 Bit 11111101 11111110 11111111 11011111
At the moment of copying that number I am aware that many of the required conditions are not met. However, I don't have a capture from the last real attempt.
This question is not how to get the regeneration going, it is decoding those 32-bits.
Tuesday,04,August,2026,15:59:43:10174
VCDS Version: Release 26.3.0 (x64)
Address 01: Engine
Control Module Part Number: 03L 906 023 FS
Component and/or Version: R4 1.6l TDI H43 9979
Software Coding: 00194036032401080000
Work Shop Code: WSC 00015
VCID: 7CA1FE0DD6691C0A93B-8028
Advanced Identification/FAZIT
Identification: SJ8-FST
Revision: --H43---
Date: 15.04.12
Manufacturer number: 0015
Test stand number: 0197
Flash Status
Programming Attempts(application): 2/2/2
Successful Attempts(application): 2/2/2
Programming Status: 00000000
Flash Date-Workshop ID-Status:
17.11.08 00000 218 00185 (OK) | 17.11.08 00000 218 00185 (OK) | 17.11.08 00000 218 00185 (OK)
Misc.
Hardware number: 03L 907 425 C
Workshop System Name: J623
Workshop ID (Adaptation): 00000 218 00185
Workshop ID (Coding): 00000 115 00015
ASAM Dataset: EV_ECM16TDI02103L906023FS
ASAM Dataset Revision: 003015
Car Info
Chassis Number: WVWZZZ3CZDE000950
Engine code: CAYC
Immobilizer
General immobilizer info :
Life status: 4
Identity counter: 0
Brand identification: 1
Power class: 3A
Power class 2: 3A
Power class supported: 00
Count of adapted keys: 0
Count of keys to be adapted by adaptation: 0
Minutes remaining for Terminal 15 ON: 0
Configuration status: 0
Reserved: 0
Lock times in minutes :
Lock time password reset: 0
Lock time login/Terminal 15 ON: 0
Lock time key adaptation: 0
Lock time leaving key adaptation: 0
Lock time login special function: 0
Immo Challenge: 78A6D04A
VCDS Info:
Labels: 03L-907-425-V1.clb
Readiness: No script available
ROD: EV_ECM16TDI021_VW46.rod
