2009 Audi Q7 V12 6.0l Tdi active codes
Craig_Brown
South Africa
C?ID=444089
Good afternoon.
My 2009 Audi Q7 V12 6.0l Tdi has developed the following fault codes that cannot be cleared using VCDS:
Active codes that won't clear: P2463 Particulate Filter Restriction - Soot accumulation Bank 1
Active codes that won't clear: P2463 Particulate Filter Restriction - Soot accumulation Bank 1 upper limit exceeded
Sporadic code: P2453 Particulate Pressure Sensor "A" Circuit Range/Performance
Sporadic code: P2452 Particulate Pressure Sensor "A" Circuit
My question is, which Block Number do I use to diagnose the following:
DPF pressure sensor Bank 1: Block Number to read data pressure before and after DPF
DPF pressure sensor Bank 2: Block Number to read data pressure before and after DPF
Soot load DPF 1
Soot load DPF 2
The vehicle currently has 88000km on the clock and only gets used on long journeys.
Your assistance will be greatly appreciated.
Regards.
Craig Brown
Please post an Auto-Scan so we can see exactly what ECUs this car has, because I sure don't know these extremely rare ones by heart.
Craig_Brown
South Africa
C?ID=444089
Good morning Sir, South Africa time.
Will do so and revert accordingly.
Thank you for response received.
Regards.
Craig Brown
Craig_Brown
South Africa
C?ID=444089
Wednesday,05,August,2026,08:04:03:52353
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.4
VIN: WUAZZZ4LXAD004740   License Plate:
Mileage: 82990km-51567mi   Repair Order:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 08 09 0E 11 31 15 16 17 18 19 28 34 36 42 46 47
          4F 52 55 56 5F 62 65 69 6C 6D 6F 72 76
VIN: WUAZZZ4LXAD004740   Mileage: 82990km-51567miles
Address 01: Engine (CCG)       Labels: Redir Fail!
   Part No SW: 4L0 910 051 E    HW: 4L0 907 051
   Component: 6.0TDI EDC17G004AGMª0010
   Revision: 34H01---    Serial number:
   Coding: 0121002C191F09A8
   Shop #: WSC 03163 996 13764
   VCID: 25160C7459EDCE329C5-8070
   VINID: 9E546AAAA11CA115000041C4001652F92D
009315 - Particle Filter
               P2463 - 000 - Excessive Soot Accumulation - MIL ON
                    Fault Status: 11100000
                    Mileage: 82994 km
                    Date: 2026.08.04
                    Time: 12:35:00
                    (no units): 71.5
                    (no units): 22.0
                    Mileage: 60 km
                    (no units): 286.7
                    Temperature: 53.1°C
               P2463 - 001 - Excessive Soot Accumulation
                    Fault Status: 01100001
                    Mileage: 82994 km
                    Date: 2026.08.04
                    Time: 12:35:00
                    (no units): 71.5
                    (no units): 22.0
                    Mileage: 60 km
                    (no units): 286.7
                    Temperature: 53.1°C
Readiness: 1 127 1 1 1
Address 02: Auto Trans        Labels: 09E-927-156.clb
   Part No SW: 4L0 910 156 D    HW: 0BQ 927 156
   Component: AG6 0BQ 6,0 TDI RdW 0040
   Revision: --H04---    Serial number:        0000850
   Coding: 0000001
   Shop #: WSC 31414 790 00001
   VCID: 2A0CFF4830F3E14AB17-807E
   Part No SW: 4L0 910 517 G    HW: 4L0 614 517 G
   Revision: 00H30001
   Coding: 0103620
   VCID: 2E04F3580C1B8D6A6DF-807A
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601357665
   Coding: 0000147
   Subsystem 1 - Part No: 4F0 910 132 A
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220
   Component: FBSAUDIC6 IDG   H01 0054
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 C    HW: 4L0 820 043 AB
   Component: KLIMA 4 ZONEN H12 0030
   Revision: 00---017    Serial number: 00000000205975
   Coding: 04041C
   VCID: 241011705ED7373A8BB-8070
   Part No SW: 4F0 910 279 Q    HW: 4F0 907 279 A
   Component: ILM Fahrer      H25 0330
   Coding: 0135122
   VCID: 372AD63CF3414CA23E9-8062
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H12 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H48 0050
   Revision: 00000014
   VCID: 211E186441C52212E0D-8074
Address 11: Engine II        Labels: Redir Fail!
   Component: 6.0TDI EDC17G004AGSª0010
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D05ZT1I
   Coding: 0014128
   Subsystem 1 - Serial number: 6332QSME6B3100220
   Subsystem 2 - Serial number: 6342QSME07324F38I
   Subsystem 3 - Serial number: 6352QSME07324D006
   Subsystem 4 - Serial number: 6362QSME333140080
   Subsystem 5 - Serial number: 63734SME562F3024
   Subsystem 6 - Serial number: 63834SME5C2D442EF
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90025091760160
   Coding: 0112142
   VCID: 270A067C23E1DC22AE9-8072
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-KOM-V3.clb
   Part No SW: 4L0 920 931 R    HW: 4L0 920 931 R
   Component: KOMBIINSTR.   H06 0138
   Revision: 00300000    Serial number: BIV22Y679
   Coding: 2F57630401010008010800
   VCID: 3A2CCF08CC5351CAC17-806E
Address 18: Aux. Heat        Labels: 4L0-910-105.clb
   Part No SW: 4L0 910 105     HW: 4L0 815 071 F
   Component: Heizgeraet      H08 0120
   Revision: 0000000E    Serial number: 00000009014264
   Coding: 0000001
   VCID: 60985D60064F6B1AAF3-8034
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0031
   Revision: LB000027    Serial number: 2700L096298070
   Coding: 000303
   VCID: 392ED004C9555AD2C8D-806C
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140626088
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000030126120
   Coding: 0000006
   VCID: 68884540EE7F135A673-803C
Address 34: Level Control        Labels: 4L0-910-553.clb
   Part No SW: 4L0 910 553 H    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7870
   Revision: --H03001    Serial number: 15.1528-0123.2
   Coding: 0025520
   Shop #: WSC 03163 996 13762
   VCID: 2F3AEE5C0B118462669-807A
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001001310458
   Coding: 00781300000011110000
   VCID: 313EE8241125929270D-8064
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000101360623
   Coding: 011F06205E41440004
   VCID: 46D4ABF888AB252AB5F-8012
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H09 0100
   Revision: 0100 ---    Serial number: 01196197610000
   Coding: 4008185
   Shop #: WSC 03163 996 87872
   VCID: 3536DC34E94DBEB22C5-8060
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
                    Fault Status: 01101100
                    Reset counter: 1
                    Mileage: 36035 km
                    Date: 2017.04.25
                    Time: 12:07:57
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4L0 035 223 E    HW: 4L0 035 223 E
   Component: BOSE G3 AU716 H01 0100
   Revision: AH001500    Serial number: 00000000003892
   Coding: 0F000000
   Part No SW: 4F0 910 280     HW: 4F0 907 280 GA
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000000727
   Coding: 0011101
   VCID: 5EE463983C3B5DEA9DF-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000101400356
   VCID: 45D6ACF4B5AD2E32BC5-8010
   Part No: 8P0 907 357 H
   Coding: 0000008
   VCID: 3FDABE1CDB7174E2F69-806A
   Part No SW: 4F0 035 053 B    HW: 4F0 035 053
   Component: Radio U Basic H45 0020
   Revision: AB001007    Serial number: 341GK097601043
   Coding: 060003010000000000
   VCID: 1C60299066A70FFA33B-8048
   Part No SW: 4L0 035 754     HW: 4L0 035 754
   Component: H-BN-RW       H41 0047
   Revision: --------    Serial number: 487G2097504586
   Coding: 010901060004F3EF41002305FF6300030000
   VCID: 68884540E27F135A673-803C
   Subsystem 1 - Part No: 8R0 060 884 D
   Component: ROW 2009/2010  5103
   Component: DU7 High  H43 0306
   Serial number: 9356GK091031370
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 612
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001337715
   Component:   CD-Database  1293
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000101473016
   Coding: 010E04204041230004
   VCID: 43D2B2ECBB991002921-8016
Address 65: Tire Pressure        Labels: 4F0-910-273-HI.clb
   Part No SW: 4F0 910 273 C    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000900033037
   Coding: 0222725
   VCID: 2312126C57D93002F21-8076
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4L0 907 383 C    HW: 4L0 907 383 C
   Component: Anhaenger     H08 0080
   Revision: 2C002002    Serial number: 00000117138485
   Coding: 0101010000000000
   Revision: --H03---    Serial number: 525PA8-J9641ZA
   Coding: 1031001
   Part No SW: 4L0 910 945     HW: 4L0 827 851 D
   Component: ValeoHeckdeckel H29 0410
   Revision: --H29001    Serial number: 8K9827852  B
   Shop #: WSC 98765 666 38354
   VCID: 6C803950FA873F7A03B-8038
   Subsystem 3 - Serial number: RD15.07.09--H29001001C0073ÿ
   Subsystem 4 - Serial number: 1C0073ÿ
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003874099-----
   Coding: 0003587
   VCID: 26140B7824EBC52A95F-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE16_SKB09H10 0200
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE16_SKB09H10 0200
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE16_SKB09H10 0200
   Revision:             Serial number: 0000101473020
   Part No SW: 4F1 910 283 B    HW: 4F1 919 283 B
   Component: Parkhilfe 8-Kan H12 0140
   Revision: 00H12000    Serial number: 64320829000050
   Coding: 0231146
   VCID: 2410117052D7373A8BB-8070
End----------(Elapsed Time: 02:24, VBatt start/end: 12.1V/12.5V)-----------
------------------------------3 Faults Found-------------------------------
NEtech
Denmark
C?ID=56995
Soot load DPF 1
Soot load DPF 2
In [01-Engine]
DPF pressure sensor Bank 1 = 106.3
DPF pressure sensor Bank 2 = 107.3
Soot load DPF Bank 1:
109.1 Oil ash
109.2 Soot mass calculated
109.3 Soot mass measured
109.4 Km since Regen
Soot load DPF Bank 2:
110.1 Oil ash
110.2 Soot mass calculated
110.3 Soot mass measured
110.4 Km since Regen
Soot limits in MWB 113 + 114
Craig_Brown
South Africa
C?ID=444089
Good evening.
Will check and revert.
Regards.
Craig Brown.
Vdub
C?ID=57533
the faults probably will only erase if you tell it has a new dpf. You have to check if the presssure (sensors) are reading good. A broken DPF can also occur despite low mileage
Craig_Brown
South Africa
C?ID=444089
Good afternoon,
Attached are the MVB readings (ignition on, engine off) for MBs 106 – 107 and 109 – 110.
I suspect a faulty pressure sensor looking at the 106.3 and 107.3 values which has caused the ECU to measure an incorrect soot mass as seen in the wide discrepancy between readings 109.3 and 110.3?
Your thoughts would be greatly appreciated.
Regards,
Craig
Friday,07,August,2026,13:10:09:52353
                Address 01: Engine  (4L0 910 051 E)
13:09:32 Group 106
  17.7°C  Temperature
  17.7°C  Temperature
  5 mbar  Pressure
  5 mbar  Pressure
13:09:32 Group 107
  17.7°C  Temperature
  17.7°C  Temperature
  -10 mbar  Pressure
  -10 mbar  Pressure
Friday,07,August,2026,13:13:34:52353
13:13:03 Group 109
  0.19  (no units)
  22.0  (no units)
  71.5  (no units)
  60 km  Mileage
13:13:03 Group 110
  0.19  (no units)
  25.5  (no units)
  2.5  (no units)
  60 km  Mileage
