Caddy 2025 autoscan and channel maps
datodaco
Slovenia
C?ID=393757
Hi,
I am posting autoscan and measuring block and also adaptation maps for caddy model year 2025,
SFD unlocked all channels available and also (19) diagnostic firewall not active.
datodaco
Slovenia
C?ID=393757
AutoScan: WV2ZZZSK8SX116493
Monday,03,August,2026,19:50:33:29755
VCDS Version: 26.7.1.0 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260708 DS378.0
VIN: WV2ZZZSK8SX116493   License Plate:
Chassis Type: SK-VN3SP PA* (5QS)
Scan: 01 03 08 09 10 13 15 17 19 22 23 42 44 52 5F 75 A5 C002 C003
VIN: WV2ZZZSK8SX116493   Mileage: 12004km-7458miles
Address 01: Engine (J623-DXRA)       Labels: None
   Part No SW: 05L 906 023 QK    HW: 05L 907 309 AH
   Component: R4 2.0l TDI   H80 4626
   Revision: NEH80---    CVN: 520B730B10A70AD289980D21252F1ED389980D2145690194
   Coding: 011900320326050920000000001000000000000000000000
   Shop #: WSC 35110 377 00028
   ASAM Dataset: EV_ECM20TDI01105L906023QK 010005
   ROD: EV_ECM20TDI01105L906023QK.rod
   VCID: 015F832C018E49B2D05-8054 SFD+SFD2 { }
   VINID: 9E60AAAAA8DB223A010461090C6F2D7959
   Heater for exhaust gas catalytic converter:
   Flush-air pump:
   Active oil separating system:
45417 - Vehicle Key Management System (VKMS)
          U35DC 00 {00100110} - Key/Certificate Missing or Invalid
          {Vehicle Key Management System (VKMS)Key/certificate missing or invalid}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:25:34
                    Engine speed: 976.00 /min
                    Normed load value: 25.9 %
                    Coolant temperature: 90 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 13.580 V
                    Engine status: COENG_RUNNING
Address 03: ABS Brakes (J104)       Labels:. 5WA-614-517-V2.clb
   Part No SW: 5WA 614 517 DQ    HW: 5WA 614 517 BS
   Component: ESC           H31 0331
   Serial number: 61425000005066  Dataset Number: V03935455DH 0001 CVN: 0D4105EC658B97A0
   Coding: 4A985428B44B399C4001559E1EB7C1C50ACF942151A000
   ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006026
   ROD: EV_Brake1ESCMQB37WUNECE_006_VN3SP.rod
   VCID: 1A6DD4408C18FA6A31F-804E SFD+SFD2 { }
8231 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 {00100111} - -
          {CCan_Klemmen_Status_01_Counter}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:25:34
                    Vehlicle_speed: 0.0 km/h
                    Resolution Mileage: 726 m
                    Voltage_value_KL.30_ESC_V: 13.8 V
                    Wake up EPB: not active
                    Wake up CAN: not active
                    Postrun_activ: not active
                    Comparison_pressure_sensor: completed successfully
                    Comparison_longitudinal_accleration: completed successfully
                    Comparison_transverse_accleration: not completed successfully
                    Comparison_yaw_rate_sensor: not completed successfully
                    LWS_comparison: not completed successfully
                    Internal_failure_code: 00 91
                    00 02 00 00 04 0C 10 0A 40 00 00 00 80 00 00 40 30 00 21 00 04
17216 - Implausible Data Received from Body Control Module (Central Electric)
          {CCan_VLK_01_Counter}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:25:34
                    Internal_failure_code: 01 20
590080 - Release / Enable Active
          B184C 00 {00100111} - -
          {SECDIAG_ROLE_UNLOCKED}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:16:55
                    Voltage_value_KL.30_ESC_V: 12.6 V
                    Internal_failure_code: 02 94
                    00 00 00 00 04 8C 10 08 80 00 00 00 80 07 00 40 30 00 21 00 04
592192 - VKMS
          B18B0 F0 {00100110} - Missing Adaptation
          {VKMS_new_download_container_required_due_to_vehicle_change}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:25:34
                    Internal_failure_code: 02 95
                    00 02 00 00 04 0C 10 0A 40 00 00 00 80 00 00 40 34 00 21 00 04
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 727 BK    HW: 5WA 907 727 AF
   Component: AC Manuell    H01 5088
   Serial number: 217052507344450 Dataset Number: V03935452UX 0001
   Coding: 023010019211000000000000101001010000010000000000000000000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002062
   ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 CN    HW: 5WA 937 086 BJ
   Component: BCM37w_M238 0451
   Serial number: BXJ53F210525940 Dataset Number: V03935471YB 0001
   ASAM Dataset: EV_BCMwBL 004001
   ROD: EV_BCMwBL_004.rod
   VCID: 1F1BE554973A9F42C61-804A SFD+SFD2 { }
   Subsystem 1 - Part No SW: 89A 955 555 C    HW: 89A 955 555 C
   Component: G397_RLFSS     004 0008
   Serial number: TTZ53508052500024365
   Subsystem 2 - Part No SW: 5H0 941 193 AF    HW: 5H0 941 193 AF
   Component: LiSi           H04 0513
   Serial number: TW571429052500010984
   Subsystem 3 - Part No SW: 5H0 925 200 AA    HW: 5H0 925 200 AA
   Component: DiETa          H07 0008
   Serial number: 92471YED001N8
   Subsystem 4 - Part No SW: 5H0 959 561 BM    HW: 5H0 959 561 BM
   Component: -VW----LINDA-  504 0833
   Serial number: MW3LND26052500011324
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 EQ    HW: 5Q1 953 549 D
   Serial number: 00000026052508490291
   Part No SW: 5QS 919 283 A    HW: 5QS 919 283
   Component: PDC 04ch low  H01 0075
   Serial number: 000015052594630 Dataset Number: V03935457CG 0001
   Coding: 0000010001
   ASAM Dataset: EV_EPHBO14VW3360000 001010
   ROD: EV_EPHBO14VW3360000_SK49.rod
   VCID: 5AED9440CC983A6AF1F-800E
Address 13: Auto Dist. Reg (J428)       Labels:| 5WA-907-567.clb
   Part No SW: 5WA 907 567     HW: 5WA 907 819
   Component: ACC Bosch MQB H50 0576
   Dataset Number: V03935445MT 0001
   Coding: 00030205000740441257400000C000042E4030000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 005024
   ROD: EV_FRONTRADARBOSCHVW380_001.rod
   VCID: 0F7BB51447DA2FC2561-805A SFD+SFD2 {x}
0313 - ROD - Unknown Error Code
          - 00 {10101110}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:25:42
Address 15: Airbags (J234)       Labels:| 5QS-959-655.clb
   Part No SW: 5QS 959 655 S    HW: 5QS 959 655 S
   Component: AirbagVW50    004 0131
   Serial number: 000000003C0TWRD Dataset Number: V03935458VW 0001
   Coding: 88CC008000E0C000000000000000000091540000A1AA0000DC00F680002B00A7
   ASAM Dataset: EV_AirbaVW50SMEVW49X 001014
   ROD: EV_AirbaVW50SMEVW49X.rod
   VCID: 73B3D9E44B326B22D29-8026 SFD+SFD2 { }
   Seat occupancy detection 1:
   Subsystem 1 - Part No SW: 2K7 959 760 F    HW: 2K7 959 760 D
   Component: wSBR F-SG      037 0250
   Serial number:         94DC4E1D3407
   Subsystem 2 - Part No SW: -----------    HW: 480 001 405 19
   Serial number: 3570000FA6850C781260
   Subsystem 3 - Part No SW: -----------    HW: 480 001 405 19
   Serial number: 3580000FA6850C751940
   Subsystem 4 - Part No SW: -----------    HW: 480 051 105 19
   Component: SideSensor_Dr  000 0149
   Serial number: 3510000C6E1AC24E6B30
   Subsystem 5 - Part No SW: -----------    HW: 480 051 105 19
   Component: SideSensor_Pr  000 0149
   Serial number: 35200009CE19DB45E670
   Subsystem 6 - Part No SW: -----------    HW: 480 051 F07 19
   Component: FrontSensor_D  000 014A
   Serial number: 35500009CE1C520E4630
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 7 - Part No SW: -----------    HW: 480 051 105 19
   Component: Side_Sens_B_D  000 0149
   Serial number: I0P000098E1AC1932820
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 8 - Part No SW: -----------    HW: 480 051 405 19
   Component: Side_Sens_B_P  000 0149
   Serial number: I0Q0000C4E2BBDCAC550
9980928 - Release / Enable Active
          B184C 00 {00101111} - -
          {ECU unlocked}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:16:53
   Part No SW: 2K7 920 310 A    HW: 2K7 920 310
   Component: KOMBI         320 2642
   Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Dataset Number: V03935458FZ 0001
   Coding: 04A405076384000801802203000000080020180800
   ASAM Dataset: EV_DashBoardVISMQB37W 005002
   ROD: EV_DashBoardVISMQB37W_005_VN3S.rod
   VCID: 2411EAB8BE5CBC9A9B3-8070 SFD { }
16711684 - Release / Enable Active
          B184C 00 {00001001} - -
          {Unlock_protection_of_vehicle_diagnosis_active}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:16:53
8667138 - Distance
          U197A 00 {00001000} - Plausibility Check
          {mileage_error_security_AR2}
                    Reset counter: 38
                    Date: 2026.07.27
                    Time: 07:56:24
   Part No SW: 5QS 907 530 B    HW: 5QS 907 530
   Component: GW MQB 23     005 3093
   Serial number: SMERBG230525007 Dataset Number: V03935466BF 0001
   Coding: 000000000000000000000000000000000000000000000000030000000000000000000000000000000000000000000000
   GVL: 3D0000000008408C8000800048000040000040000000000000000000000000C4
   ASAM Dataset: EV_GatewMQBwBL 001018
   ROD: EV_GatewMQBwBL_VW41.rod
   VCID: 53F37964AB720B22329-8006 SFD+SFD2 { }
   Generator:
   Component: 5-00-17-01-03
   Subsystem 2 - Part No SW: 5QS 915 181     HW: 5QS 915 181
   Component: J367-BDMHella  H01 2362
   Serial number: 4931966306
   Subsystem 3 - Part No SW: 571 959 442     HW: 571 959 442
   Component: E221__MFL-PR6  H07 0130
   Serial number: PR6-0440036121250795
8482819 - Activatable Functions
          B18D3 F3 {00100111} - Faulty Vehicle Configuration
          {Fs_id_configuration_error}
                    Reset counter: 1
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 18:27:18
8417280 - Diagnostic Filter
          U17A0 00 {00101111} - Not Activated
          {Filter_is_not_active}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 18:35:08
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 18:34:37
8389392 - Control Module for Driver Assist Systems
          C12D5 87 {00100110} - Missing Message
          {FAS messsages retention time to long}
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:15:49
   Part No SW: 5WA 907 554 H    HW: 5WA 525 130
   Component: 4Motion       H66 1060
   Serial number: 000028.03.25000 Dataset Number: V03935320HN 0001
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 006001
   ROD: EV_AllWheelContrHA1VW37X_006_VW27.rod
17521 - Databus
          U1121 00 {00101111} - Missing Message
          {Getriebe - TO -- Getriebe_51_Auth}
                    Reset counter: 0
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:16:54
                    Engine speed: 0.00 /min
                    Voltage terminal 30: 12.6 V
                    Haldex clutch pump: current: 0.000 A
17523 - Databus
          {Gateway - TO -- Anhänger_01 Fehler ignorieren wenn keine AHK verbaut}
                    Reset counter: 0
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:16:54
   Part No SW: 5WA 909 059 AH    HW: 3Q0 909 059 D
   Component: EBKV          H10 0563
   Serial number: BPA085150525018 Dataset Number: V03935447DC 0001
   Coding: 5402C140700000008018638C000049922449922400
   ASAM Dataset: EV_BrakeBoostVW37WUNECE 013005
   ROD: EV_BrakeBoostVW37WUNECE_013.rod
   VCID: 1675C0707800DE0A157-8042 SFD+SFD2 { }
1024304 - Release / Enable Active
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 18:43:13
   Part No SW: 3WA 959 393 A    HW: 3WA 959 393
   Component: TSG FS        001 0222
   Serial number: Y2007YDU012C3   Dataset Number: V03935443PN 0001
   Coding: 00208320C000000100001020
   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
   ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod
   VCID: 52FD7C609468022A39F-8006 SFD+SFD2 { }
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb
   Part No SW: 5QS 907 146 D    HW: 5QS 907 146
   Component: BASGEN1MQB37  263 2122
   Serial number: 00724707 Dataset Number: V03935447B  0001
   Coding: 00000000000000000001020101000100000001010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37_017.rod
   VCID: 58E98E48B294287AC7B-800C SFD+SFD2 { }
   Part No SW: 3WA 959 392 A    HW: 3WA 959 392
   Component: TSG BFS       001 0222
   Serial number: Y2007YE1000U7   Dataset Number: V03935443PP 0001
   Coding: 00200120C000000100001020
   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
   ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
   VCID: 51FF736C916E7932005-8004 SFD+SFD2 { }
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 2K7 035 869 A    HW: 2K7 035 869 A
   Component: MU-E-D-EU     065 0176
   Serial number: VWZAZ2D0781942  Dataset Number: V03935464C  0001
   Coding: 63521006000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUEIGPMQB37w 001001
   ROD: EV_MUEIGPMQB37w_VN3SP.rod
   VCID: 34311AF80EBC2C1A0B3-8060 SFD+SFD2 { }
   Subsystem 1 - Part No SW: 5H0 919 605 G    HW: 5H0 919 605 G
   Component: ABT_W_10       H50 2115
   Serial number: APUFX728052500010820
4112 - Release / Enable Active
                    Mileage: 12004 km
                    Date: 2026.08.03
                    Time: 19:16:53
   Part No SW: 571 035 284 B    HW: 571 035 284
   Component: OCUMQBW2023_H H09 0626
   Serial number: 0000000503VIBB0 Dataset Number: V03935465TG 0001
   Coding: 06010601020000110000000013002607111012111012000010
   ASAM Dataset: EV_OCUMWB2023 001066
   ROD: EV_OCUMWB2023_VW42.rod
   VCID: 1577C77C6506D5121CD-8040 SFD+SFD2 { }
   Part No SW: 5WA 980 653 F    HW: 5WA 980 653 A
   Component: MQB MFK 3.0   H12 3609
   Serial number: EAF282203251390 Dataset Number: V03935443PF 0001
   Coding: 0001089001484040409E08001000002000018048600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005071
   ROD: EV_MFK3ValeoMQB_005_SE38P.rod
End----------(Elapsed Time: 01:07, VBatt start/end: 13.8V/13.8V)-----------
------------------------------17 Faults Found------------------------------
blockmap-01-05L-906-023-QK_WV2ZZZSK8SX116493-20260803-1922.CSV
;SW:05L-906-023-QK   HW:05L-907-309-AH ---  01: Engine
;Component:R4 2.0l TDI   H80 4626, Coding:011900320326050920000000001000000000000000000000
;EV_ECM20TDI01105L906023QK,010005,EV_ECM20TDI01105L906023QK.rod
;Monday,03,August,2026,19:22:01:29755
;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0
;VCID: 015F832C018E49B2D05-8054 SFD+SFD2 { }
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WV2ZZZSK8SX116493,
IDE00019,Voltage terminal 30,13.720, V
IDE00020-ENG188621,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,983, /min
IDE00022,Transmission input speed,16383.5, /min
IDE00025,Coolant temperature,92, °C
IDE00078,Time since engine start,224, s
IDE00083,Throttle valve position (absolute),23.9, %
IDE00085,Normed load value,25.9, %
IDE00086,Accelerator pedal position,14.1, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00100,Engine torque,30.4, Nm
IDE00102,Control Module temperature,62.2, °C
IDE00151,Oil fill level,61.740, mm
IDE00172,A/C compressor torque,20.0, Nm
IDE00182,Camshaft adaptation intake bank 1: phase position,-1.89, °
IDE00190,Charge air pressure: specified value,1000, hPa
IDE00194,Coolant temperature at radiator output: specified value,88.0, °C
IDE00196,Engine oil temperature,89.2, °C
IDE00202,Low fuel pressure: specified value,5.199, bar
IDE00304,Fuel level,8.00, l
IDE00347,Air mass: actual value:,8.36, g/s
IDE00348,Intake air temperature,51, °C
IDE00349,Throttle valve position: normed,13.7, %
IDE00351,Main injection: start of activation,-0.97, °
IDE00352,Main injection: duration of activation,0.0, µs
IDE00353,Engine start: start quantity,15.26, mg/stroke
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00358,Limitation: torque,118.4, Nm
IDE00359,Limitation: smoke,117.8, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00363-ENG188621,Glow status-Bits 0-7,255,
IDE00363-ENG188621,Glow status-Bits 0-7,0,
IDE00364,Pre-glow time,0, ms
IDE00365,Injection quantity deviation cylinder 1,-0.02, mg/stroke
IDE00366,Injection quantity deviation cylinder 2,-0.04, mg/stroke
IDE00367,Injection quantity deviation cylinder 3,0.01, mg/stroke
IDE00368,Injection quantity deviation cylinder 4,0.04, mg/stroke
IDE00371,Fuel consumption,0.64, l/h
IDE00375,Generator: load signal,38.68, %
IDE00383,Pre-injection 1: activation start,4.90, °
IDE00384,Pre-injection 1: activation duration,212.8, µs
IDE00385,Pre-injection 2: activation start,11.56, °
IDE00386,Pre-injection 2: activation duration,209.2, µs
IDE00387,Post-injection 1: activation start,-11.78, °
IDE00388,Post-injection 1: activation duration,0.0, µs
IDE00389,Post-injection 2: activation start,-23.99, °
IDE00390,Post-injection 2: activation duration,0.0, µs
IDE00394,Camshaft position: start of phase window,120.89, °
IDE00395,Camshaft position: end of phase window,302.61, °
IDE00399,Regulation factor: total,1.000,
IDE00405,Crankshaft speed (RPM),983.0, /min
IDE00406,Camshaft RPM,491.3, /min
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413,Starter control: Interlock- or P/N-signal,False result,
IDE00413-ENG127289,Starter control: Interlock- or P/N-signal-Test_Program_B TRUE UBYTE,0,
IDE00416-ENG188621,Starter control: terminal 50 feedback-Bits 0-7,0,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00420,Service regeneration: current duration,0.0, s
IDE00430-ENG188621,Particle filter: field regeneration request status-Bits 0-7,0,
IDE00432,Particle filter: time since last regeneration,3.176, H
IDE00434,Particle filter: soot mass calculated,13.20, g
IDE00435,Particle filter: soot mass measured,-8.89, g
IDE00436,Particle filter: kilometers since last regeneration,88.1, km
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,73,
IDE00451,Currently running routine,Unknown (0)
IDE00472,Mean injection quantity,4.61, mg/stroke
IDE00474,Ambient air pressure,98, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,20.0, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,0,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,35, °C
IDE00583,Throttle valve specified value,14.1, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00588,Fuel tank fill level,14.9, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00603,Number of driving cycles since erasing DTC memory,0,
IDE00608,Fuel type,Diesel,
IDE00773,Terminal 15 status via CAN,1,
IDE00784,Current test step,0,
IDE01076,Time since ignition off,130948, s
IDE01260,Generator performance,801.106, W
IDE01378,Fuel high pressure: control deviation,-0.6, bar
IDE01381,Pre-injection 3: activation duration,223.2, µs
IDE01382,Post-injection 3: activation start,0.00, °
IDE01383,Post-injection 3: activation duration,0.0, µs
IDE01387,Injector 1: rail pressure calibration point 1,0.00, µs
IDE01388,Injector 1: rail pressure calibration point 2,0.00, µs
IDE01389,Injector 1: rail pressure calibration point 3,0.00, µs
IDE01390,Injector 2: rail pressure calibration point 1,0.00, µs
IDE01391,Injector 2: rail pressure calibration point 2,0.00, µs
IDE01392,Injector 2: rail pressure calibration point 3,0.00, µs
IDE01393,Injector 3: rail pressure calibration point 1,0.00, µs
IDE01394,Injector 3: rail pressure calibration point 2,0.00, µs
IDE01395,Injector 3: rail pressure calibration point 3,0.00, µs
IDE01396,Injector 4: rail pressure calibration point 1,0.00, µs
IDE01397,Injector 4: rail pressure calibration point 2,0.00, µs
IDE01398,Injector 4: rail pressure calibration point 3,0.00, µs
IDE01405-ENG188621,Starter activation: status-Bits 0-7,2,
IDE01407,Particle filter: fuel consumption since last regeneration,6.09, l
IDE01410,Charge limit over-charge,50.00, g
IDE01834,Battery voltage,13680, mV
IDE01880,Accelerator pedal position 2,14.1, %
IDE01922,Vehicle distance driven,12004, km
IDE02211,Brake pressure,0.00, MPa
IDE02540-ENG188621,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02558-ENG100471,High pressure test: cancel condition-Param 1 Tst Abort Fid,-,
IDE02558-ENG100389,High pressure test: cancel condition-Param 10 Tst Abort Inj Quant,-,
IDE02558-ENG103668,High pressure test: cancel condition-Param 11 Tst Abort Eng Speed,-,
IDE02558-ENG102582,High pressure test: cancel condition-Param 12 Tst Abort Rail Pres High,-,
IDE02558-ENG104255,High pressure test: cancel condition-Param 13 Tst Abort Rail Pres Low,-,
IDE02558-ENG163334,High pressure test: cancel condition-Param 14 Tst Abort Acctlst Nez,-,
IDE02558-ENG163335,High pressure test: cancel condition-Param 15 Tst Abort Covehtrqacs High,-,
IDE02558-ENG100876,High pressure test: cancel condition-Param 16 Undefined Abort Reason,Undefined Abort Reason,
IDE02558-ENG101560,High pressure test: cancel condition-Param 2 Tst Abort Clutch,-,
IDE02558-ENG102266,High pressure test: cancel condition-Param 3 Tst Abort Speed Nez,-,
IDE02558-ENG100337,High pressure test: cancel condition-Param 4 Tst Abort Brake Press,-,
IDE02558-ENG101825,High pressure test: cancel condition-Param 5 Tst Abort Thrpedal Press,-,
IDE02558-ENG103033,High pressure test: cancel condition-Param 6 Tst Abort Loop Ctl,-,
IDE02558-ENG103871,High pressure test: cancel condition-Param 7 Tst Abort Eng Idle Speed,-,
IDE02558-ENG102719,High pressure test: cancel condition-Param 8 Tst Abort Eng Cold,-,
IDE02558-ENG99486,High pressure test: cancel condition-Param 9 Tst Abort Pf Regen,-,
IDE02559-ENG104262,High pressure test result-Param 1 Rail st Up Hp Tst{0},0,
IDE02559-ENG104127,High pressure test result-Param 10 Rail ti Up Hp Tst{2},0, ms
IDE02559-ENG100303,High pressure test result-Param 11 Rail st Dwn Hp Tst{2},0,
IDE02559-ENG102830,High pressure test result-Param 12 Rail ti Dwn Hp Tst{2},0, ms
IDE02559-ENG100056,High pressure test result-Param 13 Rail st Up Hp Tst{3},0,
IDE02559-ENG102683,High pressure test result-Param 14 Rail ti Up Hp Tst{3},0, ms
IDE02559-ENG104012,High pressure test result-Param 15 Rail st Dwn Hp Tst{3},0,
IDE02559-ENG100728,High pressure test result-Param 16 Rail ti Dwn Hp Tst{3},0, ms
IDE02559-ENG103970,High pressure test result-Param 17 Rail ti Dwn Hp Tst{4},0, ms
IDE02559-ENG101422,High pressure test result-Param 18 Rail ti Dwn Hp Tst{5},0, ms
IDE02559-ENG103957,High pressure test result-Param 19 Rail st Dwn Hp Tst{4},0,
IDE02559-ENG100031,High pressure test result-Param 2 Rail ti Up Hp Tst{0},0, ms
IDE02559-ENG101860,High pressure test result-Param 20 Rail ti Dwn Hp Tst{6},0, ms
IDE02559-ENG101478,High pressure test result-Param 21 Rail ti Drop5 Stp Hp Tst{0},0, ms
IDE02559-ENG101370,High pressure test result-Param 22 Rail ti Drop5 Stp Hp Tst{1},0, ms
IDE02559-ENG99268,High pressure test result-Param 23 Rail ti Drop5 Stp Hp Tst{2},0, ms
IDE02559-ENG99112,High pressure test result-Param 24 Rail ti Drop5 Stp Hp Tst{3},0, ms
IDE02559-ENG102406,High pressure test result-Param 25 Rail ti Drop5 Stp Hp Tst{4},0, ms
IDE02559-ENG102422,High pressure test result-Param 26 Rail ti Drop5 Stp Hp Tst{5},0, ms
IDE02559-ENG100074,High pressure test result-Param 27 Rail ti Drop5 Stp Hp Tst{6},0, ms
IDE02559-ENG104167,High pressure test result-Param 28 Rail ti Drop5 Stp Hp Tst{7},0, ms
IDE02559-ENG100629,High pressure test result-Param 29 Rail ti Drop5 Stp Hp Tst{8},0, ms
IDE02559-ENG103601,High pressure test result-Param 3 Rail st Dwn Hp Tst{0},0,
IDE02559-ENG99302,High pressure test result-Param 30 Rail ti Drop5 Stp Hp Tst{9},0, ms
IDE02559-ENG103151,High pressure test result-Param 31 Rail ti Drop5 Stp Hp Tst{10},0, ms
IDE02559-ENG100429,High pressure test result-Param 32 Rail ti Drop5 Stp Hp Tst{11},0, ms
IDE02559-ENG101212,High pressure test result-Param 33 Rail ti Drop5 Stp Hp Tst{12},0, ms
IDE02559-ENG103534,High pressure test result-Param 34 Rail ti Drop5 Stp Hp Tst{13},0, ms
IDE02559-ENG103173,High pressure test result-Param 35 Rail ti Drop5 Stp Hp Tst{14},0, ms
IDE02559-ENG99461,High pressure test result-Param 36 Rail ti Drop5 Stp Hp Tst{15},0, ms
IDE02559-ENG163336,High pressure test result-Param 37 Rail p Std Dvt Rpl6k{0},0, hPa
IDE02559-ENG163337,High pressure test result-Param 38 Rail p Mean Val Rpl6k{0},0, hPa
IDE02559-ENG163338,High pressure test result-Param 39 Rail p Std Dvt Rpl6k{1},0, hPa
IDE02559-ENG102202,High pressure test result-Param 4 Rail ti Dwn Hp Tst{0},0, ms
IDE02559-ENG163339,High pressure test result-Param 40 Rail p Mean Val Rpl6k{1},0, hPa
IDE02559-ENG163340,High pressure test result-Param 41 Rail p Std Dvt Rpl6k{2},0, hPa
IDE02559-ENG163341,High pressure test result-Param 42 Rail p Mean Val Rpl6k{2},0, hPa
IDE02559-ENG163342,High pressure test result-Param 43 Rail p Std Dvt Rpl6k{3},0, hPa
IDE02559-ENG163343,High pressure test result-Param 44 Rail p Mean Val Rpl6k{3},0, hPa
IDE02559-ENG102632,High pressure test result-Param 5 Rail st Up Hp Tst{1},0,
IDE02559-ENG103992,High pressure test result-Param 6 Rail ti Up Hp Tst{1},0, ms
IDE02559-ENG101023,High pressure test result-Param 7 Rail st Dwn Hp Tst{1},0,
IDE02559-ENG100114,High pressure test result-Param 8 Rail ti Dwn Hp Tst{1},0, ms
IDE02559-ENG101094,High pressure test result-Param 9 Rail st Up Hp Tst{2},0,
IDE02742,Oil pressure actual value,229.6, kPa
IDE02756,Number of manual engine starts,1799,
IDE02757,Number of automatic engine starts,76,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,44,
IDE03010-MAS01627,Number of prevented stop processes-Steering,29,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,4,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,25,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,17,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03015,Compression test cylinder 1,0.0, /min
IDE03016,Compression test cylinder 2,0.0, /min
IDE03017,Compression test cylinder 3,0.0, /min
IDE03018,Compression test cylinder 4,0.0, /min
IDE03132,Pressure sensor for reducing agent: measured pressure,6014, hPa
IDE03133,Heating circuit 1 for reducing agent metering system: actual current,0.00, A
IDE03134,Heating circuit 2 for reducing agent metering system: actual current,0.00, A
IDE03135,Sensor for reducing agent tank temperature: temperature,38.2, °C
IDE03137,Heating circuit 1 for reducing agent metering system: actual voltage,0.00, V
IDE03138,Heating circuit 2 for reducing agent metering system: actual voltage,0.00, V
IDE03139,Reducing agent injector: resistance,13451, mOhm
IDE03140,NOx sensor 1: NOx concentration,93, ppm
IDE03141,NOx sensor 2: NOx concentration,9, ppm
IDE03142,Remaining vehicle distance until reducing agent deficiency,9007.00, km
IDE03145,NOx sensor 2: offset for correction factor,-1, ppm
IDE03149,NOx sensor 1: offset for correction factor,0, ppm
IDE03187,Checksum of flash,2F58,
IDE03235,Neutral position sensor: current transmission angle,-0.50, °
IDE03236,Neutral position sensor: adapted transmission angle,-0.55, °
IDE03242,Injector for reduction agent: current holding phase,408, mA
IDE03243,Reducing agent injector: current saturation phase,963, mA
IDE03246,Neutral position sensor: upper adaptation value,3240, mV
IDE03247,Neutral position sensor: lower adaptation value,1310, mV
IDE03248,Pressure control valve adaptation factor,1.0000,
IDE03328,Transmission neutral position sensor voltage,2030, mV
IDE03383,Exhaust mass flow of EGR,9.3, kg/h
IDE03393-ENG188621,Selector lever position-Bits 0-7,0,
IDE03405-ENG188621,Particle filter field regeneration: cancel conditions-Bits 0-7,0,
IDE03582,Temperature sensor for engine temperature management,222.0, °C
IDE03583-ENG188621,Engine shut-down overrides-Bits 0-7,20,
IDE03584-ENG188621,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG188621,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping prohibitions for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping prohibitions for active participants-A/C system,not active,
IDE03587-MAS00127,Stopping prohibitions for active participants-Brake,not active,
IDE03587-MAS00506,Stopping prohibitions for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping prohibitions for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping prohibitions for active participants-Gearbox,not active,
IDE03587-MAS01106,Stopping prohibitions for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping prohibitions for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping prohibitions for active participants-Steering,not active,
IDE03587-MAS02237,Stopping prohibitions for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping prohibitions for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping prohibitions for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping prohibitions for active participants-Motor,active,
IDE03587-MAS06709,Stopping prohibitions for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping prohibitions for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping prohibitions for active participants-Front sensor for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C system,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-Brake,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Gearbox,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication errors,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,-0.077, m/s²
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,8,
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,63,
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,144,
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,228,
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03998,Clutch Position Sensor,9.2, %
IDE04002,Charge air pressure control,BP_A cmd/act:99.9/93.3, kPa
IDE04003,Charge air temperature sensor,B1S1/B1S2:67/52, °C
IDE04008,Fuel consumption per hour,0.70, L/h
IDE04009,Driver's desired torque,2.0, %
IDE04010,Engine torque: normalized,8.0, %
IDE04011,Nominal torque,320, Nm
IDE04015,Exhaust gas recirculation,EGR A:36/36/0 % / EGR B:14/14/0 %,
IDE04016,Fuel Pressure Regulation,FRP CMD:28800/--- kPa / FRP ACT:27710/--- kPa,
IDE04035,exh.gas recirc. temperature,EGRTemp 11/12:---/96 °C / EGRTemp 21/22:---/--- °C,
IDE04083,Coolant temperatures,ECT 1:92, °C
IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:75.3/75.7 % / VGT_B cmd/act:---/--- %,
IDE04090,Exhaust temperature bank 1,S1/S2/S3/S4:  / 184/177/174/171 °C,
IDE04092,Particulate filter bank 1,1.11/---/---, kPa
IDE04095,Engine running time,Total:253H1677s  / Idle:38H294s ,
IDE04098,NOX Sensor,NOx11:92 ppm / NOx21:9 ppm,
IDE04099,Reduction agent dosing,ReAg Rate/Demand:0.0/0.03 L/h / Reag Tnk Lvl:58.0 %,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04260-ENG188621,Learning cycle counter of zero quant calib: bottom press pt-Bits 0-7,0,
IDE04261-ENG188621,Learning cycle counter of zero quant calib: middle press pt-Bits 0-7,0,
IDE04262-ENG188621,Learning cycle counter of zero quant calib: top press pt-Bits 0-7,0,
IDE04272,Counter for regeneration time of particulate filter,0.0, s
IDE04468,Air mass at air mass meter 1,30.2, kg/h
IDE04623,Kick-down threshold,4125.2, mV
IDE04651,Torque request: A/C compressor,13.0, Nm
IDE04652,Exhaust gas jet volume in particle filter,52.3, m³/h
IDE04653,Simulated particle filter surface temperature,169.7, °C
IDE04666,Heat delivery temperature in cooling system,-273.1, °C
IDE04670,Crankshaft signal evaluation: status,EPMHCRS_GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04682-ENG188621,Allowed number of injections-Bits 0-7,5,
IDE04683-ENG188621,Injection release status-Bits 0-7,62,
IDE04684-ENG188621,Desired injection characteristic-Bits 0-7,62,
IDE04685,Setpoint generation interior torque,31.0, Nm
IDE04686,Calculated clutch limit torque,-40.1, Nm
IDE04687,Mean temperature of SCR catalyst,171.5, °C
IDE04688-ENG188621,Engine control module reset status-Bits 0-7,48,
IDE04688-ENG188621,Engine control module reset status-Bits 0-7,0,
IDE04690-ENG188621,Transmission torque intervention status-Bits 0-7,0,
IDE04693,Increasing desired torque intervention of ESP,-52264.9, Nm
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,255,
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,229,
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,142,
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,206,
IDE04866,Charging of press sensor betw ND and HD turbocharger: adapt,1028, hPa
IDE04868-ENG188621,Glow cycles above temperature threshold-Bits 0-7,0,
IDE04868-ENG188621,Glow cycles above temperature threshold-Bits 0-7,1,
IDE04869-ENG188621,Glow cycles below temperature threshold-Bits 0-7,1,
IDE04869-ENG188621,Glow cycles below temperature threshold-Bits 0-7,0,
IDE04870-ENG188621,Glow cycles upon reaching temperature threshold-Bits 0-7,1,
IDE04870-ENG188621,Glow cycles upon reaching temperature threshold-Bits 0-7,0,
IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
IDE04875,Brake pedal value sensor: learned zero point offset value,0.00, %
IDE04887,Powertrain target torque,-176.0, Nm
IDE05132-ENG188621,Charge pressure control activity-Bits 0-7,0,
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,0,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,33,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,8,
IDE05137-ENG188621,Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-7,0,
IDE05138,Shut-off timer: last engine shut-off time,65, s
IDE05139,Shut-off timer: last ECM after-run time,1, s
IDE05260-ENG188621,Gear position sensor: current value-Bits 0-7,0,
IDE05330,Pulse-controlled inverter temperature: actual value,3003.6, °C
IDE05348,NOx-Sensor 2: O2-Concentration,0.15516,
IDE05352-ENG188621,Status of trailing throttle detec in trailing throttle coord-Bits 0-7,0,
IDE05353,Measured NOx conversion,0.000,
IDE05355,Efficiency threshold of NOx conversion,0.000,
IDE05356,Calculated NOx concentration behind turbocharger,72.75, ppm
IDE05386,Exhaust gas model temperature 0,220.8, °C
IDE05387,Exhaust gas model temperature 1,179.2, °C
IDE05388,Exhaust gas model temperature 2,175.0, °C
IDE05389,Exhaust gas model temperature 3,171.8, °C
IDE05390,Exhaust gas model temperature 4,-0.0, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000018,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000366,
IDE05442,Roadway slope angle acceleration interface: calculated,-0.0085, rad
IDE05494-ENG188621,Air cleaner full/empty detection-Bits 0-7,0,
IDE05625,Speed regulation requested torque,-179.0, Nm
IDE05626,Calculated temperature at reduction agent injection valve,50.0, °C
IDE05781,Engine temperature management actuator: specified value,0.00, %
IDE05846,DPF statistics: current average speed,0.0, km/h
IDE05853,DPF statistics: current avg temperature after part filter,6.4, K
IDE05855,DPF statistics: current regeneration time slice not possible,0.000, H
IDE05861-ENG188621,DPF statistics: number of interrupted regenerations-Bits 0-7,0,
IDE05877,DPF statistics: regen time slice not poss in charge cycle,0.000,
IDE05883,DPF statistics: regeneration time,0, s
IDE05901,DPF statistics: route in charge cycle,64, km
IDE05903,DPF statistics: avg driv cycle time during charge cycle,0, s
IDE05908-ENG188621,DPF statistics: regeneration request-Bits 0-7,0,
IDE05910,DPF statistics: exhaust temperature regulation average value,0.44,
IDE05918-ENG188621,DPF statistics: regeneration blocked status-Bits 0-7,0,
IDE05922-ENG188621,DPF statistics: error status-Bits 0-7,0,
IDE06013,Engine start: start synchronization 2,EPM_FULL_SYNC,
IDE06013-ENG127375,Engine start: start synchronization 2-Test_Program_Epm st Sync State t UBYTE,30,
IDE06041-ENG188621,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06042,Adaptation of brake pedal path sensor: result,False result,
IDE06042-ENG127289,Adaptation of brake pedal path sensor: result-Test_Program_B TRUE UBYTE,0,
IDE06058-ENG188621,Engine control module reset status info-Bits 0-7,128,
IDE06058-ENG188621,Engine control module reset status info-Bits 0-7,118,
IDE06058-ENG188621,Engine control module reset status info-Bits 0-7,228,
IDE06058-ENG188621,Engine control module reset status info-Bits 0-7,132,
IDE06059,Particulate filter: oil ash mass,4.4661423, g
IDE06060,Particulate filter ash load limit,80.000, g
IDE06216,DPF Statistics: average val.: exhaust temp. ctrl before DPF,1.0,
IDE06255,Vehicle lateral acceleration,0.01, g
IDE06256,Vehicle lateral acceleration: raw value,0.01, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06258,Charge air temperature at the turbocharger outlet: calculated,67.0, °C
IDE06298-ENG188621,Status of engine during start-Bits 0-7,0,
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06391,Oil temperature sensor 2,-0.0, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,0.0, mV
IDE06405,Engine oil temperature_SAE,89, °C
IDE06433,Standardized airflow ratio: filtered,1.6874,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,-0.063, m/s²
IDE06446-ENG188621,Status: incline angle-Bits 0-7,0,
IDE06552,Time since terminal 15 ON,316610, ms
IDE06567,Frequency counter deactivate start/stop function,30,
IDE06568,Stop prevention by driver frequency counter,6378,
IDE06569,Frequency counter vehicle standstill,6896,
IDE06610,Frequency counter vehicle standstill with stop,102,
IDE06647-ENG188621,Start-stop switch status-Bits 0-7,1,
IDE06703,Drivetrain coordinator: ACC fault status,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,32,
IDE06706-ENG188621,ACC variants-Bits 0-7,0,
IDE06707,CCS Switch,1,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,1,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,49,
IDE06709-ENG188621,ACC variants (coding)-Bits 0-7,1,
IDE06710-ENG188621,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG188621,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06866-ENG188621,Range limit cancellation due to red. agent metering sys. fault-Bits 0-7,0,
IDE06946-ENG188621,Brake actuated status-Bits 0-7,0,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,Available,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,Available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,39.6, %
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,0, km
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,Available,
IDE06993-MAS05410,Oxygen sensors (broadband)-Oxygen concentration bank 1: sensor 1,16.099300, %
IDE06993-MAS05410,Oxygen sensors (broadband)-Oxygen concentration bank 1: sensor 1,Available,
IDE06993-MAS05411,Oxygen sensors (broadband)-Oxygen concentration bank 1: sensor 2,Available,
IDE06993-MAS05411,Oxygen sensors (broadband)-Oxygen concentration bank 1: sensor 2,15.913128, %
IDE06993-MAS05412,Oxygen sensors (broadband)-Oxygen concentration bank 2: sensor 1,Not available,
IDE06993-MAS05412,Oxygen sensors (broadband)-Oxygen concentration bank 2: sensor 1,0.000000, %
IDE06993-MAS05413,Oxygen sensors (broadband)-Oxygen concentration bank 2: sensor 2,Not available,
IDE06993-MAS05413,Oxygen sensors (broadband)-Oxygen concentration bank 2: sensor 2,0.000000, %
IDE06993-MAS05414,Oxygen sensors (broadband)-Oxygen value bank 1: sensor 1,Available,
IDE06993-MAS05414,Oxygen sensors (broadband)-Oxygen value bank 1: sensor 1,4.551, lambda
IDE06993-MAS05415,Oxygen sensors (broadband)-Oxygen value bank 1: sensor 2,Available,
IDE06993-MAS05415,Oxygen sensors (broadband)-Oxygen value bank 1: sensor 2,4.380, lambda
IDE06993-MAS05416,Oxygen sensors (broadband)-Oxygen value bank 2: sensor 1,Not available,
IDE06993-MAS05416,Oxygen sensors (broadband)-Oxygen value bank 2: sensor 1,0.000, lambda
IDE06993-MAS05417,Oxygen sensors (broadband)-Oxygen value bank 2: sensor 2,Not available,
IDE06993-MAS05417,Oxygen sensors (broadband)-Oxygen value bank 2: sensor 2,0.000, lambda
IDE07051-ENG188621,Engaged gear: raw signal-Bits 0-7,0,
IDE07084,Differential pressure ratio: low-pressure EGR,2.475,
IDE07086,Exhaust mass flow of low-pressure EGR: calculated,9.4, kg/h
IDE07088,NOx sensor 1: oxygen concentration,0.15411,
IDE07090-ENG188621,Speed control: status of external torque request-Bits 0-7,4,
IDE07090-ENG188621,Speed control: status of external torque request-Bits 0-7,0,
IDE07170,Clutch K0: torque,-12.3, Nm
IDE07173-ENG188621,Electric drive motor: mode of operation-Bits 0-7,15,
IDE07374,Cylinder mass flow: act. value calculated,49.5, kg/h
IDE07375,Charge pressure before throttle valve: calculated actual value,1028.3, hPa
IDE07377,EGR valve 1: B1: mass current - specified value,9.6, kg/h
IDE07378,Exhaust flap actuator 1: B1: inlet pressure - specified value,983.8, hPa
IDE07379,Cylinder charge: spec. value,424.6, mg/stroke
IDE07380,NOx storage catalytic converter: sulfur load: actual value calculated,0.000, g
IDE07381,Cylinder charge: act. value calculated,420.0, mg/stroke
IDE07382,EGR valve 2: B1: mass current - specified value,9.7, kg/h
IDE07383,NOx storage catalytic converter: aging factor: actual value calculated,0, s
IDE07384,Throttle valve actuator 1: B1: outlet pressure - specified value,932.5, hPa
IDE07385,Exhaust flap actuator 1: B1: inlet pressure - actual value calculated,984.0, hPa
IDE07386,Total HFM air mass flow: calculated,31.1, kg/h
IDE07528-ENG122685,Coordinator releases for particulate filter regeneration-SwSVW st Ctl Cdn Eng,11111111 11111111 11111111 11111111 ,
IDE07528-ENG122684,Coordinator releases for particulate filter regeneration-SwSVW st Ctl Cdn Veh,11111111 11111111 11111111 11111111 ,
IDE07529-ENG122685,Coordinator releases: standard-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
IDE07529-ENG122684,Coordinator releases: standard-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
IDE07530-ENG122685,Coordinator releases for NOx reduction-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
IDE07530-ENG122684,Coordinator releases for NOx reduction-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
IDE07531-ENG122685,Coordinator releases: sulfur removal-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
IDE07531-ENG122684,Coordinator releases: sulfur removal-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
IDE07532-ENG122685,Coordinator releases for short trip-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
IDE07532-ENG122684,Coordinator releases for short trip-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
IDE07534-ENG188621,Target operating mode for engine-Bits 0-7,19,
IDE07534-ENG188621,Target operating mode for engine-Bits 0-7,2,
IDE07534-ENG188621,Target operating mode for engine-Bits 0-7,99,
IDE07534-ENG188621,Target operating mode for engine-Bits 0-7,17,
IDE07535-ENG188621,Current operating mode of engine-Bits 0-7,17,
IDE07535-ENG188621,Current operating mode of engine-Bits 0-7,99,
IDE07535-ENG188621,Current operating mode of engine-Bits 0-7,19,
IDE07535-ENG188621,Current operating mode of engine-Bits 0-7,2,
IDE07536-ENG188621,Next requested operating mode for engine-Bits 0-7,2,
IDE07536-ENG188621,Next requested operating mode for engine-Bits 0-7,99,
IDE07536-ENG188621,Next requested operating mode for engine-Bits 0-7,17,
IDE07536-ENG188621,Next requested operating mode for engine-Bits 0-7,19,
IDE07538,Intake manifold press. sensor: act. value calculated,928, hPa
IDE07548,Engine temp. mangmt. actuator: specified value of angle,59.00, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,0.00, %
IDE07550,Engine temp. management actuator: raw value,0.0, mV
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07598,Cruise control switch actuation,12545,
IDE07605,Cruise control system: temporary deactivation,255,
IDE07706,Outside temperature sensor 1: B1: raw value,35.5, °C
IDE07707,Mass airflow sensor 1 bank 1 temperature: raw value,51.5, °C
IDE07708,Turbocharger 1 charger output: temp. sensor 1: B1: raw value,67.0, °C
IDE07709,Turbocharger 1 charger output: temp. sensor 1: B1: raw voltage,3025.4, mV
IDE07710,Charge air cooler output: temp. sensor 1: B1: raw value,52.5, °C
IDE07711,Charge air cooler output: temp. sensor 1: B1: raw voltage,3537.0, mV
IDE07712,Turbocharger 1 turbine input: temp. sensor 1: bank 1: raw value,183.7, °C
IDE07713,Turbocharger 1 turbine input: temp. sensor 1: B1: raw voltage,1258.8, mV
IDE07714,Turbocharger 1 turbine output: temp. sensor 1: B1: raw value,175.9, °C
IDE07715,Turbocharger 1 turbine output: temp. sensor 1: B1: raw voltage,1244.0, mV
IDE07716,Particulate filter input: temp. sensor 1: bank 1: raw value,174.6, °C
IDE07717,Particulate filter input: temp. sensor 1: B1: raw voltage,1239.0, mV
IDE07718,Particulate filter output: temp. sensor 1: bank 1: raw value,174.6, °C
IDE07719,Particulate filter output: temp. sensor 1: bank 1: raw voltage,1240.2, mV
IDE07722,Coolant temp. sens.1 bank 1 before charge air cooler: raw value,48.5, °C
IDE07723,Coolant temp.sens.1 bank 1 before ch.air cool.:uncnd.voltage,2327.0, mV
IDE07724,Coolant temperature at engine outlet: calculated,92.5, °C
IDE07725,Coolant temperature sensor 1: B1: on cylinder head: raw value,92.5, °C
IDE07726,Coolant temperature sensor 1: B1: on cylinder head: raw voltage,929.0, mV
IDE07731,EGR temp. sensor 2: B1: raw value,96.6, °C
IDE07732,EGR temp. sensor 2 B1: raw voltage,2650.6, mV
IDE07733,Ambient air pressure sensor 1 bank 1: raw value,982, hPa
IDE07738,Charge air cooler inlet: pressure sensor 1 bank 1: raw value,928.4, hPa
IDE07739,Charge air cooler inlet: press.sensor 1 bank 1: uncnd. voltage,982.6, mV
IDE07742,Cylinder head: pressure sensor 3 bank 1: maximum value,39.906, bar
IDE07744,Particle filter: air pressure sensor 1 bank 1: raw value,11, hPa
IDE07745,Particl.filt.: different.press.sensor 1 bank 1: adaptat. value,11, hPa
IDE07747,Par.fil: diff.pr.sens.1 bank 1: offset,-1, hPa
IDE07748,Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset,0, hPa
IDE07750,Exhaust recirculat.2: different.press.sens.1 bank 1: raw value,10.0, hPa
IDE07751,Exhaust gas recirculation 2: differential pressure sensor 1 bank 1: additional value,10.6, hPa
IDE07752,Exh.recirculat.2: different.press.sensor 1 bank 1: uncnd.volt.,0.0, mV
IDE07754,Exhaust recirculation valve 1 bank 1: activation,-18.51, %
IDE07755,Exhaust recirculation valve 1 bank 1: position feedback  uncnd. voltage,1861.8, mV
IDE07756,Exhaust recirculation valve 1 bank 1: position feedback  specified value,35.90, %
IDE07757,Exhaust recirculation valve 1 bank 1: position feedback  actual value,36.05, %
IDE07758,Exhaust recirculation valve 1 bank 1: position feedback  offset closed,-0.89, %
IDE07759-ENG188621,Exhaust recirculation valve 1 bank 1: position feedback  mechanical stops-Bits 0-7,54,
IDE07759-ENG188621,Exhaust recirculation valve 1 bank 1: position feedback  mechanical stops-Bits 0-7,149,
IDE07759-ENG188621,Exhaust recirculation valve 1 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07760-ENG188621,Exhaust recirculation valve 1 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07761,Exhaust recirculation valve 2 bank 1: activation,-12.10, %
IDE07762,Exhaust recirculation valve 2 bank 1: position feedback  uncnd. voltage,1202.0, mV
IDE07763,Exhaust recirculation valve 2 bank 1: position feedback  specified value,14.37, %
IDE07764,Exhaust recirculation valve 2 bank 1: position feedback  actual value,14.32, %
IDE07765,Exhaust recirculation valve 2 bank 1: position feedback  offset closed,-0.07, %
IDE07766-ENG188621,Exhaust recirculation valve 2 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07766-ENG188621,Exhaust recirculation valve 2 bank 1: position feedback  mechanical stops-Bits 0-7,38,
IDE07766-ENG188621,Exhaust recirculation valve 2 bank 1: position feedback  mechanical stops-Bits 0-7,242,
IDE07767-ENG188621,Exhaust recirculation valve 2 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07768,Throttle valve adapter 1 bank 1: activation,14.64, %
IDE07769,Throttle valve adapter 1 bank 1: position feedback  uncnd. voltage,1218.4, mV
IDE07770,Throttle valve adapter 1 bank 1: position feedback  specified value,86.04, %
IDE07771,Throttle valve adapter 1 bank 1: position feedback  actual value,86.02, %
IDE07772,Throttle valve adapter 1 bank 1: position feedback  offset closed,-0.81, %
IDE07773-ENG188621,Throttle valve adapter 1 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07773-ENG188621,Throttle valve adapter 1 bank 1: position feedback  mechanical stops-Bits 0-7,140,
IDE07773-ENG188621,Throttle valve adapter 1 bank 1: position feedback  mechanical stops-Bits 0-7,15,
IDE07774-ENG188621,Throttle valve adapter 1 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07775,Exhaust recirculation valve 1 bank 1: activation,13.86, %
IDE07776,Exhaust flap actuator 1 bank 1: position feedback  uncnd. voltage,1582.2, mV
IDE07777,Exhaust flap actuator 1 bank 1: position feedback  specified value,72.97, %
IDE07778,Exhaust flap actuator 1 bank 1: position feedback  actual value,72.99, %
IDE07779,Exhaust flap actuator 1 bank 1: position feedback  offset closed,0.23, %
IDE07780-ENG188621,Exhaust flap actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,150,
IDE07780-ENG188621,Exhaust flap actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,153,
IDE07780-ENG188621,Exhaust flap actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07781-ENG188621,Exhaust flap actuator 1 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07783,Turbine actuator 1 bank 1: position feedback  uncnd. voltage,1770.2, mV
IDE07784,Turbine actuator 1 bank 1: position feedback  specified value,75.73, %
IDE07785,Turbine actuator 1 bank 1: position feedback  actual value,75.72, %
IDE07786,Turbine actuator 1 bank 1: position feedback  offset closed,22.67, %
IDE07787-ENG188621,Turbine actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,129,
IDE07787-ENG188621,Turbine actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,11,
IDE07787-ENG188621,Turbine actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07788-ENG188621,Turbine actuator 1 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07789,Turbine actuator 1 bank 1: activation,-0.26, %
IDE07798,Heater support pump 1 bank 1 second.circuit: activat.,36.36, %
IDE07799,Heater support pump 1 bank 1 primary circuit: activation,100.00, %
IDE07800,Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.,95.00, %
IDE07801,Mass airflow sensor 1 bank 1 airflow: raw value,258.2, mg/stroke
IDE07807,Fuel temperature sensor 1: B1: raw value,60.0, °C
IDE07808,Fuel temperature sensor 1: B1: before CR pump: raw voltage,2680.0, mV
IDE07812,Transmission neutral position sensor 1: raw value,40.67, %
IDE07815-ENG188621,Transmission neutral position sensor: adaptation status-Bits 0-7,62,
IDE07818,Fuel high pressure sensor: actual value,292.8, bar
IDE07819,Fuel high pressure sensor: unconditioned voltage,926.6, mV
IDE07820,Fuel high pressure sensor: nominal value,290.2, bar
IDE07821,Fuel metering valve: activation,5.00, %
IDE07822,Fuel pressure regulator valve: activation,15.33, %
IDE07823-ENG188621,Tank-internal presupply pump 1 bank 1: status-Bits 0-7,0,
IDE07824,Tank-internal presupply pump 1 bank 1: activation,42.10, %
IDE07825,Tank-internal presupply pump 1 bank 1: nominal value,101.6, l/h
IDE07826,Accelerator pedal travel: raw value,0.00, %
IDE07827,Accelerator pedal: sensor voltage 1,718.8, mV
IDE07828,Accelerator pedal: sensor voltage 2,358.8, mV
IDE07832,Coolant fan 1: activation,48.04, %
IDE07833,Coolant fan 2: activation,0.00, %
IDE07834-ENG188621,Status of starter activation relay-Bits 0-7,0,
IDE07841,Precontrol value of map,0.000, µs
IDE07842-ENG188621,Precontrol map value index-Bits 0-7,5,
IDE07904-ENG188621,Brake test switch status-Bits 0-7,0,
IDE07905-ENG188621,Brake light switch status-Bits 0-7,0,
IDE07906-ENG188621,Upper clutch switch: status-Bits 0-7,0,
IDE07984,Particle sensor: cleaning deviation reaction time,0.012,
IDE07986,Particle sensor: soot volume in exhaust,0.40, mg/m³
IDE07987,Particle sensor: exhaust temperature,118.9, °C
IDE07988,Particle sensor: exhust speed,3.42, m/s
IDE07989,Particle sensor: heat voltage,0.00, V
IDE07990,Particle sensor: surface temperature,121.85, °C
IDE08065,Mass airflow sensor 1 bank 1 temperature sensor: raw value,419.0, mV
IDE08069-ENG188621,Fuel filter: water level sensor 1-Bits 0-7,0,
IDE08076,Fuel filter: water level sensor 1 raw voltage,0.0, mV
IDE08132-ENG122793,SCR error notification reset status-SCR Inducement Group,0,
IDE08132-ENG122794,SCR error notification reset status-SCR Inducement State DFCC,0,
IDE08132-ENG176596,SCR error notification reset status-SCR Inducement Tester DFCC Five,0,
IDE08132-ENG176595,SCR error notification reset status-SCR Inducement Tester DFCC Four,0,
IDE08132-ENG176592,SCR error notification reset status-SCR Inducement Tester DFCC One,0,
IDE08132-ENG176594,SCR error notification reset status-SCR Inducement Tester DFCC Three,0,
IDE08132-ENG176593,SCR error notification reset status-SCR Inducement Tester DFCC Two,0,
IDE08212,Standardized air flow ratio,1.6873,
IDE08213,Standardised airflow ratio plausibility,0,
IDE08285-ENG188621,Filling reducing agent metering system status-Bits 0-7,0,
IDE08721,Particle sensor: time in op. mode measurement,102.1, s
IDE09163,Exhaust recircul.2: different.press.sens.1 bank 1: dyn. offset,-1.0, hPa
IDE09164,Efficiency of the SCR catalytic converter,0.83020,
IDE09165,Low-pres.exhaust gas recirc.filt.diagn.:release condit.,44057,
IDE09327,Cylinder 1 bank 1 internal moment,29.8, Nm
IDE09328,Cylinder 2 bank 1 internal moment,29.6, Nm
IDE09329,Cylinder 3 bank 1 internal moment,27.5, Nm
IDE09330,Cylinder 4 bank 1 internal moment,30.3, Nm
IDE09331,Cylinder 1 bank 1 primary combustion position,0.00, °
IDE09332,Cylinder 2 bank 1 primary combustion position,0.00, °
IDE09333,Cylinder 3 bank 1 primary combustion position,-19.29, °
IDE09334,Cylinder 4 bank 1 primary combustion position,0.00, °
IDE09339,Charge limit for service regeneration while driving,40.00, g
IDE09490,Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value,11.0, hPa
IDE09672-ENG188621,Cylinder head: main combustion position controller 2 bank 1: limit status-Bits 0-7,0,
IDE09673-ENG188621,Cylinder head: main combustion position controller 3 bank 1: limit status-Bits 0-7,2,
IDE09677,Cyl. head: press. sens 3 bank 1: press. correct. intern. moment,29.6, Nm
IDE09681-ENG188621,Cyl. head: press. sen 3 bank 1: error status combustion chamber pressure-Bits 0-7,0,
IDE09685-ENG188621,Cylinder head: controller internal moment 3 bank 1: limit status-Bits 0-7,2,
IDE09842-ENG188621,Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7,228,
IDE09842-ENG188621,Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7,8,
IDE09842-ENG188621,Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7,144,
IDE09842-ENG188621,Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7,63,
IDE09843-ENG188621,Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7,206,
IDE09843-ENG188621,Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7,229,
IDE09843-ENG188621,Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7,142,
IDE09843-ENG188621,Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7,255,
IDE09886,Exhaust gas recirc. valve 2 bank 1: mass flow - calculated,9.6, kg/h
IDE09962,Cylinder head: pressure sensor 3 bank 1: primary combustion position,18.65, °
IDE09966,Cylinder head: pressure sensor 3 bank 1: primary combustion standard deviation,0.00, °
IDE09970,Cyl. head: press. sens. 3 bank 1: max press. in decelerat.mode,0.00, °
IDE09974-ENG188621,Cylinder head: pressure sensor 3 bank 1: group run time-Bits 0-7,248,
IDE09974-ENG188621,Cylinder head: pressure sensor 3 bank 1: group run time-Bits 0-7,255,
IDE09976,Coolant fan 1: activation,48.04, %
IDE09977,Control module temp.: max. value,70.3, °C
IDE10022,Heating circuit 3 for reducing agent metering: voltage,0.00, V
IDE10023,Heating circuit 2 for reducing agent metering: power,0.00, W
IDE10024,Heating circuit 1 for reducing agent: power,0.00, W
IDE10025,Heating circuit 3 for reducing agent: power set value,0.00, W
IDE10028,Heating circuit 1 for reducing agent: power set value,0.00, W
IDE10029,Heating circuit 3 for reducing agent: current,0.00, A
IDE10032,Reducing agent quality sensor: urea concentration,33.30, %
IDE10037,Heating circuit 3 for reducing agent: power,0.00, W
IDE10063,Engine oil level: current value,86.6, %
IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,100.0, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,11107, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,11100, km
IDE10064-MAS09807,Engine oil level: history 1-Qualification,2,
IDE10064-ENG137751,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,5,
IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,95.8, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,10626, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,10583, km
IDE10065-MAS09807,Engine oil level: history 2-Qualification,7,
IDE10065-ENG137751,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,6,
IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,74.4, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,10028, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,3, km
IDE10066-MAS09807,Engine oil level: history 3-Qualification,7,
IDE10066-ENG137751,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,4,
IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,81.6, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,9401, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,9397, km
IDE10067-MAS09807,Engine oil level: history 4-Qualification,7,
IDE10067-ENG137751,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,6,
IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,83.1, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,7481, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,7479, km
IDE10068-MAS09807,Engine oil level: history 5-Qualification,7,
IDE10068-ENG137751,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,3,
IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,71.2, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,6853, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,6763, km
IDE10069-MAS09807,Engine oil level: history 6-Qualification,7,
IDE10069-ENG137751,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,3,
IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,83.7, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,6223, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,6208, km
IDE10070-MAS09807,Engine oil level: history 7-Qualification,7,
IDE10070-ENG137751,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,3,
IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,99.5, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,5597, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,5570, km
IDE10071-MAS09807,Engine oil level: history 8-Qualification,7,
IDE10071-ENG137751,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,2,
IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,98.7, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,4966, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,4943, km
IDE10072-MAS09807,Engine oil level: history 9-Qualification,7,
IDE10072-ENG137751,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,2,
IDE10241,Reducing agent pump module relative press.: calculated,6497, hPa
IDE10246,Reducing agent tank volume: act. value filtered,11.2871, kg
IDE10247,Reducing agent tank volume: act. value calculated,10.391, l
IDE10249,Reducing agent fill level sensor: act. value,253.3, mm
IDE10251,Reducing agent supply pump: measured resistance,4065, mOhm
IDE10253,Exh. gas recirc. valve 1 bank 1: pos. contr. spec. value,36.41, %
IDE10254,Turbine actuator 1 bank 1: pos. contr. spec. value,75.83, %
IDE10255,Throttle valve adapter 1 bank 1: pos. contr. spec. value,85.68, %
IDE10313-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,7,
IDE10313-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,16,
IDE10313-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,68,
IDE10313-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,64,
IDE10314-ENG188621,Exhaust recirculation valve 2 bank 1: monitoring  status-Bits 0-7,7,
IDE10314-ENG188621,Exhaust recirculation valve 2 bank 1: monitoring  status-Bits 0-7,68,
IDE10314-ENG188621,Exhaust recirculation valve 2 bank 1: monitoring  status-Bits 0-7,16,
IDE10314-ENG188621,Exhaust recirculation valve 2 bank 1: monitoring  status-Bits 0-7,64,
IDE10315-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,7,
IDE10315-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,68,
IDE10315-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,64,
IDE10315-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,16,
IDE10316-ENG188621,Turbine actuator 1 bank 1: monitoring - status-Bits 0-7,1,
IDE10316-ENG188621,Turbine actuator 1 bank 1: monitoring - status-Bits 0-7,64,
IDE10316-ENG188621,Turbine actuator 1 bank 1: monitoring - status-Bits 0-7,4,
IDE10316-ENG188621,Turbine actuator 1 bank 1: monitoring - status-Bits 0-7,16,
IDE10402-ENG188621,Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7,7,
IDE10402-ENG188621,Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7,16,
IDE10402-ENG188621,Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7,64,
IDE10402-ENG188621,Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7,0,
IDE10560-ENG188621,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10569-ENG188621,Turbo charger 1 Turbine inp.: Temp. sensor 1 Bank 1: raw data-Bits 0-7,0,
IDE10570,Turbo charger.1 turbine inp.: temp.sensor 1 bank 1: comp. temp.,-273.1, °C
IDE10571,Turbo charger.1 turbine inp.: temp.sens. 1 bank 1: ins.resist.,0, kOhm
IDE10576-ENG188621,Reducing agent system and actuator: condition-Bits 0-7,8,
IDE10576-ENG188621,Reducing agent system and actuator: condition-Bits 0-7,196,
IDE10579-ENG188621,Reducing agent system pressurization release conditions-Bits 0-7,255,
IDE10579-ENG188621,Reducing agent system pressurization release conditions-Bits 0-7,7,
IDE10580,Engine oil level: test method 1,46.7, %
IDE10581,Engine oil level: test method 2,86.0, %
IDE10582,Engine oil level: test method 3,42.4, %
IDE10633,Clutch protection function: reduced torque,3276.0, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0.0, 1/min/s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,55, ml/mm
IDE10811-ENG188621,Release requirement for DPF regeneration-Bits 0-7,0,
IDE10812-ENG188621,Particulate filter regeneration: status-Bits 0-7,0,
IDE10813,Temp. dwnstrm. of oxi-cat without fuel combustion: calculated,176.2, °C
IDE10814,Exhaust recirculation cooler 2 Bank 1: efficiency calculated,0.0000,
IDE10815,Post injection 2: quantity spec. value,1.00, mg/stroke
IDE10816-ENG188621,Particulate filter regeneration level: current-Bits 0-7,0,
IDE10817,Lambda value at inlet of particulate filter,5.004,
IDE10818,Temp. spec. value for exhaust gas temp.con.dwnstrm. of oxi-cat,-1000.0, °C
IDE10819,Exh. gas temp.control dwnstrm. of oxi-cat: filtered model error,-0.0, °C
IDE10820,Exh. gas temp. ctrl. upstrm. of turbine: spec. value,364.7, °C
IDE10823,Exhaust gas model temperature 5,95.6, °C
IDE10824,Exhaust gas model temperature 6,-0.0, °C
IDE10825,Exhaust gas model temperature 7,-0.0, °C
IDE10826,Exh. gas temp. controller upstrm. of turbine: I-part,0.000,
IDE10827,Exh.gas temp.contr. dwnstrm.of oxi-cat:post inject.qty.spec.val,0.00, mg/stroke
IDE10828,Exh. gas temp.contr. upstrm. of turbine: post inject.qty.corr.,0.00, mg/injection
IDE10829,Post injection 1: quantity spec. value,1.00, mg/stroke
IDE10830,Post injection 3: quantity spec. value,0.00, mg/stroke
IDE10831,Exhaust recirculat.2: different.press.sens.1 bank 1: calculated,986, hPa
IDE10878,Remaining veh distance until reducing agent deficiency:display,9007.95, km
IDE10879,Sensor for reducing agent fill level: calibrated,54.72, %
IDE10917,Reducing agent delivery pump: coil temperature,39.0, °C
IDE10920,Temp. upstrm. of reducing agent cat.: calculated,175.5, °C
IDE10921-ENG188621,Reducing agent delivery pump: number of strokes-Bits 0-7,173,
IDE10921-ENG188621,Reducing agent delivery pump: number of strokes-Bits 0-7,0,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,6,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,3,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11074,Fuel pres.sen. 1 bank 1 upstream from HD pump: press. dev.,0.0, kPa
IDE11111,Fuel pres.sen 1 bank 1 upstr from HD pump: act.value averaged,519.5, kPa
IDE11112,Fuel pres.sens.1 bank 1 upstr from HD pump: act.val. filtered,519.9, kPa
IDE11113,Fuel pres.sen. 1 bank 1 upstream from HD pump: raw volt.,2.364, V
IDE11114,Fuel press. sensor 1 bank 1 upstr. from HD pump: adapt. value,0.0, kPa
IDE11115,Start/stop driver request: counter restart by starter,4,
IDE11116,Start/stop driver request: counter internal-motor restart,1,
IDE11117,Charge press. ctrl deviation after throttle valve bank 1,932.0, hPa
IDE11118,Pressure after throttle valve: calculated,-24.0, hPa
IDE11119,Pressure corr. value after low pressure EGR valve: calculated,-30.8, hPa
IDE11203,Oil pressure setpoint,228.7, kPa
IDE11219,Reducing agent inj. quantity: spec. value,3.3, mg/s
IDE11220,Reducing agent system: current status,METMOD,
IDE11220-ENG127431,Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE,30,
IDE11221,Reducing agent system: last status,PPREPN,
IDE11221-ENG127431,Reducing agent system: last status-Test_Program_SCR Con State 01 UBYTE,20,
IDE11222,Reducing agent system: current substatus,NOSUBST,
IDE11222-ENG127432,Reducing agent system: current substatus-Test_Program_SCR Con State 02 UBYTE,0,
IDE11223,Reducing agent system: last substatus,PPREPN_PBLD,
IDE11223-ENG127432,Reducing agent system: last substatus-Test_Program_SCR Con State 02 UBYTE,20,
IDE11227,Charge air cooler water mixing valve: position feedback  closed: offset,0.00, %
IDE11267,Oil level: max. value: relative,-3276.8, %
IDE11268,Oil level: min. value: relative,3276.7, %
IDE11302-ENG188621,Engine oil level: test method 1 qualification-Bits 0-7,1,
IDE11303-ENG188621,Engine oil level: test method 3 qualification-Bits 0-7,1,
IDE11321-ENG188621,Rail press. regulation: operating condition-Bits 0-7,3,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,161,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,2,
IDE11330,Oil press. control valve: activation pulse duty factor,33.60, %
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometres,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometres,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometres,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometres,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometres,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometres,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometres,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometres,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometres,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometres,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11448,Reducing agent over-pressure: diagnosis progress,100.0, %
IDE11449,Reducing agent under-pressure: diagnosis progress,100.0, %
IDE11574,Status max. oil level dynamically exceeded,False result,
IDE11574-ENG127289,Status max. oil level dynamically exceeded-Test_Program_B TRUE UBYTE,0,
IDE11575,Status max. oil level permanently exceeded,False result,
IDE11575-ENG127289,Status max. oil level permanently exceeded-Test_Program_B TRUE UBYTE,0,
IDE11576,Oil level: last valid dynamic value overfilling,0.000, mm
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11895-ENG188621,Particle filter: differential press. sens.1 bank 1: raw data 1-Bits 0-7,181,
IDE11895-ENG188621,Particle filter: differential press. sens.1 bank 1: raw data 1-Bits 0-7,2,
IDE11896,Particle filter: differential press. sens.1 bank 1: raw value 1,11, hPa
IDE11897,Particle filter: differential press. sens.1 bank 1: raw value 2,10, hPa
IDE11898-ENG188621,Particle filter: differential press. sens.1 bank 1: raw data 2-Bits 0-7,179,
IDE11898-ENG188621,Particle filter: differential press. sens.1 bank 1: raw data 2-Bits 0-7,2,
IDE11899,Par.fil: diff.pr.sens.1 bank 1: sensor temperature,84.36, °C
IDE11900,Par.fil: diff.pr.sens.1 bank 1: data quality,100.00, %
IDE11901-ENG188621,Par.fil: diff.pr.sens.1 bank 1: sensor configuration-Bits 0-7,0,
IDE11902-ENG188621,Par.fil: diff.pr.sens.1 bank 1: manufacturer ID-Bits 0-7,0,
IDE11903-ENG188621,Par.fil: diff.pr.sens.1 bank 1: internal error code-Bits 0-7,0,
IDE11904-ENG188621,Par.fil: diff.pr.sens.1 bank 1: sensor type-Bits 0-7,0,
IDE11905-ENG188621,Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-7,0,
IDE11905-ENG188621,Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-7,14,
IDE11906-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,14,
IDE11906-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,0,
IDE11907-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,0,
IDE11907-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,15,
IDE11908-ENG188621,Throttle position actuator 1 bank 1: adaptation status-Bits 0-7,15,
IDE11908-ENG188621,Throttle position actuator 1 bank 1: adaptation status-Bits 0-7,0,
IDE11910-ENG188621,Turbine actuator 1 bank 1: adaptation status-Bits 0-7,0,
IDE11910-ENG188621,Turbine actuator 1 bank 1: adaptation status-Bits 0-7,7,
IDE11981,Turbocharg. 1 turb: input temp.sensor 1 bank 1: data quality,0.00, %
IDE12044-ENG188621,Crankshaft Position adapt.: write attempt counter-Bits 0-7,1,
IDE12074-ENG188621,Position adapt. of intake camshaft bank 1: counter-Bits 0-7,1,
IDE12078-ENG188621,Position adapt. of camshafts cyl: individual bank 1: counter-Bits 0-7,0,
IDE12105,Temperature sensor for cylinder block: uncond. voltage value,931.4, mV
IDE12106,Temperature sensor for cylinder block,92.4, °C
IDE12392,Turbocharger: pin separation from min. throughput position,100.0, mV
IDE12457-ENG188621,Turbocharger 1 bypass valve 1 bank 1: position feedback  adaption value-Bits 0-7,7,
IDE12458,Turbocharger 1 bypass valve 1 bank 1: position feedback  initial teach-in,957.0, mV
IDE12468-ENG188621,Login counter of the simulation interface-Bits 0-7,0,
IDE12683,Reducing agent system efficiency diagnostic release,0,
IDE12748,Oil level: amount added MIN to MAX,1000, ml
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,16793602,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13387,Turbocharger: current averaged minimum throughput position,857.0, mV
IDE13597,NOx sensor 3: NOx concentration,2, ppm
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WV2ZZZSK8SX116493,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,21,
IDE13845,Production mode status,False result,
IDE13845-ENG127289,Production mode status-Test_Program_B TRUE UBYTE,0,
IDE14135,Cylinder pressure sensor 3: angle correction value,-0.68, °
IDE14152,Oil level: maximum value: compensated,19.500, mm
IDE14153,Oil level: minimum value: compensated,46.728, mm
IDE14207,Fuel pressure sensor for high-pressure pump: regulation status,Correct result,
IDE14207-ENG127289,Fuel pressure sensor for high-pressure pump: regulation status-Test_Program_B TRUE UBYTE,1,
IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,0.00, %
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 D8,
IDE14492-MAS28619,Secure Onboard Communication: verification failed-currently failed,not failed,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3E 28 30 EA 48 10 6A,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,9,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0A,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14502-ENG188621,Fuel system output test status-Bits 0-7,0,
IDE14503-ENG188621,High-pressure fuel system: leak test status-Bits 0-7,0,
IDE14505-ENG188621,High Pressure test: status-Bits 0-7,0,
IDE14507,Fuel high-pressure system: residual current pressure regulation valve,0, mA
IDE14508,Fuel high-pressure system: pressure regulation valve control limit,0, mm³/s
IDE14509,Fuel high pressure system: lowest fuel low-pressure value,0, hPa
IDE14510,High-pressure fuel system: metering unit first throttle effect,0, mm³/s
IDE14511,Fuel high-pressure system: leak test maximum value,0, hPa
IDE14512,High-pressure fuel system: leak test final result,0, hPa
IDE14513,High pressure system: leak test starter deactivated,0, hPa
IDE14518,High Pressure test: standard deviation phase 4,0, hPa
IDE14519,High Pressure test: standard deviation phase 3,0, hPa
IDE14520,High Pressure test: standard deviation phase 2,0, hPa
IDE14521,High Pressure test: standard deviation phase 1,0, hPa
IDE14522,High Pressure test: pressure build-up time phase 4,0, ms
IDE14523,High Pressure test: pressure build-up time phase 3,0, ms
IDE14524,High Pressure test: pressure build-up time phase 2,0, ms
IDE14525,High Pressure test: pressure build-up time phase 1,0, ms
IDE14526,High Pressure test: pressure reduction time phase 4,0, ms
IDE14527,High Pressure test: pressure reduction time phase 3,0, ms
IDE14528,High Pressure test: pressure reduction time phase 2,0, ms
IDE14529,High Pressure test: pressure reduction time phase 1,0, ms
IDE14536,High Pressure test: high pressure average value phase 1,0, hPa
IDE14537,High Pressure test: high pressure average value phase 2,0, hPa
IDE14538,High Pressure test: high pressure average value phase 3,0, hPa
IDE14539,High Pressure test: high pressure average value phase 4,0, hPa
IDE14540,High Pressure test: pressure build-up time: final value 1,0, ms
IDE14541,High Pressure test: pressure build-up time: final value 2,0, ms
IDE14542,High Pressure test: pressure build-up time: final value 3,0, ms
IDE14607-ENG188621,Coolant distributor module: position feedback  breakaway attempts-Bits 0-7,0,
IDE14608-ENG188621,Coolant distributor module: position feedback  mechanical stops-Bits 0-7,0,
IDE14904,Crankcase ventilation heater 1: control,0.00, %
IDE14965,AGR total ground current: deviation from specified value,-0.1, kg/h
IDE14966,High Pressure AGR ground current: threshold value deviation from specified value,0.0, kg/h
IDE14967,Low pressure AGR ground current threshold value discrepancy from specified value,2.0, kg/h
IDE14968,High Pressure AGR ground current: deviation from specified value,0.1, kg/h
IDE14969,Low pressure AGR ground current: deviation from specified value,-0.1, kg/h
IDE14971,AGR overall ground current: threshold value deviation from specified value,500.0, kg/h
IDE15033,Oxidation catalytic converter diagnostic: distance since last intervention,11986406, m
IDE15034,Oxidation catalytic converter diagnostic: frequency counter mode,0,
IDE15186,NOx sensor 3: offset for correction factor,-2, ppm
IDE15187,NOx-Sensor 3: O2-Concentration,0.15469,
IDE15271-ENG188621,Crankcase ventilation disk separator: actual speed-Bits 0-7,255,
IDE15272,Crankcase ventilation disk separator: supply voltage,25.5, V
IDE15273,Crankcase ventilation disk separator: current consumption,51.0, A
IDE15317,Reducing agent injector 2: current holding phase,433, mA
IDE15318,Calculated temperature at reduction agent injection valve 2,60.7, °C
IDE15319,Reducing agent injector 2: current saturation phase,944, mA
IDE15320,Reducing agent injector 2: resistance,13792, mOhm
IDE15321,Efficiency of SCR catalytic converter 2,0.61084,
IDE15322,Temperature of SCR catalytic converter 2 calculated,148.7, °C
IDE15323,Efficiency threshold of NOx efficiency In the catalytic converter 2,0.000,
IDE15324,Measured NOx efficiency of SCR catalytic converter 2,0.000,
IDE15330-ENG188621,Initial fuel filling with toggle activation: status-Bits 0-7,0,
IDE15565,High-pressure fuel system: low-pressure pump duty cycle,0.00, %
IDE15592-ENG188621,Fuel high-pressure system: flow rate test operating point-Bits 0-7,0,
IDE15593,Fuel high-pressure system: fuel temperature during test,-273.1, °C
IDE15712-ENG188621,NOx sensor 1: release status-Bits 0-7,31,
IDE15713-ENG188621,NOx sensor 2: release status-Bits 0-7,31,
IDE15714-ENG188621,NOx sensor 3: release status-Bits 0-7,31,
IDE15715,NOx efficiency SCR diagnostic: progress,0.000,
IDE15716,NOx efficiency SCR 2 diagnostic: progress,0.000,
IDE15717,NOx efficiency SCR diagnostic: release status,4088266735,
IDE15718,NOx efficiency SCR 2 diagnostic: release status,2029518331,
IDE15719,NOx efficiency SCR diagnostic: quick-start release status,4087738351,
IDE15720,NOx efficiency SCR 2 diagnostic: quick-start release status,2029252091,
IDE15781,VW Trustcenter Project ID,1073,
IDE15785,Reducing agent sensor quality: adaptation status,False result,
IDE15785-ENG127289,Reducing agent sensor quality: adaptation status-Test_Program_B TRUE UBYTE,0,
IDE15922,NOx sensor: oxygen adaptation factor,1.0337,
IDE15923,NOx sensor 2: oxygen adaptation factor,1.0361,
IDE15924,NOx sensor 3: oxygen adaptation factor,1.0215,
IDE15928,NOx Sensor: Lambda actual value,4.275,
IDE15929,NOx Sensor 2: Lambda actual value,4.421,
IDE15930,NOx Sensor 3: Lambda actual value,4.242,
IDE15963,NOx sensor 3: heater release status,Correct result,
IDE15963-ENG127289,NOx sensor 3: heater release status-Test_Program_B TRUE UBYTE,1,
IDE15964,NOx sensor 3: signal validity after start/stop phase,Correct result,
IDE15964-ENG127289,NOx sensor 3: signal validity after start/stop phase-Test_Program_B TRUE UBYTE,1,
IDE15965,NOx sensor 3: Lambda validity - signal,1,
IDE15966,NOx sensor 3: validity,1,
IDE15973,NOx sensor 3: inverse Lambda - signal,0.2580,
IDE15981,NOx sensor 1: heater release status,Correct result,
IDE15981-ENG127289,NOx sensor 1: heater release status-Test_Program_B TRUE UBYTE,1,
IDE15982,NOx sensor 2: heater release status,Correct result,
IDE15982-ENG127289,NOx sensor 2: heater release status-Test_Program_B TRUE UBYTE,1,
IDE15983,NOx sensor 1: status after start/stop phase,Correct result,
IDE15983-ENG127289,NOx sensor 1: status after start/stop phase-Test_Program_B TRUE UBYTE,1,
IDE15984,NOx sensor 2: status after start/stop phase,Correct result,
IDE15984-ENG127289,NOx sensor 2: status after start/stop phase-Test_Program_B TRUE UBYTE,1,
IDE16005,Drive train coordinator: acceleration request target value,0.000, m/s²
IDE16006,Drive train coordinator current status,2,
IDE16007,Drive train coordinator: Acceleration Requester Status,0,
IDE16008,Drive Train Coordinator: Embassies Status,16,
IDE16009,Drivetrain coordinator: proximity control type,0,
IDE16010,Driver assistance systems: control panel actuations,16385,
IDE16011,Drive train coordinator: blocking reasons of CCS and limiter,0,
IDE16022,Urea concentration: temperature & offset corrected,33.3, %
IDE16023,urea concentration: temperature corrected,33.30, %
IDE16115,Consumed reducing agent,12134.760, g
IDE16127-ENG188621,Particulate sensor: status-Bits 0-7,2,
IDE16131,Initial calibration: individual progresses,0.000, µA
IDE16144,Heating circuit 1 for Reducing Agent Metering System: PWM activation,0.00, %
IDE16145,Heating circuit 2 for Reducing Agent Metering System: PWM activation,0.00, %
IDE16146,Heating circuit 3 for Reducing Agent Metering System: PWM activation,0.00, %
IDE16147,Reducing agent injector: mass flow actual value,0.0, mg/s
IDE16148,Reducing agent injector 2: mass flow actual value,0.0, mg/s
IDE16149,Reducing Agent Injector 2: mass flow set point,0.0, mg/s
IDE16150,Reducing Agent Injector: adaptation factor,0.000,
IDE16151,Reducing Agent Injector 2: adaptation factor,0.000,
IDE16153,Reducing agent return flow pump: coil resistance,4073, mOhm
IDE16210,Reducing Agent Return Flow Pump: flush temperature,43.0, °C
IDE16240-ENG188621,Counter write attempts: adaptation to aging SCR coating-Bits 0-7,0,
IDE16313-ENG188621,Crankshaft sensor wheel adaptation values: status after reset-Bits 0-7,1,
IDE16315,Reducing Agent Pump: flow volume per stroke,32.30, mm³/stroke
IDE16334-ENG188621,Reducing Agent Metering System: status after initial filling-Bits 0-7,0,
IDE16335-ENG188621,Reducing Agent Metering System: status after pressure build-up-Bits 0-7,0,
IDE16336-ENG188621,Reducing Agent Metering System: status before system emptied-Bits 0-7,0,
IDE16339-ENG188621,Reducing Agent Metering System: status of dosing volume test: valve 2-Bits 0-7,0,
IDE16340-ENG188621,Reducing Agent Metering System: status of dosing volume test: valve 1-Bits 0-7,0,
IDE16408-ENG188621,Reducing Agent delivery pump: status at last suction stroke-Bits 0-7,2,
IDE16409,Reducing agent flow pump: time between strokes,10414, ms
IDE16410,Reducing agent delivery pump: operating mode,URSOLNPMP_IDLE,
IDE16410-ENG281607,Reducing agent delivery pump: operating mode-Test_Program_Ur Soln Pmp st Pmp Oper Mod VERB UBYTE,0,
IDE16412,Reducing agent delivery pump: coil resistance correction factor,0.999,
IDE16413,Reducing agent return flow pump: adapt coil resistance,0.995,
IDE16414,Reducing Agent Metering System: maximum defrosting time,0, s
IDE16415,Reducing Agent Metering System: actual defrosting time,309, s
IDE16416,Reducing Agent Metering System: thawed mass calculated,2000000.0, mg
IDE16473,Reducing agent pump: change of volume of one stroke,-0.00054, mm³/hPa
IDE16474,Reducing agent return pump: volume per stroke,50.00, mm³/stroke
IDE16475,Reducing agent injector 2: specified value,0.0, ms
IDE16476,Reducing agent return pump: volume per increased stroke,32.45, mm³/stroke
IDE16477,Reducing agent return pump: change of volume per stroke,-0.00056, mm³/hPa
IDE16478,Particulate filter reducing agent injector: specified value,0.0, ms
IDE16608,Engine protection torque limitation: depending on temperature,0,
IDE16613,Reducing agent return flow pump: coil resistance reference value,3730, mOhm
IDE17643,Filling level at start of diagnosis initialization,0.000, l
IDE19430,Heater for catalytic converter: current,16383.8, A
IDE19431,Heater for catalytic converter: voltage,6553.5, V
IDE19432,Heater for catalytic converter: actual power,65535, W
IDE20033,Radiator blind 1: actual position,1638.38, %
IDE20034,Radiator blind 2: actual position,1638.38, %
MAS16371-ENG188621,Low pressure EGR cooler efficiency diagnostic: status-Bits 0-7,184,
MAS16371-ENG188621,Low pressure EGR cooler efficiency diagnostic: status-Bits 0-7,31,
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16535,Exhaust gas recirculation 2: filter pressure loss at bank 1: modeled,-500.0, hPa
MAS16536,Exhaust gas recirculation 2: filter pressure loss at bank 1: simulated,-1.0, hPa
MAS16542,NOx catalytic converter of Bank 1: NH3 reducing agent fill level,0.4067, g/l
MAS17236-ENG188621,Adaptation of radiator shutter 2: status-Bits 0-7,0,
MAS17359-ENG188621,Mass airflow sensor: temperatures: raw data-Bits 0-7,1,
MAS17359-ENG188621,Mass airflow sensor: temperatures: raw data-Bits 0-7,163,
MAS17360-ENG188621,Mass airflow sensor including temperature sensor: sensor type-Bits 0-7,26,
MAS17360-ENG188621,Mass airflow sensor including temperature sensor: sensor type-Bits 0-7,0,
MAS17361-ENG188621,Mass airflow sensor including temperature sensor: sensor design-Bits 0-7,0,
MAS17362-ENG188621,Mass airflow sensor including temperature sensor: internal fault code-Bits 0-7,0,
MAS17363-ENG188621,Mass airflow sensor: airflow: raw data-Bits 0-7,23,
MAS17363-ENG188621,Mass airflow sensor: airflow: raw data-Bits 0-7,105,
MAS17364-ENG188621,Mass airflow sensor including temperature sensor: manufacturer ID-Bits 0-7,0,
MAS17364-ENG188621,Mass airflow sensor including temperature sensor: manufacturer ID-Bits 0-7,118,
MAS17365,Mass airflow sensor including temperature sensor: data quality,100.00, %
MAS17366-ENG188621,Charge air cooler inlet: pressure sender: sensor design-Bits 0-7,0,
MAS17366-ENG188621,Charge air cooler inlet: pressure sender: sensor design-Bits 0-7,1,
MAS17367-ENG188621,Charge air cooler inlet: pressure sender: raw data-Bits 0-7,3,
MAS17367-ENG188621,Charge air cooler inlet: pressure sender: raw data-Bits 0-7,207,
MAS17368,Charge air cooler inlet: pressure sender: data quality,100.00, %
MAS17369-ENG188621,Charge air cooler inlet: pressure sender: internal error code-Bits 0-7,0,
MAS17370-ENG188621,Charge air cooler inlet: pressure sender: manufacturer ID-Bits 0-7,0,
MAS17370-ENG188621,Charge air cooler inlet: pressure sender: manufacturer ID-Bits 0-7,86,
MAS17371-ENG188621,Charge air cooler inlet: pressure sender: sensor type-Bits 0-7,0,
MAS17371-ENG188621,Charge air cooler inlet: pressure sender: sensor type-Bits 0-7,4,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,40 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS20408,NOx catalytic converter 2: NH3 reducing agent loading,0.2417, g/l
MAS21928,Drive train coordinator: longitudinal dynamics control: functionalities,12,
MAS22113,SCR initial filling,Correct result,
MAS22113-ENG127289,SCR initial filling-Test_Program_B TRUE UBYTE,1,
MAS25521-ENG188621,Reducing agent delivery pump: error status-Bits 0-7,0,
MAS26973,Engine control module: terminal 30 voltage monitoring status,Correct result,
MAS26973-ENG127289,Engine control module: terminal 30 voltage monitoring status-Test_Program_B TRUE UBYTE,1,
MAS30043,SCR quality sensor,32.90, %
ENG119898,Actual_section_of_standard_test,0,
ENG390318,AES IDs and States,|Auxiliary Emission Strategy Identifier,Auxiliary Emission Strategy State|2304
ENG122655,Air_flow_adaption_engine_revolutions_datapoint,2750.0, /min
ENG122656,Air_flow_adaption_map_number_datapoint,0,
ENG122654,Air_flow_adaption_mass_flow_value,0, mg/stroke
ENG122657,Air_flow_adaption_moment_datapoint,390.0, Nm
ENG128810-ENG188621,Boost_pressure_adaption_index_value-Bits 0-7,1,
ENG128811,Boost_pressure_adaption_learning_value,0.00, hPa
ENG101413,Calibration Identifications,05L023QK4626BEAE,
ENG99697,Calibration Verification Numbers,52 0B 73 0B,
ENG126402-ENG188621,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,4,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,0,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG274020,Cylinder Fuel Rate,4.44, mg/stroke
ENG105735,Cylinder_pressure_offset_cylinder_3,-0.992, bar
ENG254612-ENG255535,Diesel Exhaust Fluid Dosing-Commanded DEF Dosing,0.0, %
ENG254612-ENG255536,Diesel Exhaust Fluid Dosing-Commanded DEF Dosing Supported,Not available,
ENG254612-ENG255583,Diesel Exhaust Fluid Dosing-DEF Usage for the Current Driving Cycle,0.0015, l
ENG254612-ENG255584,Diesel Exhaust Fluid Dosing-DEF Usage for the Current Driving Cycle Supported,Available,
ENG274021-ENG274330,Diesel Exhaust Fluid Sensor Output-DEF Concentration,33.25, %
ENG274021-ENG274331,Diesel Exhaust Fluid Sensor Output-DEF Concentration supported,Available,
ENG274021-ENG274332,Diesel Exhaust Fluid Sensor Output-DEF Level supported,Available,
ENG274021-ENG274333,Diesel Exhaust Fluid Sensor Output-DEF Tank Level,58.0, %
ENG274021-ENG274334,Diesel Exhaust Fluid Sensor Output-DEF Tank Temperature,38, °C
ENG274021-ENG274335,Diesel Exhaust Fluid Sensor Output-DEF Temperature supported,Available,
ENG274021-ENG274336,Diesel Exhaust Fluid Sensor Output-DEF Type,No Sensor fault: no results available,
ENG274021-ENG274337,Diesel Exhaust Fluid Sensor Output-DEF Type supported,Available,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG106086-ENG188621,EGR_governor_deviation_monitoring_enabling-Bits 0-7,0,
ENG247045,Engine Exhaust Flow Rate,40.6, kg/h
ENG151174,Engine Friction - Percent Torque,6.0, %
ENG289267-ENG188621,Exh st N Ox Sens Vld Bits Cat2 Ds-Bits 0-7,0,
ENG137923-ENG188621,Exh st N Ox Sens Vld Bits Ds-Bits 0-7,31,
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.16, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.16, g/s
ENG151175-ENG151917,Fuel System Control Status (Compression Ignition)-Fuel Injection Quantity Control 1 Status,in closed loop control,
ENG151175-ENG151925,Fuel System Control Status (Compression Ignition)-Fuel Injection Quantity Control 1 supported,Available,
ENG151175-ENG151921,Fuel System Control Status (Compression Ignition)-Fuel Injection Quantity Control 2 Status,not in closed loop control,
ENG151175-ENG151929,Fuel System Control Status (Compression Ignition)-Fuel Injection Quantity Control 2 supported,Not available,
ENG151175-ENG151918,Fuel System Control Status (Compression Ignition)-Fuel Injection Timing Control 1 Status,in closed loop control,
ENG151175-ENG151926,Fuel System Control Status (Compression Ignition)-Fuel Injection Timing Control 1 supported,Available,
ENG151175-ENG151922,Fuel System Control Status (Compression Ignition)-Fuel Injection Timing Control 2 Status,not in closed loop control,
ENG151175-ENG151930,Fuel System Control Status (Compression Ignition)-Fuel Injection Timing Control 2 supported,Not available,
ENG151175-ENG151916,Fuel System Control Status (Compression Ignition)-Fuel Pressure Control 1 Status,in closed loop control,
ENG151175-ENG151924,Fuel System Control Status (Compression Ignition)-Fuel Pressure Control 1 supported,Available,
ENG151175-ENG151920,Fuel System Control Status (Compression Ignition)-Fuel Pressure Control 2 Status,not in closed loop control,
ENG151175-ENG151928,Fuel System Control Status (Compression Ignition)-Fuel Pressure Control 2 supported,Not available,
ENG151175-ENG151919,Fuel System Control Status (Compression Ignition)-Idle Fuel Balance/Contribution Control 1 Status,in closed loop control,
ENG151175-ENG151927,Fuel System Control Status (Compression Ignition)-Idle Fuel Balance/Contribution Control 1 supported,Available,
ENG151175-ENG151923,Fuel System Control Status (Compression Ignition)-Idle Fuel Balance/Contribution Control 2 Status,not in closed loop control,
ENG151175-ENG151931,Fuel System Control Status (Compression Ignition)-Idle Fuel Balance/Contribution Control 2 supported,Not available,
ENG111022,Glow_period_control_unit_calculated_glow_voltage,0, mV
ENG111025,Glow_period_control_unit_energy_integrator_calculated_value,220.0, V²s
ENG111024,Glow_period_control_unit_energy_integrator_input_voltage,0, mV
ENG111026,Glow_period_control_unit_engine_temperature,92.5, °C
ENG103875-ENG99452,In-use Performance Tracking: 16 counters-Boost Pressure Monitor Completion Condition Counts,706, counts
ENG103875-ENG103994,In-use Performance Tracking: 16 counters-Boost Pressure Monitor Conditions Encountered Counts,180, counts
ENG103875-ENG125935,In-use Performance Tracking: 16 counters-Counters 17-18,|Fuel Monitor Completion Condition Counts,Fuel Monitor Conditions Encountered Counts|1057
ENG103875-ENG100817,In-use Performance Tracking: 16 counters-EGR and/or VVT Monitor Completion Condition Counts,0, counts
ENG103875-ENG101113,In-use Performance Tracking: 16 counters-EGR and/or VVT Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG104133,In-use Performance Tracking: 16 counters-Exhaust Gas Sensor Monitor Completion Condition Counts,0, counts
ENG103875-ENG104165,In-use Performance Tracking: 16 counters-Exhaust Gas Sensor Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG102823,In-use Performance Tracking: 16 counters-Ignition Cycle Counter,46080, counts
ENG103875-ENG99234,In-use Performance Tracking: 16 counters-NMHC Catalyst Monitor Completion Condition Counts,0, counts
ENG103875-ENG99167,In-use Performance Tracking: 16 counters-NMHC Catalyst Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG101363,In-use Performance Tracking: 16 counters-NOx Adsorber Monitor Completion Condition Counts,0, counts
ENG103875-ENG103522,In-use Performance Tracking: 16 counters-NOx Adsorber Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG125933,In-use Performance Tracking: 16 counters-NOx/SCR Catalyst Monitor Completion Condition Counts,0, counts
ENG103875-ENG125934,In-use Performance Tracking: 16 counters-NOx/SCR Catalyst Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG99988,In-use Performance Tracking: 16 counters-OBD Monitoring Conditions Encountered Counts,8448, counts
ENG103875-ENG100240,In-use Performance Tracking: 16 counters-PM Filter Monitor Completion Condition Counts,0, counts
ENG103875-ENG103730,In-use Performance Tracking: 16 counters-PM Filter Monitor Conditions Encountered Counts,0, counts
ENG110883,IUMPR_minimum_ratio_group_0,7.1428,
ENG110884,IUMPR_minimum_ratio_group_1,2.4777,
ENG110885,IUMPR_minimum_ratio_group_2,0.0000,
ENG110886,IUMPR_minimum_ratio_group_3,6.0000,
ENG110887,IUMPR_minimum_ratio_group_4,0.8999,
ENG110888,IUMPR_minimum_ratio_group_5,2.3944,
ENG110889,IUMPR_minimum_ratio_group_6,3.9221,
ENG110890,IUMPR_minimum_ratio_group_7,5.8722,
ENG107569,Main_injection_quantity,1.23, mg/stroke
ENG274010-ENG274696,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 3,0, ppm
ENG274010-ENG274697,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 3 data availability,Results available OR MAX value because of Sensor fault,
ENG274010-ENG274698,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 3 supported,installed,
ENG274010-ENG274699,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 4,0, ppm
ENG274010-ENG274700,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 4 data availability,Results available OR MAX value because of Sensor fault,
ENG274010-ENG274701,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 4 supported,not installed,
ENG274010-ENG274702,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 3,0, ppm
ENG274010-ENG274703,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 3 data availability,Results available OR MAX value because of Sensor fault,
ENG274010-ENG274704,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 3 supported,not installed,
ENG274010-ENG274705,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 4,0, ppm
ENG274010-ENG274706,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 4 data availability,Results available OR MAX value because of Sensor fault,
ENG274010-ENG274707,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 4 supported,not installed,
ENG151177-ENG151947,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 1 Sensor 3,15.780366, %
ENG151177-ENG151955,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 1 Sensor 3 supported,Available,
ENG151177-ENG151948,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 1 Sensor 4,0.000000, %
ENG151177-ENG151956,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 1 Sensor 4 supported,Not available,
ENG151177-ENG151949,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 2 Sensor 3,0.000000, %
ENG151177-ENG151957,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 2 Sensor 3 supported,Not available,
ENG151177-ENG151950,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 2 Sensor 4,0.000000, %
ENG151177-ENG151958,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 2 Sensor 4 supported,Not available,
ENG151177-ENG151951,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 1 Sensor 3,4.265, lambda
ENG151177-ENG151959,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 1 Sensor 3 supported,Available,
ENG151177-ENG151952,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 1 Sensor 4,0.000, lambda
ENG151177-ENG151960,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 1 Sensor 4 supported,Not available,
ENG151177-ENG151953,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 2 Sensor 3,0.000, lambda
ENG151177-ENG151961,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 2 Sensor 3 supported,Not available,
ENG151177-ENG151954,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 2 Sensor 4,0.000, lambda
ENG151177-ENG151962,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 2 Sensor 4 supported,Not available,
ENG168870,Oxicat_diagnose_active_status,20542,
ENG127252-ENG151857,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 1 Sensor 1,active,
ENG127252-ENG151859,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 2 Sensor 1,not active,
ENG127252-ENG151855,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 1 Sensor 1,0.00, %
ENG127252-ENG151856,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 2 Sensor 1,0.00, %
ENG127252-ENG151861,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 1 Sensor 1 supported,Available,
ENG127252-ENG151863,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 2 Sensor 1 supported,Not available,
ENG127252-ENG151858,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 1 Sensor 1,not active,
ENG127252-ENG151860,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 2 Sensor 1,not active,
ENG127252-ENG151862,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 1 Sensor 1 supported,Available,
ENG127252-ENG151864,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 2 Sensor 1 supported,Not available,
ENG119902-ENG188621,Prioritize_exceptional_case_control-Bits 0-7,0,
ENG127401,Reductant_inducement_system_error,False result,
ENG127401-ENG127289,Reductant_inducement_system_error-Test_Program_B TRUE UBYTE,0,
ENG281417,Reductant_pump_coil_resistance_reference,3780, mOhm
ENG110382-ENG151591,SCR inducem system status-deviation of reagent consumption,Unknown (0)
ENG110382-ENG151584,SCR inducem system status-Distance traveled in current 10K block,1325, km
ENG110382-ENG151585,SCR inducem system status-Distance traveled while inducement system active in 20K block,0, km
ENG110382-ENG151586,SCR inducem system status-Distance traveled while inducement system active in 30K block,0, km
ENG110382-ENG151587,SCR inducem system status-Distance traveled while inducement system active in 40K block,0, km
ENG110382-ENG151583,SCR inducem system status-Distance traveled while inducement system active in current 10K block,0, km
ENG110382-ENG151590,SCR inducem system status-incorrect reagent,Unknown (0)
ENG110382-ENG151588,SCR inducem system status-inducement system active,not_active,
ENG110382-ENG151592,SCR inducem system status-NOx emissions too high,Unknown (0)
ENG110382-ENG151589,SCR inducem system status-reagent level too low,Unknown (0)
ENG132858-ENG188621,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,6,
ENG109106-ENG188621,Status_of_adaption_of_toothed_speed-Bits 0-7,1,
ENG132847,Top_speed_limitation,250.000, km/h
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG247048,Vehicle Odometer,12005.0, km
ENG252424,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime)
ENG132846,Velocity_limiter_setpoint,511.000, km/h
Elapsed Time: 01:36
blockmap-03-5WA-614-517-DQ_WV2ZZZSK8SX116493-20260803-1923.CSV
;SW:5WA-614-517-DQ   HW:5WA-614-517-BS ---  03: ABS Brakes
;Component:ESC           H31 0331, Coding:4A985428B44B399C4001559E1EB7C1C50ACF942151A000
;EV_Brake1ESCMQB37WUNECE,006026,EV_Brake1ESCMQB37WUNECE_006_VN3SP.rod
;Monday,03,August,2026,19:23:46:29755
;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0
;VCID: 1A6DD4408C18FA6A31F-804E SFD+SFD2 { }
Group,Description,Actual
IDE00019,Voltage terminal 30,13.828, V
IDE00021,Engine speed,983, /min
IDE00025,Coolant temperature,92.0, °C
IDE00085,Normed load value,25.8824, %
IDE00086,Accelerator pedal position,14.1, %
IDE00097,OBD - requirements for which this vehicle is designed,EOBD,
IDE00601-ENG161107,Monitoring status since erasing DTC memory-MIL_Status,OFF,
IDE00601-ENG161129,Monitoring status since erasing DTC memory-Number_of_errors_Mode$03,0,
IDE00601-ENG161142,Monitoring status since erasing DTC memory-Readiness_State,00000000 ,
IDE00601-ENG161227,Monitoring status since erasing DTC memory-Supported_Info,00000000 ,
IDE00601-ENG161228,Monitoring status since erasing DTC memory-Supported_Info_Readiness,00000100 ,
IDE00602-ENG161054,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_continous_diagnostics,00000100 ,
IDE00602-ENG161055,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_non_continous_diagnostics,00000000 ,
IDE00602-ENG161141,Monitoring status in current driving cycle-Readiness_Code,00000000 ,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-IDE05726,CAN input signal(s) status-Dimmer terminal 58xd,90.9, %
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,Not operated,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamps,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,SK8SX116493,
IDE02270-MAS15790,CAN input signal(s) status-Setting for clear error memory,locked,
IDE02271-IDE02070,CAN output signal(s) status-Wake-up cause,Bus communication,
IDE02486,Data logger triggering,not initialized,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,OFF,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.braking,not active,
IDE03008-MAS01299,Stop process prevented-Offroad,not active,
IDE03008-MAS01478,Stop process prevented-insufficient voltage,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.braking,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,4,
IDE03010-MAS01299,Number of prevented stop processes-Offroad,0,
IDE03010-MAS01478,Number of prevented stop processes-insufficient voltage,17,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,10737,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,21,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,16152,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,4,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,21,
IDE03310,Brake lamp,OFF,
IDE03310-MAS01167,Brake lamp-Actuation time,0 s,
IDE03310-ENG170421,Brake lamp-IoReached Status,Output diagnostic test not active,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,0.0, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,13.8, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,13.7, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,13.7, V
IDE03680-MAS01468,Supply voltages-Terminal 15,On,
IDE04082-MAS00580,Instrument cluster text output-Electromechanical parking brake text 1,0,
IDE04082-MAS03359,Instrument cluster text output-Text,0,
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.02, bar
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.00, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,forward,
IDE04425-MAS09580,Left front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.00, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,forward,
IDE04426-MAS09580,Right front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.00, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04427-MAS09580,Left rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.00, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-MAS09580,Right rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,-163.94500, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-163.70000, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,0.1, g
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.00000, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-327.680, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,16.006, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,7.694, °
IDE04443-MAS28636,Slip control system sensor-Yaw rate sensor 1: Z-axis: offset,0.000, °/s
IDE04446-IDE14988,Hill descent control-Incline,0, %
IDE04446-MAS01299,Hill descent control-Offroad,Off-road deactivated,
IDE04446-MAS05585,Hill descent control-Standby,not active,
IDE04446-MAS12601,Hill descent control-HDC intervention,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not operated,
IDE04452-IDE03664,Brake system button-Button for driving program,Not available due to specific system,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not available due to specific system,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,9008, km
IDE04461-IDE18475,Internal measured values-Data record 1: data block description,Block 1,
IDE04461-IDE18476,Internal measured values-Data record 2: data block description,Block 1,
IDE04461-IDE18477,Internal measured values-Data record 3: data block description,Block 1,
IDE04461-IDE18478,Internal measured values-Data record 4: data block description,Block 2,
IDE04461-IDE18479,Internal measured values-Data record 5: data block description,Block 2,
IDE04461-IDE18480,Internal measured values-Data record 6: data block description,Block 1,
IDE04461-IDE18481,Internal measured values-Data record 7: data block description,Block 2,
IDE04461-MAS01481,Internal measured values-Temperature in control module,86.7, °C
IDE04461-MAS10973,Internal measured values-Hardware reset,51,
IDE04461-MAS10974,Internal measured values-Software reset,553,
IDE04461-MAS17870,Internal measured values-Number of resets,0,
IDE04508-IDE01238,Hydraulic brake booster-Driving cycles,0,
IDE04508-MAS03095,Hydraulic brake booster-Function status,Available,
IDE04508-MAS27015,Hydraulic brake booster-Activation counter,0,
IDE04644-IDE02955,Roll-over protection-System status,Available,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,not activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,0, m/s²
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,0, km
IDE04772,Indicator light in the button for electromech. parking brake,On,
IDE04772-MAS01167,Indicator light in the button for electromech. parking brake-Actuation time,Without time limit,
IDE04772-ENG170421,Indicator light in the button for electromech. parking brake-IoReached Status,Output diagnostic test not active,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,9008, km
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,65.0, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,59.1, %
IDE04939-IDE02763,Tire Pressure Monitoring System (TPMS)-System malfunction lamp: status,OFF,
IDE04939-IDE02765,Tire Pressure Monitoring System (TPMS)-Pressure warning lamp: status,OFF,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,1048574, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,1048574, km
IDE04939-IDE09286,Tire Pressure Monitoring System (TPMS)-Software version of tire monitoring display,R2008A31,
IDE04939-IDE09287,Tire Pressure Monitoring System (TPMS)-Param. set version tire press monitoring display,11,
IDE04939-IDE09288,Tire Pressure Monitoring System (TPMS)-Param. set tire press monitor display: checksum,243,
IDE04939-IDE09289,Tire Pressure Monitoring System (TPMS)-Tire press monitor.display: diagnosis status,00 00 00 20 80 07 66 38 00 30,
IDE04939-IDE11039,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: le. frt,255,
IDE04939-IDE11040,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,241,
IDE04939-IDE11041,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.:counter for fast press. loss: le. rr.,254,
IDE04939-IDE11042,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,254,
IDE04939-IDE11043,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. frt,254,
IDE04939-IDE11044,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,248,
IDE04939-IDE11045,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. rr.,253,
IDE04939-IDE11046,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,253,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2026,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2000,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2025,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,7,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,3,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,4,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,0,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,10,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,5,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,17,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,8,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,29,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,25,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,2,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,0,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,18,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,4,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,0,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,14,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,1,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,13,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,0,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,2,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,25,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,44,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,35,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,40,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,24,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,13,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,51,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,38,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,9,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,21,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,17,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,0,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,33,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,55,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,6,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,20,
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,1048574, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,3887, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,147, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,10887, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,10887, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,10887, km
IDE04939-MAS14292,Tire Pressure Monitoring System (TPMS)-Analysis data of latest programming,02 22 00 00 00 00 00 00 00 10,
IDE04939-MAS14293,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest programming,02 22 00 00 00 00 00 00 00 10,
IDE04939-MAS14294,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14295,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14296,Tire Pressure Monitoring System (TPMS)-Analysis data of the latest warning,01 21 00 00 00 00 00 00 00 10,
IDE04939-MAS14297,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest warning,02 2D 00 00 00 00 98 99 01 20,
IDE04939-MAS14298,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest warning,02 2D 00 00 00 00 98 99 01 20,
IDE04939-MAS14299,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest warning,02 2D 00 00 00 00 98 99 01 20,
IDE04939-MAS18039,Tire Pressure Monitoring System (TPMS)-Odometer reading at fifth most recent configuration,5, km
IDE04939-MAS18041,Tire Pressure Monitoring System (TPMS)-Analysis data from fifth most recent configuration,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS18042,Tire Pressure Monitoring System (TPMS)-Temperature at time of most recent warning,15, °C
IDE04939-MAS18066,Tire Pressure Monitoring System (TPMS)-Temperature at time of second to last warning,13, °C
IDE04939-MAS18067,Tire Pressure Monitoring System (TPMS)-Temperature at time of third most recent warning,13, °C
IDE04939-MAS18069,Tire Pressure Monitoring System (TPMS)-Temperature at time of fourth most recent warning,15, °C
IDE04939-MAS18070,Tire Pressure Monitoring System (TPMS)-Odometer reading of fifth most recent warning,10887, km
IDE04939-MAS18072,Tire Pressure Monitoring System (TPMS)-Temperature at time of fifth most recent warning,15, °C
IDE04939-MAS18073,Tire Pressure Monitoring System (TPMS)-Analysis data of fifth most recent warning,02 25 00 00 00 00 98 99 01 20,
IDE04939-MAS18074,Tire Pressure Monitoring System (TPMS)-Tire control display parameter set info,194,
IDE04939-MAS18076,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during most recent warning,128, °C
IDE04939-MAS18077,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during second most recent warning,13, °C
IDE04939-MAS18078,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during third most recent warning,13, °C
IDE04939-MAS18079,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fourth most recent warning,15, °C
IDE04939-MAS18080,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fifth most recent warning,15, °C
IDE04939-ENG135557,Tire Pressure Monitoring System (TPMS)-RKA_Config_Info,,
IDE05053,Right parking brake motor: close gradually,Open,
IDE05053-MAS01167,Right parking brake motor: close gradually-Actuation time,Without time limit,
IDE05053-ENG170421,Right parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05054,Left parking brake motor: close gradually,Open,
IDE05054-MAS01167,Left parking brake motor: close gradually-Actuation time,Without time limit,
IDE05054-ENG170421,Left parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05333,Indicator light in AUTO HOLD button,OFF,
IDE05333-MAS01167,Indicator light in AUTO HOLD button-Actuation time,Without time limit,
IDE05333-ENG170421,Indicator light in AUTO HOLD button-IoReached Status,Output diagnostic test not active,
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE07183,Parking brake motors: close incrementally,Open,
IDE07183-MAS01167,Parking brake motors: close incrementally-Actuation time,Without time limit,
IDE07183-ENG170421,Parking brake motors: close incrementally-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,active,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,5,
IDE13845,Production mode status,not active,
IDE14227-IDE02955,modular vehicle dynamic controller-System status,Not coded,
IDE14227-MAS18086,modular vehicle dynamic controller-Dynamic Chassis Control function status,mFDR_not_active_by_coding,
IDE14227-ENG391332,modular vehicle dynamic controller-Function_status_torque_splitter,mFDR_not_active_due_to_coding_TS,
IDE14227-ENG391837,modular vehicle dynamic controller-Function_status_VAQ,mFDR_not_active_due_to_coding_VAQ,
IDE14227-ENG370769,modular vehicle dynamic controller-mFDR_Active_DCC,mFDR_DCC_not_available_due_to_initialisation,
IDE14227-ENG391725,modular vehicle dynamic controller-mFDR_DCC_delta_current_FL,0.0, mA
IDE14227-ENG392020,modular vehicle dynamic controller-mFDR_DCC_delta_current_FR,0.0, mA
IDE14227-ENG391213,modular vehicle dynamic controller-mFDR_DCC_delta_current_RL,0.0, mA
IDE14227-ENG391587,modular vehicle dynamic controller-mFDR_DCC_delta_current_RR,0.0, mA
IDE14227-ENG370771,modular vehicle dynamic controller-mFDR_FPA_value_actual,mFDR_FPA_current_value_no_can_signal_or_not_available,
IDE14227-ENG370772,modular vehicle dynamic controller-mFDR_FPA_value_nominal,mFDR_FPA_desired_value_no_can_signal_or_not_available,
IDE14227-ENG391204,modular vehicle dynamic controller-mFDR_TS_torque_RL,0.0, Nm
IDE14227-ENG391459,modular vehicle dynamic controller-mFDR_TS_torque_RR,0.0, Nm
IDE14227-ENG391868,modular vehicle dynamic controller-mFDR_VAQ_locking_torque_max,100.0, %
IDE14227-ENG391685,modular vehicle dynamic controller-mFDR_VAQ_locking_torque_min,0.0, %
IDE14227-ENG370855,modular vehicle dynamic controller-System_state_FPA,Not available,
IDE14479-IDE02657,Parking brake system status-Cut-off current: left: reached,0.00, A
IDE14479-IDE02658,Parking brake system status-Cut-off current: right: reached,0.00, A
IDE14479-IDE04496,Parking brake system status-Left parking brake motor: status,closed,
IDE14479-IDE04497,Parking brake system status-Right parking brake motor: status,closed,
IDE14479-IDE04506,Parking brake system status-Calculated left rear brake temperature,40.0, °C
IDE14479-IDE04507,Parking brake system status-Calculated right rear brake temperature,40.0, °C
IDE14479-IDE04647,Parking brake system status-Left parking brake motor: current,0.00, A
IDE14479-IDE04648,Parking brake system status-Right parking brake motor: current,0.00, A
IDE14479-IDE05048,Parking brake system status-Left parking brake motor: actuation counter,2180,
IDE14479-IDE05049,Parking brake system status-Right parking brake motor: actuation counter,2180,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3E 28 30 EA 48 12 41,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0E,
IDE14623,Commutation test status,not active,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,35.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,35.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,35.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,35.0, °C
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Available,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,23,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,28,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,12004, km
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Available,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver´s door,closed,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02286-MAS01167,Hydraulic pump-Actuation time,0 s,
MAS02286-MAS06857,Hydraulic pump-Speed,0, /min
MAS02286-ENG170421,Hydraulic pump-IoReached Status,Output diagnostic test not active,
MAS02426-MAS01167,Text display in instrument cluster-Actuation time,Without time limit,
MAS02426,Text display in instrument cluster,0,
MAS02426-ENG170421,Text display in instrument cluster-IoReached Status,Output diagnostic test not active,
MAS04012-IDE03297,Intake valves-Left front ABS inlet valve,OFF,
MAS04012-IDE03299,Intake valves-Right front ABS inlet valve,OFF,
MAS04012-IDE03301,Intake valves-left rear ABS intake valve,OFF,
MAS04012-IDE03303,Intake valves-right rear ABS intake valve,OFF,
MAS04012-MAS01167,Intake valves-Actuation time,0 s,
MAS04012-ENG170421,Intake valves-IoReached Status,Output diagnostic test not active,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,42 min,
MAS26780-MAS26781,Distance safety-Total of average distance pulses from rear wheels,A3 F2 B4 1E 00,
MAS27687,Pump motor supplier,Nidec CL.2.0,
ENG101413,Calibration Identifications,5WA517DQ03310230,
ENG99697-ENG110852,Calibration Verification Numbers-Calibration Verification Number,0D 41 05 EC,
ENG377742,Dimming_characteristic_curve_1,80.2, %
ENG377743,Dimming_characteristic_curve_2,80.2, %
ENG100152,ECUNAME,BSCM-BrakeSystem,
ENG264438,Entwicklermesswert_01,A3 32 38 35 31 37 39 36 32 33 38 33 30 30 30 30 36 32 35 35 32 32 30 31 33 43 41 2B 02 22 45 1E 3F B0 00 3A 00 00 37 04 07 51 03 65 03 08 03 38 03 1E 07 06 07 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 CA DE 51 E3 00 00 00 00 02 00 00 00 CA DE 51 E3 00 00 00 00 9A 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C A4 68 C3 FE FD FD FF 00 3D 35 00 00 00 00 00 00 00 4A 09 F0 04 2B 09 00 00 CA 01 84 FF D0 00 00 00 00 00 FF 00 55 F6 4A 09 F0 04 2B 09 00 00 CA 01 84 FF D0 00 00 00 00 00 FF 00 55 F6 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 32 34 39 34 70 00 35 38 37 38 38 33 3C 34 39 29 0D 39 03 00 D9 20 35 10 03 04 00 01 00 00 1E D9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 A3 00 00 01 0A 80 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6F 00 E5 00 69 80 00 00 00 AA F0 05 00 50 00 00 00 03 00 00 00 09 00 02 01 02 00 02 01 00 02 00 01 00 00 01 00 00 00 03 00 01 00 02 02 00 00 02 01 03 01 02 01 03 00 01 01 01 01 01 01 00 01 00 02 02 01 00 00 00 00 00 00 00 00 00 02 01 00 01 1E 00 14 00 F5 03 25 03 00 00 00 00 00 80 00 00 98 4A 28 54 4B B4 9C 39 01 40 9E 55 B7 1E C5 C1 CF 0A 21 94 A0 51 00 00 C0 C6 FB 00 00 E4 01 32 C8 52 20 28 00 00 00 00 F0 1E 26 BA 04 78 01 84 39 BA 66 00 00 00 00 01 16 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 57 5A 32 5A 5A 4B 53 53 38 31 58 36 31 39 34 00 33 77 00 00 00 00 00 00 00 00 00 00 00,
ENG264439-ENG127089,Entwicklermesswert_02-Cf,106592.0,
ENG264439-ENG127090,Entwicklermesswert_02-Cr,125808.0,
ENG264439-ENG127091,Entwicklermesswert_02-Theta,3995,
ENG264439-ENG122580,Entwicklermesswert_02-value_1_percentaged,121.9, %
ENG264439-ENG122579,Entwicklermesswert_02-value_1_quantity,0,
ENG264439-ENG122582,Entwicklermesswert_02-value_2_percentaged,121.9, %
ENG264439-ENG122581,Entwicklermesswert_02-value_2_quantity,0,
ENG264439-ENG122584,Entwicklermesswert_02-value_3_percentaged,119.9, %
ENG264439-ENG122583,Entwicklermesswert_02-value_3_quantity,771,
ENG264439-ENG122586,Entwicklermesswert_02-value_4_percentaged,123.4, %
ENG264439-ENG122585,Entwicklermesswert_02-value_4_quantity,1024,
ENG264439-ENG122588,Entwicklermesswert_02-value_5_percentaged,120.3, %
ENG264439-ENG122587,Entwicklermesswert_02-value_5_quantity,217,
ENG264439-ENG122590,Entwicklermesswert_02-value_6_percentaged,122.3, %
ENG264439-ENG122589,Entwicklermesswert_02-value_6_quantity,288,
ENG264439-ENG127703,Entwicklermesswert_02-vehicle_index,     2,
ENG264440,Entwicklermesswert_03,0,
ENG264441,Entwicklermesswert_04,0,
ENG264442-MAS00106,Entwicklermesswert_05-Year,2000,
ENG264442-MAS00106,Entwicklermesswert_05-Year,2127,
ENG264442-MAS00107,Entwicklermesswert_05-Month,15,
ENG264442-MAS00107,Entwicklermesswert_05-Month,0,
ENG264442-MAS00108,Entwicklermesswert_05-Day,0,
ENG264442-MAS00108,Entwicklermesswert_05-Day,31,
ENG264442-MAS00109,Entwicklermesswert_05-Hours,0,
ENG264442-MAS00109,Entwicklermesswert_05-Hours,31,
ENG264442-MAS00110,Entwicklermesswert_05-Minutes,0,
ENG264442-MAS00110,Entwicklermesswert_05-Minutes,63,
ENG264442-MAS00111,Entwicklermesswert_05-Seconds,0,
ENG264442-MAS00111,Entwicklermesswert_05-Seconds,63,
ENG264442-ENG127707,Entwicklermesswert_05-level_1_OFF_actuation_n_distance,0, km
ENG264442-ENG264557,Entwicklermesswert_05-level_1_ON_actuation_distance,0, km
ENG264442-ENG264558,Entwicklermesswert_05-level_2_OFF_actuation_distance,16777215, km
ENG264442-ENG264559,Entwicklermesswert_05-level_2_ON_actuation_distance,0, km
ENG264443-ENG264593,Entwicklermesswert_06-PCU,Texas_Instruments,
ENG264445,Entwicklermesswert_08,|VZM_function_request,VZM_Participant
ENG264446-ENG264515,Entwicklermesswert_09-FL_WSA_Cal_Status_100-110km/h,100, %
ENG264446-ENG264516,Entwicklermesswert_09-FL_WSA_Cal_Status_110-120km/h,100, %
ENG264446-ENG264517,Entwicklermesswert_09-FL_WSA_Cal_Status_120-130km/h,0, %
ENG264446-ENG264518,Entwicklermesswert_09-FL_WSA_Cal_Status_130-140km/h,0, %
ENG264446-ENG264519,Entwicklermesswert_09-FL_WSA_Cal_Status_140-150km/h,0, %
ENG264446-ENG264520,Entwicklermesswert_09-FL_WSA_Cal_Status_150-160km/h,0, %
ENG264446-ENG264521,Entwicklermesswert_09-FL_WSA_Cal_Status_40-50km/h,100, %
ENG264446-ENG264522,Entwicklermesswert_09-FL_WSA_Cal_Status_50-60km/h,100, %
ENG264446-ENG264523,Entwicklermesswert_09-FL_WSA_Cal_Status_60-70km/h,100, %
ENG264446-ENG264524,Entwicklermesswert_09-FL_WSA_Cal_Status_70-80km/h,100, %
ENG264446-ENG264525,Entwicklermesswert_09-FL_WSA_Cal_Status_80-90km/h,100, %
ENG264446-ENG264526,Entwicklermesswert_09-FL_WSA_Cal_Status_90-100km/h,100, %
ENG264446-ENG264532,Entwicklermesswert_09-FR_WSA_Cal_Status_100-110km/h,100, %
ENG264446-ENG264533,Entwicklermesswert_09-FR_WSA_Cal_Status_110-120km/h,100, %
ENG264446-ENG264534,Entwicklermesswert_09-FR_WSA_Cal_Status_120-130km/h,0, %
ENG264446-ENG264535,Entwicklermesswert_09-FR_WSA_Cal_Status_130-140km/h,0, %
ENG264446-ENG264536,Entwicklermesswert_09-FR_WSA_Cal_Status_140-150km/h,0, %
ENG264446-ENG264537,Entwicklermesswert_09-FR_WSA_Cal_Status_150-160km/h,0, %
ENG264446-ENG264538,Entwicklermesswert_09-FR_WSA_Cal_Status_40-50km/h,100, %
ENG264446-ENG264539,Entwicklermesswert_09-FR_WSA_Cal_Status_50-60km/h,100, %
ENG264446-ENG264540,Entwicklermesswert_09-FR_WSA_Cal_Status_60-70km/h,100, %
ENG264446-ENG264541,Entwicklermesswert_09-FR_WSA_Cal_Status_70-80km/h,100, %
ENG264446-ENG264542,Entwicklermesswert_09-FR_WSA_Cal_Status_80-90km/h,100, %
ENG264446-ENG264543,Entwicklermesswert_09-FR_WSA_Cal_Status_90-100km/h,100, %
ENG264446-ENG135582,Entwicklermesswert_09-RKA_Calibration_Activity,40, %
ENG264446-ENG135581,Entwicklermesswert_09-RKA_Calibration_Time,12960, s
ENG264446-ENG264598,Entwicklermesswert_09-RKA_Driving_days_100km/h-120km/h,0, d
ENG264446-ENG264599,Entwicklermesswert_09-RKA_Driving_days_10km/h-40km/h,0, d
ENG264446-ENG264600,Entwicklermesswert_09-RKA_Driving_days_120km/h-150km/h,0, d
ENG264446-ENG264601,Entwicklermesswert_09-RKA_Driving_days_150km/h-Vmax,0, d
ENG264446-ENG264597,Entwicklermesswert_09-RKA_Driving_days_1-Vmax,0, d
ENG264446-ENG264602,Entwicklermesswert_09-RKA_Driving_days_40km/h-60km/h,0, d
ENG264446-ENG264603,Entwicklermesswert_09-RKA_Driving_days_60km/h-80km/h,0, d
ENG264446-ENG264604,Entwicklermesswert_09-RKA_Driving_days_80km/h-100km/h,0, d
ENG264446-ENG264606,Entwicklermesswert_09-RKA_Driving_hours_100km/h-120km/h,0, H
ENG264446-ENG264607,Entwicklermesswert_09-RKA_Driving_hours_10km/h-40km/h,5, H
ENG264446-ENG264608,Entwicklermesswert_09-RKA_Driving_hours_120km/h-150km/h,0, H
ENG264446-ENG264609,Entwicklermesswert_09-RKA_Driving_hours_150km/h-Vmax,0, H
ENG264446-ENG264605,Entwicklermesswert_09-RKA_Driving_hours_1-Vmax,20, H
ENG264446-ENG264610,Entwicklermesswert_09-RKA_Driving_hours_40km/h-60km/h,10, H
ENG264446-ENG264611,Entwicklermesswert_09-RKA_Driving_hours_60km/h-80km/h,3, H
ENG264446-ENG264612,Entwicklermesswert_09-RKA_Driving_hours_80km/h-100km/h,0, H
ENG264446-ENG264614,Entwicklermesswert_09-RKA_Driving_minutes_100km/h-120km/h,29, min
ENG264446-ENG264615,Entwicklermesswert_09-RKA_Driving_minutes_10km/h-40km/h,19, min
ENG264446-ENG264616,Entwicklermesswert_09-RKA_Driving_minutes_120km/h-150km/h,51, min
ENG264446-ENG264617,Entwicklermesswert_09-RKA_Driving_minutes_150km/h-Vmax,0, min
ENG264446-ENG264613,Entwicklermesswert_09-RKA_Driving_minutes_1-Vmax,35, min
ENG264446-ENG264618,Entwicklermesswert_09-RKA_Driving_minutes_40km/h-60km/h,10, min
ENG264446-ENG264619,Entwicklermesswert_09-RKA_Driving_minutes_60km/h-80km/h,5, min
ENG264446-ENG264620,Entwicklermesswert_09-RKA_Driving_minutes_80km/h-100km/h,38, min
ENG264446-ENG264622,Entwicklermesswert_09-RKA_Driving_seconds_100km/h-120km/h,31, s
ENG264446-ENG264623,Entwicklermesswert_09-RKA_Driving_seconds_10km/h-40km/h,48, s
ENG264446-ENG264624,Entwicklermesswert_09-RKA_Driving_seconds_120km/h-150km/h,53, s
ENG264446-ENG264625,Entwicklermesswert_09-RKA_Driving_seconds_150km/h-Vmax,0, s
ENG264446-ENG264621,Entwicklermesswert_09-RKA_Driving_seconds_1-Vmax,6, s
ENG264446-ENG264626,Entwicklermesswert_09-RKA_Driving_seconds_40km/h-60km/h,2, s
ENG264446-ENG264627,Entwicklermesswert_09-RKA_Driving_seconds_60km/h-80km/h,43, s
ENG264446-ENG264628,Entwicklermesswert_09-RKA_Driving_seconds_80km/h-100km/h,7, s
ENG264446-ENG135567,Entwicklermesswert_09-RKA_LA_counter_all,590,
ENG264446-ENG135568,Entwicklermesswert_09-RKA_LA_counter_diffusion,10649,
ENG264446-ENG135565,Entwicklermesswert_09-RKA_Maximale_Systemzeit,0, ms
ENG264446-ENG135572,Entwicklermesswert_09-RKA_NVM00_Counter_Prio_0,91,
ENG264446-ENG135573,Entwicklermesswert_09-RKA_NVM01_Counter_WSA_Static_A,286,
ENG264446-ENG135574,Entwicklermesswert_09-RKA_NVM02_Counter_WSA_Static_B,286,
ENG264446-ENG135575,Entwicklermesswert_09-RKA_NVM03_Counter_WRA_Static_A,112,
ENG264446-ENG135576,Entwicklermesswert_09-RKA_NVM04_Counter_WRA_Static_B,112,
ENG264446-ENG135577,Entwicklermesswert_09-RKA_NVM05_Counter_CL_Static_A,275,
ENG264446-ENG135578,Entwicklermesswert_09-RKA_NVM06_Counter_CL_Static_B,275,
ENG264446-ENG135579,Entwicklermesswert_09-RKA_NVM07_CounterDynamic,1956,
ENG264446-ENG135580,Entwicklermesswert_09-RKA_NVM08_Counter_Blockselect,76,
ENG264446-ENG135583,Entwicklermesswert_09-RKA_System_Activity_WRA,54, %
ENG264446-ENG135584,Entwicklermesswert_09-RKA_System_Activity_WSA,57, %
ENG264446-ENG135564,Entwicklermesswert_09-RKA_WRA_WSA_Cal_High_Speed,23, %
ENG264446-ENG135563,Entwicklermesswert_09-RKA_WRA_WSA_Cal_Low_Speed,191, %
ENG264446-ENG264629,Entwicklermesswert_09-RL_WSA_Cal_Status_100-110km/h,0, %
ENG264446-ENG264630,Entwicklermesswert_09-RL_WSA_Cal_Status_110-120km/h,0, %
ENG264446-ENG264631,Entwicklermesswert_09-RL_WSA_Cal_Status_120-130km/h,0, %
ENG264446-ENG264632,Entwicklermesswert_09-RL_WSA_Cal_Status_130-140km/h,0, %
ENG264446-ENG264633,Entwicklermesswert_09-RL_WSA_Cal_Status_140-150km/h,0, %
ENG264446-ENG264634,Entwicklermesswert_09-RL_WSA_Cal_Status_150-160km/h,0, %
ENG264446-ENG264635,Entwicklermesswert_09-RL_WSA_Cal_Status_40-50km/h,0, %
ENG264446-ENG264636,Entwicklermesswert_09-RL_WSA_Cal_Status_50-60km/h,0, %
ENG264446-ENG264637,Entwicklermesswert_09-RL_WSA_Cal_Status_60-70km/h,0, %
ENG264446-ENG264638,Entwicklermesswert_09-RL_WSA_Cal_Status_70-80km/h,0, %
ENG264446-ENG264639,Entwicklermesswert_09-RL_WSA_Cal_Status_80-90km/h,0, %
ENG264446-ENG264640,Entwicklermesswert_09-RL_WSA_Cal_Status_90-100km/h,0, %
ENG264446-ENG264641,Entwicklermesswert_09-RR_WSA_Cal_Status_100-110km/h,0, %
ENG264446-ENG264642,Entwicklermesswert_09-RR_WSA_Cal_Status_110-120km/h,0, %
ENG264446-ENG264643,Entwicklermesswert_09-RR_WSA_Cal_Status_120-130km/h,0, %
ENG264446-ENG264644,Entwicklermesswert_09-RR_WSA_Cal_Status_130-140km/h,0, %
ENG264446-ENG264645,Entwicklermesswert_09-RR_WSA_Cal_Status_140-150km/h,0, %
ENG264446-ENG264646,Entwicklermesswert_09-RR_WSA_Cal_Status_150-160km/h,0, %
ENG264446-ENG264647,Entwicklermesswert_09-RR_WSA_Cal_Status_40-50km/h,0, %
ENG264446-ENG264648,Entwicklermesswert_09-RR_WSA_Cal_Status_50-60km/h,0, %
ENG264446-ENG264649,Entwicklermesswert_09-RR_WSA_Cal_Status_60-70km/h,0, %
ENG264446-ENG264650,Entwicklermesswert_09-RR_WSA_Cal_Status_70-80km/h,0, %
ENG264446-ENG264651,Entwicklermesswert_09-RR_WSA_Cal_Status_80-90km/h,0, %
ENG264446-ENG264652,Entwicklermesswert_09-RR_WSA_Cal_Status_90-100km/h,0, %
ENG264446-ENG264699,Entwicklermesswert_09-WRA_Cal_Status_100-150km/h,100, %
ENG264446-ENG135687,Entwicklermesswert_09-WRA_Cal_Status_10-50km/h,100, %
ENG264446-ENG264700,Entwicklermesswert_09-WRA_Cal_Status_150-200km/h,37, %
ENG264446-ENG264701,Entwicklermesswert_09-WRA_Cal_Status_200-250km/h,0, %
ENG264446-ENG264702,Entwicklermesswert_09-WRA_Cal_Status_250-300km/h,0, %
ENG264446-ENG264703,Entwicklermesswert_09-WRA_Cal_Status_300-350km/h,0, %
ENG264446-ENG135688,Entwicklermesswert_09-WRA_Cal_Status_50-100km/h,100, %
ENG264447-ENG135743,Entwicklermesswert_11-Left_Brake_Full_Clamping_Force,2180,
ENG264447-ENG135741,Entwicklermesswert_11-Right_Brake_Full_Clamping_Force,2180,
ENG264448,Entwicklermesswert_12,500823,
ENG264449-ENG135765,Entwicklermesswert_13-Input_Signal_A_Belt_Error,No malfunction,
ENG264449-ENG135764,Entwicklermesswert_13-Input_Signal_A_Belt_Status,not selected,
ENG264449-ENG135767,Entwicklermesswert_13-Input_Signal_B_Door_Error,No malfunction,
ENG264449-ENG135766,Entwicklermesswert_13-Input_Signal_B_Door_Status,closed,
ENG264450-MAS01167,Entwicklerstellglied_01_status-Actuation time,0 s,
ENG264450-MAS11641,Entwicklerstellglied_01_status-OBD lamp,OFF,
ENG264450-ENG170421,Entwicklerstellglied_01_status-IoReached Status,Output diagnostic test not active,
ENG310439-ENG103176,In_use_monitor_performance_ratio_1-General Denominator,175,
ENG310439-ENG102823,In_use_monitor_performance_ratio_1-Ignition Cycle Counter,1738,
ENG310439-ENG100120,In_use_monitor_performance_ratio_1-Milage,11500, km
ENG310439-ENG102846,In_use_monitor_performance_ratio_1-Number of IUMPR Records,56,
ENG310440-ENG101817,In_use_monitor_performance_ratio_2-Denominator,175,
ENG310440-ENG103772,In_use_monitor_performance_ratio_2-DFCC Value,139,
ENG310440-ENG99150,In_use_monitor_performance_ratio_2-Numerator,1385,
ENG310440-ENG101622,In_use_monitor_performance_ratio_2-Record Number,1,
ENG310441-ENG101817,In_use_monitor_performance_ratio_3-Denominator,175,
ENG310441-ENG103772,In_use_monitor_performance_ratio_3-DFCC Value,269,
ENG310441-ENG99150,In_use_monitor_performance_ratio_3-Numerator,1385,
ENG310441-ENG101622,In_use_monitor_performance_ratio_3-Record Number,2,
Elapsed Time: 00:23
blockmap-08-5WA-907-727-BK_WV2ZZZSK8SX116493-20260803-1924.CSV
;SW:5WA-907-727-BK   HW:5WA-907-727-AF ---  08: Auto HVAC
;Component:AC Manuell    H01 5088, Coding:023010019211000000000000101001010000010000000000000000000000
;EV_ACClimaBHBE3ADV,002062,EV_ACClimaBHBE3ADV_002_VW41.rod
;Monday,03,August,2026,19:24:34:29755
IDE00019,Voltage terminal 30,13.50, V
IDE00021,Engine speed,983.0, /min
IDE00025,Coolant temperature,92.00, °C
IDE00198,Refrigerant pressure,12.20, bar
IDE00767,No. of unscheduled ECU resets,3,
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.46, A
IDE00967,Compressor current: specified value,0.46, A
IDE00968,Compressor speed,550.0, /min
IDE00969,Compressor load,12.9, Nm
IDE00970,Coolant fan activation: actual value,19.20, %
IDE00971,Coolant fan activation: specified value,68.4, %
IDE00973,Outside temperature,35.50, °C
IDE00974,Outside air temperature internally calculated,35.00, °C
IDE00976,Left front vent temperature,87.50, °C
IDE00977,Right front vent temperature,87.50, °C
IDE00981,Footwell vent temperature,87.50,
IDE00982,Temperature downstream of evaporator,2.00, °C
IDE00983,Inside temperature,13067.00, °C
IDE00984,Sun intensity left,2080.00, W/m²
IDE00985,Sun intensity right,2080.00, W/m²
IDE00987,Blower voltage: specified value,4.80, V
IDE00989,Blower status,not active,
IDE00992,Recirculation flap specified value,Measuring value not available,
IDE00994,Actual value for fresh air/recirculation air flow flap,127.5, %
IDE00994,Actual value for fresh air/recirculation air flow flap,65535,
IDE00995,Fresh air/recirculating air/back pressure door specified value,820,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,80,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,800,
IDE00998,Left temperature flap - actual value,599,
IDE00998,Left temperature flap - actual value,60.0, %
IDE00999,Temperature door left - Specified value,598,
IDE01040,Left Temperature Control Door - cold stop,115,
IDE01041,Left temperature flap: warm stop,921,
IDE01046,Temperature flap: actual value,599,
IDE01046,Temperature flap: actual value,60.00, %
IDE01047,Temperature door - Specified value,598,
IDE01048,Temperature flap: cold stop,115,
IDE01049,Temperature flap: warm stop,921,
IDE01050,Front air distribution flap: actual value,75.50, %
IDE01050,Front air distribution flap: actual value,920,
IDE01051,Air distribution door front - Specified value,921,
IDE01052,Front air distribution flap: air outlet stop,104,
IDE01059,Air distribution flap: actual value,920,
IDE01059,Air distribution flap: actual value,75.50, %
IDE01060,Air distribution flap: specified value,920,
IDE01063,Status of recirculation air,Manual recirc. active,
IDE01065,Rear vent temperature,0.00, °C
IDE01069,Rear blower voltage: specified value,0.00, V
IDE01076,Time since ignition off,0, min
IDE01226,Blower voltage: actual value,4.70, V
IDE01227,Blower current,1.75, A
IDE01232,Supply voltage for external components,5.00, V
IDE01419,Compressor shut-off condition: last,Shut-off from Engine Control Module (ECM) via CAN,
IDE01420,Compressor shut-off requirement: penultimate,Low pressure event,
IDE01421,Compressor shut-off requirement: antepenultimate,Low pressure event,
IDE01433,Air quality status,not installed,
IDE01442-MAS01533,Pressing a button-Defrost,operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,operated,
IDE01442-MAS01550,Pressing a button-AC,operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01564,Pressing a button-Windshield defogger,Not operated,
IDE01442-MAS01577,Pressing a button-Auxiliary heating,operated,
IDE01442-MAS02015,Pressing a button-AUTO,operated,
IDE01442-MAS02192,Pressing a button-SYNC,operated,
IDE01442-MAS03196,Pressing a button-Menu,operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,operated,
IDE01442-MAS04605,Pressing a button-AC MAX,operated,
IDE01448,Actual value of heated front window,not coded / not installed,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,255, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,255, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,6503.00, °C
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,6503.00, °C
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,6503.00, °C
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,6503.00, °C
IDE01540-MAS07052,Left front heated seat-Setting,not coded / not installed,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,655.35, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,655.35, kOhm
IDE01540-MAS07921,Left front heated seat-Balance setting,Unknown (14)
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,8382.00, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,6503.00, °C
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,6503.00, °C
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not coded / not installed,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not coded / not installed,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,55.54, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),25.50, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),25.50, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,255, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,255, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,6503.00, °C
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,6503.00, °C
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,6503.00, °C
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,6503.00, °C
IDE01541-MAS07052,Right front heated seat-Setting,not coded / not installed,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,655.35, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,655.35, kOhm
IDE01541-MAS07921,Right front heated seat-Balance setting,Unknown (14)
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,8382.00, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,6503.00, °C
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,6503.00, °C
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not coded / not installed,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not coded / not installed,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded / not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,55.54, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),25.50, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),25.50, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,OFF,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,OFF,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,OFF,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),65534,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),65534,
IDE01694-MAS01767,Left rear seat heater-Left rear seat heater stage,0,
IDE01694-MAS01768,Left rear seat heater-Left rear seat heater specified temperature,0.0, °C
IDE01694-MAS01769,Left rear seat heater-Left rear seat heater actual temperature,0.0, °C
IDE01694-MAS01770,Left rear seat heater-Left rear seat heater current,0.00, A
IDE01695-MAS01771,Right rear seat heater-Right rear seat heater stage,0,
IDE01695-MAS01772,Right rear seat heater-Right rear seat heater specified temperature,0.0, °C
IDE01695-MAS01773,Right rear seat heater-Right rear seat heater actual temperature,0.0, °C
IDE01695-MAS01774,Right rear seat heater-Right rear seat heater current,0.00, A
IDE02270-IDE01268,CAN input signal(s) status-Front windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management: shut-off stage,Deactivation stage 0,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,On,
IDE02744-IDE15944,Steering wheel heating-Energy management approval,Activation,
IDE02744-IDE15945,Steering wheel heating-Heater parameter set,n/a,
IDE02744-MAS01632,Steering wheel heating-Status,switched off,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Stage 1,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,operated,
IDE02744-MAS09022,Steering wheel heating-PWM value,0, %
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,204, °C
IDE03008-IDE80251,Stop process prevented-Neck heating,not active,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxiliary heat mode,not active,
IDE03008-MAS05046,Stop process prevented-Evaporator temperature difference from setting,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03010-IDE80251,Number of prevented stop processes-Neck heating,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxiliary heat mode,0,
IDE03010-MAS05046,Number of prevented stop processes-Evaporator temperature difference from setting,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-IDE80251,Number of requested start processes-Neck heating,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxiliary heat mode,0,
IDE03011-MAS05046,Number of requested start processes-Evaporator temperature difference from setting,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE03537-MAS01482,Ionizer: status-Hardware version,65534,
IDE03537-MAS01483,Ionizer: status-Software version,65534,
IDE03537-MAS02829,Ionizer: status-High voltage,not coded / not installed,
IDE03537-MAS02830,Ionizer: status-Ionizer button,not coded / not installed,
IDE03537-MAS02831,Ionizer: status-Ionizer check light,not coded / not installed,
IDE03538-MAS01632,Ionizer: diagnosis-Status,No malfunction,
IDE03538-MAS02830,Ionizer: diagnosis-Ionizer button,not coded / not installed,
IDE03538-MAS02831,Ionizer: diagnosis-Ionizer check light,not coded / not installed,
IDE03538-MAS13074,Ionizer: diagnosis-Error validity status,not coded / not installed,
IDE04312-IDE04095,System run time-Engine running time,255, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01447,Driving profile selection-Actual value,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05533,Heater for nozzles,not coded / not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,62.70, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,87.50, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,127.00, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,62.70, °C
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,62.10, °C
IDE06163-MAS04629,Humidity sensor: exterior-Sensor temperature,164.50, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,126.50, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,62.10, °C
IDE06201,Blower reduction,Unknown (0)
IDE06233-MAS01632,Auxiliary heater: controlled-Status,Malfunction,
IDE06233-MAS03746,Auxiliary heater: controlled-Current: actual value,255, A
IDE06233-MAS04625,Auxiliary heater: controlled-Power: actual value,2550, W
IDE06233-MAS04626,Auxiliary heater: controlled-Power: target value,0, W
IDE06235,Potentiometer for rear vent temperature,6.375, V
IDE06235,Potentiometer for rear vent temperature,0,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0, H
IDE06307-MAS00110,Stop prevention history data-Minutes,0, min
IDE06307-MAS00111,Stop prevention history data-Seconds,0, s
IDE06307-MAS01517,Stop prevention history data-Defrost active,not active,
IDE06307-MAS01564,Stop prevention history data-Windshield defogger,not active,
IDE06307-MAS02802,Stop prevention history data-Interior temperature difference to specifications,not active,
IDE06307-MAS02803,Stop prevention history data-Interior vent difference to setting,not active,
IDE06307-MAS02804,Stop prevention history data-Manual fan speed increase,not active,
IDE06307-MAS04353,Stop prevention history data-Fogging hazard (humidity sensor),not active,
IDE06307-MAS04354,Stop prevention history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06307-MAS05009,Stop prevention history data-A/C request: auxiliary heat mode,not active,
IDE06307-MAS05046,Stop prevention history data-Evaporator temperature difference from setting,not active,
IDE06307-MAS05047,Stop prevention history data-Maximum cooling and heating set,not active,
IDE06307-MAS06551,Stop prevention history data-Seat ventilation,not active,
IDE06307-MAS09538,Stop prevention history data-max A/C,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0, H
IDE06308-MAS00110,Start request history data-Minutes,0, min
IDE06308-MAS00111,Start request history data-Seconds,0, s
IDE06308-MAS01517,Start request history data-Defrost active,not active,
IDE06308-MAS01564,Start request history data-Windshield defogger,not active,
IDE06308-MAS02802,Start request history data-Interior temperature difference to specifications,not active,
IDE06308-MAS02803,Start request history data-Interior vent difference to setting,not active,
IDE06308-MAS02804,Start request history data-Manual fan speed increase,not active,
IDE06308-MAS03904,Start request history data-Maximum permissible stop duration reached,not active,
IDE06308-MAS04353,Start request history data-Fogging hazard (humidity sensor),not active,
IDE06308-MAS04354,Start request history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06308-MAS05009,Start request history data-A/C request: auxiliary heat mode,not active,
IDE06308-MAS05046,Start request history data-Evaporator temperature difference from setting,not active,
IDE06308-MAS05047,Start request history data-Maximum cooling and heating set,not active,
IDE06308-MAS06551,Start request history data-Seat ventilation,not active,
IDE06308-MAS09538,Start request history data-max A/C,not active,
IDE06545,Blower voltage for production routines,6.00, V
IDE06546,Interior specified temperature for production routines,22, °C
IDE06547,Air distribution for production routines,Air distribution top and footwell,
IDE06593,Air recirculation for production routines,Fresh air,
IDE07080-MAS07921,Left rear seat ventilation setting-Balance setting,not coded / not installed,
IDE07080-MAS07928,Left rear seat ventilation setting-Ventilation stage,not coded / not installed,
IDE07080-MAS07929,Left rear seat ventilation setting-Power quota setting by energy management,8382.00, %
IDE07244-MAS07921,Right rear seat ventilation setting-Balance setting,not coded / not installed,
IDE07244-MAS07928,Right rear seat ventilation setting-Ventilation stage,not coded / not installed,
IDE07244-MAS07929,Right rear seat ventilation setting-Power quota setting by energy management,8382.00, %
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Actual value,255, %
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Specified value,255, %
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Actual value,255, %
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Specified value,255, %
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Actual value,255, %
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Specified value,255, %
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Actual value,255, %
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Specified value,255, %
IDE07253-IDE11719,Installation info: rear seat ventilation-Fan 1 for left rear seat backrest,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Fan 1 for right rear seat backrest,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Fan 1 for right rear seat cushion,not installed,
IDE07991-MAS04446,A/C clutch-Relay activation status,active,
IDE08364-MAS01447,Left seat backrest fan 1: activation-Actual value,255,
IDE08364-MAS01448,Left seat backrest fan 1: activation-Specified value,255, %
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Actual value,255, %
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Specified value,255, %
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Actual value,255,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Specified value,255, %
IDE08368-MAS01447,Right seat backrest fan 1: activation-Actual value,255,
IDE08368-MAS01448,Right seat backrest fan 1: activation-Specified value,255, %
IDE08370-MAS01447,Right seat cushion fan 1: activation-Actual value,255,
IDE08370-MAS01448,Right seat cushion fan 1: activation-Specified value,255, %
IDE08371-MAS01447,Right seat cushion fan 2: activation-Actual value,255,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Specified value,255, %
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,not coded / not installed,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,65535,
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),65535,
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,not coded / not installed,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,not coded / not installed,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,8382.00, %
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,not coded / not installed,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,not coded / not installed,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,8382.00, %
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,not coded / not installed,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,not coded / not installed,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,not installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,not installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE09168-MAS01632,Refrigerant Shut-Off Valve 1-Status,closed,
IDE10942-MAS00788,Expansion valve 1 for refrigerant-LIN node- address,Not adapted,
IDE10942-MAS01447,Expansion valve 1 for refrigerant-Actual value,11932, %
IDE10942-MAS01448,Expansion valve 1 for refrigerant-Specified value,0, %
IDE10942-MAS02201,Expansion valve 1 for refrigerant-Temperature,128, °C
IDE10942-MAS10469,Expansion valve 1 for refrigerant-Raw value,65534,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,3276750.00, W/m²
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,655.35, V
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,6473.500, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,655.35, kOhm
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,4045.938, °C
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,655.35, kOhm
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,4045.938, °C
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,655.35, kOhm
IDE11791,Particulate matter content in air,65010, µg/m³
IDE11836,Query of the supported PIDs (0x01 - 0x20),135790593,
IDE11837,Query of the supported PIDs (0x21 - 0x40),1,
IDE11838,Query of the supported PIDs (0x41 - 0x60),0,
IDE11839,Query of the supported InfoTypes (0x01 - 0x20),0,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine is running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside temperature too low,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WV2ZZZSK8SX116493,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,3,
IDE14095,Wiper park position heater,not coded / not installed,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,3,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 28,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15414,Potentiometer for rear vent temperature - end stop cold,0,
IDE15414,Potentiometer for rear vent temperature - end stop cold,0.000, V
IDE15415,Potentiometer for rear vent temperature - end stop warm,0,
IDE15415,Potentiometer for rear vent temperature - end stop warm,0.000, V
IDE16797,Pre-ventilation: total elapsed time of the function,0, s
IDE16798,Pre-ventilation: number of functions performed,0,
IDE16799,Pre-ventilation: remaining time,1460,
IDE18268-IDE18264,Humidity/temperature sensor for seat: left front-Seat cushion humidity,255, %
IDE18268-IDE18265,Humidity/temperature sensor for seat: left front-Seat cushion temperature,127.50, °C
IDE18268-IDE18266,Humidity/temperature sensor for seat: left front-Backrest humidity,255, %
IDE18268-IDE18267,Humidity/temperature sensor for seat: left front-Temperature seat backrest,20.00, °C
IDE18269-IDE18264,Humidity/temperature sensor for seat: right front-Seat cushion humidity,255, %
IDE18269-IDE18265,Humidity/temperature sensor for seat: right front-Seat cushion temperature,127.50, °C
IDE18269-IDE18266,Humidity/temperature sensor for seat: right front-Backrest humidity,255, %
IDE18269-IDE18267,Humidity/temperature sensor for seat: right front-Temperature seat backrest,127.50, °C
IDE18270-IDE18264,Humidity/temperature sensor for seat: left rear-Seat cushion humidity,255, %
IDE18270-IDE18265,Humidity/temperature sensor for seat: left rear-Seat cushion temperature,127.50, °C
IDE18270-IDE18266,Humidity/temperature sensor for seat: left rear-Backrest humidity,255, %
IDE18270-IDE18267,Humidity/temperature sensor for seat: left rear-Temperature seat backrest,127.50, °C
IDE18271-IDE18264,Humidity/temperature sensor for seat: right rear-Seat cushion humidity,255, %
IDE18271-IDE18265,Humidity/temperature sensor for seat: right rear-Seat cushion temperature,127.50, °C
IDE18271-IDE18266,Humidity/temperature sensor for seat: right rear-Backrest humidity,255, %
IDE18271-IDE18267,Humidity/temperature sensor for seat: right rear-Temperature seat backrest,127.50, °C
MAS00464-MAS00110,Standard - ambient data 1-Minutes,24,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,31,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,199,
MAS11297-MAS01379,Standstilll A/C: customer setting-Operating time,49, min
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 05 03 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,5,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
MAS20376-MAS01634,High-voltage air heater status: internal-Supply voltage,too High,
MAS20376-MAS02246,High-voltage air heater status: internal-Timeout,OK,
MAS20376-MAS03746,High-voltage air heater status: internal-Current: actual value,0.00, A
MAS20376-MAS05978,High-voltage air heater status: internal-High voltage supply voltage,128, V
MAS20376-MAS07055,High-voltage air heater status: internal-Response error,OK,
MAS20376-MAS09468,High-voltage air heater status: internal-Vehicle high voltage system,too High,
MAS20376-MAS09469,High-voltage air heater status: internal-HV heater: status,Unknown (10)
MAS20376-MAS10074,High-voltage air heater status: internal-Supply voltage: actual value,6.40, V
MAS20376-MAS21216,High-voltage air heater status: internal-Heater electronics and circuit board temperature (PCB),128, °C
MAS20376-MAS21217,High-voltage air heater status: internal-Heating circuit 1 status,Temperature shut-off,
MAS20376-MAS21218,High-voltage air heater status: internal-Heating circuit 2 status,Temperature shut-off,
MAS20376-MAS21219,High-voltage air heater status: internal-Heating circuit 3 status,Temperature shut-off,
MAS20376-MAS21221,High-voltage air heater status: internal-Heating circuit 4 status,Temperature shut-off,
MAS20376-MAS21222,High-voltage air heater status: internal-Current flow with heating circuit not activated,OK,
MAS20376-MAS21223,High-voltage air heater status: internal-Total current over long period of time too high,OK,
MAS20376-MAS21224,High-voltage air heater status: internal-Circuit board temperature: shut-off value,OK,
MAS20376-MAS21225,High-voltage air heater status: internal-Internal error (other),OK,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
ENG181012,FoD_slave_state,2,
ENG254718-IDE04332,Function_On_Demand_Unlock_ID_Status_Dev-Release code for a SWaP function,Not available,
ENG254718-IDE05814,Function_On_Demand_Unlock_ID_Status_Dev-Individualization characteristic,invalid,
ENG254718-IDE06260,Function_On_Demand_Unlock_ID_Status_Dev-ID number,268763904,
ENG254718-MAS01340,Function_On_Demand_Unlock_ID_Status_Dev-Functions,Available,
ENG254718-MAS01903,Function_On_Demand_Unlock_ID_Status_Dev-Configuration,not OK,
ENG254718-MAS02934,Function_On_Demand_Unlock_ID_Status_Dev-Preconditions met,Condition not met,
ENG254718-MAS05616,Function_On_Demand_Unlock_ID_Status_Dev-Cancellation,not_canceled,
ENG254718-MAS05617,Function_On_Demand_Unlock_ID_Status_Dev-Authentication,Condition not met,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,5,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
Elapsed Time: 00:33
blockmap-09-5WA-937-086-CN_WV2ZZZSK8SX116493-20260803-1925.CSV
;SW:5WA-937-086-CN   HW:5WA-937-086-BJ ---  09: Cent. Elect.
;Component:BCM37w_M238 0451, Coding:
;EV_BCMwBL,004001,EV_BCMwBL_004.rod
;Monday,03,August,2026,19:25:38:29755
;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0
;VCID: 1F1BE554973A9F42C61-804A SFD+SFD2 { }
Group,Description,Actual
IDE00001,Production mode,not active,
IDE00301,Distance,12004, km
IDE00324-MAS20322,Programming preconditions-Number of programming requirements,7,
IDE00324,Programming preconditions,|Program precondition|Engine speed is not zero|Vehicle immobilizer is not activated|Vehicle speed is not zero|Supply voltage too low|Lockout time for programming is active|Sub data bus system in diagnosis|Engine stop active in Start/Stop mode|,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,none,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Initialization,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,active,
IDE01992-SFT00183,Installation list: current installations-Interface for access/start system,not active,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,not active,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,not active,
IDE01992-SFT33031,Installation list: current installations-Antenna module,not active,
IDE01992-SFT33054,Installation list: current installations-Burglary protection control module 1 VL,not active,
IDE01992-SFT33055,Installation list: current installations-Burglary protection control module 2 VR,not active,
IDE01992-SFT33056,Installation list: current installations-Burglary protection control module 3 HL,not active,
IDE01992-SFT33057,Installation list: current installations-Burglary protection control module 4 HR,not active,
IDE01992-SFT33058,Installation list: current installations-Burglary protection control module 5 vehicle interior,not active,
IDE01996-SFT00009,Installation list: specified installations-Electronic central electric,active,
IDE01996-SFT00183,Installation list: specified installations-Interface for access/start system,not active,
IDE01996-SFT00214,Installation list: specified installations-Light Control Left 2,not active,
IDE01996-SFT00215,Installation list: specified installations-Light Control Right 2,not active,
IDE01996-SFT33031,Installation list: specified installations-Antenna module,not active,
IDE01996-SFT33054,Installation list: specified installations-Burglary protection control module 1 VL,not active,
IDE01996-SFT33055,Installation list: specified installations-Burglary protection control module 2 VR,not active,
IDE01996-SFT33056,Installation list: specified installations-Burglary protection control module 3 HL,not active,
IDE01996-SFT33057,Installation list: specified installations-Burglary protection control module 4 HR,not active,
IDE01996-SFT33058,Installation list: specified installations-Burglary protection control module 5 vehicle interior,not active,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,Signal from door lock: engaged,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlock button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not coded / not installed,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,Closed,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Closed,
IDE02092-MAS09072,Tailgate condition-Locking mechanism button in the rear lid,Not operated,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not coded / not installed,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,not coded / not installed,
IDE02515,Low beams,|Connector number,Connector terminal number
IDE02614-MAS02788,Reversing light switch-CAN,not coded / not installed,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711-IDE05228,Rear wiper-Operating hour counter,1C 00 00 00 00 00 00 00 25 6D 50 52 80 5C 3B 52 80 5B C0 01 09 DC EC 40 0C 2E 26 01 22 9A 80 40,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02743,Main beam,|Connector number,Connector terminal number
IDE02745-IDE00096,Ignition Switch Key Lock Solenoid-Selector lever position,Intermediate position,
IDE02745-MAS08205,Ignition Switch Key Lock Solenoid-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition Switch Key Lock Solenoid-CAN ESP speed,0.00, km/h
IDE02857-IDE03111,Activation current-Interior lighting,16, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-MAS01288,Activation current-Horn,Measuring value not available,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE02957,Ambient lighting,|Channel,Connector number
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,not ready for sleep,
IDE03150-SFT00183,Readiness for bus sleep mode-Interface for access/start system,Ready For Sleep,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,Ready For Sleep,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,Ready For Sleep,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,Ready For Sleep,
IDE03150-SFT33054,Readiness for bus sleep mode-Burglary protection control module 1 VL,Ready For Sleep,
IDE03150-SFT33055,Readiness for bus sleep mode-Burglary protection control module 2 VR,Ready For Sleep,
IDE03150-SFT33056,Readiness for bus sleep mode-Burglary protection control module 3 HL,Ready For Sleep,
IDE03150-SFT33057,Readiness for bus sleep mode-Burglary protection control module 4 HR,Ready For Sleep,
IDE03150-SFT33058,Readiness for bus sleep mode-Burglary protection control module 5 vehicle interior,Ready For Sleep,
IDE03150-SFT33111,Readiness for bus sleep mode-Burglary protection control module 6: vehicle interior 2,Ready For Sleep,
IDE03150-SFT33112,Readiness for bus sleep mode-Burglary protection control module 7: vehicle interior 3,Ready For Sleep,
IDE03150-SFT33113,Readiness for bus sleep mode-Burglary protection control module 8: vehicle interior 4,Ready For Sleep,
IDE03310,Brake lamp,|Connector number,Connector terminal number
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,0.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638,Static cornering light,|Connector number,Connector terminal number
IDE03788,Status of basic headlamp setting,no request,
IDE04213,Central locking button,not coded / not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded / not installed,
IDE04254-MAS00222,Play protection for central locking-Rear lid,not active,
IDE04254-MAS02444,Play protection for central locking-Central locking,not active,
IDE04254-MAS06465,Play protection for central locking-Fuel tank cover via button,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,automatic,
IDE04347-MAS01458,Expanded freeze frame conditions-Operating State,Normal mode,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,35.00, °C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,13.80, V
IDE04347-MAS09388,Expanded freeze frame conditions-Engine run,On,
IDE04347-MAS15304,Expanded freeze frame conditions-Status drive readiness,not ready to drive,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04639,Last wake-up cause,Comfort data bus,
IDE04925,Daytime running lamps,|Connector number,Connector terminal number
IDE05042-MAS03873,Emergency flasher button-Pulse duty factor,9.50, %
IDE05045-MAS02832,Front wiper module-Malfunction status,not coded / not installed,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,25500,
IDE05045-MAS05878,Front wiper module-level,Stage 1,
IDE05045-MAS09627,Front wiper module-Error status: wiper 2,not coded / not installed,
IDE05045-MAS22050,Front wiper module-Relay activation stage 1,not active,
IDE05045-MAS22051,Front wiper module-Relay activation stage 2,not active,
IDE05323,Fog lamp,|Connector number,Connector terminal number
IDE05413,Tail lamps,|Connector number,Connector terminal number
IDE05434,Rear entry light,|Connector number,Side
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded / not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05725-MAS01634,Dimmer terminal 58xs-Supply voltage,0.0, %
IDE05730,Luggage compartment light,|Connector number,Connector terminal number
IDE05739,Footwell lamp,|Connector number,Connector terminal number
IDE05742-IDE02515,Light switch position-Low beams,not coded / not installed,
IDE05742-IDE05323,Light switch position-Fog lamp,not coded / not installed,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,not coded / not installed,
IDE05742-MAS03835,Light switch position-Position lamps,not coded / not installed,
IDE05742-MAS03836,Light switch position-Rear fog lamp,not coded / not installed,
IDE05742-MAS09941,Light switch position-zero position,not coded / not installed,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not coded / not installed,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,not coded / not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded / not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded / not installed,
IDE05833-MAS00106,Anti-theft warning system: history data-Year,2000,
IDE05833-MAS00107,Anti-theft warning system: history data-Month,0,
IDE05833-MAS00108,Anti-theft warning system: history data-Day,0,
IDE05833-MAS00109,Anti-theft warning system: history data-Hours,0,
IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,0,
IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,Door contact driver door,
IDE05834-MAS00212,Driver info-Washer fluid low,not coded / not installed,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded / not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,not coded / not installed,
IDE05838-MAS02248,Light recognition sensor-Signal status,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,3200, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,2820, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE05839,Parking lamps,|Connector number,Connector terminal number
IDE05841,Central locking history data,|Control-section / cause,Additional information
IDE05842,Comfort function history data,|Control-section / cause,Operating command
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,not coded / not installed,
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,not coded / not installed,
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,not coded / not installed,
IDE06091-MAS04647,Humidity sensor: interior-Dew point,not coded / not installed,
IDE06096-IDE03111,Interior lights-Interior lighting,0, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,42.0,
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,0.0,
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,85.0,
IDE06096-MAS01634,Interior lights-Supply voltage,active,
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,45, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded / not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,closed,
IDE06324-MAS10861,Tank cap lock-Fuel tank cap unlocked via ECM,not coded / not installed,
IDE06470,Periphery lighting,|Connector number,Connector terminal number
IDE06507-MAS13127,Button in center console-Status of button 1,not coded / not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded / not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded / not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded / not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded / not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded / not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded / not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded / not installed,
IDE06566-IDE00008,Key identification-Software version,S305,
IDE06566-IDE00016,Key identification-Hardware version,H22,
IDE06566-MAS04970,Key identification-Part Number,5G6959753DQ,
IDE06624-MAS05016,Remote control-Receiver status,not installed,
IDE06624-MAS05049,Remote control-Quality of signal last received,0, %
IDE06649-MAS05016,Wireless transmitter-Receiver status,not installed,
IDE06649-MAS05048,Wireless transmitter-Number of transmitters adapted,0,
IDE06649-MAS19499,Wireless transmitter-Radio remote control 1 for remote start: identification,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-MAS19500,Wireless transmitter-Radio remote control 2 for remote start: identification,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06864,Daytime running lights,|Connector number,Connector terminal number
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,09,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07293-IDE00500,History data of panic alarm-Hour,0,
IDE07293-IDE00501,History data of panic alarm-Minute,0,
IDE07293-MAS00107,History data of panic alarm-Month,0,
IDE07293-MAS00108,History data of panic alarm-Day,0,
IDE07293-MAS04478,History data of panic alarm-Cause for alarm activation,Panic button,
IDE08162-MAS06256,TSG driver side: signals for central locking-Status door lock,unlocked,
IDE08162-MAS06266,TSG driver side: signals for central locking-Contact switch in lock cylinder,Not operated,
IDE08162-MAS06431,TSG driver side: signals for central locking-Door contact switch,closed,
IDE08162-MAS06432,TSG driver side: signals for central locking-Interior lock switch,Not operated,
IDE08162-MAS06433,TSG driver side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08163-MAS06256,TSG frt.pass.side: signals for central locking-Status door lock,unlocked,
IDE08163-MAS06266,TSG frt.pass.side: signals for central locking-Contact switch in lock cylinder,Not operated,
IDE08163-MAS06431,TSG frt.pass.side: signals for central locking-Door contact switch,closed,
IDE08163-MAS06432,TSG frt.pass.side: signals for central locking-Interior lock switch,Not operated,
IDE08163-MAS06433,TSG frt.pass.side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,not coded / not installed,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,not coded / not installed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Interior lock switch,not coded / not installed,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,not coded / not installed,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,not coded / not installed,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,not coded / not installed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Interior lock switch,not coded / not installed,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,not coded / not installed,
IDE08177-MAS06456,Central locking-Auto lock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,closed,
IDE08177-MAS09895,Central locking-Act. condition: Status central locking locked,active,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-MAS24025,Central locking-Target state: status of central locking individual door unlocked,not active,
IDE08177-ENG263791,Central locking-Cabin/Cargo lock,not active,
IDE08178-MAS06437,Valet parking service-Valet parking lock button,not coded / not installed,
IDE08178-MAS06438,Valet parking service-Valet parking indicator lamp,not coded / not installed,
IDE08185,Counter for play protection of central locking,not active,
IDE08211-MAS03129,History data control module reset-Reset counter,0,
IDE08211-ENG370721,History data control module reset-Field for Iteration,|last cause of reset,Year
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,FC,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,Yes,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,Yes,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,Yes,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,54 9F EE C1,
IDE08239,Transponder ID Key 1,6A 9F EE C1,
IDE08240,Transponder ID Key 2,54 9F EE C1,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,C9 76 D9 9D,
IDE08343,Immobilizer Challenge,18 9E A0 41,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,1370, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,1365, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,not coded / not installed,
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,not coded / not installed,
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,0, mA
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,not coded / not installed,
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,not coded / not installed,
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,not coded / not installed,
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,not coded / not installed,
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,0, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,0, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,0, mA
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,0, mA
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,13, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,0,
IDE10285-MAS02447,Release of rear lid exterior button-Activation,Enabled,
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10662-MAS12418,Light switch (button module)-Automatic driving light control button,not active,
IDE10662-MAS17838,Light switch (button module)-Exterior lighting: global shutoff,OFF,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beams,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-Main beam,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-Static cornering light,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,not installed / not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,Installed: not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,Installed: not active,
IDE11134-MAS04422,Light sequence HU test result-Brake light signal via CAN,Installed: not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,not coded / not installed,
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,not coded / not installed,
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-cause:,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,5,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,5,
IDE11551-ENG303032,Status of identification data query on LIN-Bus-complete_config_hash,No,
IDE11551-ENG303033,Status of identification data query on LIN-Bus-complete_programming_hash,No,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded / not installed,
IDE11727-MAS13128,Function of the central console button-Indicator lamp button 1,installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded / not installed,
IDE11727-MAS13131,Function of the central console button-Indicator lamp button 2,installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded / not installed,
IDE11727-MAS13134,Function of the central console button-Indicator lamp button 3,installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded / not installed,
IDE11727-MAS13136,Function of the central console button-Indicator lamp button 4,installed,
IDE11943,Signature lamp,|Connector number,Connector terminal number
IDE12060,Headlight range adjustment counter,00 00 00 53,
IDE12262-ENG356520,Virtual radio key: status-Device_auth_and_permisission,Init,
IDE12262-ENG355368,Virtual radio key: status-Ephemeral_keypair_available,No,
IDE12262-ENG353272,Virtual radio key: status-Mdk_system_coded,No,
IDE12262-ENG354422,Virtual radio key: status-Mdk_vehicle_id_transfer_nfc_centralconsole,No,
IDE12262-ENG354834,Virtual radio key: status-Mdk_vehicle_id_transfer_nfc_doorhandle,No,
IDE12262-ENG356609,Virtual radio key: status-Mdkccc_backend_nvm_consistent,Yes,
IDE12262-ENG353487,Virtual radio key: status-Mdkccc_config_nvm_consistent,Yes,
IDE12262-ENG353946,Virtual radio key: status-Mdkccc_key_list_nvm_consistent,Yes,
IDE12262-ENG352400,Virtual radio key: status-Mdkccc_owner_conf_nvm_consistent,Yes,
IDE12262-ENG357291,Virtual radio key: status-Mdkccc_service_card_nvm_consistent,Yes,
IDE12262-ENG353419,Virtual radio key: status-Not_authorized_reason,No_error_description,
IDE12262-ENG355337,Virtual radio key: status-Owner_paired,No,
IDE12262-ENG354138,Virtual radio key: status-Owner_pairing_long_term_keypair,invalid,
IDE12262-ENG352847,Virtual radio key: status-Owner_pairing_verifier,invalid,
IDE12262-ENG354351,Virtual radio key: status-Pairing_active,No,
IDE12262-ENG357247,Virtual radio key: status-Servicecard_active,Yes,
IDE12262-ENG354528,Virtual radio key: status-Status_immotoken,Init,
IDE12262-ENG356037,Virtual radio key: status-System_activated,No,
IDE12262-ENG356733,Virtual radio key: status-Transaction_id_available,No,
IDE12262-ENG352422,Virtual radio key: status-Vehicle_config_available,No,
IDE12262-ENG356198,Virtual radio key: status-Vehicle_id_available,No,
IDE12262-ENG357481,Virtual radio key: status-Vehicle_oem_cert_available,No,
IDE12466,Unlocking central locking system history data,|Control-section / cause,Key number
IDE12940-IDE01268,Lever functions of the steering column electronics-Front windshield wiper,Not operated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 2,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE13750-IDE01351,Input signals: control of terminal-Terminal 75 status,On,
IDE13750-IDE01715,Input signals: control of terminal-Status terminal S,active,
IDE13750-IDE01716,Input signals: control of terminal-Terminal 50 status,OFF,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not coded / not installed,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not coded / not installed,
IDE13750-MAS12787,Input signals: control of terminal-Terminal 15 ignition switch signal 1,active,
IDE13750-MAS12788,Input signals: control of terminal-Terminal 15 ignition switch signal 2,active,
IDE13750-MAS17227,Input signals: control of terminal-Starter button: error status,No malfunction detected,
IDE13750-MAS17233,Input signals: control of terminal-Terminal start command,not active,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-ENG256402,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13751-ENG255221,Output signals: control of terminal-Terminal_50_CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,not active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,23,
IDE13845,Production mode status,not active,
IDE13956-IDE00075,Key position replication: input signals-Vehicle speed,0.00, km/h
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,OFF,
IDE13956-IDE80258,Key position replication: input signals-Immobilizer status,Electronic steering locking device installed,
IDE13956-MAS01493,Key position replication: input signals-Engine is running,active,
IDE13956-MAS02248,Key position replication: input signals-Signal status,valid,
IDE13956-MAS03607,Key position replication: input signals-Engine stop active in Start/Stop mode,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,OFF,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,active,
IDE13956-MAS06793,Key position replication: input signals-Number of adapted keys,2,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG255532,Key position replication: input signals-clampcoordinator_approval,On,
IDE13956-ENG255625,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG256242,Key position replication: input signals-Powertrain_activation_permitted,Yes,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,Activation,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG256549,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG256550,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG256551,Key position replication: input signals-Trigger_terminal_15_shutoff,No,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14015-MAS04970,Lock set part number-Part Number,2K7800375CK,
IDE14016,Transponder type,00 33,
IDE14238-MAS02282,Wiper arm position-Position,not coded / not installed,
IDE14238-MAS19580,Wiper arm position-Alternating park position,Outside alternating park position,
IDE14328-MAS19447,Back flash safety version of software blocks-Versioning,01,
IDE14328,Back flash safety version of software blocks,|Rear flash protection: minimal version,Rear flash protection: current version|0001
IDE14337-MAS01853,Vehicle inclination sensor: rotation angle-Left front,Not installed due to specific system,
IDE14337-MAS01855,Vehicle inclination sensor: rotation angle-Left rear,Not installed due to specific system,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 7C,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3E 28 30 EA 48 17 D3,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,10,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 35,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was queried,
IDE14665-IDE01097,Control unit for driving and comfort functions: status-Front passenger airbag -disabled- indicator lamp,OFF,
IDE14665-IDE04213,Control unit for driving and comfort functions: status-Central locking button,Initialization/not installed,
IDE14665-MAS01118,Control unit for driving and comfort functions: status-Air Conditioning,Not operated,
IDE14665-MAS01533,Control unit for driving and comfort functions: status-Defrost,Initialization/not installed,
IDE14665-MAS01535,Control unit for driving and comfort functions: status-Rear window defogger,Initialization/not installed,
IDE14665-MAS01564,Control unit for driving and comfort functions: status-Windshield defogger,Initialization/not installed,
IDE14665-MAS03834,Control unit for driving and comfort functions: status-Emergency signal flashing,Not operated,
IDE14665-MAS08072,Control unit for driving and comfort functions: status-Driving profile selection,Initialization/not installed,
IDE14665-MAS15376,Control unit for driving and comfort functions: status-Front passenger airbag indicator lamp on,On,
IDE14665-MAS18688,Control unit for driving and comfort functions: status-Parking,Initialization/not installed,
IDE14665-MAS18689,Control unit for driving and comfort functions: status-Parking: function display,OFF,
IDE14665-MAS18690,Control unit for driving and comfort functions: status-Driving mode selection: function lighting,OFF,
IDE14665-MAS18691,Control unit for driving and comfort functions: status-Emergency signal flashing: function lighting,OFF,
IDE14665-MAS18692,Control unit for driving and comfort functions: status-Car menu,Initialization/not installed,
IDE14665-MAS18693,Control unit for driving and comfort functions: status-Car menu: function lighting,OFF,
IDE14665-MAS18694,Control unit for driving and comfort functions: status-Windshield defogger: function lighting,OFF,
IDE14665-MAS18695,Control unit for driving and comfort functions: status-Driver assistance systems,Not operated,
IDE14665-MAS18696,Control unit for driving and comfort functions: status-Rear window heating: function lighting,OFF,
IDE14665-MAS18697,Control unit for driving and comfort functions: status-Defrost: function lighting,OFF,
IDE14665-MAS18698,Control unit for driving and comfort functions: status-Front passenger airbag indicator lamp on: inverted,Blinking,
IDE14665-MAS18699,Control unit for driving and comfort functions: status-Front passenger airbag -Disabled- indicator lamp: inverted,Unknown (0)
IDE14665-MAS18700,Control unit for driving and comfort functions: status-Central locking button: function lighting,OFF,
IDE14731-MAS01853,Vehicle inclination sensor: adaptation value (deflected)-Left front,Not installed due to specific system,
IDE14731-MAS01855,Vehicle inclination sensor: adaptation value (deflected)-Left rear,Not installed due to specific system,
IDE14732,Static headlamp range control: specified value,33.0,
IDE14754-IDE08167,Anti-Theft Alarm System: cause of level 1 emergency activation-Sunroof: status standardization,No,
IDE14754-MAS06509,Anti-Theft Alarm System: cause of level 1 emergency activation-Door control module driver side: Timeout,not active,
IDE14754-MAS06510,Anti-Theft Alarm System: cause of level 1 emergency activation-Door ctrl. module frt.pass.side: Timeout,not active,
IDE14754-MAS06511,Anti-Theft Alarm System: cause of level 1 emergency activation-Door control module driver side rear: Timeout,active,
IDE14754-MAS06512,Anti-Theft Alarm System: cause of level 1 emergency activation-Door control module frt. pass. side rear: Timeout,active,
IDE14754-MAS19082,Anti-Theft Alarm System: cause of level 1 emergency activation-Trunk lid electronics: timeout,active,
IDE14754-MAS19083,Anti-Theft Alarm System: cause of level 1 emergency activation-Sunroof Control Module: no communication,not active,
IDE14754-MAS19092,Anti-Theft Alarm System: cause of level 1 emergency activation-A/C/heating electronics: timeout,not active,
IDE14754-MAS20679,Anti-Theft Alarm System: cause of level 1 emergency activation-Front window regulator: driver side: status normalization,Yes,
IDE14754-MAS20680,Anti-Theft Alarm System: cause of level 1 emergency activation-Front window regulator: passenger side: status normalization,Yes,
IDE14754-MAS20681,Anti-Theft Alarm System: cause of level 1 emergency activation-Rear window regulator: driver side: status normalization,No,
IDE14754-MAS20682,Anti-Theft Alarm System: cause of level 1 emergency activation-Rear window regulator: passenger side: status normalization,No,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,not recognised,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,not recognised,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not recognised,
IDE14958-SFT00008,Recognized actual fitting list: adapt-HVAC electronics,detected,
IDE14958-SFT00022,Recognized actual fitting list: adapt-Steering Column Electronics,not recognised,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not recognised,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,not recognised,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,not recognised,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not recognised,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not recognised,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,not recognised,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not recognised,
IDE14958-SFT00118,Recognized actual fitting list: adapt-Parking aid,not recognised,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,not recognised,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for driver assistance systems,detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,not recognised,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,not recognised,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,not recognised,
IDE14958-SFT00222,Recognized actual fitting list: adapt-charging device 1 for mobile end device,not recognised,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,not recognised,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary protection control module 1 VL,not recognised,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary protection control module 2 VR,not recognised,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary protection control module 3 HL,not recognised,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary protection control module 4 HR,not recognised,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary protection control module 5 vehicle interior,not recognised,
IDE14958-SFT33111,Recognized actual fitting list: adapt-Burglary protection control module 6: vehicle interior 2,not recognised,
IDE14958-SFT33112,Recognized actual fitting list: adapt-Burglary protection control module 7: vehicle interior 3,not recognised,
IDE14958-SFT33113,Recognized actual fitting list: adapt-Burglary protection control module 8: vehicle interior 4,not recognised,
IDE14958-SFT271890,Recognized actual fitting list: adapt-Driver door control module,detected,
IDE14958-SFT271891,Recognized actual fitting list: adapt-Front passenger door control module,detected,
IDE14958-SFT271948,Recognized actual fitting list: adapt-Left rear door control module,not recognised,
IDE14958-SFT271949,Recognized actual fitting list: adapt-Right rear door control module,not recognised,
IDE14958-SFT272107,Recognized actual fitting list: adapt-Antenna for short-range communication,not recognised,
IDE14958-ENG251481,Recognized actual fitting list: adapt-Klr,not recognised,
IDE14958-ENG356590,Recognized actual fitting list: adapt-MIK,not recognised,
IDE14958-ENG353028,Recognized actual fitting list: adapt-SBM,not recognised,
IDE14958-ENG357342,Recognized actual fitting list: adapt-UWB_BT_HR,not recognised,
IDE14958-ENG354330,Recognized actual fitting list: adapt-UWB_BT_IN,not recognised,
IDE14958-ENG356451,Recognized actual fitting list: adapt-UWB_BT_VL,not recognised,
IDE14958-ENG353480,Recognized actual fitting list: adapt-UWB_HL,not recognised,
IDE14958-ENG352338,Recognized actual fitting list: adapt-UWB_VR,not recognised,
IDE14959,Tailgate opening: reason for non-availability,No release by access control,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 3B,
IDE14993-ENG370721,Software composition list identification data-Field for Iteration,|Software Composition ID,System designation
IDE15048-ENG255825,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_CAN,unrestricted,
IDE15048-ENG255826,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_SR,unrestricted,
IDE15048-ENG255827,Output signals: terminal coordinator-KST_Request_Clamp_15,CL_15_HW_AND_CAN,
IDE15048-ENG255828,Output signals: terminal coordinator-KST_Specialstate_Request_CAN,Initialization,
IDE15048-ENG255829,Output signals: terminal coordinator-KST_Specialstate_Request_SR,Initialization,
IDE15048-ENG255830,Output signals: terminal coordinator-KST_Specialstate_Status_CAN,active,
IDE15048-ENG255831,Output signals: terminal coordinator-KST_Specialstate_Status_SR,active,
IDE15049-IDE09065,Input signals: terminal coordinator-Status: remote start,Initialization,
IDE15049-MAS20292,Input signals: terminal coordinator-Key position reproduction: status,Initialization,
IDE15049-MAS20294,Input signals: terminal coordinator-Key position reproduction: terminal query,none,
IDE15049-MAS20297,Input signals: terminal coordinator-Key position replication: immobilizer request,none,
IDE15049-MAS20298,Input signals: terminal coordinator-Terminal 15 via diagnostic: query status,Initialization,
IDE15049-ENG263759,Input signals: terminal coordinator-AAA_Request_Clamp_15,none,
IDE15049-ENG263760,Input signals: terminal coordinator-AAA_Request_Immobiliser_Level,none,
IDE15049-ENG263761,Input signals: terminal coordinator-AAA_Request_Status,Initialization,
IDE15049-ENG263762,Input signals: terminal coordinator-MWS_Request_Clamp_15,none,
IDE15049-ENG263763,Input signals: terminal coordinator-MWS_Request_Immobiliser_Level,none,
IDE15049-ENG263764,Input signals: terminal coordinator-MWS_Request_Status,Initialization,
IDE15049-ENG263765,Input signals: terminal coordinator-PHP_Request_Clamp_15,none,
IDE15049-ENG263766,Input signals: terminal coordinator-PHP_Request_Immobiliser_Level,none,
IDE15049-ENG263767,Input signals: terminal coordinator-PHP_Request_Status,Initialization,
IDE15049-ENG263768,Input signals: terminal coordinator-RPA_Request_Clamp_15,none,
IDE15049-ENG263769,Input signals: terminal coordinator-RPA_Request_Immobiliser_Level,none,
IDE15049-ENG263770,Input signals: terminal coordinator-RPA_Request_Status,Initialization,
IDE15049-ENG263771,Input signals: terminal coordinator-RST_Request_Clamp_15,none,
IDE15049-ENG263772,Input signals: terminal coordinator-RST_Request_Immobiliser_Level,none,
IDE15049-ENG263773,Input signals: terminal coordinator-RWK_Request_Clamp_15,none,
IDE15049-ENG263774,Input signals: terminal coordinator-RWK_Request_Immobiliser_Level,none,
IDE15049-ENG263775,Input signals: terminal coordinator-RWK_Request_Status,Initialization,
IDE15049-ENG263776,Input signals: terminal coordinator-ZAS_Request_Clamp_15,Terminal 15: discrete and CAN,
IDE15049-ENG263777,Input signals: terminal coordinator-ZAS_Request_Immobiliser_Level,unrestricted,
IDE15049-ENG263778,Input signals: terminal coordinator-ZAS_Request_Status,active,
IDE15114,Supply voltage for ambient lighting,|Connector number,Connector terminal number
IDE15176-IDE15177,Remote start function: mobile online services-Remote start function: captcha list of mobile online services,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15176-IDE15178,Remote start function: mobile online services-Remote start function: online service communication key,00 00 00 00 00 00 00 00,
IDE15848-MAS14747,DWA for interior monitoring: deactivation softkey-MIB softkey,operated,
IDE15848-MAS21162,DWA for interior monitoring: deactivation softkey-Signal: status deactivation,active,
IDE17075-MAS06854,Functions that can be enabled: FoD slave enhanced status-Version,11,
IDE17075-MAS27237,Functions that can be enabled: FoD slave enhanced status-Length of reference data,53,
IDE17075-MAS27238,Functions that can be enabled: FoD slave enhanced status-Reference data of enhanced status,00 01 00 D6 03 03 00 02 00 00 03 03 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 C8 00 00 75 30 00 05 7E 40 00 00 03 E8 00 0A 01 05 22 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE17850-MAS01632,Convenience shutdown: status-Status,initialized,
IDE17851-MAS01632,Roll safety: availability-Status,Not available,
IDE19099-ENG370721,Virtual key: deactivation by over-the-air update-Field for Iteration,|Deactivation duration,Year
IDE19126-ENG370721,Lock vehicle history data after automatic closing-Field for Iteration,|Year,Month
IDE19127-ENG370721,Unlock/lock keyless history data-Field for Iteration,|Year,Month
IDE19128-ENG370721,Keyless event search history data-Field for Iteration,|Year,Month
IDE19129,Status of antennas for burglary protection,not active,
IDE19130-MAS07151,Field strength of ultra-wide band antennas-RSSI value,128,
IDE19132-ENG370721,Keyless start authorization for mobile end devices history data-Field for Iteration,|Year,Month
IDE19134-ENG370721,History data of locked mobile end devices-Field for Iteration,|Year,Month
IDE19135-ENG370721,Historical data of assigned identifications of mobile end devices-Field for Iteration,|Year,Month
IDE19136-ENG370721,Historical data of failed search for mobile end devices-Field for Iteration,|Year,Month
IDE19324-ENG130242,Light driver communication protection-Zählerstand Spoc 1,0,
IDE19324-ENG130243,Light driver communication protection-Zählerstand Spoc 2,0,
IDE80001-ENG370721,Analysis 1-Field for Iteration,|not_in_ODX,not_in_ODX_2|84 41 24
IDE80001-ENG263844,Analysis 1-not_in_ODX,132,
IDE80030-ENG286807,Analysis 30-state rear left,0,
IDE80030-ENG286808,Analysis 30-state: front left,0,
IDE80030-ENG286982,Analysis 30-value fron tleft,0F FD,
IDE80030-ENG286794,Analysis 30-value rear left,0F FD,
IDE80031,Analysis 31,00,
IDE80031,Analysis 31,0F,
IDE80031,Analysis 31,FD,
IDE80031,Analysis 31,00 00,
IDE80031,Analysis 31,10 01,
IDE80031,Analysis 31,01 00 00 00 00 00 00 00,
IDE80031,Analysis 31,00 00 00 00 00 00 00 00,
IDE80252-MAS02545,History data 0-Last,0451,
IDE80252-MAS02546,History data 0-Second to last,ÿÿÿÿ,
IDE80252-MAS02547,History data 0-Third to last,ÿÿÿÿ,
IDE80252-MAS02548,History data 0-Fourth to last,ÿÿÿÿ,
IDE80252-MAS12541,History data 0-fifth to last,ÿÿÿÿ,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,13.75, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,13.80, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,13.70, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,13.75, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,17.75, V
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,0C,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,14 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG299121,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,26,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,3,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,199,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,12004, km
MAS01281,Back-up lamps,|Connector number,Connector terminal number
MAS02101-MAS07806,Child safety-Specified status,OFF,
MAS03835,Position lamps,|Connector number,Connector terminal number
MAS03836,Rear fog lamp,|Connector number,Connector terminal number
MAS07959,Remote start history data,|Stop or cancel cause,Cause for cancellation
MAS08228-MAS01632,Light sensor-Status,not coded / not installed,
MAS08228-MAS02851,Light sensor-Brightness,not coded / not installed,
MAS08228-MAS04121,Light sensor-Voltage,not coded / not installed,
MAS12666-SFT271873,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT271874,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT271875,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT271876,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT271894,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT271896,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT271909,SubSystemNodeAddress of sub bus participant-Left taillight 1,0x0025,
MAS12666-SFT271910,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT271947,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT271948,SubSystemNodeAddress of sub bus participant-Left rear door control module,0x004C,
MAS12666-SFT271949,SubSystemNodeAddress of sub bus participant-Right rear door control module,0x004D,
MAS12666-SFT271950,SubSystemNodeAddress of sub bus participant-Power rear lid opening control module,0x004E,
MAS12666-SFT271966,SubSystemNodeAddress of sub bus participant-Left neck heater,0x005E,
MAS12666-SFT271967,SubSystemNodeAddress of sub bus participant-Right neck heater,0x005F,
MAS12666-SFT272009,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT272014,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT272057,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT272061,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT272065,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,0x00C1,
MAS12666-SFT272067,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,0x00C3,
MAS12666-SFT272069,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,0x00C5,
MAS12666-SFT272071,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,0x00C7,
MAS12666-SFT272107,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT272121,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT272142,SubSystemNodeAddress of sub bus participant-Left taillight 2,0x010E,
MAS12666-SFT272143,SubSystemNodeAddress of sub bus participant-Right taillight 1,0x010F,
MAS12666-SFT272144,SubSystemNodeAddress of sub bus participant-Right taillight 2,0x0110,
MAS12666-SFT272221,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT272238,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT272272,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver's side,0x0190,
MAS12666-SFT272286,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger's side,0x019E,
MAS12667-SFT271873,Specified installation of sub-bus users-Wiper motor control module,Not available,
MAS12667-SFT271874,Specified installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12667-SFT271875,Specified installation of sub-bus users-Light switch,Available,
MAS12667-SFT271876,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT271894,Specified installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12667-SFT271896,Specified installation of sub-bus users-Alarm horn,Not available,
MAS12667-SFT271909,Specified installation of sub-bus users-Left taillight 1,Not available,
MAS12667-SFT271910,Specified installation of sub-bus users-Roof electronics control module,Available,
MAS12667-SFT271947,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT271948,Specified installation of sub-bus users-Left rear door control module,Not available,
MAS12667-SFT271949,Specified installation of sub-bus users-Right rear door control module,Not available,
MAS12667-SFT271950,Specified installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12667-SFT271966,Specified installation of sub-bus users-Left neck heater,Not available,
MAS12667-SFT271967,Specified installation of sub-bus users-Right neck heater,Not available,
MAS12667-SFT272009,Specified installation of sub-bus users-Steering Column Switch,Available,
MAS12667-SFT272014,Specified installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12667-SFT272057,Specified installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12667-SFT272061,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12667-SFT272065,Specified installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12667-SFT272067,Specified installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12667-SFT272069,Specified installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12667-SFT272071,Specified installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12667-SFT272107,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT272121,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT272142,Specified installation of sub-bus users-Left taillight 2,Not available,
MAS12667-SFT272143,Specified installation of sub-bus users-Right taillight 1,Not available,
MAS12667-SFT272144,Specified installation of sub-bus users-Right taillight 2,Not available,
MAS12667-SFT272221,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT272238,Specified installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12667-SFT272272,Specified installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12667-SFT272286,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12668-SFT271873,Actual installation of sub-bus users-Wiper motor control module,Not available,
MAS12668-SFT271874,Actual installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12668-SFT271875,Actual installation of sub-bus users-Light switch,Available,
MAS12668-SFT271876,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT271894,Actual installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12668-SFT271896,Actual installation of sub-bus users-Alarm horn,Not available,
MAS12668-SFT271909,Actual installation of sub-bus users-Left taillight 1,Not available,
MAS12668-SFT271910,Actual installation of sub-bus users-Roof electronics control module,Available,
MAS12668-SFT271947,Actual installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12668-SFT271948,Actual installation of sub-bus users-Left rear door control module,Not available,
MAS12668-SFT271949,Actual installation of sub-bus users-Right rear door control module,Not available,
MAS12668-SFT271950,Actual installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12668-SFT271966,Actual installation of sub-bus users-Left neck heater,Not available,
MAS12668-SFT271967,Actual installation of sub-bus users-Right neck heater,Not available,
MAS12668-SFT272009,Actual installation of sub-bus users-Steering Column Switch,Available,
MAS12668-SFT272014,Actual installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12668-SFT272057,Actual installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12668-SFT272061,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12668-SFT272065,Actual installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12668-SFT272067,Actual installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12668-SFT272069,Actual installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12668-SFT272071,Actual installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12668-SFT272107,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT272121,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT272142,Actual installation of sub-bus users-Left taillight 2,Not available,
MAS12668-SFT272143,Actual installation of sub-bus users-Right taillight 1,Not available,
MAS12668-SFT272144,Actual installation of sub-bus users-Right taillight 2,Not available,
MAS12668-SFT272221,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT272238,Actual installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12668-SFT272272,Actual installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12668-SFT272286,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12669-SFT271873,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT271874,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT271875,Bus identification of sub-bus users-Light switch,Local data bus,
MAS12669-SFT271876,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT271894,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT271896,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT271909,Bus identification of sub-bus users-Left taillight 1,Local data bus 8,
MAS12669-SFT271910,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT271947,Bus identification of sub-bus users-Humidity sensor: interior,Local data bus,
MAS12669-SFT271948,Bus identification of sub-bus users-Left rear door control module,Local data bus 12,
MAS12669-SFT271949,Bus identification of sub-bus users-Right rear door control module,Local data bus 12,
MAS12669-SFT271950,Bus identification of sub-bus users-Power rear lid opening control module,Local data bus 8,
MAS12669-SFT271966,Bus identification of sub-bus users-Left neck heater,Local data bus 4,
MAS12669-SFT271967,Bus identification of sub-bus users-Right neck heater,Local data bus 4,
MAS12669-SFT272009,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT272014,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus,
MAS12669-SFT272057,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT272061,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT272065,Bus identification of sub-bus users-Blower 1 for left front backrest,Local data bus 4,
MAS12669-SFT272067,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Local data bus 4,
MAS12669-SFT272069,Bus identification of sub-bus users-Blower 1 for right front backrest,Local data bus 4,
MAS12669-SFT272071,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Local data bus 4,
MAS12669-SFT272107,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT272121,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT272142,Bus identification of sub-bus users-Left taillight 2,Local data bus 8,
MAS12669-SFT272143,Bus identification of sub-bus users-Right taillight 1,Local data bus 8,
MAS12669-SFT272144,Bus identification of sub-bus users-Right taillight 2,Local data bus 8,
MAS12669-SFT272221,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT272238,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT272272,Bus identification of sub-bus users-Virtual pedal door opening: rear driver's side,Local data bus 4,
MAS12669-SFT272286,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger's side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,36 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,not active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,not active,
MAS19775-MAS06430,Status of sliding door rear driver side-Main notch contact of rotary latch,closed,
MAS19775-MAS15328,Status of sliding door rear driver side-Interior door handle switch,Not operated,
MAS19775-MAS19404,Status of sliding door rear driver side-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
MAS19775-MAS21226,Status of sliding door rear driver side-Mechanical separation door inside handle: status,OFF,
MAS19775-MAS21227,Status of sliding door rear driver side-Motor for safe: child safety: and crash activation,OFF,
MAS19775-MAS21228,Status of sliding door rear driver side-Rotary motor: activation,OFF,
MAS19775-MAS21237,Status of sliding door rear driver side-Virtual crash redundancy sensor: sliding door,OFF,
MAS19777-MAS06430,Status of sliding door passenger side rear-Main notch contact of rotary latch,closed,
MAS19777-MAS15328,Status of sliding door passenger side rear-Interior door handle switch,Not operated,
MAS19777-MAS19403,Status of sliding door passenger side rear-Rear Passenger Exterior Door Handle Switch: status,Not operated,
MAS19777-MAS21226,Status of sliding door passenger side rear-Mechanical separation door inside handle: status,OFF,
MAS19777-MAS21227,Status of sliding door passenger side rear-Motor for safe: child safety: and crash activation,OFF,
MAS19777-MAS21228,Status of sliding door passenger side rear-Rotary motor: activation,OFF,
MAS19777-MAS21237,Status of sliding door passenger side rear-Virtual crash redundancy sensor: sliding door,OFF,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS21279,Monitoring for digital component supply voltage,|Connector number,Connector terminal number
MAS23572-ENG423280,AlcoLock interface: internal module signals-AI_data_plausibility,not active,
MAS23572-ENG423281,AlcoLock interface: internal module signals-AI_data_plausibility_check_active,not active,
MAS23572-ENG423282,AlcoLock interface: internal module signals-AI_data_unplausible_data_received_counter,00,
MAS23572-ENG354512,AlcoLock interface: internal module signals-AI_ECU_breath_test_valid,Init,
MAS23572-ENG423285,AlcoLock interface: internal module signals-AI_ECU_error_reason,Init,
MAS23572-ENG415652,AlcoLock interface: internal module signals-AI_ECU_IDLE_states,Nothing_to_report,
MAS23572-ENG423286,AlcoLock interface: internal module signals-AI_ECU_lockout_reason,Init,
MAS23572-ENG356980,AlcoLock interface: internal module signals-AI_ECU_test_request_state,Init,
MAS23572-ENG423287,AlcoLock interface: internal module signals-AI_ECU_time_remaining_for_wait_ignition,0, s
MAS23572-ENG415653,AlcoLock interface: internal module signals-AI_LIN_data_sent,not active,
MAS23572-ENG415654,AlcoLock interface: internal module signals-AI_LIN_Wake,not active,
MAS23572-ENG351542,AlcoLock interface: internal module signals-Engine_Runs,active,
MAS23572-ENG351747,AlcoLock interface: internal module signals-LIN_version_AI_ECU,Unknown (0)
MAS23572-ENG356917,AlcoLock interface: internal module signals-LIN_version_AI_interface,LIN_2_0,
MAS23572-ENG423694,AlcoLock interface: internal module signals-Protocol_plausibilty,Init,
MAS23572-ENG423695,AlcoLock interface: internal module signals-Protocol_version_AI_ECU,Unknown (0)
MAS23572-ENG423696,AlcoLock interface: internal module signals-Protocol_version_AI_interface,Version_2022,
MAS23572-ENG423718,AlcoLock interface: internal module signals-Terminal_activation_request_detected,not active,
MAS23572-ENG423759,AlcoLock interface: internal module signals-Vehicle_communication_state,Shut_down,
MAS23572-ENG109868,AlcoLock interface: internal module signals-vehicle_locked_externally,not active,
MAS23572-ENG354758,AlcoLock interface: internal module signals-Vehicle_state,Shut_down,
MAS24797-ENG423288,AlcoLock interface: output signals-AI_interface_terminal_release,active,
MAS24798-ENG354120,AlcoLock interface: LIN output signals-AI_interface_LIN_data1,240, s
MAS24798-ENG353741,AlcoLock interface: LIN output signals-AI_interface_LIN_data2,255, s
MAS24798-ENG357362,AlcoLock interface: LIN output signals-AI_interface_LIN_data3,255, s
MAS24798-ENG355675,AlcoLock interface: LIN output signals-AI_interface_LIN_data4,255, s
MAS24798-ENG356287,AlcoLock interface: LIN output signals-AI_interface_LIN_data5,255, s
MAS24798-ENG357125,AlcoLock interface: LIN output signals-AI_interface_LIN_data6,255, s
MAS24798-ENG353930,AlcoLock interface: LIN output signals-AI_interface_LIN_data7,255, s
MAS24798-ENG355955,AlcoLock interface: LIN output signals-LIN_AI_interface_vehicle_state,Shut_down,
MAS24799-ENG423375,AlcoLock interface: input signals-Central_locking_state_locked,not active,
MAS24799-ENG423376,AlcoLock interface: input signals-Central_locking_state_safe,not active,
MAS24799-ENG423576,AlcoLock interface: input signals-KBI_Kilometer_mileage,3073280, km
MAS24799-ENG423577,AlcoLock interface: input signals-KBI_unit_tacho,kilometers_per_hour,
MAS24799-ENG186493,AlcoLock interface: input signals-Status_terminal_15,active,
MAS24799-ENG423716,AlcoLock interface: input signals-Status_terminals,active,
MAS24799-ENG423175,AlcoLock interface: input signals-Terminal_activation_request,not active,
MAS24799-ENG423750,AlcoLock interface: input signals-USS_comfort_ready_status,active,
MAS24799-ENG423751,AlcoLock interface: input signals-USS_driver_presence_status,driver_absent,
MAS24800-ENG352190,AlcoLock interface: LIN input signals-AI_ECU_blocking_state,Blocking_state_LSB_Range_0_AB,
MAS24800-ENG423283,AlcoLock interface: LIN input signals-AI_ECU_blocking_state_inverse,Unknown (0)
MAS24800-ENG423284,AlcoLock interface: LIN input signals-AI_ECU_communication_state,Unknown (0)
MAS24800-ENG354636,AlcoLock interface: LIN input signals-AI_ECU_LIN_data1,0, s
MAS24800-ENG354806,AlcoLock interface: LIN input signals-AI_ECU_LIN_data2,0, s
MAS24800-ENG357261,AlcoLock interface: LIN input signals-AI_ECU_LIN_data3,0, s
MAS24800-ENG356291,AlcoLock interface: LIN input signals-AI_ECU_LIN_data4,0, s
MAS24800-ENG353833,AlcoLock interface: LIN input signals-AI_ECU_LIN_data5,0, s
MAS24801-IDE00075,AlcoLock interface: CAN input signals-Vehicle speed,0.00, km/h
MAS24801-ENG356016,AlcoLock interface: CAN input signals-Driver_door_open,not active,
MAS24801-ENG352670,AlcoLock interface: CAN input signals-Driving_enabled_mode,not active,
MAS24801-ENG106219,AlcoLock interface: CAN input signals-Engine_Speed,39.12,
MAS24801-ENG355977,AlcoLock interface: CAN input signals-Engine_speed_not_valid,not active,
MAS24801-ENG352728,AlcoLock interface: CAN input signals-Engine_speed_timeout,not active,
MAS24801-ENG423590,AlcoLock interface: CAN input signals-Motor_start_stopp_mode,not active,
MAS24801-ENG357049,AlcoLock interface: CAN input signals-Motor_start_stopp_status,active,
MAS24801-ENG423173,AlcoLock interface: CAN input signals-status_terminal_50,not active,
MAS24802,AlcoLock interface: historical memory,|Negative_issues,Date_Year
MAS24928-IDE06956,Secure presence detection-Driver-side belt buckle status,Open,
MAS24928-IDE13428,Secure presence detection-Accelerator pedal value,Not operated,
MAS24928-IDE15366,Secure presence detection-Selector lever P button status,Not operated,
MAS24928-MAS00218,Secure presence detection-Driver´s door,closed,
MAS24928-MAS00370,Secure presence detection-Vehicle speed,plausible,
MAS24928-MAS00635,Secure presence detection-Available,Available,
MAS24928-MAS03554,Secure presence detection-Clutch pedal operation,Not operated,
MAS24928-MAS05192,Secure presence detection-Driver braking,Not braking,
MAS24928-MAS07200,Secure presence detection-Multi-function steering wheel,not around,
MAS24928-MAS07652,Secure presence detection-Vehicle movement,Standstill,
MAS24928-MAS17288,Secure presence detection-Driver seat occupant detection,Not assigned,
MAS24928-MAS22006,Secure presence detection-Start request recognition: status,Not operated,
MAS24928-MAS22963,Secure presence detection-Starter button actuated,Not operated,
MAS24928-MAS25017,Secure presence detection-Selector mechanism,Not operated,
MAS24928-MAS25018,Secure presence detection-Driver request: switch position,Not operated,
MAS24928-MAS25020,Secure presence detection-Presence detection: status,Not available,
MAS24928-SFT33114,Secure presence detection-Multifunction interior camera,not recognised,
MAS24928-ENG357179,Secure presence detection-Clutch_pedal_actuation_plausible,Implausible,
MAS24928-ENG354959,Secure presence detection-Driver_brakes_plausible,plausible,
MAS24928-ENG352344,Secure presence detection-Driver_pedal_value_plausible,plausible,
MAS24928-ENG352881,Secure presence detection-Driver_side_door_plausible,plausible,
MAS24928-ENG355601,Secure presence detection-Epb_switch_position_plausible,plausible,
MAS24928-ENG354436,Secure presence detection-Multifunction_interior_camera_plausible,Implausible,
MAS24928-ENG357466,Secure presence detection-Multifunction_steering_wheel_plausible,Implausible,
MAS24928-ENG353527,Secure presence detection-Seat_belt_driver_plausible,plausible,
MAS24928-ENG352047,Secure presence detection-Seat_occupied_driver_plausible,plausible,
MAS24928-ENG353443,Secure presence detection-Selector_lever_p_button_status_plausible,Implausible,
MAS24928-ENG356327,Secure presence detection-Switching_actuation_activated_plausible,Implausible,
MAS25323,Ambient lighting: error locations,not installed,
MAS26682,Distance of storage error,00,
MAS26683,Distance of calculation error,00,
MAS27748-IDE02068,Distance data with electronic stabilization program information-Time stamp,00 00 42 00 00,
MAS27748-MAS00106,Distance data with electronic stabilization program information-Year,2000, yr
MAS27748-MAS00107,Distance data with electronic stabilization program information-Month,1, Months
MAS27748-MAS00108,Distance data with electronic stabilization program information-Day,1, d
MAS27748-MAS00109,Distance data with electronic stabilization program information-Hours,0, H
MAS27748-MAS00110,Distance data with electronic stabilization program information-Minutes,0, min
MAS27748-MAS00111,Distance data with electronic stabilization program information-Seconds,0, s
MAS27748-MAS27735,Distance data with electronic stabilization program information-ESC distance pulses,12004777, m
MAS27748-MAS27749,Distance data with electronic stabilization program information-Distance pulses: number of jumps,1,
MAS27748-MAS27750,Distance data with electronic stabilization program information-Distance pulses: largest positive jump,0, m
MAS27748-MAS27751,Distance data with electronic stabilization program information-Distance pulses: largest negative jump,242, m
MAS27748-MAS27752,Distance data with electronic stabilization program information-Distance pulses: total jumps,242, m
MAS27748-MAS27753,Distance data with electronic stabilization program information-Distance pulses: jump balance,-246, m
MAS27748-MAS27754,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: number,11,
MAS27748-MAS27755,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: total duration,345, s
MAS27748-MAS27756,Distance data with electronic stabilization program information-Longest electronic stabilization program communication failure,6, min
SFT00085,Headlamp range control,static,
ENG277599-MAS18508,ASIL_relevante_RDIDs-Number of nodes,48,
ENG277599-ENG370721,ASIL_relevante_RDIDs-Field for Iteration,|Adapted values/adaptation,Status of adaptation|2674
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG186123-ENG255560,Authentic_time_last_client_response-Current_time_ used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,1970-01-01T00:00:00Z,
ENG370267-IDE09250,Can_signals_mdk-Key search in vehicle interior,0,
ENG370267-MAS06118,Can_signals_mdk-ID sensor not found,0,
ENG370267-MAS28651,Can_signals_mdk-Kessy faulty,0,
ENG370267-MAS28652,Can_signals_mdk-Key in mobile end device faulty,0,
ENG254556-MAS09527,Control_voltage_actual_value-Activation voltage: act. value,4.4, V
ENG254556-MAS10074,Control_voltage_actual_value-Supply voltage: actual value,13.6, V
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,0,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,PIN A16_A17 Komfort CAN,
ENG347824,Digital_key_SE_Reference_Long,|Secure_element_reference_state,Secure_element_reference_length
ENG286564,Easy_open_HBFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG286565,Easy_open_HFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,108, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,143, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,22.50, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,25500,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,64450,
ENG116813-ENG370721,Entwicklermesswerte_CONTI-Field for Iteration,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,3,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,active,
ENG254718-ENG370721,Function_On_Demand_Unlock_ID_Status_Dev-Field for Iteration,|ID number,Release code for a SWaP function
ENG310456-IDE10283,key_fob-Key identification: transponder ID,00 00 00 00,
ENG310456-ENG331600,key_fob-key_fob_battery_level,1.00, V
ENG310456-ENG331607,key_fob-key_fob_button,no_button,
ENG310456-ENG331605,key_fob-key_fob_error_state,no_UHF_message,
ENG310456-ENG331606,key_fob-key_fob_number,no_UHF_message,
ENG310456-ENG331603,key_fob-LF_range_limitation,no_UHF_message,
ENG310456-ENG331601,key_fob-number_of_adapted_key_fobs,2,
ENG310456-ENG331602,key_fob-rolling_code_synchronisation,no_UHF_message,
ENG286616,Last_LIN_Message_BCM_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286617,Last_LIN_Message_BCM_VIP_HFS,00 00 00 00 00 00 00 00,
ENG121906,Last_LIN_Message_Kessy,00 00 00 00 00 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 02 80 02 00 00 00 3C,
ENG286618,Last_LIN_Message_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286619,Last_LIN_Message_VIP_HFS,00 00 00 00 00 00 00 00,
ENG130144-ENG130193,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_0,0,
ENG130144-ENG130194,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_1,0,
ENG130144-ENG130203,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_10,0,
ENG130144-ENG130204,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_11,0,
ENG130144-ENG130205,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_12,0,
ENG130144-ENG130206,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_13,0,
ENG130144-ENG130207,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_14,0,
ENG130144-ENG130208,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_15,0,
ENG130144-ENG130209,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_16,0,
ENG130144-ENG130210,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_17,0,
ENG130144-ENG130211,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_18,0,
ENG130144-ENG130212,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_19,0,
ENG130144-ENG130195,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_2,0,
ENG130144-ENG130213,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_20,0,
ENG130144-ENG130214,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_21,0,
ENG130144-ENG130215,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_22,0,
ENG130144-ENG130216,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_23,0,
ENG130144-ENG130217,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_24,0,
ENG130144-ENG130218,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_25,0,
ENG130144-ENG130219,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_26,0,
ENG130144-ENG130220,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_27,0,
ENG130144-ENG130221,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_28,0,
ENG130144-ENG130222,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_29,0,
ENG130144-ENG130196,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_3,0,
ENG130144-ENG130223,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_30,0,
ENG130144-ENG130224,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_31,0,
ENG130144-ENG130225,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_32,0,
ENG130144-ENG130226,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_33,0,
ENG130144-ENG130227,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_34,0,
ENG130144-ENG263824,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_35,0,
ENG130144-ENG263825,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_36,0,
ENG130144-ENG263826,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_37,0,
ENG130144-ENG263827,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_38,0,
ENG130144-ENG263828,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_39,0,
ENG130144-ENG130197,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_4,0,
ENG130144-ENG263829,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_40,0,
ENG130144-ENG263830,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_41,0,
ENG130144-ENG263831,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_42,0,
ENG130144-ENG263832,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_43,0,
ENG130144-ENG263833,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_44,0,
ENG130144-ENG263834,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_45,0,
ENG130144-ENG130198,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_5,0,
ENG130144-ENG130199,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_6,0,
ENG130144-ENG130200,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_7,0,
ENG130144-ENG130201,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_8,0,
ENG130144-ENG130202,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_9,0,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG256023,LIN activity-LIN 10,not coded / not installed,
ENG116909-ENG256024,LIN activity-LIN 11,not coded / not installed,
ENG116909-ENG256025,LIN activity-LIN 12,not coded / not installed,
ENG116909-ENG256026,LIN activity-LIN 13,not coded / not installed,
ENG116909-ENG256027,LIN activity-LIN 14,not coded / not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded / not installed,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,not coded / not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded / not installed,
ENG116909-ENG114951,LIN activity-LIN 6,Communication,
ENG116909-ENG256030,LIN activity-LIN 7,not coded / not installed,
ENG116909-ENG256031,LIN activity-LIN 8,not coded / not installed,
ENG116909-ENG256032,LIN activity-LIN 9,not coded / not installed,
ENG254795,Personalized_Signals_2_0,|Current profile slot number for customization,Customization control command
ENG116792-ENG370721,Power up history-Field for Iteration,|Funktionsanforderung|0|0|0|0|0|0|0|0|0|0|,
ENG254816,Snapshot_DTC_Notlaufpfad,No malfunction,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG370398-ENG370721,State_access_nvram_mdk-Field for Iteration,|Reason for access,kilometer reading|Reading data record
ENG254825,steuergeraetinterne_Messwert,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-kilometer reading,10285, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.70, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.90, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,13.80, V
ENG370404-ENG370721,Suppression_entry_exit_go-Field for Iteration,|Reason for low pressure,Year
ENG254841-ENG255534,User State Server-Comfort Ready Status,active,
ENG254841-ENG255633,User State Server-Driver Presence Status,driver_absent,
ENG254841-ENG255634,User State Server-Driver Presence_Qbit,gueltiger_Wert,
ENG254841-ENG255639,User State Server-DTC OccupantPresenceService Error,no error,
ENG254841-ENG255640,User State Server-DTC OccupantPresenceService Restriction,no restriction,
ENG254841-ENG255787,User State Server-HV_Anwesenheit,No HV request,
ENG254841-ENG256105,User State Server-Occupant Presence Status,occupant_absent,
ENG254841-ENG256557,User State Server-USS CAN Nachlauf,inactive,
Elapsed Time: 01:36
datodaco
Slovenia
C?ID=393757
blockmap-10-5QS-919-283-A_WV2ZZZSK8SX116493-20260803-1935.CSV
;SW:5QS-919-283-A   HW:5QS-919-283 ---  10: Park/Steer Assist
;Component:PDC 04ch low  H01 0075, Coding:0000010001
;EV_EPHBO14VW3360000,001010,
;Monday,03,August,2026,19:35:28:29755
;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0
;VCID: 5AED9440CC983A6AF1F-800E
Group,Description,Actual
Elapsed Time: 00:00
blockmap-13-5WA-907-567_WV2ZZZSK8SX116493-20260803-1935.CSV
;SW:5WA-907-567   HW:5WA-907-819 ---  13: Auto Dist. Reg
;Component:ACC Bosch MQB H50 0576, Coding:00030205000740441257400000C000042E4030000000000000000000000000
;EV_FRONTRADARBOSCHVW380,005024,EV_FRONTRADARBOSCHVW380_004_VN3S.rod
;Monday,03,August,2026,19:35:32:29755
;VCID: 0F7BB51447DA2FC2561-805A SFD+SFD2 {x}
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,13.4, V
IDE00102,Control Module temperature,65, °C
IDE00310,Outside temperature,35.0, °C
IDE00391,Adaptive distance regulation: status,ACC_reversible_error,
IDE00924,Steering angle,26.600, °
IDE00925,Yaw rate,0.000, rad/s
IDE01268-MAS02506,Front windshield wiper-Wiper active,not active,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,5B 73 0C E0,
IDE02057-MAS02356,Dynamic calibration: status-Type of calibration,static,
IDE02057-MAS05634,Dynamic calibration: status-Progress,0, %
IDE02057-ENG279299,Dynamic calibration: status-Absolute_driving_distance,0, m
IDE02057-ENG279303,Dynamic calibration: status-Acceleration_out_of_range,Framework conditions currently not met,
IDE02057-ENG98465,Dynamic calibration: status-Calibration status,not started,
IDE02057-ENG279396,Dynamic calibration: status-Effective_driving_distance,0, m
IDE02057-ENG279410,Dynamic calibration: status-Fault_signal_active,Framework conditions currently not met,
IDE02057-ENG279411,Dynamic calibration: status-Few_locations,Framework conditions currently not met,
IDE02057-ENG279533,Dynamic calibration: status-Speed_out_of_range,Framework conditions currently not met,
IDE02057-ENG279572,Dynamic calibration: status-Yaw_rate_out_of_range,Framework conditions currently not met,
IDE02068-MAS00106,Time stamp-Year,2026,
IDE02068-MAS00107,Time stamp-Month,8,
IDE02068-MAS00108,Time stamp-Day,3,
IDE02068-MAS00109,Time stamp-Hours,19,
IDE02068-MAS00110,Time stamp-Minutes,35,
IDE02068-MAS00111,Time stamp-Seconds,2,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead approaching: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead approaching: ACC OFF,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead approaching: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead approaching: ACC OFF,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01447,Driving profile selection-Actual value,5,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE08936,Misalignment angle: horiz,0.044, °
IDE09906,Vertical deadjustment,3.403, °
IDE10902-IDE00018,Expanded ambient data 1-Voltage terminal 15,13.3, V
IDE10902-IDE00102,Expanded ambient data 1-Control Module temperature,65, °C
IDE10902-IDE00310,Expanded ambient data 1-Outside temperature,35.5, °C
IDE10902-IDE03660,Expanded ambient data 1-Longitudinal acceleration,0.00, m/s²
IDE10902-MAS00370,Expanded ambient data 1-Vehicle speed,0.00, m/s
IDE10902-MAS01632,Expanded ambient data 1-Status,ACC_reversible_error,
IDE10903-IDE00924,Expanded ambient data 2-Steering angle,26.600, °
IDE10903-IDE00925,Expanded ambient data 2-Yaw rate,0.000, rad/s
IDE10903-IDE01268,Expanded ambient data 2-Front windshield wiper,not active,
IDE10903-IDE08936,Expanded ambient data 2-Misalignment angle: horiz,0.044, °
IDE10903-IDE09906,Expanded ambient data 2-Vertical deadjustment,3.403, °
IDE10903-MAS00106,Expanded ambient data 2-Year,2026,
IDE10903-MAS00107,Expanded ambient data 2-Month,8,
IDE10903-MAS00108,Expanded ambient data 2-Day,3,
IDE10903-MAS00109,Expanded ambient data 2-Hours,19,
IDE10903-MAS00110,Expanded ambient data 2-Minutes,35,
IDE10903-MAS00111,Expanded ambient data 2-Seconds,5,
IDE10903-MAS00711,Expanded ambient data 2-kilometer reading,12004, km
IDE10903-MAS13429,Expanded ambient data 2-Horizontal correction angle: currently,0.090, °
IDE10903-MAS13430,Expanded ambient data 2-Vertical correction angle: currently,3.320, °
IDE10903-ENG255471,Expanded ambient data 2-Blindness_combined,0, %
IDE10903-ENG255476,Expanded ambient data 2-Blindness_indicator_1,100, %
IDE10903-ENG255477,Expanded ambient data 2-Blindness_indicator_2,100, %
IDE10903-ENG255478,Expanded ambient data 2-Blindness_indicator_3,0, %
IDE10903-ENG255479,Expanded ambient data 2-Blindness_indicator_4,97, %
IDE10903-ENG255480,Expanded ambient data 2-Blindness_indicator_5,0, %
IDE10903-ENG255481,Expanded ambient data 2-Blindness_indicator_6,0, %
IDE10903-ENG255628,Expanded ambient data 2-Distance_index,0.00, m
IDE10903-ENG256311,Expanded ambient data 2-Sensor_FRKL,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|2|2|2|2|2|2|2|2|2|,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|,
IDE11923-MAS13423,Number of calibration procedures-Counter for statistical calibration procedures started,1,
IDE11923-MAS13424,Number of calibration procedures-Counter for statistical calibration procedures successful,1,
IDE11923-MAS13425,Number of calibration procedures-Counter for dynamical calibration procedures started,0,
IDE11923-MAS13426,Number of calibration procedures-Counter for dynamical calibration procedures successful,0,
IDE11923-MAS17950,Number of calibration procedures-Counter dynamic EOL calibration processes started,0,
IDE11923-MAS17951,Number of calibration procedures-Number of dynamic EOL calibration processes successfully ended,0,
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.090, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,3.320, °
IDE12062,Counter for terminal 15 reset,1915,
IDE12238,I network: discarded messages counter,0,
IDE13845,Production mode status,not active,
IDE14997,Number of events: sensor blind,6,
IDE14998,Number of events: misalignment,1,
IDE15000-IDE08936,History data sensor calibration-Misalignment angle: horiz,1.088, °
IDE15000-IDE09906,History data sensor calibration-Vertical deadjustment,1.450, °
IDE15000-IDE14999,History data sensor calibration-Duration of calibration,0.20, s
IDE15000-IDE15022,History data sensor calibration-Result of calibration,OK,
IDE15000-MAS00106,History data sensor calibration-Year,2025,
IDE15000-MAS00107,History data sensor calibration-Month,6,
IDE15000-MAS00108,History data sensor calibration-Day,9,
IDE15000-MAS00109,History data sensor calibration-Hours,20,
IDE15000-MAS00110,History data sensor calibration-Minutes,51,
IDE15000-MAS00111,History data sensor calibration-Seconds,43,
IDE15000-MAS00711,History data sensor calibration-kilometer reading,0, km
IDE15000-MAS02356,History data sensor calibration-Type of calibration,static,
IDE15000-MAS13429,History data sensor calibration-Horizontal correction angle: currently,1.080, °
IDE15000-MAS13430,History data sensor calibration-Vertical correction angle: currently,1.440, °
IDE15006,History data sensor 01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15007,History data sensor 02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15008,History data sensor 03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15009,History data sensor 04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15010,History data sensor 05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15011,History data sensor 06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15012,History data sensor 07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15013,History data sensor 08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15014,History data sensor 09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15015,History data sensor 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15016,History data sensor 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15017,History data sensor 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15018,History data sensor 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15019,History data sensor 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15020,History data sensor 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE16615,Control module internal information,00 00 00,
IDE17075-MAS06854,Functions that can be enabled: FoD slave enhanced status-Version,10,
IDE17075-ENG298547,Functions that can be enabled: FoD slave enhanced status-Extended_state_payload,00 01 00 D6 02 02 01 02 00 00 03 03 00 00 00 00 00 00 00 F2 00 00 00 00 03 00 00 00 14 00 00 00 00 00 00 3A 98 00 02 BF 20 00 00 01 F4 00 0A 02 0F 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE17075-ENG298612,Functions that can be enabled: FoD slave enhanced status-Payload_length,51,
MAS00370,Vehicle speed,0.00, m/s
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 01 01 00,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,10,
ENG302951,DTCCodeRef_for_FAULT_CS520_TIMESTAMP,00 00 00,
ENG302952,DTCCodeRef_for_FAULT_MMIC_TIMESTAMP,00 00 00,
ENG302953,DTCCodeRef_for_FAULT_RIF_TIMESTAMP,00 00 00,
ENG302954,DTCCodeRef_for_FAULT_SPU_TIMESTAMP,00 00 00,
ENG302955,DTCCodeRef_for_FAULT_UC_TIMESTAMP,00 00 00,
ENG254628,Freeze_Frame_Dataset_Fct_01_Evt_Last,FF 34 8A 49 0F 5D C0 C7 E5 82 D0 4C 23 00 24 00 00 2D E8 00 02 20 01 4B FF 17 00 59 63 1E 05 03 08 00 24 00 00 00 24 00 00 E8 E8 00 00 00 00 4B 00 20 01 00 80 00 40 DC 00 19 00 00 19 00 02 08 40 0A 00 36 B8 00 BE 00 00 00,
ENG254629,Freeze_Frame_Dataset_Fct_01_Evt_Prev1,EF 34 8A 7D C1 5A E0 DE E1 82 05 4B 23 00 00 01 00 1C FD 01 01 1A FF 62 FF 08 01 5F 63 20 03 02 08 00 00 01 00 00 00 01 00 FD FD 01 01 00 00 62 00 1A FF 00 80 00 48 DE 00 19 00 00 19 02 02 08 40 0A 00 36 FD 00 84 00 00 00,
ENG254630,Freeze_Frame_Dataset_Fct_01_Evt_Prev2,EF 34 EA 64 B9 5A 40 CF E3 82 A1 4B 23 00 0B 02 00 25 F7 04 00 1D 08 5F FC FF 03 5F 63 14 03 02 08 00 17 09 09 00 0B 02 00 F7 EF 0B 04 15 08 5F 00 11 FF 14 80 00 48 E1 00 19 00 00 19 04 02 08 40 0A 00 36 BD 00 BC 00 00 00,
ENG254631,Freeze_Frame_Dataset_Fct_01_Evt_Prev3,E6 34 E7 B2 B6 5A 20 E8 E3 02 61 4B 23 00 00 FE FF 2B FE FC 00 1A FC 6D 01 F6 FF 64 63 19 03 02 08 00 05 FE 00 00 00 FE FF FE FE FC FA 02 00 6D 01 1A FC 01 80 08 48 DC 00 19 00 00 19 82 02 08 40 0A 00 36 DA 00 CE 00 00 00,
ENG254632,Freeze_Frame_Dataset_Fct_02_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254633,Freeze_Frame_Dataset_Fct_02_Evt_Prev1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254634,Freeze_Frame_Dataset_Fct_02_Evt_Prev2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254635,Freeze_Frame_Dataset_Fct_02_Evt_Prev3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254636,Freeze_Frame_Dataset_Fct_03_Evt_Last,FF 34 8A 49 0F 5D C0 C7 E5 82 D0 4C 23 00 25 00 00 2D E7 00 02 20 01 4B FF 17 00 59 63 1E 05 03 08 00 33 02 04 00 1E FF FE EB DC 00 FE 23 1D 68 04 09 02 23 80 00 48 DC 00 19 00 00 19 00 16 08 40 1E 00 36 B8 1C BE 00 00 00,
ENG254637,Freeze_Frame_Dataset_Fct_03_Evt_Prev1,BA 34 E6 CE DE 55 00 0E E4 82 4B 4B 23 00 24 00 00 19 EB 00 FE 10 FD 61 00 08 FF 63 63 20 07 00 07 00 25 00 00 00 24 00 00 EB EA 00 00 01 01 61 00 10 FD 00 80 00 48 DC 00 19 00 00 19 00 16 08 40 1A 00 36 84 00 12 00 00 00,
ENG254638,Freeze_Frame_Dataset_Fct_03_Evt_Prev2,77 33 8D 98 CA 3B E0 F9 E5 81 33 E2 23 00 20 00 00 4E F1 01 06 4B 01 3D FF 09 01 64 63 20 03 02 08 00 28 01 03 00 00 00 FF F1 E2 02 FE 21 19 4B 04 24 FD 21 80 00 48 F4 00 19 00 00 19 00 1B 08 40 1E 00 36 FD 19 DC 00 00 00,
ENG254639,Freeze_Frame_Dataset_Fct_03_Evt_Prev3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254640,Freeze_Frame_Dataset_Fct_04_Evt_Last,B2 34 0E 26 9D 55 C0 49 E1 82 ED 4A 23 00 14 FF FE 1C FB 01 FE 0A FF 6D 00 FA 00 64 63 20 03 03 08 00 29 FF FF 00 14 FE FD FB ED 01 00 05 02 6D 04 09 FF 05 80 00 48 D8 00 19 00 00 19 00 0E 08 40 26 00 36 78 02 66 00 00 00,
ENG254641,Freeze_Frame_Dataset_Fct_04_Evt_Prev1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254642,Freeze_Frame_Dataset_Fct_04_Evt_Prev2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254643,Freeze_Frame_Dataset_Fct_04_Evt_Prev3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254644,Freeze_Frame_Dataset_Fct_05_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254645,Freeze_Frame_Dataset_Fct_05_Evt_Prev1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254646,Freeze_Frame_Dataset_Fct_05_Evt_Prev2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254647,Freeze_Frame_Dataset_Fct_05_Evt_Prev3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254648,Freeze_Frame_Dataset_Fct_06_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254649,Freeze_Frame_Dataset_Fct_06_Evt_Prev1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254650,Freeze_Frame_Dataset_Fct_06_Evt_Prev2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254651,Freeze_Frame_Dataset_Fct_06_Evt_Prev3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254652,Freeze_Frame_Dataset_Fct_07_Evt_Last,B2 34 0E 2E 9D 55 E0 49 E1 82 EC 4A 23 00 29 FE FE 1A EC 00 FE 08 FF 6D 00 07 00 64 63 1F 03 04 08 00 32 FE 01 00 1E FD FE EF E5 00 FF 16 0A 76 04 05 FF 16 80 00 48 D8 00 19 00 00 19 00 12 09 40 3E 00 36 CB 00 66 00 00 00,
ENG254653,Freeze_Frame_Dataset_Fct_07_Evt_Prev1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254654,Freeze_Frame_Dataset_Fct_07_Evt_Prev2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254655,Freeze_Frame_Dataset_Fct_07_Evt_Prev3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254656,Freeze_Frame_Dataset_Fct_08_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254657,Freeze_Frame_Dataset_Fct_08_Evt_Prev1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254658,Freeze_Frame_Dataset_Fct_08_Evt_Prev2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254659,Freeze_Frame_Dataset_Fct_08_Evt_Prev3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254660,Freeze_Frame_Dataset_Fct_09_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254661,Freeze_Frame_Dataset_Fct_09_Evt_Prev1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254662,Freeze_Frame_Dataset_Fct_09_Evt_Prev2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254663,Freeze_Frame_Dataset_Fct_09_Evt_Prev3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139729,Freeze_Frame_Dataset_Fct_10_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254664,Freeze_Frame_Dataset_Fct_10_Evt_Prev1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254665,Freeze_Frame_Dataset_Fct_10_Evt_Prev2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254666,Freeze_Frame_Dataset_Fct_10_Evt_Prev3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254686,Freeze_Frame_Fct_01_Cnt,39,
ENG254687,Freeze_Frame_Fct_02_Cnt,0,
ENG254688,Freeze_Frame_Fct_03_Cnt,3,
ENG254689,Freeze_Frame_Fct_04_Cnt,1,
ENG254690,Freeze_Frame_Fct_05_Cnt,0,
ENG254691,Freeze_Frame_Fct_06_Cnt,0,
ENG254692,Freeze_Frame_Fct_07_Cnt,1,
ENG254693,Freeze_Frame_Fct_08_Cnt,0,
ENG254694,Freeze_Frame_Fct_09_Cnt,0,
ENG139751,Freeze_Frame_Fct_10_Cnt,0,
ENG139752,Freeze_Frame_Fct_11_Cnt,5,
ENG139753,Freeze_Frame_Fct_12_Cnt,31,
ENG139754,Freeze_Frame_Fct_13_Cnt,3,
ENG139755,Freeze_Frame_Fct_14_Cnt,0,
ENG139756,Freeze_Frame_Fct_15_Cnt,0,
ENG139757,Freeze_Frame_Fct_16_Cnt,0,
ENG139758,Freeze_Frame_Fct_17_Cnt,0,
ENG254695,Freeze_Frame_Fct_18_Cnt,0,
ENG254696,Freeze_Frame_Fct_19_Cnt,0,
ENG254697,Freeze_Frame_Fct_20_Cnt,0,
ENG254698,Freeze_Frame_Fct_21_Cnt,0,
ENG254699,Freeze_Frame_Fct_22_Cnt,0,
ENG254700,Freeze_Frame_Fct_23_Cnt,0,
ENG254701,Freeze_Frame_Fct_24_Cnt,0,
ENG254702,Freeze_Frame_Fct_25_Cnt,0,
ENG254703,Freeze_Frame_Indikator_Temp_Cnt_01,0,
ENG254703,Freeze_Frame_Indikator_Temp_Cnt_01,3,
ENG254703,Freeze_Frame_Indikator_Temp_Cnt_01,1,
ENG254704,Freeze_Frame_Indikator_Temp_Cnt_02,0,
ENG254704,Freeze_Frame_Indikator_Temp_Cnt_02,32,
ENG254704,Freeze_Frame_Indikator_Temp_Cnt_02,1,
ENG254704,Freeze_Frame_Indikator_Temp_Cnt_02,21,
ENG254705,Freeze_Frame_Indikator_Temp_Cnt_03,32,
ENG254705,Freeze_Frame_Indikator_Temp_Cnt_03,11901,
ENG254705,Freeze_Frame_Indikator_Temp_Cnt_03,1301,
ENG254705,Freeze_Frame_Indikator_Temp_Cnt_03,3415,
ENG254705,Freeze_Frame_Indikator_Temp_Cnt_03,607,
ENG254705,Freeze_Frame_Indikator_Temp_Cnt_03,3783,
ENG254706,Freeze_Frame_Indikator_Temp_Cnt_04,613,
ENG254706,Freeze_Frame_Indikator_Temp_Cnt_04,58,
ENG254706,Freeze_Frame_Indikator_Temp_Cnt_04,4,
ENG254706,Freeze_Frame_Indikator_Temp_Cnt_04,5,
ENG254706,Freeze_Frame_Indikator_Temp_Cnt_04,324,
ENG254706,Freeze_Frame_Indikator_Temp_Cnt_04,146,
ENG254707,Freeze_Frame_Indikator_Temp_Cnt_05,0,
ENG254708,Freeze_Frame_Indikator_Temp_Cnt_06,0,
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,537, s
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,542396, s
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,138077, s
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,182, s
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,134, s
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,1146, s
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,1747, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,489, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,1169, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,450297, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,4751, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,579, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,771, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,1909, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,26333, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,335564, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,15945, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,20031, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,13368, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,16457, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,269214, s
ENG254712,Freeze_Frame_Indikator_Time_Cnt_04,1419, s
ENG254712,Freeze_Frame_Indikator_Time_Cnt_04,1725, s
ENG254712,Freeze_Frame_Indikator_Time_Cnt_04,1017, s
ENG254712,Freeze_Frame_Indikator_Time_Cnt_04,1060, s
ENG254712,Freeze_Frame_Indikator_Time_Cnt_04,686663, s
ENG254712,Freeze_Frame_Indikator_Time_Cnt_04,4014, s
ENG254712,Freeze_Frame_Indikator_Time_Cnt_04,1014, s
ENG254713,Freeze_Frame_Indikator_Time_Cnt_05,0, s
ENG254714,Freeze_Frame_Indikator_Time_Cnt_06,0, s
ENG254715,Freeze_Frame_Sensor_Blind_decision,3,
ENG254715,Freeze_Frame_Sensor_Blind_decision,0,
ENG254716,Freeze_Frame_Sensor_Blind_decision_Time,692933, s
ENG254716,Freeze_Frame_Sensor_Blind_decision_Time,0, s
ENG254716,Freeze_Frame_Sensor_Blind_decision_Time,3980, s
ENG254718-MAS17521,Function_On_Demand_Unlock_ID_Status_Dev-Unlockable functions: activation status,|ID number,Release code for a SWaP function
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,10,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG139759-ENG98375,Supplier_sw_block_version-Application,30 35 37 36,
ENG139759-ENG140150,Supplier_sw_block_version-Bootloader,30 35 37 31,
ENG139832,Sw_version_supplier,EV_FRONTRADARBOSCHVW38000502400{¯Ø=05765WA907567  SysC_37w_MOPF_0576_RC1000,
Elapsed Time: 00:24
blockmap-15-5QS-959-655-S_WV2ZZZSK8SX116493-20260803-1936.CSV
;SW:5QS-959-655-S   HW:5QS-959-655-S ---  15: Airbags
;Component:AirbagVW50    004 0131, Coding:88CC008000E0C000000000000000000091540000A1AA0000DC00F680002B00A7
;EV_AirbaVW50SMEVW49X,001014,EV_AirbaVW50SMEVW49X.rod
;Monday,03,August,2026,19:36:07:29755
;VCID: 73B3D9E44B326B22D29-8026 SFD+SFD2 { }
IDE00821-MAS01632,Seat belt switch 2nd row driver's side-Status,not installed,
IDE00821-MAS04136,Seat belt switch 2nd row driver's side-Current,no measured value present,
IDE00821-MAS05030,Seat belt switch 2nd row driver's side-Resistance,no measured value present,
IDE00822-MAS01632,Safety belt switch 2nd row frt.passenger side-Status,not installed,
IDE00822-MAS04136,Safety belt switch 2nd row frt.passenger side-Current,no measured value present,
IDE00822-MAS05030,Safety belt switch 2nd row frt.passenger side-Resistance,no measured value present,
IDE00823-MAS01632,Seat belt switch 2nd row center-Status,not installed,
IDE00823-MAS04136,Seat belt switch 2nd row center-Current,no measured value present,
IDE00823-MAS05030,Seat belt switch 2nd row center-Resistance,no measured value present,
IDE00824-MAS01632,Seat belt switch 3rd row driver's side-Status,not installed,
IDE00824-MAS04136,Seat belt switch 3rd row driver's side-Current,no measured value present,
IDE00824-MAS05030,Seat belt switch 3rd row driver's side-Resistance,no measured value present,
IDE00825-MAS01632,Passenger side 3rd row seat belt switch-Status,not installed,
IDE00825-MAS04136,Passenger side 3rd row seat belt switch-Current,no measured value present,
IDE00825-MAS05030,Passenger side 3rd row seat belt switch-Resistance,no measured value present,
IDE00826-MAS01632,Seat belt switch 3rd row center-Status,not installed,
IDE00826-MAS04136,Seat belt switch 3rd row center-Current,no measured value present,
IDE00826-MAS05030,Seat belt switch 3rd row center-Resistance,no measured value present,
IDE00947-MAS01632,Rear driver head curtain airbag igniter-Status,not installed,
IDE00947-MAS05030,Rear driver head curtain airbag igniter-Resistance,no measured value present,
IDE00948-MAS01632,Rear passenger head curtain airbag igniter-Status,not installed,
IDE00948-MAS05030,Rear passenger head curtain airbag igniter-Resistance,no measured value present,
IDE01097-MAS01167,Front passenger airbag -disabled- indicator lamp-Actuation time,Unknown (0)
IDE01097-MAS01168,Front passenger airbag -disabled- indicator lamp-Start parameter,OFF,
IDE01097-ENG102225,Front passenger airbag -disabled- indicator lamp-Input Output Control Parameter,---,
IDE01271-ENG297101,Number of rollover bar deployments-Number of activations airbag ecu,0,
IDE01271-ENG297107,Number of rollover bar deployments-Number of activations current rollbar actuator,0,
IDE01357-MAS01632,Left pedestrian protection igniter-Status,not installed,
IDE01357-MAS05030,Left pedestrian protection igniter-Resistance,no measured value present,
IDE01358-MAS01632,Right pedestrian protection igniter-Status,not installed,
IDE01358-MAS05030,Right pedestrian protection igniter-Resistance,no measured value present,
IDE01359-MAS01632,Front pedestrian protection trigger-Status,not installed,
IDE01359-MAS05030,Front pedestrian protection trigger-Resistance,no measured value present,
IDE01552-MAS01167,Activation of active head restraint-Actuation time,Unknown (0)
IDE01552-MAS01168,Activation of active head restraint-Start parameter,OFF,
IDE01552-ENG102225,Activation of active head restraint-Input Output Control Parameter,---,
IDE01555,Number of frontal crashes,1,
IDE01556,Number of side crashes driver side,1,
IDE01560-ENG297106,Number of activations of active head restraint-Number of activations airbag ecu driver side,0,
IDE01560-ENG297103,Number of activations of active head restraint-Number of activations airbag ecu passenger side,0,
IDE01560-ENG297104,Number of activations of active head restraint-Number of activations current headrest actuator driver side,0,
IDE01560-ENG297102,Number of activations of active head restraint-Number of activations current headrest actuator passenger side,0,
IDE02255,Malfunction text output,Unknown (255)
IDE02255-MAS01167,Malfunction text output-Actuation time,Unknown (0)
IDE02255-MAS01168,Malfunction text output-Start parameter,OFF,
IDE02255-ENG102225,Malfunction text output-Input Output Control Parameter,---,
IDE02256-MAS01167,Seat belt tensioner: activation-Actuation time,Unknown (0)
IDE02256-MAS01168,Seat belt tensioner: activation-Start parameter,OFF,
IDE02256-MAS01340,Seat belt tensioner: activation-Functions,Unknown (255)
IDE02256-MAS04150,Seat belt tensioner: activation-Side,Unknown (115)
IDE02256-ENG102225,Seat belt tensioner: activation-Input Output Control Parameter,---,
IDE02852-MAS01632,Battery Interrupt Igniter High-Voltage Battery-Status,not installed,
IDE02852-MAS05030,Battery Interrupt Igniter High-Voltage Battery-Resistance,no measured value present,
IDE03800-MAS01632,Driver airbag release valve igniter-Status,not installed,
IDE03800-MAS05030,Driver airbag release valve igniter-Resistance,no measured value present,
IDE03801-MAS01632,Frt.pass. airbag release valve igniter-Status,not installed,
IDE03801-MAS05030,Frt.pass. airbag release valve igniter-Resistance,no measured value present,
IDE05726-MAS09976,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'off': frt. pass. side,0.0, %
IDE05726-MAS09977,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'on': frt. pass. side,0.0, %
IDE05726-MAS09978,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'text': frt. pass. side,0.0, %
IDE06032-MAS01167,Vehicle conditioning-Actuation time,Unknown (0)
IDE06032-MAS01168,Vehicle conditioning-Start parameter,OFF,
IDE06032-MAS01340,Vehicle conditioning-Functions,Unknown (255)
IDE06032-ENG102225,Vehicle conditioning-Input Output Control Parameter,---,
IDE06034-MAS01632,Rollover protection trigger: driver side-Status,not installed,
IDE06034-MAS05030,Rollover protection trigger: driver side-Resistance,no measured value present,
IDE06035-MAS01632,Rollover protection trigger: front passenger side-Status,not installed,
IDE06035-MAS05030,Rollover protection trigger: front passenger side-Resistance,no measured value present,
IDE07190-MAS01632,Igniter for battery open circuit 2nd battery-Status,not installed,
IDE07190-MAS05030,Igniter for battery open circuit 2nd battery-Resistance,no measured value present,
IDE07192-MAS01632,Thorax airbag igniter-Status,not installed,
IDE07192-MAS05030,Thorax airbag igniter-Resistance,no measured value present,
IDE08436-MAS01632,Front driver side third row seat belt tensioner igniter-Status,not installed,
IDE08436-MAS05030,Front driver side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE08437-MAS01632,Front passenger side third row seat belt tensioner igniter-Status,not installed,
IDE08437-MAS05030,Front passenger side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE09598-MAS01167,Triggering crash shutoff: high voltage system (Bus signal)-Actuation time,Unknown (0)
IDE09598-MAS01168,Triggering crash shutoff: high voltage system (Bus signal)-Start parameter,OFF,
IDE09598-MAS05705,Triggering crash shutoff: high voltage system (Bus signal)-Shutdown request,Unknown (255)
IDE09598-ENG102225,Triggering crash shutoff: high voltage system (Bus signal)-Input Output Control Parameter,---,
IDE09599-IDE09624,Accident severity management-Crash severity,Unknown (255)
IDE09599-IDE09625,Accident severity management-Collision pos. - front drvr. side,not active,
IDE09599-IDE09626,Accident severity management-Collision pos. - front pass. side,not active,
IDE09599-IDE09627,Accident severity management-Collision pos. - side drvr. side,not active,
IDE09599-IDE09628,Accident severity management-Collision pos. - side frt. pass. side,not active,
IDE09599-IDE09629,Accident severity management-Collision pos. - rear of drvr. side,not active,
IDE09599-IDE09630,Accident severity management-Collision pos. - rear of frt. pass. side,not active,
IDE09599-IDE09631,Accident severity management-Collision position - rollover crash,not active,
IDE09599-IDE09632,Accident severity management-Collision pos. - pedestr. protect.,not active,
IDE09599-MAS01167,Accident severity management-Actuation time,Unknown (0)
IDE09599-MAS01168,Accident severity management-Start parameter,OFF,
IDE09599-ENG102225,Accident severity management-Input Output Control Parameter,---,
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,not installed,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,not installed,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,correct,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,2.4, Ohm
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12158-MAS01632,Front pedestrian protection trigger 2-Status,not installed,
IDE12158-MAS05030,Front pedestrian protection trigger 2-Resistance,no measured value present,
IDE12208-MAS01632,Igniter for deactivation of A/C system 1-Status,not installed,
IDE12208-MAS05030,Igniter for deactivation of A/C system 1-Resistance,no measured value present,
IDE12209-MAS01632,Igniter for deactivation of A/C system 2-Status,not installed,
IDE12209-MAS05030,Igniter for deactivation of A/C system 2-Resistance,no measured value present,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,0,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,0,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,0,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,0,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,0,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,0,
IDE12257-IDE14842,Extended belts witch diagnostic-Center seat belt switch,0,
IDE12257-IDE14843,Extended belts witch diagnostic-Seat belt switch: 4th row driver side,0,
IDE12257-IDE14844,Extended belts witch diagnostic-Seat belt switch: 4th row passenger side,0,
IDE12257-IDE14845,Extended belts witch diagnostic-Seat belt switch: 4th row center,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,5,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,0,
IDE12257-MAS00478,Extended belts witch diagnostic-Reserved,0,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,not installed,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,not connected,
IDE12257-MAS09326,Extended belts witch diagnostic-Function,not active,
IDE12257-MAS09326,Extended belts witch diagnostic-Function,active,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,no measured value present,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,no measured value present,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WV2ZZZSK8SX116493,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,5,
IDE14239-MAS01632,Igniter for high-voltage battery 2 open circuit-Status,not installed,
IDE14239-MAS05030,Igniter for high-voltage battery 2 open circuit-Resistance,no measured value present,
IDE14240-MAS01632,Driver side seat occupancy detection-Status,Not assigned,
IDE14240-MAS05030,Driver side seat occupancy detection-Resistance,404.0, Ohm
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3E 28 30 EA 48 2F 35,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,3,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 06,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14662-IDE13284,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row driver side,0,
IDE14662-IDE13586,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,0,
IDE14662-IDE14240,Expanded diagnosis of seat occupancy detection-Driver side seat occupancy detection,0,
IDE14662-IDE14240,Expanded diagnosis of seat occupancy detection-Driver side seat occupancy detection,5,
IDE14662-IDE14846,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: center,0,
IDE14662-IDE14847,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row driver side,0,
IDE14662-IDE14848,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,0,
IDE14662-IDE14849,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row center,0,
IDE14662-MAS00038,Expanded diagnosis of seat occupancy detection-Seat occupied recognition rear  driver side,0,
IDE14662-MAS00039,Expanded diagnosis of seat occupancy detection-Seat occupied recognition rear  passenger side,0,
IDE14662-MAS00040,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: center: rear,0,
IDE14662-MAS00231,Expanded diagnosis of seat occupancy detection-Seat occupant detection passenger side,0,
IDE14662-MAS00478,Expanded diagnosis of seat occupancy detection-Reserved,0,
IDE14662-MAS01632,Expanded diagnosis of seat occupancy detection-Status,not installed,
IDE14662-MAS01632,Expanded diagnosis of seat occupancy detection-Status,Not assigned,
IDE14662-MAS09326,Expanded diagnosis of seat occupancy detection-Function,not active,
IDE14662-MAS09326,Expanded diagnosis of seat occupancy detection-Function,active,
IDE14662-MAS18987,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: 3rd row center,0,
IDE14740-IDE13284,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row driver side,not installed,
IDE14740-IDE13586,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,not installed,
IDE14740-IDE14240,Wireless seat occupancy detection-Driver side seat occupancy detection,not installed,
IDE14740-IDE14846,Wireless seat occupancy detection-Seat occupancy detection: center,not installed,
IDE14740-IDE14847,Wireless seat occupancy detection-Seat-occupied recognition: 4th row driver side,not installed,
IDE14740-IDE14848,Wireless seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,not installed,
IDE14740-IDE14849,Wireless seat occupancy detection-Seat-occupied recognition: 4th row center,not installed,
IDE14740-MAS00038,Wireless seat occupancy detection-Seat occupied recognition rear  driver side,Not assigned,
IDE14740-MAS00039,Wireless seat occupancy detection-Seat occupied recognition rear  passenger side,Not assigned,
IDE14740-MAS00040,Wireless seat occupancy detection-Seat occupied recognition: center: rear,Not assigned,
IDE14740-MAS00231,Wireless seat occupancy detection-Seat occupant detection passenger side,not installed,
IDE14740-MAS18987,Wireless seat occupancy detection-Seat occupancy detection: 3rd row center,not installed,
IDE14741-IDE00821,Wireless belt buckle query-Seat belt switch 2nd row driver's side,not connected,
IDE14741-IDE00822,Wireless belt buckle query-Safety belt switch 2nd row frt.passenger side,not connected,
IDE14741-IDE00823,Wireless belt buckle query-Seat belt switch 2nd row center,not connected,
IDE14741-IDE00824,Wireless belt buckle query-Seat belt switch 3rd row driver's side,not installed,
IDE14741-IDE00825,Wireless belt buckle query-Passenger side 3rd row seat belt switch,not installed,
IDE14741-IDE00826,Wireless belt buckle query-Seat belt switch 3rd row center,not installed,
IDE14741-IDE14842,Wireless belt buckle query-Center seat belt switch,not installed,
IDE14741-IDE14843,Wireless belt buckle query-Seat belt switch: 4th row driver side,not installed,
IDE14741-IDE14844,Wireless belt buckle query-Seat belt switch: 4th row passenger side,not installed,
IDE14741-IDE14845,Wireless belt buckle query-Seat belt switch: 4th row center,not installed,
IDE14741-MAS00025,Wireless belt buckle query-Driver seat belt switch,not installed,
IDE14741-MAS00026,Wireless belt buckle query-Front passenger side safety belt switch,not installed,
IDE14841-MAS01632,Seat Belt Tensioner Igniter: center 3rd row-Status,not installed,
IDE14841-MAS05030,Seat Belt Tensioner Igniter: center 3rd row-Resistance,no measured value present,
IDE14842-MAS01632,Center seat belt switch-Status,not installed,
IDE14842-MAS04136,Center seat belt switch-Current,no measured value present,
IDE14842-MAS05030,Center seat belt switch-Resistance,no measured value present,
IDE14846-MAS01632,Seat occupancy detection: center-Status,not installed,
IDE14846-MAS05030,Seat occupancy detection: center-Resistance,no measured value present,
IDE15772-MAS14174,Wireless belt request/seat occupancy detection status-2nd Row Center,correct,
IDE15772-MAS20984,Wireless belt request/seat occupancy detection status-1st Row Driver Side,not configured,
IDE15772-MAS20985,Wireless belt request/seat occupancy detection status-1st Row Passenger Side,not configured,
IDE15772-MAS20986,Wireless belt request/seat occupancy detection status-1st Row Center,not configured,
IDE15772-MAS20987,Wireless belt request/seat occupancy detection status-3rd Row Center,not configured,
IDE15772-MAS20988,Wireless belt request/seat occupancy detection status-4th Row Center,not configured,
IDE15772-MAS20989,Wireless belt request/seat occupancy detection status-4th Row Passenger Side,not configured,
IDE15772-MAS20990,Wireless belt request/seat occupancy detection status-3rd Row Passenger Side,not configured,
IDE15772-MAS20991,Wireless belt request/seat occupancy detection status-2nd Row Passenger Side,correct,
IDE15772-MAS20992,Wireless belt request/seat occupancy detection status-2nd Row Driver Side,correct,
IDE15772-MAS20993,Wireless belt request/seat occupancy detection status-3rd Row Driver Side,not configured,
IDE15772-MAS20994,Wireless belt request/seat occupancy detection status-4th Row Driver Side,not configured,
IDE15776-MAS01632,Deactivation igniter: DC/DC converter-Status,not installed,
IDE15776-MAS05030,Deactivation igniter: DC/DC converter-Resistance,no measured value present,
IDE16063-MAS01632,Igniter for high-voltage battery 3 open circuit-Status,not installed,
IDE16063-MAS05030,Igniter for high-voltage battery 3 open circuit-Resistance,no measured value present,
IDE16064-MAS01632,Driver Head Curtain Airbag Igniter 2-Status,not installed,
IDE16064-MAS05030,Driver Head Curtain Airbag Igniter 2-Resistance,no measured value present,
IDE16065-MAS01632,Front Passenger Head Curtain Airbag Igniter 2-Status,not installed,
IDE16065-MAS05030,Front Passenger Head Curtain Airbag Igniter 2-Resistance,no measured value present,
IDE16304-IDE02241,Inertial sensor system-Lateral acceleration sensor 1,0.1, m/s²
IDE16304-IDE02245,Inertial sensor system-Lateral acceleration sensor 2,0.0, m/s²
IDE16304-IDE02538,Inertial sensor system-Longitude Acceleration Sensor,-0.1, m/s²
IDE16304-IDE02546,Inertial sensor system-Roll rate sensor,0.0, °/s
IDE16304-IDE02549,Inertial sensor system-Pitch rate sensor,0.0, °/s
IDE16304-IDE02552,Inertial sensor system-Yaw rate sensor,-0.0, °/s
IDE16304-IDE02555,Inertial sensor system-Yaw rate sensor 2,0.0, °/s
IDE16304-IDE16337,Inertial sensor system-Longitudinal Acceleration Sensor 2,-163.8, m/s²
IDE16304-MAS04460,Inertial sensor system-Validity,Not installed due to specific system,
IDE16304-MAS04460,Inertial sensor system-Validity,OK,
IDE16304-MAS22296,Inertial sensor system-Vertical Motion Sensor,0.0, m/s²
IDE16304-MAS22298,Inertial sensor system-Vertical Motion Sensor 2,0.0, m/s²
IDE17275-MAS01632,Igniter for deactivation of A/C system 3-Status,not installed,
IDE17275-MAS05030,Igniter for deactivation of A/C system 3-Resistance,no measured value present,
MAS00001-MAS01632,Driver airbag igniter-Status,correct,
MAS00001-MAS05030,Driver airbag igniter-Resistance,3.0, Ohm
MAS00002-MAS01632,Driver's Airbag Igniter 2-Status,not installed,
MAS00002-MAS05030,Driver's Airbag Igniter 2-Resistance,no measured value present,
MAS00003-MAS01632,Front passenger front airbag igniter-Status,correct,
MAS00003-MAS05030,Front passenger front airbag igniter-Resistance,2.1, Ohm
MAS00004-MAS01632,Front passenger airbag igniter 2-Status,not installed,
MAS00004-MAS05030,Front passenger airbag igniter 2-Resistance,no measured value present,
MAS00005-MAS01632,Driver thorax airbag igniter-Status,correct,
MAS00005-MAS05030,Driver thorax airbag igniter-Resistance,2.5, Ohm
MAS00006-MAS01632,Front passenger thorax airbag igniter-Status,correct,
MAS00006-MAS05030,Front passenger thorax airbag igniter-Resistance,2.5, Ohm
MAS00007-MAS01632,Driver side rear thorax airbag igniter-Status,not installed,
MAS00007-MAS05030,Driver side rear thorax airbag igniter-Resistance,no measured value present,
MAS00008-MAS01632,Passenger side rear thorax airbag igniter-Status,not installed,
MAS00008-MAS05030,Passenger side rear thorax airbag igniter-Resistance,no measured value present,
MAS00009-MAS01632,Driver head curtain airbag igniter-Status,correct,
MAS00009-MAS05030,Driver head curtain airbag igniter-Resistance,2.4, Ohm
MAS00010-MAS01632,Front passenger head curtain airbag igniter-Status,correct,
MAS00010-MAS05030,Front passenger head curtain airbag igniter-Resistance,2.4, Ohm
MAS00011-MAS01632,Driver knee airbag igniter-Status,not installed,
MAS00011-MAS05030,Driver knee airbag igniter-Resistance,no measured value present,
MAS00012-MAS01632,Front passenger knee airbag igniter-Status,not installed,
MAS00012-MAS05030,Front passenger knee airbag igniter-Resistance,no measured value present,
MAS00013-MAS01632,Driver seat belt tension igniter-Status,correct,
MAS00013-MAS05030,Driver seat belt tension igniter-Resistance,2.4, Ohm
MAS00014-MAS01632,Front passenger seat belt tensioner igniter-Status,correct,
MAS00014-MAS05030,Front passenger seat belt tensioner igniter-Resistance,2.3, Ohm
MAS00015-MAS01632,Driver seat belt tensioner igniter 2-Status,correct,
MAS00015-MAS05030,Driver seat belt tensioner igniter 2-Resistance,2.5, Ohm
MAS00016-MAS01632,Front passenger seat belt tensioner igniter 2-Status,not installed,
MAS00016-MAS05030,Front passenger seat belt tensioner igniter 2-Resistance,no measured value present,
MAS00017-MAS01632,Igniter for Driver Belt Force Limiter-Status,not installed,
MAS00017-MAS05030,Igniter for Driver Belt Force Limiter-Resistance,no measured value present,
MAS00018-MAS01632,Front passenger side belt force limiter igniter-Status,not installed,
MAS00018-MAS05030,Front passenger side belt force limiter igniter-Resistance,no measured value present,
MAS00019-MAS01632,Driver side rear safety belt tension igniter-Status,correct,
MAS00019-MAS05030,Driver side rear safety belt tension igniter-Resistance,2.6, Ohm
MAS00020-MAS01632,Passenger side rear seat belt tensioner igniter-Status,correct,
MAS00020-MAS05030,Passenger side rear seat belt tensioner igniter-Resistance,2.5, Ohm
MAS00021-MAS01632,Center rear seat belt tensioner igniter-Status,not installed,
MAS00021-MAS05030,Center rear seat belt tensioner igniter-Resistance,no measured value present,
MAS00022-MAS01632,Battery Interrupt Igniter-Status,not installed,
MAS00022-MAS05030,Battery Interrupt Igniter-Resistance,no measured value present,
MAS00023-MAS01632,Driver active head restraint igniter/trigger-Status,not installed,
MAS00023-MAS05030,Driver active head restraint igniter/trigger-Resistance,no measured value present,
MAS00024-MAS01632,Front passenger active head restraint igniter/trigger-Status,not installed,
MAS00024-MAS05030,Front passenger active head restraint igniter/trigger-Resistance,no measured value present,
MAS00025-MAS01632,Driver seat belt switch-Status,not connected,
MAS00025-MAS04136,Driver seat belt switch-Current,no measured value present,
MAS00025-MAS05030,Driver seat belt switch-Resistance,404.0, Ohm
MAS00026-MAS01632,Front passenger side safety belt switch-Status,not connected,
MAS00026-MAS04136,Front passenger side safety belt switch-Current,no measured value present,
MAS00026-MAS05030,Front passenger side safety belt switch-Resistance,0.0, Ohm
MAS00031,Airbag deactivation status,On,
MAS00032-MAS01632,Key switch terminal 1-Status,On,
MAS00032-MAS05030,Key switch terminal 1-Resistance,700.0, Ohm
MAS00033-MAS01632,Key switch terminal 2-Status,On,
MAS00033-MAS05030,Key switch terminal 2-Resistance,1480.0, Ohm
MAS00035-MAS01632,Seat position sensor: driver side-Status,not installed,
MAS00035-MAS04136,Seat position sensor: driver side-Current,no measured value present,
MAS00036-MAS01632,Seat position sensor: front passenger side-Status,not installed,
MAS00036-MAS04136,Seat position sensor: front passenger side-Current,no measured value present,
MAS00038-MAS01632,Seat occupied recognition rear  driver side-Status,not installed,
MAS00038-MAS05030,Seat occupied recognition rear  driver side-Resistance,no measured value present,
MAS00039-MAS01632,Seat occupied recognition rear  passenger side-Status,not installed,
MAS00039-MAS05030,Seat occupied recognition rear  passenger side-Resistance,no measured value present,
MAS00040-MAS01632,Seat occupied recognition: center: rear-Status,not installed,
MAS00040-MAS05030,Seat occupied recognition: center: rear-Resistance,no measured value present,
MAS00082-MAS01167,Rollover bar deployment-Actuation time,Unknown (0)
MAS00082-MAS01168,Rollover bar deployment-Start parameter,OFF,
MAS00082-ENG102225,Rollover bar deployment-Input Output Control Parameter,---,
MAS00083-IDE05251,Deploying crash signal-Crash direction,Unknown (255)
MAS00083-IDE05258,Deploying crash signal-Crash intensity,Unknown (255)
MAS00083-MAS01167,Deploying crash signal-Actuation time,Unknown (0)
MAS00083-MAS01168,Deploying crash signal-Start parameter,OFF,
MAS00083-ENG102225,Deploying crash signal-Input Output Control Parameter,---,
MAS00231-MAS01632,Seat occupant detection passenger side-Status,Not assigned,
MAS00231-MAS05030,Seat occupant detection passenger side-Resistance,412.0, Ohm
MAS01634-IDE00020,Supply voltage-Terminal 15 status,On,
MAS01634-IDE00773,Supply voltage-Terminal 15 status via CAN,On,
MAS01634-IDE02537,Supply voltage-Terminal 30 status,correct,
MAS01634-MAS06489,Supply voltage-Terminal 15 signal,13.4, V
MAS01634-MAS06982,Supply voltage-Terminal 15 status signal,On,
MAS01634-MAS15175,Supply voltage-Terminal 30,13.6, V
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,35 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
MAS18987-MAS01632,Seat occupancy detection: 3rd row center-Status,not installed,
MAS18987-MAS05030,Seat occupancy detection: 3rd row center-Resistance,no measured value present,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS29851-MAS01632,Igniter for seat ramp airbag 2nd row: passenger's side-Status,not installed,
MAS29851-MAS05030,Igniter for seat ramp airbag 2nd row: passenger's side-Resistance,no measured value present,
MAS29852-MAS01632,Igniter for seat ramp airbag 2nd row: driver's side-Status,not installed,
MAS29852-MAS05030,Igniter for seat ramp airbag 2nd row: driver's side-Resistance,no measured value present,
Elapsed Time: 00:22
blockmap-17-2K7-920-310-A_WV2ZZZSK8SX116493-20260803-1919.CSV
;SW:2K7-920-310-A   HW:2K7-920-310 ---  17: Instruments
;Component:KOMBI         320 2642, Coding:04A405076384000801802203000000080020180800
;EV_DashBoardVISMQB37W,005002,EV_DashBoardVISMQB37W_005_VN3S.rod
;Monday,03,August,2026,19:19:03:29755
;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0
;VCID: 2411EAB8BE5CBC9A9B3-8070 SFD { }
Group,Description,Actual
IDE00019,Voltage terminal 30,13.6, V
IDE00021,Engine speed,981.000, /min
IDE00025,Coolant temperature,90.00, °C
IDE00196,Engine oil temperature,89, °C
IDE00310,Outside temperature,36.0, °C
IDE00316-IDE00500,Time-Hour,19, H
IDE00316-IDE00501,Time-Minute,18, min
IDE00316-MAS00111,Time-Seconds,33, s
IDE00317-IDE00502,Date-Year,2026, yr
IDE00317-IDE00503,Date-Month,8, Months
IDE00317-IDE00504,Date-Day,3, d
IDE00706,Fuel level gasoline,101.6, %
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2004, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2084, mm
IDE01076,Time since ignition off,66, s
IDE01985-MAS06855,FAZIT identification test sum-Test sum,81 3F 1E C2,
IDE02307,Parking brake status,Not available,
IDE02642,Outside temp.: displayed value,35.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,216,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,0,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,42,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,163,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane departure warning,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,17.7, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,34.9, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,34.9, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,18.1, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,3.3, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,32.5, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,32.5, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,3.7, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,8.6, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,24.6, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,25.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,8.0, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,7.2, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,51.2, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,51.4, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,7.4, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,116200, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,114200, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,111000, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,105500, km
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,183, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,289, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,4, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,4, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,32768, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,32768, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,09 71,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,09 15,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,0A D5,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,05 73,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,FF FF,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,FF FF,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,FF FF,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,FF FF,
IDE03474-IDE00304,Calculated volume-Fuel level,8.2, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,179, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,284, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,9.8, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,6553.5, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,6553.5, l
IDE03474-IDE00802,Calculated volume-Full volume,495.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,9.8, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-1.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-MAS18153,Calculated volume-Calculated volume unlimited: sensor 1,-3.0, l
IDE03474-MAS18154,Calculated volume-Calculated volume unlimited: sensor 2,-13.8, l
IDE03474-MAS18155,Calculated volume-Calculated volume unlimited: sensor 3,12.7, l
IDE03474-MAS18156,Calculated volume-Calculated volume unlimited: sensor 4,12.7, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.000000,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.000000,
IDE03474-ENG102894,Calculated volume-averaged_volume,9.8, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,9.8, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,9.8, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,0.000000,
IDE03474-ENG99553,Calculated volume-linking,0.00000000000000000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.0625, m/s²
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-12.0313, m/s²
IDE03474-ENG101623,Calculated volume-reference_volume,0.8, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.000000,
IDE03474-ENG99683,Calculated volume-version_of_application,80,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.00029182434082031250,
IDE03477-IDE00500,GPS time-Hour,17, H
IDE03477-IDE00501,GPS time-Minute,18, min
IDE03477-IDE00501,GPS time-Minute,17, min
IDE03477-IDE00502,GPS time-Year,2026, yr
IDE03477-IDE00503,GPS time-Month,8, Months
IDE03477-IDE00504,GPS time-Day,3, d
IDE03477-MAS00111,GPS time-Seconds,56, s
IDE03477-MAS00111,GPS time-Seconds,14, s
IDE03477-MAS03493,GPS time-last synchronization year,2026, yr
IDE03506,Distance: high resolution,00 B7 3E B1,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 26,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 06,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 06,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 26,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,4F F0 05 FA,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,0F F0 2E 7C,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,8F F0 2E 7C,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,CF F0 05 FA,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE06566-IDE00008,Key identification-Software version,S305,
IDE06566-IDE00016,Key identification-Hardware version,H22,
IDE06566-MAS04970,Key identification-Part Number,5G6959753DQ,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08238,Transponder ID current Key,54 9F EE C1,
IDE08343,Immobilizer Challenge,1F 80 E6 38,
IDE12972,Oil: theoretical service interval,13200, km
IDE12973,Oil: service interval exceeded in km,0, km
IDE12974,Oil service interval exceeded in days,0, d
IDE12975,Oil: remaining driving distance,14890, km
IDE12976,Oil: remaining running time,359, d
IDE12977-MAS07266,Oil status-Oil change: unit of dist. travelled,Unknown (2)
IDE12977-MAS07267,Oil status-Oil change: dist. travelled,14600,
IDE12977-MAS07268,Oil status-Oil change: stat. of dist. travelled,Function not available,
IDE12977-MAS07269,Oil status-Oil change: stat. of time,Unknown (5)
IDE12977-MAS07270,Oil status-Inspection: stat. of dist. travelled,Unknown (7)
IDE12977-MAS07271,Oil status-Inspection: unit of distance traveled,miles,
IDE12977-MAS07272,Oil status-Inspection: dist. travelled,4300,
IDE12977-MAS07273,Oil status-Inspection: time,724, d
IDE12977-MAS07274,Oil status-Oil change warning,no warning,
IDE12977-MAS07277,Oil status-Inspections warning,no warning,
IDE12977-MAS07305,Oil status-Oil change: time,354, d
IDE12977-MAS07308,Oil status-Inspection: status time,Service in,
IDE12977-MAS10768,Oil status-Daily mileage,0,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,10,
IDE13845,Production mode status,not active,
IDE14015,Lock set part number,32 4B 37 38 30 30 33 37 35 43 4B,
IDE14016,Transponder type,00 33,
IDE14124-IDE03840,Gong status-Volume of actuator test,0, %
IDE14124-MAS01167,Gong status-Actuation time,Without time limit,
IDE14124-MAS05781,Gong status-Acoustics,all_acoustics,
IDE14124-ENG261531,Gong status-IO Reached Status,Output diagnostic test not active,
IDE14129-IDE04290,Segment test status-Color code,White,
IDE14129-MAS01167,Segment test status-Actuation time,Without time limit,
IDE14129-ENG261531,Segment test status-IO Reached Status,Output diagnostic test not active,
IDE14130-MAS01167,Test image in center display status-Actuation time,Without time limit,
IDE14130-MAS01168,Test image in center display status-Start parameter,Unknown (0)
IDE14130-ENG261531,Test image in center display status-IO Reached Status,Output diagnostic test not active,
IDE14132-MAS01167,Indicator lamp status-Actuation time,Without time limit,
IDE14132-MAS01168,Indicator lamp status-Start parameter,00 00 00,
IDE14132-ENG261531,Indicator lamp status-IO Reached Status,Output diagnostic test not active,
IDE14185-IDE00301,Gas systems test-Distance,0, km
IDE14185-IDE00502,Gas systems test-Year,0, yr
IDE14185-IDE00503,Gas systems test-Month,0, Months
IDE14185-IDE00504,Gas systems test-Day,0, d
IDE14185-MAS17869,Gas systems test-Time since last reset,0,
IDE14185-MAS17870,Gas systems test-Number of resets,0,
IDE14212-ENG103300,Service Key Master daily data-Service_Data,5E AF 01 25 29 C0 1A 08 03 13 0F 22 E9 2E 00 00 95 10 67 11 2B 11 D4 12 07 DF 01 A1 73 A3 11 A4 0E A5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 1C 25 00 00 40 07,
IDE14213-ENG103300,Service Key Master current data-Service_Data,F1 D3 01 25 29 D0 1A 08 03 13 12 18 E9 2E 00 00 95 10 67 11 2B 11 D4 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 1C 25 00 00 40 06,
IDE14214-ENG263244,Service Key Master write counter-Counter_current_clamp_15,1,
IDE14214-ENG263245,Service Key Master write counter-Counter_current_total,2460,
IDE14214-ENG263246,Service Key Master write counter-Counter_daily_clamp_15,0,
IDE14214-ENG263247,Service Key Master write counter-Counter_daily_total,1519,
IDE14214-ENG119822,Service Key Master write counter-Error_Counter,1519,
IDE14214-ENG263298,Service Key Master write counter-state_current,Wait_Trigger,
IDE14214-ENG263299,Service Key Master write counter-State_daily,Wait_Trigger,
IDE14214-ENG263221,Service Key Master write counter-transponder_id,1419767489,
IDE14214-ENG263220,Service Key Master write counter-Transponder_type,51,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,2026, yr
IDE14236-MAS00107,Authentic time: last confirmed time-Month,8, Months
IDE14236-MAS00108,Authentic time: last confirmed time-Day,3, d
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,17, H
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,17, min
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,3, s
IDE14236-MAS03617,Authentic time: last confirmed time-Time zone,6, H
IDE14237-MAS00106,Authentic time: actual time-Year,56, H
IDE14237-MAS00107,Authentic time: actual time-Month,8, Months
IDE14237-MAS00108,Authentic time: actual time-Day,3, d
IDE14237-MAS00109,Authentic time: actual time-Hours,17, H
IDE14237-MAS00110,Authentic time: actual time-Minutes,19, min
IDE14237-MAS00111,Authentic time: actual time-Seconds,1, s
IDE14237-MAS03617,Authentic time: actual time-Time zone,6, H
IDE14334,Authentic time: number of maximum deviation exceeded,00 0A,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 7D,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3E 28 30 EA 48 07 36,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,8,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 04,
IDE15081,Authentic time: status of distribution signal trigger,1,
MAS00902-ENG99140,Extended Service Intervals (ESI)-advance_warning_fixed_days,not active,
MAS00902-ENG100265,Extended Service Intervals (ESI)-advance_warning_fixed_km,not active,
MAS00902-ENG101600,Extended Service Intervals (ESI)-advance_warning_WIV_days,not active,
MAS00902-ENG102887,Extended Service Intervals (ESI)-advance_warning_WIV_km,not active,
MAS00902-ENG99971,Extended Service Intervals (ESI)-in_calculation,active,
MAS00902-ENG101015,Extended Service Intervals (ESI)-no_calculation_available,not active,
MAS00902-ENG101477,Extended Service Intervals (ESI)-service_warning_fixed_days,not active,
MAS00902-ENG101550,Extended Service Intervals (ESI)-service_warning_fixed_km,not active,
MAS00902-ENG101709,Extended Service Intervals (ESI)-service_warning_WIV_days,not active,
MAS00902-ENG102993,Extended Service Intervals (ESI)-service_warning_WIV_km,not active,
MAS10768,Daily mileage,35, km
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,54 minutes,
MAS26570-ENG334268,Distance of safety error-mileage_error_security_AR2_value,00 00,
MAS27747-MAS00106,Distance data with onboard supply control unit and electronic stabilization program information-Year,2106,
MAS27747-MAS00107,Distance data with onboard supply control unit and electronic stabilization program information-Month,3,
MAS27747-MAS00108,Distance data with onboard supply control unit and electronic stabilization program information-Day,9,
MAS27747-MAS00109,Distance data with onboard supply control unit and electronic stabilization program information-Hours,0,
MAS27747-MAS00110,Distance data with onboard supply control unit and electronic stabilization program information-Minutes,0,
MAS27747-MAS00111,Distance data with onboard supply control unit and electronic stabilization program information-Seconds,14,
MAS27747-MAS27735,Distance data with onboard supply control unit and electronic stabilization program information-ESC distance pulses,00 00 00 00 1E B4 F2 A0,
MAS27747-MAS27749,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: number of jumps,1,
MAS27747-MAS27750,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: largest positive jump,0,
MAS27747-MAS27751,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: largest negative jump,10400,
MAS27747-MAS27752,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: total jumps,00 00 00 00 00 00 28 A0,
MAS27747-MAS27753,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: jump balance,-10400, m
MAS27747-MAS27754,Distance data with onboard supply control unit and electronic stabilization program information-Electronic stabilization program communication failures: number,9,
MAS27747-MAS27755,Distance data with onboard supply control unit and electronic stabilization program information-Electronic stabilization program communication failures: total duration,1399, s
MAS27747-MAS27756,Distance data with onboard supply control unit and electronic stabilization program information-Longest electronic stabilization program communication failure,1, min
MAS27747-MAS27757,Distance data with onboard supply control unit and electronic stabilization program information-Longest onboard supply control unit communication failure,1, min
MAS27747-MAS27758,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit communication failures: total duration,0, s
MAS27747-MAS27759,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: number of jumps,21,
MAS27747-MAS27760,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: jump balance,-23, m
MAS27747-MAS27761,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: total jumps,23, m
MAS27747-MAS27762,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: largest negative jump,2, m
MAS27747-MAS27763,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: largest positive jump,0, m
MAS27747-MAS27764,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit communication failures: number,9,
MAS27747-MAS27765,Distance data with onboard supply control unit and electronic stabilization program information-Total distance: status,12004, km
ENG186121,Authentic_time_current_counter_kl15_since_last_sync,0,
ENG262946,Authentic_time_last_backend_response,eyJhbGciOiJFUzI1NiIsImN0eSI6Im5vbmUiLCJraWQiOiJWV0dfRUtNRi1BLVBSRC1CQy1BVVRJTUUtR0xPQkFMLVZXMzhYLTIwMTctMDAxIiwidHMiOiIyMDI2LTA4LTAzVDE3OjE3OjAzWiIsImNobCI6IlRFZFZiMmZkTXlsMHF2a3JsVGd6bXcifQ..qmL-v_23CQNqaAo_oDDpnvoDMRGgwmtEwP-kbGrkvhEPu5wQceTEBPj1gxdNMNgqC0hj8ffDoFXasJnkefB3WQ,
ENG186123,Authentic_time_last_client_response,2026-08-03T17:17:03Z,
ENG186123,Authentic_time_last_client_response,0,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,0, %
ENG105830-ENG100577,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_day,0, %
ENG105830-ENG263248,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_night,0,
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,0, %
ENG105830-ENG263249,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_blue,0, %
ENG105830-ENG263250,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_green,100, %
ENG105830-ENG263251,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_red,100, %
ENG105830-ENG263252,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_yellow,100, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,59, %
ENG105830-ENG261530,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_internal characteristic_phototransistor,250,
ENG99439,Instrument_recorder,63 67 FF FF 7C 50 4F 52 3A 1B 7C 20 7C 20 7C 20 7C 54 4C 3A 2E 3E 1E 3E 03 3E 00 3E 0A 7C 56 4C 3A 32 36 34 32,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,170,
ENG119884-ENG119837,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0,0, d
ENG119884-ENG119867,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1,0, d
ENG119884-ENG119868,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2,0, d
ENG119884-ENG119870,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0,0, Months
ENG119884-ENG119836,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1,0, Months
ENG119884-ENG119850,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2,0, Months
ENG119884-ENG119869,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0,2000, yr
ENG119884-ENG119835,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1,2000, yr
ENG119884-ENG119845,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2,2000, yr
ENG119884-ENG119834,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0,0,
ENG119884-ENG119839,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1,0,
ENG119884-ENG119840,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2,0,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,Bank_1,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,0,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,0,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,0,
Elapsed Time: 00:17
blockmap-19-5QS-907-530-B_WV2ZZZSK8SX116493-20260803-1920.CSV
;SW:5QS-907-530-B   HW:5QS-907-530 ---  19: CAN Gateway
;Component:GW MQB 23     005 3093, Coding:000000000000000000000000000000000000000000000000030000000000000000000000000000000000000000000000
;EV_GatewMQBwBL,001018,EV_GatewMQBwBL_VW41.rod
;Monday,03,August,2026,19:20:00:29755
;VCID: 53F37964AB720B22329-8006 SFD+SFD2 { }
IDE00019,Voltage terminal 30,13.8, V
IDE00056,History data 1,73 06 1C 03 08 7E 00 01 00 00 00,
IDE00056,History data 1,72 15 0A 02 08 7E 00 00 00 01 00 00 00,
IDE00056,History data 1,00 00 00 00 00 00 00 00 00 00 00,
IDE00056,History data 1,74 06 35 03 08 7E 00 02 00 00 00,
IDE00056,History data 1,03 14 08 02 07 7E 00 01 00 00 00,
IDE00056,History data 1,00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00056,History data 1,7B 0A 05 03 08 7E 00 00 00 74 0C 00 00,
IDE00056,History data 1,70 12 2A 02 08 7E 00 00 00 00 00,
IDE00057,History data 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00057,History data 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00059,History data 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00059,History data 4,03 00 00 01 01 00 00 46 45 41 42 31 35 30 35 32 36 51 56 51 57 09 11 7E 00 00 0D 00 00 00 00 00 00 00,
IDE00060,History data 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00061,History data 6,81 13 11 03 08 1A 01 04 00 00 40 4E 4E 58 59 AA 00 00 94 01 80 00,
IDE00061,History data 6,7F 12 0C 03 08 1A 01 26 0B 00 44 4B 4E 55 58 AA 00 00 94 01 80 00,
IDE00061,History data 6,7B 09 37 03 08 1A 00 03 00 00 44 3A 39 49 49 90 00 00 94 01 80 00,
IDE00061,History data 6,7D 0B 09 03 08 1A 00 0E 02 00 44 40 41 4C 4C A4 00 00 94 01 80 00,
IDE00061,History data 6,77 08 0A 03 08 1A 01 0C 01 00 44 3C 3D 46 46 90 00 00 94 03 80 00,
IDE00061,History data 6,78 08 1D 03 08 1A 01 03 00 00 44 3E 3D 46 46 90 00 00 94 01 80 00,
IDE00061,History data 6,80 13 10 03 08 1A 00 01 00 00 44 4E 4E 58 58 AA 00 00 94 01 80 00,
IDE00061,History data 6,7C 0A 0D 03 08 1A 03 75 08 00 44 37 41 49 4C 90 02 00 94 01 80 00,
IDE00061,History data 6,7E 12 03 03 08 1A 01 09 01 00 44 4A 4B 55 55 B0 00 00 94 01 80 00,
IDE00061,History data 6,76 07 34 03 08 1A 01 51 03 00 40 35 3C 44 46 8A 00 00 94 01 80 00,
IDE00062,History data 7,7F 12 0B 03 08 1A 02 00 00 00 00 4B 18 00 00 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00062,History data 7,81 13 10 03 08 1A 04 00 01 00 00 4E 19 00 00 58 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00062,History data 7,76 08 0A 03 08 1A 00 00 00 00 00 3C 11 00 00 46 00 00 00 06 00 01 00 00 00 00 20 00 00 00 00 00 00 00,
IDE00062,History data 7,7F 13 0F 03 08 1A 01 00 01 00 00 4E 1C 00 00 58 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00062,History data 7,78 08 1D 03 08 1A 4D 00 53 00 00 39 11 00 00 49 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00062,History data 7,7B 09 37 03 08 1A 05 00 10 00 00 37 11 00 00 49 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00062,History data 7,7C 0B 03 03 08 1A 06 00 06 00 00 3F 15 00 00 4C 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00,
IDE00062,History data 7,7D 0B 17 03 08 1A 0E 00 8C 01 00 4A 1B 00 00 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00062,History data 7,75 07 21 03 08 1A 05 00 12 00 00 35 0F 00 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00062,History data 7,77 08 10 03 08 1A 05 00 0C 00 00 3D 14 00 00 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00063,History data 8,7F 13 0F 03 08 1A 00 01 00 01 00 00 4E 5A 26 F5 FF FF 78 01,
IDE00063,History data 8,80 13 10 03 08 1A 00 01 00 01 00 00 4E 5B 03 0C 00 00 78 01,
IDE00063,History data 8,7D 00 00 01 01 00 00 01 00 01 00 00 4A 54 37 F1 FF FF 78 00,
IDE00064,History data 9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00065,History data 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00066,History data 11,7F 12 0C 03 08 1A AD 0D 00 00 00 00 00 00 00 00 00 80 30 01 00 00 30 01 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00066,History data 11,7E 12 03 03 08 1A 16 00 00 00 00 00 00 00 00 00 00 80 D1 01 00 00 D1 01 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00066,History data 11,81 13 11 03 08 1A 6B 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00066,History data 11,74 00 85 00 2E 01 01 00 0D 00 00 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00066,History data 11,7D 0B 09 03 08 1A 60 02 00 00 00 00 C4 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00066,History data 11,80 13 10 03 08 1A 22 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00067,History data 12,00 00 00 00 00 00 00 00 00,
IDE00067,History data 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00067,History data 12,7E 12 03 03 08 1A 01 4A 55 19 B2 A4 FE FF 34 20 00 00 00 00 00,
IDE00067,History data 12,7D 0B 09 03 08 1A 01 40 4C 19 62 69 FD FF 64 1F 00 00 00 00 00,
IDE00067,History data 12,37 00 01 00 00 00 00 00,
IDE00067,History data 12,7C 0A 27 03 08 1A 01 3F 4B 19 70 A5 F9 FF 71 1A 00 00 00 00 00,
IDE00067,History data 12,7C 0A 27 03 08 1A 01 3F 4B 19 80 EB F8 FF 5A 1A 00 00 00 00 00,
IDE00067,History data 12,7C 0A 27 03 08 1A 01 3F 4B 19 A4 17 F9 FF E2 19 00 00 00 00 00,
IDE00068,History data 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00071,History data 16,E4 2E 00 00 00 01 00,
IDE00071,History data 16,00 00 00 00 00 00 00 00 00 00 00 00,
IDE00071,History data 16,15 00 06 00 06 00 06 00 08 00 03 00 03 00 04 00 02 00 04 00 00 00 00 00,
IDE00071,History data 16,2F 00 16 00 07 00 0D 00 00 00,
IDE00071,History data 16,00 00 00 00 00 00 00 00 23 00,
IDE00071,History data 16,63 00 22 00 0C 00 00 00,
IDE00071,History data 16,1E 00 16 00 31 00 03 00 00 00,
IDE00071,History data 16,00 00 00 00 00 00 00 00,
IDE00071,History data 16,5E 00 DD 00 32 01 07 00 00 00,
IDE00071,History data 16,00 00 00 00 02 00 57 00,
IDE00356,Cruise Control System (CCS): switch position,On,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,2,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,CCS Switch,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,11,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,42,
IDE00634,Vehicle electric system current,21, A
IDE00767-ENG280618,No. of unscheduled ECU resets-FCCU_RF_S0_Status,00 00 00 80,
IDE00767-ENG280619,No. of unscheduled ECU resets-FCCU_RF_S1_Status,00 00 00 00,
IDE00767-ENG280620,No. of unscheduled ECU resets-FCCU_RF_S2_Status,40 00 00 00,
IDE00767-ENG280621,No. of unscheduled ECU resets-FCCU_RF_S3_Status,00 01 80 00,
IDE00767-ENG136152,No. of unscheduled ECU resets-KL30_Reset_Counter,18,
IDE00767-ENG443419,No. of unscheduled ECU resets-MCU_Reset_Counter,1,
IDE00767-ENG280678,No. of unscheduled ECU resets-Reason_of_2th_last_reset,0,
IDE00767-ENG280679,No. of unscheduled ECU resets-Reason_of_3th_last_reset,0,
IDE00767-ENG280680,No. of unscheduled ECU resets-Reason_of_4th_last_reset,0,
IDE00767-ENG280681,No. of unscheduled ECU resets-Reason_of_5th_last_reset,0,
IDE00767-ENG280682,No. of unscheduled ECU resets-Reason_of_latest_reset,1,
IDE00767-ENG280768,No. of unscheduled ECU resets-Watchdog_Reset_Counter,0,
IDE01803,History data 17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE01803,History data 17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.0, H
IDE01807-MAS00106,History data 21-Year,2000,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,1,
IDE01807-MAS00109,History data 21-Hours,0, H
IDE01807-MAS00110,History data 21-Minutes,0, min
IDE01807-MAS14375,History data 21-Cycle counter,0,
IDE01807-MAS14376,History data 21-ECU 1,00 00,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.0, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 00,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 00,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 00,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-MAS28454,History data 21-Data bus to ECU 1,Unknown,
IDE01807-MAS28455,History data 21-Data bus to ECU 2,Unknown,
IDE01807-MAS28456,History data 21-Data bus to ECU 3,Unknown,
IDE01807-MAS28457,History data 21-Data bus to ECU 4,Unknown,
IDE01807-MAS28458,History data 21-Data bus to ECU 5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS05972,History data 22-Local data bus 3,0.0, H
IDE01808-MAS12183,History data 22-Comfort CAN bus 2,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01808-MAS16909,History data 22-Data bus driver assistance systems,0.0, H
IDE01808-MAS16912,History data 22-VLAN_FAS,0.0, H
IDE01808-MAS16913,History data 22-VLAN_Infotainment,0.0, H
IDE01808-MAS16915,History data 22-VLAN_Komfort,0.0, H
IDE01808-MAS16916,History data 22-VLAN_Powertrain,0.0, H
IDE01808-MAS16917,History data 22-VLAN_Diagnose,0.0, H
IDE01808-MAS18934,History data 22-VLAN Connect,0.0, H
IDE01808-MAS20476,History data 22-Data bus electrification,0.0, H
IDE01808-MAS22817,History data 22-Data bus driver assistance systems 2,0.0, H
IDE01808-MAS27736,History data 22-Comfort CAN bus 3,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 00,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-MAS28454,History data 23-Data bus to ECU 1,Unknown,
IDE01809-MAS28455,History data 23-Data bus to ECU 2,Unknown,
IDE01809-MAS28456,History data 23-Data bus to ECU 3,Unknown,
IDE01809-MAS28457,History data 23-Data bus to ECU 4,Unknown,
IDE01809-MAS28458,History data 23-Data bus to ECU 5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.0, H
IDE01810-MAS00106,History data 24-Year,2000,
IDE01810-MAS00107,History data 24-Month,1,
IDE01810-MAS00108,History data 24-Day,1,
IDE01810-MAS00109,History data 24-Hours,0, H
IDE01810-MAS00110,History data 24-Minutes,0, min
IDE01810-MAS14375,History data 24-Cycle counter,0,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,0,
IDE01810-MAS14393,History data 24-ID of the alerting message,00 00 00 00,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Unknown,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Unknown,
IDE01810-MAS14413,History data 24-Alert events in current cycle,0,
IDE01810-MAS20473,History data 24-Alerting message counter,0,
IDE01812-MAS01468,History data 26-Terminal 15,0,
IDE01812-MAS03173,History data 26-Powertrain data bus,0,
IDE01812-MAS03174,History data 26-Comfort data bus,0,
IDE01812-MAS03177,History data 26-Infotainment data bus,0,
IDE01812-MAS03178,History data 26-Suspension data bus,0,
IDE01812-MAS03180,History data 26-Local data bus,0,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS12185,History data 26-Hybrid data bus,0,
IDE01812-MAS14374,History data 26-Totals,0,
IDE01812-MAS16909,History data 26-Data bus driver assistance systems,0,
IDE01812-MAS16917,History data 26-VLAN_Diagnose,0,
IDE01812-MAS22817,History data 26-Data bus driver assistance systems 2,0,
IDE01813-MAS03173,History data 27-Powertrain data bus,0,
IDE01813-MAS03174,History data 27-Comfort data bus,0,
IDE01813-MAS03177,History data 27-Infotainment data bus,0,
IDE01813-MAS03178,History data 27-Suspension data bus,0,
IDE01813-MAS12183,History data 27-Comfort CAN bus 2,0,
IDE01813-MAS14374,History data 27-Totals,0,
IDE01813-MAS16909,History data 27-Data bus driver assistance systems,0,
IDE01813-MAS16912,History data 27-VLAN_FAS,0,
IDE01813-MAS16913,History data 27-VLAN_Infotainment,0,
IDE01813-MAS16915,History data 27-VLAN_Komfort,0,
IDE01813-MAS16916,History data 27-VLAN_Powertrain,0,
IDE01813-MAS18934,History data 27-VLAN Connect,0,
IDE01813-MAS20476,History data 27-Data bus electrification,0,
IDE01813-MAS22817,History data 27-Data bus driver assistance systems 2,0,
IDE01813-MAS27736,History data 27-Comfort CAN bus 3,0,
IDE01814-MAS03173,History data 28-Powertrain data bus,0,
IDE01814-MAS03174,History data 28-Comfort data bus,0,
IDE01814-MAS03177,History data 28-Infotainment data bus,0,
IDE01814-MAS03178,History data 28-Suspension data bus,0,
IDE01814-MAS12183,History data 28-Comfort CAN bus 2,0,
IDE01814-MAS12185,History data 28-Hybrid data bus,0,
IDE01814-MAS14374,History data 28-Totals,0,
IDE01814-MAS16909,History data 28-Data bus driver assistance systems,0,
IDE01814-MAS16912,History data 28-VLAN_FAS,0,
IDE01814-MAS16913,History data 28-VLAN_Infotainment,0,
IDE01814-MAS16915,History data 28-VLAN_Komfort,0,
IDE01814-MAS16916,History data 28-VLAN_Powertrain,0,
IDE01814-MAS18934,History data 28-VLAN Connect,0,
IDE01814-MAS22817,History data 28-Data bus driver assistance systems 2,0,
IDE01814-MAS27736,History data 28-Comfort CAN bus 3,0,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.0, H
IDE01816-MAS00106,History data 30-Year,2000,
IDE01816-MAS00107,History data 30-Month,1,
IDE01816-MAS00108,History data 30-Day,1,
IDE01816-MAS00109,History data 30-Hours,0, H
IDE01816-MAS00110,History data 30-Minutes,0, min
IDE01816-MAS14375,History data 30-Cycle counter,0,
IDE01816-MAS28463,History data 30-Data bus 1,Unknown,
IDE01816-MAS28464,History data 30-Data bus 2,Unknown,
IDE01816-MAS28465,History data 30-Data bus 3,Unknown,
IDE01816-MAS28467,History data 30-Data bus 4,Unknown,
IDE01816-MAS28470,History data 30-Data bus 5,Unknown,
IDE01816-MAS28474,History data 30-Active time for data bus 1,0.0, H
IDE01816-MAS28475,History data 30-Active time for data bus 2,0.0, H
IDE01816-MAS28476,History data 30-Active time for data bus 3,0.0, H
IDE01816-MAS28477,History data 30-Active time for data bus 4,0.0, H
IDE01816-MAS28478,History data 30-Active time for data bus 5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.0, H
IDE01817-MAS00106,History data 31-Year,2000,
IDE01817-MAS00107,History data 31-Month,1,
IDE01817-MAS00108,History data 31-Day,1,
IDE01817-MAS00109,History data 31-Hours,0, H
IDE01817-MAS00110,History data 31-Minutes,0, min
IDE01817-MAS14375,History data 31-Cycle counter,0,
IDE01817-MAS14376,History data 31-ECU 1,00 00,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.0, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 00,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 00,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 00,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-MAS28454,History data 31-Data bus to ECU 1,Unknown,
IDE01817-MAS28455,History data 31-Data bus to ECU 2,Unknown,
IDE01817-MAS28456,History data 31-Data bus to ECU 3,Unknown,
IDE01817-MAS28457,History data 31-Data bus to ECU 4,Unknown,
IDE01817-MAS28458,History data 31-Data bus to ECU 5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,00 00,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.0, H
IDE01819-MAS00106,History data 33-Year,2000,
IDE01819-MAS00107,History data 33-Month,1,
IDE01819-MAS00108,History data 33-Day,1,
IDE01819-MAS00109,History data 33-Hours,0, H
IDE01819-MAS00110,History data 33-Minutes,0, min
IDE01819-MAS14375,History data 33-Cycle counter,0,
IDE01819-MAS14393,History data 33-ID of the alerting message,00 00 00 00,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Unknown,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2000,
IDE01820-MAS00107,History data 34-Month,1,
IDE01820-MAS00108,History data 34-Day,1,
IDE01820-MAS00109,History data 34-Hours,0, H
IDE01820-MAS00110,History data 34-Minutes,0, min
IDE01820-MAS14375,History data 34-Cycle counter,0,
IDE01820-MAS14393,History data 34-ID of the alerting message,00 00 00 00,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,1839.3, H
IDE01823-MAS00106,History data 37-Year,2000,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,not activated,
IDE01823-MAS14375,History data 37-Cycle counter,0,
IDE01823-MAS14429,History data 37-Time in current cycle,1839.3, H
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,140A_ASIL,
IDE01831-MAS06311,Generator variant-ASIC manufacturer,1,
IDE01831-MAS06312,Generator variant-ASIC variant,3,
IDE01848,Energy balance of last driving cycle,0.3, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Duration of last driving cycle,0.0, H
IDE01985-MAS06855,FAZIT identification test sum-Test sum,02 AD C7 89,
IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1
IDE02486,Data logger triggering,active,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE13057,Stop process prevented-Lithium ions starter battery,not active,
IDE03008-MAS01161,Stop process prevented-Communication errors,not active,
IDE03008-MAS01478,Stop process prevented-insufficient voltage,not active,
IDE03008-MAS01979,Stop process prevented-Adapting,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS07348,Stop process prevented-Status battery off,not active,
IDE03008-MAS12452,Stop process prevented-Engine restart request,not active,
IDE03008-MAS26493,Stop process prevented-Energy system performance too low,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,20,
IDE03010-MAS01161,Number of prevented stop processes-Communication errors,0,
IDE03010-MAS01478,Number of prevented stop processes-insufficient voltage,0,
IDE03010-MAS01979,Number of prevented stop processes-Adapting,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,669,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,8,
IDE03010-MAS07348,Number of prevented stop processes-Status battery off,0,
IDE03010-MAS12452,Number of prevented stop processes-Engine restart request,2,
IDE03010-MAS26493,Number of prevented stop processes-Energy system performance too low,10,
IDE03011-IDE01838,Number of requested start processes-Battery temperature,0,
IDE03011-IDE13057,Number of requested start processes-Lithium ions starter battery,0,
IDE03011-MAS01161,Number of requested start processes-Communication errors,0,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,1,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,1,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,0,
IDE03011-MAS26493,Number of requested start processes-Energy system performance too low,0,
IDE03150-ENG299090,Readiness for bus sleep mode-ECU_Sleepindication,|Sleep-Bit 0,Sleep-Bit 1
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG299091,Bus identification-ECU_databus_identification,|bus_number,bus_type|0
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,not active,
IDE05740-ENG256034,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG256107,Driving profile selection: system status-operation_state,not engaged,
IDE05740-ENG255187,Driving profile selection: system status-profile_state,not engaged,
IDE05814,Individualization characteristic,ED FA 94 62 BF,
IDE05960-IDE01827,Generator-Specified generator voltage,13.925, V
IDE05960-IDE01828,Generator-Generator DF Signal,41.950, %
IDE05960-IDE01829,Generator-Generator exciter current,2.30, A
IDE05960-IDE01830,Generator-Generator Status,On,
IDE05960-IDE01855,Generator-Generator current,26.1, A
IDE05960-MAS06306,Generator-Status generator release by engine,Request by Engine Control Module,
IDE05960-MAS11758,Generator-Identification,Yes,
IDE05960-MAS14589,Generator-mechanical power,800, W
IDE05960-MAS21174,Generator-Generator reserve current,41.5, A
IDE05960-MAS21325,Generator-Ramp time,6, s
IDE06011-ENG118665,Selected driving profile-driving_profile,without_function,
IDE06011-ENG256033,Selected driving profile-link_profile,link_profile_1,
IDE06011-ENG157286,Selected driving profile-Operation_mode,Unknown (0)
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,0, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06307,Stop prevention history data,|Possible standing time too short,Energy system performance too low
IDE06308,Start request history data,|Battery state of charge too low,Standing time timed out
IDE06592-MAS31502,Status: special functions-Luggage compartment remote control via mobile online services,locked,
IDE06592-MAS31503,Status: special functions-Sunroof remote control via mobile online services.,locked,
IDE06592-MAS31504,Status: special functions-Ventilation remote control via mobile online services,locked,
IDE06592-MAS31505,Status: special functions-Window and sunroof remote control via mobile online services,locked,
IDE06592-MAS31506,Status: special functions-Remote vehicle start via mobile online services,locked,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,07,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,1,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,Malfunction,
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07636-MAS03001,Status hybrid DC/DC converter-Mode,0,
IDE07636-MAS04063,Status hybrid DC/DC converter-Malfunction in D/C-D/C converter,0,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,14.3, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,0, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,0, A
IDE08343,Immobilizer Challenge,F3 A1 1E CF,
IDE09058-IDE01845,Energy management: consumer releases-Reduce internal fan request,no request,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Neck heating,Enabling stage 3,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,Enabled,
IDE09058-MAS01564,Energy management: consumer releases-Windshield defogger,1240, W
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,Enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,Enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heating,Enabling stage 3,
IDE09058-MAS06552,Energy management: consumer releases-Seat heating: front,Enabling stage 3,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS14071,Energy management: consumer releases-Seat ventilation: rear,Enabling stage 3,
IDE09058-MAS20117,Energy management: consumer releases-Front seat ventilation,Enabling stage 3,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,327400, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),14.0, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,6.6, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,13.0, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,33.8, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,400, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,91, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,13, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,91, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,91, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,0, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,2047, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,95,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,95,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,2045,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,Kilometres,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,8.2, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.8, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.4, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.9, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,6.1, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,7.6, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,13.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,13.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,13.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,13.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,13.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,13.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,5.9, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery:  RWB-internal deduction,0, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,0,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Actual value,0,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11579-IDE13057,Number of prevented stop processes 2-Lithium ions starter battery,0,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,No error recognized,
IDE11683-MAS15122,Engine electronics: status of 48V network-Actual status,0,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,No error recognized,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Standby-mode,
IDE11728,Ethernet signal quality: branch 1,no link,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,no link,
IDE11733,Ethernet signal quality: branch 6,no link,
IDE11734,Ethernet signal quality: branch 7,no link,
IDE11735,Ethernet signal quality: branch 8,no link,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,0,
IDE11739,Ethernet counter connection interruptions: branch 4,0,
IDE11740,Ethernet counter connection interruptions: branch 5,0,
IDE11741,Ethernet counter connection interruptions: branch 6,0,
IDE11742,Ethernet counter connection interruptions: branch 7,0,
IDE11743,Ethernet counter connection interruptions: branch 8,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11750,Ethernet counter checksum error: branch 7,0,
IDE11751,Ethernet counter checksum error: branch 8,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 10|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 18|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 25|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 27|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 2A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 2E|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 60|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 75|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 8E|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 90|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 91|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 95|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 99|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 9B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 9F|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 B4|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 B5|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 B6|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 B8|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 E3|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 37|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 52|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 7D|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 80|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 FD|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 FE|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|3|4|5|7|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,71,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|44 20 63 23 7B E4|,
IDE11869,IP network: NDP cache,Write only channel,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,Write only channel,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|02 7D FA 00 73 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|B4 E3 D0 65 30 11|,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,Write only channel,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,Write only channel,
IDE11994-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 7-MAC address,Write only channel,
IDE11995-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 8-MAC address,Write only channel,
IDE12084-IDE02185,Component protection participant status-IKA key,stored,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,Generation 2,
IDE12084-MAS13795,Component protection participant status-Node address,00 0E,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,not locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS18011,Component protection participant status-Query message,Sent,
IDE12084-ENG157306,Component protection participant status-Status_of_component_protection_slaves,|Node address,IKA key
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|5|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|2|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|3|4|7|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|4|7|,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,|VLAN|2|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|2|,
IDE12236-MAS14856,IP network: VLANs of Ethernet switch ports branch 7-VLAN,|VLAN|3|5|,
IDE12237-MAS14856,IP network: VLANs of Ethernet switch ports branch 8-VLAN,|VLAN|2|,
IDE12238,I network: discarded messages counter,71,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 01 00 00 00 00 00 00 00 E0
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,254,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,254,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,254,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,Initialization,
IDE12627,IP network: current link deceleration: branch 3,65535, µs
IDE12628,IP network: current link deceleration: branch 4,65535, µs
IDE12629,IP network: current link deceleration: branch 5,65535, µs
IDE12630,IP network: current link deceleration: branch 6,65535, µs
IDE12633,IP Network maximum correction of the synchronized clock,0, µs
IDE12806-ENG299124,Diagnostic capability of the bus interface-Diag_paths,|Diag_path Bit 0,Diag_path Bit 1
IDE12807-ENG299127,Participant authenticity-Ecu_authentications,|Ecu_authentication Bit 0,Ecu_authentication Bit 1
IDE12844-ENG299092,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECM name
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13679-MAS06117,Power generator status-Specified voltage,13.925, V
IDE13679-MAS09777,Power generator status-Target current,0, A
IDE13679-MAS14362,Power generator status-Voltage limit boost mode,12.4,
IDE13754-IDE04447,Diagnostic filter: status-Function status,Function active: SFD protected,
IDE13754-MAS16866,Diagnostic filter: status-Mileage recorder,20, km
IDE13754-MAS16867,Diagnostic filter: status-Reason for deactivation,Temporarily deactivated,
IDE13754-MAS16875,Diagnostic filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00012004*2026-08-03-18:35:08*1*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00012009*2000-00-00-00:00:00*0*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00012009*2000-00-00-00:00:00*0*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00011959*2000-00-00-00:00:00*0*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00011959*2000-00-00-00:00:00*0*,
IDE13782-MAS00106,History data of the last 25 charges-Year,2000,
IDE13782-MAS00107,History data of the last 25 charges-Month,0,
IDE13782-MAS00108,History data of the last 25 charges-Day,0,
IDE13782-MAS00109,History data of the last 25 charges-Hours,0,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,0,
IDE13782-MAS00478,History data of the last 25 charges-Reserved,00000000 ,
IDE13782-MAS08747,History data of the last 25 charges-Charging plug connected,00000000 ,
IDE13782-ENG279300,History data of the last 25 charges-AC 1Phase,00000000 ,
IDE13782-ENG279301,History data of the last 25 charges-AC 2Phase,00000000 ,
IDE13782-ENG279302,History data of the last 25 charges-AC 3Phase,00000000 ,
IDE13782-ENG250730,History data of the last 25 charges-AWC,00000000 ,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,0,
IDE13782-ENG279316,History data of the last 25 charges-Charging start or Error,00000000 ,
IDE13782-ENG123224,History data of the last 25 charges-DC,00000000 ,
IDE13782-ENG279324,History data of the last 25 charges-Derating AC Notladen,not active,
IDE13782-ENG279325,History data of the last 25 charges-Derating AC Temp Abschaltung,not active,
IDE13782-ENG279326,History data of the last 25 charges-Derating DC begrenzt,not active,
IDE13782-ENG279327,History data of the last 25 charges-Derating DC reduziert,not active,
IDE13782-ENG279328,History data of the last 25 charges-Derating DC Temp Abschaltung,not active,
IDE13782-ENG279329,History data of the last 25 charges-Derating Fehler Temp AC,not active,
IDE13782-ENG279330,History data of the last 25 charges-Derating Fehler Temp DC,not active,
IDE13782-ENG279336,History data of the last 25 charges-DTC Fehler Crash Detektiert,not active,
IDE13782-ENG279337,History data of the last 25 charges-DTC Fehler FuSi Absch,not active,
IDE13782-ENG279338,History data of the last 25 charges-DTC Fehler Fzg Verrollsicher,not active,
IDE13782-ENG279339,History data of the last 25 charges-DTC Fehler Keine CP Komm,not active,
IDE13782-ENG279340,History data of the last 25 charges-DTC Fehler Ladebereit HV Koord,not active,
IDE13782-ENG279341,History data of the last 25 charges-DTC Fehler Ladebereit Ls,not active,
IDE13782-ENG279342,History data of the last 25 charges-DTC Fehler Ladebereit OCC,not active,
IDE13782-ENG279343,History data of the last 25 charges-DTC Fehler Lv Nicht Stby,not active,
IDE13782-ENG279344,History data of the last 25 charges-DTC Fehler Not Abschaltung,not active,
IDE13782-ENG279345,History data of the last 25 charges-DTC Fehler Remote Update On,not active,
IDE13782-ENG279346,History data of the last 25 charges-DTC Fehler Stecker Nicht Verr,not active,
IDE13782-ENG279409,History data of the last 25 charges-Event Entry HVL HDS 600by RAW,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13782-ENG255755,History data of the last 25 charges-Grund für Ladeende,Ladeende durch Kunde an der LS,
IDE13782-ENG255756,History data of the last 25 charges-Grundladeplan Abweichung,00,
IDE13782-ENG255801,History data of the last 25 charges-Indikator geäernderter Ziel_SOC,00000000 ,
IDE13782-ENG279486,History data of the last 25 charges-Indikator_01,00000000 ,
IDE13782-ENG279487,History data of the last 25 charges-Indikator_02,00000000 ,
IDE13782-ENG279488,History data of the last 25 charges-Indikator_03,00000000 ,
IDE13782-ENG279489,History data of the last 25 charges-Indikator_04,00000000 ,
IDE13782-ENG279490,History data of the last 25 charges-Indikator_05,00000000 ,
IDE13782-ENG279491,History data of the last 25 charges-Indikator_06,00000000 ,
IDE13782-ENG279492,History data of the last 25 charges-Indikator_07,00000000 ,
IDE13782-ENG279493,History data of the last 25 charges-Indikator_08,00000000 ,
IDE13782-ENG279494,History data of the last 25 charges-Indikator_09,00000000 ,
IDE13782-ENG279495,History data of the last 25 charges-Indikator_10,00000000 ,
IDE13782-ENG279496,History data of the last 25 charges-Indikator_11,00000000 ,
IDE13782-ENG279497,History data of the last 25 charges-Indikator_12,00000000 ,
IDE13782-ENG279498,History data of the last 25 charges-Indikator_13,00000000 ,
IDE13782-ENG279499,History data of the last 25 charges-Indikator_14,00000000 ,
IDE13782-ENG279500,History data of the last 25 charges-Indikator_15,00000000 ,
IDE13782-ENG279501,History data of the last 25 charges-Indikator_16,00000000 ,
IDE13782-ENG279502,History data of the last 25 charges-Indikator_17,00000000 ,
IDE13782-ENG279503,History data of the last 25 charges-Indikator_18,00000000 ,
IDE13782-ENG279504,History data of the last 25 charges-Indikator_19,00000000 ,
IDE13782-ENG279505,History data of the last 25 charges-Indikator_20,00000000 ,
IDE13782-ENG279506,History data of the last 25 charges-Indikator_21,00000000 ,
IDE13782-ENG279507,History data of the last 25 charges-Indikator_22,00000000 ,
IDE13782-ENG279508,History data of the last 25 charges-Indikator_23,00000000 ,
IDE13782-ENG279509,History data of the last 25 charges-Indikator_24,00000000 ,
IDE13782-ENG279510,History data of the last 25 charges-Indikator_25,00000000 ,
IDE13782-ENG279513,History data of the last 25 charges-Kein Derating,not active,
IDE13782-ENG255832,History data of the last 25 charges-Ladeanlauf Zustaende,0,
IDE13782-ENG255833,History data of the last 25 charges-Ladedauer zu Ladebeginn,0, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,0, min
IDE13782-ENG255835,History data of the last 25 charges-Ladedosen Temperatur max,0,
IDE13782-ENG255836,History data of the last 25 charges-Ladestrategie,0,
IDE13782-ENG279526,History data of the last 25 charges-Reserve 1,not active,
IDE13782-ENG279268,History data of the last 25 charges-Reserve 2,not active,
IDE13782-ENG160434,History data of the last 25 charges-soc_end,0, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,0, %
IDE13782-ENG256324,History data of the last 25 charges-SOC_Ziel,0, %
IDE13782-ENG256395,History data of the last 25 charges-Status Grundladen,Sofortladen Standby,
IDE13782-ENG279538,History data of the last 25 charges-stream,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13782-ENG256532,History data of the last 25 charges-Tracking DTC (10),not active,
IDE13782-ENG256533,History data of the last 25 charges-Tracking DTC (11),not active,
IDE13782-ENG256534,History data of the last 25 charges-Tracking DTC (12),not active,
IDE13782-ENG256535,History data of the last 25 charges-Tracking DTC (13),not active,
IDE13782-ENG256546,History data of the last 25 charges-Tracking DTC (9),not active,
IDE13782-ENG256721,History data of the last 25 charges-Zaehler_Bit,stored,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WV2ZZZSK8SX116493,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 0C,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,31,
IDE13845,Production mode status,not active,
IDE13873-MAS01159,Ethernet status electrical error-Version number,01,
IDE13873-MAS20288,Ethernet status electrical error-Number of status electrical error,9,
IDE13873,Ethernet status electrical error,|Ethernet interface,|2
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,650, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,0,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,30.0, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,22.5, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,20.0, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.0, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,16.5, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.0, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,17.5, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,18.0, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.0, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,22.0, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,30.0, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,22.5, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,20.0, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,17.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,16.5, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,17.0, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,17.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.0, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,20.0, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,22.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,650, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,65532,
IDE14151-MAS17930,Route-based range calculation-Range from destination,65532,
IDE14151-MAS17931,Route-based range calculation-Route-based range,65532,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,0,
IDE14169-MAS02832,Autonomous recharging-Malfunction status,Malfunction,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,Initialization,
IDE14169-ENG334094,Autonomous recharging-Comfort_limits,reached,
IDE14169-ENG334226,Autonomous recharging-HV_off_timer_status,Enabled,
IDE14169-ENG334227,Autonomous recharging-HV_power_supply_status,No malfunction,
IDE14169-ENG98676,Autonomous recharging-Init,not active,
IDE14169-ENG334254,Autonomous recharging-Limits_of_hv_battery,reached,
IDE14267-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 9-MAC address,Write only channel,
IDE14270-MAS14856,IP network: VLANs of Ethernet switch ports branch 9-VLAN,|VLAN|2|,
IDE14277,Ethernet signal quality: branch 9,no link,
IDE14280,Ethernet counter connection interruptions: branch 9,0,
IDE14283,Ethernet counter checksum error: branch 9,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 06,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,4,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3E 28 30 EA 48 0A FD,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,53,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2E,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15471,High-voltage charging manager: status of charging plan monitoring,not active,
IDE15472,High-voltage charging manager: energy deviation from charging plan,0.00, kWh
IDE15473-MAS20827,High-voltage charging manager: preferred charging time 1-Preferred charging time active,not activated,
IDE15473-MAS20835,High-voltage charging manager: preferred charging time 1-Begin hour,Initialization,
IDE15473-MAS20836,High-voltage charging manager: preferred charging time 1-End minute,Initialization,
IDE15473-MAS20837,High-voltage charging manager: preferred charging time 1-Begin minute,Initialization,
IDE15473-MAS20838,High-voltage charging manager: preferred charging time 1-End hour,Initialization,
IDE15474-MAS20827,High-voltage charging manager: preferred charging time 2-Preferred charging time active,not activated,
IDE15474-MAS20835,High-voltage charging manager: preferred charging time 2-Begin hour,Initialization,
IDE15474-MAS20836,High-voltage charging manager: preferred charging time 2-End minute,Initialization,
IDE15474-MAS20837,High-voltage charging manager: preferred charging time 2-Begin minute,Initialization,
IDE15474-MAS20838,High-voltage charging manager: preferred charging time 2-End hour,Initialization,
IDE15475-MAS20827,High-voltage charging manager: preferred charging time 3-Preferred charging time active,not activated,
IDE15475-MAS20835,High-voltage charging manager: preferred charging time 3-Begin hour,Initialization,
IDE15475-MAS20836,High-voltage charging manager: preferred charging time 3-End minute,Initialization,
IDE15475-MAS20837,High-voltage charging manager: preferred charging time 3-Begin minute,Initialization,
IDE15475-MAS20838,High-voltage charging manager: preferred charging time 3-End hour,Initialization,
IDE15476-MAS20827,High-voltage charging manager: preferred charging time 4-Preferred charging time active,not activated,
IDE15476-MAS20835,High-voltage charging manager: preferred charging time 4-Begin hour,Initialization,
IDE15476-MAS20836,High-voltage charging manager: preferred charging time 4-End minute,Initialization,
IDE15476-MAS20837,High-voltage charging manager: preferred charging time 4-Begin minute,Initialization,
IDE15476-MAS20838,High-voltage charging manager: preferred charging time 4-End hour,Initialization,
IDE15477-MAS20819,High-voltage charging manager: total energy requirement for charging planning-Target energy requirement,6529.50, kWh
IDE15477-MAS20820,High-voltage charging manager: total energy requirement for charging planning-Minimum energy requirement,6529.50, kWh
IDE15477-MAS20821,High-voltage charging manager: total energy requirement for charging planning-Maximum energy requirement,6529.50, kWh
IDE15498-MAS00106,High-voltage charging manager: active charging timer-Year,65295, yr
IDE15498-MAS00107,High-voltage charging manager: active charging timer-Month,Initialization,
IDE15498-MAS00108,High-voltage charging manager: active charging timer-Day,Initialization,
IDE15498-MAS00109,High-voltage charging manager: active charging timer-Hours,Initialization,
IDE15498-MAS00110,High-voltage charging manager: active charging timer-Minutes,Initialization,
IDE15499-MAS13088,High-voltage charging manager: active charging profile-Preconditioning of the interior,Initialization,
IDE15499-MAS20823,High-voltage charging manager: active charging profile-Target SoC,Initialization,
IDE15499-MAS20824,High-voltage charging manager: active charging profile-Minimum SoC,Initialization,
IDE15499-MAS20825,High-voltage charging manager: active charging profile-Charging current reduction,not activated,
IDE15499-MAS20826,High-voltage charging manager: active charging profile-Domestic current usage,not activated,
IDE15501,High-voltage charging manager: status of current charging plan creation,no request,
IDE15502-MAS03084,High-voltage charging manager: target current presetting-Phase 1,0.00, A
IDE15502-MAS03085,High-voltage charging manager: target current presetting-Phase 2,0.00, A
IDE15502-MAS03086,High-voltage charging manager: target current presetting-Phase 3,0.00, A
IDE15503,High-voltage charging manager: use of target current presetting,not activated,
IDE15504,High-voltage charging manager: target performance of expanded charging function,-50000, W
IDE15505,High-voltage charging manager: charging strategy of expanded charging function,Unknown (12)
IDE15506,High-voltage charging manager: status of extended charging functions,not active,
IDE15513-ENG279311,High-voltage charging manager: plug type and plug status-Byte to EOP,00 00 00 00 00 00 00 00 00 00,
IDE15521,High-voltage charging manager: charging process visualization,OFF,
IDE15522-MAS21677,DC charging: charging station statistics for charge process-DC charging: total energy turnover supply,1638.20, kWh
IDE15522-MAS21678,DC charging: charging station statistics for charge process-DC charging: total charging time,1022, min
IDE15523-MAS21679,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery maximum cell temperature,-50, °C
IDE15523-MAS21680,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery minimum cell temperature,-50, °C
IDE15523-MAS21681,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery maximum cell voltage,0.00, V
IDE15523-MAS21682,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery minimum cell voltage,0.00, V
IDE15524-MAS07479,DC charging: maximum output of charging station-Max. charge voltage DC charge station,1638.20, V
IDE15524-MAS21408,DC charging: maximum output of charging station-DC charging: maximum current charging station,-400, A
IDE15524-MAS21409,DC charging: maximum output of charging station-DC charging: minimum charging station voltage,1638.20, V
IDE15524-MAS21410,DC charging: maximum output of charging station-DC charging: minimum current charging station,-400, A
IDE15525-ENG279311,DC charging: request parameters for high-voltage battery-Byte to EOP,00 00 00 00 00,
IDE15526-IDE08969,DC charging: high-voltage battery charging parameters-HV battery: available capacity,0.00, kWh
IDE15526-MAS09113,DC charging: high-voltage battery charging parameters-Maximum temperature,-50, °C
IDE15526-MAS21681,DC charging: high-voltage battery charging parameters-DC charging: high-voltage battery maximum cell voltage,0.00, V
IDE15527,DC charging: high-voltage battery status,0,
IDE15527,DC charging: high-voltage battery status,-50, °C
IDE15527,DC charging: high-voltage battery status,normal,
IDE15527,DC charging: high-voltage battery status,tbd,
IDE15528-IDE06954,DC charging: charging station status-Actual HV charge current,-400, A
IDE15528-IDE13628,DC charging: charging station status-HV charging voltage: current value,1638.20, V
IDE15528-IDE15530,DC charging: charging station status-DC charging: charging station readiness,Pause,
IDE15528-MAS21678,DC charging: charging station status-DC charging: total charging time,1022, min
IDE15529,DC charging: charging status of high-voltage battery,0.00, V
IDE15529,DC charging: charging status of high-voltage battery,0, min
IDE15529,DC charging: charging status of high-voltage battery,-400, A
IDE15530,DC charging: charging station readiness,Not ready,
IDE15531-MAS21360,Activation of tailgate locking-Charge socket A: loading hatch request status,no request,
IDE15531-MAS21361,Activation of tailgate locking-Charge socket B: loading hatch request status,no request,
IDE15532-MAS21358,Activation of charger plug lock-Charge socket A: charging connector requirement status,no request,
IDE15532-MAS21359,Activation of charger plug lock-Charge socket B: charging connector request status,no request,
IDE15533,DC charging: controlled by charging station,not locked,
IDE15533,DC charging: controlled by charging station,Not permitted,
IDE15533,DC charging: controlled by charging station,Initialization,
IDE15533,DC charging: controlled by charging station,normal_operating_status,
IDE15536,DC charging: vehicle charging readiness,tbd,
IDE15537-ENG279311,DC charging: charging station detection-Byte to EOP,00 00 00 00 00,
IDE15538-ENG279311,DC charging: parameters for vehicle charging components-Byte to EOP,00 00 00 00,
IDE15539-ENG279311,DC charging: charging station protocol version-Byte to EOP,00 00 00,
IDE15540,DC charging: maximum vehicle charging voltage,0.00, V
IDE15541,DC charging: control module internal charging process control,tbd,
IDE15541,DC charging: control module internal charging process control,no request,
IDE15541,DC charging: control module internal charging process control,Standby,
IDE15541,DC charging: control module internal charging process control,-400.00, A
IDE15542,DC charging: charging process control across control modules,Norm_from_Year_2011,
IDE15542,DC charging: charging process control across control modules,not recognised,
IDE15542,DC charging: charging process control across control modules,no request,
IDE15542,DC charging: charging process control across control modules,Send_cyclic_message_fast_cycle,
IDE15543,DC charging: charging station status (Chademo),tbd,
IDE15543,DC charging: charging station status (Chademo),Standby,
IDE15545,DC charging: vehicle status,closed,
IDE15545,DC charging: vehicle status,Selector lever in position P,
IDE15545,DC charging: vehicle status,Not ready,
IDE15550,DC charging: vehicle control,Standby,
IDE15550,DC charging: vehicle control,no request,
IDE15550,DC charging: vehicle control,not requested,
IDE15550,DC charging: vehicle control,0, A
IDE15550,DC charging: vehicle control,tbd,
IDE15551-ENG279311,Power line communication: charging station status-Byte to EOP,00 00 00 00 00 3E 00 0E FF FE 03 03 03 03 FE 03 FE 03 FE 00 03 FE 03 FE 03 FE,
IDE15552,Power line communication: vehicle status,no request,
IDE15552,Power line communication: vehicle status,No_connection,
IDE15552,Power line communication: vehicle status,no warning,
IDE15552,Power line communication: vehicle status,Not ready,
IDE15552,Power line communication: vehicle status,No malfunction,
IDE15553,Power line communication: transfer and authentication,active,
IDE15553,Power line communication: transfer and authentication,Initialization,
IDE15554,Power line communication: process and manipulated variables,no request,
IDE15554,Power line communication: process and manipulated variables,0.00, V
IDE15554,Power line communication: process and manipulated variables,-400.00, A
IDE15555,Power line communication boundary conditions,0.00, V
IDE15555,Power line communication boundary conditions,0.00, A
IDE15555,Power line communication boundary conditions,-400.00, A
IDE15556,Power line communication: communication and process control,not specified,
IDE15556,Power line communication: communication and process control,AC_single_phase_core,
IDE15557,Charger input: maximum charging current permitted per phase,0.00, A
IDE15558,Charger output: maximum charging capacity: and maximum charge current,1638.00, A
IDE15558,Charger output: maximum charging capacity: and maximum charge current,819000, W
IDE15559-ENG279311,Actual voltage: current: and charging status of high-voltage battery-Byte to EOP,0F FE 7F FE 07 FE,
IDE15561,Calculated charge time remaining,0, min
IDE15562,Status of charge time calculation,Initialization,
IDE15563,Calculated charging speed,0, km
IDE15563,Calculated charging speed,kilometers_per_minute,
IDE15564,Calculated total charging time for one charge process,0.00, min
IDE15566,Deviation from actual calculated charging time,Unknown (0)
IDE15568,Average total charging time over multiple values,0.00, min
IDE15570,DC charging: charge process control,no request,
IDE15571-ENG279311,Charge process status information-Byte to EOP,00 00 00 00 00,
IDE15572,AC charging: adjacent phase voltage on charger rectifier,not recognised,
IDE15574,Activation of charger rectifier,0.00, A
IDE15574,Activation of charger rectifier,0, V
IDE15574,Activation of charger rectifier,Standby,
IDE15575,Requested charging type and charge initiation,not requested,
IDE15575,Requested charging type and charge initiation,No enabling,
IDE15576,Charging subsystem status information,0, %
IDE15576,Charging subsystem status information,Initialization,
IDE15576,Charging subsystem status information,0, min
IDE15576,Charging subsystem status information,no request,
IDE15577,Charging initiated by high-voltage coordinator,Not_ready_for_operation,
IDE15579,High-voltage charging manager: hold management status information,No malfunction,
IDE15579,High-voltage charging manager: hold management status information,Parking,
IDE15580,High-voltage charging management: accidental rolling preventing request,no request,
IDE15580,High-voltage charging management: accidental rolling preventing request,Leave standstill,
IDE15581,Control pilot activation,Close,
IDE15581,Control pilot activation,Open,
IDE15582-ENG279311,Charging readiness control: status information-Byte to EOP,00 00 00 00 00 00 00,
IDE15583,Charging mode detected by control pilot evaluation,Initialization,
IDE15584-ENG279311,Control pilot signal evaluation-Byte to EOP,00 00,
IDE15585-MAS02949,Control Pilot charging socket A: input variables-Frequency,Initialization,
IDE15585-MAS02952,Control Pilot charging socket A: input variables-Control voltage,Initialization,
IDE15585-MAS03873,Control Pilot charging socket A: input variables-Pulse duty factor,Initialization,
IDE15586-MAS02949,Control Pilot charging socket B: input variables-Frequency,Initialization,
IDE15586-MAS02952,Control Pilot charging socket B: input variables-Control voltage,Initialization,
IDE15586-MAS03873,Control Pilot charging socket B: input variables-Pulse duty factor,Initialization,
IDE15587,Status of charging plug lock,Initialization,
IDE15587,Status of charging plug lock,not completed,
IDE15588-MAS21352,Connector lock: operating status: door key cylinder-Central Locking System: lock triggered by door lock,Not operated,
IDE15588-MAS21353,Connector lock: operating status: door key cylinder-Central Locking System: unlock request triggered by door lock,Not operated,
IDE15589-MAS21441,Connector lock: operating status: radio key signal-Central Locking System: unlock triggered by remote key,Not operated,
IDE15589-MAS21442,Connector lock: operating status: radio key signal-Central Locking System: lock triggered by remote key,Not operated,
IDE15750,Visible status in charging plan processing,not active,
IDE15752,Charging requirement for expanded charging functions of basic charging,tbd,
IDE15854-MAS21195,Report system for deviations: blacklist data bus infotainment-CAN identifier invalid,00 00 00 00,
IDE15854-MAS21196,Report system for deviations: blacklist data bus infotainment-Event counter,0,
IDE15855-MAS21195,Report system for deviations: blacklist data bus drive-CAN identifier invalid,00 00 00 00,
IDE15855-MAS21196,Report system for deviations: blacklist data bus drive-Event counter,0,
IDE15856-MAS21195,Report system for deviations: violation of time specifications-CAN identifier invalid,09 10 00 00,
IDE15856-MAS21196,Report system for deviations: violation of time specifications-Event counter,4342784,
IDE15857-MAS21195,Report system for deviations: violations during signal change-CAN identifier invalid,00 00 18 17,
IDE15857-MAS21196,Report system for deviations: violations during signal change-Event counter,335609856,
IDE15989-ENG279311,High voltage charging manager: next charging start-Byte to EOP,00 00 00 00 01 01,
IDE16057-MAS06854,FoD assignment of work clearance ID-Version,02,
IDE16057-MAS20326,FoD assignment of work clearance ID-Diagnostic address,00 5F,
IDE16057-MAS22310,FoD assignment of work clearance ID-Number of assignments of work clearance ID,10,
IDE16057-MAS22311,FoD assignment of work clearance ID-Lower limit for clearance ID,00 00 01,
IDE16057-MAS22312,FoD assignment of work clearance ID-Upper limit for clearance ID,0F FF FF,
IDE16456-MAS06854,Configuration of unlockable functions. status-Version,02,
IDE16456-MAS17974,Configuration of unlockable functions. status-Slave number,0,
IDE16456-MAS17975,Configuration of unlockable functions. status-Slave node address,00 76,
IDE16456-MAS17976,Configuration of unlockable functions. status-Slave diagnostic address,00 01,
IDE16456-MAS20489,Configuration of unlockable functions. status-Number,8,
IDE16459,Unlockable functions: vehicle identification number,WV2ZZZSK8SX116493,
IDE16460-MAS05076,Unlockable functions: read authentic time-Time,6A 70 CD 0D,
IDE16460-MAS12398,Unlockable functions: read authentic time-Time parameter,6A 70 CC E5,
IDE16460-MAS15286,Unlockable functions: read authentic time-Number of terminal 15 cycles,00 00 00 01,
IDE16461-MAS05584,Unlockable functions: import status-Result,00 00,
IDE16461-MAS15826,Unlockable functions: import status-System specific routine status,02,
IDE16461-MAS18832,Unlockable functions: import status-Time stamp 1,00 00 00 00,
IDE16461-MAS18833,Unlockable functions: import status-Time stamp 2,00 00 00 00,
IDE16461-MAS18834,Unlockable functions: import status-Time stamp 3,68 47 40 35,
IDE16461-MAS18835,Unlockable functions: import status-Time stamp 4,00 00 00 00,
IDE16461-MAS25531,Unlockable functions: import status-Result 2,00 00,
IDE16463-MAS02246,Unlockable functions: communication status-Timeout,4, s
IDE16463-MAS04389,Unlockable functions: communication status-Number of repeat attempts,3,
IDE16463-MAS06173,Unlockable functions: communication status-Protocol,02,
IDE16463-MAS06854,Unlockable functions: communication status-Version,02,
IDE16463-MAS17974,Unlockable functions: communication status-Slave number,0,
IDE16463-MAS17976,Unlockable functions: communication status-Slave diagnostic address,00 01,
IDE16463-MAS20489,Unlockable functions: communication status-Number,8,
IDE16495,12V energy architecture: installation variant,0,
IDE16497-MAS27312,12V vehicle electrical system activation-12-V vehicle electrical system information,0,
IDE16497-MAS27313,12V vehicle electrical system activation-12-V Li-Ion cooling information,0,
IDE16497-MAS27314,12V vehicle electrical system activation-12-V consumer information,0,
IDE16936-IDE01834,Low-voltage energy management: key figures of the lead battery-Battery voltage,13.83, V
IDE16936-IDE01836,Low-voltage energy management: key figures of the lead battery-Battery current,3, A
IDE16936-IDE12072,Low-voltage energy management: key figures of the lead battery-Warning displays,no warning,
IDE16936-IDE17292,Low-voltage energy management: key figures of the lead battery-Charge indicator,53.958,
IDE16936-MAS04059,Low-voltage energy management: key figures of the lead battery-Battery temperature,51, °C
IDE16936-MAS05030,Low-voltage energy management: key figures of the lead battery-Resistance,3.6,
IDE16936-MAS23197,Low-voltage energy management: key figures of the lead battery-Reason for warning display,0,
IDE16936-MAS23866,Low-voltage energy management: key figures of the lead battery-Limit resistance,8.4,
IDE16936-MAS23867,Low-voltage energy management: key figures of the lead battery-Escalation counter for battery alerts,0,
IDE16936-MAS26492,Low-voltage energy management: key figures of the lead battery-Duration of vehicle electrical system warning,0, H
IDE17058-IDE06260,List of imported identifiers-ID number,10 00 01 00,
IDE17058-MAS17839,List of imported identifiers-Number of functions which can be activated,10,
IDE17389-MAS02832,Status of trustworthy time synchronization in the master-Malfunction status,Unknown (16)
IDE17389-MAS03555,Status of trustworthy time synchronization in the master-Lap counter,Lap_counter,
IDE17389-MAS20489,Status of trustworthy time synchronization in the master-Number,0,
IDE17389-MAS23886,Status of trustworthy time synchronization in the master-Vehicle time second,19864342611380, s
IDE17389-MAS23887,Status of trustworthy time synchronization in the master-Vehicle time nanosecond,3022530049, ns
IDE17389-MAS23888,Status of trustworthy time synchronization in the master-Inbound buffer,1,
IDE17389-MAS23889,Status of trustworthy time synchronization in the master-Outbound buffer,6,
IDE18879-IDE18880,Last communication: overload detected-Communication channel overload,Unknown (0)
IDE18879-MAS00106,Last communication: overload detected-Year,2000,
IDE18879-MAS00107,Last communication: overload detected-Month,0,
IDE18879-MAS00108,Last communication: overload detected-Day,0,
IDE18879-MAS00109,Last communication: overload detected-Hours,0,
IDE18879-MAS00110,Last communication: overload detected-Minutes,0,
IDE18879-MAS00111,Last communication: overload detected-Seconds,0,
IDE18879-MAS03006,Last communication: overload detected-Overload,Unknown (0)
IDE18879-ENG104031,Last communication: overload detected-Number,0,
IDE18914-MAS21195,Report system for deviations: convenience CAN bus2 blacklist-CAN identifier invalid,00 00 00 00,
IDE18914-MAS21196,Report system for deviations: convenience CAN bus2 blacklist-Event counter,0,
IDE18915-MAS21195,Report system for deviations: suspension data bus blacklist-CAN identifier invalid,00 00 00 00,
IDE18915-MAS21196,Report system for deviations: suspension data bus blacklist-Event counter,0,
MAS00464-MAS00106,Standard - ambient data 1-Year,2064,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,6,
MAS00464-MAS00109,Standard - ambient data 1-Hours,24,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,13,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,32,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,199,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,12004, km
MAS00769-IDE02717,Multi-function steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multi-function steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multi-function steering wheel control module-MFL Variant code,9,
MAS00769-MAS01065,Multi-function steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multi-function steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multi-function steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multi-function steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multi-function steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multi-function steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multi-function steering wheel control module-MFL message counter,11,
MAS00769-MAS06030,Multi-function steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multi-function steering wheel control module-MFL Local active,active,
MAS00769-MAS06035,Multi-function steering wheel control module-MFL M button,Not operated,
MAS01458,Operating State,00 00 00 00 00 00 00 00 00 00 00 00,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 1D
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|81|81|81|0|0|0|0|0|82|82|0|0|0|0|0|0|0|83|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
MAS16744-IDE01836,12-volt battery-Battery current,3.167, A
MAS16744-IDE01837,12-volt battery-Temperature of battery sensor,51, °C
MAS16744-IDE01838,12-volt battery-Battery temperature,49, °C
MAS16744-IDE01839,12-volt battery-Battery charge status,78, %
MAS16744-IDE01841,12-volt battery-Battery internal resistance,3.8, mOhm
MAS16744-IDE01842,12-volt battery-Usable battery charge,30, Ah
MAS16744-IDE01948,12-volt battery-Battery internal resistance not normed,3.8, mOhm
MAS16744-IDE04186,12-volt battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12-volt battery-adapted battery capacity,70, Ah
MAS16744-MAS00362,12-volt battery-Battery voltage,13.831, V
MAS16744-MAS06086,12-volt battery-Total re-charge,1774.5, Ah
MAS16744-MAS06087,12-volt battery-Entire energy throughput,1812.4, Ah
MAS16744-MAS22232,12-volt battery-Battery aging: charge-related,100, %
MAS16744-MAS22233,12-volt battery-Battery aging: performance-related,100, %
MAS16745-IDE01839,Quiescent current management-Battery charge status,80, %
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.5, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,Measurement,
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-0.134, A
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 13 15 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,30,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,valid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 01 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,Available,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,15,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,03,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,Available,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,ED FA 94 62 BF 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,68 47 40 35,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1723,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Incomplete transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,8,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,0,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,118,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 01,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,43 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS24971,Low-voltage energy management: energy charging balance,10009, Ah
MAS26902-MAS26903,Battery management: information-Battery management: communication basis,1,
MAS26902-MAS26904,Battery management: information-Battery management: generation,2,
MAS26965-MAS21181,Medium-voltage energy management: function support for NVEM-Vehicle system diagnostic,no restriction,
MAS26965-MAS25333,Medium-voltage energy management: function support for NVEM-Performance specification for the LV energy management system,6300, W
MAS26966-MAS21330,Medium-voltage energy management: signals from NVEM-Low-voltage EM approval for increasing medium-voltage EM,No,
MAS26966-MAS26810,Medium-voltage energy management: signals from NVEM-Low-voltage energy management: energy network status,QM security integrity,
MAS26966-MAS26811,Medium-voltage energy management: signals from NVEM-Low-voltage energy management: OBD adaptation,Initialization,
MAS26966-MAS26812,Medium-voltage energy management: signals from NVEM-Low-voltage energy management: support request,no request,
MAS26966-MAS26813,Medium-voltage energy management: signals from NVEM-Low-voltage energy management: energy network type,Conventional combustion engine,
MAS26966-MAS26814,Medium-voltage energy management: signals from NVEM-Low-voltage energy management: functional safety status driving,Initialization,
MAS26966-MAS26815,Medium-voltage energy management: signals from NVEM-Low-voltage energy management: mode,0,
MAS26967-MAS03001,Battery management: operating status of the 48V network-Mode,Standby-mode,
MAS26967-MAS06915,Battery management: operating status of the 48V network-Performance reduction,not active,
MAS26967-MAS26816,Battery management: operating status of the 48V network-Energy availability,Available,
MAS26967-MAS26817,Battery management: operating status of the 48V network-Relay welded,not active,
MAS26967-MAS26818,Battery management: operating status of the 48V network-Relay Open,not active,
SFT271901-ENG250861,Generator-alternator_family,5,
SFT271901-ENG245985,Generator-asic_manufacturer,01,
SFT271901-ENG250451,Generator-asic_variant,03,
SFT271901-ENG378372,Generator-hyphen_1,-,
SFT271901-ENG378369,Generator-hyphen_2,-,
SFT271901-ENG378371,Generator-hyphen_3,-,
SFT271901-ENG378370,Generator-hyphen_4,-,
SFT271901-ENG171470,Generator-Manufacturer,00,
SFT271901-ENG99001,Generator-Variant,17,
ENG445405-IDE01842,12V_memory_diagnostic-Usable battery charge,0, Ah
ENG377607-MAS06117,Alternator_analysis-Specified voltage,13.9, V
ENG377607-MAS06864,Alternator_analysis-Generator actual voltage,13.8, V
ENG377607-MAS06865,Alternator_analysis-Voltage difference generator battery,0.0, V
ENG377607-MAS06866,Alternator_analysis-Generator speed,2506, /min
ENG377607-MAS06867,Alternator_analysis-Generator chip temperature,72, °C
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG186123-ENG255560,Authentic_time_last_client_response-Current_time_ used,2026-08-03T17:17:03Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2026-08-03T17:17:03Z,
ENG347825-MAS06854,Distribution_master_extended_state-Version,11,
ENG347825-ENG298547,Distribution_master_extended_state-Extended_state_payload,00 01,
ENG347825-ENG298612,Distribution_master_extended_state-Payload_length,158,
ENG254617-ENG299125,DoIP_Status-DoIP_Status_ECU,|Node_address,number_tcp_connections_ecu
ENG254617-ENG280661,DoIP_Status-number_of_total_ecu,0,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognised,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognised,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,1,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,not active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG347891-MAS06854,Function_enabling_extended_state-Version,12,
ENG347891-ENG298547,Function_enabling_extended_state-Extended_state_payload,12 06,
ENG347891-ENG298612,Function_enabling_extended_state-Payload_length,1597,
ENG254720-ENG255783,High_voltage_charging_information-High_voltage_charging_state,Init,
ENG254720-ENG255784,High_voltage_charging_information-High_voltage_type_of_charging_request,charging_not_requested,
ENG254720-ENG334265,High_voltage_charging_information-Maximum_by_drive_enabled_power,Init,
ENG395486-ENG395811,Hv_power_handshake-Additional_powerrequest_powertrain,Init,
ENG395486-ENG396081,Hv_power_handshake-Powertarget_hvlm_base_load,0, W
ENG395486-ENG396082,Hv_power_handshake-Powertarget_hvlm_interior_comfort,0, W
ENG254725-ENG334194,HV-EM_consumer_contingent-Enabling_battery_heater,No enabling,
ENG254725-ENG255697,HV-EM_consumer_contingent-Enabling_climate_aggregates,Initialization,
ENG254725-ENG334243,HV-EM_consumer_contingent-Hvem_wake_up,not active,
ENG254727-ENG152029,HV-EM_energy_specification-High_voltage_battery_energy_information,Initialization,
ENG254727-ENG354697,HV-EM_energy_specification-High_voltage_battery_energy_information_ube,0, Wh
ENG254727-ENG152032,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,Initialization,
ENG254728-ENG152033,HV-EM_high_voltage_activation-HV-EM_HV_requirement,no request,
ENG254728-ENG334233,HV-EM_high_voltage_activation-Hvem_ops_hv_presence,no request,
ENG254728-ENG152036,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG254728-ENG334240,HV-EM_high_voltage_activation-Hvem_request_battery_conditioning,no request,
ENG254728-ENG334241,HV-EM_high_voltage_activation-Hvem_request_by_hv_charging,not active,
ENG254728-ENG334242,HV-EM_high_voltage_activation-Hvem_request_independent_air_conditioning,no request,
ENG254728-ENG395988,HV-EM_high_voltage_activation-Hvem_request_independent_low_voltage,no request,
ENG254729-ENG255533,HV-EM_operation_data-climate_power,0, W
ENG254729-ENG255581,HV-EM_operation_data-dcdc_power,6220, W
ENG254729-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,Standby,
ENG254730-ENG353491,HV-EM_operation_limitation-Charge_state_hv_battery_display_soc,127.0, %
ENG254730-ENG263259,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,No enabling,
ENG254730-ENG152034,HV-EM_operation_limitation-HV-EM_NV_power_limitation,6300, W
ENG254730-ENG152035,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG310451-ENG334228,HV-EM_Power_contingent-Hvem_actual_performance_auxiliary_consumers,25500, W
ENG310451-ENG334236,HV-EM_Power_contingent-Hvem_power_specification_air_conditioner,Initialization,
ENG310451-ENG334238,HV-EM_Power_contingent-Hvem_power_specification_battery_heater,Initialization,
ENG310452-ENG334231,HV-EM_Power_request-Hvem_minimum_power,Init,
ENG310452-ENG334234,HV-EM_Power_request-Hvem_power_intention,Init,
ENG310452-ENG334293,HV-EM_Power_request-Power_demand_air_conditioner,Initialization,
ENG310452-ENG334295,HV-EM_Power_request-Power_demand_battery_heater,0, W
ENG254743-ENG255799,Intrusion_detection_system_disable_time-ids_disable_timeslot,0, ms
ENG151186-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,Measurement running: please wait,
ENG151186-ENG140421,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,Initialization,
ENG151187-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,Measurement running: please wait,
ENG151191,MV-EM_dc_current_Mv,0.0, A
ENG151192,MV-EM_dc_power_desired,0, W
ENG151193,MV-EM_DC_voltage_desired,0.00, V
ENG151194,MV-EM_dc_voltage_Mv,0.00, V
ENG151197,MV-EM_Mv_current,511, A
ENG377943,MVEM_Status_Development,00 00 00 00 00 00 00 00 00 00 00,
ENG310457-ENG334195,NVEM_12V_autonome_Funktionen-Energieinhalt_Primärseite,0,
ENG310457-ENG334211,NVEM_12V_autonome_Funktionen-functional_requirement_NVEM,0,
ENG310457-ENG334297,NVEM_12V_autonome_Funktionen-Qe_auf_Basis_SOC,30, Ah
ENG310457-ENG334298,NVEM_12V_autonome_Funktionen-Qe_Batterie,85, Ah
ENG310457-ENG334299,NVEM_12V_autonome_Funktionen-QKomfort,31, Ah
ENG310457-ENG334442,NVEM_12V_autonome_Funktionen-Zaehler_Haeufigkeit_autonomes_Nachladen,0,
ENG310458-ENG334272,Nvem_12V_recognized_battery_data-Nvem_12V_recognized_battery_capacity,70, Ah
ENG310458-ENG334273,Nvem_12V_recognized_battery_data-Nvem_12V_recognized_battery_technology,9,
ENG310459-MAS06344,NVEM_crank_voltage_analysis-Minimum voltage at last engine start,9.35, V
ENG310459-MAS06345,NVEM_crank_voltage_analysis-Minimum voltage at last engine start recognized,not recognised,
ENG310459-MAS06346,NVEM_crank_voltage_analysis-Voltage drop through engine start recognized,not recognised,
ENG310459-MAS06347,NVEM_crank_voltage_analysis-Current voltage drop last start,3.25, V
ENG310459-MAS06348,NVEM_crank_voltage_analysis-Normed voltage drop,3.20, V
ENG310459-MAS11064,NVEM_crank_voltage_analysis-Current last engine start,920, A
ENG310459-MAS11065,NVEM_crank_voltage_analysis-Current delta last engine start,904, A
ENG310460,NVEM_Grund_falsch_codiert,0,
ENG310461-ENG255299,NVEM_idle_speed_increase-Anforderung_Leerlaufanhebung,no request,
ENG310461-ENG255780,NVEM_idle_speed_increase-Heizleistungskontingent_Stufe,Stage 1,
ENG310462-IDE06339,NVEM_mode_operation-Hybrid readiness: status,not active,
ENG310462-MAS03679,NVEM_mode_operation-Terminal 15 status,active,
ENG310462-ENG278695,NVEM_mode_operation-Comfort_Ready_Status,not active,
ENG310462-ENG157286,NVEM_mode_operation-Operation_mode,12,
ENG310462-ENG334324,NVEM_mode_operation-safety_drivestate,1,
ENG347975-MAS06319,NVEM_park_heater_flag-Allowed parking heater runtime,60, min
ENG347975-ENG355694,NVEM_park_heater_flag-park_heater_target_time_long,Initialization,
ENG347976-ENG391372,NVEM_Rekuperation_12V-Freigabe_Anfahrhilfe,active,
ENG347976-ENG354080,NVEM_Rekuperation_12V-Freigabe_Batterie_Temperatur,active,
ENG347976-ENG356503,NVEM_Rekuperation_12V-Freigabe_Dieselpartikelfilter_Regeneration,active,
ENG347976-ENG355218,NVEM_Rekuperation_12V-Freigabe_Entnehmbare_Ladung,active,
ENG347976-ENG352164,NVEM_Rekuperation_12V-Freigabe_Fahrzeug_Fahrbetrieb,active,
ENG347976-ENG391757,NVEM_Rekuperation_12V-Freigabe_Festspannung,active,
ENG347976-ENG352642,NVEM_Rekuperation_12V-Freigabe_Kein_Anhaenger,Yes,
ENG347976-ENG356103,NVEM_Rekuperation_12V-Freigabe_Kein_Produktionsmodus,Yes,
ENG347976-ENG355487,NVEM_Rekuperation_12V-Freigabe_Kein_Transportschutz,Yes,
ENG347976-ENG255737,NVEM_Rekuperation_12V-Freigabe_KFG,active,
ENG347976-ENG352779,NVEM_Rekuperation_12V-Freigabe_Komponente_Batterie,active,
ENG347976-ENG355530,NVEM_Rekuperation_12V-Freigabe_Leerlaufanhebung,active,
ENG347976-ENG356741,NVEM_Rekuperation_12V-Freigabe_Master_Energiebilanz,active,
ENG347976-ENG351947,NVEM_Rekuperation_12V-Freigabe_Motor,active,
ENG347976-ENG353873,NVEM_Rekuperation_12V-Freigabe_Niedervolt_Energiewandler,active,
ENG347976-ENG440084,NVEM_Rekuperation_12V-Freigabe_PNEB,not active,
ENG347976-ENG354426,NVEM_Rekuperation_12V-Freigabe_Rueckspeisung_Batterie_Temperatur,not active,
ENG347976-ENG391030,NVEM_Rekuperation_12V-Freigabe_rueckspeisung_komponente_batterie,active,
ENG347976-ENG356115,NVEM_Rekuperation_12V-Freigabe_Rueckspeisung_Kundenspezifisches_Funktionssteuergeraet,active,
ENG347976-ENG355635,NVEM_Rekuperation_12V-Freigabe_Rueckspeisung_Mittelvolt,active,
ENG347976-ENG353550,NVEM_Rekuperation_12V-Freigabe_Rueckspeisung_Motor,active,
ENG347976-ENG353574,NVEM_Rekuperation_12V-Freigabe_State_Of_Health_Ladung,active,
ENG347976-ENG440085,NVEM_Rekuperation_12V-Freigabe_State_Of_Health_Liistung,active,
ENG347976-ENG256076,NVEM_Rekuperation_12V-Modus_Rekuperation_Motor,Neutral,
ENG347976-ENG353906,NVEM_Rekuperation_12V-Regelungsart,Voltage regulation,
ENG347976-ENG354388,NVEM_Rekuperation_12V-Soll_Spannung_Wandler,13.800, V
ENG347976-ENG352108,NVEM_Rekuperation_12V-Soll_Strom_Wandler,210.0, A
ENG347976-ENG352098,NVEM_Rekuperation_12V-Sollspannung_Rampe_Wandler,3.0, V/s
ENG347976-ENG256364,NVEM_Rekuperation_12V-Spannungsanforderung_BCM,not active,
ENG347976-ENG256365,NVEM_Rekuperation_12V-Spannungsanforderung_Bremse,not active,
ENG347976-ENG354515,NVEM_Rekuperation_12V-Spannungsanforderung_elektromechanischer_Bremskraftverstaerker,not active,
ENG347976-ENG256366,NVEM_Rekuperation_12V-Spannungsanforderung_KFG,not active,
ENG347976-ENG256367,NVEM_Rekuperation_12V-Spannungsanforderung_Klima,not active,
ENG347976-ENG256368,NVEM_Rekuperation_12V-Spannungsanforderung_Lenkung,not active,
ENG347976-ENG256369,NVEM_Rekuperation_12V-Spannungsanforderung_Motor,not active,
ENG347976-ENG256399,NVEM_Rekuperation_12V-Status_Rekuperation,active,
ENG310463-MAS06117,NVEM_Sollvorgaben-Specified voltage,13.800, V
ENG310463-MAS09777,NVEM_Sollvorgaben-Target current,31.5, A
ENG310463-ENG334355,NVEM_Sollvorgaben-Sollleistung,6250, W
ENG310463-ENG334356,NVEM_Sollvorgaben-Sollleistung_grund,0,
ENG310463-ENG334357,NVEM_Sollvorgaben-Sollleistung_vorgabe,900, W
ENG310463-ENG334358,NVEM_Sollvorgaben-Spannung_soll_grund,0,
ENG310463-ENG334370,NVEM_Sollvorgaben-Strom_soll_grund,6,
ENG347977-MAS06327,NVEM_start/stop_system_faults_active_participants-Battery data module defective,not active,
ENG347977-MAS07657,NVEM_start/stop_system_faults_active_participants-insufficient voltage,not active,
ENG347977-MAS29388,NVEM_start/stop_system_faults_active_participants-Fault of lithium-ion starter battery,not active,
ENG347977-MAS29389,NVEM_start/stop_system_faults_active_participants-Fault in OBD configuration,not active,
ENG347978-IDE03212,NVEM_Start_/_Stopp-Start/stop conditions,Stop release,
ENG347978-IDE03213,NVEM_Start_/_Stopp-Start/stop enable,No release by coordinator,
ENG347978-IDE03214,NVEM_Start_/_Stopp-Engine stop using start-stop function,not active,
ENG347978-IDE07621,NVEM_Start_/_Stopp-Permitted engine stop time,max.value,
ENG347978-IDE07622,NVEM_Start_/_Stopp-Power consumption during idle phase,25, A
ENG310464-MAS00978,NVEM_VST_Zustand-Priority,0,
ENG310464-ENG334316,NVEM_VST_Zustand-Reason_consumer_cutoff,2,
ENG310464-ENG334423,NVEM_VST_Zustand-Trigger_consumer_cutoff,0,
ENG297745-MAS11001,Power_network_state-Reason,26,
ENG254806-ENG256121,SEC_dropped_frames-par_dropped_frames_port_2,00 00 00 00 00 00 00 00,
ENG254806-ENG256122,SEC_dropped_frames-par_dropped_frames_port_3,00 00 00 00 00 00 00 00,
ENG254806-ENG256123,SEC_dropped_frames-par_dropped_frames_port_4,00 00 00 00 00 00 00 00,
ENG254806-ENG256124,SEC_dropped_frames-par_dropped_frames_port_5,00 00 00 00 00 00 00 00,
ENG254806-ENG256125,SEC_dropped_frames-par_dropped_frames_port_6,00 00 00 00 00 00 00 00,
ENG254806-ENG256126,SEC_dropped_frames-par_dropped_frames_port_7,00 00 00 00 00 00 00 00,
ENG254807-ENG256132,SEC_filtered_packets-par_number_of_filtered_packets_icmp,0,
ENG254807-ENG256133,SEC_filtered_packets-par_number_of_filtered_packets_ip,71,
ENG254807-ENG256134,SEC_filtered_packets-par_number_of_filtered_packets_other,0,
ENG254807-ENG256135,SEC_filtered_packets-par_number_of_filtered_packets_tcp,0,
ENG254807-ENG256136,SEC_filtered_packets-par_number_of_filtered_packets_total,71,
ENG254807-ENG256137,SEC_filtered_packets-par_number_of_filtered_packets_udp,0,
ENG254808-ENG256138,SEC_rx_bytes-par_rx_bytes_port_2,00 00 00 00 00 00 00 00,
ENG254808-ENG256139,SEC_rx_bytes-par_rx_bytes_port_3,00 00 00 00 00 00 00 00,
ENG254808-ENG256140,SEC_rx_bytes-par_rx_bytes_port_4,00 00 00 00 00 4D E0 6C,
ENG254808-ENG256141,SEC_rx_bytes-par_rx_bytes_port_5,00 00 00 00 01 CD B7 F4,
ENG254808-ENG256142,SEC_rx_bytes-par_rx_bytes_port_6,00 00 00 00 00 00 00 00,
ENG254808-ENG256143,SEC_rx_bytes-par_rx_bytes_port_7,00 00 00 00 00 00 00 00,
ENG254809-ENG256144,SEC_rx_frames-par_rx_frames_port_2,00 00 00 00 00 00 00 00,
ENG254809-ENG256145,SEC_rx_frames-par_rx_frames_port_3,00 00 00 00 00 00 00 00,
ENG254809-ENG256146,SEC_rx_frames-par_rx_frames_port_4,00 00 00 00 00 00 CC E7,
ENG254809-ENG256147,SEC_rx_frames-par_rx_frames_port_5,00 00 00 00 00 01 FF 05,
ENG254809-ENG256148,SEC_rx_frames-par_rx_frames_port_6,00 00 00 00 00 00 00 00,
ENG254809-ENG256149,SEC_rx_frames-par_rx_frames_port_7,00 00 00 00 00 00 00 00,
ENG254810-ENG256150,SEC_tx_bytes-par_tx_bytes_port_2,00 00 00 00 00 00 00 00,
ENG254810-ENG256151,SEC_tx_bytes-par_tx_bytes_port_3,00 00 00 00 00 00 00 00,
ENG254810-ENG256152,SEC_tx_bytes-par_tx_bytes_port_4,00 00 00 00 27 E5 25 33,
ENG254810-ENG256153,SEC_tx_bytes-par_tx_bytes_port_5,00 00 00 00 19 BD CA AF,
ENG254810-ENG256154,SEC_tx_bytes-par_tx_bytes_port_6,00 00 00 00 00 00 00 00,
ENG254810-ENG256155,SEC_tx_bytes-par_tx_bytes_port_7,00 00 00 00 00 00 00 00,
ENG254811-ENG256156,SEC_tx_frames-par_tx_frames_port_2,00 00 00 00 00 00 00 00,
ENG254811-ENG256157,SEC_tx_frames-par_tx_frames_port_3,00 00 00 00 00 00 00 00,
ENG254811-ENG256158,SEC_tx_frames-par_tx_frames_port_4,00 00 00 00 00 32 BA C4,
ENG254811-ENG256159,SEC_tx_frames-par_tx_frames_port_5,00 00 00 00 00 1A 84 55,
ENG254811-ENG256160,SEC_tx_frames-par_tx_frames_port_6,00 00 00 00 00 00 00 00,
ENG254811-ENG256161,SEC_tx_frames-par_tx_frames_port_7,00 00 00 00 00 00 00 00,
Elapsed Time: 01:19
datodaco
Slovenia
C?ID=393757
blockmap-22-5WA-907-554-H_WV2ZZZSK8SX116493-20260803-1936.CSV
;SW:5WA-907-554-H   HW:5WA-525-130 ---  22: AWD
;Component:4Motion       H66 1060, Coding:0001
;EV_AllWheelContrHA1VW37X,006001,EV_AllWheelContrHA1VW37X_006_AU38.rod
;Monday,03,August,2026,19:36:49:29755
;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0
;VCID: 53F37964AB720B22329-8006
Group,Description,Actual
IDE00019,Voltage terminal 30,13.7, V
IDE00102,Control Module temperature,48, °C
IDE00920,Front left wheel speed,0.0, km/h
IDE00921,Wheel speed: right front,0.0, km/h
IDE00922,Left rear wheel speed,0.0, km/h
IDE00923,Right rear wheel speed,0.0, km/h
IDE01617,Clutch temperature,185.50, °C
IDE02271-IDE02384,CAN output signal(s) status-Status of event memory,active,
IDE02271-MAS01464,CAN output signal(s) status-Emergency running mode,active,
IDE02271-MAS01480,CAN output signal(s) status-excessive temperature,not active,
IDE02404,Checksum calculation,94 17 DD 30,
IDE04502-MAS04730,Haldex clutch: status-Degree of blockage,0.00, %
IDE05609,Cooling fin temperature,42.14, °C
IDE05610,Duration of overtemperature,0, min
IDE05707,Haldex clutch pump: current,0.000, A
IDE05708,Haldex clutch pump: PWM signal,53, %
IDE05710,Haldex clutch pump: voltage,0.0, V
IDE06111,Axle speed deltas,0.0, km/h
IDE80003-ENG119372,Analysis 3-Exeedance_Intergral_1_traction_slip_controller,53,
IDE80003-ENG119373,Analysis 3-Exeedance_Intergral_2_extreme_slip_event,87,
IDE80003-ENG119374,Analysis 3-Undercut_Integral_3_differential_lock_too_far_closed,65,
IDE80004-ENG119372,Analysis 4-Exeedance_Intergral_1_traction_slip_controller,53,
IDE80004-ENG119373,Analysis 4-Exeedance_Intergral_2_extreme_slip_event,87,
IDE80004-ENG119374,Analysis 4-Undercut_Integral_3_differential_lock_too_far_closed,65,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,36,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,20,
MAS03129,Reset counter,6,
ENG119394-ENG119379,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_EEPROM,2970,
ENG119394-ENG119380,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_Last_Measurement,1085,
ENG119394-ENG119378,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Pressure_EEPROM,195,
ENG119394-ENG119381,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_EEPROM,389,
ENG119394-ENG119382,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_Last_Measurement,2939,
ENG119394-ENG119384,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_EEPROM,2366,
ENG119394-ENG119385,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_Interpolation,2806,
ENG119394-ENG119383,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Pressure_EEPROM,7186,
ENG119394-ENG119386,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_EEPROM,6848,
ENG119394-ENG119387,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_Interpolation,10607,
ENG119394-ENG119389,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_EEPROM,6100,
ENG119394-ENG119390,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_Last_Measurement,19455,
ENG119394-ENG119388,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Pressure_EEPROM,4077,
ENG119394-ENG119391,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_EEPROM,6474,
ENG119394-ENG119392,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_Last_Measurement,16464,
ENG119394-ENG119377,Pump_Calibration_Values-Series_Number_Pump,,
ENG119394-ENG119376,Pump_Calibration_Values-Temperature_Value_at_Calibration,31109, °C
ENG119375,Upper Limit of Temperature Duration,0, min
Elapsed Time: 00:03
blockmap-42-3WA-959-393-A_WV2ZZZSK8SX116493-20260803-1937.CSV
;SW:3WA-959-393-A   HW:3WA-959-393 ---  42: Door Elect, Driver
;Component:TSG FS        001 0222, Coding:00208320C000000100001020
;EV_DCU4DriveSideMAXHKLO,001016,
;Monday,03,August,2026,19:37:34:29755
;VCID: 52FD7C609468022A39F-8006 SFD+SFD2 {x}
Elapsed Time: 00:00
blockmap-44-5QS-907-146-D_WV2ZZZSK8SX116493-20260803-1937.CSV
;SW:5QS-907-146-D   HW:5QS-907-146 ---  44: Steering Assist
;Component:BASGEN1MQB37  263 2122, Coding:00000000000000000001020101000100000001010101
;EV_SteerAssisBASGEN1MQB37,017078,EV_SteerAssisBASGEN1MQB37_017.rod
;Monday,03,August,2026,19:37:40:29755
;VCID: 58E98E48B294287AC7B-800C SFD+SFD2 { }
IDE00019,Voltage terminal 30,13.81, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,981, /min
IDE00323-IDE01022,Security Access: Number of invalid keys-Counter: incorrect inputs of key-code,45,
IDE00323-MAS01155,Security Access: Number of invalid keys-Control module,Unknown (45)
IDE00323-MAS02913,Security Access: Number of invalid keys-Remaining running time,11565,
IDE02202,End stage temperature,58, °C
IDE02955,System status,Driving mode,
IDE03214,Engine stop using start-stop function,not met,
IDE03682-IDE04457,motor position sensor-Speed of electric drive motor,-18000.1, /min
IDE03682-MAS02961,motor position sensor-Engine angle,26, °
IDE03726-IDE02955,Parallel Parking Assistance-System status,inactive,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,1.93715e-005, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,6374.4, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not active,
IDE03735,Steering torque,0.0, Nm
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,0.0, °
IDE04118-MAS03095,Straight line running correction-Function status,active,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,0.0, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03095,Active default-Function status,active,
IDE04119-MAS03738,Active default-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,0.0, Nm
IDE04184,Steering assistance: engine output,100, %
IDE04448,Steering angle sensor: angle,26.6, °
IDE04454,Steering angle sensor: angle speed,0, °/s
IDE04458,Steering angle sensor: mechanical steering stroke,160.7, mm
IDE04459,Steering angle sensor: offset index mark mechanical middle,235, mm
IDE04460,Steering angle sensor: offset straight line running,2.6, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,detected,
IDE04765-IDE02955,Counter steer support-System status,Function is not active,
IDE04765-MAS02974,Counter steer support-Target force,0, N
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,6533.5, Nm
IDE04765-MAS14021,Counter steer support-Steering recommendation: correcting torque offset,0.0, Nm
IDE04805-IDE02955,Driving profile selection-System status,00,
IDE04805-IDE06011,Driving profile selection-Selected driving profile,00,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,Deceleration,
IDE04805-MAS01447,Driving profile selection-Actual value,no function,
IDE04805-MAS01448,Driving profile selection-Specified value,Unknown (255)
IDE04805-MAS03095,Driving profile selection-Function status,00,
IDE04805-MAS05058,Driving profile selection-Compatibility,00,
IDE05155,Power steering current consumption,0.0, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05162-MAS11513,Software end stop-End stop left,80.29, mm
IDE05162-MAS11514,Software end stop-End stop right,-80.51, mm
IDE05162-MAS12179,Software end stop-Validation of end stops: left and right,Condition met,
IDE05162-MAS12180,Software end stop-Validation of end stops: steering stroke,Condition met,
IDE05162-MAS12181,Software end stop-Validation of end stops: center,Condition not met,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS04460,Network diagnosis-Validity,No,
IDE05713-MAS06528,Network diagnosis-Release status,No,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,4294967295,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,4294967295,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,4294967295,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,4294967295,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,4294967295,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,4294967295,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,4294967295,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,4294967295,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,4294967295,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,4294967295,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,4294967295,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,4294967295,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,4294967295,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,4294967295,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,4294967295,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,4294967295,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,4294967295,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,4294967295,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,4294967295,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,4294967295,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,4294967295,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,4294967295,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,4294967295,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,4294967295,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,4294967295,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,4294967295,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,4294967295,
IDE05994-ENG139218,Engine specified torque load-10_to_11_kilo_newton,4294967295,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,4294967295,
IDE05994-ENG139219,Engine specified torque load--11_to_-10_kilo_newton,4294967295,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,4294967295,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,4294967295,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,4294967295,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,4294967295,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,4294967295,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,4294967295,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,4294967295,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,4294967295,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,4294967295,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,4294967295,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,4294967295,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,4294967295,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,4294967295,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,4294967295,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,4294967295,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,4294967295,
IDE05994-ENG161314,Engine specified torque load-above_11_kilo_newton,4294967295,
IDE05994-ENG161479,Engine specified torque load-below_-11_kilo_newton,4294967295,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,4294967295,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,4294967295,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,4294967295,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,4294967295,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,4294967295,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,4294967295,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,4294967295,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,4294967295,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,4294967295,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,4294967295,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,4294967295,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,4294967295,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,4294967295,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,4294967295,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,4294967295,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,4294967295,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,4294967295,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,4294967295,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,4294967295,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,4294967295,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,4294967295,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,4294967295,
IDE06678-MAS03000,Pull compensation-Adaptation value,-1200, N
IDE06678-MAS03095,Pull compensation-Function status,not active,
IDE07399-MAS00966,Engine type-Manufacturer index location,LZE,
IDE07399-MAS01466,Engine type-Direction of rotation,Positive,
IDE07399-MAS06614,Engine type-Variant,MQB37AW_iconst_10.5kN_AP,
IDE07399-MAS06742,Engine type-Certificate type,Series,
IDE07399-MAS09595,Engine type-Production mode,End-of-line test ended,
IDE07399-MAS12093,Engine type-Sensors,Volkswagen AG,
IDE07399-MAS12535,Engine type-Test stand mode,End-of-line test ended,
IDE07399-MAS13709,Engine type-Engine variant,M39P_Bosch_MQB37W_BSapa,
IDE07399-ENG276781,Engine type-SOK Activation State,not active,
IDE07543,Vehicle speed,0, km/h
IDE10300,OBD Driving Cycle detected,active,
IDE11591-IDE11629,Result of basic setting of steering angle-Status of the active routine,Finish routine: routine OK,
IDE11591-MAS05584,Result of basic setting of steering angle-Result,Preconditions met,
IDE11591-MAS14036,Result of basic setting of steering angle-Number of iterations,2,
IDE11591-MAS14037,Result of basic setting of steering angle-RESTRICTION,no restriction,
IDE11591-MAS14038,Result of basic setting of steering angle-Type of restriction,Precondition,
IDE11602-IDE11629,Result of steering angle sensor: initialization-Status of the active routine,Finish routine: routine OK,
IDE11602-MAS05584,Result of steering angle sensor: initialization-Result,Preconditions met,
IDE11602-MAS14036,Result of steering angle sensor: initialization-Number of iterations,2,
IDE11602-MAS14037,Result of steering angle sensor: initialization-RESTRICTION,no restriction,
IDE11602-MAS14038,Result of steering angle sensor: initialization-Type of restriction,Precondition,
IDE11603-IDE11629,Result of steering angle sensor: move to mechanical center-Status of the active routine,Finish routine: routine OK,
IDE11603-MAS05584,Result of steering angle sensor: move to mechanical center-Result,Preconditions met,
IDE11603-MAS14036,Result of steering angle sensor: move to mechanical center-Number of iterations,2,
IDE11603-MAS14037,Result of steering angle sensor: move to mechanical center-RESTRICTION,no restriction,
IDE11603-MAS14038,Result of steering angle sensor: move to mechanical center-Type of restriction,Precondition,
IDE11604-IDE11629,Result of steer.angle sens.: zero calibr.steer.wheel balance-Status of the active routine,Finish routine: routine OK,
IDE11604-MAS05584,Result of steer.angle sens.: zero calibr.steer.wheel balance-Result,Pre-conditions not fulfilled,
IDE11604-MAS14036,Result of steer.angle sens.: zero calibr.steer.wheel balance-Number of iterations,2,
IDE11604-MAS14037,Result of steer.angle sens.: zero calibr.steer.wheel balance-RESTRICTION,Cancellation by user,
IDE11604-MAS14038,Result of steer.angle sens.: zero calibr.steer.wheel balance-Type of restriction,Precondition,
IDE11605-IDE11629,Result of resetting of all adaptation values-Status of the active routine,Finish routine: routine OK,
IDE11605-MAS05584,Result of resetting of all adaptation values-Result,Preconditions met,
IDE11605-MAS14036,Result of resetting of all adaptation values-Number of iterations,2,
IDE11605-MAS14037,Result of resetting of all adaptation values-RESTRICTION,no restriction,
IDE11605-MAS14038,Result of resetting of all adaptation values-Type of restriction,Precondition,
IDE11606-IDE11629,Result of resetting of all adjustments-Status of the active routine,Finish routine: routine OK,
IDE11606-MAS05584,Result of resetting of all adjustments-Result,Preconditions met,
IDE11606-MAS14036,Result of resetting of all adjustments-Number of iterations,2,
IDE11606-MAS14037,Result of resetting of all adjustments-RESTRICTION,no restriction,
IDE11606-MAS14038,Result of resetting of all adjustments-Type of restriction,Precondition,
IDE11607-IDE11629,Result of resetting all software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11607-MAS05584,Result of resetting all software end-stops-Result,Preconditions met,
IDE11607-MAS14036,Result of resetting all software end-stops-Number of iterations,2,
IDE11607-MAS14037,Result of resetting all software end-stops-RESTRICTION,no restriction,
IDE11607-MAS14038,Result of resetting all software end-stops-Type of restriction,Precondition,
IDE11608-IDE11629,Result of resetting to factory setting-Status of the active routine,Finish routine: routine OK,
IDE11608-MAS05584,Result of resetting to factory setting-Result,Preconditions met,
IDE11608-MAS14036,Result of resetting to factory setting-Number of iterations,2,
IDE11608-MAS14037,Result of resetting to factory setting-RESTRICTION,no restriction,
IDE11608-MAS14038,Result of resetting to factory setting-Type of restriction,Precondition,
IDE11609-IDE11629,Result of steering angle sensor: software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11609-MAS05584,Result of steering angle sensor: software end-stops-Result,Preconditions met,
IDE11609-MAS14036,Result of steering angle sensor: software end-stops-Number of iterations,2,
IDE11609-MAS14037,Result of steering angle sensor: software end-stops-RESTRICTION,no restriction,
IDE11609-MAS14038,Result of steering angle sensor: software end-stops-Type of restriction,Precondition,
IDE11863,Support power reduction,100.0, %
IDE11865-IDE00021,Reason for engagement steering support-Engine speed,Met,
IDE11865-IDE00075,Reason for engagement steering support-Vehicle speed,not met,
IDE11865-MAS01737,Reason for engagement steering support-Diagnosis,not met,
IDE11865-MAS08112,Reason for engagement steering support-Drive readiness,not met,
MAS01172-MAS01156,Development messages-Communication status,Stop,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS01891-IDE02955,Lane departure warning-System status,inactive,
MAS01891-MAS03095,Lane departure warning-Function status,not active,
MAS01891-MAS03368,Lane departure warning-Steering wheel vibration,not active,
MAS01891-MAS05054,Lane departure warning-Steering torque request: lane retention assistant,6543.5, Nm
MAS01891-MAS12816,Lane departure warning-Lane assistant: direct access power,0, N
MAS01891-MAS12817,Lane departure warning-Lane assistant: steering wheel vibration force,0, N
MAS01891-MAS12818,Lane departure warning-Lane assistant: overlay torque,0.0, Nm
MAS02126-IDE05744,Steering angle sensor: status-Steering angle sensor: initialization,initialized,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,invalid,
MAS02126-MAS10118,Steering angle sensor: status-Steering angle sensor: status of calibration,calibrated,
MAS08112,Drive readiness,not active,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,36 minutes,
ENG276385-ENG276657,Alteration_calculation_data-Damage Counter raw,00 00 88 73 7B EB 2A A1,
ENG276385-ENG276693,Alteration_calculation_data-Dmage Counter %,00,
ENG157548-MAS00976,Angle_estimator-Counter,0,
ENG157548-ENG163894,Angle_estimator-Symmetry_angle_a,1.52588e-005, °
ENG157548-ENG163895,Angle_estimator-Symmetry_angle_b,1.52588e-005, °
ENG157548-ENG163896,Angle_estimator-Symmetry_angle_offset,1.52588e-005, °
ENG157548-ENG163897,Angle_estimator-Symmetry_calculated_angle,-1024, °
ENG157548-ENG163898,Angle_estimator-Symmetry_learning_status,Not adapted,
ENG157712,Current_gradient_limiting,12.0, %
ENG157713,Current_limiting,0.0, %
Elapsed Time: 00:07
blockmap-52-3WA-959-392-A_WV2ZZZSK8SX116493-20260803-1937.CSV
;SW:3WA-959-392-A   HW:3WA-959-392 ---  52: Door Elect, Pass.
;Component:TSG BFS       001 0222, Coding:00200120C000000100001020
;EV_DCU4PasseSideMAXHKLO,001016,
;Monday,03,August,2026,19:37:57:29755
;VCID: 51FF736C916E7932005-8004 SFD+SFD2 {x}
Elapsed Time: 00:00
blockmap-5F-2K7-035-869-A_WV2ZZZSK8SX116493-20260803-1938.CSV
;SW:2K7-035-869-A   HW:2K7-035-869-A ---  5F: Information Electr.
;Component:MU-E-D-EU     065 0176, Coding:63521006000020000000000000000000000000000000000000
;EV_MUEIGPMQB37w,001001,
;Monday,03,August,2026,19:38:03:29755
;VCID: 34311AF80EBC2C1A0B3-8060 SFD+SFD2 {x}
Elapsed Time: 00:00
blockmap-75-571-035-284-B_WV2ZZZSK8SX116493-20260803-1938.CSV
;SW:571-035-284-B   HW:571-035-284 ---  75: Telematics
;Component:OCUMQBW2023_H H09 0626, Coding:06010601020000110000000013002607111012111012000010
;EV_OCUMWB2023,001066,
;Monday,03,August,2026,19:38:07:29755
;VCID: 1577C77C6506D5121CD-8040 SFD+SFD2 {x}
Elapsed Time: 00:00
blockmap-A5-5WA-980-653-F_WV2ZZZSK8SX116493-20260803-1938.CSV
;SW:5WA-980-653-F   HW:5WA-980-653-A ---  A5: Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H12 3609, Coding:0001089001484040409E08001000002000018048600000000000000000000000
;EV_MFK3ValeoMQB,005071,EV_MFK3ValeoMQB_005_VN3S.rod
;Monday,03,August,2026,19:38:13:29755
IDE00018,Voltage terminal 15,13.9, V
IDE00767,No. of unscheduled ECU resets,0,
IDE00973,Outside temperature,34.5, °C
IDE01968,Dynamic calibration: yaw angle offset,1.530, °
IDE01969,Dynamic calibration: pitch angle offset,-1.961, °
IDE01970,Dynamic calibration: roll angle offset,2.079, °
IDE01971,Lowest recorded control module temperature,-13, °C
IDE01972,Highest recorded control module temperature,80, °C
IDE01974-MAS01167,Steering wheel vibration-Actuation time,0 s,
IDE01974-MAS08863,Steering wheel vibration-Status of actuator test,Output diagnostic test not active,
IDE02007-MAS01167,Yellow indicator light for directional stabilization assistance-Actuation time,0 s,
IDE02007-MAS08863,Yellow indicator light for directional stabilization assistance-Status of actuator test,Output diagnostic test not active,
IDE02008-MAS01167,Green indicator light for directional stabilization assistance-Actuation time,0 s,
IDE02008-MAS08863,Green indicator light for directional stabilization assistance-Status of actuator test,Output diagnostic test not active,
IDE02009-MAS01167,Directional stabilization assistance display-Actuation time,0 s,
IDE02009-MAS08863,Directional stabilization assistance display-Status of actuator test,Output diagnostic test not active,
IDE02057,Dynamic calibration: status,Passive values stored,
IDE02608-MAS01167,Window defogger for front sensor system-Actuation time,0 s,
IDE02608-MAS08863,Window defogger for front sensor system-Status of actuator test,Output diagnostic test not active,
IDE03222-MAS02534,Blindness detection-Clear view,Yes,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS17450,Blindness detection-Blindness: space detection,No,
IDE03222-MAS17452,Blindness detection-Windshield heater blindness request,No,
IDE03222-MAS17453,Blindness detection-Clear view currently detected,Yes,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,3006, km
IDE03948-MAS01167,High beam recommendation-Actuation time,0 s,
IDE03948-MAS08863,High beam recommendation-Status of actuator test,Output diagnostic test not active,
IDE04036-MAS01632,High beam assistant: status-Status,not active,
IDE04036-MAS17492,High beam assistant: status-Switching state,OFF,
IDE04036-MAS17493,High beam assistant: status-Sensor view,Not assigned,
IDE04036-MAS17494,High beam assistant: status-Higher sensitivity active,No,
IDE04123-MAS01480,High beam: reason for shut-off-excessive temperature,No,
IDE04123-MAS06833,High beam: reason for shut-off-Ambient brightness too high,No,
IDE04123-MAS06846,High beam: reason for shut-off-Location detected,No,
IDE04123-MAS14875,High beam: reason for shut-off-Fog detected,No,
IDE04123-MAS17489,High beam: reason for shut-off-Oncoming vehicle detected,No,
IDE04123-MAS17490,High beam: reason for shut-off-Vehicle ahead detected,No,
IDE04123-MAS17491,High beam: reason for shut-off-Speed not achieved,Yes,
IDE04123,High beam: reason for shut-off,4,
IDE04123,High beam: reason for shut-off,0,
IDE04227,Directional stab. asst w/ pwr steering asst: steering status,Lane assist deactivated in steering,
IDE04229,Directional stab. asst w/ pwr steering asst: steering torque,-0.00, Nm
IDE04904-MAS01167,Traffic sign display in instrument cluster-Actuation time,0 s,
IDE04904-MAS08863,Traffic sign display in instrument cluster-Status of actuator test,Output diagnostic test not active,
IDE06592-MAS00478,Status: special functions-Reserved,00,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,used,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE07214,Dynamic calibration: camera height offset,25, mm
IDE07543,Vehicle speed,0.00, km/h
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,1023, m
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,1023, m
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,25.650001, °
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,25.650001, °
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,35.150001, °
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,35.150001, °
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,51.15, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,51.15, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,Not available,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,Not available,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,Not available,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,Not available,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Right hand driv.,
IDE09492-MAS11790,Temperatures-Control Module temperature,67, °C
IDE09492-MAS17447,Temperatures-Temperature of the EyeQ chip,74, °C
IDE09492-MAS17448,Temperatures-Temperature of the memory in the EyeQ chip,70, °C
IDE09492-MAS17449,Temperatures-High temperature shutdown,OFF,
IDE10220,Initial online calibration active,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,0.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,0.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,0.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,0.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.000, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,0.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.000, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,0.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,0.000, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,0.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1200, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,0.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0,
IDE10406-MAS00106,Last initial calibrations: details-Year,2025,
IDE10406-MAS00107,Last initial calibrations: details-Month,6,
IDE10406-MAS00108,Last initial calibrations: details-Day,9,
IDE10406-MAS00109,Last initial calibrations: details-Hours,20,
IDE10406-MAS00110,Last initial calibrations: details-Minutes,51,
IDE10406-MAS00111,Last initial calibrations: details-Seconds,56,
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2025,
IDE10664-MAS00107,Current initial calibration: details-Month,6,
IDE10664-MAS00108,Current initial calibration: details-Day,9,
IDE10664-MAS00109,Current initial calibration: details-Hours,20,
IDE10664-MAS00110,Current initial calibration: details-Minutes,51,
IDE10664-MAS00111,Current initial calibration: details-Seconds,56,
IDE10664-MAS00711,Current initial calibration: details-kilometer reading,0,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,WV2ZZZSK8SX116493,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10924-MAS02479,Initial calibration: result-Yaw angle,-0.290, °
IDE10924-MAS05286,Initial calibration: result-Roll angle,0.301, °
IDE10924-MAS05287,Initial calibration: result-Pitch angle,-0.073, °
IDE10924-MAS10678,Initial calibration: result-Camera height,1496, mm
IDE11752-ENG277500,IP network: IPv6-addresses-Ip_ipv6_addresses_list,|Param to DOP_24662|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 4F|, hex
IDE11753-ENG277501,IP network: IPv6-multicast-addresses-Ip_ipv6_multicast_addresses_list,|IPv6 Multicast address|FF 14 00 00 00 00|00 00 00 00 00 00|00 00 00 0B 00 00|, hex
IDE11755-ENG277505,IP network: VLANs-Ip_vlans_list,|VLAN|2|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,1,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,1,
IDE11761-ENG277502,IP network: MAC addresses-Ip_mac_addresses_list,|MAC address|74 90 50 00 00 00|, hex
IDE11869-ENG277503,IP network: NDP cache-Ip_ndp_cache_list,|MAC address,IPv6 address
IDE11988-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 1-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|74 90 50 00 00 00|00 00 00 00 00 00|00 00 00 0B FC 57|56 32 5A 5A 5A 53|4B 38 53 58 31 31|36 34 39 33 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11989-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 2-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11990-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 3-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11991-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 4-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11992-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 5-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11993-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 6-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11994-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 7-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11995-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 8-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE12230-ENG277505,IP network: VLANs of Ethernet switch ports branch 1-Ip_vlans_list,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE12231-ENG277505,IP network: VLANs of Ethernet switch ports branch 2-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12232-ENG277505,IP network: VLANs of Ethernet switch ports branch 3-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12233-ENG277505,IP network: VLANs of Ethernet switch ports branch 4-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12234-ENG277505,IP network: VLANs of Ethernet switch ports branch 5-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12235-ENG277505,IP network: VLANs of Ethernet switch ports branch 6-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12236-ENG277505,IP network: VLANs of Ethernet switch ports branch 7-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12237-ENG277505,IP network: VLANs of Ethernet switch ports branch 8-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12238,I network: discarded messages counter,0,
IDE12239-ENG277504,IP network: test feedback value of communications relationships-Ip_return_value_test_communication_connection,|IPv6 address,Result|02 FD 53 7C B8 03 83 02 00 00 00 00 00 00 00 00
IDE12625,IP network: current link deceleration: branch 1,0, µs
IDE12626,IP network: current link deceleration: branch 2,0, µs
IDE12627,IP network: current link deceleration: branch 3,0, µs
IDE12628,IP network: current link deceleration: branch 4,0, µs
IDE12629,IP network: current link deceleration: branch 5,0, µs
IDE12630,IP network: current link deceleration: branch 6,0, µs
IDE12631,IP network: current link deceleration: branch 7,0, µs
IDE12632,IP network: current link deceleration: branch 8,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,Not available,
IDE13994-MAS17458,Intrinsic calibration: result-Main point x,634.90, px
IDE13994-MAS17463,Intrinsic calibration: result-Main point y,533.57, px
IDE13994-MAS17464,Intrinsic calibration: result-Focal length x,1462.62, px
IDE13994-MAS17465,Intrinsic calibration: result-Focal length y,1462.62, px
IDE13994-MAS17466,Intrinsic calibration: result-Distortion in k1,-0.000468891,
IDE13994-MAS17467,Intrinsic calibration: result-Distortion in k2,-0.000363679,
IDE13994-MAS17468,Intrinsic calibration: result-Distortion in k3,-0.000638848,
IDE13994-MAS17469,Intrinsic calibration: result-Distortion in t1,-0.000000000,
IDE13994-MAS17470,Intrinsic calibration: result-Distortion in t2,-0.000000000,
IDE13994-MAS17471,Intrinsic calibration: result-Gamma,1.00,
IDE13994-MAS17472,Intrinsic calibration: result-Incline,0.00, px
IDE13995-MAS08824,Calibration target position: stored values-Target 1: calibration mark 1: x-coordinate,2397.75, mm
IDE13995-MAS08825,Calibration target position: stored values-Target 1: calibration mark 1: y-coordinate,732.50, mm
IDE13995-MAS08826,Calibration target position: stored values-Target 1: calibration mark 1: z-coordinate,1694.00, mm
IDE13995-MAS08827,Calibration target position: stored values-Target 1: calibration mark 2: x-coordinate,2397.75, mm
IDE13995-MAS08828,Calibration target position: stored values-Target 1: calibration mark 2: y-coordinate,-732.50, mm
IDE13995-MAS08829,Calibration target position: stored values-Target 1: calibration mark 2: z-coordinate,1694.00, mm
IDE13995-MAS08830,Calibration target position: stored values-Target 1: calibration mark 3: x-coordinate,2397.75, mm
IDE13995-MAS08831,Calibration target position: stored values-Target 1: calibration mark 3: y-coordinate,732.50, mm
IDE13995-MAS08832,Calibration target position: stored values-Target 1: calibration mark 3: z-coordinate,1106.00, mm
IDE13995-MAS08833,Calibration target position: stored values-Target 1: calibration mark 4: x-coordinate,2397.75, mm
IDE13995-MAS08834,Calibration target position: stored values-Target 1: calibration mark 4: y-coordinate,-732.50, mm
IDE13995-MAS08835,Calibration target position: stored values-Target 1: calibration mark 4: z-coordinate,1106.00, mm
IDE13996-IDE05717,Axle offset: stored values-Front axle transverse position,5.5, mm
IDE13996-IDE05718,Axle offset: stored values-Rear axle transverse position,6.9, mm
IDE13997-IDE02001,Body height to wheel house edge: stored values-Body height left front wheel house edge,715.00, mm
IDE13997-IDE02002,Body height to wheel house edge: stored values-Body height right front wheel house edge,721.00, mm
IDE13997-IDE02003,Body height to wheel house edge: stored values-Body height left rear wheel house edge,746.00, mm
IDE13997-IDE02004,Body height to wheel house edge: stored values-Body height right rear wheel house edge,752.00, mm
IDE13998,Distance to calibration field: stored values,1500.00, mm
IDE14000,Windshield defogger camera: activation status,OFF,
MAS01634-MAS09193,Supply voltage-PLA,13.8, V
MAS01634-MAS17440,Supply voltage-Supply voltage 1V0,1.0, V
MAS01634-MAS17441,Supply voltage-Supply voltage 1V1,1.0, V
MAS01634-MAS17442,Supply voltage-Supply voltage 1V2,0.0, V
MAS01634-MAS17443,Supply voltage-Supply voltage 1V25,1.2, V
MAS01634-MAS17444,Supply voltage-Supply voltage 1V8,1.7, V
MAS01634-MAS17445,Supply voltage-Supply voltage 3V3,3.2, V
MAS01634-MAS17446,Supply voltage-Supply voltage 5V0,4.9, V
MAS11502-MAS10691,Self-glare recognition-Self-glare quality,0, %
MAS11502-MAS11503,Self-glare recognition-Self-glare status,active,
MAS11502-MAS15965,Self-glare recognition-Glare detected,No,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17473,Functional state and lane boundary information,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 0E 0F 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,2,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS19593-MAS01167,Upload for expanded static navigation data activation-Actuation time,0 s,
MAS19593-MAS08863,Upload for expanded static navigation data activation-Status of actuator test,Output diagnostic test not active,
MAS19594-MAS01167,Upload for expanded dynamic navigation data activation-Actuation time,0 s,
MAS19594-MAS08863,Upload for expanded dynamic navigation data activation-Status of actuator test,Output diagnostic test not active,
ENG152732-MAS06854,CRC32 Checksum of FAZIT Identification String-Version,81,
ENG152732-MAS06855,CRC32 Checksum of FAZIT Identification String-Test sum,DB 01 77 4E,
ENG347809,Current_ELKS_Failure_State,ELKS_no_Failure,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,2,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,2,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902-ENG247044,Function_On_Demand_Freischalt_ID_Status_Dev-Function_On_Demand_Freischalt_ID_Status,|Authentication,Functions
ENG106922,Immobilizer - Challenge,B9 30 D4 04,
ENG185847-MAS01167,Light_assist_blockage_detection-Actuation time,0 s,
ENG185847-MAS08863,Light_assist_blockage_detection-Status of actuator test,Output diagnostic test not active,
ENG185858-MAS01167,Light_assist_self_glare_detection-Actuation time,0 s,
ENG185858-MAS08863,Light_assist_self_glare_detection-Status of actuator test,Output diagnostic test not active,
ENG185848-MAS01167,Main_beam_defect_message-Actuation time,0 s,
ENG185848-MAS08863,Main_beam_defect_message-Status of actuator test,Output diagnostic test not active,
ENG251654-MAS01167,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Actuation time,0 s,
ENG251654-MAS08863,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Status of actuator test,Output diagnostic test not active,
ENG251655-MAS01167,REM_Static_EyeQ_Data_Test_Trigger_status-Actuation time,0 s,
ENG251655-MAS08863,REM_Static_EyeQ_Data_Test_Trigger_status-Status of actuator test,Output diagnostic test not active,
ENG185865-MAS01167,SAE_mode_activation-Actuation time,0 s,
ENG185865-MAS08863,SAE_mode_activation-Status of actuator test,Output diagnostic test not active,
ENG370415-ENG370815,VZE_Codierung-Regulierung,ISA_Level_1,
ENG370415-ENG391890,VZE_Codierung-Verkaufsland,EU_27_Country,
ENG158350-ENG135053,VZE_GetVersion-GetVersion,859189305,
ENG370416-ENG370975,VZE_Monitoring-VZE_monitoring_001,402781,
ENG370416-ENG370976,VZE_Monitoring-VZE_monitoring_002,0,
ENG370416-ENG370977,VZE_Monitoring-VZE_monitoring_003,34943,
ENG370416-ENG370978,VZE_Monitoring-VZE_monitoring_004,0,
ENG370416-ENG370979,VZE_Monitoring-VZE_monitoring_005,193809,
ENG370416-ENG370980,VZE_Monitoring-VZE_monitoring_006,0,
ENG370416-ENG370981,VZE_Monitoring-VZE_monitoring_007,10436,
ENG370416-ENG370982,VZE_Monitoring-VZE_monitoring_008,0,
ENG370416-ENG370983,VZE_Monitoring-VZE_monitoring_009,0,
Elapsed Time: 00:46
blockmap-OBD_WV2ZZZSK8SX116493-20260803-1939.CSV
;33-OBD2
;Monday,03,August,2026,19:39:23:29755
;VCID: 55F7877CAC061512DCD-8000
04,Calculated load value,24.3 %
05,Engine coolant temperature,87 °C
0C,Engine RPM,979 /min
0D,Vehicle speed,0 km/h
0F,Intake air temperature,49 °C
10,Mass Air Flow,8.41 g/s
11,Absolute Throttle Position,23.5 %
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,1267 s
21,Distance travelled with MIL on,0 km
2F,Fuel Level Input,14.9 %
30,Warm-ups since DTC cleared,0
31,Distance since DTC cleared,0 km
33,Barometric pressure,98 kPa abs
42,Control module voltage,13.700 V
45,Relative Throttle Position,12.9 %
46,Ambient Air Temp,34 °C
49,Accelerator Pedal Position D,14.1 %
4A,Accelerator Pedal Position E,14.1 %
4C,Commanded Throttle Actuator Control,13.3 %
51,Fuel type,Diesel
5C,Engine Oil Temp,85 °C
5E,Engine Fuel Rate,0.70 L/h
61,Torque Driver's Request,2.0 %
62,Torque actual,9.0 %
63,Torque Reference,320 Nm
65,Auxiliary Input/Output,GEAR_RCMD: N
67,Engine Coolant Temp,ECT 1:87 °C
69,EGR Command/Actual/Error,EGR A:35/35/0 %,EGR B:14/14/2 %
6B,EGR Temperature,EGRTemp 11/12:---/88 °C,EGRTemp 21/22:---/--- °C
6D,Fuel Press. Control A/B,FRP CMD:27940/--- kPa,FRP ACT:28130/--- kPa
70,Boost Press Ctrl A/B,BP_A cmd/act:99.3/92.0 kPa
71,Var. Geom. Turb. Ctrl A/B,VGT_A cmd/act:75.7/75.7 %,VGT_B cmd/act:---/--- %
77,Charge Air Temp.,B1S1/B1S2:64/50 °C
78,EGT B1-S1-4,S1/S2/S3/S4:,178/170/170/158 °C
7A,DPF Bank 1 Delta/In/Out,1.05/---/--- kPa
7F,Engine Run Time,Total:253H2705s,Idle:38H1322s
83,NOx Sensor Bank 1/2,NOx11:89 ppm,NOx21:15 ppm
85,NOx Control System,ReAg Rate/Demand:0.0/0.03 L/h,Reag Tnk Lvl:58.0 %
8B,Aftertreatment status,PF_Regen:Status:N,Typ:Pass.
8C,O2 sensor wide range,4.658 lbd,4.498 lbd
8E,Eng. friction %torque,6.0 %
8F,PM sensor output,B1S1:ACT:YES;REGN:NO,B1S1:0.00 %
9B,DEF sensor,conc. N/A,DEF_CON:  %
9C,O2 sensor wide range,4.541 lbd,4.541
9D,Fuel rate,Engine: 0.16 g/s,Vehicle: 0.16 g/s
9E,Exhaust flow rate,40.4 kg/h
A2,Cyl. fuel rate,4.00 mg/str
A4,Transm gear,N
A6,Odometer,12005.0 km
Type 02 - VIN : WV2ZZZSK8SX116493 (Address 01)
Type 04 - Calibration ID : 05L023QK4626BEAEHCUBDD0032291000NOX00907807 003ENOX00907807 003FNOX00907807 003EPMS00906261 1100 (Address 01)
Type 06 - Calibration Verification Number : 520B730B (Address 01)
Type 06 - Calibration Verification Number : 10A70AD2 (Address 01)
Type 06 - Calibration Verification Number : 89980D21 (Address 01)
Type 06 - Calibration Verification Number : 252F1ED3 (Address 01)
Type 06 - Calibration Verification Number : 45690194 (Address 01)
Type 0A - Controller Name : ECM-EngineControl (Address 01)
Type 0B - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 180
    Ignition cycle count : 1777
         NMHC Catalyst : 100 / 14
         NOx/SCR Catalyst : 446 / 180
         NOx Adsorber : 0 / 0
         PM Filter : 84 / 14
         Exhaust Gas Sensor : 162 / 180
         EGR and/or VVT : 431 / 180
         Boost Pressure : 706 / 180
         Fuel : 1057 / 180
Type 17 - Vehicle Operation Data - Distance-Fuel Used, Recent/Lifetime:
         Total Distance Traveled : -0.1 km / 12003.4 km
         Total Fuel Consumed : -0.01 L / 885.28 L
datodaco
Slovenia
C?ID=393757
AutoScan: WV2ZZZSK8SX116493
Monday,03,August,2026,19:50:33:29755VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64VCDS Version: 26.7.1.0 (x64)  HEX-V2 CB: 0.4713.4Data version: 20260708 DS378.0www.Ross-Tech.comVIN: WV2ZZZSK8SX116493   License Plate: Chassis Type: SK-VN3SP PA* (5QS)Scan: 01 03 08 09 10 13 15 17 19 22 23 42 44 52 5F 75 A5 C002 C003VIN: WV2ZZZSK8SX116493   Mileage: 12004km-7458miles01-Engine -- Status: Malfunction 001003-ABS Brakes -- Status: Malfunction 001008-Auto HVAC -- Status: OK 000009-Cent. Elect. -- Status: OK 000010-Park/Steer Assist -- Status: OK 000013-Auto Dist. Reg -- Status: Malfunction 001015-Airbags -- Status: Malfunction 001017-Instruments -- Status: Malfunction 001019-CAN Gateway -- Status: Malfunction 001022-AWD -- Status: Malfunction 001023-Brake Booster -- Status: Malfunction 001042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: OK 000052-Door Elect, Pass. -- Status: OK 00005F-Information Electr. -- Status: OK 000075-Telematics -- Status: OK 0000A5-Frt Sens. Drv. Assist -- Status: OK 0000-------------------------------------------------------------------------------Address 01: Engine (J623-DXRA)       Labels: None   Part No SW: 05L 906 023 QK    HW: 05L 907 309 AH   Component: R4 2.0l TDI   H80 4626     Revision: NEH80---    CVN: 520B730B10A70AD289980D21252F1ED389980D2145690194   Coding: 011900320326050920000000001000000000000000000000   Shop #: WSC 35110 377 00028   ASAM Dataset: EV_ECM20TDI01105L906023QK 010005   ROD: EV_ECM20TDI01105L906023QK.rod   VCID: 015F832C018E49B2D05-8054 SFD+SFD2 { }   VINID: 9E60AAAAA8DB223A010461090C6F2D7959   Heater for exhaust gas catalytic converter:   Flush-air pump:   Active oil separating system: 1 Fault Found:45417 - Vehicle Key Management System (VKMS)          U35DC 00 {00100110} - Key/Certificate Missing or Invalid          {Vehicle Key Management System (VKMS)Key/certificate missing or invalid}          Intermittent - Not Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 2                    Fault Frequency: 4                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:25:34                    Engine speed: 976.00 /min                    Normed load value: 25.9 %                    Vehicle speed: 0 km/h                    Coolant temperature: 90 °C                    Intake air temperature: 51 °C                    Ambient air pressure: 980 mbar                    Voltage terminal 30: 13.580 V                    Unlearning counter according OBD: 40                    Engine status: COENG_RUNNING                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3Readiness: 0 0 0 0 1 -------------------------------------------------------------------------------Address 03: ABS Brakes (J104)       Labels:. 5WA-614-517-V2.clb   Part No SW: 5WA 614 517 DQ    HW: 5WA 614 517 BS   Component: ESC           H31 0331     Serial number: 61425000005066  Dataset Number: V03935455DH 0001 CVN: 0D4105EC658B97A0   Coding: 4A985428B44B399C4001559E1EB7C1C50ACF942151A000   ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006026   ROD: EV_Brake1ESCMQB37WUNECE_006_VN3SP.rod   VCID: 1A6DD4408C18FA6A31F-804E SFD+SFD2 { }4 Faults Found:8231 - Implausible Data Received from Body Control Module (Central Electric)          U0422 00 {00100111} - -          {CCan_Klemmen_Status_01_Counter}          Not Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 2                    Fault Frequency: 4                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:25:34                    Vehlicle_speed: 0.0 km/h                    Resolution Mileage: 726 m                    Voltage_value_KL.30_ESC_V: 13.8 V                    Wake up EPB: not active                    Wake up CAN: not active                    Postrun_activ: not active                    Comparison_pressure_sensor: completed successfully                    Comparison_longitudinal_accleration: completed successfully                    Comparison_transverse_accleration: not completed successfully                    Comparison_yaw_rate_sensor: not completed successfully                    LWS_comparison: not completed successfully                    Internal_failure_code: 00 91                    00 02 00 00 04 0C 10 0A 40 00 00 00 80 00 00 40 30 00 21 00 0417216 - Implausible Data Received from Body Control Module (Central Electric)          U0422 00 {00100111} - -          {CCan_VLK_01_Counter}          Not Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 5                    Fault Frequency: 4                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:25:34                    Vehlicle_speed: 0.0 km/h                    Resolution Mileage: 726 m                    Voltage_value_KL.30_ESC_V: 13.8 V                    Wake up EPB: not active                    Wake up CAN: not active                    Postrun_activ: not active                    Comparison_pressure_sensor: completed successfully                    Comparison_longitudinal_accleration: completed successfully                    Comparison_transverse_accleration: not completed successfully                    Comparison_yaw_rate_sensor: not completed successfully                    LWS_comparison: not completed successfully                    Internal_failure_code: 01 20                    00 02 00 00 04 0C 10 0A 40 00 00 00 80 00 00 40 30 00 21 00 04590080 - Release / Enable Active          B184C 00 {00100111} - -          {SECDIAG_ROLE_UNLOCKED}          Not Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 6                    Fault Frequency: 1                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:16:55                    Vehlicle_speed: 0.0 km/h                    Resolution Mileage: 726 m                    Voltage_value_KL.30_ESC_V: 12.6 V                    Wake up EPB: not active                    Wake up CAN: not active                    Postrun_activ: not active                    Comparison_pressure_sensor: completed successfully                    Comparison_longitudinal_accleration: completed successfully                    Comparison_transverse_accleration: not completed successfully                    Comparison_yaw_rate_sensor: not completed successfully                    LWS_comparison: not completed successfully                    Internal_failure_code: 02 94                    00 00 00 00 04 8C 10 08 80 00 00 00 80 07 00 40 30 00 21 00 04592192 - VKMS          B18B0 F0 {00100110} - Missing Adaptation          {VKMS_new_download_container_required_due_to_vehicle_change}          Intermittent - Not Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 3                    Fault Frequency: 4                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:25:34                    Vehlicle_speed: 0.0 km/h                    Resolution Mileage: 726 m                    Voltage_value_KL.30_ESC_V: 13.8 V                    Wake up EPB: not active                    Wake up CAN: not active                    Postrun_activ: not active                    Comparison_pressure_sensor: completed successfully                    Comparison_longitudinal_accleration: completed successfully                    Comparison_transverse_accleration: not completed successfully                    Comparison_yaw_rate_sensor: not completed successfully                    LWS_comparison: not completed successfully                    Internal_failure_code: 02 95                    00 02 00 00 04 0C 10 0A 40 00 00 00 80 00 00 40 34 00 21 00 04-------------------------------------------------------------------------------Address 08: Auto HVAC (J979)       Labels:* None   Part No SW: 5WA 907 727 BK    HW: 5WA 907 727 AF   Component: AC Manuell    H01 5088     Serial number: 217052507344450 Dataset Number: V03935452UX 0001   Coding: 023010019211000000000000101001010000010000000000000000000000   ASAM Dataset: EV_ACClimaBHBE3ADV 002062   ROD: EV_ACClimaBHBE3ADV_002_VW41.rod   VCID: 1A6DD4408C18FA6A31F-804E SFD+SFD2 { }No fault code found.-------------------------------------------------------------------------------Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb   Part No SW: 5WA 937 086 CN    HW: 5WA 937 086 BJ   Component: BCM37w_M238 0451     Serial number: BXJ53F210525940 Dataset Number: V03935471YB 0001   ASAM Dataset: EV_BCMwBL 004001   ROD: EV_BCMwBL_004.rod   VCID: 1F1BE554973A9F42C61-804A SFD+SFD2 { }   Rain/Light Recognition Sensor:   Subsystem 1 - Part No SW: 89A 955 555 C    HW: 89A 955 555 C   Component: G397_RLFSS     004 0008   Serial number: TTZ53508052500024365   Light switch:   Subsystem 2 - Part No SW: 5H0 941 193 AF    HW: 5H0 941 193 AF   Component: LiSi           H04 0513   Serial number: TW571429052500010984   Control head for driving and comfort functions:   Subsystem 3 - Part No SW: 5H0 925 200 AA    HW: 5H0 925 200 AA   Component: DiETa          H07 0008   Serial number: 92471YED001N8         Roof electronics control module:   Subsystem 4 - Part No SW: 5H0 959 561 BM    HW: 5H0 959 561 BM   Component: -VW----LINDA-  504 0833   Serial number: MW3LND26052500011324   Steering Column Switch:   Subsystem 5 - Part No SW: 5Q1 953 507 EQ    HW: 5Q1 953 549 D   Component: J527 SMLS MQB  005 0080   Serial number: 00000026052508490291No fault code found.-------------------------------------------------------------------------------Address 10: Park/Steer Assist (J446)       Labels:* None   Part No SW: 5QS 919 283 A    HW: 5QS 919 283   Component: PDC 04ch low  H01 0075     Serial number: 000015052594630 Dataset Number: V03935457CG 0001   Coding: 0000010001   ASAM Dataset: EV_EPHBO14VW3360000 001010   ROD: EV_EPHBO14VW3360000_SK49.rod   VCID: 5AED9440CC983A6AF1F-800ENo fault code found.-------------------------------------------------------------------------------Address 13: Auto Dist. Reg (J428)       Labels:| 5WA-907-567.clb   Part No SW: 5WA 907 567     HW: 5WA 907 819   Component: ACC Bosch MQB H50 0576     Dataset Number: V03935445MT 0001   Coding: 00030205000740441257400000C000042E4030000000000000000000000000   ASAM Dataset: EV_FRONTRADARBOSCHVW380 005024   ROD: EV_FRONTRADARBOSCHVW380_001.rod   VCID: 0F7BB51447DA2FC2561-805A SFD+SFD2 {x}1 Fault Found:0313 - ROD - Unknown Error Code          - 00 {10101110}          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 4                    Fault Frequency: 3                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:25:42-------------------------------------------------------------------------------Address 15: Airbags (J234)       Labels:| 5QS-959-655.clb   Part No SW: 5QS 959 655 S    HW: 5QS 959 655 S   Component: AirbagVW50    004 0131     Serial number: 000000003C0TWRD Dataset Number: V03935458VW 0001   Coding: 88CC008000E0C000000000000000000091540000A1AA0000DC00F680002B00A7   Shop #: WSC 00000 000 00000   ASAM Dataset: EV_AirbaVW50SMEVW49X 001014   ROD: EV_AirbaVW50SMEVW49X.rod   VCID: 73B3D9E44B326B22D29-8026 SFD+SFD2 { }   Seat occupancy detection 1:   Subsystem 1 - Part No SW: 2K7 959 760 F    HW: 2K7 959 760 D   Component: wSBR F-SG      037 0250   Serial number:         94DC4E1D3407   Crash sensor for side airbag: driver side:   Subsystem 2 - Part No SW: -----------    HW: 480 001 405 19   Component: SideSensor_Df  001 0887   Serial number: 3570000FA6850C781260   Crash sensor for side airbag: passenger side:   Subsystem 3 - Part No SW: -----------    HW: 480 001 405 19   Component: SideSensor_Pf  001 0887   Serial number: 3580000FA6850C751940   Crash sensor for side airbag: driver side rear:   Subsystem 4 - Part No SW: -----------    HW: 480 051 105 19   Component: SideSensor_Dr  000 0149   Serial number: 3510000C6E1AC24E6B30   Crash sensor for side airbag: passenger side rear:   Subsystem 5 - Part No SW: -----------    HW: 480 051 105 19   Component: SideSensor_Pr  000 0149   Serial number: 35200009CE19DB45E670   Crash sensor for front airbag: driver side:   Subsystem 6 - Part No SW: -----------    HW: 480 051 F07 19   Component: FrontSensor_D  000 014A   Serial number: 35500009CE1C520E4630   Crash sensor for side airbag: B-pillar: driver side:   Subsystem 7 - Part No SW: -----------    HW: 480 051 105 19   Component: Side_Sens_B_D  000 0149   Serial number: I0P000098E1AC1932820   Crash sensor for side airbag: B-pillar: passenger side:   Subsystem 8 - Part No SW: -----------    HW: 480 051 405 19   Component: Side_Sens_B_P  000 0149   Serial number: I0Q0000C4E2BBDCAC5501 Fault Found:9980928 - Release / Enable Active          B184C 00 {00101111} - -          {ECU unlocked}          Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 5                    Fault Frequency: 1                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:16:53-------------------------------------------------------------------------------Address 17: Instruments (J285)       Labels:* None-SRI2   Part No SW: 2K7 920 310 A    HW: 2K7 920 310   Component: KOMBI         320 2642     Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Dataset Number: V03935458FZ 0001   Coding: 04A405076384000801802203000000080020180800   ASAM Dataset: EV_DashBoardVISMQB37W 005002   ROD: EV_DashBoardVISMQB37W_005_VN3S.rod   VCID: 2411EAB8BE5CBC9A9B3-8070 SFD { }2 Faults Found:16711684 - Release / Enable Active          B184C 00 {00001001} - -          {Unlock_protection_of_vehicle_diagnosis_active}          Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 3                    Fault Frequency: 1                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:16:538667138 - Distance          U197A 00 {00001000} - Plausibility Check          {mileage_error_security_AR2}          Intermittent - Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 4                    Fault Frequency: 2                    Reset counter: 38                    Mileage: 0 km                    Date: 2026.07.27                    Time: 07:56:24-------------------------------------------------------------------------------Address 19: CAN Gateway (J533)       Labels:* None   Part No SW: 5QS 907 530 B    HW: 5QS 907 530   Component: GW MQB 23     005 3093     Serial number: SMERBG230525007 Dataset Number: V03935466BF 0001   Coding: 000000000000000000000000000000000000000000000000030000000000000000000000000000000000000000000000   GVL: 3D0000000008408C8000800048000040000040000000000000000000000000C4   ASAM Dataset: EV_GatewMQBwBL 001018   ROD: EV_GatewMQBwBL_VW41.rod   VCID: 53F37964AB720B22329-8006 SFD+SFD2 { }   Generator:   Component: 5-00-17-01-03     Battery Monitoring Control Module:   Subsystem 2 - Part No SW: 5QS 915 181     HW: 5QS 915 181   Component: J367-BDMHella  H01 2362   Serial number: 4931966306             Multi-function steering wheel control module:   Subsystem 3 - Part No SW: 571 959 442     HW: 571 959 442   Component: E221__MFL-PR6  H07 0130   Serial number: PR6-04400361212507954 Faults Found:8482819 - Activatable Functions          B18D3 F3 {00100111} - Faulty Vehicle Configuration          {Fs_id_configuration_error}          Not Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 3                    Fault Frequency: 1                    Reset counter: 1                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 18:27:188417280 - Diagnostic Filter          U17A0 00 {00101111} - Not Activated          {Filter_is_not_active}          Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 3                    Fault Frequency: 1                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 18:35:0812400 - Release / Enable Active          B184C 00 {00100111} - -          {Unlock_protection_of_vehicle_diagnosis_active}          Not Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 3                    Fault Frequency: 1                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 18:34:378389392 - Control Module for Driver Assist Systems          C12D5 87 {00100110} - Missing Message          {FAS messsages retention time to long}          Intermittent - Not Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 6                    Fault Frequency: 2                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:15:49-------------------------------------------------------------------------------Address 22: AWD (J492)       Labels:| 0CQ-907-554-V1.clb   Part No SW: 5WA 907 554 H    HW: 5WA 525 130   Component: 4Motion       H66 1060     Serial number: 000028.03.25000 Dataset Number: V03935320HN 0001   Coding: 0001   ASAM Dataset: EV_AllWheelContrHA1VW37X 006001   ROD: EV_AllWheelContrHA1VW37X_006_VW27.rod   VCID: 53F37964AB720B22329-80062 Faults Found:17521 - Databus          U1121 00 {00101111} - Missing Message          {Getriebe - TO -- Getriebe_51_Auth}          Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 6                    Fault Frequency: 1                    Reset counter: 0                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:16:54                    Vehicle speed: 0 km/h                    Engine speed: 0.00 /min                    Voltage terminal 30: 12.6 V                    Haldex clutch pump: current: 0.000 A17523 - Databus          U1121 00 {00101111} - Missing Message          {Gateway - TO -- Anhänger_01 Fehler ignorieren wenn keine AHK verbaut}          Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 6                    Fault Frequency: 1                    Reset counter: 0                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:16:54                    Vehicle speed: 0 km/h                    Engine speed: 0.00 /min                    Voltage terminal 30: 12.6 V                    Haldex clutch pump: current: 0.000 A-------------------------------------------------------------------------------Address 23: Brake Booster (J539)       Labels: None   Part No SW: 5WA 909 059 AH    HW: 3Q0 909 059 D   Component: EBKV          H10 0563     Serial number: BPA085150525018 Dataset Number: V03935447DC 0001   Coding: 5402C140700000008018638C000049922449922400   ASAM Dataset: EV_BrakeBoostVW37WUNECE 013005   ROD: EV_BrakeBoostVW37WUNECE_013.rod   VCID: 1675C0707800DE0A157-8042 SFD+SFD2 { }1 Fault Found:1024304 - Release / Enable Active          B184C 00 {00101111} - -          {SECDIAG_ROLE_UNLOCKED}          Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 1                    Fault Frequency: 1                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 18:43:13-------------------------------------------------------------------------------Address 42: Door Elect, Driver (J386)       Labels:* None   Part No SW: 3WA 959 393 A    HW: 3WA 959 393   Component: TSG FS        001 0222     Serial number: Y2007YDU012C3   Dataset Number: V03935443PN 0001   Coding: 00208320C000000100001020   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016   ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod   VCID: 52FD7C609468022A39F-8006 SFD+SFD2 { }No fault code found.-------------------------------------------------------------------------------Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb   Part No SW: 5QS 907 146 D    HW: 5QS 907 146   Component: BASGEN1MQB37  263 2122     Serial number: 00724707 Dataset Number: V03935447B  0001   Coding: 00000000000000000001020101000100000001010101   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078   ROD: EV_SteerAssisBASGEN1MQB37_017.rod   VCID: 58E98E48B294287AC7B-800C SFD+SFD2 { }No fault code found.-------------------------------------------------------------------------------Address 52: Door Elect, Pass. (J387)       Labels:* None   Part No SW: 3WA 959 392 A    HW: 3WA 959 392   Component: TSG BFS       001 0222     Serial number: Y2007YE1000U7   Dataset Number: V03935443PP 0001   Coding: 00200120C000000100001020   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016   ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod   VCID: 51FF736C916E7932005-8004 SFD+SFD2 { }No fault code found.-------------------------------------------------------------------------------Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb   Part No SW: 2K7 035 869 A    HW: 2K7 035 869 A   Component: MU-E-D-EU     065 0176     Serial number: VWZAZ2D0781942  Dataset Number: V03935464C  0001   Coding: 63521006000020000000000000000000000000000000000000   ASAM Dataset: EV_MUEIGPMQB37w 001001   ROD: EV_MUEIGPMQB37w_VN3SP.rod   VCID: 34311AF80EBC2C1A0B3-8060 SFD+SFD2 { }   Display and control head 1 for information electronics:   Subsystem 1 - Part No SW: 5H0 919 605 G    HW: 5H0 919 605 G   Component: ABT_W_10       H50 2115   Serial number: APUFX7280525000108201 Fault Found:4112 - Release / Enable Active          B184C 00 {00001001} - -          {Unlock_protection_of_vehicle_diagnosis_active}          Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Priority: 3                    Fault Frequency: 1                    Reset counter: 40                    Mileage: 12004 km                    Date: 2026.08.03                    Time: 19:16:53                    Voltage terminal 30: 12.6 V-------------------------------------------------------------------------------Address 75: Telematics (J949)       Labels:* None   Part No SW: 571 035 284 B    HW: 571 035 284   Component: OCUMQBW2023_H H09 0626     Serial number: 0000000503VIBB0 Dataset Number: V03935465TG 0001   Coding: 06010601020000110000000013002607111012111012000010   ASAM Dataset: EV_OCUMWB2023 001066   ROD: EV_OCUMWB2023_VW42.rod   VCID: 1577C77C6506D5121CD-8040 SFD+SFD2 { }No fault code found.-------------------------------------------------------------------------------Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb   Part No SW: 5WA 980 653 F    HW: 5WA 980 653 A   Component: MQB MFK 3.0   H12 3609     Serial number: EAF282203251390 Dataset Number: V03935443PF 0001   Coding: 0001089001484040409E08001000002000018048600000000000000000000000   ASAM Dataset: EV_MFK3ValeoMQB 005071   ROD: EV_MFK3ValeoMQB_005_SE38P.rod   VCID: 52FD7C609468022A39F-8006No fault code found.End----------(Elapsed Time: 01:07, VBatt start/end: 13.8V/13.8V)-----------------------------------------17 Faults Found------------------------------
adpmap-01-05L-906-023-QK_WV2ZZZSK8SX116493-20260803-1923.CSV
;SW:05L-906-023-QK   HW:05L-907-309-AH ---  01: Engine;Component:R4 2.0l TDI   H80 4626, Coding:011900320326050920000000001000000000000000000000;EV_ECM20TDI01105L906023QK,010005,EV_ECM20TDI01105L906023QK.rod;Monday,03,August,2026,19:23:38:29755;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0;VCID: 015F832C018E49B2D05-8054 SFD+SFD2 { }{SFD } IDE00001-Production mode,00 00 00 ,3{SFD } IDE00263-Injector 1 correction value,88R5COG ,7{SFD } IDE00264-Injector 2 correction value,88Z5AXI ,7{SFD } IDE00265-Injector 3 correction value,ARSGA2C ,7{SFD } IDE00266-Injector 4 correction value,8785AFH ,7{SFD } IDE01096-Particulate Filter Statistics,0 ,1{SFD } IDE01711-Blocking of particle filter regeneration,not active ,1{SFD } IDE01945-Engine run-in oil pressure,not active ,1{SFD } IDE02248-Individually adjustable top speed limit,300.0 km/h,2IDE02332-Deactivate production mode,00 00 00 ,3IDE04617-Protective function,Enabled ,1{EPTI} IDE06425-Dynamometer mode: functional,not activated ,1{SFD } IDE07903-Adaptation of ash mass,4.46 g,2{SFD } IDE10309-Adaptation of oxidation catalytic converter aging,1.70752e+006 s,2{SFD } IDE12048-MAS13895-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor,-139.84 °,4{SFD } IDE12048-MAS13896-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor wheel,0.00 °,4{SFD } IDE12080-MAS13895-Adaptation of correction angle of crankshaft position detection-Error angle sensor,3.13 °,4{SFD } IDE12080-MAS13896-Adaptation of correction angle of crankshaft position detection-Error angle sensor wheel,0.00 °,4{SFD } IDE15783-Adaptation for aging coated particulate filter,2730705.3125 s,4Elapsed Time: 00:04
adpmap-03-5WA-614-517-DQ_WV2ZZZSK8SX116493-20260803-1924.CSV
;SW:5WA-614-517-DQ   HW:5WA-614-517-BS ---  03: ABS Brakes;Component:ESC           H31 0331, Coding:4A985428B44B399C4001559E1EB7C1C50ACF942151A000;EV_Brake1ESCMQB37WUNECE,006026,EV_Brake1ESCMQB37WUNECE_006_VN3SP.rod;Monday,03,August,2026,19:24:12:29755;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0;VCID: 1A6DD4408C18FA6A31F-804E SFD+SFD2 { }IDE02332-Deactivate production mode,0 ,3{SFD2} IDE04456-Brake disk drying,Medium ,1{SFD2} IDE05055-Hydraulic brake assistant,normal ,1{SFD } IDE05057-Brake prefill,activated ,1{SFD } IDE05161-Straight ahead brake stabilization,activated ,1IDE06425-Dynamometer mode: functional,not activated ,1{EXTD} IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2{EXTD} IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2{SFD } IDE07291-Vehicle Identification Number (VIN),WV2ZZZSK8SX116493 ,17{EXTD} IDE07292-Brake pre-filling,ended ,1{SFD } IDE07565-ABS in lower speed range,activated ,1{SFD2} IDE11985-Expected OBD requirements,EOBD ,1{SFD } IDE12030-Rough road optimization,activated ,1{SFD2} IDE14225-IDE07280-Delay and hold management-Multiple collision brake,activated ,3{SFD2} IDE14225-IDE08968-Delay and hold management-High-voltage charging management,not activated ,3{SFD2} IDE14225-IDE11421-Delay and hold management-Leaving concept,activated ,3{SFD2} IDE14225-IDE11447-Delay and hold management-electro-mechanical brake booster,activated ,3{SFD2} IDE14225-IDE18029-Delay and hold management-Rush Hour Pilot,not activated ,3{SFD2} IDE14225-MAS01090-Delay and hold management-Gearbox,not activated ,3{SFD2} IDE14225-MAS05087-Delay and hold management-ACC,not activated ,3{SFD2} IDE14225-MAS05129-Delay and hold management-Motor,not activated ,3{SFD2} IDE14225-MAS05506-Delay and hold management-Stopping distance reduction,activated ,3{SFD2} IDE14225-MAS10858-Delay and hold management-Rear camera,not activated ,3{SFD2} IDE14225-MAS12422-Delay and hold management-intelligent parking assistant,not activated ,3{SFD2} IDE14225-MAS15696-Delay and hold management-Rear cross traffic assistant,not activated ,3{SFD2} IDE14225-MAS15806-Delay and hold management-Parking assist,activated ,3{SFD2} IDE14225-MAS18082-Delay and hold management-Emergency assistant,not activated ,3{SFD2} IDE15332-MAS17834-Vehicle curb weight-Curb weight of rear axle,805.0 kg,4{SFD2} IDE15332-MAS17837-Vehicle curb weight-Curb weight of front axle,1013.0 kg,4{SFD2} IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,28{SFD2} IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,13 ,28{EXTD} MAS02080-XCP calibration protocol,Security access required,28{SFD2} MAS03691-Dimming,activated ,1{EXTD} MAS09595-IDE00001-Production mode-Production mode,not active ,3{EXTD} MAS09595-IDE01211-Production mode-Static current measuring mode,Deactivating ,3{EXTD} MAS09595-IDE02939-Production mode-Activate/lock control,Deactivating ,3{EXTD} MAS09595-IDE09543-Production mode-Vehicle holding function,Deactivating ,3{EXTD} MAS09595-MAS18521-Production mode-Production mode: recuperation,Deactivating ,3{EXTD} MAS09595-MAS24092-Production mode-Electromechanical parking brake button: long push,Deactivating ,3{SFD } MAS14035-Precondition,0 ,3{SFD2} MAS30112-OBD market,NO OBD ,1ENG114742-ENG264054-Activation of Development Messages-Activation of Development Message EPB01,not activated ,3ENG114742-ENG264055-Activation of Development Messages-Activation of Development Message EPB02,not activated ,3ENG114742-ENG264056-Activation of Development Messages-Activation of Development Message ESC00,not activated ,3ENG114742-ENG264057-Activation of Development Messages-Activation of Development Message ESC01,not activated ,3ENG114742-ENG264059-Activation of Development Messages-Activation of Development Message ESC03,not activated ,3ENG114742-ENG264060-Activation of Development Messages-Activation of Development Message ESC04,not activated ,3ENG114742-ENG387510-Activation of Development Messages-Activation of Development Message ESC05 (RKA01),not activated ,3ENG114742-ENG264062-Activation of Development Messages-Activation of Development Message ESC06,not activated ,3ENG114742-ENG264063-Activation of Development Messages-Activation of Development Message ESC07,not activated ,3ENG114742-ENG264064-Activation of Development Messages-Activation of Development Message ESC08,not activated ,3ENG114742-ENG387511-Activation of Development Messages-Activation of Development Message ESC11 (FDR01),not activated ,3{SFD } ENG264022-Developer_Function_01,00 00 ,2{SFD2} ENG264035-Developer_Function_03,not activated ,2{EXTD} ENG264025-Developer_Function_04,5 ,1{EXTD} ENG264021-Developer_Function_10,activated ,1{SFD2} ENG139530-Developer_Function_111,Security access required,1{SFD2} ENG122844-ENG264130-dimming_characteristic_1-Daempfung_Abdimmen_KL_58xD_PWM,0.16 s,20{SFD2} ENG122844-ENG154584-dimming_characteristic_1-Daempfung_Aufdimmen_KL_58xd_PWM,0.32 s,20{SFD2} ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,20{SFD2} ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,20{SFD2} ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,20{SFD2} ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,20{SFD2} ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,20{SFD2} ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,20{SFD2} ENG122844-ENG99777-dimming_characteristic_1-Y1,6.0 %,20{SFD2} ENG122844-ENG100480-dimming_characteristic_1-Y2,6.0 %,20{SFD2} ENG122844-ENG100773-dimming_characteristic_1-Y3,6.0 %,20{SFD2} ENG122844-ENG100631-dimming_characteristic_1-Y4,10.0 %,20{SFD2} ENG122844-ENG102174-dimming_characteristic_1-Y5,80.0 %,20{SFD2} ENG122844-ENG113993-dimming_characteristic_1-Y6,100.0 %,20{SFD2} ENG122845-ENG264130-dimming_characteristic_2-Daempfung_Abdimmen_KL_58xD_PWM,0.16 s,20{SFD2} ENG122845-ENG154584-dimming_characteristic_2-Daempfung_Aufdimmen_KL_58xd_PWM,0.32 s,20{SFD2} ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,20{SFD2} ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,20{SFD2} ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,20{SFD2} ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,20{SFD2} ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,20{SFD2} ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,20{SFD2} ENG122845-ENG99777-dimming_characteristic_2-Y1,6.0 %,20{SFD2} ENG122845-ENG100480-dimming_characteristic_2-Y2,6.0 %,20{SFD2} ENG122845-ENG100773-dimming_characteristic_2-Y3,6.0 %,20{SFD2} ENG122845-ENG100631-dimming_characteristic_2-Y4,10.0 %,20{SFD2} ENG122845-ENG102174-dimming_characteristic_2-Y5,80.0 %,20{SFD2} ENG122845-ENG113993-dimming_characteristic_2-Y6,100.0 %,20{SFD } ENG264029-ENG264073-Dynamic_Developer_Function_01-ASAP_Address_0,00 00 00 00 ,182{SFD } ENG264029-ENG264074-Dynamic_Developer_Function_01-ASAP_Address_1,00 00 00 00 ,182{SFD } ENG264029-ENG264075-Dynamic_Developer_Function_01-ASAP_Address_10,00 00 00 00 ,182{SFD } ENG264029-ENG264076-Dynamic_Developer_Function_01-ASAP_Address_100,00 00 00 00 ,182{SFD } ENG264029-ENG264077-Dynamic_Developer_Function_01-ASAP_Address_11,00 00 00 00 ,182{SFD } ENG264029-ENG264078-Dynamic_Developer_Function_01-ASAP_Address_12,00 00 00 00 ,182{SFD } ENG264029-ENG264079-Dynamic_Developer_Function_01-ASAP_Address_13,00 00 00 00 ,182{SFD } ENG264029-ENG264080-Dynamic_Developer_Function_01-ASAP_Address_14,00 00 00 00 ,182{SFD } ENG264029-ENG264081-Dynamic_Developer_Function_01-ASAP_Address_15,00 00 00 00 ,182{SFD } ENG264029-ENG264082-Dynamic_Developer_Function_01-ASAP_Address_2,00 00 00 00 ,182{SFD } ENG264029-ENG264083-Dynamic_Developer_Function_01-ASAP_Address_3,00 00 00 00 ,182{SFD } ENG264029-ENG264084-Dynamic_Developer_Function_01-ASAP_Address_4,00 00 00 00 ,182{SFD } ENG264029-ENG264085-Dynamic_Developer_Function_01-ASAP_Address_5,00 00 00 00 ,182{SFD } ENG264029-ENG264086-Dynamic_Developer_Function_01-ASAP_Address_6,00 00 00 00 ,182{SFD } ENG264029-ENG264087-Dynamic_Developer_Function_01-ASAP_Address_7,00 00 00 00 ,182{SFD } ENG264029-ENG264088-Dynamic_Developer_Function_01-ASAP_Address_8,00 00 00 00 ,182{SFD } ENG264029-ENG264089-Dynamic_Developer_Function_01-ASAP_Address_81,00 00 00 00 ,182{SFD } ENG264029-ENG264090-Dynamic_Developer_Function_01-ASAP_Address_82,00 00 00 00 ,182{SFD } ENG264029-ENG264091-Dynamic_Developer_Function_01-ASAP_Address_83,00 00 00 00 ,182{SFD } ENG264029-ENG264092-Dynamic_Developer_Function_01-ASAP_Address_84,00 00 00 00 ,182{SFD } ENG264029-ENG264093-Dynamic_Developer_Function_01-ASAP_Address_85,00 00 00 00 ,182{SFD } ENG264029-ENG264094-Dynamic_Developer_Function_01-ASAP_Address_86,00 00 00 00 ,182{SFD } ENG264029-ENG264095-Dynamic_Developer_Function_01-ASAP_Address_87,00 00 00 00 ,182{SFD } ENG264029-ENG264096-Dynamic_Developer_Function_01-ASAP_Address_88,00 00 00 00 ,182{SFD } ENG264029-ENG264097-Dynamic_Developer_Function_01-ASAP_Address_89,00 00 00 00 ,182{SFD } ENG264029-ENG264098-Dynamic_Developer_Function_01-ASAP_Address_9,00 00 00 00 ,182{SFD } ENG264029-ENG264099-Dynamic_Developer_Function_01-ASAP_Address_90,00 00 00 00 ,182{SFD } ENG264029-ENG264100-Dynamic_Developer_Function_01-ASAP_Address_91,00 00 00 00 ,182{SFD } ENG264029-ENG264101-Dynamic_Developer_Function_01-ASAP_Address_92,00 00 00 00 ,182{SFD } ENG264029-ENG264102-Dynamic_Developer_Function_01-ASAP_Address_93,00 00 00 00 ,182{SFD } ENG264029-ENG264103-Dynamic_Developer_Function_01-ASAP_Address_94,00 00 00 00 ,182{SFD } ENG264029-ENG264104-Dynamic_Developer_Function_01-ASAP_Address_95,00 00 00 00 ,182{SFD } ENG264029-ENG264105-Dynamic_Developer_Function_01-ASAP_Address_96,00 00 00 00 ,182{SFD } ENG264029-ENG264106-Dynamic_Developer_Function_01-ASAP_Address_97,00 00 00 00 ,182{SFD } ENG264029-ENG264107-Dynamic_Developer_Function_01-ASAP_Address_98,00 00 00 00 ,182{SFD } ENG264029-ENG264108-Dynamic_Developer_Function_01-ASAP_Address_99,00 00 00 00 ,182{SFD } ENG264029-ENG264109-Dynamic_Developer_Function_01-ASAP_Data_Type_100,undefined ,182{SFD } ENG264029-ENG264110-Dynamic_Developer_Function_01-ASAP_Data_Type_81,undefined ,182{SFD } ENG264029-ENG264111-Dynamic_Developer_Function_01-ASAP_Data_Type_82,undefined ,182{SFD } ENG264029-ENG264112-Dynamic_Developer_Function_01-ASAP_Data_Type_83,undefined ,182{SFD } ENG264029-ENG264113-Dynamic_Developer_Function_01-ASAP_Data_Type_84,undefined ,182{SFD } ENG264029-ENG264114-Dynamic_Developer_Function_01-ASAP_Data_Type_85,undefined ,182{SFD } ENG264029-ENG264115-Dynamic_Developer_Function_01-ASAP_Data_Type_86,undefined ,182{SFD } ENG264029-ENG264116-Dynamic_Developer_Function_01-ASAP_Data_Type_87,undefined ,182{SFD } ENG264029-ENG264117-Dynamic_Developer_Function_01-ASAP_Data_Type_88,undefined ,182{SFD } ENG264029-ENG264118-Dynamic_Developer_Function_01-ASAP_Data_Type_89,undefined ,182{SFD } ENG264029-ENG264119-Dynamic_Developer_Function_01-ASAP_Data_Type_90,undefined ,182{SFD } ENG264029-ENG264120-Dynamic_Developer_Function_01-ASAP_Data_Type_91,undefined ,182{SFD } ENG264029-ENG264121-Dynamic_Developer_Function_01-ASAP_Data_Type_92,undefined ,182{SFD } ENG264029-ENG264122-Dynamic_Developer_Function_01-ASAP_Data_Type_93,undefined ,182{SFD } ENG264029-ENG264123-Dynamic_Developer_Function_01-ASAP_Data_Type_94,undefined ,182{SFD } ENG264029-ENG264124-Dynamic_Developer_Function_01-ASAP_Data_Type_95,undefined ,182{SFD } ENG264029-ENG264125-Dynamic_Developer_Function_01-ASAP_Data_Type_96,undefined ,182{SFD } ENG264029-ENG264126-Dynamic_Developer_Function_01-ASAP_Data_Type_97,undefined ,182{SFD } ENG264029-ENG264127-Dynamic_Developer_Function_01-ASAP_Data_Type_98,undefined ,182{SFD } ENG264029-ENG264128-Dynamic_Developer_Function_01-ASAP_Data_Type_99,undefined ,182{SFD } ENG264029-ENG264131-Dynamic_Developer_Function_01-Data_position_0_Bit_position,0 ,182{SFD } ENG264029-ENG264132-Dynamic_Developer_Function_01-Data_position_0_Byte_position,0 ,182{SFD } ENG264029-ENG264133-Dynamic_Developer_Function_01-Data_position_1_Bit_position,0 ,182{SFD } ENG264029-ENG264134-Dynamic_Developer_Function_01-Data_position_1_Byte_position,0 ,182{SFD } ENG264029-ENG264135-Dynamic_Developer_Function_01-Data_position_10_Bit_position,0 ,182{SFD } ENG264029-ENG264136-Dynamic_Developer_Function_01-Data_position_10_Byte_position,0 ,182{SFD } ENG264029-ENG264137-Dynamic_Developer_Function_01-Data_position_11_Bit_position,0 ,182{SFD } ENG264029-ENG264138-Dynamic_Developer_Function_01-Data_position_11_Byte_position,0 ,182{SFD } ENG264029-ENG264139-Dynamic_Developer_Function_01-Data_position_12_Bit_position,0 ,182{SFD } ENG264029-ENG264140-Dynamic_Developer_Function_01-Data_position_12_Byte_position,0 ,182{SFD } ENG264029-ENG264141-Dynamic_Developer_Function_01-Data_position_13_Bit_position,0 ,182{SFD } ENG264029-ENG264142-Dynamic_Developer_Function_01-Data_position_13_Byte_position,0 ,182{SFD } ENG264029-ENG264143-Dynamic_Developer_Function_01-Data_position_14_Bit_position,0 ,182{SFD } ENG264029-ENG264144-Dynamic_Developer_Function_01-Data_position_14_Byte_position,0 ,182{SFD } ENG264029-ENG264145-Dynamic_Developer_Function_01-Data_position_15_Bit_position,0 ,182{SFD } ENG264029-ENG264146-Dynamic_Developer_Function_01-Data_position_15_Byte_position,0 ,182{SFD } ENG264029-ENG264147-Dynamic_Developer_Function_01-Data_position_2_Bit_position,0 ,182{SFD } ENG264029-ENG264148-Dynamic_Developer_Function_01-Data_position_2_Byte_position,0 ,182{SFD } ENG264029-ENG264149-Dynamic_Developer_Function_01-Data_position_3_Bit_position,0 ,182{SFD } ENG264029-ENG264150-Dynamic_Developer_Function_01-Data_position_3_Byte_position,0 ,182{SFD } ENG264029-ENG264151-Dynamic_Developer_Function_01-Data_position_4_Bit_position,0 ,182{SFD } ENG264029-ENG264152-Dynamic_Developer_Function_01-Data_position_4_Byte_position,0 ,182{SFD } ENG264029-ENG264153-Dynamic_Developer_Function_01-Data_position_5_Bit_position,0 ,182{SFD } ENG264029-ENG264154-Dynamic_Developer_Function_01-Data_position_5_Byte_position,0 ,182{SFD } ENG264029-ENG264155-Dynamic_Developer_Function_01-Data_position_6_Bit_position,0 ,182{SFD } ENG264029-ENG264156-Dynamic_Developer_Function_01-Data_position_6_Byte_position,0 ,182{SFD } ENG264029-ENG264157-Dynamic_Developer_Function_01-Data_position_7_Bit_position,0 ,182{SFD } ENG264029-ENG264158-Dynamic_Developer_Function_01-Data_position_7_Byte_position,0 ,182{SFD } ENG264029-ENG264159-Dynamic_Developer_Function_01-Data_position_8_Bit_position,0 ,182{SFD } ENG264029-ENG264160-Dynamic_Developer_Function_01-Data_position_8_Byte_position,0 ,182{SFD } ENG264029-ENG264161-Dynamic_Developer_Function_01-Data_position_9_Bit_position,0 ,182{SFD } ENG264029-ENG264162-Dynamic_Developer_Function_01-Data_position_9_Byte_position,0 ,182{SFD } ENG264029-ENG264166-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_1,1 ,182{SFD } ENG264029-ENG264167-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_2,2 ,182{SFD } ENG264027-ENG264073-Dynamic_Developer_Function_02-ASAP_Address_0,00 00 00 00 ,182{SFD } ENG264027-ENG264074-Dynamic_Developer_Function_02-ASAP_Address_1,00 00 00 00 ,182{SFD } ENG264027-ENG264075-Dynamic_Developer_Function_02-ASAP_Address_10,00 00 00 00 ,182{SFD } ENG264027-ENG264076-Dynamic_Developer_Function_02-ASAP_Address_100,00 00 00 00 ,182{SFD } ENG264027-ENG264077-Dynamic_Developer_Function_02-ASAP_Address_11,00 00 00 00 ,182{SFD } ENG264027-ENG264078-Dynamic_Developer_Function_02-ASAP_Address_12,00 00 00 00 ,182{SFD } ENG264027-ENG264079-Dynamic_Developer_Function_02-ASAP_Address_13,00 00 00 00 ,182{SFD } ENG264027-ENG264080-Dynamic_Developer_Function_02-ASAP_Address_14,00 00 00 00 ,182{SFD } ENG264027-ENG264081-Dynamic_Developer_Function_02-ASAP_Address_15,00 00 00 00 ,182{SFD } ENG264027-ENG264082-Dynamic_Developer_Function_02-ASAP_Address_2,00 00 00 00 ,182{SFD } ENG264027-ENG264083-Dynamic_Developer_Function_02-ASAP_Address_3,00 00 00 00 ,182{SFD } ENG264027-ENG264084-Dynamic_Developer_Function_02-ASAP_Address_4,00 00 00 00 ,182{SFD } ENG264027-ENG264085-Dynamic_Developer_Function_02-ASAP_Address_5,00 00 00 00 ,182{SFD } ENG264027-ENG264086-Dynamic_Developer_Function_02-ASAP_Address_6,00 00 00 00 ,182{SFD } ENG264027-ENG264087-Dynamic_Developer_Function_02-ASAP_Address_7,00 00 00 00 ,182{SFD } ENG264027-ENG264088-Dynamic_Developer_Function_02-ASAP_Address_8,00 00 00 00 ,182{SFD } ENG264027-ENG264089-Dynamic_Developer_Function_02-ASAP_Address_81,00 00 00 00 ,182{SFD } ENG264027-ENG264090-Dynamic_Developer_Function_02-ASAP_Address_82,00 00 00 00 ,182{SFD } ENG264027-ENG264091-Dynamic_Developer_Function_02-ASAP_Address_83,00 00 00 00 ,182{SFD } ENG264027-ENG264092-Dynamic_Developer_Function_02-ASAP_Address_84,00 00 00 00 ,182{SFD } ENG264027-ENG264093-Dynamic_Developer_Function_02-ASAP_Address_85,00 00 00 00 ,182{SFD } ENG264027-ENG264094-Dynamic_Developer_Function_02-ASAP_Address_86,00 00 00 00 ,182{SFD } ENG264027-ENG264095-Dynamic_Developer_Function_02-ASAP_Address_87,00 00 00 00 ,182{SFD } ENG264027-ENG264096-Dynamic_Developer_Function_02-ASAP_Address_88,00 00 00 00 ,182{SFD } ENG264027-ENG264097-Dynamic_Developer_Function_02-ASAP_Address_89,00 00 00 00 ,182{SFD } ENG264027-ENG264098-Dynamic_Developer_Function_02-ASAP_Address_9,00 00 00 00 ,182{SFD } ENG264027-ENG264099-Dynamic_Developer_Function_02-ASAP_Address_90,00 00 00 00 ,182{SFD } ENG264027-ENG264100-Dynamic_Developer_Function_02-ASAP_Address_91,00 00 00 00 ,182{SFD } ENG264027-ENG264101-Dynamic_Developer_Function_02-ASAP_Address_92,00 00 00 00 ,182{SFD } ENG264027-ENG264102-Dynamic_Developer_Function_02-ASAP_Address_93,00 00 00 00 ,182{SFD } ENG264027-ENG264103-Dynamic_Developer_Function_02-ASAP_Address_94,00 00 00 00 ,182{SFD } ENG264027-ENG264104-Dynamic_Developer_Function_02-ASAP_Address_95,00 00 00 00 ,182{SFD } ENG264027-ENG264105-Dynamic_Developer_Function_02-ASAP_Address_96,00 00 00 00 ,182{SFD } ENG264027-ENG264106-Dynamic_Developer_Function_02-ASAP_Address_97,00 00 00 00 ,182{SFD } ENG264027-ENG264107-Dynamic_Developer_Function_02-ASAP_Address_98,00 00 00 00 ,182{SFD } ENG264027-ENG264108-Dynamic_Developer_Function_02-ASAP_Address_99,00 00 00 00 ,182{SFD } ENG264027-ENG264109-Dynamic_Developer_Function_02-ASAP_Data_Type_100,undefined ,182{SFD } ENG264027-ENG264110-Dynamic_Developer_Function_02-ASAP_Data_Type_81,undefined ,182{SFD } ENG264027-ENG264111-Dynamic_Developer_Function_02-ASAP_Data_Type_82,undefined ,182{SFD } ENG264027-ENG264112-Dynamic_Developer_Function_02-ASAP_Data_Type_83,undefined ,182{SFD } ENG264027-ENG264113-Dynamic_Developer_Function_02-ASAP_Data_Type_84,undefined ,182{SFD } ENG264027-ENG264114-Dynamic_Developer_Function_02-ASAP_Data_Type_85,undefined ,182{SFD } ENG264027-ENG264115-Dynamic_Developer_Function_02-ASAP_Data_Type_86,undefined ,182{SFD } ENG264027-ENG264116-Dynamic_Developer_Function_02-ASAP_Data_Type_87,undefined ,182{SFD } ENG264027-ENG264117-Dynamic_Developer_Function_02-ASAP_Data_Type_88,undefined ,182{SFD } ENG264027-ENG264118-Dynamic_Developer_Function_02-ASAP_Data_Type_89,undefined ,182{SFD } ENG264027-ENG264119-Dynamic_Developer_Function_02-ASAP_Data_Type_90,undefined ,182{SFD } ENG264027-ENG264120-Dynamic_Developer_Function_02-ASAP_Data_Type_91,undefined ,182{SFD } ENG264027-ENG264121-Dynamic_Developer_Function_02-ASAP_Data_Type_92,undefined ,182{SFD } ENG264027-ENG264122-Dynamic_Developer_Function_02-ASAP_Data_Type_93,undefined ,182{SFD } ENG264027-ENG264123-Dynamic_Developer_Function_02-ASAP_Data_Type_94,undefined ,182{SFD } ENG264027-ENG264124-Dynamic_Developer_Function_02-ASAP_Data_Type_95,undefined ,182{SFD } ENG264027-ENG264125-Dynamic_Developer_Function_02-ASAP_Data_Type_96,undefined ,182{SFD } ENG264027-ENG264126-Dynamic_Developer_Function_02-ASAP_Data_Type_97,undefined ,182{SFD } ENG264027-ENG264127-Dynamic_Developer_Function_02-ASAP_Data_Type_98,undefined ,182{SFD } ENG264027-ENG264128-Dynamic_Developer_Function_02-ASAP_Data_Type_99,undefined ,182{SFD } ENG264027-ENG264131-Dynamic_Developer_Function_02-Data_position_0_Bit_position,0 ,182{SFD } ENG264027-ENG264132-Dynamic_Developer_Function_02-Data_position_0_Byte_position,0 ,182{SFD } ENG264027-ENG264133-Dynamic_Developer_Function_02-Data_position_1_Bit_position,0 ,182{SFD } ENG264027-ENG264134-Dynamic_Developer_Function_02-Data_position_1_Byte_position,0 ,182{SFD } ENG264027-ENG264135-Dynamic_Developer_Function_02-Data_position_10_Bit_position,0 ,182{SFD } ENG264027-ENG264136-Dynamic_Developer_Function_02-Data_position_10_Byte_position,0 ,182{SFD } ENG264027-ENG264137-Dynamic_Developer_Function_02-Data_position_11_Bit_position,0 ,182{SFD } ENG264027-ENG264138-Dynamic_Developer_Function_02-Data_position_11_Byte_position,0 ,182{SFD } ENG264027-ENG264139-Dynamic_Developer_Function_02-Data_position_12_Bit_position,0 ,182{SFD } ENG264027-ENG264140-Dynamic_Developer_Function_02-Data_position_12_Byte_position,0 ,182{SFD } ENG264027-ENG264141-Dynamic_Developer_Function_02-Data_position_13_Bit_position,0 ,182{SFD } ENG264027-ENG264142-Dynamic_Developer_Function_02-Data_position_13_Byte_position,0 ,182{SFD } ENG264027-ENG264143-Dynamic_Developer_Function_02-Data_position_14_Bit_position,0 ,182{SFD } ENG264027-ENG264144-Dynamic_Developer_Function_02-Data_position_14_Byte_position,0 ,182{SFD } ENG264027-ENG264145-Dynamic_Developer_Function_02-Data_position_15_Bit_position,0 ,182{SFD } ENG264027-ENG264146-Dynamic_Developer_Function_02-Data_position_15_Byte_position,0 ,182{SFD } ENG264027-ENG264147-Dynamic_Developer_Function_02-Data_position_2_Bit_position,0 ,182{SFD } ENG264027-ENG264148-Dynamic_Developer_Function_02-Data_position_2_Byte_position,0 ,182{SFD } ENG264027-ENG264149-Dynamic_Developer_Function_02-Data_position_3_Bit_position,0 ,182{SFD } ENG264027-ENG264150-Dynamic_Developer_Function_02-Data_position_3_Byte_position,0 ,182{SFD } ENG264027-ENG264151-Dynamic_Developer_Function_02-Data_position_4_Bit_position,0 ,182{SFD } ENG264027-ENG264152-Dynamic_Developer_Function_02-Data_position_4_Byte_position,0 ,182{SFD } ENG264027-ENG264153-Dynamic_Developer_Function_02-Data_position_5_Bit_position,0 ,182{SFD } ENG264027-ENG264154-Dynamic_Developer_Function_02-Data_position_5_Byte_position,0 ,182{SFD } ENG264027-ENG264155-Dynamic_Developer_Function_02-Data_position_6_Bit_position,0 ,182{SFD } ENG264027-ENG264156-Dynamic_Developer_Function_02-Data_position_6_Byte_position,0 ,182{SFD } ENG264027-ENG264157-Dynamic_Developer_Function_02-Data_position_7_Bit_position,0 ,182{SFD } ENG264027-ENG264158-Dynamic_Developer_Function_02-Data_position_7_Byte_position,0 ,182{SFD } ENG264027-ENG264159-Dynamic_Developer_Function_02-Data_position_8_Bit_position,0 ,182{SFD } ENG264027-ENG264160-Dynamic_Developer_Function_02-Data_position_8_Byte_position,0 ,182{SFD } ENG264027-ENG264161-Dynamic_Developer_Function_02-Data_position_9_Bit_position,0 ,182{SFD } ENG264027-ENG264162-Dynamic_Developer_Function_02-Data_position_9_Byte_position,0 ,182{SFD } ENG264027-ENG264166-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_1,1 ,182{SFD } ENG264027-ENG264167-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_2,2 ,182{SFD } ENG264028-ENG264073-Dynamic_Developer_Function_03-ASAP_Address_0,00 00 00 00 ,182{SFD } ENG264028-ENG264074-Dynamic_Developer_Function_03-ASAP_Address_1,00 00 00 00 ,182{SFD } ENG264028-ENG264075-Dynamic_Developer_Function_03-ASAP_Address_10,00 00 00 00 ,182{SFD } ENG264028-ENG264076-Dynamic_Developer_Function_03-ASAP_Address_100,00 00 00 00 ,182{SFD } ENG264028-ENG264077-Dynamic_Developer_Function_03-ASAP_Address_11,00 00 00 00 ,182{SFD } ENG264028-ENG264078-Dynamic_Developer_Function_03-ASAP_Address_12,00 00 00 00 ,182{SFD } ENG264028-ENG264079-Dynamic_Developer_Function_03-ASAP_Address_13,00 00 00 00 ,182{SFD } ENG264028-ENG264080-Dynamic_Developer_Function_03-ASAP_Address_14,00 00 00 00 ,182{SFD } ENG264028-ENG264081-Dynamic_Developer_Function_03-ASAP_Address_15,00 00 00 00 ,182{SFD } ENG264028-ENG264082-Dynamic_Developer_Function_03-ASAP_Address_2,00 00 00 00 ,182{SFD } ENG264028-ENG264083-Dynamic_Developer_Function_03-ASAP_Address_3,00 00 00 00 ,182{SFD } ENG264028-ENG264084-Dynamic_Developer_Function_03-ASAP_Address_4,00 00 00 00 ,182{SFD } ENG264028-ENG264085-Dynamic_Developer_Function_03-ASAP_Address_5,00 00 00 00 ,182{SFD } ENG264028-ENG264086-Dynamic_Developer_Function_03-ASAP_Address_6,00 00 00 00 ,182{SFD } ENG264028-ENG264087-Dynamic_Developer_Function_03-ASAP_Address_7,00 00 00 00 ,182{SFD } ENG264028-ENG264088-Dynamic_Developer_Function_03-ASAP_Address_8,00 00 00 00 ,182{SFD } ENG264028-ENG264089-Dynamic_Developer_Function_03-ASAP_Address_81,00 00 00 00 ,182{SFD } ENG264028-ENG264090-Dynamic_Developer_Function_03-ASAP_Address_82,00 00 00 00 ,182{SFD } ENG264028-ENG264091-Dynamic_Developer_Function_03-ASAP_Address_83,00 00 00 00 ,182{SFD } ENG264028-ENG264092-Dynamic_Developer_Function_03-ASAP_Address_84,00 00 00 00 ,182{SFD } ENG264028-ENG264093-Dynamic_Developer_Function_03-ASAP_Address_85,00 00 00 00 ,182{SFD } ENG264028-ENG264094-Dynamic_Developer_Function_03-ASAP_Address_86,00 00 00 00 ,182{SFD } ENG264028-ENG264095-Dynamic_Developer_Function_03-ASAP_Address_87,00 00 00 00 ,182{SFD } ENG264028-ENG264096-Dynamic_Developer_Function_03-ASAP_Address_88,00 00 00 00 ,182{SFD } ENG264028-ENG264097-Dynamic_Developer_Function_03-ASAP_Address_89,00 00 00 00 ,182{SFD } ENG264028-ENG264098-Dynamic_Developer_Function_03-ASAP_Address_9,00 00 00 00 ,182{SFD } ENG264028-ENG264099-Dynamic_Developer_Function_03-ASAP_Address_90,00 00 00 00 ,182{SFD } ENG264028-ENG264100-Dynamic_Developer_Function_03-ASAP_Address_91,00 00 00 00 ,182{SFD } ENG264028-ENG264101-Dynamic_Developer_Function_03-ASAP_Address_92,00 00 00 00 ,182{SFD } ENG264028-ENG264102-Dynamic_Developer_Function_03-ASAP_Address_93,00 00 00 00 ,182{SFD } ENG264028-ENG264103-Dynamic_Developer_Function_03-ASAP_Address_94,00 00 00 00 ,182{SFD } ENG264028-ENG264104-Dynamic_Developer_Function_03-ASAP_Address_95,00 00 00 00 ,182{SFD } ENG264028-ENG264105-Dynamic_Developer_Function_03-ASAP_Address_96,00 00 00 00 ,182{SFD } ENG264028-ENG264106-Dynamic_Developer_Function_03-ASAP_Address_97,00 00 00 00 ,182{SFD } ENG264028-ENG264107-Dynamic_Developer_Function_03-ASAP_Address_98,00 00 00 00 ,182{SFD } ENG264028-ENG264108-Dynamic_Developer_Function_03-ASAP_Address_99,00 00 00 00 ,182{SFD } ENG264028-ENG264109-Dynamic_Developer_Function_03-ASAP_Data_Type_100,undefined ,182{SFD } ENG264028-ENG264110-Dynamic_Developer_Function_03-ASAP_Data_Type_81,undefined ,182{SFD } ENG264028-ENG264111-Dynamic_Developer_Function_03-ASAP_Data_Type_82,undefined ,182{SFD } ENG264028-ENG264112-Dynamic_Developer_Function_03-ASAP_Data_Type_83,undefined ,182{SFD } ENG264028-ENG264113-Dynamic_Developer_Function_03-ASAP_Data_Type_84,undefined ,182{SFD } ENG264028-ENG264114-Dynamic_Developer_Function_03-ASAP_Data_Type_85,undefined ,182{SFD } ENG264028-ENG264115-Dynamic_Developer_Function_03-ASAP_Data_Type_86,undefined ,182{SFD } ENG264028-ENG264116-Dynamic_Developer_Function_03-ASAP_Data_Type_87,undefined ,182{SFD } ENG264028-ENG264117-Dynamic_Developer_Function_03-ASAP_Data_Type_88,undefined ,182{SFD } ENG264028-ENG264118-Dynamic_Developer_Function_03-ASAP_Data_Type_89,undefined ,182{SFD } ENG264028-ENG264119-Dynamic_Developer_Function_03-ASAP_Data_Type_90,undefined ,182{SFD } ENG264028-ENG264120-Dynamic_Developer_Function_03-ASAP_Data_Type_91,undefined ,182{SFD } ENG264028-ENG264121-Dynamic_Developer_Function_03-ASAP_Data_Type_92,undefined ,182{SFD } ENG264028-ENG264122-Dynamic_Developer_Function_03-ASAP_Data_Type_93,undefined ,182{SFD } ENG264028-ENG264123-Dynamic_Developer_Function_03-ASAP_Data_Type_94,undefined ,182{SFD } ENG264028-ENG264124-Dynamic_Developer_Function_03-ASAP_Data_Type_95,undefined ,182{SFD } ENG264028-ENG264125-Dynamic_Developer_Function_03-ASAP_Data_Type_96,undefined ,182{SFD } ENG264028-ENG264126-Dynamic_Developer_Function_03-ASAP_Data_Type_97,undefined ,182{SFD } ENG264028-ENG264127-Dynamic_Developer_Function_03-ASAP_Data_Type_98,undefined ,182{SFD } ENG264028-ENG264128-Dynamic_Developer_Function_03-ASAP_Data_Type_99,undefined ,182{SFD } ENG264028-ENG264131-Dynamic_Developer_Function_03-Data_position_0_Bit_position,0 ,182{SFD } ENG264028-ENG264132-Dynamic_Developer_Function_03-Data_position_0_Byte_position,0 ,182{SFD } ENG264028-ENG264133-Dynamic_Developer_Function_03-Data_position_1_Bit_position,0 ,182{SFD } ENG264028-ENG264134-Dynamic_Developer_Function_03-Data_position_1_Byte_position,0 ,182{SFD } ENG264028-ENG264135-Dynamic_Developer_Function_03-Data_position_10_Bit_position,0 ,182{SFD } ENG264028-ENG264136-Dynamic_Developer_Function_03-Data_position_10_Byte_position,0 ,182{SFD } ENG264028-ENG264137-Dynamic_Developer_Function_03-Data_position_11_Bit_position,0 ,182{SFD } ENG264028-ENG264138-Dynamic_Developer_Function_03-Data_position_11_Byte_position,0 ,182{SFD } ENG264028-ENG264139-Dynamic_Developer_Function_03-Data_position_12_Bit_position,0 ,182{SFD } ENG264028-ENG264140-Dynamic_Developer_Function_03-Data_position_12_Byte_position,0 ,182{SFD } ENG264028-ENG264141-Dynamic_Developer_Function_03-Data_position_13_Bit_position,0 ,182{SFD } ENG264028-ENG264142-Dynamic_Developer_Function_03-Data_position_13_Byte_position,0 ,182{SFD } ENG264028-ENG264143-Dynamic_Developer_Function_03-Data_position_14_Bit_position,0 ,182{SFD } ENG264028-ENG264144-Dynamic_Developer_Function_03-Data_position_14_Byte_position,0 ,182{SFD } ENG264028-ENG264145-Dynamic_Developer_Function_03-Data_position_15_Bit_position,0 ,182{SFD } ENG264028-ENG264146-Dynamic_Developer_Function_03-Data_position_15_Byte_position,0 ,182{SFD } ENG264028-ENG264147-Dynamic_Developer_Function_03-Data_position_2_Bit_position,0 ,182{SFD } ENG264028-ENG264148-Dynamic_Developer_Function_03-Data_position_2_Byte_position,0 ,182{SFD } ENG264028-ENG264149-Dynamic_Developer_Function_03-Data_position_3_Bit_position,0 ,182{SFD } ENG264028-ENG264150-Dynamic_Developer_Function_03-Data_position_3_Byte_position,0 ,182{SFD } ENG264028-ENG264151-Dynamic_Developer_Function_03-Data_position_4_Bit_position,0 ,182{SFD } ENG264028-ENG264152-Dynamic_Developer_Function_03-Data_position_4_Byte_position,0 ,182{SFD } ENG264028-ENG264153-Dynamic_Developer_Function_03-Data_position_5_Bit_position,0 ,182{SFD } ENG264028-ENG264154-Dynamic_Developer_Function_03-Data_position_5_Byte_position,0 ,182{SFD } ENG264028-ENG264155-Dynamic_Developer_Function_03-Data_position_6_Bit_position,0 ,182{SFD } ENG264028-ENG264156-Dynamic_Developer_Function_03-Data_position_6_Byte_position,0 ,182{SFD } ENG264028-ENG264157-Dynamic_Developer_Function_03-Data_position_7_Bit_position,0 ,182{SFD } ENG264028-ENG264158-Dynamic_Developer_Function_03-Data_position_7_Byte_position,0 ,182{SFD } ENG264028-ENG264159-Dynamic_Developer_Function_03-Data_position_8_Bit_position,0 ,182{SFD } ENG264028-ENG264160-Dynamic_Developer_Function_03-Data_position_8_Byte_position,0 ,182{SFD } ENG264028-ENG264161-Dynamic_Developer_Function_03-Data_position_9_Bit_position,0 ,182{SFD } ENG264028-ENG264162-Dynamic_Developer_Function_03-Data_position_9_Byte_position,0 ,182{SFD } ENG264028-ENG264166-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_1,1 ,182{SFD } ENG264028-ENG264167-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_2,2 ,182Elapsed Time: 00:18
adpmap-08-5WA-907-727-BK_WV2ZZZSK8SX116493-20260803-1925.CSV
;SW:5WA-907-727-BK   HW:5WA-907-727-AF ---  08: Auto HVAC;Component:AC Manuell    H01 5088, Coding:023010019211000000000000101001010000010000000000000000000000;EV_ACClimaBHBE3ADV,002062,EV_ACClimaBHBE3ADV_002_VW41.rod;Monday,03,August,2026,19:25:09:29755;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0;VCID: 1A6DD4408C18FA6A31F-804E SFD+SFD2 { }{PROD} IDE00001-ENG128289-Production mode-Air_condition_compressor_deactivate,not active ,3{PROD} IDE00001-ENG128290-Production mode-Battery_cooling_and_heating_deactivate,not active ,3{PROD} IDE00001-ENG128291-Production mode-ClearResetEmissionRelated-DiagnosticInformation_Mode$04,not active ,3{PROD} IDE00001-ENG369640-Production mode-ProductionByte_0,0 ,3{PROD} IDE00001-ENG369641-Production mode-ProductionByte_2,0 ,3{SFD2} IDE00036-Vehicle equipment code,Variant 1 ,1{SFD2} IDE01067-Retention of driver's seat heater level,not active ,1{SFD2} IDE01476-Store air recirculation setting with terminal 15 OFF,Service life-dependent store ,1{EXTD} IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore ,1{SFD2} IDE01479-Gear ratio of engine - A/C compressor,1.26 ,1{SFD2} IDE01482-After-run of parking heater or parking ventilation,not activated ,1{SFD2} IDE01483-Blower voltage with voice control,not activated ,1{SFD2} IDE01488-Auxiliary heating retrofit without CAN,not installed ,1{SFD } IDE01493-Sensitivity of air quality sensor,Medium ,1{SFD } IDE01503-Running time of basic setting for compressor break-in,60 s,1{SFD2} IDE01536-Post heating of auxiliary heating,0 ,1IDE02155-Reset all counters,not activated ,1IDE02332-Deactivate production mode,0 ,3{SFD2} IDE02371-Time until seat heating performance is reduced from stage 3 to stage 2,0 min,1{SFD2} IDE02372-Time until seat heating performance is reduced from stage 2 to stage 1,0 min,1{SFD2} IDE02744-IDE15865-Steering wheel heating-NTC target temperature stage 1 (Steering Wheel: Heated),34 °C,10{SFD2} IDE02744-IDE15866-Steering wheel heating-NTC target temperature stage 2 (Steering Wheel: Heated),39 °C,10{SFD2} IDE02744-IDE15867-Steering wheel heating-NTC target temperature stage 3 (Steering Wheel: Heated),44 °C,10{SFD2} IDE02744-IDE15868-Steering wheel heating-PI controller I factor (Steering Wheel: Heated),0.40 ,10{SFD2} IDE02744-IDE15869-Steering wheel heating-PI controller P factor (Steering Wheel: Heated),18 ,10{SFD2} IDE02744-IDE15870-Steering wheel heating-Offset I controller target temperature (Steering Wheel: Heated),5 °C,10{SFD2} IDE02744-IDE15871-Steering wheel heating-Maximum temperature (Steering Wheel: Heated),50 °C,10{SFD2} IDE02744-IDE15872-Steering wheel heating-NTC static timeout (Steering Wheel: Heated),10 min,10{SFD2} IDE02744-IDE15873-Steering wheel heating-Load mode timeout (Steering Wheel: Heated),10 min,10{SFD2} IDE02744-IDE15874-Steering wheel heating-Automatic heating pad configuration (Steering Wheel: Heated),1 ms,10{SFD2} IDE02744-IDE20215-Steering wheel heating-LIN SCSM installed,not activated ,10{SFD } IDE03176-Duration of compressor run in,40 s,1{SFD2} IDE03251-Stop enable for Start/Stop function,always: except for safety-relevant functions ,1{SFD2} IDE04074-Driving program,not installed ,1{SFD } IDE04159-Deactivation of start/stop function,not active ,1{SFD2} IDE04927-IDE01446-Window heater-Running time of heated front window,0 s,10{SFD2} IDE04927-MAS12610-Window heater-Activation of wiper arm heater,-50.0 °C,10{SFD2} IDE04927-ENG263527-Window heater-Config_heating_voltage_request,No_set_point_voltage ,10{SFD2} IDE04927-ENG263525-Window heater-Heating_rear_window_activation_time,320 s,10{SFD2} IDE04927-ENG263512-Window heater-Heating_rear_window_cutoff_temperature,35.00 °C,10{SFD2} IDE04927-ENG263556-Window heater-Heating_rear_window_temperature_activation_time,active ,10{SFD2} IDE04927-ENG263570-Window heater-Window_heating_front_activation_time_pause,0 s,10{SFD2} IDE04927-ENG263505-Window heater-Window_heating_front_cutoff_temperature,-50.00 °C,10{SFD2} IDE04927-ENG263589-Window heater-Window_heating_front_maximum_temperature_activation_time,0 s,10{SFD2} IDE04927-ENG263529-Window heater-Window_heating_front_temperature_activation_time,not active ,10{SFD2} IDE06089-ENG263584-Seat heater level current consumption allocation-Config_seat_heating_high_voltage_request,Keine Spannungsanforderung ,17{SFD2} IDE06089-ENG263533-Seat heater level current consumption allocation-Config_seat_heating_low_voltage_request,Keine Spannungsanforderung ,17{SFD2} IDE06089-ENG263526-Seat heater level current consumption allocation-Seat_heating_correction_of_temperature_regulation_on_heat_flow,0.0 °C,17{SFD2} IDE06089-ENG263552-Seat heater level current consumption allocation-Seat_heating_filter_constant_for_heat_flow,1 s,17{SFD2} IDE06089-ENG263578-Seat heater level current consumption allocation-Seat_heating_offset_voltage,15.0 V,17{SFD2} IDE06089-ENG263544-Seat heater level current consumption allocation-Seat_heating_stage_1_lower_threshold,0.0 °C,17{SFD2} IDE06089-ENG263507-Seat heater level current consumption allocation-Seat_heating_stage_1_upper_threshold,0.00 °C,17{SFD2} IDE06089-ENG263592-Seat heater level current consumption allocation-Seat_heating_stage_2_lower_threshold,0.00 °C,17{SFD2} IDE06089-ENG263559-Seat heater level current consumption allocation-Seat_heating_stage_2_upper_threshold,0.00 °C,17{SFD2} IDE06089-ENG263539-Seat heater level current consumption allocation-Seat_heating_stage_3_lower_threshold,0.00 °C,17{SFD2} IDE06089-ENG263554-Seat heater level current consumption allocation-Seat_heating_stage_3_upper_threshold,0.00 °C,17{SFD2} IDE06089-ENG263536-Seat heater level current consumption allocation-Seat_heating_stage_4_lower_threshold,0.00 °C,17{SFD2} IDE06089-ENG263549-Seat heater level current consumption allocation-Seat_heating_stage_4_upper_threshold,0.00 ,17{SFD2} IDE06089-ENG263566-Seat heater level current consumption allocation-Seat_heating_stage_5_lower_threshold,0.00 ,17{SFD2} IDE06089-ENG263597-Seat heater level current consumption allocation-Seat_heating_stage_5_upper_threshold,0.00 ,17{SFD2} IDE06089-ENG263562-Seat heater level current consumption allocation-Seat_heating_stage_6_lower_threshold,0.00 °C,17{SFD2} IDE06089-ENG263524-Seat heater level current consumption allocation-Seat_heating_stage_6_upper_threshold,0.00 ,17{SFD2} IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1500 l/min,1IDE06545-Blower voltage for production routines,6.00 V,1IDE06546-Interior specified temperature for production routines,22 °C,1IDE06547-Air distribution for production routines,Air distribution top and footwell ,1IDE06593-Air recirculation for production routines,Fresh air ,1{SFD2} IDE07108-A/C styles,Display ,1{SFD } IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2{SFD } IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2{SFD } IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 s,2{SFD } IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 s,2{SFD2} IDE07301-Remote start function: activation of seat heating,Without seat heater and ventilation ,1{SFD2} IDE07304-Remote start function: activation of seat ventilation,not activated ,1{SFD2} IDE07398-Blower logic with manual adjustment,Fan setting: absolute ,1{SFD2} IDE07418-Additional filter,not installed ,1{SFD2} IDE07585-Hand heater function during cold start,active ,1{SFD2} IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,active ,1{SFD2} IDE07948-Retention of frt.pass. seat heater level,not active ,1{SFD2} IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,0 %,12{SFD2} IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,0 %,12{SFD2} IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,0 %,12{SFD2} IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,0 %,12{SFD2} IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,0 %,12{SFD2} IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,0 %,12{SFD2} IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,0 %,12{SFD2} IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,0 %,12{SFD2} IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,0 %,12{SFD2} IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,0 %,12{SFD2} IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,0 %,12{SFD2} IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,0 %,12{SFD2} IDE10118-Fan speed reduction for telephony,not activated ,1{SFD2} IDE10278-Behavior of compressor during moderate outside temperatures,Always active ,1{SFD2} IDE11425-Rear blower logic: for manual adjustment,Matching coding ,1{SFD2} IDE11426-Rear blower voltage: for voice activation,not activated ,1IDE11427-Rear blower voltage: for production routines,6.00 V,1IDE11428-Rear air distribution: for production routines,No effect ,1{SFD } IDE11631-MAS13043-Remaining run-time of the cooling circuit deaeration-Circuit 1,1200.0 s,2{SFD } IDE11631-MAS13044-Remaining run-time of the cooling circuit deaeration-Circuit 2,1200.0 s,2{SFD2} IDE11935-Personalization,not activated ,1{SFD2} IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest,0 %,12{SFD2} IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion,0 %,12{SFD2} IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest,0 %,12{SFD2} IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion,0 %,12{SFD2} IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest,0 %,12{SFD2} IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion,0 %,12{SFD2} IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest,0 %,12{SFD2} IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion,0 %,12{SFD2} IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest,0 %,12{SFD2} IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion,0 %,12{SFD2} IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest,0 %,12{SFD2} IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion,0 %,12{SFD2} IDE12229-Filtering of interior air: store,Service life-dependent store ,1{SFD } IDE13371-Interior humidity sensor: sensitivity,Medium ,1{SFD2} IDE14087-Time until seat heat recovery within the maximum level,0 min,1{SFD } IDE15635-Number of interruptions permitted during compressor run-in,10 ,1{SFD2} IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,592 ,112{SFD2} IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,55 ,112{SFD2} IDE16800-Pre-ventilation: coding override,not active ,1{SFD2} IDE17680-IDE16487-Coolant: fill level detection-CO2 overfill detection,not active ,1{SFD2} IDE17680-MAS14106-Coolant: fill level detection-CO2: low fill level detection,active when stationary ,1{SFD2} IDE18112-Auxiliary heater: runtime,short ,1{SFD2} IDE18376-MAS03179-Adjustment of the schedule table-Local data bus 2,1 s,4{SFD2} IDE18376-MAS03180-Adjustment of the schedule table-Local data bus,1 s,4{SFD2} IDE18376-MAS05972-Adjustment of the schedule table-Local data bus 3,0 s,4{SFD2} IDE18376-MAS06525-Adjustment of the schedule table-Local data bus 4,0 s,4{SFD2} IDE18376-MAS06526-Adjustment of the schedule table-Local data bus 5,0 ,4{SFD2} IDE18376-MAS06527-Adjustment of the schedule table-Local data bus 6,0 s,4{SFD2} IDE18376-MAS14771-Adjustment of the schedule table-Local data bus 7,0 s,4{SFD2} IDE18376-MAS19909-Adjustment of the schedule table-Local data bus 8,0 s,4{SFD2} IDE19964-ENG387656-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_1_lower_threshold,22.00 °C,17{SFD2} IDE19964-ENG387657-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_1_upper_threshold,23.00 °C,17{SFD2} IDE19964-ENG387658-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_2_lower_threshold,22.00 °C,17{SFD2} IDE19964-ENG387659-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_2_upper_threshold,23.00 °C,17{SFD2} IDE19964-ENG387660-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_3_lower_threshold,35.50 °C,17{SFD2} IDE19964-ENG387661-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_3_upper_threshold,36.00 °C,17{SFD2} IDE19964-ENG387662-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_4_lower_threshold,36.00 °C,17{SFD2} IDE19964-ENG387663-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_4_upper_threshold,52.50 °C,17{SFD2} IDE19964-ENG387664-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_5_lower_threshold,52.50 °C,17{SFD2} IDE19964-ENG387665-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_5_upper_threshold,53.00 °C,17{SFD2} IDE19964-ENG387666-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_6_lower_threshold,52.50 °C,17{SFD2} IDE19964-ENG387667-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_6_upper_threshold,53.00 °C,17{EXTD} IDE80009-Analysis 9,not activated ,1{EXTD} IDE80010-Analysis 10,not activated ,1{EXTD} IDE80011-Analysis 11,not activated ,1{SFD2} MAS01651-Display and control unit: rear,not installed ,1{SFD2} MAS05214-Steering wheel heating,long_push ,1{SFD2} MAS06414-Temperature tuning,normal tuning ,1{SFD2} MAS06415-Blower adjustment,normal tuning ,1{SFD2} MAS06416-Blower display in auto operation,not activated ,1{SFD2} MAS06417-Amplified overshoots heater operation,not activated ,1{SFD2} MAS19886-Interior temperature sensor: after-run time,180 s,2{SFD2} SFT00117-Emergency call module and communication unit,installed ,1{SFD2} ENG263483-AC_evaporator_temperature_offset,-0.70 K,1{SFD2} ENG276128-air_recirculation_deactivate_at_open_sunroof,not activated ,1{SFD2} ENG316722-AP_Clima_Master_FL_Setup,83 01 00 00 83 01 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ,24{SFD2} ENG316723-AP_Clima_Zone1_FL_Setup,15 00 00 08 15 00 00 08 07 00 00 CF C7 8A 04 07 00 00 CF C7 8A 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,40{SFD2} ENG316724-AP_Clima_Zone2_FL_Setup,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,40{SFD2} ENG316725-AP_SIH_FL_Setup,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,25{SFD2} ENG316726-AP_Steering_wheel_heating,00 00 00 00 00 00 00 00 00 00 ,10{SFD2} ENG316727-AP_Windowheater,C0 00 00 00 00 00 00 00 00 00 00 00 00 ,13{SFD2} ENG263479-Auto-Toggle,not activated ,1{SFD } ENG263474-ENG263585-Development_Messages_Mode_Activation-General_Messages,0 ,18{SFD } ENG263474-ENG263519-Development_Messages_Mode_Activation-LIN_1_Messages,0 ,18{SFD } ENG263474-ENG263517-Development_Messages_Mode_Activation-LIN_2_Messages,0 ,18{SFD } ENG263474-ENG263537-Development_Messages_Mode_Activation-LIN_3_Messages,0 ,18{SFD } ENG263474-ENG263573-Development_Messages_Mode_Activation-LIN_4_Messages,0 ,18{SFD } ENG263474-ENG263548-Development_Messages_Mode_Activation-LIN_5_Messages,0 ,18{SFD } ENG263474-ENG263518-Development_Messages_Mode_Activation-LIN_6_Messages,0 ,18{SFD } ENG263474-ENG263550-Development_Messages_Mode_Activation-LIN_7_Messages,0 ,18{SFD } ENG263474-ENG263508-Development_Messages_Mode_Activation-LIN_8_Messages,0 ,18{SFD } ENG263440-Entwicklungs-ID für Entwicklungszwecke freischalten,0 ,2{SFD } ENG153885-Knockout_test_mode,0 ,1{SFD2} ENG263490-manuel_air_recirculation_deacivate_AUTO_mode,activated ,1{SFD } ENG263452-OnBoardDiagnose für Entwicklungszwecke freischalten,not activated ,1{SFD2} ENG279929-ENG280096-pms_data_to_hmi-papam_pms_inside,No display ,2{SFD2} ENG279929-ENG280097-pms_data_to_hmi-papam_pms_outside,No display ,2{SFD2} ENG263450-seat_dependent_climatisation,not activated ,1{SFD2} ENG263443-seatheatin_function_switch,AUTO_seatheating_function ,1{SFD2} ENG263458-winterfunction,not installed ,1Elapsed Time: 00:23
adpmap-09-5WA-937-086-CN_WV2ZZZSK8SX116493-20260803-1931.CSV
;SW:5WA-937-086-CN   HW:5WA-937-086-BJ ---  09: Cent. Elect.;Component:BCM37w_M238 0451, Coding:;EV_BCMwBL,004001,EV_BCMwBL_004.rod;Monday,03,August,2026,19:31:27:29755;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0;VCID: 1F1BE554973A9F42C61-804A SFD+SFD2 { }IDE00001-ENG99061-Production mode-Access control,not active ,3IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3IDE00001-ENG112304-Production mode-Heckwischer,not active ,3IDE00001-ENG98647-Production mode-Interior lights,not active ,3IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode,not active ,3IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode,not active ,3IDE00001-ENG263594-Production mode-pa_klemme_15_pmode,not active ,3IDE00001-ENG263561-Production mode-pa_klemme_50_pmode,not active ,3IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode,not active ,3IDE00001-ENG260220-Production mode-Remotestart Pmode,not active ,3IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active ,3IDE00001-ENG115731-Production mode-Virtuel_pedal,not active ,3{SFD2} IDE00002-Transport mode,active ,1{SFD } IDE00301-Distance,12004 km,4{SFD2} IDE00820-Activating and deactivating all development messages,not active ,1{SFD2} IDE01550-Service position,No Response From Subnet Component,1IDE02152-Characteristics in production mode,2000 ms,4IDE02332-Deactivate production mode,0 ,3{SFD2} IDE02455-MAS28776-Light function "Coming/Leaving Home"-Coming Home light: installation status,not enabled ,2{SFD2} IDE02455-MAS28799-Light function "Coming/Leaving Home"-Leaving Home light: default value for activation via BAP,not active ,2{SFD2} IDE02455-MAS28801-Light function "Coming/Leaving Home"-Leaving Home light: installation status,Not available ,2{SFD2} IDE02455-MAS28805-Light function "Coming/Leaving Home"-Display of Leaving Home light history,not active ,2{SFD2} IDE02455-MAS28890-Light function "Coming/Leaving Home"-Leaving Home and Coming Home light menu settings,Changing the Leaving Home and Coming Home light time via BAP ,2{SFD2} IDE02455-MAS28898-Light function "Coming/Leaving Home"-Display of Coming Home light history,not active ,2{SFD2} IDE02455-MAS28918-Light function "Coming/Leaving Home"-Coming Home light: default value for activation via BAP,not active ,2{SFD } IDE02488-Anti-theft system interior monitoring,No Response From Subnet Component,2IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen,not active ,8IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen,not active ,8IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8IDE02711-ENG112304-Rear wiper-Heckwischer,1Draht_Heckwischer ,8IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf,not active ,8IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart,Heckwischerstopp bei Wiederstart und Erststart ,8IDE02711-ENG114946-Rear wiper-Komfortwischen Heck,active ,8IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS,10 s,8IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW,active ,8IDE02711-ENG261056-Rear wiper-Modus_Heckintervall,statische Intervallpausenzeit ,8IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp,OFF ,8IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8{SFD2} IDE03471-ENG369552-Vehicle configuration-Fahrzeugplattform,MQB ,16{SFD2} IDE03471-ENG369585-Vehicle configuration-Innenraumsuche_SmartDevices_Freigeben_bei_Remotestart,not activated ,16{SFD2} IDE03471-ENG369594-Vehicle configuration-Ladetankklappe_bereich,Entry_bereich_gesamt ,16{SFD2} IDE03471-ENG369608-Vehicle configuration-MDK_System_aktiv,not activated ,16{SFD2} IDE03471-ENG369637-Vehicle configuration-PassiveEntry_FK_aktiv,not activated ,16{SFD2} IDE03471-ENG369638-Vehicle configuration-PassiveGo_Startberechtigter_Innenraum,ohne Kofferraum ,16{SFD2} IDE03471-ENG259357-Vehicle configuration-PassiveKomfortTogglen_aktiv,not activated ,16{SFD2} IDE03471-ENG369646-Vehicle configuration-Reichweitenueberpruefung_fuer_RPA_aktiv,not activated ,16{SFD2} IDE03471-ENG369649-Vehicle configuration-Rke_fenster_sad_komfortlauf,not activated ,16{SFD2} IDE03471-ENG369650-Vehicle configuration-Rke_frontdeckel_entriegeln,not activated ,16{SFD2} IDE03471-ENG369651-Vehicle configuration-Rke_fzg_entriegeln_aktiv,not activated ,16{SFD2} IDE03471-ENG369652-Vehicle configuration-Rke_heckdeckel_entriegeln,not activated ,16{SFD2} IDE03471-ENG369653-Vehicle configuration-Rke_heckdeckel_komfortlauf,not activated ,16{SFD2} IDE03471-ENG369654-Vehicle configuration-Rke_panic_alarm,not activated ,16{SFD2} IDE03471-ENG369655-Vehicle configuration-Rke_verdeck_komfortlauf,not activated ,16{SFD2} IDE03471-ENG369657-Vehicle configuration-RSAD_Kanal_A_aktiv,not activated ,16{SFD2} IDE03471-ENG369658-Vehicle configuration-RSAD_Kanal_B_aktiv,not activated ,16{SFD2} IDE03471-ENG369686-Vehicle configuration-UWB_BT_HR_verbaut,not activated ,16{SFD2} IDE03471-ENG369687-Vehicle configuration-UWB_BT_IN_H_KR_verbaut,not activated ,16{SFD2} IDE03471-ENG369688-Vehicle configuration-UWB_BT_IN_H_verbaut,not activated ,16{SFD2} IDE03471-ENG369689-Vehicle configuration-UWB_BT_VL verbaut,not activated ,16{SFD2} IDE03471-ENG369690-Vehicle configuration-UWB_HL_verbaut,not activated ,16{SFD2} IDE03471-ENG369691-Vehicle configuration-UWB_IN_V_KR_verbaut,not activated ,16{SFD2} IDE03471-ENG369692-Vehicle configuration-UWB_IN_V_verbaut,not activated ,16{SFD2} IDE03471-ENG369693-Vehicle configuration-UWB_Kanal_5_aktiv,not activated ,16{SFD2} IDE03471-ENG369694-Vehicle configuration-UWB_Kanal_6_aktiv,not activated ,16{SFD2} IDE03471-ENG369695-Vehicle configuration-UWB_Kanal_8_aktiv,not activated ,16{SFD2} IDE03471-ENG369696-Vehicle configuration-UWB_Kanal_9_aktiv,not activated ,16{SFD2} IDE03471-ENG369697-Vehicle configuration-UWB_VR_verbaut,not activated ,16{SFD2} IDE03471-ENG369746-Vehicle configuration-WAL_beim_Timeout_aktiv,not activated ,16{SFD2} IDE03471-ENG369747-Vehicle configuration-WAL_beim_Verschwinden_aktiv,not activated ,16{SFD2} IDE03471-ENG369748-Vehicle configuration-WAL_mit _Schluessel_im_Innenraum_aktiv,not activated ,16{SFD2} IDE03787-Activate left/right hand drive switch-over,Unknown (255),1{SFD2} IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,7{SFD2} IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel,active ,7{SFD2} IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit,0 ms,7{SFD2} IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit,0 ms,7{SFD2} IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit,10000 ms,7{SFD2} IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init,0 ,7{SFD2} IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit,0 ms,7{SFD2} IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit,2000 ms,7{SFD } IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,7{SFD2} IDE05823-DWA Interior monitoring parameter set,No Response From Subnet Component,7{SFD2} IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam,Low beams ,4{SFD2} IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam,Main beam ,4IDE06425-Dynamometer mode: functional,not activated ,1IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,active ,8IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8IDE07007-ENG331134-Air conditioning/heating function via remote control-pa_RSt_MOD_CAPTCHA_aktiv,active ,8IDE07007-ENG331135-Air conditioning/heating function via remote control-pa_t_Motorstartanforderung_RSt,not active ,8IDE07007-ENG331136-Air conditioning/heating function via remote control-pa_t_S2_Timer_RSt_MOD,15 s,8IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start,not installed ,8IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8IDE07007-ENG331137-Air conditioning/heating function via remote control-Remotestart_MOD_verbaut,not installed ,8IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung,active ,8{SFD2} IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,70 min,2{SFD2} IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2IDE07161-temporary VIN,Conditions not correct or request sequence error,2{SFD2} IDE07356-Position during interval mode,No Response From Subnet Component,2{SFD2} IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,2{SFD2} IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,2{SFD2} IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,2{SFD2} IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,2{SFD2} IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,2{SFD2} IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,2{SFD2} IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,2{SFD2} IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,2{SFD2} IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,2{SFD2} IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,2{SFD2} IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,2{SFD2} IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,2{SFD2} IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,2{SFD2} IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,2{SFD2} IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,2{SFD2} IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,2{SFD2} IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,2{SFD2} IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,2{SFD2} IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,2{SFD2} IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,2{SFD2} IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,2{SFD2} IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,2{SFD2} IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,2{SFD2} IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,not active ,9{SFD2} IDE08786-MAS28772-Assistance light functions-Automatic headlight control: delay,500 ms,9{SFD2} IDE08786-MAS28775-Assistance light functions-Light sensor sensitivity,sensitive ,9{SFD2} IDE08786-MAS28910-Assistance light functions-Masking of rain light menu,active ,9{SFD2} IDE08786-MAS28926-Assistance light functions-Rain-activated automatic headlight control,not active ,9{SFD2} IDE08786-MAS28927-Assistance light functions-Rotary light switch: fault output,active ,9{SFD2} IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,No Response From Subnet Component,9{SFD2} IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,No Response From Subnet Component,9{SFD2} IDE09377-IDE03007-Multi-contour seat driver's side-Component location,No Response From Subnet Component,9{SFD2} IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,9{SFD2} IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9{SFD2} IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,No Response From Subnet Component,9{SFD2} IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,No Response From Subnet Component,9{SFD2} IDE09378-IDE03007-Multi-contour seat passenger side-Component location,No Response From Subnet Component,9{SFD2} IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,9{SFD2} IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9{SFD2} IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,9{SFD2} IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,9{SFD2} IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,9{SFD2} IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,9{SFD2} IDE09767-MAS28778-Position lamps-Two-sided parking light availability,24 s,7{SFD2} IDE09767-MAS28828-Position lamps-Two-sided parking light reduction,active ,7{SFD2} IDE09767-MAS28897-Position lamps-Parking light activated via steering-column switch,One-sided ,7{SFD2} IDE09767-MAS28901-Position lamps-Distinction between light warning for campers and passenger cars,Terminal-dependent ,7{SFD2} IDE09767-MAS28902-Position lamps-Condition for two-sided parking light limitation/deactivation,Switch-off due to energy management ,7{SFD2} IDE09767-MAS28903-Position lamps-Conditions for parking light limitation,Switch-off due to energy management ,7{SFD2} IDE09767-MAS28904-Position lamps-Factor for availability timer,Availability up to 24 hours of operation  five minutes ,7{SFD2} IDE09767-MAS28931-Position lamps-Two-sided parking light OFF with dipped beam switch: S contact OFF,active ,7IDE10283-Key identification: transponder ID,Conditions not correct or request sequence error,7{SFD2} IDE10298-Alternating park position 1,No Response From Subnet Component,7{SFD2} IDE10299-Alternating park position 2,No Response From Subnet Component,7{SFD2} IDE10308-Garage door opener: support door name,No Response From Subnet Component,7{SFD2} IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,7{SFD2} IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,7{SFD2} IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,7{SFD2} IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,7{SFD2} IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,7{SFD2} IDE10844-Control module rear lid opening: duration status query,0 ms,2{SFD2} IDE10845-ENG258964-Control module rear lid opening: vehicle type-p_a_p_mode_aktivieren_vip,00 ,12{SFD2} IDE10845-ENG259328-Control module rear lid opening: vehicle type-p_t_delay_VIP_Freigabe_ZV_Ansteuerung,0 s,12{SFD2} IDE10845-ENG260538-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell,0 ms,12{SFD2} IDE10845-ENG259913-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell_offen,0 ms,12{SFD2} IDE10845-ENG260941-Control module rear lid opening: vehicle type-p_t_VIP_Sperrzeit_Schlüsselsuche,0 s,12{SFD2} IDE10845-ENG259196-Control module rear lid opening: vehicle type-p_t_VIP_Verzoegerung,0 ms,12{SFD2} IDE10845-ENG259996-Control module rear lid opening: vehicle type-p_v_VIP_aktiv,0 km/h,12{SFD2} IDE10845-ENG261214-Control module rear lid opening: vehicle type-p_v_VIP_deaktiv,0 km/h,12{SFD2} IDE10845-ENG121904-Control module rear lid opening: vehicle type-Rear_Lid_Opening_Sender_vehicle_type,00 ,12{SFD2} IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,12{SFD2} IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,12{SFD2} IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,12{SFD2} IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,12{SFD2} IDE12302-SFT00022-Identification of sub-bus participant-Steering Column Electronics,old ,6{SFD2} IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,old ,6{SFD2} IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,old ,6{SFD2} IDE12302-SFT271875-Identification of sub-bus participant-Light switch,old ,6{SFD2} IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,old ,6{SFD2} IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,old ,6{SFD2} IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,old ,6{SFD2} IDE12302-SFT271909-Identification of sub-bus participant-Left taillight 1,old ,6{SFD2} IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,old ,6{SFD2} IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,old ,6{SFD2} IDE12302-SFT271948-Identification of sub-bus participant-Left rear door control module,old ,6{SFD2} IDE12302-SFT271949-Identification of sub-bus participant-Right rear door control module,old ,6{SFD2} IDE12302-SFT271950-Identification of sub-bus participant-Power rear lid opening control module,New ,6{SFD2} IDE12302-SFT271966-Identification of sub-bus participant-Left neck heater,old ,6{SFD2} IDE12302-SFT271967-Identification of sub-bus participant-Right neck heater,old ,6{SFD2} IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions,New ,6{SFD2} IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side,old ,6{SFD2} IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side,old ,6{SFD2} IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,old ,6{SFD2} IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,old ,6{SFD2} IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,old ,6{SFD2} IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,old ,6{SFD2} IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions,old ,6{SFD2} IDE12302-SFT272142-Identification of sub-bus participant-Left taillight 2,old ,6{SFD2} IDE12302-SFT272143-Identification of sub-bus participant-Right taillight 1,old ,6{SFD2} IDE12302-SFT272144-Identification of sub-bus participant-Right taillight 2,old ,6{SFD2} IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start,old ,6{SFD2} IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2,old ,6{SFD2} IDE12302-SFT272272-Identification of sub-bus participant-Virtual pedal door opening: rear driver's side,old ,6{SFD2} IDE12302-SFT272286-Identification of sub-bus participant-Virtual pedal door opening: rear passenger's side,old ,6{SFD2} IDE12488-Antenna 1 for short-range communication,No Response From Subnet Component,6{SFD2} IDE12986-IDE18243-BAP configuration-Switch-on and off effect 1,0 ,8{SFD2} IDE12986-IDE18244-BAP configuration-Switch-on and off effect 2,0 ,8{SFD2} IDE12986-IDE20547-BAP configuration-Available HD projections in the HMI menu,0 ,8{SFD2} IDE12986-IDE20548-BAP configuration-Default value for HD projection in the HMI menu,0 ,8{SFD2} IDE13064-Wiper motor control module: dataset,No Response From Subnet Component,8{SFD2} IDE13065-Left tail lamp 1: parameter set,No Response From Subnet Component,8{SFD2} IDE13066-Left tail lamp 2: parameter set,No Response From Subnet Component,8{SFD2} IDE13067-Right tail lamp 1: parameter set,No Response From Subnet Component,8{SFD2} IDE13068-Right tail lamp 2: parameter set,No Response From Subnet Component,8{SFD2} IDE13354-Wiper motor control module: dataset 2,No Response From Subnet Component,8{SFD2} IDE13355-Wiper motor control module: dataset 3,No Response From Subnet Component,8{SFD2} IDE13356-Wiper motor control module: dataset 4,No Response From Subnet Component,8{SFD2} IDE13391-IDE17779-BAP function status-Exit/entry lighting: brightness detection,old ,16{SFD2} IDE13391-IDE17826-BAP function status-Switchable light signature: front added,not installed ,16{SFD2} IDE13391-IDE17827-BAP function status-Light signature: front,not installed ,16{SFD2} IDE13391-IDE17828-BAP function status-Light signature: rear,not installed ,16{SFD2} IDE13391-IDE17848-BAP function status-Switchable light signature: rear added,not installed ,16{SFD2} IDE13391-IDE18239-BAP function status-Daytime running light timer: delay,0 ms,16{SFD2} IDE13391-IDE18240-BAP function status-Low beam headlight timer: delay,0 ms,16{SFD2} IDE13391-IDE18241-BAP function status-Default value for operating and display log for taillight animation,0 ,16{SFD2} IDE13391-IDE18242-BAP function status-Default value for operating and display log for turn signal animation,0 ,16{SFD2} IDE13391-IDE20512-BAP function status-Operating and display log: taillight signature standard value,0 ,16{SFD2} IDE13391-IDE20515-BAP function status-Installation coding: troubleshooting switchable light signatures,not installed ,16{SFD2} IDE13391-MAS28779-BAP function status-Leaving Home lights,Low beams ,16{SFD2} IDE13391-MAS28797-BAP function status-Leaving Home light: default value for time setting via BAP,not active ,16{SFD2} IDE13391-MAS28798-BAP function status-Leaving Home light: default value for time setting during the day,10 seconds ,16{SFD2} IDE13391-MAS28800-BAP function status-Leaving Home light: switch-on event,Ignition On ,16{SFD2} IDE13391-MAS28803-BAP function status-Leaving Home and Coming Home light: run-on,0 ms,16{SFD2} IDE13391-MAS28804-BAP function status-Daytime running light with Leaving Home light during the day in AUTO position,not active ,16{SFD2} IDE13391-MAS28816-BAP function status-Daytime running light with Coming Home light during the day in AUTO position,not active ,16{SFD2} IDE13391-MAS28833-BAP function status-Switchable signatures,not installed ,16{SFD2} IDE13391-MAS28891-BAP function status-Coming Home light: default value for time setting during the day,10 seconds ,16{SFD2} IDE13391-MAS28892-BAP function status-Coming Home light: default value for time setting via BAP,not active ,16{SFD2} IDE13391-MAS28915-BAP function status-Switchable signatures: selection of light functions for switching,00 ,16{SFD2} IDE13391-MAS28916-BAP function status-Switchable signatures: operating mode (ECE: NAR: RoW),0 ,16{SFD2} IDE13391-MAS28920-BAP function status-Default value for operating and display log headlight signature,0 ,16{SFD2} IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung,0 lx,16{SFD2} IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung,0 lx,16{SFD2} IDE15050-ENG258767-Occupant Detection-central locking system deactivation_ComfortReadyStatus,true ,20{SFD2} IDE15050-ENG261091-Occupant Detection-ComfortReadyStatus_Klemme_S,false ,20{SFD2} IDE15050-ENG260007-Occupant Detection-deactivation_ComfortReadyStatus,door ,20{SFD2} IDE15050-ENG258901-Occupant Detection-DriverSBE_Out,true ,20{SFD2} IDE15050-ENG260692-Occupant Detection-HV_Fahreranwesenheit_aktiv,false ,20{SFD2} IDE15050-ENG259960-Occupant Detection-HV_Fahreranwesenheit_deactivation_via_Kl15,false ,20{SFD2} IDE15050-ENG259613-Occupant Detection-nm_cluster_ComfortReadyStatus,not_active ,20{SFD2} IDE15050-ENG261255-Occupant Detection-nm_cluster_tuer,not_active ,20{SFD2} IDE15050-ENG259794-Occupant Detection-nm_timeout_tuer,90 s,20{SFD2} IDE15050-ENG260195-Occupant Detection-OccupantSBE_Out,true ,20{SFD2} IDE15050-ENG258604-Occupant Detection-timeout_ComfortReadyStatus,30 s,20{SFD2} IDE15050-ENG260437-Occupant Detection-timeout_DriverExitIntent,30 s,20{SFD2} IDE15901-Direct entry keys,installed ,2{SFD2} IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light,No ,4{SFD2} IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light,Yes ,4{SFD2} IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL,Yes ,4{SFD2} IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.,Yes ,4IDE15906-ENG395123-Light control module-High_Beam_Architecture,1_FLA ,4IDE15906-ENG430598-Light control module-LCM_Mounting,not_installed ,4IDE15906-ENG430599-Light control module-LCM_Turn_Indicator,true ,4{SFD2} IDE16363-IDE16579-Writing data to subsystem-Data record for identifier (target),General reject,4{SFD2} IDE16363-MAS25934-Writing data to subsystem-Node address of the subsystem (destination),General reject,4{SFD2} IDE16363-MAS25935-Writing data to subsystem-Identifier (destination),General reject,4{SFD2} IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,388{SFD2} IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,00 C1 ,388{SFD2} IDE19299-MAS14172-Smart rear combination lamp: configuration-Brake light larger area,not active ,23{SFD2} IDE19299-MAS14173-Smart rear combination lamp: configuration-Brake light smaller area,not active ,23{SFD2} IDE19299-MAS28752-Smart rear combination lamp: configuration-Dynamic taillight,not active ,23{SFD2} IDE19299-MAS28753-Smart rear combination lamp: configuration-Adaptive brightness adjustment: rear,not active ,23{SFD2} IDE19299-MAS28754-Smart rear combination lamp: configuration-Activation status: additional taillight faulty,not active ,23{SFD2} IDE19299-MAS28755-Smart rear combination lamp: configuration-Activation status: diagnostics LED faulty,not active ,23{SFD2} IDE19299-MAS28756-Smart rear combination lamp: configuration-Activation status: diagnostics status faulty,not active ,23{SFD2} IDE19299-MAS28757-Smart rear combination lamp: configuration-Upper speed threshold: dynamic taillight ON,75 km/h,23{SFD2} IDE19299-MAS28758-Smart rear combination lamp: configuration-Lower speed threshold: dynamic taillight OFF,60 km/h,23{SFD2} IDE19299-MAS28759-Smart rear combination lamp: configuration-Lower speed threshold: braking surface reduced ON,10 km/h,23{SFD2} IDE19299-MAS28760-Smart rear combination lamp: configuration-Upper speed threshold: braking surface reduced OFF,20 km/h,23{SFD2} IDE19299-MAS28765-Smart rear combination lamp: configuration-Taillight animation: when light button module is set to AUTO,not active ,23{SFD2} IDE19299-MAS28766-Smart rear combination lamp: configuration-Taillight animation: dimming activation when terminal 15 OFF,0 ,23{SFD2} IDE19299-MAS28767-Smart rear combination lamp: configuration-Taillight animation: dimming activation when terminal 15 ON,0 ,23{SFD2} IDE19299-MAS28771-Smart rear combination lamp: configuration-Delay time until braking surface must be engaged,10 ms,23{SFD2} IDE19299-MAS28773-Smart rear combination lamp: configuration-Upper distance threshold: increase braking surface,0.00 m,23{SFD2} IDE19299-MAS28774-Smart rear combination lamp: configuration-Lower distance threshold: reduce braking surface,0.00 m,23{SFD2} IDE19299-MAS28780-Smart rear combination lamp: configuration-Lower ambient brightness threshold: decrease brightness of rear combination lamp,4000 lx,23{SFD2} IDE19299-MAS28781-Smart rear combination lamp: configuration-Upper ambient brightness threshold: increase brightness of rear combination lamp,50000 lx,23{SFD2} IDE19299-MAS28793-Smart rear combination lamp: configuration-Acceleration threshold: brake light area enlargement,-16.00000 m/s²,23{SFD2} IDE19299-ENG260962-Smart rear combination lamp: configuration-p_CHO_LHO_statisch,not active ,23{SFD2} IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,No Response From Subnet Component,23{SFD2} IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,23{SFD2} IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,No Response From Subnet Component,23{SFD2} IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,No Response From Subnet Component,23{SFD2} IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,No Response From Subnet Component,23{SFD2} IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,No Response From Subnet Component,23{SFD2} IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,No Response From Subnet Component,23{SFD2} IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,No Response From Subnet Component,23{SFD2} IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,No Response From Subnet Component,23{SFD2} IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,23{SFD2} IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,23{SFD2} IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,23{SFD2} IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,No Response From Subnet Component,23{SFD2} IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,No Response From Subnet Component,23{SFD2} IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,No Response From Subnet Component,23{SFD2} IDE80008-ENG259691-Analysis 8-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,23{SFD2} IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,No Response From Subnet Component,23{SFD2} IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,23{SFD2} IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,23{SFD2} IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,23{SFD2} IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung,No Response From Subnet Component,23{SFD2} IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung,No Response From Subnet Component,23{SFD2} IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,23{SFD2} IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,23{SFD2} IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,23{SFD2} IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,23{SFD2} IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,No Response From Subnet Component,23{SFD2} IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,No Response From Subnet Component,23{SFD2} IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,No Response From Subnet Component,23{SFD2} IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,No Response From Subnet Component,23{SFD2} IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,No Response From Subnet Component,23{SFD2} IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,No Response From Subnet Component,23{SFD2} IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,No Response From Subnet Component,23{SFD2} IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,23{SFD2} IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,23{SFD2} IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,23{SFD2} IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,No Response From Subnet Component,23{SFD2} IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,No Response From Subnet Component,23{SFD2} IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,No Response From Subnet Component,23{SFD2} IDE80013-ENG259691-Analysis 13-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,23{SFD2} IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,No Response From Subnet Component,23{SFD2} IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,23{SFD2} IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,23{SFD2} IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,23{SFD2} IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung,No Response From Subnet Component,23{SFD2} IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung,No Response From Subnet Component,23{SFD2} IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,23{SFD2} IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,23{SFD2} IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,23{SFD2} IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,23{SFD2} IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,23{SFD2} IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,23{SFD2} IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,23{SFD2} IDE80016-Analysis 16,No Response From Subnet Component,23{SFD2} IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,No Response From Subnet Component,23{SFD2} IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,No Response From Subnet Component,23{SFD2} IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,No Response From Subnet Component,23{SFD2} IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,No Response From Subnet Component,23{SFD2} IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,No Response From Subnet Component,23{SFD2} IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,No Response From Subnet Component,23{SFD2} IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,No Response From Subnet Component,23{SFD2} IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,No Response From Subnet Component,23{SFD2} IDE80017-ENG289601-Analysis 17-Offset_PP1,No Response From Subnet Component,23{SFD2} IDE80017-ENG289602-Analysis 17-Offset_PP2,No Response From Subnet Component,23{SFD2} IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,No Response From Subnet Component,23{SFD2} IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,No Response From Subnet Component,23{SFD2} IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,No Response From Subnet Component,23{SFD2} IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,No Response From Subnet Component,23{SFD2} IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,No Response From Subnet Component,23{SFD2} IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,No Response From Subnet Component,23{SFD2} IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,No Response From Subnet Component,23{SFD2} IDE80017-ENG289603-Analysis 17-Offset_T1,No Response From Subnet Component,23{SFD2} IDE80017-ENG289604-Analysis 17-Offset_T2,No Response From Subnet Component,23{SFD2} IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,No Response From Subnet Component,23{SFD2} IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,No Response From Subnet Component,23{SFD2} IDE80017-ENG133491-Analysis 17-p_longpush_time,No Response From Subnet Component,23{SFD2} IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,23{SFD2} IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,23{SFD2} IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,No Response From Subnet Component,23{SFD2} IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,No Response From Subnet Component,23{SFD2} IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,23{SFD2} IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,No Response From Subnet Component,23{SFD2} IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,23{SFD2} IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,23{SFD2} IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,23{SFD2} IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,23{SFD2} IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,23{SFD2} IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,23{SFD2} IDE80017-ENG133465-Analysis 17-s_MaxIntervall,No Response From Subnet Component,23{SFD2} IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,No Response From Subnet Component,23{SFD2} IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,23{SFD2} IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,No Response From Subnet Component,23{SFD2} IDE80017-ENG133468-Analysis 17-s_Sitzvariante,No Response From Subnet Component,23{SFD2} IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,23{SFD2} IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,23{SFD2} IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,No Response From Subnet Component,23{SFD2} IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,No Response From Subnet Component,23{SFD2} IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,No Response From Subnet Component,23{SFD2} IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,No Response From Subnet Component,23{SFD2} IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,No Response From Subnet Component,23{SFD2} IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,No Response From Subnet Component,23{SFD2} IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,No Response From Subnet Component,23{SFD2} IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,No Response From Subnet Component,23{SFD2} IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,No Response From Subnet Component,23{SFD2} IDE80018-ENG289601-Analysis 18-Offset_PP1,No Response From Subnet Component,23{SFD2} IDE80018-ENG289602-Analysis 18-Offset_PP2,No Response From Subnet Component,23{SFD2} IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,No Response From Subnet Component,23{SFD2} IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,No Response From Subnet Component,23{SFD2} IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,No Response From Subnet Component,23{SFD2} IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,No Response From Subnet Component,23{SFD2} IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,No Response From Subnet Component,23{SFD2} IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,No Response From Subnet Component,23{SFD2} IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,No Response From Subnet Component,23{SFD2} IDE80018-ENG289603-Analysis 18-Offset_T1,No Response From Subnet Component,23{SFD2} IDE80018-ENG289604-Analysis 18-Offset_T2,No Response From Subnet Component,23{SFD2} IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,No Response From Subnet Component,23{SFD2} IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,No Response From Subnet Component,23{SFD2} IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,No Response From Subnet Component,23{SFD2} IDE80018-ENG133491-Analysis 18-p_longpush_time,No Response From Subnet Component,23{SFD2} IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,23{SFD2} IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,23{SFD2} IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,No Response From Subnet Component,23{SFD2} IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,No Response From Subnet Component,23{SFD2} IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,23{SFD2} IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,No Response From Subnet Component,23{SFD2} IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,23{SFD2} IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,23{SFD2} IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,23{SFD2} IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,23{SFD2} IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,23{SFD2} IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,23{SFD2} IDE80018-ENG133465-Analysis 18-s_MaxIntervall,No Response From Subnet Component,23{SFD2} IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,No Response From Subnet Component,23{SFD2} IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,23{SFD2} IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,No Response From Subnet Component,23{SFD2} IDE80018-ENG133468-Analysis 18-s_Sitzvariante,No Response From Subnet Component,23{SFD2} IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,23{SFD2} IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,23{SFD2} IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,No Response From Subnet Component,23{SFD2} IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,No Response From Subnet Component,23{SFD2} IDE80019-ENG125667-Analysis 19-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125666-Analysis 19-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125668-Analysis 19-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125673-Analysis 19-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125672-Analysis 19-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125674-Analysis 19-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125670-Analysis 19-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125669-Analysis 19-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125671-Analysis 19-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125676-Analysis 19-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125675-Analysis 19-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125677-Analysis 19-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125664-Analysis 19-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125663-Analysis 19-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80019-ENG125665-Analysis 19-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125667-Analysis 20-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125666-Analysis 20-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125668-Analysis 20-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125673-Analysis 20-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125672-Analysis 20-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125674-Analysis 20-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125670-Analysis 20-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125669-Analysis 20-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125671-Analysis 20-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125676-Analysis 20-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125675-Analysis 20-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125677-Analysis 20-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125664-Analysis 20-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125663-Analysis 20-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80020-ENG125665-Analysis 20-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125667-Analysis 21-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125666-Analysis 21-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125668-Analysis 21-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125673-Analysis 21-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125672-Analysis 21-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125674-Analysis 21-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125670-Analysis 21-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125669-Analysis 21-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125671-Analysis 21-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125676-Analysis 21-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125675-Analysis 21-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125677-Analysis 21-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125664-Analysis 21-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125663-Analysis 21-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80021-ENG125665-Analysis 21-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125667-Analysis 22-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125666-Analysis 22-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125668-Analysis 22-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125673-Analysis 22-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125672-Analysis 22-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125674-Analysis 22-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125670-Analysis 22-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125669-Analysis 22-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125671-Analysis 22-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125676-Analysis 22-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125675-Analysis 22-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125677-Analysis 22-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125664-Analysis 22-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125663-Analysis 22-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80022-ENG125665-Analysis 22-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125667-Analysis 23-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125666-Analysis 23-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125668-Analysis 23-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125673-Analysis 23-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125672-Analysis 23-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125674-Analysis 23-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125670-Analysis 23-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125669-Analysis 23-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125671-Analysis 23-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125676-Analysis 23-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125675-Analysis 23-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125677-Analysis 23-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125664-Analysis 23-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125663-Analysis 23-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80023-ENG125665-Analysis 23-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125667-Analysis 24-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125666-Analysis 24-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125668-Analysis 24-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125673-Analysis 24-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125672-Analysis 24-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125674-Analysis 24-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125670-Analysis 24-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125669-Analysis 24-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125671-Analysis 24-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125676-Analysis 24-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125675-Analysis 24-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125677-Analysis 24-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125664-Analysis 24-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125663-Analysis 24-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80024-ENG125665-Analysis 24-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80025-ENG126865-Analysis 25-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,23{SFD2} IDE80025-ENG126867-Analysis 25-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,23{SFD2} IDE80025-ENG126866-Analysis 25-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,23{SFD2} IDE80025-ENG126868-Analysis 25-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,23{SFD2} IDE80025-ENG125690-Analysis 25-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,23{SFD2} IDE80026-ENG125667-Analysis 26-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125691-Analysis 26-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,23{SFD2} IDE80026-ENG125668-Analysis 26-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125673-Analysis 26-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125672-Analysis 26-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125674-Analysis 26-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125670-Analysis 26-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125669-Analysis 26-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125671-Analysis 26-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125676-Analysis 26-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125675-Analysis 26-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125677-Analysis 26-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125664-Analysis 26-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125663-Analysis 26-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80026-ENG125665-Analysis 26-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125667-Analysis 27-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125666-Analysis 27-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125668-Analysis 27-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125673-Analysis 27-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125672-Analysis 27-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125674-Analysis 27-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125670-Analysis 27-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125669-Analysis 27-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125671-Analysis 27-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125676-Analysis 27-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125675-Analysis 27-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125677-Analysis 27-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125664-Analysis 27-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125663-Analysis 27-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80027-ENG125665-Analysis 27-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125667-Analysis 28-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125666-Analysis 28-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125668-Analysis 28-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125673-Analysis 28-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125672-Analysis 28-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125674-Analysis 28-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125670-Analysis 28-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125669-Analysis 28-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125671-Analysis 28-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125676-Analysis 28-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125675-Analysis 28-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125677-Analysis 28-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125692-Analysis 28-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,23{SFD2} IDE80028-ENG125663-Analysis 28-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80028-ENG125665-Analysis 28-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125667-Analysis 29-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125666-Analysis 29-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125668-Analysis 29-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125673-Analysis 29-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125672-Analysis 29-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125674-Analysis 29-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125670-Analysis 29-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125669-Analysis 29-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125671-Analysis 29-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125676-Analysis 29-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125675-Analysis 29-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125677-Analysis 29-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125664-Analysis 29-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125663-Analysis 29-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80029-ENG125665-Analysis 29-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125667-Analysis 30-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125666-Analysis 30-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125668-Analysis 30-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125673-Analysis 30-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125672-Analysis 30-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125674-Analysis 30-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125670-Analysis 30-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125669-Analysis 30-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125671-Analysis 30-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125676-Analysis 30-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125675-Analysis 30-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125677-Analysis 30-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125664-Analysis 30-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125663-Analysis 30-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} IDE80030-ENG125665-Analysis 30-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,23{SFD2} MAS05055-lower turn position,No Response From Subnet Component,23{SFD2} MAS05056-upper turn position,No Response From Subnet Component,23{SFD2} MAS05807-ENG264052-Coding-Abparken nach Stop Haubenkontak (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264068-Coding-adaptive Nachwischzyklen SRA (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264069-Coding-APS bei Abparken (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264070-Coding-APS bei Klemme 15 Wechsel (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264071-Coding-APS für 100 Zyklen deaktiv (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264072-Coding-APS2 Verlassen bei Geschwindigkeit (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264178-Coding-geräusch optimierte Wischkennlinie (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264181-Coding-langsames Abparken (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264190-Coding-Produktionsmodus möglich (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264192-Coding-Regensensoraktivierung über Fahrfreigabe (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264194-Coding-Schleppfunktion Poti (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264195-Coding-schnelles Tippwischen (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264271-Coding-softe Geschwindigkeitsrückschaltung (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264272-Coding-Start bei Klemme 15 EIN (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264274-Coding-Stop bei Haubenkontakt (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264275-Coding-Stop bei Klemme 15 AUS (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264276-Coding-Tränenwischen (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264279-Coding-v-abhängige Wischstufenrückschaltung (1bit),No Response From Subnet Component,23{SFD2} MAS05807-ENG264280-Coding-variable Intervallwischgeschwindigkeit (1bit),No Response From Subnet Component,23{SFD2} MAS05894-IDE13022-Engine run on-Function activation,not active ,4{SFD2} MAS05894-MAS13391-Engine run on-Delay time timer,400 ms,4{SFD2} MAS07146-MAS13125-Button 1-Function of button 1,not coded / not installed ,1{SFD2} MAS07146-MAS13128-Button 1-Indicator lamp button 1,installed ,1{SFD2} MAS07147-MAS13129-Button 2-Function of button 2,not coded / not installed ,1{SFD2} MAS07147-MAS13131-Button 2-Indicator lamp button 2,installed ,1{SFD2} MAS07148-MAS13132-Button 3-Function of button 3,not coded / not installed ,1{SFD2} MAS07148-MAS13134-Button 3-Indicator lamp button 3,installed ,1MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,1200 lx,24MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,2200 lx,24MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO,600 lx,24MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten,1200 lx,24MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten,2200 lx,24MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 1E ,24MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,3500 lx,24MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway,not active ,24MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,Medium ,24MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,3800 mV,24MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,3500 lx,24MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke,0 lx,24MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung,02 ,24{SFD2} MAS09325-IDE13878-Daytime running lights-Activation: daytime running lights,Daytime running lights ,8{SFD2} MAS09325-MAS09335-Daytime running lights-Daytime running lights/parking light,not active ,8{SFD2} MAS09325-MAS16273-Daytime running lights-Speed warning active: rear fog lamps,0 km/h,8{SFD2} MAS09325-MAS21314-Daytime running lights-Daytime running indicator lamp,not active ,8{SFD2} MAS09325-MAS28806-Daytime running lights-Daytime running light: speed-dependent,0 km/h,8{SFD2} MAS09325-MAS28807-Daytime running lights-Daytime running light: deactivation via speed,not active ,8{SFD2} MAS09325-MAS28808-Daytime running lights-Daytime running light: switchover of standard output value,active ,8{SFD2} MAS09325-MAS28812-Daytime running lights-Deactivate daytime/continuous running light with handbrake active,not active ,8{SFD2} MAS09325-MAS28813-Daytime running lights-Daytime/continuous running light also activates two-sided parking light,not active ,8{SFD2} MAS09325-MAS28814-Daytime running lights-Daytime running light activation possible via BAP or operating sequence,not active ,8{SFD2} MAS09325-MAS28815-Daytime running lights-Daytime running light only in AUTO switch position,active ,8{SFD2} MAS09325-ENG387560-Daytime running lights-DRL_activates_tail_light,not active ,8{SFD2} MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode,active ,8{SFD2} MAS12382-MAS07029-Dynamic turn signal control-Crash flashing,active ,8{SFD2} MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing,active ,8{SFD2} MAS12382-MAS07033-Dynamic turn signal control-Panic flashing,active ,8{SFD2} MAS12382-MAS07034-Dynamic turn signal control-Theft flashing,active ,8{SFD2} MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing,active ,8{SFD2} MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing,active ,8{SFD2} MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing,active ,8{SFD2} MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant,active ,8{SFD2} MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking,active ,8{SFD2} MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking,active ,8{SFD2} MAS12382-MAS28788-Dynamic turn signal control-Multi-collision indication,not active ,8{SFD2} MAS12382-MAS28820-Dynamic turn signal control-Side Assist: left turn signal,active ,8{SFD2} MAS12382-MAS28821-Dynamic turn signal control-Side Assist: right turn signal,active ,8{SFD2} MAS12382-MAS28825-Dynamic turn signal control-Hazard warning lights with ignition off,active ,8{SFD2} MAS12382-MAS28826-Dynamic turn signal control-Hazard warning lights with ignition on,active ,8{SFD2} MAS12382-MAS28829-Dynamic turn signal control-Emergency warning signal: emergency brake display: phase 2,active ,8{SFD2} MAS12382-MAS28831-Dynamic turn signal control-Turn signal: left,active ,8{SFD2} MAS12382-MAS28832-Dynamic turn signal control-Turn signal: right,active ,8{SFD2} MAS12382-MAS28912-Dynamic turn signal control-Park Assist/Park Assist Plus with remote control: turn signal confirmation,active ,8{SFD2} MAS12382-MAS28913-Dynamic turn signal control-Park Assist/Park Assist Plus with remote control: turn signal left,active ,8{SFD2} MAS12382-MAS28914-Dynamic turn signal control-Park Assist/Park Assist Plus with remote control: turn signal right,active ,8{SFD2} MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung,active ,8{SFD2} MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay,50 ms,8{SFD2} MAS13139-MAS13135-Button 4-Function of button 4,not coded / not installed ,1{SFD2} MAS13139-MAS13136-Button 4-Indicator lamp button 4,installed ,1{SFD2} MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,No Response From Subnet Component,1{SFD2} MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,No Response From Subnet Component,1{SFD2} MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,No Response From Subnet Component,1{SFD2} MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,No Response From Subnet Component,1{SFD2} MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,No Response From Subnet Component,1{SFD2} MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,No Response From Subnet Component,1{SFD2} MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,No Response From Subnet Component,1{SFD2} MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,No Response From Subnet Component,1{SFD2} MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,No Response From Subnet Component,1{SFD2} MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,No Response From Subnet Component,1{SFD2} MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,No Response From Subnet Component,1{SFD2} MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,No Response From Subnet Component,1{SFD2} MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,No Response From Subnet Component,1{SFD2} MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,No Response From Subnet Component,1{SFD2} MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,No Response From Subnet Component,1{SFD2} MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,No Response From Subnet Component,1{SFD2} MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,No Response From Subnet Component,1{SFD2} MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,No Response From Subnet Component,1{SFD2} MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,No Response From Subnet Component,1{SFD2} MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,No Response From Subnet Component,1{SFD2} MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,No Response From Subnet Component,1{SFD2} MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,No Response From Subnet Component,1{SFD2} MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,No Response From Subnet Component,1{SFD2} MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,No Response From Subnet Component,1{SFD2} MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,No Response From Subnet Component,1{SFD2} MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,No Response From Subnet Component,1{SFD2} MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,No Response From Subnet Component,1{SFD2} MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,No Response From Subnet Component,1{SFD2} MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,No Response From Subnet Component,1{SFD2} MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,No Response From Subnet Component,1{SFD2} MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,No Response From Subnet Component,1{SFD2} MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,No Response From Subnet Component,1{SFD2} MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,No Response From Subnet Component,1{SFD2} MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,No Response From Subnet Component,1{SFD2} MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,No Response From Subnet Component,1{SFD2} MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,No Response From Subnet Component,1{SFD2} MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,No Response From Subnet Component,1{SFD2} MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,No Response From Subnet Component,1{SFD2} MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,No Response From Subnet Component,1{SFD2} MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,No Response From Subnet Component,1{SFD2} MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,No Response From Subnet Component,1{SFD2} MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,No Response From Subnet Component,1{SFD2} MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,No Response From Subnet Component,1{SFD2} MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,No Response From Subnet Component,1{SFD2} MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,No Response From Subnet Component,1{SFD2} MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,No Response From Subnet Component,1{SFD2} MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,No Response From Subnet Component,1{SFD2} MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,No Response From Subnet Component,1{SFD2} MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,No Response From Subnet Component,1{SFD2} MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,No Response From Subnet Component,1{SFD2} MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,No Response From Subnet Component,1{SFD2} MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,No Response From Subnet Component,1{SFD2} MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,No Response From Subnet Component,1{SFD2} MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,No Response From Subnet Component,1{SFD2} MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,No Response From Subnet Component,1{SFD2} MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,No Response From Subnet Component,1{SFD2} MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,No Response From Subnet Component,1{SFD2} MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,No Response From Subnet Component,1{SFD2} MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,No Response From Subnet Component,1{SFD2} MAS14140-IDE15905-Flashing function-Travel Assist,not active ,4{SFD2} MAS14140-IDE18029-Flashing function-Rush Hour Pilot,not active ,4{SFD2} MAS14140-IDE20494-Flashing function-Installation coding: flashing request for rush hour pilot,not active ,4{SFD2} MAS14140-IDE21298-Flashing function-Travel Assist Handsfree,not active ,4{SFD2} MAS14140-MAS28783-Flashing function-Driving assistance system: flashing function,Hazard warning lights permitted ,4{SFD2} MAS14140-MAS28895-Flashing function-Hazard warning lights by means of driver assist system,not active ,4{SFD2} MAS14140-MAS28928-Flashing function-Horn via driver assist system,active ,4{SFD2} MAS18824-IDE15903-Light button module-Light button module,LTM_Zentraltaste ,12{SFD2} MAS18824-MAS21301-Light button module-Reactivation limit light,95 m,12{SFD2} MAS18824-ENG246963-Light button module-Anzeigezeit_LTM_PopUp1,4.0 s,12{SFD2} MAS18824-ENG246964-Light button module-Anzeigezeit_LTM_PopUp1_lang,4 s,12{SFD2} MAS18824-ENG246965-Light button module-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,12{SFD2} MAS18824-ENG246966-Light button module-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,12{SFD2} MAS18824-ENG246978-Light button module-Licht_anforderung_FAS,not installed ,12{SFD2} MAS18824-ENG246979-Light button module-Licht_anforderung_Pilopark,not active ,12{SFD2} MAS18824-ENG246982-Light button module-LTM_Anzeige_Config,02 ,12{SFD2} MAS18824-ENG246983-Light button module-LTM_Beleuchtung_Geschwindigkeits_Schwelle,10 km/h,12{SFD2} MAS18824-ENG246984-Light button module-LTM_BGL_Geschwindigkeitsabhängig,active ,12{SFD2} MAS18824-ENG246985-Light button module-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,12{SFD2} MAS18824-ENG246986-Light button module-LTM_BGL_Wegabhängig,active ,12{SFD2} MAS18824-ENG246987-Light button module-LTM_GlobalOFF_Geschwindigkeitsabhängig,active ,12{SFD2} MAS18824-ENG246988-Light button module-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,12{SFD2} MAS18824-ENG246989-Light button module-LTM_GlobalOFF_Wegabhängig,active ,12{SFD2} MAS18824-ENG246990-Light button module-LTM_GlobalOFF_Zündungsabhängig,not active ,12{SFD2} MAS18831-IDE80001-Control module for optical rear lid opening: dataset-Analysis 1,No Response From Subnet Component,12{SFD2} MAS18831-IDE80002-Control module for optical rear lid opening: dataset-Analysis 2,No Response From Subnet Component,12{SFD2} MAS18831-IDE80003-Control module for optical rear lid opening: dataset-Analysis 3,No Response From Subnet Component,12{SFD2} MAS18831-IDE80004-Control module for optical rear lid opening: dataset-Analysis 4,No Response From Subnet Component,12{SFD2} MAS18831-IDE80005-Control module for optical rear lid opening: dataset-Analysis 5,No Response From Subnet Component,12{SFD2} MAS18831-IDE80006-Control module for optical rear lid opening: dataset-Analysis 6,No Response From Subnet Component,12{SFD2} MAS18831-IDE80007-Control module for optical rear lid opening: dataset-Analysis 7,No Response From Subnet Component,12{SFD2} MAS18831-IDE80008-Control module for optical rear lid opening: dataset-Analysis 8,No Response From Subnet Component,12{SFD2} MAS18831-IDE80009-Control module for optical rear lid opening: dataset-Analysis 9,No Response From Subnet Component,12{SFD2} MAS18831-IDE80010-Control module for optical rear lid opening: dataset-Analysis 10,No Response From Subnet Component,12{SFD2} MAS18831-IDE80011-Control module for optical rear lid opening: dataset-Analysis 11,No Response From Subnet Component,12{SFD2} MAS18831-IDE80012-Control module for optical rear lid opening: dataset-Analysis 12,No Response From Subnet Component,12{SFD2} MAS18831-IDE80013-Control module for optical rear lid opening: dataset-Analysis 13,No Response From Subnet Component,12{SFD2} MAS18831-IDE80014-Control module for optical rear lid opening: dataset-Analysis 14,No Response From Subnet Component,12{SFD2} MAS18831-IDE80015-Control module for optical rear lid opening: dataset-Analysis 15,No Response From Subnet Component,12{SFD2} MAS18831-IDE80016-Control module for optical rear lid opening: dataset-Analysis 16,No Response From Subnet Component,12{SFD2} MAS18831-IDE80017-Control module for optical rear lid opening: dataset-Analysis 17,No Response From Subnet Component,12{SFD2} MAS18831-IDE80018-Control module for optical rear lid opening: dataset-Analysis 18,No Response From Subnet Component,12{SFD2} MAS18831-IDE80019-Control module for optical rear lid opening: dataset-Analysis 19,No Response From Subnet Component,12{SFD2} MAS18831-IDE80020-Control module for optical rear lid opening: dataset-Analysis 20,No Response From Subnet Component,12{SFD2} MAS18831-IDE80021-Control module for optical rear lid opening: dataset-Analysis 21,No Response From Subnet Component,12{SFD2} MAS18831-IDE80022-Control module for optical rear lid opening: dataset-Analysis 22,No Response From Subnet Component,12{SFD2} MAS18831-IDE80023-Control module for optical rear lid opening: dataset-Analysis 23,No Response From Subnet Component,12{SFD2} MAS18831-IDE80024-Control module for optical rear lid opening: dataset-Analysis 24,No Response From Subnet Component,12{SFD2} MAS18831-IDE80025-Control module for optical rear lid opening: dataset-Analysis 25,No Response From Subnet Component,12{SFD2} MAS18831-IDE80026-Control module for optical rear lid opening: dataset-Analysis 26,No Response From Subnet Component,12{SFD2} MAS18831-IDE80027-Control module for optical rear lid opening: dataset-Analysis 27,No Response From Subnet Component,12{SFD2} MAS18831-IDE80028-Control module for optical rear lid opening: dataset-Analysis 28,No Response From Subnet Component,12{SFD2} MAS18831-IDE80029-Control module for optical rear lid opening: dataset-Analysis 29,No Response From Subnet Component,12{SFD2} MAS18831-IDE80030-Control module for optical rear lid opening: dataset-Analysis 30,No Response From Subnet Component,12{SFD2} MAS18831-IDE80031-Control module for optical rear lid opening: dataset-Analysis 31,No Response From Subnet Component,12{SFD2} MAS18831-IDE80032-Control module for optical rear lid opening: dataset-Analysis 32,No Response From Subnet Component,12{SFD2} MAS18831-IDE80033-Control module for optical rear lid opening: dataset-Analysis 33,No Response From Subnet Component,12{SFD2} MAS18831-IDE80034-Control module for optical rear lid opening: dataset-Analysis 34,No Response From Subnet Component,12{SFD2} MAS18831-IDE80035-Control module for optical rear lid opening: dataset-Analysis 35,No Response From Subnet Component,12{SFD2} MAS18831-IDE80036-Control module for optical rear lid opening: dataset-Analysis 36,No Response From Subnet Component,12{SFD2} MAS18831-IDE80037-Control module for optical rear lid opening: dataset-Analysis 37,No Response From Subnet Component,12{SFD2} MAS18831-IDE80038-Control module for optical rear lid opening: dataset-Analysis 38,No Response From Subnet Component,12{SFD2} MAS18831-IDE80039-Control module for optical rear lid opening: dataset-Analysis 39,No Response From Subnet Component,12{SFD2} MAS18831-IDE80040-Control module for optical rear lid opening: dataset-Analysis 40,No Response From Subnet Component,12{SFD2} MAS18831-IDE80041-Control module for optical rear lid opening: dataset-Analysis 41,No Response From Subnet Component,12{SFD2} MAS18831-IDE80042-Control module for optical rear lid opening: dataset-Analysis 42,No Response From Subnet Component,12{SFD2} MAS18831-IDE80043-Control module for optical rear lid opening: dataset-Analysis 43,No Response From Subnet Component,12{SFD2} MAS18831-IDE80044-Control module for optical rear lid opening: dataset-Analysis 44,No Response From Subnet Component,12{SFD2} MAS18831-IDE80045-Control module for optical rear lid opening: dataset-Analysis 45,No Response From Subnet Component,12{SFD2} MAS18831-IDE80046-Control module for optical rear lid opening: dataset-Analysis 46,No Response From Subnet Component,12{SFD2} MAS18831-IDE80047-Control module for optical rear lid opening: dataset-Analysis 47,No Response From Subnet Component,12{SFD2} MAS18831-IDE80048-Control module for optical rear lid opening: dataset-Analysis 48,No Response From Subnet Component,12{SFD2} MAS18831-IDE80049-Control module for optical rear lid opening: dataset-Analysis 49,No Response From Subnet Component,12{SFD2} MAS18831-IDE80050-Control module for optical rear lid opening: dataset-Analysis 50,No Response From Subnet Component,12{SFD2} MAS18831-IDE80051-Control module for optical rear lid opening: dataset-Analysis 51,No Response From Subnet Component,12{SFD2} MAS18831-IDE80052-Control module for optical rear lid opening: dataset-Analysis 52,No Response From Subnet Component,12{SFD2} MAS18831-IDE80053-Control module for optical rear lid opening: dataset-Analysis 53,No Response From Subnet Component,12{SFD2} MAS18831-IDE80054-Control module for optical rear lid opening: dataset-Analysis 54,No Response From Subnet Component,12{SFD2} MAS18831-IDE80055-Control module for optical rear lid opening: dataset-Analysis 55,No Response From Subnet Component,12{SFD2} MAS18831-IDE80056-Control module for optical rear lid opening: dataset-Analysis 56,No Response From Subnet Component,12{SFD2} MAS18831-IDE80057-Control module for optical rear lid opening: dataset-Analysis 57,No Response From Subnet Component,12{SFD2} MAS18831-IDE80058-Control module for optical rear lid opening: dataset-Analysis 58,No Response From Subnet Component,12{SFD2} MAS18831-IDE80059-Control module for optical rear lid opening: dataset-Analysis 59,No Response From Subnet Component,12{SFD2} MAS18831-IDE80060-Control module for optical rear lid opening: dataset-Analysis 60,No Response From Subnet Component,12{SFD2} MAS20279-WFS transponder gateway coding,Transponder GW in instrument cluster ,4SFT00061-MAS10520-Special Function-Special function 1,not installed ,4SFT00061-SFT00048-Special Function-Special Function 2,not enabled ,4SFT00061-ENG260472-Special Function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4{SFD2} ENG253311-IDE01058-604 UGDO Sender-Country coding,No Response From Subnet Component,4{SFD2} ENG253311-MAS07183-604 UGDO Sender-Oper. concept,No Response From Subnet Component,4{SFD2} ENG253311-MAS07186-604 UGDO Sender-Multimedia system,No Response From Subnet Component,4{SFD2} ENG344785-ENG345280-Alco_lock_coding-Alco_lock_installed,No ,2{SFD2} ENG344785-ENG422578-Alco_lock_coding-Comfort_ready_debounce,No ,2{SFD2} ENG344785-ENG422661-Alco_lock_coding-Eval_comfort_ready,No ,2{SFD2} ENG344785-ENG422662-Alco_lock_coding-Eval_driver_presence,Yes ,2{SFD2} ENG344785-ENG422663-Alco_lock_coding-Eval_external_LIN_activity_by_LIN_busmaster,No ,2{SFD2} ENG344785-ENG422664-Alco_lock_coding-Eval_unplausible_values_from_Alco_lock,No ,2{SFD2} ENG344785-ENG422700-Alco_lock_coding-LIN_send_delay,No ,2{SFD2} ENG344785-ENG422701-Alco_lock_coding-LIN_send_delay_msg_counter,No ,2{SFD2} ENG344785-ENG422736-Alco_lock_coding-Permanent_terminal_15_release_in_unset_mode,No ,2{SFD2} ENG344785-ENG422761-Alco_lock_coding-USS_debounce,No ,2{SFD2} ENG344785-ENG422762-Alco_lock_coding-Vehicle_state_change_mode_set_mode_to_shut_down_via_timeout,Yes ,2{SFD2} ENG344786-ENG422579-Alco_lock_parameter-Counter_unplausible_data_received,0 s,21{SFD2} ENG344786-ENG422581-Alco_lock_parameter-Debounce_Comfort_ready_signal,0.0 s,21{SFD2} ENG344786-ENG422582-Alco_lock_parameter-Debounce_USS_signals,0.0 s,21{SFD2} ENG344786-ENG422699-Alco_lock_parameter-LIN_data_send_delay,0.0 s,21{SFD2} ENG344786-ENG413992-Alco_lock_parameter-Qual_time_delay_DTC_104,0.0 s,21{SFD2} ENG344786-ENG422745-Alco_lock_parameter-Rpm_threshold_engine_running,100 /min,21{SFD2} ENG344786-ENG422750-Alco_lock_parameter-Speed_threshold_vehicle_stopped,7.0 km/h,21{SFD2} ENG344786-ENG422751-Alco_lock_parameter-State_change_set_mode_to_unset_mode_via_terminal_15,Condition_terminal_15_active ,21{SFD2} ENG344786-ENG414014-Alco_lock_parameter-Time_delay_switchoff_LIN_activity_bit,0.0 s,21{SFD2} ENG344786-ENG422754-Alco_lock_parameter-Timeout_automatic_transition_set_mode_to_shut_down,5 min,21{SFD2} ENG344786-ENG422755-Alco_lock_parameter-Timeout_automatic_transition_unset_mode_to_set_mode,1 s,21{SFD2} ENG344786-ENG422756-Alco_lock_parameter-Timeout_protocol_validation,5 s,21{SFD2} ENG344786-ENG422757-Alco_lock_parameter-Timeout_switchoff_alco_lock_after_idle_followup_time,0.0 min,21{SFD2} ENG344786-ENG346064-Alco_lock_parameter-Used_LIN_version,LIN_2_0 ,21{SFD2} ENG344786-ENG422760-Alco_lock_parameter-Used_protocol_version,Norm_version_2022 ,21{SFD2} ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max,100 ms,270{SFD2} ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9,00 00 00 00 00 00 00 00 ,270{SFD2} ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray,0 ,270{SFD2} ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld,0 ,270{SFD2} ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung,6.0 m,270{SFD2} ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID,not active ,270{SFD2} ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation,active ,270{SFD2} ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente,not active ,270{SFD2} ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout,0.00 s,270{SFD2} ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled,not active ,270{SFD2} ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken,not active ,270{SFD2} ENG253358-ENG403619-Anpassungen_Exterior_Light-VIP30_Dimmzeit,0 ms,270{SFD2} ENG253358-ENG403620-Anpassungen_Exterior_Light-VIP30_Umfeld-SALR,00 ,270{SFD2} ENG253358-ENG403621-Anpassungen_Exterior_Light-VIP30_Umfeld-TSG,00 ,270ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp,H7 ,8ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung,active ,8ENG253146-ENG345149-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung Bremslicht,not active ,8ENG253146-ENG141987-Aussenlicht-SG-Architektur-Bremslicht_ist_auch_Blinklicht,No ,8ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1,FF ,8ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2,FF ,8ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3,FF ,8ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1,FF ,8ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2,FF ,8ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3,FF ,8ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich,active ,8ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,8ENG253146-ENG115831-Aussenlicht-SG-Architektur-Schlusslicht mit Bremslichtfunktion,not active ,8ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,8{SFD2} ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv,not activated ,4{SFD2} ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv,not activated ,4{SFD2} ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv,not activated ,4{SFD2} ENG253356-ENG281101-Automatische_Funktionen-AutomatikFunktionen_WarnungWennIDGeberImInnenraum_aktiv,not activated ,4{SFD2} ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv,not activated ,4{SFD2} ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv,not activated ,4{SFD2} ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv,not activated ,4{SFD2} ENG253240-ENG263514-Automatisierte Abschaltungen-Abschalt_wunsch_entprellung,1.0 s,8{SFD2} ENG253240-ENG277086-Automatisierte Abschaltungen-Dauer für Ausführung des Abschaltwunsch an SPN,2.0 s,8{SFD2} ENG253240-ENG277087-Automatisierte Abschaltungen-Dauer Hinweistext Komfortabschaltung,10.0 s,8{SFD2} ENG253240-ENG259819-Automatisierte Abschaltungen-Signalisierungsdauer Automatische Abschaltung erfolgt,5.0 s,8{SFD2} ENG253240-ENG258392-Automatisierte Abschaltungen-Stillstandsdrehzahlschwelle Verbrennungsmotor,400 ,8{SFD2} ENG253240-ENG346089-Automatisierte Abschaltungen-Verfügbarkeit Hinweis Komfortabschaltung,active ,8{SFD2} ENG253240-ENG346090-Automatisierte Abschaltungen-Verfügbarkeit Hinweis Komfortabschaltung bevorstehend,active ,8{SFD2} ENG253240-ENG346091-Automatisierte Abschaltungen-Verfügbarkeit Hinweis Standlichtnachlauf,active ,8{SFD2} ENG253240-ENG346092-Automatisierte Abschaltungen-Verfügbarkeit Hinweis zur Weiterfahrt,not active ,8{SFD2} ENG253240-ENG258639-Automatisierte Abschaltungen-Verfügbarkeit Komfortabschaltung,Not available ,8{SFD2} ENG253240-ENG258110-Automatisierte Abschaltungen-Zündungsabschaltung über Energiemanagement,Not available ,8{SFD2} ENG253240-ENG126843-Automatisierte Abschaltungen-ZV verriegeln bei Klemme 15 Ein,not active ,8{SFD2} ENG307652-ENG331129-Child Presence Detection-p_CPD_warnton_aktiv,not active ,2{SFD2} ENG307652-ENG331130-Child Presence Detection-p_t_Delta_Timer,10 ,2{SFD2} ENG307652-ENG331133-Child Presence Detection-p_ZV_child_presence_detection,active ,2{SFD2} ENG253018-Clamp_Control,Driver´s door ,1{SFD2} ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA,10 ,40{SFD2} ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG,10 ,40{SFD2} ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS,10 ,40{SFD2} ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU,1 ,40{SFD2} ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP,10 ,40{SFD2} ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA,10 ,40{SFD2} ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK,100 ,40{SFD2} ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN,10 ,40{SFD2} ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS,10 ,40ENG253350-ENG258402-Coding_seat_pneumatics_driver_side-Function_easy_entry,No Response From Subnet Component,40ENG253350-ENG260372-Coding_seat_pneumatics_driver_side-Function_massage,No Response From Subnet Component,40ENG253350-ENG260893-Coding_seat_pneumatics_driver_side-Function_memory,No Response From Subnet Component,40ENG253350-ENG261225-Coding_seat_pneumatics_driver_side-Function_off_autocorrection,No Response From Subnet Component,40ENG253350-ENG259055-Coding_seat_pneumatics_driver_side-Function_off_delay,No Response From Subnet Component,40ENG253350-ENG259290-Coding_seat_pneumatics_driver_side-Function_personalisation,No Response From Subnet Component,40ENG253350-ENG259372-Coding_seat_pneumatics_driver_side-Function_pre_crash_lordosis,No Response From Subnet Component,40ENG253350-ENG259654-Coding_seat_pneumatics_driver_side-Function_precrash_side_support,No Response From Subnet Component,40ENG253350-ENG259159-Coding_seat_pneumatics_driver_side-Function_race_mode,No Response From Subnet Component,40ENG253350-ENG261329-Coding_seat_pneumatics_driver_side-Function_side_support,No Response From Subnet Component,40ENG253350-ENG258695-Coding_seat_pneumatics_driver_side-Level_self_diagnostics,No Response From Subnet Component,40ENG253175-ENG258402-Coding_seat_pneumatics_passenger_side-Function_easy_entry,No Response From Subnet Component,40ENG253175-ENG260372-Coding_seat_pneumatics_passenger_side-Function_massage,No Response From Subnet Component,40ENG253175-ENG260893-Coding_seat_pneumatics_passenger_side-Function_memory,No Response From Subnet Component,40ENG253175-ENG261225-Coding_seat_pneumatics_passenger_side-Function_off_autocorrection,No Response From Subnet Component,40ENG253175-ENG259055-Coding_seat_pneumatics_passenger_side-Function_off_delay,No Response From Subnet Component,40ENG253175-ENG259290-Coding_seat_pneumatics_passenger_side-Function_personalisation,No Response From Subnet Component,40ENG253175-ENG259372-Coding_seat_pneumatics_passenger_side-Function_pre_crash_lordosis,No Response From Subnet Component,40ENG253175-ENG259654-Coding_seat_pneumatics_passenger_side-Function_precrash_side_support,No Response From Subnet Component,40ENG253175-ENG259159-Coding_seat_pneumatics_passenger_side-Function_race_mode,No Response From Subnet Component,40ENG253175-ENG261329-Coding_seat_pneumatics_passenger_side-Function_side_support,No Response From Subnet Component,40ENG253175-ENG258695-Coding_seat_pneumatics_passenger_side-Level_self_diagnostics,No Response From Subnet Component,40{SFD2} ENG344797-ENG345093-Config A2L_Monitor-Address 1,00 00 00 00 ,16{SFD2} ENG344797-ENG345094-Config A2L_Monitor-Address 2,00 00 00 00 ,16{SFD2} ENG344797-ENG345095-Config A2L_Monitor-Address 3,00 00 00 00 ,16{SFD2} ENG344797-ENG345096-Config A2L_Monitor-Address 4,00 00 00 00 ,16ENG344801-Datensatz PrDet (SC 790),30 33 31 30 30 37 39 30 50 52 44 45 54 32 30 36 01 00 01 00 01 00 01 01 01 00 01 01 01 01 00 01 0A 01 0E 00 C8 01 01 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 D4 02 D4 02 D4 02 D4 00 00 00 00 00 00 00 00 02 D1 02 D1 02 D1 02 D1 00 00 00 00 00 00 00 00 02 C5 02 C5 02 C5 02 C5 00 00 00 00 00 00 00 00 02 95 02 95 02 95 02 95 02 55 02 55 02 55 02 55 00 00 00 00 00 00 00 00 00 D5 00 D5 00 D5 00 D5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 90 80 0D ,512ENG344802-Datensatz USS,30 34 30 31 30 30 36 31 55 53 53 30 30 30 30 34 00 32 00 64 07 D0 01 F4 00 0A 03 E8 00 00 00 1E 00 32 00 32 00 32 00 32 02 58 05 07 D0 01 01 01 00 01 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33 E0 D6 DD ,128{SFD2} ENG126647-ENG98399-debug_light_function-Activation,0 ,11{SFD2} ENG126647-ENG101417-debug_light_function-Adresse,0 ,11{SFD2} ENG126647-ENG126820-debug_light_function-Bitmask,0 ,11{SFD2} ENG126647-ENG126821-debug_light_function-Divisor,0 ,11{SFD2} ENG126647-ENG98827-debug_light_function-Offset,0 ,11{SFD2} ENG126647-ENG126822-debug_light_function-Polaritaet,0 ,11{SFD2} ENG253229-ENG258467-Define_Const-Dimm2Bin,0 %,4{SFD2} ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld,0.00 s,4{SFD2} ENG253229-ENG253468-Define_Const-Gamma,0.0 ,4{SFD2} ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung,Standlicht/Fahrlicht_u_RLS ,5{SFD2} ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle,20 ,5{SFD2} ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle,100 ,5{SFD2} ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert,100 ,5{SFD2} ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-,05 ,5{SFD2} ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function,Function only allowed for terminal 15 off ,6{SFD2} ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv,not activated ,6{SFD2} ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv,not_activated ,6{SFD2} ENG253216-ENG345291-DevCod_Automatische_Verriegelung-AutomatischeFunktionenDurchExterneTrigger_aktiv,activated ,6{SFD2} ENG253028-DevCod_Bedienstellen,not activated ,1{SFD2} ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function,not active ,6{SFD2} ENG253195-ENG281096-DevCod_Dienste_Byte1-Entry_Deaktivierung_aktiv,not activated ,6{SFD2} ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante,not activated ,6{SFD2} ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv,activated ,6{SFD2} ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv,activated ,6{SFD2} ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart,activated ,6{SFD2} ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv,activated ,6{SFD2} ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante,not activated ,6{SFD2} ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv,not activated ,6{SFD2} ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv,not activated ,6{SFD2} ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren,activated ,6{SFD2} ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv,not activated ,6{SFD2} ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv,not activated ,6{SFD2} ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv,not activated ,6{SFD2} ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv,not activated ,6{SFD2} ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv,not activated ,6{SFD2} ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close,not activated ,6{SFD2} ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit,not activated ,6{SFD2} ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut,activated ,6{SFD2} ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible,not activated ,6{SFD2} ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer,activated ,6{SFD2} ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer,activated ,6{SFD2} ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen,activated ,6{SFD2} ENG253296-ENG259616-DevCod_Fahrzeugkonfiguration_Byte1-Reaktivierung_all_Tueren_VK2,not activated ,6{SFD2} ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut,installed ,6{SFD2} ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv,not activated ,6{SFD2} ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv,not activated ,6{SFD2} ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv,not activated ,6{SFD2} ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv,not activated ,6{SFD2} ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv,not activated ,6{SFD2} ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering assignment,Left ,6{SFD2} ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer,activated ,6{SFD2} ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen,not activated ,6{SFD2} ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schließverhinderung,activated ,6{SFD2} ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante,not activated ,6{SFD2} ENG253369-ENG281080-DevCod_IDGeber_Suche-Unterdrueckung_zyklischer _Suchen_bei_entriegeltem_Fahrzeug_aktiv,not activated ,6{SFD2} ENG253170-ENG281102-DevCod_Nutzerkonfigurationen-HMIMenue_Aktivierung_Nah_Mittel_Fern_aktiv,not activated ,6{SFD2} ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv,not activated ,6{SFD2} ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv,not activated ,6{SFD2} ENG253170-ENG281078-DevCod_Nutzerkonfigurationen-HMIMenue_Nutzer_Warnung_AutomatikFunktion_aktiv,not activated ,6{SFD2} ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function,Function only allowed for terminal 15 off ,7{SFD2} ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function,not activated ,7{SFD2} ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function,Function only allowed for terminal 15 off ,7{SFD2} ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren,activated ,7{SFD2} ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer,not activated ,7{SFD2} ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren,not activated ,7{SFD2} ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv,not activated ,7{SFD2} ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart,not activated ,6{SFD2} ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe,activated ,6{SFD2} ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebetür,activated ,6{SFD2} ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6{SFD2} ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,not installed ,6{SFD2} ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,not active ,6{SFD2} ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,limited ,6{SFD2} ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6{SFD2} ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,not installed ,6{SFD2} ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,not active ,6{SFD2} ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,not installed ,6{SFD2} ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6{SFD2} ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6{SFD2} ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6{SFD2} ENG253244-MAS31160-Diebstahlschutz.Modulsoftware-OBD monitoring,not active ,6{SFD2} ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,not active ,6{SFD2} ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,not active ,6{SFD2} ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,60_ms ,6{SFD2} ENG253244-ENG278531-Diebstahlschutz.Modulsoftware-dwa_alarm_delay_quelle,immidiat_driver_door_contact_thatcham ,6{SFD2} ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6{SFD2} ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6{SFD2} ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6{SFD2} ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,active ,6{SFD2} ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv,not activated ,4{SFD2} ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv,not activated ,4{SFD2} ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv,activated ,4{SFD2} ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv,not activated ,4{SFD2} ENG253365-ENG258571-Dienste-GenerischeOrtung_aktiv,not activated ,4{SFD2} ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv,not activated ,4{SFD2} ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv,not activated ,4{SFD2} ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,3.0 %,21{SFD2} ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,160 %,21{SFD2} ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,160 %,21{SFD2} ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,160 %,21{SFD2} ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,21{SFD2} ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,90.0 %,21{SFD2} ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,10.0 %,21{SFD2} ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,5.0 %,21{SFD2} ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,1.0 s,21{SFD2} ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21{SFD2} ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21{SFD2} ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,10 min,21{SFD2} ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,12 min,21{SFD2} ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,21{SFD2} ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,21{SFD2} ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,21{SFD2} ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,21{SFD2} ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,21{SFD2} ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,21{SFD2} ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,21{SFD2} ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,21{SFD2} ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,21{SFD2} ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,21{SFD2} ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,21{SFD2} ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,21{SFD2} ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,21{SFD2} ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,21{SFD2} ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,21{SFD2} ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,21{SFD2} ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,21{SFD2} ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,21{SFD2} ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,21{SFD2} ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,21{SFD2} ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,21{SFD2} ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,21{SFD2} ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,21{SFD2} ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,21{SFD2} ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,21{SFD2} ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,21{SFD2} ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,21{SFD2} ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,21{SFD2} ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,21{SFD2} ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,21{SFD2} ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,21{SFD2} ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,21{SFD2} ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,21ENG252014-ENG252049-Driver_seat_perso_1-Hoehe_Lordose_Perso,No Response From Subnet Component,21ENG252014-ENG252081-Driver_seat_perso_1-Perso_Lehnenwangen,No Response From Subnet Component,21ENG252014-ENG252087-Driver_seat_perso_1-Perso_letztes_Massageprogramm,No Response From Subnet Component,21ENG252014-ENG252064-Driver_seat_perso_1-Perso_Massageintensitaet,No Response From Subnet Component,21ENG252014-ENG252088-Driver_seat_perso_1-Weite_Lordose_Perso,No Response From Subnet Component,21ENG252015-ENG252049-Driver_seat_perso_2-Hoehe_Lordose_Perso,No Response From Subnet Component,21ENG252015-ENG252081-Driver_seat_perso_2-Perso_Lehnenwangen,No Response From Subnet Component,21ENG252015-ENG252087-Driver_seat_perso_2-Perso_letztes_Massageprogramm,No Response From Subnet Component,21ENG252015-ENG252064-Driver_seat_perso_2-Perso_Massageintensitaet,No Response From Subnet Component,21ENG252015-ENG252088-Driver_seat_perso_2-Weite_Lordose_Perso,No Response From Subnet Component,21ENG252016-ENG252049-Driver_seat_perso_3-Hoehe_Lordose_Perso,No Response From Subnet Component,21ENG252016-ENG252081-Driver_seat_perso_3-Perso_Lehnenwangen,No Response From Subnet Component,21ENG252016-ENG252087-Driver_seat_perso_3-Perso_letztes_Massageprogramm,No Response From Subnet Component,21ENG252016-ENG252064-Driver_seat_perso_3-Perso_Massageintensitaet,No Response From Subnet Component,21ENG252016-ENG252088-Driver_seat_perso_3-Weite_Lordose_Perso,No Response From Subnet Component,21ENG252017-ENG252049-Driver_seat_perso_4-Hoehe_Lordose_Perso,No Response From Subnet Component,21ENG252017-ENG252081-Driver_seat_perso_4-Perso_Lehnenwangen,No Response From Subnet Component,21ENG252017-ENG252087-Driver_seat_perso_4-Perso_letztes_Massageprogramm,No Response From Subnet Component,21ENG252017-ENG252064-Driver_seat_perso_4-Perso_Massageintensitaet,No Response From Subnet Component,21ENG252017-ENG252088-Driver_seat_perso_4-Weite_Lordose_Perso,No Response From Subnet Component,21ENG252018-ENG252049-Driver_seat_perso_5-Hoehe_Lordose_Perso,No Response From Subnet Component,21ENG252018-ENG252081-Driver_seat_perso_5-Perso_Lehnenwangen,No Response From Subnet Component,21ENG252018-ENG252087-Driver_seat_perso_5-Perso_letztes_Massageprogramm,No Response From Subnet Component,21ENG252018-ENG252064-Driver_seat_perso_5-Perso_Massageintensitaet,No Response From Subnet Component,21ENG252018-ENG252088-Driver_seat_perso_5-Weite_Lordose_Perso,No Response From Subnet Component,21ENG252019-ENG252049-Driver_seat_perso_6-Hoehe_Lordose_Perso,No Response From Subnet Component,21ENG252019-ENG252081-Driver_seat_perso_6-Perso_Lehnenwangen,No Response From Subnet Component,21ENG252019-ENG252087-Driver_seat_perso_6-Perso_letztes_Massageprogramm,No Response From Subnet Component,21ENG252019-ENG252064-Driver_seat_perso_6-Perso_Massageintensitaet,No Response From Subnet Component,21ENG252019-ENG252088-Driver_seat_perso_6-Weite_Lordose_Perso,No Response From Subnet Component,21ENG252020-ENG252049-Driver_seat_perso_7-Hoehe_Lordose_Perso,No Response From Subnet Component,21ENG252020-ENG252081-Driver_seat_perso_7-Perso_Lehnenwangen,No Response From Subnet Component,21ENG252020-ENG252087-Driver_seat_perso_7-Perso_letztes_Massageprogramm,No Response From Subnet Component,21ENG252020-ENG252064-Driver_seat_perso_7-Perso_Massageintensitaet,No Response From Subnet Component,21ENG252020-ENG252088-Driver_seat_perso_7-Weite_Lordose_Perso,No Response From Subnet Component,21{SFD2} ENG286142-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,21{SFD2} ENG286142-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,21{SFD2} ENG286142-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,21{SFD2} ENG286142-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,21{SFD2} ENG286142-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,21{SFD2} ENG286142-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,21{SFD2} ENG286142-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,21{SFD2} ENG286142-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,21{SFD2} ENG286142-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,21{SFD2} ENG286142-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,21{SFD2} ENG286142-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,21{SFD2} ENG286142-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,21{SFD2} ENG286142-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,21{SFD2} ENG286142-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,21{SFD2} ENG286142-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,21{SFD2} ENG286142-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,21{SFD2} ENG286142-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,21{SFD2} ENG286142-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,21{SFD2} ENG286142-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,21{SFD2} ENG286142-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,21{SFD2} ENG286142-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,21{SFD2} ENG286142-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,21{SFD2} ENG286142-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,21{SFD2} ENG286142-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,21{SFD2} ENG286142-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,21{SFD2} ENG286142-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,21{SFD2} ENG286142-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,21{SFD2} ENG286142-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,21{SFD2} ENG286142-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,21{SFD2} ENG286142-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,21{SFD2} ENG286142-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,21{SFD2} ENG286142-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,21{SFD2} ENG286142-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,21{SFD2} ENG286142-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,21{SFD2} ENG286142-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,21{SFD2} ENG286142-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,21{SFD2} ENG286142-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,21{SFD2} ENG286142-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,21{SFD2} ENG286142-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,21{SFD2} ENG286142-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,21{SFD2} ENG286142-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,21{SFD2} ENG286142-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,21{SFD2} ENG286142-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,21{SFD2} ENG286142-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,21{SFD2} ENG286142-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,21{SFD2} ENG286142-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,21{SFD2} ENG286142-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,21{SFD2} ENG286142-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,21{SFD2} ENG286142-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,21{SFD2} ENG286142-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,21{SFD2} ENG286142-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,21{SFD2} ENG286142-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,21{SFD2} ENG286142-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,21{SFD2} ENG286142-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,21{SFD2} ENG286142-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,21{SFD2} ENG286142-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,21{SFD2} ENG286142-IDE80057-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,21{SFD2} ENG286142-IDE80058-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,21{SFD2} ENG286142-IDE80059-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,21{SFD2} ENG286142-IDE80060-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,21{SFD2} ENG286143-IDE00047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,21{SFD2} ENG286143-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,21{SFD2} ENG286143-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,21{SFD2} ENG286143-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,21{SFD2} ENG286143-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,21{SFD2} ENG286143-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,21{SFD2} ENG286143-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,21{SFD2} ENG286143-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,21{SFD2} ENG286143-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,21{SFD2} ENG286143-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,21{SFD2} ENG286143-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,21{SFD2} ENG286143-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,21{SFD2} ENG286143-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,21{SFD2} ENG286143-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,21{SFD2} ENG286143-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,21{SFD2} ENG286143-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,21{SFD2} ENG286143-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,21{SFD2} ENG286143-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,21{SFD2} ENG286143-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,21{SFD2} ENG286143-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,21{SFD2} ENG286143-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,21{SFD2} ENG286143-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,21{SFD2} ENG286143-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,21{SFD2} ENG286143-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,21{SFD2} ENG286143-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,21{SFD2} ENG286143-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,21{SFD2} ENG286143-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,21{SFD2} ENG286143-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,21{SFD2} ENG286143-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,21{SFD2} ENG286143-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,21{SFD2} ENG286143-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,21{SFD2} ENG286143-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,21{SFD2} ENG286143-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,21{SFD2} ENG286143-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,21{SFD2} ENG286143-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,21{SFD2} ENG286143-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,21{SFD2} ENG286143-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,21{SFD2} ENG286143-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,21{SFD2} ENG286143-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,21{SFD2} ENG286143-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,21{SFD2} ENG286143-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,21{SFD2} ENG286143-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,21{SFD2} ENG286143-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,21{SFD2} ENG286143-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,21{SFD2} ENG286143-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,21{SFD2} ENG286143-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,21{SFD2} ENG286143-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,21{SFD2} ENG286143-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,21{SFD2} ENG286143-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,21{SFD2} ENG286143-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,21{SFD2} ENG286143-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,21{SFD2} ENG286143-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,21{SFD2} ENG286143-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,21{SFD2} ENG286143-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,21{SFD2} ENG286143-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,21{SFD2} ENG286143-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,21{SFD2} ENG286143-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,21{SFD2} ENG286143-MAS01078-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,21{SFD2} ENG286143-MAS14087-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,21{SFD2} ENG122925-DWA_Interior_Monitoring_Data_Set_Development,No Response From Subnet Component,21{SFD2} ENG253243-ENG286261-Easy Open-p_a_Schiebetürentriegelung_durch_VIP_bei_Tankklappe_offen,not active ,4{SFD2} ENG253243-ENG258420-Easy Open-p_a_VIP_Freigabeentzug_bei_Anhaenger,not active ,4{SFD2} ENG253243-ENG258644-Easy Open-Virtuelles_Pedal_Aktiv_Kl_15,not active ,4{SFD2} ENG253243-ENG259016-Easy Open-Virtuelles_Pedal_Aktiv_Kl_S,not active ,4{SFD2} ENG253243-ENG260097-Easy Open-Virtuelles_Pedal_Aktiv_Motorlauf,not active ,4{SFD2} ENG253243-ENG286386-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_15,not active ,4{SFD2} ENG253243-ENG286387-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_S,not active ,4{SFD2} ENG253243-ENG286388-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Motorlauf,not active ,4{SFD2} ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese,5 ,15{SFD2} ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel,70 %,15{SFD2} ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev,30 %,15{SFD2} ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,15{SFD2} ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans,20.0 s,15{SFD2} ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans,7.0 s,15{SFD2} ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv,not activated ,4{SFD2} ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln,not activated ,4{SFD2} ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP,not activated ,4{SFD2} ENG122934-erase_error_table,No Response From Subnet Component,4{SFD2} ENG122933-error_mask,No Response From Subnet Component,4{SFD2} ENG253250-MAS28923-Fahrlichthinweis-Multiple warnings when driving in the dark without lights,active ,4{SFD2} ENG253250-MAS28924-Fahrlichthinweis-Warning when driving in the dark without lights: configuration,Hinweis_in_LDS-Stellung_Null_und_SL ,4{SFD2} ENG141650-MAS28896-Fernlicht_assistent-Resetting high-beam control Light Assist,not active ,6{SFD2} ENG141650-MAS28925-Fernlicht_assistent-Factory setting for high-beam control Light Assist  information electronics menu,Not available ,6{SFD2} ENG141650-MAS28929-Fernlicht_assistent-Activation of high-beam control Light Assist: menu in information electronics,present ,6ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6ENG141682-ENG260711-Front_wiper-cp_tipwischen_Kl_15_aus,OFF ,6ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm,active ,6ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,keine Abtaupostition ,6ENG141682-ENG260480-Front_wiper-Frontwischer_typ,Direct ,6ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,6ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,active ,6ENG141682-ENG258360-Front_wiper-pa_2_Motorsystem,not active ,6ENG141682-ENG259770-Front_wiper-Regensensor aktiv Fahrfreigabe,active ,6ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,active ,6ENG141682-ENG260083-Front_wiper-Spannungsanforderung_konfig_Frontwischer,Sollspannungsanforderung 13.5 ,6ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz,active ,6ENG141682-ENG259232-Front_wiper-tipwischen_Kl_15_aus,not active ,6ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant,not active ,6ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,6ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6ENG141682-ENG122991-Front_wiper-Wischer stop bei Motorstart,kein Wischerstopp ,6ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6{SFD2} ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,No Response From Subnet Component,6{SFD2} ENG117283-ENG263535-Frontwaschfunktion-Waschfrequenz_bei_LSS_aus,No Response From Subnet Component,6{SFD2} ENG171911-ENG263558-Funk-FFB Batteriewarnung unterdruecken,not active ,4{SFD2} ENG171911-ENG141957-Funk-Radio freq.,MQB A0: 434.42MHz (RdW ,4ENG253288-Grundparameter SPN-,10000 ms,30ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection,1000 ms,30ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection,3000 ms,30ENG253288-ENG126950-Grundparameter SPN-duration_ZAT_debounce,50 ms,30ENG253288-ENG260569-Grundparameter SPN-Speed_ threshold_for_start_wish_plausibilisation,10 km/h,30ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,30ENG253288-ENG126954-Grundparameter SPN-time_to_ZAT_Open_circuit_detection,1000 ms,30ENG253288-ENG126951-Grundparameter SPN-time_to_ZAT_Short_circuit_fault_detection,60 s,30ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff,1000 ms,30ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff,500 ms,30ENG253288-ENG253449-Grundparameter SPN-time_ZAT_one_switch_actuation_detection,3000 ms,30{SFD2} ENG253178-ENG126630-Heckdeckelsteuerung-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8{SFD2} ENG253178-ENG125652-Heckdeckelsteuerung-Servoheck Schlossansteuerung,Always ,8{SFD2} ENG253178-ENG126838-Heckdeckelsteuerung-Softtouch-Betaetigung senden,Always ,8{SFD2} ENG253178-ENG142011-Heckdeckelsteuerung-trunk_lid_conrol_unit,not installed ,8{SFD2} ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid,installed ,8{SFD2} ENG141645-MAS00212-HW_Verbau-Washer fluid low,not installed ,8{SFD2} ENG141645-MAS00213-HW_Verbau-Insufficient coolant,installed ,8{SFD2} ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8{SFD2} ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor,installed ,8{SFD2} ENG141645-ENG260128-HW_Verbau-Kontaktfritten,OFF ,8{SFD2} ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube,installed ,8{SFD2} ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8{SFD2} ENG141645-ENG152427-HW_Verbau-Rear window defogger,installed ,8{SFD2} ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8{SFD2} ENG253080-IAA Nutzermanagement,installed ,1{SFD2} ENG253173-ENG259645-IDGeber_Suche-Innenraumsuche_Kl15_aktiv,activated ,4{SFD2} ENG253173-ENG261236-IDGeber_Suche-Innenraumsuche_Kl15_Triggerung_aktiv,activated ,4{SFD2} ENG253173-ENG260685-IDGeber_Suche-Innenraumsuche_Kl15_TuerenKlappenFenster_auch_vor_erstem_Anfahren,activated ,4{SFD2} ENG253173-ENG258195-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_aktiv,activated ,4{SFD2} ENG253173-ENG260525-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_aktiv,activated ,4{SFD2} ENG253173-ENG258977-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_NFZ_aktiv,activated ,4{SFD2} ENG253173-ENG258651-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_TriggerVariante,activated ,4{SFD2} ENG253173-ENG261351-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Tueren_aktiv,activated ,4ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4ENG253039-MAS06614-Intelligente Heckleuchte-Verbau-Variant,0 ,4ENG253039-MAS21321-Intelligente Heckleuchte-Verbau-Audi parking system installed,not installed ,4ENG253039-SFT271909-Intelligente Heckleuchte-Verbau-Left taillight 1,not installed ,4ENG253039-SFT272142-Intelligente Heckleuchte-Verbau-Left taillight 2,not installed ,4ENG253039-SFT272143-Intelligente Heckleuchte-Verbau-Right taillight 1,not installed ,4ENG253039-SFT272144-Intelligente Heckleuchte-Verbau-Right taillight 2,not installed ,4ENG253039-ENG345762-Intelligente Heckleuchte-Verbau-LIN_SBBR_full_e2e,not active ,4ENG253039-ENG261019-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_KZL_iSBBR,not active ,4ENG253039-ENG260486-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_NSL_iSBBR,not active ,4ENG253039-ENG260357-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_RFL_iSBBR,not active ,4{SFD2} ENG253265-ENG260602-Interior_light_default_values-Default_value_active_profile,08 ,96{SFD2} ENG253265-ENG258400-Interior_light_default_values-Default_value_ambient_color,01 ,96{SFD2} ENG253265-ENG259067-Interior_light_default_values-Default_value_ambient_color_fod,01 ,96{SFD2} ENG253265-ENG258906-Interior_light_default_values-Default_value_brightness_profile_1,50 %,96{SFD2} ENG253265-ENG260896-Interior_light_default_values-Default_value_brightness_profile_2,50 %,96{SFD2} ENG253265-ENG259361-Interior_light_default_values-Default_value_brightness_profile_3,50 %,96{SFD2} ENG253265-ENG259248-Interior_light_default_values-Default_value_brightness_profile_4,50 %,96{SFD2} ENG253265-ENG259191-Interior_light_default_values-Default_value_brightness_profile_5,50 %,96{SFD2} ENG253265-ENG259315-Interior_light_default_values-Default_value_brightness_profile_6,50 %,96{SFD2} ENG253265-ENG260148-Interior_light_default_values-Default_value_brightness_profile_7,50 %,96{SFD2} ENG253265-ENG259491-Interior_light_default_values-Default_value_brightness_profile_8,0 %,96{SFD2} ENG253265-ENG258409-Interior_light_default_values-Default_value_brightness_set_1,50 %,96{SFD2} ENG253265-ENG260620-Interior_light_default_values-Default_value_brightness_set_2,50 %,96{SFD2} ENG253265-ENG259395-Interior_light_default_values-Default_value_brightness_set_3,50 %,96{SFD2} ENG253265-ENG260548-Interior_light_default_values-Default_value_brightness_set_4,50 %,96{SFD2} ENG253265-ENG261071-Interior_light_default_values-Default_value_brightness_set_5,50 %,96{SFD2} ENG253265-ENG259147-Interior_light_default_values-Default_value_brightness_set_6,50 %,96{SFD2} ENG253265-ENG259714-Interior_light_default_values-Default_value_brightness_set_7,50 %,96{SFD2} ENG253265-ENG260350-Interior_light_default_values-Default_value_brightness_set_8,50 %,96{SFD2} ENG253265-ENG260494-Interior_light_default_values-Default_value_contour_color,01 ,96{SFD2} ENG253265-ENG259828-Interior_light_default_values-Default_value_contour_color_fod,01 ,96{SFD2} ENG253265-ENG258473-Interior_light_default_values-Default_value_door_contact,active ,96{SFD2} ENG253265-ENG261059-Interior_light_default_values-Default_value_functional_ambient_lighting,not active ,96{SFD2} ENG253265-ENG258185-Interior_light_default_values-Default_value_play_of_colors,00 ,96{SFD2} ENG253265-ENG260118-Interior_light_default_values-Status_functional_ambient_lighting_function_0,00 ,96{SFD2} ENG253265-ENG260033-Interior_light_default_values-Status_functional_ambient_lighting_function_1,00 ,96{SFD2} ENG253265-ENG260515-Interior_light_default_values-Status_functional_ambient_lighting_function_10,00 ,96{SFD2} ENG253265-ENG261126-Interior_light_default_values-Status_functional_ambient_lighting_function_11,00 ,96{SFD2} ENG253265-ENG260982-Interior_light_default_values-Status_functional_ambient_lighting_function_12,00 ,96{SFD2} ENG253265-ENG258716-Interior_light_default_values-Status_functional_ambient_lighting_function_13,00 ,96{SFD2} ENG253265-ENG258745-Interior_light_default_values-Status_functional_ambient_lighting_function_14,00 ,96{SFD2} ENG253265-ENG258773-Interior_light_default_values-Status_functional_ambient_lighting_function_15,00 ,96{SFD2} ENG253265-ENG261349-Interior_light_default_values-Status_functional_ambient_lighting_function_16,00 ,96{SFD2} ENG253265-ENG258101-Interior_light_default_values-Status_functional_ambient_lighting_function_17,00 ,96{SFD2} ENG253265-ENG258275-Interior_light_default_values-Status_functional_ambient_lighting_function_18,00 ,96{SFD2} ENG253265-ENG258192-Interior_light_default_values-Status_functional_ambient_lighting_function_19,00 ,96{SFD2} ENG253265-ENG260897-Interior_light_default_values-Status_functional_ambient_lighting_function_2,00 ,96{SFD2} ENG253265-ENG260194-Interior_light_default_values-Status_functional_ambient_lighting_function_20,00 ,96{SFD2} ENG253265-ENG258332-Interior_light_default_values-Status_functional_ambient_lighting_function_21,00 ,96{SFD2} ENG253265-ENG259651-Interior_light_default_values-Status_functional_ambient_lighting_function_22,00 ,96{SFD2} ENG253265-ENG261294-Interior_light_default_values-Status_functional_ambient_lighting_function_23,00 ,96{SFD2} ENG253265-ENG259414-Interior_light_default_values-Status_functional_ambient_lighting_function_24,00 ,96{SFD2} ENG253265-ENG258573-Interior_light_default_values-Status_functional_ambient_lighting_function_25,00 ,96{SFD2} ENG253265-ENG258495-Interior_light_default_values-Status_functional_ambient_lighting_function_26,00 ,96{SFD2} ENG253265-ENG260792-Interior_light_default_values-Status_functional_ambient_lighting_function_27,00 ,96{SFD2} ENG253265-ENG261350-Interior_light_default_values-Status_functional_ambient_lighting_function_28,00 ,96{SFD2} ENG253265-ENG259636-Interior_light_default_values-Status_functional_ambient_lighting_function_29,00 ,96{SFD2} ENG253265-ENG259360-Interior_light_default_values-Status_functional_ambient_lighting_function_3,00 ,96{SFD2} ENG253265-ENG260163-Interior_light_default_values-Status_functional_ambient_lighting_function_30,00 ,96{SFD2} ENG253265-ENG260013-Interior_light_default_values-Status_functional_ambient_lighting_function_31,00 ,96{SFD2} ENG253265-ENG260816-Interior_light_default_values-Status_functional_ambient_lighting_function_32,00 ,96{SFD2} ENG253265-ENG258823-Interior_light_default_values-Status_functional_ambient_lighting_function_33,00 ,96{SFD2} ENG253265-ENG258362-Interior_light_default_values-Status_functional_ambient_lighting_function_34,00 ,96{SFD2} ENG253265-ENG258252-Interior_light_default_values-Status_functional_ambient_lighting_function_35,00 ,96{SFD2} ENG253265-ENG261196-Interior_light_default_values-Status_functional_ambient_lighting_function_36,00 ,96{SFD2} ENG253265-ENG260391-Interior_light_default_values-Status_functional_ambient_lighting_function_37,00 ,96{SFD2} ENG253265-ENG259418-Interior_light_default_values-Status_functional_ambient_lighting_function_38,00 ,96{SFD2} ENG253265-ENG259523-Interior_light_default_values-Status_functional_ambient_lighting_function_39,00 ,96{SFD2} ENG253265-ENG258165-Interior_light_default_values-Status_functional_ambient_lighting_function_4,00 ,96{SFD2} ENG253265-ENG259088-Interior_light_default_values-Status_functional_ambient_lighting_function_40,00 ,96{SFD2} ENG253265-ENG258142-Interior_light_default_values-Status_functional_ambient_lighting_function_41,00 ,96{SFD2} ENG253265-ENG259166-Interior_light_default_values-Status_functional_ambient_lighting_function_42,00 ,96{SFD2} ENG253265-ENG258220-Interior_light_default_values-Status_functional_ambient_lighting_function_43,00 ,96{SFD2} ENG253265-ENG259935-Interior_light_default_values-Status_functional_ambient_lighting_function_44,00 ,96{SFD2} ENG253265-ENG260916-Interior_light_default_values-Status_functional_ambient_lighting_function_45,00 ,96{SFD2} ENG253265-ENG258884-Interior_light_default_values-Status_functional_ambient_lighting_function_46,00 ,96{SFD2} ENG253265-ENG260167-Interior_light_default_values-Status_functional_ambient_lighting_function_47,00 ,96{SFD2} ENG253265-ENG259709-Interior_light_default_values-Status_functional_ambient_lighting_function_48,00 ,96{SFD2} ENG253265-ENG258367-Interior_light_default_values-Status_functional_ambient_lighting_function_49,00 ,96{SFD2} ENG253265-ENG261268-Interior_light_default_values-Status_functional_ambient_lighting_function_5,00 ,96{SFD2} ENG253265-ENG260926-Interior_light_default_values-Status_functional_ambient_lighting_function_50,00 ,96{SFD2} ENG253265-ENG258790-Interior_light_default_values-Status_functional_ambient_lighting_function_51,00 ,96{SFD2} ENG253265-ENG259976-Interior_light_default_values-Status_functional_ambient_lighting_function_52,00 ,96{SFD2} ENG253265-ENG260404-Interior_light_default_values-Status_functional_ambient_lighting_function_53,00 ,96{SFD2} ENG253265-ENG258371-Interior_light_default_values-Status_functional_ambient_lighting_function_54,00 ,96{SFD2} ENG253265-ENG259284-Interior_light_default_values-Status_functional_ambient_lighting_function_55,00 ,96{SFD2} ENG253265-ENG260285-Interior_light_default_values-Status_functional_ambient_lighting_function_56,00 ,96{SFD2} ENG253265-ENG258600-Interior_light_default_values-Status_functional_ambient_lighting_function_57,00 ,96{SFD2} ENG253265-ENG260626-Interior_light_default_values-Status_functional_ambient_lighting_function_58,00 ,96{SFD2} ENG253265-ENG260773-Interior_light_default_values-Status_functional_ambient_lighting_function_59,00 ,96{SFD2} ENG253265-ENG259316-Interior_light_default_values-Status_functional_ambient_lighting_function_6,00 ,96{SFD2} ENG253265-ENG261109-Interior_light_default_values-Status_functional_ambient_lighting_function_60,00 ,96{SFD2} ENG253265-ENG258106-Interior_light_default_values-Status_functional_ambient_lighting_function_61,00 ,96{SFD2} ENG253265-ENG260286-Interior_light_default_values-Status_functional_ambient_lighting_function_62,00 ,96{SFD2} ENG253265-ENG260233-Interior_light_default_values-Status_functional_ambient_lighting_function_63,00 ,96{SFD2} ENG253265-ENG260974-Interior_light_default_values-Status_functional_ambient_lighting_function_7,00 ,96{SFD2} ENG253265-ENG259492-Interior_light_default_values-Status_functional_ambient_lighting_function_8,00 ,96{SFD2} ENG253265-ENG260578-Interior_light_default_values-Status_functional_ambient_lighting_function_9,00 ,96{SFD2} ENG253069-ENG436052-Interior_light_external_events-Display_ORU_on_TK,not active ,16{SFD2} ENG253069-ENG259642-Interior_light_external_events-External_event_activation_69,not active ,16{SFD2} ENG253069-ENG403530-Interior_light_external_events-External_event_activation_atmospheres,not active ,16{SFD2} ENG253069-ENG403531-Interior_light_external_events-External_event_activation_door_scenario,not active ,16{SFD2} ENG253069-ENG259453-Interior_light_external_events-External_event_activation_of_ready_to_drive_visualization,not active ,16{SFD2} ENG253069-ENG403532-Interior_light_external_events-External_event_activation_wellbeing,not active ,16{SFD2} ENG253069-ENG258384-Interior_light_external_events-External_event_ready_to_drive_visualization_with_sound,not active ,16{SFD2} ENG253344-ENG253469-Interior_light_functions_1_to_70-Light_function_1,not active ,9{SFD2} ENG253344-ENG260993-Interior_light_functions_1_to_70-Light_function_10,not active ,9{SFD2} ENG253344-ENG261210-Interior_light_functions_1_to_70-Light_function_11,not active ,9{SFD2} ENG253344-ENG259885-Interior_light_functions_1_to_70-Light_function_12,not active ,9{SFD2} ENG253344-ENG258428-Interior_light_functions_1_to_70-Light_function_13,not active ,9{SFD2} ENG253344-ENG260468-Interior_light_functions_1_to_70-Light_function_14,not active ,9{SFD2} ENG253344-ENG259544-Interior_light_functions_1_to_70-Light_function_15,not active ,9{SFD2} ENG253344-ENG261129-Interior_light_functions_1_to_70-Light_function_16,not active ,9{SFD2} ENG253344-ENG259775-Interior_light_functions_1_to_70-Light_function_17,not active ,9{SFD2} ENG253344-ENG259446-Interior_light_functions_1_to_70-Light_function_18,not active ,9{SFD2} ENG253344-ENG259229-Interior_light_functions_1_to_70-Light_function_19,not active ,9{SFD2} ENG253344-ENG253470-Interior_light_functions_1_to_70-Light_function_2,active ,9{SFD2} ENG253344-ENG259487-Interior_light_functions_1_to_70-Light_function_20,not active ,9{SFD2} ENG253344-ENG259385-Interior_light_functions_1_to_70-Light_function_21,not active ,9{SFD2} ENG253344-ENG259785-Interior_light_functions_1_to_70-Light_function_22,not active ,9{SFD2} ENG253344-ENG258581-Interior_light_functions_1_to_70-Light_function_23,not active ,9{SFD2} ENG253344-ENG260265-Interior_light_functions_1_to_70-Light_function_24,not active ,9{SFD2} ENG253344-ENG261256-Interior_light_functions_1_to_70-Light_function_25,not active ,9{SFD2} ENG253344-ENG260361-Interior_light_functions_1_to_70-Light_function_26,not active ,9{SFD2} ENG253344-ENG259100-Interior_light_functions_1_to_70-Light_function_27,not active ,9{SFD2} ENG253344-ENG260930-Interior_light_functions_1_to_70-Light_function_28,not active ,9{SFD2} ENG253344-ENG259955-Interior_light_functions_1_to_70-Light_function_29,not active ,9{SFD2} ENG253344-ENG253471-Interior_light_functions_1_to_70-Light_function_3,not active ,9{SFD2} ENG253344-ENG259370-Interior_light_functions_1_to_70-Light_function_30,active ,9{SFD2} ENG253344-ENG261130-Interior_light_functions_1_to_70-Light_function_31,active ,9{SFD2} ENG253344-ENG258748-Interior_light_functions_1_to_70-Light_function_32,not active ,9{SFD2} ENG253344-ENG260955-Interior_light_functions_1_to_70-Light_function_33,not active ,9{SFD2} ENG253344-ENG259496-Interior_light_functions_1_to_70-Light_function_34,not active ,9{SFD2} ENG253344-ENG258588-Interior_light_functions_1_to_70-Light_function_35,not active ,9{SFD2} ENG253344-ENG259600-Interior_light_functions_1_to_70-Light_function_36,not active ,9{SFD2} ENG253344-ENG259095-Interior_light_functions_1_to_70-Light_function_37,not active ,9{SFD2} ENG253344-ENG260346-Interior_light_functions_1_to_70-Light_function_38,not active ,9{SFD2} ENG253344-ENG259274-Interior_light_functions_1_to_70-Light_function_39,not active ,9{SFD2} ENG253344-ENG260499-Interior_light_functions_1_to_70-Light_function_4,not active ,9{SFD2} ENG253344-ENG258529-Interior_light_functions_1_to_70-Light_function_40,not active ,9{SFD2} ENG253344-ENG258505-Interior_light_functions_1_to_70-Light_function_41,not active ,9{SFD2} ENG253344-ENG258603-Interior_light_functions_1_to_70-Light_function_42,not active ,9{SFD2} ENG253344-ENG259158-Interior_light_functions_1_to_70-Light_function_43,not active ,9{SFD2} ENG253344-ENG260244-Interior_light_functions_1_to_70-Light_function_44,not active ,9{SFD2} ENG253344-ENG260634-Interior_light_functions_1_to_70-Light_function_45,not active ,9{SFD2} ENG253344-ENG258174-Interior_light_functions_1_to_70-Light_function_46,not active ,9{SFD2} ENG253344-ENG260984-Interior_light_functions_1_to_70-Light_function_47,not active ,9{SFD2} ENG253344-ENG258949-Interior_light_functions_1_to_70-Light_function_48,not active ,9{SFD2} ENG253344-ENG259994-Interior_light_functions_1_to_70-Light_function_49,not active ,9{SFD2} ENG253344-ENG258326-Interior_light_functions_1_to_70-Light_function_5,not active ,9{SFD2} ENG253344-ENG259724-Interior_light_functions_1_to_70-Light_function_50,not active ,9{SFD2} ENG253344-ENG259989-Interior_light_functions_1_to_70-Light_function_51,not active ,9{SFD2} ENG253344-ENG259580-Interior_light_functions_1_to_70-Light_function_52,not active ,9{SFD2} ENG253344-ENG258381-Interior_light_functions_1_to_70-Light_function_53,not active ,9{SFD2} ENG253344-ENG259438-Interior_light_functions_1_to_70-Light_function_54,not active ,9{SFD2} ENG253344-ENG261290-Interior_light_functions_1_to_70-Light_function_55,not active ,9{SFD2} ENG253344-ENG259516-Interior_light_functions_1_to_70-Light_function_56,not active ,9{SFD2} ENG253344-ENG261086-Interior_light_functions_1_to_70-Light_function_57,not active ,9{SFD2} ENG253344-ENG260704-Interior_light_functions_1_to_70-Light_function_58,not active ,9{SFD2} ENG253344-ENG258566-Interior_light_functions_1_to_70-Light_function_59,not active ,9{SFD2} ENG253344-ENG261278-Interior_light_functions_1_to_70-Light_function_6,not active ,9{SFD2} ENG253344-ENG260248-Interior_light_functions_1_to_70-Light_function_60,not active ,9{SFD2} ENG253344-ENG260845-Interior_light_functions_1_to_70-Light_function_61,not active ,9{SFD2} ENG253344-ENG258817-Interior_light_functions_1_to_70-Light_function_62,not active ,9{SFD2} ENG253344-ENG260488-Interior_light_functions_1_to_70-Light_function_63,not active ,9{SFD2} ENG253344-ENG259000-Interior_light_functions_1_to_70-Light_function_64,not active ,9{SFD2} ENG253344-ENG260181-Interior_light_functions_1_to_70-Light_function_65,not active ,9{SFD2} ENG253344-ENG259146-Interior_light_functions_1_to_70-Light_function_66,not active ,9{SFD2} ENG253344-ENG258530-Interior_light_functions_1_to_70-Light_function_67,not active ,9{SFD2} ENG253344-ENG261172-Interior_light_functions_1_to_70-Light_function_68,not active ,9{SFD2} ENG253344-ENG258454-Interior_light_functions_1_to_70-Light_function_69,not active ,9{SFD2} ENG253344-ENG259680-Interior_light_functions_1_to_70-Light_function_7,not active ,9{SFD2} ENG253344-ENG260506-Interior_light_functions_1_to_70-Light_function_70,not active ,9{SFD2} ENG253344-ENG258912-Interior_light_functions_1_to_70-Light_function_8,not active ,9{SFD2} ENG253344-ENG258633-Interior_light_functions_1_to_70-Light_function_9,not active ,9{SFD2} ENG253391-ENG258190-Interior_light_general_settings-Automatic_ambiance_lighting_with_fpa,not active ,14{SFD2} ENG253391-ENG403484-Interior_light_general_settings-Automatic_intensity_adjustment,not active ,14{SFD2} ENG253391-ENG259555-Interior_light_general_settings-Crash_color,01 ,14{SFD2} ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light,not active ,14{SFD2} ENG253391-ENG258939-Interior_light_general_settings-Door_warning_light_brightness,100 %,14{SFD2} ENG253391-ENG258181-Interior_light_general_settings-Door_warning_light_color,01 ,14{SFD2} ENG253391-ENG259296-Interior_light_general_settings-Innenlicht_durch_Fahrerassistenz,active ,14{SFD2} ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk,active ,14{SFD2} ENG253391-ENG261275-Interior_light_general_settings-Interior_light_alternative_clamp_control_entry,not active ,14{SFD2} ENG253391-ENG260888-Interior_light_general_settings-Interior_light_alternative_clamp_control_exit,not active ,14{SFD2} ENG253391-ENG258268-Interior_light_general_settings-interior_light_color,01 ,14{SFD2} ENG253391-ENG260936-Interior_light_general_settings-Interior_light_dependency_on_key_or_belt_buckle,02 ,14{SFD2} ENG253391-ENG259666-Interior_light_general_settings-Interior_light_function,active ,14{SFD2} ENG253391-ENG260600-Interior_light_general_settings-Interior_light_trunk_light,active ,14{SFD2} ENG253391-ENG259259-Interior_light_general_settings-Kl30alm,active ,14{SFD2} ENG253391-ENG259746-Interior_light_general_settings-Kl30G_activation_by_opening_trunk,active ,14{SFD2} ENG253391-ENG260275-Interior_light_general_settings-Kl30G_wake_up_behaviour,not active ,14{SFD2} ENG253391-ENG259384-Interior_light_general_settings-Kl30G_without_pwm,not active ,14{SFD2} ENG253391-ENG258730-Interior_light_general_settings-Kl58_color,01 ,14{SFD2} ENG253391-ENG260492-Interior_light_general_settings-Mapping_fpa_profile_1,1 ,14{SFD2} ENG253391-ENG261042-Interior_light_general_settings-Mapping_fpa_profile_2,5 ,14{SFD2} ENG253391-ENG258453-Interior_light_general_settings-Mapping_fpa_profile_3,3 ,14{SFD2} ENG253391-ENG260820-Interior_light_general_settings-Mapping_fpa_profile_4,4 ,14{SFD2} ENG253391-ENG258889-Interior_light_general_settings-Mapping_fpa_profile_5,2 ,14{SFD2} ENG253391-ENG260732-Interior_light_general_settings-Mapping_fpa_profile_6,7 ,14{SFD2} ENG253391-ENG260062-Interior_light_general_settings-Mfg_interior_light_color,01 ,14{SFD2} ENG253391-ENG403552-Interior_light_general_settings-Overvoltage_deactivation,not active ,14{SFD2} ENG253391-ENG260638-Interior_light_general_settings-Pso_active_participant_ambient_lighting_interior_enabled,active ,14{SFD2} ENG253391-ENG258979-Interior_light_general_settings-roof_console_installed,active ,14{SFD2} ENG253391-ENG258685-Interior_light_general_settings-Trunk_light_brightness,100 %,14{SFD2} ENG253391-ENG260452-Interior_light_general_settings-Trunk_light_color,01 ,14{SFD2} ENG253391-ENG403611-Interior_light_general_settings-Undervoltage_deactivation,not active ,14{SFD2} ENG253223-ENG260423-Interior_light_hmi_config-Bytes 25-60,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100{SFD2} ENG253223-ENG259513-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_1,64 ,100{SFD2} ENG253223-ENG260783-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_2,64 ,100{SFD2} ENG253223-ENG260290-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_3,64 ,100{SFD2} ENG253223-ENG258130-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_4,64 ,100{SFD2} ENG253223-ENG259034-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_5,64 ,100{SFD2} ENG253223-ENG259728-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_6,64 ,100{SFD2} ENG253223-ENG258649-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_7,64 ,100{SFD2} ENG253223-ENG258756-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_8,00 ,100{SFD2} ENG253223-ENG260831-Interior_light_hmi_config-Hmi_ambient_color,not active ,100{SFD2} ENG253223-ENG258324-Interior_light_hmi_config-Hmi_ambient_colors_bitmask,00 00 00 00 ,100{SFD2} ENG253223-ENG258789-Interior_light_hmi_config-Hmi_ambient_colors_fod_bitmask,00 00 00 00 ,100{SFD2} ENG253223-ENG260180-Interior_light_hmi_config-Hmi_ambient_profile_1,not active ,100{SFD2} ENG253223-ENG258163-Interior_light_hmi_config-Hmi_ambient_profile_2,not active ,100{SFD2} ENG253223-ENG258800-Interior_light_hmi_config-Hmi_ambient_profile_3,not active ,100{SFD2} ENG253223-ENG258761-Interior_light_hmi_config-Hmi_ambient_profile_4,not active ,100{SFD2} ENG253223-ENG259948-Interior_light_hmi_config-Hmi_ambient_profile_5,not active ,100{SFD2} ENG253223-ENG261117-Interior_light_hmi_config-Hmi_ambient_profile_6,not active ,100{SFD2} ENG253223-ENG258601-Interior_light_hmi_config-Hmi_ambient_profile_7,not active ,100{SFD2} ENG253223-ENG259615-Interior_light_hmi_config-Hmi_ambient_profile_8,not active ,100{SFD2} ENG253223-ENG258875-Interior_light_hmi_config-Hmi_config_fixed_color_play_of_colors,00 ,100{SFD2} ENG253223-ENG260154-Interior_light_hmi_config-Hmi_config_hmi_preview,not active ,100{SFD2} ENG253223-ENG258806-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_1,00 ,100{SFD2} ENG253223-ENG260370-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_2,00 ,100{SFD2} ENG253223-ENG261327-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_3,00 ,100{SFD2} ENG253223-ENG260102-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_4,00 ,100{SFD2} ENG253223-ENG259550-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_5,00 ,100{SFD2} ENG253223-ENG258870-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_6,00 ,100{SFD2} ENG253223-ENG260001-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_7,00 ,100{SFD2} ENG253223-ENG259068-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_8,00 ,100{SFD2} ENG253223-ENG259772-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_1,00 ,100{SFD2} ENG253223-ENG259687-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_2,00 ,100{SFD2} ENG253223-ENG259129-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_3,00 ,100{SFD2} ENG253223-ENG260699-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_4,00 ,100{SFD2} ENG253223-ENG259317-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_5,00 ,100{SFD2} ENG253223-ENG258480-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_6,00 ,100{SFD2} ENG253223-ENG261090-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_7,00 ,100{SFD2} ENG253223-ENG258664-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_8,00 ,100{SFD2} ENG253223-ENG261119-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_1,00 ,100{SFD2} ENG253223-ENG259685-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_2,00 ,100{SFD2} ENG253223-ENG260690-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_3,00 ,100{SFD2} ENG253223-ENG259252-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_4,00 ,100{SFD2} ENG253223-ENG258904-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_5,00 ,100{SFD2} ENG253223-ENG260909-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_6,00 ,100{SFD2} ENG253223-ENG258840-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_7,00 ,100{SFD2} ENG253223-ENG260828-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_8,00 ,100{SFD2} ENG253223-ENG259535-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_1,00 ,100{SFD2} ENG253223-ENG259249-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_2,00 ,100{SFD2} ENG253223-ENG258349-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_3,00 ,100{SFD2} ENG253223-ENG260458-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_4,00 ,100{SFD2} ENG253223-ENG258285-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_5,00 ,100{SFD2} ENG253223-ENG258936-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_6,00 ,100{SFD2} ENG253223-ENG260143-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_7,00 ,100{SFD2} ENG253223-ENG259986-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_8,00 ,100{SFD2} ENG253223-ENG260694-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_1,00 ,100{SFD2} ENG253223-ENG259604-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_2,00 ,100{SFD2} ENG253223-ENG258410-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_3,00 ,100{SFD2} ENG253223-ENG261012-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_4,00 ,100{SFD2} ENG253223-ENG259932-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_5,00 ,100{SFD2} ENG253223-ENG260104-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_6,00 ,100{SFD2} ENG253223-ENG260125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_7,00 ,100{SFD2} ENG253223-ENG259125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_8,00 ,100{SFD2} ENG253223-ENG260419-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_1,00 ,100{SFD2} ENG253223-ENG261132-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_2,00 ,100{SFD2} ENG253223-ENG260056-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_3,00 ,100{SFD2} ENG253223-ENG259330-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_4,00 ,100{SFD2} ENG253223-ENG258990-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_5,00 ,100{SFD2} ENG253223-ENG259936-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_6,00 ,100{SFD2} ENG253223-ENG258422-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_7,00 ,100{SFD2} ENG253223-ENG258463-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_8,00 ,100{SFD2} ENG253223-ENG258418-Interior_light_hmi_config-Hmi_config_timer_hmi_preview,5 s,100{SFD2} ENG253223-ENG259957-Interior_light_hmi_config-Hmi_contour_color,not active ,100{SFD2} ENG253223-ENG259365-Interior_light_hmi_config-Hmi_contour_colors_bitmask,00 00 00 00 ,100{SFD2} ENG253223-ENG259211-Interior_light_hmi_config-Hmi_contour_colors_fod_bitmask,00 00 00 00 ,100{SFD2} ENG253223-ENG260051-Interior_light_hmi_config-Hmi_Display_Color_light_function,02 ,100{SFD2} ENG253223-ENG258352-Interior_light_hmi_config-Hmi_door_contact,not active ,100{SFD2} ENG253223-ENG258250-Interior_light_hmi_config-Hmi_fpa_dependency,not active ,100{SFD2} ENG253223-ENG260229-Interior_light_hmi_config-Hmi_functional_ambiance_lighting_list,not active ,100{SFD2} ENG253223-ENG258930-Interior_light_hmi_config-Hmi_functional_ambience_lighting,not active ,100{SFD2} ENG253223-ENG258483-Interior_light_hmi_config-Hmi_menu_ambient_lighting,not active ,100{SFD2} ENG253223-ENG261116-Interior_light_hmi_config-Hmi_play_of_colors,not active ,100{SFD2} ENG253223-ENG260969-Interior_light_hmi_config-Hmi_setup_set_1,FF ,100{SFD2} ENG253223-ENG260367-Interior_light_hmi_config-Hmi_setup_set_2,FF ,100{SFD2} ENG253223-ENG259030-Interior_light_hmi_config-Hmi_setup_set_3,FF ,100{SFD2} ENG253223-ENG260913-Interior_light_hmi_config-Hmi_setup_set_4,FF ,100{SFD2} ENG253223-ENG258666-Interior_light_hmi_config-Hmi_setup_set_5,FF ,100{SFD2} ENG253223-ENG259988-Interior_light_hmi_config-Hmi_setup_set_6,FF ,100{SFD2} ENG253223-ENG258907-Interior_light_hmi_config-Hmi_setup_set_7,FF ,100{SFD2} ENG253223-ENG258492-Interior_light_hmi_config-Hmi_setup_set_8,FF ,100{SFD2} ENG253223-ENG259126-Interior_light_hmi_config-roof_console_door_contact,active ,100{SFD2} ENG253355-Interior_light_interface_function,No_voltage_requirement ,1{SFD2} ENG253312-ENG297177-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_1,00 ,51{SFD2} ENG253312-ENG297178-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_10,00 ,51{SFD2} ENG253312-ENG297179-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_11,00 ,51{SFD2} ENG253312-ENG297180-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_12,00 ,51{SFD2} ENG253312-ENG297181-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_13,00 ,51{SFD2} ENG253312-ENG297182-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_14,00 ,51{SFD2} ENG253312-ENG297183-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_15,00 ,51{SFD2} ENG253312-ENG297184-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_2,00 ,51{SFD2} ENG253312-ENG297185-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_3,00 ,51{SFD2} ENG253312-ENG297186-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_4,00 ,51{SFD2} ENG253312-ENG297187-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_5,00 ,51{SFD2} ENG253312-ENG297188-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_6,00 ,51{SFD2} ENG253312-ENG297189-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_7,00 ,51{SFD2} ENG253312-ENG297190-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_8,00 ,51{SFD2} ENG253312-ENG297191-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_9,00 ,51{SFD2} ENG253312-ENG297192-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_1,00 ,51{SFD2} ENG253312-ENG297193-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_10,00 ,51{SFD2} ENG253312-ENG297194-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_11,00 ,51{SFD2} ENG253312-ENG297195-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_12,00 ,51{SFD2} ENG253312-ENG297196-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_13,00 ,51{SFD2} ENG253312-ENG297197-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_14,00 ,51{SFD2} ENG253312-ENG297198-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_15,00 ,51{SFD2} ENG253312-ENG297199-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_2,00 ,51{SFD2} ENG253312-ENG297200-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_3,00 ,51{SFD2} ENG253312-ENG297201-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_4,00 ,51{SFD2} ENG253312-ENG297202-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_5,00 ,51{SFD2} ENG253312-ENG297203-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_6,00 ,51{SFD2} ENG253312-ENG297204-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_7,00 ,51{SFD2} ENG253312-ENG297205-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_8,00 ,51{SFD2} ENG253312-ENG297206-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_9,00 ,51{SFD2} ENG253312-ENG297207-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_1,00 ,51{SFD2} ENG253312-ENG297208-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_10,00 ,51{SFD2} ENG253312-ENG297209-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_11,00 ,51{SFD2} ENG253312-ENG297210-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_12,00 ,51{SFD2} ENG253312-ENG297211-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_13,00 ,51{SFD2} ENG253312-ENG297212-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_14,00 ,51{SFD2} ENG253312-ENG297213-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_15,00 ,51{SFD2} ENG253312-ENG297214-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_2,00 ,51{SFD2} ENG253312-ENG297215-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_3,00 ,51{SFD2} ENG253312-ENG297216-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_4,00 ,51{SFD2} ENG253312-ENG297217-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_5,00 ,51{SFD2} ENG253312-ENG297218-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_6,00 ,51{SFD2} ENG253312-ENG297219-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_7,00 ,51{SFD2} ENG253312-ENG297220-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_8,00 ,51{SFD2} ENG253312-ENG297221-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_9,00 ,51{SFD2} ENG253312-ENG297222-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_1,Offset_0 ,51{SFD2} ENG253312-ENG297223-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_10,Offset_0 ,51{SFD2} ENG253312-ENG297224-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_11,Offset_0 ,51{SFD2} ENG253312-ENG297225-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_12,Offset_0 ,51{SFD2} ENG253312-ENG297226-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_13,Offset_0 ,51{SFD2} ENG253312-ENG297227-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_14,Offset_0 ,51{SFD2} ENG253312-ENG297228-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_15,Offset_0 ,51{SFD2} ENG253312-ENG297229-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_2,Offset_0 ,51{SFD2} ENG253312-ENG297230-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_3,Offset_0 ,51{SFD2} ENG253312-ENG297231-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_4,Offset_0 ,51{SFD2} ENG253312-ENG297232-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_5,Offset_0 ,51{SFD2} ENG253312-ENG297233-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_6,Offset_0 ,51{SFD2} ENG253312-ENG297234-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_7,Offset_0 ,51{SFD2} ENG253312-ENG297235-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_8,Offset_0 ,51{SFD2} ENG253312-ENG297236-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_9,Offset_0 ,51{SFD2} ENG253312-ENG297237-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_1,Offset_0 ,51{SFD2} ENG253312-ENG297238-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_10,Offset_0 ,51{SFD2} ENG253312-ENG297239-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_11,Offset_0 ,51{SFD2} ENG253312-ENG297240-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_12,Offset_0 ,51{SFD2} ENG253312-ENG297241-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_13,Offset_0 ,51{SFD2} ENG253312-ENG297242-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_14,Offset_0 ,51{SFD2} ENG253312-ENG297243-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_15,Offset_0 ,51{SFD2} ENG253312-ENG297244-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_2,Offset_0 ,51{SFD2} ENG253312-ENG297245-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_3,Offset_0 ,51{SFD2} ENG253312-ENG297246-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_4,Offset_0 ,51{SFD2} ENG253312-ENG297247-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_5,Offset_0 ,51{SFD2} ENG253312-ENG297248-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_6,Offset_0 ,51{SFD2} ENG253312-ENG297249-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_7,Offset_0 ,51{SFD2} ENG253312-ENG297250-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_8,Offset_0 ,51{SFD2} ENG253312-ENG297251-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_9,Offset_0 ,51{SFD2} ENG253312-ENG297252-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_1,Offset_0 ,51{SFD2} ENG253312-ENG297253-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_10,Offset_0 ,51{SFD2} ENG253312-ENG297254-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_11,Offset_0 ,51{SFD2} ENG253312-ENG297255-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_12,Offset_0 ,51{SFD2} ENG253312-ENG297256-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_13,Offset_0 ,51{SFD2} ENG253312-ENG297257-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_14,Offset_0 ,51{SFD2} ENG253312-ENG297258-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_15,Offset_0 ,51{SFD2} ENG253312-ENG297259-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_2,Offset_0 ,51{SFD2} ENG253312-ENG297260-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_3,Offset_0 ,51{SFD2} ENG253312-ENG297261-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_4,Offset_0 ,51{SFD2} ENG253312-ENG297262-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_5,Offset_0 ,51{SFD2} ENG253312-ENG297263-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_6,Offset_0 ,51{SFD2} ENG253312-ENG297264-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_7,Offset_0 ,51{SFD2} ENG253312-ENG297265-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_8,Offset_0 ,51{SFD2} ENG253312-ENG297266-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_9,Offset_0 ,51{SFD2} ENG253400-ENG259423-Interior_light_router_config-Output_bcm_amb1_light_function,00 ,93{SFD2} ENG253400-ENG258209-Interior_light_router_config-Output_bcm_amb2_light_function,00 ,93{SFD2} ENG253400-ENG261174-Interior_light_router_config-Output_bcm_amb3_light_function,00 ,93{SFD2} ENG253400-ENG259810-Interior_light_router_config-Output_bcm_amb4_light_function,00 ,93{SFD2} ENG253400-ENG261141-Interior_light_router_config-Output_bcm_frl_light_function,00 ,93{SFD2} ENG253400-ENG258669-Interior_light_router_config-Output_BCM_interiorlight,00 ,93{SFD2} ENG253400-ENG260789-Interior_light_router_config-Output_bcm_krl_light_function,FE ,93{SFD2} ENG253400-ENG263574-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_left,00 ,93{SFD2} ENG253400-ENG263530-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_right,00 ,93{SFD2} ENG253400-ENG263557-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_left,00 ,93{SFD2} ENG253400-ENG263579-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_right,00 ,93{SFD2} ENG253400-ENG259911-Interior_light_router_config-Output_lin10_light_function_slave_1,00 ,93{SFD2} ENG253400-ENG261157-Interior_light_router_config-Output_lin10_light_function_slave_10,00 ,93{SFD2} ENG253400-ENG259627-Interior_light_router_config-Output_lin10_light_function_slave_11,00 ,93{SFD2} ENG253400-ENG260063-Interior_light_router_config-Output_lin10_light_function_slave_12,00 ,93{SFD2} ENG253400-ENG260392-Interior_light_router_config-Output_lin10_light_function_slave_13,00 ,93{SFD2} ENG253400-ENG261033-Interior_light_router_config-Output_lin10_light_function_slave_14,00 ,93{SFD2} ENG253400-ENG260756-Interior_light_router_config-Output_lin10_light_function_slave_15,00 ,93{SFD2} ENG253400-ENG259504-Interior_light_router_config-Output_lin10_light_function_slave_2,00 ,93{SFD2} ENG253400-ENG259442-Interior_light_router_config-Output_lin10_light_function_slave_3,00 ,93{SFD2} ENG253400-ENG260805-Interior_light_router_config-Output_lin10_light_function_slave_4,00 ,93{SFD2} ENG253400-ENG258266-Interior_light_router_config-Output_lin10_light_function_slave_5,00 ,93{SFD2} ENG253400-ENG259364-Interior_light_router_config-Output_lin10_light_function_slave_6,00 ,93{SFD2} ENG253400-ENG258390-Interior_light_router_config-Output_lin10_light_function_slave_7,00 ,93{SFD2} ENG253400-ENG259292-Interior_light_router_config-Output_lin10_light_function_slave_8,00 ,93{SFD2} ENG253400-ENG258719-Interior_light_router_config-Output_lin10_light_function_slave_9,00 ,93{SFD2} ENG253400-ENG259289-Interior_light_router_config-Output_lin5_light_function_slave_1,00 ,93{SFD2} ENG253400-ENG260386-Interior_light_router_config-Output_lin5_light_function_slave_10,00 ,93{SFD2} ENG253400-ENG259124-Interior_light_router_config-Output_lin5_light_function_slave_11,00 ,93{SFD2} ENG253400-ENG259695-Interior_light_router_config-Output_lin5_light_function_slave_12,00 ,93{SFD2} ENG253400-ENG260422-Interior_light_router_config-Output_lin5_light_function_slave_13,00 ,93{SFD2} ENG253400-ENG261133-Interior_light_router_config-Output_lin5_light_function_slave_14,00 ,93{SFD2} ENG253400-ENG258921-Interior_light_router_config-Output_lin5_light_function_slave_15,00 ,93{SFD2} ENG253400-ENG260665-Interior_light_router_config-Output_lin5_light_function_slave_2,00 ,93{SFD2} ENG253400-ENG260238-Interior_light_router_config-Output_lin5_light_function_slave_3,00 ,93{SFD2} ENG253400-ENG260068-Interior_light_router_config-Output_lin5_light_function_slave_4,00 ,93{SFD2} ENG253400-ENG260774-Interior_light_router_config-Output_lin5_light_function_slave_5,00 ,93{SFD2} ENG253400-ENG258506-Interior_light_router_config-Output_lin5_light_function_slave_6,00 ,93{SFD2} ENG253400-ENG259536-Interior_light_router_config-Output_lin5_light_function_slave_7,00 ,93{SFD2} ENG253400-ENG260354-Interior_light_router_config-Output_lin5_light_function_slave_8,00 ,93{SFD2} ENG253400-ENG261251-Interior_light_router_config-Output_lin5_light_function_slave_9,00 ,93{SFD2} ENG253400-ENG259104-Interior_light_router_config-Output_lin9_light_function_slave_1,00 ,93{SFD2} ENG253400-ENG260459-Interior_light_router_config-Output_lin9_light_function_slave_10,00 ,93{SFD2} ENG253400-ENG259020-Interior_light_router_config-Output_lin9_light_function_slave_11,00 ,93{SFD2} ENG253400-ENG260441-Interior_light_router_config-Output_lin9_light_function_slave_12,00 ,93{SFD2} ENG253400-ENG260308-Interior_light_router_config-Output_lin9_light_function_slave_13,00 ,93{SFD2} ENG253400-ENG258226-Interior_light_router_config-Output_lin9_light_function_slave_14,00 ,93{SFD2} ENG253400-ENG259889-Interior_light_router_config-Output_lin9_light_function_slave_15,00 ,93{SFD2} ENG253400-ENG259254-Interior_light_router_config-Output_lin9_light_function_slave_2,00 ,93{SFD2} ENG253400-ENG258737-Interior_light_router_config-Output_lin9_light_function_slave_3,00 ,93{SFD2} ENG253400-ENG260120-Interior_light_router_config-Output_lin9_light_function_slave_4,00 ,93{SFD2} ENG253400-ENG258661-Interior_light_router_config-Output_lin9_light_function_slave_5,00 ,93{SFD2} ENG253400-ENG260829-Interior_light_router_config-Output_lin9_light_function_slave_6,00 ,93{SFD2} ENG253400-ENG260402-Interior_light_router_config-Output_lin9_light_function_slave_7,00 ,93{SFD2} ENG253400-ENG261173-Interior_light_router_config-Output_lin9_light_function_slave_8,00 ,93{SFD2} ENG253400-ENG260176-Interior_light_router_config-Output_lin9_light_function_slave_9,00 ,93{SFD2} ENG253400-ENG258236-Interior_light_router_config-Output_roof_console_1,1F ,93{SFD2} ENG253400-ENG258284-Interior_light_router_config-Output_roof_console_2,1F ,93{SFD2} ENG253400-ENG260269-Interior_light_router_config-Output_roof_console_3,1F ,93{SFD2} ENG253400-ENG261203-Interior_light_router_config-Output_roof_console_4,1F ,93{SFD2} ENG253400-ENG258705-Interior_light_router_config-Output_roof_console_5,1E ,93{SFD2} ENG253400-ENG258805-Interior_light_router_config-Output_roof_console_6,1E ,93{SFD2} ENG253400-ENG260327-Interior_light_router_config-Output_tsg_bfs_1,00 ,93{SFD2} ENG253400-ENG259694-Interior_light_router_config-Output_tsg_bfs_2,00 ,93{SFD2} ENG253400-ENG261276-Interior_light_router_config-Output_tsg_bfs_3,00 ,93{SFD2} ENG253400-ENG258178-Interior_light_router_config-Output_tsg_bfs_4,00 ,93{SFD2} ENG253400-ENG260821-Interior_light_router_config-Output_tsg_bfsh_1,00 ,93{SFD2} ENG253400-ENG260853-Interior_light_router_config-Output_tsg_bfsh_2,00 ,93{SFD2} ENG253400-ENG258859-Interior_light_router_config-Output_tsg_bfsh_3,00 ,93{SFD2} ENG253400-ENG261258-Interior_light_router_config-Output_tsg_bfsh_4,00 ,93{SFD2} ENG253400-ENG260340-Interior_light_router_config-Output_tsg_fs_1,00 ,93{SFD2} ENG253400-ENG258105-Interior_light_router_config-Output_tsg_fs_2,00 ,93{SFD2} ENG253400-ENG260046-Interior_light_router_config-Output_tsg_fs_3,00 ,93{SFD2} ENG253400-ENG258946-Interior_light_router_config-Output_tsg_fs_4,00 ,93{SFD2} ENG253400-ENG259611-Interior_light_router_config-Output_tsg_fsh_1,00 ,93{SFD2} ENG253400-ENG258415-Interior_light_router_config-Output_tsg_fsh_2,00 ,93{SFD2} ENG253400-ENG260438-Interior_light_router_config-Output_tsg_fsh_3,00 ,93{SFD2} ENG253400-ENG259398-Interior_light_router_config-Output_tsg_fsh_4,00 ,93{SFD2} ENG253388-ENG247388-Kessyfunktion-beeptime_reunlock,60_ms ,4{SFD2} ENG253388-ENG174170-Kessyfunktion-central_locking_system_selective_sigle_door_kessy_NAR,active ,4{SFD2} ENG253388-ENG259401-Kessyfunktion-Gesamtoeffnung_ueber_Kessy,active ,4{SFD2} ENG253388-ENG258623-Kessyfunktion-Heck_wiederentriegelung_ohne_Auswurf,active ,4{SFD2} ENG253388-ENG259486-Kessyfunktion-Komfortbedienung_fh_oeffnen_ueber_kessy,not active ,4{SFD2} ENG253388-ENG258699-Kessyfunktion-Komfortbedienung_fh_schliessen_ueber_kessy,active ,4{SFD2} ENG253388-ENG248300-Kessyfunktion-reunlock_beep,not active ,4{SFD2} ENG253388-ENG259448-Kessyfunktion-Verriegeln_ueber_Toggle_nur_bei_Aussenhaut_geschlossen,not active ,4{SFD2} ENG253388-ENG259117-Kessyfunktion-Wiederentriegelung_komplett,not_active ,4{SFD2} ENG253388-ENG260947-Kessyfunktion-ZV_Kessy_Toggle_Taster_aktiv,not active ,4ENG253068-ENG261092-Leuchte 0 BLK VL B24-Dimming Direction DEF 0,maximize ,20ENG253068-ENG259139-Leuchte 0 BLK VL B24-Dimming Direction GHI 0,maximize ,20ENG253068-ENG259025-Leuchte 0 BLK VL B24-Dimming Direction JKL 0,maximize ,20ENG253068-ENG259443-Leuchte 0 BLK VL B24-Dimmwert ABC 0,100 ,20ENG253068-ENG260613-Leuchte 0 BLK VL B24-Dimmwert DEF 0,0 ,20ENG253068-ENG259327-Leuchte 0 BLK VL B24-Dimmwert GHI 0,0 ,20ENG253068-ENG261252-Leuchte 0 BLK VL B24-Dimmwert JKL 0,0 ,20ENG253068-ENG115875-Leuchte 0 BLK VL B24-Fehlerort mittleres Byte DTC-DFCC 0,14 ,20ENG253068-ENG116547-Leuchte 0 BLK VL B24-Lampendefektbit Position 0,34 ,20ENG253068-ENG258269-Leuchte 0 BLK VL B24-Lasttyp_0,Blinkleuchten ,20ENG253068-ENG260373-Leuchte 0 BLK VL B24-Lichtansteuerung HD ABC 0,Always ,20ENG253068-ENG115876-Leuchte 0 BLK VL B24-Lichtfunktion A 0,Blinken links Hellphase ,20ENG253068-ENG115877-Leuchte 0 BLK VL B24-Lichtfunktion B 0,not active ,20ENG253068-ENG115880-Leuchte 0 BLK VL B24-Lichtfunktion C 0,not active ,20ENG253068-ENG115881-Leuchte 0 BLK VL B24-Lichtfunktion D 0,not active ,20ENG253068-ENG115884-Leuchte 0 BLK VL B24-Lichtfunktion E 0,not active ,20ENG253068-ENG115885-Leuchte 0 BLK VL B24-Lichtfunktion F 0,not active ,20ENG253068-ENG115888-Leuchte 0 BLK VL B24-Lichtfunktion G 0,not active ,20ENG253068-ENG115889-Leuchte 0 BLK VL B24-Lichtfunktion H 0,not active ,20ENG253068-ENG258703-Leuchte 0 BLK VL B24-Lichtfunktion I 0,not active ,20ENG253068-ENG261318-Leuchte 0 BLK VL B24-Lichtfunktion J 0,not active ,20ENG253068-ENG258291-Leuchte 0 BLK VL B24-Lichtfunktion K 0,not active ,20ENG253068-ENG258466-Leuchte 0 BLK VL B24-Lichtfunktion L 0,not active ,20ENG263470-ENG261125-Leuchte 1 BLK VR B9-Dimming Direction DEF 1,maximize ,20ENG263470-ENG259203-Leuchte 1 BLK VR B9-Dimming Direction GHI 1,maximize ,20ENG263470-ENG259792-Leuchte 1 BLK VR B9-Dimming Direction JKL 1,maximize ,20ENG263470-ENG259773-Leuchte 1 BLK VR B9-Dimmwert ABC 1,100 ,20ENG263470-ENG259452-Leuchte 1 BLK VR B9-Dimmwert DEF 1,0 ,20ENG263470-ENG258945-Leuchte 1 BLK VR B9-Dimmwert GHI 1,0 ,20ENG263470-ENG260514-Leuchte 1 BLK VR B9-Dimmwert JKL 1,0 ,20ENG263470-ENG115894-Leuchte 1 BLK VR B9-Fehlerort mittleres Byte DTC-DFCC 1,21 ,20ENG263470-ENG116548-Leuchte 1 BLK VR B9-Lampendefektbitposition 1,62 ,20ENG263470-ENG115892-Leuchte 1 BLK VR B9-Lasttyp 1,Blinkleuchten ,20ENG263470-ENG258732-Leuchte 1 BLK VR B9-Lichtansteuerung HD ABC 1,Always ,20ENG263470-ENG115895-Leuchte 1 BLK VR B9-Lichtfunktion A 1,Blinken rechts Hellphase ,20ENG263470-ENG115896-Leuchte 1 BLK VR B9-Lichtfunktion B 1,not active ,20ENG263470-ENG115899-Leuchte 1 BLK VR B9-Lichtfunktion C 1,not active ,20ENG263470-ENG115900-Leuchte 1 BLK VR B9-Lichtfunktion D 1,not active ,20ENG263470-ENG115903-Leuchte 1 BLK VR B9-Lichtfunktion E 1,not active ,20ENG263470-ENG115904-Leuchte 1 BLK VR B9-Lichtfunktion F 1,not active ,20ENG263470-ENG115907-Leuchte 1 BLK VR B9-Lichtfunktion G 1,not active ,20ENG263470-ENG116549-Leuchte 1 BLK VR B9-Lichtfunktion H 1,not active ,20ENG263470-ENG258834-Leuchte 1 BLK VR B9-Lichtfunktion I 1,not active ,20ENG263470-ENG259586-Leuchte 1 BLK VR B9-Lichtfunktion J 1,not active ,20ENG263470-ENG260282-Leuchte 1 BLK VR B9-Lichtfunktion K 1,not active ,20ENG263470-ENG260467-Leuchte 1 BLK VR B9-Lichtfunktion L 1,not active ,20ENG263477-ENG260590-Leuchte 10 SHUTTER L B23-Dimming Direction DEF 10,maximize ,20ENG263477-ENG260408-Leuchte 10 SHUTTER L B23-Dimming Direction GHI 10,maximize ,20ENG263477-ENG258321-Leuchte 10 SHUTTER L B23-Dimming Direction JKL 10,maximize ,20ENG263477-ENG260576-Leuchte 10 SHUTTER L B23-Dimmwert ABC 10,0 ,20ENG263477-ENG258223-Leuchte 10 SHUTTER L B23-Dimmwert DEF 10,0 ,20ENG263477-ENG260725-Leuchte 10 SHUTTER L B23-Dimmwert GHI 10,0 ,20ENG263477-ENG258779-Leuchte 10 SHUTTER L B23-Dimmwert JKL 10,0 ,20ENG263477-ENG116064-Leuchte 10 SHUTTER L B23-Fehlerort mittleres Byte DTC-DFCC 10,0 ,20ENG263477-ENG116560-Leuchte 10 SHUTTER L B23-Lampendefektbitposition 10,0 ,20ENG263477-ENG116062-Leuchte 10 SHUTTER L B23-Lasttyp 10,not_active ,20ENG263477-ENG260677-Leuchte 10 SHUTTER L B23-Lichtansteuerung HD ABC 10,Always ,20ENG263477-ENG116065-Leuchte 10 SHUTTER L B23-Lichtfunktion A 10,not active ,20ENG263477-ENG116066-Leuchte 10 SHUTTER L B23-Lichtfunktion B 10,not active ,20ENG263477-ENG116069-Leuchte 10 SHUTTER L B23-Lichtfunktion C 10,not active ,20ENG263477-ENG116070-Leuchte 10 SHUTTER L B23-Lichtfunktion D 10,not active ,20ENG263477-ENG116073-Leuchte 10 SHUTTER L B23-Lichtfunktion E 10,not active ,20ENG263477-ENG116074-Leuchte 10 SHUTTER L B23-Lichtfunktion F 10,not active ,20ENG263477-ENG116077-Leuchte 10 SHUTTER L B23-Lichtfunktion G 10,not active ,20ENG263477-ENG116078-Leuchte 10 SHUTTER L B23-Lichtfunktion H 10,not active ,20ENG263477-ENG261127-Leuchte 10 SHUTTER L B23-Lichtfunktion I 10,not active ,20ENG263477-ENG259264-Leuchte 10 SHUTTER L B23-Lichtfunktion J 10,not active ,20ENG263477-ENG258792-Leuchte 10 SHUTTER L B23-Lichtfunktion K 10,not active ,20ENG263477-ENG260117-Leuchte 10 SHUTTER L B23-Lichtfunktion L 10,not active ,20ENG263480-ENG260377-Leuchte 11 SHUTTER R B22-Dimming Direction DEF 11,maximize ,20ENG263480-ENG261238-Leuchte 11 SHUTTER R B22-Dimming Direction GHI 11,maximize ,20ENG263480-ENG258509-Leuchte 11 SHUTTER R B22-Dimming Direction JKL 11,maximize ,20ENG263480-ENG259362-Leuchte 11 SHUTTER R B22-Dimmwert ABC 11,0 ,20ENG263480-ENG259167-Leuchte 11 SHUTTER R B22-Dimmwert DEF 11,0 ,20ENG263480-ENG259831-Leuchte 11 SHUTTER R B22-Dimmwert GHI 11,0 ,20ENG263480-ENG259729-Leuchte 11 SHUTTER R B22-Dimmwert JKL 11,0 ,20ENG263480-ENG116083-Leuchte 11 SHUTTER R B22-Fehlerort mittleres Byte DTC-DFCC 11,0 ,20ENG263480-ENG116561-Leuchte 11 SHUTTER R B22-Lampendefektbitposition 11,0 ,20ENG263480-ENG116081-Leuchte 11 SHUTTER R B22-Lasttyp 11,not_active ,20ENG263480-ENG259732-Leuchte 11 SHUTTER R B22-Lichtansteuerung HD ABC 11,Always ,20ENG263480-ENG116084-Leuchte 11 SHUTTER R B22-Lichtfunktion A 11,not active ,20ENG263480-ENG116085-Leuchte 11 SHUTTER R B22-Lichtfunktion B 11,not active ,20ENG263480-ENG116088-Leuchte 11 SHUTTER R B22-Lichtfunktion C 11,not active ,20ENG263480-ENG116089-Leuchte 11 SHUTTER R B22-Lichtfunktion D 11,not active ,20ENG263480-ENG116092-Leuchte 11 SHUTTER R B22-Lichtfunktion E 11,not active ,20ENG263480-ENG116093-Leuchte 11 SHUTTER R B22-Lichtfunktion F 11,not active ,20ENG263480-ENG116096-Leuchte 11 SHUTTER R B22-Lichtfunktion G 11,not active ,20ENG263480-ENG116097-Leuchte 11 SHUTTER R B22-Lichtfunktion H 11,not active ,20ENG263480-ENG260510-Leuchte 11 SHUTTER R B22-Lichtfunktion I 11,not active ,20ENG263480-ENG258304-Leuchte 11 SHUTTER R B22-Lichtfunktion J 11,not active ,20ENG263480-ENG260059-Leuchte 11 SHUTTER R B22-Lichtfunktion K 11,not active ,20ENG263480-ENG260686-Leuchte 11 SHUTTER R B22-Lichtfunktion L 11,not active ,20{SFD2} ENG263462-ENG259122-Leuchte 12 NL L B45-Dimming Direction DEF 12,maximize ,20{SFD2} ENG263462-ENG260186-Leuchte 12 NL L B45-Dimming Direction GHI 12,maximize ,20{SFD2} ENG263462-ENG258138-Leuchte 12 NL L B45-Dimming Direction JKL 12,maximize ,20{SFD2} ENG263462-ENG261305-Leuchte 12 NL L B45-Dimmwert ABC 12,0 ,20{SFD2} ENG263462-ENG258909-Leuchte 12 NL L B45-Dimmwert DEF 12,0 ,20{SFD2} ENG263462-ENG261043-Leuchte 12 NL L B45-Dimmwert GHI 12,0 ,20{SFD2} ENG263462-ENG261121-Leuchte 12 NL L B45-Dimmwert JKL 12,0 ,20{SFD2} ENG263462-ENG116102-Leuchte 12 NL L B45-Fehlerort mittleres Byte DTC-DFCC 12,0 ,20{SFD2} ENG263462-ENG116562-Leuchte 12 NL L B45-Lampendefektbitposition 12,0 ,20{SFD2} ENG263462-ENG116100-Leuchte 12 NL L B45-Lasttyp 12,not_active ,20{SFD2} ENG263462-ENG258775-Leuchte 12 NL L B45-Lichtansteuerung HD ABC 12,Always ,20{SFD2} ENG263462-ENG116103-Leuchte 12 NL L B45-Lichtfunktion A 12,not active ,20{SFD2} ENG263462-ENG116104-Leuchte 12 NL L B45-Lichtfunktion B 12,not active ,20{SFD2} ENG263462-ENG116107-Leuchte 12 NL L B45-Lichtfunktion C 12,not active ,20{SFD2} ENG263462-ENG116108-Leuchte 12 NL L B45-Lichtfunktion D 12,not active ,20{SFD2} ENG263462-ENG116111-Leuchte 12 NL L B45-Lichtfunktion E 12,not active ,20{SFD2} ENG263462-ENG116112-Leuchte 12 NL L B45-Lichtfunktion F 12,not active ,20{SFD2} ENG263462-ENG116115-Leuchte 12 NL L B45-Lichtfunktion G 12,not active ,20{SFD2} ENG263462-ENG116116-Leuchte 12 NL L B45-Lichtfunktion H 12,not active ,20{SFD2} ENG263462-ENG261188-Leuchte 12 NL L B45-Lichtfunktion I 12,not active ,20{SFD2} ENG263462-ENG260482-Leuchte 12 NL L B45-Lichtfunktion J 12,not active ,20{SFD2} ENG263462-ENG258107-Leuchte 12 NL L B45-Lichtfunktion K 12,not active ,20{SFD2} ENG263462-ENG259735-Leuchte 12 NL L B45-Lichtfunktion L 12,not active ,20{SFD2} ENG263429-ENG258235-Leuchte 13 NL R B5-Dimming Direction DEF 13,maximize ,20{SFD2} ENG263429-ENG258860-Leuchte 13 NL R B5-Dimming Direction GHI 13,maximize ,20{SFD2} ENG263429-ENG261185-Leuchte 13 NL R B5-Dimming Direction JKL 13,maximize ,20{SFD2} ENG263429-ENG260614-Leuchte 13 NL R B5-Dimmwert ABC 13,0 ,20{SFD2} ENG263429-ENG258948-Leuchte 13 NL R B5-Dimmwert DEF 13,0 ,20{SFD2} ENG263429-ENG261076-Leuchte 13 NL R B5-Dimmwert GHI 13,0 ,20{SFD2} ENG263429-ENG260048-Leuchte 13 NL R B5-Dimmwert JKL 13,0 ,20{SFD2} ENG263429-ENG116121-Leuchte 13 NL R B5-Fehlerort mittleres Byte DTC-DFCC 13,0 ,20{SFD2} ENG263429-ENG116563-Leuchte 13 NL R B5-Lampendefektbitposition 13,0 ,20{SFD2} ENG263429-ENG116119-Leuchte 13 NL R B5-Lasttyp 13,not_active ,20{SFD2} ENG263429-ENG259297-Leuchte 13 NL R B5-Lichtansteuerung HD ABC 13,Always ,20{SFD2} ENG263429-ENG116122-Leuchte 13 NL R B5-Lichtfunktion A 13,not active ,20{SFD2} ENG263429-ENG116123-Leuchte 13 NL R B5-Lichtfunktion B 13,not active ,20{SFD2} ENG263429-ENG116564-Leuchte 13 NL R B5-Lichtfunktion C 13,not active ,20{SFD2} ENG263429-ENG116127-Leuchte 13 NL R B5-Lichtfunktion D 13,not active ,20{SFD2} ENG263429-ENG116130-Leuchte 13 NL R B5-Lichtfunktion E 13,not active ,20{SFD2} ENG263429-ENG116131-Leuchte 13 NL R B5-Lichtfunktion F 13,not active ,20{SFD2} ENG263429-ENG116134-Leuchte 13 NL R B5-Lichtfunktion G 13,not active ,20{SFD2} ENG263429-ENG116135-Leuchte 13 NL R B5-Lichtfunktion H 13,not active ,20{SFD2} ENG263429-ENG259477-Leuchte 13 NL R B5-Lichtfunktion I 13,not active ,20{SFD2} ENG263429-ENG259138-Leuchte 13 NL R B5-Lichtfunktion J 13,not active ,20{SFD2} ENG263429-ENG258127-Leuchte 13 NL R B5-Lichtfunktion K 13,not active ,20{SFD2} ENG263429-ENG259174-Leuchte 13 NL R B5-Lichtfunktion L 13,not active ,20{SFD2} ENG263460-ENG260021-Leuchte 16 BLK SL B42_C31-Dimming Direction DEF 16,maximize ,20{SFD2} ENG263460-ENG258735-Leuchte 16 BLK SL B42_C31-Dimming Direction GHI 16,maximize ,20{SFD2} ENG263460-ENG260912-Leuchte 16 BLK SL B42_C31-Dimming Direction JKL 16,maximize ,20{SFD2} ENG263460-ENG260010-Leuchte 16 BLK SL B42_C31-Dimmwert ABC 16,100 ,20{SFD2} ENG263460-ENG258276-Leuchte 16 BLK SL B42_C31-Dimmwert DEF 16,0 ,20{SFD2} ENG263460-ENG259552-Leuchte 16 BLK SL B42_C31-Dimmwert GHI 16,0 ,20{SFD2} ENG263460-ENG260945-Leuchte 16 BLK SL B42_C31-Dimmwert JKL 16,0 ,20{SFD2} ENG263460-ENG116178-Leuchte 16 BLK SL B42_C31-Fehlerort mittleres Byte DTC-DFCC 16,23 ,20{SFD2} ENG263460-ENG116567-Leuchte 16 BLK SL B42_C31-Lampendefektbitposition 16,57 ,20{SFD2} ENG263460-ENG116176-Leuchte 16 BLK SL B42_C31-Lasttyp 16,Blinkleuchten ,20{SFD2} ENG263460-ENG258626-Leuchte 16 BLK SL B42_C31-Lichtansteuerung HD ABC 16,Always ,20{SFD2} ENG263460-ENG116179-Leuchte 16 BLK SL B42_C31-Lichtfunktion A 16,Blinken links Hellphase ,20{SFD2} ENG263460-ENG116180-Leuchte 16 BLK SL B42_C31-Lichtfunktion B 16,not active ,20{SFD2} ENG263460-ENG116183-Leuchte 16 BLK SL B42_C31-Lichtfunktion C 16,not active ,20{SFD2} ENG263460-ENG116184-Leuchte 16 BLK SL B42_C31-Lichtfunktion D 16,not active ,20{SFD2} ENG263460-ENG116187-Leuchte 16 BLK SL B42_C31-Lichtfunktion E 16,not active ,20{SFD2} ENG263460-ENG116188-Leuchte 16 BLK SL B42_C31-Lichtfunktion F 16,not active ,20{SFD2} ENG263460-ENG116191-Leuchte 16 BLK SL B42_C31-Lichtfunktion G 16,not active ,20{SFD2} ENG263460-ENG116192-Leuchte 16 BLK SL B42_C31-Lichtfunktion H 16,not active ,20{SFD2} ENG263460-ENG261052-Leuchte 16 BLK SL B42_C31-Lichtfunktion I 16,not active ,20{SFD2} ENG263460-ENG258938-Leuchte 16 BLK SL B42_C31-Lichtfunktion J 16,not active ,20{SFD2} ENG263460-ENG258710-Leuchte 16 BLK SL B42_C31-Lichtfunktion K 16,not active ,20{SFD2} ENG263460-ENG259847-Leuchte 16 BLK SL B42_C31-Lichtfunktion L 16,not active ,20{SFD2} ENG253179-ENG258693-Leuchte 17 BLK_SR B4_A61-Dimming Direction DEF 17,maximize ,20{SFD2} ENG253179-ENG259225-Leuchte 17 BLK_SR B4_A61-Dimming Direction GHI 17,maximize ,20{SFD2} ENG253179-ENG260036-Leuchte 17 BLK_SR B4_A61-Dimming Direction JKL 17,maximize ,20{SFD2} ENG253179-ENG259305-Leuchte 17 BLK_SR B4_A61-Dimmwert ABC 17,100 ,20{SFD2} ENG253179-ENG260736-Leuchte 17 BLK_SR B4_A61-Dimmwert DEF 17,0 ,20{SFD2} ENG253179-ENG261209-Leuchte 17 BLK_SR B4_A61-Dimmwert GHI 17,0 ,20{SFD2} ENG253179-ENG260649-Leuchte 17 BLK_SR B4_A61-Dimmwert JKL 17,0 ,20{SFD2} ENG253179-ENG116197-Leuchte 17 BLK_SR B4_A61-Fehlerort mittleres Byte DTC-DFCC 17,25 ,20{SFD2} ENG253179-ENG116568-Leuchte 17 BLK_SR B4_A61-Lampendefektbitposition 17,67 ,20{SFD2} ENG253179-ENG116195-Leuchte 17 BLK_SR B4_A61-Lasttyp 17,Blinkleuchten ,20{SFD2} ENG253179-ENG259860-Leuchte 17 BLK_SR B4_A61-Lichtansteuerung HD ABC 17,Always ,20{SFD2} ENG253179-ENG116198-Leuchte 17 BLK_SR B4_A61-Lichtfunktion A 17,Blinken rechts Hellphase ,20{SFD2} ENG253179-ENG116569-Leuchte 17 BLK_SR B4_A61-Lichtfunktion B 17,not active ,20{SFD2} ENG253179-ENG116202-Leuchte 17 BLK_SR B4_A61-Lichtfunktion C 17,not active ,20{SFD2} ENG253179-ENG116203-Leuchte 17 BLK_SR B4_A61-Lichtfunktion D 17,not active ,20{SFD2} ENG253179-ENG116206-Leuchte 17 BLK_SR B4_A61-Lichtfunktion E 17,not active ,20{SFD2} ENG253179-ENG116207-Leuchte 17 BLK_SR B4_A61-Lichtfunktion F 17,not active ,20{SFD2} ENG253179-ENG116210-Leuchte 17 BLK_SR B4_A61-Lichtfunktion G 17,not active ,20{SFD2} ENG253179-ENG116211-Leuchte 17 BLK_SR B4_A61-Lichtfunktion H 17,not active ,20{SFD2} ENG253179-ENG258378-Leuchte 17 BLK_SR B4_A61-Lichtfunktion I 17,not active ,20{SFD2} ENG253179-ENG259950-Leuchte 17 BLK_SR B4_A61-Lichtfunktion J 17,not active ,20{SFD2} ENG253179-ENG259363-Leuchte 17 BLK_SR B4_A61-Lichtfunktion K 17,not active ,20{SFD2} ENG253179-ENG259816-Leuchte 17 BLK_SR B4_A61-Lichtfunktion L 17,not active ,20ENG263478-ENG260141-Leuchte 18 BLK HL A60-Dimming Direction DEF 18,maximize ,20ENG263478-ENG258397-Leuchte 18 BLK HL A60-Dimming Direction GHI 18,maximize ,20ENG263478-ENG259980-Leuchte 18 BLK HL A60-Dimming Direction JKL 18,maximize ,20ENG263478-ENG261250-Leuchte 18 BLK HL A60-Dimmwert ABC 18,100 ,20ENG263478-ENG258343-Leuchte 18 BLK HL A60-Dimmwert DEF 18,0 ,20ENG263478-ENG258799-Leuchte 18 BLK HL A60-Dimmwert GHI 18,0 ,20ENG263478-ENG259813-Leuchte 18 BLK HL A60-Dimmwert JKL 18,0 ,20ENG263478-ENG116216-Leuchte 18 BLK HL A60-Fehlerort mittleres Byte DTC-DFCC 18,22 ,20ENG263478-ENG116570-Leuchte 18 BLK HL A60-Lampendefektbitposition 18,8 ,20ENG263478-ENG116214-Leuchte 18 BLK HL A60-Lasttyp 18,Blinkleuchten ,20ENG263478-ENG258246-Leuchte 18 BLK HL A60-Lichtansteuerung HD ABC 18,Always ,20ENG263478-ENG116217-Leuchte 18 BLK HL A60-Lichtfunktion A 18,Blinken links Hellphase ,20ENG263478-ENG116218-Leuchte 18 BLK HL A60-Lichtfunktion B 18,not active ,20ENG263478-ENG116221-Leuchte 18 BLK HL A60-Lichtfunktion C 18,not active ,20ENG263478-ENG116222-Leuchte 18 BLK HL A60-Lichtfunktion D 18,not active ,20ENG263478-ENG116225-Leuchte 18 BLK HL A60-Lichtfunktion E 18,not active ,20ENG263478-ENG116226-Leuchte 18 BLK HL A60-Lichtfunktion F 18,not active ,20ENG263478-ENG116229-Leuchte 18 BLK HL A60-Lichtfunktion G 18,not active ,20ENG263478-ENG116230-Leuchte 18 BLK HL A60-Lichtfunktion H 18,not active ,20ENG263478-ENG259904-Leuchte 18 BLK HL A60-Lichtfunktion I 18,not active ,20ENG263478-ENG260450-Leuchte 18 BLK HL A60-Lichtfunktion J 18,not active ,20ENG263478-ENG258383-Leuchte 18 BLK HL A60-Lichtfunktion K 18,not active ,20ENG263478-ENG261100-Leuchte 18 BLK HL A60-Lichtfunktion L 18,not active ,20ENG263431-ENG258368-Leuchte 19 BLK HR C27-Dimming Direction DEF 19,maximize ,20ENG263431-ENG260517-Leuchte 19 BLK HR C27-Dimming Direction GHI 19,maximize ,20ENG263431-ENG260100-Leuchte 19 BLK HR C27-Dimming Direction JKL 19,maximize ,20ENG263431-ENG259136-Leuchte 19 BLK HR C27-Dimmwert ABC 19,100 ,20ENG263431-ENG260521-Leuchte 19 BLK HR C27-Dimmwert DEF 19,0 ,20ENG263431-ENG260131-Leuchte 19 BLK HR C27-Dimmwert GHI 19,0 ,20ENG263431-ENG259140-Leuchte 19 BLK HR C27-Dimmwert JKL 19,0 ,20ENG263431-ENG116235-Leuchte 19 BLK HR C27-Fehlerort mittleres Byte DTC-DFCC 19,24 ,20ENG263431-ENG116571-Leuchte 19 BLK HR C27-Lampendefektbitposition 19,24 ,20ENG263431-ENG116233-Leuchte 19 BLK HR C27-Lasttyp 19,Blinkleuchten ,20ENG263431-ENG258684-Leuchte 19 BLK HR C27-Lichtansteuerung HD ABC 19,Always ,20ENG263431-ENG116236-Leuchte 19 BLK HR C27-Lichtfunktion A 19,Blinken rechts Hellphase ,20ENG263431-ENG116237-Leuchte 19 BLK HR C27-Lichtfunktion B 19,not active ,20ENG263431-ENG116240-Leuchte 19 BLK HR C27-Lichtfunktion C 19,not active ,20ENG263431-ENG116241-Leuchte 19 BLK HR C27-Lichtfunktion D 19,not active ,20ENG263431-ENG116244-Leuchte 19 BLK HR C27-Lichtfunktion E 19,not active ,20ENG263431-ENG116245-Leuchte 19 BLK HR C27-Lichtfunktion F 19,not active ,20ENG263431-ENG116248-Leuchte 19 BLK HR C27-Lichtfunktion G 19,not active ,20ENG263431-ENG116249-Leuchte 19 BLK HR C27-Lichtfunktion H 19,not active ,20ENG263431-ENG258386-Leuchte 19 BLK HR C27-Lichtfunktion I 19,not active ,20ENG263431-ENG261194-Leuchte 19 BLK HR C27-Lichtfunktion J 19,not active ,20ENG263431-ENG260240-Leuchte 19 BLK HR C27-Lichtfunktion K 19,not active ,20ENG263431-ENG258090-Leuchte 19 BLK HR C27-Lichtfunktion L 19,not active ,20ENG263453-ENG259538-Leuchte 2 SL VL B20-Dimming Direction DEF 2,maximize ,20ENG263453-ENG259039-Leuchte 2 SL VL B20-Dimming Direction GHI 2,maximize ,20ENG263453-ENG261192-Leuchte 2 SL VL B20-Dimming Direction JKL 2,maximize ,20ENG263453-ENG260561-Leuchte 2 SL VL B20-Dimmwert ABC 2,0 ,20ENG263453-ENG259420-Leuchte 2 SL VL B20-Dimmwert DEF 2,0 ,20ENG263453-ENG258177-Leuchte 2 SL VL B20-Dimmwert GHI 2,0 ,20ENG263453-ENG260473-Leuchte 2 SL VL B20-Dimmwert JKL 2,0 ,20ENG263453-ENG115912-Leuchte 2 SL VL B20-Fehlerort mittleres Byte DTC-DFCC 2,0 ,20ENG263453-ENG116550-Leuchte 2 SL VL B20-Lampendefektbitposition 2,0 ,20ENG263453-ENG115910-Leuchte 2 SL VL B20-Lasttyp 2,not_active ,20ENG263453-ENG259674-Leuchte 2 SL VL B20-Lichtansteuerung HD ABC 2,Always ,20ENG263453-ENG115913-Leuchte 2 SL VL B20-Lichtfunktion A 2,not active ,20ENG263453-ENG115914-Leuchte 2 SL VL B20-Lichtfunktion B 2,not active ,20ENG263453-ENG115917-Leuchte 2 SL VL B20-Lichtfunktion C 2,not active ,20ENG263453-ENG115918-Leuchte 2 SL VL B20-Lichtfunktion D 2,not active ,20ENG263453-ENG115921-Leuchte 2 SL VL B20-Lichtfunktion E 2,not active ,20ENG263453-ENG115922-Leuchte 2 SL VL B20-Lichtfunktion F 2,not active ,20ENG263453-ENG115925-Leuchte 2 SL VL B20-Lichtfunktion G 2,not active ,20ENG263453-ENG115926-Leuchte 2 SL VL B20-Lichtfunktion H 2,not active ,20ENG263453-ENG261008-Leuchte 2 SL VL B20-Lichtfunktion I 2,not active ,20ENG263453-ENG259089-Leuchte 2 SL VL B20-Lichtfunktion J 2,not active ,20ENG263453-ENG259764-Leuchte 2 SL VL B20-Lichtfunktion K 2,not active ,20ENG263453-ENG261215-Leuchte 2 SL VL B20-Lichtfunktion L 2,not active ,20ENG263476-ENG258998-Leuchte 20 BR L A71-Dimming Direction DEF 20,maximize ,20ENG263476-ENG260228-Leuchte 20 BR L A71-Dimming Direction GHI 20,maximize ,20ENG263476-ENG258824-Leuchte 20 BR L A71-Dimming Direction JKL 20,maximize ,20ENG263476-ENG261006-Leuchte 20 BR L A71-Dimmwert ABC 20,35 ,20ENG263476-ENG260784-Leuchte 20 BR L A71-Dimmwert DEF 20,100 ,20ENG263476-ENG260188-Leuchte 20 BR L A71-Dimmwert GHI 20,0 ,20ENG263476-ENG258358-Leuchte 20 BR L A71-Dimmwert JKL 20,0 ,20ENG263476-ENG116254-Leuchte 20 BR L A71-Fehlerort mittleres Byte DTC-DFCC 20,57 ,20ENG263476-ENG116572-Leuchte 20 BR L A71-Lampendefektbitposition 20,16 ,20ENG263476-ENG116252-Leuchte 20 BR L A71-Lasttyp 20,Bremsleuchten ,20ENG263476-ENG259045-Leuchte 20 BR L A71-Lichtansteuerung HD ABC 20,Always ,20ENG263476-ENG116255-Leuchte 20 BR L A71-Lichtfunktion A 20,Position lamps ,20ENG263476-ENG116256-Leuchte 20 BR L A71-Lichtfunktion B 20,Parking light left ,20ENG263476-ENG116259-Leuchte 20 BR L A71-Lichtfunktion C 20,not active ,20ENG263476-ENG116260-Leuchte 20 BR L A71-Lichtfunktion D 20,Brake lamp ,20ENG263476-ENG116263-Leuchte 20 BR L A71-Lichtfunktion E 20,not active ,20ENG263476-ENG116264-Leuchte 20 BR L A71-Lichtfunktion F 20,not active ,20ENG263476-ENG116267-Leuchte 20 BR L A71-Lichtfunktion G 20,not active ,20ENG263476-ENG116268-Leuchte 20 BR L A71-Lichtfunktion H 20,not active ,20ENG263476-ENG259111-Leuchte 20 BR L A71-Lichtfunktion I 20,not active ,20ENG263476-ENG259768-Leuchte 20 BR L A71-Lichtfunktion J 20,not active ,20ENG263476-ENG260741-Leuchte 20 BR L A71-Lichtfunktion K 20,not active ,20ENG263476-ENG258272-Leuchte 20 BR L A71-Lichtfunktion L 20,not active ,20ENG263446-ENG259371-Leuchte 21 BR R C8-Dimming Direction DEF 21,maximize ,20ENG263446-ENG261222-Leuchte 21 BR R C8-Dimming Direction GHI 21,maximize ,20ENG263446-ENG260449-Leuchte 21 BR R C8-Dimming Direction JKL 21,maximize ,20ENG263446-ENG260142-Leuchte 21 BR R C8-Dimmwert ABC 21,35 ,20ENG263446-ENG259169-Leuchte 21 BR R C8-Dimmwert DEF 21,100 ,20ENG263446-ENG258330-Leuchte 21 BR R C8-Dimmwert GHI 21,0 ,20ENG263446-ENG260224-Leuchte 21 BR R C8-Dimmwert JKL 21,0 ,20ENG263446-ENG116273-Leuchte 21 BR R C8-Fehlerort mittleres Byte DTC-DFCC 21,58 ,20ENG263446-ENG116573-Leuchte 21 BR R C8-Lampendefektbitposition 21,32 ,20ENG263446-ENG116271-Leuchte 21 BR R C8-Lasttyp 21,Bremsleuchten ,20ENG263446-ENG259749-Leuchte 21 BR R C8-Lichtansteuerung HD ABC 21,Always ,20ENG263446-ENG116274-Leuchte 21 BR R C8-Lichtfunktion A 21,Position lamps ,20ENG263446-ENG116275-Leuchte 21 BR R C8-Lichtfunktion B 21,Parking light right ,20ENG263446-ENG116278-Leuchte 21 BR R C8-Lichtfunktion C 21,not active ,20ENG263446-ENG116279-Leuchte 21 BR R C8-Lichtfunktion D 21,Brake lamp ,20ENG263446-ENG116282-Leuchte 21 BR R C8-Lichtfunktion E 21,not active ,20ENG263446-ENG116283-Leuchte 21 BR R C8-Lichtfunktion F 21,not active ,20ENG263446-ENG116286-Leuchte 21 BR R C8-Lichtfunktion G 21,not active ,20ENG263446-ENG116287-Leuchte 21 BR R C8-Lichtfunktion H 21,not active ,20ENG263446-ENG260531-Leuchte 21 BR R C8-Lichtfunktion I 21,not active ,20ENG263446-ENG258267-Leuchte 21 BR R C8-Lichtfunktion J 21,not active ,20ENG263446-ENG261265-Leuchte 21 BR R C8-Lichtfunktion K 21,not active ,20ENG263446-ENG261356-Leuchte 21 BR R C8-Lichtfunktion L 21,not active ,20ENG263487-ENG261009-Leuchte 22 BR M A57-Dimming Direction DEF 22,maximize ,20ENG263487-ENG259558-Leuchte 22 BR M A57-Dimming Direction GHI 22,maximize ,20ENG263487-ENG258098-Leuchte 22 BR M A57-Dimming Direction JKL 22,maximize ,20ENG263487-ENG260824-Leuchte 22 BR M A57-Dimmwert ABC 22,127 ,20ENG263487-ENG261330-Leuchte 22 BR M A57-Dimmwert DEF 22,0 ,20ENG263487-ENG260249-Leuchte 22 BR M A57-Dimmwert GHI 22,0 ,20ENG263487-ENG260794-Leuchte 22 BR M A57-Dimmwert JKL 22,0 ,20ENG263487-ENG116292-Leuchte 22 BR M A57-Fehlerort mittleres Byte DTC-DFCC 22,44 ,20ENG263487-ENG116574-Leuchte 22 BR M A57-Lampendefektbitposition 22,41 ,20ENG263487-ENG116290-Leuchte 22 BR M A57-Lasttyp 22,LED_dritte_Bremsleuchte ,20ENG263487-ENG259134-Leuchte 22 BR M A57-Lichtansteuerung HD ABC 22,Always ,20ENG263487-ENG116293-Leuchte 22 BR M A57-Lichtfunktion A 22,Brake lamp ,20ENG263487-ENG116294-Leuchte 22 BR M A57-Lichtfunktion B 22,not active ,20ENG263487-ENG116297-Leuchte 22 BR M A57-Lichtfunktion C 22,not active ,20ENG263487-ENG116298-Leuchte 22 BR M A57-Lichtfunktion D 22,not active ,20ENG263487-ENG116301-Leuchte 22 BR M A57-Lichtfunktion E 22,not active ,20ENG263487-ENG116302-Leuchte 22 BR M A57-Lichtfunktion F 22,not active ,20ENG263487-ENG116305-Leuchte 22 BR M A57-Lichtfunktion G 22,not active ,20ENG263487-ENG116306-Leuchte 22 BR M A57-Lichtfunktion H 22,not active ,20ENG263487-ENG261266-Leuchte 22 BR M A57-Lichtfunktion I 22,not active ,20ENG263487-ENG259294-Leuchte 22 BR M A57-Lichtfunktion J 22,not active ,20ENG263487-ENG258164-Leuchte 22 BR M A57-Lichtfunktion K 22,not active ,20ENG263487-ENG259578-Leuchte 22 BR M A57-Lichtfunktion L 22,not active ,20ENG263433-ENG259710-Leuchte 23 SL HL C10-Dimming Direction DEF 32,maximize ,20ENG263433-ENG258905-Leuchte 23 SL HL C10-Dimming Direction GHI 32,maximize ,20ENG263433-ENG260532-Leuchte 23 SL HL C10-Dimming Direction JKL 32,maximize ,20ENG263433-ENG259737-Leuchte 23 SL HL C10-Dimmwert ABC 32,0 ,20ENG263433-ENG259346-Leuchte 23 SL HL C10-Dimmwert DEF 32,0 ,20ENG263433-ENG260258-Leuchte 23 SL HL C10-Dimmwert GHI 32,0 ,20ENG263433-ENG260382-Leuchte 23 SL HL C10-Dimmwert JKL 32,0 ,20ENG263433-ENG116482-Leuchte 23 SL HL C10-Fehlerort mittleres Byte DTC-DFCC 32,0 ,20ENG263433-ENG116584-Leuchte 23 SL HL C10-Lampendefektbitposition 32,0 ,20ENG263433-ENG116480-Leuchte 23 SL HL C10-Lasttyp 32,not_active ,20ENG263433-ENG259035-Leuchte 23 SL HL C10-Lichtansteuerung HD ABC 32,Always ,20ENG263433-ENG116483-Leuchte 23 SL HL C10-Lichtfunktion A 32,not active ,20ENG263433-ENG116484-Leuchte 23 SL HL C10-Lichtfunktion B 32,not active ,20ENG263433-ENG116487-Leuchte 23 SL HL C10-Lichtfunktion C 32,not active ,20ENG263433-ENG116488-Leuchte 23 SL HL C10-Lichtfunktion D 32,not active ,20ENG263433-ENG116491-Leuchte 23 SL HL C10-Lichtfunktion E 32,not active ,20ENG263433-ENG116492-Leuchte 23 SL HL C10-Lichtfunktion F 32,not active ,20ENG263433-ENG116495-Leuchte 23 SL HL C10-Lichtfunktion G 32,not active ,20ENG263433-ENG116496-Leuchte 23 SL HL C10-Lichtfunktion H 32,not active ,20ENG263433-ENG258763-Leuchte 23 SL HL C10-Lichtfunktion I 32,not active ,20ENG263433-ENG259842-Leuchte 23 SL HL C10-Lichtfunktion J 32,not active ,20ENG263433-ENG258857-Leuchte 23 SL HL C10-Lichtfunktion K 32,not active ,20ENG263433-ENG260175-Leuchte 23 SL HL C10-Lichtfunktion L 32,not active ,20ENG263475-ENG260709-Leuchte 24 SL HR A65-Dimming Direction DEF 24,maximize ,20ENG263475-ENG258518-Leuchte 24 SL HR A65-Dimming Direction GHI 24,maximize ,20ENG263475-ENG258189-Leuchte 24 SL HR A65-Dimming Direction JKL 24,maximize ,20ENG263475-ENG259150-Leuchte 24 SL HR A65-Dimmwert ABC 24,0 ,20ENG263475-ENG259120-Leuchte 24 SL HR A65-Dimmwert DEF 24,0 ,20ENG263475-ENG259774-Leuchte 24 SL HR A65-Dimmwert GHI 24,0 ,20ENG263475-ENG259393-Leuchte 24 SL HR A65-Dimmwert JKL 24,0 ,20ENG263475-ENG116330-Leuchte 24 SL HR A65-Fehlerort mittleres Byte DTC-DFCC 24,0 ,20ENG263475-ENG116576-Leuchte 24 SL HR A65-Lampendefektbitposition 24,0 ,20ENG263475-ENG116328-Leuchte 24 SL HR A65-Lasttyp 24,not_active ,20ENG263475-ENG258842-Leuchte 24 SL HR A65-Lichtansteuerung HD ABC 24,Always ,20ENG263475-ENG116331-Leuchte 24 SL HR A65-Lichtfunktion A 24,not active ,20ENG263475-ENG116332-Leuchte 24 SL HR A65-Lichtfunktion B 24,not active ,20ENG263475-ENG116335-Leuchte 24 SL HR A65-Lichtfunktion C 24,not active ,20ENG263475-ENG116336-Leuchte 24 SL HR A65-Lichtfunktion D 24,not active ,20ENG263475-ENG116339-Leuchte 24 SL HR A65-Lichtfunktion E 24,not active ,20ENG263475-ENG116340-Leuchte 24 SL HR A65-Lichtfunktion F 24,not active ,20ENG263475-ENG116343-Leuchte 24 SL HR A65-Lichtfunktion G 24,not active ,20ENG263475-ENG116344-Leuchte 24 SL HR A65-Lichtfunktion H 24,not active ,20ENG263475-ENG260865-Leuchte 24 SL HR A65-Lichtfunktion I 24,not active ,20ENG263475-ENG260414-Leuchte 24 SL HR A65-Lichtfunktion J 24,not active ,20ENG263475-ENG260577-Leuchte 24 SL HR A65-Lichtfunktion K 24,not active ,20ENG263475-ENG260598-Leuchte 24 SL HR A65-Lichtfunktion L 24,not active ,20ENG263447-ENG260768-Leuchte 25 KZL H A59-Dimming Direction DEF 25,maximize ,20ENG263447-ENG259422-Leuchte 25 KZL H A59-Dimming Direction GHI 25,maximize ,20ENG263447-ENG258848-Leuchte 25 KZL H A59-Dimming Direction JKL 25,maximize ,20ENG263447-ENG258210-Leuchte 25 KZL H A59-Dimmwert ABC 25,127 ,20ENG263447-ENG260749-Leuchte 25 KZL H A59-Dimmwert DEF 25,0 ,20ENG263447-ENG258574-Leuchte 25 KZL H A59-Dimmwert GHI 25,0 ,20ENG263447-ENG259896-Leuchte 25 KZL H A59-Dimmwert JKL 25,0 ,20ENG263447-ENG116349-Leuchte 25 KZL H A59-Fehlerort mittleres Byte DTC-DFCC 25,48 ,20ENG263447-ENG116577-Leuchte 25 KZL H A59-Lampendefektbitposition 25,40 ,20ENG263447-ENG116347-Leuchte 25 KZL H A59-Lasttyp 25,allg_LED_mit_Open_Load_Diagnose_ohne_PWM ,20ENG263447-ENG259553-Leuchte 25 KZL H A59-Lichtansteuerung HD ABC 25,Always ,20ENG263447-ENG116350-Leuchte 25 KZL H A59-Lichtfunktion A 25,Position lamps ,20ENG263447-ENG116351-Leuchte 25 KZL H A59-Lichtfunktion B 25,not active ,20ENG263447-ENG116354-Leuchte 25 KZL H A59-Lichtfunktion C 25,not active ,20ENG263447-ENG116355-Leuchte 25 KZL H A59-Lichtfunktion D 25,not active ,20ENG263447-ENG116358-Leuchte 25 KZL H A59-Lichtfunktion E 25,not active ,20ENG263447-ENG259247-Leuchte 25 KZL H A59-Lichtfunktion F25,not active ,20ENG263447-ENG116362-Leuchte 25 KZL H A59-Lichtfunktion G 25,not active ,20ENG263447-ENG116363-Leuchte 25 KZL H A59-Lichtfunktion H 25,not active ,20ENG263447-ENG260931-Leuchte 25 KZL H A59-Lichtfunktion I 25,not active ,20ENG263447-ENG258654-Leuchte 25 KZL H A59-Lichtfunktion J 25,not active ,20ENG263447-ENG260798-Leuchte 25 KZL H A59-Lichtfunktion K 25,not active ,20ENG263447-ENG258935-Leuchte 25 KZL H A59-Lichtfunktion L 25,not active ,20{SFD2} ENG263489-ENG259412-Leuchte 26 NSL L A72-Dimming Direction DEF 26,maximize ,20{SFD2} ENG263489-ENG259883-Leuchte 26 NSL L A72-Dimming Direction GHI 26,maximize ,20{SFD2} ENG263489-ENG260584-Leuchte 26 NSL L A72-Dimming Direction JKL 26,maximize ,20{SFD2} ENG263489-ENG261357-Leuchte 26 NSL L A72-Dimmwert ABC 26,100 ,20{SFD2} ENG263489-ENG260958-Leuchte 26 NSL L A72-Dimmwert DEF 26,0 ,20{SFD2} ENG263489-ENG258546-Leuchte 26 NSL L A72-Dimmwert GHI 26,0 ,20{SFD2} ENG263489-ENG259662-Leuchte 26 NSL L A72-Dimmwert JKL 26,0 ,20{SFD2} ENG263489-ENG116368-Leuchte 26 NSL L A72-Fehlerort mittleres Byte DTC-DFCC 26,46 ,20{SFD2} ENG263489-ENG116578-Leuchte 26 NSL L A72-Lampendefektbitposition 26,12 ,20{SFD2} ENG263489-ENG116366-Leuchte 26 NSL L A72-Lasttyp 26,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20{SFD2} ENG263489-ENG260640-Leuchte 26 NSL L A72-Lichtansteuerung HD ABC 26,Always ,20{SFD2} ENG263489-ENG116369-Leuchte 26 NSL L A72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,20{SFD2} ENG263489-ENG116370-Leuchte 26 NSL L A72-Lichtfunktion B 26,not active ,20{SFD2} ENG263489-ENG116373-Leuchte 26 NSL L A72-Lichtfunktion C 26,not active ,20{SFD2} ENG263489-ENG116374-Leuchte 26 NSL L A72-Lichtfunktion D 26,not active ,20{SFD2} ENG263489-ENG116377-Leuchte 26 NSL L A72-Lichtfunktion E 26,not active ,20{SFD2} ENG263489-ENG116378-Leuchte 26 NSL L A72-Lichtfunktion F 26,not active ,20{SFD2} ENG263489-ENG116381-Leuchte 26 NSL L A72-Lichtfunktion G 26,not active ,20{SFD2} ENG263489-ENG116382-Leuchte 26 NSL L A72-Lichtfunktion H 26,not active ,20{SFD2} ENG263489-ENG258650-Leuchte 26 NSL L A72-Lichtfunktion I 26,not active ,20{SFD2} ENG263489-ENG258937-Leuchte 26 NSL L A72-Lichtfunktion J 26,not active ,20{SFD2} ENG263489-ENG259765-Leuchte 26 NSL L A72-Lichtfunktion K 26,not active ,20{SFD2} ENG263489-ENG260970-Leuchte 26 NSL L A72-Lichtfunktion L 26,not active ,20{SFD2} ENG263468-ENG259400-Leuchte 27 NSL R C6-Dimming Direction DEF 27,maximize ,20{SFD2} ENG263468-ENG260627-Leuchte 27 NSL R C6-Dimming Direction GHI 27,maximize ,20{SFD2} ENG263468-ENG260547-Leuchte 27 NSL R C6-Dimming Direction JKL 27,maximize ,20{SFD2} ENG263468-ENG259742-Leuchte 27 NSL R C6-Dimmwert ABC 27,0 ,20{SFD2} ENG263468-ENG258926-Leuchte 27 NSL R C6-Dimmwert DEF 27,0 ,20{SFD2} ENG263468-ENG259009-Leuchte 27 NSL R C6-Dimmwert GHI 27,0 ,20{SFD2} ENG263468-ENG260084-Leuchte 27 NSL R C6-Dimmwert JKL 27,0 ,20{SFD2} ENG263468-ENG116387-Leuchte 27 NSL R C6-Fehlerort mittleres Byte DTC-DFCC 27,0 ,20{SFD2} ENG263468-ENG116579-Leuchte 27 NSL R C6-Lampendefektbitposition 27,0 ,20{SFD2} ENG263468-ENG116385-Leuchte 27 NSL R C6-Lasttyp 27,not_active ,20{SFD2} ENG263468-ENG258715-Leuchte 27 NSL R C6-Lichtansteuerung HD ABC 27,Always ,20{SFD2} ENG263468-ENG116388-Leuchte 27 NSL R C6-Lichtfunktion A 27,not active ,20{SFD2} ENG263468-ENG116389-Leuchte 27 NSL R C6-Lichtfunktion B 27,not active ,20{SFD2} ENG263468-ENG116392-Leuchte 27 NSL R C6-Lichtfunktion C 27,not active ,20{SFD2} ENG263468-ENG116393-Leuchte 27 NSL R C6-Lichtfunktion D 27,not active ,20{SFD2} ENG263468-ENG116396-Leuchte 27 NSL R C6-Lichtfunktion E 27,not active ,20{SFD2} ENG263468-ENG116397-Leuchte 27 NSL R C6-Lichtfunktion F 27,not active ,20{SFD2} ENG263468-ENG116400-Leuchte 27 NSL R C6-Lichtfunktion G 27,not active ,20{SFD2} ENG263468-ENG116401-Leuchte 27 NSL R C6-Lichtfunktion H 27,not active ,20{SFD2} ENG263468-ENG258753-Leuchte 27 NSL R C6-Lichtfunktion I 27,not active ,20{SFD2} ENG263468-ENG258206-Leuchte 27 NSL R C6-Lichtfunktion J 27,not active ,20{SFD2} ENG263468-ENG260268-Leuchte 27 NSL R C6-Lichtfunktion K 27,not active ,20{SFD2} ENG263468-ENG259071-Leuchte 27 NSL R C6-Lichtfunktion L 27,not active ,20{SFD2} ENG263472-ENG258565-Leuchte 28 RFL L C11-Dimming Direction DEF 28,maximize ,20{SFD2} ENG263472-ENG258532-Leuchte 28 RFL L C11-Dimming Direction GHI 28,maximize ,20{SFD2} ENG263472-ENG259396-Leuchte 28 RFL L C11-Dimming Direction JKL 28,maximize ,20{SFD2} ENG263472-ENG259919-Leuchte 28 RFL L C11-Dimmwert ABC 28,100 ,20{SFD2} ENG263472-ENG258647-Leuchte 28 RFL L C11-Dimmwert DEF 28,0 ,20{SFD2} ENG263472-ENG261179-Leuchte 28 RFL L C11-Dimmwert GHI 28,0 ,20{SFD2} ENG263472-ENG260446-Leuchte 28 RFL L C11-Dimmwert JKL 28,0 ,20{SFD2} ENG263472-ENG116406-Leuchte 28 RFL L C11-Fehlerort mittleres Byte DTC-DFCC 28,49 ,20{SFD2} ENG263472-ENG116580-Leuchte 28 RFL L C11-Lampendefektbitposition 28,11 ,20{SFD2} ENG263472-ENG116404-Leuchte 28 RFL L C11-Lasttyp 28,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20{SFD2} ENG263472-ENG258804-Leuchte 28 RFL L C11-Lichtansteuerung HD ABC 28,Always ,20{SFD2} ENG263472-ENG116407-Leuchte 28 RFL L C11-Lichtfunktion A 28,Rueckfahrlicht ,20{SFD2} ENG263472-ENG116408-Leuchte 28 RFL L C11-Lichtfunktion B 28,not active ,20{SFD2} ENG263472-ENG116411-Leuchte 28 RFL L C11-Lichtfunktion C 28,not active ,20{SFD2} ENG263472-ENG116412-Leuchte 28 RFL L C11-Lichtfunktion D 28,not active ,20{SFD2} ENG263472-ENG116415-Leuchte 28 RFL L C11-Lichtfunktion E 28,not active ,20{SFD2} ENG263472-ENG116416-Leuchte 28 RFL L C11-Lichtfunktion F 28,not active ,20{SFD2} ENG263472-ENG116419-Leuchte 28 RFL L C11-Lichtfunktion G 28,not active ,20{SFD2} ENG263472-ENG116420-Leuchte 28 RFL L C11-Lichtfunktion H 28,not active ,20{SFD2} ENG263472-ENG260485-Leuchte 28 RFL L C11-Lichtfunktion I 28,not active ,20{SFD2} ENG263472-ENG260652-Leuchte 28 RFL L C11-Lichtfunktion J 28,not active ,20{SFD2} ENG263472-ENG258363-Leuchte 28 RFL L C11-Lichtfunktion K 28,not active ,20{SFD2} ENG263472-ENG260174-Leuchte 28 RFL L C11-Lichtfunktion L 28,not active ,20{SFD2} ENG263492-ENG261198-Leuchte 29 RFL R A64-Dimming Direction DEF 29,maximize ,20{SFD2} ENG263492-ENG259250-Leuchte 29 RFL R A64-Dimming Direction GHI 29,maximize ,20{SFD2} ENG263492-ENG260299-Leuchte 29 RFL R A64-Dimming Direction JKL 29,maximize ,20{SFD2} ENG263492-ENG259879-Leuchte 29 RFL R A64-Dimmwert ABC 29,100 ,20{SFD2} ENG263492-ENG260443-Leuchte 29 RFL R A64-Dimmwert DEF 29,0 ,20{SFD2} ENG263492-ENG260415-Leuchte 29 RFL R A64-Dimmwert GHI 29,0 ,20{SFD2} ENG263492-ENG260684-Leuchte 29 RFL R A64-Dimmwert JKL 29,0 ,20{SFD2} ENG263492-ENG116425-Leuchte 29 RFL R A64-Fehlerort mittleres Byte DTC-DFCC 29,50 ,20{SFD2} ENG263492-ENG116581-Leuchte 29 RFL R A64-Lampendefektbitposition 29,27 ,20{SFD2} ENG263492-ENG116423-Leuchte 29 RFL R A64-Lasttyp 29,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20{SFD2} ENG263492-ENG260077-Leuchte 29 RFL R A64-Lichtansteuerung HD ABC 29,Always ,20{SFD2} ENG263492-ENG116426-Leuchte 29 RFL R A64-Lichtfunktion A 29,Rueckfahrlicht ,20{SFD2} ENG263492-ENG116427-Leuchte 29 RFL R A64-Lichtfunktion B 29,not active ,20{SFD2} ENG263492-ENG116429-Leuchte 29 RFL R A64-Lichtfunktion C 29,not active ,20{SFD2} ENG263492-ENG116431-Leuchte 29 RFL R A64-Lichtfunktion D 29,not active ,20{SFD2} ENG263492-ENG116434-Leuchte 29 RFL R A64-Lichtfunktion E 29,not active ,20{SFD2} ENG263492-ENG116435-Leuchte 29 RFL R A64-Lichtfunktion F 29,not active ,20{SFD2} ENG263492-ENG116438-Leuchte 29 RFL R A64-Lichtfunktion G 29,not active ,20{SFD2} ENG263492-ENG116439-Leuchte 29 RFL R A64-Lichtfunktion H 29,not active ,20{SFD2} ENG263492-ENG260646-Leuchte 29 RFL R A64-Lichtfunktion I 29,not active ,20{SFD2} ENG263492-ENG259712-Leuchte 29 RFL R A64-Lichtfunktion J 29,not active ,20{SFD2} ENG263492-ENG259236-Leuchte 29 RFL R A64-Lichtfunktion K 29,not active ,20{SFD2} ENG263492-ENG259606-Leuchte 29 RFL R A64-Lichtfunktion L 29,not active ,20ENG263454-ENG260476-Leuchte 3 SL VR B32-Dimming Direction DEF 3,maximize ,20ENG263454-ENG259703-Leuchte 3 SL VR B32-Dimming Direction GHI 3,maximize ,20ENG263454-ENG259508-Leuchte 3 SL VR B32-Dimming Direction JKL 3,maximize ,20ENG263454-ENG258539-Leuchte 3 SL VR B32-Dimmwert ABC 3,0 ,20ENG263454-ENG259082-Leuchte 3 SL VR B32-Dimmwert DEF 3,0 ,20ENG263454-ENG260713-Leuchte 3 SL VR B32-Dimmwert GHI 3,0 ,20ENG263454-ENG261150-Leuchte 3 SL VR B32-Dimmwert JKL 3,0 ,20ENG263454-ENG115931-Leuchte 3 SL VR B32-Fehlerort mittleres Byte DTC-DFCC 3,0 ,20ENG263454-ENG116551-Leuchte 3 SL VR B32-Lampendefektbitposition 3,0 ,20ENG263454-ENG115929-Leuchte 3 SL VR B32-Lasttyp 3,not_active ,20ENG263454-ENG260316-Leuchte 3 SL VR B32-Lichtansteuerung HD ABC 3,Always ,20ENG263454-ENG115932-Leuchte 3 SL VR B32-Lichtfunktion A 3,not active ,20ENG263454-ENG115933-Leuchte 3 SL VR B32-Lichtfunktion B 3,not active ,20ENG263454-ENG115936-Leuchte 3 SL VR B32-Lichtfunktion C 3,not active ,20ENG263454-ENG115937-Leuchte 3 SL VR B32-Lichtfunktion D 3,not active ,20ENG263454-ENG115940-Leuchte 3 SL VR B32-Lichtfunktion E 3,not active ,20ENG263454-ENG116552-Leuchte 3 SL VR B32-Lichtfunktion F 3,not active ,20ENG263454-ENG115944-Leuchte 3 SL VR B32-Lichtfunktion G 3,not active ,20ENG263454-ENG115945-Leuchte 3 SL VR B32-Lichtfunktion H 3,not active ,20ENG263454-ENG260399-Leuchte 3 SL VR B32-Lichtfunktion I 3,not active ,20ENG263454-ENG260155-Leuchte 3 SL VR B32-Lichtfunktion J 3,not active ,20ENG263454-ENG260622-Leuchte 3 SL VR B32-Lichtfunktion K 3,not active ,20ENG263454-ENG258091-Leuchte 3 SL VR B32-Lichtfunktion L 3,not active ,20{SFD2} ENG263428-ENG260857-Leuchte 30 FR L C72-Dimming Direction DEF 30,maximize ,20{SFD2} ENG263428-ENG258841-Leuchte 30 FR L C72-Dimming Direction GHI 30,maximize ,20{SFD2} ENG263428-ENG259433-Leuchte 30 FR L C72-Dimming Direction JKL 30,maximize ,20{SFD2} ENG263428-ENG259620-Leuchte 30 FR L C72-Dimmwert ABC 30,0 ,20{SFD2} ENG263428-ENG260960-Leuchte 30 FR L C72-Dimmwert DEF 30,0 ,20{SFD2} ENG263428-ENG260191-Leuchte 30 FR L C72-Dimmwert GHI 30,0 ,20{SFD2} ENG263428-ENG259143-Leuchte 30 FR L C72-Dimmwert JKL 30,0 ,20{SFD2} ENG263428-ENG116444-Leuchte 30 FR L C72-Fehlerort mittleres Byte DTC-DFCC 30,0 ,20{SFD2} ENG263428-ENG116582-Leuchte 30 FR L C72-Lampendefektbitposition 30,0 ,20{SFD2} ENG263428-ENG116442-Leuchte 30 FR L C72-Lasttyp 30,not_active ,20{SFD2} ENG263428-ENG261067-Leuchte 30 FR L C72-Lichtansteuerung HD ABC 30,Always ,20{SFD2} ENG263428-ENG116445-Leuchte 30 FR L C72-Lichtfunktion A 30,not active ,20{SFD2} ENG263428-ENG116446-Leuchte 30 FR L C72-Lichtfunktion B 30,not active ,20{SFD2} ENG263428-ENG116449-Leuchte 30 FR L C72-Lichtfunktion C 30,not active ,20{SFD2} ENG263428-ENG116450-Leuchte 30 FR L C72-Lichtfunktion D 30,not active ,20{SFD2} ENG263428-ENG116453-Leuchte 30 FR L C72-Lichtfunktion E 30,not active ,20{SFD2} ENG263428-ENG116454-Leuchte 30 FR L C72-Lichtfunktion F 30,not active ,20{SFD2} ENG263428-ENG116457-Leuchte 30 FR L C72-Lichtfunktion G 30,not active ,20{SFD2} ENG263428-ENG116458-Leuchte 30 FR L C72-Lichtfunktion H 30,not active ,20{SFD2} ENG263428-ENG260108-Leuchte 30 FR L C72-Lichtfunktion I 30,not active ,20{SFD2} ENG263428-ENG260034-Leuchte 30 FR L C72-Lichtfunktion J 30,not active ,20{SFD2} ENG263428-ENG259668-Leuchte 30 FR L C72-Lichtfunktion K 30,not active ,20{SFD2} ENG263428-ENG258691-Leuchte 30 FR L C72-Lichtfunktion L 30,not active ,20{SFD2} ENG263445-ENG260925-Leuchte 31 AMBL 1 C61-Dimming Direction DEF 31,maximize ,20{SFD2} ENG263445-ENG259991-Leuchte 31 AMBL 1 C61-Dimming Direction GHI 31,maximize ,20{SFD2} ENG263445-ENG259114-Leuchte 31 AMBL 1 C61-Dimming Direction JKL 31,maximize ,20{SFD2} ENG263445-ENG261277-Leuchte 31 AMBL 1 C61-Dimmwert ABC 31,0 ,20{SFD2} ENG263445-ENG259981-Leuchte 31 AMBL 1 C61-Dimmwert DEF 31,0 ,20{SFD2} ENG263445-ENG260837-Leuchte 31 AMBL 1 C61-Dimmwert GHI 31,0 ,20{SFD2} ENG263445-ENG258112-Leuchte 31 AMBL 1 C61-Dimmwert JKL 31,0 ,20{SFD2} ENG263445-ENG116463-Leuchte 31 AMBL 1 C61-Fehlerort mittleres Byte DTC-DFCC 31,0 ,20{SFD2} ENG263445-ENG116583-Leuchte 31 AMBL 1 C61-Lampendefektbitposition 31,0 ,20{SFD2} ENG263445-ENG116461-Leuchte 31 AMBL 1 C61-Lasttyp 31,not_active ,20{SFD2} ENG263445-ENG260205-Leuchte 31 AMBL 1 C61-Lichtansteuerung HD ABC 31,Always ,20{SFD2} ENG263445-ENG116464-Leuchte 31 AMBL 1 C61-Lichtfunktion A 31,not active ,20{SFD2} ENG263445-ENG116465-Leuchte 31 AMBL 1 C61-Lichtfunktion B 31,not active ,20{SFD2} ENG263445-ENG116468-Leuchte 31 AMBL 1 C61-Lichtfunktion C 31,not active ,20{SFD2} ENG263445-ENG116469-Leuchte 31 AMBL 1 C61-Lichtfunktion D 31,not active ,20{SFD2} ENG263445-ENG116472-Leuchte 31 AMBL 1 C61-Lichtfunktion E 31,not active ,20{SFD2} ENG263445-ENG116473-Leuchte 31 AMBL 1 C61-Lichtfunktion F 31,not active ,20{SFD2} ENG263445-ENG116476-Leuchte 31 AMBL 1 C61-Lichtfunktion G 31,not active ,20{SFD2} ENG263445-ENG116477-Leuchte 31 AMBL 1 C61-Lichtfunktion H 31,not active ,20{SFD2} ENG263445-ENG260861-Leuchte 31 AMBL 1 C61-Lichtfunktion I 31,not active ,20{SFD2} ENG263445-ENG260553-Leuchte 31 AMBL 1 C61-Lichtfunktion J 31,not active ,20{SFD2} ENG263445-ENG259999-Leuchte 31 AMBL 1 C61-Lichtfunktion K 31,not active ,20{SFD2} ENG263445-ENG260353-Leuchte 31 AMBL 1 C61-Lichtfunktion L 31,not active ,20{SFD2} ENG263449-ENG259710-Leuchte 32 AMBL 2 C35-Dimming Direction DEF 32,maximize ,20{SFD2} ENG263449-ENG258905-Leuchte 32 AMBL 2 C35-Dimming Direction GHI 32,maximize ,20{SFD2} ENG263449-ENG260532-Leuchte 32 AMBL 2 C35-Dimming Direction JKL 32,maximize ,20{SFD2} ENG263449-ENG259737-Leuchte 32 AMBL 2 C35-Dimmwert ABC 32,0 ,20{SFD2} ENG263449-ENG259346-Leuchte 32 AMBL 2 C35-Dimmwert DEF 32,0 ,20{SFD2} ENG263449-ENG260258-Leuchte 32 AMBL 2 C35-Dimmwert GHI 32,0 ,20{SFD2} ENG263449-ENG260382-Leuchte 32 AMBL 2 C35-Dimmwert JKL 32,0 ,20{SFD2} ENG263449-ENG116482-Leuchte 32 AMBL 2 C35-Fehlerort mittleres Byte DTC-DFCC 32,0 ,20{SFD2} ENG263449-ENG116584-Leuchte 32 AMBL 2 C35-Lampendefektbitposition 32,0 ,20{SFD2} ENG263449-ENG116480-Leuchte 32 AMBL 2 C35-Lasttyp 32,not_active ,20{SFD2} ENG263449-ENG259035-Leuchte 32 AMBL 2 C35-Lichtansteuerung HD ABC 32,Always ,20{SFD2} ENG263449-ENG116483-Leuchte 32 AMBL 2 C35-Lichtfunktion A 32,not active ,20{SFD2} ENG263449-ENG116484-Leuchte 32 AMBL 2 C35-Lichtfunktion B 32,not active ,20{SFD2} ENG263449-ENG116487-Leuchte 32 AMBL 2 C35-Lichtfunktion C 32,not active ,20{SFD2} ENG263449-ENG116488-Leuchte 32 AMBL 2 C35-Lichtfunktion D 32,not active ,20{SFD2} ENG263449-ENG116491-Leuchte 32 AMBL 2 C35-Lichtfunktion E 32,not active ,20{SFD2} ENG263449-ENG116492-Leuchte 32 AMBL 2 C35-Lichtfunktion F 32,not active ,20{SFD2} ENG263449-ENG116495-Leuchte 32 AMBL 2 C35-Lichtfunktion G 32,not active ,20{SFD2} ENG263449-ENG116496-Leuchte 32 AMBL 2 C35-Lichtfunktion H 32,not active ,20{SFD2} ENG263449-ENG258763-Leuchte 32 AMBL 2 C35-Lichtfunktion I 32,not active ,20{SFD2} ENG263449-ENG259842-Leuchte 32 AMBL 2 C35-Lichtfunktion J 32,not active ,20{SFD2} ENG263449-ENG258857-Leuchte 32 AMBL 2 C35-Lichtfunktion K 32,not active ,20{SFD2} ENG263449-ENG260175-Leuchte 32 AMBL 2 C35-Lichtfunktion L 32,not active ,20{SFD2} ENG263439-ENG258755-Leuchte 33 AMBL 3 C36-Dimming Direction DEF 33,maximize ,20{SFD2} ENG263439-ENG258237-Leuchte 33 AMBL 3 C36-Dimming Direction GHI 33,maximize ,20{SFD2} ENG263439-ENG259038-Leuchte 33 AMBL 3 C36-Dimming Direction JKL 33,maximize ,20{SFD2} ENG263439-ENG259476-Leuchte 33 AMBL 3 C36-Dimmwert ABC 33,0 ,20{SFD2} ENG263439-ENG260461-Leuchte 33 AMBL 3 C36-Dimmwert DEF 33,0 ,20{SFD2} ENG263439-ENG261181-Leuchte 33 AMBL 3 C36-Dimmwert GHI 33,0 ,20{SFD2} ENG263439-ENG258425-Leuchte 33 AMBL 3 C36-Dimmwert JKL 33,0 ,20{SFD2} ENG263439-ENG116501-Leuchte 33 AMBL 3 C36-Fehlerort mittleres Byte DTC-DFCC 33,0 ,20{SFD2} ENG263439-ENG116585-Leuchte 33 AMBL 3 C36-Lampendefektbitposition 33,0 ,20{SFD2} ENG263439-ENG116499-Leuchte 33 AMBL 3 C36-Lasttyp 33,not_active ,20{SFD2} ENG263439-ENG259471-Leuchte 33 AMBL 3 C36-Lichtansteuerung HD ABC 33,Always ,20{SFD2} ENG263439-ENG116502-Leuchte 33 AMBL 3 C36-Lichtfunktion A 33,not active ,20{SFD2} ENG263439-ENG116503-Leuchte 33 AMBL 3 C36-Lichtfunktion B 33,not active ,20{SFD2} ENG263439-ENG116506-Leuchte 33 AMBL 3 C36-Lichtfunktion C 33,not active ,20{SFD2} ENG263439-ENG116507-Leuchte 33 AMBL 3 C36-Lichtfunktion D 33,not active ,20{SFD2} ENG263439-ENG116510-Leuchte 33 AMBL 3 C36-Lichtfunktion E 33,not active ,20{SFD2} ENG263439-ENG116511-Leuchte 33 AMBL 3 C36-Lichtfunktion F 33,not active ,20{SFD2} ENG263439-ENG116514-Leuchte 33 AMBL 3 C36-Lichtfunktion G 33,not active ,20{SFD2} ENG263439-ENG116515-Leuchte 33 AMBL 3 C36-Lichtfunktion H 33,not active ,20{SFD2} ENG263439-ENG260403-Leuchte 33 AMBL 3 C36-Lichtfunktion I 33,not active ,20{SFD2} ENG263439-ENG261239-Leuchte 33 AMBL 3 C36-Lichtfunktion J 33,not active ,20{SFD2} ENG263439-ENG260953-Leuchte 33 AMBL 3 C36-Lichtfunktion K 33,not active ,20{SFD2} ENG263439-ENG261234-Leuchte 33 AMBL 3 C36-Lichtfunktion L 33,not active ,20{SFD2} ENG263434-ENG259648-Leuchte 34 AMBL 4 C37-Dimming Direction DEF 34,maximize ,20{SFD2} ENG263434-ENG259188-Leuchte 34 AMBL 4 C37-Dimming Direction GHI 34,maximize ,20{SFD2} ENG263434-ENG260464-Leuchte 34 AMBL 4 C37-Dimming Direction JKL 34,maximize ,20{SFD2} ENG263434-ENG259524-Leuchte 34 AMBL 4 C37-Dimmwert ABC 34,0 ,20{SFD2} ENG263434-ENG260705-Leuchte 34 AMBL 4 C37-Dimmwert DEF 34,0 ,20{SFD2} ENG263434-ENG258677-Leuchte 34 AMBL 4 C37-Dimmwert GHI 34,0 ,20{SFD2} ENG263434-ENG259924-Leuchte 34 AMBL 4 C37-Dimmwert JKL 34,0 ,20{SFD2} ENG263434-ENG116520-Leuchte 34 AMBL 4 C37-Fehlerort mittleres Byte DTC-DFCC 34,0 ,20{SFD2} ENG263434-ENG116586-Leuchte 34 AMBL 4 C37-Lampendefektbitposition 34,0 ,20{SFD2} ENG263434-ENG116518-Leuchte 34 AMBL 4 C37-Lasttyp 34,not_active ,20{SFD2} ENG263434-ENG259804-Leuchte 34 AMBL 4 C37-Lichtansteuerung HD ABC 34,Always ,20{SFD2} ENG263434-ENG116521-Leuchte 34 AMBL 4 C37-Lichtfunktion A 34,not active ,20{SFD2} ENG263434-ENG116522-Leuchte 34 AMBL 4 C37-Lichtfunktion B 34,not active ,20{SFD2} ENG263434-ENG116525-Leuchte 34 AMBL 4 C37-Lichtfunktion C 34,not active ,20{SFD2} ENG263434-ENG116526-Leuchte 34 AMBL 4 C37-Lichtfunktion D 34,not active ,20{SFD2} ENG263434-ENG116529-Leuchte 34 AMBL 4 C37-Lichtfunktion E 34,not active ,20{SFD2} ENG263434-ENG116530-Leuchte 34 AMBL 4 C37-Lichtfunktion F 34,not active ,20{SFD2} ENG263434-ENG116533-Leuchte 34 AMBL 4 C37-Lichtfunktion G 34,not active ,20{SFD2} ENG263434-ENG116534-Leuchte 34 AMBL 4 C37-Lichtfunktion H 34,not active ,20{SFD2} ENG263434-ENG259061-Leuchte 34 AMBL 4 C37-Lichtfunktion I 34,not active ,20{SFD2} ENG263434-ENG258125-Leuchte 34 AMBL 4 C37-Lichtfunktion J 34,not active ,20{SFD2} ENG263434-ENG259670-Leuchte 34 AMBL 4 C37-Lichtfunktion K 34,not active ,20{SFD2} ENG263434-ENG260771-Leuchte 34 AMBL 4 C37-Lichtfunktion L 34,not active ,20ENG141657-ENG258314-Leuchte 35 LED Warnblinktaster C48-Dimming Direction DEF 35,maximize ,20ENG141657-ENG260208-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GHI 35,maximize ,20ENG141657-ENG260869-Leuchte 35 LED Warnblinktaster C48-Dimming Direction JKL 35,maximize ,20ENG141657-ENG259780-Leuchte 35 LED Warnblinktaster C48-Dimmwert ABC 35,100 ,20ENG141657-ENG258175-Leuchte 35 LED Warnblinktaster C48-Dimmwert DEF 35,100 ,20ENG141657-ENG259257-Leuchte 35 LED Warnblinktaster C48-Dimmwert GHI 35,0 ,20ENG141657-ENG260977-Leuchte 35 LED Warnblinktaster C48-Dimmwert JKL 35,0 ,20ENG141657-ENG258758-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 35,0 ,20ENG141657-ENG258551-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 35,0 ,20ENG141657-ENG259566-Leuchte 35 LED Warnblinktaster C48-Lasttyp 35,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20ENG141657-ENG260595-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD ABC 35,Always ,20ENG141657-ENG260217-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 35,Warnblink Taster Suchbeleuchtung ,20ENG141657-ENG259017-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 35,not active ,20ENG141657-ENG259618-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 35,not active ,20ENG141657-ENG259584-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 35,not active ,20ENG141657-ENG259128-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 35,not active ,20ENG141657-ENG258995-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 35,not active ,20ENG141657-ENG258137-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 35,not active ,20ENG141657-ENG259014-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 35,not active ,20ENG141657-ENG258258-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion I 35,not active ,20ENG141657-ENG260608-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion J 35,not active ,20ENG141657-ENG260082-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion K 35,not active ,20ENG141657-ENG261046-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion L 35,not active ,20{SFD2} ENG253037-ENG259399-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction DEF 36,maximize ,20{SFD2} ENG253037-ENG260703-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction GHI 36,maximize ,20{SFD2} ENG253037-ENG260112-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction JKL 36,maximize ,20{SFD2} ENG253037-ENG258344-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert ABC 36,0 ,20{SFD2} ENG253037-ENG258426-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert DEF 36,0 ,20{SFD2} ENG253037-ENG260039-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert GHI 36,0 ,20{SFD2} ENG253037-ENG259503-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert JKL 36,0 ,20{SFD2} ENG253037-ENG260858-Leuchte 36 LEDNL_PWM_L_B37-Fehlerort mittleres Byte DTC-DFCC 36,0 ,20{SFD2} ENG253037-ENG258523-Leuchte 36 LEDNL_PWM_L_B37-Lampendefektbitposition 36,0 ,20{SFD2} ENG253037-ENG261341-Leuchte 36 LEDNL_PWM_L_B37-Lasttyp 36,not_active ,20{SFD2} ENG253037-ENG259878-Leuchte 36 LEDNL_PWM_L_B37-Lichtansteuerung HD ABC 36,Always ,20{SFD2} ENG253037-ENG258899-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion A 36,not active ,20{SFD2} ENG253037-ENG260362-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion B 36,not active ,20{SFD2} ENG253037-ENG258356-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion C 36,not active ,20{SFD2} ENG253037-ENG258388-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion D 36,not active ,20{SFD2} ENG253037-ENG258248-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion E 36,not active ,20{SFD2} ENG253037-ENG260017-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion F 36,not active ,20{SFD2} ENG253037-ENG260071-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion G 36,not active ,20{SFD2} ENG253037-ENG259734-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion H 36,not active ,20{SFD2} ENG253037-ENG260720-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion I 36,not active ,20{SFD2} ENG253037-ENG259525-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion J 36,not active ,20{SFD2} ENG253037-ENG259972-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion K 36,not active ,20{SFD2} ENG253037-ENG259404-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion L 36,not active ,20{SFD2} ENG253226-ENG260671-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction DEF 37,maximize ,20{SFD2} ENG253226-ENG258552-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction GHI 37,maximize ,20{SFD2} ENG253226-ENG260966-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction JKL 37,maximize ,20{SFD2} ENG253226-ENG260262-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert ABC 37,0 ,20{SFD2} ENG253226-ENG258498-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert DEF 37,0 ,20{SFD2} ENG253226-ENG258952-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert GHI 37,0 ,20{SFD2} ENG253226-ENG260588-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert JKL 37,0 ,20{SFD2} ENG253226-ENG258708-Leuchte 37 LEDNL_PWM_R_B38-Fehlerort mittleres Byte DTC-DFCC 37,0 ,20{SFD2} ENG253226-ENG260786-Leuchte 37 LEDNL_PWM_R_B38-Lampendefektbitposition 37,0 ,20{SFD2} ENG253226-ENG259218-Leuchte 37 LEDNL_PWM_R_B38-Lasttyp 37,not_active ,20{SFD2} ENG253226-ENG260323-Leuchte 37 LEDNL_PWM_R_B38-Lichtansteuerung HD ABC 37,Always ,20{SFD2} ENG253226-ENG259995-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion A 37,not active ,20{SFD2} ENG253226-ENG259686-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion B 37,not active ,20{SFD2} ENG253226-ENG259495-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion C 37,not active ,20{SFD2} ENG253226-ENG258914-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion D 37,not active ,20{SFD2} ENG253226-ENG258741-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion E 37,not active ,20{SFD2} ENG253226-ENG261001-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion F 37,not active ,20{SFD2} ENG253226-ENG259796-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion G 37,not active ,20{SFD2} ENG253226-ENG258391-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion H 37,not active ,20{SFD2} ENG253226-ENG260757-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion I 37,not active ,20{SFD2} ENG253226-ENG261282-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion J 37,not active ,20{SFD2} ENG253226-ENG258097-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion K 37,not active ,20{SFD2} ENG253226-ENG261120-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion L 37,not active ,20{SFD2} ENG253185-ENG260594-Leuchte 38 Sidemarker_V_B21-Dimming Direction DEF 38,maximize ,20{SFD2} ENG253185-ENG259176-Leuchte 38 Sidemarker_V_B21-Dimming Direction GHI 38,maximize ,20{SFD2} ENG253185-ENG258361-Leuchte 38 Sidemarker_V_B21-Dimming Direction JKL 38,maximize ,20{SFD2} ENG253185-ENG258271-Leuchte 38 Sidemarker_V_B21-Dimmwert ABC 38,0 ,20{SFD2} ENG253185-ENG258593-Leuchte 38 Sidemarker_V_B21-Dimmwert DEF 38,0 ,20{SFD2} ENG253185-ENG259740-Leuchte 38 Sidemarker_V_B21-Dimmwert GHI 38,0 ,20{SFD2} ENG253185-ENG260375-Leuchte 38 Sidemarker_V_B21-Dimmwert JKL 38,0 ,20{SFD2} ENG253185-ENG259110-Leuchte 38 Sidemarker_V_B21-Fehlerort mittleres Byte DTC-DFCC 38,0 ,20{SFD2} ENG253185-ENG259339-Leuchte 38 Sidemarker_V_B21-Lampendefektbitposition 38,0 ,20{SFD2} ENG253185-ENG258774-Leuchte 38 Sidemarker_V_B21-Lasttyp 38,not_active ,20{SFD2} ENG253185-ENG259319-Leuchte 38 Sidemarker_V_B21-Lichtansteuerung HD ABC 38,Always ,20{SFD2} ENG253185-ENG258971-Leuchte 38 Sidemarker_V_B21-Lichtfunktion A 38,not active ,20{SFD2} ENG253185-ENG260328-Leuchte 38 Sidemarker_V_B21-Lichtfunktion B 38,not active ,20{SFD2} ENG253185-ENG258602-Leuchte 38 Sidemarker_V_B21-Lichtfunktion C 38,not active ,20{SFD2} ENG253185-ENG260130-Leuchte 38 Sidemarker_V_B21-Lichtfunktion D 38,not active ,20{SFD2} ENG253185-ENG260126-Leuchte 38 Sidemarker_V_B21-Lichtfunktion E 38,not active ,20{SFD2} ENG253185-ENG260093-Leuchte 38 Sidemarker_V_B21-Lichtfunktion F 38,not active ,20{SFD2} ENG253185-ENG258515-Leuchte 38 Sidemarker_V_B21-Lichtfunktion G 38,not active ,20{SFD2} ENG253185-ENG259657-Leuchte 38 Sidemarker_V_B21-Lichtfunktion H 38,not active ,20{SFD2} ENG253185-ENG259428-Leuchte 38 Sidemarker_V_B21-Lichtfunktion I 38,not active ,20{SFD2} ENG253185-ENG258516-Leuchte 38 Sidemarker_V_B21-Lichtfunktion J 38,not active ,20{SFD2} ENG253185-ENG260994-Leuchte 38 Sidemarker_V_B21-Lichtfunktion K 38,not active ,20{SFD2} ENG253185-ENG259179-Leuchte 38 Sidemarker_V_B21-Lichtfunktion L 38,not active ,20{SFD2} ENG253171-ENG259501-Leuchte 39 Sidemarker_H C26-Dimming Direction DEF 39,maximize ,20{SFD2} ENG253171-ENG260533-Leuchte 39 Sidemarker_H C26-Dimming Direction GHI 39,maximize ,20{SFD2} ENG253171-ENG259331-Leuchte 39 Sidemarker_H C26-Dimming Direction JKL 39,maximize ,20{SFD2} ENG253171-ENG259663-Leuchte 39 Sidemarker_H C26-Dimmwert ABC 39,0 ,20{SFD2} ENG253171-ENG260625-Leuchte 39 Sidemarker_H C26-Dimmwert DEF 39,0 ,20{SFD2} ENG253171-ENG258607-Leuchte 39 Sidemarker_H C26-Dimmwert GHI 39,0 ,20{SFD2} ENG253171-ENG259031-Leuchte 39 Sidemarker_H C26-Dimmwert JKL 39,0 ,20{SFD2} ENG253171-ENG260272-Leuchte 39 Sidemarker_H C26-Fehlerort mittleres Byte DTC-DFCC 39,0 ,20{SFD2} ENG253171-ENG261342-Leuchte 39 Sidemarker_H C26-Lampendefektbitposition 39,0 ,20{SFD2} ENG253171-ENG258910-Leuchte 39 Sidemarker_H C26-Lasttyp 39,not_active ,20{SFD2} ENG253171-ENG261145-Leuchte 39 Sidemarker_H C26-Lichtansteuerung HD ABC 39,Always ,20{SFD2} ENG253171-ENG259436-Leuchte 39 Sidemarker_H C26-Lichtfunktion A 39,not active ,20{SFD2} ENG253171-ENG260471-Leuchte 39 Sidemarker_H C26-Lichtfunktion B 39,not active ,20{SFD2} ENG253171-ENG260554-Leuchte 39 Sidemarker_H C26-Lichtfunktion C 39,not active ,20{SFD2} ENG253171-ENG258988-Leuchte 39 Sidemarker_H C26-Lichtfunktion D 39,not active ,20{SFD2} ENG253171-ENG259727-Leuchte 39 Sidemarker_H C26-Lichtfunktion E 39,not active ,20{SFD2} ENG253171-ENG258355-Leuchte 39 Sidemarker_H C26-Lichtfunktion F 39,not active ,20{SFD2} ENG253171-ENG261095-Leuchte 39 Sidemarker_H C26-Lichtfunktion G 39,not active ,20{SFD2} ENG253171-ENG258577-Leuchte 39 Sidemarker_H C26-Lichtfunktion H 39,not active ,20{SFD2} ENG253171-ENG259902-Leuchte 39 Sidemarker_H C26-Lichtfunktion I 39,not active ,20{SFD2} ENG253171-ENG260202-Leuchte 39 Sidemarker_H C26-Lichtfunktion J 39,not active ,20{SFD2} ENG253171-ENG260436-Leuchte 39 Sidemarker_H C26-Lichtfunktion K 39,not active ,20{SFD2} ENG253171-ENG259237-Leuchte 39 Sidemarker_H C26-Lichtfunktion L 39,not active ,20ENG263459-ENG258414-Leuchte 4 TFL L B3-Dimming Direction DEF 4,maximize ,20ENG263459-ENG260894-Leuchte 4 TFL L B3-Dimming Direction GHI 4,maximize ,20ENG263459-ENG259900-Leuchte 4 TFL L B3-Dimming Direction JKL 4,maximize ,20ENG263459-ENG259665-Leuchte 4 TFL L B3-Dimmwert ABC 4,100 ,20ENG263459-ENG260507-Leuchte 4 TFL L B3-Dimmwert DEF 4,33 ,20ENG263459-ENG258447-Leuchte 4 TFL L B3-Dimmwert GHI 4,0 ,20ENG263459-ENG258461-Leuchte 4 TFL L B3-Dimmwert JKL 4,0 ,20ENG263459-ENG115950-Leuchte 4 TFL L B3-Fehlerort mittleres Byte DTC-DFCC 4,32 ,20ENG263459-ENG116553-Leuchte 4 TFL L B3-Lampendefektbitposition 4,58 ,20ENG263459-ENG115948-Leuchte 4 TFL L B3-Lasttyp 4,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20ENG263459-ENG259234-Leuchte 4 TFL L B3-Lichtansteuerung HD ABC 4,Always ,20ENG263459-ENG115951-Leuchte 4 TFL L B3-Lichtfunktion A 4,Daytime running lights ,20ENG263459-ENG115952-Leuchte 4 TFL L B3-Lichtfunktion B 4,not active ,20ENG263459-ENG115955-Leuchte 4 TFL L B3-Lichtfunktion C 4,not active ,20ENG263459-ENG115956-Leuchte 4 TFL L B3-Lichtfunktion D 4,Standlicht vorn ,20ENG263459-ENG115959-Leuchte 4 TFL L B3-Lichtfunktion E 4,Parking light left ,20ENG263459-ENG115960-Leuchte 4 TFL L B3-Lichtfunktion F 4,not active ,20ENG263459-ENG115963-Leuchte 4 TFL L B3-Lichtfunktion G 4,not active ,20ENG263459-ENG115964-Leuchte 4 TFL L B3-Lichtfunktion H 4,not active ,20ENG263459-ENG258442-Leuchte 4 TFL L B3-Lichtfunktion I 4,not active ,20ENG263459-ENG258629-Leuchte 4 TFL L B3-Lichtfunktion J 4,not active ,20ENG263459-ENG259468-Leuchte 4 TFL L B3-Lichtfunktion K 4,not active ,20ENG263459-ENG258421-Leuchte 4 TFL L B3-Lichtfunktion L 4,not active ,20{SFD2} ENG263465-ENG260616-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction DEF 40,maximize ,20{SFD2} ENG263465-ENG259877-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction GHI v,maximize ,20{SFD2} ENG263465-ENG258734-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction JKL 40,maximize ,20{SFD2} ENG263465-ENG258702-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert ABC 40,0 ,20{SFD2} ENG263465-ENG259888-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert DEF 40,0 ,20{SFD2} ENG263465-ENG258927-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert GHI 40,0 ,20{SFD2} ENG263465-ENG258852-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert JKL 40,0 ,20{SFD2} ENG263465-ENG260246-Leuchte 40 Zusatz_hecklicht_HL C9-Fehlerort mittleres Byte DTC-DFCC 40,0 ,20{SFD2} ENG263465-ENG259652-Leuchte 40 Zusatz_hecklicht_HL C9-Lampendefektbitposition 40,0 ,20{SFD2} ENG263465-ENG260978-Leuchte 40 Zusatz_hecklicht_HL C9-Lasttyp 40,not_active ,20{SFD2} ENG263465-ENG259185-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtansteuerung HD ABC 40,Always ,20{SFD2} ENG263465-ENG259008-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion A 40,not active ,20{SFD2} ENG263465-ENG258714-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion B 40,not active ,20{SFD2} ENG263465-ENG258586-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion C 40,not active ,20{SFD2} ENG263465-ENG258768-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion D 40,not active ,20{SFD2} ENG263465-ENG259573-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion E 40,not active ,20{SFD2} ENG263465-ENG258923-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion F 40,not active ,20{SFD2} ENG263465-ENG258928-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion G 40,not active ,20{SFD2} ENG263465-ENG259450-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion H 40,not active ,20{SFD2} ENG263465-ENG260309-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion I 40,not active ,20{SFD2} ENG263465-ENG258499-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion J 40,not active ,20{SFD2} ENG263465-ENG261065-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion K 40,not active ,20{SFD2} ENG263465-ENG259658-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion L 40,not active ,20{SFD2} ENG263486-ENG259814-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction DEF 41,maximize ,20{SFD2} ENG263486-ENG259194-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction GHI 41,maximize ,20{SFD2} ENG263486-ENG258697-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction JKL 41,maximize ,20{SFD2} ENG263486-ENG260405-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert ABC 41,0 ,20{SFD2} ENG263486-ENG261284-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert DEF 41,0 ,20{SFD2} ENG263486-ENG259351-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert GHI 41,0 ,20{SFD2} ENG263486-ENG258887-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert JKL 41,0 ,20{SFD2} ENG263486-ENG258329-Leuchte 41 Zusatz_hecklicht_HR A67-Fehlerort mittleres Byte DTC-DFCC 41,0 ,20{SFD2} ENG263486-ENG258960-Leuchte 41 Zusatz_hecklicht_HR A67-Lampendefektbitposition 41,0 ,20{SFD2} ENG263486-ENG261015-Leuchte 41 Zusatz_hecklicht_HR A67-Lasttyp 41,not_active ,20{SFD2} ENG263486-ENG260435-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtansteuerung HD ABC 41,Always ,20{SFD2} ENG263486-ENG260996-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion A 41,not active ,20{SFD2} ENG263486-ENG259966-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion B 41,not active ,20{SFD2} ENG263486-ENG258450-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion C 41,not active ,20{SFD2} ENG263486-ENG259570-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion D 41,not active ,20{SFD2} ENG263486-ENG260906-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion E 41,not active ,20{SFD2} ENG263486-ENG260838-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion F 41,not active ,20{SFD2} ENG263486-ENG258108-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion G 41,not active ,20{SFD2} ENG263486-ENG258430-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion H 41,not active ,20{SFD2} ENG263486-ENG260615-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion I 41,not active ,20{SFD2} ENG263486-ENG260918-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion J 41,not active ,20{SFD2} ENG263486-ENG258150-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion K 41,not active ,20{SFD2} ENG263486-ENG258739-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion L 41,not active ,20{SFD2} ENG253110-ENG261024-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction DEF 42,maximize ,20{SFD2} ENG253110-ENG258668-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction GHI 42,maximize ,20{SFD2} ENG253110-ENG258123-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction JKL 42,maximize ,20{SFD2} ENG253110-ENG258370-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert ABC 42,0 ,20{SFD2} ENG253110-ENG258109-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert DEF 42,0 ,20{SFD2} ENG253110-ENG261169-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert GHI 42,0 ,20{SFD2} ENG253110-ENG259028-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert JKL 42,0 ,20{SFD2} ENG253110-ENG259381-Leuchte 42 Wischblinksignal_li C30_B35-Fehlerort mittleres Byte DTC-DFCC 42,0 ,20{SFD2} ENG253110-ENG259973-Leuchte 42 Wischblinksignal_li C30_B35-Lampendefektbitposition 42,0 ,20{SFD2} ENG253110-ENG258662-Leuchte 42 Wischblinksignal_li C30_B35-Lasttyp 42,not_active ,20{SFD2} ENG253110-ENG258290-Leuchte 42 Wischblinksignal_li C30_B35-Lichtansteuerung HD ABC 42,Always ,20{SFD2} ENG253110-ENG258895-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion A 42,not active ,20{SFD2} ENG253110-ENG260384-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion B 42,not active ,20{SFD2} ENG253110-ENG261085-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion C 42,not active ,20{SFD2} ENG253110-ENG260667-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion D 42,not active ,20{SFD2} ENG253110-ENG260232-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion E 42,not active ,20{SFD2} ENG253110-ENG258671-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion F 42,not active ,20{SFD2} ENG253110-ENG259243-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion G 42,not active ,20{SFD2} ENG253110-ENG259518-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion H 42,not active ,20{SFD2} ENG253110-ENG259526-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion I 42,not active ,20{SFD2} ENG253110-ENG259239-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion J 42,not active ,20{SFD2} ENG253110-ENG258327-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion K 42,not active ,20{SFD2} ENG253110-ENG260944-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion L 42,not active ,20{SFD2} ENG253212-ENG261135-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction DEF 43,maximize ,20{SFD2} ENG253212-ENG258953-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction GHI 43,maximize ,20{SFD2} ENG253212-ENG260351-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction JKL 43,maximize ,20{SFD2} ENG253212-ENG259567-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert ABC 43,0 ,20{SFD2} ENG253212-ENG259435-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert DEF 43,0 ,20{SFD2} ENG253212-ENG260024-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert GHI 43,0 ,20{SFD2} ENG253212-ENG259623-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert JKL 43,0 ,20{SFD2} ENG253212-ENG258411-Leuchte 43 Wischblinksignal_re C33_B36-Fehlerort mittleres Byte DTC-DFCC 43,0 ,20{SFD2} ENG253212-ENG261311-Leuchte 43 Wischblinksignal_re C33_B36-Lampendefektbitposition 43,0 ,20{SFD2} ENG253212-ENG259612-Leuchte 43 Wischblinksignal_re C33_B36-Lasttyp 43,not_active ,20{SFD2} ENG253212-ENG261054-Leuchte 43 Wischblinksignal_re C33_B36-Lichtansteuerung HD ABC 43,Always ,20{SFD2} ENG253212-ENG258146-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion A 43,not active ,20{SFD2} ENG253212-ENG258144-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion B 43,not active ,20{SFD2} ENG253212-ENG258171-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion C 43,not active ,20{SFD2} ENG253212-ENG259397-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion D 43,not active ,20{SFD2} ENG253212-ENG260658-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion E 43,not active ,20{SFD2} ENG253212-ENG260002-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion F 43,not active ,20{SFD2} ENG253212-ENG260698-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion G 43,not active ,20{SFD2} ENG253212-ENG261082-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion H 43,not active ,20{SFD2} ENG253212-ENG260261-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion I 43,not active ,20{SFD2} ENG253212-ENG259097-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion J 43,not active ,20{SFD2} ENG253212-ENG260203-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion K 43,not active ,20{SFD2} ENG253212-ENG258986-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion L 43,not active ,20{SFD2} ENG253108-ENG258231-Leuchte 44 ALV C70-Dimming Direction DEF 44,maximize ,20{SFD2} ENG253108-ENG260416-Leuchte 44 ALV C70-Dimming Direction GHI 44,maximize ,20{SFD2} ENG253108-ENG260409-Leuchte 44 ALV C70-Dimming Direction JKL 44,maximize ,20{SFD2} ENG253108-ENG261347-Leuchte 44 ALV C70-Dimmwert ABC 44,127 ,20{SFD2} ENG253108-ENG260630-Leuchte 44 ALV C70-Dimmwert DEF 44,0 ,20{SFD2} ENG253108-ENG259610-Leuchte 44 ALV C70-Dimmwert GHI 44,0 ,20{SFD2} ENG253108-ENG261335-Leuchte 44 ALV C70-Dimmwert JKL 44,0 ,20{SFD2} ENG253108-ENG260566-Leuchte 44 ALV C70-Fehlerort mittleres Byte DTC-DFCC 44,133 ,20{SFD2} ENG253108-ENG261036-Leuchte 44 ALV C70-Lampendefektbitposition 44,0 ,20{SFD2} ENG253108-ENG258970-Leuchte 44 ALV C70-Lasttyp 44,LED Lichtmodul ohne Open Load Diagnose ,20{SFD2} ENG253108-ENG258540-Leuchte 44 ALV C70-Lichtansteuerung HD ABC 44,Always ,20{SFD2} ENG253108-ENG260079-Leuchte 44 ALV C70-Lichtfunktion A 44,Ambientelichtmodul Versorgung ,20{SFD2} ENG253108-ENG260296-Leuchte 44 ALV C70-Lichtfunktion B 44,not active ,20{SFD2} ENG253108-ENG261154-Leuchte 44 ALV C70-Lichtfunktion C 44,not active ,20{SFD2} ENG253108-ENG259507-Leuchte 44 ALV C70-Lichtfunktion D 44,not active ,20{SFD2} ENG253108-ENG258260-Leuchte 44 ALV C70-Lichtfunktion E 44,not active ,20{SFD2} ENG253108-ENG260714-Leuchte 44 ALV C70-Lichtfunktion F 44,not active ,20{SFD2} ENG253108-ENG260064-Leuchte 44 ALV C70-Lichtfunktion G 44,not active ,20{SFD2} ENG253108-ENG259720-Leuchte 44 ALV C70-Lichtfunktion H 44,not active ,20{SFD2} ENG253108-ENG258947-Leuchte 44 ALV C70-Lichtfunktion I 44,not active ,20{SFD2} ENG253108-ENG260429-Leuchte 44 ALV C70-Lichtfunktion J 44,not active ,20{SFD2} ENG253108-ENG260305-Leuchte 44 ALV C70-Lichtfunktion K 44,not active ,20{SFD2} ENG253108-ENG259925-Leuchte 44 ALV C70-Lichtfunktion L 44,not active ,20{SFD2} ENG253209-ENG259161-Leuchte 45 KRL C56-Dimming Direction DEF 45,maximize ,20{SFD2} ENG253209-ENG260000-Leuchte 45 KRL C56-Dimming Direction GHI 45,maximize ,20{SFD2} ENG253209-ENG258382-Leuchte 45 KRL C56-Dimming Direction JKL 45,maximize ,20{SFD2} ENG253209-ENG258536-Leuchte 45 KRL C56-Dimmwert ABC 45,100 ,20{SFD2} ENG253209-ENG261049-Leuchte 45 KRL C56-Dimmwert DEF 45,0 ,20{SFD2} ENG253209-ENG258646-Leuchte 45 KRL C56-Dimmwert GHI 45,0 ,20{SFD2} ENG253209-ENG258455-Leuchte 45 KRL C56-Dimmwert JKL 45,0 ,20{SFD2} ENG253209-ENG258548-Leuchte 45 KRL C56-Fehlerort mittleres Byte DTC-DFCC 45,137 ,20{SFD2} ENG253209-ENG259186-Leuchte 45 KRL C56-Lampendefektbitposition 45,0 ,20{SFD2} ENG253209-ENG259655-Leuchte 45 KRL C56-Lasttyp 45,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20{SFD2} ENG253209-ENG259881-Leuchte 45 KRL C56-Lichtansteuerung HD ABC 45,Always ,20{SFD2} ENG253209-ENG258376-Leuchte 45 KRL C56-Lichtfunktion A 45,Luggage compartment light ,20{SFD2} ENG253209-ENG260107-Leuchte 45 KRL C56-Lichtfunktion B 45,not active ,20{SFD2} ENG253209-ENG259696-Leuchte 45 KRL C56-Lichtfunktion C 45,not active ,20{SFD2} ENG253209-ENG258534-Leuchte 45 KRL C56-Lichtfunktion D 45,not active ,20{SFD2} ENG253209-ENG258311-Leuchte 45 KRL C56-Lichtfunktion E 45,not active ,20{SFD2} ENG253209-ENG259561-Leuchte 45 KRL C56-Lichtfunktion F 45,not active ,20{SFD2} ENG253209-ENG258655-Leuchte 45 KRL C56-Lichtfunktion G 45,not active ,20{SFD2} ENG253209-ENG258706-Leuchte 45 KRL C56-Lichtfunktion H 45,not active ,20{SFD2} ENG253209-ENG260201-Leuchte 45 KRL C56-Lichtfunktion I 45,not active ,20{SFD2} ENG253209-ENG259692-Leuchte 45 KRL C56-Lichtfunktion J 45,not active ,20{SFD2} ENG253209-ENG259667-Leuchte 45 KRL C56-Lichtfunktion K 45,not active ,20{SFD2} ENG253209-ENG259221-Leuchte 45 KRL C56-Lichtfunktion L 45,not active ,20ENG263430-ENG259519-Leuchte 5 TFL R B4-Dimming Direction DEF 5,maximize ,20ENG263430-ENG258873-Leuchte 5 TFL R B4-Dimming Direction GHI 5,maximize ,20ENG263430-ENG260664-Leuchte 5 TFL R B4-Dimming Direction JKL 5,maximize ,20ENG263430-ENG261164-Leuchte 5 TFL R B4-Dimmwert ABC 5,100 ,20ENG263430-ENG259517-Leuchte 5 TFL R B4-Dimmwert DEF 5,33 ,20ENG263430-ENG260636-Leuchte 5 TFL R B4-Dimmwert GHI 5,0 ,20ENG263430-ENG258543-Leuchte 5 TFL R B4-Dimmwert JKL 5,0 ,20ENG263430-ENG115969-Leuchte 5 TFL R B4-Fehlerort mittleres Byte DTC-DFCC 5,33 ,20ENG263430-ENG116554-Leuchte 5 TFL R B4-Lampendefektbitposition 5,68 ,20ENG263430-ENG115967-Leuchte 5 TFL R B4-Lasttyp 5,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20ENG263430-ENG258404-Leuchte 5 TFL R B4-Lichtansteuerung HD ABC 5,Always ,20ENG263430-ENG115970-Leuchte 5 TFL R B4-Lichtfunktion A 5,Daytime running lights ,20ENG263430-ENG115971-Leuchte 5 TFL R B4-Lichtfunktion B 5,not active ,20ENG263430-ENG115974-Leuchte 5 TFL R B4-Lichtfunktion C 5,not active ,20ENG263430-ENG115975-Leuchte 5 TFL R B4-Lichtfunktion D 5,Standlicht vorn ,20ENG263430-ENG115978-Leuchte 5 TFL R B4-Lichtfunktion E 5,Parking light right ,20ENG263430-ENG116555-Leuchte 5 TFL R B4-Lichtfunktion F 5,not active ,20ENG263430-ENG115982-Leuchte 5 TFL R B4-Lichtfunktion G 5,not active ,20ENG263430-ENG115983-Leuchte 5 TFL R B4-Lichtfunktion H 5,not active ,20ENG263430-ENG259352-Leuchte 5 TFL R B4-Lichtfunktion I 5,not active ,20ENG263430-ENG260105-Leuchte 5 TFL R B4-Lichtfunktion J 5,not active ,20ENG263430-ENG261301-Leuchte 5 TFL R B4-Lichtfunktion K 5,not active ,20ENG263430-ENG258882-Leuchte 5 TFL R B4-Lichtfunktion L 5,not active ,20ENG263442-ENG259123-Leuchte 6 ABL L C5-Dimming Direction DEF 6,maximize ,20ENG263442-ENG258751-Leuchte 6 ABL L C5-Dimming Direction GHI 6,maximize ,20ENG263442-ENG259402-Leuchte 6 ABL L C5-Dimming Direction JKL 6,maximize ,20ENG263442-ENG260099-Leuchte 6 ABL L C5-Dimmwert ABC 6,100 ,20ENG263442-ENG259481-Leuchte 6 ABL L C5-Dimmwert DEF 6,0 ,20ENG263442-ENG258578-Leuchte 6 ABL L C5-Dimmwert GHI 6,0 ,20ENG263442-ENG259931-Leuchte 6 ABL L C5-Dimmwert JKL 6,0 ,20ENG263442-ENG115988-Leuchte 6 ABL L C5-Fehlerort mittleres Byte DTC-DFCC 6,26 ,20ENG263442-ENG116556-Leuchte 6 ABL L C5-Lampendefektbitposition 6,54 ,20ENG263442-ENG115986-Leuchte 6 ABL L C5-Lasttyp 6,Low beams ,20ENG263442-ENG260333-Leuchte 6 ABL L C5-Lichtansteuerung HD ABC 6,Always ,20ENG263442-ENG115989-Leuchte 6 ABL L C5-Lichtfunktion A 6,Abblendlicht links ,20ENG263442-ENG115990-Leuchte 6 ABL L C5-Lichtfunktion B 6,not active ,20ENG263442-ENG115993-Leuchte 6 ABL L C5-Lichtfunktion C 6,not active ,20ENG263442-ENG115994-Leuchte 6 ABL L C5-Lichtfunktion D 6,not active ,20ENG263442-ENG115997-Leuchte 6 ABL L C5-Lichtfunktion E 6,not active ,20ENG263442-ENG115998-Leuchte 6 ABL L C5-Lichtfunktion F 6,not active ,20ENG263442-ENG116001-Leuchte 6 ABL L C5-Lichtfunktion G 6,not active ,20ENG263442-ENG116002-Leuchte 6 ABL L C5-Lichtfunktion H 6,not active ,20ENG263442-ENG259152-Leuchte 6 ABL L C5-Lichtfunktion I 6,not active ,20ENG263442-ENG260123-Leuchte 6 ABL L C5-Lichtfunktion J 6,not active ,20ENG263442-ENG258263-Leuchte 6 ABL L C5-Lichtfunktion K 6,not active ,20ENG263442-ENG260915-Leuchte 6 ABL L C5-Lichtfunktion L 6,not active ,20ENG263471-ENG258829-Leuchte 7 ABL R B1-Dimming Direction DEF 7,minimize ,20ENG263471-ENG258643-Leuchte 7 ABL R B1-Dimming Direction GHI 7,maximize ,20ENG263471-ENG260358-Leuchte 7 ABL R B1-Dimming Direction JKL 7,maximize ,20ENG263471-ENG258757-Leuchte 7 ABL R B1-Dimmwert ABC 7,100 ,20ENG263471-ENG260928-Leuchte 7 ABL R B1-Dimmwert DEF 7,0 ,20ENG263471-ENG258547-Leuchte 7 ABL R B1-Dimmwert GHI 7,0 ,20ENG263471-ENG260103-Leuchte 7 ABL R B1-Dimmwert JKL 7,0 ,20ENG263471-ENG116007-Leuchte 7 ABL R B1-Fehlerort mittleres Byte DTC-DFCC 7,27 ,20ENG263471-ENG116557-Leuchte 7 ABL R B1-Lampendefektbitposition 7,64 ,20ENG263471-ENG116005-Leuchte 7 ABL R B1-Lasttyp 7,Low beams ,20ENG263471-ENG259256-Leuchte 7 ABL R B1-Lichtansteuerung HD ABC 7,Always ,20ENG263471-ENG116008-Leuchte 7 ABL R B1-Lichtfunktion A 7,Abblendlicht rechts ,20ENG263471-ENG116009-Leuchte 7 ABL R B1-Lichtfunktion B 7,not active ,20ENG263471-ENG116012-Leuchte 7 ABL R B1-Lichtfunktion C 7,not active ,20ENG263471-ENG116013-Leuchte 7 ABL R B1-Lichtfunktion D 7,not active ,20ENG263471-ENG116016-Leuchte 7 ABL R B1-Lichtfunktion E 7,not active ,20ENG263471-ENG116017-Leuchte 7 ABL R B1-Lichtfunktion F 7,not active ,20ENG263471-ENG116020-Leuchte 7 ABL R B1-Lichtfunktion G 7,not active ,20ENG263471-ENG116021-Leuchte 7 ABL R B1-Lichtfunktion H 7,not active ,20ENG263471-ENG259451-Leuchte 7 ABL R B1-Lichtfunktion I 7,not active ,20ENG263471-ENG259043-Leuchte 7 ABL R B1-Lichtfunktion J 7,not active ,20ENG263471-ENG261166-Leuchte 7 ABL R B1-Lichtfunktion K 7,not active ,20ENG263471-ENG258778-Leuchte 7 ABL R B1-Lichtfunktion L 7,not active ,20ENG263437-ENG260885-Leuchte 8 FL L B39-Dimming Direction DEF 8,maximize ,20ENG263437-ENG259591-Leuchte 8 FL L B39-Dimming Direction GHI 8,maximize ,20ENG263437-ENG259283-Leuchte 8 FL L B39-Dimming Direction JKL 8,maximize ,20ENG263437-ENG259944-Leuchte 8 FL L B39-Dimmwert ABC 8,100 ,20ENG263437-ENG258915-Leuchte 8 FL L B39-Dimmwert DEF 8,0 ,20ENG263437-ENG261200-Leuchte 8 FL L B39-Dimmwert GHI 8,0 ,20ENG263437-ENG259325-Leuchte 8 FL L B39-Dimmwert JKL 8,0 ,20ENG263437-ENG116026-Leuchte 8 FL L B39-Fehlerort mittleres Byte DTC-DFCC 8,28 ,20ENG263437-ENG116558-Leuchte 8 FL L B39-Lampendefektbitposition 8,55 ,20ENG263437-ENG116024-Leuchte 8 FL L B39-Lasttyp 8,allgemeine_Scheinwerfer ,20ENG263437-ENG261218-Leuchte 8 FL L B39-Lichtansteuerung HD ABC 8,Always ,20ENG263437-ENG116027-Leuchte 8 FL L B39-Lichtfunktion A 8,Main beam left ,20ENG263437-ENG116028-Leuchte 8 FL L B39-Lichtfunktion B 8,Headlamp flasher ,20ENG263437-ENG116031-Leuchte 8 FL L B39-Lichtfunktion C 8,not active ,20ENG263437-ENG116032-Leuchte 8 FL L B39-Lichtfunktion D 8,not active ,20ENG263437-ENG116035-Leuchte 8 FL L B39-Lichtfunktion E 8,not active ,20ENG263437-ENG116036-Leuchte 8 FL L B39-Lichtfunktion F 8,not active ,20ENG263437-ENG116039-Leuchte 8 FL L B39-Lichtfunktion G 8,not active ,20ENG263437-ENG116040-Leuchte 8 FL L B39-Lichtfunktion H 8,not active ,20ENG263437-ENG261106-Leuchte 8 FL L B39-Lichtfunktion I 8,not active ,20ENG263437-ENG259701-Leuchte 8 FL L B39-Lichtfunktion J 8,not active ,20ENG263437-ENG260491-Leuchte 8 FL L B39-Lichtfunktion K 8,not active ,20ENG263437-ENG260880-Leuchte 8 FL L B39-Lichtfunktion L 8,not active ,20ENG263456-ENG260851-Leuchte 9 FL R B2-Dimming Direction DEF 9,maximize ,20ENG263456-ENG260306-Leuchte 9 FL R B2-Dimming Direction GHI 9,maximize ,20ENG263456-ENG261237-Leuchte 9 FL R B2-Dimming Direction JKL 9,maximize ,20ENG263456-ENG260111-Leuchte 9 FL R B2-Dimmwert ABC 9,100 ,20ENG263456-ENG260295-Leuchte 9 FL R B2-Dimmwert DEF 9,0 ,20ENG263456-ENG259797-Leuchte 9 FL R B2-Dimmwert GHI 9,0 ,20ENG263456-ENG260331-Leuchte 9 FL R B2-Dimmwert JKL 9,0 ,20ENG263456-ENG116045-Leuchte 9 FL R B2-Fehlerort mittleres Byte DTC-DFCC 9,29 ,20ENG263456-ENG116559-Leuchte 9 FL R B2-Lampendefektbitposition 9,65 ,20ENG263456-ENG116043-Leuchte 9 FL R B2-Lasttyp 9,allgemeine_Scheinwerfer ,20ENG263456-ENG258094-Leuchte 9 FL R B2-Lichtansteuerung HD ABC 9,Always ,20ENG263456-ENG116046-Leuchte 9 FL R B2-Lichtfunktion A 9,Main beam right ,20ENG263456-ENG116047-Leuchte 9 FL R B2-Lichtfunktion B 9,Headlamp flasher ,20ENG263456-ENG116050-Leuchte 9 FL R B2-Lichtfunktion C 9,not active ,20ENG263456-ENG116051-Leuchte 9 FL R B2-Lichtfunktion D 9,not active ,20ENG263456-ENG116054-Leuchte 9 FL R B2-Lichtfunktion E 9,not active ,20ENG263456-ENG116055-Leuchte 9 FL R B2-Lichtfunktion F 9,not active ,20ENG263456-ENG116058-Leuchte 9 FL R B2-Lichtfunktion G 9,not active ,20ENG263456-ENG116059-Leuchte 9 FL R B2-Lichtfunktion H 9,not active ,20ENG263456-ENG260691-Leuchte 9 FL R B2-Lichtfunktion I 9,not active ,20ENG263456-ENG260334-Leuchte 9 FL R B2-Lichtfunktion J 9,not active ,20ENG263456-ENG258156-Leuchte 9 FL R B2-Lichtfunktion K 9,not active ,20ENG263456-ENG259184-Leuchte 9 FL R B2-Lichtfunktion L 9,not active ,20{SFD2} ENG253237-IDE03311-Licht Konfig-Abhängig-Emergency braking display,active ,4{SFD2} ENG253237-IDE07470-Licht Konfig-Abhängig-After-run for park light,No run-on of two-sided parking light ,4{SFD2} ENG253237-MAS28761-Licht Konfig-Abhängig-All-weather light: installation status,not installed ,4{SFD2} ENG253237-MAS28762-Licht Konfig-Abhängig-Signature light: installation status,not installed ,4{SFD2} ENG253237-MAS28763-Licht Konfig-Abhängig-Discreet right taillight: installation status,installed ,4{SFD2} ENG253237-MAS28764-Licht Konfig-Abhängig-Discreet left taillight: installation status,installed ,4{SFD2} ENG253237-MAS28782-Licht Konfig-Abhängig-Instrument cluster display: signature light user interface specifications,not active ,4{SFD2} ENG253335-ENG259757-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_A,00 ,28{SFD2} ENG253335-ENG261031-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_B,00 ,28{SFD2} ENG253335-ENG259460-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_C,00 ,28{SFD2} ENG253335-ENG261084-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_D,00 ,28{SFD2} ENG253335-ENG260307-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_1,00 ,28{SFD2} ENG253335-ENG258132-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_2,00 ,28{SFD2} ENG253335-ENG258256-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_A,00 ,28{SFD2} ENG253335-ENG260342-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_B,00 ,28{SFD2} ENG253335-ENG259281-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_C,00 ,28{SFD2} ENG253335-ENG260011-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_D,00 ,28{SFD2} ENG253335-ENG260245-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_1,00 ,28{SFD2} ENG253335-ENG261364-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_2,00 ,28{SFD2} ENG253335-ENG260487-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_A,00 ,28{SFD2} ENG253335-ENG260833-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_B,00 ,28{SFD2} ENG253335-ENG261075-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_C,00 ,28{SFD2} ENG253335-ENG260552-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_D,00 ,28{SFD2} ENG253335-ENG260964-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_1,00 ,28{SFD2} ENG253335-ENG260937-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_2,00 ,28{SFD2} ENG253335-ENG261254-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_A,00 ,28{SFD2} ENG253335-ENG259240-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_B,00 ,28{SFD2} ENG253335-ENG258653-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_C,00 ,28{SFD2} ENG253335-ENG258931-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_D,00 ,28{SFD2} ENG253335-ENG259853-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_1,00 ,28{SFD2} ENG253335-ENG258582-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_2,00 ,28ENG174381-IDE17998-light_control-(De)activating the taillight animation,not active ,4ENG174381-IDE18362-light_control-Park Assist plus / with remote control  activating the turn signal: status,not active ,4ENG174381-IDE20495-light_control-Installation coding: hazard warning lights for child presence detection,not active ,4ENG174381-MAS00525-light_control-Trailer turn signal indicator lamp,INDIVIDUAL ,4ENG174381-MAS07990-light_control-Comfort flasher,active ,4ENG174381-MAS07991-light_control-Comfort flasher set point,3 ,4ENG174381-MAS10538-light_control-Light rotary sw. connection,Data bus LIN 1 ,4ENG174381-MAS12415-light_control-Parking lamp indicator lamp,INDIVIDUAL ,4ENG174381-MAS21313-light_control-Blinker signature,not active ,4ENG174381-MAS21315-light_control-Convenience flashing cancellation,active ,4ENG174381-ENG142188-light_control-bewusstes Standlicht,Aktive Begrenzung ,4ENG174381-ENG154711-light_control-PreCrash_RECAS,active ,4ENG174381-ENG126817-light_control-Umfeldleuchte als Manoevrierleuchte,not active ,4ENG174381-ENG142004-light_control-Umgreifende_Heckklappe,not installed ,4{SFD2} ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,2{SFD2} ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,2{SFD2} ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,2{SFD2} ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,2{SFD2} ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,2{SFD2} ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,2{SFD2} ENG126648-ENG260631-LIN-Mirrormode-LIN10,active ,2{SFD2} ENG126648-ENG259894-LIN-Mirrormode-LIN11,active ,2{SFD2} ENG126648-ENG260777-LIN-Mirrormode-LIN12,active ,2{SFD2} ENG126648-ENG258456-LIN-Mirrormode-LIN13,active ,2{SFD2} ENG126648-ENG259488-LIN-Mirrormode-LIN14,active ,2{SFD2} ENG126648-ENG260898-LIN-Mirrormode-LIN7,active ,2{SFD2} ENG126648-ENG259836-LIN-Mirrormode-LIN8,active ,2{SFD2} ENG126648-ENG258319-LIN-Mirrormode-LIN9,active ,2{SFD2} ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,2{SFD } ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27{SFD } ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27{SFD } ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27{SFD } ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27{SFD } ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27{SFD } ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27{SFD } ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27{SFD } ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27{SFD } ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27{SFD } ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.04 ,27{SFD } ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,4 °C,27{SFD } ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,13.0 %,27{SFD } ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27{SFD } ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27{SFD } ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27{SFD } ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27{SFD } ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,39 °C,27{SFD } ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,43 °C,27{SFD } ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,47 °C,27{SFD } ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27{SFD } ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27{SFD } ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,40 ms,27{SFD } ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27{SFD } ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27{SFD } ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27{SFD } ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,60 s,27{SFD } ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2{SFD } ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2{SFD } ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,installed ,2{SFD } ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2{SFD } ENG153728-MAS00128-LIN-SMLS_konfig_2-Adaptive Cruise Control,not installed ,2{SFD } ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2{SFD } ENG153728-MAS02790-LIN-SMLS_konfig_2-Diagnosis,not active ,2{SFD } ENG153728-MAS03758-LIN-SMLS_konfig_2-Not assigned,not installed ,2{SFD } ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2{SFD } ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2{SFD } ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2{SFD } ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2{SFD } ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2{SFD2} ENG253274-ENG260814-Lock Unlock Taster-Lock_Unlock_Taster_diskret,not active ,2{SFD2} ENG253274-ENG258303-Lock Unlock Taster-Lock_Unlock_Taster_Logik,Rocker sw. ,2{SFD2} ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.0 %,12{SFD2} ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12{SFD2} ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12{SFD2} ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12{SFD2} ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12{SFD2} ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12{SFD2} ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %,12{SFD2} ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.0 %,12{SFD2} ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.0 %,12{SFD2} ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %,12{SFD2} ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.0 %,12{SFD2} ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %,12{SFD2} ENG253158-LWR Basissoftware,15 %,16{SFD2} ENG253042-IDE03638-LWR Konfiguration-Static cornering light,Deactivated ,8{SFD2} ENG253042-IDE03644-LWR Konfiguration-Highway light,not activated ,8{SFD2} ENG253042-MAS02922-LWR Konfiguration-City light,not activated ,8{SFD2} ENG253042-MAS07013-LWR Konfiguration-All-weather light,not activated ,8{SFD2} ENG253042-MAS07933-LWR Konfiguration-Eco mode,not activated ,8{SFD2} ENG253042-ENG172238-LWR Konfiguration-chassis_unit,Verbundlenkerhinterachse ,8{SFD2} ENG253042-ENG260425-LWR Konfiguration-Function_activation_LWR,activated ,8{SFD2} ENG253042-ENG174374-LWR Konfiguration-LED_Headlight,not activated ,8{SFD2} ENG253042-ENG259430-LWR Konfiguration-LWR_konfig,DC HMI ,8{SFD2} ENG253042-ENG172241-LWR Konfiguration-lwr_sensors,1_sensor ,8{SFD2} ENG253042-ENG171501-LWR Konfiguration-Market,ECE ,8{SFD2} ENG253042-ENG173009-LWR Konfiguration-offroad_light,not activated ,8{SFD2} ENG253042-ENG172245-LWR Konfiguration-rain_light,not activated ,8{SFD2} ENG253042-ENG174637-LWR Konfiguration-Source_height_value,BCM ,8{SFD2} ENG253042-ENG172240-LWR Konfiguration-steering_curve,normal ,8{SFD2} ENG369156-ENG369620-MDK Automatikfunktionen-p_auto_ZV_Reak_nicht_in_Front_Heck_Zone,not active ,1{SFD2} ENG369156-ENG369621-MDK Automatikfunktionen-p_auto_ZV_Reak_nicht_nur_in_personalisierter_Zone,not active ,1{SFD2} ENG369156-ENG369622-MDK Automatikfunktionen-p_auto_ZV_Reak_Tueren_nicht_bei_Front_Heck_Zone,not active ,1{SFD2} ENG369156-ENG369623-MDK Automatikfunktionen-p_auto_ZV_Reak_ver_mit_SAFE,not active ,1{SFD2} ENG369156-ENG369624-MDK Automatikfunktionen-p_FBS_Kessy_MDK_auto_entr_quittierung,not active ,1{SFD2} ENG369156-ENG369625-MDK Automatikfunktionen-p_FBS_Kessy_MDK_auto_ver_Abbruchquittierung,not active ,1{SFD2} ENG369156-ENG369626-MDK Automatikfunktionen-p_FBS_kessy_MDK_auto_ver_ohne_SAFE_quittierung,not_active ,1{SFD2} ENG369156-ENG369627-MDK Automatikfunktionen-p_FBS_Kessy_MDK_auto_ver_quittierung,not active ,1{SFD2} ENG344856-ENG345887-MDK Funktion-p_komfortbedienung_fh_oeffnen_ueber_MDK,not active ,4{SFD2} ENG344856-ENG345888-MDK Funktion-p_komfortbedienung_fh_schliessen_ueber_MDK,not active ,4{SFD2} ENG344856-ENG345889-MDK Funktion-p_komfortbedienung_MDK_aktiv,not active ,4{SFD2} ENG344856-ENG345890-MDK Funktion-p_komfortbedienung_verdeck_oeffnen_ueber_MDK,not active ,4{SFD2} ENG344856-ENG345891-MDK Funktion-p_komfortbedienung_verdeck_schliessen_ueber_MDK,not active ,4{SFD2} ENG344856-ENG345892-MDK Funktion-p_MDK_verbaut,not installed ,4{SFD2} ENG344857-mdk_funktionaktivierung,not activated ,1{SFD2} ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,1{SFD2} ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,1{SFD2} ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,1{SFD2} ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,1{SFD2} ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,1{SFD2} ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,1{SFD2} ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,1{SFD2} ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,1{SFD2} ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,1{SFD2} ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,1{SFD2} ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,1{SFD2} ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,1{SFD2} ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,1{SFD2} ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,1{SFD2} ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,1{SFD2} ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,1{SFD2} ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,1{SFD2} ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,1{SFD2} ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,1{SFD2} ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,1{SFD2} ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8{SFD2} ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8{SFD2} ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8{SFD2} ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8{SFD2} ENG153902-NFC_FS_debug_switch,No Response From Subnet Component,8{SFD2} ENG124714-ENG395072-OCU-cp_remote_fenster_komfort,not active ,10{SFD2} ENG124714-ENG142044-OCU-DWA_push,active ,10{SFD2} ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,10{SFD2} ENG124714-OCU-,installed ,10{SFD2} ENG124714-ENG395178-OCU-p_t_rlu_komfortbedienungsdauer,10.00 s,10{SFD2} ENG124714-ENG395179-OCU-p_t_rlu_komfortschliessen_pausenzeit,2.00 s,10{SFD2} ENG124714-ENG395180-OCU-p_t_rlu_komfortschliessen_startphase,10.00 s,10{SFD2} ENG124714-ENG259569-OCU-Remote HuF,active ,10{SFD2} ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,10{SFD2} ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,10{SFD2} ENG124714-ENG260662-OCU-Remote HuF maximale Ausführungsdauer,30 s,10{SFD2} ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,30 s,10{SFD2} ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,1000 ms,10{SFD2} ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,10{SFD2} ENG298054-ENG260528-OpenByWire_RBox_Schloss-p_t_ZV_ansteuerzeit_motor,0 ms,9{SFD2} ENG298054-ENG298139-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_Crash_ansteuerzeit_motor,250 ms,9{SFD2} ENG298054-ENG298140-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor,70 ms,9{SFD2} ENG298054-ENG298141-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor_max,90 ms,9{SFD2} ENG298054-ENG298142-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor_min,60 ms,9{SFD2} ENG298054-ENG298143-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_bremsen_motor,20 ms,9{SFD2} ENG298054-ENG298144-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_verzoegerte_ansteuerung,0 ms,9{SFD2} ENG298054-ENG298145-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_warten_motor,500 ms,9{SFD2} ENG298055-ENG298136-OpenByWire_Schloss-p_t_ZV_OBW_EOE_ansteuerzeit_motor,500 ms,2{SFD2} ENG298055-ENG298137-OpenByWire_Schloss-p_t_ZV_OBW_EOE_bremsen_motor,0 ms,2{SFD2} ENG253051-ENG260817-Par_AutomatikFKT-AutomatikFunktion_Gueltigkeitsdauer_IDGeber_Authentifizierungsstatus_Beschleunigtes_Entry,5.00 s,27{SFD2} ENG253051-ENG345290-Par_AutomatikFKT-AutomatikFunktion_RSSI_Bewertungsschwelle_IDGeber,45 dB,27{SFD2} ENG253051-ENG260526-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Inkrement,1 ,27{SFD2} ENG253051-ENG261190-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle,60 ,27{SFD2} ENG253051-ENG258545-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle_Offset,5 ,27{SFD2} ENG253051-ENG258184-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Dekrement,60 s,27{SFD2} ENG253051-ENG260053-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Inkrement,10 s,27{SFD2} ENG253051-ENG258738-Par_AutomatikFKT-AutomatikFunktionen_WechselBeiIDGebernInRuhe_Timeout,30 s,27{SFD2} ENG253051-ENG258350-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_FahrendesFzg,20 km/h,27{SFD2} ENG253051-ENG260570-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_StehendesFzg,10 km/h,27{SFD2} ENG253051-ENG259977-Par_AutomatikFKT-TemporaereSperrungFuerAutomatikFunktionen_Dauer,0 s,27{SFD2} ENG253220-Par_Bedienstellen,2 ,7{SFD2} ENG253257-ENG259939-Par_Dienste-Beeinflussung_StartStopp_DauerWiederstart,500 ms,18{SFD2} ENG253257-ENG259005-Par_Dienste-Beeinflussung_StartStopp_Timeout,500 ms,18{SFD2} ENG253257-ENG259811-Par_Dienste-Bereichsueberwachung_Pilotiertes_Parken_Timeout,120 s,18{SFD2} ENG253257-ENG261028-Par_Dienste-EntryGoDeaktivierung_ZweiteBedienhandlung_Timeout,5 s,18{SFD2} ENG253257-ENG261102-Par_Dienste-Innenraumsuche_GueltigkeitFuerExterneFunktionen,10 s,18{SFD2} ENG253257-ENG258558-Par_Dienste-Paketbotenmodus_Timeout,15 min,18{SFD2} ENG253257-ENG259702-Par_Dienste-Signalisierungsdauer_Ergebnis_IDGebersuche_ext_Funktionen,500 ms,18{SFD2} ENG253257-ENG260866-Par_Dienste-SpielschutzFuerDienste_Dekrement_Timeout,60 s,18{SFD2} ENG253257-ENG260031-Par_Dienste-SpielschutzFuerDienste_Schwelle,10 ,18{SFD2} ENG253257-ENG258560-Par_Dienste-VIT_Mindest_Empfangs_Dauer_Betaetigt_Start_Suche,10 ms,18{SFD2} ENG253386-ENG345660-Par_IDGeberSuche-Entprellzyklen_Signalisierung_IDGeber_AutoEntry (2),4 ,26{SFD2} ENG253386-ENG345661-Par_IDGeberSuche-Entprellzyklen_Signalisierung_IDGeber_AutoExit,1 ,26{SFD2} ENG253386-ENG345662-Par_IDGeberSuche-Entprellzyklen_Signalisierung_IDGeber_EasyClose,1 ,26{SFD2} ENG253386-ENG345663-Par_IDGeberSuche-Entprellzyklen_Signalisierung_IDGeber_FastEntry,1 ,26{SFD2} ENG253386-ENG259497-Par_IDGeberSuche-Innenraumsuche_Kl15_Pause,5000 ms,26{SFD2} ENG253386-ENG258238-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FahrendesFzg,20 km/h,26{SFD2} ENG253386-ENG260811-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FensterGeschlossen,5.0 %,26{SFD2} ENG253386-ENG258295-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_SADGeschlossen,1 %,26{SFD2} ENG253386-ENG259267-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_StehendesFzg,10 km/h,26{SFD2} ENG253386-ENG261289-Par_IDGeberSuche-Innenraumsuche_Kl15_Wiederholungen,5 ,26{SFD2} ENG253386-ENG260801-Par_IDGeberSuche-Innenraumsuche_verzoegertFFBKomfortschließen,3200 ms,26{SFD2} ENG253386-ENG260447-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Heck_ZeitfensterFuerRasten,500 ms,26{SFD2} ENG253386-ENG260184-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_FensterOffen,100.0 %,26{SFD2} ENG253386-ENG260557-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_SADOffen,5.0 %,26{SFD2} ENG253386-ENG258851-Par_IDGeberSuche-SignalisierungFunkkommunikation_Vorlauf,0 ms,26{SFD2} ENG253236-ENG260747-Par_Passive_EntryExit_Toggle-BewussteGesamtEntriegelung,5000 ms,6{SFD2} ENG253236-ENG281088-Par_Passive_EntryExit_Toggle-TemporaereSperrungFuerExit_Dauer,0.0 s,6{SFD2} ENG253236-ENG281089-Par_Passive_EntryExit_Toggle-Verriegelungskontrolle_Dauer,2.0 s,6{SFD2} ENG253347-ENG258202-Par_RSAD-Box2Box_Zuordnung_RSAD_HL,3 ,20{SFD2} ENG253347-ENG259350-Par_RSAD-Box2Box_Zuordnung_RSAD_HR,3 ,20{SFD2} ENG253347-ENG260315-Par_RSAD-Box2Box_Zuordnung_RSAD_IN,1 ,20{SFD2} ENG253347-ENG260967-Par_RSAD-Box2Box_Zuordnung_RSAD_VL,1 ,20{SFD2} ENG253347-ENG260395-Par_RSAD-Box2Box_Zuordnung_RSAD_VR,1 ,20{SFD2} ENG253347-ENG259213-Par_RSAD-maxAbstand_RSAD_innen_Referenzbox,600 cm,20{SFD2} ENG253347-ENG258615-Par_RSAD-maxAbstand_RSAD_links_rechts,345 cm,20{SFD2} ENG253347-ENG260439-Par_RSAD-maxAbstand_RSAD_vorne_hinten,600 cm,20{SFD2} ENG253347-ENG281104-Par_RSAD-minAbstand_RSAD_innen_Referenzbox,210 cm,20{SFD2} ENG253347-ENG281079-Par_RSAD-minAbstand_RSAD_links_rechts,105 cm,20{SFD2} ENG253347-ENG281105-Par_RSAD-minAbstand_RSAD_vorne_hinten,210 cm,20{SFD2} ENG253347-ENG259498-Par_RSAD-RSAD_UWB_aussen_Entfernung,600 cm,20{SFD2} ENG253347-ENG260842-Par_RSAD-RSAD_UWB_innen_Entfernung,0 cm,20{SFD2} ENG253347-ENG289610-Par_RSAD-RSAD_UWB_maxAbweichung,45 cm,20{SFD2} ENG253398-ENG261340-Par_ScanStrat_RetryHandling-anz_GesamtRetries,1 ,18{SFD2} ENG253398-ENG260989-Par_ScanStrat_RetryHandling-anz_RetriesAuthentifizierung,2 ,18{SFD2} ENG253398-ENG260903-Par_ScanStrat_RetryHandling-Dynamischer_Anteil_Registering,7 ms,18{SFD2} ENG253398-ENG259602-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_UWB,80 ms,18{SFD2} ENG253398-ENG258787-Par_ScanStrat_RetryHandling-Timeout_Go_Authentifizierungsphase,160 ms,18{SFD2} ENG253398-ENG260198-Par_ScanStrat_RetryHandling-Wartezeit_Challenge_Retry_Challenge_Entry,6 ms,18{SFD2} ENG253398-ENG259374-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Entry,4 ms,18{SFD2} ENG253398-ENG261047-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Go,35 ms,18{SFD2} ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,18{SFD2} ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,18{SFD2} ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,18{SFD2} ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,18{SFD2} ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,18{SFD2} ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,18{SFD2} ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,18{SFD2} ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,18{SFD2} ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,18{SFD2} ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,18{SFD2} ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,18{SFD2} ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,18{SFD2} ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,18{SFD2} ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,18{SFD2} ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,18{SFD2} ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,18{SFD2} ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,18{SFD2} ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,18{SFD2} ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,18{SFD2} ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,18{SFD2} ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,18{SFD2} ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,18{SFD2} ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,18{SFD2} ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,18{SFD2} ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,18{SFD2} ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,18{SFD2} ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,18{SFD2} ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,18{SFD2} ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,18{SFD2} ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,18{SFD2} ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,18{SFD2} ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,18{SFD2} ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,18{SFD2} ENG286146-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,18{SFD2} ENG286146-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,18{SFD2} ENG286146-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,18{SFD2} ENG286146-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,18{SFD2} ENG286146-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,18{SFD2} ENG286146-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,18{SFD2} ENG286146-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,18{SFD2} ENG286146-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,18{SFD2} ENG286146-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,18{SFD2} ENG286146-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,18{SFD2} ENG286146-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,18{SFD2} ENG286146-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,18{SFD2} ENG286146-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,18{SFD2} ENG286146-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,18{SFD2} ENG286146-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,18{SFD2} ENG286146-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,18{SFD2} ENG286146-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,18{SFD2} ENG286146-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,18{SFD2} ENG286146-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,18{SFD2} ENG286146-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,18{SFD2} ENG286146-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,18{SFD2} ENG286146-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,18{SFD2} ENG286146-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,18{SFD2} ENG286146-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,18{SFD2} ENG286146-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,18{SFD2} ENG286146-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,18{SFD2} ENG286146-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,18{SFD2} ENG286146-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,18{SFD2} ENG286146-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,18{SFD2} ENG286146-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,18{SFD2} ENG286146-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,18{SFD2} ENG286146-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,18{SFD2} ENG286146-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,18{SFD2} ENG286146-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,18{SFD2} ENG286146-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,18{SFD2} ENG286146-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,18{SFD2} ENG286146-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,18{SFD2} ENG286146-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,18{SFD2} ENG286146-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,18{SFD2} ENG286146-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,18{SFD2} ENG286146-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,18{SFD2} ENG286146-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,18{SFD2} ENG286146-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,18{SFD2} ENG286146-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,18{SFD2} ENG286146-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,18{SFD2} ENG286146-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,18{SFD2} ENG286146-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,18{SFD2} ENG286146-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,18{SFD2} ENG286146-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,18{SFD2} ENG286146-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,18{SFD2} ENG286146-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,18{SFD2} ENG286146-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,18{SFD2} ENG286146-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,18{SFD2} ENG286146-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,18{SFD2} ENG286146-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,18{SFD2} ENG286146-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,18{SFD2} ENG286146-IDE80057-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,18{SFD2} ENG286146-IDE80058-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,18{SFD2} ENG286146-IDE80059-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,18{SFD2} ENG286146-IDE80060-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,18{SFD2} ENG286147-IDE00047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,18{SFD2} ENG286147-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,18{SFD2} ENG286147-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,18{SFD2} ENG286147-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,18{SFD2} ENG286147-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,18{SFD2} ENG286147-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,18{SFD2} ENG286147-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,18{SFD2} ENG286147-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,18{SFD2} ENG286147-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,18{SFD2} ENG286147-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,18{SFD2} ENG286147-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,18{SFD2} ENG286147-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,18{SFD2} ENG286147-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,18{SFD2} ENG286147-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,18{SFD2} ENG286147-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,18{SFD2} ENG286147-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,18{SFD2} ENG286147-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,18{SFD2} ENG286147-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,18{SFD2} ENG286147-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,18{SFD2} ENG286147-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,18{SFD2} ENG286147-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,18{SFD2} ENG286147-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,18{SFD2} ENG286147-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,18{SFD2} ENG286147-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,18{SFD2} ENG286147-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,18{SFD2} ENG286147-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,18{SFD2} ENG286147-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,18{SFD2} ENG286147-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,18{SFD2} ENG286147-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,18{SFD2} ENG286147-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,18{SFD2} ENG286147-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,18{SFD2} ENG286147-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,18{SFD2} ENG286147-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,18{SFD2} ENG286147-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,18{SFD2} ENG286147-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,18{SFD2} ENG286147-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,18{SFD2} ENG286147-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,18{SFD2} ENG286147-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,18{SFD2} ENG286147-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,18{SFD2} ENG286147-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,18{SFD2} ENG286147-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,18{SFD2} ENG286147-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,18{SFD2} ENG286147-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,18{SFD2} ENG286147-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,18{SFD2} ENG286147-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,18{SFD2} ENG286147-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,18{SFD2} ENG286147-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,18{SFD2} ENG286147-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,18{SFD2} ENG286147-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,18{SFD2} ENG286147-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,18{SFD2} ENG286147-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,18{SFD2} ENG286147-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,18{SFD2} ENG286147-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,18{SFD2} ENG286147-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,18{SFD2} ENG286147-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,18{SFD2} ENG286147-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,18{SFD2} ENG286147-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,18{SFD2} ENG286147-MAS01078-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,18{SFD2} ENG286147-MAS14087-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,18{SFD2} ENG253136-IDE02456-Passive_EntryExit_Toggle-Passive entry right rear door handle,not activated ,8{SFD2} ENG253136-IDE02457-Passive_EntryExit_Toggle-Passive entry left rear door handle,not activated ,8{SFD2} ENG253136-IDE02458-Passive_EntryExit_Toggle-Passive entry frt.pass. door handle,not activated ,8{SFD2} ENG253136-IDE02459-Passive_EntryExit_Toggle-Passive entry driver door handle,not activated ,8{SFD2} ENG253136-IDE02460-Passive_EntryExit_Toggle-Passive exit right rear door handle,not activated ,8{SFD2} ENG253136-IDE02461-Passive_EntryExit_Toggle-Passive exit left rear door handle,not activated ,8{SFD2} ENG253136-IDE02462-Passive_EntryExit_Toggle-Passive exit frt. pass. door handle,not activated ,8{SFD2} ENG253136-IDE02463-Passive_EntryExit_Toggle-Passive exit driver door handle,not activated ,8{SFD2} ENG253136-IDE03178-Passive_EntryExit_Toggle-Unlocking by electr. sliding door,not activated ,8{SFD2} ENG253136-MAS18905-Passive_EntryExit_Toggle-Passive entry via control section rear,not activated ,8{SFD2} ENG253136-MAS18906-Passive_EntryExit_Toggle-Passive entry by rear sensor,not activated ,8{SFD2} ENG253136-MAS18907-Passive_EntryExit_Toggle-Monitoring of locking by pulling door handle,activated ,8{SFD2} ENG253136-MAS18912-Passive_EntryExit_Toggle-Passive exit door handle control section rear,not activated ,8{SFD2} ENG253136-MAS18913-Passive_EntryExit_Toggle-Lock/unlock button on driver door active,not activated ,8{SFD2} ENG253136-MAS18914-Passive_EntryExit_Toggle-Lock/unlock button on front passenger door active,not activated ,8{SFD2} ENG253136-MAS18915-Passive_EntryExit_Toggle-Lock/unlock button on rear driver side active,not activated ,8{SFD2} ENG253136-MAS18916-Passive_EntryExit_Toggle-Lock/unlock button on front passenger side active,not activated ,8{SFD2} ENG253136-MAS18917-Passive_EntryExit_Toggle-Lock/unlock button control section rear active,not activated ,8{SFD2} ENG253136-ENG259242-Passive_EntryExit_Toggle-TemporaerSperrungFuerExit_aktiv,not activated ,8{SFD2} ENG253136-ENG260214-Passive_EntryExit_Toggle-Verriegelungskontrolle_Heck_aktiv,not activated ,8{SFD2} ENG129043-PASSIVE_GO,not activated ,4{SFD2} ENG253210-ENG260453-Personalisierung_2_0-Active_Participant_Doorlocking_Enabled,Deactivated ,12{SFD2} ENG253210-ENG259841-Personalisierung_2_0-Active_Participant_ExteriorLight_Enabled,activated ,12{SFD2} ENG253210-ENG260445-Personalisierung_2_0-Active_Participant_InteriorLight_Enabled,activated ,12{SFD2} ENG253210-ENG259660-Personalisierung_2_0-Active_Participant_Mirror_Enabled,activated ,12{SFD2} ENG253210-ENG298068-Personalisierung_2_0-Active_Participant_SeatPneumatic_Enabled,activated ,12{SFD2} ENG253210-ENG259827-Personalisierung_2_0-Active_Participant_WiperComfort_Enabled,activated ,12{SFD2} ENG253210-ENG258609-Personalisierung_2_0-PSO_Setup_1,not_active ,12{SFD2} ENG253210-ENG260679-Personalisierung_2_0-PSO_Setup_2,not_active ,12{SFD2} ENG253210-ENG259992-Personalisierung_2_0-PSO_Setup_Bereich_1,0 ms,12{SFD2} ENG253210-ENG260317-Personalisierung_2_0-PSO_Setup_Bereich_2,0 ms,12{SFD2} ENG253210-ENG260178-Personalisierung_2_0-Version_ Personalisierung,Customization coded 2.x ,12{SFD2} ENG253210-ENG247653-Personalisierung_2_0-Wait_for_IAA_Slot_Info,150 ms,12{SFD2} ENG344862-ENG146414-Pilotiertes_Parken_ZV-ffb_kessy_active_for_piloted_parking,not active ,5{SFD2} ENG344862-ENG260469-Pilotiertes_Parken_ZV-KFT_Pilopar_aktiv,not active ,5{SFD2} ENG344862-ENG258878-Pilotiertes_Parken_ZV-ZV_Pilopar_aktiv,not active ,5{SFD2} ENG253109-PSI5 Konfiguration,0F ,16{SFD2} ENG253310-PSI5 Sensoren,not installed ,1{SFD2} ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,8{SFD2} ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,8{SFD2} ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,8{SFD2} ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,8{SFD2} ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,8{SFD2} ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,8{SFD2} ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,8{SFD2} ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,8{SFD2} ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,8{SFD2} ENG141646-ENG141964-Querschnitts_funktionen-Steering assignment,Left ,8{SFD2} ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,8{SFD2} ENG244881-ENG286173-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286174-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286175-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286176-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286177-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286178-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286179-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssSlopeThreshold,No Response From Subnet Component,8{SFD2} ENG244881-ENG286180-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286181-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286182-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286183-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286184-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286185-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG289577-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8{SFD2} ENG244881-ENG289578-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Samples,No Response From Subnet Component,8{SFD2} ENG244881-ENG286188-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucDebounce,No Response From Subnet Component,8{SFD2} ENG244881-ENG289579-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay,No Response From Subnet Component,8{SFD2} ENG244881-ENG289580-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8{SFD2} ENG244881-ENG289581-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8{SFD2} ENG244881-ENG289582-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Width,No Response From Subnet Component,8{SFD2} ENG244881-ENG289583-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Mean_Width,No Response From Subnet Component,8{SFD2} ENG244881-ENG289584-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Var_Delay,No Response From Subnet Component,8{SFD2} ENG244881-ENG286195-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucStdDevOnRawWidth,No Response From Subnet Component,8{SFD2} ENG244881-ENG286196-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ulMinHeightSquaredMax,No Response From Subnet Component,8{SFD2} ENG244881-ENG286197-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286198-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286199-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286200-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286201-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286202-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286203-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286204-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286205-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286206-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286207-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286208-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286209-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usCRC,No Response From Subnet Component,8{SFD2} ENG244881-ENG289585-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Default_Squared_Val,No Response From Subnet Component,8{SFD2} ENG244881-ENG289586-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Squared_Factor,No Response From Subnet Component,8{SFD2} ENG244881-ENG286212-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usRawVarMax,No Response From Subnet Component,8{SFD2} ENG244881-ENG286213-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usVarianceThr,No Response From Subnet Component,8{SFD2} ENG244881-ENG286214-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286215-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286216-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286217-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286218-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286219-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286220-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssSlopeThreshold,No Response From Subnet Component,8{SFD2} ENG244881-ENG286221-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286222-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286223-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286224-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286225-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286226-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG289587-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8{SFD2} ENG244881-ENG289588-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Samples,No Response From Subnet Component,8{SFD2} ENG244881-ENG286229-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucDebounce,No Response From Subnet Component,8{SFD2} ENG244881-ENG289589-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay,No Response From Subnet Component,8{SFD2} ENG244881-ENG289590-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8{SFD2} ENG244881-ENG289591-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8{SFD2} ENG244881-ENG289592-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Width,No Response From Subnet Component,8{SFD2} ENG244881-ENG289593-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Mean_Width,No Response From Subnet Component,8{SFD2} ENG244881-ENG289594-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Var_Delay,No Response From Subnet Component,8{SFD2} ENG244881-ENG286236-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucStdDevOnRawWidth,No Response From Subnet Component,8{SFD2} ENG244881-ENG286237-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ulMinHeightSquaredMax,No Response From Subnet Component,8{SFD2} ENG244881-ENG286238-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286239-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286240-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286241-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286242-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286243-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286244-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286245-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286246-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286247-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286248-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286249-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286250-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usCRC,No Response From Subnet Component,8{SFD2} ENG244881-ENG289595-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Default_Squared_Val,No Response From Subnet Component,8{SFD2} ENG244881-ENG289596-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Squared_Factor,No Response From Subnet Component,8{SFD2} ENG244881-ENG286253-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usRawVarMax,No Response From Subnet Component,8{SFD2} ENG244881-ENG286254-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usVarianceThr,No Response From Subnet Component,8{SFD2} ENG244881-ENG286262-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-padding,No Response From Subnet Component,8{SFD2} ENG244881-ENG286271-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286272-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286273-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286274-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG289612-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_High,No Response From Subnet Component,8{SFD2} ENG244881-ENG289613-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_Low,No Response From Subnet Component,8{SFD2} ENG244881-ENG286278-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_1_Range_{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286279-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286280-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286281-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio1_Range_{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286282-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286283-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286284-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286285-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286286-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{10},No Response From Subnet Component,8{SFD2} ENG244881-ENG286287-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{11},No Response From Subnet Component,8{SFD2} ENG244881-ENG286288-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{12},No Response From Subnet Component,8{SFD2} ENG244881-ENG286289-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{13},No Response From Subnet Component,8{SFD2} ENG244881-ENG286290-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{14},No Response From Subnet Component,8{SFD2} ENG244881-ENG286291-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{15},No Response From Subnet Component,8{SFD2} ENG244881-ENG286292-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{16},No Response From Subnet Component,8{SFD2} ENG244881-ENG286293-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{17},No Response From Subnet Component,8{SFD2} ENG244881-ENG286294-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{18},No Response From Subnet Component,8{SFD2} ENG244881-ENG286295-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{19},No Response From Subnet Component,8{SFD2} ENG244881-ENG286296-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{2},No Response From Subnet Component,8{SFD2} ENG244881-ENG286297-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{20},No Response From Subnet Component,8{SFD2} ENG244881-ENG286298-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{21},No Response From Subnet Component,8{SFD2} ENG244881-ENG286299-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{22},No Response From Subnet Component,8{SFD2} ENG244881-ENG286300-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{23},No Response From Subnet Component,8{SFD2} ENG244881-ENG286301-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{24},No Response From Subnet Component,8{SFD2} ENG244881-ENG286302-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{25},No Response From Subnet Component,8{SFD2} ENG244881-ENG286303-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{26},No Response From Subnet Component,8{SFD2} ENG244881-ENG286304-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{27},No Response From Subnet Component,8{SFD2} ENG244881-ENG286305-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{28},No Response From Subnet Component,8{SFD2} ENG244881-ENG286306-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{29},No Response From Subnet Component,8{SFD2} ENG244881-ENG286307-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{3},No Response From Subnet Component,8{SFD2} ENG244881-ENG286308-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{30},No Response From Subnet Component,8{SFD2} ENG244881-ENG286309-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{31},No Response From Subnet Component,8{SFD2} ENG244881-ENG286310-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{32},No Response From Subnet Component,8{SFD2} ENG244881-ENG286311-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{33},No Response From Subnet Component,8{SFD2} ENG244881-ENG286312-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{34},No Response From Subnet Component,8{SFD2} ENG244881-ENG286313-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{35},No Response From Subnet Component,8{SFD2} ENG244881-ENG286314-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{36},No Response From Subnet Component,8{SFD2} ENG244881-ENG286315-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{37},No Response From Subnet Component,8{SFD2} ENG244881-ENG286316-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{38},No Response From Subnet Component,8{SFD2} ENG244881-ENG286317-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{39},No Response From Subnet Component,8{SFD2} ENG244881-ENG286318-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{4},No Response From Subnet Component,8{SFD2} ENG244881-ENG286319-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{40},No Response From Subnet Component,8{SFD2} ENG244881-ENG286320-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{41},No Response From Subnet Component,8{SFD2} ENG244881-ENG286321-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{42},No Response From Subnet Component,8{SFD2} ENG244881-ENG286322-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{43},No Response From Subnet Component,8{SFD2} ENG244881-ENG286323-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{44},No Response From Subnet Component,8{SFD2} ENG244881-ENG286324-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{45},No Response From Subnet Component,8{SFD2} ENG244881-ENG286325-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{46},No Response From Subnet Component,8{SFD2} ENG244881-ENG286326-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{47},No Response From Subnet Component,8{SFD2} ENG244881-ENG286327-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{48},No Response From Subnet Component,8{SFD2} ENG244881-ENG286328-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{49},No Response From Subnet Component,8{SFD2} ENG244881-ENG286329-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{5},No Response From Subnet Component,8{SFD2} ENG244881-ENG286330-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{50},No Response From Subnet Component,8{SFD2} ENG244881-ENG286331-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{51},No Response From Subnet Component,8{SFD2} ENG244881-ENG286332-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{52},No Response From Subnet Component,8{SFD2} ENG244881-ENG286333-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{53},No Response From Subnet Component,8{SFD2} ENG244881-ENG286334-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{54},No Response From Subnet Component,8{SFD2} ENG244881-ENG286335-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{55},No Response From Subnet Component,8{SFD2} ENG244881-ENG286336-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{56},No Response From Subnet Component,8{SFD2} ENG244881-ENG286337-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{57},No Response From Subnet Component,8{SFD2} ENG244881-ENG286338-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{58},No Response From Subnet Component,8{SFD2} ENG244881-ENG286339-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{59},No Response From Subnet Component,8{SFD2} ENG244881-ENG286340-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{6},No Response From Subnet Component,8{SFD2} ENG244881-ENG286341-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{60},No Response From Subnet Component,8{SFD2} ENG244881-ENG286342-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{61},No Response From Subnet Component,8{SFD2} ENG244881-ENG286343-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{62},No Response From Subnet Component,8{SFD2} ENG244881-ENG286344-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{63},No Response From Subnet Component,8{SFD2} ENG244881-ENG286345-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{64},No Response From Subnet Component,8{SFD2} ENG244881-ENG286346-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{65},No Response From Subnet Component,8{SFD2} ENG244881-ENG286347-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{7},No Response From Subnet Component,8{SFD2} ENG244881-ENG286348-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{8},No Response From Subnet Component,8{SFD2} ENG244881-ENG286349-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{9},No Response From Subnet Component,8{SFD2} ENG244881-ENG289614-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Retry_Timeout,No Response From Subnet Component,8{SFD2} ENG244881-ENG289615-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Sent_Time,No Response From Subnet Component,8{SFD2} ENG244881-ENG286353-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Algo_Time_Out,No Response From Subnet Component,8{SFD2} ENG244881-ENG286354-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_1,No Response From Subnet Component,8{SFD2} ENG244881-ENG289616-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_2,No Response From Subnet Component,8{SFD2} ENG244881-ENG286355-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_1,No Response From Subnet Component,8{SFD2} ENG244881-ENG286356-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_2,No Response From Subnet Component,8{SFD2} ENG244881-ENG286357-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_3,No Response From Subnet Component,8{SFD2} ENG244881-ENG286358-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_4,No Response From Subnet Component,8{SFD2} ENG244881-ENG286359-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Fahrzeugtyp,No Response From Subnet Component,8{SFD2} ENG244881-ENG286360-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Padding,No Response From Subnet Component,8{SFD2} ENG244881-ENG286361-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286362-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{01},No Response From Subnet Component,8{SFD2} ENG244881-ENG286363-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{2},No Response From Subnet Component,8{SFD2} ENG244881-ENG286364-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{3},No Response From Subnet Component,8{SFD2} ENG244881-ENG286365-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{4},No Response From Subnet Component,8{SFD2} ENG244881-ENG286366-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{5},No Response From Subnet Component,8{SFD2} ENG244881-ENG286367-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{6},No Response From Subnet Component,8{SFD2} ENG244881-ENG286368-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{7},No Response From Subnet Component,8{SFD2} ENG244881-ENG286369-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{8},No Response From Subnet Component,8{SFD2} ENG244881-ENG286370-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{9},No Response From Subnet Component,8{SFD2} ENG244881-ENG286371-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286372-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286373-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286374-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286375-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_{0},No Response From Subnet Component,8{SFD2} ENG244881-ENG286376-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286377-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ucPoly_FeatureNumber,No Response From Subnet Component,8{SFD2} ENG244881-ENG286378-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ul_CRC,No Response From Subnet Component,8{SFD2} ENG244881-ENG286380-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_0,No Response From Subnet Component,8{SFD2} ENG244881-ENG286381-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_1,No Response From Subnet Component,8{SFD2} ENG244881-ENG286382-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa Time_Diff_Range_{1},No Response From Subnet Component,8{SFD2} ENG244881-ENG286383-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa_Time_Diff_Range_{0},No Response From Subnet Component,8{SFD2} ENG263432-ENG142229-Regensensorik_Verbauund_ABT_Steuerung-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,3{SFD2} ENG263432-ENG141956-Regensensorik_Verbauund_ABT_Steuerung-Humidity sensor,not installed ,3{SFD2} ENG263432-ENG253444-Regensensorik_Verbauund_ABT_Steuerung-Light sensor,LIN_REGEN_LICHT_SENSOR ,3{SFD2} ENG263432-ENG253437-Regensensorik_Verbauund_ABT_Steuerung-rain sensor,not installed ,3{SFD2} ENG263432-ENG124476-Regensensorik_Verbauund_ABT_Steuerung-Sunlight photo sensor,not installed ,3{SFD2} ENG264033-ENG264176-RLFS_RLS Codierung (KII05)-Filterleerung bei Poti-Verstellung,On ,3{SFD2} ENG264033-ENG264051-RLFS_RLS Codierung (KII05)-Licht an bei Regen,Master steuert ,3{SFD2} ENG264033-ENG264182-RLFS_RLS Codierung (KII05)-Licht an über Geschwindigkeit,Ein / Slave steuert ,3{SFD2} ENG264033-ENG264183-RLFS_RLS Codierung (KII05)-Lichtschaltschwellen Kalibrierung,0% (Standard) ,3{SFD2} ENG264033-ENG159332-RLFS_RLS Codierung (KII05)-Parameter set,Parametersatz I ,3{SFD2} ENG264033-ENG264191-RLFS_RLS Codierung (KII05)-Regenerkennung bei Kl.15 aus,OFF ,3{SFD2} ENG264033-ENG264193-RLFS_RLS Codierung (KII05)-Regensensorbetrieb,OFF ,3{SFD2} ENG264033-ENG264273-RLFS_RLS Codierung (KII05)-Start-Up-Wipe,OFF ,3{SFD2} ENG264033-ENG264277-RLFS_RLS Codierung (KII05)-Transmission 550nm,75% Transmission ,3{SFD2} ENG264033-ENG264278-RLFS_RLS Codierung (KII05)-Transmission 880nm,40% Transmission ,3{SFD2} ENG264033-ENG264282-RLFS_RLS Codierung (KII05)-Wischeranlagentyp,LIN ,3{SFD2} ENG179054-ENG179160-RLFS_ZF_TRW-p_n_1st_wipe_threshold,No Response From Subnet Component,3{SFD2} ENG179054-ENG179161-RLFS_ZF_TRW-p_n_highspeed_wipe_threshold,No Response From Subnet Component,3{SFD2} ENG179054-ENG179162-RLFS_ZF_TRW-p_n_interval_wipe_threshold,No Response From Subnet Component,3{SFD2} ENG179054-ENG179163-RLFS_ZF_TRW-p_n_LIN_Filter,No Response From Subnet Component,3{SFD2} ENG179054-ENG179164-RLFS_ZF_TRW-p_n_permanent_wipe_threshold,No Response From Subnet Component,3{SFD2} ENG179054-ENG179165-RLFS_ZF_TRW-p_n_RsEmergencyReducePercent,No Response From Subnet Component,3{SFD2} ENG179054-ENG179166-RLFS_ZF_TRW-p_t_ParkPosition_SpeedReset,No Response From Subnet Component,3{SFD2} ENG179054-ENG179167-RLFS_ZF_TRW-p_t_ParkPosition_WipeTimeout,No Response From Subnet Component,3{SFD2} ENG179054-ENG263513-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Cycle,No Response From Subnet Component,3{SFD2} ENG179054-ENG263511-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Delay,No Response From Subnet Component,3{SFD2} ENG179054-ENG179170-RLFS_ZF_TRW-p_t_tunnel_wipe_delay,No Response From Subnet Component,3{SFD2} ENG179054-ENG179171-RLFS_ZF_TRW-p_t_tunnel_wipe_window,No Response From Subnet Component,3{SFD2} ENG179054-ENG179172-RLFS_ZF_TRW-pa_lx_tunnel_light_on,No Response From Subnet Component,3{SFD2} ENG179054-ENG179173-RLFS_ZF_TRW-pa_n_wisch_max_2,No Response From Subnet Component,3{SFD2} ENG179054-ENG179174-RLFS_ZF_TRW-pa_t_tunnel_delay_decrement,No Response From Subnet Component,3{SFD2} ENG179054-ENG179175-RLFS_ZF_TRW-pa_t_tunnel_delay_max,No Response From Subnet Component,3{SFD2} ENG179054-ENG179176-RLFS_ZF_TRW-Pa_t_tunnel_delay_on,No Response From Subnet Component,3{SFD2} ENG179054-ENG179177-RLFS_ZF_TRW-pa_t_tunnel_delay_step,No Response From Subnet Component,3{SFD2} ENG179054-ENG179178-RLFS_ZF_TRW-pa_v_RsActivationSpeed,No Response From Subnet Component,3{SFD2} ENG179054-ENG179179-RLFS_ZF_TRW-pa_v_wisch_max_1,No Response From Subnet Component,3{SFD2} ENG179054-ENG179180-RLFS_ZF_TRW-pa_v_wisch_max_2,No Response From Subnet Component,3{SFD2} ENG122927-RLS_close_glazing,No Response From Subnet Component,3{SFD2} ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,No Response From Subnet Component,3{SFD2} ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,No Response From Subnet Component,3{SFD2} ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,No Response From Subnet Component,3{SFD2} ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,No Response From Subnet Component,3{SFD2} ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,No Response From Subnet Component,3{SFD2} ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,No Response From Subnet Component,3{SFD2} ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,No Response From Subnet Component,3{SFD2} ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,No Response From Subnet Component,3{SFD2} ENG122929-RLS_LIN_Communication,No Response From Subnet Component,3{SFD2} ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,No Response From Subnet Component,3{SFD2} ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,No Response From Subnet Component,3{SFD2} ENG122930-RLS_tunel_gateway_recognize,No Response From Subnet Component,3{SFD2} ENG122935-RLS_Washer_Front,No Response From Subnet Component,3{SFD2} ENG122926-RLS_wiper_position_parking,No Response From Subnet Component,3{SFD2} ENG253157-roof_module,installed ,1{SFD2} ENG253336-MAS10512-Schiebedach_ZV-Sunroof module MD1,not installed ,6{SFD2} ENG253336-ENG260428-Schiebedach_ZV-dachrollo_2_verbaut,not installed ,6{SFD2} ENG253336-ENG258762-Schiebedach_ZV-dachrollo_verbaut,not installed ,6{SFD2} ENG253336-ENG261040-Schiebedach_ZV-Komfortbedienung_reichweitenbegrenzung_verdeck,not active ,6{SFD2} ENG253336-ENG259091-Schiebedach_ZV-Komfortbedienung_verdecktaste_aktiv,not active ,6{SFD2} ENG253336-ENG149217-Schiebedach_ZV-SAD_Komfort_oeffnen,not active ,6{SFD2} ENG253336-ENG369659-Schiebedach_ZV-SAD_Komfort_oeffnungs_modus,tilting ,6{SFD2} ENG253336-ENG149216-Schiebedach_ZV-SAD_Komfort_schliessen,not active ,6{SFD2} ENG253336-ENG259548-Schiebedach_ZV-SAD_MD3,not active ,6{SFD2} ENG253336-ENG259227-Schiebedach_ZV-SAD_t_Freigabe_eFH,600 s,6{SFD2} ENG253336-ENG258522-Schiebedach_ZV-schiebedach_2_verbaut,not installed ,6{SFD2} ENG253012-ENG298118-Schiebetür-p_n_eRWK_Abbruchblinken_Blinkzyklen,3 ,14{SFD2} ENG253012-ENG298119-Schiebetür-p_n_eRWK_Mindestanzahl_Oeffnungsblinken,2 ,14{SFD2} ENG253012-ENG298120-Schiebetür-p_n_Sbt_Crashred_Wdh,10 ,14{SFD2} ENG253012-ENG298121-Schiebetür-p_t_Abbruchblinken_eRWK_Hellphase,50 %,14{SFD2} ENG253012-ENG298122-Schiebetür-p_t_Abbruchblinken_eRWK_Periodendauer,1000 ms,14{SFD2} ENG253012-ENG298123-Schiebetür-p_t_Anf_Entr_Sbt_Timeout,10.00 s,14{SFD2} ENG253012-ENG298125-Schiebetür-p_t_eRWK_Oeffnungsblinken_Hellphase,50 %,14{SFD2} ENG253012-ENG298126-Schiebetür-p_t_eRWK_Oeffnungsblinken_max,10 s,14{SFD2} ENG253012-ENG298127-Schiebetür-p_t_eRWK_Oeffnungsblinken_Periodendauer,1000 ms,14{SFD2} ENG253012-ENG298128-Schiebetür-p_t_KiSi_Fkt_Bel_Timeout,600 s,14{SFD2} ENG253012-ENG298130-Schiebetür-p_t_Sbt_Verzoegerung_Nachverriegelung,0 ms,14{SFD2} ENG253012-ENG298132-Schiebetür-p_t_ZV_eKiSi_gesperrt,300 ms,14{SFD2} ENG253012-ENG298133-Schiebetür-p_t_ZV_eRWK_Oeffnungsblinken_Mindest_Dauer,1.00 s,14{SFD2} ENG253012-ENG298134-Schiebetür-p_t_ZV_FFB_Schiebetuer_Verzoegerung,800 ms,14{SFD2} ENG253238-ENG258554-Schluesselkonfiguration-Fahrzeugplattform_MEB_aktiv,not activated ,1{SFD2} ENG253238-ENG258470-Schluesselkonfiguration-Kessy_UWB_Frequenzband_a_aktiv,activated ,1{SFD2} ENG253238-ENG259650-Schluesselkonfiguration-Kessy_UWB_Frequenzband_b_aktiv,activated ,1{SFD2} ENG253238-ENG261161-Schluesselkonfiguration-Kessy_UWB_Frequenzband_c_aktiv,activated ,1{SFD2} ENG253118-IDE02851-Schlüsselpositionsnachbildung (SPN)-S-contact shut-off after timeout,Yes ,31{SFD2} ENG253118-ENG126943-Schlüsselpositionsnachbildung (SPN)-Display_duration_emergency_off,3000 ms,31{SFD2} ENG253118-ENG126944-Schlüsselpositionsnachbildung (SPN)-Display_duration_error_mode_2_SPN,10 s,31{SFD2} ENG253118-ENG277093-Schlüsselpositionsnachbildung (SPN)-Evaluation_Klemmenkoordinator,Yes ,31{SFD2} ENG253118-ENG126945-Schlüsselpositionsnachbildung (SPN)-min_time_for_Terminal_50_request,300 ms,31{SFD2} ENG253118-ENG129003-Schlüsselpositionsnachbildung (SPN)-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,31{SFD2} ENG253118-ENG253448-Schlüsselpositionsnachbildung (SPN)-Number_of_ZAT_activations_to_fault,10 ,31{SFD2} ENG253118-ENG126939-Schlüsselpositionsnachbildung (SPN)-rpm_threshold_engine_runnning,100 /min,31{SFD2} ENG253118-ENG126946-Schlüsselpositionsnachbildung (SPN)-Terminal_S_Timeout,30 min,31{SFD2} ENG253118-ENG258251-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_clampcoordinator_trigger,1000 ms,31{SFD2} ENG253118-ENG126947-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_ignition_trigger,35 s,31{SFD2} ENG253224-ENG258215-Seat_pneumatics-Bcm_response_timer,350 ms,8{SFD2} ENG253224-ENG259532-Seat_pneumatics-Installation_seat_pneumatics,not installed ,8{SFD2} ENG253224-ENG260752-Seat_pneumatics-Installation_side_support,installed ,8{SFD2} ENG253224-ENG259164-Seat_pneumatics-Massage_intensity_level,0 ,8{SFD2} ENG253224-ENG259581-Seat_pneumatics-Massage_programs,0 ,8{SFD2} ENG253224-ENG259920-Seat_pneumatics-occupancy_passenger_side,5 ,8{SFD2} ENG253224-ENG259260-Seat_pneumatics-Popup_knockout_time,25 min,8{SFD2} ENG253224-ENG259408-Seat_pneumatics-Seat_pneumatics_adjustment_passenger_side,not installed ,8{SFD2} ENG253224-ENG259024-Seat_pneumatics-Velocity_limit,10 km/h,8{SFD2} ENG253224-ENG260841-Seat_pneumatics-Velocity_min,10 km/h,8{SFD2} ENG253090-ENG261034-Seat_pneumatics_massage_program_allocation-massage_program_allocation_01,1 ,6{SFD2} ENG253090-ENG258845-Seat_pneumatics_massage_program_allocation-massage_program_allocation_02,2 ,6{SFD2} ENG253090-ENG258718-Seat_pneumatics_massage_program_allocation-massage_program_allocation_03,5 ,6{SFD2} ENG253090-ENG260661-Seat_pneumatics_massage_program_allocation-massage_program_allocation_04,1 ,6{SFD2} ENG253090-ENG258113-Seat_pneumatics_massage_program_allocation-massage_program_allocation_05,2 ,6{SFD2} ENG253090-ENG259726-Seat_pneumatics_massage_program_allocation-massage_program_allocation_06,5 ,6{SFD2} ENG253283-ENG258595-Signal_mapping_tsg-verzoegerung_swc_signale,0 ms,4{SFD2} ENG253283-ENG260734-Signal_mapping_tsg-Zeitbasis_0,50 ms,4{SFD2} ENG253283-ENG260177-Signal_mapping_tsg-Zeitbasis_1,250 ms,4{SFD } ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48{SFD } ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48{SFD } ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48{SFD } ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48{SFD } ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48{SFD } ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48{SFD } ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48{SFD } ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48{SFD } ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48{SFD } ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,5000 ms,48{SFD } ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,5000 ms,48{SFD } ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,400 ms,48{SFD } ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48{SFD } ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48{SFD } ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48{SFD } ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48{SFD } ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48{SFD } ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48{SFD } ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48{SFD } ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48{SFD } ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48{SFD } ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48{SFD } ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48{SFD } ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48{SFD } ENG153742-ENG289599-SMLS_konfig_entw-lrh_taster_haengt_aus,50 ms,48{SFD } ENG153742-ENG289600-SMLS_konfig_entw-lrh_taster_haengt_ein,60 s,48{SFD } ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,100 ms,48{SFD } ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,250 ,48{SFD } ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48{SFD } ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48{SFD } ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48{SFD } ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48{SFD } ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,200 ms,48{SFD } ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,200 ms,48{SFD } ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,2000 ms,48{SFD } ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,1000 ms,48{SFD } ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,30 s,48{SFD } ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48{SFD } ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48{SFD } ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,5.0 s,48{SFD } ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,300 s,48{SFD } ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48{SFD } ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48{SFD } ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48{SFD } ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48{SFD } ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48{SFD } ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48{SFD } ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48{SFD2} ENG141635-ENG260621-Spiegelverstellung-cp_Komfortbedienung_Spiegel_anklappen,not active ,3{SFD2} ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,not active ,3{SFD2} ENG141635-ENG258306-Spiegelverstellung-Menuesteuerung_Spiegelabsenkung,not active ,3{SFD2} ENG141635-ENG259505-Spiegelverstellung-Menuesteuerung_synchrone_Spiegelverstellung,active ,3{SFD2} ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,not active ,3{SFD2} ENG141635-ENG260424-Spiegelverstellung-Spiegelanklappen_bei_Verriegelung,not active ,3{SFD2} ENG141635-ENG260252-Spiegelverstellung-Spiegelverstellung_Synchron,active ,3{SFD2} ENG253125-ENG260641-SRA-p_sra_bcm_temperaturgrenze,0 °C,8{SFD2} ENG253125-ENG260115-SRA-p_sra_geschwindigkeitsgrenze,0 km/h,8{SFD2} ENG253125-ENG259607-SRA-p_sra_nach_t_frontwaschendauer,0 ms,8{SFD2} ENG253125-ENG259677-SRA-p_sra_obere_aussentemperaturgrenze,-100 °C,8{SFD2} ENG253125-ENG261148-SRA-p_sra_untere_aussentemperaturgrenze,-100 °C,8{SFD2} ENG253125-ENG260015-SRA-p_t_sra_ueberlast,0 s,8{SFD2} ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10{SFD2} ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10{SFD2} ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10{SFD2} ENG302681-ENG260527-Störungsmeldungen_Licht_Wischwasch-p_Lichtrouter_meldung_ausmaskiert,00 ,15{SFD2} ENG302681-ENG260368-Störungsmeldungen_Licht_Wischwasch-p_t_LDS_defekt_meldung,10 s,15{SFD2} ENG302681-ENG260726-Störungsmeldungen_Licht_Wischwasch-p_t_RLS_Meldung,2000 ms,15{SFD2} ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0,0 ms,22{SFD2} ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22{SFD2} ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22{SFD2} ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22{SFD2} ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22{SFD2} ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22{SFD2} ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22{SFD2} ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22{SFD2} ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22{SFD2} ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22{SFD2} ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22{SFD2} ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0,100.0 %,22{SFD2} ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22{SFD2} ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10,0.0 %,22{SFD2} ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22{SFD2} ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22{SFD2} ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22{SFD2} ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22{SFD2} ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22{SFD2} ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22{SFD2} ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22{SFD2} ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22{SFD2} ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.04 s,21{SFD2} ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.04 s,21{SFD2} ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.04 s,21{SFD2} ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,21{SFD2} ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.08 s,21{SFD2} ENG141663-ENG258796-Suchbeleuchtung_allgemein-Eingabemedium Suchbeleuchtung von ALM,not active ,21{SFD2} ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21{SFD2} ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,6.9 s,21{SFD2} ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,1.8 s,21{SFD2} ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe,not active ,21{SFD2} ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21{SFD2} ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung,active ,21{SFD2} ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21{SFD2} ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.08 s,21{SFD2} ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21{SFD2} ENG141663-ENG260116-Suchbeleuchtung_allgemein-Suchbeleuchtung PSO2.0 Teilnehmer,active ,21{SFD2} ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl,Fotosensor_Kombi ,21{SFD2} ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,21{SFD2} ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21{SFD2} ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 ,21{SFD2} ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0,0 ,22{SFD2} ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1,50 ,22{SFD2} ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10,0 ,22{SFD2} ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2,100 ,22{SFD2} ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3,200 ,22{SFD2} ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4,253 ,22{SFD2} ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5,0 ,22{SFD2} ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6,0 ,22{SFD2} ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7,0 ,22{SFD2} ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8,0 ,22{SFD2} ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9,0 ,22{SFD2} ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0,0 lx,22{SFD2} ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22{SFD2} ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10,0 lx,22{SFD2} ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22{SFD2} ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 lx,22{SFD2} ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 lx,22{SFD2} ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 lx,22{SFD2} ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6,0 lx,22{SFD2} ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7,0 lx,22{SFD2} ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8,0 lx,22{SFD2} ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9,0 lx,22{SFD2} ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0,0 ms,22{SFD2} ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22{SFD2} ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22{SFD2} ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22{SFD2} ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22{SFD2} ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22{SFD2} ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22{SFD2} ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22{SFD2} ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22{SFD2} ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22{SFD2} ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22{SFD2} ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0,0.0 %,22{SFD2} ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22{SFD2} ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10,100.0 %,22{SFD2} ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22{SFD2} ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22{SFD2} ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22{SFD2} ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22{SFD2} ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22{SFD2} ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22{SFD2} ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22{SFD2} ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22{SFD2} ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 ,12{SFD2} ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 ,12{SFD2} ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 ,12{SFD2} ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 ,12{SFD2} ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 ,12{SFD2} ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 ,12{SFD2} ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0,10 ,12{SFD2} ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1,10 ,12{SFD2} ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2,100 ,12{SFD2} ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3,150 ,12{SFD2} ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4,220 ,12{SFD2} ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5,253 ,12{SFD2} ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0,0 lx,10{SFD2} ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1,8 lx,10{SFD2} ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2,200 lx,10{SFD2} ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3,300 lx,10{SFD2} ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4,500 lx,10{SFD2} ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0,16.0 ,10{SFD2} ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1,16.0 ,10{SFD2} ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2,100.0 ,10{SFD2} ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3,100.0 ,10{SFD2} ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4,100.0 ,10{SFD2} ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0,0 lx,10{SFD2} ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,8 lx,10{SFD2} ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2,220 lx,10{SFD2} ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3,300 lx,10{SFD2} ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4,500 lx,10{SFD2} ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0,6.0 ,10{SFD2} ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,6.0 ,10{SFD2} ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,50.0 ,10{SFD2} ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,50.0 ,10{SFD2} ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,50.0 ,10{SFD2} ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0,0 ,12{SFD2} ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1,10 ,12{SFD2} ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,100 ,12{SFD2} ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,150 ,12{SFD2} ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4,220 ,12{SFD2} ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5,253 ,12{SFD2} ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,3.0 %,12{SFD2} ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,3.0 %,12{SFD2} ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,11.0 %,12{SFD2} ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %,12{SFD2} ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %,12{SFD2} ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5,100.0 %,12{SFD2} ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 ,10{SFD2} ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 ,10{SFD2} ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 ,10{SFD2} ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 ,10{SFD2} ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 ,10{SFD2} ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 %,10{SFD2} ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 %,10{SFD2} ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 %,10{SFD2} ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 %,10{SFD2} ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 %,10{SFD2} ENG253155-ENG115658-Suchbeleuchtung_KL_58xs_max-x0,0 lx,8{SFD2} ENG253155-ENG101574-Suchbeleuchtung_KL_58xs_max-X1,8 lx,8{SFD2} ENG253155-ENG99557-Suchbeleuchtung_KL_58xs_max-X2,50 lx,8{SFD2} ENG253155-ENG102140-Suchbeleuchtung_KL_58xs_max-X3,500 lx,8{SFD2} ENG253155-ENG115659-Suchbeleuchtung_KL_58xs_max-y0,100.0 ,8{SFD2} ENG253155-ENG99777-Suchbeleuchtung_KL_58xs_max-Y1,100.0 ,8{SFD2} ENG253155-ENG100480-Suchbeleuchtung_KL_58xs_max-Y2,100.0 ,8{SFD2} ENG253155-ENG100773-Suchbeleuchtung_KL_58xs_max-Y3,100.0 ,8{SFD2} ENG253251-ENG115658-Suchbeleuchtung_KL_58xs_min-x0,0 lx,8{SFD2} ENG253251-ENG101574-Suchbeleuchtung_KL_58xs_min-X1,8 lx,8{SFD2} ENG253251-ENG99557-Suchbeleuchtung_KL_58xs_min-X2,50 lx,8{SFD2} ENG253251-ENG102140-Suchbeleuchtung_KL_58xs_min-X3,500 lx,8{SFD2} ENG253251-ENG115659-Suchbeleuchtung_KL_58xs_min-y0,6.0 ,8{SFD2} ENG253251-ENG99777-Suchbeleuchtung_KL_58xs_min-Y1,6.0 ,8{SFD2} ENG253251-ENG100480-Suchbeleuchtung_KL_58xs_min-Y2,50.0 ,8{SFD2} ENG253251-ENG100773-Suchbeleuchtung_KL_58xs_min-Y3,50.0 ,8{SFD2} ENG153970-ENG115658-Suchbeleuchtung_KL_58xs_PWM-x0,0.0 ,6{SFD2} ENG153970-ENG101574-Suchbeleuchtung_KL_58xs_PWM-X1,50.0 ,6{SFD2} ENG153970-ENG99557-Suchbeleuchtung_KL_58xs_PWM-X2,100.0 ,6{SFD2} ENG153970-ENG115659-Suchbeleuchtung_KL_58xs_PWM-y0,0.0 %,6{SFD2} ENG153970-ENG99777-Suchbeleuchtung_KL_58xs_PWM-Y1,50.0 %,6{SFD2} ENG153970-ENG100480-Suchbeleuchtung_KL_58xs_PWM-Y2,100.0 %,6{SFD2} ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 ,10{SFD2} ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 ,10{SFD2} ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 ,10{SFD2} ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 ,10{SFD2} ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 ,10{SFD2} ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 %,10{SFD2} ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 %,10{SFD2} ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 %,10{SFD2} ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 %,10{SFD2} ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 %,10{SFD2} ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0,0 lx,8{SFD2} ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1,8 lx,8{SFD2} ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2,50 lx,8{SFD2} ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3,500 lx,8{SFD2} ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0,100.0 ,8{SFD2} ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1,100.0 ,8{SFD2} ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2,100.0 ,8{SFD2} ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3,100.0 ,8{SFD2} ENG253314-ENG115658-Suchbeleuchtung_KL_58xt_min-x0,0 lx,8{SFD2} ENG253314-ENG101574-Suchbeleuchtung_KL_58xt_min-X1,8 lx,8{SFD2} ENG253314-ENG99557-Suchbeleuchtung_KL_58xt_min-X2,50 lx,8{SFD2} ENG253314-ENG102140-Suchbeleuchtung_KL_58xt_min-X3,500 lx,8{SFD2} ENG253314-ENG115659-Suchbeleuchtung_KL_58xt_min-y0,6.0 ,8{SFD2} ENG253314-ENG99777-Suchbeleuchtung_KL_58xt_min-Y1,6.0 ,8{SFD2} ENG253314-ENG100480-Suchbeleuchtung_KL_58xt_min-Y2,50.0 ,8{SFD2} ENG253314-ENG100773-Suchbeleuchtung_KL_58xt_min-Y3,50.0 ,8{SFD2} ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 ,6{SFD2} ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 ,6{SFD2} ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 ,6{SFD2} ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0,0.0 %,6{SFD2} ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1,50.0 %,6{SFD2} ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2,100.0 %,6{SFD2} ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,24{SFD2} ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,24{SFD2} ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,24{SFD2} ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,24{SFD2} ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,24{SFD2} ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1021 lx,24{SFD2} ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,24{SFD2} ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,160 ,24{SFD2} ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,300 ,24{SFD2} ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,380 ,24{SFD2} ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,440 ,24{SFD2} ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,24{SFD2} ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ,10{SFD2} ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,100 ,10{SFD2} ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,150 ,10{SFD2} ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,200 ,10{SFD2} ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,255 ,10{SFD2} ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,0.0 %,10{SFD2} ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 %,10{SFD2} ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 %,10{SFD2} ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 %,10{SFD2} ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 %,10ENG286149-ENG286256-Switch Panel-Drive Select,No Response From Subnet Component,10ENG286149-ENG286257-Switch Panel-ESC_Off-Taster,No Response From Subnet Component,10ENG286149-ENG286389-Switch Panel-WBT,No Response From Subnet Component,10ENG126938-Terminal_15_adaption_body_control_module,Default ,1{SFD2} ENG344887-total_distance_pass_jump,activated ,1{SFD2} ENG249751-Two_keys,active ,3{SFD2} ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3{SFD2} ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3{SFD2} ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3{SFD2} ENG252991-Vehicle configuration,not activated ,1{SFD2} ENG253245-verbauliste_subcan,not installed ,4{SFD2} ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,6{SFD2} ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,6{SFD2} ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,6{SFD2} ENG141634-ENG116655-Verdecksteuergeraet-Kessy Komfortbedienung Reichweitenbegrenzung,active ,6{SFD2} ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,6{SFD2} ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,6{SFD2} ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,6{SFD2} ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,6{SFD2} ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active ,6{SFD2} ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,6{SFD2} ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,6{SFD2} ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,6{SFD2} ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,6{SFD2} ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,6{SFD2} ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,6{SFD2} ENG253327-ENG261016-Verlassenswarnung und Standlichtnachlauf-Ausgabeverzögerung der Verlassenswarnung,1.4 s,8{SFD2} ENG253327-ENG261326-Verlassenswarnung und Standlichtnachlauf-Entprellung Degradierte Verlassenswarnung,1.6 s,8{SFD2} ENG253327-ENG259356-Verlassenswarnung und Standlichtnachlauf-Entprellung Verlassenswarnung,5 min,8{SFD2} ENG253327-ENG258196-Verlassenswarnung und Standlichtnachlauf-Fahrzeuggeschwindigkeit zur Stillstandserkennung,3 km/h,8{SFD2} ENG253327-ENG116720-Verlassenswarnung und Standlichtnachlauf-Standlicht-Nachlaufzeit,30 min,8{SFD2} ENG253327-ENG346085-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit degradierte VLW,not active ,8{SFD2} ENG253327-ENG346086-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Fehlermeldung Gurt,active ,8{SFD2} ENG253327-ENG346087-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Fehlermeldung Sitz,active ,8{SFD2} ENG253327-ENG346088-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Fehlermeldung Tür,active ,8{SFD2} ENG253327-ENG277124-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Standlichtnachlauf,active ,8{SFD2} ENG253327-ENG277125-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Verlassenswarnung,not_active ,8{SFD2} ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 00 00 ,28{SFD2} ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 00 00 ,28{SFD2} ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 00 00 ,28{SFD2} ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 00 00 ,28{SFD2} ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,28{SFD2} ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,28{SFD2} ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,28{SFD2} ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,28{SFD2} ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,28{SFD2} ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,28{SFD2} ENG159625-ENG142259-Virtual pedal-Kick_and_close,not installed ,8{SFD2} ENG159625-ENG286258-Virtual pedal-Kick_and_close_HBFS,not installed ,8{SFD2} ENG159625-ENG286259-Virtual pedal-Kick_and_close_HFS,not installed ,8{SFD2} ENG159625-ENG115869-Virtual pedal-Virtuelles_Pedal,not active ,8{SFD2} ENG159625-ENG259761-Virtual pedal-Virtuelles_Pedal_HMI_Auswahl,not active ,8{SFD2} ENG159625-ENG126611-Virtual pedal-virtuelles_pedal_HMI_einstellbar,not active ,8{SFD2} ENG253214-ENG261193-Virtuelles_Pedal_Global-Bremslichtquittierung,not active ,4{SFD2} ENG253214-ENG261115-Virtuelles_Pedal_Global-Bremslichtquittierung bei offenem Heckdeckel bzw. -klappe,not active ,4{SFD2} ENG253214-ENG259151-Virtuelles_Pedal_Global-Quittierungslicht_Max,0 ms,4{SFD2} ENG253214-ENG273673-Virtuelles_Pedal_Global-Sperrzeit_Bewertung_Spotlight,0 ms,4{SFD2} ENG253214-ENG286384-Virtuelles_Pedal_Global-Virtuelles_Pedal_HBFS_Verbau,not installed ,4{SFD2} ENG253214-ENG286385-Virtuelles_Pedal_Global-Virtuelles_Pedal_HFS_Verbau,not installed ,4{SFD2} ENG253214-ENG142257-Virtuelles_Pedal_Global-Virtuelles_Pedal_Verbau,not installed ,4{SFD2} ENG154424-IDE05534-Waschen-Headlamp washer system,not installed ,8{SFD2} ENG154424-ENG154706-Waschen-Mindestwaschzeit_Frontwischer,0 ms,8{SFD2} ENG154424-ENG249933-Waschen-RVC_Speed_Hysteresis,5 km/h,8{SFD2} ENG154424-ENG249934-Waschen-RVC_Speed_max,50 km/h,8{SFD2} ENG154424-ENG260022-Waschen-RVC_Waschen,not installed ,8{SFD2} ENG154424-ENG249936-Waschen-RVC_Waschen_HMI,not active ,8{SFD2} ENG154424-ENG260162-Waschen-Time_RVC_cleaning_Pumpe_active_BCM,1.5 s,8{SFD2} ENG154424-ENG281090-Waschen-Transportmodus_SRA,not active ,8{SFD2} ENG154424-ENG258116-Waschen-Waschen_ohne_KL15,not active ,8{SFD2} ENG154424-ENG260669-Waschen-Wiederstart_Restfunktionen,not active ,8{SFD2} ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8{SFD2} ENG249803-ENG261175-Waschen_Parameter-pa_t_wasch_min_heck,1200 ms,8{SFD2} ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8{SFD2} ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8{SFD2} ENG253306-ENG259934-Wascher_pumpe-p_n_Spielschutz_Wascherpumpen,10 ,4{SFD2} ENG253306-ENG258230-Wascher_pumpe-p_t_Delay_Frontwaschen,1500 ms,4{SFD2} ENG253306-ENG260892-Wascher_pumpe-p_t_DWP_Blockiererkennung,100 ms,4{SFD2} ENG253306-ENG259530-Wascher_pumpe-p_t_Wascherpumpe_max,10 s,4{SFD2} ENG253279-ENG126852-Wisch_geschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,No Response From Subnet Component,4{SFD2} ENG253279-ENG126853-Wisch_geschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,No Response From Subnet Component,4{SFD2} ENG253279-ENG116699-Wisch_geschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,No Response From Subnet Component,4{SFD2} ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,No Response From Subnet Component,4{SFD2} ENG253287-ENG261269-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_defined_rpm,500.00 ,11{SFD2} ENG253287-ENG258373-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOSignal_Timer1,3000 ms,11{SFD2} ENG253287-ENG258259-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOsignal_Timer2,3000 ms,11{SFD2} ENG281049-ENG395058-Zündungswarnung und Antrieb-Aktiv-Warnung-Ausgabe erweiterte AAW,active ,8{SFD2} ENG281049-ENG263583-Zündungswarnung und Antrieb-Aktiv-Warnung-Ausgabe MoLaWa_AAW,active ,8{SFD2} ENG281049-ENG345659-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellung VLW in N,1.4 s,8{SFD2} ENG281049-ENG263581-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellung_MoLaWa,0.8 ,8{SFD2} ENG281049-ENG263504-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswechsel Belegt zu nicht Belegt,0.0 s,8{SFD2} ENG281049-ENG281097-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswecsel nicht Belegt zu Belegt,0.0 s,8{SFD2} ENG281049-ENG395232-Zündungswarnung und Antrieb-Aktiv-Warnung-Timer erweiterte AAW,600 s,8{SFD2} ENG281049-ENG395233-Zündungswarnung und Antrieb-Aktiv-Warnung-Timer erweiterte AAW Standzeit,7200 s,8{SFD2} ENG281049-ENG395234-Zündungswarnung und Antrieb-Aktiv-Warnung-Timer erweiterte AAW Zykluszeit,600 s,8{SFD2} ENG281049-ENG263531-Zündungswarnung und Antrieb-Aktiv-Warnung-Unterdrückung der Zündungswarnung,not_active ,8{SFD2} ENG141651-ENG258596-ZV allgemein-abgesichertes_Safen_aktiv,not active ,6{SFD2} ENG141651-ENG260901-ZV allgemein-Bedienstellen_tankklappenentriegelung,via_ZV ,6{SFD2} ENG141651-ENG173067-ZV allgemein-central_locking_system_deadlock_mechanism,safe_function_not_active ,6{SFD2} ENG141651-ENG345672-ZV allgemein-FFB_kessy_verr_sperren_bei_nicht_eingelegter_p_stellung,active ,6{SFD2} ENG141651-ENG259465-ZV allgemein-Funk_bei_Kl15_ein,not active ,6{SFD2} ENG141651-ENG260878-ZV allgemein-kein_Safe_bei_IRUE_Abwahl,not active ,6{SFD2} ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,6{SFD2} ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,6{SFD2} ENG141651-ENG261270-ZV allgemein-rollsicherung_ZV_plausibilisierung,not active ,6{SFD2} ENG141651-ENG260049-ZV allgemein-Rueckmeldung_TKL,active ,6{SFD2} ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale_Entriegelung ,6{SFD2} ENG141651-ENG258274-ZV allgemein-ZV_Verriegelung_ueber_SZ_bei_offener_FT_zulassen,not active ,6{SFD2} ENG141653-ENG258843-ZV Heck-Direktauswurf_heckdeckel,not active ,6{SFD2} ENG141653-ENG442356-ZV Heck-eingeschraenkte_Freigabe_HD_Innentaste,not active ,6{SFD2} ENG141653-ENG260874-ZV Heck-Elektrische_Laderaumabdeckung_Aktiviert,not installed ,6{SFD2} ENG141653-ENG259200-ZV Heck-Elektrische_Laderaumabdeckung_verbaut,not installed ,6{SFD2} ENG141653-ENG263593-ZV Heck-HD_Innentaster_bei_ext_verriegelt,not active ,6{SFD2} ENG141653-ENG259391-ZV Heck-HDF_IT_direkt,not installed ,6{SFD2} ENG141653-ENG260877-ZV Heck-Heck_autolock,active ,6{SFD2} ENG141653-ENG259349-ZV Heck-Heck_ohne_softtouch,not active ,6{SFD2} ENG141653-ENG260581-ZV Heck-Heckschloss_mit_VR,Yes ,6{SFD2} ENG141653-ENG260712-ZV Heck-Heckschloss_rastengesteuert,contact_control ,6{SFD2} ENG141653-ENG259467-ZV Heck-Heckschloss_Typ,1 or 2 notch rear actuator ,6{SFD2} ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.80 s,6{SFD2} ENG141653-ENG248302-ZV Heck-unlocking_trunk_lid_via_double_actuation,not active ,6{SFD2} ENG141653-ENG140934-ZV Heck-valet_parking,not active ,6{SFD2} ENG141653-ENG258713-ZV Heck-ZV_entriegelt_heckdeckel,active ,6{SFD2} ENG253049-ENG260834-ZV Komfort_Fensterheber-Ausstiegspanel_Automatiklauf,not active ,8{SFD2} ENG253049-ENG261010-ZV Komfort_Fensterheber-BAP_komfortschließen_brasilien,not active ,8{SFD2} ENG253049-ENG259807-ZV Komfort_Fensterheber-el_fh_hinten,not installed ,8{SFD2} ENG253049-ENG116663-ZV Komfort_Fensterheber-Fahrertuerbedienung Fensterheber oeffnen,active ,8{SFD2} ENG253049-ENG259968-ZV Komfort_Fensterheber-Fensterheber_freigabnachlauf_busruhe,active ,8{SFD2} ENG253049-ENG258141-ZV Komfort_Fensterheber-Freigabenachlauf_abbruch_bei_tueroeffnen,active ,8{SFD2} ENG253049-ENG260611-ZV Komfort_Fensterheber-KL_15_aus_fh_freigabenachlauf,active ,8{SFD2} ENG253049-ENG159639-ZV Komfort_Fensterheber-Komfort_oeffnen,not active ,8{SFD2} ENG253049-ENG273538-ZV Komfort_Fensterheber-Komfort_schließen,active ,8{SFD2} ENG253049-ENG258991-ZV Komfort_Fensterheber-Komfortbedienung_ffb_aktiv,active ,8{SFD2} ENG253049-ENG258982-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_funk,active ,8{SFD2} ENG253049-ENG260329-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_sz,not active ,8{SFD2} ENG253049-ENG259463-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_fh_taster,active ,8{SFD2} ENG253049-ENG259865-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_funk,active ,8{SFD2} ENG253049-ENG149198-ZV Komfort_Fensterheber-Komfortbedienung_global,active ,8{SFD2} ENG253049-ENG260481-ZV Komfort_Fensterheber-komfortbedienung_global_hmi,adjustable ,8{SFD2} ENG253049-ENG259275-ZV Komfort_Fensterheber-Komfortfunktion_im_Transportmodus,not active ,8{SFD2} ENG253049-ENG116642-ZV Komfort_Fensterheber-Komfortoeffnen nur FH Fahrertuer,not active ,8{SFD2} ENG253049-ENG155244-ZV Komfort_Fensterheber-Komfortschliessen_Brasilien,not active ,8{SFD2} ENG263451-ENG252093-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abbruchblinken_Heck,not active ,7{SFD2} ENG263451-ENG248659-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,7{SFD2} ENG263451-ENG248660-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,7{SFD2} ENG263451-ENG248661-ZV NFZ - Elektronische Rueckwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,7{SFD2} ENG263451-ENG248662-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,7{SFD2} ENG263451-ENG263534-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Oeffnungsblinken_Heckauswurf,not active ,7{SFD2} ENG263451-ENG248664-ZV NFZ - Elektronische Rueckwandklappe-eRWK_ohne_FFB_HDF,not active ,7{SFD2} ENG263451-ENG252079-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Pruefung_Umfelderkennung,1.60 s,7{SFD2} ENG263451-ENG252068-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Start_Umfelderkennung,2.00 s,7{SFD2} ENG263451-ENG281092-ZV NFZ - Elektronische Rueckwandklappe-pa_eRWK_KST_Sonderzustand_Anf,not active ,7{SFD2} ENG263491-ENG263568-ZV NFZ - Tueren HBFS-Schiebetuer HBFS,Mechanical ,2{SFD2} ENG263491-ENG258359-ZV NFZ - Tueren HBFS-Schlosstyp HBFS,OBWr_Schloss ,2{SFD2} ENG263491-ENG263538-ZV NFZ - Tueren HBFS-Tuerkontaktmodul HBFS,Yes ,2{SFD2} ENG263438-ENG263586-ZV NFZ - Tueren HFS-Schiebetuer HFS,Mechanical ,2{SFD2} ENG263438-ENG258315-ZV NFZ - Tueren HFS-Schlosstyp HFS,OBWr_Schloss ,2{SFD2} ENG263438-ENG263572-ZV NFZ - Tueren HFS-Tuerkontaktmodul HFS,Yes ,2{SFD2} ENG253123-ENG259042-ZV Nutzfahrzeuge-SBT_Schloss_direkt,not installed ,5{SFD2} ENG253123-ENG142041-ZV Nutzfahrzeuge-Schiebetueren_Crafter,not installed ,5{SFD2} ENG253123-ENG260914-ZV Nutzfahrzeuge-TKM_BFS_verbaut,not installed ,5{SFD2} ENG253123-ENG258445-ZV Nutzfahrzeuge-TKM_FS_verbaut,not installed ,5{SFD2} ENG252999-ENG258724-ZV Quittierungen-Komfort_quittung,active ,6{SFD2} ENG252999-ENG260606-ZV Quittierungen-Quittierton_beim_zweiten_ZV_AUF_Befehl,not active ,6{SFD2} ENG252999-ENG258550-ZV Quittierungen-Quittierton_beim_zweiten_ZV_ZU_Befehl,not active ,6{SFD2} ENG252999-ENG260511-ZV Quittierungen-Quittierton_global,not active ,6{SFD2} ENG252999-ENG258336-ZV Quittierungen-Quittierungston_bei_entriegeln,not active ,6{SFD2} ENG252999-ENG263543-ZV Quittierungen-Quittungs_blinken_bei_verriegeln,DELAY ,6{SFD2} ENG252999-ENG263595-ZV Quittierungen-Quittungs_ton_bei_verriegeln,not active ,6{SFD2} ENG252999-ENG259470-ZV Quittierungen-Quittungston_hmi_einstellbar,not active ,6{SFD2} ENG252999-ENG260257-ZV Quittierungen-Quittungston_ueber_hupe,not active ,6{SFD2} ENG141652-ENG258598-ZV Türkonfiguration-Fzg_mit_Vier_Tueren,No ,2{SFD2} ENG141652-ENG345897-ZV Türkonfiguration-pa_ZV_erweiterte_Synchronisation,active ,2{SFD2} ENG141652-ENG260173-ZV Türkonfiguration-Schloesser_direkt_gesteuert,vordere via CAN angeschlossen: hinten diskre ,2{SFD2} ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,2{SFD2} ENG141652-ENG258913-ZV Türkonfiguration-ZV Schlosstyp,Einmotorenschloss ohne Safe ,2{SFD2} ENG253276-ENG173074-ZV_Autolock-automatic_unlock_nar,not active ,2{SFD2} ENG253276-ENG116621-ZV_Autolock-automatisches Entriegeln,active ,2{SFD2} ENG253276-ENG115756-ZV_Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,2{SFD2} ENG253276-ENG345632-ZV_Autolock-disable_unlock_over_15kmh,active ,2{SFD2} ENG253276-ENG260929-ZV_Autolock-ZV_autolock_autounlock_hmi,not active ,2{SFD2} ENG253027-ENG173641-ZV_Crash-central_locking_system_emergency_assist,not active ,2{SFD2} ENG253027-ENG259575-ZV_Crash-Verzoegerung_ZV_Entriegelung_bei_Seitencrash,active ,2{SFD2} ENG263484-ENG263546-ZV_HW_Router-PIN_A11,Ansteuerung KiSi/Safe ,5{SFD2} ENG263484-ENG263569-ZV_HW_Router-PIN_A31,LuT zentral oder Tankklappenrueckmeldung ,5{SFD2} ENG263484-ENG263532-ZV_HW_Router-PIN_A32,Softtouch Heckdeckel ,5{SFD2} ENG263484-ENG263567-ZV_HW_Router-PIN_A33,eKisi-Status Tuer hinten rechts ,5{SFD2} ENG263484-ENG263596-ZV_HW_Router-PIN_A35,eKisi-Status Tür hinten links ,5{SFD2} ENG263484-ENG263575-ZV_HW_Router-PIN_A48,mechan. SBT (TIG/TAG rechts) ,5{SFD2} ENG263484-ENG263528-ZV_HW_Router-PIN_A49,Hauptraste SBT links ,5{SFD2} ENG263484-ENG263547-ZV_HW_Router-PIN_A50,mechan. SBT (TIG/TAG links) ,5{SFD2} ENG263484-ENG263598-ZV_HW_Router-PIN_A51,IRUE/NGS aus oder Heckscheibenbruch ,5{SFD2} ENG263484-ENG263545-ZV_HW_Router-PIN_A7,Ansteuerung KiSi/Safe ,5{SFD2} ENG263484-ENG263590-ZV_HW_Router-PIN_C21,Ansteuerung eÖ-Motor links ,5{SFD2} ENG263484-ENG263523-ZV_HW_Router-PIN_C22,Ansteuerung eÖ-Motor rechts ,5{SFD2} ENG263484-ENG263565-ZV_HW_Router-PIN_C34,Hauptraste Tür hinten rechts ,5{SFD2} ENG263484-ENG263571-ZV_HW_Router-PIN_C59,Cockpit-Taste 4 ,5{SFD2} ENG263427-ENG252063-zv_router_global-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,5{SFD2} ENG263427-ENG263506-zv_router_global-Elektrischer_SBT_Feststeller_verbaut,not installed ,5{SFD2} ENG263427-ENG263563-zv_router_global-Elektronische_Kindersicherung_eKiSi,Yes ,5{SFD2} ENG263427-ENG263551-zv_router_global-FFB_Schiebetuer_entriegelt,No ,5{SFD2} ENG263427-ENG248688-zv_router_global-Freischaltung_der_Kisi_Auswurffunktion,active ,5{SFD2} ENG263427-ENG248689-zv_router_global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,not active ,5{SFD2} ENG263427-ENG248698-zv_router_global-HD_Innentaster_im_Heck,not installed ,5{SFD2} ENG263427-ENG263588-zv_router_global-Laderaumschliessung_Taster_togglen,not active ,5{SFD2} ENG263427-ENG263582-zv_router_global-Laderaumtaster_verbaut,not installed ,5{SFD2} ENG263427-ENG248768-zv_router_global-NFZ_Schliessung,not active ,5{SFD2} ENG263427-ENG263555-zv_router_global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt,active ,5{SFD2} ENG263427-ENG259542-zv_router_global-Schiebetuer_verriegeln_bei_offenem_tank,active ,5{SFD2} ENG263427-ENG263553-zv_router_global-Schiebetuertaste_Armaturentafel_bei extern_verriegelt,not active ,5{SFD2} ENG263427-ENG133390-zv_router_global-Wiederverriegelung_Laderaum,not installed ,5Elapsed Time: 03:57
datodaco
Slovenia
C?ID=393757
adpmap-10-5QS-919-283-A_WV2ZZZSK8SX116493-20260803-1935.CSV
;SW:5QS-919-283-A   HW:5QS-919-283 ---  10: Park/Steer Assist
;Component:PDC 04ch low  H01 0075, Coding:0000010001
;EV_EPHBO14VW3360000,001010,
;Monday,03,August,2026,19:35:28:29755
;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0
;VCID: 5AED9440CC983A6AF1F-800E
Elapsed Time: 00:00
adpmap-13-5WA-907-567_WV2ZZZSK8SX116493-20260803-1935.CSV
;SW:5WA-907-567   HW:5WA-907-819 ---  13: Auto Dist. Reg
;Component:ACC Bosch MQB H50 0576, Coding:00030205000740441257400000C000042E4030000000000000000000000000
;EV_FRONTRADARBOSCHVW380,005024,EV_FRONTRADARBOSCHVW380_004_VN3S.rod
;Monday,03,August,2026,19:35:57:29755
;VCID: 0F7BB51447DA2FC2561-805A SFD+SFD2 {x}
{SFD } IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
{SFD } IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
{SFD } IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
{SFD } IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
{SFD } IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
{SFD2} IDE01949-Distance basic setting option,OFF ,1
{SFD2} IDE05815-Sail function,Deactivating ,1
{SFD2} IDE08935-Expanded restart function,OFF ,1
{SFD2} IDE09564-Distance change via speed adjustment,On ,1
{SFD2} IDE09565-Prioritized target object display,OFF ,1
{SFD } IDE11924-MAS13429-Correction angle-Horizontal correction angle: currently,-10.000 °,4
{SFD } IDE11924-MAS13430-Correction angle-Vertical correction angle: currently,-10.000 °,4
{PROD} IDE11926-MAS04910-Static calibration: preparation-Driving axis angle,0 ,7
{PROD} IDE11926-MAS13433-Static calibration: preparation-Lateral displacement of front axle,0.00 mm,7
{PROD} IDE11926-MAS13434-Static calibration: preparation-Lateral displacement of rear axle,0.00 mm,7
{PROD} IDE11926-MAS13435-Static calibration: preparation-Vertical lead angle,-0.00 °,7
{SFD2} IDE12516-Predictive speed limit regulation,not activated ,1
{PROD} IDE14161-MAS04910-Static calibration: follow-up-Driving axis angle,0 ,7
{PROD} IDE14161-MAS13433-Static calibration: follow-up-Lateral displacement of front axle,0.00 mm,7
{PROD} IDE14161-MAS13434-Static calibration: follow-up-Lateral displacement of rear axle,0.00 mm,7
{PROD} IDE14161-MAS13435-Static calibration: follow-up-Vertical lead angle,-0.00 °,7
{SFD2} IDE15695-Front radar-based localization,activated ,1
{SFD2} MAS19336-Active participant function activated,activated ,1
{SFD } ENG253321-Monitoring_and_FRKL_masking,General reject,1
Elapsed Time: 00:04
adpmap-15-5QS-959-655-S_WV2ZZZSK8SX116493-20260803-1936.CSV
;SW:5QS-959-655-S   HW:5QS-959-655-S ---  15: Airbags
;Component:AirbagVW50    004 0131, Coding:88CC008000E0C000000000000000000091540000A1AA0000DC00F680002B00A7
;EV_AirbaVW50SMEVW49X,001014,EV_AirbaVW50SMEVW49X.rod
;Monday,03,August,2026,19:36:30:29755
;VCID: 73B3D9E44B326B22D29-8026 SFD+SFD2 { }
{EXTD} IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
{EXTD} IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
{EXTD} IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
{EXTD} IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
{EXTD} IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
{EXTD} IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
{EXTD} IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
{EXTD} IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
{SFD } IDE05178-Conclude start of operation,locked ,1
{SFD2} IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,42
{SFD } IDE06527-IDE06311-Adaptation pre-crash-Left seat belt tensioner,not defined ,4
{SFD } IDE06527-IDE06312-Adaptation pre-crash-Right seat belt tensioner,not defined ,4
{SFD } IDE06527-IDE07271-Adaptation pre-crash-Belt tensioner second row right,not defined ,4
{SFD } IDE06527-IDE07274-Adaptation pre-crash-Belt tensioner second row left,not defined ,4
{SFD } IDE06527-IDE12159-Adaptation pre-crash-Control module for belt feed: second row left,not defined ,4
{SFD } IDE06527-IDE12160-Adaptation pre-crash-Control module for belt feed: second row right,not defined ,4
{SFD } IDE06527-MAS00478-Adaptation pre-crash-Reserved,2 ,4
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,0 min,3
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,0 min,3
IDE07160-ENG258305-Control module switch-off: switch-off time-BusKnockOut_Tmr_NVEM,0 min,3
{SFD } IDE09601-IDE03311-Adaptation PreCrash functions-Emergency braking display,not defined ,16
{SFD } IDE09601-IDE03633-Adaptation PreCrash functions-Close sunroof,not defined ,16
{SFD } IDE09601-IDE03634-Adaptation PreCrash functions-Close windows,not defined ,16
{SFD } IDE09601-IDE09602-Adaptation PreCrash functions-Locale hazard warning,not defined ,16
{SFD } IDE09601-IDE09603-Adaptation PreCrash functions-RECAS,not defined ,16
{SFD } IDE09601-IDE09604-Adaptation PreCrash functions-Seat adjustment - backrest,not defined ,16
{SFD } IDE09601-IDE09605-Adaptation PreCrash functions-Seat adjust. - side bolster,not defined ,16
{SFD } IDE09601-IDE09606-Adaptation PreCrash functions-Seat adjustment - headrests,not defined ,16
{SFD } IDE09601-IDE09607-Adaptation PreCrash functions-PreCrash Front,not defined ,16
{SFD } IDE09601-IDE09608-Adaptation PreCrash functions-Seat belt slack reduction: left,not defined ,16
{SFD } IDE09601-IDE09609-Adaptation PreCrash functions-Seat belt slack reduction: right,not defined ,16
{SFD } IDE09601-IDE09610-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row left,not defined ,16
{SFD } IDE09601-IDE09611-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row right,not defined ,16
{SFD } IDE09601-IDE09612-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row ctr.,not defined ,16
{SFD } IDE09601-IDE09613-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row left,not defined ,16
{SFD } IDE09601-IDE09614-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row right,not defined ,16
{SFD } IDE09601-IDE09615-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row ctr.,not defined ,16
{SFD } IDE09601-IDE09616-Adaptation PreCrash functions-Reversible belt tensioning left,not defined ,16
{SFD } IDE09601-IDE09617-Adaptation PreCrash functions-Reversible belt tensioning right,not defined ,16
{SFD } IDE09601-IDE09618-Adaptation PreCrash functions-Reversible belt tensioning: act. code of seat belt tightenert,not defined ,16
{SFD } IDE09601-IDE09619-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row right,not defined ,16
{SFD } IDE09601-IDE09620-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row ctr.,not defined ,16
{SFD } IDE09601-IDE09621-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row left,not defined ,16
{SFD } IDE09601-IDE09622-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row right,not defined ,16
{SFD } IDE09601-IDE09623-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row ctr.,not defined ,16
{SFD } IDE09601-IDE16527-Adaptation PreCrash functions-PreCrash door locking,not defined ,16
{SFD } IDE09601-IDE16528-Adaptation PreCrash functions-PreCrash seat adjustment: driver's seat,not defined ,16
{SFD } IDE09601-IDE16529-Adaptation PreCrash functions-PreCrash seat adjustment: passenger seat,not defined ,16
{SFD } IDE09601-IDE16530-Adaptation PreCrash functions-PreCrash seat adjustment: 2nd seat row,not defined ,16
{SFD } IDE09601-MAS00478-Adaptation PreCrash functions-Reserved,2 ,16
{SFD } IDE09601-MAS03834-Adaptation PreCrash functions-Emergency signal flashing,not defined ,16
{SFD } IDE09601-MAS09950-Adaptation PreCrash functions-LED bar activation,not defined ,16
{SFD } IDE09601-MAS15067-Adaptation PreCrash functions-Belt parking 1st row,not defined ,16
{SFD } IDE09601-MAS15068-Adaptation PreCrash functions-Belt parking 2nd row,not defined ,16
{SFD } IDE09601-MAS15069-Adaptation PreCrash functions-Measurement recording,not defined ,16
{SFD } IDE09601-MAS15070-Adaptation PreCrash functions-BAP resistance PreSense system,not defined ,16
{SFD } IDE09601-MAS15071-Adaptation PreCrash functions-BAP resistance PreSense warning,not defined ,16
{SFD } IDE09601-MAS15072-Adaptation PreCrash functions-BAP resistance: distance warning,not defined ,16
{SFD } IDE09601-MAS15073-Adaptation PreCrash functions-BAP resistance: turning assistance,not defined ,16
{SFD } IDE09601-MAS15074-Adaptation PreCrash functions-BAP resistance proactive passenger cover,not defined ,16
{SFD } IDE09601-MAS15107-Adaptation PreCrash functions-Drivetrain actuation,not defined ,16
{SFD } IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,activated ,8
{SFD } IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
{SFD } IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
{SFD } IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
{SFD } IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,activated ,8
{SFD } IDE12055-IDE14841-Adaptation airbag 2-Seat Belt Tensioner Igniter: center 3rd row,not defined ,8
{SFD } IDE12055-IDE15776-Adaptation airbag 2-Deactivation igniter: DC/DC converter,not defined ,8
{SFD } IDE12055-IDE16063-Adaptation airbag 2-Igniter for high-voltage battery 3 open circuit,not defined ,8
{SFD } IDE12055-IDE17275-Adaptation airbag 2-Igniter for deactivation of A/C system 3,not defined ,8
{SFD } IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
{SFD } IDE12055-MAS29851-Adaptation airbag 2-Igniter for seat ramp airbag 2nd row: passenger's side,not defined ,8
{SFD } IDE12055-MAS29852-Adaptation airbag 2-Igniter for seat ramp airbag 2nd row: driver's side,not defined ,8
{SFD } IDE15773-MAS05774-Wireless belt request/seat occupancy detection-2nd Row Left,DA DC 1D 4E DC 94 ,72
{SFD } IDE15773-MAS05775-Wireless belt request/seat occupancy detection-2nd Row Right,BB CC 1D 4E DC 94 ,72
{SFD } IDE15773-MAS14174-Wireless belt request/seat occupancy detection-2nd Row Center,8A CC 1D 4E DC 94 ,72
{SFD } IDE15773-MAS20986-Wireless belt request/seat occupancy detection-1st Row Center,FF FF FF FF FF FF ,72
{SFD } IDE15773-MAS20987-Wireless belt request/seat occupancy detection-3rd Row Center,FF FF FF FF FF FF ,72
{SFD } IDE15773-MAS20988-Wireless belt request/seat occupancy detection-4th Row Center,FF FF FF FF FF FF ,72
{SFD } IDE15773-MAS25344-Wireless belt request/seat occupancy detection-3rd Row Left,FF FF FF FF FF FF ,72
{SFD } IDE15773-MAS25345-Wireless belt request/seat occupancy detection-4th Row Left,FF FF FF FF FF FF ,72
{SFD } IDE15773-MAS25346-Wireless belt request/seat occupancy detection-4th Row Right,FF FF FF FF FF FF ,72
{SFD } IDE15773-MAS25347-Wireless belt request/seat occupancy detection-3rd Row Right,FF FF FF FF FF FF ,72
{SFD } IDE15773-MAS25348-Wireless belt request/seat occupancy detection-1st Row Right,FF FF FF FF FF FF ,72
{SFD } IDE15773-MAS25349-Wireless belt request/seat occupancy detection-1st Row Left,FF FF FF FF FF FF ,72
{SUSR} IDE15819-Exchange protection,00 ,1
{SFD2} IDE18988-Type-version-variant data for accident data recorder,---------------------------------------------------------------------------------------------------- ,100
{SFD } MAS00975-IDE00947-Airbag adaptations-Rear driver head curtain airbag igniter,not defined ,8
{SFD } MAS00975-IDE00948-Airbag adaptations-Rear passenger head curtain airbag igniter,not defined ,8
{SFD } MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
{SFD } MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
{SFD } MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
{SFD } MAS00975-IDE07192-Airbag adaptations-Thorax airbag igniter,not defined ,8
{SFD } MAS00975-IDE08436-Airbag adaptations-Front driver side third row seat belt tensioner igniter,not defined ,8
{SFD } MAS00975-IDE08437-Airbag adaptations-Front passenger side third row seat belt tensioner igniter,not defined ,8
{SFD } MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
{SFD } MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
{SFD } MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
{SFD } MAS00975-MAS00003-Airbag adaptations-Front passenger front airbag igniter,activated ,8
{SFD } MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
{SFD } MAS00975-MAS00006-Airbag adaptations-Front passenger thorax airbag igniter,activated ,8
{SFD } MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined ,8
{SFD } MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined ,8
{SFD } MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated ,8
{SFD } MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated ,8
{SFD } MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
{SFD } MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined ,8
{SFD } MAS00975-MAS00013-Airbag adaptations-Driver seat belt tension igniter,activated ,8
{SFD } MAS00975-MAS00014-Airbag adaptations-Front passenger seat belt tensioner igniter,activated ,8
{SFD } MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,activated ,8
{SFD } MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,activated ,8
{SFD } MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
{SFD } MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
{SFD } MAS00975-MAS00023-Airbag adaptations-Driver active head restraint igniter/trigger,not defined ,8
{SFD } MAS00975-MAS00024-Airbag adaptations-Front passenger active head restraint igniter/trigger,not defined ,8
{SFD } MAS00975-MAS00079-Airbag adaptations-Key-operated switch,Airbag deactivation key switch installed ,8
{SFD } MAS00975-MAS00231-Airbag adaptations-Seat occupant detection passenger side,activated ,8
{SFD } MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
{SFD } MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter hood,not defined ,8
Elapsed Time: 00:14
adpmap-17-2K7-920-310-A_WV2ZZZSK8SX116493-20260803-1919.CSV
;SW:2K7-920-310-A   HW:2K7-920-310 ---  17: Instruments
;Component:KOMBI         320 2642, Coding:04A405076384000801802203000000080020180800
;EV_DashBoardVISMQB37W,005002,EV_DashBoardVISMQB37W_005_VN3S.rod
;Monday,03,August,2026,19:19:22:29755
;VCID: 2411EAB8BE5CBC9A9B3-8070 SFD { }
IDE00301-Distance,12009 km,3
IDE00343-Language variant,slovenian ,1
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,1633 d,2
IDE00820-ENG98466-Activating and deactivating all development messages-CAN,not active ,1
IDE00820-ENG148062-Activating and deactivating all development messages-Ethernet,not active ,1
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l,5
IDE03346-IDE00301-Units adjusted-Distance,Kilometres ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,litre ,3
IDE03348-MAS01456-Speed warning-Speed,40 ,2
IDE03348-Speed warning-,active ,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG262858-Service-key settings-p_deactivate_SK-Sub_Function_Current_Data,On ,5
IDE03568-ENG262855-Service-key settings-p_deactivate_SK-Sub_Function_Daily_Data,On ,5
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,On ,5
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE06922-No-voltage display,Display ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,not active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12960-Resetting oil service,no warning ,1
IDE12961-Oil quality,poor oil quality ,1
IDE12962-Oil: soot entry,100 km,2
IDE12963-Oil: thermal loading,500 km,2
IDE12964-Oil: driven distance since last oil service,100 km,3
IDE12965-Oil: time since last oil service,6 d,2
IDE12966-Oil: min distance until next oil service (flexible interval),15000 km,2
IDE12967-Oil: max. distance until next oil service (flexible interval),30000 km,2
IDE12968-Oil: min time until next oil service (flexible interval),365 d,2
IDE12969-Oil: max time until next oil service (flexible interval),730 d,2
IDE12970-Oil: distance until next oil service (fixed interval),15000 km,2
IDE12971-Oil: time until next oil service (fixed interval),365 d,2
IDE12978-Inspection: distance until next inspection,30000 km,3
IDE12979-Inspection: time until next inspection,730 d,2
IDE12980-Inspection: distance driven since the last inspection,100 km,3
IDE12981-Inspection: time since the last inspection,6 d,2
IDE12982-Inspection: distance reset value,30000 km,2
IDE12983-Inspection: time reset value,730 d,2
IDE13094-Tachometer end value,Variant 2 ,1
IDE13441-Secondary speed in case of unit replacement,No display ,1
IDE13607-MAS16706-Lock display contents-List time out,72000 s,9
IDE14112-Gas system test - warning reset,No ,1
IDE14116-Gas system test - warning time,1460 d,2
IDE14123-MAS01129-Design variant activation-Variant 1,not active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,not active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,not active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,not active ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,No ,1
IDE14220-Vehicle speed warning for India-,90.0 s,1
IDE14222-Test number length: authentic time,16 bit,1
IDE14875-MAS19483-Activation of views-View 1,not active ,2
IDE14875-MAS19484-Activation of views-View 2,not active ,2
IDE14875-MAS19485-Activation of views-View 3,not active ,2
IDE14875-MAS19486-Activation of views-View 4,not active ,2
IDE14875-MAS19487-Activation of views-View 5,not active ,2
IDE14875-MAS19488-Activation of views-View 6,not active ,2
IDE14875-MAS19489-Activation of views-View 7,not active ,2
IDE14875-MAS19490-Activation of views-View 8,not active ,2
IDE14875-MAS19491-Activation of views-View 9,not active ,2
IDE14875-MAS19492-Activation of views-View 10,not active ,2
IDE14875-MAS19493-Activation of views-View 12,active ,2
IDE14875-MAS19494-Activation of views-View 11,active ,2
IDE14875-MAS19495-Activation of views-View 13,not active ,2
IDE14875-MAS19496-Activation of views-View 14,active ,2
IDE14875-MAS19497-Activation of views-View 15,not active ,2
IDE14875-MAS19498-Activation of views-View 16,not active ,2
IDE15080-Logo,kein_logo ,1
IDE15909-Removable seats,Removable seats ,1
IDE18473-WLTP concept,Default WLTP ,1
MAS01083-IDE12211-Country Variant-China variant,No ,2
MAS01083-IDE14114-Country Variant-USA Variant,No ,2
MAS01083-IDE14115-Country Variant-Asian variant,No ,2
MAS01083-IDE18009-Country Variant-Canada variant,No ,2
MAS01758-IDE00500-Date / time-Hour,19 H,6
MAS01758-IDE00501-Date / time-Minute,19 min,6
MAS01758-IDE00502-Date / time-Year,2026 yr,6
MAS01758-IDE00503-Date / time-Month,8 Months,6
MAS01758-IDE00504-Date / time-Day,3 d,6
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG264768-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights_green-X1,00 ,18
ENG264768-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights_green-X2,0A ,18
ENG264768-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights_green-X3,32 ,18
ENG264768-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights_green-X4,64 ,18
ENG264768-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights_green-X5,96 ,18
ENG264768-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights_green-X6,FD ,18
ENG264768-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights_green-Y1,1000 ,18
ENG264768-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights_green-Y2,1000 ,18
ENG264768-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights_green-Y3,1000 ,18
ENG264768-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights_green-Y4,1000 ,18
ENG264768-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights_green-Y5,1000 ,18
ENG264768-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights_green-Y6,1000 ,18
ENG264767-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights_red-X1,00 ,18
ENG264767-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights_red-X2,0A ,18
ENG264767-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights_red-X3,32 ,18
ENG264767-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights_red-X4,64 ,18
ENG264767-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights_red-X5,96 ,18
ENG264767-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights_red-X6,FD ,18
ENG264767-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights_red-Y1,1000 ,18
ENG264767-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights_red-Y2,1000 ,18
ENG264767-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights_red-Y3,1000 ,18
ENG264767-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights_red-Y4,1000 ,18
ENG264767-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights_red-Y5,1000 ,18
ENG264767-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights_red-Y6,1000 ,18
ENG264765-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights_yellow-X1,00 ,18
ENG264765-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights_yellow-X2,0A ,18
ENG264765-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights_yellow-X3,32 ,18
ENG264765-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights_yellow-X4,64 ,18
ENG264765-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights_yellow-X5,96 ,18
ENG264765-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights_yellow-X6,FD ,18
ENG264765-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights_yellow-Y1,1000 ,18
ENG264765-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights_yellow-Y2,1000 ,18
ENG264765-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights_yellow-Y3,1000 ,18
ENG264765-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights_yellow-Y4,1000 ,18
ENG264765-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights_yellow-Y5,1000 ,18
ENG264765-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights_yellow-Y6,1000 ,18
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG153810-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X1,00 ,18
ENG153810-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X2,0A ,18
ENG153810-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X3,32 ,18
ENG153810-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X4,64 ,18
ENG153810-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X5,96 ,18
ENG153810-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X6,FD ,18
ENG153810-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y1,12 ,18
ENG153810-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y2,12 ,18
ENG153810-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y3,20 ,18
ENG153810-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y4,70 ,18
ENG153810-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y5,500 ,18
ENG153810-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y6,1000 ,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,40.0 %,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.0 %,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,75.0 %,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,85.0 %,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,95.0 %,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,100.0 %,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,80.0 %,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.0 %,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,40.0 %,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,25.0 %,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,12.0 %,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,0.0 %,24
ENG387296-IDE03360-Displayable_content_configuration-Upshift display in center panel,No display ,4
ENG387296-IDE12722-Displayable_content_configuration-Driving profile display,No display ,4
ENG387296-MAS01833-Displayable_content_configuration-Charge air pressure,not active ,4
ENG387296-MAS03555-Displayable_content_configuration-Lap counter,not active ,4
ENG387296-MAS03688-Displayable_content_configuration-Navigation information,not active ,4
ENG387296-MAS05424-Displayable_content_configuration-Natural gas quality,No display ,4
ENG387296-MAS05757-Displayable_content_configuration-Engine torque,not active ,4
ENG387296-MAS12789-Displayable_content_configuration-Display: engine running required,No display ,4
ENG387296-MAS14767-Displayable_content_configuration-Convenience tire pressure warning display,No display ,4
ENG387296-MAS15298-Displayable_content_configuration-Night vision system automatic triggering,not active ,4
ENG387296-MAS18773-Displayable_content_configuration-Acceleration measurement,No display ,4
ENG387296-MAS18774-Displayable_content_configuration-Drag indicator,No display ,4
ENG387296-MAS19085-Displayable_content_configuration-Tailgate position,Variant 1 ,4
ENG387296-MAS19086-Displayable_content_configuration-Charge symbol color,Standard ,4
ENG387296-MAS19327-Displayable_content_configuration-Engine performance,not active ,4
ENG387296-MAS19328-Displayable_content_configuration-Transmission temperature,not active ,4
ENG387296-MAS19329-Displayable_content_configuration-G-meter,not active ,4
ENG387296-MAS19330-Displayable_content_configuration-Torque distribution,not active ,4
ENG387296-MAS23291-Displayable_content_configuration-Color switch-over,not active ,4
ENG251650-GPS_speed,active ,1
ENG376355-IPA_verbaut,not active ,1
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 °C,16
ENG135292-phev_stat_intervall-,5.0 ,7
ENG135292-phev_stat_intervall-,100 m,7
ENG135292-phev_stat_intervall-,0 min,7
ENG135292-phev_stat_intervall-,0.5 km,7
ENG135292-phev_stat_intervall-,kein ,7
ENG135292-phev_stat_intervall-,0.5 s,7
ENG135292-phev_stat_intervall-,16 ,7
ENG119876-Service_Key_Clear_All_Counter,No ,1
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 s,17
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 s,17
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.50 s,17
ENG153987-volume_offset,100 %,1
Elapsed Time: 00:32
adpmap-19-5QS-907-530-B_WV2ZZZSK8SX116493-20260803-1921.CSV
;SW:5QS-907-530-B   HW:5QS-907-530 ---  19: CAN Gateway
;Component:GW MQB 23     005 3093, Coding:000000000000000000000000000000000000000000000000030000000000000000000000000000000000000000000000
;EV_GatewMQBwBL,001018,EV_GatewMQBwBL_VW41.rod
;Monday,03,August,2026,19:21:20:29755
;VCID: 53F37964AB720B22329-8006 SFD+SFD2 { }
IDE00001-MAS00170-Production mode-OBD,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS21169-Production mode-Park coordinator,Deactivating ,3
{SFD } IDE00002-Transport mode,not active ,1
{SFD2} IDE00003-Coding,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,48
{EXTD} IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,Security access required,48
{EXTD} IDE00820-ENG259081-Activating and deactivating all development messages-BCmE_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG258247-Activating and deactivating all development messages-eASS_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG261332-Activating and deactivating all development messages-EHR_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG447862-Activating and deactivating all development messages-ELF_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG260014-Activating and deactivating all development messages-FoD_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG260247-Activating and deactivating all development messages-FPA_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG260571-Activating and deactivating all development messages-GW_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG259210-Activating and deactivating all development messages-HD_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG259946-Activating and deactivating all development messages-HV-EM_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG447864-Activating and deactivating all development messages-HVLM_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG447863-Activating and deactivating all development messages-HVL-SF_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG259153-Activating and deactivating all development messages-IDS_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG258853-Activating and deactivating all development messages-KS_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG258958-Activating and deactivating all development messages-MFL_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG258567-Activating and deactivating all development messages-MKE_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG260849-Activating and deactivating all development messages-MV-EM_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG259788-Activating and deactivating all development messages-NV-EM_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG260650-Activating and deactivating all development messages-OBDC_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG261321-Activating and deactivating all development messages-PaCo_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG261353-Activating and deactivating all development messages-RWB_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG258585-Activating and deactivating all development messages-SDA_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG258798-Activating and deactivating all development messages-SK1a_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG260530-Activating and deactivating all development messages-SK3_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG259285-Activating and deactivating all development messages-SOK_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG258316-Activating and deactivating all development messages-SWaP_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG259637-Activating and deactivating all development messages-VDC_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG259338-Activating and deactivating all development messages-VKMS_development_CAN_messages,Security access required,48
{EXTD} IDE00820-ENG259833-Activating and deactivating all development messages-WUM_development_CAN_messages,Security access required,48
{SFD } IDE01211-Static current measuring mode,not activated ,1
{SFD2} IDE01996-ENG151565-Installation list: specified installations-ECU coded Bit 0,Yes ,32
{SFD2} IDE01996-ENG176508-Installation list: specified installations-ECU coded Bit 1,No ,32
{SFD2} IDE01996-ENG176493-Installation list: specified installations-ECU coded Bit 2,Yes ,32
{SFD2} IDE01996-ENG176430-Installation list: specified installations-ECU coded Bit 3,Yes ,32
{SFD2} IDE01996-ENG176439-Installation list: specified installations-ECU coded Bit 4,Yes ,32
{SFD2} IDE01996-ENG176505-Installation list: specified installations-ECU coded Bit 5,Yes ,32
{SFD2} IDE01996-ENG176473-Installation list: specified installations-ECU coded Bit 6,No ,32
{SFD2} IDE01996-ENG176498-Installation list: specified installations-ECU coded Bit 7,No ,32
{SFD } IDE03256-MAS06105-Battery adaptation-Rated battery capacity,70 Ah,15
{SFD } IDE03256-MAS06106-Battery adaptation-Battery technology,EFB+ ,15
{SFD } IDE03256-MAS06107-Battery adaptation-Battery manufacturer,EAB ,15
{SFD } IDE03256-MAS06108-Battery adaptation-Battery Serial Number,150526QVQW ,15
IDE03903-Production process data 1,00 00 ,2
{SFD } IDE06425-Dynamometer mode: functional-,not activated ,1
{SFD } IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
{SFD } IDE06530-Distance left for deactivation of static current measuring mode,4 km,1
{SFD } IDE06541-Distance left for deactivation of transport mode,52 km,1
IDE07139-Normal bus behavior during diagnosis,active ,1
{PROD} IDE07160-Control module switch-off: switch-off time,20 min,2
IDE08220-Vehicle production mode,not active ,1
{SFD2} IDE08623-MAS02672-OBD configuration-Start-stop,StartStopp ,2
{SFD2} IDE08623-MAS08039-OBD configuration-HV charging,NoHVLaden ,2
{SFD2} IDE08623-MAS14468-OBD configuration-OBD type,EOBD ,2
{SFD2} IDE08623-MAS26199-OBD configuration-MHEV,NoMHEV ,2
{SFD2} IDE08623-MAS26725-OBD configuration-Internal combustion engine information,ICE ,2
{SFD2} IDE08623-MAS26826-OBD configuration-HEV,NoHEV ,2
{SFD2} IDE08623-MAS27147-OBD configuration-OBD on event data recorder (EDR),No ,2
{SFD2} IDE08623-MAS28789-OBD configuration-Starter battery: type,Lead ,2
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,10.1 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,4 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,0 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,0 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,0 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,151 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,10.1 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,15.1 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,15.1 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,15.1 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,15.1 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,20.1 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),15.1 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,5.1 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,15.1 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,10.1 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,10.1 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,5.1 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,5.1 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,5.1 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,5.1 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,5.1 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,10.1 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,5.1 l/100km,48
{EXTD} IDE10351-MAS10460-Message mirroring-Target bus,Security access required,48
{EXTD} IDE10351-MAS21167-Message mirroring-Source bus,Security access required,48
{SFD } IDE11689-48V-System: locking,regular operation ,1
{SFD2} IDE13748-IDE17293-Coding low voltage energy management-Autonomous inverter for socket,Not coded ,6
{SFD2} IDE13748-IDE17294-Coding low voltage energy management-Battery architecture,0 ,6
{SFD2} IDE13748-MAS23870-Coding low voltage energy management-Battery installation point,8 ,6
{SFD2} IDE13748-MAS23871-Coding low voltage energy management-Additional memory control,Not coded ,6
{SFD2} IDE13748-SFT271977-Coding low voltage energy management-Inverter for socket,Not coded ,6
IDE13756-Diagnosis filter: activation,not active ,1
IDE13844-Distance left for deactivation of production mode,100 km,1
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,12.0 kWh/100 km,40
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,12.0 kWh/100 km,40
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,12.0 kWh/100 km,40
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,12.0 kWh/100 km,40
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,12.0 kWh/100 km,40
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,12.0 kWh/100 km,40
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,12.0 kWh/100 km,40
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,12.0 kWh/100 km,40
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,12.0 kWh/100 km,40
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,12.0 kWh/100 km,40
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,12.0 kWh/100 km,40
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,12.0 kWh/100 km,40
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,12.0 kWh/100 km,40
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,12.0 kWh/100 km,40
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,12.0 kWh/100 km,40
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,12.0 kWh/100 km,40
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,12.0 kWh/100 km,40
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,12.0 kWh/100 km,40
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,12.0 kWh/100 km,40
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,12.0 kWh/100 km,40
{SFD2} IDE14423-IDE01058-High-voltage charging management coding-Country coding,Europe ,5
{SFD2} IDE14423-MAS01065-High-voltage charging management coding-Brand,Volkswagen AG ,5
{SFD2} IDE14423-MAS08226-High-voltage charging management coding-Max charging current,6A ,5
{SFD2} IDE14423-ENG172426-High-voltage charging management coding-AC_charging_socket_A,not installed ,5
{SFD2} IDE14423-ENG172427-High-voltage charging management coding-AC_charging_socket_B,not installed ,5
{SFD2} IDE14423-ENG174048-High-voltage charging management coding-Automatic_wireless_charging,not installed ,5
{SFD2} IDE14423-ENG259912-High-voltage charging management coding-charge_flap_lock_detection,not installed ,5
{SFD2} IDE14423-ENG260779-High-voltage charging management coding-Charge_flap_locking,not installed ,5
{SFD2} IDE14423-ENG172423-High-voltage charging management coding-DC_charging_Chademo,not installed ,5
{SFD2} IDE14423-ENG258832-High-voltage charging management coding-DC_charging_china,not installed ,5
{SFD2} IDE14423-ENG174370-High-voltage charging management coding-kind_of_plug_interlock_detection,limit_switch ,5
{SFD2} IDE14423-ENG172503-High-voltage charging management coding-PLC_charging_socket_A,not installed ,5
{SFD2} IDE14423-ENG172504-High-voltage charging management coding-PLC_charging_socket_B,not installed ,5
{SFD2} IDE14423-ENG251485-High-voltage charging management coding-plug_and_charge,not installed ,5
{SFD2} IDE14423-ENG251486-High-voltage charging management coding-plug_interlock,not installed ,5
{SFD2} IDE14423-ENG174643-High-voltage charging management coding-stimulation_wire,not installed ,5
{SFD2} IDE15100-IDE02321-Parking coordinator coding-Activation of park assist,manually ,8
{SFD2} IDE15100-IDE17041-Parking coordinator coding-Reversing mode bumper protection,not installed ,8
{SFD2} IDE15100-IDE17042-Parking coordinator coding-Reversing mode parking space,installed ,8
{SFD2} IDE15100-IDE17043-Parking coordinator coding-Reversing mode parallel to road,not installed ,8
{SFD2} IDE15100-IDE17044-Parking coordinator coding-Reversing mode crossing traffic,installed ,8
{SFD2} IDE15100-IDE17045-Parking coordinator coding-Reversing mode trailer hitch,not installed ,8
{SFD2} IDE15100-IDE17046-Parking coordinator coding-Rear Assist,not installed ,8
{SFD2} IDE15100-IDE17047-Parking coordinator coding-Automatic rear pedestrian brake,not installed ,8
{SFD2} IDE15100-IDE17048-Parking coordinator coding-Video Parking System,not installed ,8
{SFD2} IDE15100-IDE21181-Parking coordinator coding-Cross traffic alert (RCTA): mode,last mode active ,8
{SFD2} IDE15100-IDE21185-Parking coordinator coding-TopView camera (design variant),eMid not installed ,8
{SFD2} IDE15100-IDE21225-Parking coordinator coding-Main switch parking message manager,not active ,8
{SFD2} IDE15100-MAS01083-Parking coordinator coding-Country Variant,Europe ,8
{SFD2} IDE15100-MAS01090-Parking coordinator coding-Gearbox,Man.trans. ,8
{SFD2} IDE15100-MAS09095-Parking coordinator coding-Optical parking system,installed ,8
{SFD2} IDE15100-MAS12061-Parking coordinator coding-Sensor with rotation direction detection,installed ,8
{SFD2} IDE15100-MAS12321-Parking coordinator coding-Trailer maneuvering system,not installed ,8
{SFD2} IDE15100-MAS15696-Parking coordinator coding-Rear cross traffic assistant,not installed ,8
{SFD2} IDE15100-MAS23011-Parking coordinator coding-trailer hitch,without trailer hitch ,8
{SFD2} IDE15100-MAS23012-Parking coordinator coding-Intersection assistant,not installed ,8
{SFD2} IDE15100-MAS23014-Parking coordinator coding-Acoustic parking system,PDC rear only ,8
{SFD2} IDE15100-MAS23015-Parking coordinator coding-Collision assistant,Maneuvering brake function ,8
{SFD2} IDE15100-MAS23016-Parking coordinator coding-Remote controlled functions,not installed ,8
{SFD2} IDE15100-MAS23019-Parking coordinator coding-Electric parking brake,installed ,8
{SFD2} IDE15100-MAS23063-Parking coordinator coding-PDC front and rear or front: rear and side,not installed ,8
{SFD2} IDE15100-MAS25259-Parking coordinator coding-Trained parking,not installed ,8
{SFD2} IDE15100-SFT33108-Parking coordinator coding-Rush Hour Pilot,not installed ,8
{SFD2} IDE15100-ENG364596-Parking coordinator coding-HMI Concept,User interface (HMI) 1.X ,8
{SFD2} IDE15100-ENG257808-Parking coordinator coding-PaCo_Car_HardKeyFAS,installed ,8
{SFD2} IDE15100-ENG258080-Parking coordinator coding-PaCo_Drive_type,Combustion engine ,8
{SFD2} IDE15100-ENG257781-Parking coordinator coding-PaCo_Parking_Hardkey,not installed ,8
{SFD2} IDE15100-ENG257858-Parking coordinator coding-PaCo_Personalisation,active ,8
{SFD2} IDE15100-ENG258079-Parking coordinator coding-PaCo_Traffic_side,Right hand driv. ,8
IDE15316-FoD Partner,Available ,1
{SFD2} IDE15331-Multifunction steering wheel extended adaptation,Configuration 5 ,3
{SFD2} IDE15413-IDE18871-Anomaly detection configuration-Report system for deviations: activation status,On ,1
{SFD2} IDE15413-MAS26275-Anomaly detection configuration-GBT China compliant,OFF ,1
{SFD2} IDE15756-Ethernet port 3 VLAN configuration,VLAN_Comfort and VLAN_Infotainment ,1
{SFD2} IDE16058-FoD Set assignment of work clearance ID,02 00 0A 00 5F 00 00 01 0F FF FF 00 09 10 02 00 10 02 FF 00 A5 10 0E 00 10 0E FF 00 19 10 00 01 10 00 01 00 13 10 01 00 10 01 FF 00 01 10 07 00 10 07 FF 00 08 10 05 00 10 05 FF 00 19 10 13 00 10 13 FF 00 17 10 04 00 10 04 FF 81 5A 10 09 00 10 09 FF ,83
{SFD2} IDE16455-Configuration of unlockable functions,02 08 00 00 01 00 76 01 00 09 00 0E 02 00 13 00 57 03 00 17 00 14 06 00 A5 00 4F 07 00 5F 00 73 0B 00 08 00 46 10 81 5A 00 39 ,42
{SFD2} IDE16462-Unlockable functions: communication configuration,02 08 00 00 01 04 03 02 01 00 09 04 03 02 02 00 13 04 03 00 03 00 17 04 03 00 06 00 A5 04 03 00 07 00 5F 04 03 02 0B 00 08 04 03 02 10 81 5A 04 03 02 ,50
{SFD } IDE16611-Diagnosis filter: temporary deactivation,not active ,1
{EXTD} IDE17298-MAS00128-Trustworthy time synchronization in the master performance-Adaptive Cruise Control,Activate ,3
{EXTD} IDE17298-MAS13018-Trustworthy time synchronization in the master performance-Front sensor for driver assistance systems,Activate ,3
{EXTD} IDE17298-MAS23893-Trustworthy time synchronization in the master performance-Round counter for redeterminations,5 ,3
{EXTD} IDE17298-MAS23894-Trustworthy time synchronization in the master performance-Round counter for memory attempts,5 ,3
{EXTD} IDE17298-SFT33033-Trustworthy time synchronization in the master performance-Short-range radar 1,Activate ,3
{EXTD} IDE17298-SFT33034-Trustworthy time synchronization in the master performance-Short-range radar 2,Activate ,3
{EXTD} IDE17298-SFT33035-Trustworthy time synchronization in the master performance-Short-range radar 3,Deactivating ,3
{EXTD} IDE17298-SFT33036-Trustworthy time synchronization in the master performance-Short-range radar 4,Deactivating ,3
{SFD2} IDE18363-Electronic architecture,00 00 00 ,3
{SFD2} IDE19530-Ethernet port 4 VLAN configuration,VLAN infotainment system: VLAN Internet and VLAN connect ,1
{SFD2} MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,active ,5
{SFD2} MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,active ,5
{SFD2} MAS08072-ENG172201-Driving profile selection-FPA_Funktion,not active ,5
{SFD2} MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,not active ,5
{SFD2} MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,not active ,5
{SFD2} MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,not active ,5
{SFD2} MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,not active ,5
{SFD2} MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,not active ,5
{SFD2} MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,not active ,5
{SFD2} MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,not active ,5
{SFD2} MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,not active ,5
{SFD2} MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,not active ,5
{SFD2} MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,not active ,5
{SFD2} MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,not active ,5
{SFD2} MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,not active ,5
{SFD2} MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,not active ,5
{SFD2} MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,not active ,5
{SFD2} MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,not active ,5
{SFD2} MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,not active ,5
{SFD2} MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,not active ,5
{SFD2} MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,not active ,5
{SFD2} MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,not active ,5
{SFD2} MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,not active ,5
{SFD2} MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,not active ,5
{SFD2} MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,not active ,5
{SFD2} MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,not active ,5
{SFD2} MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,active ,5
{SFD2} MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,not active ,5
{SFD2} MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,not active ,5
{SFD2} MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,not active ,5
{SFD2} MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,not active ,5
{SFD2} MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,not active ,5
{SFD2} MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,not active ,5
{SFD2} MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,not active ,5
{SFD2} MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,not active ,5
{SFD2} MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,active ,5
{SFD2} MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,active ,5
{SFD2} MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,active ,5
{SFD2} MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Rising slope ,5
{SFD2} MAS12667-SFT271901-Specified installation of sub-bus users-Generator,Yes ,4
{SFD2} MAS12667-SFT271921-Specified installation of sub-bus users-Multi-function steering wheel control module,Yes ,4
{SFD2} MAS12667-SFT271927-Specified installation of sub-bus users-Battery Monitoring Control Module,Yes ,4
{SFD2} MAS12667-SFT271977-Specified installation of sub-bus users-Inverter for socket,No ,4
{SFD2} MAS12667-SFT271986-Specified installation of sub-bus users-Analog clock,No ,4
{SFD2} MAS12667-SFT272175-Specified installation of sub-bus users-Control head driving profile,No ,4
{SFD2} MAS12667-SFT272190-Specified installation of sub-bus users-Steering Wheel Touch Recognition Control Module,No ,4
{SFD2} MAS16743-Alternator gear ratio,6A ,1
{SFD2} MAS23693-MAS18081-Drowsiness and attention detection-Test Mode,00 ,22
{SFD2} MAS23693-MAS20954-Drowsiness and attention detection-Function coding,01 ,22
{SFD2} MAS23693-ENG101808-Drowsiness and attention detection-Bytes 1-16,6C 4D C0 00 00 02 80 69 2C 24 00 00 00 00 01 69 ,22
{SFD2} MAS26807-Engine start with belt-driven starter-alternator,not active ,1
{SFD2} MAS28749-MAS28939-DoIP ECU configuration-Node address: DoIP-only control module 1,No ecu ,16
{SFD2} MAS28749-MAS28940-DoIP ECU configuration-Node address: DoIP-only control module 2,No ecu ,16
{SFD2} MAS28749-MAS28941-DoIP ECU configuration-Node address: DoIP-only control module 3,No ecu ,16
{SFD2} MAS28749-MAS28942-DoIP ECU configuration-Node address: DoIP-only control module 4,No ecu ,16
{SFD2} MAS28749-MAS28943-DoIP ECU configuration-Node address: DoIP-only control module 5,No ecu ,16
{SFD2} MAS28749-MAS28944-DoIP ECU configuration-Node address: DoIP-only control module 6,No ecu ,16
{SFD2} MAS28749-MAS28945-DoIP ECU configuration-Node address: DoIP-only control module 7,No ecu ,16
{SFD2} MAS28749-MAS28946-DoIP ECU configuration-Node address: DoIP-only control module 8,No ecu ,16
{SFD2} SFT271921-IDE02583-Multi-function steering wheel control module-Steering wheel Tiptronic switch,not installed ,3
{SFD2} SFT271921-IDE07856-Multi-function steering wheel control module-Terminal status,active with terminal 58 ,3
{SFD2} SFT271921-MAS02311-Multi-function steering wheel control module-Steering wheel heating button,not active ,3
{SFD2} SFT271921-MAS04733-Multi-function steering wheel control module-Two-stage,not active ,3
{SFD2} SFT271921-MAS06614-Multi-function steering wheel control module-Variant,Cruise control system ,3
{SFD2} SFT271921-MAS09758-Multi-function steering wheel control module-Temperature sensor,not installed ,3
{SFD2} SFT271921-MAS10720-Multi-function steering wheel control module-Speed limiter,not active ,3
{SFD2} SFT271921-MAS13892-Multi-function steering wheel control module-Platform,MQB2020 ,3
{SFD2} SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,not active ,3
{SFD2} SFT271921-MAS21171-Multi-function steering wheel control module-Distance regulation function query (FoD),automatic ,3
{SFD2} SFT271921-MAS21172-Multi-function steering wheel control module-Travel Assist function query (FoD),automatic ,3
{SFD2} SFT271921-ENG262857-Multi-function steering wheel control module-Kombi_02_gueltig,invalid ,3
SFT272190-Steering Wheel Touch Recognition Control Module,No Response From Subnet Component,3
{EXTD} ENG253073-Diagnostic_filter_permanent_deactivation,activated ,1
{SFD2} ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
{SFD2} ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12
{SFD2} ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
{SFD2} ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
{SFD2} ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12
{SFD2} ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
{SFD2} ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
{SFD2} ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12
{SFD2} ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
{SFD2} ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms,12
{EXTD} ENG331085-ENG280094-Egress_filter-packet_based_/_port_shaper_burst_size_configuration,Security access required,12
{EXTD} ENG331085-ENG280095-Egress_filter-packet_based_/_port_shaper_shaping_rate_configuration,Security access required,12
{EXTD} ENG331085-ENG280098-Egress_filter-port_shaper_bucket_count_select,Security access required,12
{EXTD} ENG331085-ENG280099-Egress_filter-port_shaper_enabling,Security access required,12
{EXTD} ENG253271-ENG259280-GW_Content_list-Bus_ID,Security access required,12
{EXTD} ENG253271-ENG253458-GW_Content_list-Node_address,Security access required,12
{EXTD} ENG253382-ENG258827-IDS_critical_PDUs_list_mqb2020-Airbag_01_can-id_0x040,Security access required,12
{EXTD} ENG253382-ENG259901-IDS_critical_PDUs_list_mqb2020-Airbag_02_can-id_0x520,Security access required,12
{EXTD} ENG253382-ENG259106-IDS_critical_PDUs_list_mqb2020-Airbag_03_can-id_0x041,Security access required,12
{EXTD} ENG253382-ENG261312-IDS_critical_PDUs_list_mqb2020-APS_Master_can-id_0x380,Security access required,12
{EXTD} ENG253382-ENG259066-IDS_critical_PDUs_list_mqb2020-ARA_02_can-id_0x2A5,Security access required,12
{EXTD} ENG253382-ENG260221-IDS_critical_PDUs_list_mqb2020-BMS_NV_01_can-id_0x1F3,Security access required,12
{EXTD} ENG253382-ENG258308-IDS_critical_PDUs_list_mqb2020-Bremse_EV_02_can-id_0x387,Security access required,12
{EXTD} ENG253382-ENG258444-IDS_critical_PDUs_list_mqb2020-EA_01_can-id_0x1A4,Security access required,12
{EXTD} ENG253382-ENG259736-IDS_critical_PDUs_list_mqb2020-EA_02_can-id_0x1F0,Security access required,12
{EXTD} ENG253382-ENG258228-IDS_critical_PDUs_list_mqb2020-EPB_03_can-id_0x1F7,Security access required,12
{EXTD} ENG253382-ENG258443-IDS_critical_PDUs_list_mqb2020-ESP_10_can-id_0x116,Security access required,12
{EXTD} ENG253382-ENG258403-IDS_critical_PDUs_list_mqb2020-ESP_14_can-id_0x08A,Security access required,12
{EXTD} ENG253382-ENG259539-IDS_critical_PDUs_list_mqb2020-ESP_20_can-id_0x65D,Security access required,12
{EXTD} ENG253382-ENG258752-IDS_critical_PDUs_list_mqb2020-ESP_21_can-id_0x0FD,Security access required,12
{EXTD} ENG253382-ENG258803-IDS_critical_PDUs_list_mqb2020-ESP_24_can-id_0x31B,Security access required,12
{EXTD} ENG253382-ENG259454-IDS_critical_PDUs_list_mqb2020-GRA_ACC_01_can-id_0x12B,Security access required,12
{EXTD} ENG253382-ENG260975-IDS_critical_PDUs_list_mqb2020-HCA_01_can-id_0x126,Security access required,12
{EXTD} ENG253382-ENG258427-IDS_critical_PDUs_list_mqb2020-IPA_01_can-id_0x138,Security access required,12
{EXTD} ENG253382-ENG259431-IDS_critical_PDUs_list_mqb2020-Klemmen_Status_01_can-id_0x3C0,Security access required,12
{EXTD} ENG253382-ENG258280-IDS_critical_PDUs_list_mqb2020-Klemmen_Steuerung_01_can-id_0x58C,Security access required,12
{EXTD} ENG253382-ENG259354-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_L_can-id_0x56B,Security access required,12
{EXTD} ENG253382-ENG258318-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_R_can-id_0x56C,Security access required,12
{EXTD} ENG253382-ENG260165-IDS_critical_PDUs_list_mqb2020-LCM_Soll_Fkt_can-id_0x193,Security access required,12
{EXTD} ENG253382-ENG259048-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_L_can-id_0x19B,Security access required,12
{EXTD} ENG253382-ENG259708-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_R_can-id_0x19D,Security access required,12
{EXTD} ENG253382-ENG259220-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_L_03_can-id_0x16A95416,Security access required,12
{EXTD} ENG253382-ENG259096-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_R_03_can-id_0x16A95417,Security access required,12
{EXTD} ENG253382-ENG260883-IDS_critical_PDUs_list_mqb2020-LH_EPS_01_can-id_0x32A,Security access required,12
{EXTD} ENG253382-ENG261199-IDS_critical_PDUs_list_mqb2020-LH_EPS_02_can-id_0x11D,Security access required,12
{EXTD} ENG253382-ENG259434-IDS_critical_PDUs_list_mqb2020-LH_EPS_03_can-id_0x09F,Security access required,12
{EXTD} ENG253382-ENG258969-IDS_critical_PDUs_list_mqb2020-Licht_Anf_01_can-id_0x3D5,Security access required,12
{EXTD} ENG253382-ENG259107-IDS_critical_PDUs_list_mqb2020-LWI_01_can-id_0x086,Security access required,12
{EXTD} ENG253382-ENG259990-IDS_critical_PDUs_list_mqb2020-MFG_02_can-id_0x48D,Security access required,12
{EXTD} ENG253382-ENG260730-IDS_critical_PDUs_list_mqb2020-Motor_14_can-id_0x3BE,Security access required,12
{EXTD} ENG253382-ENG258115-IDS_critical_PDUs_list_mqb2020-Motor_Code_01_can-id_0x641,Security access required,12
{EXTD} ENG253382-ENG258876-IDS_critical_PDUs_list_mqb2020-PreCrash_02_can-id_0x13F,Security access required,12
{EXTD} ENG253382-ENG261021-IDS_critical_PDUs_list_mqb2020-Q_Diode_01_can-id_0x298,Security access required,12
{EXTD} ENG253382-ENG260760-IDS_critical_PDUs_list_mqb2020-RCTA_01_can-id_0x2B7,Security access required,12
{EXTD} ENG253382-ENG259993-IDS_critical_PDUs_list_mqb2020-TSG_FT_02_can-id_0x3E5,Security access required,12
{EXTD} ENG253382-ENG260263-IDS_critical_PDUs_list_mqb2020-WBA_03_can-id_0x394,Security access required,12
{EXTD} ENG376354-ENG376439-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ACC_18_can-id_0x14D,Security access required,12
{EXTD} ENG376354-ENG258827-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_01_can-id_0x040,Security access required,12
{EXTD} ENG376354-ENG259901-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_02_can-id_0x520,Security access required,12
{EXTD} ENG376354-ENG259106-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_03_can-id_0x041,Security access required,12
{EXTD} ENG376354-ENG376486-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_04_can-id_0x545,Security access required,12
{EXTD} ENG376354-ENG376503-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-AWV_03_can-id_0x0DB,Security access required,12
{EXTD} ENG376354-ENG376508-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Blinkmodi_02_can-id_0x366,Security access required,12
{EXTD} ENG376354-ENG258357-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-BMS_07_can-id_0x5CA,Security access required,12
{EXTD} ENG376354-ENG376567-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DCDC_02_can-id_0x3F4,Security access required,12
{EXTD} ENG376354-ENG376569-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DCDC_04_can-id_0x0F7,Security access required,12
{EXTD} ENG376354-ENG376581-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DiETa_01_can-id_0x353,Security access required,12
{EXTD} ENG376354-ENG258444-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EA_01_can-id_0x1A4,Security access required,12
{EXTD} ENG376354-ENG259736-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EA_02_can-id_0x1F0,Security access required,12
{EXTD} ENG376354-ENG376591-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EBKV_03_can-id_0x176,Security access required,12
{EXTD} ENG376354-ENG376634-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ELV_01_can-id_0x656,Security access required,12
{EXTD} ENG376354-ENG376635-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EM1_01_can-id_0x0C0,Security access required,12
{EXTD} ENG376354-ENG376636-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EM2_01_can-id_0x0C1,Security access required,12
{EXTD} ENG376354-ENG258228-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EPB_03_can-id_0x1F7,Security access required,12
{EXTD} ENG376354-ENG376650-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_50_can-id_0x102,Security access required,12
{EXTD} ENG376354-ENG376651-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_51_Auth_can-id_0x0FC,Security access required,12
{EXTD} ENG376354-ENG376652-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_52_can-id_0x12DD5497,Security access required,12
{EXTD} ENG376354-ENG258443-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_10_can-id_0x116,Security access required,12
{EXTD} ENG376354-ENG258752-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_21_can-id_0x0FD,Security access required,12
{EXTD} ENG376354-ENG258803-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_24_can-id_0x31B,Security access required,12
{EXTD} ENG376354-ENG376653-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_30_can-id_0x1A555521,Security access required,12
{EXTD} ENG376354-ENG376705-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Getriebe_11_can-id_0x0AD,Security access required,12
{EXTD} ENG376354-ENG376706-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Getriebe_16_can-id_0x144,Security access required,12
{EXTD} ENG376354-ENG376748-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-HVK_01_can-id_0x503,Security access required,12
{EXTD} ENG376354-ENG376756-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-IPA_02_can-id_0x16A9545F,Security access required,12
{EXTD} ENG376354-ENG259431-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Klemmen_Status_01_can-id_0x3C0,Security access required,12
{EXTD} ENG376354-ENG258280-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Klemmen_Steuerung_01_can-id_0x58C,Security access required,12
{EXTD} ENG376354-ENG260883-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_01_can-id_0x32A,Security access required,12
{EXTD} ENG376354-ENG261199-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_02_can-id_0x11D,Security access required,12
{EXTD} ENG376354-ENG259434-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_03_can-id_0x09F,Security access required,12
{EXTD} ENG376354-ENG376764-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_05_can-id_0x06E,Security access required,12
{EXTD} ENG376354-ENG258969-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Licht_Anf_01_can-id_0x3D5,Security access required,12
{EXTD} ENG376354-ENG259107-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LWI_01_can-id_0x086,Security access required,12
{EXTD} ENG376354-ENG376780-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Mem_Taster_BT_01_can-id_0x49C,Security access required,12
{EXTD} ENG376354-ENG376781-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Mem_Taster_FT_01_can-id_0x492,Security access required,12
{EXTD} ENG376354-ENG260730-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_14_can-id_0x3BE,Security access required,12
{EXTD} ENG376354-ENG376786-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_51_Auth_can-id_0x10B,Security access required,12
{EXTD} ENG376354-ENG376787-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_54_can-id_0x14C,Security access required,12
{EXTD} ENG376354-ENG376788-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_55_Auth_can-id_0x0F6,Security access required,12
{EXTD} ENG376354-ENG376789-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_56_can-id_0x0BE,Security access required,12
{EXTD} ENG376354-ENG376790-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_57_can-id_0x12DD54AA,Security access required,12
{EXTD} ENG376354-ENG258115-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_Code_01_can-id_0x641,Security access required,12
{EXTD} ENG376354-ENG376814-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-PAO_Status_01_can-id_0x16A954FD,Security access required,12
{EXTD} ENG376354-ENG376817-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Parken_01_can-id_0x206,Security access required,12
{EXTD} ENG376354-ENG376824-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-PLA_04_can-id_0x407,Security access required,12
{EXTD} ENG376354-ENG376834-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-QFK_01_Auth_can-id_0x13D,Security access required,12
{EXTD} ENG376354-ENG260760-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-RCTA_01_can-id_0x2B7,Security access required,12
{EXTD} ENG376354-ENG376908-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TA_01_can-id_0x26B,Security access required,12
{EXTD} ENG376354-ENG259993-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TSG_FT_02_can-id_0x3E5,Security access required,12
{EXTD} ENG376354-ENG376959-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TSG_HFS_02_can-id_0x341,Security access required,12
{EXTD} ENG376354-ENG376988-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-VMM_02_can-id_0x139,Security access required,12
{EXTD} ENG376354-ENG376990-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Waehlhebel_04_can-id_0x0B5,Security access required,12
{EXTD} ENG253192-MAS01898-IDS_white_list_features-Drive train,Security access required,12
{EXTD} ENG253192-MAS03178-IDS_white_list_features-Suspension data bus,Security access required,12
{EXTD} ENG253192-MAS12183-IDS_white_list_features-Comfort CAN bus 2,Security access required,12
{EXTD} ENG253192-MAS16574-IDS_white_list_features-Infotainment,Security access required,12
{EXTD} ENG376363-Max_number_of_TCP-Sockets,Security access required,12
{SFD } ENG309781-NVEM_function_variant,0 ,1
{EXTD} ENG253268-MAS03173-TCR_bus_can-Powertrain data bus,Security access required,1
{EXTD} ENG253268-MAS03174-TCR_bus_can-Comfort data bus,Security access required,1
{EXTD} ENG253268-MAS03175-TCR_bus_can-Extended data bus,Security access required,1
{EXTD} ENG253268-MAS03177-TCR_bus_can-Infotainment data bus,Security access required,1
{EXTD} ENG253268-MAS03178-TCR_bus_can-Suspension data bus,Security access required,1
{EXTD} ENG253268-MAS05686-TCR_bus_can-Data bus diagnostics,Security access required,1
{EXTD} ENG253268-MAS12185-TCR_bus_can-Hybrid data bus,Security access required,1
{EXTD} ENG253268-MAS16910-TCR_bus_can-Migration data bus,Security access required,1
ENG253184-MAS03179-TCR_bus_lin-Local data bus 2,Security access required,1
ENG253184-MAS03180-TCR_bus_lin-Local data bus,Security access required,1
ENG253184-MAS05972-TCR_bus_lin-Local data bus 3,Security access required,1
ENG253184-MAS06525-TCR_bus_lin-Local data bus 4,Security access required,1
{EXTD} ENG253199-MAS16912-TCR_bus_vlan-VLAN_FAS,Security access required,1
{EXTD} ENG253199-MAS16913-TCR_bus_vlan-VLAN_Infotainment,Security access required,1
{EXTD} ENG253199-MAS16915-TCR_bus_vlan-VLAN_Komfort,Security access required,1
{EXTD} ENG253199-MAS16916-TCR_bus_vlan-VLAN_Powertrain,Security access required,1
{EXTD} ENG253199-MAS18934-TCR_bus_vlan-VLAN Connect,Security access required,1
{EXTD} ENG376385-Traffic_Limit_on_ext_ETH-Ports,Security access required,1
{SFD } ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,10
{SFD } ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,10
{SFD } ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,10
{SFD } ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,10
{SFD } ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,10
{SFD } ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,10
{SFD } ENG118773-ENG260551-WakeUpMonitor_Configuration-WakeUpMonitor_Start_WakeUp_Delay,1800 s,10
Elapsed Time: 00:31
adpmap-22-5WA-907-554-H_WV2ZZZSK8SX116493-20260803-1936.CSV
;SW:5WA-907-554-H   HW:5WA-525-130 ---  22: AWD
;Component:4Motion       H66 1060, Coding:0001
;EV_AllWheelContrHA1VW37X,006001,EV_AllWheelContrHA1VW37X_006_AU38.rod
;Monday,03,August,2026,19:36:52:29755
;VCDS Version: 26.7.1.0 (x64)  Data version: 20260708 DS378.0
IDE07843-ENG142105-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_4,2200 ,8
IDE07843-ENG142107-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_5,2200 ,8
IDE07843-ENG142109-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_6,2200 ,8
IDE07843-ENG142111-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_7_plus,2200 ,8
IDE07843-ENG142104-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_4,1300 ,8
IDE07843-ENG142106-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_5,1300 ,8
IDE07843-ENG142108-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_6,1300 ,8
IDE07843-ENG142110-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_7_plus,1300 ,8
IDE07844-ENG142113-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_4,2200 ,8
IDE07844-ENG142115-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_5,2200 ,8
IDE07844-ENG142117-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_6,2200 ,8
IDE07844-ENG142119-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_7_plus,2200 ,8
IDE07844-ENG142112-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_4,1300 ,8
IDE07844-ENG142114-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_5,1300 ,8
IDE07844-ENG142116-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_6,1300 ,8
IDE07844-ENG142118-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_7_plus,1300 ,8
MAS06098-Acoustic measure: wiring logic,Standard ,1
Elapsed Time: 00:03
adpmap-42-3WA-959-393-A_WV2ZZZSK8SX116493-20260803-1937.CSV
;SW:3WA-959-393-A   HW:3WA-959-393 ---  42: Door Elect, Driver
;Component:TSG FS        001 0222, Coding:00208320C000000100001020
;EV_DCU4DriveSideMAXHKLO,001016,
;Monday,03,August,2026,19:37:36:29755
;VCID: 52FD7C609468022A39F-8006 SFD+SFD2 {x}
Elapsed Time: 00:00
adpmap-44-5QS-907-146-D_WV2ZZZSK8SX116493-20260803-1937.CSV
;SW:5QS-907-146-D   HW:5QS-907-146 ---  44: Steering Assist
;Component:BASGEN1MQB37  263 2122, Coding:00000000000000000001020101000100000001010101
;EV_SteerAssisBASGEN1MQB37,017078,EV_SteerAssisBASGEN1MQB37_017.rod
;Monday,03,August,2026,19:37:48:29755
;VCID: 58E98E48B294287AC7B-800C SFD+SFD2 { }
{EXTD} IDE00820-Activating and deactivating all development messages,not active ,1
{SFD2} IDE03724-Straight line running,Active: with learned value ,1
{PROD} IDE03734-Support power,100% ,1
{SFD2} IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
{SFD } IDE04555-Activation of pwr steering asst without engine running,not active ,1
{EXTD} IDE05162-Software end stop,active ,1
{SFD2} IDE06419-Driving profile switchover,Incremental: controlled over time ,1
{SFD2} IDE06678-Pull compensation,Active: without learned value ,1
{SFD } IDE07540-Download without rest bus,not active ,1
{PROD} IDE09571-RPM monitoring,active ,1
{SFD2} IDE14345-Lateral assistant coordinator: parking assist,not active ,1
{SFD2} IDE14346-Lateral assistant coordinator: reduced stopping distance,active ,1
{SFD2} IDE14347-Lateral assistance coordinator: lane assist,active ,1
{SFD2} IDE14348-Lateral assistant coordination: counter-steering assist,active ,1
{SFD2} IDE15619-Maneuvering assistant lateral control coordinator,not active ,1
{EXTD} MAS02080-XCP calibration protocol,not active ,1
{SFD2} MAS06373-Vehicle variant,MQB_W_Baseline ,1
{SFD } MAS09008-Plausibility check,active ,1
Elapsed Time: 00:06
adpmap-52-3WA-959-392-A_WV2ZZZSK8SX116493-20260803-1937.CSV
;SW:3WA-959-392-A   HW:3WA-959-392 ---  52: Door Elect, Pass.
;Component:TSG BFS       001 0222, Coding:00200120C000000100001020
;EV_DCU4PasseSideMAXHKLO,001016,
;Monday,03,August,2026,19:37:59:29755
;VCID: 51FF736C916E7932005-8004 SFD+SFD2 {x}
Elapsed Time: 00:00
adpmap-5F-2K7-035-869-A_WV2ZZZSK8SX116493-20260803-1938.CSV
;SW:2K7-035-869-A   HW:2K7-035-869-A ---  5F: Information Electr.
;Component:MU-E-D-EU     065 0176, Coding:63521006000020000000000000000000000000000000000000
;EV_MUEIGPMQB37w,001001,
;Monday,03,August,2026,19:38:04:29755
;VCID: 34311AF80EBC2C1A0B3-8060 SFD+SFD2 {x}
Elapsed Time: 00:00
adpmap-75-571-035-284-B_WV2ZZZSK8SX116493-20260803-1938.CSV
;SW:571-035-284-B   HW:571-035-284 ---  75: Telematics
;Component:OCUMQBW2023_H H09 0626, Coding:06010601020000110000000013002607111012111012000010
;EV_OCUMWB2023,001066,
;Monday,03,August,2026,19:38:08:29755
;VCID: 1577C77C6506D5121CD-8040 SFD+SFD2 {x}
Elapsed Time: 00:00
adpmap-A5-5WA-980-653-F_WV2ZZZSK8SX116493-20260803-1939.CSV
;SW:5WA-980-653-F   HW:5WA-980-653-A ---  A5: Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H12 3609, Coding:0001089001484040409E08001000002000018048600000000000000000000000
;EV_MFK3ValeoMQB,005071,EV_MFK3ValeoMQB_005_VN3S.rod
;Monday,03,August,2026,19:39:00:29755
IDE04733-Road sign detection fusion mode-,0 ,2
IDE04733-Road sign detection fusion mode-,Road sign fusion ,2
IDE07358-Distance to calibration field,1500.00 mm,2
IDE09375-IDE05717-Axle offset-Front axle transverse position,5.5 mm,4
IDE09375-IDE05718-Axle offset-Rear axle transverse position,6.9 mm,4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,715.00 mm,8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,721.00 mm,8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,746.00 mm,8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,752.00 mm,8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2397.75 mm,24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,732.50 mm,24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1694.00 mm,24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2397.75 mm,24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-732.50 mm,24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1694.00 mm,24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2397.75 mm,24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,732.50 mm,24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,1106.00 mm,24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2397.75 mm,24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-732.50 mm,24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,1106.00 mm,24
IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
IDE10873-BAP personalization,activated ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.290 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.301 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,-0.073 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,1496 mm,8
IDE12097-Menu for roadside fusion persistency,activated ,1
ENG114742-ENG130919-Activation of Development Messages-Activation_of_development_messages_EHR,not active ,2
ENG114742-ENG185756-Activation of Development Messages-Activation_of_development_messages_HCA_01,not active ,2
ENG114742-ENG185757-Activation of Development Messages-Activation_of_development_messages_HCA_02,not active ,2
ENG114742-ENG130922-Activation of Development Messages-Activation_of_development_messages_internal,not active ,2
ENG114742-ENG185758-Activation of Development Messages-Activation_of_development_messages_lane_1,not active ,2
ENG114742-ENG185759-Activation of Development Messages-Activation_of_development_messages_lane_2,not active ,2
ENG114742-ENG130915-Activation of Development Messages-Activation_of_development_messages_reserved,not active ,2
ENG114742-ENG185760-Activation of Development Messages-Activation_of_development_messages_RFD,not active ,2
ENG114742-ENG185761-Activation of Development Messages-Activation_of_development_messages_TSF,not_active ,2
ENG114742-ENG185762-Activation of Development Messages-Activation_of_development_messages_VZF_TSR1,not_active ,2
ENG114742-ENG185763-Activation of Development Messages-Activation_of_development_messages_VZF_TSR2,not active ,2
ENG114742-ENG130917-Activation of Development Messages-Activation_of_development_messages_WLA,not active ,2
ENG114742-ENG185770-Activation of Development Messages-Dev_messages_vd_deaktivation,not active ,2
ENG185678-Activation_OCAL,activated ,1
ENG130776-ENG185767-Adaptation_tsr-country_code_RSR,0 ,2
ENG130776-ENG185809-Adaptation_tsr-relevance_mode,Enabled ,2
ENG185690-ENG185780-HCA_Development-HCA_Development_1,00 00 00 00 ,24
ENG185690-ENG185781-HCA_Development-HCA_Development_2,00 00 00 00 ,24
ENG185690-ENG185782-HCA_Development-HCA_Development_3,00 00 00 00 ,24
ENG185690-ENG185783-HCA_Development-HCA_Development_4,00 00 00 00 ,24
ENG185690-ENG185784-HCA_Development-HCA_Development_5,00 00 00 00 ,24
ENG185690-ENG185785-HCA_Development-HCA_Development_6,00 00 00 00 ,24
ENG185698-HiL_Funktionsdeaktivierung,4294967295 ,4
ENG185694-Hil_init_mode,not active ,1
ENG120319-Mask_error_reactions_for_development,not_activated ,1
ENG107577-ENG185789-Masked_fault_classes-Masked_fault_classes_1,255 ,4
ENG107577-ENG185790-Masked_fault_classes-Masked_fault_classes_2,255 ,4
ENG107577-ENG185791-Masked_fault_classes-Masked_fault_classes_3,255 ,4
ENG107577-ENG185792-Masked_fault_classes-Masked_fault_classes_4,255 ,4
ENG309782-PSD_HCA_Support,not_active ,1
ENG185706-Reset_eyeq_mode,not active ,1
ENG130777-standstill_mode,not active ,1
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,30.0 ,5
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,40.0 ,5
ENG130781-ENG185819-WLA_adjustment-WLA_Object_type_extended,Object_extended_off ,5
ENG130779-Xcp_interface,not activated ,1
Elapsed Time: 00:13
datodaco
Slovenia
C?ID=393757
WV2ZZZSK8SX116493,Address 0x19,5QS 907 530 B,Online SFD,Monday,03,August,2026,18:35:01,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x19,5QS 907 530 B,Online SFD,Monday,03,August,2026,18:35:07,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x19,5QS 907 530 B,Online SFD,Monday,03,August,2026,18:35:07,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x19,5QS 907 530 B,Online SFD,Monday,03,August,2026,18:35:09,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x01,05L 906 023 QK,Online SFD,Monday,03,August,2026,18:35:55,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x01,05L 906 023 QK,Online SFD,Monday,03,August,2026,18:35:58,H11-031216,SFD unlock token retrieval success, 532 bytes
WV2ZZZSK8SX116493,Address 0x01,05L 906 023 QK,Online SFD,Monday,03,August,2026,18:35:58,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x01,05L 906 023 QK,Online SFD,Monday,03,August,2026,18:35:58,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x03,5WA 614 517 DQ,Online SFD,Monday,03,August,2026,18:36:17,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x03,5WA 614 517 DQ,Online SFD,Monday,03,August,2026,18:36:20,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x03,5WA 614 517 DQ,Online SFD,Monday,03,August,2026,18:36:20,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x03,5WA 614 517 DQ,Online SFD,Monday,03,August,2026,18:36:22,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x08,5WA 907 727 BK,Online SFD,Monday,03,August,2026,18:37:26,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x08,5WA 907 727 BK,Online SFD,Monday,03,August,2026,18:37:31,H11-031216,SFD unlock token retrieval success, 532 bytes
WV2ZZZSK8SX116493,Address 0x08,5WA 907 727 BK,Online SFD,Monday,03,August,2026,18:37:31,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x08,5WA 907 727 BK,Online SFD,Monday,03,August,2026,18:37:33,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x09,5WA 937 086 CN,Online SFD,Monday,03,August,2026,18:37:47,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x09,5WA 937 086 CN,Online SFD,Monday,03,August,2026,18:37:49,H11-031216,SFD unlock token retrieval success, 532 bytes
WV2ZZZSK8SX116493,Address 0x09,5WA 937 086 CN,Online SFD,Monday,03,August,2026,18:37:49,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x09,5WA 937 086 CN,Online SFD,Monday,03,August,2026,18:37:50,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x13,5WA 907 567 ,Online SFD,Monday,03,August,2026,18:40:32,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x13,5WA 907 567 ,Online SFD,Monday,03,August,2026,18:40:35,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x13,5WA 907 567 ,Online SFD,Monday,03,August,2026,18:40:35,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x13,5WA 907 567 ,Online SFD,Monday,03,August,2026,18:40:36,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x15,5QS 959 655 S,Online SFD,Monday,03,August,2026,18:41:46,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x15,5QS 959 655 S,Online SFD,Monday,03,August,2026,18:41:50,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x15,5QS 959 655 S,Online SFD,Monday,03,August,2026,18:41:50,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x15,5QS 959 655 S,Online SFD,Monday,03,August,2026,18:41:52,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x17,2K7 920 310 A,Online SFD,Monday,03,August,2026,18:43:12,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x17,2K7 920 310 A,Online SFD,Monday,03,August,2026,18:43:15,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x17,2K7 920 310 A,Online SFD,Monday,03,August,2026,18:43:15,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x17,2K7 920 310 A,Online SFD,Monday,03,August,2026,18:43:17,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x23,5WA 909 059 AH,Online SFD,Monday,03,August,2026,18:43:39,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x23,5WA 909 059 AH,Online SFD,Monday,03,August,2026,18:43:42,H11-031216,SFD unlock token retrieval success, 532 bytes
WV2ZZZSK8SX116493,Address 0x23,5WA 909 059 AH,Online SFD,Monday,03,August,2026,18:43:42,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x23,5WA 909 059 AH,Online SFD,Monday,03,August,2026,18:43:44,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x42,3WA 959 393 A,river,  Online SFD,Monday,03,August,2026,18:44:07,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x42,3WA 959 393 A,river,  Online SFD,Monday,03,August,2026,18:44:10,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x42,3WA 959 393 A,river,  Online SFD,Monday,03,August,2026,18:44:10,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x42,3WA 959 393 A,river,  Online SFD,Monday,03,August,2026,18:44:12,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x44,5QS 907 146 D,Online SFD,Monday,03,August,2026,18:44:23,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x44,5QS 907 146 D,Online SFD,Monday,03,August,2026,18:44:26,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x44,5QS 907 146 D,Online SFD,Monday,03,August,2026,18:44:26,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x44,5QS 907 146 D,Online SFD,Monday,03,August,2026,18:44:28,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x52,3WA 959 392 A,ass.,  Online SFD,Monday,03,August,2026,18:44:45,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x52,3WA 959 392 A,ass.,  Online SFD,Monday,03,August,2026,18:44:48,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x52,3WA 959 392 A,ass.,  Online SFD,Monday,03,August,2026,18:44:49,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x52,3WA 959 392 A,ass.,  Online SFD,Monday,03,August,2026,18:44:50,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x5F,2K7 035 869 A,Online SFD,Monday,03,August,2026,18:45:07,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x5F,2K7 035 869 A,Online SFD,Monday,03,August,2026,18:45:10,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x5F,2K7 035 869 A,Online SFD,Monday,03,August,2026,18:45:10,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x5F,2K7 035 869 A,Online SFD,Monday,03,August,2026,18:45:11,H11-031216,Unlock_successful
WV2ZZZSK8SX116493,Address 0x75,571 035 284 B,Online SFD,Monday,03,August,2026,18:45:29,H11-031216,SFD challenge retrieval success, 583 bytes
WV2ZZZSK8SX116493,Address 0x75,571 035 284 B,Online SFD,Monday,03,August,2026,18:45:33,H11-031216,SFD unlock token retrieval success, 852 bytes
WV2ZZZSK8SX116493,Address 0x75,571 035 284 B,Online SFD,Monday,03,August,2026,18:45:33,H11-031216,SFD unlock token transmitted to controller
WV2ZZZSK8SX116493,Address 0x75,571 035 284 B,Online SFD,Monday,03,August,2026,18:45:34,H11-031216,Unlock_successful
datodaco
Slovenia
C?ID=393757
I ve also found out that that also on this car in channel Auto distance (13) said that is successfully unlocked but hasnt been actually unlocked. Any other channels worked, i tried many tmes but no luck. Maybe because this is SFD 2.
  • Informative
