Recently Performed Right front Strut swap, this caused a fault. my initial thinking is an ABS sensor may have been inadvertently damaged.. however I'm perplexed aa to all the other codes associated with this issue. I was not the original Person doing strut repair. I've checked all connections perform a fault clear and the following faults come back?
Disregard these as they are known faults
Address 01: Engine (J623-DKFA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 9C0 BB0 2 HW: 06K 907 425 J
Component: R4 2.0l TFS H13 0003
Revision: --H13--- CVN: 0F880410
Coding: 092500124424012F3000
Shop #: WSC 00066 790 00391
ASAM Dataset: EV_ECM20TFS0205G09C0BB02 001003
ROD: EV_ECM20TFS0205G09C0BB02.rod
VCID: 3E253D7E40FB60AAFDF-806A
VINID: 0E69C69074A509B7411070070831080CB9
20638 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [00100111] - Malfunction / Open Circuit
15255 - Secondary Air Injection System Valve (N112)
P0413 00 [01100101] - Open Circuit
Sunday,02,August,2026,18:15:30:52565
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4701.4
VIN: 3VW6T7BU2KM147072 License Plate: AUG 02 2026 GLI WHEEL ISSUE
Mileage: 172536km-107208mi Repair Order:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 2B 32 3C 42 44 52 5F A9
VIN: 3VW6T7BU2KM147072 Mileage: 172536km-107208miles
Mileage: 172532 km
Date: 2026.08.02
Time: 17:58:44
Engine speed: 0.00 /min
Coolant temperature: 95 °C
Intake air temperature: 72 °C
Ambient air pressure: 840 mbar
Voltage terminal 30: 12.167 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 83 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
FAC_TPS_1_SAE: 16.406250 %
FUP_H_SAE: 10990.0 kPa
Mileage: 172532 km
Date: 2026.08.02
Time: 18:05:01
Engine speed: 845.75 /min
Normed load value: 7.5 %
Coolant temperature: 92 °C
Voltage terminal 30: 11.835 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
MAP_MES_SAE: 26 kPa
FAC_TPS_1_SAE: 12.890625 %
FUP_H_SAE: 8520.0 kPa
23176 - Sensor for Ambient Air Temperature (G17)
P0070 00 [00100100] - Malfunction
Mileage: 172533 km
Date: 2026.08.02
Time: 18:08:08
Engine speed: 3321.00 /min
Normed load value: 24.3 %
Vehicle speed: 105 km/h
Coolant temperature: 100 °C
Intake air temperature: 57 °C
Voltage terminal 30: 12.871 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 187 s
MAP_MES_SAE: 86 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.904 V
FAC_TPS_1_SAE: 30.859375 %
FUP_H_SAE: 20080.0 kPa
16803 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [00100100] - -
Mileage: 172533 km
Date: 2026.08.02
Time: 18:08:08
Engine speed: 3327.75 /min
Normed load value: 22.7 %
Voltage terminal 30: 12.832 V
ECU_STATE: SYN_ENG_IGK_ON
Engine oil temperature: 97.0 °C
Time since engine start: 188.9 s
T_ES: 0 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
T_AST_SAE: 187 s
Readiness: 0110 1101
Part No SW: 0GC 300 020 G HW: 0GC 927 711 H
Component: GSG DQ381 H06 2403
Revision: 00H06V07 CVN: BB564CFC
ROD: EV_TCMDQ381061.rod
VCID: 2615F51EB86BD86A95F-8072
No subsystems:
Part No SW: 5Q0 614 517 EB HW: 5Q0 614 517 BR
Component: ESC H82 0108
Revision: 00000000 Serial number: 53168000001068
Coding: 70FB6BA1502421738577020760C5A90ED60A84A1400695761041F059D2894B0B0000000012121212B835351919323200
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 75B7E252354DE3F2EC5-8020
16411 - Display for Tire Pressure Monitoring
C1146 02 [00001000] - Signal Failure
Reset counter: 30
Mileage: 172533 km
Date: 2026.08.02
Time: 18:08:17
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0500403098 Dataset Number: V03935272JE 0001
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004046
VCID: 43D34C8A2B190D42921-8016
Part No SW: 5GM 907 044 P HW: 5GM 907 044 P
Component: Climatronic H04 2009
Revision: 00001K04
Coding: 0102000420011800100400001211100C
ASAM Dataset: EV_ACClimaBHBVW37X 006148
VCID: 51FF76C2E165EFD210D-8004
459527 - Databus
[Klima_Sensor_02 - empfangener Fehlerwert]
Reset counter: 30
Mileage: 172533 km
Date: 2026.08.02
Time: 18:08:09
Part No SW: 5Q0 937 087 BB HW: 5Q0 937 087 BB
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C864281118052U Dataset Number: V03935281MQ 0001
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CA1F7761667B2BA93B-8028
Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: S6Y18M10D10H19M50S14
Coding: 0038DD
Humidity sensor: interior:
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 AS HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300181220180C202871
137217 - Outside temperature sensor
B103F 1B [10001000] - Resistance Too High
Reset counter: 30
Mileage: 172533 km
Date: 2026.08.02
Time: 18:08:07
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beams: Not operated
Voltage: 13.2 V
Outside temperature: 77.5 °C
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Dataset Number: V03935284GG 0205
Coding: 3300008111FFC428949C810500301600000000000000000004
VCID: 44D14F962E170A7AABB-8010
1395 - Databus
[FAULT_TEMP_FAIL]
Reset counter: 30
Mileage: 172533 km
Date: 2026.08.02
Time: 18:08:07
Control Module temperature: 65 °C
Voltage terminal 15: 12.9 V
Velocity_vehicle_reference: 28.60 m/s
Longitudinal_acceleration_vehicle_reference: 0.01 m/s²
Part No SW: 5Q0 959 655 BM HW: 5Q0 959 655 BM
Component: AirbagVW21 005 0403
Serial number: 003FGM000KA0 Dataset Number: V03935295BA 0001
Coding: 8CCCFC00000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 0C41A7B646C7823AA3B-8058
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000APNURW
Coding: 30344A
Subsystem 2 - Part No SW: ----------- HW: 480 003 110 18
Serial number: 35700000000133095531
Subsystem 3 - Part No SW: ----------- HW: 480 003 110 18
Serial number: 35800000000C2309553C
Subsystem 4 - Part No SW: ----------- HW: 480 403 108 18
Component: SideSensor_Dr 003 6149
Serial number: 35100019B2BB7D438249
Subsystem 5 - Part No SW: ----------- HW: 480 403 108 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001BB2A3241384F%
Subsystem 6 - Part No SW: ----------- HW: 480 400 511 18
Component: FrontSensor_D 004 6149
Serial number: 35500011C2B7C81310E0
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 511 18
Component: FrontSensor_P 004 6149
Serial number: 35600010A2BF5A73659C
1054981 - Databus
[NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
Reset counter: 30
Mileage: 172533 km
Date: 2026.08.02
Time: 18:08:11
Part No SW: 17A 920 840 A HW: 17A 920 840 A
Component: KOMBI 252 2500
Coding: 01A4011A2388CF05028823095000000020000000
Shop #: WSC 00066 790 00013
ASAM Dataset: EV_DashBoardVDDMQBAB 009065
VCID: 211FE602D1453F52E0D-8074
13639936 - Databus
[Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
Reset counter: 30
Mileage: 172533 km
Date: 2026.08.02
Time: 18:08:07
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 03121800842800 Dataset Number: V03935291WX 0001
Coding: 030100047F085900FB0002E99C0F00010001070000000000000000000000
Shop #: WSC 00066 790 00162
GVL: 01403C5000000600404C80000000C80000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E85CD3E501BD02A2DF-803A
Generator:
Component: 0-00-0d-00-04
Subsystem 2 - Part No SW: 5G0 959 442 AD HW: 5G0 959 442 AD Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0052
Serial number: 29180002518890098434
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 7009136200
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H07 0021
Serial number: 18000345145003
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F164281A58FD270D-8064
Address 32: Differential Locks (J492) Labels:| 0CQ-907-554-V2.clb
Part No SW: 0CQ 907 554 P HW: 0CQ 907 554 P
Component: Quersperre H52 8043
Serial number: HA1-00014.08.18 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 52FD79CEE46394CA297-8006
Address 3C: Lane Change (J1086) Labels:| 2Qx-907-686-V1.clb
Part No SW: 2Q0 907 686 A HW: 2Q0 907 686 A
Component: HRE3_Kl15_Mst H03 0052
Serial number: 00000496451945 Dataset Number: V03935286DX 0001
Coding: 5000C500
ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
ROD: EV_HREntryHellaGen3Kl15_001_VW37.rod
VCID: 38292B6662DF5E9A373-806C
Subsystem 1 - Part No SW: 2Q0 907 685 A HW: 2Q0 907 685 A
Component: HRE3_Kl15_Slv H03 0052
Serial number: 00000495786182
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q4 959 393 M HW: 5Q4 959 393 F
Component: TSG FS 006 0247
Serial number: 50038834200692 Dataset Number: V03935288VK 0001
Coding: 003C1B200000028000000000
VCID: 4DC76AB2FD5DCB32745-8018
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000001346863
Coding: 011000
Part No SW: 5QN 909 144 A HW: 5QN 909 144 A
Component: EPS_MQB_ZFLS 507 5081
Dataset Number: V03935283PS 0001
Coding: 811F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 50F973C6EA6FE6DA1F3-8004
Part No SW: 5Q4 959 392 M HW: 5Q4 959 392 F
Component: TSG BFS 006 0247
Serial number: 54038831401112 Dataset Number: V03935288VL 0001
Coding: 003C13200000028000000000
VCID: 4CC167B60647C23A63B-8018
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000001336138
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 17A 035 868 HW: 17A 035 868
Component: MU-E--ER 695 8742
Serial number: 15101800011277 Dataset Number: V03935281LR 0001
Coding: 02730100BE00000041220001001000009F0000D40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001041
ROD: EV_MUEnt4CGen2LGE_VW37.rod
VCID: 678BB81A7FE101626E9-8032
Part No SW: 5G0 907 159 F HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0004
Serial number: 181005203594
End----------(Elapsed Time: 01:27, VBatt start/end: 12.6V/12.6V)-----------
------------------------------10 Faults Found------------------------------
