Maps 2017 Passat B8 2.0 tfsi CHHB
Maps
Elder Moreira dos Santos
Brasil
C?ID=304355
AutoScan: WVWMV83C0JE096319
Wednesday,30,October,2024,13:28:11:18837
VCDS Version: 24.9.1.0 (x64)  HEX-NET CB: 0.4656.4
Data version: 20240926 DS359.0
VIN: WVWMV83C0JE096319   License Plate: PASSAT B8 2017
Mileage: 64698km-40201mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 42 44 4B 52 5F
          6C 6D A5 BB BC CA D6 D7
VIN: WVWMV83C0JE096319   Mileage: 64698km-40201miles
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259     HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---    CVN: 6ADF689C
   Coding: 091D00122464050B3000
   Shop #: WSC 05311 115 00324
   ASAM Dataset: EV_ECM20TFS0203G0906259 001007
   ROD: EV_ECM20TFS0203G0906259.rod
   VCID: 699A5BCB883077DDFC-803C
   VINID: 9E69DD9880D301A5402460C124F5AA5257
23176 - Sensor for Ambient Air Temperature (G17)
          P0070 00 {10101111} - Malfunction
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:18
                    Engine RPM: 0.00 /min
                    Coolant temperature: 61 °C
                    Intake air temperature: 36 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 11.777 V
                    Engine: operating status: ES
                    STATE_LS_SAE{1}: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 92 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.973 V
                    FAC_TPS_1_SAE: 16.015625 %
                    FUP_H_SAE: 12190.0 kPa
15007 - Valve for Fuel Metering (N290)
          P0089 00 {01100000} - Inadequate Performance
                    Mileage: 64689 km
                    Date: 2024.10.29
                    Time: 12:30:21
                    Engine RPM: 1517.75 /min
                    Normed load value: 25.1 %
                    Vehicle speed: 35 km/h
                    Coolant temperature: 85 °C
                    Voltage terminal 30: 12.968 V
                    Unlearning counter according OBD: 36
                    Engine: operating status: PL
                    STATE_LS_SAE{1}: CL
                    T_AST_SAE: 296 s
                    MAP_MES_SAE: 75 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.934 V
                    FUP_EFP_MES: 2531.31 hPa
                    FUP_H_SAE: 17660.0 kPa
16803 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 {00101111} - -
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:18
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 36.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 3 min
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    ECU_STATE: ENG_STOP
Readiness: 0010 0001
   Part No SW: 0D9 300 043 F    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5202
   Revision: 06454104    Serial number: TFK01708282741 CVN: 0000D204
   Shop #: WSC 05311 115 00086
   ROD: EV_TCMDQ250021.rod
   VCID: 1D723F1B0CF85B7D40-8048
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 62917000001082
   Coding: 0EEC6A8F34292372477A060140CC4970562CC4E2600292753842F0B8C209420000000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
   VCID: 79BA0B8BF890C75D0C-802C
16411 - Display for Tire Pressure Monitoring
          C1146 02 {10001001} - Signal Failure
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:41:02
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0458218208 Dataset Number: V03935260TX 0001
   Coding: 1F20000723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E30D897A13E206579-806A
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8095760
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 {00001000} - -
          {Function restriction due to temp low voltage}
                    Reset counter: 53
                    Mileage: 64686 km
                    Date: 2024.10.29
                    Time: 10:33:39
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 8.567 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 1102001420010001111550000010182A
   ROD: EV_ACClimaBHBVW37X_006_VW48.rod
   VCID: 78BC0E8FC39ADE5573-802C
   Air quality sensor:
   Humidity sensor: exterior:
459527 - Databus
          U1123 00 {00001001} - Received Error Message
          {Klima_Sensor_02 - empfangener Fehlerwert}
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:51
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865809101700EW Dataset Number: V03935267PZ 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06407077B96EB8A571-8052
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    171001  042 0607
   Serial number:         171006171721
   Component: RLHS  047 0105
   Serial number: S9Y17M10D22H23M29S27
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 23 05 2017  10000091
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY172450KDF
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0006
   Serial number: 00000000000000011233
   Humidity sensor: interior:
137217 - Outside temperature sensor
          B103F 1B {10001001} - Resistance Too High
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:52
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 11.7 V
                    Outside temperature: 77.5 °C
204546 - Remote key 2
          B147A 18 {00001001} - Current Too Low
                    Reset counter: 12
                    Mileage: 64686 km
                    Date: 2024.10.29
                    Time: 10:34:20
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.9 V
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617287 Dataset Number: V03935258CH 0001
   Coding: 0471151811
   ROD: EV_EPHVA18AU3700000_009_VW48.rod
   VCID: 4BD68143E28C85CDEE-801E
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 {00001001} - Open Circuit
                    Fault Frequency: 15
                    Reset counter: 15
                    Mileage: 64686 km
                    Date: 2024.10.29
                    Time: 10:33:42
13637888 - Databus
          {Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen}
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:58
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Dataset Number: V03935243QB 0001
   Coding: 320067C259FFC428949C8045
   Shop #: WSC 49314 004 1048576
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X_VW48.rod
   VCID: 3522C7BB9408E33DA8-8060
0795 - Databus
          {FAULT_APS_RELEVANT_ERROR}
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:53
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 11.7 V
1395 - Databus
          {FAULT_TEMP_FAIL}
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:53
   Serial number: 21091741350662 Dataset Number: V03935232RZ 0001
   ROD: EV_DRCONTITEMIC_VW48.rod
   VCID: 383CCE8F831A1E55B3-806C
835584 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 {10001001} - -
                    Fault Frequency: 21
                    Reset counter: 16
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:56
36363 - Valve for DamPing Adjustment Front Left
          C1040 13 {10001001} - Open Circuit
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:56
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6PM7TU7W Dataset Number: V03935266FT 0001
   Coding: 88CCC000000000005C5400CF000800000065
   Shop #: WSC 05311 000 08193
   VCID: 085C7E4FB37AAED503-805C
   Left seat belt tensioner:
   Serial number: 3G1857705G0290R01522
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3G1857706G0284R01955
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 000 510 17
   Serial number: 357000000009BC31D82V
   Subsystem 4 - Part No SW: -----------    HW: 454 000 510 17
   Serial number: 3580000000028BDCE921
   Subsystem 5 - Part No SW: -----------    HW: 454 801 210 17
   Serial number: 351003ED71C12000000J
   Subsystem 6 - Part No SW: -----------    HW: 454 801 210 17
   Serial number: 3520093CE1C12000000L
   Subsystem 7 - Part No SW: -----------    HW: 454 800 510 17
   Serial number: 3550091F52611000000A
1054981 - Databus
          {NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef}
                    Fault Frequency: 13
                    Reset counter: 16
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:49
   Part No SW: 5Q0 953 521 AF    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20171010300856
   Coding: 0010
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 76A000B7C98EA82561-8022
   Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
   Component: KOMBI         406 3193
   Coding: 07A401183F80000801886B011001000080000000
   VCID: 291A1BCB48B0B7DD3C-807C
13639936 - Databus
          {Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen}
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:52
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 16101710520362 Dataset Number: V03935263RC 0001
   Coding: 030300047F085900FB00025E9C0F00010001070000000000000000000000
   GVL: 01563C0008000600409C80000002CC0010000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3326F9A39A7CFD0D86-8066
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29170002191950067394
   Coding: 2DFFFF
   Serial number: 75886000001710140472
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
8526361 - LV Energy Management
          B1802 F1 {00001000} - Warning Triggered
                    Reset counter: 53
                    Mileage: 64690 km
                    Date: 2024.10.29
                    Time: 12:45:24
                    Terminal 30 power supply: 10.7 V
                    Terminal 15: On
   Serial number: 17000287135017
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71AA33ABA0E08F1DB4-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0022
   Serial number: Y0006QJB15825
   Coding: 001000020000050081C280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
   VCID: 3A38D487BD160C4545-806E
          {Funktionseinschränkung durch Unterspannung --> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.}
                    Reset counter: 53
                    Mileage: 64686 km
                    Date: 2024.10.29
                    Time: 12:25:22
   Serial number: 080917EI801567 Dataset Number: V03935256EF 0001
   Coding: 003F1A20D200028000000000
   ROD: EV_DCUDriveSideEWMAXCONT_VW48.rod
   VCID: 43C6A963CADC4D8D16-8016
   Revision: 00000000    Serial number: 0002101407 Dataset Number: V03935268WB 0001
   Coding: 01000010004001
   Shop #: WSC 00015 115 00324
   ROD: EV_SteerAssisVWBSMQBA_009.rod
   VCID: 40CCA66FDBCA56950B-8014
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 14101710800508
   Coding: 000000060100034A06004F01020000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_001_VW41.rod
   VCID: 72A83CA7A5E6B4054D-8026
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
0030 - Power Output Module for LED Headlamps; Left
          U1170 00 {10001001} - No Communications
          {KN_LED_DK3_L no communication}
                    Fault Frequency: 30
                    Reset counter: 16
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:51
131353 - Power Output Module for LED Headlamps; Left
          {LED_Feh_LM_L_03 no communication}
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:51
5275953 - Power Output Module for Left Headlamp
          C1081 31 {10001001} - No Signal
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:51
13706008 - Databus
          {KBI_Aussen_Temp_gef received error value}
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:51
5276182 - Power Output Module for Right Headlamp
          C1082 16 {00001000} - Voltage Too Low
                    Reset counter: 53
                    Mileage: 64690 km
                    Date: 2024.10.29
                    Time: 12:45:10
   Serial number: 300917EIU05619 Dataset Number: V03935268PR 0001
   Coding: 003F1020DE00028200000000
   ROD: EV_DCUPasseSideEWMAXCONT_VW48.rod
   VCID: 42C8AC67D5C644851D-8016
65578 - Motors for Central Locking
          B122B 12 {00001000} - Short to Plus
                    Reset counter: 54
65579 - Motors for Central Locking
          B122B 11 {00001000} - Short to Ground
                    Reset counter: 55
                    Mileage: 64686 km
                    Date: 2024.10.29
                    Time: 10:34:20
65598 - Motor for mirror fold-in
          B11F6 01 {00001000} - Electrical Failure
                    Reset counter: 54
65599 - Motor for mirror fold-in
                    Reset counter: 55
                    Mileage: 64686 km
                    Date: 2024.10.29
                    Time: 10:34:20
   Part No SW: 5NA 035 045 A    HW: 5NA 035 045
   Component: MU-H-N-RW     H54 1161
   Serial number: A849J0HS011554 Dataset Number: V03935264UK 0001
   Coding: 02840103FF00000051220001001828001F0100E401200400DF
   VCID: 3620C0B7890EE825A1-8062
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT2950642
   Subsystem 2 - Part No SW: V03 959 806 ND    HW: -----------
   Component: ROW 2021  --- 0090
   Compact disc data bank:
   Component: Gracenote2  --- 4012
   Dataset Number: V03935230RV 0001
   Coding: 0184010162002017000040
   VCID: 393ACB8BB810075D4C-806C
9591827 - Video Signal Line
          B125C 13 {00001000} - Open Circuit
                    Reset counter: 54
                    Mileage: 64686 km
                    Date: 2024.10.29
                    Time: 10:33:41
                    active
   Part No SW: 5Q0 959 107 K    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31566224000000 Dataset Number: V03935244HR 0001
   Coding: 0108
0066 - Databus
                    Reset counter: 11
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:51
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 13101712P14093 Dataset Number: V03935265PG 0001
   Coding: 0004080100000101002223448150490000000E300140
   VCID: 3C34D29FB722327557-8068
1123175 - Databus
          {Gateway_72_BCM1_Aussen_Temp_ungef}
                    Reset counter: 16
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:51
                    Control Module temperature: 36 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 238.8 s
                    mid: 02 8D
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1123184 - Databus
          {Kombi_02_KBI_Aussen_Temp_gef}
                    Reset counter: 16
                    Mileage: 64686 km
                    Date: 2024.10.28
                    Time: 19:40:54
                    System run time: 242.0 s
                    mid: 02 E2
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 260917EIN34494 Dataset Number: V03935256XR 0001
   Coding: 000E10200100028000000000
   ROD: EV_DCURearDriveMAXCONT_VW48.rod
   VCID: 45C2B77BC4E873BD38-8010
   Serial number: 260917EIN42532 Dataset Number: V03935256NT 0001
   ROD: EV_DCURearPasseMAXCONT_VW48.rod
   Part No SW: 4M0 907 594 K    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: V03935239FY 0001
   Coding: 608000748101
   ROD: EV_SunRoofCONTIAU736_006_VW41.rod
Address D6: Light Ctrl Left 2
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1R         H09 0003
   VCID: 16602037E9CE082581-8042
End----(Elapsed Time: 02:31, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
adpmap-01-3G0-906-259_WVWMV83C0JE096319-20241030-1329.CSV
;SW:3G0-906-259   HW:06K-907-425-E ---  Engine
;Component:2.0l R4 TFSI  H13 0004, Coding:091D00122464050B3000
;EV_ECM20TFS0203G0906259,001007,EV_ECM20TFS0203G0906259.rod
;Wednesday,30,October,2024,13:29:52:18837
;VCDS Version: Beta 24.9.1 (x64)  Data version: 20240926 DS359.0
;VCID: 699A5BCB883077DDFC-803C
IDE00259-Idle RPM correction,0 /min,1
IDE01945-Engine run-in oil pressure,not active ,1
IDE04158-Activation of start/stop function,active ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,-1.13 °,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,-3.19 °,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °,2
IDE06734-Timing deviation: current value intake bank 1,-1.00 °,2
IDE06736-Timing deviation: current value exhaust bank 1,-3.19 °,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,5 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,4 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,active ,1
IDE10261-MAS10172-Operating mode selec.-DI operation,not activated ,4
IDE10261-MAS10174-Operating mode selec.-CNG operation,not activated ,4
IDE10261-Operating mode selec.-,not activated ,4
Elapsed Time: 00:04
adpmap-02-0D9-300-043-F_WVWMV83C0JE096319-20241030-1329.CSV
;SW:0D9-300-043-F   HW:02E-927-770-AS ---  Auto Trans
;Component:DQ250-6F MQB  H54 5202, Coding:0014
;EV_TCMDQ250021,001001,EV_TCMDQ250021.rod
;Wednesday,30,October,2024,13:29:59:18837
;VCID: 1D723F1B0CF85B7D40-8048
Elapsed Time: 00:00
adpmap-03-5Q0-614-517-CH_WVWMV83C0JE096319-20241030-1330.CSV
;SW:5Q0-614-517-CH   HW:5Q0-614-517-AH ---  ABS Brakes
;Component:ESC           H62 0743, Coding:0EEC6A8F34292372477A060140CC4970562CC4E2600292753842F0B8C209420000000012121212B835351919323200
;EV_Brake1UDSContiMK100IPB,036010,EV_Brake1UDSContiMK100IPB_036_VW48.rod
;Wednesday,30,October,2024,13:30:05:18837
;VCID: 79BA0B8BF890C75D0C-802C
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake Boost,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05337-Starting vibration reduction-,Strong ,1
IDE05337-MAS02653-Starting vibration reduction-Limited torque,Deactivated ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,1 ,1
IDE07292-Brake pre-filling,completed successfully ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS07300-Monitoring infotainment control unit,Security access required,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG118148-Developer_Function_1,0 ,1
ENG122612-Developer_Function_100,Security access required,1
ENG122613-Developer_Function_101,Security access required,1
ENG122614-Developer_Function_102,Security access required,1
ENG122615-Developer_Function_103,Security access required,1
ENG122616-Developer_Function_104,Security access required,1
ENG122617-Developer_Function_105,Security access required,1
ENG122618-Developer_Function_108,Security access required,1
ENG125054-Developer_Function_110,Security access required,1
ENG130301-Developer_Function_121,not activated ,1
ENG118149-Developer_Function_2,Security access required,1
ENG118200-Developer_Function_3,Security access required,1
ENG118201-Developer_Function_4,Security access required,1
ENG127702-Developer_Function_5,Security access required,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:16
adpmap-05-3Q0-959-435-G_WVWMV83C0JE096319-20241030-1330.CSV
;SW:3Q0-959-435-G   HW:3Q0-959-435-G ---  Acc/Start Auth.
;Component:VWKESSYMQB    037 0906, Coding:1F20000723
;EV_KessyHellaMQBAB,004041,EV_KessyHellaMQBAB.rod
;Wednesday,30,October,2024,13:30:26:18837
;VCID: 3E30D897A13E206579-806A
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE09735-CU tailgate opener: sensor 1: threshold value 1,16 ,1
IDE09736-CU tailgate opener: sensor 1: threshold value 2,16 ,1
IDE09737-CU tailgate opener: sensor 1: threshold value 3,16 ,1
IDE09738-CU tailgate opener: sensor 1: threshold value 4,16 ,1
IDE09739-CU tailgate opener: sensor 1: threshold value 5,16 ,1
IDE09740-CU tailgate opener: sensor 2: threshold value 1,16 ,1
IDE09741-CU tailgate opener: sensor 2: threshold value 2,16 ,1
IDE09742-CU tailgate opener: sensor 2: threshold value 3,16 ,1
IDE09743-CU tailgate opener: sensor 2: threshold value 4,16 ,1
IDE09744-CU tailgate opener: sensor 2: threshold value 5,16 ,1
IDE09745-CU tailgate opener: sensor 1: timer value 1,0 ,1
IDE09746-CU tailgate opener: sensor 1: timer value 2,64 ,1
IDE09747-CU tailgate opener: sensor 1: timer value 3,2 ,1
IDE09748-CU tailgate opener: sensor 1: timer value 4,31 ,1
IDE09749-CU tailgate opener: sensor 1: timer value 5,5 ,1
IDE09750-CU tailgate opener: sensor 2: timer value 1,0 ,1
IDE09751-CU tailgate opener: sensor 2: timer value 2,224 ,1
IDE09752-CU tailgate opener: sensor 2: timer value 3,66 ,1
IDE09753-CU tailgate opener: sensor 2: timer value 4,31 ,1
IDE09754-CU tailgate opener: sensor 2: timer value 5,5 ,1
IDE09755-CU tailgate opener: sensor 1: burst length,0 ,1
IDE09756-CU tailgate opener: sensor 1: active screening,17 ,1
IDE09757-CU tailgate opener: sensor 2: burst length,0 ,1
IDE09758-CU tailgate opener: sensor 2: active screening,48 ,1
IDE09759-CU for tailgate opener: reset all counters,Reset ,1
IDE09760-CU for tailgate opener: check sum,255 ,1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,10 ,1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,9 ,1
IDE09831-CU for tailgate opener: play protection increments,6 ,1
IDE09832-CU for tailgate opener: play protection decrements,25 ,1
IDE09833-CU for tailgate opener: play protection threshold active,255 ,1
IDE09834-CU for tailgate opener: play protection threshold inactive,5 ,1
IDE09835-CU for tailgate opener: play protection decrement interval,60 ,1
IDE09836-CU tailgate opener: sensor 1: control parameter,45 ,1
IDE09837-CU tailgate opener: sensor 2: control parameter,192 ,1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,224 ,1
IDE09839-CU for tailgate opener: parameter set version,65535 ,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,1B ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG297724-Byte13_vit_lf-toggleVariante,China ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,not activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,Left hand steering ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %,9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,70 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms,9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,F4 ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,05 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,70 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,65 mV/m,5
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,7 B,1
ENG107595-MCTX settling phase,7 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,activated ,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
Elapsed Time: 00:57
adpmap-08-5G0-907-044-DP_WVWMV83C0JE096319-20241030-1331.CSV
;SW:5G0-907-044-DP   HW:5G0-907-044-DP ---  Auto HVAC
;Component:Climatronic   H04 2001, Coding:1102001420010001111550000010182A
;EV_ACClimaBHBVW37X,006146,EV_ACClimaBHBVW37X_006_VW48.rod
;Wednesday,30,October,2024,13:31:49:18837
;VCID: 78BC0E8FC39ADE5573-802C
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01479-Gear ratio of engine - A/C compressor,0.00 ,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01488-Auxiliary heating retrofit without CAN,not installed ,1
IDE01493-Sensitivity of air quality sensor,Maximum ,1
IDE01503-Running time of basic setting for compressor break-in,10 s,1
IDE01536-Post heating of auxiliary heating,0 min,1
IDE03176-Duration of compressor run in,0 s,1
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1500 /min,1
IDE06545-Blower voltage for production routines,6.0 V,1
IDE06593-Air recirculation for production routines,No effect ,1
IDE07108-A/C styles,Matching coding ,1
IDE07301-Remote start function: activation of seat heating,Front seat heating ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat.,4 °C,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,15 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,20 °C,1
IDE07307-Remote start function: activation stage of seat heating,2 ,1
IDE07308-Remote start function: activation stage of seat ventilation,2 ,1
IDE07398-Blower logic with manual adjustment,Matching coding ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,not active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE80006-Analysis 6,not activated ,1
IDE80007-Analysis 7,00000000 00000000  ,2
IDE80008-Analysis 8,not active ,1
MAS05739-CO2 compressor on-time reduction,Matching coding ,1
MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
MAS07251-Cut-in behavior,Matching coding ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
ENG122846-ENG99557-dimming_characteristic_3-X2,10 ,12
ENG122846-ENG102140-dimming_characteristic_3-X3,50 ,12
ENG122846-ENG102936-dimming_characteristic_3-X4,100 ,12
ENG122846-ENG103548-dimming_characteristic_3-X5,220 ,12
ENG122846-ENG113992-dimming_characteristic_3-X6,253 ,12
ENG122846-ENG99777-dimming_characteristic_3-Y1,3 %,12
ENG122846-ENG100480-dimming_characteristic_3-Y2,3 %,12
ENG122846-ENG100773-dimming_characteristic_3-Y3,6 %,12
ENG122846-ENG100631-dimming_characteristic_3-Y4,12 %,12
ENG122846-ENG102174-dimming_characteristic_3-Y5,100 %,12
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
ENG122847-ENG99557-dimming_characteristic_4-X2,10 ,12
ENG122847-ENG102140-dimming_characteristic_4-X3,50 ,12
ENG122847-ENG102936-dimming_characteristic_4-X4,100 ,12
ENG122847-ENG103548-dimming_characteristic_4-X5,220 ,12
ENG122847-ENG113992-dimming_characteristic_4-X6,253 ,12
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %,12
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %,12
ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %,12
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %,12
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %,12
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %,12
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
ENG130577-Knockout_timer_activation,not activated ,1
Elapsed Time: 00:14
adpmap-09-5Q0-937-086-BM_WVWMV83C0JE096319-20241030-1332.CSV
;SW:5Q0-937-086-BM   HW:5Q0-937-086-BH ---  Cent. Elect.
;Component:BCM PQ37BOSCH 034 0242, Coding:
;EV_BodyContrModul1UDSBosc,018001,EV_BCMBOSCH_018.rod
;Wednesday,30,October,2024,13:32:11:18837
;VCID: 06407077B96EB8A571-8052
IDE01550-Service position,153.296551 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG112304-Rear wiper-Heckwischer,not installed ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04928-MAS01577-Anti-theft protection-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,activ ,8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,Yes ,8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,21 34 00 14 02 00 7F 00 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 00 9C 08 09 1C 12 00 9C 04 4C 00 4C 14 00 64 07 00 9C 08 0A 1C 13 00 9C 01 3A 00 49 14 00 7F 00 00 00 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 00 00 00 08 0A 7F 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 C2 28 29 ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,17.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,17.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,27.50 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,26.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,27.50 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,26.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07356-Position during interval mode,24.890085 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,80 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,80 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,10 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting,Keine_Spannungsanforderung ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,1 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumatics,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,8.296695 °,2
IDE10299-Alternating park position 2,24.890085 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.40 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.40 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.60 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000001  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00111100  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,60 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,60 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,60 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,60 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,60 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,60 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,60 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,127 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,126 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,60 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,60 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,60 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,60 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,2.0 s,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
MAS05055-lower turn position,26.296677 °,2
MAS05056-upper turn position,171.296533 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag,Daytime running lamps ,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light,not installed ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Sollspannungsanforderung 13.5 ,18
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,56.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,56.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,56.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,56.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,51.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,47.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,33.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,26.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,3A ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,20 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Brake lamp ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,39 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,10 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Brake lamp ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Blinken links aktiv (beide Phasen) ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Brake lamp ,16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,minimize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Blinken rechts aktiv (beide Phasen) ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Brake lamp ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,90 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Brake lamp ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,minimize ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,37 ,16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,09 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,34 - LED Bremsleuchten ,16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Brake lamp ,16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,28 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,28 ,16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,28 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lamps ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Nebellicht links ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,28 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,28 ,16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,28 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lamps ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right ,16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Nebellicht rechts ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lamps ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lamps ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,0 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,not active ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,not active ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,0 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,not active ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,not active ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 64 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 64 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 64 06 18 80 00 00 00 00 00 00 20 1A 00 2A 08 0A 64 07 18 80 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 DA 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 64 18 00 80 1B 00 64 00 00 00 22 09 00 37 18 00 64 1B 00 80 00 00 00 00 00 00 25 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,25 20 00 3A 08 0A 64 18 00 64 00 00 00 00 00 00 25 10 00 39 08 09 64 18 00 64 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,CAN_Daempferregelung ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2550 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG141684-SFT271873-Slave_systems_identification-Wiper motor control module,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain/Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage door opener control head,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Anti-theft alarm system sensor,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sunroof control module,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Roof electronics control module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof shade control module,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Humidity sensor: interior,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Left head area heater,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Right head area heater,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Blower 1 for left front backrest,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Blower 1 for left front seat cushion,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Blower 1 for right front backrest,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Blower 1 for right front seat cushion,Not available ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,50 lx,10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,16.0 ,10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,25.0 ,10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,30.0 ,10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,50.0 ,10
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,installed ,9
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,active ,7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal,Inverted ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
Elapsed Time: 01:57
adpmap-10-5QA-919-294-B_WVWMV83C0JE096319-20241030-1334.CSV
;SW:5QA-919-294-B   HW:5QA-919-294 ---  Park/Steer Assist
;Component:PDC 8 KanalH07 0044, Coding:0471151811
;EV_EPHVA18AU3700000,009035,EV_EPHVA18AU3700000_009_VW48.rod
;Wednesday,30,October,2024,13:34:11:18837
;VCDS Version: Beta 24.9.1 (x64)  Data version: 20240926 DS359.0
;VCID: 4BD68143E28C85CDEE-801E
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble,not activated ,1
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble,not activated ,1
IDE00845-Wheel circumference,2070 mm,2
IDE01167-Convertible offset for volume level 1,255 ,1
IDE01168-Increment for convertible volume levels,255 ,1
IDE01169-Audio lowering request,On ,1
IDE02328-Distance to curb,15 cm,1
IDE03782-Switch-off speed for parking assist,14 km/h,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE11215-Automatic Activation,activated ,1
MAS01426-Rear parking aid buzzer: volume,Stage 6 ,1
MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
MAS01428-Front parking aid buzzer: volume,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 6 ,1
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners,0.180 1/m,6
MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners,1.308 1/m,6
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang,1.103 m,6
MAS12843-Maneuvering brake function,activated ,1
Elapsed Time: 00:08
adpmap-13-3Q0-907-572-C_WVWMV83C0JE096319-20241030-1334.CSV
;SW:3Q0-907-572-C   HW:3Q0-907-572-C ---  Auto Dist. Reg
;Component:ACC BOSCH MQB H04 0195, Coding:320067C259FFC428949C8045
;EV_ACCBOSCHVW48X,001009,EV_ACCBOSCHVW48X_VW48.rod
;Wednesday,30,October,2024,13:34:24:18837
;VCID: 3522C7BB9408E33DA8-8060
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01795-Heated lens,On ,1
IDE01949-Distance basic setting option,On ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,OFF ,1
IDE09564-Distance change via speed adjustment,On ,1
IDE09565-Prioritized target object display,On ,1
IDE10280-Constant delay after transfer request,Yes ,1
Elapsed Time: 00:04
adpmap-14-5Q0-907-376-B_WVWMV83C0JE096319-20241030-1334.CSV
;SW:5Q0-907-376-B   HW:5Q0-907-376-A ---  Susp. Elect.
;Component:DAEMPFUNGS-SG H17 0121, Coding:
;EV_DRCONTITEMIC,001019,EV_DRCONTITEMIC_VW48.rod
;Wednesday,30,October,2024,13:34:31:18837
;VCID: 383CCE8F831A1E55B3-806C
IDE04642-MAS00138-Chassis data-1,0 ,32
IDE04642-MAS00139-Chassis data-2,0 ,32
IDE04642-MAS00140-Chassis data-3,0 ,32
IDE04642-MAS00141-Chassis data-4,0 ,32
IDE04642-MAS00142-Chassis data-5,0 ,32
IDE04642-MAS00143-Chassis data-6,0 ,32
IDE04642-MAS00144-Chassis data-7,0 ,32
IDE04642-MAS01338-Chassis data-8,0 ,32
IDE04642-MAS03035-Chassis data-9,0 ,32
IDE04642-MAS03036-Chassis data-10,0 ,32
IDE04642-MAS03037-Chassis data-11,0 ,32
IDE04642-MAS03038-Chassis data-12,0 ,32
IDE04642-MAS03039-Chassis data-13,0 ,32
IDE04642-MAS03040-Chassis data-14,0 ,32
IDE04642-MAS03041-Chassis data-15,0 ,32
IDE04642-MAS03042-Chassis data-16,0 ,32
IDE04893-IDE04195-Adapting with deflected wheels-Left front level ctrl sys sensor: adaptation value (deflected),61.07 %,8
IDE04893-IDE04198-Adapting with deflected wheels-Right front level ctrl sys sensor: adaptation value (deflected),37.50 %,8
IDE04893-IDE04201-Adapting with deflected wheels-Left rear level ctrl sys sensor: adaptation value (deflected),67.74 %,8
IDE04893-IDE04204-Adapting with deflected wheels-Right rear level ctrl sys sensor: adaptation value (deflected),33.00 %,8
IDE04894-MAS04005-Constant current loading mode-Constant current loading mode: activation,OFF ,9
IDE04894-MAS04007-Constant current loading mode-Constant current loading mode: left front,0 mA,9
IDE04894-MAS04008-Constant current loading mode-Constant current loading mode: right front,0 mA,9
IDE04894-MAS04009-Constant current loading mode-Constant current loading mode: left rear,0 mA,9
IDE04894-MAS04010-Constant current loading mode-Constant current loading mode: right rear,0 mA,9
MAS02810-Channel selection,1 ,1
Elapsed Time: 00:02
adpmap-15-3Q0-959-655-BK_WVWMV83C0JE096319-20241030-1334.CSV
;SW:3Q0-959-655-BK   HW:3Q0-959-655-BK ---  Airbags
;Component:Airbag VW21   006 0703, Coding:88CCC000000000005C5400CF000800000065
;EV_AirbaVW21TS6VW48X,001014,EV_AirbaVW21TS6VW48X_VW37.rod
;Wednesday,30,October,2024,13:34:41:18837
;VCID: 085C7E4FB37AAED503-805C
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE06314-Calibration data: pre-crash,60 00 00 60 E0 00 00 00 00 FF 80 F8 00 60 B8 60 00 03 ,18
IDE06527-IDE06311-Adaptation pre-crash-Left seat belt tensioner,activated ,4
IDE06527-IDE06312-Adaptation pre-crash-Right seat belt tensioner,activated ,4
IDE12055-IDE12258-Adaptation airbag 2-Assistance-System-Monitor,activated ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed ,8
Elapsed Time: 00:03
adpmap-16-5Q0-953-521-AF_WVWMV83C0JE096319-20241030-1334.CSV
;SW:5Q0-953-521-AF   HW:5Q0-953-569-A ---  Steering wheel
;Component:Lenks.Modul   075 0235, Coding:0010
;EV_SMLSVALEOMQB,001016,EV_SMLSVALEOMQB.rod
;Wednesday,30,October,2024,13:34:47:18837
;VCID: 76A000B7C98EA82561-8022
ENG126417-p_n_fehler_p_verriegelt,50 ,1
ENG120504-p_s_NWDF_spg,0 ms,1
ENG102189-p_t_blinker_entprellen,40 ms,1
ENG102332-p_t_blinker_err_el_kurzschluss,200 ms,1
ENG104011-p_t_blinker_err_el_unterbrechung,1000 ms,1
ENG120503-p_t_blinker_err_fernlicht_haengt_aus,5000 ms,1
ENG120502-p_t_blinker_err_fernlicht_haengt_ein,300 s,1
ENG104185-p_t_blinker_err_gra_haengt_aus,5000 ms,1
ENG100988-p_t_blinker_err_gra_haengt_ein,300 s,1
ENG103202-p_t_blinker_err_lichthupe_haengt_aus,5000 ms,1
ENG100154-p_t_blinker_err_lichthupe_haengt_ein,300 s,1
ENG100923-p_t_blinker_err_unplausibel,2000 ms,1
ENG127113-p_t_blinker_err_weckkontakthaengt_aus,5000 ms,1
ENG127112-p_t_blinker_err_weckkontakthaengt_ein,3000 ms,1
ENG103471-p_t_blinker_gra_entprellen,40 ms,1
ENG101294-p_t_blinker_sperrzeit,100 ms,1
ENG127114-p_t_entprellung_p_unplausibel,400 ms,1
ENG104033-p_t_entprellzeit_ueberspannung,90000 ms,1
ENG101392-p_t_entprellzeit_unterspannung,90000 ms,1
ENG102689-p_t_fas_entprellen,40 ms,1
ENG120505-p_t_gra_ea_error,2000 ms,1
ENG101014-p_t_grahebel_entprellen,40 ms,1
ENG104117-p_t_grahebel_err_el_kurzschluss,200 ms,1
ENG102950-p_t_grahebel_err_el_unterbrechung,1000 ms,1
ENG103784-p_t_grahebel_err_gra_haengt_aus,5000 ms,1
ENG102546-p_t_grahebel_err_gra_haengt_ein,300 s,1
ENG103536-p_t_grahebel_err_unplausibel,200 ms,1
ENG99436-p_t_hupe_entprellen,40 ms,1
ENG102496-p_t_hupe_err_hinweis,2000 ms,1
ENG101071-p_t_hupe_err_hupe_haengt_aus,5000 ms,1
ENG101518-p_t_hupe_err_hupe_haengt_ein,60 s,1
ENG101702-p_t_hupe_indien_entprellen,500 ms,1
ENG100796-p_t_spannung_obere_schwelle,18.0 V,1
ENG102338-p_t_spannung_untere_schwelle,6.5 V,1
ENG100559-p_t_wischer_entprellen,40 ms,1
ENG103039-p_t_wischer_err_el_kurzschluss,200 ms,1
ENG101343-p_t_wischer_err_el_unterbrechung,1000 ms,1
ENG108143-p_t_wischer_err_intervallpoti_haengt_aus,5000 ms,1
ENG102443-p_t_wischer_err_intervallpoti_haengt_ein,300 s,1
ENG101059-p_t_wischer_err_mfa_haengt_aus,5000 ms,1
ENG100346-p_t_wischer_err_mfa_haengt_ein,300 s,1
ENG103464-p_t_wischer_err_waschen_haengt_aus,5000 ms,1
ENG100423-p_t_wischer_err_waschen_haengt_ein,300 s,1
ENG99933-p_t_wischer_err_wischen_haengt_aus,5000 ms,1
ENG102586-p_t_wischer_err_wischen_haengt_ein,300 s,1
ENG101592-p_t_wischer_intervall_entprellen,40 ms,1
ENG103607-p_t_wischer_winterstellung,60 s,1
Elapsed Time: 00:11
adpmap-17-3G0-920-791-C_WVWMV83C0JE096319-20241030-1328.CSV
;SW:3G0-920-791-C   HW:3G0-920-791-C ---  Instruments
;Component:KOMBI         406 3193, Coding:07A401183F80000801886B011001000080000000
;EV_DashBoardVDDMQBAB,009058,EV_DashBoardVDDMQBAB_009_VW26.rod
;Wednesday,30,October,2024,13:28:27:18837
;VCID: 291A1BCB48B0B7DD3C-807C
IDE00295-Oil temperature display,On ,1
IDE00301-Mileage,64698 km,3
IDE00342-ESI: Resetting ESI,Warning active ,1
IDE00343-Language variant,Portuguese (Brazil) ,1
IDE00500-Hour,13 H,1
IDE00501-Minute,28 min,1
IDE00502-Year,2024 yr,2
IDE00503-Month,10 Months,1
IDE00504-Day,30 d,1
IDE00510-ESI: distance driven from inspection,7630 km,3
IDE00511-ESI: time from inspection,381 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00518-ESI: thermal load,20200 km,2
IDE00819-Day counter,2416 d,2
IDE01153-SIA: maximum value of distance to service,10000 km,2
IDE02489-Display depiction,Variant 2 ,1
IDE03329-Driving profiled for range remaining,12.5 l/100km,2
IDE03346-IDE00301-Units adjusted-Mileage,Kilometers ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS03032-Units adjusted-Volume,Liters ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Kilometers per liter ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03349-FIX:Max. distance driven until next mileage-related inspection,30000 km,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,7600 km,2
IDE03352-FIX: Time since last time-dependent inspection,381 d,2
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Readout ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,not active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,not active ,1
MAS03555-Lap counter,Conditions not correct or request sequence error,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1,00 00 ,24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2,00 0A ,24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3,00 32 ,24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4,00 64 ,24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5,00 96 ,24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6,00 FD ,24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1,00 32 ,24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2,00 32 ,24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3,00 78 ,24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4,00 E6 ,24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5,01 F4 ,24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6,03 E8 ,24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1,00 00 ,24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2,00 0A ,24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3,00 64 ,24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4,00 96 ,24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5,00 DC ,24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6,00 FD ,24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1,00 09 ,24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2,00 09 ,24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3,00 50 ,24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4,01 90 ,24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5,03 52 ,24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6,03 E8 ,24
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 01 ,20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 32 ,20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,01 2C ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0A ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 32 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG126396-Scale_switching_algorithm,lowbeam_foglight ,1
ENG153765-Second_digital_speed,Readout ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.15 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
ENG153766-Tube_version,variant_0 ,1
Elapsed Time: 00:27
adpmap-19-3Q0-907-530-G_WVWMV83C0JE096319-20241030-1329.CSV
;SW:3Q0-907-530-G   HW:3Q0-907-530-C ---  CAN Gateway
;Component:GW MQB High   518 5304, Coding:030300047F085900FB00025E9C0F00010001070000000000000000000000
;EV_GatewNF,013023,EV_GatewNF_VW37.rod
;Wednesday,30,October,2024,13:29:20:18837
;VCID: 3326F9A39A7CFD0D86-8066
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01996-SFT00001-Installation list: specified installations-Engine Electronics,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Climate Control Module,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Distance Regulation,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics,coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systems,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,1 ,32
IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering column lock,coded ,32
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-A/C compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,coded ,32
IDE01996-SFT00081-Installation list: specified installations-Electric drive,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Trip recorder,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,coded ,32
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking aid,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Sunroof control module,coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter generator,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,69 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 ,2
IDE04159-Deactivation of start/stop function,Mode not active ,1
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE07838-Counter for inconsistent states,3022 ,2
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE10735-Number requests autonomous recharging,3 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,activated ,3
IDE11689-48V-System: locking,regular operation ,1
MAS16372-Security version number,2 ,2
SFT271921-IDE02583-Multifunction steering wheel control module-Steering wheel Tiptronic switch,installed ,3
SFT271921-MAS02311-Multifunction steering wheel control module-Steering wheel heating button,not active ,3
SFT271921-MAS04733-Multifunction steering wheel control module-Two-stage,Unknown (3),3
SFT271921-MAS06614-Multifunction steering wheel control module-Variant,ACC ,3
SFT271921-MAS09758-Multifunction steering wheel control module-Temperature sensor,not installed ,3
SFT271921-MAS13892-Multifunction steering wheel control module-Platform,Unknown (3),3
SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function,active ,3
SFT271921-ENG258379-Multifunction steering wheel control module-clamp behaviour,active with terminal 58 ,3
SFT271921-ENG260738-Multifunction steering wheel control module-FoD ACC,activated ,3
SFT271921-ENG258784-Multifunction steering wheel control module-FoD Travel Assist,activated ,3
SFT271921-ENG262857-Multifunction steering wheel control module-Kombi_02_gueltig,active ,3
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,0 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC),Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics,activated ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics,activated ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics,not activated ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side,activated ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Module,activated ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric,activated ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,activated ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1,activated ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Distance Regulation,activated ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics,activated ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not activated ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering column electronics systems,activated ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster,activated ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating,activated ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface,activated ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,activated ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant,activated ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2,activated ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics,activated ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,activated ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation,activated ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock,activated ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,activated ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics,activated ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side,activated ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance,activated ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,activated ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor,activated ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics,activated ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering,activated ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,activated ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive,activated ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics,activated ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control,activated ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,activated ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,activated ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1,activated ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder,activated ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS),activated ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,activated ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system,activated ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics,activated ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit,activated ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid,activated ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1,activated ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display,activated ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management,activated ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systems,activated ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module,activated ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator,activated ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system,activated ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics,activated ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics,activated ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management,activated ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door,activated ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door,activated ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,activated ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,activated ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger,activated ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module,activated ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator,activated ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,activated ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,activated ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,activated ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,activated ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,activated ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,activated ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,activated ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,activated ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,activated ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,activated ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,activated ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,activated ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,activated ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,activated ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,activated ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,activated ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,activated ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,activated ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,activated ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,activated ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,activated ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,activated ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,activated ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,activated ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,activated ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,activated ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,activated ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,activated ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,activated ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,activated ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,activated ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,activated ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,activated ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,activated ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,activated ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,activated ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,activated ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,activated ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,activated ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,activated ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,activated ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,activated ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,activated ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,activated ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,activated ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,activated ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,activated ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,activated ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,activated ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,activated ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,activated ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,activated ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,activated ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,activated ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,activated ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,activated ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,activated ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,activated ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,activated ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,activated ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,activated ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,activated ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,activated ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,activated ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,activated ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,activated ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,activated ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,activated ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,activated ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,activated ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,activated ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,activated ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,activated ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,activated ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,activated ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,activated ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,activated ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,activated ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,activated ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,activated ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,activated ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,activated ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,activated ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,activated ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,activated ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,activated ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,activated ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,activated ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,activated ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,activated ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,activated ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,activated ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,activated ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,activated ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,activated ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,activated ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,activated ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,activated ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,activated ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,activated ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,activated ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,activated ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,activated ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,activated ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,activated ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,activated ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,activated ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,activated ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,activated ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,activated ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,activated ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,activated ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,activated ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,activated ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,activated ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,activated ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,activated ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,activated ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,activated ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,activated ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,activated ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,activated ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,activated ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,activated ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,activated ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,activated ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,activated ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,activated ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,activated ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,activated ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,activated ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,activated ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,activated ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,activated ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,activated ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,activated ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,activated ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,activated ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,activated ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,activated ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,activated ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,activated ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,activated ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,activated ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,activated ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,activated ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,activated ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,ativado ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,ativado ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,ativado ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,ativado ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,ativado ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,ativado ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,ativado ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,ativado ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,ativado ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,ativado ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,ativado ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,ativado ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,ativado ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,ativado ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,ativado ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,ativado ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,ativado ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,ativado ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,ativado ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,ativado ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,ativado ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,ativado ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,ativado ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,ativado ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,ativado ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,ativado ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,ativado ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,ativado ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,ativado ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,ativado ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,ativado ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,ativado ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,ativado ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,ativado ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,ativado ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,ativado ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,ativado ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,ativado ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,ativado ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,ativado ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,ativado ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,ativado ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,ativado ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,ativado ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,ativado ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,ativado ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Barramento de dados do trem de força ,2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,não ativo,2
ENG152379-MV-EM_adaptação_48V_potencial_zero,operação_regular ,1
ENG137850-MVK_Aviso, operação normal, 1
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,ativado ,1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,ativado ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,10 ,8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,120 min,8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
Tempo decorrido: 00:27
[/CÓDIGO]
Elder Moreira dos Santos
Brasil
C?ID=304355
adpmap-2B-3Q0-905-861_WVWMV83C0JE096319-20241030-1335.CSV
;SW:3Q0-905-861   HW:3Q0-905-861 ---  Steer. Col. Lock
;Component:ELV-MQBB      H05 0032, Coding:0800000000000000
;EV_ELVMarquMQBB,001007,EV_ELVMarquMQBB_VW37.rod
;Wednesday,30,October,2024,13:35:01:18837
;VCDS Version: Beta 24.9.1 (x64)  Data version: 20240926 DS359.0
;VCID: 71AA33ABA0E08F1DB4-8024
IDE07566-Steering column lock unlocked,unlock ,1
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,tested ,1
Elapsed Time: 00:01
adpmap-36-3Q0-959-760-B_WVWMV83C0JE096319-20241030-1335.CSV
;SW:3Q0-959-760-B   HW:3Q0-959-760-B ---  Seat Mem. Drvr
;Component:Sitzmemory    H05 0022, Coding:001000020000050081C280808080000000008181000000F400
;EV_SeatMemorDriveSide,002021,EV_SeatMemorDriveSide_002_VW48.rod
;Wednesday,30,October,2024,13:35:05:18837
;VCID: 3A38D487BD160C4545-806E
IDE06869-installation position,Memory seat driver side ,1
ENG123066-vehicle_velocity_monitoring,active ,1
Elapsed Time: 00:00
adpmap-42-5Q0-959-593-E_WVWMV83C0JE096319-20241030-1335.CSV
;SW:5Q0-959-593-E   HW:5Q0-959-593-B ---  Door Elect, Driver
;Component:TSG FS        020 0041, Coding:003F1A20D200028000000000
;EV_DCUDriveSideEWMAXKLO,006003,EV_DCUDriveSideEWMAXCONT_VW48.rod
;Wednesday,30,October,2024,13:35:08:18837
;VCID: 43C6A963CADC4D8D16-8016
IDE00001-Production mode,00000000 00000000 00000000  ,3
IDE02332-Deactivate production mode,00000000 00000000 00000000  ,3
ENG117304-Patch_Code_Driver_Side_Rear,No Response From Subnet Component,3
ENG117299-Reversing_Threshold_Driver_Side_Rear,No Response From Subnet Component,1
ENG117302-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1,No Response From Subnet Component,1
ENG117303-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2,No Response From Subnet Component,1
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,No Response From Subnet Component,1
Elapsed Time: 00:12
adpmap-44-5Q0-909-143-P_WVWMV83C0JE096319-20241030-1335.CSV
;SW:5Q0-909-143-P   HW:5Q0-909-143-E ---  Steering Assist
;Component:MQB_PP_APA    204 2051, Coding:01000010004001
;EV_SteerAssisVWBSMQBA,009129,EV_SteerAssisVWBSMQBA_009.rod
;Wednesday,30,October,2024,13:35:23:18837
;VCID: 40CCA66FDBCA56950B-8014
IDE03724-Straight line running,active ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
Elapsed Time: 00:02
adpmap-4B-3Q0-907-338_WVWMV83C0JE096319-20241030-1335.CSV
;SW:3Q0-907-338   HW:3Q0-907-338 ---  Multifunc. Module
;Component:FCM MQB Low   002 0286, Coding:000000060100034A06004F01020000000000000000000000000000000000
;EV_MultiModulContiVW48X,001010,EV_MultiModulContiVW48X_001_VW41.rod
;Wednesday,30,October,2024,13:35:29:18837
;VCID: 72A83CA7A5E6B4054D-8026
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection,Yes ,1
IDE01996-SFT00041-Installation list: specified installations-Left light control,No ,1
IDE01996-SFT00057-Installation list: specified installations-Right light control,No ,1
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE03641-Presentation run dynamic AFS light,active ,1
IDE08418-Matrix light: total dimming,100 %,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest,0 %,12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion,0 %,12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest,0 %,12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion,0 %,12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest,0 %,12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion,0 %,12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest,0 %,12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion,0 %,12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest,0 %,12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion,0 %,12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest,0 %,12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion,0 %,12
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:09
adpmap-52-5Q0-959-592-E_WVWMV83C0JE096319-20241030-1335.CSV
;SW:5Q0-959-592-E   HW:5Q0-959-592-B ---  Door Elect, Pass.
;Component:TSG BFS       020 0041, Coding:003F1020DE00028200000000
;EV_DCUPasseSideEWMAXKLO,006003,EV_DCUPasseSideEWMAXCONT_VW48.rod
;Wednesday,30,October,2024,13:35:41:18837
;VCID: 42C8AC67D5C644851D-8016
ENG117308-Patch_Code_Passenger_Side_Rear,No Response From Subnet Component,3
ENG117300-Reversing_Threshold_Passenger_Side_Rear,No Response From Subnet Component,1
ENG117306-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1,No Response From Subnet Component,1
ENG117307-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2,No Response From Subnet Component,1
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,No Response From Subnet Component,1
Elapsed Time: 00:12
adpmap-5F-5NA-035-045-A_WVWMV83C0JE096319-20241030-1335.CSV
;SW:5NA-035-045-A   HW:5NA-035-045 ---  Information Electr.
;Component:MU-H-N-RW     H54 1161, Coding:02840103FF00000051220001001828001F0100E401200400DF
;EV_MUHig4CGen2HBAS,001001,EV_MUHig4CGen2HBAS_VW37.rod
;Wednesday,30,October,2024,13:35:58:18837
;VCID: 3620C0B7890EE825A1-8062
IDE00346-Summertime-automatic,manual ,1
IDE00759-Base volume of speech output,50 %,1
IDE00760-Microphone sensitivity,0 dB,1
IDE00768-Country identification: country of sale,-- ,2
IDE00769-Call number 1 for info call,5E 05 A1 80 00 55 75 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 05 A1 80 00 55 75 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE00845-Wheel circumference,0 mm,2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,No ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control head,No ,3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
IDE02121-CD eject button,Enabled ,1
IDE02330-Call number 2 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,49
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22 ,49
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22 ,49
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22 ,49
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22 ,49
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22 ,49
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22 ,49
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22 ,49
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,49
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,49
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,49
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,49
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,49
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22 ,49
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22 ,49
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22 ,49
IDE02502-Confirmation of installation change,2F 8D ,2
IDE02506-MAS03229-Copy multimedia data-Data carrier,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,On ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 91 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 91 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,On ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,locked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,not installed ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,not installed ,30
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,Deactivated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,On ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,1 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_AMERICA ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB888 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_ROW_SOUTHAMERICA ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,present ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,On ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,locked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,On ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE03902-Automatic ring break diagnostic,No automatic start ,1
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,1 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,4 ,2
IDE04521-Sporadic ring break detection,optical ,1
IDE04522-Awakening ability on optical databus,OFF ,1
IDE05111-Fee-based traffic information (TMC),65535 ,2
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Gas ,1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2,Gas ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE10082-MAS09813-Telephone functions configuration-Entering Access Point Name,On ,1
IDE10082-MAS09814-Telephone functions configuration-Call Center Function,On ,1
IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi,available. ,1
IDE10082-MAS13847-Telephone functions configuration-Call center function on MIB: roadside assistance call,On ,1
IDE10082-MAS13848-Telephone functions configuration-Call center function on MIB: POI call,On ,1
IDE10082-MAS16726-Telephone functions configuration-Call center function on MIB: POI call regions,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 ,40
IDE10604-Menu entries for mobile online services,not activated ,1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,37 dBµV,3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,32 dB,3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,15.0 s,3
IDE11105-Brand-specific display of connect application, ,256
IDE11122-Country identification: country of sale HMI,BR ,2
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength,4294967295 ,330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle,65535 ,330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle,65535 ,330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos,32767 ,330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle,65535 ,330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos,32767 ,330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos,32767 ,330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,21
IDE11524-ENG249835-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57,not activated ,192
IDE11524-ENG249836-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57_msg_bus,not activated ,192
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
IDE11524-ENG249837-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C,not activated ,192
IDE11524-ENG249838-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C_msg_bus,not activated ,192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,not activated ,192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
IDE11524-ENG248719-Vehicle function list BAP 2nd generation: expansion-ITM_0x65,not activated ,192
IDE11524-ENG248720-Vehicle function list BAP 2nd generation: expansion-ITM_0x65_msg_bus,not activated ,192
IDE11524-ENG249902-Vehicle function list BAP 2nd generation: expansion-lift_0x64,not activated ,192
IDE11524-ENG249903-Vehicle function list BAP 2nd generation: expansion-lift_0x64_msg_bus,not activated ,192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,not activated ,192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
IDE11638-Bluetooth Audio Codec,FF ,1
IDE12353-Configuration of traffic light online functions,On ,1
IDE12434-ENG249906-Vehicle menu operation: second generation: extension-menu_chassis_control,not activated ,60
IDE12434-ENG249907-Vehicle menu operation: second generation: extension-menu_chassis_control_after_disclaimer,not activated ,60
IDE12434-ENG249908-Vehicle menu operation: second generation: extension-menu_chassis_control_clamp_15_off,not activated ,60
IDE12434-ENG249909-Vehicle menu operation: second generation: extension-menu_chassis_control_over_threshold_high,not activated ,60
IDE12434-ENG249910-Vehicle menu operation: second generation: extension-menu_chassis_control_stillstand,not activated ,60
IDE12434-ENG152495-Vehicle menu operation: second generation: extension-menu_connection_manager,not activated ,60
IDE12434-ENG152499-Vehicle menu operation: second generation: extension-menu_connection_manager_after_disclaimer,not activated ,60
IDE12434-ENG152496-Vehicle menu operation: second generation: extension-menu_connection_manager_clamp_15_off,not activated ,60
IDE12434-ENG152497-Vehicle menu operation: second generation: extension-menu_connection_manager_over_threshold_high,not activated ,60
IDE12434-ENG152498-Vehicle menu operation: second generation: extension-menu_connection_manager_standstill,not activated ,60
IDE12434-ENG249911-Vehicle menu operation: second generation: extension-menu_convertible_top,not activated ,60
IDE12434-ENG249912-Vehicle menu operation: second generation: extension-menu_convertible_top_after_disclaimer,not activated ,60
IDE12434-ENG249913-Vehicle menu operation: second generation: extension-menu_convertible_top_clamp_15_off,not activated ,60
IDE12434-ENG249914-Vehicle menu operation: second generation: extension-menu_convertible_top_over_threshold_high,not activated ,60
IDE12434-ENG249915-Vehicle menu operation: second generation: extension-menu_convertible_top_stillstand,not activated ,60
IDE12434-ENG152548-Vehicle menu operation: second generation: extension-menu_daf_profile,not activated ,60
IDE12434-ENG152549-Vehicle menu operation: second generation: extension-menu_daf_profile_after_disclaimer,not activated ,60
IDE12434-ENG152550-Vehicle menu operation: second generation: extension-menu_daf_profile_clamp_15_off,not activated ,60
IDE12434-ENG152551-Vehicle menu operation: second generation: extension-menu_daf_profile_over_threshold_high,not activated ,60
IDE12434-ENG152552-Vehicle menu operation: second generation: extension-menu_daf_profile_stillstand,not activated ,60
IDE12434-ENG185793-Vehicle menu operation: second generation: extension-menu_engine_functions,not activated ,60
IDE12434-ENG185794-Vehicle menu operation: second generation: extension-menu_engine_functions_after_disclaimer,not activated ,60
IDE12434-ENG185795-Vehicle menu operation: second generation: extension-menu_engine_functions_clamp_15_off,not activated ,60
IDE12434-ENG185796-Vehicle menu operation: second generation: extension-menu_engine_functions_over_threshold_high,not activated ,60
IDE12434-ENG185797-Vehicle menu operation: second generation: extension-menu_engine_functions_stillstand,not activated ,60
IDE12434-ENG152515-Vehicle menu operation: second generation: extension-menu_fas_profile,not activated ,60
IDE12434-ENG152519-Vehicle menu operation: second generation: extension-menu_fas_profile_after_disclaimer,not activated ,60
IDE12434-ENG152516-Vehicle menu operation: second generation: extension-menu_fas_profile_clamp_15_off,not activated ,60
IDE12434-ENG152517-Vehicle menu operation: second generation: extension-menu_fas_profile_over_threshold_high,not activated ,60
IDE12434-ENG152518-Vehicle menu operation: second generation: extension-menu_fas_profile_standstill,not activated ,60
IDE12434-ENG185798-Vehicle menu operation: second generation: extension-menu_fod,not activated ,60
IDE12434-ENG185799-Vehicle menu operation: second generation: extension-menu_fod_after_disclaimer,not activated ,60
IDE12434-ENG185800-Vehicle menu operation: second generation: extension-menu_fod_clamp_15_off,not activated ,60
IDE12434-ENG185801-Vehicle menu operation: second generation: extension-menu_fod_over_threshold_high,not activated ,60
IDE12434-ENG185802-Vehicle menu operation: second generation: extension-menu_fod_stillstand,not activated ,60
IDE12434-ENG248744-Vehicle menu operation: second generation: extension-menu_ITM,not activated ,60
IDE12434-ENG248745-Vehicle menu operation: second generation: extension-menu_ITM_after_disclaimer,not activated ,60
IDE12434-ENG248746-Vehicle menu operation: second generation: extension-menu_ITM_clamp_15_off,not activated ,60
IDE12434-ENG248747-Vehicle menu operation: second generation: extension-menu_ITM_over_threshold_high,not activated ,60
IDE12434-ENG248748-Vehicle menu operation: second generation: extension-menu_ITM_stillstand,not activated ,60
IDE12434-ENG249916-Vehicle menu operation: second generation: extension-menu_lift,not activated ,60
IDE12434-ENG249917-Vehicle menu operation: second generation: extension-menu_lift_after_disclaimer,not activated ,60
IDE12434-ENG249918-Vehicle menu operation: second generation: extension-menu_lift_clamp_15_off,not activated ,60
IDE12434-ENG249919-Vehicle menu operation: second generation: extension-menu_lift_over_threshold_high,not activated ,60
IDE12434-ENG249920-Vehicle menu operation: second generation: extension-menu_lift_stillstand,not activated ,60
IDE12434-ENG184478-Vehicle menu operation: second generation: extension-menu_mascot,not activated ,60
IDE12434-ENG184479-Vehicle menu operation: second generation: extension-menu_mascot_after_disclaimer,not activated ,60
IDE12434-ENG184480-Vehicle menu operation: second generation: extension-menu_mascot_clamp_15_off,not activated ,60
IDE12434-ENG184481-Vehicle menu operation: second generation: extension-menu_mascot_over_threshold_high,not activated ,60
IDE12434-ENG184482-Vehicle menu operation: second generation: extension-menu_mascot_stillstand,not activated ,60
IDE12434-ENG152562-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile,not activated ,60
IDE12434-ENG152563-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_after_disclaimer,not activated ,60
IDE12434-ENG152564-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_clamp_15_off,not activated ,60
IDE12434-ENG152565-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_over_threshold_high,not activated ,60
IDE12434-ENG152566-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_stillstand,not activated ,60
IDE12434-ENG152505-Vehicle menu operation: second generation: extension-menu_statistic,not activated ,60
IDE12434-ENG152509-Vehicle menu operation: second generation: extension-menu_statistic_after_disclaimer,not activated ,60
IDE12434-ENG152506-Vehicle menu operation: second generation: extension-menu_statistic_clamp_15_off,not activated ,60
IDE12434-ENG152507-Vehicle menu operation: second generation: extension-menu_statistic_over_threshold_high,not activated ,60
IDE12434-ENG152508-Vehicle menu operation: second generation: extension-menu_statistic_standstill,not activated ,60
IDE12434-ENG152510-Vehicle menu operation: second generation: extension-menu_sunroof,not activated ,60
IDE12434-ENG152514-Vehicle menu operation: second generation: extension-menu_sunroof_after_disclaimer,not activated ,60
IDE12434-ENG152511-Vehicle menu operation: second generation: extension-menu_sunroof_clamp_15_off,not activated ,60
IDE12434-ENG152512-Vehicle menu operation: second generation: extension-menu_sunroof_over_threshold_high,not activated ,60
IDE12434-ENG152513-Vehicle menu operation: second generation: extension-menu_sunroof_standstill,not activated ,60
IDE12434-ENG185803-Vehicle menu operation: second generation: extension-menu_vas,not activated ,60
IDE12434-ENG185804-Vehicle menu operation: second generation: extension-menu_vas_after_disclaimer,not activated ,60
IDE12434-ENG185805-Vehicle menu operation: second generation: extension-menu_vas_clamp_15_off,not activated ,60
IDE12434-ENG185806-Vehicle menu operation: second generation: extension-menu_vas_over_threshold_high,not activated ,60
IDE12434-ENG185807-Vehicle menu operation: second generation: extension-menu_vas_stillstand,not activated ,60
IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging,not activated ,60
IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer,not activated ,60
IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off,not activated ,60
IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high,not activated ,60
IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill,not activated ,60
IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
MAS00951-Bluetooth,On ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
MAS03782-WLAN,On ,1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,OFF ,12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,0.00 ms,12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,OFF ,12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,0.00 ms,12
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Extended data bus ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Infotainment data bus ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Powertrain data bus ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Infotainment data bus ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Infotainment data bus ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Powertrain data bus ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Extended data bus ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Infotainment data bus ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Extended data bus ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Infotainment data bus ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Powertrain data bus ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Infotainment data bus ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Extended data bus ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Extended data bus ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Infotainment data bus ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Infotainment data bus ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Infotainment data bus ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,available. ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Infotainment data bus ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Powertrain data bus ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,available. ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,available. ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On ,10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE ,10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1 ,10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,0 ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,OFF ,10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1 ,10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,MOST_streaming ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On ,10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 28 02 50 02 50 02 28 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 48 ,40
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,13 %,1
ENG117910-Set_Remote_Test_Channel_Scanning,Conditions not correct or request sequence error,2
ENG117908-Shift_Remote_Test_Frequency_AM,Conditions not correct or request sequence error,2
ENG117907-Shift_Remote_Test_Frequency_FM,Conditions not correct or request sequence error,2
ENG117906-Shift_Remote_Test_Volume,Conditions not correct or request sequence error,2
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 00:54
adpmap-6C-5Q0-980-556-B_WVWMV83C0JE096319-20241030-1336.CSV
;SW:5Q0-980-556-B   HW:5Q0-980-556-B ---  Back-up Cam.
;Component:RVC Compact   H12 0231, Coding:0184010162002017000040
;EV_CamSysRVRVCPANAMQBAB,006009,EV_CamSysRVRVCPANAMQBAB.rod
;Wednesday,30,October,2024,13:36:56:18837
;VCDS Version: Beta 24.9.1 (x64)  Data version: 20240926 DS359.0
;VCID: 393ACB8BB810075D4C-806C
IDE02709-Actuator: PWM signal,100 %,1
IDE03531-Wheel/tire description,1950 mm,2
MAS02209-Image contrast,53 %,1
MAS02851-Brightness,51 %,1
ENG119212-camera_off,35.00 km/h,2
ENG119211-camera_on,30.00 km/h,2
ENG119200-color,51 %,1
ENG119218-debounce_time_for_reverse_gear,0 ms,2
ENG119215-display_position,0 px,1
ENG119216-engine_restart_timer,0 ms,2
ENG119209-Frequency_Swinging_Logo,100 Hz,2
ENG119221-FSG_control_state,On ,1
ENG119220-ENG119101-grafic_element_setting-setting_1_color_value,FF FF ,128
ENG119220-ENG119099-grafic_element_setting-setting_1_HMI_mode,FF ,128
ENG119220-ENG119100-grafic_element_setting-setting_1_pallet_ID,255 ,128
ENG119220-ENG119128-grafic_element_setting-setting_10_color_value,FF FF ,128
ENG119220-ENG119126-grafic_element_setting-setting_10_HMI_mode,FF ,128
ENG119220-ENG119127-grafic_element_setting-setting_10_pallet_ID,255 ,128
ENG119220-ENG119131-grafic_element_setting-setting_11_color_value,FF FF ,128
ENG119220-ENG119129-grafic_element_setting-setting_11_HMI_mode,FF ,128
ENG119220-ENG119130-grafic_element_setting-setting_11_pallet_ID,255 ,128
ENG119220-ENG119134-grafic_element_setting-setting_12_color_value,FF FF ,128
ENG119220-ENG119132-grafic_element_setting-setting_12_HMI_mode,FF ,128
ENG119220-ENG119133-grafic_element_setting-setting_12_pallet_ID,255 ,128
ENG119220-ENG119137-grafic_element_setting-setting_13_color_value,FF FF ,128
ENG119220-ENG119135-grafic_element_setting-setting_13_HMI_mode,FF ,128
ENG119220-ENG119136-grafic_element_setting-setting_13_pallet_ID,255 ,128
ENG119220-ENG119140-grafic_element_setting-setting_14_color_value,FF FF ,128
ENG119220-ENG119138-grafic_element_setting-setting_14_HMI_mode,FF ,128
ENG119220-ENG119139-grafic_element_setting-setting_14_pallet_ID,255 ,128
ENG119220-ENG119143-grafic_element_setting-setting_15_color_value,FF FF ,128
ENG119220-ENG119141-grafic_element_setting-setting_15_HMI_mode,FF ,128
ENG119220-ENG119142-grafic_element_setting-setting_15_pallet_ID,255 ,128
ENG119220-ENG119146-grafic_element_setting-setting_16_color_value,FF FF ,128
ENG119220-ENG119144-grafic_element_setting-setting_16_HMI_mode,FF ,128
ENG119220-ENG119145-grafic_element_setting-setting_16_pallet_ID,255 ,128
ENG119220-ENG119149-grafic_element_setting-setting_17_color_value,FF FF ,128
ENG119220-ENG119147-grafic_element_setting-setting_17_HMI_mode,FF ,128
ENG119220-ENG119148-grafic_element_setting-setting_17_pallet_ID,255 ,128
ENG119220-ENG119152-grafic_element_setting-setting_18_color_value,FF FF ,128
ENG119220-ENG119150-grafic_element_setting-setting_18_HMI_mode,FF ,128
ENG119220-ENG119151-grafic_element_setting-setting_18_pallet_ID,255 ,128
ENG119220-ENG119155-grafic_element_setting-setting_19_color_value,FF FF ,128
ENG119220-ENG119153-grafic_element_setting-setting_19_HMI_mode,FF ,128
ENG119220-ENG119154-grafic_element_setting-setting_19_pallet_ID,255 ,128
ENG119220-ENG119104-grafic_element_setting-setting_2_color_value,FF FF ,128
ENG119220-ENG119102-grafic_element_setting-setting_2_HMI_mode,FF ,128
ENG119220-ENG119103-grafic_element_setting-setting_2_pallet_ID,255 ,128
ENG119220-ENG119158-grafic_element_setting-setting_20_color_value,FF FF ,128
ENG119220-ENG119156-grafic_element_setting-setting_20_HMI_mode,FF ,128
ENG119220-ENG119157-grafic_element_setting-setting_20_pallet_ID,255 ,128
ENG119220-ENG119161-grafic_element_setting-setting_21_color_value,FF FF ,128
ENG119220-ENG119159-grafic_element_setting-setting_21_HMI_mode,FF ,128
ENG119220-ENG119160-grafic_element_setting-setting_21_pallet_ID,255 ,128
ENG119220-ENG119164-grafic_element_setting-setting_22_color_value,FF FF ,128
ENG119220-ENG119162-grafic_element_setting-setting_22_HMI_mode,FF ,128
ENG119220-ENG119163-grafic_element_setting-setting_22_pallet_ID,255 ,128
ENG119220-ENG119167-grafic_element_setting-setting_23_color_value,FF FF ,128
ENG119220-ENG119165-grafic_element_setting-setting_23_HMI_mode,FF ,128
ENG119220-ENG119166-grafic_element_setting-setting_23_pallet_ID,255 ,128
ENG119220-ENG119170-grafic_element_setting-setting_24_color_value,FF FF ,128
ENG119220-ENG119168-grafic_element_setting-setting_24_HMI_mode,FF ,128
ENG119220-ENG119169-grafic_element_setting-setting_24_pallet_ID,255 ,128
ENG119220-ENG119173-grafic_element_setting-setting_25_color_value,FF FF ,128
ENG119220-ENG119171-grafic_element_setting-setting_25_HMI_mode,FF ,128
ENG119220-ENG119172-grafic_element_setting-setting_25_pallet_ID,255 ,128
ENG119220-ENG119176-grafic_element_setting-setting_26_color_value,FF FF ,128
ENG119220-ENG119174-grafic_element_setting-setting_26_HMI_mode,FF ,128
ENG119220-ENG119175-grafic_element_setting-setting_26_pallet_ID,255 ,128
ENG119220-ENG119179-grafic_element_setting-setting_27_color_value,FF FF ,128
ENG119220-ENG119177-grafic_element_setting-setting_27_HMI_mode,FF ,128
ENG119220-ENG119178-grafic_element_setting-setting_27_pallet_ID,255 ,128
ENG119220-ENG119182-grafic_element_setting-setting_28_color_value,FF FF ,128
ENG119220-ENG119180-grafic_element_setting-setting_28_HMI_mode,FF ,128
ENG119220-ENG119181-grafic_element_setting-setting_28_pallet_ID,255 ,128
ENG119220-ENG119185-grafic_element_setting-setting_29_color_value,FF FF ,128
ENG119220-ENG119183-grafic_element_setting-setting_29_HMI_mode,FF ,128
ENG119220-ENG119184-grafic_element_setting-setting_29_pallet_ID,255 ,128
ENG119220-ENG119107-grafic_element_setting-setting_3_color_value,FF FF ,128
ENG119220-ENG119105-grafic_element_setting-setting_3_HMI_mode,FF ,128
ENG119220-ENG119106-grafic_element_setting-setting_3_pallet_ID,255 ,128
ENG119220-ENG119188-grafic_element_setting-setting_30_color_value,FF FF ,128
ENG119220-ENG119186-grafic_element_setting-setting_30_HMI_mode,FF ,128
ENG119220-ENG119187-grafic_element_setting-setting_30_pallet_ID,255 ,128
ENG119220-ENG119191-grafic_element_setting-setting_31_color_value,FF FF ,128
ENG119220-ENG119189-grafic_element_setting-setting_31_HMI_mode,FF ,128
ENG119220-ENG119190-grafic_element_setting-setting_31_pallet_ID,255 ,128
ENG119220-ENG119194-grafic_element_setting-setting_32_color_value,FF FF ,128
ENG119220-ENG119192-grafic_element_setting-setting_32_HMI_mode,FF ,128
ENG119220-ENG119193-grafic_element_setting-setting_32_pallet_ID,255 ,128
ENG119220-ENG119110-grafic_element_setting-setting_4_color_value,FF FF ,128
ENG119220-ENG119108-grafic_element_setting-setting_4_HMI_mode,FF ,128
ENG119220-ENG119109-grafic_element_setting-setting_4_pallet_ID,255 ,128
ENG119220-ENG119113-grafic_element_setting-setting_5_color_value,FF FF ,128
ENG119220-ENG119111-grafic_element_setting-setting_5_HMI_mode,FF ,128
ENG119220-ENG119112-grafic_element_setting-setting_5_pallet_ID,255 ,128
ENG119220-ENG119116-grafic_element_setting-setting_6_color_value,FF FF ,128
ENG119220-ENG119114-grafic_element_setting-setting_6_HMI_mode,FF ,128
ENG119220-ENG119115-grafic_element_setting-setting_6_pallet_ID,255 ,128
ENG119220-ENG119119-grafic_element_setting-setting_7_color_value,FF FF ,128
ENG119220-ENG119117-grafic_element_setting-setting_7_HMI_mode,FF ,128
ENG119220-ENG119118-grafic_element_setting-setting_7_pallet_ID,255 ,128
ENG119220-ENG119122-grafic_element_setting-setting_8_color_value,FF FF ,128
ENG119220-ENG119120-grafic_element_setting-setting_8_HMI_mode,FF ,128
ENG119220-ENG119121-grafic_element_setting-setting_8_pallet_ID,255 ,128
ENG119220-ENG119125-grafic_element_setting-setting_9_color_value,FF FF ,128
ENG119220-ENG119123-grafic_element_setting-setting_9_HMI_mode,FF ,128
ENG119220-ENG119124-grafic_element_setting-setting_9_pallet_ID,255 ,128
ENG119201-image_delay_timer,0.0 s,1
ENG119219-Minimal_time_to_stay_in_bus_sleep_before_ECU_off,20000 ms,2
ENG119214-rv_dark_off,10.00 km/h,2
ENG119213-rv_dark_on,15.00 km/h,2
ENG119203-RV_Last_Mode,90° parking spot ,1
ENG102898-RV_Start_Mode,90° parking spot ,1
ENG119205-Time_to_open_Swinging_Logo,750 ms,2
Elapsed Time: 00:07
adpmap-6D-5Q0-959-107-K_WVWMV83C0JE096319-20241030-1337.CSV
;SW:5Q0-959-107-K   HW:5Q0-959-107-H ---  Trunk Elect.
;Component:HDSG-Modul    H13 0261, Coding:0108
;EV_DeckLidCONTIAU736,001014,EV_DeckLidCONTIAU736_VW37.rod
;Wednesday,30,October,2024,13:37:05:18837
;VCID: 40CCA66FDBCA56950B-8014
IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
IDE00001-MAS10735-Production mode-Calibration,not active ,3
IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
IDE02158-Program opening stop,1258 ,2
IDE03435-Detection area upper,10 ,2
IDE03776-Offset for maximum programmable opening stop,40 ,2
IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,1 ,4
IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,224 ,4
IDE09511-Minimum opening height of tailgate,400 ,2
IDE09512-Deactivation of tailgate,active ,1
IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active ,2
IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
IDE09520-Offset for opening height after basic setting,0 ,2
IDE10408-Opening height in production mode,60 %,2
IDE10695-Dectivation of the luggage compartment cover,not active ,1
IDE10703-Luggage compartment cover: tolerance of the block counter,0 ,2
IDE10704-Luggage compartment cover: maximum no. of block drives,0 ,2
IDE10705-Luggage compartment cover: number bloom drives,0 ,2
IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,0 ,4
IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,0 ,4
IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,0 ,4
IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,0 ,4
IDE10708-Luggage compartment cover: adjust. track tolerance,0 ,2
IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active ,1
ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,not active ,2
ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,active ,2
ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,active ,2
ENG131232-MAS08212-Ausstattungen aktivieren-Motor 2,not active ,2
ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,not active ,2
Elapsed Time: 00:06
adpmap-A5-3Q0-980-654-H_WVWMV83C0JE096319-20241030-1337.CSV
;SW:3Q0-980-654-H   HW:3Q0-980-654-A ---  Frt Sens. Drv. Assist
;Component:MQB_B_MFK     H07 0272, Coding:0004080100000101002223448150490000000E300140
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_VW36.rod
;Wednesday,30,October,2024,13:37:21:18837
;VCID: 3C34D29FB722327557-8068
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
IDE04733-Road sign detection fusion mode,Road sign fusion ,1
IDE07358-Distance to calibration field,1500 mm,2
IDE09375-IDE05717-Axle offset-Front axle transverse position,7.70001 mm,4
IDE09375-IDE05718-Axle offset-Rear axle transverse position,4.70001 mm,4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,724.25 mm,8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,728.5 mm,8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,726.5 mm,8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,729.75 mm,8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2400 mm,24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,745 mm,24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1530 mm,24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2400 mm,24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-745 mm,24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1530 mm,24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2400 mm,24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,745 mm,24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,870 mm,24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2400 mm,24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-745 mm,24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,870 mm,24
IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
IDE10872-Warning intensity: lane depart. warning,Medium ,1
IDE10873-BAP personalization,activated ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.204 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.297 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,-0.459 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,1338 mm,8
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
ENG120319-Mask_error_reactions_for_development,not activated ,1
ENG107577-Masked_fault_classes-,255 ,4
ENG130777-standstill_mode,not activated ,1
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,1 ,5
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,20 ,5
ENG130779-Xcp_interface,not activated ,1
Elapsed Time: 00:07
adpmap-BB-5Q0-959-595-E_WVWMV83C0JE096319-20241030-1337.CSV
;SW:5Q0-959-595-E   HW:5Q0-959-595-B ---  Door Rear Drv
Componente: TSG HFS 020 0041, Codificação: 000E10200100028000000000
;EV_DCURearDriveMAXKLO,006003,EV_DCURearDriveMAXCONT_VW48.rod
Quarta-feira, 30 de outubro de 2024, 13:37:35:18837
;Versão do VCDS: Beta 24.9.1 (x64) Versão dos dados: 20240926 DS359.0
;VCID: 45C2B77BC4E873BD38-8010
IDE00001-Modo de produção,00000000 00000000 00000000 ,3
IDE02332-Desativar modo de produção,00000000 00000000 00000000 ,3
ENG117299-Limiar_de_Reversão_Lado_do_Motorista_Traseiro,90%,1
Tempo decorrido: 00:01
[/CÓDIGO]
adpmap-BC-5Q0-959-595-E_WVWMV83C0JE096319-20241030-1337.CSV
[CÓDIGO]
;SW:5Q0-959-595-E HW:5Q0-959-595-B --- Porta Traseira do Passageiro
Componente: TSG HBFS 020 0041, Codificação: 000E10200100028000000000
;EV_DCURearPasseMAXKLO,006003,EV_DCURearPasseMAXCONT_VW48.rod
Quarta-feira, 30 de outubro de 2024, 13:37:43:18837
ENG117300-Soleira_de_Reversão_Lado_do_Passageiro_Traseira,90%,1
[/CÓDIGO]
adpmap-CA-4M0-907-594-K_WVWMV83C0JE096319-20241030-1337.CSV
[CÓDIGO]
;SW:4M0-907-594-K HW:4M0-907-594 --- Teto solar
Componente: SAD_STG_1 014 0005, Codificação: 608000748101
;EV_SunRoofCONTIAU736,006008,EV_SunRoofCONTIAU736_006_VW41.rod
Quarta-feira, 30 de outubro de 2024, 13:37:47:18837
;VCID: 3E30D897A13E206579-806A
IDE00001 - Modo de produção, não ativo, 3
IDE00820 - Ativar e desativar todas as mensagens de desenvolvimento, não ativo, 1
IDE02104-IDE03633-Ativação dependente da temperatura-Fechar o teto solar, não ativo, 1
IDE02104-MAS09030-Ativação dependente da temperatura-Teto solar aberto, ativo, 1
IDE02104-MAS09031-Ativação dependente da temperatura-Persiana de teto aberta, não ativa, 1
IDE02104-MAS09032-Ativação dependente da temperatura-Fechar persiana do teto, não ativa, 1
IDE02332-Desativar modo de produção,0 ,3
IDE09435-IDE03633-Ativação dependente da velocidade-Fechar o teto solar, não ativo, 1
IDE09435-MAS09030-Ativação dependente da velocidade-Teto solar aberto, ativo, 1
IDE09435-MAS09031-Ativação dependente da velocidade-Persiana de teto aberta, não ativa, 1
IDE09435-MAS09032-Ativação dependente da velocidade-Fechar persiana do teto, não ativo, 1
IDE09439-MAS08884-Comutação lógica: controles-Botão do teto solar, não ativo, 1
IDE09439-MAS08932-Comutação lógica: controles-Botão da persiana do teto solar, não ativo, 1
IDE09439-MAS08992-Comutador lógico: controles-Botão para teto deslizante, não ativo, 1
IDE09439-MAS10443-Comutador lógico: controles-Botão para teto solar/teto basculante: traseiro, não ativo, 1
IDE09439-MAS10444-Comutador lógico: controles-Botão da persiana do teto solar: traseiro, não ativo, 1
IDE09451-MAS08936-Percurso de deslocamento-Posição inclinada: largura máxima de abertura, não ativo, 1
IDE09451-MAS08937-Trajetória de deslocamento-Posição deslizante: posição intermediária, não ativa, 1
IDE09451-MAS08991-Percurso de deslocamento-Posição deslizante: largura de abertura reduzida, não ativo, 1
IDE09451-MAS10725-Trajetória de viagem-Cortina do teto solar: posição intermediária aberta, não ativa, 1
IDE09451-MAS10726-Trajetória de deslocamento-Cortina do teto solar: posição intermediária fechada, não ativa, 1
IDE11842-IDE09434-Funções de conforto-Posição alvo para abertura confortável,Posição de inclinação para fora,1
IDE11842-MAS13329-Funções de conforto-Abertura de conforto da cobertura, não ativa, 1
IDE11842-MAS13330-Funções de conforto-Fechamento confortável da cobertura, não ativo, 1
IDE11842-MAS14142-Funções de conforto-Modo esfera privada, não ativo, 1
ENG146366-Modo de aplicação desativado, Desativando, 1
Tempo decorrido: 00:02
[/CÓDIGO]
adpmap-D7-7PP-941-572-AB_WVWMV83C0JE096319-20241030-1337.CSV
[CÓDIGO]
;SW:7PP-941-572-AB HW:7PP-941-572-A --- Controle de luz direito 2
Componente: LED1R H09 0003, Codificação:
;EV_LEDModRightMELCOAU736,001004,EV_LEDModLeftMELCOAU736_VW37.rod
Quarta-feira, 30 de outubro de 2024, 13:37:54:18837
;VCID: 16602037E9CE082581-8042
[/CÓDIGO]
How’s that not broken? 🤔
