- Aug 12, 2024
- 17
- 0
- Bosnia and Herzegovina
- C?ID=566813
AUDI Q5 2019
I NEED CODING FOR RADAR ACC
ORI MODULE NUMBER 80A907561B
NEW MODULE WITH C
NOT WORK CODES
5577FFFB58FFEC0A959B83E0
5577FFFA58FFEC0A959B83E0
5577E7FA58FFEC0A949883E0
5573FFE258FFEC0A959B83E0
5573FFEA58FFEC06757B63E0
NEW MODULE WITH C
NOT WORK CODES
Saturday,01,August,2026,19:48:14:19566
VCDS Version: 26.3.0.0 (x64) HEX-NET2 CB: 0.4713.5
VIN: WAUZZZFY9L2004438 License Plate:
Chassis Type: FY-AU49 (8W7)
Scan: 01 02 03 08 09 13 15 16 17 19 29 39 42 44 46 52 5F 69 81 8B
A5 AC BB BC CA
VIN: WAUZZZFY9L2004438 Mileage: 186178km-115685miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DCPC) Labels:. 059-907-401-V3.clb
Part No SW: 80A 907 401 L HW: 059 907 309 L
Component: 3.0l V6 TDI H26 0001
Revision: CAH26--- CVN: 17871A4CA30C3AD38947E11D8947E11D00000000D6C3ECFE
Coding: 2A2A40320576050334080000000000000000000000000000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM30TDI01180A907401L 001001
ROD: EV_ECM30TDI01180A907401L.rod
VCID: 2A066E8FAC7BEFBAB17-807E
VINID: 9D196AAAA5A925C08000410320D9D5F1D9
17156 - Databus
U1123 00 [00101111] - Received Error Message
Fault Frequency: 11
Mileage: 186161 km
Date: 2026.08.01
Time: 11:41:25
Engine speed: 0.00 /min
Coolant temperature: 34 °C
Intake air temperature: 29 °C
Voltage terminal 30: 11.700 V
Drivetrain coordinator: brake function status-Bits 0-7: 32
Acceleration: 0.000 m/s˛
Engine status: COENG_READY
10065 - Mass Air Flow Sensor (G70)
P0104 00 [00100000] - Intermittent
Mileage: 186161 km
Date: 2026.08.01
Time: 11:41:26
Voltage terminal 30: 11.680 V
Mean injection quantity: 0.00 mg/stroke
Control Module temperature: 30.7 °C
EGR_governor_deviation: 237.2 mg/stroke
Inj Ctl q Curr: 0.00 mg/stroke
Standardized air flow ratio: -4.0000
Air mass at air mass meter 1: 62.5 kg/h
Actual charge pressure: 968 hPa
Part No SW: 80A 927 158 AC HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H05 0001
Revision: --H05--- CVN: 30A49CF8
Coding: 100000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMALX52011 002013
ROD: EV_TCMALX52011.rod
VCID: 6D8CA5935D153882145-8038
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-V1.clb
Part No SW: 80A 907 379 AA HW: 80A 907 379 A
Component: ESP9 Premium H16 0777
Dataset Number: 80B909504AC 0005 CVN: 92C6B8A1
Coding: 1CAA30BE30A20A9AD1A25894008552A2E5B592380C0C508B1A004A45A7AD49
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 6E8EA29F5013C39A2DF-803A
415488 - TPMS Warning; Front Left Tire
C1055 00 [00101111] - Flat
Mileage: 186177 km
Date: 2026.08.01
Time: 14:24:36
8D 00 80 20 88 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
419328 - TPMS Warning; Front Right Tire
C1057 00 [00101111] - Flat
Mileage: 186177 km
Date: 2026.08.01
Time: 14:24:36
419584 - TPMS Warning; Rear Left Tire
C1059 00 [00101111] - Flat
Mileage: 186177 km
Date: 2026.08.01
Time: 14:24:36
419840 - TPMS Warning; Rear Right Tire
C105B 00 [00101111] - Flat
Mileage: 186177 km
Date: 2026.08.01
Time: 14:24:36
467968 - Databus
U1122 00 [00101111] - Implausible Message
[Signal_AB_Gurtschloss_FA_invalid_(0_or_1)]
Mileage: 186161 km
Date: 2026.08.01
Time: 11:41:27
76 00 80 00 C2 24 00 00 00 00
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 A HW: 80A 820 043 A
Component: Klima Zone 1 H40 0241
Coding: 6618082D51410005000001000B0000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 1B68BB4BF32106323A1-804E
Subsystem 1 - Part No SW: 4M1 820 021 C HW: 4M1 820 021 C
Component: J126 FLuftV H09 0004
Serial number: 00000000000003740776
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H02 0007
Serial number: 25A1199900PAG0FSA002
262658 - High Pressure Sensor
B10AE 31 [00001000] - No Signal
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.21
Time: 15:57:37
Outside temperature: 35.50 °C
Engine speed: 700 /min
Compressor current: actual value: 0.00 A
Temperature downstream of evaporator: 30.00 °C
459027 - Databus
Fault Frequency: 19
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 19:22:41
459521 - Databus
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 17:49:34
0387 - Function limitation due to crash signal
B1397 00 [00001000] - -
Reset counter: 146
Mileage: 186135 km
Date: 2026.04.24
Time: 14:14:02
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 DG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0313
Dataset Number: 80B909514L 0041
Coding: C2501142C17900CD054D51189CBE80B9110B3108000000000000000020001A010041002B025601
ASAM Dataset: EV_BCM1BOSCHAU736 019008
ROD: EV_BCM1BOSCHAU736_019.rod
VCID: 0358E32B6B91DEF2D21-8056
Subsystem 1 - Part No SW: 80B 955 119 A HW: 80B 955 119
Component: 426 LL 190619 040 0581
Serial number: 00000001906062108046
Coding: FFC7F7
Serial number: 22964937X81A955555A0
Coding: 0200FF
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 18 07 2019 91990579
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE105061923811047
Interior Light Module:
Subsystem 5 - Part No SW: 80A 947 135 AE HW: 80A 947 135
Component: Dachmodul Q5 H32 0330
Serial number: Q00014363
Coding: 0D0101
Subsystem 6 - Part No SW: 8W0 925 301 BD HW: 8W0 925 301 BD
Component: SL-B9/Q5NF H18 0010
Serial number: 4919000104641002
66679 - Databus
[Right LCM: implausible data record]
Fault Frequency: 11
Reset counter: 108
Mileage: 186161 km
Date: 2026.08.01
Time: 11:42:16
average_Voltage_terminals: 11.70 V
Outside air temperature sensor-Outside air temperature on CAN: 28.00 °C
interior_temperature: 28.50 °C
Vehicle speed: 0.00 km/h
66964 - Databus
[Right LCM: turn signal faulty]
Fault Frequency: 11
Reset counter: 108
Mileage: 186161 km
Date: 2026.08.01
Time: 11:42:16
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 80A 907 561 C HW: 8W0 907 561
Component: LRR4 H12 0451
Dataset Number: 80B909863J 0004
Coding: 5573FFEA58FFEC06757B63E0
ASAM Dataset: EV_ACCBOSCHAU49X 003024
ROD: EV_ACCBOSCHAU49X_003_AU49.rod
VCID: 28029487B277DDAAA73-807C
2143 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
[FAULT_ENGINE_PLAUS_FAIL]
Reset counter: 108
Mileage: 186178 km
Date: 2026.08.01
Time: 19:42:02
Control Module temperature: 45 °C
Voltage terminal 15: 11.9 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s˛
Adaptive distance regulation: status: ACC_irreversible error
2153 - Databus
[FAULT_HC_STA_FAIL]
Reset counter: 108
Mileage: 186178 km
Date: 2026.08.01
Time: 19:42:02
2095 - Databus
[FAULT_SEATBELT_FAIL]
Reset counter: 108
Mileage: 186178 km
Date: 2026.08.01
Time: 19:42:02
Address 15: Airbags (J234) Labels:| 80A-959-655-V1.clb
Part No SW: 80A 959 655 N HW: 80A 959 655 N
Component: AirbagVW30 051 0605
Serial number: 003WBM0BWA80 Dataset Number: 80A909602H 0006
Coding: AACCF0C00C800000985400FFF00C400000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
VCID: 3E2E52DF40F3731AFDF-806A
Right seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2040
Serial number: 80A857706G0147T02112
Coding: 88001B
Subsystem 2 - Part No SW: ----------- HW: 480 001 905 19
Serial number: 35700000000B436DDB3-
Subsystem 3 - Part No SW: ----------- HW: 480 001 905 19
Serial number: 358000000002F3FC2C3.
Subsystem 4 - Part No SW: ----------- HW: 480 031 105 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C20CE9117109F7
Subsystem 5 - Part No SW: ----------- HW: 480 031 105 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C20CE0DCC10A4H
Subsystem 6 - Part No SW: ----------- HW: 480 030 106 19
Component: FrontSensor_D 002 0149
Serial number: 355001C20BFBE551386L
Subsystem 7 - Part No SW: ----------- HW: 480 032 306 19
Component: PedP_Sensor_C 002 0149
Serial number: 230001C208DA78C0EE1L
Subsystem 8 - Part No SW: ----------- HW: 480 000 106 19
Serial number: I0M000000009FB59EBB$
Subsystem 9 - Part No SW: ----------- HW: 480 002 709 19
Serial number: I0N00000000CC21430C1
Central crash sensor X/Y:
Subsystem 10 - Part No SW: ----------- HW: 480 022 205 19
Component: CentrSensorXY 000 0108
Serial number: I0O0001B52DEAAB4E76L
17 Faults Found:
1115904 - No Communication with Control Module for Seat Belt Tensioner; Front Left
U017E 00 [00001001] - -
[NWD: 0x141 RGS_VL_02 Timeout]
Reset counter: 108
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:43
1060617 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
Reset counter: 108
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:43
1060614 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
Reset counter: 108
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:43
9444113 - Front Passenger's Front Airbag Crash Sensor
B101B 11 [10001001] - Short to Ground
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:45
9572122 - Ignitor for Passenger Airbag Release Valve
B120F 1A [10001001] - Resistance Too Low
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
B1008 1B [10001001] - Resistance Too High
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
9451547 - Igniter 1 for pedestrian protection
B1038 1B [10001001] - Resistance Too High
Mileage: 186163 km
Date: 2026.08.01
Time: 13:18:41
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
B1009 1B [10001001] - Resistance Too High
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
9451803 - Igniter 2 for pedestrian protection
B1039 1B [10001001] - Resistance Too High
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [10001001] - Resistance Too High
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [10001001] - Resistance Too High
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
B1006 1B [10001001] - Resistance Too High
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
9439002 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1A [10001001] - Resistance Too Low
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
9444371 - Safety belt switch - driver side
B101C 13 [10001000] - Open Circuit
Mileage: 186167 km
Date: 2026.08.01
Time: 14:09:24
9444369 - Safety belt switch - driver side
B101C 11 [10001001] - Short to Ground
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
9444883 - Driver's seat position sensor
B101E 13 [10001001] - Open Circuit
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
9445139 - Passenger's seat position sensor
B101F 13 [10001001] - Open Circuit
Mileage: 186161 km
Date: 2026.08.01
Time: 11:36:44
Part No SW: 80A 907 129 CL HW: 80A 907 129 CL
Component: Lenks.Modul H02 0005
VCID: 74BAB0F73E3FE94ADBB-8020
7340544 - Heated Steering Wheel
B1538 13 [00001001] - Open Circuit
Reset counter: 106
Mileage: 186134 km
Freeze_Frame_Heated_Steering_Wheel-Current_Average: 0.00 A
Freeze_Frame_Heated_Steering_Wheel-Current_Peak: 0.00 A
Freeze_Frame_Heated_Steering_Wheel-Operation_time_counter: 205454 min
Freeze_Frame_Heated_Steering_Wheel-PWM_Duty_Cycle: 0 %
Freeze_Frame_Heated_Steering_Wheel-Steeringwheel_Temperatur_Raw_Busvalue: 0 °
Freeze_Frame_Heated_Steering_Wheel-Voltage_12V: 11842.97 mV
Freeze_Frame_Heated_Steering_Wheel-Voltage_5VS: 4914.84 mV
Freeze_Frame_Heated_Steering_Wheel-Voltage_at_sensor: 0.00 V
Freeze_Frame_Heated_Steering_Wheel-Voltage_Output_Power_Switch: 1 bit
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 E HW: 8W5 920 790 E
Component: FBenRDW H19 0417
Coding: 05848EC42C800008008369601000600000000000
ASAM Dataset: EV_DashBoardAU736 001032
VCID: 44DA20372E1F19CAABB-8010
9582600 - Switch for Instrument Cluster
B1893 13 [00001000] - Open Circuit
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 13:41:28
16776996 - Databus
[FCW_01 communication error can_error_timeout]
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 17:49:32
16777089 - Databus
[ACC_12 communication error can_error_timeout]
Reset counter: 147
Mileage: 186135 km
Date: 2026.04.24
Time: 14:14:02
16777091 - Databus
[VZE_01 communication error can_error_timeout]
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 17:49:32
16777110 - Databus
[AEB_01 communication error can_error_timeout]
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 17:49:29
Part No SW: 8W7 907 468 J HW: 8W7 907 468 G
Component: Gateway H46 0152
Revision: BU000001 Serial number: 018BU527719527 Dataset Number: 80B909515J 0064
Coding: 03010001004006407F07000000590032DC1A000710000000017D078E10000000
GVL: 01503C0000040000C08CC8000000C80010080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 004190
ROD: EV_CGateCONTIAU491_004_VW53.rod
VCID: 52F6166FE46B877A297-8006
Subsystem 1 - Part No SW: 4M0 951 523 HW: 4M0 951 523
Component: J453 MFL H06 0002
Serial number: 20170208041728 00510
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 7153846600
U1101 00 [00001000] - Active
[KS_Active_1]
Fault Frequency: 9
Reset counter: 148
Mileage: 186161 km
Date: 2026.08.01
Time: 11:43:47
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 80A 907 397 A HW: 80A 907 397 A
Component: LCM_MLBevo H07 0022
Dataset Number: 80B909519D 0011
VCID: 2D0C65939D95F882545-8078
0625 - Positioning Motor for Headlamp Range
C11C0 11 [00001000] - Short to Ground
Reset counter: 148
Mileage: 186178 km
Date: 2026.08.01
Time: 17:15:55
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Part No SW: 80A 907 397 B HW: 80A 907 397 B
Dataset Number: 80B909520D 0011
VCID: 2E0E629F9093839A6DF-807A
0019 - Headlamp Type
C119F 00 [00001001] - Implausible
Fault Frequency: 11
Reset counter: 108
Mileage: 186161 km
Date: 2026.08.01
Time: 11:43:01
Part No SW: 8W1 959 593 D HW: 8W1 959 593 D
Component: TSG FS001 0188
Serial number: CLSM1SG5000KM Dataset Number: 80B909872E 0039
Coding: 001D0A015000048000001002
ROD: EV_DCU2DriveSideMAXHKLO_AU49.rod
VCID: 4CCA0817064FD18A63B-8018
196897 - Crash Response
B1908 F0 [00001000] - Active
Reset counter: 146
Mileage: 186135 km
Date: 2026.04.24
Time: 14:14:06
Address 44: Steering Assist (J500) Labels:* 4N0-909-144-V1.clb
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Dataset Number: 80B909852L 0002
Coding: B0002101000101
ROD: EV_EPSVWBSAU426_010.rod
VCID: 323676EF84ABA77A097-8066
Part No SW: 4N0 907 064 DP HW: 4N0 907 064 P
Component: BCM2 MLBevo H15 0182
Dataset Number: 80B909501K 0041
Coding: 013400000FB100606309A0006C00D00213020008804F04502F0000000104803F001F0001000011
ASAM Dataset: EV_BCM2CONTIAU651 010009
ROD: EV_BCM2CONTIAU651_010_VW53.rod
VCID: 0052EC277A87C5EACF3-8054
ID - sensor:
Subsystem 1 - Part No SW: 4M0 959 754 CF HW: 4M0 959 754 CF
Component: ID-Geber H41 0233
Serial number: 3619000077017010
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY191201B8D
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000047122437
Rear spoiler control module:
65585 - Databus
[Steering column electronics control module: SMLS_01: no signal/communication]
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 17:49:32
Supply voltages-Terminal 30 power supply: 11.727 V
Supply voltages-Supply voltage Terminal 30 - 2: 11.643 V
Supply voltages-Supply voltage Terminal 30 - 3: 11.601 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 94 00 78
can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
65649 - Rear Lid Closed Sensor
B146C 29 [00001000] - Signal Implausible
Reset counter: 110
Mileage: 184130 km
Date: 2026.03.20
Time: 14:43:27
Supply voltages-Terminal 30 power supply: 12.179 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.214 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.165 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 00
65664 - Databus
[Control module for distance control: ACC_07: no signal/communication]
Reset counter: 147
Mileage: 186135 km
Date: 2026.04.24
Time: 14:14:02
Supply voltages-Terminal 30 power supply: 15.373 V
Supply voltages-Supply voltage Terminal 30 - 2: 15.325 V
Supply voltages-Supply voltage Terminal 30 - 3: 15.269 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 02 A2 94 00 60
general_additional_freeze_frame-Vehicle speed: 71.83 km/h
65760 - Databus
[Airbag control module: error value in signal AB_Gurtschloss_FA]
Reset counter: 106
Mileage: 186134 km
Date: 2026.07.21
Time: 15:57:44
Supply voltages-Terminal 30 power supply: 14.879 V
Supply voltages-Supply voltage Terminal 30 - 2: 14.789 V
Supply voltages-Supply voltage Terminal 30 - 3: 14.719 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 02 8A 90 02 60
general_additional_freeze_frame-Vehicle speed: 1.68 km/h
Part No SW: 8W1 959 592 D HW: 8W1 959 592 D
Component: TSG BFS001 0188
Serial number: CLSM1SFD000BL Dataset Number: 80B909873E 0039
Coding: 001D0A015C00048000001000
ROD: EV_DCU2PasseSideMAXHKLO_AU49.rod
VCID: 4BC80B0B0341D6B26A1-801E
Reset counter: 146
Mileage: 186135 km
Date: 2026.04.24
Time: 14:14:06
196726 - Motor for mirror fold-in
B11F6 13 [00001000] - Open Circuit
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.23
Time: 16:13:18
Part No SW: 8W5 035 036 D HW: 8W5 035 036
Component: MU-P-LN-EU 035 1329
Serial number: A795G0K9284414 Dataset Number: 80B909545T 0034
Coding: 01240601FF00000053110001000A00332F0015E5017001009E
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 392441C359DD5422C8D-806C
Subsystem 1 - Part No SW: V03 959 802 TN HW: -----------
Component: ECE 2022 --- 0195
Multimedia display unit 1:
Subsystem 2 - Part No SW: 80A 919 605 HW: 80A 919 605
Component: AU426_DU_HIGH H42 0008
Serial number: AUZ8Z9KBL08PAT
Subsystem 3 - Part No SW: 80A 919 615 HW: 80A 919 615
Component: ControlUnit_P H15 0209
Serial number: 06051900000000000943
Compact disc data bank:
Component: Gracenote2 --- 1017
0517 - Front Right Bass Speaker
B1062 13 [00001000] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung]
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.22
Time: 14:13:38
Voltage terminal 30: 12.1 V
6917 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[ACC (0x05) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 147
Mileage: 186135 km
Date: 2026.04.24
Time: 14:14:05
Voltage terminal 30: 12.7 V
7173 - Function Restricted due to Missing Message(s)
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 147
Mileage: 186135 km
Date: 2026.04.24
Time: 14:14:08
Voltage terminal 30: 12.6 V
BAP-BAP_Function_ID: 02
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 8W1 907 383 A HW: 8W1 907 383
Component: Anhaenger H07 0039
Serial number: 000000000005202 Dataset Number: 8Y0909527A 0005
Coding: 0100000202001100
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW38.rod
VCID: 3FD02FDB47F97A12F69-806A
655882 - Bulb for Brake Light on Trailer
C10F3 15 [00100000] - Open or Short to Plus
656138 - Bulb for Right Tail Light on Trailer
C10F4 15 [00100000] - Open or Short to Plus
656394 - Bulb for Left Tail Light on Trailer
C10F5 15 [00100000] - Open or Short to Plus
656650 - Bulb for Right Turn Signal on Trailer
C10F6 15 [00101000] - Open or Short to Plus
Reset counter: 37
Mileage: 186074 km
Date: 2026.04.23
Time: 15:13:09
656906 - Bulb for Left Turn Signal on Trailer
C10F7 15 [00100000] - Open or Short to Plus
336920 - Implausible Data Received from ABS Control Module
U0415 00 [00101000] - -
[Brake electronics - implausible message (ESP_v_signal)]
Reset counter: 39
Mileage: 174823 km
Date: 2025.11.07
Time: 17:30:22
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 80B 713 041 M HW: 80B 713 041 M
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 20190606000502
ROD: EV_GSMWaehlZFAU736.rod
VCID: 270097BBBF69D2D2AE9-8072
24703 - Databus
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 17:49:31
Voltage terminal 30: 11.0 V
Selec. range display: spec. val.: P
Selector lever position: Basic setting X
Standard_FreezeFrame_Extended_Temperature_CAN: 9F
Standard_FreezeFrame_Extended_Temperature_Celsius: 29.5 °C
System run time: 106 s
27686 - Unlock Button
P17EC 00 [00001000] - Electrical Malfunction
Fault Frequency: 14
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 12:58:58
Voltage terminal 30: 11.6 V
Standard_FreezeFrame_Extended_Temperature_CAN: A7
Standard_FreezeFrame_Extended_Temperature_Celsius: 33.5 °C
System run time: 6 s
28449 - Switch for Parking Lock
P18CA 00 [00001000] - Electrical Malfunction
Fault Frequency: 14
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 12:58:58
30120 - Indicator Lamp for Parking Lock
P10EA 00 [00001000] - Electrical Malfunction
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 12:58:58
Voltage terminal 30: 11.7 V
30118 - Selector Lever Range Display
P18C8 00 [00001000] - Supply Voltage
Fault Frequency: 11
Reset counter: 146
Mileage: 186134 km
Date: 2026.07.18
Time: 13:19:24
Voltage terminal 30: 11.8 V
Selec. range display: spec. val.: Malfunction
Standard_FreezeFrame_Extended_Temperature_CAN: 00
Standard_FreezeFrame_Extended_Temperature_Celsius: -50.0 °C
System run time: 5 s
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 80A 907 541 B HW: 8W0 907 541
Component: LRR4 H10 0340
Dataset Number: 80B909885E 0004
ASAM Dataset: EV_ACC2BOSCHAU49X 003022
ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
VCID: 251C9DB3C565C0C29C5-8070
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 80A 907 217 C HW: 80A 907 217 A
Component: BVS H17 0055
Dataset Number: 80B909466D 0027
Coding: 0404020600000401022023A5A50000FEB0F0C010C020
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
VCID: 261E9ABFB863CBDA95F-8072
1123714 - Databus
[Airbag_01_AB_Systemfehler]
Reset counter: 107
Mileage: 186161 km
Date: 2026.08.01
Time: 11:39:50
Control Module temperature: 35 °C
Voltage terminal 15: 11.60 V
Address AC: Reductant Control (J880) Labels: 80A-907-355.clb
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H08 0004
Dataset Number: 80B909571J 0001
ASAM Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
VCID: 2C0A6897A68FF18A43B-8078
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V2.clb
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS003 0188
Serial number: CLSM1SG5000L1 Dataset Number: 80B909897E 0039
Coding: 000D08000000048000001000
ROD: EV_DCU2RearDriveMAXHKLO_VW41.rod
VCID: 4ECE021FF053E39A0DF-801A
Reset counter: 146
Mileage: 186135 km
Date: 2026.04.24
Time: 14:14:06
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V2.clb
Component: TSG HBFS003 0188
Serial number: CLSM1SG5000KV Dataset Number: 80B909896E 0039
ROD: EV_DCU2RearPasseMAXHKLO_VW41.rod
Reset counter: 146
Mileage: 186135 km
Date: 2026.04.24
Time: 14:14:06
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: 80B909469F 0011
Coding: 62800004260C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75BC8DF33545F042EC5-8020
End----(Elapsed Time: 02:11, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
------------------------------66 Faults Found------------------------------
