VW GOLF GTI Rear Camera Retrofit - request for exeption
bigal1952
High Wycombe, UK
C?ID=503714
Hi Uwe,
Another long time VAGCOM/VCDS user here seeking an exception. I am a 74 year old retired electronics engineer and have been a registered user since before 2007, I started with release 404.0 and have had 3 different interfaces in that time.
I have a 2022 Golf GTI (UK spec) and am trying to retrofit a reversing camera.
I would be very happy to supply logs and other comments on the SFD process if you see fit to give me an exception.
I would have been equally happy to pay the $50 for the 1 year access, but it doesn't work yet.
I've attached a full scan from this morning taken with version 26.7.1
Saturday,01,August,2026,09:25:18:51324
VCDS Version: 26.7.1.0 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260708 DS378.0
VIN: WVWZZZCDZNW193097   License Plate:
Mileage: 46887km-29134mi   Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 14 15 17 19 23 2B 32 3C 42 44 4B 52 5F
          75 A5 A9 D6 D7 8107 811E 811F 8120 8121 C002 C003
VIN: WVWZZZCDZNW193097   Mileage: 46887km-29134miles
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DNPA)       Labels: Redir Fail!
   Part No SW: 8Y0 906 264 C    HW: 06K 907 425 N
   Component: R4 2.0l TFS   H08 0001
   Dataset Number: 06Q909102F  0008 CVN: 70014AD0
   Coding: 091940322464050B30080000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0208Y0906264C 001001
   ROD: EV_ECM20TFS0208Y0906264C_VW38.rod
   VCID: 3FDB4CA947F13B32E61-806A
   VINID: 9E69EAAAA4D4A9E9C12430091C8F96EA53
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 BL    HW: 5WA 614 517 N
   Component: ESC           H13 0133
   Serial number: 60722000000708  Dataset Number: V03935367R  0001 CVN: 419C1980
   Coding: 36FC6C9056296A6F5377A40925CA60064A52585542D067C0219CB831018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
   ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
   VCID: 1373B0191BF90F52729-8046 SFD [x]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 J    HW: 5WA 959 436 J
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935341VY 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 5BE39839B3A90712EA9-800E
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 007 Q    HW: 5WA 907 007 Q
   Component: AC Automat    H31 3440
   Serial number: --------------- Dataset Number: V03935358HE 0001
   Coding: 002100010211120010000010101111110000131100200000000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001100
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 55F78E01D58DD162DCD-8000
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000000917598
   Subsystem 2 - Part No SW: 11A 907 049     HW: 11A 907 049
   Component: E265 KPH       H02 0183
   Serial number: G04S05.04.2200971880
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002010322133632517
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 AF    HW: 5WA 937 086 M
   Component: BCM37w_M1028 0175
   Serial number: BXJ53F200322940 Dataset Number: V03935362UV 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_VW38.rod
   VCID: 1577CE01150D11621CD-8040 SFD [x]
   Subsystem 1 - Part No SW: 5H2 955 119 A    HW: 5H2 955 119 A
   Component: FWISCHER_MYJT  003 0051
   Serial number: 907353F0402126801964
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           054 0206
   Serial number: SBY22M04D04H15M09S15
   Subsystem 3 - Part No SW: 5H0 941 193 AN    HW: 5H0 941 193 AN
   Component: LiSi           H06 0008
   Serial number: 92471VB200192
   Subsystem 4 - Part No SW: 5H0 925 200 R    HW: 5H0 925 200 R
   Component: DiETa          H07 0008
   Serial number: 92471VBN001C5
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000002230364
   Subsystem 6 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA    005 0403
   Serial number: 000000000ZL2208200JV
   Subsystem 7 - Part No SW: 5H0 959 569 C    HW: 5H0 959 569 C
   Component: DACHKONSOLE    101 0104
   Serial number: 000000092661VBB00161
   Steering Column Switch:
   Subsystem 8 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Serial number: 00000024022204221124
Address 10: Park/Steer Assist (J446)       Labels:| 5WA-919-298.clb
   Part No SW: 5WA 919 298 B    HW: 5WA 919 298
   Component: PLA 12 Kanal  H05 0578
   Serial number: 000019012294630 Dataset Number: V03935363JA 0001
   Coding: 8300026001
   ASAM Dataset: EV_EPHBO2CVW3800000 002028
   ROD: EV_EPHBO2CVW3800000_VW38.rod
Address 13: Auto Dist. Reg (J428)       Labels:| 5WA-907-572.clb
   Part No SW: 5WA 907 572 B    HW: 5WA 907 572
   Component: ACC Bosch MQB H20 0395
   Dataset Number: V03935351MD 0001
   Coding: 060310F7400740451247400800404004AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4DC76661FD5D99A264D-8018
Address 14: Susp. Elect. (J250)       Labels: 1EA-907-376.clb
   Part No SW: 1EA 907 376 C    HW: 1EA 907 376
   Component: DAEMPFUNGS-SG H05 0457
   Serial number: 2C7673241218102 Dataset Number: V03935344MM 0001
   ASAM Dataset: EV_DCC3CONTITEMIC 002006
   ROD: EV_DCC3CONTITEMIC_002_VW38.rod
   VCID: 3A2D3DBD5CD31E1AD1F-806E
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 H    HW: 5WA 959 655 H
   Component: AirbagVW40    008 0636
   Serial number: 000000003C0HZR8 Dataset Number: V03935349GD 0001
   Coding: 88CC000000C0C000000000000000000051540000205400004000F68000930065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 5CE19B25B6A7002AE33-8008 SFD [x]
   Subsystem 1 - Part No SW: -----------    HW: 480 401 003 22
   Serial number: 3510001BD07ABD00D44A
   Subsystem 2 - Part No SW: -----------    HW: 480 400 903 22
   Serial number: 3520001A507BF405A5FC
   Subsystem 3 - Part No SW: -----------    HW: 480 002 102 22
   Serial number: 357000000009B3750C5O
   Subsystem 4 - Part No SW: -----------    HW: 480 001 702 22
   Serial number: 3580000000095D14D85V
   Subsystem 5 - Part No SW: -----------    HW: 480 401 911 21
   Component: FrontSensor_D  003 614A
   Serial number: 3550001C4C6850B28905
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 B    HW: 5H0 920 340 B
   Component: KOMBI         220 5370
   Dataset Number: V03935353UH 0001
   Coding: 24AC04007B9C06000180620B2000080800300400
   ASAM Dataset: EV_DashBoardVDDMQB37W 003033
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: 211FEAD1D1456DC2F05-8074 SFD [x]
16777020 - Control unit for information electronics 1
          U1054 00 [00001001] - No Communication
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 110
                    Mileage: 46887 km
                    Date: 2026.08.01
                    Time: 09:21:53
   Part No SW: 5WA 907 530 Q    HW: 5WA 907 530 G
   Component: GW2020 High   756 7300
   Revision: --------    Serial number: 771049050022090 Dataset Number: V03935387YA 0001
   Coding: 0000808D0F00000000000000010303317301610900000300030100000001010000000000000000000000000000000000
   GVL: 3D400000020840CC800080004C00004000004002004400000000000000000044
   ASAM Dataset: EV_GatewMQB2020 005011
   ROD: EV_GatewMQB2020_004_VW38.rod
   VCID: 56F5890DC88BDA7AD57-8002 SFD [x]
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 1328947905
   Subsystem 3 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Component: MFL            H03 0219
   Serial number: 17036218120492201468
   Subsystem 4 - Part No SW: 5H0 959 542 J    HW: 5H0 959 542 J
   Component: KLR_JSS_1Zone  076 0022
   Serial number: 3133020AB22062129203
   Part No SW: 5WA 909 059 Q    HW: 3Q0 909 059 D
   Component: EBKV          H09 0309
   Serial number: BPA085230122013 Dataset Number: V03935367RC 0001
   Coding: 5003C5409600007BEFBDF7DE000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 5EE5912DA0BB123A8D7-800A SFD [x]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 22000042020013 Dataset Number: V03935336NF 0001
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323D159D84A3E65A19F-8066
Address 32: Differential Locks (-----)       Labels:| 0CQ-907-554-V2.clb
   Part No SW: 5WA 907 554 B    HW: 5WA 525 130
   Component: Quersperre    H65 8640
   Serial number: HH3-00024.11.21
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 005001
   ROD: EV_LockElectHA1VW37X_005.rod
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 J    HW: 2Q0 907 686 J
   Component: HRE_Master    H27 0288
   Serial number: 00000595143983  Dataset Number: V03935362YB 0001
   Coding: 969945D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001016
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   VCID: 41DF4A5131054DC2905-8014
   Subsystem 1 - Part No SW: 2Q0 907 685 J    HW: 2Q0 907 685 J
   Component: HRE_Slave      H27 0288
   Serial number: 00000595153223
   Lane change assistance display left:
   Subsystem 2 - Part No SW: 5H1 949 145     HW: 5H1 949 145
   Component: SWA LED VL     H05 0005
   Serial number: 00000000000016909060
   Lane change assistance display right:
   Subsystem 3 - Part No SW: 5H1 949 146     HW: 5H1 949 146
   Component: SWA LED VR     H05 0005
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS003 0350
   Serial number: YE007VB61470A Dataset Number: V03935342BG 0001
   Coding: 003B1220D001040000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 4ACD6D7D0C338E9A41F-801E
   Subsystem 1 - Part No SW: 5Q0 959 407 G    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000058272192
   Coding: 0D0000
Address 44: Steering Assist
   Part No SW: 5WA 907 338 B    HW: 5WA 907 338
   Component: FCM2020 Low   014 1447
   Serial number: 240151222121177 Dataset Number: V03935346BX 0001
   Coding: 00000000090007CE07000F10020003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 004012
   ROD: EV_MultiModulContiVW38X.rod
   VCID: 4DC76661FD5D99A264D-8018 SFD [x]
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YE007VBB1549E Dataset Number: V03935342BD 0001
   Coding: 003B1020DC01040000801000
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 49CF527109358582485-801C
   Subsystem 1 - Part No SW: 5Q0 959 408 G    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000058105279
   Coding: 150000
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5H0 035 820 K    HW: 5H0 035 820
   Component: MU-O-ND-EU    H58 1985
   Serial number: WG8LGM230322000 Dataset Number: V03935362LB 0001
   Coding: 23800008000200000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_VW38.rod
   VCID: 2A0D0DFDAC73AE9AA1F-807E SFD [x]
   Subsystem 1 - Part No SW: 5H0 919 605 B    HW: 5H0 919 605 B
   Component: ABT_W_10       H42 3080
   Serial number: VDD02409022212210122
   Subsystem 2 - Part No SW: V03 959 809 TP    HW: -----------
   Component: EUR 2022       --- 6053
   Part No SW: 5WA 035 284 J    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H12 0311
   Serial number: 0000000110VIYK9 Dataset Number: V03935447ZH 0001
   Coding: 023800109068A8209405460071502607
   ASAM Dataset: EV_OCU3HMQB37W 002029
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   Part No SW: 5WA 980 653 C    HW: 5WA 980 653
   Component: MQB MFK 3.0   H09 3302
   Serial number: E82645704220950 Dataset Number: V03935357JG 0001
   Coding: 00000908116CC040109E00001030008000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   VCID: 4FFB7C69F751ABB2161-801A
   Part No SW: 5H0 907 159     HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 220308292928
   ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
   VCID: 6C81CBE5660770AA133-8038
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 6597BEC185ED41E24CD-8030
   Component: LED1R         H08 9202
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 B    HW: 5WA 035 741 B
   Component: TrxModulHigh  H10 0081
   Serial number: 0000000107VIFWA Dataset Number: V03935364CE 0001
   Coding: 02380011040080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: 43D340592B195FD2829-8016 SFD [x]
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: 47CB54491F2173F25E1-8012
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----(Elapsed Time: 02:17, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
-------------------------------1 Fault Found------
Reactions: TTT
