Hi all!
I have changed the motor for opening and closing the rear lid. I got it to work fine, but there is "No basic setting"!?
Can someone advice me how to do that?
Kind regard in advance!
//Kjell
//Kjell
Thursday,30,July,2026,10:14:06:44714
VCDS Version: 25.3.3.0 (x64) HEX-NET2 CB: 0.4671.5
Data version: 20260227 DS365.0
VIN: TMBLK9NE3H0161860 License Plate: NLT521
Mileage: 169631km-105403mi Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 20 22 42 44 47 52 55 5F
69 6D
VIN: TMBLK9NE3H0161860 Mileage: 169631km-105403miles
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BT HW: 04L 907 309 R
Component: R4 2.0l TDI H23 7612
Revision: B5H23--- CVN: C960982E
Coding: 011D001A047601080000
Shop #: WSC 23578 005 1048576
ASAM Dataset: EV_ECM20TDI01104L906026BT 004005
ROD: EV_ECM20TDI01104L906026BS_004.rod
VCID: 7DAC96CE6D7B8442E5D-8028
VINID: 91D49C6C97950D800118120600BE78EDB8
Part No SW: 0D9 300 014 T HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5221
Revision: 06454104 Serial number: TFK01612082155 CVN: 00001E91
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ250021.rod
VCID: 2904929EC973C8E2F95-807C
12 Faults Found:
21153 - Gear 1
P072C 00 [00000010] - Not Selectable
21154 - Gear 2
P072D 00 [00000010] - Not Selectable
21155 - Gear 3
P072E 00 [00000010] - Not Selectable
21156 - Gear 4
P072F 00 [00000010] - Not Selectable
21157 - Gear 5
P073A 00 [00000010] - Not Selectable
21158 - Gear 6
P073B 00 [00000010] - Not Selectable
21159 - Gear R
P072B 00 [00000010] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [00000010] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
P174E 00 [00000010] - Electrical malfunction
21207 - Pressure Control Solenoid 3
P0797 00 [00000010] - Stuck ON
10906 - Cooling Oil Valve
P179D 00 [00000010] - Electrical Malfunction
P1734 00 [00000010] - -
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 63646000000021
Coding: 1B0762913426096D407F070640C329D8462C9002E002947416615070C00943000009021212131AA435351919323200
VCID: 79A482DE7953B862C95-802C
Part No SW: 5E0 907 044 AE HW: 5E0 907 044 AE
Component: Climatronic H04 1601
Revision: 00001K07
Coding: 02010104004111011005000000101002
ASAM Dataset: EV_ACClimaBHBVW37X 006142
VCID: 6882D79A12F931EA26B-803C
Air quality sensor:
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 8658201216004Q Dataset Number: V03935247KE 0001
Coding: 0C021B56C24722FB4FE44004001C17080400000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_015.rod
VCID: 0358E0360B9FF2B2939-8056
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 161116 041 0570
Serial number: 161205220813
Coding: 065DDD
Component: RLHS 042 0105
Serial number: S2Y16M12D29H05M14S38
Coding: 00885D
Humidity sensor: interior:
12307 - License Plate Light
B12CA 01 [00001000] - Electrical Failure
Reset counter: 135
Mileage: 169603 km
Date: 2026.07.30
Time: 08:42:06
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.3 V
Outside temperature: 26.5 C
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39361700403001 Dataset Number: V03935237TR 0001
Coding: 0071151151
Shop #: WSC 73430 790 00063
VCID: 43D820364B1F32B2D39-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 K HW: 5Q0 907 572 K
Component: ACC Bosch MQB H05 0402
Serial number: 18121603272515 Dataset Number: 5e0114t____ 0009
Coding: 000C1800FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 3FD02CC627F75652B71-806A
Part No SW: 3Q0 959 655 AP HW: 3Q0 959 655 AP
Component: Airbag VW21 004 0306
Revision: -------- Serial number: 003RAPRMQAF- Dataset Number: V03935243CF 0001
Coding: 98FCC000000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
VCID: 0C4ACB0A26C1BDCAE23-8058
Left seat belt tensioner:
Component: BeltPretRevFL H37 0350
Serial number: 34169593C06011750224
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H37 0350
Serial number: 34169592C05011751251
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 454 001 012 16
Serial number: 357000000009D23CB02O
Subsystem 4 - Part No SW: ----------- HW: 454 001 112 16
Serial number: 35800000000B120D3126
Subsystem 5 - Part No SW: ----------- HW: 454 801 212 16
Serial number: 35100E6F2CF0D0000000
Subsystem 6 - Part No SW: ----------- HW: 454 801 212 16
Serial number: 3520091CFCA0D000000$
Subsystem 7 - Part No SW: ----------- HW: 454 800 612 16
Serial number: 355000C670A0D000000I
Part No SW: 5Q0 953 507 HB HW: 5Q0 953 549 E
Revision: -------- Serial number: 05011704220141
Coding: 6410
Shop #: WSC 73430 031 00000
ROD: EV_SMLSKLOMQB_018_VW37.rod
Part No SW: 5E0 920 759 C HW: 5E0 920 759 C
Component: KOMBI 305 8311
Coding: 07A40809AD800008018C6A011000000000000000
VCID: 2D0C668EFD9BD4C215D-8078
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 G HW: 5Q0 963 272 G
Component: STH-MQB 008 0075
Coding: 9309
VCID: 3A265DD23CD5737A80F-806E
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000167362
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005752586 Dataset Number: V03935242BZ 0001
Coding: 030100345F087300EB00025E1C0F00010001050000000000000000000000
GVL: 01D43C0008000100C00C90000004C80000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F307C86F797A6D2271-807A
Generator:
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000A1266121216
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001701020674
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 3G0 857 511 G HW: 3G0 857 511 G
Component: FLA H10 0003
Revision: AA001001
Coding: 0202000700000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001017
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 2C0A6B8AC681DDCA023-8078
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Serial number: HA1-00006.12.16 Dataset Number: v1260x015G0 0000
Coding: 0001
VCID: 4AC60D126C35E3FA10F-801E
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-DCD-V1.clb
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0032
Serial number: 0000235049108 Dataset Number: V03935252QV 0001
Coding: 00110920D000048000001100
VCID: 47C034267F271E920F1-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012723999
Coding: 010200
Component: EPS_MQB_ZFLS 129 1072
Dataset Number: V03935242GR 0001
Coding: 0107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45DC3E2E452B0C82FDD-8010
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1GJE00VR7Q Dataset Number: V03935242LX 0001
Coding: 0373020000AA002AAA0000000000
ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
ROD: EV_AMPMst16C4Gen2ALPI.rod
VCID: 59E4E25ED9939862A95-800C
U1101 00 [00001000] - Active
[Anti-theft protection - component protection active (0xEA6100)]
Reset counter: 110
Mileage: 168086 km
Date: 2026.07.16
Time: 15:58:49
Voltage terminal 30: 12.4 V
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0032
Serial number: 0000235210866 Dataset Number: V03935252QY 0001
Coding: 00110120D000048000001100
VCID: 46DE3922782D079AF47-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012820975
Coding: 190200
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: -------------- Dataset Number: 5E0036t____ 0010
Coding: 03EA00003F000000
ROD: EV_HeadlRegulVWAFS_VW37.rod
VCID: 40D22F3A5A0929AACEB-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 864 B HW: 5Q0 035 864 B
Component: MU-S-N-ER H30 0359
Serial number: SKZAZ2T5003708 Dataset Number: V03935251HM 0001
Coding: 037342010000000011110002000800232F0102F401208100CE
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 323675F2E4A58B3A48F-8066
Subsystem 1 - Part No SW: 5E0 919 605 J HW: 5E0 919 605 J
Component: ABT_Std-2_Nav H43 1031
Serial number: SKZ8Z9TLH02F7M
Subsystem 2 - Part No SW: 5L0 051 236 P HW: -----------
Component: ECE1 2017 --- 0730
Part No SW: 5Q0 907 383 J HW: 5Q0 907 383 B
Component: Anhaenger H21 0204
Revision: 8C001003 Serial number: 0427126520 Dataset Number: 5E0124t____ 0005
Coding: 0100000202000000
VCID: 3E2E51C220FD5F5ABC7-806A
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 5E0 959 107 A HW: 5E0 959 107
Component: HDSG-Modul H01 0746
Revision: 42001001 Serial number: 350601490 Dataset Number: 5e0771t____ 0009
Coding: 1233074003
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462.rod
VCID: 2A066D92CC75C3FAF0F-807E
0004 - No Basic Setting
B2010 00 [10001001] - -
[Steuerger t nicht kalibriert]
Reset counter: 96
Mileage: 169631 km
Date: 2026.07.30
Time: 10:07:56
Voltage terminal 30: 13.08 V
End----------(Elapsed Time: 02:00, VBatt start/end: 12.9V/12.9V)-----------
------------------------------15 Faults Found------------------------------
