2017 Golf R Went into hard limp mode
Kushdaiin
CT, USA
C?ID=192983
Last Thursday (07/23), I was driving my 2017 Golf R around town when I pulled away from an intersection and the car suddenly lit up with multiple warnings: EPC, ACC, and EPB faults. At the same time, it went into a semi-hard limp mode with very little (and sometimes no) response from the accelerator pedal.
I managed to drive about 100 feet to my destination, parked, and tried restarting the car several times. The faults remained initially, but after letting the car sit for 30–60 seconds and trying again, it started normally with no warning lights. Very strange.
I decided to head home so I could scan the car myself. About 15 minutes into the highway drive, the same thing happened again, but this time it went into a full limp mode with absolutely no accelerator response. I pulled over and attempted the same restart procedure. However, each restart attempt resulted in the engine struggling to catch, briefly revving to around 1,500 RPM, and then shutting off within 2–3 seconds.
At that point, I had the car towed to the local VW dealer. Their initial diagnosis pointed to loose terminal pins in the ECM-to-throttle-body wiring circuit and/or a failed ECM. They also reported a turbo wastegate actuator position fault, claiming the actuator voltage would not calibrate consistently. They have since repaired the loose pins.
As of last night, they had the vehicle running again, but this morning the issue apparently returned. They reported that the ECM was becoming unusually hot and are now attempting to source a replacement ECM (assuming one can be found).
What seems a bit questionable to me is the recommendation for a new turbocharger due to the wastegate actuator fault. Based on the scan data I captured before taking the car in, I'm not seeing the fault codes I would typically expect for a failed turbocharger or wastegate actuator. I'm curious whether anyone has seen a similar failure before or has experience with an ECM causing these kinds of symptoms. Any thoughts on ECM replacement, diagnosis, or logical next steps would be appreciated.
I was at least able to negotiate with the dealer that, if VW's repair procedure ultimately calls for a new turbocharger, we would first attempt replacing the wastegate actuator with a Unitronic actuator since VW does not appear to offer the actuator separately.
Monday,27,July,2026,16:57:09:28357
VCDS Version: https://urldefense.com/v3/__http://26.3.0.0__;!!KQQRbYJqkXCDY_8FAQ!FI42_BIwKz1O7KSEn21M-228q7wWLU0JZ_r5Ahvs87h-rC9lQ5AogSBzdSwqVooKHNXeoof6lHuCQrUvdrQgGcW9JMJAPY1UMNJsN1o$ [26[.]3[.]0[.]0] (x64)  HEX-V2 CB: 0.4701.4
https://urldefense.com/v3/__http://www.Ross-Tech.com__;!!KQQRbYJqkXCDY_8FAQ!FI42_BIwKz1O7KSEn21M-228q7wWLU0JZ_r5Ahvs87h-rC9lQ5AogSBzdSwqVooKHNXeoof6lHuCQrUvdrQgGcW9JMJAPY1UnqF7984$ [ross-tech[.]com]
VIN: WVWWF7AU1HW149710   License Plate: 899ZXU
Mileage: 153637km-95465mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F 65 6C 75 A5 A9
VIN: WVWWF7AU1HW149710   Mileage: 153637km-95465miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---    CVN: 4788C367
   Coding: 091900322446000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001005
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 48C95FE64235171A473-801C
   VINID: 9E69E75874650589C11091C100131EE2CF
15472 - Engine Coolant Level Sensor/Switch
          P2556 00 [00100111] - Electrical Malfunction
                    Mileage: 153637 km
                    Engine speed: 0.00 /min
                    Coolant temperature: 34  C
                    Intake air temperature: 33  C
                    Voltage terminal 30: 12.519 V
                    Engine: operating status: ES
                    Engine temp. management actuator: raw value: 0
                    Engine temperature management actuator: stop open: 138
                    Engine temperature management actuator: after-run stop: 3958
                    RVC_SP: 88.75
                    RVC_AV: 0.00
                    RVCPWM: -100.000 %
15373 - Sensor Reference Voltage A
          P0642 00 [10101111] - Voltage too Low
                    Mileage: 153637 km
                    Date: 2026.07.27
                    Time: 13:28:09
                    Coolant temperature: 41  C
                    Intake air temperature: 34  C
                    Voltage terminal 30: 13.652 V
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 101 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.890 V
                    FAC_TPS_1_SAE: 0.000000 %
                    FUP_H_SAE: 29400.0 kPa
16469 - Throttle Actuator Control Circuit
          P2100 00 [00100000] - Open Circuit
                    Mileage: 153637 km
                    Date: 2026.07.27
                    Time: 13:50:18
                    Vehicle speed: 255 km/h
                    Coolant temperature: 35  C
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 11 s
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.948 V
Readiness: 1110 0101
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 63256000008869
   Coding: 01FA6BA154240975477E030140C36980D62A90E2C00296373440508440A8430000000012121212B835351919323200
   Shop #: WSC 61740 001 104857
   VCID: 78A9EF267255A79AF73-802C
8274 - Databus
          [FCAN: MO_Fahrpedalgradient signal is invalid]
                    Fault Frequency: 14
                    Reset counter: 31
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
8296 - Databus
          [FCAN: MO_QBit_Drehzahl_01 signal is invalid]
                    Fault Frequency: 14
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
8330 - Databus
          [FCAN: MO_QBit_Fahrpedalrohwert signal is invalid]
                    Fault Frequency: 17
                    Reset counter: 31
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0424013287 Dataset Number: V03935252RB 0001
   Coding: 032C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B23302A03E34C82DA1-806E
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000410010001011500401211142A
   VCID: 6D87CE720D171232145-8038
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 4 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H06 0012
   Serial number: BA31921700PAG0MUFU04
329479 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [00001000] - Open or Short to Plus
                    Fault Frequency: 11
                    Reset counter: 71
                    Mileage: 152902 km
                    Date: 2026.07.09
                    Time: 17:50:56
                    Voltage terminal 30: 13.2 V
                    Outside temperature: 26.0  C
                    Inside temperature: 23.4  C
                    Actual value for fresh air/recirculation air flow flap: 0.0 %
                    Actual value for fresh air/recirculation air flow flap: 50
                    Fresh air/recirculating air/back pressure door specified value: 50
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061632000280 Dataset Number: V03935237L  0001
   Coding: 00010E46C041A2F169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 04518BD63E9DF37AEBB-8050
   Component: WWS    161027  043 0551
   Serial number:         161112142417
   Component: RLHS  042 0105
   Serial number: S6Y16M11D23H16M26S22
   Coding: 06A8DD
560917 - Databus
                    Fault Frequency: 134
                    Reset counter: 31
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:18
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 12.2 V
                    Outside temperature: 18.0  C
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417319037 Dataset Number: ----------
   Coding: 0271667801
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: 51FF7282B16FD6D210D-8004
13637426 - Databus
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
13688835 - Databus
          [Steuerger t f r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 31
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:42
13637429 - Databus
          [Motorsteuerger t - Motor_20.MO_Fahrpedalgradient - Fehlerspeicher auslesen]
                    Fault Frequency: 9
                    Reset counter: 31
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Dataset Number: V03935253UB 0001
   Coding: 2D0060C151FFC428949C810510301600000000000000000000
   VCID: 3C21333606ED4BBAD3B-8068
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Fault Frequency: 14
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
                    Control Module temperature: 43  C
                    Voltage terminal 15: 13.7 V
                    Velocity_vehicle_reference: 12.60 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.48 m/s
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:22
                    Velocity_vehicle_reference: 12.94 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.25 m/s
2058 - Databus
          [FAULT_GP_INVALID]
                    Fault Frequency: 9
                    Reset counter: 31
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
                    Voltage terminal 15: 13.6 V
                    Velocity_vehicle_reference: 12.48 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.51 m/s
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001000] - -
          [FAULT_MISALIGNMENT_VERTICAL]
                    Reset counter: 47
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:18
                    Control Module temperature: 27  C
                    Voltage terminal 15: 12.1 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
2131 - Databus
          U1122 00 [00001000] - Implausible Message
          [FAULT_RPM_INVALID]
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
                    Voltage terminal 15: 13.8 V
                    Velocity_vehicle_reference: 12.46 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.49 m/s
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 31
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:22
                    Control Module temperature: 42  C
                    Velocity_vehicle_reference: 12.96 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.62 m/s
   Serial number: 14101641350035 Dataset Number: V03935231PP 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292F2632D5679A373-806C
   Serial number: 003GCR06L212 Dataset Number: V03935221QJ 0001
   VCID: 47CB5CDA4F2B18624E9-8012
   Serial number: IBH000000000005ZWOU0
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 002 411 16
   Serial number: 35700000000B5805E02H
   Subsystem 3 - Part No SW: -----------    HW: 480 001 811 16
   Serial number: 35800000000590B00F1E
   Subsystem 4 - Part No SW: -----------    HW: 480 402 211 16
   Serial number: 3510001B522F976174F8
   Subsystem 5 - Part No SW: -----------    HW: 480 401 811 16
   Serial number: 3520001B523204B3A56U
   Subsystem 6 - Part No SW: -----------    HW: 480 401 411 16
   Serial number: 3550002C122E8E15611$
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 711 16
   Component: FrontSensor_P  000 6149
   Serial number: 3560001C323B3B54C10$
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 22111604221391
   Coding: 0C00
   VCID: 094F9AE219BFAE1298D-805C
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         409 3197
   Coding: 076D4092FE88CF4402847F0F4401000800000000
   VCID: 2A0D056EFC79C50AB17-807E
10485828 - Internal Control Module Memory Check Sum Error
          B2000 41 [00001001] - General Checksum Failure
          [Steuerger t defekt (Fehler durch Selbsttest entdeckt)]
                    Mileage: 148266 km
                    Date: 2026.01.18
                    Time: 19:19:53
          U1110 00 [00001000] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 63
                    Mileage: 153339 km
                    Date: 2026.07.20
                    Time: 16:15:25
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 11111610802901 Dataset Number: V03935242HR 0001
   Coding: 0101000838085900FB00023A880F00000001050000000000000000000000
   GVL: 01DC3C100000060040CC900080024C0000000000000000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CA1F336466D8BBA93B-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29160003055210106456
   Coding: 34FFFF
131595 - Tire Pressure Monitoring Module
          U0127 00 [00001000] - No Communications
          [Timeout Knoten 0x0B / 65 - Steuerger t f r Reifendruck berwachung]
                    Reset counter: 71
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:07:06
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: OFF
          U1101 00 [00001001] - Active
                    Reset counter: 18
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:19
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: On
   Serial number: HA1-00002.11.16 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4ACD65EE5C39E50A517-801E
   Revision: 00000000    Serial number: 16000196591010
   Coding: 5500000000000000
   VCID: 34311B162EBD83FA1BB-8060
   Serial number: 0422386557 Dataset Number: V03935221MX 0001
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Serial number: 0422370730
   Coding: 020111
338048 - Databus
          [Parkhilfe_01::PH_Tongeber_H_verfuegbar]
                    Reset counter: 31
                    Mileage: 153614 km
                    Date: 2026.07.23
                    Time: 15:36:22
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Serial number: 111116EKB02623 Dataset Number: V03935248YZ 0001
   Coding: 003F1320D000040000000000
   VCID: 43D348CA7B133442921-8016
   Serial number: 00000000000012329432
   Coding: 111000
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [00001000] - Electrical Failure
                    Fault Frequency: 62
                    Reset counter: 71
                    Mileage: 152831 km
                    Date: 2026.07.09
                    Time: 15:25:57
65649 - Lamp for Ambient Illumination
          B1325 13 [00001000] - Open Circuit
                    Reset counter: 58
                    Mileage: 153254 km
                    Date: 2026.07.19
                    Time: 15:43:47
   Dataset Number: V03935249RP 0001
   Coding: 9302
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D352E0CD9758AC17-806E
23044 - Databus
          [MOTOR_20 Botschaft - SNA-Check]
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 14.00 V
                    Temperature: 56.0  C
                    KFC: 5A
                    KFA: 00 04
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 13.94 V
                    uAdSensI_SwitchedKl30_xdu16: 13.93 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
22532 - Databus
          [MOTOR_12 Botschaft - SNA-Check]
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
                    Motor status: 02
                    Temperature: 56.0  C
                    KFC: 58
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 14.09 V
                    uAdSensI_SwitchedKl30_xdu16: 14.08 V
   Revision: 00000001    Serial number: VWZ8Z1GBA02V197 Dataset Number: V03935253GC 0001
   Coding: 1200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   Serial number: 121116EKC08275 Dataset Number: V03935249AG 0001
   Coding: 003F1320DE00040000800000
   VCID: 42DD4DCE64093D4A997-8016
   Serial number: 00000000000012443399
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935237WR 0021
   Coding: 022202107F000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40D947C66A052F5A8F3-8014
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Part No SW: 5NA 035 047 C    HW: 5NA 035 047
   Component: MU-H-NS-US    H51 1126
   Serial number: P065J0GB010073
   Coding: 027310020000000051220002001808201F0007E471708405DE
   Shop #: WSC 00256 168 00001
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 606 C    HW: 5G6 919 606 C
   Component: ABT_High-2  280 9304
   Serial number: VWZ6ZMY3005349
   Subsystem 2 - Part No SW: V03 959 821 DC    HW: -----------
   Component: NAR 2024/2025  --- 0376
   Compact disc data bank:
   Component: Gracenote2  --- 3011
          B201A 00 [00001001] - -
                    Fault Frequency: 50
                    Reset counter: 31
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:27
                    Voltage terminal 30: 12.4 V
                    Status_Software_Version_Management-module_name: MDUV669/Main
          [Anti-theft protection - component protection active (0xEA6100)]
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:22
2571 - Navigation System
          B126C F2 [00001000] - Navigation Database not Enabled
                    Reset counter: 58
                    Mileage: 152950 km
                    Date: 2026.07.11
                    Time: 17:25:31
                    Voltage terminal 30: 12.7 V
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.07
                    Time: 04:15:19
                    Voltage terminal 30: 12.1 V
0009 - Antenna for Satellite Radio
          B10F4 13 [00001001] - Open Circuit
                    Fault Frequency: 33
                    Reset counter: 31
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:22
7225 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Range data (0x39) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:24
                    BAP-BAP_Function_ID: 02
   Serial number: 30000000343204 Dataset Number: v09600047P6 0204
   ROD: EV_RDKBERU30_006_VW37.rod
   Dataset Number: 81A909460E  0001
   Coding: 01000001C2002017040060
   Shop #: WSC 12345 123 61029
   VCID: 392F2A2209DF7E92C8D-806C
Address 75: Telematics (J949)       Labels:| 5QE-035-28X-V1.clb
   Dataset Number: V03935236TB 0001
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB_VW37.rod
   Serial number: 22111612K23470 Dataset Number: V03935243PV 0001
   Coding: 000307000000020100221354C040890084000E120040
1135140 - Databus
          [APS_03_US_Fehler_HS]
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:24
                    Control Module temperature: 54  C
                    Outside temperature: 26.5  C
                    Vehicle speed: 43.35 km/h
                    System run time: 64.3 s
                    mid: 02 65
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1135139 - Databus
          [APS_03_US_Fehler_VS]
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:24
                    mid: 02 64
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Fault Frequency: 13
                    Reset counter: 71
                    Mileage: 153615 km
                    Date: 2026.07.23
                    Time: 15:37:23
                    Vehicle speed: 44.75 km/h
                    System run time: 63.5 s
                    mid: 02 E0
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 161103202521
   VCID: 2F3B147AC79BA022669-807A
End----(Elapsed Time: 02:21, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
------------------------------35 Faults Found------------------------------
Plausible based on your scan.
I'm not seeing that either.
Rossatron
Scotland
C?ID=610069
Unplug the ECU and check the plugs and ECU for coolant.
The 2.0 TFSI is famous for water pump/thermostat failure and sometimes it can leak into the plug on the bottom of the unit which then gets carried up through the wiring loom into the ECU causing all sorts of weird running faults.
Kushdaiin
CT, USA
C?ID=192983
Thank you for your responses, I'll keep this updated as I get more information and after I find out more.
nugentp
C?ID=6386
Surely "full limp mode" is a better expression of your problems than "hard limp mode" 😝
Kushdaiin
CT, USA
C?ID=192983
Full limp mode comes right after hard limp mode. lol
Vdub
C?ID=57533
indeed check the plug/connector on the Waterpump/thermostathousing
Kushdaiin
CT, USA
C?ID=192983
Since there are no new ECUs available in the NAR or out of Germany (where they are produced), I'm going to try and send out the ECU to The ECU Pro and see if they can diagnose, repair/replace my unit. If the ECU is indeed faulty (which the VW techs was quite hot to the touch when the car was running but very rough), then it seems like a cheaper option instead of new.
Wait, a MY 2017 car can be at most 10 years old. How can there be no ECUs available for it?
Kushdaiin
CT, USA
C?ID=192983
I should clarify that there are currently no ECUs available. It will be a waiting game with the manufacturer as there is no ETA. I've ordered a few things in the past year that have been in this status. Could take 2 weeks (wheels I ordered that were backordered to the manufacturer that will be here tomorrow) or 14 months (replacement center console cover that I ordered in late December of 2024, arrived in March of 2026). This alternate option seems like a way to shortcut the waiting game and potentially save some money.
OK, thanks. I'd be pretty upset VW was saying "No Longer Available" for a car this young.
Rossatron
Scotland
C?ID=610069
May be different in the states but UK VAG group supplier discontinues parts for a vehicle once 10 years old.
I had a 2008 C6 RS6 other day needs some parts for engine oil leaks - all discontinued years ago.
2015 Biturbo A6 needed an ECU - discontinued !
  • Sad
Vdub
C?ID=57533
In the EU its officially 15y after the last produced model, but I don't think its for every part. Ecu is the least problem, a used one can be programmed/cloned mostly.
There are several on ebay (used) ; 06K 907 425 E
ECU <-----Link
You could send your original and the used ECU to a member here on the forum and he can
transfer the data for you. Interested?
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I strongly suggest to not send Ecu to any "repair" online store. Many people regret doing this , in most cases they will say your Ecu is not repairable and we can supply remain ( they will paint used Ecu and call remain ) and offer Cloning , which will brick Ecu. On Those Sinos 18 Ecus there is no way you can clone it ,only way is to transfer immo data very special way. If you say no , then they will charge at least $200-250 for them diagnostic time. In some cases I saw they brake original Ecu and not possible to read it anymore and you end up with brick in your hand. Local shop had Mercedes Ecu car was running but had some problems, they send it to one of those stores and they return none working Ecu. They end up buying replacement Ecu and program it with me which cost much more then if they did that before this online repair shop brake it.
However I can program Used Ecu while your Ecu is still Ok and read diagnostic. For more info please send me message here or email me .
Kushdaiin
CT, USA
C?ID=192983
So @Jetta 97 provided excellent service and returned a used ECM with my immobilization data transferred over. The good news is that the donor ECM worked flawlessly, however after plugging it in all of the same symptoms remained. Anyway, yesterday I visited the car at the dealership, started up VCDS and decided to autoscan and then to delete all of the DTCs. I then turned the car over to try and get a fresh set of codes when the car turned over it started and ran normally with no codes.
Success, or so I thought. I ended up driving it home and when I got to a moderately steep hill (possibly boost demand), the car went right back to throwing all of the same DTCs. Now while the car was at the dealer, the master tech suggested that I was probably in short order for a turbo due to him seeing that the reference voltage in the wastegate actuator was not returning to the same voltage when he was moving the actuator arm. He also tested a known good throttle body, which seems to eliminate the throttle body.
After last nights fresh set of errors, I ran the autoscan this afternoon and am still getting the "Sensor Reference Voltage A" and "Engine Coolant Level Sensor" errors. But now I'm getting the "Manifold Pressure / Boost Sensor" error. I was leaning towards replacing the Turbo before the autoscan but now it seems that there could be some issues with the sensors or the wiring going to them.
At this point I've relied again on AI and it suggesting I start by testing the G31, G71/G42, and the G247 sensors by unplugging them to see if the voltage returns to normal and clears the P0642 error. Just looking to see if that seems reasonable to check and can I use live data on VCDS to monitor voltage when I unplug these sensors?
Saturday,22,August,2026,14:09:05:28357
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
Mileage: 153648km-95472mi   Repair Order:
          5F 65 6C 75 A5 A9
VIN: WVWWF7AU1HW149710   Mileage: 153648km-95472miles
          P2556 00 [01100100] - Electrical Malfunction
                    Mileage: 153648 km
                    Date: 2026.08.21
                    Time: 17:47:44
                    Coolant temperature: 90  C
                    Voltage terminal 30: 12.617 V
                    Engine temp. management actuator: raw value: 2760
                    Engine temperature management actuator: stop open: 141
                    RVC_SP: 174.25
                    RVC_AV: 174.95
                    RVCPWM: 0.000 %
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:18
                    Vehicle speed: 62 km/h
                    Coolant temperature: 94  C
                    Intake air temperature: 26  C
                    Voltage terminal 30: 14.160 V
                    T_AST_SAE: 517 s
                    MAP_MES_SAE: 51 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.539 V
26363 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [01100101] - Implausible Signal
                    Mileage: 153648 km
                    Date: 2026.08.21
                    Time: 17:47:44
                    Coolant temperature: 91  C
                    T_AST_SAE: 248 s
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.992 V
Readiness: 1010 0001
8274 - Databus
                    Reset counter: 32
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:13
8296 - Databus
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:19
8330 - Databus
                    Reset counter: 32
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:13
   Coding: 032C0C
   Revision: 00001K08
   Air quality sensor:
   Coding: 06A8DD
560917 - Databus
                    Fault Frequency: 9
                    Reset counter: 32
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:11
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.9 V
                    Outside temperature: 19.0  C
   Coding: 0271667801
13637426 - Databus
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:20
13688835 - Databus
                    Reset counter: 32
                    Mileage: 153644 km
                    Date: 2026.08.21
                    Time: 17:40:11
13637429 - Databus
                    Reset counter: 32
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:12
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:19
                    Control Module temperature: 34  C
                    Voltage terminal 15: 14.0 V
                    Velocity_vehicle_reference: 16.93 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.96 m/s
2101 - Databus
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:19
                    Velocity_vehicle_reference: 17.55 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.57 m/s
2058 - Databus
          [FAULT_GP_INVALID]
                    Reset counter: 32
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:12
                    Control Module temperature: 29  C
                    Voltage terminal 15: 11.8 V
2131 - Databus
          [FAULT_RPM_INVALID]
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:20
                    Velocity_vehicle_reference: 16.72 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.83 m/s
2068 - Databus
                    Reset counter: 32
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:12
   Coding: 30324E
   Coding: 0C00
                    Mileage: 148266 km
                    Date: 2026.01.18
                    Time: 19:19:53
   Generator:
   Coding: 34FFFF
                    Fault Frequency: 12
                    Reset counter: 72
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:42:33
                    Terminal 30 power supply: 12.6 V
                    Terminal 15: OFF
                    Reset counter: 31
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:12
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
   Coding: 0001
   Coding: 02011103
   Coding: 020111
338048 - Databus
                    Reset counter: 32
                    Mileage: 153644 km
                    Date: 2026.08.21
                    Time: 17:40:09
   Coding: 111000
                    Reset counter: 72
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:42:30
   Coding: 9302
23044 - Databus
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:19
                    Motor status: 00
                    Temperature: 34.0  C
                    KFC: 5A
                    KFA: 00 04
22532 - Databus
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:19
                    Motor status: 00
                    Temperature: 34.0  C
                    KFC: 58
                    KFA: 00 04
   Coding: 091000
   Coding: 900000
   Coding: 900000
                    Reset counter: 32
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:23
                    Reset counter: 31
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:16
                    Reset counter: 31
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 16:14:28
                    Voltage terminal 30: 12.3 V
                    Reset counter: 31
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:18
                    Reset counter: 31
                    Mileage: 153636 km
                    Date: 2026.08.21
                    Time: 15:41:18
1135140 - Databus
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:20
                    Control Module temperature: 31  C
                    Outside temperature: 19.5  C
                    Vehicle speed: 57.67 km/h
                    System run time: 520.6 s
                    Voltage terminal 15: 13.9 V
                    mid: 02 65
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1135139 - Databus
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:20
                    mid: 02 64
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
                    Reset counter: 72
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:19
                    Vehicle speed: 60.05 km/h
                    System run time: 519.7 s
                    mid: 02 E0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
End----(Elapsed Time: 02:20, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
------------------------------30 Faults Found------------------------------
Vdub
C?ID=57533
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:18
This one comes first, after that 5V becomes bad.
i would check your Crankshaftsensor because youre driving 62kmh with no rpm.. and the ABS also complains about RPM
Kushdaiin
CT, USA
C?ID=192983
                    Mileage: 153642 km
                    Date: 2026.08.21
                    Time: 17:35:18
I will check that out first. Best way to test would be to clear codes, unplug sensor, and then turn car on and see if P0642 comes back?
Vdub
C?ID=57533
No, because it wont start, but it wont hurt check the wires/plug around there.
