Friday,07,August,2026,08:03:54:14071
VCDS Version: 26.3.0.0 HEX-V2 CB: 0.4713.5
VIN: WVGZZZ5NZJM196424 License Plate: 0708
Mileage: 85589km-53182mi Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 22 29 2B 36 39 42 44
4B 52 5F 65 6C 6D A5 BB BC D6 D7
VIN: WVGZZZ5NZJM196424 Mileage: 85589km-53182miles
6C-Back-up Cam. -- Status: Cannot be reached 0100
Address 01: Engine (J623-DGVA) Labels:. 06K-907-309-V2.clb
Part No SW: 5NA 907 115 E HW: 06L 907 309 B
Component: 2.0 R4 TFSI H31 0002
Revision: 1DH31000 CVN: 510AAFF5
Coding: 022500122466052B34000000000000000000000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM20TFS0115NA907115E 001004
ROD: EV_ECM20TFS0115NA907115E_VW37.rod
VCID: 40DEA19B7A00AC7A8F3-8014
VINID: 9E65EAAAA15EA9A74124610210B429140D
17156 - Databus
U1123 00 [00100111] - Received Error Message
Mileage: 85584 km
Date: 2026.08.07
Time: 07:32:35
Engine speed: 1339.50 /min
Normed load value: 2.4 %
Coolant temperature: 36 C
Intake air temperature: 36 C
Voltage terminal 30: 11.360 V
Drivetrain coordinator: brake fault status-Bits 0-7: 1
Drivetrain coordinator: brake function status-Bits 0-7: 5
Acceleration: 0.000 m/s
Readiness: 0010 0001
Part No SW: 0DL 300 012 M HW: 0GC 927 711 H
Component: GSG DQ500 H06 2107
Revision: 00H06V15 CVN: D6B16A11
ROD: EV_TCMDQ500021.rod
VCID: 3334FE573BB607E2021-8066
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 51548000000084
Coding: 0BEE6B9A54291B72477B070262C749D0D62AD8E2E046927D38425008420A4200002864121A1C230935351919323200
VCID: 78AE097B625024BAF73-802C
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0479643943 Dataset Number: V03935267GZ 0001
Coding: 132C2C0723
Shop #: WSC 01383 790 50316
VCID: 3E22DF6300F4DA8AFDF-806A
Power rear lid opening control module:
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11039347
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Serial number: Y0006RDK15522
Coding: 0010000000000500818280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorPasseSide 002022
ROD: EV_SeatMemorPasseSide.rod
VCID: 3D20D86F0DF2C192E45-8068
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 R HW: 5NA 907 044 R
Component: AC Automat H35 4401
Revision: 20K03000 Serial number: 00000D00181363
Coding: 0002000410010001100510401010142A
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ACClimaPrehVW37X 002025
VCID: 4EC28FA3B0544A0A0DF-801A
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
459778 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [00001000] - Performance
Reset counter: 54
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:35
Part No SW: 5Q0 937 086 BL HW: 5Q0 937 086 BG
Component: BCM PQ37BOSCH 034 0246
Revision: -------- Serial number: C86425061802A4 Dataset Number: V03935285ZY 0001
Shop #: WSC 00066 790 00451
ROD: EV_BCMBOSCH_018_VW37.rod
VCID: 0550708F25A24952FC5-8050
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 180601 034 0373
Serial number: 18052822000340
Component: RLHS 052 0107
Serial number: S2Y18M06D18H06M41S59
Coding: 00A8DD
Humidity sensor: interior:
Part No SW: 5QA 919 294 E HW: 5QA 919 294
Component: PDC 8 KanalH07 0443
Serial number: 000145450R18184 Dataset Number: V03935280HL 0001
Coding: 0471451811
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 X390
Dataset Number: V03935305AH 0001
Coding: 30095F831EFFC728779F81E48357874010000000009A404014
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: 73B43E577B3647E2C21-8026
Part No SW: 5Q0 959 655 BG HW: 5Q0 959 655 BG
Component: AirbagVW21 005 0336
Serial number: 003VUM01K44T Dataset Number: V03935271PJ 0001
Coding: 88CCC000000000005C0000CF000800000065
VCID: 0652778318A4424AF5F-8052
Subsystem 1 - Part No SW: ----------- HW: 480 002 306 18
Serial number: 357000000003C468EE2Z
Subsystem 2 - Part No SW: ----------- HW: 480 002 306 18
Serial number: 35800000000C6D594F2$
Subsystem 3 - Part No SW: ----------- HW: 480 402 005 18
Component: SideSensor_Dr 004 6149
Serial number: 3510001102AF12F271CZ
Subsystem 4 - Part No SW: ----------- HW: 480 402 005 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001B529F25F43141
Subsystem 5 - Part No SW: ----------- HW: 480 402 905 18
Component: FrontSensor_D 004 6149
Serial number: 3550001202B7222333EM
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 19041820240372
Coding: 0410
VCID: 074C7A871FAE5B428E9-8052
Part No SW: 5NA 920 750 B HW: 5NA 920 750 B
Component: KOMBI 380 0310
Coding: 07A50898EE84000801883B071401000000000000
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 518 5366
Serial number: 08061800841143 Dataset Number: WangANJing 0001
Coding: 000000F0000F58000F000000000F00000001000100000000000000000000
GVL: 01DE3C000800060040BC80000002C80000000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E822F2310146A0A2DF-803A
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [00001000] - -
[Timeout Knoten 0x46 / 08 - Steuerger t f r Klima]
Reset counter: 54
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:38
Terminal 30 power supply: 12.1 V
Terminal 15: OFF
131689 - Rear View Camera System Control Module
U104C 00 [00001001] - No communication
[Timeout Knoten 0x69 / 6C - Steuerger t f r R ckfahrkamerasystem]
Reset counter: 14
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
Terminal 30 power supply: 12.0 V
Terminal 15: On
67072 - Local Databus
U1125 00 [00001001] - Additional Installations Detected
[Subsystem Mehrverbau erkannt]
Reset counter: 14
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
Terminal 15: On
1036 - invalid data record
B2005 00 [00001001] - -
[ung ltiger Datensatz: Funktion "M digkeitserkennung"]
Reset counter: 14
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
Terminal 15: On
1026 - invalid data record
[Data_set_invalid_NV-EM]
Reset counter: 14
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
Terminal 15: On
0769 - Analog Measuring Input
C1155 31 [00001001] - No Signal
Reset counter: 14
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
Terminal 15: On
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00009.04.18 Dataset Number: v1260x015G0 0000
Coding: 0101
VCID: 4CC685AB4648781A63B-8018
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45D0B08F65228952BC5-8010
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000169673003
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
Address 36: Seat Mem. Drvr (J810) Labels:* None
Serial number: Y0006RDK15566
Coding: 001000020000050001C280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide_VW37.rod
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-DCD-V1.clb
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038818602158 Dataset Number: V03935269KM 0001
Coding: 003F1B20D200028000001000
VCID: 47CCBA875F2E9B424E9-8012
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1081
Dataset Number: V03935273HA 0001
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 50FE91DBAA605CFA1F3-8004
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 03071800840073 Dataset Number: V03935260VN 0001
Coding: 0000000501001D5200000F000A0000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_001_VW37.rod
VCID: 72BA3B53042C4EEAC97-8026
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038807300967 Dataset Number: V03935269KN 0001
Coding: 003F1320DE00028000001000
VCID: 46D2B7835824824AB5F-8012
Part No SW: 3Q0 035 824 C HW: 3Q0 035 824 C
Component: MU-S--ER 722 0867
Serial number: Dataset Number: V03935281LR 0001
Coding: 02730600FF00000051110001001828001F0506D40120010002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2D00E82FDD925112545-8078
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H52 8130
Serial number: VWZ6ZJV1591729
6720 - Rear View Camera
B1102 31 [00001001] - No Signal
Reset counter: 14
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
Voltage terminal 30: 12.0 V
7202 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Driver alert system (0x22) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 14
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:33
BAP-BAP_Function_ID: 02
7207 - Function Restricted due to Missing Message(s)
[Start/stop reasons (0x27) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 14
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:33
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000179011 Dataset Number: V03935267QN 0001
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3436FD4B3EB800DA1BB-8060
Address 6C: Back-up Cam.
Part No SW: 5Q0 959 107 Q HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0266
Revision: -------- Serial number: A2-C758-8700-2 Dataset Number: V03935297GM 0001
Coding: 0A28
Shop #: WSC 00066 790 00446
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2QD 980 653 HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1302
Serial number: E98887401213640 Dataset Number: V03935357NE 0001
Coding: 00000798104C4028A89F1C801010002000238000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
9 Faults Found:
1124185 - Local Data Bus
U1169 00 [00001001] - Missing Message
[TIMEOUT_RDR1_StrukturRechts]
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:31
1124184 - Local Data Bus
[TIMEOUT_RDR1_StrukturLinks]
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:31
1122599 - Local Data Bus
[Timeout_RDR1_Obj_02]
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
1124134 - Local Data Bus
[TIMEOUT_RDR1_Obj_01]
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
1124193 - Local Data Bus
[TIMEOUT_RDR1_ObjGegen_02]
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
1124192 - Local Data Bus
[TIMEOUT_RDR1_ObjGegen_01]
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
1122601 - Local Data Bus
[Timeout_RDR1_Obj_04]
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
1122600 - Local Data Bus
[Timeout_RDR1_Obj_03]
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
1122597 - Local Data Bus
[Timeout_RDR1_Header]
Mileage: 85584 km
Date: 2026.08.06
Time: 20:58:30
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V1.clb
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: TSG HFS 012 0032
Serial number: 0000323700263 Dataset Number: V03935262CY 0001
Coding: 002A11200101028000001000
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
ROD: EV_DCURearDriveMAXCONT_VW37.rod
VCID: 49C8BCBF493A6D3258D-801C
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V1.clb
Component: TSG HBFS 012 0032
Serial number: 0000323700357 Dataset Number: V03935262CX 0001
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
ROD: EV_DCURearPasseMAXCONT_VW37.rod
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 167227C34804F2CA05F-8042
Component: LED1R H09 0003
End----------(Elapsed Time: 02:04, VBatt start/end: 12.5V/12.4V)-----------
------------------------------20 Faults Found------------------------------
