Volkswagen tiguan 2018 acc deactived after change battery
shin1986
Hanoi, Vietnam
C?ID=660275
Hello everyone,
I'm currently driving a 2018 Volkswagen Tiguan and have run into an issue after replacing the battery.
Immediately after installing the new battery, the Adaptive Cruise Control (ACC) stopped working. Lane Assist is still functioning normally, but whenever I try to activate ACC, the instrument cluster displays "ACC Deactivated", and the ACC system cannot be used.
I have already scanned the vehicle with VCDS and cleared all low-voltage fault codes that were generated during the battery replacement, but the ACC still does not work.
Has anyone experienced the same issue after replacing the battery? If so, I would really appreciate any advice on how to fix it.
Before the battery replacement, the ACC was working perfectly without any problems.
Thank you in advance for your help!
Here is auto-scan :
Wednesday,29,July,2026,15:50:30:14071
VCDS Version: 26.3.0.0  HEX-V2 CB: 0.4713.5
VIN: WVGZZZ5NZJM196424   License Plate: 29-8
Mileage: 85221km-52953mi   Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 22 29 2B 36 39 42 44
          4B 52 5F 65 6C 6D A5 BB BC D6 D7
VIN: WVGZZZ5NZJM196424   Mileage: 85221km-52953miles
4B-Multifunc. Module -- Status: Cannot be reached 0100
6C-Back-up Cam. -- Status: Cannot be reached 0100
Address 01: Engine (J623-DGVA)       Labels:. 06K-907-309-V2.clb
   Part No SW: 5NA 907 115 E    HW: 06L 907 309 B
   Component: 2.0 R4 TFSI   H31 0002
   Revision: 1DH31000    CVN: 510AAFF5
   Coding: 022500122466052B34000000000000000000000000000000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TFS0115NA907115E 001004
   ROD: EV_ECM20TFS0115NA907115E_VW37.rod
   VCID: 40DEA19B7A00AC7A8F3-8014
   VINID: 9E65EAAAA15EA9A74124610210B429140D
17156 - Databus
          U1123 00 [00101111] - Received Error Message
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:57
                    Engine speed: 797.00 /min
                    Normed load value: 4.3 %
                    Coolant temperature: 98  C
                    Intake air temperature: 65  C
                    Voltage terminal 30: 13.480 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 4
                    Acceleration: 0.000 m/s
Readiness: 0000 0001
   Part No SW: 0DL 300 012 M    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 2107
   Revision: 00H06V15    CVN: D6B16A11
   ROD: EV_TCMDQ500021.rod
   VCID: 3334FE573BB607E2021-8066
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 51548000000084
   Coding: 0BEE6B9A54291B72477B070262C749D0D62AD8E2E046927D38425008420A4200002864121A1C230935351919323200
   VCID: 78AE097B625024BAF73-802C
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0479643943 Dataset Number: V03935267GZ 0001
   Coding: 132C2C0723
   Shop #: WSC 01383 790 50316
   VCID: 3E22DF6300F4DA8AFDF-806A
   Power rear lid opening control module:
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11039347
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RDK15522
   Coding: 0010000000000500818280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: 3D20D86F0DF2C192E45-8068
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 R    HW: 5NA 907 044 R
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00181363
   Coding: 0002000420010001100510401010142A
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   VCID: 4EC28FA3B0544A0A0DF-801A
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
459778 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [00001000] - Performance
                    Fault Frequency: 9
                    Reset counter: 43
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:39:40
   Part No SW: 5Q0 937 086 BL    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C86425061802A4 Dataset Number: V03935285ZY 0001
   Shop #: WSC 00066 790 00451
   ROD: EV_BCMBOSCH_018_VW37.rod
   VCID: 0550708F25A24952FC5-8050
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 180601  034 0373
   Serial number: 18052822000340
   Component: RLHS  052 0107
   Serial number: S2Y18M06D18H06M41S59
   Coding: 00A8DD
   Humidity sensor: interior:
   Part No SW: 5QA 919 294 E    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0443
   Serial number: 000145450R18184 Dataset Number: V03935280HL 0001
   Coding: 0471451811
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 X390
   Dataset Number: V03935305AH 0001
   Coding: 30095F831EFFC728779F81E48357874010000000009A404014
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 73B43E577B3647E2C21-8026
   Part No SW: 5Q0 959 655 BG    HW: 5Q0 959 655 BG
   Component: AirbagVW21    005 0336
   Serial number: 003VUM01K44T Dataset Number: V03935271PJ 0001
   Coding: 88CCC000000000005C0000CF000800000065
   VCID: 0652778318A4424AF5F-8052
   Subsystem 1 - Part No SW: -----------    HW: 480 002 306 18
   Serial number: 357000000003C468EE2Z
   Subsystem 2 - Part No SW: -----------    HW: 480 002 306 18
   Serial number: 35800000000C6D594F2$
   Subsystem 3 - Part No SW: -----------    HW: 480 402 005 18
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001102AF12F271CZ
   Subsystem 4 - Part No SW: -----------    HW: 480 402 005 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001B529F25F43141
   Subsystem 5 - Part No SW: -----------    HW: 480 402 905 18
   Serial number: 3550001202B7222333EM
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 19041820240372
   Coding: 0410
   VCID: 074C7A871FAE5B428E9-8052
   Part No SW: 5NA 920 750 B    HW: 5NA 920 750 B
   Component: KOMBI         380 0310
   Coding: 07A50898EE84000801883B071401000000000000
   Component: GW MQB High   518 5366
   Serial number: 08061800841143 Dataset Number: WangANJing  0001
   Coding: 000000F0000F58000F000000000F00000001000100000000000000000000
   GVL: 01DE3C000800060040BC80000002C80000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E822F2310146A0A2DF-803A
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [00001000] - -
          [Timeout Knoten 0x46 / 08 - Steuerger t f r Klima]
                    Fault Frequency: 9
                    Reset counter: 43
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:39:43
                    Terminal 30 power supply: 12.9 V
                    Terminal 15: OFF
131689 - Rear View Camera System Control Module
          U104C 00 [00001001] - No communication
          [Timeout Knoten 0x69 / 6C - Steuerger t f r R ckfahrkamerasystem]
                    Reset counter: 3
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:57
                    Terminal 30 power supply: 13.5 V
                    Terminal 15: On
67072 - Local Databus
          U1125 00 [00001001] - Additional Installations Detected
          [Subsystem Mehrverbau erkannt]
                    Reset counter: 3
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:57
                    Terminal 15: On
1036 - invalid data record
          B2005 00 [00001001] - -
          [ung ltiger Datensatz: Funktion "M digkeitserkennung"]
                    Reset counter: 3
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:57
                    Terminal 15: On
1026 - invalid data record
          [Data_set_invalid_NV-EM]
                    Reset counter: 3
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:57
                    Terminal 15: On
0769 - Analog Measuring Input
          C1155 31 [00001001] - No Signal
                    Reset counter: 3
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:57
                    Terminal 15: On
   Serial number: HA1-00009.04.18 Dataset Number: v1260x015G0 0000
   Coding: 0101
   VCID: 4CC685AB4648781A63B-8018
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45D0B08F65228952BC5-8010
   Serial number: 18000169673003
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Serial number: Y0006RDK15566
   Coding: 001000020000050001C280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Serial number: 5038818602158  Dataset Number: V03935269KM 0001
   Coding: 003F1B20D200028000001000
   VCID: 47CCBA875F2E9B424E9-8012
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1081
   Dataset Number: V03935273HA 0001
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50FE91DBAA605CFA1F3-8004
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 03071800840073 Dataset Number: V03935260VN 0001
   Coding: 0000000501001D5200000F000A0000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_001_VW37.rod
   VCID: 72BA3B53042C4EEAC97-8026
   Serial number: 6038807300967  Dataset Number: V03935269KN 0001
   Coding: 003F1320DE00028000001000
   VCID: 46D2B7835824824AB5F-8012
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      722 0867
   Serial number:                Dataset Number: V03935281LR 0001
   Coding: 02730600FF00000051110001001828001F0506D40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D00E82FDD925112545-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV1591729
6720 - Rear View Camera
          B1102 31 [00001001] - No Signal
                    Reset counter: 3
                    Mileage: 85190 km
                    Date: 2026.07.27
                    Time: 21:48:37
                    Voltage terminal 30: 13.5 V
7202 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Driver alert system (0x22) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 3
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:39:00
                    Voltage terminal 30: 13.6 V
                    BAP-BAP_Function_ID: 02
7207 - Function Restricted due to Missing Message(s)
          [Start/stop reasons (0x27) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 3
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:39:00
   Serial number: 40000000179011 Dataset Number: V03935267QN 0001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3436FD4B3EB800DA1BB-8060
Address 6C: Back-up Cam.
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0266
   Revision: --------    Serial number: A2-C758-8700-2 Dataset Number: V03935297GM 0001
   Coding: 0A28
   Shop #: WSC 00066 790 00446
   Part No SW: 2QD 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E98887401213640 Dataset Number: V03935357NE 0001
   Coding: 00000798104C4028A89F1C801010002000238000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
9 Faults Found:
1124185 - Local Data Bus
          U1169 00 [00001001] - Missing Message
          [TIMEOUT_RDR1_StrukturRechts]
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:56
1124184 - Local Data Bus
          [TIMEOUT_RDR1_StrukturLinks]
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:56
1122599 - Local Data Bus
          [Timeout_RDR1_Obj_02]
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:56
1124134 - Local Data Bus
          [TIMEOUT_RDR1_Obj_01]
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:56
1124193 - Local Data Bus
          [TIMEOUT_RDR1_ObjGegen_02]
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:56
1124192 - Local Data Bus
          [TIMEOUT_RDR1_ObjGegen_01]
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:56
1122601 - Local Data Bus
          [Timeout_RDR1_Obj_04]
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:56
1122600 - Local Data Bus
          [Timeout_RDR1_Obj_03]
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:56
1122597 - Local Data Bus
          [Timeout_RDR1_Header]
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:38:56
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V1.clb
   Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Component: TSG HFS       012 0032
   Serial number: 0000323700263  Dataset Number: V03935262CY 0001
   Coding: 002A11200101028000001000
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   VCID: 49C8BCBF493A6D3258D-801C
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V1.clb
   Component: TSG HBFS      012 0032
   Serial number: 0000323700357  Dataset Number: V03935262CX 0001
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 167227C34804F2CA05F-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:17, VBatt start/end: 12.5V/12.4V)-----------
------------------------------20 Faults Found------------------------------
shin1986
Hanoi, Vietnam
C?ID=660275
I've now added the detailed Auto-Scan file. Please have a look when you have time.
Only a wild guess, but the "Invalid Data Record" faults in the Gateway bother me the most, and this isn't something that can be fixed with VCDS.
downtime
Finland
C?ID=280813
Clear all dtcs and cycle ignition. See what comes back
Vdub
C?ID=57533
Did you press some button on the mfsw?
shin1986
Hanoi, Vietnam
C?ID=660275
thank you so you mean I should try Odis or other tool like OBD11 right?
shin1986
Hanoi, Vietnam
C?ID=660275
Hi i tried to clear all dtcs and cycle ignition. this is my new all scan detail.
Thursday,30,July,2026,13:14:58:14071
VIN: WVGZZZ5NZJM196424   License Plate: 30E66216
Mileage: 85278km-52989mi   Repair Order:
VIN: WVGZZZ5NZJM196424   Mileage: 85278km-52989miles
17156 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:01
                    Engine speed: 798.50 /min
                    Normed load value: 3.9 %
                    Intake air temperature: 57  C
                    Voltage terminal 30: 13.340 V
                    Drivetrain coordinator: brake function status-Bits 0-7: 1
Readiness: 1110 0001
   Coding: 132C2C0723
                    Fault Frequency: 26
                    Reset counter: 43
                    Mileage: 85187 km
                    Date: 2026.07.27
                    Time: 21:39:40
   Coding: 00A8DD
   Coding: 0471451811
   Coding: 0410
                    Reset counter: 3
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:08:27
                    Terminal 30 power supply: 13.4 V
                    Terminal 15: On
                    Reset counter: 3
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:08:27
                    Terminal 15: On
                    Reset counter: 3
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:08:27
                    Terminal 15: On
                    Reset counter: 3
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:08:27
                    Terminal 15: On
                    Reset counter: 3
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:08:27
                    Terminal 15: On
   Coding: 0101
   Coding: 911F0000
                    Reset counter: 3
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:09:20
                    Voltage terminal 30: 13.4 V
                    Reset counter: 3
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:09:23
                    Reset counter: 3
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:09:23
   Coding: 0A28
9 Faults Found:
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:28
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:28
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:28
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:28
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:28
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:28
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:28
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:28
                    Mileage: 85278 km
                    Date: 2026.07.30
                    Time: 13:07:28
End----------(Elapsed Time: 02:01, VBatt start/end: 13.5V/13.5V)-----------
------------------------------19 Faults Found------------------------------
downtime
Finland
C?ID=280813
You A5 camera is the problem why ACC doesn't work. It complains it does not have connection to radar with these missing messages. Go to ACC coding in module 13, disable front camera from the coding, save it and cycle ignition 2 times. ACC should be back working. Of course not in it's full glory as one part of the sensor fusion is now missing.
The errors look like there's a problem with the proprietary CAN between camera and radar.
What has been done to the car? These things don't appear on their own
Spacewalker
Poland
C?ID=159607
replace battery is not for everyone......
1999 - remote adatation lost when new battery replace
2015 - key lost - due to batetry replace
2026 - acc deactivate due to battery replace
we can write a book "What damn battery deactivated in VW group"
shin1986
Hanoi, Vietnam
C?ID=660275
Thank you very much for your detailed explanation.
You’re absolutely right that this issue started immediately after I replaced the new battery.
After the battery replacement, Module 13 reported a calibration fault, and the vehicle displayed “Front Assist Not Available.” I then performed a dynamic calibration (calibration while driving) using VCDS (13 - Basic Settings → Adaptive Cruise Control (ACC) Calibration → Go). After that, the “Front Assist Not Available” message disappeared.
However, after that, the fault related to the A5 camera appeared.
Other than replacing the battery, no hardware has been replaced, adjusted, or modified on the vehicle. Everything I mentioned above was done using VCDS only.
I would be very grateful if you could help me resolve all of these faults.
Based on my understanding, the hardware itself (the radar and sensors) is probably not faulty. It seems more likely that the problem is related to communication between the modules or a software/coding issue after the battery replacement. Am I understanding this correctly?
Thank you again for your time and assistance.
shin1986
Hanoi, Vietnam
C?ID=660275
I completely agree with your opinion.
This is my first Volkswagen (it’s actually the fifth car my family has owned), and I was quite surprised that simply replacing the battery could affect the ACC system.
I bought a genuine HEX-V2 interface and have been trying to learn how to use VCDS so I can diagnose and fix the problem myself instead of taking the car to a Volkswagen service center. It’s been a very interesting learning experience, but also quite a headache!
shin1986
Hanoi, Vietnam
C?ID=660275
Does anyone could help me how to make acc back to normal please, thank you
downtime
Finland
C?ID=280813
Did you try disabling the front camera from acc coding like i instructed?
shin1986
Hanoi, Vietnam
C?ID=660275
I’m concerned that disabling the A5 camera might make the ACC work again, but could also affect other driver-assistance functions, such as Lane Assist and maintaining a safe following distance from the vehicle in front.
Could you please guide me through the proper procedure to fully restore the ACC system, while keeping all the original driver-assistance functions working correctly?
I would really appreciate a complete and safe solution. Thank you very much for your help.
downtime
Finland
C?ID=280813
It does not affect either of these. Disabling front camera from ACC coding only disables sensor fusion between those two. It means that the safety features they complement on each other are disabled but both work independently.
Reason I'm asking to do it, is to verify if the problem with ACC due to camera errors or not.
Why in your pic there's no problem with ACC? You have limiter selected as active assistant.
Edit :
And btw, is your ACC hacked? You have experimental software in your ACC (X390)
shin1986
Hanoi, Vietnam
C?ID=660275
Edit :
No its not hack, in last picture is lim function not acc. Because acc not work so i used lim function. I tried to disable front camera in module 13, could you take a look please
downtime
Finland
C?ID=280813
Yes it's disabled. Only the first pic bit is needed to be removed. That disables the front camera connection.
Do you have your ACC back now?
