Getting beep codes. 3 beeps X 5
Tinbum
C?ID=239741
When I plug my hexnet in to the car ODB port or my PC via USB I get 3 beeps x 5 . Tried firmware update but just get USB error after the laptop has downloaded it.
Exactly the same as this thread except that mine does not beep at all if you do a factory reset.
Shaun
If you are comfortable doing this, please try removing the screws and opening the interface and removing and re-inserting the SD card inside, and see if the beeping goes away. Can you also please post a screenshot of the update information from VCIConfig?
Tinbum
C?ID=239741
Thanks for the quick reply. Beeping still their..
Hi Nick,
I sent you an email from our Support account with one additional suggestion before we move onto replacement of the SD card.
Tinbum
C?ID=239741
Thank you. The feat code did not work on the existing sd card, still 3 x 5 bleeps on power up.
I then put in a new formatted card, ran the feat code and then updated.
No beeping now but when I open vcds mobile it says "could not find the page you are looking for." copyright (C) Hex microsystems (Pty) Ltd. 2013. Same also on a laptop. Are their supposed to be any HTML files on the sd card?
Thanks for the update and that is correct. VCDS-Mobile is essentially a web interface so there should be HTML files and that could not find the page you are looking for response means something isn't right.
Now that the card isn't dead try the red button hold for 50+ seconds once more. It should respond now (unlike before). Providing it resets, give it a few seconds to boot back up and unplug it for a 10 second reboot. Then use VCIConfig once more to update. If that doesn't sort it you can repeat the special feat code steps once more.
In the meanwhile, VCDS should be working again when connected via USB wire so if you have any car repairs to do I think you will be in a better position regardless of the VCDS-Mobile/SD card results today.
@Shaun, should we reset his server side flags? I think those triggered when the card was malfunctioning.
Tinbum
C?ID=239741
Just tried all that and the update was very very slow at times updating over the usb and then just hung. Trying again with the original sd card. (I put that in a desktop computer, it said requires formatting so did that first).
Shaun
Everything looks fine server side. One more thing you might be able to try is see if you can find or borrow a different PC and then run the feature code and the updates again in a different PC. It might be something on the first PC interfered with the process, some antivirus software can try to scan the card when it mounts and cause issues. The update should take a decent amount of time maybe twenty minutes. If that doesn't work or you're not able to do that, let us know.
Tinbum
C?ID=239741
Thanks, Tried on a laptop and a PC. Both similar. Both running windows with Microsofts own anti virus.
I have got it connected to a car via usb but seems a bit hit and miss. Will keep investigating.
If i look at the SD card on a pc is their a way to see if any files are missing? Or is their any other way to do a factory reset / firmware reset that will take it right back to the beginning?
Hi Nick,
The reset feature code and long button hold procedures are the factory-like reset options so it looks like there's an larger issue with this interface. You can continue to tinker with it but we do not think it will recover. In that case we can do one of two things moving forward:
1) If it still works via USB with Windows based VCDS you could use it as-is. I would not expect any wireless functions or VCDS-Mobile to be functional.
2) We can generate a RMA number and get you into our FRR (Flat Rate Repair) program. Because International shipping is outrageous at present, and you would need to ship the malfunctioning interface to us if we handled that directly, I think we would want to reach out to one of our UK distributors to see if they can handle this locally. If you want to go this route we can pass your contact info along to one of those distributors and they can work out the cost details.
Tinbum
C?ID=239741
Thanks, could you pass on my details to a UK distributor.
Thank you.
Will do. I'm mentioning @RTSupport so this turns into an email reminder for us as well.
Gendan Ltd. should be reaching out you at the email address that I sent that initial code to. If you don't receive anything prior to Monday check your junk/spam for sender including @gendan.co.uk
Internal ref to: RET?ID=8491
Tinbum
C?ID=239741
Thank you. They have contacted me but I can't believe how much they want to charge.
How much is a FFR from the USA?
Going through us directly is $199 USD but keep in mind that does not include currency conversion fees, the round trip international shipping or any duties/taxes/vat that FedEx bills directly. I don't process orders but if I had to take a rough guess those costs may be well over an additional $150 USD which is why we try to steer customers to the local distributors when possible.
If you want to let our webstore calculate the one-way FedEx shipping from us to you put a new interface (such as the HN https://store.ross-tech.com/shop/vchn/) into your cart and move forward to the point where the shipping cost is calculated. At that point you can add that to your estimate for return shipping of the malfunctioning unit to us in addition to the tax/vat.
Bruce
Near Philadelphia, PA, USA
I think you will find the taxes are running about 30% into the UK and that shipping will be approximately $100 give or take. We only ship overseas by FedEx Priority Service - the only one that seems to get things done and even they are not what they used to be.
And, there is the cost you will pay to ship your interface back to the US. That too will be expensive.
Then consider that you will have to coordinate any and all paper as we are not going to do that work for other countries. We simply do not know all the rules and such. Our distribs master that for their country and they handle it all. They tell us what we should do to get the product to their door. FedEx does help us clear goods through customs.
As @Dana has said, we recommend that if our distributor is willing to work with you, and it is their option, that you take advantage of the option.
Tinbum
C?ID=239741
I have just bought another used one, could my license be transferred over to that?
Maybe. We'd need details of the new (to you) one.
Tinbum
C?ID=239741
Thanks, as soon as I have received it I will send.
