VW Polo 2020 BCM 2Q0 937 089 B (2Q0937089B) Wiring pinouts
Termina80r
Would anyone have a wiring pinout for VW PQ27 Continental 2Q0 937 089 B BCM?
Im trying to put this BCM on the bench using a godiag connecting box and need to know the ground, power pinouts as well as can low and high connections
At present im thinking
T73a - pin63 - ground
T73c - pin63 - permanent +12v
T73c - pin42 - CAN high
T73c - pin43 - CAN low
T73c - pin57 - Ignition +12v
Tried searching various online articles without much joy finding this specific BCM
Termina80r
Found them on Erwin - thanks - CAN L/H incorrect originally so good job got correct pins now - all powered up on bench and can read no problems
T73a (labelled a on bcm) - pin63 - ground
T73b (labelled c on bcm) - pin63 - permanent +12v
T73b (labelled c on bcm) - pin46 - CAN high
T73b (labelled c on bcm) - pin47 - CAN low
T73b (labelled c on bcm) - pin57 - Ignition +12v
Cannot post auto-scan as its only the BCM im reading at present
