2024 Golf 8
r420
Poland
C?ID=561009
I have just tested SFD in Golf 8. Unlocking in 19 OK, Unlocking in 09 Error
Sunday,26,July,2026,13:36:18:18612
VCDS Version: 26.7.0.1 (x64)  HEX-NET2 CB: 0.4713.5
Data version: 20260708 DS378.0
Dealer/Shop Name: AutoKomplex
VIN: WVWEB7CD7RW1xxxxx   License Plate: XXXX
Mileage: 57448km-35696mi   Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 23 2B 36 3C 42 44 47 4B
          52 5F 6C 75 82 A5 A9 CA D6 D7 8126 8127 C002 C003
VIN: WVWEB7CD7RW1xxxxx   Mileage: 57448km-35696miles
CA-Sunroof -- Status: OK 0000
8126-Trq distrib RearL axle -- Status: OK 0000
8127-Trq distrib RearR axle -- Status: OK 0000
Address 01: Engine (J623-DSFE)       Labels: Redir Fail!
   Part No SW: 5H0 906 259 J    HW: 06K 907 425 N
   Component: R4 2.0l TFS   H08 0001
   Dataset Number: 06Q909102H  0010 CVN: 22274287FCD25DD3
   Coding: 092500322466010E30040000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0205H0906259J 001002
   ROD: EV_ECM20TFS020_VW38.rod
   VCID: 363E4BAC78C3F6FA35E-8062
   VINID: 9E69D54874D41E29C1183102100EB4A816
23079 - Control unit for information electronics 1
          U1054 00 [00101111] - No Communication
                    Fault Frequency: 18
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:16:33
                    Engine speed: 1305.75 /min
                    Normed load value: 10.2 %
                    Coolant temperature: 44  C
                    Intake air temperature: 24  C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 14.511 V
                    LF_MVB_PDU_INTC_DIAG_8: 0
                    LF_MVB_PDU_INTC_DIAG_9: 0
                    LF_MVB_PDU_INTC_DIAG_10: 0
                    LF_MVB_PDU_INTC_DIAG_11: 8192
                    LF_MVB_PDU_INTC_DIAG_13: 4
                    LF_MVB_BUS_INTC_DIAG: 256
16465 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [00100000] - -
                    Reset counter: 23
                    Mileage: 56780 km
                    Date: 2026.07.11
                    Time: 00:26:17
                    Engine speed: 0.00 /min
                    Coolant temperature: 102  C
                    Intake air temperature: 33  C
                    Voltage terminal 30: 11.972 V
                    Unlearning counter according OBD: 23
                    Engine temperature management actuator: stop open: 150
                    Engine temperature management actuator: after-run stop: 2299
                    Engine temp. management actuator: raw value: 2302
                    Engine temp. mangmt. actuator: actual value of angle: 255.34
                    Engine temp. mangmt. actuator: specified value of angle: 274.25
                    Engine temp. management actuator: duty cycle activation: 34.99 %
                    Engine status: Stop
16987 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [01101000] - -
                    Fault Frequency: 22
                    Mileage: 56697 km
                    Date: 2026.07.10
                    Time: 20:24:44
                    Coolant temperature: 103  C
                    Voltage terminal 30: 11.992 V
                    Engine temperature management actuator: stop open: 145
                    Engine temperature management actuator: after-run stop: 3948
                    Engine temp. management actuator: raw value: 2234
                    Engine temp. mangmt. actuator: actual value of angle: 140.26
                    Engine temp. mangmt. actuator: specified value of angle: 4.00
                    Engine temp. management actuator: duty cycle activation: 0.00 %
                    Engine status: Stop
   Part No SW: 0GC 906 557 CF    HW: 0GC 300 019 N
   Component: GSG DQ381     H06 4460
   CVN: D7EC5F92
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: 0358E2787B919352C20-8056
   Subsystem 1 - Part No SW: 5WA 713 033 CD    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20231115000090087751
   Subsystem 2 - Part No SW: 5H0 713 059 Q    HW: 5H0 713 059 Q
   Component: ZSB_SB_Mono    H03 0014
   Serial number: 92478WL200297
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700006014040
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 CF    HW: 5WA 614 517 N
   Component: ESC           H13 0135
   Serial number: 63413000009235  Dataset Number: V03935397FY 0001 CVN: C8DB43C2
   Coding: 76FC6E9076266E6F527B6E0276C760064A525A555A88030820B4B831018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
   ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
   VCID: 0E4EC34C20D3EE3A5DE-805A SFD [x]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 Q    HW: 5WA 959 436 Q
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935341VY 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 6296C7FC84CB3A5AA96-8036
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 007 AC    HW: 5WA 907 007 AC
   Component: AC Automat    H31 3623
   Serial number: --------------- Dataset Number: V03935418JG 0001
   Coding: 002000110211120011101010111111110000131100200100000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001102
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 0842F55442B7B00A972-805C
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000002767660
   Subsystem 2 - Part No SW: 11A 907 049 B    HW: 11A 907 049 B
   Component: E265 KPH SH    H02 0184
   Serial number: G07S16.11.2300972676
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002201123013014503
459025 - Databus
          [Databus missing message radio]
                    Fault Frequency: 16
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:31
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BT    HW: 5WA 937 086 BB
   Component: BCM37w_H134 0183
   Serial number: BXJ53F051223940 Dataset Number: V03935400FM 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_VW38.rod
   VCID: 241A81E4DE5F746A9BA-8070 SFD [x]
   Subsystem 1 - Part No SW: 5H1 955 119 B    HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0061
   Serial number: 907453F0302332400954
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           054 0206
   Serial number: SAY23M12D05H18M25S03
   Subsystem 3 - Part No SW: 5H0 941 193 AL    HW: 5H0 941 193 AL
   Component: LiSi           H06 0008
   Serial number: 92471WJQ000J1
   Subsystem 4 - Part No SW: 5H0 925 200 R    HW: 5H0 925 200 R
   Component: DiETa          H07 0008
   Serial number: 92471WKT001ZB
   Subsystem 5 - Part No SW: 5H0 959 561 BQ    HW: 5H0 959 561 BQ
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND25112300011244
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0102
   Serial number: ESE3953612
   Subsystem 7 - Part No SW: 3G0 963 345 A    HW: 3G0 963 345 A
   Component: SysNameFanLin  015 0102
   Serial number: ESE3963063
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE3953614
   Subsystem 9 - Part No SW: 3G0 963 345 A    HW: 3G0 963 345 A
   Serial number: ESE3963044
   Steering Column Switch:
   Subsystem 10 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Serial number: 00000005122308490245
   Part No SW: 5R3 919 298 A    HW: 5R3 919 298
   Component: PLA 12 Kanal  H05 1570
   Serial number: 000995442323338 Dataset Number: V03935394RP 0001
   Coding: 8200026011
   ASAM Dataset: EV_EPHVA2CVW3800000 002036
   ROD: EV_EPHVA2CVW3800000_VW38.rod
   VCID: 41D42870210D414290C-8014
12664912 - Databus
          U1121 00 [00101100] - Missing Message
          [MIB - AMP_01 kein Signal/keine Kommunikation]
                    Fault Frequency: 15
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:30
1114113 - Driver Assistance Systems Audio Output
          B1AE2 F0 [00101111] - Infotainment System; Implausible Signal
          [sound_ouput_MIB_totally_disturbed]
                    Fault Frequency: 14
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:31
1114116 - Driver Assistance Systems Audio Output
          B1AE2 F1 [00101100] - Amplifier; Implausible Signal
          [sound_ouput_AMP_totally_disturbed]
                    Fault Frequency: 15
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:30
13688835 - Databus
          U1123 00 [00101111] - Received Error Message
          [Steuerger t f r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Fault Frequency: 17
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:30
13638928 - Databus
          U1121 00 [00101111] - Missing Message
          [MIB - MainUnit_01 - kein Signal/keine Kommunikation]
                    Fault Frequency: 13
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:30
Address 13: Auto Dist. Reg (J428)       Labels:| 5WA-907-572.clb
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H45 0461
   Dataset Number: V03935392FC 0001
   Coding: 0E030894407780451247400000804004AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4ECE034CE053AE3A1DE-801A
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Fault Frequency: 15
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:16:33
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Fault Frequency: 15
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:16:33
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Fault Frequency: 15
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:16:33
1230 - Databus
          [FAULT_TIMEOUT_MAINUNIT_01]
                    Fault Frequency: 13
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:30
2068 - Databus
          U1123 00 [00101000] - Received Error Message
          [FAULT_TSK_IRREV_ERROR]
                    Reset counter: 23
                    Mileage: 56780 km
                    Date: 2026.07.11
                    Time: 00:26:18
Address 14: Susp. Elect. (J250)       Labels: 1EA-907-376.clb
   Part No SW: 1EA 907 376 C    HW: 1EA 907 376
   Component: DAEMPFUNGS-SG H05 0457
   Serial number: 2C7673241330032 Dataset Number: V03935344MR 0001
   ASAM Dataset: EV_DCC3CONTITEMIC 002006
   ROD: EV_DCC3CONTITEMIC_002_VW38.rod
   VCID: 3A265F9C4CDB129AD16-806E
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 M    HW: 5WA 959 655 M
   Component: AirbagVW40    011 0636
   Serial number: 000000003C0J3RA Dataset Number: V03935370MB 0001
   Coding: 8CCC000000FCC00000000000000000005100000000000000000036F800130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 6194C8F081CD2142B0C-8034 SFD [x]
   Component: -------------  H17 0022
   Serial number: IBH00000000000LM9XOQ
   Subsystem 2 - Part No SW: -----------    HW: 480 050 812 23
   Component: SideSensor_Dr  000 0149
   Serial number: 35100009ECC72215EA5G
   Subsystem 3 - Part No SW: -----------    HW: 480 050 812 23
   Component: SideSensor_Pr  000 0149
   Serial number: 3520000BCCC7B654C94T
   Subsystem 4 - Part No SW: -----------    HW: 480 002 509 23
   Serial number: 357000000005E4E8BA61
   Subsystem 5 - Part No SW: -----------    HW: 480 001 111 23
   Serial number: 358000000002B2182C6H
   Subsystem 6 - Part No SW: -----------    HW: 480 050 712 23
   Component: FrontSensor_D  000 014A
   Serial number: 3550000B8C716254C689
   Subsystem 7 - Part No SW: -----------    HW: 480 050 712 23
   Component: FrontSensor_P  000 014A
   Serial number: 3560000AECC7B3CF477%
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 C    HW: 5H0 920 340 C
   Component: KOMBI         310 7380
   Dataset Number: V03935364SX 0001
   Coding: 08FC02427B9C88090780620B2000000810300000
   ASAM Dataset: EV_DashBoardVDDMQB37W 003035
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: 221687FCC44B7A5AE96-8076 SFD [x]
16777018 - Control unit for information electronics 1
          U1054 00 [00001001] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Fault Frequency: 33
                    Mileage: 56768 km
                    Date: 2026.07.11
                    Time: 00:15:36
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Fault Frequency: 21
                    Mileage: 57013 km
                    Date: 2026.07.13
                    Time: 17:17:44
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Fault Frequency: 16
                    Mileage: 56768 km
                    Date: 2026.07.11
                    Time: 00:15:36
   Part No SW: 5WA 907 530 AB    HW: 5WA 907 530 L
   Component: GW2020 High   778 7105
   Revision: --------    Serial number: 771049110023339 Dataset Number: V03935393AA 0001
   Coding: 0000808D0F00000000000000012303327302610902000301030100000001010000000000000000000000000000000000
   GVL: 3D080000020840DC80008082CC00104004404002004000300200000000000044
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VW38.rod
   VCID: 0842F55442B7B00A972-805C SFD [ ]
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 3185573406
   Subsystem 3 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Component: MFL            H03 0219
   Serial number: 17038315102512300204
   Subsystem 4 - Part No SW: 5H0 959 542 N    HW: 5H0 959 542 N
   Component: KLR_JSS_1Zone  089 0023
   Serial number: 3136188AA23327094603
8 Faults Found:
2175091 - Control unit for information electronics 1
          [Information_electronics_control_module_1_no_communication]
                    Fault Frequency: 23
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:16:34
1049253 - Ethernet Databus Branch 5
          U1230 00 [00101111] - No Communication
          [Ethernet_databus_no_communication_branch_5_/_port_6]
                    Mileage: 57448 km
                    Date: 2026.07.26
                    Time: 13:17:29
1049254 - Ethernet Databus Branch 6
          U1231 00 [00101110] - No Communication
          [Ethernet_databus_no_communication_branch_6_/_port_7]
2498675 - Ethernet Module for Information Electronics 1
          U1645 00 [00101000] - No Communication
          [Information_electronics_control_module_1_no_communication_vlan]
8397571 - LV Energy Management
          B1802 F1 [00101000] - Warning Triggered
          B184C 00 [00101111] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Mileage: 57448 km
                    Date: 2026.07.26
                    Time: 13:31:52
8466689 - VKMS
          B18B0 F0 [00100000] - Missing Adaptation
          [VKMS_new_download_container_required_due_to_vehicle_change]
8398594 - Control unit for battery monitoring
          U1050 00 [00101000] - No Communication
          [BDMs_FuSi_no_communication]
   Part No SW: 5WA 909 059 AB    HW: 3Q0 909 059 D
   Component: EBKV          H09 0372
   Serial number: 7XM369091123014 Dataset Number: V03935367RC 0001
   Coding: 5003C5009B00009C73CE39E7000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 1072DD343AE7F8CA4F2-8044 SFD [x]
107008 - No Communication with Transmission Control Module
          U0101 00 [00100000] - -
          [ComScl_Getriebe_11_Timeout]
107024 - Transmission Control Module
          U14E4 00 [00100000] - Received Malfunction Value
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
108400 - Immobilizer Control Module
          U0167 00 [00100000] - No Communications
          [NoVINDetected]
1024368 - Brake Booster
          C1187 F6 [00101000] - Function Limitation due to External Brake Pressure Build-Up
          [ActiveRestrictionDetected]
                    Reset counter: 24
                    Mileage: 57376 km
                    Date: 2026.07.21
                    Time: 21:00:14
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 23000268947007 Dataset Number: V03935336NF 0001
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323677BC94ABEADA196-8066
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0362
   Serial number: 23A1901KA05221 Dataset Number: V03935307MP 0001
   Coding: 01589A400000A0408803010101010000000000212100000000000000215000
   VCID: 59E4E010A99DF982F8C-800C
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 J    HW: 2Q0 907 686 J
   Component: HRE_Master    H27 0288
   Serial number: 00000634717557  Dataset Number: V03935373GS 0001
   Coding: 569945D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001016
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 J    HW: 2Q0 907 685 J
   Component: HRE_Slave      H27 0288
   Serial number: 00000634782206
   Lane change assistance display left:
   Subsystem 2 - Part No SW: 5H1 949 145     HW: 5H1 949 145
   Component: SWA LED VL     H05 0005
   Serial number: 00000000000016909060
   Lane change assistance display right:
   Subsystem 3 - Part No SW: 5H1 949 146     HW: 5H1 949 146
   Component: SWA LED VR     H05 0005
2232357 - Databus
          [databus message missing - MainUnit_01]
                    Fault Frequency: 13
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:31
2236437 - Databus
          [databus error value received - Parkhilfe_04 - APSOPS_PaCo_MainState]
                    Mileage: 57448 km
                    Date: 2026.07.26
                    Time: 13:17:23
2236439 - Databus
          [databus message missing - AMP_01]
                    Fault Frequency: 16
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:30
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS004 0350
   Serial number: YE007WKN2687A Dataset Number: V03935387Z  0001
   Coding: 003B13205200040008000000
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 4AC60F5C1C3B821A416-801E
   Subsystem 1 - Part No SW: 5Q0 959 408 G    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000076448276
   Coding: 111000
   Part No SW: 5WA 907 145 G    HW: 5WA 907 145 C
   Component: BASGEN1MQB37  502 1040
   Serial number: 03374073 Dataset Number: V03935358SR 0001
   Coding: 0000000000000001000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
Address 47: Sound System
   Part No SW: 5WA 907 338 B    HW: 5WA 907 338
   Component: FCM2020 Low   H14 1447
   Serial number: 250151223482764 Dataset Number: V03935346BX 0001
   Coding: 000000000900075206112310040003070300000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 004012
   ROD: EV_MultiModulContiVW38X.rod
   VCID: 4DCC0440ED559522644-8018 SFD [x]
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS004 0350
   Serial number: YE007WKH0224E Dataset Number: V03935386XH 0001
   Coding: 003B13205E00040000800000
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 49C43050193D890248C-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 G    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000076473873
   Coding: 091000
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H31 0344
   Serial number: FCLK20251023010 Dataset Number: V03935359FC 0001
   Coding: 02030004E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   VCID: 52F6173CF46BCADA396-8006
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 285 D    HW: 5WA 035 285 A
   Component: OCU3HMQB37W   H12 0021
   Serial number: 0000000305VIFWH Dataset Number: V03935379BN 0001
   Coding: 023800209068AC209025460070502E07
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 48C235540237700A572-801C SFD [x]
9455892 - Mute switch radio
          B1049 14 [00001001] - Open or Short to Ground
                    Mileage: 57448 km
                    Date: 2026.07.26
                    Time: 13:17:17
                    Voltage terminal 30: 11.7 V
1866 - Emergency Call and Communication Moduke
          U1785 00 [00001000] - Software Error
          [Control_unit_AP_recovery_mode]
                    Reset counter: 29
                    Mileage: 57210 km
                    Date: 2026.07.17
                    Time: 18:54:01
7248 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [InfotainmentSettings (0x50) - Funktionseinschr nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Reset counter: 19
                    Mileage: 56800 km
                    Date: 2026.07.11
                    Time: 02:50:40
                    Voltage terminal 30: 12.9 V
Address 82: Head Up Display (J898)       Labels:| 5H1-919-608.clb
   Part No SW: 5H1 919 608     HW: 5H1 919 608
   Component: HeadupDisplay H17 2045
   Dataset Number: V03935332ET 0001
   Coding: 5740A0
   ASAM Dataset: EV_HeadUpDisplMQB37W 001018
   ROD: EV_HeadUpDisplMQB37W.rod
   VCID: 6FB0BEC847198732368-803A
13894400 - Function limitation due to excessive temperature
          B1050 00 [00001001] - -
          [ECU_function_restriction_overtemperature]
                    Mileage: 57448 km
                    Date: 2026.07.26
                    Time: 13:08:31
16777040 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [NAV_0x32_communication_error_bap_error_timeout_heartbeat]
                    Fault Frequency: 16
                    Mileage: 57393 km
                    Date: 2026.07.22
                    Time: 19:35:24
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H12 3405
   Serial number: EB7590902233330 Dataset Number: V03935412E  0001
   Coding: 00000B88116CC040109F40001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   VCID: 50F21D34FA67B8CA0F2-8004
1122626 - Databus
          [Timeout_Mainunit_01]
                    Fault Frequency: 13
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:17:31
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Fault Frequency: 18
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:16:33
1122672 - Databus
          [Timeout_PSD_06]
                    Fault Frequency: 18
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:16:33
1122665 - Databus
          [Timeout_PSD_05]
                    Fault Frequency: 18
                    Mileage: 57448 km
                    Date: 2026.07.23
                    Time: 20:16:33
1126451 - Databus
          [ACC_18_ACC_Status_ACC_irreversibel_ERROR]
                    Reset counter: 23
                    Mileage: 56780 km
                    Date: 2026.07.11
                    Time: 00:26:18
   Part No SW: 5H0 907 159 A    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0002
   Serial number: 231115290065
   ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
   VCID: 2D0C64C08D95B522444-8078
   Part No SW: 4K1 907 594 CB    HW: 4K1 907 594
   Component: SAD_STG_1     006 0040
   Dataset Number: V03935402SS 0001
   Coding: 008000738001
   VCID: 77A086A83F49CFF2EE8-8022
   Part No SW: 992 941 571 AH    HW: 992 941 571 A
   Component: LED1L         H25 9204
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 6882D5D462F7500A772-803C
   Component: LED1R         H25 9204
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 8126: Trq distrib RearL axle (J492)       Labels: 08E-907-554.clb
   Part No SW: 08E 907 554 F    HW: 08E 525 130
   Component: 4Motion       H06 0123
   Serial number: 01DE8QQ
   Coding: 00010100
   ASAM Dataset: EV_TorquSplitLeftMAGNA 001005
   ROD: EV_TorquSplitLeftMAGNA.rod
   VCID: 313478B091ADD1C260C-8064
Address 8127: Trq distrib RearR axle (J492)       Labels: 08E-907-554.clb
   Serial number: 01DE74U
   Coding: 00010100
   ASAM Dataset: EV_TorquSplitRightMAGNA 001005
   ROD: EV_TorquSplitRightMAGNA_001.rod
End----(Elapsed Time: 01:51, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
------------------------------42 Faults Found------------------------------
r420
Poland
C?ID=561009
Please post SFDLog.CSV from your Debug sub-folder.
,,,Start SFD Session,Sunday,26,July,2026,13    19    13,HN2-025334,SFD session start successful
WVWEB7CD7RW1xxxxx,Address 0x09,5WA 937 086 BT,Online SFD,Sunday,26,July,2026,13    19    58,HN2-025334,SFD challenge retrieval fail, error CR-5
WVWEB7CD7RW1xxxxx,Address 0x09,5WA 937 086 BT,Online SFD,Sunday,26,July,2026,13    24    49,HN2-025334,SFD challenge retrieval fail, error CR-5
,,,Start SFD Session,Sunday,26,July,2026,13    30    53,HN2-025334,SFD session start successful
WVWEB7CD7RW1xxxxx,Address 0x19,5WA 907 530 AB,Online SFD,Sunday,26,July,2026,13    31    55,HN2-025334,SFD challenge retrieval success, 583 bytes
WVWEB7CD7RW1xxxxx,Address 0x19,5WA 907 530 AB,Online SFD,Sunday,26,July,2026,13    31    57,HN2-025334,SFD unlock token retrieval success, 852 bytes
WVWEB7CD7RW1xxxxx,Address 0x19,5WA 907 530 AB,Online SFD,Sunday,26,July,2026,13    31    57,HN2-025334,SFD unlock token transmitted to controller
WVWEB7CD7RW1xxxxx,Address 0x19,5WA 907 530 AB,Online SFD,Sunday,26,July,2026,13    32    00,HN2-025334,Unlock_successful
WVWEB7CD7RW1xxxxx,Address 0x09,5WA 937 086 BT,Online SFD,Sunday,26,July,2026,13    33    00,HN2-025334,SFD challenge retrieval fail, error CR-5
,,,Start SFD Session,Sunday,26,July,2026,17    5    54,HN2-025334,SFD session start successful
WVWEB7CD7RW1xxxxx,Address 0x5F,5H0 035 877 C,Online SFD,Sunday,26,July,2026,17    6    50,HN2-025334,SFD challenge retrieval success, 583 bytes
WVWEB7CD7RW1xxxxx,Address 0x5F,5H0 035 877 C,Online SFD,Sunday,26,July,2026,17    6    52,HN2-025334,SFD unlock token retrieval fail, error TR-19 (-18632)
Eric
HC800000
That looks like someone didn't turn off the filter in 0x19 before trying to unlock 0x09.
r420
Poland
C?ID=561009
1. Unlock SFD in 19 Gateway
2. try unlock SFD in 09 and not work
Today try Tiguan 2024y unlock 01 without unlock 19 and ok
Andy
Sector 7G
HC424490
It looks like you skipped step 2.5
After unlocking SFD, go into 19 CAN Gateway then Adaptation and click Turn Off Filter
r420
Poland
C?ID=561009
Yes, Valuable point, I didn't do that.
