2004 Touareg V8, Fan at full power with ignition on and no A/C
ferumac
Tijuana, Mexico
C?ID=564171
I have a problem on my Touareg 2004 V8... the fans stay ON all the time, A/C not working once the fans problem appeard, Evap problems, etc... My first scann had 32 Faults, I clear all DTC and after that only 11 faults came back, the 32 faults appear if I scann it 24 hours later, can you give me some advice where to start?.... Also a Convertible Top Module is on my DTC.
Thursday,23,July,2026,20:26:33:39651
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4713.4
VIN: WVGEM77L64D062094 License Plate:
Mileage: 207720km-129071mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGEM77L64D062094 Mileage: 207720km-129071miles
Address 01: Engine Labels: 077-907-560-AXQ.lbl
Part No SW: 4D0 907 560 DA HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Coding: 0007875
Shop #: WSC 31414 000 00000
VCID: 6889A8D25E6A757A673-5160
VINID: 9E65D57471DC18450018200910DF859742
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground - MIL ON
17880 - EVAP Leak Detection Pump
P1472 - 002 - Short to Ground - MIL ON
17876 - EVAP Canister Solenoid Valve 2 (N115)
P1468 - 002 - Short to Ground - MIL ON
16580 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0014593
Shop #: WSC 07437 444 53720
VCID: 3A2D229A704637EAC17-5160
00814 - Solenoid for Brake Pressure (N247)
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 C HW: 7L0 909 137 C
Component: G2 Kessy 6850
Revision: 00H24072 Serial number: VWZ3Z0D7160221
Coding: 0147688
Shop #: WSC 49143 000 1048576
VCID: 33330FBE572CC6A2021-5160
Component: ELV XXXX
00830 - Convertible Top Control Module (J256)
Fault Frequency: 14
Reset counter: 135
Time: 20:11:14
Address 08: Auto HVAC Labels: 7L6-907-044.clb
Part No: 7L6 907 044 AK
Component: CLIMAtronic 2+2 4534
Coding: 0020020
Shop #: WSC 22104 444 72711
VCID: 7DA7E98621E8C0D2A45-5160
Subsystem 1 - Part No: 7L6 907 049 C
Component: CLIMAtronic FOND X 0306
00898 - Control Circuit A/C compressor
014 - Defective
02599 - Rear Left Temperature Flap Motor (V313)
00064 - Left B-pillar/Footwell Shut-Off Flap Motor (V212)
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2703
Coding: 0105692
Shop #: WSC 11111 111 45799
VCID: 44D15C620282711AABB-5160
00968 - Right Turn Signals
01498 - Bulb for Parking Lamps; Right (M3)
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 980 MX
Component: KOMBIINSTRUMENT RB0 2935
Coding: 0007231
VCID: 1A6DC21AD08617EA217-5160
010 - Open or Short to Plus
02613 - Stabilizer Control Module (J736)
01304 - Radio
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9C0B266BABDBA3F3-5160
8 Faults Found:
00459 - Control Module for Display and Input; Front (J523)
01304 - Radio
00467 - TV Tuner (R78)
01302 - Control Module for Telematic (J499)
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 B
Component: SG-Quersperre 5018
VCID: 372B3BAE43542A823E9-5160
02062 - Differential Lock
003 - Mechanical Failure
Address 46: Central Conv. Labels: 7L0-959-933.clb
Part No: 7L0 959 933 E
Component: 2M HSG 0201
Coding: 0000085
VCID: 3E252E8A6C6E1BCAFDF-4B1E
Subsystem 1 - Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0201
00487 - Rear Left Outside Door Handle Central Locking Button (E371)
Address 56: Radio Labels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 A
Component: Radio 0635
Coding: 0005055
Shop #: WSC 22110 444 58773
VCID: 313F05B6AD30F4B270D-5160
00856 - Radio Antenna
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
01024 - Rain Sensor (G213)
014 - Defective
End----------(Elapsed Time: 07:25, VBatt start/end: 13.6V/13.4V)-----------
------------------------------32 Faults Found------------------------------
Now the Second Scann with 11 fault codes....
Thursday,23,July,2026,20:38:01:39651
   Coding: 0007875
   Coding: 0147688
                    Fault Frequency: 0
                    Reset counter: 136
                    Time: 20:29:12
   Coding: 0020020
            014 - Defective
   Component:                     2703
   Coding: 0105692
   Coding: 0007231
   Coding: 0000006
End----------(Elapsed Time: 08:15, VBatt start/end: 13.5V/13.4V)-----------
------------------------------11 Faults Found------------------------------
Vdub
C?ID=57533
the convertible top module is probaly a wrong coding.
The scans are weird, there is no installations list on top of the scan, did you edit the scans before posting?
I often code out the air quality sensor, as its an expensive sensor and often broken.
The G65 sensor is certainly a fault code i would look at, it will stop the working of the ac. Replace it ONLY with a good brand sensor, OEM or Hella or so!
ferumac
Tijuana, Mexico
C?ID=564171
Vdub thank you for your response... Yes I edit the scann, I removed the ones that had no faults because it was to long... sorry about that.
Ok I will start with the G65 sensor and see if the AC comes back, could that be the reason for the fans allways on?...
Thanks.
Vdub
C?ID=57533
Yes that is possible.
Don't edit the scans next time, just past them in the codeblock like you did.
ferumac
Tijuana, Mexico
C?ID=564171
OK Vdub sorry about the edit and thank you for the advice... So Yesterday I went to VW and bought the G65 sensor and the N80 valve and install them... the DTC´s are the same...
Saturday,25,July,2026,21:51:54:39651
   Coding: 0007875
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No: 09D 927 750 BG
   Component: AL 600 6Q           0459
   Coding: 0004153
   VCID: 74B1CCA212A2819ADBB-513C
   Coding: 0014593
   Coding: 0147688
                    Fault Frequency: 0
                    Reset counter: 148
                    Time: 21:43:32
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77ABFBAE03D4EA82FE9-5160
   Coding: 0020020
            014 - Defective
   Component:                     2703
   Coding: 0105692
   Part No: 3D0 909 601 C
   Component: 05 Airbag 8.4E++H01 0352
   Revision: BB36963     Serial number: 00009080
   Coding: 0012341
   VCID: 2313FFFEE7CC5622F21-5160
   Subsystem 1 - Part No: 7L0 959 339 B
   Component: BF-Gewichtsens. 005 0006
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenks ulenmodul     3301
   Coding: 0000032
   VCID: 40D95072169A6D3A8F3-5160
   Coding: 0007231
   Coding: 0000006
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879
   Component: JCI PathPoint       1700
   VCID: 04519C624202B11AEBB-5160
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5B138E2BE4D2C2B69-5160
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  X012
   Coding: 0000003
   VCID: 6695A6EA547E630A55F-5160
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   Shop #: WSC 00046 000 00000
   VCID: 363536AA445ED38A25F-5160
Address 37: Navigation        Labels: 7L6-919-887-CD.lbl
   Part No: 7L6 919 887 D
   Component:      Navigation     0635
   Coding: 0000101
   Shop #: WSC 22110 444 64743
   VCID: 47CB4B6E33B45A024E9-5160
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  X012
   Coding: 0000003
   VCID: 678BABEE53747A026E9-5160
   Coding: 0000085
   Part No: 7L6 035 466
   Component: 12K-AUDIOVERST      0108
   VCID: 71BFC5B66DB0B4B230D-5160
   Coding: 0005055
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No: 7L6 907 273
   Component: Reifendruckueberw.  0052
   Coding: 0210390
   VCID: 75B7F1A619D89892EC5-5160
   Coding: 0000004
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 E    HW: 7L0 907 383 E
   Component: ANHAENGERELEKTRONIK 8254
   Coding: 0000002
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 F
   Component: DACHDISPLAY         0530
   Revision: 00600530    Serial number: 2009289.02
Address 76: Park Assist        Labels: None
   Part No: 7L0 919 283 E
   Component: 0E Einparkhilfe     0907
   VCID: 382938924E4A25FA373-5160
End----------(Elapsed Time: 08:10, VBatt start/end: 12.7V/13.6V)-----------
------------------------------10 Faults Found------------------------------
Vdub
C?ID=57533
Past them INto the codeblock with the button </>
Did you do a erase all faultcodes? or at least erase them in 01 Engine and the 08 HVAC after you installed those 2 sensors?
TTT
C?ID=547002
Stop buying parts. Do you have the wiring diagrams for this vehicle?
  • Agree
Vdub
C?ID=57533
did you check the old hvac sensor/connector on corrosion?
Which colors do the wires have?
P1 Brown
P2 Yellow/Blue
P3 Red/Green
ferumac
Tijuana, Mexico
C?ID=564171
Hello Vdub, so after I installed the parts and clear all DTC´s the errors where still present, so I searched every wire in the engine related to those two sensors and found that the Oil Level Sensor was burnt so I change It and also the connector because it was melted in to the sensor...
After that the codes of Evap went away and no more DTC for engine are showing... I dont have my laptop right now but VCDS scann shows only 5 DTC´s... and my fan assembly works normal again!!!!....
I will update tomorrow....
Hello TTT, no I do not have them, I went online and searched the sensors related to engine oil and EVAP... that is how I found the Oil Level Sensor... the one that I didnt find was the Oil Pressure Switch...
Thank you both for your help and I will up load the scann tomorrow.
ferumac
Tijuana, Mexico
C?ID=564171
Hello Bruce, erWin does not permit private individuals to register... I will search for the wiring diagrams and download them this weekend... Thanks!
Vdub
C?ID=57533
I have what you need on diagrams, just ask for which sensors
ferumac
Tijuana, Mexico
C?ID=564171
Thank´s Vdub, I will get to work on the Touareg Sunday and I will let you know...
TTT
C?ID=547002
Well @Vdub, you're stuck at work Sunday, Mexico time. :)
Ziddywerks
Northern NJ USA
C?ID=208579
I would bet good money that faults in engine are related to a common fuse,vcc or ground.
Vdub
C?ID=57533
i dont think that would be a problem, iam in almost the same timezone as Mexico..
ferumac
Tijuana, Mexico
C?ID=564171
Hi sorry about the delay... I had to work sunday and got out late... this is my first scann
Sunday,02,August,2026,22:52:30:39651
Mileage: 207840km-129145mi   Repair Order:
VIN: WVGEM77L64D062094   Mileage: 207840km-129145miles
   Coding: 0007875
17831 - Secondary Air Injection System; Bank 1
            P1423 - 002 - Insufficient Flow
17546 - Fuel Trim: Bank 2 (Add)
            P1138 - 001 - System too Lean - MIL ON
17887 - Brake Boost Vacuum System
            P1479 - 008 - Mechanical Failure - Intermittent
Readiness: 0000 1101
   Coding: 0004153
   VCID: 74B1CCA212A2819ADBB-5160
   Coding: 0014593
   Coding: 0147688
                    Fault Frequency: 14
                    Reset counter: 168
                    Time: 14:55:18
   Coding: 0020020
            014 - Defective
   Component:                     2703
   Coding: 0105692
01494 - Bulb for Parking Lamps; Left (M1)
   Coding: 0012341
   Coding: 0000032
   Coding: 0007231
01304 - Radio
   Coding: 0000006
8 Faults Found:
01304 - Radio
   Coding: 0000003
   VCID: 6695A6EA547E630A55F-513C
   Coding: 0015521
   Coding: 0000101
   Coding: 0000003
   Coding: 0000085
   Coding: 0005055
   Coding: 0210390
            004 - No Signal/Communication - Intermittent - MIL ON
   Coding: 0000004
            014 - Defective
   Coding: 0000002
01626 - Sensor for Parking-Aid; Front Right (G252)
End----------(Elapsed Time: 07:54, VBatt start/end: 14.0V/13.9V)-----------
------------------------------29 Faults Found------------------------------
ferumac
Tijuana, Mexico
C?ID=564171
This is after I cleared all DTC
Sunday,02,August,2026,23:11:36:39651
   Coding: 0007875
   Coding: 0004153
   Coding: 0014593
   Coding: 0147688
                    Fault Frequency: 0
                    Reset counter: 169
                    Time: 23:02:34
   Coding: 0020020
            014 - Defective
   Component:                     2703
   Coding: 0105692
   Coding: 0012341
   Coding: 0000032
   Coding: 0007231
   Coding: 0000006
   Coding: 0000003
   Coding: 0015521
   Coding: 0000101
   Coding: 0000003
   Coding: 0000085
   Coding: 0005055
   Coding: 0210390
   Coding: 0000004
   Coding: 0000002
End----------(Elapsed Time: 08:37, VBatt start/end: 13.8V/13.9V)-----------
------------------------------5 Faults Found-------------------------------
ferumac
Tijuana, Mexico
C?ID=564171
ferumac
Tijuana, Mexico
C?ID=564171
Forgot to tell you that when this short appeared the message of low oil pressure showed up in my dashboard... know it does not appear but still the pressure gauge will not work.
The thing is that I can not find the oil pressure switch to check the wires or change the sensor...
Any idea of where is located and how to get to it to replace it?...
Thank you for all your advice.
