Maps Brazil 2026 VW Nivus Gts 1.4 CWLA
Maps
Elder Moreira dos Santos
Brasil
C?ID=304355
AutoScan: 9BWCJ6CH7TP054606
Monday,20,July,2026,08:47:40:18837
VCDS Version: 26.6.0.1 (x64)  HEX-NET CB: 0.4713.4
Data version: 20260708 DS377.1
VIN: 9BWCJ6CH7TP054606   License Plate: NIVUS GTS 26
Mileage: 348km-216mi   Repair Order:
Chassis Type: CH-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 44 5F 75 A5 A9 C002 C003
VIN: 9BWCJ6CH7TP054606   Mileage: 348km-216miles
Address 01: Engine (J623-CWLA)       Labels: None
   Part No SW: 04E 906 025 FE    HW: 04E 907 309 GL
   Component: R4 1.4l TFS   H80 5036
   Revision: 64H80000    CVN: BDAE321E
   Coding: 011A003223441D001000
   Shop #: WSC 01530 935 00200
   ASAM Dataset: EV_ECM14TFS01104E906025FE 001004
   ROD: EV_ECM14TFS01104E906025FE.rod
   VCID: 6A9824C78D367CCE3C-803E-R
   VINID: 2529D36864D81E4800144180187221285F
Readiness: 0000 0100
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09S 927 158 JJ    HW: 09S 927 158
   Component: AISIN AG6 G4  211 4173
   CVN: BBB93070
   Coding: 0100000100000000010000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 003022
   ROD: EV_TCMAQ250031_003_VW27.rod
   VCID: 106C562FCB2AE61E12-8044-R
Address 03: ABS Brakes (J104)       Labels:. 2Q0-614-517.clb
   Part No SW: 2Q0 614 517 BD    HW: 2Q0 614 517 L
   Component: ESC_base      H13 0280
   Serial number: 86400993251210
   Coding: 13054C553F46C8B13202FC1668E0716649E6D106AA6A46244854225445168E6692678B6055566224122A442AA229D64F7F946BF2FEE854A8172A15
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0_005_VW27.rod
   VCID: 71AA33ABA0E08F167D-8024-R
1272 - Tire Pressure Warning
          C102D 00 {00001000} - -
                    Reset counter: 55
                    Mileage: 278 km
                    Date: 2026.07.18
                    Time: 20:27:18
   Part No SW: 3Q1 959 435 F    HW: 3Q1 959 435 F
   Component: VWKESSYMQB    037 1502
   Revision: 00037000    Serial number: 0672950719 Dataset Number: V03935468ZX 0001
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004057
   ROD: EV_KessyHellaMQBAB_VW27.rod
   VCID: 3E30D897A13E206EB0-806A-R
Address 08: Auto HVAC (J255)       Labels:| 2GN-907-044-V1.clb
   Part No SW: 6EA 907 057 A    HW: 6EA 907 057 A
   Component: Climatronic   H35 0214
   Coding: 0120000018000000010008005240010D0011000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0Touch 001008
   ROD: EV_ACClimaBHBMQBA0Touch.rod
   VCID: 393ACB8BB810075685-806C-R
          B10CD 00 {00001000} - -
                    Reset counter: 47
                    Mileage: 15 km
                    Date: 2026.07.16
                    Time: 15:33:31
                    Voltage terminal 30: 11.7 V
                    CAN input signal(s) status-Front windshield wiper: OFF
                    CAN input signal(s) status-Energy management: shut-off stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamps: OFF
                    Blower reduction: No switch-off: no reduction
Address 09: Cent. Elect. (J519)       Labels: 2QX-937-BCM-V2.clb
   Part No SW: 2Q0 937 090 G    HW: 2Q0 937 090 G
   Component: BCM A0 Std+   H16 0995
   Serial number: 40025283064502 Dataset Number: V03935469LL 0001
   ASAM Dataset: EV_BCMA0 210001
   ROD: EV_BCMA0_209_VW27.rod
   VCID: 3620C0B7890EE82E68-8062-R SFD+SFD2 {x}
   Coding: 0018DD
   Driver door control module:
   Front passenger door control module:
   Part No SW: 5QA 919 298 M    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H12 0083
   Serial number: 000C58853125246 Dataset Number: V03935457FF 0001
   Coding: 0271167851
   ASAM Dataset: EV_EPHVA2CAU3700000 010060
   ROD: EV_EPHVA2CAU3700000_010_VW37.rod
   VCID: 5AF874075D56EC4EAC-800E-R
   Part No SW: 2Q0 907 567 C    HW: 2Q0 907 819
   Component: ACCCONTIMQB   H04 0541
   Dataset Number: V03935444UB 0001
   Coding: 300260C308FF8448949C810560308700000000000000008024
   ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
   ROD: EV_ACCMRRCONTIUNECEMQB_VW27.rod
   VCID: 383CCE8F831A1E5E7A-806C-R SFD+SFD2 {x}
2068 - Databus
          U1123 00 {00001000} - Received Error Message
          {FAULT_TSK_IRREV_FAIL}
                    Reset counter: 47
                    Mileage: 14 km
                    Date: 2026.07.16
                    Time: 15:09:24
                    Voltage terminal 15: 13.9 V
                    Control Module temperature: 54 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2QB 959 655 E    HW: 2QB 959 655 E
   Component: VW22Airbag    016 0511
   Revision: --------    Dataset Number: V03935453EU 0001
   Coding: 88CCC000000000007C5400CF000800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 51EA932B00A0AF165D-8004-R
   Subsystem 1 - Part No SW: -----------    HW: 442 130 000 00
   Component: SideSensor_Df  2DB 0887
   Serial number: 357BR00BF1B13AD0C0EF
   Subsystem 2 - Part No SW: -----------    HW: 442 130 000 00
   Component: SideSensor_Pf  2DB 0887
   Serial number: 358BR00BF1B13AD163BB
   Subsystem 3 - Part No SW: -----------    HW: 442 1A1 010 25
   Component: SideSensor_Dr  2C4 0148
   Serial number: 351B45C329FF19A8055.
   Subsystem 4 - Part No SW: -----------    HW: 442 1A1 010 25
   Component: SideSensor_Pr  2C4 0148
   Serial number: 352B45C309FF19AA57EB
   Subsystem 5 - Part No SW: -----------    HW: 442 131 809 25
   Component: FrontSensor_D  290 118A
   Serial number: 355AGA3DE40AA4780968
   Part No SW: 2G0 920 320 G    HW: 2G0 920 320 G
   Component: KOMBI         813 9129
   Dataset Number: V03935444ZD 0001
   Coding: 042420086588000C0288224B5001000000001524
   ASAM Dataset: EV_DashBoardVDDMQBA0 003063
   ROD: EV_DashBoardVDDMQBA0_003_VW27.rod
   VCID: 200C06EF3B8A769EA2-8074-R SFD+SFD2 {x}
   Part No SW: 3Q0 907 530 BF    HW: 3Q0 907 530 BB
   Component: GW 2023 CLA   550 5585
   Revision: --------    Serial number: 423702500252940 Dataset Number: V03935470CE 0001
   Coding: 0000808D0F00000000000000000000000000000000000300030000000001000000000000000000000000000000000000
   GVL: 3D100000040040C080000000C800000000000000000000000000000000000044
   ASAM Dataset: EV_GatewMQB2020Class 001001
   ROD: EV_GatewMQB2020Class_VW27.rod
   VCID: 74A43ABFDFF2BA3E96-8020 SFD+SFD2 {x}
   Generator:
   Subsystem 2 - Part No SW: 2QB 915 181     HW: 2QB 915 181
   Component: J367-BDMHella  H11 9071
   Serial number: 9651272201
   Subsystem 3 - Part No SW: 3G0 959 442 AE    HW: 3G0 959 442 AE
   Component: E221__MFL-YLG  H07 0120
   Serial number: YLG-0700084218251234
   Subsystem 4 - Part No SW: 2GP 959 542     HW: 2GP 959 542
   Component: KLR_JSS_1Zone  089 0023
   Serial number: 3136188AA25168232504
8417280 - Diagnostic Filter
          U17A0 00 {00101000} - Not Activated
          {Filter_is_not_active}
                    Reset counter: 31
                    Mileage: 14 km
                    Date: 2026.07.16
                    Time: 15:08:59
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 H    HW: 2Q0 907 686 H
   Component: HRE_Master    H26 0320
   Serial number: 14520086472959  Dataset Number: V03935428YC 0001
   Coding: 56954640
   ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
   ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
   VCID: 3FCEA593A6342966BB-806A-R
   Subsystem 1 - Part No SW: 2Q0 907 685 H    HW: 2Q0 907 685 H
   Component: HRE_Slave      H26 0320
   Serial number: 14520089370224
Address 44: Steering Assist (J500)       Labels:. 2Qx-909-144-V3.clb
   Part No SW: 2QD 909 144 F    HW: 2QD 909 144 A
   Component: EPS_ECU       420 4220
   Serial number: 000006.08.25000 Dataset Number: V03935464BD 0001
   Coding: 00000101010000010101020101000101000001010101
   ASAM Dataset: EV_SteerAssisNSKGEN3MQB 003008
   ROD: EV_SteerAssisNSKGEN3MQB_003_VW27.rod
   VCID: 48DCBE4FF3FA6EDE0A-801C-R
   Part No SW: 2GM 035 180 L    HW: 2GM 035 180 L
   Component: MU-R--R2      H03 0871
   Serial number: VWZ7Z2DD202539  Dataset Number: V03935468VS 0001
   Coding: 22703500000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUREGIO 001010
   ROD: EV_MUREGIO.rod
   VCID: 43C6A963CADC4D86DF-8016-R
   Part No SW: 2G5 035 282     HW: 2GA 035 286
   Component: OCUClas2023_H H11 0612
   Serial number: 0000000510VISM3 Dataset Number: V03935446TB 0001
   Coding: 02080500000100210000000011000607001110011012011110
   ASAM Dataset: EV_OCUClass2023 001063
   ROD: EV_OCUClass2023.rod
   VCID: 62884CE77506248EF4-8036-R SFD+SFD2 {x}
   Part No SW: 2Q0 980 653 H    HW: 2Q0 980 653 A
   Component: MQB MFK 3.0   H19 1602
   Serial number: EF1689304252530 Dataset Number: V03935452BZ 0001
   Coding: 00000190006EC020089E08000020000000418000600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007058
   VCID: 3A38D487BD160C4E8C-806E-R
1126518 - Databus
          {ACC_06_ACC_Status_ACC_irreversibel_ERROR}
                    Reset counter: 31
                    Mileage: 14 km
                    Date: 2026.07.16
                    Time: 15:08:59
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 2G0 907 159 E    HW: 4ML 907 159 D
   Component: SAS-GEN 2.9   H10 0001
   Serial number: 250724202323H01
   ASAM Dataset: EV_SoundActuaGen2AU64X 005018
   ROD: EV_SoundActuaGen2AU64X_005_VW27.rod
   VCID: 2D12EFDB7C58ABF619-8078-R
End----------(Elapsed Time: 01:10, VBatt start/end: 12.2V/12.2V)-----------
------------------------------5 Faults Found-------------------------------
elder_2000@hotmail.com
adpmap-01-04E-906-025-FE_9BWCJ6CH7TP054606-20260720-0849.CSV
;SW:04E-906-025-FE   HW:04E-907-309-GL ---  01: Engine
;Component:R4 1.4l TFS   H80 5036, Coding:011A003223441D001000
;EV_ECM14TFS01104E906025FE,001004,EV_ECM14TFS01104E906025FE.rod
;Monday,20,July,2026,08:49:46:18837
;VCDS Version: 26.6.0.1 (x64)  Data version: 20260708 DS377.1
;VCID: 6A9824C78D367CCE3C-803E-R
IDE02248-Individually adjustable top speed limit,300.0 km/h,2
IDE04158-Activation of start/stop function,active ,1
IDE08456-Setting of fuel portion ethanol/gasoline,Unknown (0),1
IDE10893-Inlet camshaft Bank 1: setting the sensor tolerance,FF E8 FF 3C FF EB FF 5E FF F8 FF 58 FF FE FF 7D 00 00 00 8B ,21
IDE10896-Outlet camshaft Bank 1: setting the sensor tolerance,FF 9B FF 3C FF 87 FF 56 FF A4 FF 42 FF AE FF 3B 00 00 00 4D ,21
Elapsed Time: 00:02
adpmap-02-09S-927-158-JJ_9BWCJ6CH7TP054606-20260720-0849.CSV
;SW:09S-927-158-JJ   HW:09S-927-158 ---  02: Auto Trans
;Component:AISIN AG6 G4  211 4173, Coding:0100000100000000010000000000000000000000
;EV_TCMAQ250031,003022,EV_TCMAQ250031_003_VW27.rod
;Monday,20,July,2026,08:49:52:18837
;VCID: 106C562FCB2AE61E12-8044-R
IDE03012-Erase counter for start/stop procedures,not activated ,1
Elapsed Time: 00:01
adpmap-03-2Q0-614-517-BD_9BWCJ6CH7TP054606-20260720-0849.CSV
;SW:2Q0-614-517-BD   HW:2Q0-614-517-L ---  03: ABS Brakes
;Component:ESC_base      H13 0280, Coding:13054C553F46C8B13202FC1668E0716649E6D106AA6A46244854225445168E6692678B6055566224122A442AA229D64F7F946BF2FEE854A8172A15
;EV_Brake1BOSCHESPMQBA0,005001,EV_Brake1BOSCHESPMQBA0_005_VW27.rod
;Monday,20,July,2026,08:49:58:18837
;VCID: 71AA33ABA0E08F167D-8024-R
IDE00820-ENG155021-Activating and deactivating all development messages-DEV_ESP_Resp_00,not activated ,1
IDE00820-ENG155022-Activating and deactivating all development messages-DEV_ESP_Resp_01,not activated ,1
IDE00820-ENG155023-Activating and deactivating all development messages-DEV_ESP_Resp_02,not activated ,1
IDE00820-ENG155024-Activating and deactivating all development messages-DEV_ESP_Resp_03,not activated ,1
IDE00820-ENG155025-Activating and deactivating all development messages-DEV_ESP_Resp_04,not activated ,1
IDE00820-ENG155026-Activating and deactivating all development messages-DEV_ESP_Resp_05,not activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04643-Overboost in brake system,activated ,1
IDE04939-Tire Pressure Monitoring System (TPMS),Default ,1
IDE04949-Engine drag torque control,activated ,1
IDE04952-Braking torque boost for distance regulation,100 %,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05286-Expanded electronic differential lock,Medium ,1
IDE05337-Starting vibration reduction,Strong ,1
IDE07292-Brake pre-filling,ended ,1
IDE11623-Emergency brake information,activated ,1
IDE14084-Pump test run,present ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS08145-MAS13354-Hill-start assistant: increase threshold-Gradient threshold engine running,3 %,2
MAS08145-MAS13355-Hill-start assistant: increase threshold-Gradient threshold start-stop - engine-stop,0 %,2
ENG153789-ENG154895-content_of_developement_message_1-address_of_byte_0,00 00 00 00 ,40
ENG153789-ENG154896-content_of_developement_message_1-address_of_byte_1,00 00 00 00 ,40
ENG153789-ENG154897-content_of_developement_message_1-address_of_byte_2,00 00 00 00 ,40
ENG153789-ENG154898-content_of_developement_message_1-address_of_byte_3,00 00 00 00 ,40
ENG153789-ENG154899-content_of_developement_message_1-address_of_byte_4,00 00 00 00 ,40
ENG153789-ENG154900-content_of_developement_message_1-address_of_byte_5,00 00 00 00 ,40
ENG153789-ENG154901-content_of_developement_message_1-address_of_byte_6,00 00 00 00 ,40
ENG153789-ENG154902-content_of_developement_message_1-address_of_byte_7,00 00 00 00 ,40
ENG153789-ENG155896-content_of_developement_message_1-Signal_length_byte_0,00 ,40
ENG153789-ENG155897-content_of_developement_message_1-Signal_length_byte_1,00 ,40
ENG153789-ENG155898-content_of_developement_message_1-Signal_length_byte_2,00 ,40
ENG153789-ENG155899-content_of_developement_message_1-Signal_length_byte_3,00 ,40
ENG153789-ENG155900-content_of_developement_message_1-Signal_length_byte_4,00 ,40
ENG153789-ENG155901-content_of_developement_message_1-Signal_length_byte_5,00 ,40
ENG153789-ENG155902-content_of_developement_message_1-Signal_length_byte_6,00 ,40
ENG153789-ENG155903-content_of_developement_message_1-Signal_length_byte_7,00 ,40
ENG153790-ENG154895-content_of_developement_message_2-address_of_byte_0,00 00 00 00 ,40
ENG153790-ENG154896-content_of_developement_message_2-address_of_byte_1,00 00 00 00 ,40
ENG153790-ENG154897-content_of_developement_message_2-address_of_byte_2,00 00 00 00 ,40
ENG153790-ENG154898-content_of_developement_message_2-address_of_byte_3,00 00 00 00 ,40
ENG153790-ENG154899-content_of_developement_message_2-address_of_byte_4,00 00 00 00 ,40
ENG153790-ENG154900-content_of_developement_message_2-address_of_byte_5,00 00 00 00 ,40
ENG153790-ENG154901-content_of_developement_message_2-address_of_byte_6,00 00 00 00 ,40
ENG153790-ENG154902-content_of_developement_message_2-address_of_byte_7,00 00 00 00 ,40
ENG153790-ENG155896-content_of_developement_message_2-Signal_length_byte_0,00 ,40
ENG153790-ENG155897-content_of_developement_message_2-Signal_length_byte_1,00 ,40
ENG153790-ENG155898-content_of_developement_message_2-Signal_length_byte_2,00 ,40
ENG153790-ENG155899-content_of_developement_message_2-Signal_length_byte_3,00 ,40
ENG153790-ENG155900-content_of_developement_message_2-Signal_length_byte_4,00 ,40
ENG153790-ENG155901-content_of_developement_message_2-Signal_length_byte_5,00 ,40
ENG153790-ENG155902-content_of_developement_message_2-Signal_length_byte_6,00 ,40
ENG153790-ENG155903-content_of_developement_message_2-Signal_length_byte_7,00 ,40
ENG153791-ENG154895-content_of_developement_message_3-address_of_byte_0,00 00 00 00 ,40
ENG153791-ENG154896-content_of_developement_message_3-address_of_byte_1,00 00 00 00 ,40
ENG153791-ENG154897-content_of_developement_message_3-address_of_byte_2,00 00 00 00 ,40
ENG153791-ENG154898-content_of_developement_message_3-address_of_byte_3,00 00 00 00 ,40
ENG153791-ENG154899-content_of_developement_message_3-address_of_byte_4,00 00 00 00 ,40
ENG153791-ENG154900-content_of_developement_message_3-address_of_byte_5,00 00 00 00 ,40
ENG153791-ENG154901-content_of_developement_message_3-address_of_byte_6,00 00 00 00 ,40
ENG153791-ENG154902-content_of_developement_message_3-address_of_byte_7,00 00 00 00 ,40
ENG153791-ENG155896-content_of_developement_message_3-Signal_length_byte_0,00 ,40
ENG153791-ENG155897-content_of_developement_message_3-Signal_length_byte_1,00 ,40
ENG153791-ENG155898-content_of_developement_message_3-Signal_length_byte_2,00 ,40
ENG153791-ENG155899-content_of_developement_message_3-Signal_length_byte_3,00 ,40
ENG153791-ENG155900-content_of_developement_message_3-Signal_length_byte_4,00 ,40
ENG153791-ENG155901-content_of_developement_message_3-Signal_length_byte_5,00 ,40
ENG153791-ENG155902-content_of_developement_message_3-Signal_length_byte_6,00 ,40
ENG153791-ENG155903-content_of_developement_message_3-Signal_length_byte_7,00 ,40
ENG118148-Developer_Function_1,00 00 ,2
ENG122614-Developer_Function_102,activated ,1
ENG122615-Developer_Function_103,activated ,1
ENG122619-Developer_Function_109,not activated ,1
ENG125053-Developer_Function_120,Default ,1
ENG118200-Developer_Function_3,not activated ,1
ENG118201-Developer_Function_4,05 ,1
Elapsed Time: 00:09
adpmap-05-3Q1-959-435-F_9BWCJ6CH7TP054606-20260720-0850.CSV
;SW:3Q1-959-435-F   HW:3Q1-959-435-F ---  05: Acc/Start Auth.
;Component:VWKESSYMQB    037 1502, Coding:132C0C0723
;EV_KessyHellaMQBAB,004057,EV_KessyHellaMQBAB_VW27.rod
;Monday,20,July,2026,08:50:11:18837
;VCID: 3E30D897A13E206EB0-806A-R
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,FE ,1
ENG422501-ENG422667-Block_reason_evaluation_clamp_50-Evaluate_Timeout_DTC,00000001  ,1
ENG422501-ENG422668-Block_reason_evaluation_clamp_50-Evaluate_Update_Fail_DTC,00000000  ,1
ENG422501-ENG422669-Block_reason_evaluation_clamp_50-Evaluate_ZR_ORU_Status,00000001  ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG297724-Byte13_vit_lf-toggleVariante,China ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,not activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG422502-ENG422665-Clamp_state_display_reason_evaluation-Evaluate_Clamp_15_State,00000001  ,1
ENG422502-ENG422666-Clamp_state_display_reason_evaluation-Evaluate_Clamp_50_State,00000001  ,1
ENG422502-ENG422667-Clamp_state_display_reason_evaluation-Evaluate_Timeout_DTC,00000001  ,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,not activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,Left hand steering ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %,9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,70 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms,9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,0E ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,05 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,70 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,65 mV/m,5
ENG248425-EasyOpen_optical_active,not activated ,1
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,14 B,1
ENG107595-MCTX settling phase,10 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG244880-Minimum_holdtime_ak,500 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,70 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,not activated ,1
ENG244883-Speed_ threshold_for_start_request_plausibilisation,10 km/h,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG422525-Startstop_button_clamp_state_display_activation_timer,3000 ms,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG422526-Time_to_set_signal_clamp_state_display,3000 ms,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG422527-Timeout_oru_update,60 min,3
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG244884-Toggle_offtime_other_doorhandle,2.00 s,1
ENG244885-Toggle_offtime_same_doorhandle,2.00 s,1
ENG422528-ENG422667-Unblock_reason_evaluation_clamp_50-Evaluate_Timeout_DTC,00000000  ,1
ENG422528-ENG422668-Unblock_reason_evaluation_clamp_50-Evaluate_Update_Fail_DTC,00000000  ,1
ENG422528-ENG422669-Unblock_reason_evaluation_clamp_50-Evaluate_ZR_ORU_Status,00000001  ,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
Elapsed Time: 00:53
adpmap-08-6EA-907-057-A_9BWCJ6CH7TP054606-20260720-0851.CSV
;SW:6EA-907-057-A   HW:6EA-907-057-A ---  08: Auto HVAC
;Component:Climatronic   H35 0214, Coding:0120000018000000010008005240010D0011000000000000000000000000
;EV_ACClimaBHBMQBA0Touch,001008,EV_ACClimaBHBMQBA0Touch.rod
;Monday,20,July,2026,08:51:07:18837
;VCID: 393ACB8BB810075685-806C-R
Elapsed Time: 00:11
adpmap-09-2Q0-937-090-G_9BWCJ6CH7TP054606-20260720-0851.CSV
;SW:2Q0-937-090-G   HW:2Q0-937-090-G ---  09: Cent. Elect.
;Component:BCM A0 Std+   H16 0995, Coding:
;EV_BCMA0,210001,EV_BCMA0_209_VW27.rod
;Monday,20,July,2026,08:51:39:18837
;VCID: 3620C0B7890EE82E68-8062-R SFD+SFD2 {x}
IDE00001-ENG130235-Production mode-Entry_control,not_active ,3
IDE00001-ENG115730-Production mode-Exterior lighting,not_active ,3
IDE00001-ENG112304-Production mode-Heckwischer,not_active ,3
IDE00001-ENG98647-Production mode-Interior lights,not_active ,3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not_active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not_active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not_active ,3
IDE00002-Transport mode,active ,4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,5
IDE02269-ENG149191-Acknowledgement signals-Akustische_Rueckmeldung_entriegeln,active ,5
IDE02269-ENG149190-Acknowledgement signals-Akustische_Rueckmeldung_global,not active ,5
IDE02269-ENG149195-Acknowledgement signals-Akustische_Rueckmeldung_Signalhorn,active ,5
IDE02269-ENG149192-Acknowledgement signals-Akustische_Rueckmeldung_verriegeln,active ,5
IDE02269-ENG149194-Acknowledgement signals-Dauer_der_Akustischen_Rueckmeldung_vom_Einfachhorn,short ,5
IDE02269-ENG149193-Acknowledgement signals-Menuesteuerung_akustische_Rueckmeldung,active ,5
IDE02269-ENG149189-Acknowledgement signals-Optische_Rueckmeldung_3.Bremsleuchte,not active ,5
IDE02269-ENG149188-Acknowledgement signals-Optische_Rueckmeldung_Komfortschliessen,active ,5
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,5
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,5
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG149246-Rear wiper-Automatisches_Heckwischen,not active ,8
IDE02711-ENG112304-Rear wiper-Heckwischer,Keine_Spannungsanforderung ,8
IDE02711-ENG149248-Rear wiper-Heckwischer_Weiterlauf,not active ,8
IDE02711-ENG115850-Rear wiper-Komfortwischen_Heck,active ,8
IDE02711-ENG149251-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_1,3 s,8
IDE02711-ENG149252-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_2,1 s,8
IDE02711-ENG149250-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Automatik,5 s,8
IDE02711-ENG149249-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Intervall,5 s,8
IDE02711-ENG149245-Rear wiper-Menuesteuerung_Komfortwischen_HW,active ,8
IDE02711-ENG148996-Rear wiper-rear_window_wiper,nur Komfortwischen ,8
IDE02711-ENG149247-Rear wiper-Traenenwischen_Heck,active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE02957-ENG154500-Ambient lighting-Ambience_borders_front,not installed ,8
IDE02957-ENG133384-Ambient lighting-Ambient_Farbliste_HMI,not active ,8
IDE02957-ENG154513-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,8
IDE02957-ENG154514-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,8
IDE02957-ENG149168-Ambient lighting-Ambientelicht_mit_raste_heckdeckel,Enabled ,8
IDE02957-ENG126836-Ambient lighting-Ambientemenue mit alle Zonen,not active ,8
IDE02957-ENG126835-Ambient lighting-Ambientemenue mit globalem aus,not active ,8
IDE02957-ENG154907-Ambient lighting-Applikationsleisten_Tuer,not installed ,8
IDE02957-ENG154995-Ambient lighting-Cupholderbeleuchtung,not installed ,8
IDE02957-ENG125648-Ambient lighting-Dachbeleuchtung,not installed ,8
IDE02957-ENG125029-Ambient lighting-Defaultwert Ambienteprofil Farbe,Cold white ,8
IDE02957-ENG149163-Ambient lighting-Defaultwert_Ambienteprofil_Fussraum,0 %,8
IDE02957-ENG149164-Ambient lighting-Defaultwert_Ambienteprofil_Tuer,0 %,8
IDE02957-ENG149165-Ambient lighting-Defaultwert_Ambienteprofil_Vorn,0 %,8
IDE02957-ENG125651-Ambient lighting-Farbwahl ueber Fahrprofil,not installed ,8
IDE02957-ENG125650-Ambient lighting-Farbwahl ueber HMI,not installed ,8
IDE02957-ENG114629-Ambient lighting-Footwell lighting,not installed ,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG155264-Ambient lighting-Lautsprecherbeleuchtung,not installed ,8
IDE02957-ENG125647-Ambient lighting-Mittelkonsolenbeleuchtung,not installed ,8
IDE02957-ENG125649-Ambient lighting-Panoramaschiebedachbeleuchtung,not installed ,8
IDE02957-ENG149167-Ambient lighting-Tuerinnengriff_mit_Tuertafel,not installed ,8
IDE02957-ENG149166-Ambient lighting-Tuerinnengriffbeleuchtung_mit_I-Tafel,not installed ,8
IDE03638-IDE04231-Static cornering light-Steering wheel angle: offset,0.0 °,16
IDE03638-ENG116677-Static cornering light-Abdimmgeschwindigkeit,20.0 %/s,16
IDE03638-ENG149111-Static cornering light-bei_Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116682-Static cornering light-Maximaltemperatur,120.0 °C,16
IDE03638-ENG149114-Static cornering light-Obere_Geschwindigkeitsschwelle,40.0 km/h,16
IDE03638-ENG149117-Static cornering light-obere_Grenztemperatur,100.0 °C,16
IDE03638-ENG149116-Static cornering light-Oberer_Lenkradwinkel,120 °,16
IDE03638-ENG149113-Static cornering light-Untere_Geschwindigkeitsschwelle,0.0 km/h,16
IDE03638-ENG149118-Static cornering light-untere_Grenztemperatur,80.0 °C,16
IDE03638-ENG149115-Static cornering light-Unterer_Lenkradwinkel,80 °,16
IDE03638-ENG116674-Static cornering light-Vorschrift,ECE_R119 ,16
IDE03638-ENG149112-Static cornering light-Zeitwert_Einschaltzeit_Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,320 s,9
IDE04927-MAS01535-Window heater-Rear window defogger,installed ,9
IDE04927-MAS01564-Window heater-Windshield defogger,not installed ,9
IDE04927-ENG142182-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung,35.0 °C,9
IDE04927-ENG142181-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung,35.0 °C,9
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,600 s,9
IDE04927-ENG142180-Window heater-Heckscheibenheizung_Zeitwert,320 s,9
IDE04927-ENG142179-Window heater-Temperaturabhaengige_Einschaltzeit_FSH,active ,9
IDE04927-ENG142178-Window heater-Temperaturabhaengige_Einschaltzeit_HSH,active ,9
IDE05548-ENG149125-Additional interior light-Signal_mapping_ambient_lighting_doors_lin,0 ,38
IDE05548-ENG149126-Additional interior light-Signal_mapping_door_handle_lighting_lin,0 ,38
IDE05548-ENG149127-Additional interior light-Signal_mapping_puddle_light_lin,puddle light ,38
IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,38
IDE05823-DWA Interior monitoring parameter set,C7 00 2A 4B 4F 53 54 41 4C 2A 31 30 31 34 30 33 30 33 2A 2A 66 00 10 00 01 00 56 57 20 20 20 20 5A 00 3C 00 02 00 02 00 00 00 04 00 5A 00 00 00 00 00 02 00 28 00 28 00 FA 00 96 00 0F 00 32 00 32 00 02 00 01 00 0A 00 28 00 14 00 07 00 28 00 28 00 04 00 C8 00 50 46 C2 01 32 00 04 00 04 00 10 00 04 00 04 00 B1 01 00 05 40 06 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,172
IDE06089-ENG149261-Seat heater level current consumption allocation-Art_der_Sitzheizungsregelung,Time-controlled ,36
IDE06089-ENG155386-Seat heater level current consumption allocation-Not_networked_seat_heater_rearseats,not connected ,36
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not installed ,36
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,36
IDE06089-ENG149262-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 1,0 %,36
IDE06089-ENG149263-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 2,20 %,36
IDE06089-ENG149264-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 3,0 %,36
IDE06089-ENG149265-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 4,100 %,36
IDE06089-ENG149266-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 5,0 %,36
IDE06089-ENG149267-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 6,100 %,36
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.05 ,36
IDE06089-ENG149271-Seat heater level current consumption allocation-Sitzheizung Stufe 0 Ansteuerzeit,2 min,36
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,24.00 °C,36
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,36
IDE06089-ENG149269-Seat heater level current consumption allocation-Sitzheizung Stufe 4 Ansteuerzeit,15 min,36
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,32.00 °C,36
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,30.00 °C,36
IDE06089-ENG149268-Seat heater level current consumption allocation-Sitzheizung Stufe 6 Ansteuerzeit,15 min,36
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,40.00 °C,36
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,38.00 °C,36
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,36
IDE06089-ENG155904-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase LO,Keine_Spannungsanforderung ,36
IDE06096-ENG149157-Interior lights-Innenlicht_bei_offenem_Heckdeckel_einschalten,active ,8
IDE06096-ENG98648-Interior lights-Interior lighting,Keine_Spannungsanforderung ,8
IDE08786-MAS10528-Assistance light functions-Rain light sensor,Rain light sensor ,9
IDE08786-MAS10545-Assistance light functions-Humidity sensor,not installed ,9
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,not active ,9
IDE08786-ENG149124-Assistance light functions-AFL_Zeitverzoegerung,0 ms,9
IDE08786-ENG149123-Assistance light functions-Assistenzfahrlicht_bei_Regen,active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,82 °,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,85 °,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,83 °,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,86 °,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm ,7
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,Energiemanagement oder Zeit ,6
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,30 min,6
IDE11421-ENG179280-Leaving concept-VLK_Deaktivierung_der_Diagnose,not active ,6
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE11944-MAS10510-Keyless access and start authorization-Kessy,installed ,5
IDE11944-ENG174170-Keyless access and start authorization-central_locking_system_selective_sigle_door_kessy_NAR,not active ,5
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,active ,5
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,active ,5
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,5
IDE11944-ENG149273-Keyless access and start authorization-Kessy_Komfort_oeffnen,not active ,5
IDE11944-ENG149274-Keyless access and start authorization-Kessy_Komfort_schliessen,not active ,5
IDE11944-ENG149275-Keyless access and start authorization-Oeffnung_Heckdeckel_bei_Wiederentriegelung,not active ,5
IDE11944-ENG149000-Keyless access and start authorization-Steering_wheel_locking_system,not installed ,5
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,Not available ,6
IDE12302-SFT271890-Identification of sub-bus participant-Driver door control module,Not available ,6
IDE12302-SFT271891-Identification of sub-bus participant-Front passenger door control module,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module,Not available ,6
IDE12302-SFT271948-Identification of sub-bus participant-Left rear door control module,Not available ,6
IDE12302-SFT271949-Identification of sub-bus participant-Right rear door control module,Not available ,6
MAS01490-IDE08581-Energy management-Recuperation,active ,5
MAS01490-MAS12921-Energy management-Predictive energy management,not active ,5
MAS01490-ENG149047-Energy management-Eingriff_durch_Energiemanagement,active ,5
MAS01490-ENG98636-Energy management-Hybrid,No ,5
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 32 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain,active ,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,Unknown (1),24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4300 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS16372-Security version number,1 ,2
ENG307645-ENG331913-Ambientebeleuchtung Teil 1-p_adaption_kundenwunsch_cupholder,1.00 ,32
ENG307645-ENG128539-Ambientebeleuchtung Teil 1-p_adaption_kundenwunsch_fussraum,0.40 ,32
ENG307645-ENG128571-Ambientebeleuchtung Teil 1-p_adaption_kundenwunsch_itafel,1.00 ,32
ENG307645-ENG128555-Ambientebeleuchtung Teil 1-p_adaption_kundenwunsch_lautsprecher,1.00 ,32
ENG307645-ENG331914-Ambientebeleuchtung Teil 1-p_adaption_kundenwunsch_tuertafel,1.00 ,32
ENG307645-ENG331917-Ambientebeleuchtung Teil 1-p_beschleunigung_cupholder,1.00 ,32
ENG307645-ENG331919-Ambientebeleuchtung Teil 1-p_beschleunigung_fussraum,1.00 ,32
ENG307645-ENG331920-Ambientebeleuchtung Teil 1-p_beschleunigung_itafel,1.00 ,32
ENG307645-ENG331921-Ambientebeleuchtung Teil 1-p_beschleunigung_lautsprecher,1.00 ,32
ENG307645-ENG331922-Ambientebeleuchtung Teil 1-p_beschleunigung_tuertafel,1.00 ,32
ENG307645-ENG331977-Ambientebeleuchtung Teil 1-p_inszenierung_zwischenwert_cupholder,100.0 %,32
ENG307645-ENG331979-Ambientebeleuchtung Teil 1-p_inszenierung_zwischenwert_fussraum,100.0 %,32
ENG307645-ENG331981-Ambientebeleuchtung Teil 1-p_inszenierung_zwischenwert_itafel,100.0 %,32
ENG307645-ENG331982-Ambientebeleuchtung Teil 1-p_inszenierung_zwischenwert_lautsprecher,100.0 %,32
ENG307645-ENG331983-Ambientebeleuchtung Teil 1-p_inszenierung_zwischenwert_tuertafel,100.0 %,32
ENG307645-ENG331984-Ambientebeleuchtung Teil 1-p_korrekturwert_cupholder,2.55 ,32
ENG307645-ENG331986-Ambientebeleuchtung Teil 1-p_korrekturwert_fussraum,2.55 ,32
ENG307645-ENG331987-Ambientebeleuchtung Teil 1-p_korrekturwert_itafel,2.55 ,32
ENG307645-ENG331988-Ambientebeleuchtung Teil 1-p_korrekturwert_tuertafel,2.55 ,32
ENG307645-ENG331990-Ambientebeleuchtung Teil 1-p_max_helligkeit_cupholder,96 %,32
ENG307645-ENG331992-Ambientebeleuchtung Teil 1-p_max_helligkeit_fussraum,96 %,32
ENG307645-ENG331993-Ambientebeleuchtung Teil 1-p_max_helligkeit_itafel,96 %,32
ENG307645-ENG331994-Ambientebeleuchtung Teil 1-p_max_helligkeit_lautsprecher,96 %,32
ENG307645-ENG331995-Ambientebeleuchtung Teil 1-p_max_helligkeit_tuertafel,96 %,32
ENG307645-ENG332132-Ambientebeleuchtung Teil 1-p_t_il_verzoegerung_inszenierung_ausstieg_frl,1.5 s,32
ENG307645-ENG332133-Ambientebeleuchtung Teil 1-p_t_il_verzoegerung_inszenierung_ausstieg_tuertafel,1.5 s,32
ENG307645-ENG332135-Ambientebeleuchtung Teil 1-p_t_il_verzoegerung_inszenierung_einstieg_frl,1.5 s,32
ENG307645-ENG332136-Ambientebeleuchtung Teil 1-p_t_il_verzoegerung_inszenierung_einstieg_tuertafel,1.5 s,32
ENG307645-ENG332138-Ambientebeleuchtung Teil 1-p_t_il_verzoegerung_inszenierung_oeffnen_frl,1.5 s,32
ENG307645-ENG332139-Ambientebeleuchtung Teil 1-p_t_il_verzoegerung_inszenierung_oeffnen_tuertafel,1.5 s,32
ENG307645-ENG332140-Ambientebeleuchtung Teil 1-p_t_il_verzoegerung_inszenierung_standard_frl,1.5 s,32
ENG307645-ENG332141-Ambientebeleuchtung Teil 1-p_t_il_verzoegerung_inszenierung_standard_tuertafel,1.5 s,32
ENG307646-ENG128619-Ambientebeleuchtung Teil 2-p_adaption_kundenwunsch_dach,1.00 ,16
ENG307646-ENG128659-Ambientebeleuchtung Teil 2-p_ambientelicht_verbauinformation_HMI,00001001  ,16
ENG307646-ENG128660-Ambientebeleuchtung Teil 2-p_ambientelicht_verbauinformation_HMI_2,00010000  ,16
ENG307646-ENG128661-Ambientebeleuchtung Teil 2-p_ambientelicht_verbauinformation_HMI_3,00000000  ,16
ENG307646-ENG128662-Ambientebeleuchtung Teil 2-p_ambientelicht_verbauinformation_HMI_4,00000000  ,16
ENG307646-ENG128655-Ambientebeleuchtung Teil 2-p_ambienteumfang_mehrfarbig_HMI,00000000  ,16
ENG307646-ENG128656-Ambientebeleuchtung Teil 2-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,16
ENG307646-ENG331918-Ambientebeleuchtung Teil 2-p_beschleunigung_dach,0.01 ,16
ENG307646-ENG331932-Ambientebeleuchtung Teil 2-p_einausstieg_dach,1 ,16
ENG307646-ENG128654-Ambientebeleuchtung Teil 2-p_farbauswahl_HMI,00000000  ,16
ENG307646-ENG331978-Ambientebeleuchtung Teil 2-p_inszenierung_zwischenwert_dach,100.0 %,16
ENG307646-ENG331985-Ambientebeleuchtung Teil 2-p_korrekturwert_dach,2.55 ,16
ENG307646-ENG331991-Ambientebeleuchtung Teil 2-p_max_helligkeit_dach,100 ,16
ENG307646-ENG332131-Ambientebeleuchtung Teil 2-p_t_il_verzoegerung_inszenierung_ausstieg_dach,1.5 s,16
ENG307646-ENG332134-Ambientebeleuchtung Teil 2-p_t_il_verzoegerung_inszenierung_einstieg_dach,1.5 s,16
ENG307646-ENG332137-Ambientebeleuchtung Teil 2-p_t_il_verzoegerung_inszenierung_oeffnen_dach,1.5 s,16
ENG148492-MAS01577-Anti-theft protection-Auxiliary heating,not installed ,5
ENG148492-ENG149232-Anti-theft protection-Akustischer_Alarm_Signalhorn,active ,5
ENG148492-ENG115864-Anti-theft protection-Alarmsignal,frequency_modulated ,5
ENG148492-ENG148991-Anti-theft protection-anti_theft_alarm_system,active ,5
ENG148492-ENG148992-Anti-theft protection-anti_theft_alarm_with_simple_horn,not installed ,5
ENG148492-ENG148993-Anti-theft protection-anti_theft_alarm_without_Thatcham,No ,5
ENG148492-ENG148990-Anti-theft protection-deactivation_button_anti_theft_alarm_sensor,not installed ,5
ENG148492-ENG154590-Anti-theft protection-Deaktivierung_DWA_ueber_MMI,active ,5
ENG148492-ENG123016-Anti-theft protection-Diebstahlschutz_mit_Anhaenger,not active ,5
ENG148492-ENG149229-Anti-theft protection-DWA_Alarmverzoegerung,delay_driver_door_contact_thatcham ,5
ENG148492-ENG149230-Anti-theft protection-DWA_Camper_Modus,not active ,5
ENG148492-ENG148994-Anti-theft protection-interior_monitoring_sensor,Yes ,5
ENG148492-ENG149231-Anti-theft protection-Sirenen_Alarmzahl,1_alarm ,5
ENG148492-ENG142008-Anti-theft protection-tilt_sensor,No ,5
ENG148492-ENG149228-Anti-theft protection-Verzoegerung_Panikalarm,keine_verzoegerung ,5
ENG307642-Antriebsstrang,00000000  ,1
ENG307648-ENG258152-Assistenz_fahrlichtsteuerung-p_count_slow,01 ,9
ENG307648-ENG258408-Assistenz_fahrlichtsteuerung-p_diag_ks_masse,0.3 V,9
ENG307648-ENG259928-Assistenz_fahrlichtsteuerung-p_diag_ks_versorgung,4.8 V,9
ENG307648-ENG259659-Assistenz_fahrlichtsteuerung-p_step_fast,09 ,9
ENG307648-ENG258786-Assistenz_fahrlichtsteuerung-p_step_slow,03 ,9
ENG307648-ENG258698-Assistenz_fahrlichtsteuerung-p_t_init,500 ms,9
ENG307648-ENG259682-Assistenz_fahrlichtsteuerung-p_t_ls_calc,10 ms,9
ENG307648-ENG332226-Assistenz_fahrlichtsteuerung-p_TFL_AusVer,40 ms,9
ENG307648-ENG332227-Assistenz_fahrlichtsteuerung-p_TFL_EinVer,0 ms,9
ENG307649-ENG332079-Assistenz_lichtfunktionen-p_s_ece48r6_wegstrecke,99 m,3
ENG307649-ENG332252-Assistenz_lichtfunktionen-p_v_abl_ece48_ein,10 km/h,3
ENG307649-ENG332258-Assistenz_lichtfunktionen-p_v_tfl_ece48_ein,10 km/h,3
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,5
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken,active ,5
ENG141649-ENG130187-Außenlicht_Blinker-Blinkkontrolleuchte_fuer_Anhaenger,separte ,5
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing,not active ,5
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,5
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,5
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay,50 ms,5
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken,not active ,5
ENG141649-ENG331881-Außenlicht_Blinker-Flash_delay_discrete,0 ms,5
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken,active ,5
ENG141649-ENG115854-Außenlicht_Blinker-Komfortblinken_Blinkzyklen,3 ,5
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken,not active ,5
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2,not active ,5
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,5
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,5
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,5
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,not active ,5
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,5
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,5
ENG141649-ENG286352-Außenlicht_Blinker-Telematikblinken_OCU_Blinken,not active ,5
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,5
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,5
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,5
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,5
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,5
ENG141647-MAS10529-Außenlicht_Front-Low beam: bulb type,H7 ,9
ENG141647-ENG149099-Außenlicht_Front-Allwetterlicht_Ausschaltgrenze,350 km/h,9
ENG141647-ENG149098-Außenlicht_Front-Allwetterlicht_Einschaltgrenze,350 km/h,9
ENG141647-ENG149106-Außenlicht_Front-Fahrlicht_bei_Tag,Daytime running lights ,9
ENG141647-ENG149097-Außenlicht_Front-Lichthupe_bei_Zuendung_aus_moeglich,active ,9
ENG141647-ENG126567-Außenlicht_Front-max_scheinwerfer_2limitieren,in_Betrieb_lassen ,9
ENG141647-ENG149100-Außenlicht_Front-Scheinwerferferreinigungsansteuerung_und_Abblendlichtanzeige_bei_Dauerfahrlicht,not active ,9
ENG141647-ENG149103-Außenlicht_Front-Standlicht_aktiviert_zusaetzlich_Tagfahrlicht,not active ,9
ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich,not active ,9
ENG141647-ENG149104-Außenlicht_Front-Tagfahrlicht_Dauerfahrlicht_bei_Handbremse_abschalten,not active ,9
ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,not active ,9
ENG141647-ENG149105-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht_aktiviert_zusaetzlich_Standlicht,not active ,9
ENG141647-ENG149102-Außenlicht_Front-Werkseinstellung_fuer_Tagfahrlicht_Freischaltung_BAP_/_Bedienfolge,active ,9
ENG141648-MAS10533-Aussenlicht_Heck-Brake light is turn signal,No ,5
ENG141648-ENG179109-Aussenlicht_Heck-Bremslicht_mit_Schlusslichtfunktion,not active ,5
ENG141648-ENG149110-Aussenlicht_Heck-Nebelschlusslicht_Warngeschwindigkeit,255 km/h,5
ENG141648-ENG115847-Aussenlicht_Heck-Notbremsanzeige_NBA,active ,5
ENG141648-ENG155652-Aussenlicht_Heck-Schlusslicht_mit_Brems_und_Blinklichtfunktion,not active ,5
ENG141648-ENG149109-Aussenlicht_Heck-Schlusslicht_mit_Bremslichtfunktion,not active ,5
ENG141656-MAS10538-Außenlicht_uebergreifend-Light rotary sw. connection,Discrete signal current ,16
ENG141656-MAS10541-Außenlicht_uebergreifend-Light rotary switch with fog light,No ,16
ENG141656-MAS10542-Außenlicht_uebergreifend-Light rotary switch with fog tail light,No ,16
ENG141656-MAS10543-Außenlicht_uebergreifend-Light rotary sw. with AFL,Yes ,16
ENG141656-MAS10544-Außenlicht_uebergreifend-Light rotary switch with park. light pos.,Yes ,16
ENG141656-ENG248495-Außenlicht_uebergreifend-ABL_off_ECE48_Rev6,No ,16
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,Energy management ,16
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,Energy management ,16
ENG141656-ENG126566-Außenlicht_uebergreifend-beidseitiges_dauerparklicht,active ,16
ENG141656-ENG281103-Außenlicht_uebergreifend-CHo_Nachlauf,0 ms,16
ENG141656-ENG149092-Außenlicht_uebergreifend-Coming_home_Leuchten,Low beams ,16
ENG141656-ENG149089-Außenlicht_uebergreifend-Coming_Home_Verbaustatus,manually ,16
ENG141656-ENG149093-Außenlicht_uebergreifend-Coming-home_Einschaltereignis,Driver_door ,16
ENG141656-ENG248654-Außenlicht_uebergreifend-ECE48_Rev6_aktiv,not active ,16
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,16
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,in 0 and SL position ,16
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,16
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,16
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,16
ENG141656-ENG149096-Außenlicht_uebergreifend-Helligkeitsschwelle_Forward-Messung,116 ,16
ENG141656-ENG149094-Außenlicht_uebergreifend-Helligkeitsschwelle_Infrarot-Messung,72 ,16
ENG141656-ENG155156-Außenlicht_uebergreifend-keine_LCM_blinker,false ,16
ENG141656-ENG149086-Außenlicht_uebergreifend-Kontrollleuchte_fuer_Begrenzungslicht,integriert_in_Suchbeleuchtung ,16
ENG141656-ENG149095-Außenlicht_uebergreifend-Leaving-Home_Verbausstatus,Enabled ,16
ENG141656-ENG126569-Außenlicht_uebergreifend-lho_aktiviert,active ,16
ENG141656-ENG126570-Außenlicht_uebergreifend-lho_zeit,30 seconds ,16
ENG141656-ENG149005-Außenlicht_uebergreifend-Lichtdrehschalter_mit_Nebellicht_bei_Assistenzfahrlicht,Yes ,16
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,16
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,16
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beams,Keine_Spannungsanforderung ,16
ENG141656-ENG149088-Außenlicht_uebergreifend-Menueeinstellung_CHO_LHO,Menuesteuerung_Zeit_aktivieren ,16
ENG141656-ENG149091-Außenlicht_uebergreifend-Menueeinstellung_Cominghome,30 seconds ,16
ENG141656-ENG149090-Außenlicht_uebergreifend-Menuesteuerung_Coming_Home_Werkseinstellung,active ,16
ENG141656-ENG149087-Außenlicht_uebergreifend-Parklicht_ueber_LSS_aktiviert,not active ,16
ENG141656-ENG126565-Außenlicht_uebergreifend-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,16
ENG141656-ENG137035-Außenlicht_uebergreifend-Standlicht-Verfuegbarkeit,24 s,16
ENG141656-ENG248823-Außenlicht_uebergreifend-TFL_off_ECE48_Rev6,No ,16
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Keine_Spannungsanforderung ,16
ENG148494-MAS10534-Background lighting-Input medium: search illumination,HMI ,21
ENG148494-ENG142240-Background lighting-Daempfung Abdimmen KL 58xd PWM,0.00 s,21
ENG148494-ENG154582-Background lighting-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG148494-ENG154583-Background lighting-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG148494-ENG154584-Background lighting-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG148494-ENG154585-Background lighting-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG148494-ENG179120-Background lighting-Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG148494-ENG142242-Background lighting-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
ENG148494-ENG142241-Background lighting-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
ENG148494-ENG149159-Background lighting-KL58_Einschalten_mit_Rampe,not active ,21
ENG148494-ENG149160-Background lighting-KL58_Verriegelungsausschalten,not_active ,21
ENG148494-ENG149161-Background lighting-Lichtsensor_wirkt_auf_Suchbeleuchtung,active ,21
ENG148494-ENG149162-Background lighting-Suchbeleuchtung_Festwert,100 %,21
ENG148494-ENG142234-Background lighting-Umgebungs_helligkeit_auswahl,Fotosensor_Kombi ,21
ENG148494-ENG130188-Background lighting-Warnblinktastersuchbeleuchtung_Aktivierung,always_active ,21
ENG148494-ENG130190-Background lighting-Warnblinktastersuchbeleuchtung_Faktor,0.100 ,21
ENG148494-ENG130189-Background lighting-Warnblinktastersuchbeleuchtung_Grundwert,6.0 %,21
ENG253111-ENG258489-Batteriespannungskompensation-p_k_pwm_negativ,1.00 ,5
ENG253111-ENG259899-Batteriespannungskompensation-p_k_pwm_positiv,1.00 ,5
ENG253111-ENG258711-Batteriespannungskompensation-p_U_EMV,16.0 V,5
ENG253111-ENG261105-Batteriespannungskompensation-p_U_forward_LED,2.0 V,5
ENG307652-ENG331129-Child Presence Detection-p_CPD_warnton_aktiv,not active ,2
ENG307652-ENG331130-Child Presence Detection-p_t_Delta_Timer,10 ,2
ENG307652-ENG331133-Child Presence Detection-p_ZV_child_presence_detection,not active ,2
ENG253005-ENG332186-Cockpit button-p_t_Taster_1_Blinkperiode,400 ms,12
ENG253005-ENG332187-Cockpit button-p_t_Taster_1_Entprellung,40 ms,12
ENG253005-ENG332188-Cockpit button-p_t_Taster_1_lokal_LED,500 ms,12
ENG253005-ENG332189-Cockpit button-p_t_Taster_2_Blinkperiode,400 ms,12
ENG253005-ENG332190-Cockpit button-p_t_Taster_2_Entprellung,40 ms,12
ENG253005-ENG332191-Cockpit button-p_t_Taster_2_lokal_LED,500 ms,12
ENG253005-ENG332192-Cockpit button-p_t_Taster_3_Blinkperiode,400 ms,12
ENG253005-ENG332193-Cockpit button-p_t_Taster_3_Entprellung,40 ms,12
ENG253005-ENG332194-Cockpit button-p_t_Taster_3_lokal_LED,500 ms,12
ENG253005-ENG332195-Cockpit button-p_t_Taster_4_Blinkperiode,400 ms,12
ENG253005-ENG332196-Cockpit button-p_t_Taster_4_Entprellung,40 ms,12
ENG253005-ENG332197-Cockpit button-p_t_Taster_4_lokal_LED,500 ms,12
ENG307657-ENG259520-Dimmung Suchbeleuchtung KL58-p_delta_KL58D_min,3.0 %,15
ENG307657-ENG253461-Dimmung Suchbeleuchtung KL58-p_Fehlerwert_Kl_58xd,80.0 %,15
ENG307657-ENG253462-Dimmung Suchbeleuchtung KL58-p_Fehlerwert_Kl_58xs,80.0 %,15
ENG307657-ENG253463-Dimmung Suchbeleuchtung KL58-p_Fehlerwert_Kl_58xt,80.0 %,15
ENG307657-ENG331934-Dimmung Suchbeleuchtung KL58-p_Helligkeit_RLS_Daempfung_Abdimmen,4.0 ,15
ENG307657-ENG331935-Dimmung Suchbeleuchtung KL58-p_Helligkeit_RLS_Daempfung_Aufdimmen,2.0 ,15
ENG307657-ENG259127-Dimmung Suchbeleuchtung KL58-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,15
ENG307657-ENG261206-Dimmung Suchbeleuchtung KL58-p_kl58d_poti_uin_max,4.900 V,15
ENG307657-ENG258780-Dimmung Suchbeleuchtung KL58-p_kl58d_poti_uin_min,0.100 V,15
ENG307657-ENG259198-Dimmung Suchbeleuchtung KL58-p_kl58d_poti_uin_tol,0.050 V,15
ENG307657-ENG261308-Dimmung Suchbeleuchtung KL58-p_langer_Tastendruck,1.0 s,15
ENG307657-ENG260197-Dimmung Suchbeleuchtung KL58-p_timer_Kl_58xs_Nachlauf_lang,900 s,15
ENG307657-ENG261144-Dimmung Suchbeleuchtung KL58-p_timer_Kl_58xt_Nachlauf_kurz,30 s,15
ENG307657-ENG258180-Dimmung Suchbeleuchtung KL58-p_timer_Netz_Nachlauf_Master,10 min,15
ENG307657-ENG253464-Dimmung Suchbeleuchtung KL58-p_timer_Netz_Nachlauf_Slave,12 min,15
ENG248426-ENG252093-Elektronische_Rückwandklappe-eRWK_Abbruchblinken_Heck,not active ,9
ENG248426-ENG248659-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,9
ENG248426-ENG248660-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,9
ENG248426-ENG248661-Elektronische_Rückwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,9
ENG248426-ENG248662-Elektronische_Rückwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,9
ENG248426-ENG248663-Elektronische_Rückwandklappe-eRWK_Oeffnungsblinken_Heck,not active ,9
ENG248426-ENG248664-Elektronische_Rückwandklappe-eRWK_ohne_FFB_HDF,not active ,9
ENG248426-ENG252079-Elektronische_Rückwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,9
ENG248426-ENG252068-Elektronische_Rückwandklappe-eRWK_Start_Umfelderkennung,2.0 s,9
ENG148609-ENG148997-Fahrerinformation-Cockpit_button_1,installed ,5
ENG148609-ENG148998-Fahrerinformation-Cockpit_button_2,installed ,5
ENG148609-ENG148999-Fahrerinformation-Cockpit_button_3,not installed ,5
ENG148609-ENG149003-Fahrerinformation-Cockpit_button_4,not installed ,5
ENG307664-ENG258176-Fahrerinformation 2-p_ERR_aussentemperatur_sensor_kurzschluss,100 ,15
ENG307664-ENG258740-Fahrerinformation 2-p_ERR_aussentemperatur_sensor_unterbrechung,60 ,15
ENG307664-ENG259037-Fahrerinformation 2-p_kuehlmittel_widerstandsschwelle,150 ,15
ENG307664-ENG259178-Fahrerinformation 2-p_t_bremsbelag_io,1 s,15
ENG307664-ENG260298-Fahrerinformation 2-p_t_bremsbelag_offen,1 s,15
ENG307664-ENG258424-Fahrerinformation 2-p_t_bremsfluessigkeit_mangel,1 s,15
ENG307664-ENG260509-Fahrerinformation 2-p_t_bremsfluessigkeit_vorhanden,1 s,15
ENG307664-ENG258380-Fahrerinformation 2-p_t_ERR_aussentemperatur_sensor,5 s,15
ENG307664-ENG260655-Fahrerinformation 2-p_t_kuehlmittel_mangel,1 s,15
ENG307664-ENG261122-Fahrerinformation 2-p_t_kuehlmittel_vorhanden,1 s,15
ENG307664-ENG259926-Fahrerinformation 2-p_t_NOERR_aussentemperatur_sensor,5 s,15
ENG307664-ENG332198-Fahrerinformation 2-p_t_taster_haengt,300 s,15
ENG307664-ENG260951-Fahrerinformation 2-p_t_waschwasser_mangel,1 s,15
ENG307664-ENG258366-Fahrerinformation 2-p_t_waschwasser_vorhanden,1 s,15
ENG307664-ENG260216-Fahrerinformation 2-p_waschwasser_widerstandsschwelle,200 ,15
ENG307665-ENG259344-Fahrzeugspezifische Parameter-p_count_fast,05 ,26
ENG307665-ENG331926-Fahrzeugspezifische Parameter-p_diag_qualififizierung_notlauf,480 ms,26
ENG307665-ENG261296-Fahrzeugspezifische Parameter-p_diag_unplausibel,1.1 V,26
ENG307665-ENG331927-Fahrzeugspezifische Parameter-p_diag_unplausibel_2,0.0 V,26
ENG307665-ENG259246-Fahrzeugspezifische Parameter-p_ls_init,1275 ,26
ENG307665-ENG260211-Fahrzeugspezifische Parameter-p_n_plausi_Nockenkontakt_AUS,0A ,26
ENG307665-ENG260695-Fahrzeugspezifische Parameter-p_n_plausi_Nockenkontakt_EIN,40 ,26
ENG307665-ENG298120-Fahrzeugspezifische Parameter-p_n_Sbt_Crashred_Wdh,10 ,26
ENG307665-ENG332035-Fahrzeugspezifische Parameter-p_n_wechsel_kls_kl15_fahrzyklus_gegen_ft,15 ,26
ENG307665-ENG259269-Fahrzeugspezifische Parameter-p_t_abbiegelicht_abdimm,1.00 s,26
ENG307665-ENG259597-Fahrzeugspezifische Parameter-p_t_BLS_Entprellung,0.20 s,26
ENG307665-ENG332109-Fahrzeugspezifische Parameter-p_t_DWP_SRA_delay,300 ms,26
ENG307665-ENG332112-Fahrzeugspezifische Parameter-p_t_Entprellung_LED_Diagnose,500 ms,26
ENG307665-ENG332159-Fahrzeugspezifische Parameter-p_t_LCM_Hochlauf,0.10 s,26
ENG307665-ENG258610-Fahrzeugspezifische Parameter-p_t_ls_countmax,150 ms,26
ENG307665-ENG259202-Fahrzeugspezifische Parameter-p_t_maximale_zeit_anforderung_komfortblinken,1.000 s,26
ENG307665-ENG261285-Fahrzeugspezifische Parameter-p_t_retrigger,1500 ms,26
ENG307665-ENG332183-Fahrzeugspezifische Parameter-p_t_Serviceposition_Ansteuerung,650 ms,26
ENG307665-ENG332201-Fahrzeugspezifische Parameter-p_t_tippwischen,300 ms,26
ENG307665-ENG258337-Fahrzeugspezifische Parameter-p_t_ZV_FFB_HDF_Verzoegerung,800 ms,26
ENG307665-ENG258507-Fahrzeugspezifische Parameter-p_t_ZV_FFB_Mindestverzoegerung_zweiter_Befehl,100 ms,26
ENG307665-ENG259343-Fahrzeugspezifische Parameter-p_timeout_blinker_status,0.29 s,26
ENG141650-MAS10514-Fernlicht_assistent-Expanded high beam control,Halogen ,6
ENG141650-ENG149120-Fernlicht_assistent-Fernlichtassistent_Reset,not active ,6
ENG141650-ENG149122-Fernlicht_assistent-Fernlichtassistent_Zeitverzoegerungswert,800 ms,6
ENG141650-ENG149119-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent,Not available ,6
ENG141650-ENG149121-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent_Werkseinstellung,Not available ,6
ENG307666-ENG332143-FFB / Kessy-p_t_Kessy_Intervall_Wiederentriegelung,10 s,8
ENG307666-ENG332145-FFB / Kessy-p_t_KESSY_UHF_Antwort_Delayzeit,10000 µs,8
ENG307666-ENG332146-FFB / Kessy-p_t_kessy_uhf_timeout_2,0 ms,8
ENG307666-ENG332147-FFB / Kessy-p_t_kessy_Weckleitung_Pulse,13600 µs,8
ENG307666-ENG258675-FFB / Kessy-p_t_ZV_Verzögerung_Funkaktivierung,3000 ms,8
ENG307666-ENG332243-FFB / Kessy-p_u_KESSY_ID_Geber_Schwelle_1,2300 mV,8
ENG307666-ENG332244-FFB / Kessy-p_u_KESSY_ID_Geber_Schwelle_2,2200 mV,8
ENG307666-ENG332245-FFB / Kessy-p_u_KESSY_Min_Amplitude_UHF_Antwort,-255 ,8
ENG307667-ENG332003-FH / SAD / DWA-p_n_DWA_QuittiertonDauerSounder,00 ,22
ENG307667-ENG332006-FH / SAD / DWA-p_n_Komfort_Bitfehler,2 ,22
ENG307667-ENG332060-FH / SAD / DWA-p_prz_DWA_Oeffnungsgrad_FH,10 %,22
ENG307667-ENG332061-FH / SAD / DWA-p_prz_FH_Oeffnungsgrad_geschlossen,2 %,22
ENG307667-ENG332062-FH / SAD / DWA-p_prz_FH_Oeffnungsgrad_offen,95 %,22
ENG307667-ENG332063-FH / SAD / DWA-p_prz_PSD_Oeffnungsgrad_geschlossen,2 %,22
ENG307667-ENG332064-FH / SAD / DWA-p_prz_SAD_Oeffnungsgrad_offen,1 %,22
ENG307667-ENG332104-FH / SAD / DWA-p_t_DWA_Entschaerfen_Nachlauf_Komfort,0.50 s,22
ENG307667-ENG332105-FH / SAD / DWA-p_t_DWA_Verzoegerung_Deaktivierung_Thatcham,15000 ms,22
ENG307667-ENG332106-FH / SAD / DWA-p_t_DWA_Verzoegerung_Drehfalle_Auf,200 ms,22
ENG307667-ENG332107-FH / SAD / DWA-p_t_DWA_Verzoegerung_Drehfalle_Zu,5000 ms,22
ENG307667-ENG332108-FH / SAD / DWA-p_t_DWA_Voraktivierungszeit,30 s,22
ENG307667-ENG332114-FH / SAD / DWA-p_t_Freigabe_Komfort_SZ_nach_ext_verriegelt,45000 ms,22
ENG307667-ENG332142-FH / SAD / DWA-p_t_Innenraumsicherung,30 s,22
ENG307667-ENG332144-FH / SAD / DWA-p_t_KESSY_Komfortoeffnen_Freigabezeit,5000 ms,22
ENG307667-ENG332153-FH / SAD / DWA-p_t_Komfort_oeffnen_max,30000 ms,22
ENG307667-ENG332154-FH / SAD / DWA-p_t_Komfort_oeffnen_Startverzoegerung,2000 ms,22
ENG307667-ENG332155-FH / SAD / DWA-p_t_Komfort_schliessen_max,30000 ms,22
ENG307667-ENG332156-FH / SAD / DWA-p_t_Komfort_schliessen_Startverzoegerung,2000 ms,22
ENG307667-ENG332157-FH / SAD / DWA-p_t_Komfortfreigabezeit,600 s,22
ENG307667-ENG332158-FH / SAD / DWA-p_t_Komfortquittung_Verzoegerung,1000 ms,22
ENG248411-ENG248631-Front doors-cockpittaster2_funktion,not active ,1
ENG248411-ENG252063-Front doors-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,1
ENG248411-ENG248723-Front doors-Laderaumschließung Taster togglen,not active ,1
ENG248411-ENG248768-Front doors-NFZ_Schliessung,not active ,1
ENG248411-ENG248784-Front doors-pa_Schlosstyp_vorne,Einmotorenschloss ,1
ENG248411-ENG133390-Front doors-Wiederverriegelung_Laderaum,not installed ,1
ENG307668-ENG332100-Front Scheibenheizung-p_t_Delay_FrontscheibenHzg,500 ms,9
ENG307668-ENG332119-Front Scheibenheizung-p_t_FSH_Anzeigevorleistung,1000 ms,9
ENG307668-ENG332120-Front Scheibenheizung-p_t_FSH_Kundenwunsch_Speicherdauer,900 s,9
ENG307668-ENG332121-Front Scheibenheizung-p_t_FSH_Longpush,2.0 s,9
ENG307668-ENG332122-Front Scheibenheizung-p_t_FSH_Longpush_Feedback,500 ms,9
ENG307668-ENG332123-Front Scheibenheizung-p_t_FSH_Taster_haengt20790,20 s,9
ENG307668-ENG332224-Front Scheibenheizung-p_temp_FSH_defrost,4.0 °C,9
ENG307668-ENG332241-Front Scheibenheizung-p_u_DeltaSpg_FrontscheibenHzg,100 mV,9
ENG148493-ENG115721-Front windshield wiper-Frontwischer,Sollspannungsanforderung 13.5 ,6
ENG148493-ENG133394-Front windshield wiper-Frontwischer_Abtauposition,keine_Abtaupostition ,6
ENG148493-ENG149235-Front windshield wiper-Frontwischer_Referenzlauf,active ,6
ENG148493-ENG126573-Front windshield wiper-Frontwischer_Serviceposition,active ,6
ENG148493-ENG149241-Front windshield wiper-Geschwindigkeitsabhaengige_Wischstufenrueckschaltung,active ,6
ENG148493-ENG149239-Front windshield wiper-Menuesteuerung_Frontwischer,active ,6
ENG148493-ENG154706-Front windshield wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG148493-ENG149042-Front windshield wiper-rain_sensor_function,installed ,6
ENG148493-ENG149238-Front windshield wiper-Regensensor_aktivieren,active ,6
ENG148493-ENG149242-Front windshield wiper-Traenenwischen_Front_Status,not active ,6
ENG148493-ENG126844-Front windshield wiper-Washer_Tipwiping_Variant,active ,6
ENG148493-ENG148995-Front windshield wiper-windshield_wiper_typ,Direct ,6
ENG148493-ENG149237-Front windshield wiper-Wischer_abparken_bei_Oeffnen_der_Motorhaube,not active ,6
ENG148493-ENG149236-Front windshield wiper-Wischer_stop_bei_KL15_aus,not active ,6
ENG148493-ENG149244-Front windshield wiper-Wischer_stop_bei_Motorstart,immer_Wischerstopp ,6
ENG148493-ENG149243-Front windshield wiper-Wischer_Stopp_bei_Oeffnen_der_Motorhaube,active ,6
ENG307669-ENG260119-Front Wischer-p_n_Anzahl_RLS_LIN_Initbotschaften,3 ,13
ENG307669-ENG332005-Front Wischer-p_n_Intervallstufe_ohne_Intervallpoti,3 ,13
ENG307669-ENG332011-Front Wischer-p_n_Retry_Frontwiper,10 ,13
ENG307669-ENG332101-Front Wischer-p_t_dequali,2000 ms,13
ENG307669-ENG332110-Front Wischer-p_t_einzelansteuer_verzoeg,1.00 s,13
ENG307669-ENG332169-Front Wischer-p_t_Parklagenkontakt_Entprellung,500 ms,13
ENG307669-ENG332171-Front Wischer-p_t_quali_kurz,2000 ms,13
ENG307669-ENG332172-Front Wischer-p_t_quali_lang,4000 ms,13
ENG307669-ENG332184-Front Wischer-p_t_Serviceposition_minimale_Betätigung,140 ms,13
ENG307669-ENG332199-Front Wischer-p_t_timeout_ServicePosition,2000 ms,13
ENG307669-ENG332202-Front Wischer-p_T_traenen,255 °C,13
ENG307669-ENG155534-Front Wischer-p_v_klemme_15_AUS,4 km/h,13
ENG307669-ENG258743-Front Wischer-p_v_klemme_x,1 km/h,13
ENG307670-ENG259255-Funktionsparameter Licht-p_abbiegelicht_frei_entprellt,1 ,25
ENG307670-ENG259961-Funktionsparameter Licht-p_abbiegelicht_frei_entprellt_schwelle,1 ,25
ENG307670-ENG331911-Funktionsparameter Licht-p_abbiegelicht_motordrehzahl_schwelle,50 ,25
ENG307670-ENG259592-Funktionsparameter Licht-p_abbiegelicht_temp_offset,25 K,25
ENG307670-ENG260038-Funktionsparameter Licht-p_abl_bei_fl,90.0 %,25
ENG307670-ENG331924-Funktionsparameter Licht-p_blinkerhebelverzoegerung_kl15ein,1000 ms,25
ENG307670-ENG259684-Funktionsparameter Licht-p_lho_bei_LDS_abblendlicht,0 ,25
ENG307670-ENG258221-Funktionsparameter Licht-p_lho_spielschutz,3 ,25
ENG307670-ENG260225-Funktionsparameter Licht-p_t_afl_ausschaltverzoegerung,3000 ms,25
ENG307670-ENG259130-Funktionsparameter Licht-p_t_ausstieg,30 s,25
ENG307670-ENG332092-Funktionsparameter Licht-p_t_Blinker_LSS_Entprellung,80 ms,25
ENG307670-ENG332093-Funktionsparameter Licht-p_t_Blinker_Ueberschwingfilter,80 ms,25
ENG307670-ENG258903-Funktionsparameter Licht-p_t_bremslicht_hw_unterdrueckung,30 ,25
ENG307670-ENG261035-Funktionsparameter Licht-p_t_fahrlicht_hinweis,2 s,25
ENG307670-ENG259165-Funktionsparameter Licht-p_t_glw_lh_entprellung,400 ms,25
ENG307670-ENG260320-Funktionsparameter Licht-p_t_LDS_AFL_entprellung,60 ms,25
ENG307670-ENG258465-Funktionsparameter Licht-p_t_LDS_entprellung,60 ms,25
ENG307670-ENG332160-Funktionsparameter Licht-p_t_Lichthupe_LSS_Entprellung,50 ms,25
ENG307670-ENG258222-Funktionsparameter Licht-p_t_lichtwarnung_dauer,10.0 s,25
ENG307670-ENG260596-Funktionsparameter Licht-p_t_rfl_entprellung,400 ms,25
ENG307670-ENG259614-Funktionsparameter Licht-p_t_tfl_affengriff,3.0 s,25
ENG307670-ENG260579-Funktionsparameter Licht-p_v_abbiegelicht_hysterese,5 km/h,25
ENG307670-ENG261112-Funktionsparameter Licht-p_v_fahrlicht_hinweis,0 km/h,25
ENG307670-ENG260942-Funktionsparameter Licht-p_v_fahrlicht_hinweis_reset,2 km/h,25
ENG248444-ENG248688-Global-Freischaltung_der_Kisi_Auswurffunktion,No ,1
ENG248444-ENG248689-Global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,No ,1
ENG248444-ENG248691-Global-Funktion_SAFE,No ,1
ENG248444-ENG248774-Global-pa_eKiSi,No ,1
ENG248444-ENG248776-Global-pa_FFb_Sbt_Tausch_Seite,No ,1
ENG248444-ENG248809-Global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt_aktiv,No ,1
ENG248444-ENG248810-Global-Schiebetuertaste_Armaturentafel_bei_extern_verriegelt_aktiv,No ,1
ENG253149-ENG331880-Globale Diagnoseparameter-Ereignis-Unterdrückung,0 ,32
ENG253149-ENG258568-Globale Diagnoseparameter-p_dtc_diagnose_komplett,0 ,32
ENG253149-ENG261307-Globale Diagnoseparameter-p_Ereignisspeicher_Unterdrueckung,0 ,32
ENG253149-ENG260727-Globale Diagnoseparameter-p_KD_Fehler_Bit,0 ,32
ENG253149-ENG331999-Globale Diagnoseparameter-p_n_DelayCount_Kl15,10 ,32
ENG253149-ENG332000-Globale Diagnoseparameter-p_n_DelayCount_Leds,5 ,32
ENG253149-ENG332001-Globale Diagnoseparameter-p_n_DelayCount_Others,10 ,32
ENG253149-ENG332002-Globale Diagnoseparameter-p_n_DelayCount_ZV,2 ,32
ENG253149-ENG332015-Globale Diagnoseparameter-p_n_scdDelayCountRest_Kl15,0 ,32
ENG253149-ENG332016-Globale Diagnoseparameter-p_n_scdDelayCountRest_Leds,5 ,32
ENG253149-ENG332017-Globale Diagnoseparameter-p_n_scdDelayCountRest_Others,5 ,32
ENG253149-ENG332018-Globale Diagnoseparameter-p_n_scdDelayCountRest_ZV,1 ,32
ENG253149-ENG332019-Globale Diagnoseparameter-p_n_scdKl15_Cycle_Kl15,0 ,32
ENG253149-ENG332020-Globale Diagnoseparameter-p_n_scdKl15_Cycle_Leds,3 ,32
ENG253149-ENG332021-Globale Diagnoseparameter-p_n_scdKl15_Cycle_Others,3 ,32
ENG253149-ENG332022-Globale Diagnoseparameter-p_n_scdKl15_Cycle_ZV,3 ,32
ENG253149-ENG332023-Globale Diagnoseparameter-p_n_scdKl15_ReactCycle_Leds,5 ,32
ENG253149-ENG332024-Globale Diagnoseparameter-p_n_scdKl15_ReactCycle_ZV,5 ,32
ENG253149-ENG332026-Globale Diagnoseparameter-p_n_scdReact_Cycle_Kl15,0 ,32
ENG253149-ENG332028-Globale Diagnoseparameter-p_n_scdRestart_Kl15,0 ,32
ENG253149-ENG332029-Globale Diagnoseparameter-p_n_scdRestart_Leds,3 ,32
ENG253149-ENG332030-Globale Diagnoseparameter-p_n_scdRestart_ZV,3 ,32
ENG253149-ENG258364-Globale Diagnoseparameter-p_t_delay_LIN_Diagnose,10 s,32
ENG253149-ENG260231-Globale Diagnoseparameter-p_t_Diagnoseverbot_nach_Start,5 s,32
ENG253149-ENG332177-Globale Diagnoseparameter-p_t_scdRes_Kl15,0.00 s,32
ENG253149-ENG332179-Globale Diagnoseparameter-p_t_scdRest_Leds,1.00 s,32
ENG253149-ENG332180-Globale Diagnoseparameter-p_t_scdRest_Others,1.00 s,32
ENG253149-ENG332181-Globale Diagnoseparameter-p_t_scdRest_ZV,1.00 s,32
ENG253149-ENG260718-Globale Diagnoseparameter-p_VW_application_data_Identifier (Highbyte),48 ,32
ENG253149-ENG259105-Globale Diagnoseparameter-p_VW_application_data_Identifier (Lowbyte),48 ,32
ENG248445-ENG248698-Heckklappe: Türen-HD_Innentaster_im_Heck,not installed ,1
ENG248445-ENG248782-Heckklappe: Türen-pa_Schlosstyp_Heck,Federsteller ,1
ENG248445-ENG248787-Heckklappe: Türen-pa_Typ_Heck,Klappe ,1
ENG307671-ENG332255-Heckwischersteuerung Geschwindigkeiten-p_v_hecktraenen,4 km/h,2
ENG307671-ENG259805-Heckwischersteuerung Geschwindigkeiten-p_v_komfortwischen,4 km/h,2
ENG307672-ENG259855-Heckwischersteuerung Zeiten-p_t_einzelwischhub,0.30 s,11
ENG307672-ENG332111-Heckwischersteuerung Zeiten-p_t_entprell_rückfahrwischen,1.0 s,11
ENG307672-ENG332117-Heckwischersteuerung Zeiten-p_t_frontwischer _aktiv,5 s,11
ENG307672-ENG260632-Heckwischersteuerung Zeiten-p_t_Heck_verschlossen,3 s,11
ENG307672-ENG332125-Heckwischersteuerung Zeiten-p_t_hecktraenen,5 s,11
ENG307672-ENG258658-Heckwischersteuerung Zeiten-p_t_Heckwasch_Anforderung,0 ms,11
ENG307672-ENG260642-Heckwischersteuerung Zeiten-p_t_pause_einzelwischhub,1.8 s,11
ENG307672-ENG258100-Heckwischersteuerung Zeiten-p_t_Rueckfahrwisch_historie,10 s,11
ENG307672-ENG258993-Heckwischersteuerung Zeiten-p_t_rueckfahrwisch_mindestaktivzeit,0.8 s,11
ENG307672-ENG259530-Heckwischersteuerung Zeiten-p_t_Wascherpumpe_max,10 s,11
ENG141645-MAS00212-HW_Verbau-Washer fluid low,not installed ,8
ENG141645-MAS06495-HW_Verbau-Engine hood contact switch,installed ,8
ENG141645-MAS10521-HW_Verbau-Exterior temp. sensor,installed ,8
ENG141645-ENG126574-HW_Verbau-auspraegung_Bremsfluessigkeitsschalter,Open ,8
ENG141645-ENG115848-HW_Verbau-Signalhorn_ohne_KL15,not active ,8
ENG141645-ENG149002-HW_Verbau-Signalhorn_ueber_LIN,horn_via_LIN ,8
ENG141645-ENG142011-HW_Verbau-trunk_lid_conrol_unit,not installed ,8
ENG148603-ENG115658-Innen_beleuchtung_KL58_xd_max-x0,0 lx,10
ENG148603-ENG101574-Innen_beleuchtung_KL58_xd_max-X1,8 lx,10
ENG148603-ENG99557-Innen_beleuchtung_KL58_xd_max-X2,200 lx,10
ENG148603-ENG102140-Innen_beleuchtung_KL58_xd_max-X3,300 lx,10
ENG148603-ENG102936-Innen_beleuchtung_KL58_xd_max-X4,500 lx,10
ENG148603-ENG115659-Innen_beleuchtung_KL58_xd_max-y0,16.0 ,10
ENG148603-ENG99777-Innen_beleuchtung_KL58_xd_max-Y1,16.0 ,10
ENG148603-ENG100480-Innen_beleuchtung_KL58_xd_max-Y2,100.0 ,10
ENG148603-ENG100773-Innen_beleuchtung_KL58_xd_max-Y3,100.0 ,10
ENG148603-ENG100631-Innen_beleuchtung_KL58_xd_max-Y4,100.0 ,10
ENG148602-ENG115658-Innen_beleuchtung_KL58_xd_min-x0,0 lx,10
ENG148602-ENG101574-Innen_beleuchtung_KL58_xd_min-X1,8 lx,10
ENG148602-ENG99557-Innen_beleuchtung_KL58_xd_min-X2,220 lx,10
ENG148602-ENG102140-Innen_beleuchtung_KL58_xd_min-X3,300 lx,10
ENG148602-ENG102936-Innen_beleuchtung_KL58_xd_min-X4,500 lx,10
ENG148602-ENG115659-Innen_beleuchtung_KL58_xd_min-y0,6.0 ,10
ENG148602-ENG99777-Innen_beleuchtung_KL58_xd_min-Y1,6.0 ,10
ENG148602-ENG100480-Innen_beleuchtung_KL58_xd_min-Y2,100.0 ,10
ENG148602-ENG100773-Innen_beleuchtung_KL58_xd_min-Y3,100.0 ,10
ENG148602-ENG100631-Innen_beleuchtung_KL58_xd_min-Y4,100.0 ,10
ENG148607-ENG115658-Innen_beleuchtung_KL58_xd_PWM-x0,0 ,12
ENG148607-ENG101574-Innen_beleuchtung_KL58_xd_PWM-X1,10 ,12
ENG148607-ENG99557-Innen_beleuchtung_KL58_xd_PWM-X2,50 ,12
ENG148607-ENG102140-Innen_beleuchtung_KL58_xd_PWM-X3,100 ,12
ENG148607-ENG102936-Innen_beleuchtung_KL58_xd_PWM-X4,220 ,12
ENG148607-ENG103548-Innen_beleuchtung_KL58_xd_PWM-X5,253 ,12
ENG148607-ENG115659-Innen_beleuchtung_KL58_xd_PWM-y0,2.0 %,12
ENG148607-ENG99777-Innen_beleuchtung_KL58_xd_PWM-Y1,2.0 %,12
ENG148607-ENG100480-Innen_beleuchtung_KL58_xd_PWM-Y2,6.0 %,12
ENG148607-ENG100773-Innen_beleuchtung_KL58_xd_PWM-Y3,10.0 %,12
ENG148607-ENG100631-Innen_beleuchtung_KL58_xd_PWM-Y4,80.0 %,12
ENG148607-ENG102174-Innen_beleuchtung_KL58_xd_PWM-Y5,100.0 %,12
ENG148599-ENG115658-Innen_beleuchtung_KL58_xs_max-x0,0 lx,8
ENG148599-ENG101574-Innen_beleuchtung_KL58_xs_max-X1,8 lx,8
ENG148599-ENG99557-Innen_beleuchtung_KL58_xs_max-X2,50 lx,8
ENG148599-ENG102140-Innen_beleuchtung_KL58_xs_max-X3,500 lx,8
ENG148599-ENG115659-Innen_beleuchtung_KL58_xs_max-y0,100.0 ,8
ENG148599-ENG99777-Innen_beleuchtung_KL58_xs_max-Y1,100.0 ,8
ENG148599-ENG100480-Innen_beleuchtung_KL58_xs_max-Y2,100.0 ,8
ENG148599-ENG100773-Innen_beleuchtung_KL58_xs_max-Y3,100.0 ,8
ENG148605-ENG115658-Innen_beleuchtung_KL58_xs_PWM-x0,0.0 %,6
ENG148605-ENG101574-Innen_beleuchtung_KL58_xs_PWM-X1,50.0 %,6
ENG148605-ENG99557-Innen_beleuchtung_KL58_xs_PWM-X2,100.0 %,6
ENG148605-ENG115659-Innen_beleuchtung_KL58_xs_PWM-y0,0.0 %,6
ENG148605-ENG99777-Innen_beleuchtung_KL58_xs_PWM-Y1,50.0 %,6
ENG148605-ENG100480-Innen_beleuchtung_KL58_xs_PWM-Y2,100.0 %,6
ENG148601-ENG115658-Innen_beleuchtung_KL58_xt_max-x0,0 lx,8
ENG148601-ENG101574-Innen_beleuchtung_KL58_xt_max-X1,8 lx,8
ENG148601-ENG99557-Innen_beleuchtung_KL58_xt_max-X2,50 lx,8
ENG148601-ENG102140-Innen_beleuchtung_KL58_xt_max-X3,500 lx,8
ENG148601-ENG115659-Innen_beleuchtung_KL58_xt_max-y0,100.0 ,8
ENG148601-ENG99777-Innen_beleuchtung_KL58_xt_max-Y1,100.0 ,8
ENG148601-ENG100480-Innen_beleuchtung_KL58_xt_max-Y2,100.0 ,8
ENG148601-ENG100773-Innen_beleuchtung_KL58_xt_max-Y3,100.0 ,8
ENG148600-ENG115658-Innen_beleuchtung_KL58_xt_min-x0,0 lx,8
ENG148600-ENG101574-Innen_beleuchtung_KL58_xt_min-X1,8 lx,8
ENG148600-ENG99557-Innen_beleuchtung_KL58_xt_min-X2,50 lx,8
ENG148600-ENG102140-Innen_beleuchtung_KL58_xt_min-X3,500 lx,8
ENG148600-ENG115659-Innen_beleuchtung_KL58_xt_min-y0,6.0 ,8
ENG148600-ENG99777-Innen_beleuchtung_KL58_xt_min-Y1,6.0 ,8
ENG148600-ENG100480-Innen_beleuchtung_KL58_xt_min-Y2,100.0 ,8
ENG148600-ENG100773-Innen_beleuchtung_KL58_xt_min-Y3,100.0 ,8
ENG148606-ENG115658-Innen_beleuchtung_KL58_xt_PWM-x0,0.0 %,6
ENG148606-ENG101574-Innen_beleuchtung_KL58_xt_PWM-X1,50.0 %,6
ENG148606-ENG99557-Innen_beleuchtung_KL58_xt_PWM-X2,100.0 %,6
ENG148606-ENG115659-Innen_beleuchtung_KL58_xt_PWM-y0,0.0 %,6
ENG148606-ENG99777-Innen_beleuchtung_KL58_xt_PWM-Y1,50.0 %,6
ENG148606-ENG100480-Innen_beleuchtung_KL58_xt_PWM-Y2,100.0 %,6
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG148597-ENG115658-Innenbeleuchtung_Abdimmen-x0,0 ms,22
ENG148597-ENG101574-Innenbeleuchtung_Abdimmen-X1,100 ms,22
ENG148597-ENG115664-Innenbeleuchtung_Abdimmen-x10,1000 ms,22
ENG148597-ENG99557-Innenbeleuchtung_Abdimmen-X2,200 ms,22
ENG148597-ENG102140-Innenbeleuchtung_Abdimmen-X3,300 ms,22
ENG148597-ENG102936-Innenbeleuchtung_Abdimmen-X4,400 ms,22
ENG148597-ENG103548-Innenbeleuchtung_Abdimmen-X5,500 ms,22
ENG148597-ENG113992-Innenbeleuchtung_Abdimmen-X6,600 ms,22
ENG148597-ENG115661-Innenbeleuchtung_Abdimmen-x7,700 ms,22
ENG148597-ENG115662-Innenbeleuchtung_Abdimmen-x8,800 ms,22
ENG148597-ENG115663-Innenbeleuchtung_Abdimmen-x9,900 ms,22
ENG148597-ENG115659-Innenbeleuchtung_Abdimmen-y0,100.0 %,22
ENG148597-ENG99777-Innenbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG148597-ENG115668-Innenbeleuchtung_Abdimmen-y10,0.0 %,22
ENG148597-ENG100480-Innenbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG148597-ENG100773-Innenbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG148597-ENG100631-Innenbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG148597-ENG102174-Innenbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG148597-ENG113993-Innenbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG148597-ENG115665-Innenbeleuchtung_Abdimmen-y7,5.0 %,22
ENG148597-ENG115666-Innenbeleuchtung_Abdimmen-y8,3.0 %,22
ENG148597-ENG115667-Innenbeleuchtung_Abdimmen-y9,1.0 %,22
ENG148598-ENG115658-Innenbeleuchtung_Fotosensor-x0,0 ,22
ENG148598-ENG101574-Innenbeleuchtung_Fotosensor-X1,50 ,22
ENG148598-ENG99557-Innenbeleuchtung_Fotosensor-X2,100 ,22
ENG148598-ENG102140-Innenbeleuchtung_Fotosensor-X3,200 ,22
ENG148598-ENG102936-Innenbeleuchtung_Fotosensor-X4,253 ,22
ENG148598-ENG115659-Innenbeleuchtung_Fotosensor-y0,0 lx,22
ENG148598-ENG99777-Innenbeleuchtung_Fotosensor-Y1,50 lx,22
ENG148598-ENG100480-Innenbeleuchtung_Fotosensor-Y2,100 lx,22
ENG148598-ENG100773-Innenbeleuchtung_Fotosensor-Y3,200 ,22
ENG148598-ENG100631-Innenbeleuchtung_Fotosensor-Y4,500 ,22
ENG148596-ENG115658-Innenbeleuchtung_Hochdimmen-x0,0 ms,22
ENG148596-ENG101574-Innenbeleuchtung_Hochdimmen-X1,100 ms,22
ENG148596-ENG115664-Innenbeleuchtung_Hochdimmen-x10,1000 ms,22
ENG148596-ENG99557-Innenbeleuchtung_Hochdimmen-X2,200 ms,22
ENG148596-ENG102140-Innenbeleuchtung_Hochdimmen-X3,300 ms,22
ENG148596-ENG102936-Innenbeleuchtung_Hochdimmen-X4,400 ms,22
ENG148596-ENG103548-Innenbeleuchtung_Hochdimmen-X5,500 ms,22
ENG148596-ENG113992-Innenbeleuchtung_Hochdimmen-X6,600 ms,22
ENG148596-ENG115661-Innenbeleuchtung_Hochdimmen-x7,700 ms,22
ENG148596-ENG115662-Innenbeleuchtung_Hochdimmen-x8,800 ms,22
ENG148596-ENG115663-Innenbeleuchtung_Hochdimmen-x9,900 ms,22
ENG148596-ENG115659-Innenbeleuchtung_Hochdimmen-y0,0.0 %,22
ENG148596-ENG99777-Innenbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG148596-ENG115668-Innenbeleuchtung_Hochdimmen-y10,100.0 %,22
ENG148596-ENG100480-Innenbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG148596-ENG100773-Innenbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG148596-ENG100631-Innenbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG148596-ENG102174-Innenbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG148596-ENG113993-Innenbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG148596-ENG115665-Innenbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG148596-ENG115666-Innenbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG148596-ENG115667-Innenbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG148604-ENG115658-Innenbeleuchtung_KL58xd_log_Bus-x0,0.0 %,12
ENG148604-ENG101574-Innenbeleuchtung_KL58xd_log_Bus-X1,6.0 %,12
ENG148604-ENG99557-Innenbeleuchtung_KL58xd_log_Bus-X2,16.0 %,12
ENG148604-ENG102140-Innenbeleuchtung_KL58xd_log_Bus-X3,30.0 %,12
ENG148604-ENG102936-Innenbeleuchtung_KL58xd_log_Bus-X4,60.0 %,12
ENG148604-ENG103548-Innenbeleuchtung_KL58xd_log_Bus-X5,100.0 %,12
ENG148604-ENG115659-Innenbeleuchtung_KL58xd_log_Bus-y0,10 ,12
ENG148604-ENG99777-Innenbeleuchtung_KL58xd_log_Bus-Y1,10 ,12
ENG148604-ENG100480-Innenbeleuchtung_KL58xd_log_Bus-Y2,100 ,12
ENG148604-ENG100773-Innenbeleuchtung_KL58xd_log_Bus-Y3,150 ,12
ENG148604-ENG100631-Innenbeleuchtung_KL58xd_log_Bus-Y4,220 ,12
ENG148604-ENG102174-Innenbeleuchtung_KL58xd_log_Bus-Y5,253 ,12
ENG148595-ENG149169-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x0,0 ms,10
ENG148595-ENG149170-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x1,2000 ms,10
ENG148595-ENG149171-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x2,3000 ms,10
ENG148595-ENG149172-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x3,4000 ms,10
ENG148595-ENG149173-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x4,5100 ms,10
ENG148595-ENG149174-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y0,1.0 %,10
ENG148595-ENG149175-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y1,5.0 ,10
ENG148595-ENG149176-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y2,15.0 ,10
ENG148595-ENG149177-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y3,40.0 ,10
ENG148595-ENG149178-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y4,100.0 ,10
ENG248447-ENG248714-Inszenierung CHoLHo-Inszenierung CHo/LHo Aktivieren,not active ,36
ENG248447-ENG115658-Inszenierung CHoLHo-x0,0 ms,36
ENG248447-ENG101574-Inszenierung CHoLHo-X1,200 ms,36
ENG248447-ENG115664-Inszenierung CHoLHo-x10,2000 ms,36
ENG248447-ENG248838-Inszenierung CHoLHo-x11,200 ms,36
ENG248447-ENG248839-Inszenierung CHoLHo-x12,400 ms,36
ENG248447-ENG248840-Inszenierung CHoLHo-x13,600 ms,36
ENG248447-ENG248841-Inszenierung CHoLHo-x14,800 ms,36
ENG248447-ENG248842-Inszenierung CHoLHo-x15,1000 ms,36
ENG248447-ENG99557-Inszenierung CHoLHo-X2,400 ms,36
ENG248447-ENG102140-Inszenierung CHoLHo-X3,600 ms,36
ENG248447-ENG102936-Inszenierung CHoLHo-X4,800 ms,36
ENG248447-ENG103548-Inszenierung CHoLHo-X5,1000 ms,36
ENG248447-ENG113992-Inszenierung CHoLHo-X6,1200 ms,36
ENG248447-ENG115661-Inszenierung CHoLHo-x7,1400 ms,36
ENG248447-ENG115662-Inszenierung CHoLHo-x8,1600 ms,36
ENG248447-ENG115663-Inszenierung CHoLHo-x9,1800 ms,36
ENG248447-ENG115659-Inszenierung CHoLHo-y0,0.0 %,36
ENG248447-ENG99777-Inszenierung CHoLHo-Y1,3.0 %,36
ENG248447-ENG115668-Inszenierung CHoLHo-y10,100.0 %,36
ENG248447-ENG136987-Inszenierung CHoLHo-Y11,3.0 %,36
ENG248447-ENG136988-Inszenierung CHoLHo-Y12,7.0 %,36
ENG248447-ENG136989-Inszenierung CHoLHo-Y13,12.0 %,36
ENG248447-ENG136990-Inszenierung CHoLHo-Y14,17.0 %,36
ENG248447-ENG136991-Inszenierung CHoLHo-Y15,24.0 %,36
ENG248447-ENG100480-Inszenierung CHoLHo-Y2,7.0 %,36
ENG248447-ENG100773-Inszenierung CHoLHo-Y3,12.0 %,36
ENG248447-ENG100631-Inszenierung CHoLHo-Y4,17.0 %,36
ENG248447-ENG102174-Inszenierung CHoLHo-Y5,24.0 %,36
ENG248447-ENG113993-Inszenierung CHoLHo-Y6,33.0 %,36
ENG248447-ENG115665-Inszenierung CHoLHo-y7,44.0 %,36
ENG248447-ENG115666-Inszenierung CHoLHo-y8,59.0 %,36
ENG248447-ENG115667-Inszenierung CHoLHo-y9,78.0 %,36
ENG252992-ENG259947-Komfortbeleuchtung-p_KL_30G_ks,0 ,18
ENG252992-ENG261283-Komfortbeleuchtung-p_t_dimmzeit_innenlicht,1500 ms,18
ENG252992-ENG260785-Komfortbeleuchtung-p_t_innenlicht_kurz,30 s,18
ENG252992-ENG258198-Komfortbeleuchtung-p_t_innenlicht_lang,600 s,18
ENG252992-ENG260410-Komfortbeleuchtung-p_t_maximale_einschaltzeit_innenlichtversorgung,10 min,18
ENG252992-ENG258338-Komfortbeleuchtung-p_t_umfeld_abkuehl,1 min,18
ENG252992-ENG258872-Komfortbeleuchtung-p_t_umfeld_max,10 min,18
ENG252992-ENG259719-Komfortbeleuchtung-p_v_innenlicht,15 km/h,18
ENG253256-ENG260427-Komfortwischen Skoda-p_n_Zykl_1,01 ,5
ENG253256-ENG259087-Komfortwischen Skoda-p_n_Zykl_2,01 ,5
ENG253256-ENG261338-Komfortwischen Skoda-p_t_RS,5 s,5
ENG253256-ENG261217-Komfortwischen Skoda-p_t_Stufe_1,30 s,5
ENG253256-ENG259825-Komfortwischen Skoda-p_t_Stufe_2,10 s,5
ENG253359-ENG261281-Lampenausfallkontrolle-p_n_lampendiag_GDLversuche,02 ,15
ENG253359-ENG332007-Lampenausfallkontrolle-p_n_olDelayCount,8 ,15
ENG253359-ENG332013-Lampenausfallkontrolle-p_n_scdDelayCount_Hw,2 ,15
ENG253359-ENG332014-Lampenausfallkontrolle-p_n_scdDelayCount_Sw,10 ,15
ENG253359-ENG332025-Lampenausfallkontrolle-p_n_scdKl15Cycle,15 ,15
ENG253359-ENG332027-Lampenausfallkontrolle-p_n_scdRestart,3 ,15
ENG253359-ENG259419-Lampenausfallkontrolle-p_t_lampendiag_GDLanlauf,1.0 s,15
ENG253359-ENG259321-Lampenausfallkontrolle-p_t_lampendiag_GDLerholung,0.5 s,15
ENG253359-ENG332175-Lampenausfallkontrolle-p_t_scdDelay_Lamp,0.10 s,15
ENG253359-ENG332176-Lampenausfallkontrolle-p_t_scdDelay_Xenon,40 s,15
ENG253359-ENG332178-Lampenausfallkontrolle-p_t_scdRest,1.00 s,15
ENG253359-ENG259410-Lampenausfallkontrolle-p_u_lampendiag_obergrenze_bulbs,15.0 V,15
ENG253359-ENG261365-Lampenausfallkontrolle-p_u_lampendiag_obergrenze_nonbulbs,15.0 V,15
ENG253359-ENG260278-Lampenausfallkontrolle-p_u_lampendiag_untergrenze_bulbs,11.0 V,15
ENG253359-ENG259509-Lampenausfallkontrolle-p_u_lampendiag_untergrenze_nonbulbs,11.0 V,15
ENG253004-ENG332034-Leaving concept-p_n_wechsel_kls_gegen_kl15,50 ,4
ENG253004-ENG260170-Leaving concept-p_t_erkennung_fahrt_fahrzyklus,1.0 s,4
ENG253004-ENG332207-Leaving concept-p_t_vlk_diagnose_tuerkontakt,10 min,4
ENG253004-ENG260121-Leaving concept-p_v_erkennung_fahrt_fahrzyklus,10 km/h,4
ENG148608-ENG148900-Lenkradhebel-Art des Lenkstockschalters,LSS ohne Elektronik ,5
ENG148608-ENG149233-Lenkradhebel-Aussenspiegelheizung_aktivierungssignal,Hardwaresignal ,5
ENG148608-ENG155105-Lenkradhebel-FAS-Taster,installed ,5
ENG148608-ENG149006-Lenkradhebel-Fernlichtstellung,FL rastend ,5
ENG148608-ENG148901-Lenkradhebel-GRA-Bedienung,MFL-Bedienung ,5
ENG148608-ENG149001-Lenkradhebel-heated_mirror,not installed ,5
ENG148608-ENG149004-Lenkradhebel-speed_limiter,not installed ,5
ENG148608-ENG179276-Lenkradhebel-Umschaltung GRA zu SL,Indirekt ,5
ENG148608-ENG154803-Lenkradhebel-Verbauort_Lenkstockschalter,CAN ,5
ENG148608-ENG149234-Lenkradhebel-Versorgung_Lenkstockschalters_KL30,installed ,5
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,127 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,20 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,52 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken_links_Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not_activ ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not_activ ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not_activ ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not_activ ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not_activ ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not_activ ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not_activ ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,LED_Blinkleuchten ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,0 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,0 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblink_taster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not_activ ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not_activ ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not_activ ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not_activ ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not_activ ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not_activ ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not_activ ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,127 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,0 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,0 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Position lamps ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,not_activ ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not_activ ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not_activ ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not_activ ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not_activ ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not_activ ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not_activ ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeineGluehlampe6W:auchH6W ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,127 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,0 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,0 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Position lamps ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,not_activ ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not_activ ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not_activ ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not_activ ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not_activ ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not_activ ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not_activ ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeineGluehlampe6W:auchH6W ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,127 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,0 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,0 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,Safe_LED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not_activ ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not_activ ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not_activ ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not_activ ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not_activ ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not_activ ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not_activ ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,127 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,0 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,0 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken_links_Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not_activ ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not_activ ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not_activ ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not_activ ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not_activ ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not_activ ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not_activ ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,127 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,0 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,0 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken_rechts_Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not_activ ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not_activ ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not_activ ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not_activ ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not_activ ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not_activ ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not_activ ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,22 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,8 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken_links_Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not_activ ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not_activ ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not_activ ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not_activ ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not_activ ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not_activ ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not_activ ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,24 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,24 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken_rechts_Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not_activ ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not_activ ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not_activ ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not_activ ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not_activ ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not_activ ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not_activ ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,127 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,21 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,62 ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken_rechts_Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not_activ ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not_activ ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not_activ ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not_activ ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not_activ ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not_activ ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not_activ ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,LED_Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,127 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,57 ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,16 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake lamp ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not_activ ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not_activ ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not_activ ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not_activ ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not_activ ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not_activ ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not_activ ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,LED Bremsleuchten_mit_Ueberspg_absch ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,127 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,58 ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,32 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake lamp ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not_activ ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not_activ ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not_activ ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not_activ ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not_activ ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not_activ ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not_activ ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,LED Bremsleuchten_mit_Ueberspg_absch ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,127 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,44 ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,41 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake lamp ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not_activ ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not_activ ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not_activ ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not_activ ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not_activ ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not_activ ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not_activ ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,allgemeine_LED_6W ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,127 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,41 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,10 ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Position lamps ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parklichtlinks ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not_activ ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not_activ ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not_activ ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not_activ ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not_activ ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not_activ ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,2*3W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,127 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,42 ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,26 ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Position lamps ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parklichtrechts ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not_activ ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not_activ ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not_activ ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not_activ ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not_activ ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not_activ ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,2*3W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,48 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,40 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Position lamps ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not_activ ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not_activ ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not_activ ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not_activ ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not_activ ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not_activ ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not_activ ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,allgemeine_LED_12W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,0 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,0 ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0 ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,not_activ ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not_activ ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not_activ ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not_activ ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not_activ ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not_activ ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not_activ ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not_activ ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,not_active ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,8 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,0 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Dimmung_Klemme_58_xs ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not_activ ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not_activ ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not_activ ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not_activ ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not_activ ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not_activ ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not_activ ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,127 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,50 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,27 ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not_activ ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not_activ ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not_activ ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not_activ ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not_activ ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not_activ ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not_activ ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeine_LED_12W ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,1 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,0 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme_30_G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not_activ ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not_activ ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not_activ ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not_activ ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not_activ ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not_activ ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not_activ ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeine_Gluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,26 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,127 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,minimize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,minimize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,26 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,74 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,114 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Position lamps ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parklichtlinks ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,Klemme 15 vfzg ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not_activ ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,Blinkenlinksaktiv ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not_activ ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,Abblendlichtlinks ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not_activ ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,LEDTagfahrlichtmodulSignal ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,126 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,7 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,0 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior lighting ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not_activ ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not_activ ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not_activ ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not_activ ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not_activ ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not_activ ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not_activ ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeine_Gluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,0 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,0 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not_activ ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not_activ ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not_activ ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not_activ ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not_activ ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not_activ ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not_activ ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not_activ ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not_active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,0 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,0 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not_activ ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not_activ ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not_activ ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not_activ ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not_activ ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not_activ ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not_activ ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not_activ ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not_active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,0 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,0 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not_activ ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not_activ ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not_activ ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not_activ ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not_activ ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not_activ ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not_activ ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not_activ ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not_active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,0 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,0 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not_activ ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not_activ ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not_activ ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not_activ ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not_activ ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not_activ ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not_activ ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not_activ ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not_active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,26 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,127 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,minimize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,minimize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,26 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,76 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,118 ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Position lamps ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parklichtrechts ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,Klemme 15 vfzg ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not_activ ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,Blinkenrechtsaktiv ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not_activ ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,Abblendlichtrechts ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not_activ ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,LEDTagfahrlichtmodulSignal ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,127 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,127 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,73 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,114 ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not_activ ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,Position lamps ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,Parklichtlinks ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not_activ ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not_activ ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not_activ ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not_activ ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,LEDTagfahrlichtmodulVersorgung ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,127 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,127 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,75 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,118 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not_activ ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,Position lamps ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,Parklichtrechts ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not_activ ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not_activ ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not_activ ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not_activ ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,LEDTagfahrlichtmodulVersorgung ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,127 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,26 ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,54 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlichtlinks ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,Headlamp flasher ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not_activ ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not_activ ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not_activ ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not_activ ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not_activ ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not_activ ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,LED_Abblendlicht ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,127 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,27 ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,64 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlichtrechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,Headlamp flasher ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not_activ ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not_activ ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not_activ ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not_activ ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not_activ ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not_activ ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,LED_Abblendlicht ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,127 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,0 ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,0 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Fernlichtlinks ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not_activ ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not_activ ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not_activ ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not_activ ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not_activ ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not_activ ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,LED_Lichtmodul ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,127 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,0 ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,0 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Fernlichtrechts ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not_activ ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not_activ ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not_activ ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not_activ ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not_activ ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not_activ ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,LED_Lichtmodul ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,0 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,0 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,Lock_Unlock_LED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not_activ ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not_activ ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not_activ ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not_activ ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not_activ ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not_activ ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not_activ ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG126648-MAS02526-LIN-Mirrormode-Activation,not active ,1
ENG126648-ENG149044-LIN-Mirrormode-LIN4,not active ,1
ENG126648-ENG149045-LIN-Mirrormode-LIN5,not active ,1
ENG148592-ENG115658-LuB_Lichtrouter_Kennlinie_1-x0,0.0 %,12
ENG148592-ENG101574-LuB_Lichtrouter_Kennlinie_1-X1,5.0 %,12
ENG148592-ENG99557-LuB_Lichtrouter_Kennlinie_1-X2,50.0 %,12
ENG148592-ENG102140-LuB_Lichtrouter_Kennlinie_1-X3,75.0 %,12
ENG148592-ENG102936-LuB_Lichtrouter_Kennlinie_1-X4,110.0 %,12
ENG148592-ENG103548-LuB_Lichtrouter_Kennlinie_1-X5,126.5 %,12
ENG148592-ENG115659-LuB_Lichtrouter_Kennlinie_1-y0,0.0 %,12
ENG148592-ENG99777-LuB_Lichtrouter_Kennlinie_1-Y1,6.0 %,12
ENG148592-ENG100480-LuB_Lichtrouter_Kennlinie_1-Y2,16.0 %,12
ENG148592-ENG100773-LuB_Lichtrouter_Kennlinie_1-Y3,30.0 %,12
ENG148592-ENG100631-LuB_Lichtrouter_Kennlinie_1-Y4,60.0 %,12
ENG148592-ENG102174-LuB_Lichtrouter_Kennlinie_1-Y5,100.0 %,12
ENG175392-ENG331923-MQB-p_blFehlerKlemmenGueltig,01 ,123
ENG175392-ENG331976-MQB-p_ILenkhilfe,50 A,123
ENG175392-ENG332050-MQB-p_PBEMHLKontingentFeld_0,1000 W,123
ENG175392-ENG332051-MQB-p_PBEMHLKontingentFeld_1,-100 W,123
ENG175392-ENG332052-MQB-p_PBEMHLKontingentFeld_2,-200 W,123
ENG175392-ENG332053-MQB-p_PBEMHLKontingentFeld_3,-300 W,123
ENG175392-ENG332054-MQB-p_PBEMHLKontingentFeld_4,-400 W,123
ENG175392-ENG332055-MQB-p_PBEMHLKontingentFeld_5,-500 W,123
ENG175392-ENG332056-MQB-p_PBEMHLKontingentFeld_6,-700 W,123
ENG175392-ENG332057-MQB-p_PBEMHLKontingentFeld_7,-800 W,123
ENG175392-ENG332058-MQB-p_PBEMHLKontingentFeld_8,-1000 W,123
ENG175392-ENG332059-MQB-p_PBEMHLKontingentFeld_9,-1000 W,123
ENG175392-ENG332065-MQB-p_przGenDfUnkrit,70.0 %,123
ENG175392-ENG332066-MQB-p_przSocNio,95 %,123
ENG175392-ENG332067-MQB-p_przZyklenKritisch_Max,75 %,123
ENG175392-ENG332068-MQB-p_przZyklenKritisch_Min,65 %,123
ENG175392-ENG332069-MQB-p_PTabKVerbrFeld_0,250 W,123
ENG175392-ENG332070-MQB-p_PTabKVerbrFeld_1,100 W,123
ENG175392-ENG332071-MQB-p_PTabKVerbrFeld_2,50 W,123
ENG175392-ENG332072-MQB-p_PTabKVerbrFeld_3,200 W,123
ENG175392-ENG332073-MQB-p_PTabKVerbrFeld_4,100 W,123
ENG175392-ENG332074-MQB-p_PTabKVerbrFeld_5,450 W,123
ENG175392-ENG332075-MQB-p_PTabKVerbrFeld_6,50 W,123
ENG175392-ENG332076-MQB-p_PTabKVerbrFeld_7,100 W,123
ENG175392-ENG332077-MQB-p_PTabKVerbrFeld_8,0 W,123
ENG175392-ENG332078-MQB-p_PTabKVerbrFeld_9,0 W,123
ENG175392-ENG332223-MQB-p_tAnzVerzVerbrAbsch,90 s,123
ENG175392-ENG332228-MQB-p_tHysNachlaufVse,5.0 s,123
ENG175392-ENG332229-MQB-p_tInkBetriebszeit,1 s,123
ENG175392-ENG332230-MQB-p_tLadebilanzStopp,300 min,123
ENG175392-ENG332231-MQB-p_tLoadResponse,5 s,123
ENG175392-ENG332232-MQB-p_tMotorlaufErkennung,10.0 s,123
ENG175392-ENG332233-MQB-p_tNachladung,45 s,123
ENG175392-ENG332234-MQB-p_tNachladung_Unkrit,15 s,123
ENG175392-ENG332236-MQB-p_tStart,240 s,123
ENG175392-ENG332237-MQB-p_tVerz_EinBetrieb1,0.5 s,123
ENG175392-ENG332238-MQB-p_tVerz_Inaktiv,5 s,123
ENG175392-ENG332239-MQB-p_tVerz_Reaktiv,5.0 s,123
ENG175392-ENG332240-MQB-p_tWarteShowroom,10 s,123
ENG175392-ENG332246-MQB-p_UAEAbschUnter,12.70 V,123
ENG175392-ENG332247-MQB-p_UDeltaSKrit,0.30 V,123
ENG175392-ENG332248-MQB-p_UKritBA1,12.70 V,123
ENG175392-ENG332249-MQB-p_UkritRemoteStart,12.90 V,123
ENG175392-ENG332250-MQB-p_UShowroom,11.70 V,123
ENG175392-ENG332260-MQB-p_valKurzstreckeMax,05 ,123
ENG175392-ENG332261-MQB-p_valPrio_TabA_Max,03 ,123
ENG175392-ENG332262-MQB-p_valPrio_TabA_Max_MotStart,0A ,123
ENG175392-ENG332263-MQB-p_valPrio_TabA_Max_Ssu,0A ,123
ENG175392-ENG332264-MQB-p_valPrio_TabAVerbrFeld_0,01 ,123
ENG175392-ENG332265-MQB-p_valPrio_TabAVerbrFeld_1,02 ,123
ENG175392-ENG332266-MQB-p_valPrio_TabAVerbrFeld_2,08 ,123
ENG175392-ENG332267-MQB-p_valPrio_TabAVerbrFeld_3,04 ,123
ENG175392-ENG332268-MQB-p_valPrio_TabAVerbrFeld_4,05 ,123
ENG175392-ENG332269-MQB-p_valPrio_TabAVerbrFeld_5,05 ,123
ENG175392-ENG332270-MQB-p_valPrio_TabAVerbrFeld_6,05 ,123
ENG175392-ENG332271-MQB-p_valPrio_TabAVerbrFeld_7,06 ,123
ENG175392-ENG332272-MQB-p_valPrio_TabAVerbrFeld_8,03 ,123
ENG175392-ENG332273-MQB-p_valPrio_TabAVerbrFeld_9,09 ,123
ENG175392-ENG332274-MQB-p_valPrio_TabBMax,05 ,123
ENG175392-ENG332275-MQB-p_valPrio_TabBVerbrFeld_0,01 ,123
ENG175392-ENG332276-MQB-p_valPrio_TabBVerbrFeld_1,02 ,123
ENG175392-ENG332277-MQB-p_valPrio_TabBVerbrFeld_2,02 ,123
ENG175392-ENG332278-MQB-p_valPrio_TabBVerbrFeld_3,03 ,123
ENG175392-ENG332279-MQB-p_valPrio_TabBVerbrFeld_4,03 ,123
ENG175392-ENG332280-MQB-p_valPrio_TabBVerbrFeld_5,04 ,123
ENG175392-ENG332281-MQB-p_valPrio_TabBVerbrFeld_6,05 ,123
ENG175392-ENG332282-MQB-p_valPrio_TabBVerbrFeld_7,05 ,123
ENG175392-ENG332283-MQB-p_valPrio_TabBVerbrFeld_8,05 ,123
ENG175392-ENG332284-MQB-p_valPrio_TabBVerbrFeld_9,FF ,123
ENG175392-ENG332285-MQB-p_valPrio_TabCMax,01 ,123
ENG175392-ENG332286-MQB-p_valPrio_TabCVerbrFeld_0,01 ,123
ENG175392-ENG332287-MQB-p_valPrio_TabCVerbrFeld_1,01 ,123
ENG175392-ENG332288-MQB-p_valPrio_TabCVerbrFeld_2,01 ,123
ENG175392-ENG332289-MQB-p_valPrio_TabCVerbrFeld_3,01 ,123
ENG175392-ENG332290-MQB-p_valPrio_TabCVerbrFeld_4,01 ,123
ENG175392-ENG332291-MQB-p_valPrio_TabCVerbrFeld_5,01 ,123
ENG175392-ENG332292-MQB-p_valPrio_TabCVerbrFeld_6,01 ,123
ENG175392-ENG332293-MQB-p_valPrio_TabCVerbrFeld_7,01 ,123
ENG175392-ENG332294-MQB-p_valPrio_TabCVerbrFeld_8,01 ,123
ENG175392-ENG332295-MQB-p_valPrio_TabCVerbrFeld_9,FF ,123
ENG175392-ENG332296-MQB-p_valPrio_TabDMax,02 ,123
ENG175392-ENG332297-MQB-p_valPrio_TabDVerbrFeld_0,01 ,123
ENG175392-ENG332298-MQB-p_valPrio_TabDVerbrFeld_1,01 ,123
ENG175392-ENG332299-MQB-p_valPrio_TabDVerbrFeld_2,01 ,123
ENG175392-ENG332300-MQB-p_valPrio_TabDVerbrFeld_3,01 ,123
ENG175392-ENG332301-MQB-p_valPrio_TabDVerbrFeld_4,01 ,123
ENG175392-ENG332302-MQB-p_valPrio_TabDVerbrFeld_5,01 ,123
ENG175392-ENG332303-MQB-p_valPrio_TabDVerbrFeld_6,01 ,123
ENG175392-ENG332304-MQB-p_valPrio_TabDVerbrFeld_7,01 ,123
ENG175392-ENG332305-MQB-p_valPrio_TabDVerbrFeld_8,01 ,123
ENG175392-ENG332306-MQB-p_valPrio_TabDVerbrFeld_9,FF ,123
ENG175392-ENG332307-MQB-p_valPrio_TabEMax,01 ,123
ENG175392-ENG332308-MQB-p_valPrio_TabFMax,09 ,123
ENG175392-ENG332309-MQB-p_valPrio_TabFVerbrFeld_0,01 ,123
ENG175392-ENG332310-MQB-p_valPrio_TabFVerbrFeld_1,02 ,123
ENG175392-ENG332311-MQB-p_valPrio_TabFVerbrFeld_2,03 ,123
ENG175392-ENG332312-MQB-p_valPrio_TabFVerbrFeld_3,03 ,123
ENG175392-ENG332313-MQB-p_valPrio_TabFVerbrFeld_4,03 ,123
ENG175392-ENG332314-MQB-p_valPrio_TabFVerbrFeld_5,04 ,123
ENG175392-ENG332315-MQB-p_valPrio_TabFVerbrFeld_6,05 ,123
ENG175392-ENG332316-MQB-p_valPrio_TabFVerbrFeld_7,06 ,123
ENG175392-ENG332317-MQB-p_valPrio_TabFVerbrFeld_8,07 ,123
ENG175392-ENG332318-MQB-p_valPrio_TabFVerbrFeld_9,FF ,123
ENG175392-ENG332319-MQB-p_valPrio_TabKVerbrFeld_0,02 ,123
ENG175392-ENG332320-MQB-p_valPrio_TabKVerbrFeld_1,01 ,123
ENG175392-ENG332321-MQB-p_valPrio_TabKVerbrFeld_2,03 ,123
ENG175392-ENG332322-MQB-p_valPrio_TabKVerbrFeld_3,03 ,123
ENG175392-ENG332323-MQB-p_valPrio_TabKVerbrFeld_4,04 ,123
ENG175392-ENG332324-MQB-p_valPrio_TabKVerbrFeld_5,06 ,123
ENG175392-ENG332325-MQB-p_valPrio_TabKVerbrFeld_6,07 ,123
ENG175392-ENG332326-MQB-p_valPrio_TabKVerbrFeld_7,05 ,123
ENG175392-ENG332327-MQB-p_valPrio_TabKVerbrFeld_8,FF ,123
ENG175392-ENG332328-MQB-p_valPrio_TabKVerbrFeld_9,FF ,123
ENG175392-ENG332329-MQB-p_valPrioTabAVerbrFeld_A,0A ,123
ENG175392-ENG332330-MQB-p_valPrioTabAVerbrFeld_B,07 ,123
ENG175392-ENG332331-MQB-p_valPrioTabAVerbrFeld_C,07 ,123
ENG175392-ENG332332-MQB-p_valPrioTabAVerbrFeld_D,FF ,123
ENG175392-ENG332333-MQB-p_valPrioTabAVerbrFeld_E,FF ,123
ENG175392-ENG332334-MQB-p_valPrioTabAVerbrFeld_F,FF ,123
ENG122979-MAS00075-Networking-ABS Control Module,installed ,8
ENG122979-MAS00798-Networking-Transmission Control Module (TCM),installed ,8
ENG122979-MAS01374-Networking-Trailer,not installed ,8
ENG122979-MAS03175-Networking-Extended data bus,not installed ,8
ENG122979-MAS09880-Networking-Interval potentiometer,installed ,8
ENG122979-MAS09882-Networking-MFA button on BCM,not installed ,8
ENG122979-MAS10518-Networking-A/C electronics,installed ,8
ENG122979-MAS10570-Networking-Window lift type,MQB_window_regulator ,8
ENG122979-ENG149007-Networking-Door LIN,installed ,8
ENG122979-ENG252084-Networking-KL30_weckfaehig,wakable ,8
ENG122979-ENG149008-Networking-Roof LIN,installed ,8
ENG122979-ENG149009-Networking-Sounder LIN,not installed ,8
ENG122979-ENG149010-Networking-Wiper LIN,not installed ,8
ENG307639-ENG298123-NFZ-p_t_Anf_Entr_Sbt_Timeout,10.0 s,18
ENG307639-ENG332095-NFZ-p_t_CargoLock_Taster_Init,300 ms,18
ENG307639-ENG332096-NFZ-p_t_CargoLock_Taster_Pulsdauer,20 ms,18
ENG307639-ENG298128-NFZ-p_t_KiSi_Fkt_Bel_Timeout,600 s,18
ENG307639-ENG298130-NFZ-p_t_Sbt_Verzoegerung_Nachverriegelung,0 ms,18
ENG307639-ENG298132-NFZ-p_t_ZV_eKiSi_gesperrt,300 ms,18
ENG307639-ENG298134-NFZ-p_t_ZV_FFB_Schiebetuer_Verzoegerung,1000 ms,18
ENG307639-ENG259515-NFZ-p_t_ZV_Heckschloss_Rastenansteuerung_Mindestaktivzeit,600 ms,18
ENG307639-ENG298136-NFZ-p_t_ZV_OBW_EOE_ansteuerzeit_motor,250 ms,18
ENG307639-ENG298137-NFZ-p_t_ZV_OBW_EOE_bremsen_motor,0 ms,18
ENG307639-ENG298139-NFZ-p_t_ZV_OBWr_Crash_ansteuerzeit_motor,250 ms,18
ENG307639-ENG332218-NFZ-p_t_ZV_OBWr_Crash_bremsen_motor,0 ms,18
ENG307639-ENG298140-NFZ-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor,70 ms,18
ENG307639-ENG298141-NFZ-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor_max,90 ms,18
ENG307639-ENG298142-NFZ-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor_min,60 ms,18
ENG307639-ENG298143-NFZ-p_t_ZV_OBWr_KiSiSafe_bremsen_motor,20 ms,18
ENG307639-ENG298144-NFZ-p_t_ZV_OBWr_KiSiSafe_verzoegerte_ansteuerung,200 ms,18
ENG307639-ENG298145-NFZ-p_t_ZV_OBWr_KiSiSafe_warten_motor,500 ms,18
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG331910-OCU-OCU_Vernetzung,installed ,8
ENG124714-ENG179221-OCU-Remote Lock Unlock Timer s0,15 s,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,30 s,8
ENG124714-ENG179222-OCU-Remote Lock Unlock Timer s2,15 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,1000 ms,8
ENG124714-ENG179223-OCU-Remote Lock Unlock Timer s4,15 s,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG124714-ENG154722-OCU-RHF_Panikalarm,active ,8
ENG148906-ENG331912-other-p_abblend_schluss_positionslicht_bei_kl15_ein,01 ,31
ENG148906-ENG331925-other-p_CAN_LIN_PQ35,0 ,31
ENG148906-ENG331928-other-p_diagnose_spoctreiber,5 ,31
ENG148906-ENG331931-other-p_einausstieg_cupholder,1 ,31
ENG148906-ENG331933-other-p_einausstieg_itafel,1 ,31
ENG148906-ENG331980-other-p_inszenierung_zwischenwert_innenlicht,100.0 %,31
ENG148906-ENG331996-other-p_Mute_Mode_aktiv,0 ,31
ENG148906-ENG331997-other-p_Mute_Mode_aktiv_redundant,0.0 %,31
ENG148906-ENG259755-other-p_n_lichtnotlauf_test,50 ,31
ENG148906-ENG259582-other-p_NL_Standby_Aus_Schwelle,0.1 ,31
ENG148906-ENG259546-other-p_NL_Standby_Ein_Schwelle,0.5 ,31
ENG148906-ENG332083-other-p_t_Ambienteverzoegerung_1,0.25 s,31
ENG148906-ENG332084-other-p_t_Ambienteverzoegerung_2,0.25 s,31
ENG148906-ENG332085-other-p_t_Ambienteverzoegerung_3,0.25 s,31
ENG148906-ENG332086-other-p_t_Ambienteverzoegerung_4,0.25 s,31
ENG148906-ENG332087-other-p_t_Ambienteverzoegerung_5,0.25 s,31
ENG148906-ENG332090-other-p_t_ARA_aktiv_max,10 min,31
ENG148906-ENG332091-other-p_t_ARA_sp_betätigt_max,60 s,31
ENG148906-ENG260624-other-p_t_CAN_Boot,0.50 s,31
ENG148906-ENG260113-other-p_t_erkennung_stillstand,200 ms,31
ENG148906-ENG260518-other-p_t_Handbremse_CAN,0.60 s,31
ENG148906-ENG332152-other-p_t_Knockout_tmr,20 min,31
ENG148906-ENG259529-other-p_t_NL_Standby_Filter,4.0 s,31
ENG148906-ENG260139-other-p_t_QRS_start,60 s,31
ENG148906-ENG260781-other-p_t_spannungsfehler,5 s,31
ENG148906-ENG258133-other-p_t_Timeout_Cnt,70 min,31
ENG148906-ENG332211-other-p_t_Zeitfenster_zweiter_ZV_Befehl,2 s,31
ENG148906-ENG332253-other-p_v_ARA_aktiv_max,15 km/h,31
ENG148906-ENG258283-other-p_v_erkennung_fahrt,1.0 km/h,31
ENG148906-ENG332256-other-p_v_maximalgeschwindigkeit,250 km/h,31
ENG148906-ENG261062-other-p_wbt_debug,0.0 %,31
ENG307679-Parameter Zulieferer,00 00 00 00 01 00 09 00 01 00 00 00 00 00 AA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,256
ENG148614-ENG148862-Patch_code_driver-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG148614-ENG148865-Patch_code_driver-Parameter_2,53 9F ,128
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,53 9F ,128
ENG148615-ENG148862-Patch_code_passenger-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG148615-ENG148865-Patch_code_passenger-Parameter_2,53 9F ,128
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,53 9F ,128
ENG98831-ENG260882-Personalization-p_t_FT_auf,50 ms,4
ENG98831-ENG259921-Personalization-p_t_PSO_MAD,10 s,4
ENG98831-ENG258281-Personalization-p_t_PSO_Schluesselerkennung,5 s,4
ENG98831-ENG258533-Personalization-p_t_PSO_verz,1000 ms,4
ENG141646-MAS00481-Querschnitts_funktionen-BAP,active ,5
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-MAS04194-Querschnitts_funktionen-Driver side,Left ,5
ENG141646-MAS10509-Querschnitts_funktionen-Traffic,Right ,5
ENG141646-MAS10511-Querschnitts_funktionen-Personalization transfer,installed ,5
ENG141646-MAS10527-Querschnitts_funktionen-Tracking System,not active ,5
ENG141646-ENG252090-Querschnitts_funktionen-anhaengerrangierassistent,not active ,5
ENG141646-ENG149084-Querschnitts_funktionen-CAN_Wecken_bei_Softtouchbetaetigung,active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG149085-Querschnitts_funktionen-Klemmenfehler_auf_CAN_ausgeben,active ,5
ENG141646-ENG126575-Querschnitts_funktionen-mute_mode_aktiv,not active ,5
ENG141646-ENG148952-Querschnitts_funktionen-P_locked,installed ,5
ENG141646-ENG125011-Querschnitts_funktionen-pa_Funktion_2aus3,installed ,5
ENG307638-ENG332080-Rear-p_swapHauptrasteVorraste,1 ,16
ENG307638-ENG260848-Rear-p_t_Freigabe_Softtouch,120 s,16
ENG307638-ENG332115-Rear-p_t_Freigabe_Softtouch_nach_ext_Verriegelung,120 s,16
ENG307638-ENG332116-Rear-p_t_Freigabe_Softtouch_nach_kl15_aus,10 s,16
ENG307638-ENG332162-Rear-p_t_max_s3_zzh_schalter(SWC-ZK: ZV_tHDZZHTimeout_AV),2.0 s,16
ENG307638-ENG332208-Rear-p_t_waitResettingSpring,3000 ms,16
ENG307638-ENG332209-Rear-p_t_Wartezeit_Ansteuerung_nach _Schliessung_GR-Heckklappe,6000 ms,16
ENG307638-ENG332212-Rear-p_t_ZH_Position_Grosse_Heckklappe_Freigabe_Timeout,10000 ms,16
ENG307638-ENG332213-Rear-p_t_ZH_Verkopplungselemente_Timeout,4000 ms,16
ENG307638-ENG258894-Rear-p_t_ZV_Freigabenachlauf_Heck_nach_Einzeloeffnung,20 s,16
ENG307638-ENG259998-Rear-p_t_ZV_HDSG_max_Rücklaufzeit,3.0 s,16
ENG307638-ENG332217-Rear-p_t_ZV_HeckSchloss_Verzoegerung,1250 ms,16
ENG307638-ENG332222-Rear-p_t_zzh_motor_abschalt,50 ms,16
ENG307638-ENG260605-Rear-p_t_zzh_motor_AnsteurungMax,3000 ms,16
ENG307638-ENG259985-Rear-p_v_Freigabe_Innenbetaetigung_Hecksecurity,5 km/h,16
ENG307638-ENG259010-Rear-p_v_Servoheck_Programmierung_Oeffnungshoehe_quittieren,2 km/h,16
ENG152427-ENG332126-Rear window defogger-p_t_HSH_Anzeigevorleistung,1000 ms,7
ENG152427-ENG332127-Rear window defogger-p_t_HSH_Kundenwunsch_Speicherdauer,900 s,7
ENG152427-ENG332128-Rear window defogger-p_t_HSH_Longpush,2.0 s,7
ENG152427-ENG332129-Rear window defogger-p_t_HSH_Longpush_Feedback,1000 ms,7
ENG152427-ENG332130-Rear window defogger-p_t_HSH_Taster_haengt,20 s,7
ENG152427-ENG332225-Rear window defogger-p_temp_HSH_defrost,4.0 °C,7
ENG152427-ENG332242-Rear window defogger-p_u_DeltaSpg_HeckscheibenHzg,100 mV,7
ENG179054-ENG179160-RLFS_ZF_TRW-p_n_1st_wipe_threshold,100 %,12
ENG179054-ENG179161-RLFS_ZF_TRW-p_n_highspeed_wipe_threshold,100 %,12
ENG179054-ENG179162-RLFS_ZF_TRW-p_n_interval_wipe_threshold,100 %,12
ENG179054-ENG179163-RLFS_ZF_TRW-p_n_LIN_Filter,3 ,12
ENG179054-ENG179164-RLFS_ZF_TRW-p_n_permanent_wipe_threshold,100 %,12
ENG179054-ENG179165-RLFS_ZF_TRW-p_n_RsEmergencyReducePercent,10 %,12
ENG179054-ENG179166-RLFS_ZF_TRW-p_t_ParkPosition_SpeedReset,1300 ms,12
ENG179054-ENG179167-RLFS_ZF_TRW-p_t_ParkPosition_WipeTimeout,1000 ms,12
ENG179054-ENG263513-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Cycle,2.0 s,12
ENG179054-ENG263511-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Delay,4.0 s,12
ENG179054-ENG179170-RLFS_ZF_TRW-p_t_tunnel_wipe_delay,6 s,12
ENG179054-ENG179171-RLFS_ZF_TRW-p_t_tunnel_wipe_window,15 s,12
ENG179054-ENG179172-RLFS_ZF_TRW-pa_lx_tunnel_light_on,1100 ,12
ENG179054-ENG179173-RLFS_ZF_TRW-pa_n_wisch_max_2,2 ,12
ENG179054-ENG179174-RLFS_ZF_TRW-pa_t_tunnel_delay_decrement,30 s,12
ENG179054-ENG179175-RLFS_ZF_TRW-pa_t_tunnel_delay_max,120 s,12
ENG179054-ENG179176-RLFS_ZF_TRW-Pa_t_tunnel_delay_on,1800 ms,12
ENG179054-ENG179177-RLFS_ZF_TRW-pa_t_tunnel_delay_step,5 s,12
ENG179054-ENG179178-RLFS_ZF_TRW-pa_v_RsActivationSpeed,5 km/h,12
ENG179054-ENG179179-RLFS_ZF_TRW-pa_v_wisch_max_1,20 km/h,12
ENG179054-ENG179180-RLFS_ZF_TRW-pa_v_wisch_max_2,4 km/h,12
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-IDE05534-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG149254-Scheinwerferreinigung-Adaptives_Nachwischen_bei_SRA,active ,10
ENG115729-ENG149255-Scheinwerferreinigung-Anzahl_Betaetigungen_Frontwaschanlage_pro_SRA_Aktivierung,10 ,10
ENG115729-ENG149253-Scheinwerferreinigung-SRA_bei_Waschwassermangel,active ,10
ENG115729-ENG149258-Scheinwerferreinigung-SRA_Einweichpausenzeit,2000 ms,10
ENG115729-ENG149259-Scheinwerferreinigung-SRA_Nachwaschzeit,800 ms,10
ENG115729-ENG149260-Scheinwerferreinigung-SRA_Pausenzeit,10000 ms,10
ENG115729-ENG149256-Scheinwerferreinigung-SRA_Verzoegerungszeit,0 ms,10
ENG115729-ENG149257-Scheinwerferreinigung-SRA_Waschzeit,800 ms,10
ENG115729-ENG148897-Scheinwerferreinigung-windshield_washer_system,not installed ,10
ENG307682-ENG331916-Schlossansteuerungen-p_Anzahl_wiederholter_Heckschlossansteuerung,10 ,25
ENG307682-ENG260965-Schlossansteuerungen-p_t_Ansteuer_Laderaumabdeckung_Freigabemotor,400 ms,25
ENG307682-ENG258807-Schlossansteuerungen-p_t_ansteuer_pausenzeit_einmotorenschloss,350 ms,25
ENG307682-ENG258584-Schlossansteuerungen-p_t_ansteuerzeit_einmotorenschloss,250 ms,25
ENG307682-ENG332089-Schlossansteuerungen-p_t_Ansteuerzeit_ZV_Motor,40 ms,25
ENG307682-ENG260089-Schlossansteuerungen-p_t_bremszeit_einmotorenschloss,100 ms,25
ENG307682-ENG260413-Schlossansteuerungen-p_t_Versatz_Schlossansteuerung_Fahrerseite_Beifahrerseite,0 ms,25
ENG307682-ENG260583-Schlossansteuerungen-p_t_Versatz_Schlossansteuerung_Fahrertuer_Heckdeckel,0 ms,25
ENG307682-ENG260313-Schlossansteuerungen-p_t_Versatz_Schlossansteuerung_Fahrertuer_Tankdeckel,0 ms,25
ENG307682-ENG259469-Schlossansteuerungen-p_t_Versatz_Schlossansteuerung_Fondtueren,0 ms,25
ENG307682-ENG332206-Schlossansteuerungen-p_t_Verzögerung_vor_wiederholter_Heckansteuerung,500 ms,25
ENG307682-ENG332214-Schlossansteuerungen-p_t_ZH_Zuziehhilfe_Timeout,4000 ms,25
ENG307682-ENG259480-Schlossansteuerungen-p_t_ZV_ansteuer_wiederholzeit,100 ms,25
ENG307682-ENG260528-Schlossansteuerungen-p_t_ZV_ansteuerzeit_motor,150 ms,25
ENG307682-ENG260542-Schlossansteuerungen-p_t_ZV_bremsen_motor,50 ms,25
ENG307682-ENG258149-Schlossansteuerungen-p_t_ZV_delay_safeLatch,100 ms,25
ENG307682-ENG332215-Schlossansteuerungen-p_t_ZV_Heckscheibenschloss_ansteuern,400 ms,25
ENG307682-ENG332216-Schlossansteuerungen-p_t_ZV_Heckscheibenschloss_rastengesteuert,1250 ms,25
ENG307682-ENG258429-Schlossansteuerungen-p_t_ZV_Heckschloss_Einraste_Impuls,600 ms,25
ENG307682-ENG261064-Schlossansteuerungen-p_t_ZV_Heckschloss_Einrasten_Timeout,1250 ms,25
ENG307682-ENG260591-Schlossansteuerungen-p_t_ZV_Heckschloss_Zweirasten_Impuls,600 ms,25
ENG307682-ENG258459-Schlossansteuerungen-p_t_ZV_Heckschloss_Zweirasten_Timeout,1250 ms,25
ENG307682-ENG258717-Schlossansteuerungen-p_t_ZV_Servoheck_Impuls,600 ms,25
ENG307682-ENG259886-Schlossansteuerungen-p_t_ZV_Servoheck_Timeout,1250 ms,25
ENG307682-ENG332220-Schlossansteuerungen-p_t_ZV_Tankschloss_ansteuern,400 ms,25
ENG307685-ENG331936-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_1,100 mA,50
ENG307685-ENG331937-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_10,1000 mA,50
ENG307685-ENG331938-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_11,1000 mA,50
ENG307685-ENG331939-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_12,250 mA,50
ENG307685-ENG331940-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_13,250 mA,50
ENG307685-ENG331941-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_14,250 mA,50
ENG307685-ENG331942-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_15,50 mA,50
ENG307685-ENG331943-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_16,50 mA,50
ENG307685-ENG331944-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_17,50 mA,50
ENG307685-ENG331945-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_18,100 mA,50
ENG307685-ENG331946-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_19,100 mA,50
ENG307685-ENG331947-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_2,100 mA,50
ENG307685-ENG331948-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_20,100 mA,50
ENG307685-ENG331949-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_21,200 mA,50
ENG307685-ENG331950-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_22,250 mA,50
ENG307685-ENG331951-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_23,1000 mA,50
ENG307685-ENG331952-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_24,100 mA,50
ENG307685-ENG331953-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_25,100 mA,50
ENG307685-ENG331954-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_26,250 mA,50
ENG307685-ENG331955-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_27,200 mA,50
ENG307685-ENG331956-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_28,50 mA,50
ENG307685-ENG331957-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_3,1000 mA,50
ENG307685-ENG331958-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_32,50 mA,50
ENG307685-ENG331959-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_33,70 mA,50
ENG307685-ENG331960-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_34,50 mA,50
ENG307685-ENG331961-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_35,50 mA,50
ENG307685-ENG331962-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_37,50 mA,50
ENG307685-ENG331963-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_38,50 mA,50
ENG307685-ENG331964-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_39,50 mA,50
ENG307685-ENG331965-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_40,50 mA,50
ENG307685-ENG331966-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_42,50 mA,50
ENG307685-ENG331967-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_43,50 mA,50
ENG307685-ENG331968-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_44,50 mA,50
ENG307685-ENG331969-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_45,50 mA,50
ENG307685-ENG331970-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_48,1000 mA,50
ENG307685-ENG331971-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_49,1000 mA,50
ENG307685-ENG331972-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_51,50 mA,50
ENG307685-ENG331973-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_7,50 mA,50
ENG307685-ENG331974-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_8,200 mA,50
ENG307685-ENG331975-Sense-Werte für Lampendiagnose-p_I_OL_Schwelle_Lasttyp_9,500 mA,50
ENG307685-ENG332040-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_16,127500 ,50
ENG307685-ENG332041-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_17,127500 ,50
ENG307685-ENG332042-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_18,127500 ,50
ENG307685-ENG332043-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_19,127500 ,50
ENG307685-ENG332044-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_20,127500 ,50
ENG307685-ENG332045-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_21,127500 ,50
ENG307685-ENG332046-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_22,127500 ,50
ENG307685-ENG332047-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_24,127500 ,50
ENG307685-ENG332048-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_26,127500 ,50
ENG307685-ENG332049-Sense-Werte für Lampendiagnose-p_P_TA_Schwelle_Lasttyp_27,127500 ,50
ENG116588-MAS10520-Sonderfunktionen-Special function 1,not installed ,4
ENG116588-ENG273845-Sonderfunktionen-Blinkerueberwachung_MFG,not installed ,4
ENG116588-ENG130186-Sonderfunktionen-Signalprioritaet_fuer_Blinker,SMLS ,4
ENG116588-ENG126568-Sonderfunktionen-Sonderfunktionen_2,not enabled ,4
ENG307688-ENG332088-Sonstiges 2-p_t_Ambienteverzoegerung6,0.25 s,20
ENG307688-ENG332164-Sonstiges 2-p_t_nachlauf_heck,10 s,20
ENG307688-ENG253465-Sonstiges 2-p_U_nenn,13.0 V,20
ENG307688-ENG332335-Sonstiges 2-p_warnblinktaster_dimmwert,100 %,20
ENG141635-ENG149220-Spiegelverstellung-Funk_Spiegelanklappen,active ,5
ENG141635-ENG149221-Spiegelverstellung-Funk_Spiegelanklappung_Modus,by_look_command_via_remote_control_key ,5
ENG141635-ENG149219-Spiegelverstellung-Menue__Spiegel_absenkung,active ,5
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,active ,5
ENG141635-ENG149043-Spiegelverstellung-only_ECU_FHSG_Driver_side,not installed ,5
ENG141635-ENG149223-Spiegelverstellung-Profilfunktion_fuer_Anklappung_der_Aussenspiegel,active ,5
ENG141635-ENG155908-Spiegelverstellung-Spiegel_ausklappen_ueber_FFB_auf,active ,5
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,active ,5
ENG141635-ENG149224-Spiegelverstellung-Spiegelanklappung_geschwindigkeitsabhaengig,active ,5
ENG141635-ENG149041-Spiegelverstellung-window_regulator_node_adress,getauscht ,5
ENG307689-ENG331929-Spielschutz / Crash / Nachlauf /Sonstiges-p_Dimmung_dritte_Bremsleuchte_Endphase,100.0 %,29
ENG307689-ENG331930-Spielschutz / Crash / Nachlauf /Sonstiges-p_Dimmung_dritte_Bremsleuchte_Umstellphase,50.0 %,29
ENG307689-ENG331989-Spielschutz / Crash / Nachlauf /Sonstiges-p_l_Caddy_Drehfalle_Signal,00000000  ,29
ENG307689-ENG331998-Spielschutz / Crash / Nachlauf /Sonstiges-p_n_Crashentriegelungen_max,10 ,29
ENG307689-ENG332004-Spielschutz / Crash / Nachlauf /Sonstiges-p_n_Heckdeckel_spielschutz,22 ,29
ENG307689-ENG332009-Spielschutz / Crash / Nachlauf /Sonstiges-p_n_reakt_lock_unlock_door,8 ,29
ENG307689-ENG332010-Spielschutz / Crash / Nachlauf /Sonstiges-p_n_reakt_lock_unlock_hd,20 ,29
ENG307689-ENG332012-Spielschutz / Crash / Nachlauf /Sonstiges-p_n_Safety_Shell_Override,00 ,29
ENG307689-ENG332031-Spielschutz / Crash / Nachlauf /Sonstiges-p_n_Spielschutz_Drehfallenmot_Akt,10 ,29
ENG307689-ENG332032-Spielschutz / Crash / Nachlauf /Sonstiges-p_n_Spielschutz_Drehfallenmot_Deakt,8 ,29
ENG307689-ENG332038-Spielschutz / Crash / Nachlauf /Sonstiges-p_n_zv_spielschutz,10 ,29
ENG307689-ENG332039-Spielschutz / Crash / Nachlauf /Sonstiges-p_n_zzh_spielschutz,20 ,29
ENG307689-ENG332097-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_Crashdeaktivierung_HD_Bedienstellen,5 s,29
ENG307689-ENG332098-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_crasherkennung_timeout,3000 ms,29
ENG307689-ENG332099-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_Crashverzoegerung_ZV_Entriegelung,5 s,29
ENG307689-ENG332102-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_Dimmung_dritte_Bremsleuchte_Betaetigungspuls_t1,200 ms,29
ENG307689-ENG332103-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_Dimmung_dritte_Bremsleuchte_Betaetigungspuls_t2,0 ms,29
ENG307689-ENG258353-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_Notschliessen_Verzoegerung,5000 ms,29
ENG307689-ENG259705-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_OCU_HuF_timer_max,30 s,29
ENG307689-ENG260109-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_SAFE_LED_Hellphase,40 ms,29
ENG307689-ENG332182-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_Senden_Spiegelanklappung,0 s,29
ENG307689-ENG332219-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_ZV_Quittierungsblinken_Aktivierungszeit,200 ms,29
ENG307689-ENG258535-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_ZV_Timeout_Front_TSG_Botschaft,200 ms,29
ENG307689-ENG332221-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_ZV_verriegeln_kl_15_ein,1.0 s,29
ENG307689-ENG260802-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_ZV_Wiederveriegelung,45000 ms,29
ENG307689-ENG258197-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_ZV_Zeitfenster_bew_entsafen,2000 ms,29
ENG307689-ENG259545-Spielschutz / Crash / Nachlauf /Sonstiges-p_t_ZV_Zeitfenster_global_entriegeln,5000 ms,29
ENG307689-ENG332251-Spielschutz / Crash / Nachlauf /Sonstiges-p_v_ Grenze_Spiegelanklappung,40 km/h,29
ENG307689-ENG259704-Spielschutz / Crash / Nachlauf /Sonstiges-p_v_Autolock,15 km/h,29
ENG253125-ENG260641-SRA-p_sra_bcm_temperaturgrenze,80 °C,7
ENG253125-ENG260115-SRA-p_sra_geschwindigkeitsgrenze,140 km/h,7
ENG253125-ENG259607-SRA-p_sra_nach_t_frontwaschendauer,2000 ms,7
ENG253125-ENG259677-SRA-p_sra_obere_aussentemperaturgrenze,36 °C,7
ENG253125-ENG261148-SRA-p_sra_untere_aussentemperaturgrenze,-11 °C,7
ENG253125-ENG332185-SRA-p_t_sra_betaetigungspause,10.0 s,7
ENG253125-ENG260015-SRA-p_t_sra_ueberlast,30 s,7
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 lx,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 lx,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 lx,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 lx,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 lx,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 ,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 ,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 ,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 ,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 ,10
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 lx,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 lx,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 lx,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 lx,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 lx,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 ,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 ,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 ,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 ,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 ,10
ENG141632-MAS10512-Sunroof-Sunroof module MD1,not installed ,4
ENG141632-MAS10513-Sunroof-Sunroof module MD shade,not installed ,4
ENG141632-ENG149217-Sunroof-SAD_Komfort_oeffnen,not active ,4
ENG141632-ENG149216-Sunroof-SAD_Komfort_schliessen,not active ,4
ENG141632-ENG149215-Sunroof-SAD_Richtung_Komfortoeffnen,tilting ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG307640-ENG259970-Terminal activation-p_mindestgeschwindigkeit_ausrollen,4 km/h,8
ENG307640-ENG259629-Terminal activation-p_t_ausrollEnde,1.0 s,8
ENG307640-ENG332113-Terminal activation-p_t_ERR_KL_74_Notlauf,2550 ms,8
ENG307640-ENG332148-Terminal activation-p_t_Klemme_15_Entprellung,10 ms,8
ENG307640-ENG332149-Terminal activation-p_t_Klemme_50_Wert_halten_bei_KomFehler,10 s,8
ENG307640-ENG332150-Terminal activation-p_t_Klemme_S_Entprellung,10 ms,8
ENG307640-ENG332151-Terminal activation-p_t_Klemme_X_Entprellung,40 ms,8
ENG307640-ENG332254-Terminal activation-p_v_Fehler_Anf_Klemme_X,10 km/h,8
ENG307700-ENG259564-Transportmodus 2-p_Transportmodus_Hzg,11111111  ,3
ENG307700-ENG261114-Transportmodus 2-p_Transportmodus_Licht,11111110  ,3
ENG307700-ENG332235-Transportmodus 2-p_Transportmodus_Licht_2,11111101  ,3
ENG248473-ENG261749-Türen HBFS-pa_NFZ_Funktion_HBFS_1,not active ,2
ENG248473-ENG248779-Türen HBFS-pa_Schiebetür_HBFS,No ,2
ENG248473-ENG248781-Türen HBFS-pa_schlosstyp_HBFS,No ,2
ENG248473-ENG248785-Türen HBFS-pa_tuerkontaktmodul_hbfs,ohne TKM ,2
ENG248474-ENG261743-Türen HFS-pa_NFZ_Funktion_HFS_1,not active ,2
ENG248474-ENG248780-Türen HFS-pa_Schiebetür_HFS,No ,2
ENG248474-ENG248783-Türen HFS-pa_schlosstyp_HFS,No ,2
ENG248474-ENG248786-Türen HFS-pa_tuerkontaktmodul_hfs,ohne TKM ,2
ENG252990-ENG259895-Turn signal control-p_level_crasherkennung,1 ,26
ENG252990-ENG298118-Turn signal control-p_n_eRWK_Abbruchblinken_Blinkzyklen,3 ,26
ENG252990-ENG298119-Turn signal control-p_n_eRWK_Mindestanzahl_Oeffnungsblinken,2 ,26
ENG252990-ENG259007-Turn signal control-p_NWB_Mindestblinkzyklen,0 ,26
ENG252990-ENG298121-Turn signal control-p_t_Abbruchblinken_eRWK_Hellphase,50 %,26
ENG252990-ENG298122-Turn signal control-p_t_Abbruchblinken_eRWK_Periodendauer,330 ms,26
ENG252990-ENG259266-Turn signal control-p_t_crashblinken_aus_zeit,0.400 s,26
ENG252990-ENG260080-Turn signal control-p_t_crashblinken_ein_zeit,0.400 s,26
ENG252990-ENG298125-Turn signal control-p_t_eRWK_Oeffnungsblinken_Hellphase,50 %,26
ENG252990-ENG298127-Turn signal control-p_t_eRWK_Oeffnungsblinken_Periodendauer,1000 ms,26
ENG252990-ENG260852-Turn signal control-p_t_PreCrash_timer_max,7 s,26
ENG252990-ENG260907-Turn signal control-p_t_RECAS_blk_aus_zeit,0.150 s,26
ENG252990-ENG261143-Turn signal control-p_t_RECAS_blk_ein_zeit,0.150 s,26
ENG252990-ENG261137-Turn signal control-p_t_RECAS_timer_max,7 s,26
ENG252990-ENG258208-Turn signal control-p_t_richtungsblinken_aus_zeit,0.400 s,26
ENG252990-ENG260254-Turn signal control-p_t_richtungsblinken_ein_zeit,0.400 s,26
ENG252990-ENG259427-Turn signal control-p_t_warnblinken_klemme_15_dunkel_zeit_1,0.400 s,26
ENG252990-ENG259711-Turn signal control-p_t_warnblinken_klemme_15_dunkel_zeit_2,0.400 s,26
ENG252990-ENG260940-Turn signal control-p_t_warnblinken_klemme_15_hell_zeit_1,0.400 s,26
ENG252990-ENG260044-Turn signal control-p_t_warnblinken_klemme_15_hell_zeit_2,0.400 s,26
ENG252990-ENG260159-Turn signal control-p_t_warnblinken_klemme_30_dunkel_zeit_1,0.400 s,26
ENG252990-ENG259466-Turn signal control-p_t_warnblinken_klemme_30_dunkel_zeit_2,0.400 s,26
ENG252990-ENG258173-Turn signal control-p_t_warnblinken_klemme_30_hell_zeit_1,0.400 s,26
ENG252990-ENG260879-Turn signal control-p_t_warnblinken_klemme_30_hell_zeit_2,0.400 s,26
ENG252990-ENG258975-Turn signal control-p_v_NBA_WBL_uebergang,10 km/h,26
ENG148611-MAS10548-Verbau Personalisierung-Profile function,Key profile ,8
ENG148611-ENG252096-Verbau Personalisierung-Aktiver_Teilnehmer_Doorlocking_aktiviert,not active ,8
ENG148611-ENG252051-Verbau Personalisierung-Aktiver_Teilnehmer_ExteriorLight_aktiviert,not active ,8
ENG148611-ENG252071-Verbau Personalisierung-Aktiver_Teilnehmer_InteriorLight_aktiviert,not active ,8
ENG148611-ENG252085-Verbau Personalisierung-Aktiver_Teilnehmer_Mirror_aktiviert,not active ,8
ENG148611-ENG252072-Verbau Personalisierung-Aktiver_Teilnehmer_WiperComfort_aktiviert,not active ,8
ENG148611-ENG126849-Verbau Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,8
ENG148611-ENG133401-Verbau Personalisierung-Anzahl_Benutzerkonten,7 ,8
ENG148611-ENG133402-Verbau Personalisierung-Automatische_ Schluesselzuordnung,active ,8
ENG148611-ENG126850-Verbau Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,8
ENG148611-ENG246970-Verbau Personalisierung-IAA -Nutzer_management,not installed ,8
ENG148611-ENG246991-Verbau Personalisierung-pa_Two_Keys,not active ,8
ENG148611-ENG126848-Verbau Personalisierung-Personalisierung_aktiv,active ,8
ENG148611-ENG126851-Verbau Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,8
ENG148611-ENG142030-Verbau Personalisierung-Profil_Variante,Schluessel ,8
ENG148611-ENG133403-Verbau Personalisierung-PSO_FSG_Setup2_Bit_0,active ,8
ENG148611-ENG133404-Verbau Personalisierung-PSO_FSG_Setup2_Bit_1,active ,8
ENG148611-ENG133405-Verbau Personalisierung-PSO_FSG_Setup2_Bit_2,not active ,8
ENG148611-ENG133406-Verbau Personalisierung-PSO_FSG_Setup2_Bit_3,not active ,8
ENG148611-ENG133407-Verbau Personalisierung-PSO_FSG_Setup2_Bit_4,not active ,8
ENG148611-ENG133408-Verbau Personalisierung-PSO_FSG_Setup2_Bit_5,not active ,8
ENG148611-ENG133409-Verbau Personalisierung-PSO_FSG_Setup2_Bit_6,not active ,8
ENG148611-ENG133410-Verbau Personalisierung-PSO_FSG_Setup2_Bit_7,not active ,8
ENG307701-Verdecksteuerung Zeiten,0.40 s,1
ENG148610-ENG148877-Vernetzungs-_Diagnosefunktionen-can_msg_1,00 00 ,20
ENG148610-ENG148878-Vernetzungs-_Diagnosefunktionen-can_msg_2,00 00 ,20
ENG148610-ENG148879-Vernetzungs-_Diagnosefunktionen-can_msg_3,00 00 ,20
ENG148610-ENG148880-Vernetzungs-_Diagnosefunktionen-can_msg_4,00 00 ,20
ENG148610-ENG148881-Vernetzungs-_Diagnosefunktionen-lin_msg_1,00 00 ,20
ENG148610-ENG148882-Vernetzungs-_Diagnosefunktionen-lin_msg_2,00 00 ,20
ENG148610-ENG148883-Vernetzungs-_Diagnosefunktionen-lin_msg_3,00 00 ,20
ENG148610-ENG148884-Vernetzungs-_Diagnosefunktionen-lin_msg_4,00 00 ,20
ENG148610-ENG148885-Vernetzungs-_Diagnosefunktionen-lin_msg_5,00 00 ,20
ENG148610-ENG148886-Vernetzungs-_Diagnosefunktionen-lin_msg_6,00 00 ,20
ENG307702-ENG258954-Wakeup-Grenzwerte-p_wup_lim_10,0A ,39
ENG307702-ENG260875-Wakeup-Grenzwerte-p_wup_lim_11,0A ,39
ENG307702-ENG260998-Wakeup-Grenzwerte-p_wup_lim_12,0A ,39
ENG307702-ENG260004-Wakeup-Grenzwerte-p_wup_lim_13,FF ,39
ENG307702-ENG260639-Wakeup-Grenzwerte-p_wup_lim_14,FF ,39
ENG307702-ENG260390-Wakeup-Grenzwerte-p_wup_lim_15,32 ,39
ENG307702-ENG259115-Wakeup-Grenzwerte-p_wup_lim_16,32 ,39
ENG307702-ENG258245-Wakeup-Grenzwerte-p_wup_lim_17,32 ,39
ENG307702-ENG332337-Wakeup-Grenzwerte-p_wup_lim_18,32 ,39
ENG307702-ENG259444-Wakeup-Grenzwerte-p_wup_lim_19,32 ,39
ENG307702-ENG332338-Wakeup-Grenzwerte-p_wup_lim_2,0A ,39
ENG307702-ENG258538-Wakeup-Grenzwerte-p_wup_lim_20,32 ,39
ENG307702-ENG260809-Wakeup-Grenzwerte-p_wup_lim_21,32 ,39
ENG307702-ENG258396-Wakeup-Grenzwerte-p_wup_lim_22,32 ,39
ENG307702-ENG332339-Wakeup-Grenzwerte-p_wup_lim_23,32 ,39
ENG307702-ENG259094-Wakeup-Grenzwerte-p_wup_lim_24,32 ,39
ENG307702-ENG260253-Wakeup-Grenzwerte-p_wup_lim_25,32 ,39
ENG307702-ENG259940-Wakeup-Grenzwerte-p_wup_lim_26,32 ,39
ENG307702-ENG259369-Wakeup-Grenzwerte-p_wup_lim_27,32 ,39
ENG307702-ENG258961-Wakeup-Grenzwerte-p_wup_lim_28,0A ,39
ENG307702-ENG258920-Wakeup-Grenzwerte-p_wup_lim_29,32 ,39
ENG307702-ENG332340-Wakeup-Grenzwerte-p_wup_lim_3,400 ,39
ENG307702-ENG258557-Wakeup-Grenzwerte-p_wup_lim_30,32 ,39
ENG307702-ENG260586-Wakeup-Grenzwerte-p_wup_lim_31,FE ,39
ENG307702-ENG259180-Wakeup-Grenzwerte-p_wup_lim_33,32 ,39
ENG307702-ENG259002-Wakeup-Grenzwerte-p_wup_lim_36,FF ,39
ENG307702-ENG332341-Wakeup-Grenzwerte-p_wup_lim_37,FF ,39
ENG307702-ENG260430-Wakeup-Grenzwerte-p_wup_lim_38,FF ,39
ENG307702-ENG259953-Wakeup-Grenzwerte-p_wup_lim_39,FF ,39
ENG307702-ENG258122-Wakeup-Grenzwerte-p_wup_lim_4,0A ,39
ENG307702-ENG258825-Wakeup-Grenzwerte-p_wup_lim_40,0A ,39
ENG307702-ENG260887-Wakeup-Grenzwerte-p_wup_lim_41,0A ,39
ENG307702-ENG260496-Wakeup-Grenzwerte-p_wup_lim_42,0A ,39
ENG307702-ENG260283-Wakeup-Grenzwerte-p_wup_lim_43,0A ,39
ENG307702-ENG260215-Wakeup-Grenzwerte-p_wup_lim_5,FF ,39
ENG307702-ENG258659-Wakeup-Grenzwerte-p_wup_lim_6,0A ,39
ENG307702-ENG258771-Wakeup-Grenzwerte-p_wup_lim_7,0A ,39
ENG307702-ENG258811-Wakeup-Grenzwerte-p_wup_lim_8,0A ,39
ENG307702-ENG258511-Wakeup-Grenzwerte-p_wup_lim_9,0A ,39
ENG253060-ENG259934-Wascherpumpe-p_n_Spielschutz_Wascherpumpen,10 ,3
ENG253060-ENG258230-Wascherpumpe-p_t_Delay_Frontwaschen,0 ms,3
ENG253060-ENG260892-Wascherpumpe-p_t_DWP_Blockiererkennung,100 ms,3
ENG148612-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_1,10 F5 00 00 50 00 B0 FF 00 00 1A FF AC FE 0C FE 70 FE 10 FF 1A FF EC FF BC 02 D4 03 58 02 58 02 00 00 B0 04 00 14 C4 E7 00 CE D8 C1 00 00 00 00 12 00 0A 04 23 01 02 06 01 02 1E 4B 96 DC 01 02 05 01 02 05 06 03 03 64 3C 00 03 0A 14 3C 37 28 0F 00 0A D0 07 90 01 C4 09 C4 09 00 06 0C 12 18 1E 20 22 24 26 28 2A 36 3A 3C 3E 44 4A 54 5A 60 6E 7C 84 92 A0 AA B4 BE C8 D2 00 00 00 00 ,128
ENG148612-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_2,40 F5 ,128
ENG148613-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_1,00 18 FC 70 FE 00 00 32 00 00 00 32 00 AA AA 99 99 88 00 00 00 00 00 00 00 00 00 00 00 3C 00 A6 FF 04 08 04 06 58 1B E8 03 00 DC 84 58 02 FB FA F9 F7 1D 3F 00 01 02 03 04 05 B8 0B 01 9A 58 4E 64 0A 37 4B 55 5F 69 5D 60 62 65 01 0B 5A 0B 0B 06 3C 46 5A 28 F6 FF F4 01 90 01 F4 01 50 00 14 00 00 00 00 7F 00 97 00 05 07 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG148613-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_2,22 3F ,128
ENG130135-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_1,F8 2A 64 00 31 52 14 2B 06 13 00 05 02 AE 6E 64 1E 32 0D 1B 05 0C 00 04 46 70 0C C8 06 DC 05 DC 05 50 50 02 02 06 0A 50 64 82 F8 19 07 11 0F 00 46 70 1E 32 0D 1B 05 0C 00 04 6E AE 31 52 14 2B 06 13 00 05 6E AE 31 52 14 2B 06 13 00 05 6E AE 31 52 14 2B 06 13 00 05 00 0A 50 02 F0 DC 05 DC 05 0A 0B 2C 01 2C 01 64 1C 4B 14 00 0A 00 1C 64 C8 E6 01 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130135-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_2,D1 4C ,128
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,DE F4 00 00 EC FF BA FF 00 00 88 FF D4 FE 70 FE E0 FC 06 FF FC FE EC FF 58 02 E4 02 58 02 58 02 00 00 B0 04 00 14 BA D8 00 F6 00 C1 00 00 00 00 14 00 0A 04 23 01 00 06 01 02 28 50 8C DC 01 02 03 01 02 04 05 03 05 64 3C 00 02 09 19 3C 2D 28 0F 00 05 14 05 2C 01 B8 0B C4 09 00 08 0A 0C 10 10 12 14 16 18 18 1B 1E 21 24 27 33 3D 47 51 57 6F 87 9B B7 CB CD CF D1 D2 CA 00 00 00 00 ,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,4F 9A ,128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,00 18 FC 18 FC 18 FC 5A 00 00 00 32 00 AA AA 99 99 88 00 00 00 00 00 00 00 00 00 00 00 3C 00 60 FF 06 0A 05 06 20 1C 20 03 01 01 00 CC 4C 58 02 03 FB FA F9 F7 1E 7F 0A 01 02 03 04 05 46 70 1E 32 0D 1B 05 0C 00 04 41 B4 05 28 00 28 B8 0B 01 9A 58 4E 64 0A 37 4B 55 5F 69 5D 60 62 65 01 5A 0B 0B 06 3C 50 5A 28 F6 FF BC 02 2C 01 F4 01 EC FF 14 00 00 00 00 7F 00 07 00 00 00 00 00 ,128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,66 0E ,128
ENG130138-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_1,10 F5 00 00 50 00 B0 FF 00 00 1A FF AC FE 0C FE 70 FE 10 FF 1A FF EC FF BC 02 D4 03 58 02 58 02 00 00 B0 04 00 14 C4 E7 00 CE D8 C1 00 00 00 00 12 00 0A 04 23 01 02 06 01 02 1E 4B 96 DC 01 02 05 01 02 05 06 03 03 64 3C 00 03 0A 14 3C 37 28 0F 00 0A D0 07 90 01 C4 09 C4 09 00 06 0C 12 18 1E 20 22 24 26 28 2A 36 3A 3C 3E 44 4A 54 5A 60 6E 7C 84 92 A0 AA B4 BE C8 D2 00 00 00 00 ,128
ENG130138-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_2,40 F5 ,128
ENG130139-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_1,00 18 FC 70 FE 00 00 32 00 00 00 32 00 AA AA 99 99 88 00 00 00 00 00 00 00 00 00 00 00 3C 00 A6 FF 04 08 04 06 58 1B E8 03 00 DD 84 58 02 FB FA F9 F7 1F 3F 00 01 02 03 04 05 46 70 1E 32 0D 1B 05 0C 00 04 B8 0B 01 9A 58 4E 64 0A 37 4B 55 5F 69 5D 60 62 65 01 5A 0B 0B 06 3C 46 5A 28 F6 FF F4 01 90 01 F4 01 50 00 14 00 00 00 00 7F 00 97 00 05 07 0A 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_2,34 43 ,128
ENG130140-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_1,88 13 DC 05 F8 2A 64 00 31 52 14 2B 06 13 00 04 04 AE 8D 64 1E 32 0C 1B 03 0B 00 02 60 64 0C C8 06 DC 05 DC 05 50 50 02 02 06 0A 50 64 82 F8 19 07 11 0F 00 50 02 F0 DC 05 DC 05 0A 0B 2C 01 2C 01 64 1C 4B 14 00 0A 00 1C 64 C8 E6 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_2,A4 52 ,128
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,DE F4 00 00 EC FF BA FF 00 00 88 FF D4 FE 70 FE E0 FC 06 FF FC FE EC FF 58 02 E4 02 2C 01 58 02 00 00 B0 04 00 14 BA D8 00 F6 00 C1 00 00 00 00 14 00 0A 04 23 02 00 06 01 02 28 50 8C DC 01 02 03 01 02 04 05 03 05 64 3C 00 02 09 19 3C 2D 28 0F 00 05 14 05 2C 01 B8 0B C4 09 00 08 0A 0C 10 10 12 14 16 18 18 1B 1E 21 24 27 33 3D 47 51 57 6F 87 9B B7 CB CD CF D1 D2 CA 00 00 00 00 ,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,F5 C2 ,128
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,00 18 FC 18 FC 18 FC 5A 00 00 00 32 00 AA AA 99 99 88 00 00 00 00 00 00 00 00 00 00 00 3C 00 60 FF 06 0A 05 06 20 1C 20 03 01 01 00 CD 4C 58 02 03 FB FA F9 F7 1C 7F 0A 01 02 03 04 05 46 70 1E 32 0D 1B 05 0C 00 04 41 B4 05 28 00 28 B8 0B 01 9A 58 4E 64 0A 37 4B 55 5F 69 5D 60 62 65 01 5A 0B 0B 06 3C 50 5A 28 F6 FF BC 02 2C 01 F4 01 EC FF 14 00 00 00 00 7F 00 07 01 00 00 00 00 ,128
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,63 E4 ,128
ENG124895-Window_Regulator_VW_Settings_Driver_Side,0C 08 14 00 14 00 2D 19 0F E8 03 28 28 00 C8 2A 32 32 03 FF 01 1E 8A 02 F4 01 B0 04 00 1E 0A 01 00 00 00 00 00 00 00 00 00 00 00 97 0F 0F C8 14 64 63 0B 05 02 00 A3 9E 14 01 48 B7 52 AD 64 14 05 01 05 0B 0F 0A 1E 0F 3C 50 01 01 19 19 0F 00 01 00 01 C8 00 14 00 01 41 B4 3C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 00 00 00 00 32 47 30 31 00 B8 38 ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,0C 14 00 14 00 19 0F 64 00 08 F8 02 2D 1C 1C 02 F4 01 B0 04 1E 0A 00 C8 28 00 32 32 00 00 00 00 00 00 00 00 00 A4 A4 00 05 3C 14 20 4E 58 4D 0B 0A 0A 05 4B A3 55 9E 64 14 05 01 05 48 B7 52 AD 64 14 05 01 05 02 00 00 32 47 30 32 FF 00 00 00 00 00 00 00 00 00 74 DE ,88
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,0C 08 14 00 14 00 2D 19 0F E8 03 28 28 00 C8 2A 32 32 03 FF 01 1E 8A 02 F4 01 B0 04 00 1E 0A 01 00 00 00 00 00 00 00 00 00 00 00 A6 05 05 C8 14 64 63 0B 05 02 00 A3 9E 14 01 48 B7 52 AD 64 14 05 01 05 0B 0F 0A 1E 0F 3C 50 01 01 0D 24 0F 01 07 00 01 C8 00 14 00 01 41 B4 3C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 00 00 00 00 32 47 30 31 00 E6 16 ,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,0C 14 00 14 00 19 0F 64 00 08 F8 02 2D 1C 1C 02 F4 01 B0 04 1E 0A 00 C8 28 00 32 32 00 00 00 00 00 00 00 00 00 A6 A6 00 05 3C 14 20 4E 58 4D 0B 00 00 05 4B A3 55 9E 64 14 05 01 05 48 B7 52 AD 64 14 05 01 05 02 00 00 32 47 30 32 FF 00 00 00 00 00 00 00 00 00 5E D6 ,88
ENG307704-ENG258253-Wischer_steuerung_Anzahl-p_n_maxAdaptiveNachwischzyklen,02 ,6
ENG307704-ENG260171-Wischer_steuerung_Anzahl-p_n_nach_kurz,01 ,6
ENG307704-ENG258335-Wischer_steuerung_Anzahl-p_n_nach_lang,02 ,6
ENG307704-ENG332033-Wischer_steuerung_Anzahl-p_n_unplausibel_Wischfrequenz,14 ,6
ENG307704-ENG332036-Wischer_steuerung_Anzahl-p_n_wischfrequenz_min_stufe_1,14 ,6
ENG307704-ENG332037-Wischer_steuerung_Anzahl-p_n_wischfrequenz_min_stufe_2,28 ,6
ENG307705-Wischer_steuerung_Faktoren,0A ,1
ENG307706-ENG261299-Wischer_steuerung_Geschwindigkeiten-p_v_frontwasch,120 km/h,7
ENG307706-ENG261306-Wischer_steuerung_Geschwindigkeiten-p_v_inf,4 km/h,7
ENG307706-ENG259155-Wischer_steuerung_Geschwindigkeiten-p_v_rs_aktiv,4 km/h,7
ENG307706-ENG260808-Wischer_steuerung_Geschwindigkeiten-p_v_service_1,4 km/h,7
ENG307706-ENG261323-Wischer_steuerung_Geschwindigkeiten-p_v_service_2,12 km/h,7
ENG307706-ENG260544-Wischer_steuerung_Geschwindigkeiten-p_v_sup,12 km/h,7
ENG307706-ENG258897-Wischer_steuerung_Geschwindigkeiten-p_v_traenen,4 km/h,7
ENG307707-Wischer_steuerung_Termperaturen,-25.0 °C,1
ENG307708-ENG332082-Wischer_steuerung_Zeiten-p_t_Abtauposition_Ansteuerung,100 ms,15
ENG307708-ENG332094-Wischer_steuerung_Zeiten-p_t_bremsdelay_Parklage,0 ms,15
ENG307708-ENG332118-Wischer_steuerung_Zeiten-p_t_Frontwischer_Timeout_WEnd,5000 ms,15
ENG307708-ENG332161-Wischer_steuerung_Zeiten-p_t_limitNachwischen,500 ms,15
ENG307708-ENG332163-Wischer_steuerung_Zeiten-p_t_nachlauf_front,10 s,15
ENG307708-ENG332165-Wischer_steuerung_Zeiten-p_t_notlauf,180 s,15
ENG307708-ENG332166-Wischer_steuerung_Zeiten-p_t_obere_Wendelage,750 ms,15
ENG307708-ENG332170-Wischer_steuerung_Zeiten-p_t_plausi_Nockenkontakt,10 s,15
ENG307708-ENG332173-Wischer_steuerung_Zeiten-p_t_rueck_int,4 s,15
ENG307708-ENG332174-Wischer_steuerung_Zeiten-p_t_rueck_min,4 s,15
ENG307708-ENG332200-Wischer_steuerung_Zeiten-p_t_tippwaschen,5000 ms,15
ENG307708-ENG332202-Wischer_steuerung_Zeiten-p_T_traenen,5 s,15
ENG307708-ENG332203-Wischer_steuerung_Zeiten-p_t_traenen_aus,10 s,15
ENG307708-ENG332205-Wischer_steuerung_Zeiten-p_t_verlasseServiceposition,300 ms,15
ENG307708-ENG332210-Wischer_steuerung_Zeiten-p_t_WWS_warnentprellung,10 s,15
ENG253269-ENG259168-Wischfrequenzen-p_wischfrequenz_stufe_1,42 /min,4
ENG253269-ENG259671-Wischfrequenzen-p_wischfrequenz_stufe_2,62 /min,4
ENG253269-ENG258648-Wischfrequenzen-p_wischfrequenz_Stufe2_AUS,03 ,4
ENG253269-ENG258831-Wischfrequenzen-p_wischfrequenz_Stufe2_EIN,05 ,4
ENG141651-MAS10522-ZV allgemein-Lock/unlock: direct button,Rocker sw. ,5
ENG141651-MAS10546-ZV allgemein-Radio freq.,434.42MHz ,5
ENG141651-MAS10554-ZV allgemein-Central locking without SAFE function,installed ,5
ENG141651-ENG179102-ZV allgemein-Abgesichertes Safen,not active ,5
ENG141651-ENG252045-ZV allgemein-Anti_theft_alarm_diagnostic_connection_monitoring,not active ,5
ENG141651-ENG248507-ZV allgemein-Auswertung_Batt_TranspID_Telegramm,active ,5
ENG141651-ENG179106-ZV allgemein-Autolock_nur_bei_Motorlauf,not active ,5
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,5
ENG141651-ENG252065-ZV allgemein-FFB_Sbt_Entriegelt,No ,5
ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein,not active ,5
ENG141651-ENG179144-ZV allgemein-Kessy Wiederentriegelung mit Außenhaut,On ,5
ENG141651-ENG149181-ZV allgemein-Menuesteuerung_Tuerentriegelung,active ,5
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,5
ENG141651-ENG179092-ZV allgemein-Schlossansteuerung,all_doors_connected_directly ,5
ENG141651-ENG149384-ZV allgemein-seitenselektive_Oeffnung,No ,5
ENG141651-ENG149180-ZV allgemein-ZV_Tuerentriegelung,Globale_Entriegelung ,5
ENG141654-ENG149213-ZV Autolock-Autolock_Autounlock_wirkt_auf_Heck,active ,5
ENG141654-ENG149211-ZV Autolock-automatisches_Entriegeln,active ,5
ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit,active ,5
ENG141654-ENG149212-ZV Autolock-Autounlock_NAR,not active ,5
ENG141654-ENG149214-ZV Autolock-Menuesteuerung_ZV_Autolock-Unlock,adjustable ,5
ENG141655-ENG149225-ZV Crash-Heckdeckel-Bedienstellen_nachCrash_temporaer_sperren,active ,4
ENG141655-ENG149227-ZV Crash-SAD_PreCrash_Konturschliessen,active ,4
ENG141655-ENG149226-ZV Crash-ZV-Entriegelung_nach_Seitencrash,not active ,4
ENG141653-MAS07515-ZV Heck-Trunk lid remote unlocking: int. button,via_pin ,5
ENG141653-MAS10551-ZV Heck-Rear lid lock control,Contact control ,5
ENG141653-MAS10555-ZV Heck-Central locking: rear lock type,1 or 2 notch rear actuator ,5
ENG141653-MAS10561-ZV Heck-Rear lock with safety catch,Yes ,5
ENG141653-ENG149183-ZV Heck-Direkter_Auswurf_des_Heckdeckels,active ,5
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,5
ENG141653-ENG149185-ZV Heck-Freigabenachlauf_Heck_nach_Einzeloeffnung_ueber_HDF-Funktaster,not active ,5
ENG141653-ENG149187-ZV Heck-Hecksteuerung_ohne_ZV,not active ,5
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.6 s,5
ENG141653-ENG261746-ZV Heck-Rear_lock_control_min_aktiv,not active ,5
ENG141653-ENG126630-ZV Heck-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,5
ENG141653-ENG155905-ZV Heck-Softtouch_Auswertung,mit_180_Ohm ,5
ENG141653-ENG252095-ZV Heck-Zentralverrieglung_ohne_Heckdeckel,not active ,5
ENG141653-ENG149182-ZV Heck-ZV_entriegelt_auch_Heckdeckel,active ,5
ENG141653-ENG149184-ZV Heck-ZV_Heck_nur_direkt_auswerfen,not active ,5
ENG148616-IDE02021-ZV Komfort (Fensterheber)-Comfort closing,active ,7
ENG148616-IDE02022-ZV Komfort (Fensterheber)-Comfort opening,active ,7
ENG148616-MAS10525-ZV Komfort (Fensterheber)-Electrical window lift: front,active ,7
ENG148616-MAS10526-ZV Komfort (Fensterheber)-Electrical window left: rear,Yes ,7
ENG148616-ENG154964-ZV Komfort (Fensterheber)-BAP_Komfortschließen,active ,7
ENG148616-ENG248524-ZV Komfort (Fensterheber)-Busruhe_bei_Fensterheberfreigabenachlauf,not active ,7
ENG148616-ENG149202-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_oeffnen,active ,7
ENG148616-ENG149206-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_schliessen,active ,7
ENG148616-ENG149203-ZV Komfort (Fensterheber)-FH_SAD_Kl15Aus_Freigabezeit,60 s,7
ENG148616-ENG149196-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Kl_15_aus,active ,7
ENG148616-ENG149197-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Tueroeffnen,active ,7
ENG148616-ENG149201-ZV Komfort (Fensterheber)-Funk_Komfort_oeffnen,active ,7
ENG148616-ENG149205-ZV Komfort (Fensterheber)-Funk_Komfort_schliessen,active ,7
ENG148616-ENG155240-ZV Komfort (Fensterheber)-Kindersicherung_Beifahrerfenster,not active ,7
ENG148616-ENG149198-ZV Komfort (Fensterheber)-Komfortbedienung_global,active ,7
ENG148616-ENG149199-ZV Komfort (Fensterheber)-Komfortoeffnen_nur_FH_Fahrertuer,not active ,7
ENG148616-ENG155244-ZV Komfort (Fensterheber)-Komfortschliessen_Brasilien,active ,7
ENG148616-ENG149209-ZV Komfort (Fensterheber)-Manuelle_ZV_Variantenprogrammierung,not active ,7
ENG148616-ENG149207-ZV Komfort (Fensterheber)-Menuesteuerung_Komfortbedienung_einstellbar,adjustable ,7
ENG148616-ENG149200-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_oeffnen,active ,7
ENG148616-ENG149204-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_schliessen,active ,7
ENG141652-MAS01914-ZV Türkonfiguration-Type of lock,1 Motor locks without Safe (NAR locks) ,5
ENG141652-MAS06443-ZV Türkonfiguration-Lock cylinder passenger door,not installed ,5
ENG141652-MAS10567-ZV Türkonfiguration-Four-door,Yes ,5
ENG141652-ENG273805-ZV Türkonfiguration-schliesszylinderlogik_lbs,active ,5
ENG307709-ENG332404-ZV VIP-Virtuell_s_Pedel_VIP,not active ,2
ENG307709-ENG332405-ZV VIP-Virtuell_s_Pedel_VIP_HMI,not active ,2
ENG307709-ENG332406-ZV VIP-Virtuell_s_Pedel_VIP_KickAndClose,not active ,2
Elapsed Time: 01:58
adpmap-10-5QA-919-298-M_9BWCJ6CH7TP054606-20260720-0853.CSV
;SW:5QA-919-298-M   HW:5QA-919-298-A ---  10: Park/Steer Assist
;Component:PLA 3.0 12K   H12 0083, Coding:0271167851
;EV_EPHVA2CAU3700000,010060,EV_EPHVA2CAU3700000_010_VW37.rod
;Monday,20,July,2026,08:53:41:18837
;VCDS Version: 26.6.0.1 (x64)  Data version: 20260708 DS377.1
;VCID: 5AF874075D56EC4EAC-800E-R
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble,not activated ,1
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble,not activated ,1
IDE01167-Convertible offset for volume level 1,255 ,1
IDE01168-Increment for convertible volume levels,255 ,1
IDE01169-Audio lowering request,On ,1
IDE02328-Distance to curb,15 cm,1
IDE03782-Switch-off speed for parking assist,15 km/h,1
IDE03783-Switch-on speed for parallel parking assist,37 km/h,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE11215-Automatic Activation,activated ,1
IDE11217-Show parking space,Conditions not correct or request sequence error,1
IDE14666-Parking aid: personalization,activated ,1
MAS01426-Rear parking aid buzzer: volume,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 1 ,1
MAS01428-Front parking aid buzzer: volume,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 7 ,1
MAS07110-Muting of audio sources,not activated ,1
MAS12843-Maneuvering brake function,activated ,1
Elapsed Time: 00:09
adpmap-13-2Q0-907-567-C_9BWCJ6CH7TP054606-20260720-0853.CSV
;SW:2Q0-907-567-C   HW:2Q0-907-819 ---  13: Auto Dist. Reg
;Component:ACCCONTIMQB   H04 0541, Coding:300260C308FF8448949C810560308700000000000000008024
;EV_ACCMRRCONTIUNECEMQB,004021,EV_ACCMRRCONTIUNECEMQB_VW27.rod
;Monday,20,July,2026,08:53:54:18837
;VCID: 383CCE8F831A1E5E7A-806C-R SFD+SFD2 {x}
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01949-Distance basic setting option,OFF ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,On ,1
IDE08936-Misalignment angle: horiz,0.28 °,4
IDE09564-Distance change via speed adjustment,On ,1
IDE09565-Prioritized target object display,OFF ,1
IDE09906-Vertical deadjustment,-0.37 °,4
IDE10280-Constant delay after transfer request,No ,1
IDE11924-MAS13427-Correction angle-Horizontal correction angle: dynamic,0.00 °,12
IDE11924-MAS13428-Correction angle-Vertical correction angle: dynamic,0.00 °,12
IDE11924-MAS13429-Correction angle-Horizontal correction angle: currently,0.28 °,12
IDE11924-MAS13430-Correction angle-Vertical correction angle: currently,-0.90 °,12
IDE11924-MAS13887-Correction angle-Horizontal correction angle static,0.28 °,12
IDE11924-MAS13888-Correction angle-Vertical correction angle static,-0.37 °,12
IDE11926-MAS04910-Static calibration: preparation-Driving axis angle,-120 ',7
IDE11926-MAS13433-Static calibration: preparation-Lateral displacement of front axle,-400.00 mm,7
IDE11926-MAS13434-Static calibration: preparation-Lateral displacement of rear axle,-400.00 mm,7
IDE11926-MAS13435-Static calibration: preparation-Vertical lead angle,-5.00 °,7
IDE12516-Predictive speed limit regulation,not activated ,1
IDE13334-Reduced radar performance,38 ,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,00 00 ,2
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,0 ,2
MAS19336-Active participant function activated,activated ,1
Elapsed Time: 00:06
adpmap-15-2QB-959-655-E_9BWCJ6CH7TP054606-20260720-0854.CSV
;SW:2QB-959-655-E   HW:2QB-959-655-E ---  15: Airbags
;Component:VW22Airbag    016 0511, Coding:88CCC000000000007C5400CF000800000065
;EV_AirbaVW22BPAVW27X,001036,EV_AirbaVW22BPAVW27X.rod
;Monday,20,July,2026,08:54:05:18837
;VCID: 51EA932B00A0AF165D-8004-R
IDE05178-Conclude start of operation,locked ,1
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,not defined ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
MAS00975-IDE00947-Airbag adaptations-Rear driver head curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Rear passenger head curtain airbag igniter,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
MAS00975-IDE07192-Airbag adaptations-Thorax airbag igniter,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Front driver side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Front passenger side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger front airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger thorax airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00013-Airbag adaptations-Driver seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger seat belt tensioner igniter,activated ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00023-Airbag adaptations-Driver active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Front passenger active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key-operated switch,Airbag deactivation key switch installed ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupant detection passenger side,not defined ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter hood,not defined ,8
Elapsed Time: 00:06
adpmap-17-2G0-920-320-G_9BWCJ6CH7TP054606-20260720-0848.CSV
;SW:2G0-920-320-G   HW:2G0-920-320-G ---  17: Instruments
;Component:KOMBI         813 9129, Coding:042420086588000C0288224B5001000000001524
;EV_DashBoardVDDMQBA0,003063,EV_DashBoardVDDMQBA0_003_VW27.rod
;Monday,20,July,2026,08:48:41:18837
;VCID: 200C06EF3B8A769EA2-8074-R SFD+SFD2 {x}
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,348 km,3
IDE00342-ESI: Resetting ESI,Resetting ,1
IDE00343-Language variant,Portuguese (Brazil) ,1
IDE00500-Hour,8 H,1
IDE00501-Minute,43 min,1
IDE00502-Year,2026 yr,2
IDE00503-Month,7 Months,1
IDE00504-Day,19 d,1
IDE00510-ESI: distance driven from inspection,342 km,3
IDE00511-ESI: time from inspection,138 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,10000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,10000 km,2
IDE00514-ESI: maximum value of time between inspections,365 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00518-ESI: thermal load,0 km,2
IDE00819-Day counter,167 d,2
IDE01153-SIA: maximum value of distance to service,10000 km,2
IDE02489-Display depiction,Variant 1 ,1
IDE03329-Driving profiled for range remaining,12.2 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometres ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,litre ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Kilometers per liter ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,10000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,365 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,300 km,2
IDE03352-FIX: Time since last time-dependent inspection,138 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE05931-FIX: Reset value for next mileage-dependent inspection,10000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE06588-Ignition active message: actuator,Driver´s door ,1
IDE06922-No-voltage display,Not available ,1
IDE07161-temporary VIN,Conditions not correct or request sequence error,1
IDE12211-China variant,No ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12467-Tubes illustration,Variant 3 ,1
IDE12722-Driving profile display,Yes ,1
IDE13094-Tachometer end value,Variant 0 ,1
IDE13607-MAS16706-Lock display contents-List time out,0 s,9
IDE13981-Sport information profile,No display ,1
IDE14184-Active participant personalization,No ,1
IDE14220-Vehicle speed warning for India-,60 s,1
IDE14984-R Logo,no R logo ,1
IDE14986-ACC illustration China,No display ,1
IDE15073-ENG249922-Digital Key 3-number_of_repeats_of_authentication_of_central_locking,01 ,3
IDE15073-ENG249951-Digital Key 3-time_for_waiting_of_receive_of_message_MDK_ZV_Resp,01 F4 s,3
IDE15113-Shift exit warning,Car exit warning ,1
IDE15132-Activate/deactivate development messages via Ethernet,not active ,1
IDE16921-MAS01877-Standard color-Red,0 ,3
IDE16921-MAS01878-Standard color-Green,0 ,3
IDE16921-MAS01879-Standard color-Blue,0 ,3
IDE18987-Network switch-over,Ethernet ,1
IDE20710-Tire pressure monitoring display: concept switchover,Tyre_monitor_display_old_concept ,1
MAS00194----,Cluster/instrument cluster concept ,1
MAS01083-Country Variant,No ,2
MAS03555-Lap counter,Conditions not correct or request sequence error,1
MAS30638-Transport Layer Security (TLS): switchover of the main source,Static_key ,1
ENG114742-Activation of Development Messages,not active ,1
ENG302677-anzahl_tueren,4 Türen ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,8 l,1
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,14 ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,02 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,04 ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,32 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,01 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,01 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,03 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,06 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,28 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,01 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,01 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,03 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,06 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,28 ,12
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1,00 00 ,24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2,00 0A ,24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3,00 32 ,24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4,00 64 ,24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5,00 96 ,24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6,00 FD ,24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1,00 32 ,24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2,00 32 ,24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3,00 78 ,24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4,00 E6 ,24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5,01 F4 ,24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6,03 E8 ,24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1,00 00 ,24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2,00 0A ,24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3,00 32 ,24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4,00 64 ,24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5,00 96 ,24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6,00 FD ,24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1,00 0C ,24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2,00 0C ,24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3,00 23 ,24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4,00 46 ,24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5,01 F4 ,24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6,03 E8 ,24
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG316729-ESI_Maximum_mileage_to_next_service_ZDC,30000 km,2
ENG316730-ESI_Maximum_time_to_next_service_ZDC,730 d,2
ENG316731-ESI_Minimum_mileage_to_next_service_ZDC,15000 km,2
ENG316732-ESI_Minimum_time_to_next_service_ZDC,365 d,2
ENG316733-ESI_Oil_quality_ZDC,poor oil quality ,1
ENG316701-FIX_Maximum_distance_to_next_mileage_based_service_event_zdc,10000 km,2
ENG316702-FIX_Maximum_time_to_next_time_based_service_event_zdc,365 d,2
ENG316734-FIX_resetvalue_distance_to_next_mileage_based_service_events_ZDC,30000 km,2
ENG316735-FIX_resetvalue_time_to_next_mileage_based_service_events_ZDC,365 d,2
ENG251650-GPS_speed,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,auto_lowbeam_foglight ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG249798-MDK_coding-,00 ,8
ENG249799-ENG249828-MDK_parameter-AZK bConfig COV,00 ,36
ENG249799-ENG249829-MDK_parameter-AZK num Time resp KY,800 ms,36
ENG249799-ENG249830-MDK_parameter-AZK num Time resp MDK,800 ms,36
ENG249799-ENG249831-MDK_parameter-AZK num Time resp WFS,5000 ms,36
ENG249799-ENG249904-MDK_parameter-MDK num Time Zv Cmd High,200 ms,36
ENG249799-ENG249905-MDK_parameter-MDK num Time Zv Cmd Low,100 ms,36
ENG249799-ENG249929-MDK_parameter-Rep Cmd Apdu,01 ,36
ENG249799-ENG249930-MDK_parameter-Rep User Auth,01 ,36
ENG249799-ENG249944-MDK_parameter-Time Esm Aktiv,10 s,36
ENG249799-ENG249945-MDK_parameter-Time Out Mob Dev Key Cmd,30 s,36
ENG249799-ENG249946-MDK_parameter-Time Out Resp Apdu,500 s,36
ENG249799-ENG249947-MDK_parameter-Time Out Ticket Table,120 s,36
ENG249799-ENG249948-MDK_parameter-Time Out VTAN Dec,2 s,36
ENG249799-ENG249949-MDK_parameter-Time Out VTAN Resp,10 s,36
ENG249799-ENG249950-MDK_parameter-Time SKC1,15 s,36
ENG249799-ENG249953-MDK_parameter-Veh Arch,00 ,36
ENG249800-ENG249840-MDK_parameter_2-Dev Param 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG249800-ENG249841-MDK_parameter_2-Dev Param 2,14 02 32 32 32 32 32 32 02 C8 C8 05 0A 1E 64 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG153765-Second_digital_speed,No display ,1
ENG316738-SID_Maximum_mileage_to_next_oil_service_ZDC,10000 km,2
ENG316739-SID_Maximum_time_to_next_oil_service_ZDC,365 d,2
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,65 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:33
adpmap-19-3Q0-907-530-BF_9BWCJ6CH7TP054606-20260720-0849.CSV
;SW:3Q0-907-530-BF   HW:3Q0-907-530-BB ---  19: CAN Gateway
;Component:GW 2023 CLA   550 5585, Coding:0000808D0F00000000000000000000000000000000000300030000000001000000000000000000000000000000000000
;EV_GatewMQB2020Class,001001,EV_GatewMQB2020Class_VW27.rod
;Monday,20,July,2026,08:49:19:18837
;VCID: 74A43ABFDFF2BA3E96-8020 SFD+SFD2 {x}
IDE00001-MAS00170-Production mode-OBD,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS21169-Production mode-Park coordinator,Deactivating ,3
IDE00002-Transport mode,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259081-Activating and deactivating all development messages-BCmE_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG258247-Activating and deactivating all development messages-eASS_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG261332-Activating and deactivating all development messages-EHR_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG260014-Activating and deactivating all development messages-FoD_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG260247-Activating and deactivating all development messages-FPA_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG260571-Activating and deactivating all development messages-GW_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259210-Activating and deactivating all development messages-HD_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259946-Activating and deactivating all development messages-HV-EM_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259153-Activating and deactivating all development messages-IDS_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG258853-Activating and deactivating all development messages-KS_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG258958-Activating and deactivating all development messages-MFL_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG258567-Activating and deactivating all development messages-MKE_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG260849-Activating and deactivating all development messages-MV-EM_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259788-Activating and deactivating all development messages-NV-EM_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG260650-Activating and deactivating all development messages-OBDC_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG261321-Activating and deactivating all development messages-PaCo_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG261353-Activating and deactivating all development messages-RWB_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG258585-Activating and deactivating all development messages-SDA_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG258798-Activating and deactivating all development messages-SK1a_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG260530-Activating and deactivating all development messages-SK3_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259285-Activating and deactivating all development messages-SOK_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG258316-Activating and deactivating all development messages-SWaP_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259637-Activating and deactivating all development messages-VDC_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259338-Activating and deactivating all development messages-VKMS_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG259833-Activating and deactivating all development messages-WUM_development_CAN_messages,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE01211-Static current measuring mode,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,59 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB+ ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,1SY ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 ,2
IDE06530-Distance left for deactivation of static current measuring mode,Security access required;You should unlock SFD before attempting advanced functions.,4
IDE06541-Distance left for deactivation of transport mode,Security access required;You should unlock SFD before attempting advanced functions.,4
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE07160-Control module switch-off: switch-off time,20 min,2
IDE08220-Vehicle production mode,not active ,1
IDE10351-MAS10460-Message mirroring-Target bus,Security access required;You should unlock SFD before attempting advanced functions.,1
IDE10351-MAS21167-Message mirroring-Source bus,Security access required;You should unlock SFD before attempting advanced functions.,1
IDE10735-Number requests autonomous recharging,Security access required;You should unlock SFD before attempting advanced functions.,1
IDE13844-Distance left for deactivation of production mode,100 km,1
IDE14750-Deactivate all development messages,0 ,5
IDE15316-FoD Partner,Available ,1
IDE15331-Multifunction steering wheel extended adaptation,Configuration 4 ,3
IDE16611-Diagnosis filter: temporary deactivation,active ,1
MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,active ,5
MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,active ,5
MAS08072-ENG172201-Driving profile selection-FPA_Funktion,active ,5
MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,active ,5
MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,not active ,5
MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,not active ,5
MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,not active ,5
MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,not active ,5
MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,not active ,5
MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,not active ,5
MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,not active ,5
MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,not active ,5
MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,active ,5
MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,not active ,5
MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,not active ,5
MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,not active ,5
MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,active ,5
MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,not active ,5
MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,active ,5
MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,not active ,5
MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,not active ,5
MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,not active ,5
MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,not active ,5
MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,active ,5
MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,not active ,5
MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,active ,5
MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,not active ,5
MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,active ,5
MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,not active ,5
MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,not active ,5
MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,not active ,5
MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,active ,5
MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,not active ,5
MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,not active ,5
MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,not active ,5
MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,active ,5
MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,not active ,5
MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,active ,5
MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Rising slope ,5
MAS12667-SFT271901-Specified installation of sub-bus users-Generator,Yes ,4
MAS12667-SFT271921-Specified installation of sub-bus users-Multi-function steering wheel control module,Yes ,4
MAS12667-SFT271927-Specified installation of sub-bus users-Battery Monitoring Control Module,Yes ,4
MAS12667-SFT271977-Specified installation of sub-bus users-Inverter for socket,No ,4
MAS12667-SFT271986-Specified installation of sub-bus users-Analog clock,No ,4
MAS12667-SFT272175-Specified installation of sub-bus users-Control head driving profile,No ,4
MAS12667-SFT272190-Specified installation of sub-bus users-Steering Wheel Touch Recognition Control Module,Yes ,4
MAS16743-Alternator gear ratio,57 ,1
MAS23693-MAS18081-Drowsiness and attention detection-Test Mode,00 ,22
MAS23693-MAS20954-Drowsiness and attention detection-Function coding,01 ,22
MAS23693-ENG101808-Drowsiness and attention detection-Bytes 1-16,64 4C E0 00 00 02 80 69 00 20 00 00 00 00 00 00 ,22
SFT271921-IDE02583-Multi-function steering wheel control module-Steering wheel Tiptronic switch,installed ,3
SFT271921-IDE07856-Multi-function steering wheel control module-Terminal status,active with terminal 58 ,3
SFT271921-MAS02311-Multi-function steering wheel control module-Steering wheel heating button,not active ,3
SFT271921-MAS04733-Multi-function steering wheel control module-Two-stage,not active ,3
SFT271921-MAS06614-Multi-function steering wheel control module-Variant,ACC ,3
SFT271921-MAS09758-Multi-function steering wheel control module-Temperature sensor,not installed ,3
SFT271921-MAS10720-Multi-function steering wheel control module-Speed limiter,active ,3
SFT271921-MAS13892-Multi-function steering wheel control module-Platform,MQB ,3
SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,active ,3
SFT271921-MAS21171-Multi-function steering wheel control module-Distance regulation function query (FoD),activated ,3
SFT271921-MAS21172-Multi-function steering wheel control module-Travel Assist function query (FoD),automatic ,3
SFT271921-ENG262857-Multi-function steering wheel control module-Kombi_02_gueltig,invalid ,3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,not active ,12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,0 ,12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,0 ms,12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,0 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG137064-EM_requirement_cyclic_time_voltage_measurement,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253271-ENG259280-GW_Content_list-Bus_ID,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253271-ENG253458-GW_Content_list-Node_address,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253340-SFD_Testmode,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253268-MAS03173-TCR_bus_can-Powertrain data bus,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253268-MAS03174-TCR_bus_can-Comfort data bus,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253268-MAS03175-TCR_bus_can-Extended data bus,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253268-MAS03177-TCR_bus_can-Infotainment data bus,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253268-MAS03178-TCR_bus_can-Suspension data bus,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253268-MAS05686-TCR_bus_can-Data bus diagnostics,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253268-MAS12185-TCR_bus_can-Hybrid data bus,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253268-MAS16910-TCR_bus_can-Migration data bus,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253184-MAS03179-TCR_bus_lin-Local data bus 2,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253184-MAS03180-TCR_bus_lin-Local data bus,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253184-MAS05972-TCR_bus_lin-Local data bus 3,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG253184-MAS06525-TCR_bus_lin-Local data bus 4,Security access required;You should unlock SFD before attempting advanced functions.,12
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,10
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,10
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,10
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,10
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,10
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,10
ENG118773-ENG260551-WakeUpMonitor_Configuration-WakeUpMonitor_Start_WakeUp_Delay,1800 s,10
Elapsed Time: 00:19
adpmap-3C-2Q0-907-686-H_9BWCJ6CH7TP054606-20260720-0854.CSV
;SW:2Q0-907-686-H   HW:2Q0-907-686-H ---  3C: Lane Change
;Component:HRE_Master    H26 0320, Coding:56954640
;EV_HREHellaGen3MstrUNECE,001001,EV_HREHellaGen3MstrUNECE_VW27.rod
;Monday,20,July,2026,08:54:16:18837
;VCID: 3FCEA593A6342966BB-806A-R
Elapsed Time: 00:03
adpmap-44-2QD-909-144-F_9BWCJ6CH7TP054606-20260720-0854.CSV
;SW:2QD-909-144-F   HW:2QD-909-144-A ---  44: Steering Assist
;Component:EPS_ECU       420 4220, Coding:00000101010000010101020101000101000001010101
;EV_SteerAssisNSKGEN3MQB,003008,EV_SteerAssisNSKGEN3MQB_003_VW27.rod
;Monday,20,July,2026,08:54:23:18837
;VCID: 48DCBE4FF3FA6EDE0A-801C-R
IDE03724-Straight line running,Active: with learned value ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE06657-Steering angle: calculated,not active ,1
IDE06678-Pull compensation,Active: without learned value ,1
IDE09571-RPM monitoring,not active ,1
MAS09008-Plausibility check,active ,1
Elapsed Time: 00:03
adpmap-5F-2GM-035-180-L_9BWCJ6CH7TP054606-20260720-0854.CSV
;SW:2GM-035-180-L   HW:2GM-035-180-L ---  5F: Information Electr.
;Component:MU-R--R2      H03 0871, Coding:22703500000000000000000000000000000000000000000000
;EV_MUREGIO,001010,EV_MUREGIO.rod
;Monday,20,July,2026,08:54:30:18837
;VCID: 43C6A963CADC4D86DF-8016-R
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,manually ,1
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,255 ,121
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,255 ,121
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,255 ,121
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,255 ,121
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,255 ,121
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,255 ,121
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,255 ,121
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,255 ,121
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,255 ,121
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,255 ,121
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,255 ,121
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,255 ,121
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,255 ,121
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,255 ,121
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,255 ,121
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,255 ,121
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,255 ,121
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,255 ,121
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,255 ,121
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,255 ,121
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,255 ,121
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,255 ,121
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,255 ,121
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,255 ,121
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,255 ,121
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,255 ,121
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,255 ,121
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,255 ,121
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,255 ,121
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,255 ,121
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,255 ,121
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,255 ,121
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,255 ,121
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,255 ,121
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,255 ,121
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,255 ,121
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,255 ,121
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,255 ,121
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,255 ,121
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,255 ,121
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,255 ,121
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,255 ,121
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,255 ,121
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,255 ,121
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,255 ,121
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,255 ,121
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,255 ,121
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,255 ,121
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,37 ,121
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,37 ,121
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,37 ,121
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,37 ,121
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,37 ,121
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,37 ,121
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,37 ,121
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,37 ,121
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,37 ,121
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,37 ,121
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,37 ,121
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,37 ,121
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,37 ,121
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,37 ,121
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,37 ,121
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,37 ,121
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,37 ,121
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,37 ,121
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,37 ,121
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,37 ,121
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,37 ,121
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,37 ,121
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,37 ,121
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,37 ,121
IDE02502-Confirmation of installation change,FF FF ,2
IDE04300-ENG331904-Vehicle menu operation-menu_AirHeater,not activated ,256
IDE04300-ENG331905-Vehicle menu operation-menu_AirHeater_after_disclaimer,not activated ,256
IDE04300-ENG331906-Vehicle menu operation-menu_AirHeater_clamp_15_off,not activated ,256
IDE04300-ENG331907-Vehicle menu operation-menu_AirHeater_over_threshold_high,not activated ,256
IDE04300-ENG331908-Vehicle menu operation-menu_AirHeater_standstill,not activated ,256
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG297698-Vehicle menu operation-menu_BSIS,not activated ,256
IDE04300-ENG297699-Vehicle menu operation-menu_BSIS_after_disclaimer,not activated ,256
IDE04300-ENG297700-Vehicle menu operation-menu_BSIS_clamp_15_off,not activated ,256
IDE04300-ENG297701-Vehicle menu operation-menu_BSIS_over_threshold_high,not activated ,256
IDE04300-ENG297702-Vehicle menu operation-menu_BSIS_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,not activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,not activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,not activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,not activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,not activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,not activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,not activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,not activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,not activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,not activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG297703-Vehicle menu operation-menu_Doorlocking_2nd,not activated ,256
IDE04300-ENG297704-Vehicle menu operation-menu_Doorlocking_2nd_after_disclaimer,not activated ,256
IDE04300-ENG297705-Vehicle menu operation-menu_Doorlocking_2nd_clamp_15_off,not activated ,256
IDE04300-ENG297706-Vehicle menu operation-menu_Doorlocking_2nd_over_threshold_high,not activated ,256
IDE04300-ENG297707-Vehicle menu operation-menu_Doorlocking_2nd_standstill,not activated ,256
IDE04300-ENG302732-Vehicle menu operation-menu_DrivingDynamics,not activated ,256
IDE04300-ENG302733-Vehicle menu operation-menu_DrivingDynamics_after_disclaimer,not activated ,256
IDE04300-ENG302734-Vehicle menu operation-menu_DrivingDynamics_clamp_15_off,not activated ,256
IDE04300-ENG302735-Vehicle menu operation-menu_DrivingDynamics_over_threshold_high,not activated ,256
IDE04300-ENG302736-Vehicle menu operation-menu_DrivingDynamics_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,not activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,not activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,not activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,not activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG297708-Vehicle menu operation-menu_MOIS,not activated ,256
IDE04300-ENG297709-Vehicle menu operation-menu_MOIS_after_disclaimer,not activated ,256
IDE04300-ENG297710-Vehicle menu operation-menu_MOIS_clamp_15_off,not activated ,256
IDE04300-ENG297711-Vehicle menu operation-menu_MOIS_over_threshold_high,not activated ,256
IDE04300-ENG297712-Vehicle menu operation-menu_MOIS_standstill,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG405718-Vehicle menu operation-menu_Plug_and_Charge,not activated ,256
IDE04300-ENG405719-Vehicle menu operation-menu_Plug_and_Charge_after_disclaimer,not activated ,256
IDE04300-ENG405720-Vehicle menu operation-menu_Plug_and_Charge_clamp_15_off,not activated ,256
IDE04300-ENG405721-Vehicle menu operation-menu_Plug_and_Charge_over_threshold_high,not activated ,256
IDE04300-ENG405722-Vehicle menu operation-menu_Plug_and_Charge_standstill,not activated ,256
IDE04300-ENG395156-Vehicle menu operation-menu_PowerOnDemand,not activated ,256
IDE04300-ENG395157-Vehicle menu operation-menu_PowerOnDemand_after_disclaimer,not activated ,256
IDE04300-ENG395158-Vehicle menu operation-menu_PowerOnDemand_clamp_15_off,not activated ,256
IDE04300-ENG395159-Vehicle menu operation-menu_PowerOnDemand_over_threshold_high,not activated ,256
IDE04300-ENG395160-Vehicle menu operation-menu_PowerOnDemand_standstill,not activated ,256
IDE04300-ENG302737-Vehicle menu operation-menu_RollingAbility,not activated ,256
IDE04300-ENG302738-Vehicle menu operation-menu_RollingAbility_after_disclaimer,not activated ,256
IDE04300-ENG302739-Vehicle menu operation-menu_RollingAbility_clamp_15_off,not activated ,256
IDE04300-ENG302740-Vehicle menu operation-menu_RollingAbility_over_threshold_high,not activated ,256
IDE04300-ENG302741-Vehicle menu operation-menu_RollingAbility_standstill,not activated ,256
IDE04300-ENG297713-Vehicle menu operation-menu_RushhourPilot,not activated ,256
IDE04300-ENG297714-Vehicle menu operation-menu_RushhourPilot_after_disclaimer,not activated ,256
IDE04300-ENG297715-Vehicle menu operation-menu_RushhourPilot_clamp_15_off,not activated ,256
IDE04300-ENG297716-Vehicle menu operation-menu_RushhourPilot_over_threshold_high,not activated ,256
IDE04300-ENG297717-Vehicle menu operation-menu_RushhourPilot_standstill,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,not activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Terminal 15 ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,Infotainment data bus ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,Infotainment data bus ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,not activated ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,not activated ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG324690-Vehicle function list BAP-California_0x81,not activated ,256
IDE04307-ENG331873-Vehicle function list BAP-California_0x81_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,not activated ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Comfort data bus ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Comfort data bus ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,not activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,not activated ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Comfort data bus ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,not activated ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,Comfort data bus ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,not activated ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,not activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,not activated ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,not activated ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,not activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,Comfort data bus ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Comfort data bus ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,not activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,not activated ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,not activated ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,not activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,not activated ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,not activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort data bus ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Extended data bus ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Comfort data bus ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,not activated ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,256
IDE04307-ENG345841-Vehicle function list BAP-MobDevKey_0x77,not activated ,256
IDE04307-ENG345842-Vehicle function list BAP-MobDevKey_0x77_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,not activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,not activated ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG325104-Vehicle function list BAP-Plug_and_charge_0x80,not activated ,256
IDE04307-ENG395187-Vehicle function list BAP-Plug_and_Charge_0x80_msg_bus,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,not activated ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Powertrain data bus ,256
IDE04307-ENG316850-Vehicle function list BAP-RollingAbility_0x75,not activated ,256
IDE04307-ENG316851-Vehicle function list BAP-RollingAbility_0x75_msg_bus,not activated ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG395209-Vehicle function list BAP-SecurityEvent_0x82,not activated ,256
IDE04307-ENG395210-Vehicle function list BAP-SecurityEvent_0x82_msg_bus,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Extended data bus ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,not activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,not activated ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,not activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Infotainment data bus ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Comfort data bus ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Comfort data bus ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,115 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,0 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,not activated ,2
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,not activated ,2
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,activated ,2
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,not activated ,2
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,activated ,2
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,activated ,2
IDE08814-MAS15014-Navigation receiver GNSS configuration-Beidou,not activated ,2
IDE08814-MAS18801-Navigation receiver GNSS configuration-external GPS receiver 2 via bus,not activated ,2
IDE08814-MAS18802-Navigation receiver GNSS configuration-Gnss update rate,1 ,2
IDE08814-ENG259336-Navigation receiver GNSS configuration-GNSS_over_ethernet,not activated ,2
IDE10604-Menu entries for mobile online services,activated ,1
IDE11105-Brand-specific display of connect application,MyVW_BR.DataApp.|MeuVW ,64
IDE11122-Country identification: country of sale HMI,BR ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,Master ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Master ,2
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,No ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,BAP ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,BAP ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,OFF ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,0 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,OFF ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF ,8
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248427-ENG248668-exit_screen_configuration-exit_screen,not activated ,2
ENG248427-ENG248669-exit_screen_configuration-exit_screen_length_of_time,0 ms,2
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,00 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,OFF ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,OFF ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP_over_CAN_and_IP ,2
ENG248429-ENG302834-function_configuration_car-Rotary_Knobs_Function,not activated ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,Yes ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Not available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,Not available ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Not available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Not available ,6
ENG248430-ENG405710-function_configuration_connectivity-Bluetooth_secure_transport_on_ethernet,OFF ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,OFF ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG369265-function_configuration_connectivity-Conbox_encrytion,not installed ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,On ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,not installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,not installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,OFF ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,OFF ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,OFF ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,OFF ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,OFF ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,On ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,OFF ,6
ENG248431-ENG405716-function_configuration_hmi-Google_search_default,On ,5
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,On ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG369611-function_configuration_hmi-Nav_showing,activated ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,2 ,5
ENG248431-ENG405754-function_configuration_hmi-Show_google_search_default,On ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,2 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248431-ENG332397-function_configuration_hmi-Twin_Wheel,Deactivated ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,OFF ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,OFF ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248433-ENG117847-function_configuration_navigation-advanced_range_display,OFF ,4
ENG248433-ENG173863-function_configuration_navigation-Country_Navigation,no_country ,4
ENG248433-ENG248692-function_configuration_navigation-gnns_antenna_Availability,not activated ,4
ENG248433-ENG127492-function_configuration_navigation-LGI,OFF ,4
ENG248433-ENG142152-function_configuration_navigation-Map_Style,0 ,4
ENG248433-ENG248488-function_configuration_navigation-Navigation_system,not activated ,4
ENG248433-ENG103811-function_configuration_navigation-PSD,not activated ,4
ENG248433-ENG126994-function_configuration_navigation-TPEG_availability,OFF ,4
ENG248433-ENG248824-function_configuration_navigation-ttraffic_information,OFF ,4
ENG248433-ENG248828-function_configuration_navigation-vza,not activated ,4
ENG248433-ENG127494-function_configuration_navigation-VZO,OFF ,4
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,OFF ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,OFF ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,not installed ,3
ENG248434-ENG345754-function_configuration_phone-interlink_box_CAN,Deactivated ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,installed ,3
ENG248434-ENG331901-function_configuration_phone-Kopplebox_Fast_Charger,Deactivated ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,Deactivated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,OFF ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,OFF ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,OFF ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,none ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,not installed ,3
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,Deactivated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,not activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,NAR ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,OFF ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,bra ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,not activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,not activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,Available ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,AM_FM_ANT ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,Deactivated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,Deactivated ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,OFF ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,Deactivated ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,OFF ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,not activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,0 ,8
ENG248437-ENG248800-function_configuration_rvc-rear_view_low_rvc,active_legal_screen ,3
ENG248437-ENG245031-function_configuration_rvc-rvc_low_black_screen_trunk_open,activated ,3
ENG248437-ENG244966-function_configuration_rvc-rvc_low_black_screen_velocity_threshold,not activated ,3
ENG248437-ENG245015-function_configuration_rvc-rvc_low_failsafe,not activated ,3
ENG248437-ENG248807-function_configuration_rvc-rvc_low_lid_close_delay_time,0 s,3
ENG248437-ENG248808-function_configuration_rvc-rvc_low_videofailure_detection_time,0 ,3
ENG248438-ENG248523-function_configuration_sound-brand_sound,No_Brand_Sound ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248448-ENG248814-ipv4_address_of_subnet_1_on_ccu-segment_1,10 ,4
ENG248448-ENG248815-ipv4_address_of_subnet_1_on_ccu-segment_2,173 ,4
ENG248448-ENG248816-ipv4_address_of_subnet_1_on_ccu-segment_3,201 ,4
ENG248448-ENG248817-ipv4_address_of_subnet_1_on_ccu-segment_4,1 ,4
ENG248449-ENG248814-ipv4_address_of_subnet_1_on_mib-segment_1,10 ,4
ENG248449-ENG248815-ipv4_address_of_subnet_1_on_mib-segment_2,173 ,4
ENG248449-ENG248816-ipv4_address_of_subnet_1_on_mib-segment_3,201 ,4
ENG248449-ENG248817-ipv4_address_of_subnet_1_on_mib-segment_4,2 ,4
ENG248450-ENG248814-ipv4_address_of_subnet_2_on_ccu-segment_1,10 ,4
ENG248450-ENG248815-ipv4_address_of_subnet_2_on_ccu-segment_2,173 ,4
ENG248450-ENG248816-ipv4_address_of_subnet_2_on_ccu-segment_3,202 ,4
ENG248450-ENG248817-ipv4_address_of_subnet_2_on_ccu-segment_4,1 ,4
ENG248451-ENG248814-ipv4_address_of_subnet_2_on_mib-segment_1,10 ,4
ENG248451-ENG248815-ipv4_address_of_subnet_2_on_mib-segment_2,173 ,4
ENG248451-ENG248816-ipv4_address_of_subnet_2_on_mib-segment_3,202 ,4
ENG248451-ENG248817-ipv4_address_of_subnet_2_on_mib-segment_4,2 ,4
ENG248457-ENG248814-ipv6_address_of_subnet_1_on_ccu-segment_1,FD 30 ,8
ENG248457-ENG248815-ipv6_address_of_subnet_1_on_ccu-segment_2,E0 8E ,8
ENG248457-ENG248816-ipv6_address_of_subnet_1_on_ccu-segment_3,C0 31 ,8
ENG248457-ENG248817-ipv6_address_of_subnet_1_on_ccu-segment_4,00 01 ,8
ENG248458-ENG248814-ipv6_address_of_subnet_1_on_mib-segment_1,FD 30 ,8
ENG248458-ENG248815-ipv6_address_of_subnet_1_on_mib-segment_2,E0 8E ,8
ENG248458-ENG248816-ipv6_address_of_subnet_1_on_mib-segment_3,C0 31 ,8
ENG248458-ENG248817-ipv6_address_of_subnet_1_on_mib-segment_4,00 01 ,8
ENG248459-ENG248814-ipv6_address_of_subnet_2_on_ccu-segment_1,FD 30 ,8
ENG248459-ENG248815-ipv6_address_of_subnet_2_on_ccu-segment_2,E0 8E ,8
ENG248459-ENG248816-ipv6_address_of_subnet_2_on_ccu-segment_3,C0 31 ,8
ENG248459-ENG248817-ipv6_address_of_subnet_2_on_ccu-segment_4,00 02 ,8
ENG248460-ENG248814-ipv6_address_of_subnet_2_on_mib-segment_1,FD 30 ,8
ENG248460-ENG248815-ipv6_address_of_subnet_2_on_mib-segment_2,E0 8E ,8
ENG248460-ENG248816-ipv6_address_of_subnet_2_on_mib-segment_3,C0 31 ,8
ENG248460-ENG248817-ipv6_address_of_subnet_2_on_mib-segment_4,00 02 ,8
ENG152375-ENG152428-Logging_Configuration-Interface,00 ,3
ENG152375-ENG152494-Logging_Configuration-loglevel,00 ,3
ENG152375-ENG98732-Logging_Configuration-Memory,00 ,3
ENG248467-number_to_name_matching_algorithm,detect_numbers ,1
ENG248470-sortorder,sortorder_1 ,1
ENG117919-Startup_Screen_Sticker_HMI,00 0A ,2
ENG277076-ENG273886-Virtual_Switch_Configuration-ECO_stst_availability,On ,32
ENG277076-ENG273846-Virtual_Switch_Configuration-ECO_stst_HMI_priority,4 ,32
ENG277076-ENG273694-Virtual_Switch_Configuration-ECO_stst_virtual_switch_assignment,wire ,32
ENG277076-ENG273883-Virtual_Switch_Configuration-ESC_Off_availability,On ,32
ENG277076-ENG273663-Virtual_Switch_Configuration-ESC_Off_HMI_priority,5 ,32
ENG277076-ENG273900-Virtual_Switch_Configuration-ESC_Off_virtual_switch_assignment,BAP ,32
ENG277076-ENG453872-Virtual_Switch_Configuration-Front_defogger_availability,OFF ,32
ENG277076-ENG453873-Virtual_Switch_Configuration-Front_defogger_HMI_priority,0 ,32
ENG277076-ENG453874-Virtual_Switch_Configuration-Front_defogger_virtual_switch_assignment,OFF ,32
ENG277076-ENG453877-Virtual_Switch_Configuration-Hill_descent_control_availability,OFF ,32
ENG277076-ENG453878-Virtual_Switch_Configuration-Hill_descent_control_HMI_priority,0 ,32
ENG277076-ENG453879-Virtual_Switch_Configuration-Hill_descent_control_virtual_switch_assignment,OFF ,32
ENG277076-ENG273893-Virtual_Switch_Configuration-load_compartment_availability,OFF ,32
ENG277076-ENG273782-Virtual_Switch_Configuration-load_compartment_HMI_priority,0 ,32
ENG277076-ENG273859-Virtual_Switch_Configuration-load_compartment_virtual_switch_assignment,OFF ,32
ENG277076-ENG273665-Virtual_Switch_Configuration-PDC_availability,On ,32
ENG277076-ENG273894-Virtual_Switch_Configuration-PDC_HMI_priority,2 ,32
ENG277076-ENG273887-Virtual_Switch_Configuration-PDC_virtual_switch_assignment,wire ,32
ENG277076-ENG273896-Virtual_Switch_Configuration-PLA_availability,On ,32
ENG277076-ENG273781-Virtual_Switch_Configuration-PLA_HMI_priority,3 ,32
ENG277076-ENG273703-Virtual_Switch_Configuration-PLA_virtual_switch_assignment,wire ,32
ENG277076-ENG273628-Virtual_Switch_Configuration-rear_defogger_availability,OFF ,32
ENG277076-ENG273648-Virtual_Switch_Configuration-rear_defogger_HMI_priority,0 ,32
ENG277076-ENG273639-Virtual_Switch_Configuration-rear_defogger_virtual_switch_assignment,OFF ,32
ENG277076-ENG273898-Virtual_Switch_Configuration-trunk_open_availability,On ,32
ENG277076-ENG273672-Virtual_Switch_Configuration-trunk_open_HMI_priority,1 ,32
ENG277076-ENG273713-Virtual_Switch_Configuration-trunk_open_virtual_switch_assignment,wire ,32
ENG244949-ENG248626-wlan_channel_numbers-channel_number_for_2_4GHz,6 ,1
ENG244949-ENG248627-wlan_channel_numbers-channel_number_for_5GHz,12 ,1
Elapsed Time: 00:45
adpmap-75-2G5-035-282_9BWCJ6CH7TP054606-20260720-0855.CSV
;SW:2G5-035-282   HW:2GA-035-286 ---  75: Telematics
;Component:OCUClas2023_H H11 0612, Coding:02080500000100210000000011000607001110011012011110
;EV_OCUClass2023,001063,EV_OCUClass2023.rod
;Monday,20,July,2026,08:55:19:18837
;VCDS Version: 26.6.0.1 (x64)  Data version: 20260708 DS377.1
;VCID: 62884CE77506248EF4-8036-R SFD+SFD2 {x}
IDE00608-MAS00713-Fuel type-Petrol,installed ,1
IDE00608-MAS00716-Fuel type-Diesel,not installed ,1
IDE00608-MAS00717-Fuel type-Petroleum gas,not installed ,1
IDE00608-MAS00718-Fuel type-Natural gas,not installed ,1
IDE00608-MAS00720-Fuel type-Battery / electric,not installed ,1
IDE00608-MAS03131-Fuel type-Hydrogen,not installed ,1
IDE00761-MAS08397-Run-on time-Long term energy budget,3600 mAh,5
IDE00761-MAS08398-Run-on time-Short term energy budget,3000 mAh,5
IDE00761-MAS08399-Run-on time-Waiting period from sleep to standby mode,5 min,5
IDE00765-Delay of audio output,1.0 s,1
IDE00769-Call number 1 for info call,empty ,5
IDE00770-Number 1 for roadside assistance,empty ,5
IDE00820-Activating and deactivating all development messages-,not activated ,1
IDE00820-ENG263580-Activating and deactivating all development messages-gnss_position_debug_traces,On ,1
IDE02330-Call number 2 for info call,empty ,5
IDE02331-Number 2 for roadside assistance,empty ,5
IDE03581-MAS00478-Vehicle function list CAN-Reserved,0 ,3
IDE03581-ENG183857-Vehicle function list CAN-brakes,activated ,3
IDE03581-ENG252060-Vehicle function list CAN-Central_Electrics,activated ,3
IDE03581-ENG252043-Vehicle function list CAN-Clima,activated ,3
IDE03581-ENG146031-Vehicle function list CAN-Dash Board,activated ,3
IDE03581-ENG252042-Vehicle function list CAN-Engine,activated ,3
IDE03581-ENG252080-Vehicle function list CAN-Front_door_co_driver,activated ,3
IDE03581-ENG252077-Vehicle function list CAN-Front_door_driver,activated ,3
IDE03581-ENG98593-Vehicle function list CAN-Gateway,activated ,3
IDE03581-ENG252094-Vehicle function list CAN-seat_memory_driver,not activated ,3
IDE03581-ENG252083-Vehicle function list CAN-Steering_Column_Electronics,activated ,3
IDE04307-IDE01762-Vehicle function list BAP-Doors,not activated ,11
IDE04307-IDE03031-Vehicle function list BAP-Seat adjustment,not activated ,11
IDE04307-IDE03111-Vehicle function list BAP-Interior lighting,not activated ,11
IDE04307-MAS00688-Vehicle function list BAP-Multi-function display,activated ,11
IDE04307-MAS00903-Vehicle function list BAP-Service interval display (SID),activated ,11
IDE04307-MAS01118-Vehicle function list BAP-Air Conditioning,not activated ,11
IDE04307-MAS01282-Vehicle function list BAP-Wiper,not activated ,11
IDE04307-MAS01891-Vehicle function list BAP-Lane departure warning,not activated ,11
IDE04307-MAS02444-Vehicle function list BAP-Central locking,activated ,11
IDE04307-MAS03385-Vehicle function list BAP-Lane change assistance,not activated ,11
IDE04307-MAS03420-Vehicle function list BAP-Head-Up-Display,not activated ,11
IDE04307-MAS03853-Vehicle function list BAP-Road sign detection,not activated ,11
IDE04307-MAS04219-Vehicle function list BAP-Auxiliary heating,not activated ,11
IDE04307-MAS05087-Vehicle function list BAP-ACC,not activated ,11
IDE04307-MAS05506-Vehicle function list BAP-Stopping distance reduction,not activated ,11
IDE04307-MAS06654-Vehicle function list BAP-Charge manager,not activated ,11
IDE04307-MAS07249-Vehicle function list BAP-Main beam,not activated ,11
IDE04307-MAS08072-Vehicle function list BAP-Driving profile selection,not activated ,11
IDE04307-MAS08785-Vehicle function list BAP-Parking aid,not activated ,11
IDE04307-MAS19762-Vehicle function list BAP-Car2X,not activated ,11
IDE04307-MAS20539-Vehicle function list BAP-BAP distance PaCo_0x55,not activated ,11
IDE04307-MAS20545-Vehicle function list BAP-BAP distance doors2_0x63,not activated ,11
IDE04307-MAS20550-Vehicle function list BAP-BAP distance infotainment_settings_0x50,not activated ,11
IDE04307-MAS20553-Vehicle function list BAP-BAP distance mirror_0x0E,not activated ,11
IDE04307-MAS20556-Vehicle function list BAP-BAP distance unit_master_0x13,not activated ,11
IDE04307-MAS22226-Vehicle function list BAP-BAP distance REM_0x5B,not activated ,11
IDE04307-MAS22227-Vehicle function list BAP-BAP distance REM2_0x67,not activated ,11
IDE04307-MAS22228-Vehicle function list BAP-BAP distance remote_services_0x4E,not activated ,11
IDE04307-MAS22229-Vehicle function list BAP-BAP distance info_settings_0x50_Buszuordnung,by_Ethernet ,11
IDE04307-MAS23125-Vehicle function list BAP-BAP distance RemonteStartOnline_0x70,not activated ,11
IDE04307-MAS26522-Vehicle function list BAP-Seat pneumatics,not activated ,11
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 ,2
IDE07699-Mobile network operator,info.m2mcubic.com ,21
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,activated ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,activated ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,activated ,1
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,not activated ,1
IDE08814-ENG244944-Navigation receiver GNSS configuration-Beidou,not activated ,1
IDE08814-ENG244974-Navigation receiver GNSS configuration-Dead_reckoning_position_transmission,activated ,1
IDE08814-ENG245012-Navigation receiver GNSS configuration-GPS_output_on_CAN,activated ,1
IDE09244-Fuel tank volume,70 l,1
IDE11108-Remote vehicle immobilizer safety protocol,Fazit4MyCar ,1
IDE11306-ENG154717-Vehicle status remote query-Remote_Vehicle_Status_BEM_Alert_Changed,activated ,5
IDE11306-ENG154718-Vehicle status remote query-Remote_Vehicle_Status_Bussleep,not activated ,5
IDE11306-ENG154719-Vehicle status remote query-Remote_Vehicle_Status_Bussleep_Delay,5 s,5
IDE11306-ENG123302-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_Off_Delay,5 s,5
IDE11306-ENG123301-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,5
IDE11306-ENG154720-Vehicle status remote query-Remote_Vehicle_Status_Trigger_Relock,5 s,5
IDE13547-ENG101574-Dimming curve of the red functional lighting in case of various colors at the same time-X1,0 ,12
IDE13547-ENG99557-Dimming curve of the red functional lighting in case of various colors at the same time-X2,20 ,12
IDE13547-ENG102140-Dimming curve of the red functional lighting in case of various colors at the same time-X3,50 ,12
IDE13547-ENG102936-Dimming curve of the red functional lighting in case of various colors at the same time-X4,100 ,12
IDE13547-ENG103548-Dimming curve of the red functional lighting in case of various colors at the same time-X5,150 ,12
IDE13547-ENG113992-Dimming curve of the red functional lighting in case of various colors at the same time-X6,253 ,12
IDE13547-ENG99777-Dimming curve of the red functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13547-ENG100480-Dimming curve of the red functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13547-ENG100773-Dimming curve of the red functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13547-ENG100631-Dimming curve of the red functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13547-ENG102174-Dimming curve of the red functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13547-ENG113993-Dimming curve of the red functional lighting in case of various colors at the same time-Y6,50 %,12
IDE13548-ENG101574-Dimming curve of the green functional lighting in case of various colors at the same time-X1,0 ,12
IDE13548-ENG99557-Dimming curve of the green functional lighting in case of various colors at the same time-X2,20 ,12
IDE13548-ENG102140-Dimming curve of the green functional lighting in case of various colors at the same time-X3,50 ,12
IDE13548-ENG102936-Dimming curve of the green functional lighting in case of various colors at the same time-X4,100 ,12
IDE13548-ENG103548-Dimming curve of the green functional lighting in case of various colors at the same time-X5,150 ,12
IDE13548-ENG113992-Dimming curve of the green functional lighting in case of various colors at the same time-X6,253 ,12
IDE13548-ENG99777-Dimming curve of the green functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13548-ENG100480-Dimming curve of the green functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13548-ENG100773-Dimming curve of the green functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13548-ENG100631-Dimming curve of the green functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13548-ENG102174-Dimming curve of the green functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13548-ENG113993-Dimming curve of the green functional lighting in case of various colors at the same time-Y6,50 %,12
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Maximum private sphere in shape 2 ,7
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,not activated ,7
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic settings not detected guest: services,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with balancing of interests,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with consent,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19887-Private sphere mode: workshop settings-Display info window for current privacy settings,No display ,7
IDE14995-MAS19892-Private sphere mode: workshop settings-Display selection for recurring dialog display,No display ,7
IDE14995-MAS19893-Private sphere mode: workshop settings-Selection for recurring dialog display availability,for personalized users ,7
IDE14995-ENG98891-Private sphere mode: workshop settings-Reserved,0 ,7
IDE15042-MAS19716-Privacy mode: customer settings-Services,Maximum private sphere in shape 2 ,3
IDE15042-MAS19722-Privacy mode: customer settings-Data collector,not activated ,3
IDE15042-MAS19887-Privacy mode: customer settings-Display info window for current privacy settings,No display ,3
IDE15074-MAS13668-Broadband audio-Emergency call,not activated ,1
IDE15074-MAS20714-Broadband audio-Breakdown assistance/information call,not activated ,1
IDE15407-IDE01762-BAP route control-Doors,automatic ,25
IDE15407-IDE03031-BAP route control-Seat adjustment,automatic ,25
IDE15407-IDE03111-BAP route control-Interior lighting,automatic ,25
IDE15407-MAS00688-BAP route control-Multi-function display,automatic ,25
IDE15407-MAS01118-BAP route control-Air Conditioning,automatic ,25
IDE15407-MAS01282-BAP route control-Wiper,automatic ,25
IDE15407-MAS01891-BAP route control-Lane departure warning,OFF ,25
IDE15407-MAS02444-BAP route control-Central locking,automatic ,25
IDE15407-MAS03385-BAP route control-Lane change assistance,automatic ,25
IDE15407-MAS03420-BAP route control-Head-Up-Display,OFF ,25
IDE15407-MAS03853-BAP route control-Road sign detection,OFF ,25
IDE15407-MAS05087-BAP route control-ACC,automatic ,25
IDE15407-MAS05506-BAP route control-Stopping distance reduction,automatic ,25
IDE15407-MAS07249-BAP route control-Main beam,automatic ,25
IDE15407-MAS08072-BAP route control-Driving profile selection,automatic ,25
IDE15407-MAS08785-BAP route control-Parking aid,automatic ,25
IDE15407-MAS20537-BAP route control-BAP distance Car2X_0x61,OFF ,25
IDE15407-MAS20539-BAP route control-BAP distance PaCo_0x55,OFF ,25
IDE15407-MAS20545-BAP route control-BAP distance doors2_0x63,automatic ,25
IDE15407-MAS20550-BAP route control-BAP distance infotainment_settings_0x50,OFF ,25
IDE15407-MAS20553-BAP route control-BAP distance mirror_0x0E,automatic ,25
IDE15407-MAS20556-BAP route control-BAP distance unit_master_0x13,automatic ,25
IDE15407-MAS26521-BAP route control-Display configuration,OFF ,25
IDE15407-MAS26522-BAP route control-Seat pneumatics,OFF ,25
IDE15407-ENG98891-BAP route control-Reserved,OFF ,25
IDE16311-MAS22303-Voice amplification for call services-Radio voice amplification: voice services,20 00 ,8
IDE16311-MAS22305-Voice amplification for call services-Emergency call speaker voice amplification: normal state,20 00 ,8
IDE16311-MAS22306-Voice amplification for call services-Emergency call speaker voice amplification: emergency battery,20 00 ,8
IDE16311-MAS22307-Voice amplification for call services-Emergency call speaker voice amplification: low temperature,20 00 ,8
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,00 00 ,2
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,0 ,2
MAS01078-Vehicle model,Passenger car (category M1) ,1
MAS07110-Muting of audio sources,Muting not active ,1
MAS07467-Speed warning maximum speed,0 km/h,2
MAS08170-User profile name,blank ,5
MAS08171-User profile password,blank ,5
MAS08172-Mobile Online services: first host name-,https://t-h-m.dp.br00.p.conveh-br.net:15443/glcs/vehicles/v2/deviceRegistered ,89
MAS08172-MAS17438-Mobile Online services: first host name-Preselection of host names,free ,89
MAS08172-ENG247627-Mobile Online services: first host name-Online_Service_Backend_Type,MBB ,89
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
MAS08177-Acoustic warning for vehicle shut-down,activated ,1
MAS08366-MAS01487-Keypad-LED,Not available ,1
MAS08366-MAS10536-Keypad-Keys,Not available ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS09650-Threshold for vehicle movement recognition,5 km/h,2
MAS13395-Transmission_status_activation-,activated ,5
MAS13395-MAS13397-Transmission_status_activation-No transmission after OTVreques,1000 d,5
MAS13395-MAS13398-Transmission_status_activation-Number of days prior to service schedule_before display combi,30 d,5
MAS13395-MAS13399-Transmission_status_activation-Number of days before service reminder,2 d,5
MAS13396-MAS13392-Remote BatteryCharging Management_Battery Status Report-threshold,95 %,3
MAS13396-MAS13394-Remote BatteryCharging Management_Battery Status Report-Steps Above Threshold,1 %,3
MAS13396-MAS13442-Remote BatteryCharging Management_Battery Status Report-Transmission interval below threshold,5 %,3
MAS13840-Gnss data transmission rate,10 Hz ,2
MAS13841-Gnss min height,5 °,2
MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,50 ,6
MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,50 %,6
MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
MAS17119-ENG245041-Fault memory mobile online service threshold-Step_00,100 ,32
MAS17119-ENG244993-Fault memory mobile online service threshold-Step_01,100 ,32
MAS17119-ENG244984-Fault memory mobile online service threshold-Step_02,100 ,32
MAS17119-ENG245001-Fault memory mobile online service threshold-Step_03,100 ,32
MAS17119-ENG245016-Fault memory mobile online service threshold-Step_04,100 ,32
MAS17119-ENG245017-Fault memory mobile online service threshold-Step_05,100 ,32
MAS17119-ENG245042-Fault memory mobile online service threshold-Step_06,100 ,32
MAS17119-ENG245043-Fault memory mobile online service threshold-Step_07,100 ,32
MAS17119-ENG244962-Fault memory mobile online service threshold-Step_08,0 ,32
MAS17119-ENG245032-Fault memory mobile online service threshold-Step_09,0 ,32
MAS17119-ENG245002-Fault memory mobile online service threshold-Step_10,0 ,32
MAS17119-ENG245003-Fault memory mobile online service threshold-Step_11,0 ,32
MAS17119-ENG245018-Fault memory mobile online service threshold-Step_12,0 ,32
MAS17119-ENG244967-Fault memory mobile online service threshold-Step_13,0 ,32
MAS17119-ENG244985-Fault memory mobile online service threshold-Step_14,0 ,32
MAS17119-ENG244968-Fault memory mobile online service threshold-Step_15,0 ,32
MAS17427-MAS00220-Door configuration-Rear left door,installed ,1
MAS17427-MAS00221-Door configuration-Rear right door,installed ,1
MAS17427-SFT271922-Door configuration-Left rear door control module,not installed ,1
MAS17427-SFT271923-Door configuration-Right rear door control module,not installed ,1
MAS17439-Wifi hotspot mobile phone connection: network operator,wifi.m2mcubic.com ,17
MAS17460-Wifi hotspot mobile phone connection: user profile name,blank ,5
MAS17461-Wifi hotspot mobile phone connection: password,blank ,5
MAS17554-Digital key: backend notification,activated ,1
MAS17562-Query interval for Real Time Monitoring,1 s,1
MAS18217-IDE09602-Activation status for local hazard warning service-Locale hazard warning,not activated ,1
MAS18217-MAS18218-Activation status for local hazard warning service-Accident,not activated ,1
MAS18217-MAS18219-Activation status for local hazard warning service-Breakdown,not activated ,1
MAS18217-MAS18220-Activation status for local hazard warning service-Loss of traction,not activated ,1
MAS18217-MAS18221-Activation status for local hazard warning service-Visual obstruction,not activated ,1
MAS18217-MAS18222-Activation status for local hazard warning service-Hydroplaning,not activated ,1
MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
MAS18272-Breakdown assistance call: protocol version,Generation_20 ,1
MAS18603-ENG247383-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247384-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Up,0.2 s,4
MAS18603-ENG247607-Damping factor for dimming up and down-Functional_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247608-Damping factor for dimming up and down-Functional_Illumination_Damping_Up,0.2 s,4
MAS18701-Setting the product data,02 01 02 01 6B 6D 32 6D 63 75 62 69 63 2E 63 6F 6D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 62 72 2E 6E 65 74 3A 31 35 34 34 33 2F 67 6C 63 73 2F 76 65 68 69 63 6C 65 73 2F 76 32 2F 64 65 76 69 63 65 52 65 67 69 73 74 65 72 65 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 C6 02 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,3296
MAS19210-Maximum waiting time to transfer UserID from IAA,150 ms,1
MAS19211-Delay time for synchronization with memory site,700 ms,1
MAS19213-Operation during severe BAP errors while storing data,Continue operation ,1
MAS19214-Maximum synchronization of an unused shadow drive,28 d,1
MAS19215-Waiting time until change to settings is transferred,60 s,2
MAS19216-Number of extensions until transfer is completed,3 s,1
MAS19218-Delay time for picking up changes,120 s,1
MAS19219-Maximum waiting time for HMI availability,5 min,1
MAS19220-Download before activating driver (driver already stored),Do not perform download ,1
MAS19221-Maximum storage duration,120 s,1
MAS19222-Maximum waiting time before storing is canceled,5 s,1
MAS19233-Identify Authorize Authenticate - user management,not installed ,1
MAS19239-Time window for key recognition,5 min,1
MAS19240-Authorization level after-run time,30 min,1
MAS19241-Key recognition mode setting,automatic ,1
MAS19242-User images display,On ,1
MAS19243-BCM user switching,OFF ,1
MAS19244-Permanent safety mode setting,On ,1
MAS19335-Maximum duration of relocation,60 s,1
MAS26501-MAS26530-Background for synchronization timer-Time until background synchronization of inactive users,2 min,2
MAS26501-MAS26531-Background for synchronization timer-Time until background synchronization of the active user,15 min,2
ENG123200-Driving_Follow_Up_Time,5 min,1
ENG244879-function_configuration_sw_update,On ,1
ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
ENG247336-MAS01424-Geofencing_Area_Height-max.value,4294967294 m,8
ENG247336-MAS01425-Geofencing_Area_Height-min.value,1 m,8
ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,2147483647 °,8
ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2147483648 °,8
ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,2147483647 °,8
ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2147483648 °,8
ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not activated ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not activated ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not activated ,1
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Direction of travel,30 °,12
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
ENG153744-supress_climatisation_settings,not activated ,1
ENG153745-supress_climatisation_temperature,activated ,1
ENG298058-Vehicle_Transport_Tracking,inactive ,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
Elapsed Time: 00:33
adpmap-A5-2Q0-980-653-H_9BWCJ6CH7TP054606-20260720-0855.CSV
;SW:2Q0-980-653-H   HW:2Q0-980-653-A ---  A5: Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H19 1602, Coding:00000190006EC020089E08000020000000418000600000000000000000000000
;EV_MFK3ValeoMQB,007058,EV_MFK3ValeoMQB_007_VW27.rod
;Monday,20,July,2026,08:55:56:18837
;VCID: 3A38D487BD160C4E8C-806E-R
ENG114742-ENG130919-Activation of Development Messages-Activation_of_development_messages_EHR,not active ,2
ENG114742-ENG185756-Activation of Development Messages-Activation_of_development_messages_HCA_01,not active ,2
ENG114742-ENG185757-Activation of Development Messages-Activation_of_development_messages_HCA_02,not active ,2
ENG114742-ENG130922-Activation of Development Messages-Activation_of_development_messages_internal,not active ,2
ENG114742-ENG185758-Activation of Development Messages-Activation_of_development_messages_lane_1,not active ,2
ENG114742-ENG185759-Activation of Development Messages-Activation_of_development_messages_lane_2,not active ,2
ENG114742-ENG130915-Activation of Development Messages-Activation_of_development_messages_reserved,not active ,2
ENG114742-ENG185760-Activation of Development Messages-Activation_of_development_messages_RFD,not active ,2
ENG114742-ENG185761-Activation of Development Messages-Activation_of_development_messages_TSF,not_active ,2
ENG114742-ENG185762-Activation of Development Messages-Activation_of_development_messages_VZF_TSR1,not_active ,2
ENG114742-ENG185763-Activation of Development Messages-Activation_of_development_messages_VZF_TSR2,not active ,2
ENG114742-ENG130917-Activation of Development Messages-Activation_of_development_messages_WLA,not active ,2
ENG114742-ENG185770-Activation of Development Messages-Dev_messages_vd_deaktivation,not active ,2
ENG369146-HCA_PSD_Support,not_active ,1
Elapsed Time: 00:08
adpmap-A9-2G0-907-159-E_9BWCJ6CH7TP054606-20260720-0856.CSV
;SW:2G0-907-159-E   HW:4ML-907-159-D ---  A9: Struct. Borne Sound
;Component:SAS-GEN 2.9   H10 0001, Coding:
;EV_SoundActuaGen2AU64X,005018,EV_SoundActuaGen2AU64X_005_VW27.rod
;Monday,20,July,2026,08:56:07:18837
;VCID: 2D12EFDB7C58ABF619-8078-R
IDE04472-Volume of structure-borne noise actuator,100.0 %,1
Elapsed Time: 00:00
Eric
HC800000
Nice. Did you want to take part in the SFD Beta and get free access?
Elder Moreira dos Santos
Brasil
C?ID=304355
Hi Eric, I’d certainly like that, but my interface is an older model; I tried to register it, but it wasn't accepted. Serial:
[redacted]
I own a shop and work with VCDS every day—I’d be lost without it.
I have many auto-scans saved and will post them here to help the forum.
Try again now.
And please see:
Eric
HC800000
Right, so only newer unlimited-VIN/Pro interfaces can sign up on their own, but all HEX-NET and HEX-v2 interfaces are welcome to the SFD beta, after posting an autoscan of an SFD-capable vehicle in the forum, made with a SFD-capable Beta, and indicating what they plan to do with an SFD-unlock so they can provide feedback afterwards. We got a little tired of people signing up for SFD early on and:
-Not logging in at all :facepalm:
-Logging in but not unlocking anything :facepalm:
-Unlocking SFD without posting any feedback whatsoever :facepalm:
You posted the autoscan (with the beta!) so now you are eligible to place an order.
We'll take anything you can post (autoscan, MVB and ADP maps) but for SFD testing purposes, as indicated by the SFD feedback thread, we're also especially interested in the Debug files SFDLog.csv, ADPLog.csv (and SOT/GESLog.csv if those functions are SFD protected). On SFD2 vehicles, ADPMaps *after* turning off the filter in the gateway would also be great.
Brasil
C?ID=304355
Got it, I'll be part of it and I'll post it whenever a new car arrives at my store. Thank you and I'm happy to be able to contribute.
