Disable ESP and warning light MK4
bundabora
Australia
C?ID=167516
Hi.
I have a MK4 Bora 2003 and want to disable the ESP warning light because the sensor has failed and I don't want to replace it. I do want the ABS to work however. Could anyone please point me in the right direction? I found advice re. MK6, but not for my car. My scan and car details is listed below. I have pulled the plug out of the YAW sensor for now to avoid the ABS intermittently applying the front right brake and so I don't really need to disable the sensor but the warning light bugs me...
Thanks,
Scott
Thursday,25,February,2016,09:36:09:00992
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVWZZZ1JZ3D502389   License Plate: DISCONNECTED
Mileage: 82250km-51107mi   Repair Order:
          76
VIN: WVWZZZ1JZ3D502389   Mileage: 82250km-51107miles
   Part No: 022 906 032 BJ
   Component: MOTRONIC ME7.1.1G   0002
   Coding: 0000132
   Shop #: WSC 78901 281 394790
   VCID: 54A7C076F4F8AF9E85-5140
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Part No: 1C0 907 379 F
   Component: ESP ALLRAD MK60     0104
   Coding: 0023046
   Shop #: WSC 31414 000 00000
   VCID: 2D51B592B712DE56EA-5140
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 31414
   VCID: 214959A2ABCA0A365E-51B6
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0008
   Coding: 12855
   Shop #: WSC 31414
   VCID: 224B56AEAECC112E47-5124
   Part No: 1J5 920 826 A
   Component: KOMBI+WEGFAHRSP VDO V13
   Coding: 07724
   VCID: 2C57B896DC08D75EFD-5124
   WVWZZZ1JZ3D502389     VWZ7Z0C7172960
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 31414
   VCID: 70EF6CE630A0F3BE81-5124
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0010
   VCID: 204F5CA6A0C0033E51-4AEE
   Part No: 1C0 959 799 B
   Component: 7K Komfortgerát HLO  003
   Coding: 00259
   Shop #: WSC 31414
   VCID: 36639AFE12449D8E9B-4B06
   Subsystem 1 - Part No: 1C2959802A
   Component: 7K Tõrsteuer.FS KLO 0009
   Subsystem 2 - Part No: 1C2959801A
   Component: 7K Tõrsteuer.BF KLO 0009
   Component: 7K Tõrsteuer.HL KLO 0009
   Component: 7K Tõrsteuer.HR KLO 0009
00912 - Window Regulator Switch; Front Left (E40)
            27-00 - Implausible Signal
End-------------------------(Elapsed Time: 04:49)--------------------------
I'm not aware of any way to do that via diagnostics on that module.
dosia
Lithuania
C?ID=27600
What, if recode CAN (adress 19). 00006-00002=00004 ?
I do not think it will work to tell the CAN Gateway that you do not have any brake electronics at all. But you can try and let us know the result.
Mrclopec
Nipomo, CA
C?ID=149231
...want to disable the ESP warning light because the sensor has failed and I don't want to replace it. I do want the ABS to work however...
Well that doesn't seem very safe. I'd just fix the car. The warning light is there for a reason and to not have it active anymore, especially for the person that owns the car after you, would seem like kind of a bad idea. Just my opinion tho. :popcorn:
bundabora
Australia
C?ID=167516
Thanks but I'm not sure how to do this?
bundabora
Australia
C?ID=167516
I understand the concern however I think 4wd and ABS is plenty of safety for me.
