TIGUAN 2013 ABS Coding
dosia
Lithuania
C?ID=27600
I'm using HEX-CAN about 10 years, but new at the forum.'
Just filled registration form, waiting for submit.
Have troubles with NAR TIGUAN, year 2013.
I'm attempting to retrofit car, for use in EU.
Have some issues for retrofitting tail lights (wiring, BCU coding), but trying to figure it by myself.
But it seems, i can't find solution for ABS coding.
After changing region in instrument cluster (ml-km), have found faults in ABS about incorrect coding.
Part No SW: 5N0 614 109 AR HW: 5N0 614 109 AR
Component: J104 C6 450M VD40 0006
Revision: --H07--- Serial number: 00000005904196
Coding: 0005158
VCID: 7BFF885E3AEA78E62B-802E
So it seems, ABS must be coded to meet EU spec.
Can somebody calculate right coding ? (after i place full scan, of course :) )
Thanks.
I think it's pretty likely.
In the meanwhile, please see How to get Verified. I think you fall into Category 2).
dosia
Lithuania
C?ID=27600
Hello Uwe, i did it before posting :)
dosia
Lithuania
C?ID=27600
Tuesday,08,March,2016,18:12:20:03864
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVGAV7AX7DW516199   License Plate: 2015
Mileage: 48570km-30179mi   Repair Order:
Chassis Type: AX (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 4C 4F
          52 53 55 56 62 6C 72
VIN: WVGAV7AX7DW516199   Mileage: 48570km-30179miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 997 027 M    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 06 0396
   Revision: P3H07---    Serial number:
   Coding: 0423010A19070160
   Shop #: WSC 63698 001 1048576
   VCID: 3F873C4E6E72A4C647-806A
Readiness: 1110 0101
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2253
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 0717E4AE76222C063F-8052
   Coding: 0005158
            000 -  -
                    Reset counter: 64
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 10.75 V
                    Bin. Bits: 00011111
                    Count: 215
                    Hex Value: 0x0000
            000 -  -
                    Reset counter: 64
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0178304523
   Coding: 030C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: 346D63629F34779EAA-8060
   Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010001002
   VCID: 7CFD8B42F7E47FDE22-8028
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 0068
   Revision: BJ021001
   Coding: 6F180A1B88232EC4008800C134000D4448D53006576D8DB0E4840000A040
   VCID: 3F873C4EAE72A4C647-806A
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 19061  013 0203
   Coding: 009795
   Component: RLS 190612 05  54  0403
   Coding: 02304D
12 Faults Found:
                    Reset counter: 104
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:55:01
                    Voltage: 8.75 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:29
                    Voltage: 9.95 V
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:29
                    Voltage: 9.95 V
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:58:55
                    Voltage: 10.30 V
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:58:55
                    Voltage: 10.30 V
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:58:55
                    Voltage: 10.25 V
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:58:55
                    Voltage: 10.25 V
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:58:55
                    Voltage: 10.25 V
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:58:55
                    Voltage: 10.25 V
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:27
                    Voltage: 10.00 V
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:58:55
                    Voltage: 10.30 V
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:58:55
                    Voltage: 10.30 V
   Part No SW: 5N0 959 655 S    HW: 5N0 959 655 S
   Component: J234__2VB VW10 HI   2118
   Revision: 24017000    Serial number: 003L6PBFSWU%
   Coding: 0022082
   VCID: 4D9B1686D4DE0656C5-8018
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000008ZU3
   Subsystem 3 - Serial number: 0009.05.120000300000850076˙†63
   Subsystem 4 - Serial number: 850076˙†6332MTS623411562 ˙†63
   Subsystem 5 - Serial number: 11562 ˙†6342MTS607571572 ˙†63
   Subsystem 6 - Serial number: 71572 ˙†6351HTS68HFN6BKR ˙†63
   Subsystem 7 - Serial number: N6BKR ˙†6361HTS6BVO30BKJ ˙†63
   Subsystem 8 - Serial number: 30BKJ ˙†63727TS67TTU3BKR ˙†63
   Subsystem 9 - Serial number: U3BKR ˙†63827TS6262V3BKR ˙
   Subsystem 10 - Serial number: V3BKR ˙
03551 - Functional Restriction of Seat Occupied Recognition
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:59:12
   Part No SW: 5K0 953 501 BL    HW: 5K0 953 569 L
   Revision: FF010041    Serial number: 20120619100930
   Coding: 110A140000
   VCID: 75EB9E66D4CE2E965D-8020
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
   Part No SW: 5N0 920 973 B    HW: 5N0 920 973 B
   Component: KOMBI         H05 0705
   Coding: 111F01
   VCID: 336F607E9A3A70A6B3-8066
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 160612F2001889
   Coding: 356002
   VCID: 41833AB6D886D23631-8014
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:37
   Component: IMMO          H05 0705
   Coding: 000007
   VCID: 6AD1BD1A8D70F16EC0-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000139600001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F676C0E76125446D7-807A
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662872712
   Coding: 020100
   VCID: 2A517D1A45F0316E00-807E
   Part No SW: 561 959 760 A    HW: 561 959 760 A
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000029267086
   Coding: 00581B0000000000000001010101202020202121202020
   VCID: 21439A3638C6F23651-8074
03332 - Motor for Height Adjustment
                    Fault Status: 01100101
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:24
03333 - Motor for Cushion Angle Adjustment
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:24
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4233885
   Coding: 0400040104000C000000100A
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 254B8E2624EE1E162D-8070
   Component: NAR_V3_(0037)  0037
1048580 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 104
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:24
1048669 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:58:28
   Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0503
   Revision: 12110009    Serial number: 0005156663
   Coding: 0015BE
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 39735256B8568AF679-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D
   Component: J388__TSG-HL  008 1504
   Serial number: 00000006709817
   Coding: 000490
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.286 1101
   Revision: 1AH03837    Serial number: 00121630285001
   Coding: 0000258
   VCID: 3D7B4646647EB6D655-8068
Address 4C: Tire Pressure II
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 050B0500
   VCID: 6FE7AC0EBE92144697-803A
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
01512 - Control Module for Sliding Roof
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:32
   Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0503
   Revision: 14110009    Serial number: 0005168223
   Coding: 0015BE
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3A714D5ABD5081EE70-806E
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D
   Component: J389__TSG-HR  008 1504
   Serial number: 00000006887923
   Coding: 000490
   Revision:   H19       Serial number: 00000000283073
   Coding: 0026156
   VCID: 3669596A4148658E94-8062
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 041200010B000400
   ROD: EV_HeadlRegulVWAFSPt_SE36.rod
   VCID: 3777546E8E429C868F-8062
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0009
   Coding: 140000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0009
   Coding: 140000
5275926 - Power Output Module for Left Headlamp
          C1081 16 [137] - Voltage Too Low
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:41
5276182 - Power Output Module for Right Headlamp
          C1082 16 [137] - Voltage Too Low
                    Reset counter: 64
                    Mileage: 48573 km
                    Date: 2016.03.08
                    Time: 01:54:41
   Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
   Revision: 00H11000    Serial number: 525PA8-J248231
   Coding: 0100010
   Shop #: WSC 01324 011 00200
   VCID: 2D5B7606B41E2656E5-8078
                    Reset counter: 104
End-------------------------(Elapsed Time: 03:18)--------------------------
dosia
Lithuania
C?ID=27600
Figuring out how to put data into a frame, no succsess :(
Verified.
Moving this to the Tweaks.
I'm not the expert on these ABS codings, but hopefully one of them will come along. :)
dosia
Lithuania
C?ID=27600
Thanks Uwe :)
