DCC delete
dubgeek
C?ID=10070
I have a 2017 RS3. In January I replaced the magride shocks with coilovers. I installed iSweep DCC defeat modules at the time, and everything worked great for 6 months. In early June I started getting an intermittent suspension malfunction warning. It would go away if I restarted the car but it eventually returned. At first it was a couple weeks between warnings, then almost daily. Now it's persistent and returns immediately if I clear the code in VCDS. I replaced the defeat modules with a different brand, no change.
The error is for an open circuit on the front left which suggests to s me it's actually a wiring or control unit issue.
I have an older HEX+CAN USB cable. I know it can't talk to some of the modules in the car, but is it capable enough to code out the DCC in this car, or are there procedures I would need to do that would require a newer cable? What steps would be involved to code out the DCC?
Auto scan:
Sunday,19,July,2026,17:51:34:58383
VCDS Version: 26.3.0.0 (x64)
VIN: WUABWGFF0H1900210   License Plate:
Mileage: 139661km-86781mi   Repair Order:
Chassis Type  FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F 6C BB BC CF
VIN: WUABWGFF0H1900210   Mileage: 139661km-86781miles
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404 G    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  H21 0005
   Revision: 53H21000    CVN: F4B8DA13
   Coding: 0A250032242600053620
   Shop #: WSC 38624 003 1048576
   ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
   ROD: EV_ECM25TFS0118V0907404G.rod
   VCID: 3D7B65EAAC95A177E8-8068
   VINID: 9E54529D7596018049000081003B8CBF44
Readiness: 1110 0101
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2112
   Revision: 00H06V07    CVN: CE0C4532
   ROD: EV_TCMDQ500021.rod
   VCID: 2E5952A671F34AEF61-807A
   Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
   Component: ESC           H25 0621
   Revision: 00000000    Serial number: 60457000000772
   Coding: 2EAA6B7DD4990BA989930B6581916974D62BD091D0819636024150D4828812
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_035.rod
   VCID: 397371FAB8BD9D57C4-806C
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0434628362 Dataset Number: 8V0909577E  0011
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_AU37.rod
   VCID: 3B7F6BF2B281AF47D6-806E
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001178523
   Coding: 03000015010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40851C1EDB67CC9F83-8014
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 4139469800PAG0MUFU03
   Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H34 0236
   Serial number: 02001706100244 Dataset Number: 8V0909514T  0036
   ROD: EV_BCMBOSCH_017_VW37.rod
   VCID: 7EF9A2E6E1137A6FB1-802A
   Component: WWS371 170119  043 0585
   Serial number:         170206062921
   Coding: 0A47F7
   Serial number: 62665878
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 23 12 2016  00000812
   Serial number: 00000000000068746850
   Sunroof control module:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST001H11P900000
   Coding: 101F00
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617056 Dataset Number: 8V0909526H  0059
   Coding: 0470155011
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   VCID: 4A913E36ED5B06CF5D-801E
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0082
   Serial number:       050217046 Dataset Number: 8V0909554G  0017
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide.rod
   VCID: 458B0D0AC445E9B7B0-8010
3149828 - Valve for DamPing Adjustment Front Left
          C1040 13 [10001001] - Open Circuit
                    Reset counter: 174
                    Mileage: 139661 km
                    Date: 2026.07.19
                    Time: 17:45:03
                    COM: C3 30 0D 00 00 00 00 00 00 00
                    Voltage terminal 30: 12.5 V
                    Terminal 15 status via CAN: Terminal 15 on
                    Vehicle_level_sender_PWM-Left front: Not available
                    Vehicle_level_sender_PWM-Right front: 0.0 %
                    Vehicle_level_sender_PWM-Left rear: 0.4 %
                    Vehicle_level_sender_PWM-Right rear: 98.8 %
                    AMR state: 0
                    Damping adjustment indicator lamp: OFF
                    Dampening adjustment: current Highside-Left front: -8 mA
                    Dampening adjustment: current Highside-Right front: -19 mA
                    Dampening adjustment: current Highside-Left rear: 1113 mA
                    Dampening adjustment: current Highside-Right rear: -35 mA
                    Dampening adjustment valve: current Lowside-Left front: 13 mA
                    Dampening adjustment valve: current Lowside-Right front: -21 mA
                    Dampening adjustment valve: current Lowside-Left rear: 1090 mA
                    Dampening adjustment valve: current Lowside-Right rear: -3 mA
                    ESP automatic engagement: not activated
                    Fall-back level: 00 00 06 42
   Serial number: 003GCR07FKFT Dataset Number: 8V0909602R  0002
   Coding: 9DCCFCC0008000005000001AC24800000065
   VCID: 47970702FE49FBA742-8012
   Left seat belt tensioner:
   Serial number: 34230167A01031750834
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34230168A01031751027
   Coding: 333135
   Subsystem 3 - Part No SW: 5C6 959 339 C    HW: 5C6 959 339 C
   Component: BF-Gewichtss.  H10 0047
   Serial number: 694000000000001XLMX0
   Coding: 303439
   Subsystem 4 - Part No SW: -----------    HW: 480 000 903 17
   Serial number: 35700000000E21D4F12O
   Subsystem 5 - Part No SW: -----------    HW: 480 000 903 17
   Serial number: 358000000004F4BCE12-
   Subsystem 6 - Part No SW: -----------    HW: 480 402 502 17
   Serial number: 3510001AD2465B45D4CD
   Subsystem 7 - Part No SW: -----------    HW: 480 402 502 17
   Serial number: 3520001A124996E4F57B
   Subsystem 8 - Part No SW: -----------    HW: 480 401 601 17
   Serial number: 3550002BD23A3F84E05H
   Subsystem 9 - Part No SW: -----------    HW: 480 401 601 17
   Serial number: 3560002BD23A3F8270FJ
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 06031704221052
   Coding: A018
   VCID: 0D1BF52ADCB551F7B8-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890     HW: 8V0 920 890
   Component: FBenUSA       H14 0046
   Coding: 086D18533B88CF050204EC041800001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 7AF1AEF6FD3B564F8D-802E
   Component: GW MQB High   515 5286
   Serial number: 04031710800468 Dataset Number: 8V0909515M  0084
   Coding: 03010004340860005B00822CB80B00000001010000000000000000000000
   GVL: 01D43C0000000600404C10000002CC0000040000000000000000000000000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 2F674FA276F943E76A-807A
   Generator:
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20170220091053 21068
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Serial number: 9871693304
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00005.10.16 Dataset Number: v1260x015G0 0000
   Coding: 0601
   ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
   VCID: 4D9B352A1C3511F778-8018
   Revision: 00000000    Serial number: 17000610003002
   Coding: 5D00000000000000
   VCID: 346D40CE9FDF603F17-8060
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------    Dataset Number: 8V0909535F  0005
   Coding: 040002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Serial number: 310117EAU04726 Dataset Number: 8V0909872J  0039
   Coding: 005D1B205C00048000000002
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 438F1312CA71D7879E-8016
   Dataset Number: 8V0909852P  0026
   Coding: 8106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A716EF6BDBB964FCD-806E
   Part No SW: 81A 035 466     HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0100
   Revision: 00000001    Serial number: AUZ8ZAGHX00J2PP Dataset Number: 8V0909510F  0006
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI_AU37.rod
   VCID: 62C1F69675ABBE8FB5-8036
0590 - Front Left Bass Speaker
          B105F 13 [00001001] - Open Circuit
                    Reset counter: 174
                    Mileage: 139661 km
                    Date: 2026.07.19
                    Time: 17:45:05
                    Voltage terminal 30: 12.4 V
   Component: TSG BFS
   Serial number: 230217EBM20792 Dataset Number: 8V0909873J  0039
   Coding: 005D13205E00048000000002
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 55ABDD4A34E55937C0-8000
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865N  0008
   Coding: 0E62021123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E7962E6A193BA6FF1-806A
Address 5F: Information Electr. (J794)       Labels:* 8V0-035-MIB-HGH2.clb
   Part No SW: 8V1 035 880 A    HW: 8V1 035 880
   Component: MU-P-LNS-US   053 0906
   Serial number: A702B0HS002415 Dataset Number: 8V2909545L  0021
   Coding: 017361020000000011220002041A00102F0028E5017001047E
   VCID: 387574FE83B7845F3B-806C
   Subsystem 1 - Part No SW: V03 959 801 GG    HW: -----------
   Component: NAR 2017  --- 0057
   Multimedia display unit 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y01B34
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL111011700010809
   Compact disc data bank:
   Component: Gracenote2---  --- 3011
   Dataset Number: 8V0909460E  0005
   Coding: 0273010102002001400040
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V1.clb
   Serial number: 140217EBE04971 Dataset Number: 8V0909897H  0027
   Coding: 000C13204000048000000002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V1.clb
   Serial number: 140217EBE04974 Dataset Number: 8V0909896H  0027
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
Address CF: Lane Chge Asst 2
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
End-------------------------(Elapsed Time: 05:38)--------------------------
------------------------------2 Faults Found-------------------------------
I agree. That sounds like a problem with the wiring or a connector.
I'm not 100% certain, but considering that the only module that it seems to have difficulties with is Address CF: Lane Chge Asst 2, I think it will be OK.
Good question. If I were undertaking that project, I would disconnect the DCC module, remove it from the Gateway Installation List, and then re-scan the car to see what other modules now complain that it is missing.
dubgeek
C?ID=10070
Thanks. I found a post elsewhere that had some detailed steps.
I removed DCC from the CAN Gateway and Instrument Cluster. I think I'm supposed to make a change to Headlight Range, but what I saw there did not match what I read, so I left it alone.
I couldn't find the DCC in the passenger side of the trunk, at least not behind the removable panel. Someone on Reddit said the DCC module on the 8V RS3 is actually under the passenger seat, so I'll look there this evening.
I tried pulling fuse 13 which the manual says is "Electronic suspension, diagnostic module." That prevented the fault code from returning, but it caused an "automatic headlight leveling" fault and prevented the "ESC Off" button from working.
With fuse 13 back in and DCC removed from CAN and Instruments, the suspension fault is gone when I turn on the car and ESC Off works, but the fault comes back within a few minutes of driving and ESC turns back on. Hopefully unplugging the DCC solves that.
Attached an image of the headlight coding. Any idea what would need to change to tell the lights the car is on standard shocks and springs, not magnetic?
I suspect the issue here is that the headlight range module gets ride-height data from the DCC and if you want to do away with DCC, you're going to have to install the ride height sensor(s) that the equivalent car without DCC would have had.
Then I think the Long Coding, Byte 1, Bit 3 needs to be flipped to tell the module that it's getting height info directly from sensor(s).
dubgeek
C?ID=10070
Oof. That probably means sourcing a kit and running wires to the ecu. Kufatec has a kit that may work. I've emailed them. Alternately, I guess I could try to track down the source of the open circuit fault on the front left. It may be from moisture. My windshield washer reservoir has started leaking when I compete at autocross events. It holds fluid just fine under normal driving, but fluid spills out behind the front left fender liner when throwing the car around a course.
golfi_vend
Tartu, Estonia
C?ID=195131
I've done it.
You need to code ABS,
Remove DCC(module+coding),
Change ride height sensor and wire it from DCC to HeadlightRange module. And also code that one.
Cuzoe
C?ID=279487
If you go through with the full delete it would be worth getting the wiring diagrams for your car. If it's anything like an MQB Golf you just need to wire the height sensor to the headlight range module (or equivalent) and then tell it to read that data directly instead of getting it over the can bus from the DCC module.
Edit... @golfi_vend beat me by a minute or two, haha.
dubgeek
C?ID=10070
Yep. I've learned I need to rewire the headlight level sensors to the BCM.
However, while working on this I unplugged the DCC under the passenger seat. None of the coding I tried worked, so I reset everything back to factory with DCC enabled and talking to the cancellers.
After a 5 minute drive the suspension fault hadn't come back. I fired up VCDS and checked live data and found the front left "shock" is reporting once again. I guess unplugging the DCC reset whatever short I had.
We'll see how long things last on these different cancellers and I'll try to track down the wiper fluid leak to see if it's a contributing factor.
Cuzoe
C?ID=279487
Nice... I have DCC (retrofit into my Mk7 Golf) and I have front right open circuit. I have not done any troubleshooting beyond visual just yet.
I'm really hoping it's just a wiring issue, and in fact I have already run a new twisted pair from the hatch area up to the front right (currently coiled in the rain tray). I was running other wiring for other retrofits along the same path so figured no better time to route that one. I also have a new connector for the strut, in case that's the issue.
Occasionally I look and see if someone is selling a single DCC canceller, haha. That would let me eliminate the wiring as the issue, the lazy way.
