Audi TTS 8S controller 17
TommyKnocker
Italy
C?ID=269370
Are any plans to add code labels to the controller 17 on the new audi TTS 8s 2015?
Thanks!
I'm sure we'd like to. Got a scan so I can take a look at what (if anything) we know about that cluster at this point?
TommyKnocker
Italy
C?ID=269370
off course, auto scan is enough or you need the controller map?
sorry if it's a silly question but i'm relativelly new to VCDS....:p
Auto-Scan for now please.
If the car is relatively "clean" (unmolested, stock) please post the scan in the Reference section and then give us a link to the thread here.
TommyKnocker
Italy
C?ID=269370
unfortunatelly have been "molested" already, one of the molested parts is cluster 17, just modified a bit in order to add a feature.
here's the auto scan:
Monday,07,March,2016,13:20:29:31116
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: TRUZZZFV3Gxxxxxxxx   License Plate:
Mileage:    Repair Order: 1
Chassis Type: FV (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 42 44 52 55 5F A5 A9
Address 01: Engine (J623-CJXG)       Labels: None
   Part No SW: 8S0 906 259 B    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A1D00322426050B3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259B 001004
   ROD: EV_ECM20TFS0208S0906259B.rod
   VCID: 3C7098BBB7122BDE62-8068
20277 - Terminal 15 Voltage
          P151B 00 [032] - Implausible
   Part No SW: 0D9 300 013 D    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4904
   Revision: 06253104    Serial number: TFK01506131111
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1838642BE3EA27FEA6-804C
   Part No SW: 8S0 907 379 C    HW: 8S0 907 379 C
   Component: ESC           H31 0511
   Revision: 00000000    Serial number: 61825000000019
   Coding: 24AA608D0A9915B040940866C299930EA2240650A8021043C97045
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
   VCID: 418EE94FD0F0463631-8014
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0709
   Revision: 00026000    Serial number: 0372286377
   Coding: 000F0F1720
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 397E81AFB8201EF679-806C
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0030
   Revision: 20009000    Serial number: 15290000009000
   Coding: 400040000011101000
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6CD068FB87F27B5EB2-8038
   Subsystem 2 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Serial number: 00000000000000009142
   Subsystem 3 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Subsystem 4 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Part No SW: 5Q0 937 084 BS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0174
   Serial number: 01061516901097
   Coding: 04055C42C20106FD03044004B31807A80080000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 0A1C0E63AD46C56E20-805E
   Slave 1:
   Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 150619  038 0371
   Serial number: 00000001506170603073
   Coding: 1BC7F7
   Slave 2:
   Serial number: 24054864
   Coding: 00005D
   Slave 3:
   Serial number: 24 04 2015  00000453
   Serial number: 00000000000032619851
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
                    Fault Frequency: 9
                    Reset counter: 129
                    Mileage: 8644 km
                    Date: 2016.02.10
                    Time: 20:41:51
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [009] - -
                    Fault Frequency: 12
                    Reset counter: 89
                    Mileage: 8470 km
                    Date: 2016.02.01
                    Time: 19:55:19
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39291516900545
   Coding: 0000050011
   ROD: EV_EPHVA14AU3700000_AU37.rod
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       230615007
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide_AU37.rod
   VCID: 4382E347CAEC542623-8016
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    010 0870
   Serial number: 003M7R00SMH/
   Coding: 88CCF0000C8000005C5000CFC04800000065
   VCID: 4D96C57F1CA89256C5-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 002 706 15
   Serial number: 35700000000C8814251D
   Subsystem 2 - Part No SW: -----------    HW: 480 002 706 15
   Serial number: 35800000000E2814251A
   Subsystem 3 - Part No SW: -----------    HW: 480 010 206 15
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A057928DE38FCU
   Subsystem 4 - Part No SW: -----------    HW: 480 402 502 15
   Serial number: 3550002C11993FB423DC
   Subsystem 5 - Part No SW: -----------    HW: 480 402 502 15
   Serial number: 3560002BF1993FB5136J
   Subsystem 6 - Part No SW: -----------    HW: 480 402 909 14
   Component: PedP_Sensor_C  001 6149
   Serial number: 23000029F175A900C0C1
   Subsystem 7 - Part No SW: -----------    HW: 480 002 306 15
   Serial number: I0M000000008F3B8F41J
   Subsystem 8 - Part No SW: -----------    HW: 480 002 306 15
   Serial number: I0N00000000F25D8F41I
   Part No SW: 8S0 907 129 AL    HW: 8S0 907 129 AL
   Component: Lenks. Modul  H07 0140
   Revision: --------    Serial number: 91335OG300894
   Coding: 281C
   ASAM Dataset: EV_SMLSKLOMQB 019002
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0400205B8F62931E5A-8050
Address 17: Instruments (J285)       Labels: Redir Fail!
   Part No SW: 8S0 920 790 A    HW: 8S0 920 790 A
   Component: FBenRDW       H35 0259
   Coding: 042D0840798400080421E8C09000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 377A87978E3408868F-8062
16777026 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
                    Fault Frequency: 28
                    Reset counter: 125
                    Mileage: 8470 km
                    Date: 2016.02.01
                    Time: 20:12:32
   Part No SW: 8S0 907 468 B    HW: 8S0 907 468
   Component: GW MQB TT3    012 0223
   Revision: --------    Serial number: 10061510800743
   Coding: 030100042F025A004B000268BC0000000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 011003
   ROD: EV_GatewContiAU33X.rod
   VCID: 3F8AEFB7A60430C647-806A
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H07 0001
   Serial number: 20150604110808 RD095
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 2696587003
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00020.05.15
   Coding: 0101
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4586FD5FC4D86A160D-8010
   Serial number: 110615BFA14064
   Coding: 001F46225C00040100001402
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 428CE643D5F65D2E28-8016
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 9103
   ROD: EV_SteerAssisMQB.rod
   Serial number: 130615BFC16982
   Coding: 001F46225E00040100001402
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Address 55: Headlight Range (J745)       Labels: 4H4-907-357-V2.clb
   Coding: 03E200102B230200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
   ROD: EV_HeadlRegulAUDIMXBAU64X_AU37.rod
   VCID: 3460B09B9F42E39EAA-8060
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 044 B    HW: 8S0 035 044
   Component: MU-H-LN-EU    042 0229
   Serial number: A579F0F7500442
   Coding: 013354010000000011110002000800132F0000E100700000DE
   VCID: 2D56A5FF7C68B256E5-8078
   Media Player Position 1:
   Radio Tuner - Digital:
   Subsystem 2 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
   Engine Control Module 2:
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Seat Adjustment Driver Side:
   Subsystem 4 - Part No SW: V03 959 801 FA    HW: -----------
   Component: ECE 2016  --- 0134
   Air Conditioning Compressor:
   Diesel Pump Control Unit:
   Door Electronics Driver Side:
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Brake Assistance:
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Interior Monitoring:
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Sound System:
   Door Electronics Rear Left:
   Subsystem 12 - Part No SW: -----------    HW: -----------
   Subsystem 13 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
   Component: ControlUnit_H  H22 0136
   Serial number: C1000013051500010084
   Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1011
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 118
                    Mileage: 8414 km
                    Date: 2016.01.30
                    Time: 19:33:12
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000379050
   Coding: 0101000001010305000501000000000100
   ROD: EV_MFKBoschAU370_AU37.rod
   Part No SW: 8S0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0005
   Serial number: 150604200883
   VCID: 3B729BA7B21C2CE66B-806E
End-------------------------(Elapsed Time: 04:35)--------------------------
Looks like we have some info in progress on that one.
Is there something in particular you are trying to do with it?
TommyKnocker
Italy
C?ID=269370
on that controller in particular no at the moment, i coded blind to add a feature. just now i was noticing an error but i can't find the error code
about the car in general i was trying to add the traffic recognition feature, coding went well but even if sign recognition itself works flawless i have no MMI menu to turn it on\off? is a coding problem or an hardware limitation?
thanks for the help! much appreciated
NEtech
Denmark
C?ID=56995
What was your old/original coding in [17-Instrument] ?
TommyKnocker
Italy
C?ID=269370
that's an original scan
Address 17: Instruments (J285) Labels: None
Coding: 042D0840798000080421E8C09000800000000000
VCID: 377B5D1B8E82B2A66A7-8062
For traffic sign recognition, try byte 14, bit 6 in the instrument cluster and let us know if that helps.
Do you have a record (scan) from the car before anything was changed?
TommyKnocker
Italy
C?ID=269370
i have it on another laptop i'll hand over asap! i'll try as well new coding!
thanks!!!
TommyKnocker
Italy
C?ID=269370
Hello! I tried the new coding but unfortunately nothing has changed, traffic sign recognition kept working but no MMI menu avaible.
https://onedrive.live.com/redir?resid=50A8AF36807C76D1!3247&authkey=!AJiE-gOzVQSEWuU&v=3&ithint=photo%2cJPG
https://onedrive.live.com/redir?resid=50A8AF36807C76D1!3248&authkey=!ALu5_s-bYYT-D0w&v=3&ithint=photo%2cJPG
here's a scan with the car almost virgin, just a couple of errors due to the satellite allarm. Installer told me the two errors are expected.
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 42 44 52 55 5F A5 A9
VIN: TRUZZZFV3GXXXXXX
55-Xenon Range -- Status: Malfunction 0010
   Revision: --H13---
   ROD: N/A
   VCID: 3C714237B7A491FE875-8069
No ASAM data for: "EV_ECM20TFS0208S0906259B" ()
20277 - ROD - Unknown Error Code
          - 00 [032]
                    Fault Frequency: 0
                    Reset counter: 0
   ROD: N/A
   VCID: 1839BEA7E35C9DDE43D-804D
No ASAM data for: "EV_TCMDQ250021" ()
   ROD: N/A
   VCID: 418F33C3D046FC16D43-8014
No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
Address 05: Acc/Start Auth. (J518)       Labels: None
   Coding: 000F0F1720
   ROD: N/A
   VCID: 397F5B23B896A4D69C3-806C
No ASAM data for: "EV_KessyHellaMQBAB" ()
   ROD: N/A
   VCID: ECD132770744417ED75-80B9
No ASAM data for: "EV_AirCondiVAPrehAU33x" ()
459015 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 54
                    Mileage: 8138 km
                    Date: 2016.01.02
                    Time: 12:50:08
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 8A1D54EF2DF0FF4E459-80DF
   Coding: 1BC7F7
   Coding: 00005D
262936 - Sensor for Anti-Theft Alarm System
                    Fault Frequency: 35
                    Reset counter: 58
                    Mileage: 565 km
                    Date: 2015.08.08
                    Time: 15:22:53
          U10F4 00 [009] - -
                    Fault Frequency: 45
                    Reset counter: 22
                    Mileage: 111 km
                    Date: 2015.08.04
                    Time: 11:46:25
541204 - Databus
                    Reset counter: 67
                    Mileage: 8398 km
                    Date: 2016.01.27
                    Time: 17:49:00
   Coding: 0000040011
   ROD: EV_EPHVA14AU3700000_VW37.rod
Address 14: Susp. Elect. (J250)       Labels: None
   ROD: EV_AudiMagneRide.rod
   VCID: 438339CBCA5AEE06C6F-8016
   VCID: 4D971FF31C1E287620B-8018
   Crash sensor for front airbag; passenger side:
Address 16: Steering wheel (J527)       Labels: None
   Coding: 281C
   ROD: N/A
   VCID: 84017AD70FD4A93E3F5-80D1
No ASAM data for: "EV_SMLSKLOMQB" ()
   VCID: 3F8B353BA6B28AE6A27-806A
8531970 - Quiescent Current
          U1406 00 [008] - Too High
                    Mileage: 7883 km
                    Date: 2015.12.24
                    Time: 09:54:01
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 428D3CCFD540E70ECD9-8017
   ROD: EV_DCUPasseSideEWMAXKLO.rod
Address 55: Xenon Range (J745)       Labels: 4H4-907-357.clb
   ROD: EV_HeadlRegulAUDIMXBAU64X_AU57.rod
   VCID: 34616A179FF459BE4F5-8061
   Coding: E01800
   Coding: E01800
   Coding: E01800
   Coding: E01800
13705736 - Databus
                    Reset counter: 54
                    Mileage: 8138 km
                    Date: 2016.01.02
                    Time: 12:50:07
13706046 - Databus
                    Reset counter: 67
                    Mileage: 8398 km
                    Date: 2016.01.27
                    Time: 17:49:05
13706047 - Databus
                    Reset counter: 67
                    Mileage: 8398 km
                    Date: 2016.01.27
                    Time: 17:49:05
5538052 - Bulb for Low Beam Headlamp Left
          B1217 13 [008] - Open Circuit
                    Reset counter: 67
                    Mileage: 8398 km
                    Date: 2016.01.27
                    Time: 17:48:59
5538308 - Bulb for Low Beam Headlamp Right
          B1218 13 [008] - Open Circuit
                    Reset counter: 67
                    Mileage: 8398 km
                    Date: 2016.01.27
                    Time: 17:48:59
   ROD: EV_MUHig6C3Gen2HBAS.rod
   VCID: 2D577F737CDE087600B-8078
   Brake Assistance:
   Sound System:
3077 - Telephone baseplate
          B1051 13 [008] - Open Circuit
                    Reset counter: 68
                    Mileage: 6267 km
                    Date: 2015.11.04
                    Time: 11:25:18
   Coding: 0100000001010305000501000000000100
Address A9: Struct. Borne Sound (J869)       Labels: None
   VCID: 3B73412BB2AA96C68EF-806E
