2022 VW ID.3 Pro Performance Autoscan
SnowyDiag
Norway
C?ID=642601
Greetings everyone.
Attached is an autoscan with the current beta of a 22 ID.3, it needs brake service mode and the service reminder reset. Would this be interesting to get some SFD logs/data on?
Thursday,16,July,2026,22:55:05:16310
VCDS Version: 26.6.0.1 (x64)  HEX-V2 CB: 0.4713.5
Data version: 20260708 DS377.1
VIN: WVWZZZE1ZNP0   License Plate:
Mileage: 166240km-103296mi   Repair Order:
Chassis Type: E1-VWE3 (1EA)
Scan: 01 03 05 08 09 10 13 14 15 16 19 23 2B 3C 42 44 51 52 5F 69
          6C 75 7E 82 8C A5 C0 C6 CA D6 D7 8105 811E 811F 8120 8121 8123 8124 8125 8128
          C002 C003
VIN: WVWZZZE1ZNP0   Mileage: 166240km-103296miles
7E-Ctrl Head Dash -- Status: OK 0000
8C-HV Battery -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
8105-DC/DC Converter 12V -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623-EBJC)       Labels: 0EA-907-425-V1.clb
   Part No SW: 0EA 906 012 CJ    HW: 0EA 907 425 C
   Component: E-Vehicle     H01 2217
   CVN: A36B5DE6
   Coding: 010200060364140070080000001000402008060000000000
   ASAM Dataset: EV_VCU00XXX0200EA906012CJ 001002
   ROD: EV_VCU00XXX0200EA906012CL.rod
   VCID: 75B0025A4542CDC2F84-8020 SFD [x]
   VINID: 9E69EAAAA541A9E8000072411018BE0A0B
   Radiator shutter:
   Subsystem 1 - Part No SW: 1EA 965 501     HW: 1EA 965 501
   Component: V711           022 0006
   Serial number: 20210625060604073572
Address 03: ABS Brakes (J104)       Labels: 1EA-614-517-V1.clb
   Part No SW: 1EA 614 517 AR    HW: 1EA 614 517
   Component: ESC-ZF_EBC470 H15 0524
   Serial number: B005ZGC         Dataset Number: V03935378JH 0001
   Coding: 09954984153B903D9245A8DF11DD11A648294916443111492888886512949268228C889214CEEBBCFD0073D73DBF00
   ASAM Dataset: EV_Brake1ZFESCEPBMEB 013164
   ROD: EV_Brake1ZFESCEPBMEB.rod
   VCID: 025A6986048CEA7ACD6-8056 SFD [x]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 AB    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0725
   Serial number: --------------- Dataset Number: V03935344RT 0001
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003.rod
   VCID: 14765FDE6EF874CA6FA-8040
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 1EA 907 727 AH    HW: 1EA 907 727 R
   Component: Climatronic   H01 0460
   Coding: 002022217020320000100010111001102000102100121101000000000000
   ASAM Dataset: EV_ACClimaBHBMEB31X 002015
   ROD: EV_ACClimaBHBMEB31X.rod
   VCID: 005E638E0A80F86ADB2-8054
   Subsystem 1 - Part No SW: 1EA 820 021 A    HW: 1EA 820 021 A
   Component: J126 J126      002 0004
   Serial number: 00000000000000000300
   A/C compressor sub:
   Subsystem 2 - Part No SW: 1EA 816 551 G    HW: 1EA 816 551 G
   Component: J842 eKK       H07 0003
   Serial number: 1EA816551G080721308W
   Humidity sensor: exterior:
   Subsystem 3 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu      H05 0010
   Serial number: AB990B6800PAG0MUFU04
   Auxiliary Heater Control Module/PTC 2:
   Subsystem 4 - Part No SW: 1EA 963 581 D    HW: 1EA 963 581 D
   Component: 0123456789012  010 0160
   Serial number: 5390220CA21204000775
   Interior temperature sensor:
   Subsystem 5 - Part No SW: 5WA 907 527     HW: 5WA 907 527
   Component: E857           H01 0103
   Serial number: 00001100721161533514
   Expansion valve 1 for refrigerant:
   Subsystem 6 - Part No SW: 1EA 816 681 A    HW: 1EA 816 681 A
   Component: N636 EV1_KaMi  003 0003
   Serial number: E10000000000000078MV
   Expansion valve 2 for refrigerant:
   Subsystem 7 - Part No SW: 1EA 816 682 A    HW: 1EA 816 682 A
   Component: N637 EV2_KaMi  003 0003
   Serial number: E20000000000000077P8
   Expansion valve 3 for refrigerant:
   Subsystem 8 - Part No SW: 1EA 816 682 A    HW: 1EA 816 682 A
   Component: N638 EV3_KaMi  003 0003
   Serial number: E30000000000000077P8
   Carbon dioxide content sensor:
   Subsystem 9 - Part No SW: 4N0 907 658     HW: 4N0 907 658
   Component: G929 ICO2S     H05 0232
   A/C pressure/coolant temperature sensor 2:
   Subsystem 10 - Part No SW: 4N0 959 126 G    HW: 4N0 959 126 G
   Component: G826 pT-Sens2  H04 0002
   A/C pressure/coolant temperature sensor 3:
   Subsystem 11 - Part No SW: 4N0 959 126 H    HW: 4N0 959 126 H
   Component: G827 pT-Sens3  H04 0002
   Refrigerant Shut-Off Valve 1:
   Subsystem 12 - Part No SW: 1EA 816 681 A    HW: 1EA 816 681 A
   Component: V424 AV1_KaMi  003 0003
   Serial number: A10000000000000078MV
   Refrigerant Shut-Off Valve 2:
   Subsystem 13 - Part No SW: 1EA 816 701 A    HW: 1EA 816 701 A
   Component: N640 AV2_KaMi  003 0003
   Serial number: A20000000000010055ZS
   Refrigerant Shut-Off Valve 3:
   Subsystem 14 - Part No SW: 1EA 816 701 A    HW: 1EA 816 701 A
   Component: N641 AV3_KaMi  003 0003
   Serial number: A30000000000010055ZS
   Refrigerant Shut-Off Valve 4:
   Subsystem 15 - Part No SW: 1EA 816 702 A    HW: 1EA 816 702 A
   Component: N642 AV4_KaMi  003 0003
   Serial number: A4000000000001005EXM
   Refrigerant Shut-Off Valve 5:
   Subsystem 16 - Part No SW: 1EA 816 702 A    HW: 1EA 816 702 A
   Component: N643 AV5_KaMi  003 0003
   Serial number: A5000000000001005EXM
   A/C pressure/coolant temperature sensor 4:
   Subsystem 17 - Part No SW: 4N0 959 126 F    HW: 4N0 959 126 F
   Component: G395 pT-Sens1  H04 0002
   A/C pressure/coolant temperature sensor 5:
   Subsystem 18 - Part No SW: 4N0 959 126 G    HW: 4N0 959 126 G
   A/C pressure/coolant temperature sensor 6:
   Subsystem 19 - Part No SW: 4N0 959 126 H    HW: 4N0 959 126 H
329988 - Motor for Defroster Flap
          B1090 71 [01100000] - Actuator Stuck
59096 - Refrigerant Shut-Off Valve 3
          P1C29 00 [00100000] - Faulty
Address 09: Cent. Elect. (J519)       Labels: 1EA-937-BCM-V1.clb
   Part No SW: 1EA 937 089 S    HW: 1EA 937 089 A
   Component: SAM_H         H22 0307
   Serial number: 06102120201735- Dataset Number: V03935341HX 0001
   ASAM Dataset: EV_SAMVW31x 004001
   ROD: EV_SAMVW31x_004.rod
   VCID: 4EC28DB68054DE1A19E-801A SFD [x]
   Subsystem 1 - Part No SW: 10A 955 119 A    HW: 10A 955 119 A
   Component: FWISCHER_MYJT  003 0050
   Serial number: 909353F0402106200233
   Wiper motor control unit 2:
   Subsystem 2 - Part No SW: 10A 955 120 A    HW: 10A 955 120 A
   Component: FWISCHER_SL02  003 0050
   Serial number: 909453F0402034300282
   Subsystem 3 - Part No SW: 5Q0 955 555 B    HW: 5Q0 955 555 B
   Component: RLHSS          054 0208
   Serial number: S7Y21M07D26H06M35S06
   Subsystem 4 - Part No SW: 10A 941 193 H    HW: 10A 941 193 H
   Component: LiSi           H04 0513
   Serial number: TW571429062100021093
   Subsystem 5 - Part No SW: 10A 925 200 D    HW: 10A 925 200 D
   Component: DiEta          H07 0513
   Serial number: TW571409072100010937
   Subsystem 6 - Part No SW: 10A 959 561 J    HW: 10A 959 561 J
   Component: DACHKONSOLE    006 0007
   Serial number: 92661UG400092-------
Address 10: Park/Steer Assist (-----)       Labels:| 1EA-919-294.clb
   Part No SW: 1EA 919 294 D    HW: 1EA 919 294
   Component: PDC08K        H02 0421
   Serial number: 000016072194560 Dataset Number: V03935360LC 0001
   Coding: 0040014101
   ASAM Dataset: EV_EPHBO18VW3100000 002016
   ROD: EV_EPHBO18VW3100000_VWE3.rod
   VCID: 3D20DA7A3DF25582F04-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 1EA-907-572.clb
   Part No SW: 1EA 907 572 H    HW: 1EA 907 572
   Component: ARS510VW19 H03 0234
   Dataset Number: V03935362QL 0001
   Coding: 050308E34071404512474000000040C5AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 003010
   ROD: EV_FRONTRADARCONTIVW310_003.rod
Address 14: Susp. Elect. (J250)       Labels: 1EA-907-376.clb
   Part No SW: 1EA 907 376 C    HW: 1EA 907 376
   Component: DAEMPFUNGS-SG H05 0457
   Serial number: 2C7673241116042 Dataset Number: V03935346T  0001
   ASAM Dataset: EV_DCC3CONTITEMIC 002006
   ROD: EV_DCC3CONTITEMIC_002_VW38.rod
   VCID: 3A2AD1662CDC62BAD56-806E
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 CD    HW: 1EA 959 655 CD
   Component: VW40Airbag    010 0366
   Serial number: V191WnE0664     Dataset Number: V03935341DN 0001
   Coding: 88CC008000F0C000000000200000000051540000A1540000C000F680002B4065
   Shop #: WSC 15588 006 1048576
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X_VW41.rod
   VCID: 0550729A15A2DD42E84-8050 SFD [x]
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 10A 980 945     HW: 10A 980 945
   Component: BeltPretRevFL  602 0100
   Serial number: 10B857705D0223V00099
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 10A 980 946     HW: 10A 980 946
   Component: BeltPretRevFR  602 0100
   Serial number: 10B857706G0225V00017
   Subsystem 3 - Part No SW: -----------    HW: 440 000 604 21
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ000000DCC65B15P
   Subsystem 4 - Part No SW: -----------    HW: 440 002 404 21
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ000000E0579635A
   Subsystem 5 - Part No SW: -----------    HW: 440 002 107 21
   Component: SideSensor_Dr  00A 0189
   Serial number: 351CJC2C3C07C924800.
   Subsystem 6 - Part No SW: -----------    HW: 440 001 304 21
   Component: SideSensor_Pr  00A 0189
   Serial number: 352CJC2C34AF458AC009
   Subsystem 7 - Part No SW: -----------    HW: 440 000 907 21
   Component: FrontSensor_P  00A 014A
   Serial number: 355CJC0C4C65F6C8500C
Address 16: Steering wheel (J527)       Labels:* 1EA-953-507.clb
   Part No SW: 1EA 953 507 N    HW: 1EA 953 507 N
   Component: GSMMEB        007 0072
   Serial number: 000000160821260
   Coding: 0000
   ASAM Dataset: EV_SMLSKLOMEB 010001
   ROD: EV_SMLSKLOMEB.rod
   VCID: 42DAA986440C2A7A8D6-8016
Address 19: CAN Gateway (J533)       Labels: 1EA-937-012.clb
   Part No SW: 1EA 937 012 AB    HW: 1EA 937 012 A
   Component: ICAS1 Host-SG 065 0299
   Serial number: SJ8ICS150721117 Dataset Number: V03935364VL 0001
   GVL: 2D0800000608D0CC806290424C181040C400400000020000000000000000DE57
   ASAM Dataset: EV_GatewICAS1MEB 005001
   ROD: EV_GatewICAS1MEB.rod
   VCID: 70BE334E3A20E8EA2B2-8024 SFD [x]
   Subsystem 1 - Part No SW: 1EA 915 181 B    HW: 1EA 915 181 A
   Component: J367-BDMConti  H04 1074
   Serial number: 7738610100210722054F
   Subsystem 2 - Part No SW: 3G0 959 542 A    HW: 3G0 959 542 A
   Component: J IEEHOD1ZONE  251 0301
   Serial number: 00000000230100551250
   Left taillight 1:
   Subsystem 3 - Part No SW: 10A 945 207     HW: 10A 945 207 H
   Component: iSBBR li 1     H04 0016
   Serial number: 000000000_H04_161645
   Right taillight 1:
   Subsystem 4 - Part No SW: 10A 945 208     HW: 10A 945 208 H
   Component: iSBBR re 1     H04 0016
   Serial number: 000000000_H04_162043
   Subsystem 5 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA    005 0403
   Serial number: 000000000ZL21187FG8H
   Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA    005 0314
   Serial number: 00000000000049850634
   Subsystem 7 - Part No SW: 1EA 959 442 H    HW: 1EA 959 442
   Component: MFL            H08 0032
   Serial number: 17029815091652100053
8 Faults Found:
8471814 - Databus
          U1123 00 [00101110] - Received Error Message
          [error_value_ESC_50_EPB_Fehlerstatus_02]
                    Fault Frequency: 52
                    Mileage: 166049 km
                    Date: 2026.07.11
                    Time: 18:29:31
7467521 - Data Set Implausible
          B2012 00 [00101111] - -
          [Data_set_implausible_CMS]
                    Mileage: 166049 km
                    Date: 2026.07.11
                    Time: 16:53:37
7467522 - Data Set Implausible
          [Data_set_implausible_HLC]
                    Mileage: 166049 km
                    Date: 2026.07.11
                    Time: 16:53:37
8491266 - Secure Onboard Communication
          U14FE 00 [00101100] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Fault Frequency: 39
                    Mileage: 166049 km
                    Date: 2026.07.11
                    Time: 17:31:54
9371914 - Predictive Route Data
          B1630 02 [01101101] - Signal Failure
                    Fault Frequency: 14
                    Mileage: 166049 km
                    Date: 2026.07.11
                    Time: 17:33:51
7467526 - Data Set Implausible
          [Data_set_implausible_ECM]
                    Fault Frequency: 34
                    Mileage: 166049 km
                    Date: 2026.07.11
                    Time: 16:53:37
7467524 - Data Set Implausible
          [Data_set_implausible_DCP]
                    Mileage: 166049 km
                    Date: 2026.07.11
                    Time: 16:53:37
8398626 - Control Module 2 for Electric Drive Power
          U0292 00 [00101111] - No Communications
          [EM2_01_no_communication]
                    Mileage: 166049 km
                    Date: 2026.07.12
                    Time: 11:23:48
Address 23: Brake Booster (J539)       Labels: 1EA-909-059-V1.clb
   Part No SW: 1EA 909 059 AN    HW: 1EA 909 059
   Component: EBB-ZF-Gen1   H28 0626
   Serial number:                 Dataset Number: V03935344AS 0001
   Coding: 08951184003B103D884500DF20DD2020202020202021212121000404040404040404848484840008001000
   ASAM Dataset: EV_BrakeBoostZFMEB 012153
   ROD: EV_BrakeBoostZFMEB_012_VWE3.rod
   VCID: 0652759628A4D65AE1E-8052 SFD [x]
2101906 - Brake/TCS Channel 1
          C055E 00 [00100110] - Hydraulic Leak
          [EBB_PRESS_CHAR_IMPLAUSIBLE]
                    Mileage: 166240 km
                    Date: 2026.07.16
                    Time: 12:52:58
                    Voltage: 12.2 V
   Part No SW: 1EA 905 861     HW: 2Q0 905 861 B
   Component: ELV-MEB       H10 0040
   Serial number: 21000197806005
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 74B63F5E4E38D4CACFA-8020
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 L    HW: 2Q0 907 686 E
   Component: HRE_Master    H25 0289
   Serial number: 00000581608125  Dataset Number: V03935346QB 0001
   Coding: 66994750
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001016
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   VCID: 43D4AC825B162372860-8016
   Subsystem 1 - Part No SW: 2Q0 907 685 L    HW: 2Q0 907 685 E
   Component: HRE_Slave      H25 0289
   Serial number: 00000581371521
   Lane change assistance display left:
   Subsystem 2 - Part No SW: 5H1 949 145     HW: 5H1 949 145
   Component: SWA LED VL     H05 0005
   Serial number: 00000000000016909060
   Lane change assistance display right:
   Subsystem 3 - Part No SW: 5H1 949 146     HW: 5H1 949 146
   Component: SWA LED VR     H05 0005
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 1EA 959 593 E    HW: 1EA 959 593
   Component: TSG FS        003 0551
   Serial number: 0000448595939  Dataset Number: V03935403FE 0001
   Coding: 003D1220D000848005001000
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
   ROD: EV_DCU3DriveSideMAXHCONT.rod
   VCID: 44D6AF9E5E18244ABFA-8010
   Door operating panel: driver side:
   Subsystem 1 - Part No SW: 10A 959 862 N    HW: 10A 959 862 N
   Component: EX36 TBF_FS    H21 0107
   Serial number: 0353-24.06.21-------
   Subsystem 2 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000052206760
   Part No SW: 1EA 907 144 AG    HW: 1EA 907 144 H
   Component: BASGEN1MQB37  246 5024
   Serial number: 00449051 Dataset Number: V03935342PE 0001
   Coding: 0000000000000201000002010100010000000100010102
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   VCID: 78AE0B6E5250B0AAE32-802C
Address 51: Electric Drive (J841)       Labels: 1EA-907-121.clb
   Part No SW: 1EA 907 121 BC    HW: 1EA 907 121 C
   Component: MEB INV4.0    H09 6045
   Serial number: VES_N7000695598 CVN: 5645535F4E37303030363935
   ASAM Dataset: EV_DMCM15000F11EA907121BC 001012
   ROD: EV_DMCM15000F11EA907121AC.rod
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 1EA 959 592 E    HW: 1EA 959 592
   Component: TSG BFS       003 0551
   Serial number: 0000447130691  Dataset Number: V03935403FF 0001
   Coding: 003D1020DC00048001801000
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
   ROD: EV_DCU3PasseSideMAXHCONT.rod
   Subsystem 1 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000052462827
Address 5F: Information Electr. (J794)       Labels:| 10A-035-IC3-V1.clb
   Part No SW: 10A 035 816 J    HW: 10A 035 816 A
   Component: IC3-SF-AR-EU  H20 0561
   Dataset Number: V03935392WL 0001
   Coding: 23106030000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 001001
   ROD: EV_MUICASSAFEPart_001_VWE3.rod
   VCID: 23140C02BB560372E60-8076 SFD [x]
   Subsystem 1 - Part No SW: 10A 919 605 K    HW: 10A 919 605 K
   Component: ABT_E_10       H48 3080
   Serial number: VDD02414072107010232
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383 B    HW: 5H0 907 383
   Component: Anhaenger     H10 0057
   Serial number: 000000000005801 Dataset Number: V03935335VA 0001
   Coding: 0100000202001400
   ASAM Dataset: EV_TrailFunctGener3Hella 001012
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 2D00EA3AED92C502404-8078
Address 6C: Back-up Cam. (J928)       Labels:| 5WA-980-556.clb
   Part No SW: 1EA 907 556 R    HW: 5WA 907 556 C
   Component: TV eEntry     H17 0284
   Serial number: FZ6ESP290621000 Dataset Number: V03935346RB 0001
   Coding: 02030C04FC3000
   ASAM Dataset: EV_CamSysTVFicosMEB 006005
   ROD: EV_CamSysTVFicosMEB.rod
   VCID: 49C8BEAA793AF9224CC-801C
   Front peripheral camera slave:
   Subsystem 1 - Part No SW: 5WA 980 546 C    HW: 5WA 980 546 C
   Component: R243 UmfKamSV  H16 0040
   Serial number: FCLMAR13042100010324
   Peripheral camera slave: left:
   Subsystem 2 - Part No SW: 5WA 980 546 D    HW: 5WA 980 546 C
   Component: R244 UmfKamSL  H16 0050
   Serial number: FCLMAR16062100045640
   Right peripheral camera slave:
   Subsystem 3 - Part No SW: 5WA 980 546 D    HW: 5WA 980 546 C
   Component: R245 UmfKamSR  H16 0050
   Serial number: FCLMAR11062100067125
   Rear peripheral camera slave:
   Subsystem 4 - Part No SW: 5WA 980 546 D    HW: 5WA 980 546 C
   Component: R246 UmfKamSH  H16 0050
   Serial number: FCLMAR13072100052700
   Part No SW: 10A 035 284 G    HW: 10A 035 284
   Component: OCUGen4       H17 0538
   Serial number: 0000000106VIBB9 Dataset Number: V03935351PP 0001
   Coding: 02310010106880008005460000000000
   ASAM Dataset: EV_OCUGen4 001031
   ROD: EV_OCUGen4_VWE3.rod
   VCID: 1F1C00F2973E2792C28-804A SFD [x]
1375744 - Secure Onboard Communication
          U14FE 00 [00101000] - Signature Verification Failed
                    Reset counter: 32
                    Mileage: 166049 km
                    Date: 2026.07.11
                    Time: 17:33:50
Address 7E: Ctrl Head Dash (J1254)       Labels:| 10A-920-320.clb
   Part No SW: 10A 920 320 C    HW: 10A 920 320 A
   Component: FAHRERDISPLAY 021 0531
   Serial number: 1F1X5690-352962
   Coding: EE70
   ASAM Dataset: EV_DashBoardLGMEB 001027
   ROD: EV_DashBoardLGMEB_001_VWE3.rod
   VCID: 157022DA65026DC2184-8040 SFD [x]
Address 82: Head Up Display (J898)       Labels: 10B-919-608.clb
   Part No SW: 10B 919 608 F    HW: 10B 919 608 D
   Component: HeadupDisplay H20 0146
   Serial number: ARHUD
   ASAM Dataset: EV_ARHeadUpDisplMEB 001036
   ROD: EV_ARHeadUpDisplMEB_001.rod
   VCID: 2A0AE126DC7CD23AA56-807E
Address 8C: HV Battery (J840)       Labels: 0Z1-915-184.clb
   Part No SW: 0Z1 915 184 J    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 007 1041
   Serial number: 000000190721010 Dataset Number: V03935382CA 0001 CVN: 9534C8BD00000000000000000000000000000000
   ASAM Dataset: EV_BMCeVWBSMEB 002015
   ROD: EV_BMCeVWBSMEB_002_VWE3.rod
   VCID: 41D8A68A410A316294C-8014
   Cell module control module 1:
   Subsystem 1 - Part No SW: 0Z1 915 140 BE    HW: 0Z1 915 140 BC
   Component: SX6  X74  CMC  005 1000
   Serial number: 00000012072110010666
   Cell module control module 5:
   Subsystem 2 - Part No SW: 0Z1 915 140 F    HW: 0Z1 915 140 D
   Serial number: 00000013072110020395
   Cell module control module 9:
   Subsystem 3 - Part No SW: 0Z1 915 140 F    HW: 0Z1 915 140 D
   Serial number: 00000013072110060393
   Coolant heating:
   Subsystem 4 - Part No SW: 1EA 963 231 A    HW: 1EA 963 231
   Component: J848 HV-PTC    H03 0500
   Serial number: CH211893014404000278
42532 - HV Battery System
          U163F 00 [00101110] - No Communication with Application Server
          [Diag_C_EVCAN_ORU_01_TO]
                    Mileage: 166049 km
                    Date: 2026.07.12
                    Time: 19:21:54
                    Mode HV battery actual value: Driving mode
                    Voltage terminal 30: 13.079 V
                    H-V battery voltage: 428.750 V
                    Current of H-V / hybrid battery: -40  C
                    Current of H-V / hybrid battery: -8.670 A
                    Current 2 of H-V / hybrid battery: -11.000 A
                    maximum voltage for battery cells-Index 1: 0
                    maximum voltage for battery cells-Value: 3.975 V
                    minimum voltage for battery cells-Index 1: 0
                    minimum voltage for battery cells-Value: 3.962 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* 1EA-980-65X-V1.clb
   Part No SW: 1EA 980 654 L    HW: 1EA 980 654
   Component: MEB MFK 4.1   H03 5332
   Dataset Number: V03935361MN 0001
   Coding: 0008302E1F9100E8162420000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001057
   ROD: EV_MFK41ValeoMEB.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 1EA-035-335.clb
   Part No SW: 10A 035 335 C    HW: 1EA 035 335
   Component: E_SOUND_SG    H05 0006
   Serial number: JTK072100821812
   ASAM Dataset: EV_ESoundMEBHarma 004011
   ROD: EV_ESoundMEBHarma_004_VWE3.rod
   VCID: 186E2BEE721050AA032-804C
Address C6: Batt. Chrg. (J1050)       Labels:| 1EA-915-684.clb
   Part No SW: 1EA 915 684 EJ    HW: 1EA 915 684 BF
   Component: HV_CHARGER    H52 1019
   Serial number: 92832UEQ000GN
   Coding: 1080
   ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002017
   ROD: EV_OCCXPhase1KLOMEB01B.rod
   VCID: 074C78922FAECF529A8-8052
3280897 - Charging Station
          B1AD0 F0 [01101101] - Identification Failed
          [ETHTRCV_30_AR7000_SLAC_STEP_1_SET_CCO_Timeout]
                    Mileage: 166232 km
                    Date: 2026.07.15
                    Time: 01:15:08
                    DID 1DA0: AC main charge
                    DID 1DAC: Charging
                    Frequency: 1003 Hz
                    Control voltage: 6029.0 mV
                    Pulse duty factor: 12.7 %
                    Activation charge cover lock charge socket A: not requested
                    Lock for high-voltage charging connector: locked
                    Status connect. recognition: detected
                    Charging socket temperature sensor AC: 30.0  C
                    Temperature sensor 1: resistance value: 1061 Ohm
                    DID 15E2: 23.0  C
                    DID 081C: 2 W
                    DID 081D: 1783 W
                    DID 081E: 0 W
                    DID 0286: 13.3 V
                    DID 497C: not active
                    DID 537A: 14.5 V
                    DID 1525: 3222 mV
                    DID 4219: high-voltage de-energization not detected
                    DID 5372: 20.0  C
                    No. of lockings: 6077
                    No. of connections: 783
                    Number of successful charging connector locks: 2495
                    Wake-up counter: contact (proximity): 0
                    Wake-up counter: Control Pilot: 0
                    Charging standard abort: status: not active
                    Loading plan: status: Not available
                    Price/performance table: status: Not available
                    Transport Layer Security (TLS) status communication: not active
                    DID 103A: supported
                    number_evse_slac: 0
                    PLC_modem_status: active
                    number_slac_attemps: 3
                    DID 1033: SLAC_failed
                    DID 1038: no_description
                    DID 1039: supported
                    Target HV charge current: 4.5 A
                    Powerline communication: charging process status: Standby
3280899 - Charging Station
          [ETHTRCV_30_AR7000_SLAC_STEP_3_PARAM_REQ_Timeout]
                    Mileage: 166232 km
                    Date: 2026.07.15
                    Time: 01:14:53
                    DID 1DAC: Charging
                    Frequency: 1003 Hz
                    Control voltage: 6035.0 mV
                    Temperature sensor 1: resistance value: 1060 Ohm
                    DID 15E2: 23.0  C
                    DID 081C: 0 W
                    DID 081D: 1781 W
                    DID 081E: 0 W
                    DID 0286: 13.3 V
                    DID 537A: 14.5 V
                    DID 1525: 3222 mV
                    DID 5372: 20.0  C
                    DID 103A: supported
                    number_evse_slac: 0
                    number_slac_attemps: 1
                    DID 1033: SLAC_active
                    DID 1039: supported
                    Target HV charge current: 4.4 A
5242881 - Communication Authentication
          U3035 00 [01101000] - Invalid Signal
                    Reset counter: 10
                    Mileage: 166049 km
                    Date: 2026.07.12
                    Time: 19:52:23
3211312 - Internal Control Module Memory Check Sum Error
          B2000 00 [01101101] - -
          [switch_s2_malfunction]
                    Mileage: 145213 km
                    Date: 2025.07.26
                    Time: 15:47:51
                    DID 0286: 13.4 V
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Lock for high-voltage charging connector: moved too far detected
                    Temperature sensor 1: resistance value: 1056 Ohm
                    DID 15E2: 26.0  C
                    DID 537A: 14.2 V
                    DID 5372: 26.0  C
   Part No SW: 89A 907 594 BD    HW: 89A 907 594
   Component: SAD_STG_1     006 0031
   Dataset Number: V03935318KB 0001
   Coding: 01002073100F
   Shop #: WSC 15611 006 1048576
   ASAM Dataset: EV_SunRoofCONTIAU736 009012
   VCID: 7AAA11666C5CA2BA956-802E
   Part No SW: 992 941 572 AE    HW: 992 941 572 A
   Component: LED1L         H08 9202
   Dataset Number: V03935336SE 0001
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 6692551608E4365A41E-8032
   Component: LED1R         H08 9202
   Dataset Number: V03935336SL 0001
Address 8105: DC/DC Converter 12V (A19)       Labels: 1EA-907-190-V1.clb
   Part No SW: 1EA 907 190 G    HW: 1EA 907 190 G
   Component: DCDC Gen4H13 1142
   Revision: 00H13000
   ASAM Dataset: EV_DCDC10030111EA907190G 001022
   ROD: EV_DCDC10030111EA907190G.rod
   VCID: 382ECB6E12D070AA232-806C
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 D    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: V04-007-XXX-SWC4.clb
   Part No: V04 007 006
   Component: ICAS1 Sys_Ada 0299
   Dataset Number: V03935361TL 0001
   ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
   ROD: EV_AppServe1Syste1ICAS1.rod
   VCID: 678C58120FEE2F527A8-8032 SFD [x]
Address 8124: App server 1 system 2 Java (SWC5)       Labels: V04-007-XXX-SWC5.clb
   Part No: V04 007 006 A
   Component: ICAS1 Sys_Jav 0299
   ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
   ROD: EV_AppServe1Syste2ICAS1.rod
   VCID: 280E1B2EC270E02AB32-807C SFD [x]
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:| V04-007-XXX-SWC6.clb
   Part No: V04 007 003 GG
   Component: IC3-IVI-D-EU  0561
   Dataset Number: V03935389XR 0001
   ASAM Dataset: EV_MUICASIVIPart 002007
   ROD: EV_MUICASIVIPart_002_VWE3.rod
   VCID: 72BA3946342CDAFADD6-8026 SFD [x]
Address 8128: Light line display (J145)       Labels: 10B-919-451.clb
   Part No SW: 10B 919 451 C    HW: 10B 919 451 B
   Component: Lichtlinie1   004 0107
   ASAM Dataset: EV_SmartLight1MEB 002001
   ROD: EV_SmartLight1MEB_002_VWE3.rod
Address C002: SW Cluster Embedded (SWC2)       Labels: V04-007-XXX-SWC2.clb
   Part No: V04 007 006 B
   Component: ICAS1 SWCL_Em 0299
   Dataset Number: V03935362KU 0001
   ASAM Dataset: EV_SWCLEmbed1ICAS1 005001
   ROD: EV_SWCLEmbed1ICAS1.rod
   VCID: 29081E2AD97AD922ACC-807C SFD [x]
7467527 - Data Set Implausible
          [Data_set_implausible_ECP]
                    Fault Frequency: 32
8491267 - Secure Onboard Communication
          U14FF 00 [01100100] - Signature Generation Failed
          [SOK_signature_creation_failed]
                    Mileage: 166232 km
                    Date: 2026.07.16
                    Time: 01:37:49
Address C003: SW Cluster Housekeeping (SWC3)       Labels: V04-007-XXX-SWC3.clb
   Part No: V04 007 006 C
   Component: ICAS1 SWCL_HK 0299
   ASAM Dataset: EV_SWCLHouse1ICAS1 005001
   ROD: EV_SWCLHouse1ICAS1.rod
   VCID: 2A0AE126DC7CD23AA56-807E SFD [x]
End----------(Elapsed Time: 02:13, VBatt start/end: 14.4V/14.4V)-----------
------------------------------19 Faults Found------------------------------
Best regards
You may place an order for (free Beta) SFD Service.
SnowyDiag
Norway
C?ID=642601
Completed a few operations today with no issues. I used a hotspot from my phone with latency 28ms, 68Mbps upload and 8 Mbps download.
Service reset:
The automatic SRI function works with address 17, which is not present in the MEB cars. Servicing adaption is moved to address 5F.
Changing the adaptation of channel IDE12981 to 1, then back to 0 sucsessfully reset the service reminder (It reset the reminder when 1 was entered, but remaining days was then 729, not 730 as it was when zero was set). Its value was shown as zero at the start. Relocking the module afterwords works well.
Brake lining mode:
Unlock of the ABS module worked first try.
Start lining change mode failed at the first attempt as I was holding the brake, i then let go of the brake and tried again and it worked. Ending av brake lining change mode and relocking of module also worked well.
Tried the SFD lock all function, where 15 acks where recevied.
Running Beta 26.6.0. Below is all the files from Debug folder (last digits of VIN removed):
AdpLog.CSV:
Address 5F,10A 035 816 J,channel IDE12981-Inspection: time since the last inspection,adapted from,0 d,to,1 d,Saturday,18,July,2026,10:08:07:16310,WVWZZZE1ZNP0
Address 5F,10A 035 816 J,channel IDE12981-Inspection: time since the last inspection,adapted from,1 d,to,0 d,Saturday,18,July,2026,10:08:15:16310,WVWZZZE1ZNP0
GSElog.CSV:
Address 0x03,1EA 614 517 AR,UDS Basic Settings,IDE03331-ENG114972-Start lining change mode,Saturday,18,July,2026,10:12:51:16310,WVWZZZE1ZNP0
Address 0x03,1EA 614 517 AR,UDS Basic Settings,IDE03331-ENG114972-Start lining change mode,Saturday,18,July,2026,10:13:49:16310,WVWZZZE1ZNP0
Address 0x03,1EA 614 517 AR,UDS Basic Settings,IDE03330-ENG114972-End brake pad change mode,Saturday,18,July,2026,10:14:39:16310,WVWZZZE1ZNP0
Address 0x03,1EA 614 517 AR,UDS Basic Settings,IDE03331-ENG114972-Start lining change mode,Saturday,18,July,2026,10:17:27:16310,WVWZZZE1ZNP0
Address 0x03,1EA 614 517 AR,UDS Basic Settings,IDE03331-ENG114972-Start lining change mode,Saturday,18,July,2026,10:18:08:16310,WVWZZZE1ZNP0
Address 0x03,1EA 614 517 AR,UDS Basic Settings,IDE03330-ENG114972-End brake pad change mode,Saturday,18,July,2026,13:28:18:16310,WVWZZZE1ZNP0
SFDlog.CSV:
WVWZZZE1ZNP0,Address 0x5F,10A 035 816 J,Online SFD,Saturday,18,July,2026,10:03:41,H17-026960,SFD challenge retrieval success, 583 bytes
WVWZZZE1ZNP0,Address 0x5F,10A 035 816 J,Online SFD,Saturday,18,July,2026,10:03:44,H17-026960,SFD unlock token retrieval success, 852 bytes
WVWZZZE1ZNP0,Address 0x5F,10A 035 816 J,Online SFD,Saturday,18,July,2026,10:03:44,H17-026960,SFD unlock token transmitted to controller
WVWZZZE1ZNP0,Address 0x5F,10A 035 816 J,Online SFD,Saturday,18,July,2026,10:03:45,H17-026960,Unlock_successful
WVWZZZE1ZNP0,Address 0x5F,10A 035 816 J,Online SFD,Saturday,18,July,2026,10:10:31,H17-026960,Re-lock successful
WVWZZZE1ZNP0,Address 0x03,1EA 614 517 AR,Online SFD,Saturday,18,July,2026,10:11:39,H17-026960,SFD challenge retrieval success, 583 bytes
WVWZZZE1ZNP0,Address 0x03,1EA 614 517 AR,Online SFD,Saturday,18,July,2026,10:11:41,H17-026960,SFD unlock token retrieval success, 852 bytes
WVWZZZE1ZNP0,Address 0x03,1EA 614 517 AR,Online SFD,Saturday,18,July,2026,10:11:41,H17-026960,SFD unlock token transmitted to controller
WVWZZZE1ZNP0,Address 0x03,1EA 614 517 AR,Online SFD,Saturday,18,July,2026,10:11:44,H17-026960,Unlock_successful
WVWZZZE1ZNP0,Address 0x03,1EA 614 517 AR,Online SFD,Saturday,18,July,2026,13:30:15,H17-026960,Re-lock successful
WVWZZZE1ZNP0,Address 0x19,1EA937012AB,SFD re-lock,Saturday,18,July,2026,13:31:19,H17-026960,SFD re-lock (CAN)...Done. Acks received: 15
+30 hit points. :thumbs:
SnowyDiag
Norway
C?ID=642601
I've played around with different ways of starting an SFD session in 26.9 today, and found a bug that seems to be reproducable.
Here are the steps to reproduce it:
  • Performing an Autoscan.
  • Open a module from the scan results window (in this case 03 ABS).
  • Click SFD button, a new windows is shown (lets call this window A).
  • Click "start SFD session".
  • A new windows pops up (Window B).
  • Type password and click "Start SFD session".
  • Window B confirms session has started, then click "Go back".
  • Window A does not refresh its status and says "No SFD session!" in red.
  • Click "Done, go back" to return to module, then click SFD.
  • Window A opens and displays correctly that the session is active.
The same issue is NOT present when opening the module directly with "select" button.
Attempt 0: 10:42: Autoscan followed by CAN DTC clear.
Repro 1 - 11:03: Start from Module. Window A refreshes correctly.
Repro 2 - 11:09: Autoscan. Window A does not refresh automatically.
Repro 3 - Start from module, but SFD session start failed. Likely wrong password?
Repro 4 - 11:19: Start from Module. Window A refreshes correctly.
Repro 5 - 11:25: Autoscan followed by CAN DTC clear. Window A does not refresh automatically.
In all the attempts (appart from 3) the session started correctly and the issue is only that the window does not update correctly, otherwise the functions seems to work.
Between the attempts VCDS was closed and the interface was disconnected from the car and computer.
Attached below are screenshots of the windows, the SFDlog and an autoscan.
Session started from Auto-Scan:
"Go back" clicked:
"Done, Go Back" clicked, followed by "SFD":
SFDLog.CSV:
WVWZZZE1ZNP000000,,,Start SFD Session,Sunday,06,September,2026,10:42:42,H17-026960,SFD session start successful
WVWZZZE1ZNP000000,Address 0x03,1EA 614 517 BC,Online SFD,Sunday,06,September,2026,10:44:40,H17-026960,SFD challenge retrieval success, 583 bytes
WVWZZZE1ZNP000000,Address 0x03,1EA 614 517 BC,Online SFD,Sunday,06,September,2026,10:44:43,H17-026960,SFD unlock token retrieval success, 852 bytes
WVWZZZE1ZNP000000,Address 0x03,1EA 614 517 BC,Online SFD,Sunday,06,September,2026,10:44:43,H17-026960,SFD unlock token transmitted to controller
WVWZZZE1ZNP000000,Address 0x03,1EA 614 517 BC,Online SFD,Sunday,06,September,2026,10:44:45,H17-026960,Unlock_successful
WVWZZZE1ZNP000000,Address 0x03,1EA 614 517 BC,Online SFD,Sunday,06,September,2026,10:57:16,H17-026960,Re-lock successful
WVWZZZE1ZNP000000,,,Start SFD Session,Sunday,06,September,2026,11:03:48,H17-026960,SFD session start successful
WVWZZZE1ZNP000000,,,Start SFD Session,Sunday,06,September,2026,11:09:34,H17-026960,SFD session start successful
WVWZZZE1ZNP000000,Address 0x03,1EA 614 517 BC,Online SFD,Sunday,06,September,2026,11:16:07,H17-026960,SFD challenge retrieval success, 583 bytes
WVWZZZE1ZNP000000,Address 0x03,1EA 614 517 BC,Online SFD,Sunday,06,September,2026,11:16:10,H17-026960,SFD unlock token retrieval fail, error TR-19 (-10)
WVWZZZE1ZNP000000,,,Start SFD Session,Sunday,06,September,2026,11:19:19,H17-026960,SFD session start successful
WVWZZZE1ZNP000000,,,Start SFD Session,Sunday,06,September,2026,11:25:05,H17-026960,SFD session start successful
Autoscan:
Sunday,06,September,2026,10:38:56:16310
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.5
VIN: WVWZZZE1ZNP   License Plate:
          C002 C003
VIN: WVWZZZE1ZNP   Mileage: 168795km-104884miles
8124-App server 1 system 2 Java -- Status: OK 0000
   Part No SW: 0EA 906 012 DG    HW: 0EA 907 425 C
   Component: E-Vehicle     H01 2604
   CVN: 80386199
   ASAM Dataset: EV_VCU00XXX0200EA906012DG 001001
   ROD: EV_VCU00XXX0200EA906012DN.rod
   VCID: 73B43C424B36D3F2EA2-8026 SFD [x]
   Radiator shutter:
   Part No SW: 1EA 614 517 BC    HW: 1EA 614 517
   Component: ESC-ZF_EBC470 H15 0526
   VCID: 74B63F5E4E38D4CAF38-8020 SFD [x]
   VCID: 14765FDE6EF874CA538-8040
   Part No SW: 1EA 907 727 AM    HW: 1EA 907 727 R
   Component: Climatronic   H01 0475
   VCID: 0550729A15A2DD42D46-8050
   A/C compressor sub:
          B1090 71 [01100100] - Actuator Stuck
                    Mileage: 168704 km
                    Date: 2026.09.04
                    Time: 22:34:51
                    Voltage terminal 30: 14.40 V
                    Inside temperature: 12.60  C
                    Outside temperature: 8.50  C
                    Defrost door - Specified value: 214
                    Defroster flap: actual value: 188
                    Defroster flap: actual value: 86.5 %
   Part No SW: 1EA 937 089 AJ    HW: 1EA 937 089 A
   Component: SAM_H         H22 0311
   VCID: 0652759628A4D65ADDC-8052 SFD [x]
   Coding: 0040014101
   VCID: 3D20DA7A3DF25582CC6-8068
209054 - Databus
          U1123 00 [00101000] - Received Error Message
          [FAULT_BV_BLINDNESS_ERROR]
                    Reset counter: 39
                    Mileage: 168705 km
                    Date: 2026.09.04
                    Time: 22:35:39
   VCID: 3A2AD1662CDC62BAE94-806E
   Part No SW: 1EA 959 655 ER    HW: 1EA 959 655 CD
   Component: VW40Airbag    010 0385
   Serial number: V191WnE0664     Dataset Number: V03935399CU 0001
   Shop #: WSC 99999 999 2097151
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001016
   ROD: EV_AirbaVW40ALVVW38X.rod
   VCID: 157022DA65026DC2246-8040 SFD [x]
   Component: FrontSensor_D  00A 014A
   Coding: 0000
   VCID: 42DAA986440C2A7AB14-8016
   Part No SW: 1EA 937 012 AD    HW: 1EA 937 012 A
   Component: ICAS1 Host-SG 065 0329
   Serial number: SJ8ICS150721117 Dataset Number: V03935500VU 0001
   VCID: 72BA3946342CDAFAE14-8026 SFD [x]
   Left taillight 1:
   Right taillight 1:
8471814 - Databus
                    Fault Frequency: 23
                    Mileage: 168582 km
                    Date: 2026.09.03
                    Time: 17:58:38
          U14FE 00 [00101110] - Signature Verification Failed
                    Fault Frequency: 33
                    Mileage: 168581 km
                    Date: 2026.09.03
                    Time: 16:10:40
                    Mileage: 168582 km
                    Date: 2026.09.03
                    Time: 16:33:25
8515846 - Heater Coolant Shut-Off Valve
          P1BF1 00 [01100100] - Input Voltage Fault
          [HVLM_no_ac_voltage_detected]
                    Reset counter: 39
                    Mileage: 168582 km
                    Date: 2026.09.04
                    Time: 04:44:30
8515864 - AC Charging Connector Recognition
          P30C1 00 [01101100] - Implausible Signal
          [HVLM_no_plug_detected_AC]
                    Mileage: 168582 km
                    Date: 2026.09.04
                    Time: 04:47:43
                    Mileage: 168582 km
                    Date: 2026.09.04
                    Time: 01:25:52
   Coding: 66994750
   VCID: 43D4AC825B162372BA2-8016
   Part No SW: 1EA 959 593 G    HW: 1EA 959 593
   Component: TSG FS        003 0555
   Serial number: 0000448595939  Dataset Number: V03935411LR 0001
   VCID: 46D2B5966824165A9DC-8012
   Part No SW: 1EA 907 144 AQ    HW: 1EA 907 144 H
   Component: BASGEN1MQB37  246 5033
   Serial number: 00449051 Dataset Number: V03935360FW 0001
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 009050
   ROD: EV_SteerAssisBASGEN1MQB37_009.rod
   VCID: 025A6986048CEA7AF14-8056
   Part No SW: 1EA 907 121 BT    HW: 1EA 907 121 C
   Component: MEB INV4.0    H09 6051
   ASAM Dataset: EV_DMCM15000F11EA907121BT 001013
   VCID: 0158668A018AF162E8E-8054 SFD [x]
   Part No SW: 1EA 959 592 G    HW: 1EA 959 592
   Component: TSG BFS       003 0555
   Serial number: 0000447130691  Dataset Number: V03935411LX 0001
   VCID: 45D0B29A55221D42946-8010
   Part No SW: 10A 035 816 P    HW: 10A 035 816 A
   Component: IC3-SF-AR-EU  H20 1771
   VCID: 29081E2AD97AD92290E-807C SFD [x]
   Component: ABT_E_10       H48 3082
   VCID: 2D00EA3AED92C5027C6-8078
   Part No SW: 1EA 907 556 S    HW: 5WA 907 556 C
   Component: TV eEntry     H17 0314
   VCID: 4ACA81A67C3CF23A794-801E
   Part No SW: 10A 035 284 J    HW: 10A 035 284
   Component: OCUGen4       H17 0716
   ASAM Dataset: EV_OCUGen4 001054
   VCID: 221A0906A44C0A7AD14-8076 SFD [x]
                    Fault Frequency: 66
                    Reset counter: 39
   Coding: EE70
   VCID: 2A0AE126DC7CD23A994-807E
   VCID: 41D8A68A410A3162A8E-8014
   Coolant heating:
                    Mileage: 168630 km
                    Date: 2026.09.04
                    Time: 12:59:00
                    Voltage terminal 30: 13.379 V
                    H-V battery voltage: 410.000 V
                    Current of H-V / hybrid battery: -5.470 A
                    Current 2 of H-V / hybrid battery: -5.850 A
                    maximum voltage for battery cells-Value: 3.801 V
                    minimum voltage for battery cells-Value: 3.787 V
   VCID: 186E2BEE721050AA3F0-804C
   Part No SW: 1EA 915 684 FH    HW: 1EA 915 684 BF
   Component: HV_CHARGER    H52 2023
   Coding: 1080
   ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002019
                    Mileage: 168582 km
                    Date: 2026.09.03
                    Time: 16:30:26
                    DID 1DAC: Charging
                    Frequency: 999 Hz
                    Control voltage: 6139.0 mV
                    Pulse duty factor: 17.8 %
                    Temperature sensor 1: resistance value: 1058 Ohm
                    DID 15E2: 21.0  C
                    DID 081C: 1195 W
                    DID 081D: 2384 W
                    DID 081E: 1213 W
                    DID 0286: 13.3 V
                    DID 537A: 14.4 V
                    DID 1525: 1952 mV
                    DID 5372: 22.0  C
                    No. of lockings: 6155
                    No. of connections: 819
                    Number of successful charging connector locks: 2534
                    DID 103A: supported
                    number_evse_slac: 0
                    DID 1039: supported
                    Target HV charge current: 11.2 A
   VCID: 7AAA11666C5CA2BAA94-802E
   VCID: 6692551608E4365A7DC-8032
   Part No SW: 1EA 907 190 K    HW: 1EA 907 190 G
   Component: DCDC Gen4H13 1144
   Revision: 00H13000
   ASAM Dataset: EV_DCDC10030111EA907190K 001023
   ROD: EV_DCDC10030111EA907190K.rod
   VCID: 3C26D77E26E85C8AFB8-8068
   VCID: 49C8BEAA793AF92270E-801C
   Part No: V04 007 006 RS
   Component: ICAS1 Sys_Ada 0329
   VCID: 0C4647BE36C8AC0A8B8-8058 SFD [x]
   Part No: V04 007 006 RT
   Component: ICAS1 Sys_Jav 0329
   VCID: 0D404ABA4DD2A5029C6-8058 SFD [x]
   Part No: V04 007 000 AD
   Component: IC3-IVI-D-EU  1771
   VCID: 6692551608E4365A7DC-8032 SFD [x]
   VCID: 23140C02BB560372DA2-8076
   Part No: V04 007 006 SA
   Component: ICAS1 SWCL_Em 0329
   VCID: 7BA4146263669BB2B22-802E SFD [x]
13706049 - Databus
          U1123 00 [00100100] - Received Error Message
          [WLA_Blindheit received error value]
                    Mileage: 168704 km
                    Date: 2026.09.04
                    Time: 22:34:42
                    Fault Frequency: 19
   Part No: V04 007 006 SB
   Component: ICAS1 SWCL_HK 0329
   VCID: 7CA6177E66689C8ABB8-8028 SFD [x]
End----------(Elapsed Time: 02:11, VBatt start/end: 15.0V/15.0V)-----------
------------------------------13 Faults Found------------------------------
  • Informative
In that case, I'm confident @Eric will have it fixed in the next version.
Eric
HC800000
In that case
Unable to reproduce here.
Others have complained about this issue, so you're not alone or imagining things :)
Think you could make me a screen recording like that showing the issue from the start of VCDS? It sounds like you should also be able to reproduce it by just doing Gateway Installation List and clicking an address?
Eric
HC800000
It also worked with the regular 26.9 under Ubuntu/Wine:
SnowyDiag
Norway
C?ID=642601
Interesting, I can record it this afternoon :) Running Windows 11
For me it happend every time when doing an Autoscan, but never when selecting an address in the Gateway installation list.
SnowyDiag
Norway
C?ID=642601
Edit: Updated the videos, I managed to post the same video twice. This forum thing is hard for the newbie
I tried to reproduce it again today, this time it worked flawlessly with the autoscan.
However, I was able to reproduce it using the Gateway installation list:
I also had this issue where it timed out:
Two of my other attemps worked fine.
The test were done with a celluar connection with around 40ms ping according to speedtest. I'm suspecting that this connection is not stable enough?
Eric
HC800000
I'd like to think your internet connection is fine. What addresses did this happen with? I notice so far you've only shown 03.
When VCDS hands off to SFDHelper, it needs to disconnect the session with the controller. Once the RT SFD session is established, it needs to reconnect to that controller. I'm wondering if the issue here could be that 03 isn't reconnecting properly or quickly enough?
I should have asked for this earlier, please set the Debug Level in Options to 1024. Without closing VCDS, try to reproduce the issue. Note the controller address where it happens. Then close VCDS gracefully, and send support@ross-tech.com the DEBUG-XX.DLM file created in VCDS\Debug, with XX being the address where the issue occurred.
Shaun
That timeout briefly shows the VCIConfig network test report almost 4.5 seconds of latency on a connection attempt, that is quite bad and almost certainly the reason it later times out. Your own network test looks pretty good after that. If this is a mobile connection and this is an intermittent problem, I would guess maybe you just lost signal at a bad moment. If this is consistent, you might want to try running a traceroute to vcds-cloud.com that might provide more info about what is going on here.
SnowyDiag
Norway
C?ID=642601
I have mostly been testing with 03 to keep the number of variables down, but I can try more addresses.
Are there addresses that you'd prefer to have tested? As it appears to be intermittent I would need a few tries for each ecu, so testing all of them becomes infeasible.
Is it sufficient to simply disconnect the interface from the car and USB to end the SFD session or is there a more "correct" way to do this?
Is the DEBUG-XX.DLM split into addresses automatically? Or would I have to close VCDS and store the file for each attempt?
Yes, this is a mobile connection where the provider rates the location coverage as "Good". It has happened in roughly every other attempt so far.
It should be possible to move the car close enough to get the laptop connected to the house WiFi to check if it behaves the same, I just need the lawn to be dry enough to not ruin it :)
I can try that for sure :) When does it make the most sense to do this? Right after a failed SFD session attempt?
Eric
HC800000
I'd mostly like to exclude 03 as the "cause". Feel free to try 19 or 01.
You don't need to disconnect anything, but it's best to finish communications with the offending address, and then close VCDS. So [Close Controller, Go Back - 06], then close the autoscan screen or Select Control Module screen, then [Exit].
When you're running a debug 1024, VCDS will create one DEBUG-XX.DLM for every address it talks to. If it talks to 03, it will create DEBUG-03.DLM . It will keep appending data to those address-specific files until you close VCDS (the debug flag will be reset when you restart VCDS). So if you're trying with 19, then 03, then 19 and it happens on 19, you should only send me the DEBUG-19.DLM; the DEBUG-03.DLM will not show the issue and so it's not interesting to me. Or you can zip up the whole folder when it's done anyway, but be sure to tell me which address and what time roughly it happened :)
Shaun
Probably.
You might not need to actually move the car. You can probably work around this networking issue by first logging into SFD from your home wifi via VCDS -> [Applications] -> [Start SFD Session]
Then with the interface still powered via USB, move to the car and switch to your mobile connection to do the actual SFD unlock, you should still be logged in as long as the interface has remained powered.
SnowyDiag
Norway
C?ID=642601
Perfect, then we have a game plan :D
I might be misunderstanding, but to start a new session I will have to end the previous one right? Most of the time the session does start, but the graphic is not correctly updated to reflect this.
I'm basically wondering what the most efficient way to run many consecutive connection attempts would be.
It is worth noting that the SFD session start just fine (almost) every time, and I have been able to complete the work I need. My complaint is that text in the window is not automatically updated, which can be confusing to the user.
This timeout event has only happend once so far.
Eric
HC800000
I might be misunderstanding, but to start a new session I will have to end the previous one right? Most of the time the session does start, but the graphic is not correctly updated to reflect this.I'm basically wondering what the most efficient way to run many consecutive connection attempts would be.
Ah right, you don't need to disconnect anything once you've reproduced the issue; but if you're trying to reproduce the issue, you do need to disconnect both USB and OBD2 DLC so that the interface reboots and wipes the SFD session. AFAIK there is no other way, and it won't hurt anything. Make sure you're not actively talking to a module in the car at the time though, because those can get confused if you do that. And VCDS doesn't like it either ;)
Shaun
Sounds like this was just an intermittent issue of your mobile signal dropping then, I wouldn't spend too much time testing network stuff if it is not a reproducible problem.
