This squealing sound has started happening on my 2012 Golf Mk6. It's actually constant once it starts, but it sounds like it's coming and going on the video.
It starts after about 10 minutes of driving, will last about 20 minutes, and then suddenly goes away again for no obvious reason - this is completely repeatable on every drive. It will also stop instantly with the lightest touch on the brakes, although it starts again as soon as you let the brake off.
I initially thought it might be the front brakes because when driving the noise sounds like it's coming from the front end, but I stripped, cleaned and regreased the front calipers and obviously the issue didn't go away.
I've now been able to isolate it to the rear wheels, because it stops when you lift the handbrake just enough.
Obviously I need to get the rear wheels off and have a proper inspection, but does it sound like anything in particular? There's no smoke or smell of dragging brake pads, and the brakes feel completely normal while it's happening. Would a failing wheel bearing make such a high-pitched sound that behaves in the same way?
