Temporarily disable Haldex by VCDS long coding?
   #41
iichel
Netherlands, Operation Market Garden
C?ID=284912
I looked up the diagram and it seems I was wrong. The caddy only has a +15 feed, by the looks of it, from SC13.
I'm used to having a +30, +15, CAN PT and GND to the controller.
nugentp
C?ID=6386
If that fuse is shared with other important components, then a simple way to stop the Haldex from being able to bind up is to unplug the 2-pin connection to the hydraulic pump (V181).
   #43
mariusm
Norway
C?ID=636016
Not sure if this is exactly the plug you meant, but it is now disconnected:
The result is that VCDS can no longer find the AWD system, and a short test drive gave zero jumping/skipping/binding etc. So far, so good.
   #44
Westbury, UK
Have you suitably covered the plug and the socket to prevent water, foreign objects, etc. damaging the connectors?
   #45
mariusm
Norway
C?ID=636016
"Suitably" is perhaps overstating it. But wrapped plug and socket in a small plastic bag which I closed with a zip tie. And zip tied the lose cable to an adjacent cable, to prevent it from dangling.
I will only do short test drives today, then deliver it to a mechanic tomorrow morning to dig out the faulty rear left speed("abs") sensor and install a new one.
   #46
mariusm
Norway
C?ID=636016
After unsuccessfully* attempting to replace the wheel speed sensor yesterday, I had a chat with my mechanic.
It seems plausible that the cause is that the Haldex clutch is (nearly?) fully engaged at sharp turns, thus not allowing for the substantial speed difference between front wheels (wider turn) and rear wheels (narrower turn).
The rear wheels will press for more speed, which causes the jumping and spinning, and the front wheels will press for less speed, which causes the binding.
I can only hope that the new wheel speed sensor will solve this.
*Mechanic says he needs to work from the inside. Removing wheel, brake assembly, bearing whatnot. He doesn't want to start on this job lest he has a new bearing. So, another attempt in a week or two.
   #47
mariusm
Norway
C?ID=636016
My mechanic also said he'd rather disconnect the other plug, from the Haldex controller ("ECU") to the Haldex pump. (Rather than disconnect the whole Haldex unit, as I had done above).
I am not convinced it makes much of a difference, but I followed his advice anyway.
   #48
mariusm
Norway
C?ID=636016
Just in case somebody checks in on this:
I have been driving around for 3 months with a disconnected haldex pumps. All symptoms gone.
(Of course, I don't have 4WD, but I am still working on that part: Replaced ABS sensor did not solve it. Replaced haldex pump neither. Probably moving on to controller and solenoid N373 next.)
   #49
mariusm
Norway
C?ID=636016
It could also be that a faulty Haldex control module has caused the Haldex clutch to lock up permanently. That would be a worst-case scenario, but I think it's a possibility.
If that's the case, you may have to remove the propshaft to confirm the diagnosis. :(
Since I am moving closer to the control module / ECU as the prime suspect: Why would I have to remove the propshaft? On different drawings, photos and videos I have seen, my gen4 Haldex control module seems to be fully accessible from underneath the car.
Like this:
   #50
Nordicduck
C?ID=571205
Had similar issues with my Mk2 Crafter, garage was useless (27 days to not fix it) I ended up having the breather tubes replaced twice and it was still not right, in the end I fixed it myself after reading something somewhere on the internet about a similar issue.
For want of a better description, the haldex on my van stops engaging at speeds over about 50mph, below 10mph it engages around 15% and when pulling away from 0mph it gets to about 40% engagement, hence why the issue is worse or only appears at low speeds or in car parks when turning tight corners. My symptoms were much more pronounced when the weather was cold (then the juddering was especially bad) felt like I had the diff lock enabled and the rear wheels were skipping. Like you when I removed the power to the haldex the juddering stopped.
I believe the haldex oil was too thick and the pump was running out of fluid as it not running back to the pump quick enough so the pump was pulsing, I changed the oil out to Ravenol AWD-H and all my problems went away.
Ravenol advertising blurb: ..... The lower the dynamic viscosity, the better. The Haldex clutch will begin to work faster, the oil will circulate more quickly and there is no wear caused by a low temperature start. With regard to the parameters for dynamic viscosity at minus 40 °C, RAVENOL AWD-H Fluid delivers 270,63% higher performance than the original oil VW G 060 175 A2....
I tend not to give much credence to advertising, however, it was a cheap and easy fix, since then I have yearly drained the oil and cleaned the pump gauze (always dirty) and replaced with new Ravonol AWD-H oil (then a pump learn via VCDS after it has got up to temperature)
Maybe worth a go!
   #51
Nordicduck
C?ID=571205
Forgot to add that the dealer in the time the dealer had my van they also fitted a new Haldex ECU (which did not fix the problem)
