Log-WV2ZZZ2KZDX005844-129650km-11jul2026.txt
Saturday,11,July,2026,17:16:55:42955
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4701.5
VIN: WV2ZZZ2KZDX005844 License Plate:
Mileage: 129650km Repair Order: 11jul2026
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 37 42 44 46 52 56 69
VIN: WV2ZZZ2KZDX005844 Mileage: 129650km-80560miles
22-AWD -- Status: Malfunction 1010
Address 01: Engine (J623-CFHF) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 NJ HW: 03L 907 309 R
Component: R4 2.0l TDI H25 9980
Revision: 42H25--- Serial number: 00000000000000 CVN: 1F81A638
Coding: 0019001A042600080000
Shop #: WSC 16913 006 1048576
ASAM Dataset: EV_ECM20TDI01103L906018NJ 003008
ROD: EV_ECM20TDI01103L906018NJ.rod
VCID: 7F5CDF2DC7770042B69-802A
VINID: 9E60AAAAA09BA94A000052041029196CF9
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [01101101] - Electrical Fault
Mileage: 127788 km
Date: 2026.07.11.
Time: 13:06:07
Engine speed: 0.00 /min
Coolant temperature: 15 �C
Intake air temperature: 13 �C
Voltage terminal 30: 11.900 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
Electric auxiliary heater: relay activation-Bits 0-7: 0
Pre-glow time: 900 ms
Glow status-Bits 0-7: 0
Glow status-Bits 0-7: 48
Glow cycles above temperature threshold-Bits 0-7: 9
Glow cycles above temperature threshold-Bits 0-7: 141
Glow cycles below temperature threshold-Bits 0-7: 0
Glow cycles below temperature threshold-Bits 0-7: 12
Outside temperature: 12.0 �C
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 623C600D092203FF461306E8901DC042300050
Shop #: WSC 35110 377 00141
VCID: 7DA02525CDFB1252A45-8028
Fault Status: 00100011
Reset counter: 111
Mileage: 127800 km
Date: 2020.12.01.
Time: 15:11:49
Count: 64
Count: 4608
Count: 67
Count: 49153
Count: 63477
Count: 64522
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 111
Mileage: 127766 km
Date: 2020.12.01.
Time: 10:59:08
Count: 3
Count: 4096
Count: 71
Count: 41984
Count: 65281
Count: 253
Fault Frequency: 9
Reset counter: 120
Mileage: 127766 km
Date: 2020.12.01.
Time: 10:59:22
Count: 16387
Count: 4096
Count: 128
Count: 41472
Count: 65281
Count: 253
Count: 7424
Fault Status: 01101100
Reset counter: 71
Mileage: 127809 km
Date: 2020.12.01.
Time: 19:26:31
Count: 16391
Count: 16896
Count: 64
Count: 43520
Count: 1
Count: 768
Part No SW: 5K0 907 044 GM HW: 5K0 907 044 GM
Component: Climatronic H19 1212
Revision: 00001004
Coding: 0010004002
Shop #: WSC 35110 790 50316
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 7CA62821D6611B5A93B-8028
9472881 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [00001000] - Actuator Stuck
Reset counter: 108
Mileage: 127704 km
Date: 2026.07.11.
Time: 17:43:49
Part No SW: 5K0 937 086 P HW: 5K0 937 086 P
Component: BCM PQ35 M+ 021 0068
Revision: BD021001
Coding: 411A0A3A80251A6B088800809400816403510C88726DAD60648000000040
VCID: 41D899D5F183B6B280D-8014
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 21051 26 0512
Coding: 009795
Component: RLS 180512 05 54 0403
Coding: 0230ED
Reset counter: 108
Mileage: 127623 km
Date: 2020.12.01.
Time: 09:08:48
Term 15 Off
Voltage: 12.75 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 2K0 919 475 HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0004
Revision: -------- Serial number: 32961214202247
Coding: 118002
ASAM Dataset: EV_EPHVA14VN3370000 001006
ROD: EV_EPHVA14VN3370000.rod
VCID: 70BE0C118A296F3A3F3-8024
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag01P H07 0013
Revision: -------- Serial number: 003HN008HVX3 Dataset Number: 2KC003v____ 0246
Coding: 000000000000000000000000000000003150
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3334C31DBBBF1422021-8066
Serial number: 3495RRB406718B72N0D$
Serial number: 3505RRB405318B74JGG0
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Revision: -------- Serial number: 90422LEQ0010H Dataset Number: 5K0953507BC D005
Coding: 1082160000
ROD: EV_SMLSNGKUDS_A05_VW32.rod
VCID: 72BA061984255D2AC97-8026
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Serial number: 0086556
Coding: 820000
Part No SW: 2K0 920 875 L HW: 2K0 920 875 L
Component: KOMBI H05 0705
Coding: 181E01
VCID: 382EF431A2D9F77A373-806C
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 A
Component: Standheizer 043 4730
Revision: 00043000 Serial number: 09022127000000
Coding: 0031012
Shop #: WSC 00999 444 64523
VCID: 3334C31DB73F1422021-8066
01489 - Over-Temp Sensor (G189)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 32
Mileage: 126739 km
Date: 2020.12.01.
Time: 09:12:39
Start
Temperature: 97.0�C
Temperature: -48.0�C
Voltage: 12.00 V
02251 - Heater Unit Locked
Reset counter: 32
Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
Component: J533 Gateway H42 1632
Revision: H42 Serial number: 190512F2000429
Coding: 357400
VCID: 3FDC9F2D8777C042F69-806A
01324 - Control Module for All Wheel Drive (J492)
Fault Status: 00110100
Reset counter: 99
Mileage: 127481 km
Date: 2020.12.01.
Time: 10:37:58
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 2K0 907 554 B HW: 2K0 907 554 B
Component: Haldex 4Motion 5007
Coding: 0000001
VCID: 2D00D565511B42D2545-8078
02248 - Valve for Controlling Clutch Operating Angle (N373)
Fault Status: 00101110
Mileage: 127481 km
Date: 2020.12.01.
Time: 10:40:34
00625 - Vehicle Speed Signal
Fault Status: 01110001
Mileage: 127481 km
Date: 2020.12.01.
Time: 10:40:34
Ign. Timing: 5.8 �ATDC
Raw, Form. N/A: 000 000 000
01155 - Clutch
Fault Status: 10000011
Mileage: 127481 km
Date: 2020.12.01.
Time: 10:40:34
Fault Status: 11001000
Mileage: 127481 km
Date: 2020.12.01.
Time: 10:40:34
Component: IMMO H05 0705
VCID: 6A8A1E79ACF595EA717-803E
Part No SW: 3C0 035 279 M HW: 3C0 035 279 M
Component: RNS315-EU H52 0319
Serial number: VWZAZ2M4691319
Coding: 000004010200130000029002
ROD: EV_RNS315EUV2UDS_VW32.rod
VCID: 2D00D5655D9B42D2545-8078
Component: EUR_W_0038 0038
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2109
Coding: 0000048
VCID: 48CE84F1DEB987FA473-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 140 3305
Revision: 00H22000
VCID: 372CF70DA347F8023E9-8062
Fault Status: 11101101
Fault Frequency: 18
Reset counter: 71
Mileage: 127803 km
Date: 2020.12.01.
Time: 15:32:19
Voltage: 13.75 V
DU
Temperature: 30.0�C
RPM: 1946 /min
Speed: 14.0 km/h
Speed: 14.0 km/h
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000048
VCID: 47CC87CDD3A788824E9-8012
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030176518
Coding: 410D000100000000
VCID: 303ECC114A292F3A7F3-8064
00576 - Terminal 15
Reset counter: 99
Mileage: 127481 km
Date: 2020.12.01.
Time: 10:37:59
End----------(Elapsed Time: 01:11, VBatt start/end: 12.4V/12.4V)-----------
------------------------------16 Faults Found------------------------------
