Temporarily disable Haldex by VCDS long coding?
mariusm
Norway
C?ID=636016
Good afternoon
My Caddy 4x4, diesel, manual is behaving oddly. One of several suspects is the hill hold assist. (Or whatever the VW term).
Can I use VCDS to disable it? How?
Thanks up front.
(I am not too good at searching through previous threads -I often can't tell if that content is really relevant to my situation- so I ask from fresh. Apologies if this is repeating.)
downtime
Finland
C?ID=280813
Would be interesting to hear what is this odd behaviour. And what makes you think hill hold causes that?
Oh and the most important, I don't see an autoscan
mariusm
Norway
C?ID=636016
Let's see if I manage the autoscan first...
Friday,26,June,2026,19:13:29:42955
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.5
VIN: WV2ZZZ2KZDX005844   License Plate:
Mileage: 127770km-79392mi   Repair Order: 26jun2026
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 37 42 44 46 52 56 69
VIN: WV2ZZZ2KZDX005844   Mileage: 127770km-79392miles
22-AWD -- Status: Malfunction 1010
Address 01: Engine (J623-CFHF)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 NJ    HW: 03L 907 309 R
   Component: R4 2.0l TDI   H25 9980
   Revision: 42H25---    Serial number: 00000000000000 CVN: 1F81A638
   Coding: 0019001A042600080000
   Shop #: WSC 16913 006 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018NJ 003008
   ROD: EV_ECM20TDI01103L906018NJ.rod
   VCID: 7F5CDF2DC7770042B69-802A
   VINID: 9E60AAAAA09BA94A000052041029196CF9
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V3.clb
   Revision: 00H31001
   Coding: 623C600D092203FF461306E8901DC042310050
   Shop #: WSC 35110 377 00141
   VCID: 7DA02525CDFB1252A45-8028
                    Reset counter: 110
                    Mileage: 127766 km
                    Date: 2020.11.16.
                    Time: 10:59:22
                    Count: 16387
                    Count: 4096
                    Count: 128
                    Count: 41472
                    Count: 65281
                    Count: 253
                    Count: 7424
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 70
                    Mileage: 127766 km
                    Date: 2020.11.16.
                    Time: 10:59:08
                    Count: 3
                    Count: 4096
                    Count: 71
                    Count: 41984
                    Count: 65281
                    Count: 253
   Part No SW: 5K0 907 044 GM    HW: 5K0 907 044 GM
   Component: Climatronic   H19 1212
   Revision: 00001004
   Coding: 0010004002
   Shop #: WSC 35110 790 50316
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: 7CA62821D6611B5A93B-8028
9472881 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [00001000] - Actuator Stuck
                    Reset counter: 108
                    Mileage: 127704 km
                    Date: 2026.06.26.
                    Time: 17:43:49
   Part No SW: 5K0 937 086 P    HW: 5K0 937 086 P
   Component: BCM PQ35 M+   021 0068
   Revision: BD021001
   Coding: 411A0A3A80251A6B088800809400816403510C88726DAD60648000000040
   VCID: 41D899D5F183B6B280D-8014
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 21051  26  0512
   Coding: 009795
   Component: RLS 180512 05  54  0403
   Coding: 0230ED
                    Reset counter: 108
                    Mileage: 127623 km
                    Date: 2020.11.16.
                    Time: 09:08:48
                        Term 15 Off
                    Voltage: 12.75 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 2K0 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0004
   Revision: --------    Serial number: 32961214202247
   Coding: 118002
   ASAM Dataset: EV_EPHVA14VN3370000 001006
   ROD: EV_EPHVA14VN3370000.rod
   VCID: 70BE0C118A296F3A3F3-8024
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag01P H07 0013
   Revision: --------    Serial number: 003HN008HVX3 Dataset Number: 2KC003v____ 0246
   Coding: 000000000000000000000000000000003150
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3334C31DBBBF1422021-8066
   Serial number: 3495RRB406718B72N0D$
   Serial number: 3505RRB405318B74JGG0
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Revision: --------    Serial number:  90422LEQ0010H Dataset Number: 5K0953507BC D005
   Coding: 1082160000
   ROD: EV_SMLSNGKUDS_A05_VW32.rod
   VCID: 72BA061984255D2AC97-8026
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0086556
   Coding: 820000
   Part No SW: 2K0 920 875 L    HW: 2K0 920 875 L
   Component: KOMBI         H05 0705
   Coding: 181E01
   VCID: 382EF431A2D9F77A373-806C
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 A
   Component: Standheizer     043 4730
   Revision: 00043000    Serial number: 09022127000000
   Coding: 0031012
   Shop #: WSC 00999 444 64523
   VCID: 3334C31DB73F1422021-8066
01489 - Over-Temp Sensor (G189)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 32
                    Mileage: 126739 km
                    Date: 2020.11.16.
                    Time: 09:12:39
                        Start
                    Temperature: 97.0�C
                    Temperature: -48.0�C
                    Voltage: 12.00 V
02251 - Heater Unit Locked
                    Reset counter: 32
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 190512F2000429
   Coding: 357400
   VCID: 3FDC9F2D8777C042F69-806A
01324 - Control Module for All Wheel Drive (J492)
                    Fault Status: 00110100
                    Reset counter: 99
                    Mileage: 127481 km
                    Date: 2020.11.16.
                    Time: 10:37:58
   Part No SW: 2K0 907 554 B    HW: 2K0 907 554 B
   Component: Haldex 4Motion      5007
   Coding: 0000001
   VCID: 2D00D565511B42D2545-8078
02248 - Valve for Controlling Clutch Operating Angle (N373)
                    Fault Status: 00101110
                    Mileage: 127481 km
                    Date: 2020.11.16.
                    Time: 10:40:34
00625 - Vehicle Speed Signal
                    Fault Status: 01110001
                    Mileage: 127481 km
                    Date: 2020.11.16.
                    Time: 10:40:34
                    Ign. Timing: 5.8 �ATDC
                    Raw, Form. N/A: 000 000 000
01155 - Clutch
                    Fault Status: 10000011
                    Mileage: 127481 km
                    Date: 2020.11.16.
                    Time: 10:40:34
                    Fault Status: 11001000
                    Mileage: 127481 km
                    Date: 2020.11.16.
                    Time: 10:40:34
   Component: IMMO          H05 0705
   VCID: 6A8A1E79ACF595EA717-803E
   Part No SW: 3C0 035 279 M    HW: 3C0 035 279 M
   Component: RNS315-EU   H52 0319
   Serial number: VWZAZ2M4691319
   Coding: 000004010200130000029002
   ROD: EV_RNS315EUV2UDS_VW32.rod
   VCID: 2D00D5655D9B42D2545-8078
   Component: EUR_W_0038  0038
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2109
   Coding: 0000048
   VCID: 48CE84F1DEB987FA473-801C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 140    3305
   Revision: 00H22000
   VCID: 372CF70DA347F8023E9-8062
                    Fault Status: 11101101
                    Fault Frequency: 16
                    Reset counter: 70
                    Mileage: 127772 km
                    Date: 2020.11.16.
                    Time: 19:11:11
                    Voltage: 12.25 V
                        DD
                    Temperature: 23.0�C
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000048
   VCID: 47CC87CDD3A788824E9-8012
   Revision: 3A001001    Serial number: 00008030176518
   Coding: 410D000100000000
   VCID: 303ECC114A292F3A7F3-8064
00576 - Terminal 15
                    Reset counter: 99
                    Mileage: 127481 km
                    Date: 2020.11.16.
                    Time: 10:37:59
End----------(Elapsed Time: 01:15, VBatt start/end: 12.3V/12.3V)-----------
------------------------------13 Faults Found------------------------------
The odd behaviour is that it seems to be applying the brake on one or more wheels, particularly when I start from zero speed. And seemingly more so the more I turn the steering wheel.
The hill hold is just a guess. (Other guesses are ABS, ESC, ASR... - anything that applies brakes without the driver actually braking. But I figured I'd test one thing at a time.)
Jacek
Poland
C?ID=360566
In the long ABS coding in byte 16, uncheck bit 0.
downtime
Finland
C?ID=280813
Thanks. Does the car sound different on higher speeds? As the problem seems more evident when turning the steering wheel, I would start my investigation on wheel bearings, possible issues in steering rack etc. Brake calipers sticking, which is pretty common issue in VW brakes.
Hill hold is only applied if you stop on a slope that has over certain degree incline/decline. So that is not your problem.
mariusm
Norway
C?ID=636016
I haven't noticed anything on speeds above, say, 20-25 km/h.
And conversely, it can be noticed when speed is barely creeping (i.e. zero throttle and just touching with the clutch in first gear), and actually even when it comes to a full stop: If that happens where there is a slight slope, and I have clutch disengaged and zero brake, the car will keep still. As if brake(s) applied.
I had brake caliper issues less than a year ago. Changed on front wheels. The local mechanic (not authorized VW, but works on ever so many) had a look at the rear brakes when the above troubles began, but couldn't see anything.
And, yes, I am aware of the intended function of the hill hold, but I figured if there is something wrong with it (sensor input?), then it might do something outside of what was intended.
Anyway, I'll try Jacek's coding suggestion, and see if that makes any difference.
mariusm
Norway
C?ID=636016
Just did this, and apparently it works.
I don't feel 100% confident yet, as I only did a very short test drive, but at least the 3 most troublesome hard turns in and out of my parking space gave apparently none of that "random" application of brake.
I will update this thread if the problem re-appears.
mariusm
Norway
C?ID=636016
Just for the record: My car is different in another way. Not only did I disable Hill hold control (which seems to be the term, at least on my VCDS screen), but I also tore the left rear ABS sensor in two, while trying to remove it.
It was already faulty, so I think it didn't make a difference as for sensor output, but since I didn't check this specifically before I went violent, I can only guess.
mariusm
Norway
C?ID=636016
The problem is still there. Must have been a coincidence that it went away (for a short time) just after disabling Hill hold control.
downtime
Finland
C?ID=280813
I told you so. Hill hold doesn’t cause that kind of behaviour. Check the measurement values from each abs sensor. Follow the rotation reading. Are they consistent between each other? Could be that one of your wheel sensors is going out but not enough to flag an error message
mariusm
Norway
C?ID=636016
As mentioned: One of the sensors is long gone. Shows zero continuously. New sensor is on order and will be replaced in two weeks or so. (The other three are consistent)
That may solve the whole thing, but I am still trying to make sense of this behaviour. Could it be that the zero km/h input from rear left wheel is interpreted as "real" when the other three wheels are slow - say, below 10-20 km/h. But it would be interpreted as "unreal" (and hence dismissed) when the other three wheels are faster? What really bugs me is that this keeps happening (almost?) exclusively when the steering wheel is at a large angle - typically in and out of a parking space, but also doing a tight 90 degree turn. Though not 100% of the time. I'd say 9 out of 10, perhaps.
(A mechanic claimed that one faulty sensor would simply disable the whole ABS, ESC, ASR... whatever assists my braking. Sounds plausible, but it doesn't fit what I am experiecing. Not that I am 100% sure it really is a brake being applied. But I can't imagine what else)
Paskal
Czech Republic
C?ID=508876
I also don't think AutoHolld is causing this.
According to the auto scan you have a faulty rear left speed sensor.
While VCDS may be a joke, I'm curious... Date and time: 16.11.2020, 10:59:08
How about doing a simple test. Jack up the car and turn it and see if one of the wheels spins and brakes.
Then if necessary do a test drive of about 5 - 10 kilometers (avoid hard braking), then stop and touch the wheels - and which ones will be noticeably warm (be careful not to burn yourself) to make it clear which wheel is braking.
Then there are 3 possibilities what could be causing this, brake pads, seized caliper roller or bearing.
Sure, it will deactivate the ABS etc and prevent the car from intermittently braking as if it didn't have ABS.
But it won't lock a wheel to slow it down.
And when you say you have a faulty ABS sensor, does your brake light on the dashboard come on?
mariusm
Norway
C?ID=636016
I'd say Hill hold control is just about ruled out.
Yes, I am aware of the sensor. As mentioned before: I tore it in two, and a new sensor is on its way. (Assuming that my "ABS sensor" and "wheel speed sensor" are the same thing, one on each wheel)
The date from 2020 may be real, for all I know. But the problem I describe appeared in May 2026.
The test with the car all jacked up would be interesting. I will suggest it to my mechanic if the new sensor doesn't solve this.
I have driven 2000+ km with this problem. Most distance rolled on highways at 80-120 km/h. This random braking doesn't seem to appear at such speeds at all: No heat from the brakes.
I don't think any wheel gets "locked". But it seems to me that one wheel gets its brake applied.
Yes, faults are lit up on my panel as well. (Although the car behaved strangely for almost a month before these came up)
PQ generation cars often have implausible dates in freeze frame data. Ignore it. Evaluate when the fault was logged based on the mileage in the freeze frame data.
mariusm
Norway
C?ID=636016
Another detail of the odd behaviour:
If this random braking happens as the last thing when I park my car. That is: If what brings my car to a full stop is not the driver's stepping on the brake pedal, but rather this random application of a brake.
Then two different observations:
a. If I switch off the ignition after only a second or two, a rather loud bang can be heard and felt, as if the brake (or whatever else was holding back) lets go, and the tension is let off. Quite similar to the sound and feeling I get if I sit in a stopped car with idling engine and I mistakenly think I am in neutral gear and take the foot off the clutch pedal quickly: A bang and the engine dies. Only now it is the the opposite order: I switch off the engine, and then comes the bang.
b. If I rather wait for a few seconds(5-10-ish?), engine idling, clutch pedal pressed all the way down. (No brake or accelerator pedal). Then the same thing as described in item a happens (only the engine doesn't die, of course): The bang.
downtime
Finland
C?ID=280813
Does your car have normal handbrake or electric one? Sorry too lazy to go up.
Those symptoms sound like a seized caliber or broken wheel bearing like @Paskal already mentioned
The magnet ring the abs sensor reads is part of the bearing and if the magnet ring is done for, could very well be causing your issues.
mariusm
Norway
C?ID=636016
Normal hand brake.
If the problem is really a seized caliper I suppose this somehow is coming (each time I brake, or each time that specific brake is applied with a certain strengt/pressure/force?) and going (each time I get the bang, loud or not).
Magnet ring could be. Since I had good readings on the other 3 wheels I suppose that would be the magnet ring on the rear left. And that rear left would show bad readings even after I change the rear left sensor
ACalamita
C?ID=367970
I've had previous vehicles and coincidentally my current VW Caddy that does sometimes seem to trigger the ABS pump or brake slightly when they have a faulty wheel speed sensor.
My Caddy currently has a broken rear WSS and did a similar thing to me the other day.
Other symptoms at slow speed are typically feeling the "ABS pump judder" through the pedal at slow speed when coming to a stop.
Fix your broken wheel speed sensor and I'm pretty confident that will fix your issue!
Paskal
Czech Republic
C?ID=508876
And have you tried physically touching that wheel? Or do you just assume it's not hotter than the other wheels?
If the wheel is braking (left rear) then you wouldn't be able to keep your hand on it after stopping.
And do you hear a whining noise (from the back left) when you take a right-hand turn? If so, that means the bearing is bad.
mariusm
Norway
C?ID=636016
I do not suspect any one wheel misbehaving. From the (perceived) braking I suspect it be at least two - one on each side. But it might even be all 4. Sometimes the bang sounds and feels more left, sometimes more right. Mostly forward, but sometimes rear.
I didn't touch the wheels, but I put my hand (and my nose) within a couple of centimeters, so I should have felt (or smelled) the difference if any one wheel was odd. But hey: I need to go for a 20 minute highway ride tomorrow. I'll touch, just to make sure.
As described previously, the problem seems to be intermittent. At least the most obvious effect is: Sometimes when I do sharp turns at low speeds the car behaves quite normally. But most times it will brake (or "brake", if that is not the actual brake). Even as it brakes, it will let go -particularly if I turn the steering wheel back towards zero. For these parking situations I believe that the braking would be insufficient to heat the brakes significantly. I.e. I would not be able to detect it that way.
No whining noise.
