Audi Q2 35 TFSI, 150hk, 2024
RazvanI
Sweden
C?ID=426034
Tuesday,14,July,2026,17:24:17:13227
VCDS Version: 26.6.0.1 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260708 DS377.1
VIN: WAUZZZGAXRA067256   License Plate:
Mileage: 43835km-27237mi   Repair Order:
Chassis Type: GA-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 18 19 2B 42 44 4B 52 5F 6C 75
          A5 BB BC D6 D7
VIN: WAUZZZGAXRA067256   Mileage: 43835km-27237miles
Address 01: Engine (J623-DXDB)       Labels: Redir Fail!
   Part No SW: 05E 906 019 BS    HW: 05E 907 309 CB
   Component: R4 1.5l TFS   H80 3609
   Revision: KMH80000    Dataset Number: V03935377HY 0001 CVN: A353B822
   Coding: 0225003A23641D0830000000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906019BS 002003
   ROD: EV_ECM15TFS01105E906019BJ_002_AU37.rod
   VCID: 78A9E394F250717AE32-802C SFD+SFD2 [x]
   VINID: 9D196AAAA5D1A2244018708518312F7312
   Part No SW: 0CW 906 556 CT    HW: 0CW 300 028 R
   Component: DQ200G3 CHI   H07 0366
   Serial number: 5ZV02404181247  CVN: 952607BD
   ASAM Dataset: EV_TCMDQ200025 001009
   ROD: EV_TCMDQ200025.rod
   VCID: 2019EBF40A40D9BAFB2-8074 SFD [x]
Address 03: ABS Brakes (J104)       Labels:. 5WA-614-517-V2.clb
   Part No SW: 5QA 614 517 BB    HW: 5QA 614 517 B
   Component: ESC           H34 0664
   Serial number: 61264000011541  Dataset Number: GA0909504LA 0002 CVN: C1119B27
   Coding: 8A185928A099839C0009A59C9CA542E404009664892000
   ASAM Dataset: EV_Brake1ESCMQB37CLASS 008020
   ROD: EV_Brake1ESCMQB37CLASS.rod
   VCID: 03538478BB9622A2C60-8056 SFD+SFD2 [x]
4214 - Auto-Hold Switch
          C10CE 29 [00100000] - Signal Implausible
          [Avh_switch_defect]
   Part No SW: 3Q1 959 435 C    HW: 3Q1 959 435 C
   Component: VWKESSYMQB    037 1501
   Revision: 00037000    Serial number: 0639676719 Dataset Number: 81A909577D  0010
   Coding: 030C0C1720
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_KessyHellaMQBAB 004056
   VCID: 3B233C9883E69A62CE0-806E
   Part No SW: 8V0 820 043 BP    HW: 8V0 820 043 BP
   Component: AC Automat    H04 0196
   Revision: 20002000    Serial number: 00000001680159 Dataset Number: 81A909862J
   Coding: 06000004000001001000000000001004
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008030
   VCID: 015F8E70A18A30B2D4C-8054
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H06 0012
   Serial number: C29A1B2A00PAG0MUFU04
   Part No SW: 5Q0 937 084 EQ    HW: 5Q0 937 084 EQ
   Component: BCM MQBAB M+  H50 0618
   Serial number: 05102413201361 Dataset Number: 81A909514S  0092
   ASAM Dataset: EV_BCMMQB 023001
   ROD: EV_BCMBOSCH_023.rod
   VCID: 0B43AC5893C66AE2BE0-805E SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 81A 955 555 B    HW: 81A 955 555
   Component: G397_RLFSS  H06 0004
   Serial number: 23378463X81A955555B0
   Coding: 80005E
   Subsystem 2 - Part No SW: 8V0 941 531 BA    HW: 8V0 941 531 BA
   Component: E1 - LDS MQB  H06 0032
   Serial number: 02 02 2024  20001021
   Steering Column Switch:
   Subsystem 3 - Part No SW: 82A 953 521 LT    HW: 5Q1 953 549 D
   Serial number: 00000029042420240829
   Part No SW: 5QA 919 294 L    HW: 5QA 919 294
   Component: PDC 8 Kanal   H12 0083
   Serial number: 000150058324132 Dataset Number: 81A909526K  0004
   Coding: 8471151811
   ASAM Dataset: EV_EPHVA18AU3700000 010058
   ROD: EV_EPHVA18AU3700000_010_AU37.rod
   VCID: 55F78A2005826C12D84-8000
   Part No SW: 2Q0 907 567 B    HW: 2Q0 907 819
   Component: ACCCONTIMQB   H04 0534
   Dataset Number: 81A909863AA 0011
   Coding: 32017F4218F78728747F61648150A70000000000000000000C
   ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
   ROD: EV_ACCMRRCONTIUNECEMQB_AU37.rod
   VCID: 372B20A8BFCEBE022A8-8062 SFD+SFD2 [x]
   Part No SW: 5QF 959 655 BQ    HW: 5QF 959 655 BQ
   Component: Airbag VW23   003 0117
   Revision: --------    Serial number: 003C0T2PF86JRH Dataset Number: 81A909602BA 0009
   Coding: 88CCF0C0000000005C5400DFC00C40000085
   ASAM Dataset: EV_AirbaVW23TS6VW48X 001010
   ROD: EV_AirbaVW23TS6VW48X_VW27.rod
   VCID: 2615FDEC6864378A81E-8072 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: -----------    HW: 654 000 205 24
   Component: SideSensor_Df  010 0887
   Serial number: 3570000D158121B1607S
   Subsystem 2 - Part No SW: -----------    HW: 654 000 105 24
   Component: SideSensor_Pf  010 0887
   Serial number: 35800005158535896870
   Subsystem 3 - Part No SW: -----------    HW: 654 002 803 24
   Component: SideSensor_Dr  080 0149
   Serial number: 351005070C6BF786A5BQ
   Subsystem 4 - Part No SW: -----------    HW: 654 002 501 24
   Component: SideSensor_Pr  080 0149
   Serial number: 352005068C7CEBCA266Z
   Subsystem 5 - Part No SW: -----------    HW: 654 002 701 24
   Component: FrontSensor_D  080 0149
   Serial number: 355005096C87D4130A5A
   Subsystem 6 - Part No SW: -----------    HW: 654 002 701 24
   Component: FrontSensor_P  080 0149
   Serial number: 356005092C87D408E57M
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 81A 920 790 G    HW: 81A 920 790 D
   Component: FBenRDW------ H03 0039
   Coding: 0C0422546D8400080B80A8401000000000000000
   ASAM Dataset: EV_DashBoardFPK2AU326 002045
   ROD: EV_DashBoardFPK2AU326.rod
   VCID: 2C010FC476880DDA57A-8078 SFD+SFD2 [x]
Address 18: Aux. Heat (J364)       Labels:| 5WA-963-27x-V1.clb
   Part No SW: 5WA 963 272 B    HW: 5WA 963 272 B
   Component: STH-VW37x     006 0012
   Serial number: 000000000000413
   Coding: 250A9458CD2E033E100D19
   ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
   ROD: EV_AuxilHeateWOSVW38X_002_VW27.rod
   VCID: 4CC16F44D6482DDA77A-8018
   Auxiliary heating remote control:
   Part No SW: 3Q0 907 530 BB    HW: 3Q0 907 530 BA
   Component: GW 2023 CLA   542 5555
   Revision: --------    Serial number: CU5SIB180424009 Dataset Number: 81A909515K  0012
   Coding: 0000808D8F00000000000000000000325301200102000100030000000001010000000000000000000000000000000000
   GVL: 3D0000000600408C80000006C800000000000002000000000000000000000046
   ASAM Dataset: EV_GatewMQB2020Class 001001
   ROD: EV_GatewMQB2020Class_VW37.rod
   VCID: 70B9DBB49A20293A2B2-8024 SFD+SFD2 [x]
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Serial number: 7588600400240504056F
   Subsystem 3 - Part No SW: 82A 951 523 F    HW: 82A 951 523 F
   Component: E221__MFL      H03 0010
   Serial number: 03S03001073142224116
2166903 - No Communication with Transmission Control Module
          U0101 00 [00101000] - -
          [TCM_no_communication]
                    Fault Frequency: 39
                    Reset counter: 38
                    Mileage: 38869 km
                    Date: 2026.03.20
                    Time: 15:11:37
8712962 - Attention and Drowsiness Assist
          U1832 00 [00100000] - Function Restriction
          [FAULT_ADA_FUNCTION_ERROR]
                    Fault Frequency: 0
                    Reset counter: 0
8417280 - Diagnostic Filter
          U17A0 00 [00100000] - Not Activated
          [Filter_is_not_active]
                    Fault Frequency: 0
                    Reset counter: 0
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000115317005 Dataset Number: 81A909564C  0005
   Coding: 0808000000000000
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 0849935482B001FA932-805C SFD+SFD2 [x]
   Part No SW: 5Q0 959 593 M    HW: 5Q0 959 593 M
   Component: TSG FS        002 0363
   Serial number: YE007XDK09758 Dataset Number: 81A909872K  0044
   Coding: 00149B204000000000001002
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 4BC36C58D3462AE27E0-801E
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb
   Part No SW: 3WA 907 145 E    HW: 3WA 907 145
   Component: BASGEN1MQB37  503 1122
   Serial number: 02678480 Dataset Number: 81A909852R  0004
   Coding: 01000000010000000001020101000100000001010100
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   VCID: 4ACD695CDC3C33EA456-801E SFD+SFD2 [x]
   Part No SW: 3Q0 907 338 P    HW: 3Q0 907 338 R
   Component: FCM MQB High  H09 0408
   Serial number: 27042411600640 Dataset Number: 81A909583H  0026
   Coding: 0000000509001A6200022300000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiMQBCl 001009
   ROD: EV_MultiModulContiMQBCl_VW27.rod
   VCID: 42DD417CE40CEBAA8D6-8016
   Part No SW: 5Q0 959 392 M    HW: 5Q0 959 392 M
   Component: TSG BFS       002 0363
   Serial number: YE007XDK2659C Dataset Number: 81A909873K  0044
   Coding: 001493204000000000001002
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 48C95354C230C1FA532-801C
   Part No SW: 81A 035 043     HW: 81A 035 043
   Component: MU-TH-ND-EU   055 4142
   Serial number: GRO-63302.05.24 Dataset Number: 81B909545A  0012
   Coding: 12760000804000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU27.rod
   VCID: 59EF8610699A4872FCC-800C SFD+SFD2 [x]
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 81A 919 619     HW: 81A 919 619
   Component: J685_CID_8.8   H30 0010
   Serial number: TPO00104032488010307
   Compact disc data bank:
   Subsystem 2 - Part No: V03 959 800 EG
   Component: Gracenote2     1010
   Volume Control 1:
   Subsystem 3 - Part No SW: 81B 919 616 B    HW: 81B 919 616 B
   Component: E67_LSR        H30 0105
   Serial number: ALJAL214022400010024
   Media socket:
   Component: RVC Compact   H19 0231
   Dataset Number: 81A909460F  0001
   Coding: 0272060102002001400040
   VCID: 392F269089DAA872DCC-806C
   Part No SW: 2GA 035 284 B    HW: 2GA 035 284
   Component: OCUClas2023_H H07 0523
   Serial number: 0000000402VITDF Dataset Number: 81A909612F  0017
   Coding: 01010501001111210000010003002607111112111011000010
   ASAM Dataset: EV_OCUClass2023 001059
   ROD: EV_OCUClass2023.rod
   VCID: 323D11BC54AC5B2A1D6-8066 SFD+SFD2 [x]
   Part No SW: 2Q0 980 653 G    HW: 2Q0 980 653 A
   Component: MQB MFK 3.0   H19 1505
   Serial number: ED3659904241350 Dataset Number: 81B909466A  0019
   Coding: 00040888014A4024489E08001020002000010048600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007057
1126517 - Databus
          [ACC_06_ACC_Status_ACC_reversibel_ERROR]
                    Mileage: 43835 km
                    Date: 2026.07.14
                    Time: 17:22:54
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 5Q0 959 595 M    HW: 8W1 959 595 K
   Component: TSG HFS       006 0363
   Serial number: YE007XDR24668 Dataset Number: 81A909897H  0041
   Coding: 000093004000000000001002
   ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
   VCID: 4DC762402D5224D2604-8018
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS      006 0363
   Serial number: YE007XDS01155 Dataset Number: 81A909896H  0041
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 8Y0 941 597 CB    HW: 8Y0 941 597 C
   Component: LMS_MQB       H20 0113
   Dataset Number: 81A909471E  0008
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 094F965099BA78F28CC-805C
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Dataset Number: 81A909472E  0008
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
End----------(Elapsed Time: 01:25, VBatt start/end: 12.1V/12.1V)-----------
------------------------------5 Faults Found-------------------------------
OK, you may place an order for (free Beta) SFD Service.
RazvanI
Sweden
C?ID=426034
map files content:
adpmap-17-81A-920-790-G_WAUZZZGAXRA067256-20260716-1753.CSV
;SW:81A-920-790-G   HW:81A-920-790-D ---  17: Instruments
;Component:FBenRDW------ H03 0039, Coding:0C0422546D8400080B80A8401000000000000000
;EV_DashBoardFPK2AU326,002045,EV_DashBoardFPK2AU326.rod
;Thursday,16,July,2026,17:53:05:13227
;VCDS Version: 26.6.0.1 (x64)  Data version: 20260708 DS377.1
;VCID: 2C010FC476880DDA57A-8078 SFD+SFD2 [x]
IDE00301-Distance,44172 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language variant,English ,1
IDE00500-Hour,17 H,1
IDE00501-Minute,54 min,1
IDE00502-Year,2026 yr,2
IDE00503-Month,7 Months,1
IDE00504-Day,16 d,1
IDE00510-ESI: distance driven from inspection,16600 km,3
IDE00511-ESI: time from inspection,254 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00518-ESI: thermal load,22300 km,2
IDE00819-Day counter,770 d,2
IDE00820-ENG98466-Activating and deactivating all development messages-CAN,not active ,1
IDE00820-ENG148062-Activating and deactivating all development messages-Ethernet,not active ,1
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE02489-Display depiction,Variant 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.80 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.80 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.70 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
IDE03346-IDE00301-Units adjusted-Distance,Kilometres ,3
IDE03346-MAS01230-Units adjusted-Date,yy_mm_dd ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,litre ,3
IDE03348-MAS01456-Speed warning-Speed,120 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,3
IDE03350-FIX: Maximum time until next time-dependent inspection,275 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,100 km,3
IDE03352-FIX: Time since last time-dependent inspection,1 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-IDE12211-Configuration of displayable contents-China variant,not active ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE13607-MAS16706-Lock display contents-List time out,72000 s,9
IDE14123-MAS01129-Design variant activation-Variant 1,active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,not active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,not active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14188-Range indicator configuration,422 km,8
IDE14220-Vehicle speed warning for India-,0 s,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,Conditions not correct or request sequence error,1
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,Conditions not correct or request sequence error,1
MAS03685-Digital speedometer,Display ,1
ENG253348-3D_speed,No ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG99320-Developers_menu,not active ,1
ENG119833-Display_Save_CP,Yes ,1
ENG316729-ESI_Maximum_mileage_to_next_service_ZDC,30000 km,2
ENG316730-ESI_Maximum_time_to_next_service_ZDC,730 d,2
ENG316731-ESI_Minimum_mileage_to_next_service_ZDC,15000 km,2
ENG316732-ESI_Minimum_time_to_next_service_ZDC,365 d,2
ENG316733-ESI_Oil_quality_ZDC,good oil quality ,1
ENG316701-FIX_Maximum_distance_to_next_mileage_based_service_event_zdc,30000 km,3
ENG316702-FIX_Maximum_time_to_next_time_based_service_event_zdc,730 d,2
ENG251650-GPS_speed,No ,1
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
ENG398324-SFD_development_mode_activation,No_activation_active ,1
ENG316738-SID_Maximum_mileage_to_next_oil_service_ZDC,15000 km,2
ENG316739-SID_Maximum_time_to_next_oil_service_ZDC,365 d,2
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG153987-volume_offset,100 %,1
Elapsed Time: 00:19
blockmap-17-81A-920-790-G_WAUZZZGAXRA067256-20260716-1752.CSV
;Thursday,16,July,2026,17:52:15:13227
Group,Description,Actual
IDE00019,Voltage terminal 30,12.20, V
IDE00025,Coolant temperature,90.00, °C
IDE00301,Distance,44172, km
IDE00310,Outside temperature,36.50, °C
IDE00316-IDE00500,Time-Hour,17, H
IDE00316-IDE00501,Time-Minute,53, min
IDE00316-MAS00111,Time-Seconds,50, s
IDE00317-IDE00502,Date-Year,2026, yr
IDE00317-IDE00503,Date-Month,7, Months
IDE00317-IDE00504,Date-Day,16, d
IDE00510,ESI: distance driven from inspection,16600, km
IDE00511,ESI: time from inspection,254, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,good oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,22300, km
IDE00695,ESI: service exceedance in km,Not available,
IDE00696,ESI: service exceedance in days,Not available,
IDE00697,ESI: remaining distance,13320, km
IDE00698,ESI: remaining running time,476, d
IDE00819,Day counter,770, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2040, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2108, mm
IDE00935,ESI: Theoretical service interval,37200, km
IDE01076,Time since ignition off,1579, s
IDE01153,SIA: maximum value of distance to service,15000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01985-ENG101043,FAZIT identification test sum-Checksum,0F D7 F0 54,
IDE01985-ENG99027,FAZIT identification test sum-Version,02,
IDE02642,Outside temp.: displayed value,26.50, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,FD,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,61524,
IDE03349,FIX: Max. distance until next mileage-related inspection,30000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,275, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,100, km
IDE03352,FIX: Time since last time-dependent inspection,1, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane departure warning,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-ENG126401,Vehicle configuration-intelligent_park_assist,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,14.30, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,50.00, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,52.00, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,14.50, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,8.00, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,50.00, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,52.00, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,9.30, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,17.20, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,50.00, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,52.00, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,17.50, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,8.90, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,50.00, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,52.00, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,9.80, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,43510, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,42950, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,42320, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,41790, km
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,231, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,not_available,
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,1, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,not_available,
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,not_available,
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,not_available,
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,not_available,
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,not_available,
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,605,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,387,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,not_available,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,not_available,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,not_available,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,not_available,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,not_available,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,not_available,
IDE03474-IDE00304,Calculated volume-Fuel level,10.20, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,229, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,not_available,
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,not_available,
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,not_available,
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,11.60, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,not_available,
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,not_available,
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,not_available,
IDE03474-IDE00802,Calculated volume-Full volume,50.00, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,11.60, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,not_available,
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,not_available,
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,not_available,
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.00,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.00,
IDE03474-ENG102894,Calculated volume-averaged_volume,11.60, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,11.60, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,11.60, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.00,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.34, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,0.00, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,11.40, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.00,
IDE03474-ENG99683,Calculated volume-version_of_application,5,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0004578,
IDE03477-IDE00500,GPS time-Hour,0, H
IDE03477-IDE00501,GPS time-Minute,0, min
IDE03477-IDE00502,GPS time-Year,2001, yr
IDE03477-IDE00503,GPS time-Month,1, Months
IDE03477-IDE00504,GPS time-Day,1, d
IDE03477-MAS00111,GPS time-Seconds,0, s
IDE03477-MAS03493,GPS time-last synchronization year,2001, yr
IDE03506,Distance: high resolution,02 A2 04 1C,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 45,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0B,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0B,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 45,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,4F F0 02 04,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,0F F0 6B 64,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,8F F0 6B 64,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,CF F0 02 04,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,8F F0 AC 15,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,CF F0 03 01,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04649-ENG128738,Activation for housing fan-PWM_FAN,0, %
IDE04649-ENG128737,Activation for housing fan-source_max_PWM_requested,none,
IDE04649-ENG98933,Activation for housing fan-Status,OFF,
IDE04649-ENG128733,Activation for housing fan-temperature_Boost,-29, °C
IDE04649-ENG128734,Activation for housing fan-temperature_chipled,57, °C
IDE04649-ENG128736,Activation for housing fan-temperature_GPU,68, °C
IDE04649-ENG128735,Activation for housing fan-temperature_KI,56, °C
IDE06425-IDE06026,Dynamometer mode: functional-Adaptation of brake pedal path sensor,not activated,
IDE06924,Performance display,0,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07159-MAS01155,Control module switch-off: counter-Control module,5, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,F8,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,F8,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,00,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08239,Transponder ID Key 1,00 9F F8 F5,
IDE08240,Transponder ID Key 2,00 A0 0D 22,
IDE08252-ENG101043,Test sum of adapted transponder-Checksum,BC 01 FF 2C,
IDE08252-ENG99027,Test sum of adapted transponder-Version,01,
IDE08343,Immobilizer Challenge,22 C9 27 79,
IDE08701-MAS07266,ESI: Status-Oil change: unit of dist. travelled,Kilometres,
IDE08701-MAS07267,ESI: Status-Oil change: dist. travelled,13400,
IDE08701-MAS07268,ESI: Status-Oil change: stat. of dist. travelled,Service in,
IDE08701-MAS07269,ESI: Status-Oil change: stat. of time,Service in,
IDE08701-MAS07270,ESI: Status-Inspection: stat. of dist. travelled,Service in,
IDE08701-MAS07271,ESI: Status-Inspection: unit of distance traveled,Kilometres,
IDE08701-MAS07272,ESI: Status-Inspection: dist. travelled,29900,
IDE08701-MAS07273,ESI: Status-Inspection: time,274,
IDE08701-MAS07274,ESI: Status-Oil change warning,no warning,
IDE08701-MAS07277,ESI: Status-Inspections warning,no warning,
IDE08701-MAS07305,ESI: Status-Oil change: time,476,
IDE08701-MAS07308,ESI: Status-Inspection: status time,Service in,
IDE08701-MAS10768,ESI: Status-Daily mileage,65,
MAS00077-ENG99298,Immobilizer-State,02 01 03 73 02 00 00 00 01 00,
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
ENG126262-ENG114675,Consumption_for_distance_on_map-s_erw_endsteigung,0.00, %
ENG126262-ENG114674,Consumption_for_distance_on_map-s_erw_str_klasse,0,
ENG126262-ENG128739,Consumption_for_distance_on_map-s_vkmrw_rwdv_antrieb_low_class,0.00, l/100km
ENG126262-ENG126309,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_0,0.00, l/100km
ENG126262-ENG126310,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_1,0.00, l/100km
ENG126262-ENG126311,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_2,0.00, l/100km
ENG126262-ENG126312,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_3,0.00, l/100km
ENG126262-ENG126313,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_4,0.00, l/100km
ENG126262-ENG126314,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_5,0.00, l/100km
ENG126262-ENG126315,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_6,0.00, l/100km
ENG126262-ENG126302,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_0,0.00, l/100km
ENG126262-ENG126303,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_1,0.00, l/100km
ENG126262-ENG126304,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_2,0.00, l/100km
ENG126262-ENG126305,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_3,0.00, l/100km
ENG126262-ENG126306,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_4,0.00, l/100km
ENG126262-ENG126307,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_5,0.00, l/100km
ENG126262-ENG126308,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_6,0.00, l/100km
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,0, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,100, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,65, km
ENG107920-ENG98868,onboard_computer-Range,124, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,5.70, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,0.00, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,0.00, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,0.00, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,5.90, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,5.40, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,0.00, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,0.00, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,0.00, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,65534, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,65534, km
ENG107920-ENG119791,onboard_computer-range_display_value,124, km
ENG107920-ENG126299,onboard_computer-range_lpg,65534, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,65534, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,153,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 99 00 11 00 00 00 36 00 00 00 00 00 39 00 00 00 00 00 7C FF FE FF FE 00 7C FF FE FF FE 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG108925-ENG103300,Service_Key_Data_Current_Page-Service_Data,00 99 00 11 00 00 00 36 00 00 00 00 00 39 00 00 00 00 00 7C FF FE FF FE 00 7C FF FE FF FE 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG108926-ENG103300,Service_Key_Data_Previous_Page-Service_Data,00 99 00 11 00 00 00 36 00 00 00 00 00 39 00 00 00 00 00 7C FF FE FF FE 00 7C FF FE FF FE 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,0,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,153,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,17,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,54,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,57,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,124,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,65534,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,254,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,Update_Error,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Unknown (255),
ENG119884-ENG119838,Service_Key_Mileage_Date-CRC_Block_0,00 36,
ENG119884-ENG119860,Service_Key_Mileage_Date-CRC_Block_1,00 00,
ENG119884-ENG119856,Service_Key_Mileage_Date-CRC_Block_2,FF FE,
ENG119884-ENG119857,Service_Key_Mileage_Date-CRC_Block_3,00 00,
ENG119884-ENG119858,Service_Key_Mileage_Date-CRC_Block_4,FF FF,
ENG119884-ENG119859,Service_Key_Mileage_Date-CRC_Block_5,FF FF,
ENG119884-ENG119861,Service_Key_Mileage_Date-CRC_Block_6,FF FF,
ENG119884-ENG119873,Service_Key_Mileage_Date-CRC_Block_7,FF FF,
ENG119884-ENG119837,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0,0, d
ENG119884-ENG119867,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1,25, d
ENG119884-ENG119868,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2,30, d
ENG119884-ENG119866,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_3,30, d
ENG119884-ENG119865,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_4,31, d
ENG119884-ENG119864,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_5,31, d
ENG119884-ENG119863,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_6,31, d
ENG119884-ENG119872,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_7,31, d
ENG119884-ENG119870,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0,0, Months
ENG119884-ENG119836,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1,1, Months
ENG119884-ENG119850,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2,15, Months
ENG119884-ENG119851,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_3,15, Months
ENG119884-ENG119852,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_4,15, Months
ENG119884-ENG119853,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_5,15, Months
ENG119884-ENG119854,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_6,15, Months
ENG119884-ENG119855,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_7,15, Months
ENG119884-ENG119869,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0,2000, yr
ENG119884-ENG119835,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1,2000, yr
ENG119884-ENG119845,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2,2127, yr
ENG119884-ENG119846,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_3,2127, yr
ENG119884-ENG119847,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_4,2127, yr
ENG119884-ENG119848,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_5,2127, yr
ENG119884-ENG119849,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_6,2127, yr
ENG119884-ENG119862,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_7,2127, yr
ENG119884-ENG119834,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0,10027025,
ENG119884-ENG119839,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1,0,
ENG119884-ENG119840,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2,124,
ENG119884-ENG119841,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_3,8191998,
ENG119884-ENG119842,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_4,4294967295,
ENG119884-ENG119843,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_5,4294967295,
ENG119884-ENG119844,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_6,4294967295,
ENG119884-ENG119871,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_7,4294967295,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG119808,Service_Key_Pointer-Write_Pointer_Adr_159,153,
ENG108929-ENG119809,Service_Key_Pointer-Write_Pointer_Adr_191,17,
ENG108929-ENG119810,Service_Key_Pointer-Write_Pointer_Adr_223,0,
Elapsed Time: 00:17
