Arteon 2021 - Trailer Assistant coding error
wh17
Stuttgart, Germany
C?ID=415332
i tried to code Trailer Assistant for the car, but after that i have an error in #17
16777026 - Function Restricted due to Interrupted Communications
U1110 00 [00001001] - -
[BAP_MFL_Jokerfunktion_0x34 keine Kommunikation]
Reset counter: 128
Mileage: 45172 km
Date: 2026.07.10
Time: 18:22:25
and the 360 camera is not available anymore.
What i changed:
Adresse 10: Einparkhilfe 2 (J791) Labeldatei:| DRV\5Q0-919-298.clb
OLD 82 71 26 79 51
NEW 8A 71 26 79 51
Byte0: 82->8A
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5G0-920-XXX-17.clb-SRI3 ...
OLD 04 A4 10 98 FE 8C 00 08 01 80 62 4F 10 01 00 08 80 70 00 03
NEW 04 ED 10 98 FE 8C 00 08 01 80 F6 4F 38 01 00 08 80 70 00 03
Byte1: A4->ED
Byte10: 62-F6
Byte 12: 10->38
Adresse 6C: R?ckfahrkamera (J928) Labeldatei:* Keine
OLD 01 84 03 01 E3 0F 20 00 00 20 40 14
NEW 01 84 03 01 E3 0F 20 00 00 20 48 14
Byte10: 40->48
Friday,10,July,2026,17:26:30:01151
VCDS Version: 26.6.0.1 (x64)  HEX-NET2 CB: 0.4713.5
Data version: 20260708 DS377.1
VIN: WVWZZZ3HZNE001053   License Plate:
Mileage: 45172km-28068mi   Repair Order: Start
Chassis Type: 3H-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 18 19 22 23 2B 36 3C 42 44
          47 4B 52 5F 65 69 6C 6D 75 82 A5 BB BC CA D6 D7
VIN: WVWZZZ3HZNE001053   Mileage: 45172km-28068miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DTUA)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 022 F    HW: 05L 907 309 B
   Component: R4 2.0l TDI   H30 0987
   Revision: E3H30---    CVN: 942F748DEA44CC7A2B2E5F22EA44CC7A43FB2DAA
   Coding: 0125043A0476050830000000000000000000000000000000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01105L906022F 006004
   ROD: EV_ECM20TDI01105L906022E_006.rod
   VCID: 2A06693F2C7F6EAAA56-807E
   VINID: 9E69EAAAA0D8A9E5400010050C330240F8
Readiness: 0 0 0 1 1
   Part No SW: 0GC 300 014 K    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2802
   Revision: 00H06V13    CVN: 766DF16A
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2D0C62231D917992404-8078
   No subsystems:
   Part No SW: 5Q0 614 517 GD    HW: 5Q0 614 517 BR
   Component: ESC           H82 0114
   Revision: 00000000    Serial number: 61581000000866
   Coding: 0DEC7A94A1203B6D4777070560C648B05E85DCE2E00612753862508852A94A0B0003010312121212B435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 79A48673995915329CC-802C
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0580966338 Dataset Number: V03935330VK 0001
   Coding: 1F20200723
   Shop #: WSC 05311 115 00313
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB_VW41.rod
   VCID: 48C233B79233BCBA532-801C
   Power rear lid opening control module:
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 25363086
   Part No SW: 3G8 907 044 C    HW: 3G8 907 044 C
   Component: Climatronic   H10 0205
   Coding: 14020114204415011115100E8010D936
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 001050
   ROD: EV_AirCondiBHTCMQB3rTranc_001_VW48.rod
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H05 0010
   Serial number: AB95092300PAG0MUFU04
   Subsystem 3 - Part No SW: 11A 907 049 A    HW: 11A 907 049 A
   Component: E265 KPH SH  H02 0183
   Serial number: G04S23.06.2100971652
   Coding: FFFFFF
   Part No SW: 5Q0 937 086 CK    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 040 0400
   Revision: --------    Serial number: J53F0606210114 Dataset Number: V03935348BK 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
   ROD: EV_BCMBOSCH_021_VW27.rod
   VCID: 055CFA83E5A161D2E84-8050
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    210412  042 0607
   Serial number:         210421122451
   Subsystem 2 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S7Y21M06D17H03M09S44
   Coding: 0008EE
   Subsystem 3 - Part No SW: 3G8 941 633 B    HW: 3G8 941 633 B
   Serial number: 18 09 2020  10001013
   Subsystem 4 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL21200FXAE
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000001858861
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 7 - Part No SW: 5Q1 953 521 MM    HW: 5Q1 953 569 K
   Component: Lenks.Modul  H24 0190
   Serial number: 0100150620210C101305
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0073
   Serial number: 000150057621173 Dataset Number: V03935355FN 0001
   Coding: 8A71267951
   Shop #: WSC 05311 115 00077
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW48.rod
   VCID: 58E2E3F742932C3AC32-800C
   Part No SW: 2Q0 907 572 T    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H07 0383
   Dataset Number: V03935346NP 0001
   Coding: 32057FDB5CFF8728749F812581408780000000000000000064
   Shop #: WSC 05311 115 00092
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_VW48.rod
   VCID: 45DC3A83A521A1D2A84-8010
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 14062141350278 Dataset Number: V03935317XE
   ROD: EV_DRCONTITEMIC_VW48.rod
   VCID: 39244673D9D9D532DCC-806C
   Part No SW: 5QF 959 655 AG    HW: 5QF 959 655 AG
   Component: Airbag VW22   015 0753
   Revision: --------    Serial number: 003018LPBLM3WI Dataset Number: V03935342QL 0001
   Coding: 98CCC0C00C8000005C5400CF000C40000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001036
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 1B68BCFB732587222E0-804E
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1062
   Serial number: 3G8857705F0191V00977
   Coding: 802006
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1062
   Serial number: 3G8857706F0194V00240
   Coding: 802006
   Subsystem 3 - Part No SW: -----------    HW: 454 002 005 21
   Serial number: 357000000001EC09525K
   Subsystem 4 - Part No SW: -----------    HW: 454 002 005 21
   Serial number: 358000000005FC09525Q
   Subsystem 5 - Part No SW: -----------    HW: 454 802 606 21
   Serial number: 35100A4425E1E000000K
   Subsystem 6 - Part No SW: -----------    HW: 454 802 606 21
   Serial number: 35200B1575E1E000000P
   Subsystem 7 - Part No SW: -----------    HW: 454 802 305 21
   Serial number: 355008A24251E000000G
   Subsystem 8 - Part No SW: -----------    HW: 454 801 805 21
   Component: PedP_Sensor_D  304 0149
   Serial number: 22800B3D6151E000000N
   Subsystem 9 - Part No SW: -----------    HW: 454 801 805 21
   Component: PedP_Sens_P_2  304 0149
   Serial number: 2290059D1151E000000J
   Subsystem 10 - Part No SW: -----------    HW: 454 801 105 21
   Component: PedP_Sensor_C  304 0149
   Serial number: 23000E2EDB51D000000Z
   Subsystem 11 - Part No SW: -----------    HW: 454 001 004 21
   Component: PedP_Sens_D_2  008 0887
   Serial number: I0M0000000024681B05Y
   Subsystem 12 - Part No SW: -----------    HW: 454 001 004 21
   Component: PedP_Sensor_P  008 0887
   Serial number: I0N0000000010781B05V
   Part No SW: 3G0 920 320 C    HW: 3G0 920 320 C
   Component: KOMBI         523 6170
   Dataset Number: V03935345PG 0001
   Coding: 04ED1098FE8C00080180F64F3801000880700003
   ASAM Dataset: EV_DashBoardVDDMQBA0 001046
   ROD: EV_DashBoardVDDMQBA0_001_VW48.rod
   VCID: 1D6CB2E36D318912D04-8048
                    Reset counter: 128
                    Mileage: 45172 km
                    Date: 2026.07.10
                    Time: 18:22:25
Address 18: Aux. Heat (J364)       Labels:| 5WA-963-27x-V1.clb
   Part No SW: 5WA 963 272 C    HW: 5WA 963 272 C
   Component: STH-VW37x     006 0012
   Serial number: 000000000000127
   Coding: 250B155A5C25162CE46D18
   ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
   ROD: EV_AuxilHeateWOSVW38X_002_VW48.rod
   VCID: 4DCC02A37D515992604-8018
   Auxiliary heating remote control:
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 12062110523289 Dataset Number: V03935343NG 0001
   Coding: 0B0900345F016A00FB1002DE980F00010001070000000000000000000000
   GVL: 01CE3C0808000608C0DC80008086CC0010000000000200000000000000000000
   ROD: EV_GatewNF_VW48.rod
   Generator:
   Component: 4-00-05-00-04
   Subsystem 2 - Part No SW: 1EA 959 442 B    HW: 1EA 959 442 B
   Component: MFL  H03 0217
   Serial number: 17036218091732102696
   Coding: 2F2B00
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H11 9070
   Serial number: 3734687605
   Inverter for socket:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H27 0810
   Serial number: 3259596
Address 22: AWD (-----)       Labels:| 0CQ-907-554-V1.clb
   Part No SW: 5WA 907 554 P    HW: 5WA 525 130
   Component: 4Motion       H65 0724
   Serial number: HA1-00004.05.21
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 005001
   ROD: EV_AllWheelContrHA1VW37X_005.rod
   VCID: 5BE8FCFB33A5C722EE0-800E
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 AC    HW: 3Q0 909 059 C
   Component: EBKV          H09 0207
   Serial number: BPA085110721013
   Coding: 0102C500300000C618638C31000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
   ROD: EV_BrakeBoostG2BoschVW48X_015_VW48.rod
   VCID: 78A28377A2530C3AE32-802C
   Component: ELV-MQBB      H06 0020
   Serial number: 21000141536007
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW48.rod
   VCID: 3338745BFBB52F62160-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 E    HW: 3Q0 959 760 E
   Component: Sitzmemory    H07 0026
   Serial number: Y0007UE931344
   Coding: 001000020000050081C281808080000000008181000000F440
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
   VCID: 3D2C5263CDF1E912F04-8068
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520010728607  Dataset Number: V03935334PN 0001
   Coding: 62A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW48.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520010735468
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS003 0350
   Serial number: YE007UFM28997 Dataset Number: V03935343BL 0001
   Coding: 003F5A42D200028000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW48.rod
   VCID: 4AC609BF8C3F4EAA456-801E
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Dataset Number: V03935339RG 0001
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C2A5F67D6EBE01AC7A-8068
   Part No SW: 3G0 035 466 D    HW: 3G0 035 466 D
   Component: AMPeth16C     H03 3831
   Serial number: A1130J00035210  Dataset Number: V03935352H  0001
   Coding: 24040000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB 001005
   ROD: EV_AMPEthMQB_VW48.rod
   VCID: 261E9D0F38674ACA81E-8072
   Part No SW: 3Q0 907 338 F    HW: 3Q0 907 338 L
   Component: FCM MQB High  006 0370
   Serial number: 14112210801993 Dataset Number: V03935347XG 0001
   Coding: 000000070F0004D207106F04020300000000000000000000000000000000
   Shop #: WSC 12986 004 1048576
   ROD: EV_MultiModulContiVW48X_003_VW48.rod
   VCID: 38224377E2D3CC3A232-806C
   Antenna for short-range communication:
   Subsystem 1 - Part No SW: 3V0 959 121 A    HW: 3V0 959 121 A
   Component: R350 NFCTGS  401 0109
   Serial number: 0000000000B5529B01D7
   Antenna 2 for short-range communication:
   Subsystem 2 - Part No SW: 3G0 980 611     HW: 3G0 980 611
   Component: J524 NFCMIKO  H09 0059
   Serial number: 32100000000001408230
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YE007UFJ0027D Dataset Number: V03935343BN 0001
   Coding: 003F5042DE00028000001000
   ROD: EV_DCU2PasseSideMAXHKLO_VW48.rod
   VCID: 49C436B3893945B24CC-801C
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3G5 035 816 F    HW: 3G5 035 816 F
   Component: MU-O-ND-EU    H22 0330
   Serial number: VWZAZ2Y0679742  Dataset Number: V03935343QN 0001
   Coding: 24830000000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_VW48.rod
   VCID: 2C0A6F27268B709A57A-8078
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2     H61 9216
   Serial number: VWZ6ZJY1821152
   Subsystem 2 - Part No: V03 959 809 TB
   Component: EUR 2021/22    5041
   Component: RDKBERU30     H06 0009
   Serial number: 40000000558237 Dataset Number: V03935349AU 0001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 343A7747FEBB285A0FA-8060
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H2 907 383     HW: 5H2 907 383
   Component: Anhaenger     H09 0040
   Serial number: 000000000005830 Dataset Number: V03935301PU 0001
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW48.rod
   VCID: 6D8CA223DD11B992004-8038
   Part No SW: 5Q0 907 556 D    HW: 5Q0 907 556
   Component: Areaview 2    H23 0609
   Serial number: C854711JJ008146 Dataset Number: V03935327KF 0001
   Coding: 01840301E30F200000204814
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW48.rod
   VCID: 3A26597FDCDFDE2AD56-806E
   Part No SW: 5WB 959 107     HW: 5WB 959 107
   Component: HDSG-Modul    H04 0430
   Revision: --------    Serial number: A2-C767-1200-5 Dataset Number: V03935342KH 0001
   Coding: 0B08
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536_001_VW42.rod
   VCID: 0D4CC2A3BDD11992A04-8058
   Part No SW: 5WA 035 284 H    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0311
   Serial number: 0000000106VIDNB Dataset Number: V03935480NJ 0001
   Coding: 024830001968AC209025460161502E07
   ASAM Dataset: EV_OCUGen3High 003021
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4BC80CBB834557A27E0-801E
Address 82: Head Up Display (J898)       Labels:| 3G0-919-608.clb
   Part No SW: 3G0 919 608 D    HW: 3G0 919 608 D
   Component: HeadupDisplay 054 0530
   Dataset Number: V03935308HM 0001
   Coding: 574040
   ASAM Dataset: EV_HeadUpDisplContiVW481 001015
   ROD: EV_HeadUpDisplContiVW481_VW48.rod
   VCID: 2F30782B179D0B82728-807A
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1301
   Serial number: E79132510211960 Dataset Number: V03935352MP 0001
   Coding: 00000898217EC020089E10001030004000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW48.rod
   VCID: 353C4A43F5C13152384-8060
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007UEP10888 Dataset Number: V03935319JE 0001
   Coding: 000A50420100028000001000
   ROD: EV_DCU2RearDriveMAXHKLO_VW48.rod
   VCID: 4CCA0FA7864B509A77A-8018
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS005 0350
   Serial number: YE007UEP1087D Dataset Number: V03935319JD 0001
   ROD: EV_DCU2RearPasseMAXHKLO_VW48.rod
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Dataset Number: V03935282GT 0001
   Coding: 608000748301
   ROD: EV_SunRoofCONTIAU736_009_VW48.rod
   VCID: 76BE8D4FA8477A4AF1E-8022
   Part No SW: 992 941 572 AA    HW: 992 941 572 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_001_VW48.rod
   VCID: 6296C11F14CFF6EAAD6-8036
   Component: LED1R         H08 9002
End----------(Elapsed Time: 02:38, VBatt start/end: 12.0V/11.8V)-----------
---------------------------No fault code found.----------------------------
Paskal
Czech Republic
C?ID=508876
And did you have the towbar extended?
When you were making coding adjustments and adapting Trailer functions.
Paskal
Czech Republic
C?ID=508876
For Trailer Assist inspiration, you can look here.
wh17
Stuttgart, Germany
C?ID=415332
i think no, is this important?
well someone wrote
"camera needs car specific dataset and coding and calibration. Try ebay, official parts shop, allegro, add breaker here :)"
Does this apply to the 360 camera
AINils
Germany (AIB)
C?ID=56975
You have to deactivate in 17 Dashboard Byte 10 -> Bit 7 as Joker Button is mostly a Audi Feature and also was inactive in old value
Reactions: TTT
wh17
Stuttgart, Germany
C?ID=415332
Do i need the trailer itself at the car to code the assistant or can i do the coding without the trailer connected?
TTT
C?ID=547002
Bullshit.
wh17
Stuttgart, Germany
C?ID=415332
So i will anwer it myself:
Yes i extended the towbar, while it seem not necessary to have the trailer connected.
What has to be done:
STG 10 > Coding > Byte 00 > Bit 3 activate
STG 17 > Coding > Byte 12 > Bit 5 activate
STR 17 ->Coding > Byte 10 ->Bit 7 decativate
STG 6C > Coding > Byte 10 > Bit 3 activate
These settings have to be changed:
STR 5F disable:
menu_display_trailer_assistant_after_disclaimer","not activated"
menu_display_trailer_assistant_over_threshold_high","not activated"
Trailer_Assistant_0x36","not activated"
Trailer_Assistant_msg_bus_0x36","none"
and i had to reset the MMI (Press Home Button for 10sec).
There was an issue to Change Adp, i got this error (sorry i used german version):
I did not take the new value and i also got the error 31 in some cases.
What i did:
(1) revert the complete coding in STR 10,17,6C
(2) change the adaption channel
(3) put back the coding
(4) reset MMI (oress Home Button for 10sec).
I got error 31 in some codings and had to split it. There seem to be dependencies and if i code it byte by byte it worked.
  • Informative
AINils
Germany (AIB)
C?ID=56975
In first post you didn't wrote about these:
This is not needed in MQB Legacy cars and will bring issues in RVC System like your case
