J393 adaption issue
Rob_ash87
Hey all new member here but long time reader, i have an A4 allroad B8.5 (UK) and tried to fit the FL LED tail lights, using adapter leads and changed the adaption channels in 46.
When i noticed that the lights weren't working as intended (brakes with fogs for turn signals) i tried to return the channels to what they should be but on doing this i noticed that it hadn't taken the adaptions i set, it set all the channels to 10248, has anyone experienced this as it doesn't matter how many times i try it won't accept the adaptions.
PRE adaptions.
195- 14849
196-14881
197-14852
198-14884
199-0
200-73
201-105
202-0
203-14849
204-14881
205-13
206-45
207-0
208-0
Im ging to my mates tomorrow to use odis could anyone confirm these channels please
Viking
C?ID=151455
Please post an autoscan showing how the car is at the moment.
Rob_ash87
Just a fault scan or channels too? as the only fault currently is invalid data
Viking
C?ID=151455
Follow the link I posted and do as it says there...
Rob_ash87
Monday,13,July,2026,07:09:59:57798
VCDS Version: 26.3.0.0 (x64)
VIN: WAUZZZ8K2EA084828   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 6D 72 77
VIN: WAUZZZ8K2EA084828   Mileage: 193950km-120514miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 KD    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---    CVN: 2D824C9C
   Coding: 32194012242601080000
   Shop #: WSC 35808 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018KD 003005
   ROD: EV_ECM20TDI01103L906018JG.rod
   VCID: 76E80735C926FB2FE9-8022
   VINID: 9D196AAAA21B09544020420220C8BF4DF1
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K9 907 379 N    HW: 8K9 907 379 N
   Component: ESP8 quattro  H09 0020
   Coding: 06154401
   Shop #: WSC 06335 000 00000
   VCID: 4D9A88D91430D8F778-8018
   Part No SW: 8K0 907 064 HG    HW: 8K0 907 064 GG
   Component: BCM2 2.0      H13 0641
   Coding: 03B24040000000000000
   VCID: 7CFC151DFF0AA17F9F-8028
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0513000081031021
   Serial number: 0213000367371016
                    Fault Status: 00101101
                    Reset counter: 54
                    Mileage: 193724 km
                    Date: 2026.07.08
                    Time: 12:11:35
00166 - Access/Start Authorization Switch (E415)
                    Reset counter: 54
                    Mileage: 193724 km
                    Date: 2026.07.08
                    Time: 12:11:35
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 54
                    Mileage: 193724 km
                    Date: 2026.07.08
                    Time: 13:41:28
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 AJ    HW: 8K2 820 043 AJ
   Revision: D1000000    Serial number: 01181120130859
   Coding: 342402E000
   VCID: 71E23429A848DC173C-8024
   Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 DD
   Revision: 04016001    Serial number: 00000054871502
   Coding: 290000308034A7C00081000300001F1F001D070827080201000008004000030000000020000000
   VCID: 74EC3D3DD75AE93FD7-8020
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 131113  H06 0080
   Serial number: SWF13110135247
   Coding: 00FD11
   Serial number: 21965513
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000911130504
   Serial number: F2788BD6000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KFDB2Z5N+   Dataset Number: 8K0909602Q  0001
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 55962 001 1048576
   VCID: 4894B9CDF3523DDF4B-801C
   Serial number: 6334MSME7D552E27S
   Serial number: 6344MSME4118430C7
   Serial number: 6352QSME5D392C5E/
   Serial number: 6362QSME653A4C4AW
   Serial number: 63732SME2339364C+
   Serial number: 63832SME23391540R
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862MKG000E2
   Coding: 000017
   VCID: 4894B9CDFB523DDF4B-801C
   Part No SW: 8K0 920 983 G    HW: 8K0 920 983 G
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: ZAC561XAE
   Coding: 3384290202012600010000
   VCID: 3972CC09B0B85457C4-806C
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0056
   Revision: 1V080027    Serial number: 2741V13A22034F
   Coding: 80CF07FF00
   Serial number: 7753961703
   Serial number: 13318003592011200181
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000080899230
   Coding: 011002204001410001
   VCID: 50A491AD0302F51F13-8004
   Component: RCEPS         H39 0507
   Revision: 00001000    Serial number: 0009026205 Dataset Number: 8K0909852H  0023
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 346CFD3D9FDAA93F17-8060
   Revision: 00002001    Serial number: 0319396608
   Coding: 013B0622A0B930408320023680000047
   Shop #: WSC 06335 123 12345
03389 - Data Set Implausible
                    Reset counter: 23
                    Mileage: 193952 km
                    Date: 2026.07.13
                    Time: 06:04:50
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 H    HW: 8R0 035 223 F
   Component: DSP STD       H11 0470
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 3162F42968C89C177C-8064
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000081833186
   VCID: 4FA692D11E3CEAE70A-801A
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 00000001396315
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3972CC09B8B85457C4-806C
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R2 035 186 P    HW: 8R2 035 186 P
   Component: Concert3 DAB  H06 0470
   Revision: 00000003    Serial number: AUZ5Z6M1970131
   Coding: 0502008201028D00035B071000
   VCID: 438EAEE1C2741E879E-8016
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000082157680
   Coding: 010002204001210001
   VCID: 4688B7F5F1462BAFB9-8012
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C7CD51DBF8A617FDF-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H52 0330
   Serial number: 8K9827852A
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000082157585
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005689491
   Coding: 0010320
   VCID: 3D7AD81964906877E8-8068
End-------------------------(Elapsed Time: 04:42)--------------------------
------------------------------4 Faults Found-------------------------------
