2005 Rialta/2004 Eurovan problems
TxPigeon
Brownwood, TX, USA
C?ID=2242
I'll try my best to do this properly.
I've had VCDS for over 20 years, but only used it for the minor things that came up on the Rialta and Jettas. Thought I had an account here, but found no reminders of it, so got a new account yesterday.
I recently bought my second Rialta, but this one has the CEL/MIL on - generic codes P0449 and P2401. Drove it home to TX from FL. No noticeable driving problems. Now I'd like to get rid of the codes so I can more thoroughly enjoy driving it. To begin with, I checked the blinker fluid and muffler bearings, so that's out of the way.:) I cleared the codes using VCDS, started the engine for a minute or so, then shut down to do a scan. Here's what it said:
Sunday,12,July,2026,08:42:15:51831
VCDS Version: 26.3.0.0 (x64)
VIN: WV3AB47074H003445   License Plate: R2A
Mileage: 128460km-79821mi   Repair Order:
Chassis Type: 70 (00 - Rialta)
Scan: 01 02 15 17 19 25 35
VIN: WV3AB47074H003445   Mileage: 128460km-79821miles
Address 01: Engine        Labels: 022-906-032-AXK.lbl
   Part No: 022 906 032 AH
   Component: MOTRONIC ME7.1  G   0003
   Coding: 00003
   Shop #: WSC 02757
   VCID: D1A351CA1B23CD179C-513C
17880 - EVAP Leak Detection Pump
            P1472 - 35-00 - Short to Ground
17876 - EVAP Canister Solenoid Valve 2 (N115)
            P1468 - 35-00 - Short to Ground
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01P-927-733.lbl
   Part No: 01P 927 733 CM
   Component: AG4 Getriebe 01P    4973
   Coding: 00000
   VCID: 8005A48E80C9F49F43-0960
01236 - Shift Selector Locking Solenoid (N110)
            31-00 - Open or Short to Ground
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 603 CK
   Component: AIRBAG VW3 -        V04
   Coding: 17227
   Shop #: WSC 02757
   VCID: F4EDF85EC471D83F57-4B18
Address 17: Instruments        Labels: 7D0-920-xxx-17.lbl
   Part No: 7D0 920 902 T
   Component: T4-KOMBIINSTR. VDO V01
   Coding: 03235
   Shop #: WSC 02757
   VCID: B56B055A8F8B8137A0-515A
   Part No: 6N0 909 901
   Coding: 00001
   Shop #: WSC 02757
   VCID: F0E5F44EB069E41FB3-515A
Address 25: Immobilizer        Labels: 6X0-953-257.lbl
   Part No: 6X0 953 257
   Component: IMMO                0008
   Coding: 00001
   VCID: FDFBDD7AF73B997728-4B18
   WV3AB47074H003445     VWZ1Z0C2453596
Address 35: Centr. Locks        Labels: 7D0-959-800.lbl
   Part No: 7D0 959 800 C
   Component:    Funksteuergerát  0002
   Coding: 00001
   Shop #: WSC 02757
   VCID: AD5B2D3A67DBC9F7D8-4B00
End-------------------------(Elapsed Time: 01:13)--------------------------
------------------------------3 Faults Found-------------------------------
I did a bit of checking, but feel sort of lost at this point. Way past anything I've done in the past. I know the Short-To-Ground is often caused by a blown fuse or bad relay, though usually a lot more shown, so I checked all of them. Found a couple of fuses that didn't seem to be related that needed replacing. Any suggestions are definitely appreciated. FYI, I do have the Bentley, most of the VW test cables (including the VAG 1598/31 for the ECU/ECM), and many of the tools needed for these critters.
Thanks,
Duane
Yup. Get out your wiring diagram for the engine, check if you have 12V on the one side of the LDP and EVAP solenoid. Typically this sorts of things are turned on by the ECU pulling the other side low. If no +12, use WD to trace back to see where it's it's not making it though.
TxPigeon
Brownwood, TX, USA
C?ID=2242
Thanks. Guess I just needed a small kick in the right direction. I have the 12V at the t4e connector in the engine compartment, but not at either of the places at the canister platform. I will find it eventually. I don't much like being out there when it's over 90, so time is limited this time of year. Supposed to be a cold front coming through, so only 88 or 89 on Wed. & Thu. though!
BTW, probably should have mentioned that I'm 98% sure that the previous owner had a local 'expert' working on it, so...
Thanks again,
Duane
TxPigeon
Brownwood, TX, USA
C?ID=2242
TA-DA! Naturally I started at the wrong end, but found a broken wire (and one almost broken) about 8 inches from the t4e connector. Hard to tell if it's mouse damage or from the battery being mishandled. Anywho, the CEL is off and no codes (yet?) I'm planning to take a little road trip tomorrow to see what else, if anything, shows up, so I may be back...
Duane
