Objet : [Golf 7 1.4 TSI] Erreurs B1154 96 (GRA/CCS) et de bus de données suite à un codage à distance incorrect
Bonomet
Pirate
Walking the Plank
Belgium
Subject: [Golf 7 1.4 TSI] B1154 96 (GRA/CCS) and databus errors after a bad remote coding
Hello everyone,
My name is Patrick, I am a retired mechanic. I am new to the Ross-Tech forum, and I would first like to thank all the contributors. The amount of knowledge shared here is fantastic.
I am reaching out for some expert advice regarding a coding mess on my 2014 Golf 7 (1.4 TSI, CXSA engine, 247k km). The car came with a factory Multi-Function Steering Wheel (MFSW). I recently attempted a Cruise Control System (GRA/CCS) retrofit. I replaced the steering wheel buttons with the GRA version and routed the required wire (from Pin 56 on Engine ECU 01 to Pin 5 on Steering Column module 16).
For the software activation, I made the mistake of letting a third party attempt a remote coding session. This person messed with several codings blindly, without leaving a log or backup of the original state. After multiple conflicts appeared, I stopped the process. Since I do not have a SWAP code for official activation, I tried to revert all modules back to their factory coding using my genuine VCDS 23.1, based on what I believe the original values were.
The Problem:Ever since this disastrous intervention, and despite my best efforts to revert to stock, I have multiple persistent fault codes. The physical GRA buttons and the retrofitted wire are still installed.
To help you check if a bad coding left by this person is hiding somewhere, here is the complete list of my current Long Codings:
  • 01 - Engine: 01190032230401082000
  • 03 - ABS Brakes: 01FA6AA124282970037A060341C32980562494C0608294F30020506AC002
  • 08 - Auto HVAC: 00020004200100011005000000101000
  • 09 - Cent. Elect.: 00000B46C24122FB4BE44000411C0708101E000000000000000000000000
  • 15 - Airbags: 98CCC000000000005C0000CF004800000065
  • 16 - Steering wheel: 0500
  • 17 - Instruments: 078519002B90000803080A00040000
  • 19 - CAN Gateway: 030100042B085700EF00024A080F00010001000000000000000000000000 (Distance Regulation adapted to "not activated")
  • 42 - Door Elect, Driver: 003E03208000040000001000
  • 44 - Steering Assist: 0303
  • 52 - Door Elect, Pass.: 003E01208E00040000801000
  • 55 - Headlight Range: 029A01000B000200
  • 5F - Information Electr.: 02730000FF0000004011000100000000000006040000010000
  • 76 - Parking Assist: 0011061041
And here are the specific DTCs that immediately return after clearing:
  • Module 19: B1154 96 - Cruise Control Switch - Component Internal Failure (Static)
  • Module 19: U140600 - Quiescent current too high (Sporadic)
  • Module 19: U006500 - Infotainment System CAN No Communication (Sporadic)
  • Module 09: U112100 - Databus missing message (Static)
  • Module 09: B126301 - Activation for fuel tank flap unlock electrical error (Static)
  • Module 03: U112300 - Databus error value received (Sporadic) -> This error appeared specifically after the third-party remote coding.
My questions:
  1. Do you spot any errors in my Long Codings that could explain these conflicts, especially regarding the ABS module?
  2. Is the Gateway physically detecting the GRA buttons over the LIN bus, causing a cascade of databus errors (U112100 and U112300) because it conflicts with my "best guess" stock coding?
  3. What is the definitive procedure to clear this B1154 96 fault code considering the hardware is still physically present?
Thank you in advance for your time and expertise!
Best regards,Patrick.
Viking
C?ID=151455
Please post a complete Autoscan from the vehicle as it currently stands.
Bonomet
Pirate
Walking the Plank
Belgium
Hi Viking,
Thank you for your reply. You are absolutely right, here is the complete and unedited VCDS Auto-Scan from the vehicle as it currently stands.
Removed.  Data from a clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
  • Disagree
RGH0
Australia
C?ID=433612
mmmm...... 23 version of VCDS :popcorn: S
  • Agree
