2015 tiguan s cruise inop and has verious codes
Hemi52rb
C?ID=659295
vehical came in for check engine light on found code for intake manifold flap sensor replaced intake manifold, and found turbo housing leaking oil so replaced turbo. now has power and no codes car left shop for about a week then returned with other issues found at first engine tach would go to about 1200 rpm then drop to 800 rpm and the engine stays at idle the whole time and continue doing this as at same time temp gauge would go to 1/4 scale then come back down to cold then back back up again all the while the cooling fan comes on high at times this doesnt act up till it is at operating temp other times it acts up when you first start up.
i just recently bout the vcds pro to talk to car hoping to find something i will tell you i have no clue as to working on diag'ing vw outside of normal maintanace i got the vcds to get the proper diag tool im new to vcds and checking ross-tech websit and wiki to get answers on were to go next. i work for independant repair company. and we have had this car for w while so i need to get some answers and stuff to try thank you all for the help and patients.
Sunday,05,July,2026,15:59:03:59201
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4713.5
VIN: WVGAV7AX6FW513491   License Plate: TOE-241
Mileage: 251570km-156318mi   Repair Order: WITH ALL MODUALS CONNECTED
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4C 52 53 56 62
          72 75 77
VIN: WVGAV7AX6FW513491   Mileage: 251570km-156318miles
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 561 907 426 E    HW: 561 907 426 E
   Component: AC Manuell    H02 0303
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1D6CB13A6D3FBAF2C45-8048
          U1111 00 [00001000] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 133
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 26
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
   Part No SW: 5K0 937 084 L    HW: 5K0 937 084 L
   Component: BCM PQ35 B    122 0174
   Revision: BG122001
   Coding: EF1A0A1B80232EC4018800C11000044448010086524D8D60648000000040
   VCID: 3B285FA2D36BD4C2DA1-806E
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 200514  24  0664
   Coding: 009795
7 Faults Found:
                    Fault Frequency: 31
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
                    Voltage: 11.25 V
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:00:26
                    Voltage: 11.05 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:59
                    Voltage: 11.25 V
                    Fault Frequency: 199
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:59
                    Voltage: 11.25 V
                    Fault Frequency: 13
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:58
                    Voltage: 11.25 V
                    Fault Frequency: 31
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:58
                    Voltage: 11.25 V
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:60
                    Voltage: 11.25 V
Address 15: Airbags        Labels:
   VCID: 55FCE91A5C0F22B2CC5-FFFE
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20250119001378
   Coding: 7982A00000
   VCID: 0256E246F481650AD97-8056
   Serial number: 0565298
   Coding: 820000
0516 - Databus
                    Fault Frequency: 15
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
          B1149 13 [00001001] - Open Circuit
                    Fault Frequency: 15
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
229127 - Cruise Control Switch
          B1154 11 [00001001] - Short to Ground
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
229147 - Cruise Control Switch
          B1154 13 [00001001] - Open Circuit
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
335876 - Powertrain Databus
          U0002 00 [00001000] - No Communications
                    Fault Frequency: 131
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:23:00
   Part No SW: 5N0 920 973 H    HW: 5N0 920 973 H
   Component: KOMBI         H03 0905
   Coding: 211F01
   VCID: 392445AAD9D7E6D2C8D-806C
7 Faults Found:
9460250 - Covering for fuel level indicator sensor 2
          B105A 1A [00001001] - Resistance Too Low
          [Geber 2 für Kraftstoffvorratsanzeige: Übergangswiderstand zu klein]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
12648448 - Function Restricted due to Missing Message(s)
          [Steuergerät für Motor: keine Kommunikation]
                    Fault Frequency: 244
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
12648704 - Function Restricted due to Missing Message(s)
          [Steuergerät für Getriebe: keine Kommunikation]
                    Fault Frequency: 33
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
12656896 - Function Restricted due to Missing Message(s)
          [Steuergerät für Bremse: keine Kommunikation]
                    Fault Frequency: 22
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
12669184 - Function Restricted due to Missing Message(s)
          [Steuergerät für Airbag: keine Kommunikation]
                    Fault Frequency: 8
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:58
13638912 - Function Restricted due to Missing Message(s)
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
12658688 - Function Restricted due to Missing Message(s)
          [Steuergerät für elektrische Parkbremse: keine Kommunikation]
                    Fault Frequency: 22
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb   WITH CAN UNPLUGGED
   Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1653
   Revision:   H57       Serial number: 190614F2000365
   Coding: 356002
   VCID: 7EAE96B680F901EABDF-802A
Address 1C: Position Sensing
   Component: IMMO          H03 0905
   VCID: 6A86AAE6ECF19D4A717-803E
Address 2E: Media Player 3
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0008713214
   Coding: 0004B4
   VCID: 382240AEE2DDFFDA373-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000008863001
   Coding: 000490
          B11EC 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 59
68108 - Function Restricted due to Missing Message(s)
          [Front CAN MSG]
                    Fault Frequency: 51
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:47
Address 44: Steering Assist
Address 4C: Tire Pressure II
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0008742276
   Coding: 0004B4
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000008827742
   Coding: 000490
          [Front CAN MSG]
                    Fault Frequency: 57
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:47
Address 53: Parking Brake
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H07 0009
   Revision: -----12S    Serial number: VWZ4Z7P3579686
   Coding: 0100044004000C
   VCID: 2B086FE2230B44424A1-807E
00625 - Vehicle Speed Signal
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140525 Dataset Number: 561098V____ 0010
   Coding: 02130602C2161A107F1606C00000
   ROD: EV_OCULow_001_VW12.rod
   VCID: 53F817025B7B3C82221-8006
12670464 - Databus
          [CAN TO brake]
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:23:03
0041 - Databus
          [CAN TO Motor ECU]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
2103041 - Control Module
          B1788 F0 [00001001] - Start Prohibition Deactivated
                    Fault Priority: 8
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:05:27
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666355317 Dataset Number: 5N0035729E  0001
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 3236728604A1158A097-8066
End----------(Elapsed Time: 01:12, VBatt start/end: 12.2V/12.4V)-----------
------------------------------36 Faults Found------------------------------
Sunday,05,July,2026,16:25:38:59201
Scan: Auto-detect
Function not supported by the gateway.
End----------(Elapsed Time: 00:02, VBatt start/end: 12.6V/12.4V)-----------
---------------------------No fault code found.----------------------------
Sunday,05,July,2026,16:04:29:59201
          72 75 77
VIN: WVGAV7AX6FW513491   Mileage: 251570km-156318miles  WITH ABS MODUAL UNPLUGGED
Address 01: Engine
   Revision: 00001K02
   Coding: 0010001002
                    Fault Frequency: 232
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 162
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
   Revision: BG122001
   Coding: 009795
7 Faults Found:
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
                    Voltage: 11.25 V
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:00:26
                    Voltage: 11.05 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:59
                    Voltage: 11.25 V
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:59
                    Voltage: 11.25 V
                    Fault Frequency: 15
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:58
                    Voltage: 11.25 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:58
                    Voltage: 11.25 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:60
                    Voltage: 11.25 V
Address 15: Airbags
   Coding: 7982A00000
   Coding: 820000
0516 - Databus
                    Fault Frequency: 18
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 15
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
          U0002 00 [00001001] - No Communications
                    Fault Frequency: 230
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:23:00
   Coding: 211F01
7 Faults Found:
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 35
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 163
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 54
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
   Coding: 356002
Address 25: Immobilizer
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
                    Reset counter: 59
          [Front CAN MSG]
                    Fault Frequency: 245
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:47
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
          [Front CAN MSG]
                    Fault Frequency: 251
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:47
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
12670464 - Databus
          [CAN TO brake]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:23:03
0041 - Databus
          [CAN TO Motor ECU]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Priority: 8
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:05:27
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:23, VBatt start/end: 12.3V/12.7V)-----------
------------------------------29 Faults Found------------------------------
Sunday,05,July,2026,16:10:08:59201
          72 75 77
Address 01: Engine
   Revision: 00001K02
   Coding: 0010001002
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
13701600 - Function Restricted due to Missing Message(s)
          [Airbagsteuergerät - kein Signal/Kommunikation --> Fehlende Botschaft [ID] von Airbagsteuergerät]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:16:56
   Revision: BG122001
   Coding: 009795
9 Faults Found:
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
                    Voltage: 11.25 V
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:00:26
                    Voltage: 11.05 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:16:58
                    Voltage: 12.80 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:59
                    Voltage: 11.25 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:59
                    Voltage: 11.25 V
                    Fault Frequency: 18
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:58
                    Voltage: 11.25 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:58
                    Voltage: 11.25 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:16:58
                    Voltage: 12.60 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:60
                    Voltage: 11.25 V
Address 15: Airbags
   Coding: 7982A00000
   Coding: 820000
0516 - Databus
                    Fault Frequency: 21
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 15
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:23:00
335886 - Powertrain Databus
          U0001 00 [00001001] - Unspecified Malfunction
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:16:55
   Coding: 211F01
7 Faults Found:
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 41
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 61
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
   Coding: 356002
01312 - Powertrain Data Bus
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:16:55
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
                    Reset counter: 59
68107 - Function Restricted due to Missing Message(s)
          [Front CAN AirBag]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:16:56
          [Front CAN MSG]
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:47
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
          [Front CAN AirBag]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:16:55
          [Front CAN MSG]
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:47
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
12670464 - Databus
          [CAN TO brake]
                    Fault Frequency: 8
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:23:03
0035 - Databus
          [CAN TO Airbag]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:17:00
0041 - Databus
          [CAN TO Motor ECU]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Priority: 8
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:18:07
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:05, VBatt start/end: 12.8V/12.6V)-----------
------------------------------37 Faults Found------------------------------
          72 75 77
VIN: WVGAV7AX6FW513491   Mileage: 251570km-156318miles   PCM UNPLUGGED
Address 01: Engine
   Revision: 00001K02
   Coding: 0010001002
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:16:56
   Revision: BG122001
   Coding: 009795
9 Faults Found:
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
                    Voltage: 11.25 V
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:00:26
                    Voltage: 11.05 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:16:58
                    Voltage: 12.80 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:59
                    Voltage: 11.25 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:59
                    Voltage: 11.25 V
                    Fault Frequency: 18
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:58
                    Voltage: 11.25 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:58
                    Voltage: 11.25 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:16:58
                    Voltage: 12.60 V
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:60
                    Voltage: 11.25 V
Address 15: Airbags
   Coding: 7982A00000
   Coding: 820000
0516 - Databus
                    Fault Frequency: 21
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 15
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:23:00
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:16:55
   Coding: 211F01
7 Faults Found:
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 41
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Frequency: 61
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
   Coding: 356002
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:16:55
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
                    Reset counter: 59
          [Front CAN AirBag]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:16:56
          [Front CAN MSG]
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:47
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
          [Front CAN AirBag]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:16:55
          [Front CAN MSG]
                    Reset counter: 99
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:03:47
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2020.11.25.
                    Time: 00:22:57
12670464 - Databus
          [CAN TO brake]
                    Fault Frequency: 8
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:23:03
0035 - Databus
          [CAN TO Airbag]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:17:00
0041 - Databus
          [CAN TO Motor ECU]
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:22:58
                    Fault Priority: 8
                    Reset counter: 59
                    Mileage: 251571 km
                    Date: 2026.07.05.
                    Time: 00:18:07
   ROD: EV_UHVUMI.rod
Powertrain databus (CAN) appears to be completely off-line. That's not going to be easy to find. Could be a bad CAN gateway. Could be a wiring problem. Could be one module on that bus choking the whole bus.
Hemi52rb
C?ID=659295
did you happen to notice i started with all modules plugged in then i unpluged pcm 1st then abs then can gateway maybe relook at it thank you
Hemi52rb
C?ID=659295
uwe
thank you for the responce i think found problem at first the dash would beep constantly then i called ross-tech they said start unpluging moduals on the network to see if anything changed i also was checking bus hi and bus low and found both were 2.47 volts knowing there suppost to be different voltages that add up to be 5.0volts witch it does not do so i found #1 i unplugged the abs modual and beeping stopped then #2 i found out gateway wasent communicating with other moduals keep getting 0010 instead of 0000 found out gateway is supposed to have 12 constant and 12 volts whe key turned to run i didnt have either i ran 2 new wires to gateway and now have voltage but still no communication so i figued abs modual took out the gateway so waiting for customer to auth abs modual and gateway
Vdub
C?ID=57533
Did you also found the box of punctuation marks and capital letters?
TTT
C?ID=547002
Can bus voltages that add up to be 5V. That's a first to me. Anyone else agrees voltages should add up to be 5V, hands up?
