Hi,
a few weeks ago (on a extremely hot day) a lot of assistants stop working at the same time, mainly related to the front assist. After one or two days, I disconnected the battery for a few seconds and connected it again, my thought were a "reset" of the car. After I connected again, I got even more fault in the dash, but driving around 5 minutes, all fault disappeared, only the airbag light remained on. I did some research and replaced the 6 year old battery, because according to the internet, this seems to be the most common reason. I coded the new capacity to the car and set the battery serial number +1. Battery technology and manufacturer (AGM or fleece and Varta VA0) stayed the same. After driving around a few days, the airbag light did not go away. I tried to delete the codes (I got a VSDC HEX V2 unlimited and SFD), no luck. At the moment i only got the airbag light in the dash and 9 faults in VCDS, all for electronic stuff. But everything seems to work, besides the airbags (but I haven't tested them either), for example the Back-Up Cam -- Status Can not be reached. I assume this is the cam for parking backwards, this cam is working absolutely fine...
The attached scan was made without a SFD session and without SFD unlocking any ECU. But I tried in the past scanning and deleting with everything unlocked, no success.
Any ideas?
Best regard Luis
Any ideas?
Best regard Luis
Saturday,11,July,2026,19:23:09:29638
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(Virtual PC)
VCDS Version 26.6.0.1 (arm64) HEX-V2 CB: 0.4713.5
Data version: 20260708 DS377.1
VIN: TMBJJ7NX8MY037966 License Plate: BERTI
Mileage: 137289km-85307mi Repair Order:
Chassis Type: NX-SK38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 52 5F 69 6C
75 A5 BB BC CA 811E 811F 8120 8121 C002 C003
VIN: TMBJJ7NX8MY037966 Mileage: 137289km-85307miles
6C-Back-up Cam. -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DSTB) Labels:. 05L-907-309-V1.clb
Part No SW: 05L 906 022 BE HW: 05L 907 309 C
Component: R4 2.0l TDI H30 9972
Revision: E3H30--- CVN: 6812400E644B2C53FDCF42ED644B2C5343FB2DAA
Coding: 012508320374050970080000000000000000000000000000
Shop #: WSC 24593 005 1048576
ASAM Dataset: EV_ECM20TDI01105L906022BE 006010
ROD: EV_ECM20TDI01105L906022BE_006_VW38.rod
VCID: 6B87117DD302CC321E0-803F
VINID: 91D49A6877A821DA400C724618346704B7
Radiator shutter:
Subsystem 1 - Part No SW: 95B 965 501 AA HW: 95B 965 501 AA
Component: V544KJS1 H13 0110
Serial number: 20200813060404051439
Part No SW: 0GC 906 555 N HW: 0GC 300 047 A
Component: GSG DQ381 H06 3563
CVN: B1C30DA9
ASAM Dataset: EV_TCMDQ381062 001001
ROD: EV_TCMDQ381062_VW38.rod
VCID: 46D180C9A820D15AA1E-8013
Subsystem 1 - Part No SW: 5WA 713 033 CD HW: 610 5
Component: ZSB_SB_AUTO H08 1035
Serial number: 20241127000095043011
Component: ZSB_SB_mono H02 0024
Serial number: 20 219 0360 L 01
Subsystem 3 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810500002138820
Address 03: ABS Brakes (J104) Labels: 5WA-614-517-V1.clb
Part No SW: 5WA 614 517 BE HW: 5WA 614 517 N
Component: ESC H13 0127
Serial number: 62290000002138 Dataset Number: V03935337CG 0001 CVN: 9296C9CB
Coding: 34072CA422234473528050060AC9A1856DB658F05AC8670801BCA231018FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013051
ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
VCID: 0C4572E1F6CC6B0AB7A-8059 SFD [x]
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 C HW: 5WA 959 436 C
Component: Kessy IOBOX 070 0706
Serial number: --------------- Dataset Number: V03935340AA 0001
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w_003.rod
VCID: 54F5AA816E7C73CA2FA-8001
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 5WA 907 727 P HW: 5WA 907 727 P
Component: Climatronic H02 0341
Coding: 201010210211120010100010101011110000112100200000000000000000
ASAM Dataset: EV_ACClimaBHBVW38X 005067
ROD: EV_ACClimaBHBVW38X_SK38.rod
VCID: 5DE34FA51DB6B282904-8009
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H01 0002
Serial number: 00000000000000215255
Subsystem 2 - Part No SW: 5E3 907 049 HW: 5E3 907 049
Component: E265KlimaHeck H02 0201
Serial number: 06051501850797
Interior temperature sensor:
Subsystem 3 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001140820080437505
Address 09: Cent. Elect. (J519) Labels: 5WA-937-08X-V1.clb
Part No SW: 5WA 937 086 E HW: 5WA 937 086 H
Component: BCM 37W BOSCH 016 0159
Serial number: BXJ53F270820940 Dataset Number: V03935351MU 0001
ASAM Dataset: EV_BCM37w 006001
ROD: EV_BCM37w_006_VW41.rod
VCID: 53F7A99D6B7274F2360-8007 SFD [x]
Subsystem 1 - Part No SW: 5E4 955 119 HW: 5E4 955 119 Labels: 5QX-955-119-V1.CLB
Component: J400FRWISCH 067 0084
Serial number: 907453F0302021104724
Serial number: 25201374X81A955555A0
Subsystem 3 - Part No SW: 5E4 941 501 A HW: 5E4 941 501
Component: E1-LTM H30 0550
Serial number: 00000000000000000219
Subsystem 4 - Part No SW: 5E3 925 200 F HW: 5E3 925 200 F
Component: DiETa H04 0002
Serial number: 01557THU000LO
Subsystem 5 - Part No SW: 5H0 959 561 P HW: 5H0 959 561 P
Component: DACHKONSOLE 006 0006
Serial number: 92661TGS00652-------
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 507 GF HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000005082020240246
Left taillight 1:
Subsystem 7 - Part No SW: 5E3 945 207 A HW: 5E3 945 207 A
Component: SHL_li1 005 1214
Serial number: ABMRO108082000060855
Left taillight 2:
Subsystem 8 - Part No SW: 5E7 945 307 A HW: 5E7 945 307 A
Component: SHL_li2 005 1214
Serial number: ABMRO113082000040974
Right taillight 1:
Subsystem 9 - Part No SW: 5E3 945 208 A HW: 5E3 945 208 A
Component: SHL_re1 005 1214
Serial number: ABMRO102032000041297
Right taillight 2:
Subsystem 10 - Part No SW: 5E7 945 308 A HW: 5E7 945 308 A
Component: SHL_re2 005 1214
Serial number: ABMRO119082000040485
15401728 - Secure Onboard Communication
U1513 00 [00101111] - Key Not Available
Mileage: 137213 km
Date: 2026.07.10
Time: 21:44:58
Terminal 15 status: OFF
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 12.4 V
Outside temperature: 20.0 ∞C
Light switch position: automatic
15402752 - VKMS
B18B0 F3 [00101111] - Invalid Key Request During Use
[VKMS - Ung¸ltige Schl¸sselanforderung durch Anwendung erkannt]
Mileage: 137213 km
Date: 2026.07.10
Time: 21:44:58
Engine run: OFF
Voltage: 12.5 V
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 294 A HW: 5WA 919 294
Component: PDC 08 Kanal H04 0026
Serial number: 000023082094630 Dataset Number: V03935330FG 0001
Coding: 0040014211
ASAM Dataset: EV_EPHBO18VW3800000 002028
ROD: EV_EPHBO18VW3800000_AU38.rod
VCID: 50FDA6915A640FEA0B2-8005
Address 13: Auto Dist. Reg (J428) Labels:| 5WA-907-572.clb
Part No SW: 5WA 907 572 A HW: 5WA 907 572
Component: ACC Bosch MQB H10 0246
Dataset Number: V03935318G 0001
Coding: 0D8308FF0077404512474000000040054E4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
ROD: EV_FRONTRADARBOSCHVW380_003_VW38.rod
VCID: 4CC5B2E1B64C2B0A77A-8019
Address 15: Airbags (J234) Labels: 1EA-959-655.clb
Part No SW: 1EA 959 655 DC HW: 1EA 959 655 T
Component: VW40Airbag 009 0169
Serial number: U244YuE1045 Dataset Number: V03935347PP 0001
Coding: 98CC000000C0C000000000000000000050540000205400004000F68000120065
ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
ROD: EV_AirbaVW40ALVVW38X_VW41.rod
VCID: 055347C5D5A61A42E84-8051 SFD [x]
Subsystem 1 - Part No SW: ----------- HW: 440 002 307 20
Component: SideSensor_Df 00A 0887
Serial number: 357CJ000000F338DA84O
Subsystem 2 - Part No SW: ----------- HW: 440 002 307 20
Component: SideSensor_Pf 00A 0887
Serial number: 358CJ00000010780684
Subsystem 3 - Part No SW: ----------- HW: 440 002 107 20
Component: SideSensor_Dr 00A 0149
Serial number: 351CJ2A636FBF616200.
Subsystem 4 - Part No SW: ----------- HW: 440 000 607 20
Component: SideSensor_Pr 00A 0149
Serial number: 352CJ226301953536000
Subsystem 5 - Part No SW: ----------- HW: 440 000 806 20
Component: FrontSensor_D 00A 014A
Serial number: 355CJ0E630197450B00I
1075977 - Databus
U1123 00 [00101110] - Received Error Message
[NWD: 0x102 ESC_50 error value ESP_v_ref]
Mileage: 137192 km
Date: 2026.07.10
Time: 20:46:16
9980928 - Release / Enable Active
B184C 00 [00100000] - -
[ECU unlocked]
16718080 - Internal Control Module Memory Check Sum Error
B2000 00 [10101000] - -
[Electronic Control Unit Malfunction]
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 5E3 920 770 A HW: 5E3 920 770 A
Component: KOMBI 202 3440
Coding: 04A40140638C00080184620B2000080800301400
ASAM Dataset: EV_DashBoardVDDMQB37W 003032
ROD: EV_DashBoardVDDMQB37W_003_SK38.rod
VCID: 270F2D4D0F6A2852BA8-8073 SFD [x]
Part No SW: 5WA 907 530 J HW: 5WA 907 530 C
Component: GW2020 High 752 7084
Revision: -------- Serial number: 150160900355022 Dataset Number: V03935351NE 0001
Coding: 0000838D0300000000000000010301727301601902000100030100000001010100000000000000000000000000000000
GVL: 3D0000000208C0CC80008002C800104004004000004000000000000000000044
ASAM Dataset: EV_GatewMQB2020 004008
ROD: EV_GatewMQB2020_004_SK38.rod
VCID: 4FFFA5ED475A1012128-801B SFD [x]
Generator:
Component: 5-00-15-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 6500935205
Subsystem 3 - Part No SW: 5E3 919 719 N HW: 5E3 919 719 N
Component: E221__MFL-PR6 H50 0500
Serial number: PR6-0440061315210344
Subsystem 4 - Part No SW: 5E3 959 542 H HW: 5E3 959 542 H
Component: KLR 082 0020
Serial number: 3133273AB21337046803
2494569 - Ethernet Module for Back-Up Cam
U1643 00 [00101111] - No Communication
[Rearview_camera_system_control_module_no_communication_vlan]
Mileage: 137209 km
Date: 2026.07.10
Time: 21:33:56
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 G HW: 3Q0 909 059 A
Component: EBKV H06 0111
Serial number: BPA085130820013 Dataset Number: V03935321VT 0001
Coding: 1002C100230000CE39E79C73000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 013023
ROD: EV_BrakeBoostG2BoschVW37W_013_VW38.rod
VCID: 54F5AA816E7C73CA2FA-8001 SFD [x]
107024 - Transmission Control Module
U14E4 00 [00100000] - Received Malfunction Value
[Scl_Getriebe_11_GE_Fahrstufe_Error]
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H09 0040
Serial number: 20000186823013
Coding: 8800000000000000
Shop #: WSC 31000 790 00256
ROD: EV_ELVMarqMQBA0_VW38.rod
VCID: 3239CC1934A85DFA1D6-8067
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 E HW: 2Q0 907 686 D
Component: HRE_Master H25 0284
Serial number: 00000554258310 Dataset Number: V03935340DT 0001
Coding: 6A9545D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
ROD: EV_HREntryHellaGen3Mstr_VW38.rod
VCID: 3C25E221E6EC9B8AC7A-8069
Subsystem 1 - Part No SW: 2Q0 907 685 E HW: 2Q0 907 685 D
Component: HRE_Slave H25 0284
Serial number: 00000554412112
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q4 959 593 H HW: 5Q4 959 593 H
Component: TSG FS 010 0691
Serial number: 0000419284834 Dataset Number: V03935319UN 0001
Coding: 001C8120D000020000001100
Shop #: WSC 31000 790 00276
VCID: 4AC9B4F9BC38353A456-801F
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 5WA 907 146 J HW: 5WA 907 146 A
Component: BASGEN1MQB37 201 2032
Serial number: 00265708 Dataset Number: V03935327VR 0001
Coding: 0000000000000000000002010100010000000101000101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 006037
ROD: EV_SteerAssisBASGEN1MQB37_006.rod
VCID: 52F9AC9954687DFA3D6-8007
Part No SW: 5Q4 959 592 H HW: 5Q4 959 592 H
Component: TSG BFS 010 0691
Serial number: 0000418983032 Dataset Number: V03935319UR 0001
VCID: 49CB8BF5B93E3E224CC-801D
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 5E3 035 816 F HW: 5E3 035 816
Component: MU-O-ND-EU H56 1941
Serial number: WG8LGM290820000 Dataset Number: V03935421CC 0001
Coding: 33820000000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_001_SK38.rod
VCID: 2A09D4791C78153AA56-807F SFD [x]
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H2 907 383 HW: 5H2 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005543 Dataset Number: V03935306DD 0001
Coding: 0100000202001200
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 6D831F65ED16C202004-8039
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 5WA 980 556 A HW: 5WA 980 556 A
Component: RV eCompact H20 0193
Serial number: FCL-K2016.04.20 Dataset Number: V03935320DS 0001
Coding: 03033300843000
ASAM Dataset: EV_CamSysRVCCompaFicos 009020
ROD: EV_CamSysRVCCompaFicos_009_VW38.rod
Address 75: Telematics (J949) Labels:* Redir Fail!
Part No SW: 5WA 035 284 A HW: 5WA 035 284 A
Component: OCU3HMQB37W H12 0067
Serial number: 0000000007VITD5 Dataset Number: V03935332LA 0001
Coding: 033820109069AC819005460061012607
ASAM Dataset: EV_OCU3HMQB37W 001039
ROD: EV_OCU3HMQB37W_001_SK38.rod
VCID: 44D59AC19E1CE34ABFA-8011 SFD [x]
12866049 - Databus
[Airbag: Error value received]
Mileage: 137209 km
Date: 2026.07.10
Time: 21:33:56
Voltage terminal 30: 12.0 V
13631563 - Internal Control Module Memory Check Sum Error
B2000 4B [00001001] - Over Temperature
[Control unit defectiveMain processor]
Voltage terminal 30: 12.4 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 5WA 980 653 A HW: 5WA 980 653
Component: MQB MFK 3.0 H05 3129
Serial number: E26735111202430 Dataset Number: V03935401NE 0001
Coding: 00020888217C4040109E40001020002001418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_SK38.rod
VCID: 4DC3BFE54D562202604-8019
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V2.clb
Part No SW: 5Q4 959 595 H HW: 5Q4 959 595 H
Component: TSG HFS 007 0691
Serial number: 0000419250458 Dataset Number: V03935319VM 0001
Coding: 000881200000020000001100
ROD: EV_DCU2RearDriveMAXHCONT_AU38.rod
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V2.clb
Component: TSG HBFS 007 0691
Serial number: 0000418758805 Dataset Number: V03935319VG 0001
ROD: EV_DCU2RearPasseMAXHCONT_AU38.rod
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935303WV 0001
Coding: 408040638202
ROD: EV_SunRoofCONTIAU736_SK38.rod
VCID: 75B3370585460AC2F84-8021
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 B HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w_002_VW38.rod
VCID: 47CF8DCDAF2AC8525A8-8013
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 01:54, VBatt start/end: 12.5V/12.5V)-----------
------------------------------9 Faults Found-------------------------------
