Good day,
I am having an issue with a 2017 Audi Q3, the coolant was bubbling out at the expansion tank. I replaced the thermostat and water pump assembly but having the same issue with the new unit. The system was bled and the issue is the same. The top radiator hose is hot while the lower hose is very cold. Can anyone identify what could be the issue?
Please refer to the scan and log below.
Sunday,05,July,2026,16:12:20:01244
VCDS Version: 26.3.0.0 (x64) HEX-NET CB: 0.4713.4
VIN: WAUZZZ8U2HR000532 License Plate: DAVID
Mileage: 149340km-92795mi Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 5F 62 6C
72
VIN: WAUZZZ8U2HR000532 Mileage: 149340km-92795miles
15-Airbags -- Status: Malfunction 1010
55-Headlight Range -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
Address 01: Engine (J623-CULC) Labels:. 06K-907-425-V1.clb
Part No SW: 8U0 906 259 HW: 06K 907 425 C
Component: 2.0l R4 TFSI H13 0005
Revision: --H13--- CVN: B479CF69
Coding: 2A251032240600082000
Shop #: WSC 00049 770 00119
ASAM Dataset: EV_ECM20TFS0208U0906259 002007
ROD: EV_ECM20TFS020_AU21.rod
VCID: 7CB4D91EF7EFBB7F9F-8028
VINID: 9D196AAAA225098880000143087EA7F526
7 Faults Found:
15048 - Coolant Fan Control Circuit 1
P0480 00 [00100100] - Electrical Malfunction
Mileage: 149345 km
Date: 2025.05.17
Time: 00:04:14
Engine speed: 0.00 /min
Coolant temperature: 30 °C
Intake air temperature: 36 °C
Voltage terminal 30: 13.554 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 98 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 17.578125 %
FUP_H_SAE: 6210.0 kPa
15005 - Valve for Fuel Metering (N290)
P0089 00 [00100000] - Inadequate Performance
Mileage: 149345 km
Date: 2025.05.15
Time: 00:39:08
Engine speed: 699.00 /min
Normed load value: 11.8 %
Vehicle speed: 1 km/h
Coolant temperature: 82 °C
Intake air temperature: 37 °C
Voltage terminal 30: 13.105 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 14 s
MAP_MES_SAE: 38 kPa
FUP_EFP_MES: 7113.66 hPa
FUP_H_SAE: 16550.0 kPa
15077 - Idle Control System RPM
P0507 00 [00100000] - Higher than Expected.
Mileage: 149344 km
Date: 2025.05.04
Time: 02:27:15
Engine speed: 1016.00 /min
Normed load value: 9.0 %
Coolant temperature: 84 °C
Intake air temperature: 38 °C
Voltage terminal 30: 12.851 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 360 s
MAP_MES_SAE: 32 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.982 V
FAC_TPS_1_SAE: 9.765625 %
FUP_H_SAE: 12940.0 kPa
15027 - Fuel Level too Low
P1250 00 [00100000] - -
19846 - No Communications with Airbag Control Module
U0151 00 [00100100] - -
Mileage: 149345 km
Date: 2025.05.17
Time: 00:00:12
Intake air temperature: 35 °C
Voltage terminal 30: 9.609 V
ECU_STATE: ENG_STOP
Engine oil temperature: 30.0 °C
Time since engine start: 0.0 s
T_ES: 2880 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
Cruise control switch actuation-Control component verified: No
STATE_ERR_ABC_PRED: 5
22063 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [00101111] - -
Fault Frequency: 15
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:06
Intake air temperature: 34 °C
Voltage terminal 30: 11.660 V
ECU_STATE: ENG_STOP
Engine oil temperature: 28.0 °C
T_ES: 2880 min
STATE_ERR_ABC_PRED: 0
23128 - Implausible Data Received from ABS Control Module
U0415 00 [00101111] - -
Mileage: 149345 km
Date: 2025.05.15
Time: 00:00:11
Coolant temperature: 28 °C
Intake air temperature: 29 °C
Voltage terminal 30: 14.589 V
T_AST_SAE: 0 s
MAP_MES_SAE: 98 kPa
FUP_H_SAE: 850.0 kPa
Readiness: 0010 0000
Part No SW: 0BH 300 012 R HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5209
Revision: 00H11V01 CVN: B5FEDF1D
ROD: EV_TCMDQ500021.rod
VCID: 32283726652BBD0F05-8066
10810 - Function Restricted due to Insufficient Voltage
U1400 00 [00101110] - -
Mileage: 149345 km
Date: 2025.05.17
Time: 00:01:21
Engine speed: 1147.00 /min
Coolant temperature: 29 °C
Clutch: primary stat: Neutral
selected gear: GANG_R
Position: P
Engine torque: 0 Nm
Control Module temperature: 30 °C
Accelerator pedal position: 15.2 %
DTC memory status: 172
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 5N0 614 109 CF HW: 5N0 614 109 CF
Component: ESC-EBC460iV1 H10 0013
Serial number: A015NVP
Coding: 21F124A1C920C36C207C840324C593C304245300508B4883
Shop #: WSC 00049 770 00152
ASAM Dataset: EV_Brake1ESCEPBTRW 006353
ROD: EV_Brake1ESCEPBTRW_006.rod
VCID: 71AAF82AA0ADC6173C-8024
10 Faults Found:
0551 - Front Left ABS Wheel Speed Sensor
C101A F2 [10001001] - Bypass Current
Reset counter: 152
Mileage: 149345 km
Additional_Codes: 00 00 00 11 DC 7F 00 0F 08
DTC: 00 02 27
Additional2: 00 00 04 00 05 22 4D 01 4D 01
0037 - Front Left Wheel Speed Sensor
C101A 01 [00001000] - Electrical Failure
Reset counter: 194
Mileage: 149345 km
Additional_Codes: 00 00 00 0C 14 FF 00 0F 0A
DTC: 00 00 25
Additional2: 03 00 03 00 6F 22 69 00 69 00
0763 - Tire Pressure Warning
C102D 00 [10001001] - -
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:04
Additional_Codes: 00 00 00 0B C9 7F 00 0B 0A
DTC: 00 02 FB
Additional2: 03 00 01 02 6F 22 3F 00 3F 00
0768 - Display for Tire Pressure Monitoring
C1146 02 [10001001] - Signal Failure
Reset counter: 152
Mileage: 149345 km
Date: 2025.05.15
Time: 00:18:02
Additional_Codes: 00 00 00 0D CF 7F 00 4B 0A
DTC: 00 03 00
Additional2: 04 03 01 02 6F 22 5E 00 5E 00
0287 - Databus
[MSG_AIRBAG_1_TIMEOUT]
Reset counter: 194
Mileage: 149345 km
Additional_Codes: 00 00 00 09 D2 7F 00 0F 08
DTC: 00 01 1F
Additional2: 03 00 00 02 05 22 90 01 90 01
0627 - Databus
[MSG_AIRBAG_03_TIMEOUT]
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
Time: 00:04:27
Additional_Codes: 00 00 00 0D 75 7F 00 4B 08
DTC: 00 02 73
Additional2: 08 04 01 02 6F 22 8A 01 8A 01
0799 - Databus
[MSG_LH3_LM_INVALID]
Reset counter: 194
Mileage: 149344 km
Date: 2025.05.04
Time: 02:52:44
Additional_Codes: 00 00 00 0A E8 7F 40 0F 0A
DTC: 00 03 1F
Additional2: 03 00 00 02 6F 22 90 01 90 01
0516 - Switch for Electric Parking Brake
C100C 01 [10001001] - Electrical Failure
Reset counter: 154
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:04
DTC: 00 02 04
0849 - Lamp in Switch for Electronic Parking Brake
C1145 13 [10001001] - Open Circuit
Reset counter: 154
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:04
Additional_Codes: 00 00 00 0B D0 7F 00 0B 0A
DTC: 00 03 51
0887 - Multiple collision brake
B13BC F2 [00001000] - No function
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
Time: 00:04:39
Additional_Codes: 00 00 00 0D 05 7F 00 4B 08
DTC: 00 03 77
Additional2: 03 00 01 02 6F 22 84 01 84 01
Address 08: Auto HVAC Labels: None
Part No SW: 8U0 820 047 D HW: 8U0 820 047 D
Component: J255 Klima Man 0020
Revision: 00H02001 Serial number: 00000000000000
VCID: 36200B364143A12F29-8062
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 AB HW: 8X0 907 063 AB
Component: BCM PQ35 M 113 0817
Revision: AC113817
Coding: 06000A2CA805F3C020184BC00144094C43FF26AA206F9123E40006840041
Shop #: WSC 00049 770 00010
VCID: 7CB4D91EFFEFBB7F9F-8028
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 160325 H38 0090
Serial number: 160406203348
Coding: 0047F7
Subsystem 2 - Part No SW: 8U0 955 559 D HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0004
Serial number: 50047817
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177 A
Component: Sensor, DWA 0 005 0002
13 Faults Found:
Fault Status: 01100001
Reset counter: 155
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:01
Voltage: 11.90 V
Term 50 On
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:01
Voltage: 11.90 V
Term 50 On
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:02
Voltage: 11.90 V
Term 50 On
Fault Frequency: 46
Reset counter: 194
Mileage: 149344 km
Date: 2025.05.04
Time: 02:21:12
Voltage: 7.95 V
Term 50 On
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
Fault Status: 01101100
Reset counter: 154
Mileage: 149344 km
Date: 2025.05.04
Time: 02:29:00
Voltage: 14.10 V
Term 50 On
Fault Status: 00101010
Reset counter: 194
Mileage: 149344 km
Date: 2025.05.04
Time: 02:37:59
Voltage: 13.00 V
Term 50 On
Reset counter: 194
Mileage: 149344 km
Date: 2025.05.04
Time: 02:37:59
Voltage: 13.00 V
Term 50 On
00897 - Windshield Washer Pump (V5)
Reset counter: 153
Mileage: 149344 km
Date: 2025.05.04
Time: 02:50:12
Voltage: 11.10 V
Term 50 On
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.05
Time: 08:12:30
Term 15 Off
Voltage: 7.90 V
Term 50 Off
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.15
Time: 00:00:10
Term 15 Off
Voltage: 5.00 V
Term 50 Off
Fault Status: 00100001
Fault Frequency: 15
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.15
Term 15 Off
Voltage: 7.10 V
Term 50 Off
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
Term 15 Off
Voltage: 17.75 V
Term 50 Off
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
Time: 00:04:15
Voltage: 12.90 V
Term 50 On
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 AD HW: 4H0 919 475 AG
Component: PARKHILFE 8K H01 0070
Revision: 11001001 Serial number: 61061609803064
Coding: 28C108
ASAM Dataset: EV_EPHVA18AU21X0000 003008
ROD: EV_EPHVA18AU21X0000_003.rod
VCID: 085CB5CEB337E7DF8B-805C
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [00001000] - Open Circuit
Reset counter: 154
Mileage: 149345 km
Date: 2025.05.17
Time: 00:05:11
13893888 - Function Restricted due to Excessive Voltage
U1401 00 [00001000] - -
[Funktionseinschränkung durch Überspannung - oberer Grenzwert überschritten]
Reset counter: 192
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 D HW: 8U0 959 655 D
Component: AirbagVW-AU10 H10 0910
Serial number: 003S0R0EJJUB Dataset Number: 8U0909602C 0007
Coding: 30513232333030303030554A305238553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001010
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 48DC75CEF3B727DF4B-801C
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME4F16463DZZZ5
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME4021433DZZZI
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME3204463DZZZO
Serial number: 3526KSME35223D3DZZZY
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME1540733CZZZ.
9440027 - Driver's side; side-airbag igniter
B100B 1B [10001001] - Resistance Too High
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:04
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 AE HW: 5K0 953 569 BD
Component: LENKS.MODUL 018 0230
Revision: FF010018 Serial number: 20160407300706
Coding: 1884004000
ROD: EV_SMLSNGVOLWSR8C_VW32.rod
VCID: 7F4E2E12E6F9A067BA-802A
Subsystem 1 - Part No SW: 8U0 951 528 E HW: 8U0 951 528 E
Component: E221 - MFL H09 0010
Serial number: 05 04 2016 B0012998
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
Fault Frequency: 8
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.04
Time: 02:26:59
114433 - Function Restricted due to Excessive Voltage
Reset counter: 194
136194 - Supply voltage
U1011 00 [00001000] - Voltage too Low
Reset counter: 192
Mileage: 149345 km
Date: 2025.05.04
Time: 02:49:03
227395 - Windshield Wiper Switch
B1145 07 [00001001] - Mechanical Failure
Fault Frequency: 8
Reset counter: 155
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:03
Address 17: Instruments (J285) Labels:| 8X0-920-KOM-V1.clb-SRI1
Part No SW: 8U0 920 930 F HW: 8U0 920 930 F
Component: KOMBI_MEDIUM H04 0480
Coding: 12CF01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
VCID: 3A381F06BD5B454FCD-806E
9453074 - Fuel Level Sensor 1
B103E 1B [00001001] - Resistance Too High
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:04
9453330 - Outside temperature sensor
B103F 1B [00001000] - Resistance Too High
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Steuergerät für Airbag: keine Kommunikation]
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
Time: 00:04:19
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Steuergerät für Leuchtweitenregelung: keine Kommunikation]
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:04
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.15
Time: 00:00:01
13635840 - Supply voltage
[Supply voltage too low]
Reset counter: 192
Mileage: 149345 km
Date: 2025.05.04
Time: 02:37:32
Address 19: CAN Gateway (J533) Labels:. 8X0-907-468.clb
Part No SW: 8U0 907 468 AQ HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0090
Revision: 1P140041 Serial number: 4141P163300751
Coding: F3460A59000108610353
Shop #: WSC 45233 002 1048576
VCID: 116A98AAC86DA6175C-8044
Reset counter: 152
Mileage: 149345 km
Date: 2025.05.04
Time: 00:00:43
Bin. Bits: 10000
Voltage: 11.30 V
Count: 7
Bin. Bits: 10000
Time: 0.90 s
Reset counter: 152
Mileage: 149345 km
Date: 2025.05.04
Time: 00:02:02
Bin. Bits: 11111
Voltage: 10.60 V
Count: 6
Bin. Bits: 10000
Time: 0.90 s
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 154
Mileage: 149345 km
Date: 2025.05.04
Time: 00:03:00
Bin. Bits: 11111
Voltage: 13.10 V
Count: 6
Bin. Bits: 10000
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.04
Time: 02:51:42
Bin. Bits: 10000
Voltage: 8.50 V
Count: 11
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
Time: 00:00:58
Bin. Bits: 00000
Voltage: 15.70 V
Count: 11
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
Time: 00:04:13
Bin. Bits: 10111
Voltage: 13.90 V
Count: 6
Bin. Bits: 10000
Time: 0.40 s
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7540
Serial number: HA1-00018.03.16 Dataset Number: v1260x015G0 0000
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
VCID: 52E857A605EB9D0F25-8006
16656 - Databus
[Bremsensteuergerät - no speed signal]
Fault Frequency: 22
Reset counter: 154
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:03
Component: IMMO H04 0480
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H11 0415
Coding: 011E16201C01000000
Shop #: WSC 00049 770 00162
VCID: 52E857A60DEB9D0F25-8006
Reset counter: 154
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:01
02123 - Door Warning Light / Entry Light
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:01
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.11
Time: 06:08:28
Reset counter: 194
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
Time: 00:00:09
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 297 3501
Revision: 00H22000
VCID: 40CC6DEE13871F9F83-8014
Fault Status: 11101101
Reset counter: 152
Mileage: 149345 km
Date: 2025.05.15
Time: 00:00:14
Voltage: 15.13 V
DD
Temperature: 27.0°C
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 7.6 V
PD
Temperature: 31.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H11 0415
Coding: 011E13201E00000000
Shop #: WSC 00049 770 00151
VCID: 51EA58AA08EDE6171C-8004
Reset counter: 154
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:01
Fault Status: 00101100
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:01
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.11
Time: 06:08:28
Reset counter: 194
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.15
Time: 12:55:54
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.17
Time: 00:00:09
Address 55: Headlight Range
Part No SW: 8U1 035 182 A HW: 8U1 035 182 A
Component: RMC Cnct Plus H61 0139
Coding: 01010600024057470823020102010000000000
VCID: 322837266D2BBD0F05-8066
Subsystem 1 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
Component: DUBasic AU316 H43 0018
Serial number: AUZ8ZDGCS01PA4C
Fault Frequency: 11
Reset counter: 154
Mileage: 149345 km
Date: 2025.05.17
Time: 00:04:28
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
02612 - Audio Wire Adapter Set
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:01
01609 - Cooling Fan in Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 153
Mileage: 149344 km
Date: 2025.05.04
Time: 02:39:38
ON Time: 6514 h
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.04
Time: 02:29:47
Voltage: 8.90 V
Reset counter: 194
Mileage: 149345 km
Date: 2025.05.04
Time: 02:50:18
Address 62: Door, Rear Left
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 8U0 907 441 HW: 8U0 907 441
Component: SG Rueckfahrkamera 0031
Revision: --H11--- Serial number: 525 PA8JB2H4YH
Coding: 1080015
Shop #: WSC 02391 785 00013
VCID: 76A0CB3601C3E12FE9-8022
02203 - Audio / Video Input 1
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:02
Reverse OFF
Count: 3
03008 - Supply Voltage for Back-Up Camera
Fault Status: 01100010
Reset counter: 152
Mileage: 149344 km
Date: 2025.05.04
Time: 02:15:02
Reverse OFF
Count: 3
Reset counter: 192
Mileage: 149345 km
Date: 2025.05.04
Time: 02:49:06
Term 15 Off
Reverse OFF
Count: 3
Reset counter: 194
Term 15 Off
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels:. 8X0-959-795.clb
Part No SW: 8X0 959 795 C HW: 8X0 909 597 95
VCID: 4FEE5ED21ED9F0E70A-801A
No Faults Found
End----------(Elapsed Time: 02:42, VBatt start/end: 13.0V/13.0V)-----------
------------------------------75 Faults Found------------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 01: Engine (8U0 906 259 )
16:32:27
IDE00025 Coolant temperature 104 °C
IDE00192 Coolant temperature at radiator outlet: actual value 44.9 °C
IDE00193 Coolant temperature at engine outlet: specified value 104.2 °C
IDE00194 Coolant temperature at radiator output: specified value -48.0 °C
IDE00195 Coolant temperature difference between engine and radiator 59.2 °C
IDE00556 Outside temperature 34 °C
