2018 S5 SRI Oil change interval
Turboaudi80
C?ID=29794
Hi Folks, New to the forum but not to Vag-Com. I would like to reset my oil change interval to 5K miles but I don't see how to change it in the SRI tool or in the instrument cluster. Is it somehow fixed in this version of the instrument cluster or am I just a dummy and can't find the right way to change it.
Any help would be appreciated.
-Eli
In addition to posting an Auto-Scan, please go to [SRI Reset], wait a few moments for VCDS to read the SRI channels, then clock [Add to logfile] and post the resulting log here.
Turboaudi80
C?ID=29794
Saturday,11,July,2026,07:58:45:47381
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.5
VIN: WAUY4GF56JN002050   License Plate:
Chassis Type: F5-AU49 (8W8)
Scan: 01 02 03 06 08 09 15 16 17 19 26 29 32 36 39 3C 42 44 46 47
          52 5F 6C 74 81 A5 A6 A9 CF D6 D7
VIN: WAUY4GF56JN002050   Mileage: 91239km-56693miles
26-Auto Roof -- Status: Malfunction 0010
A6-Microphone -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CWGD)       Labels:. 06M-907-309-V1.clb
   Part No SW: 8W0 907 559 H    HW: 06M 907 309 D
   Component: V6 3.0l TFSI  H21 0009
   Revision: B2H21000    CVN: 2619C16C
   Coding: 222A00322326010E34280000000000000000000000000000
   ASAM Dataset: EV_ECM30TFS0118W0907559H 001010
   ROD: EV_ECM30TFS0118W0907559H.rod
   VCID: 4ACABE2EBC34980A517-801E
   VINID: 9D196911758519A7800020050097873B0D
17158 - Databus
          U1123 00 [00100000] - Received Error Message
31403 - EVAP System High Pressure Purge Line Faulty
          P04F0 00 [01100000] - -
   Part No SW: 8W0 927 158 C    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H05 1003
   Revision: --H05---    CVN: DFFF19B7
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 42DA960E8404404A997-8016
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-V1.clb
   Part No SW: 8W0 907 379 G    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0719
   Dataset Number: 8W5909504B  0002 CVN: B085950A
   Coding: 1CAA149A30A20A98119E4896407D5292E6259A38280C508812024A4967A459
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESP9BOSCHCMP 001001
   ROD: EV_ESP9BOSCHCMP_001.rod
   VCID: 49C88122B932931258D-801C
12661248 - Control Module for Suspension
          U012A 00 [00100000] - No Communication
          [ComScl:_Signal_Group_SG_FDR_02-_Timeout_error]
420352 - TPMS Warning; Front Left Tire
          C1054 00 [00100000] - Pressure too Low
416768 - TPMS Warning; Front Right Tire
          C1056 00 [00100000] - Pressure too Low
420096 - TPMS Warning; Rear Left Tire
          C1058 00 [00100000] - Pressure too Low
417024 - TPMS Warning; Rear Right Tire
          C105A 00 [00100000] - Pressure too Low
200960 - Databus
          [Signal_LWR_Hoehenwert_VL_error_(255)]
   Part No SW: 4M0 959 760 A    HW: 4M0 959 760 A
   Component: MEM-BFS       008 0031
   Serial number: 00000248167130 Dataset Number: 8W5909866B  0009
   Coding: 00163004000CB2010003010141010000000000000000000000000000802002
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 3632FADED8CCECEA25F-8062
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0090
   Coding: 56080D0C5544000D10020100880000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 372CF7DADFC615E23E9-8062
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001418057
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 05D90D9880PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
65544 - Button(s) or Switch(es) in Operating Device
          B1312 07 [00001000] - Mechanical Failure
                    Reset counter: 42
                    Mileage: 89322 km
                    Date: 2026.05.10
                    Time: 10:13:27
                    Voltage terminal 30: 14.76 V
                    Outside temperature: 14.00 °C
                    Pressing a button-Button for instrument panel vents: Not operated
                    Pressing a button-Defrost: Not operated
                    Pressing a button-Recirculating air: Not operated
                    Pressing a button-Rear window defogger: Not operated
                    Pressing a button-Left pressure knob: Not operated
                    Pressing a button-Right pressure knob: Not operated
                    Pressing a button-Left air distribution: Not operated
                    Pressing a button-Right air distribution: Not operated
                    Pressing a button-AUTO left: Not operated
                    Pressing a button-AUTO right: Not operated
                    Pressing a button-Air quantity left: Not operated
                    Pressing a button-Air quantity right: Not operated
                    Pressing a button-AC: Not operated
                    Pressing a button-Left heated seat: Not operated
                    Pressing a button-Left seat ventilation: Not operated
                    Pressing a button-Right heated seat: Not operated
                    Pressing a button-Right seat ventilation: Not operated
                    Pressing a button-OFF: Not operated
                    Pressing a button-AUTO: Not operated
                    Pressing a button-Air quantity: Not operated
                    Pressing a button-Footwell air distribution: Not operated
                    Pressing a button-Upper body vent air distribution: Not operated
                    Pressing a button-Air distribution up: Not operated
                    Pressing a button-Left neck heater: Not operated
                    Pressing a button-Right neck heater: Not operated
                    Pressing a button-AC max/eco: Not operated
                    Pressing a button-Input mode: touched
                    Pressing a button-A/C mode: Not operated
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 8W5909514D  0015
   Coding: 07500363E0081CCD050D8F1518AC9CBB110B3D040000020000000000200016010A690162025705
   VCID: 025A560EC484804AD97-8056
   Subsystem 1 - Part No SW: 8W7 955 119     HW: 8W7 955 119   Labels: 1KX-955-119.CLB
   Component: 495 LL 170210  036 0476
   Serial number: 00000001702070302513
   Coding: 5FC7F7
   Serial number: 20348369X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 S    HW: 4M0 941 531 S
   Component: E1 - LDS  H06 0008
   Serial number: 05 07 2016  00715554
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0050
   Serial number: 0000009600335Z3C2N02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 8W7 959 719 A    HW: 8W7 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20170213124832 00543
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE118011723310045
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W7 947 135 Q    HW: 8W7 947 135 Q
   Component: DAMODUL AU495  H06 0110
   Serial number: 17033100010221Q
   Coding: 0C0102
   Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000005194001
   Valve block 1 in front seat driver side:
   Subsystem 9 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J873 MKS_FSv  H03 0033
   Serial number: 7008174235B170915831
   Coding: BF0500
   Valve block 1 in front seat passenger side:
   Subsystem 10 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J872 MKS_BFSv  H03 0033
   Serial number: 7008174235B171018166
   Coding: B30500
66883 - Databus
          [Left LED headlamp power output module: cornering lamp faulty]
                    Reset counter: 38
                    Mileage: 89264 km
                    Date: 2026.05.05
                    Time: 19:34:00
                    average_Voltage_terminals: 15.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 30.00 °C
                    interior_temperature: 31.50 °C
                    Vehicle speed: 0.00 km/h
66885 - Databus
          [Left LED headlamp power output module: low beam faulty]
                    Reset counter: 39
                    Mileage: 89254 km
                    Date: 2026.05.05
                    Time: 17:19:44
                    average_Voltage_terminals: 13.10 V
                    Outside air temperature sensor-Outside air temperature on CAN: 25.00 °C
                    interior_temperature: 26.50 °C
                    Vehicle speed: 45.11 km/h
574728 - Switch Module for Seat Position; Passenger Side
          B1569 F0 [00001000] - Vertical Direction Event
                    Reset counter: 59
                    Mileage: 90286 km
                    Date: 2026.06.06
                    Time: 16:39:15
                    average_Voltage_terminals: 15.10 V
                    Outside air temperature sensor-Outside air temperature on CAN: 28.00 °C
                    interior_temperature: 27.00 °C
                    Vehicle speed: 10.80 km/h
Address 15: Airbags (J234)       Labels:| 8W0-959-655-V1.clb
   Part No SW: 8W0 959 655 J    HW: 8W0 959 655 J
   Component: Airbag10.44   H09 0104
   Serial number: 003US0003R6B Dataset Number: 8W5909602F  0004
   Coding: BFC0F0C000805000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005015
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 50FEAC465A68A2DA1F3-8004
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W7857705B0096R00043
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W7857706B0100R00097
   Coding: 80000D
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J170006ZHGK0
   Subsystem 4 - Part No SW: -----------    HW: 442 061 403 17
   Serial number: 3577Y00A521922F1E1A%
   Subsystem 5 - Part No SW: -----------    HW: 442 061 403 17
   Serial number: 3587Y00A521922F204F
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 403 17
   Serial number: 3557500282A4CDF5A5E$
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 403 17
   Serial number: 3567500282A4CDF7C5B+
   Part No SW: 4M0 907 129 GB    HW: 4M0 907 129 GB
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B23ADE984CACEAE5F-8022
   Part No SW: 8W5 920 890 C    HW: 8W5 920 890 C
   Component: FBenUSA       H17 0313
   Coding: 08EF31CB38A8CF050223E9601800000008000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 43D4930A9B1E4942921-8016
   Part No SW: 8W8 907 468 D    HW: 8W8 907 468 D
   Component: Gateway       H30 0309
   Revision: 5D010003    Serial number: 0385D038417319 Dataset Number: 8W2909515B  0028
   Coding: 030100010000064054070000005900106C90000780000000017D078E10000000
   GVL: 01503C500020000040FC08000802C800010C0000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4DC0B5324D5A8F32745-8018
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20170322134945 20981
   Serial number: 7064073604
131712 - Ride Level Control Module
          U0132 00 [00001000] - No Communications
          [Timeout_Node_0x80_DiagAdress_74_EFP]
                    Reset counter: 67
                    Mileage: 90710 km
                    Date: 2026.06.12
                    Time: 10:34:50
Address 26: Auto Roof (----)       Labels: 8W7-959-255.clb
   Part No SW: 8W7 959 255     HW: 8W7 959 255
   Component: VSG B9        H04 0020
   ASAM Dataset: EV_ElectRoofContrMAQAU495 001006
   ROD: EV_ElectRoofContrMAQAU495.rod
   VCID: 09484122F9B2D31298D-805C
   Rear interior monitoring:
   Subsystem 1 - Part No SW: 8W7 959 121     HW: 8W7 959 121
   Component: Sensor, FRUE  002 0010
   Serial number: 000000000ZY170443KB0
0553 - Motor for Convertible Top Enclosure
          B17BE 13 [00001000] - Open Circuit
                    Mileage: 89761 km
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   Dataset Number: 8W5909519A  0002
   ROD: EV_LCMLeftHELLAAU736_AU37.rod
   VCID: 78AE34E69258DA9AF73-802C
Address 32: Differential Locks (J187)       Labels: 8W0-907-163.clb
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H07 0040
   Revision: 5WK12700    Serial number: 605711413250707
   Coding: 0001
   ASAM Dataset: EV_TVDCQSP22 001007
   ROD: EV_TVDCQSP22.rod
   VCID: 79A831E2A952C39288D-802C
   Component: MEM-FS        008 0031
   Serial number: 00000248166071 Dataset Number: 8W5909856B  0009
   Coding: 001E3B04000CB2010003010141010000000000000000000000000000802002
   Dataset Number: 8W5909520A  0002
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------    Dataset Number: 8W5909535B  0007
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 103
                    Mileage: 80147 km
                    Date: 2025.06.27
                    Time: 14:32:48
                    Control Module temperature: 59 °C
                    Voltage terminal 30: 14.20 V
                    Terminal 15 status: On
                    Voltage terminal 15: Measuring value not available
   Part No SW: 4M0 959 793 F    HW: 4M0 959 793 F
   Component: TSG FS        005 0011
   Serial number: 0000250518481  Dataset Number: 8W5909872B  0019
   Coding: 005F5B525E0810AC000124B2
   ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
   VCID: 41D8990281025B5280D-8014
   Subsystem 1 - Part No SW: 5Q0 959 812 C    HW: 5Q0 959 812 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  002 0005
   Serial number: 00000000000013613826
   Coding: 110000
Address 44: Steering Assist (J500)       Labels:| 8W0-909-144-V1.clb
   Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0409
   Dataset Number: 8W5909852N  0022
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003018
   ROD: EV_EPSZFAU49X_003.rod
17664 - Databus
          [KFC_ESP_22_SNA]
                    Mileage: 80147 km
                    Date: 2025.06.27
                    Time: 14:32:48
                    Expanded ambient data 1-Engine is running: Engine_not_running
                    Expanded ambient data 1-Supply voltage: 0.00 V
                    Expanded ambient data 1-Temperature: -70 °C
                    Expanded ambient data 1-System status: 5
                    Expanded ambient data 1: 00
                    Expanded ambient data 1-driving_direction: 0
                    Expanded ambient data 1-KFA: 0
                    Expanded ambient data 1-KFC: 69
                    Expanded ambient data 1-Ready_To_Drive_Bit: 0
                    Expanded ambient data 1-StartStop Info: 0
                    Expanded ambient data 1-Steering_Angle_Calculated: 0 °
                    Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
                    Expanded ambient data 1-Steering_torque: 0.30 Nm
                    Expanded ambient data 1-Steering_Torque_Sign: 0
                    Expanded ambient data 14-KFA_FAST_RESET: 0
                    Expanded ambient data 14-KFC_FAST_RESET: 0
                    Expanded ambient data 14-Register_seg_flag: 0
                    Expanded ambient data 14-Rom_ram_ecc_adr_1: 0
                    Expanded ambient data 14-Rom_ram_ecc_eipc: 0
                    Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 14.45 V
                    Expanded ambient data 14-Voltage_terminal_30_unfiltered: 14.56 V
   Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   018 0344
   Dataset Number: 8W5909501C  0028
   Coding: 013600004F900080650FA0000E01200233004000810026502F0400000B06003D201E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 005E5C06CA88925ACF3-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1705908MU
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000069025194
   Power rear lid opening control module:
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0904
   Serial number: >1070031
8 Faults Found:
65566 - Databus
          [Driver door control module: TSG_FT_01: no signal/communication]
                    Reset counter: 103
                    Mileage: 80147 km
                    Date: 2025.06.27
                    Time: 14:32:48
                    Supply voltages-Terminal 30 power supply: 14.443 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.375 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.321 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 01 02 18 04 E0
                    general_additional_freeze_frame-Vehicle speed: Not available
65567 - Databus
          [Passenger door control module: TSG_BT_01: no signal/communication]
                    Reset counter: 103
                    Mileage: 80147 km
                    Date: 2025.06.27
                    Time: 14:32:48
65573 - Databus
          [Transmission control module: Getriebe_11: no signal/communication]
                    Reset counter: 103
                    Mileage: 80147 km
                    Date: 2025.06.27
                    Time: 14:32:48
65582 - Databus
          [Airbag control module: Airbag_01: no signal/communication]
                    Reset counter: 103
                    Mileage: 80147 km
                    Date: 2025.06.27
                    Time: 14:32:48
65603 - Databus
          [Engine control module: Motor_12: no signal/no communication]
                    Reset counter: 103
                    Mileage: 80147 km
                    Date: 2025.06.27
                    Time: 14:32:48
65608 - Databus
          [Climatronic control module: Klima_12: no signal/communication]
                    Reset counter: 103
                    Mileage: 80147 km
                    Date: 2025.06.27
                    Time: 14:32:48
131120 - Remote key 1
          B1479 18 [00001000] - Current Too Low
                    Reset counter: 43
                    Mileage: 89570 km
                    Date: 2026.05.12
                    Time: 15:43:26
                    Supply voltages-Terminal 30 power supply: 14.783 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.688 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.633 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 AA 90 02 E0
                    general_additional_freeze_frame-Vehicle speed: 3.37 km/h
                    key_error_freeze_frame: 01001100 11111111 11111111 11111111
65783 - Databus
          [Driver door control module: TSG_FT_02: no signal/communication]
                    Reset counter: 103
                    Mileage: 80147 km
                    Date: 2025.06.27
                    Time: 14:32:48
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAHJA01H70R Dataset Number: 8W5909510A  0003
   Coding: 0194050800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   Part No SW: 4M0 959 792 F    HW: 4M0 959 792 F
   Component: TSG BFS       005 0011
   Serial number: 0000247451143  Dataset Number: 8W5909873B  0019
   Coding: 005F5B525E0810AC000124B0
   ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
   VCID: 40DE9C068A08525A8F3-8014
   Subsystem 1 - Part No SW: 5Q0 959 811 C    HW: 5Q0 959 811 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  002 0005
   Serial number: 00000000000013611944
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880     HW: 8W5 035 880
   Component: MU-P-LNS-US   033 0918
   Serial number: A798D0HB022018 Dataset Number: 8W5909545A  0029
   Coding: 019455020000000053220002041A00102F0012E501700904FE
   VCID: 7CA628F6A660F6BA93B-8028
   Subsystem 1 - Part No SW: V03 959 801 GG    HW: -----------
   Component: NAR 2017  --- 0057
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0160
   Serial number: TPO00128021700820393
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK115031800040130
   Compact disc data bank:
   Component: Gracenote2  --- 3011
                    Reset counter: 229
                    Mileage: 87275 km
                    Date: 2026.01.12
                    Time: 14:10:00
                    Voltage terminal 30: 13.4 V
                    Satellite radio tuner status-Audio Signal: Available
                    Satellite radio tuner status-Reception quality: optimum_signal
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
5731 - Control Head for Multimedia System; Menu Switch Left
          B1887 07 [00001001] - Mechanical Failure
                    Reset counter: 69
                    Mileage: 78372 km
                    Date: 2025.05.31
                    Time: 12:34:39
                    Voltage terminal 30: 14.6 V
   Component: RVC Compact   H12 0240
   Dataset Number: 8W5909460C  0012
   Coding: 0294050102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 3334C3CACBBEF9C2021-8066
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 H    HW: 8W0 907 777 C
   Component: Fahrwerk-SG   H35 1214
   Serial number: 2503170505  Dataset Number: 8W5909576B  0002
   Coding: 1460506158
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 4CC6B836B640863A63B-8018
   Part No SW: 8W1 713 041 K    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170314002300
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 3B24EBEAE3EE3182DA1-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W7 907 217     HW: 8W7 907 217
   Component: BVS           H14 0042
   Dataset Number: 8W5909466B  0012
   Coding: 0404090500000204022023A2AD0000FC00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 55F05D52658AC7F2CC5-8000
1122596 - Databus
          [Timeout_Fahrwerk_01]
                    Mileage: 82399 km
                    Date: 2025.08.04
                    Time: 08:19:19
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 11.70 V
Address A6: Microphone (J886)       Labels:. 420-907-394.clb
   Part No SW: 420 907 394 B    HW: 420 907 394
   Component: BELTMICBOX    H10 0820
   Coding: 0101040202
   ASAM Dataset: EV_BeltMicPARAGAU335 003011
   ROD: EV_BeltMicPARAGAU335.rod
   VCID: 186E1466B2183A9A173-804C
0032 - Microphone 1 for Passenver Side
          B1206 13 [00001001] - Open Circuit
                    Reset counter: 68
                    Mileage: 78368 km
                    Date: 2025.05.28
                    Time: 17:27:07
0064 - Microphone 3 for Passenver Side
          B1208 13 [00001001] - Open Circuit
                    Reset counter: 68
                    Mileage: 78368 km
                    Date: 2025.05.28
                    Time: 17:27:07
0080 - Microphone 1 for Drivers Side
          B1203 13 [00001001] - Open Circuit
                    Reset counter: 68
                    Mileage: 78368 km
                    Date: 2025.05.28
                    Time: 17:27:07
0096 - Microphone 2 for Drivers Side
          B1204 13 [00001001] - Open Circuit
                    Reset counter: 68
                    Mileage: 78368 km
                    Date: 2025.05.28
                    Time: 17:27:07
0112 - Microphone 3 for Drivers Side
          B1205 13 [00001001] - Open Circuit
                    Reset counter: 68
                    Mileage: 78368 km
                    Date: 2025.05.28
                    Time: 17:27:07
   Part No SW: 8W0 907 159 E    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 170322201287
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   Dataset Number: 8W5909471A  0006
   VCID: 176C175ABF0635E21E9-8042
0064 - Supply voltage
          U1012 00 [00001000] - Voltage too High
          [Voltage too high]
                    Reset counter: 38
                    Mileage: 89232 km
                    Date: 2026.05.05
                    Time: 16:21:45
                    Terminal 56b: 3.60 V
                    Terminal_56b_Textual: numerical value: no text
                    Terminal 56a: 0.80 V
                    Terminal_56a_Textual: numerical value: no text
                    Supply via vehicle elec. sys. ctrl. unit: 25.50 V
                    Terminal 15: 25.50 V
                    Daytime driving light supply: 25.50 V
                    Supply for logic: 25.50 V
0080 - Function Restricted due to Excessive Voltage
          U1401 00 [00001000] - -
          [functional limitations due to overvoltage]
                    Reset counter: 38
                    Mileage: 89230 km
                    Date: 2026.05.05
                    Time: 16:20:17
                    Terminal 56b: 2.50 V
0789 - Light Bulb for Low Beam
          C1198 01 [00001000] - Electrical Failure
                    Reset counter: 39
                    Mileage: 89254 km
                    Date: 2026.05.05
                    Time: 17:19:42
0821 - static cornering lamp
          C119A 01 [00001000] - Electrical Failure
                    Reset counter: 38
                    Mileage: 89264 km
                    Date: 2026.05.05
                    Time: 19:33:58
   Dataset Number: 8W5909472A  0006
End----(Elapsed Time: 02:28, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
------------------------------36 Faults Found------------------------------
Saturday,11,July,2026,08:05:05:47381
Mileage: 91239km-56693mi   Repair Order: S5 SRI Log
VCDS Release 26.3.0:  SRI Reset-SRI2.CLB
Control Module Part Number: 8W5 920 890 C       Labels:  *Redir Fail!-SRI2
Component:FBenUSA       H17 0313, Coding:08EF31CB38A8CF050223E9601800000008000000
Channel        Description                                                     Current val.                                                    New val.
IDE00342-ESI: Resetting ESI        ESI: Service Status                                             Resetting                                                       ---
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance SINCE last Oil Service                            0 km                                                            ---
IDE00511-ESI: time from inspection        ESI: Time SINCE last Oil Service                                12 d                                                            ---
IDE00512-ESI: minimum value km-driving distance/inspection                                              ESI: Minimum Distance to Oil Service(s)                         14500 km                                                        ---
IDE00513-ESI: maximum value km-driving distance/inspection                                              ESI: Maximum Distance to Oil Service(s)                         14500 km                                                        ---
IDE00827-ESI: minimum value of time between inspections                                                 ESI: Minimum Time to Oil Service(s)                             365 d                                                           ---
IDE00514-ESI: maximum value of time between inspections                                                 ESI: Maximum Time to Oil Service(s)                             730 d                                                           ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance SINCE last mileage-dependent Inspection           12800 km                                                        ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time SINCE last time-dependent Inspection                  409 d                                                           ---
IDE03349-FIX: Max. distance until next mileage-related inspection                                       FIX: Max. Distance to mileage-dependent Inspection(s)           32032 km                                                        ---
IDE03350-FIX: Maximum time until next time-dependent inspection                                         FIX: Max. Time to time-dependent Inspection(s)                  730 d                                                           ---
IDE01153-SIA: maximum value of distance to service                                                      SIA/SID: Maximum Distance to Service/Inspection                 16000 km                                                        ---
IDE01154-SIA: maximum value of time to service                                                          SIA/SID: Maximum Time to Service/Inspection                     365 d                                                           ---
*IDE00935-ESI: Theoretical service interval                                                             ESI/INFO: Theoretical Oil Service Interval                      28700 km                                                        ---
*IDE00697-ESI: remaining distance        ESI/INFO: Remaining Distance to Oil Service                     16000 km                                                        ---
*IDE00698-ESI: remaining running time        ESI/INFO: Remaining Time to Oil Service                         353 d                                                           ---
*IDE00695-ESI: service exceedance in km        ESI/INFO: Oil Service Exceedance                                Not available                                                   ---
*IDE00696-ESI: service exceedance in days                                                               ESI/INFO: Oil Service Exceedance                                Not available                                                   ---
IDE00819-Day counter        INFO: Day Counter (since Delivery Inspection)                   3377 d                                                          ---
IDE00301-Distance        INFO: Vehicle/Odomoter Mileage                                  91239 km                                                        ---
        Service Notification (Early Warning/Prediction)                 ---                                                             ---
IDE00517-ESI: soot entry        ESI/INFO: Soot Entry                                            0 km                                                            ---
IDE00518-ESI: thermal load        ESI/INFO: Thermal Load                                          0 km                                                            ---
IDE00515-ESI: oil quality        ESI/INFO: Oil Quality                                           poor oil quality                                                ---
I'd really like to see the values in the SRI-related channels:
NEtech
Denmark
C?ID=56995
I tried to make them available.
To many [code] and [/code]
You could try changing IDE01153 to 8000 km from 16000.
Or you could set IDE00510 to 8000 km after every reset.
Turboaudi80
C?ID=29794
Changing IDE01153 fixed it. Thank you!
