7P Touareg "Front Assist Deactivated" Message on startup
RGH0
Australia
C?ID=433612
When using one of my 2 key fobs to start my Touareg I get a message on the screen saying "Front Assist Deactivated". I changed the fob battery in the key that causes this message with no change. There are no error lights on the dash after I get this message on start up and the cruise control works normally with both keys. There are also no relevant errors in the VCDS scan. I cannot find any setting that in driver preferences which may influence this due to a different key, driver preferences like the memory seats work correctly for both keys. I am not keen to test if the emergency braking stop actually works for obvious reasons but the ACC does bring the car to a stop in traffic. Does anyone have any ideas where to look next ?
The 2 faults shown have been present for a long time and neither appear to affect any actual operation.
1. The module 08 HVAC left indirect vent fault appears to be due to a faulty lower limit sensor as the vent flap works normally as commanded but goes below the set lower limit of 10000 to 8800 for some reason. The right indirect vent when tested stops at the 10000 lower limit
2. The module 6C backup cam fault with the internal system error for the left camera does not affect the system operation
Tuesday,07,July,2026,16:04:50:47490
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
Dealer/Shop Name: Home
VIN: WVGZZZ7PZDD024849   License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 11 31 13 15 16 17 19 28 34 36 3C 42
          46 47 52 53 55 56 5F 62 65 69 6C 6D 72 85 8B 8E 8F 90
VIN: WVGZZZ7PZDD024849   Mileage: 125596km-78041miles
Address 01: Engine (J623-CKDA)       Labels:. 057-907-409-V2.clb
   Part No SW: 7P1 907 409 A    HW: 7P0 907 409
   Component: 4.2TDI EDC17  H20 0001
   Revision: 52H20---    CVN: 45D6DCE4
   Coding: 292A4012437E00020000
   Shop #: WSC 12463 002 1048576
   ASAM Dataset: EV_ECM42TDI1117P1907409A 001001
   ROD: EV_ECM42TDI111_VW52.rod
   VCID: 36352CC058CCE59A25F-8062
   VINID: 9E65EAAAA1E0A94500084204249566230A
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 BE    HW: 0C8 927 750 BE
   Component: AL1000 AISIN  001 2270
   Serial number:                CVN: 6876320A
   Coding: 001168
   Shop #: WSC 39264 002 1048576
   ASAM Dataset: EV_TCMAL991031 002114
   ROD: EV_TCMAL991031_002.rod
   VCID: 70B9DAD87A288BAA3F3-8024
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 432720010EC815 Dataset Number: 7P0012v____ 7P16
   Coding: 5B6B53C34B262F57DAFCCA97D2DBF440F700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4ACD68303C34917A517-801E
   Part No SW: 4H0 907 064 CM    HW: 4H0 907 064 CM
   Component: BCM2 2.0      H33 0433
   Coding: 05960016000000000000
   VCID: 76B5ECC018CCA59AE5F-8022
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2312000165279015
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000045309195
   Coding: 0038330000004201000001010101202020202121202020
   VCID: 343116C84E30F78A1BB-8060
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 4 Zonen H20 1305
   Coding: 38A620BEC0
   VCID: 7EA5F4E0307CEDDABDF-802A
0518 - Positioning Motor for Left Indirect Vent Flap
          B12A1 07 [00001001] - Mechanical Failure
                    Reset counter: 57
                    Mileage: 125596 km
                    Date: 2026.07.07
                    Time: 16:35:26
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001479577
   Coding: 26001010D1345D010021000780005D0C431D670803010241800000020000
   Shop #: WSC 49628 000 1048576
   VCID: 6C81CEA856806F4A03B-8038
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    121113  031 0021
   Serial number: 90243401121128212305
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20034839
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002911120325
   Component: EVLS-SG  H08 0300
   Serial number: WA103988000001758383
   Coding: 020300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28261232400548
   Coding: 518D01
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43D345141B1E4032921-8016
Address 11: Engine II (J624)       Labels:. 057-907-409-V2.clb
   Revision: 52H20---    CVN: E85A53E8
   ASAM Dataset: EV_ECM42TDI2117P1907409A 001001
   ROD: EV_ECM42TDI211_VW52.rod
   Part No SW: 7P6 907 561 B    HW: 7P6 907 561
   Component: ACC3          H19 0340
   Coding: 3704010101
   ASAM Dataset: EV_AdaptCruisContrVW526 002011
   ROD: EV_AdaptCruisContrVW526_002.rod
   VCID: 3B233DF463EE38F2DA1-806E
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag00T H05 0025
   Revision: --------    Serial number: 003L0005X3J+ Dataset Number: 7P6003v____ 0937
   Coding: 000000000000000000000000000000003054
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41DF4F1C0102522280D-8014
   Serial number: 3575LRB401C4UOJAAPOR
   Serial number: 3585LRB40184UOJAE23R
   Serial number: 3515RRB405J1ON6GIPRW
   Serial number: 3525RRB405J1ON6G7GC+
   Serial number: 3555NRB400S4UP60P9E9
   Serial number: 3565NRB400S4UP60IQ17
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 T
   Revision: --------    Serial number: 90815LKT0003K
   Coding: 000CBD
   VCID: 382922F8525813EA373-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0223844
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 881 N    HW: 7P6 920 881 N
   Component: Kombi         H13 0318
   Revision: 13240077    Serial number: 658101212592004
   Coding: 331733003F08000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001017
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 47CB51042F266C124E9-8012
   Part No SW: 7P6 907 530 G    HW: 7P6 907 530 G
   Component: GW-CAN-L-FR-M H11 6028
   Revision: --------    Serial number: 00000000766529 Dataset Number: 7P6067v____ 0026
   Coding: 0001037D00
   GVL: FF7F44E55D7F6E0000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3C213EE866E03FCAD3B-8068
   Control module for battery monitoring:
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000004190741085
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 7P6 907 049 Q    HW: 7P6 907 049 Q
   Component: Klima Fond    H14 1305
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001007
   ROD: EV_AirCondiHeck.rod
   VCID: 4BC36D34334E88726A1-801E
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 N    HW: 7P0 907 553 N
   Component: PASM          H01 1550
   Revision: 00000000    Serial number: 00000122300134
   Coding: 15210001
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 42DD40100404493A997-8016
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000045307917
   Coding: 00383B0000004201000001010101202020202121202020
   Part No SW: 7P6 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH04 0110
   Revision: 00H04000    Serial number: 6PZ 010 316-01
   Coding: 0011151
   VCID: 7EA5F4E03CFCEDDABDF-802A
   Subsystem 1 - Part No: 7P6 907 568
   Component: J770  SWA Slave H02 0110
   Subsystem 2 - Serial number: 6PZ 010 316-21
   Subsystem 3 - Serial number: 5F27.11.1200H02000AMS14112
   Subsystem 4 - Serial number: S14112
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Component: TSG FA        H02 0166
   Revision: --------    Serial number: 0000130691297
   Coding: 011D1620DE01459205080003
   VCID: 43D345141B9E4032921-8016
   Revision: 00002001    Serial number: 0187687583
   Coding: 019A1E2028B91081832006202D0000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811002058206
   VCID: 75B7EBCC05CAAE82EC5-8020
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000132322572
   Coding: 011D1620DE01459205080000
   VCID: 3B233DF4636E38F2DA1-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C12B2900121    Dataset Number:             A001
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0009
   Coding: 012E00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA1FEE82660FFCA93B-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Part No SW: 4G1 035 053 G    HW: 4G1 035 053
   Component: Radio U Basic H41 0121
   Revision: AB001007    Serial number: 227LB0C7667539
   Coding: 040005010000000003
   VCID: 2313E594FBDE6032F21-8076
   Part No SW: 7P6 035 764 D    HW: 7P6 035 764
   Component: H-BNT-RW      H46 0593
   Revision: --------    Serial number: 479LB0C7523657
   Coding: 020A01050040E9EF71102B0E00000003F00001030000000000
   VCID: 3A2D38F06C5401FAC17-806E
   Subsystem 1 - Part No: 8R0 060 884 AS
   Component: ROW 2013  0506
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M7801WAC
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  4949
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000132279400
   Coding: 011C14200001259005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 20000000005596 Dataset Number: 7P6096v____ 0019
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3FDB49E477F624D2F69-806A
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000168822336
   Coding: 030D000000000000
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 E    HW: 7P6 907 441 D
   Component: TopView       H05 0100
   Revision: 11001001    Serial number: 82330JF0066807
   Coding: 0100000001000000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
9617481 - Left Surroundings Camera
          B127E 04 [00001001] - Internal System Fault
                    Reset counter: 57
                    Mileage: 125596 km
                    Date: 2026.07.07
                    Time: 16:35:27
                    Voltage terminal 30: 14.7 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 324200446 Dataset Number: 7P6959107C  D045
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000132750104
   Part No SW: 7P6 907 217 A    HW: 7P6 907 217
   Component: DPC-SG        H23 0033
   Revision: --------    Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0021
   Coding: E8030000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 382922F852D813EA373-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000003025658_2480
   Part No SW: 7P6 907 541 B    HW: 7P6 907 541
   Coding: 3704010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 002010
   ROD: EV_AdaptCruisContr2VW526_002.rod
   VCID: 392F27FC69D20AE2C8D-806C
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 B    HW: 7P6 907 107
   Component: BV-SG         H31 0035
   Serial number: 005000012311127
   Coding: 0A801E040000
   Shop #: WSC 49628 123 104857
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
   VCID: 372B21C45FC61C923E9-8062
   Dataset Number: 7P0FH1v____ 0010
   Coding: 00660600031F037F00033810594097000000
   Shop #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F1FDCB1A2C2A270D-8064
   Dataset Number: 7P0FF1v____ 0010
   Coding: 006606000317037F00033810594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323D10D0B4A4F9BA097-8066
End----------(Elapsed Time: 02:30, VBatt start/end: 14.9V/14.9V)-----------
------------------------------2 Faults Found-------------------------------
TTT
C?ID=547002
What is the SoH of the battery?
RGH0
Australia
C?ID=433612
Battery is fine, no problem starting the car and sitting voltage 12.6V. I have not monitored cranking voltage recently but was around 11.7 when I last checked. I will recheck it
TTT
C?ID=547002
ok.
Spacewalker
Poland
C?ID=159607
maybe is a driver profile, and function is OFF? did you try to enable it and save ?
RGH0
Australia
C?ID=433612
I cant find it anywhere to set it in profile on or off. Does it exist?
It does, but I don't recall exactly how to get to it, nor do I have access to a 7P at the moment.
RGH0
Australia
C?ID=433612
I will keep looking :)
NEtech
Denmark
C?ID=56995
There are some in [46], adaptation channels 001...004
But does not look like something with ACC.
Is B127E changing Date everyday?
Date: 2026.07.07
RGH0
Australia
C?ID=433612
Found the issue :)
For the key with the problem the front assist setting had been turned off. As I don't normally use this key as its my spare it may have been like that since I got the car years ago
Turned the ignition on with the problem key
Went to CAR>SETUP>DRIVER ASSIST>FRONT ASSIST and checked the boxes, which were not checked for this key. Then turn off and lock the car and the changes were saved for the key and the dash warning on startup no longer occurs
Thanks Uwe for getting me to find the problem in the menu system.
Is everything in CAR >SETUP a key personalisation item ?
Reactions: TTT
