2019 VW Tiguan SEL 4Motion
nonpoint505
Phoenix, AZ, USA
C?ID=653417
I had the CEL come on yesterday while driving home. Ran my auto scan and these are the faults I am getting. I see that they say intermittent not confirmed. Im wondering what exactly does this mean?
Thursday,09,July,2026,19:19:47:31576
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4701.5
VIN: 3VV4B7AXXKM038028   License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 3C 42 44 47
          4B 52 5F 6C 6D 75 A5 BB BC CA D6 D7
VIN: 3VV4B7AXXKM038028   Mileage: 184893km-114887miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels:. 06K-907-309-V2.clb
   Part No SW: 83A 907 115     HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0007
   Revision: 1DH31000    CVN: 2C43E747
   Coding: 012A00122466012FB4000000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS01183A907115 001009
   ROD: EV_ECM20TFS0115NA907115K.rod
   VCID: 6398C6EDFBD20D92B21-8036
   VINID: 0E6984487468A1B7400C8002203979487A
28253 - Coolant Pump 3
          P26F8 00 [00100000] - Stuck
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00100000] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
7661 - Secondary Air Injection Solenoid Valve (N112)
          P1432 00 [11101000] - Open Circuit
                    Fault Frequency: 19
                    Mileage: 182988 km
                    Date: 2026.06.09
                    Time: 05:06:22
                    Engine speed: 3889.50 /min
                    Normed load value: 47.1 %
                    Vehicle speed: 154 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 12.980 V
                    Engine status: COENG_RUNNING
7657 - Secondary Air Injection System Switching Valve Bank 1
          P2440 00 [01100000] - Stuck Open
                    Mileage: 183826 km
                    Date: 2026.06.22
                    Time: 10:57:36
                    Engine speed: 1184.00 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 41 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 14.340 V
                    Unlearning counter according OBD: 19
Address 02: Auto Trans (J217)       Labels: 09P-927-749-V1.clb
   Part No SW: 09G 927 158 DT    HW: 09G 927 158
   Component: AISIN AQ8     206 3698
   CVN: 2408AAFC
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00438
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 0842F14122B48ECA873-805C
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 52548000000876
   Coding: 0BFA6BA454231B74C5770302A2CB49D0D62AD8A3C045927C38415058C2AA420B002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 77A082BD5F4AF132FE9-8022
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0488571075 Dataset Number: V03935276RJ 0001
   Coding: 132C2C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43D8266D5B126D92921-8016
   Power rear lid opening control module:
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11189300
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NN 907 044 K    HW: 5NN 907 044 K
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00231636
   Coding: 00020024200118001105010C1211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   VCID: 54FA1531AE7CFA2A3BB-8000
   Humidity sensor: exterior:
263425 - Air Quality Sensor
          B10AF 04 [00001000] - Internal System Fault
                    Reset counter: 114
                    Mileage: 164884 km
                    Date: 2025.11.04
                    Time: 10:49:15
                    Outside temperature: 27.0 °C
                    Voltage terminal 30: 13.3 V
                    Air quality status: Malfunction
   Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86402101801KX Dataset Number: V03935289VZ 0001
   Shop #: WSC 00066 790 00200
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CAA9D91666CD26A93B-8028
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 180926  034 0373
   Serial number: 18092521025360
   Component: RLHS  052 0107
   Serial number: SBY18M07D18H10M45S07
   Coding: 00A8DD
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23 0170
   Serial number: 0300281020180C203049
8970 - Bulb for Right Fog Lamp
          B1220 15 [00001000] - Open or Short to Plus
939524 - No Communications with Humidity Sensor
          U10F5 00 [00001000] - -
          [Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
204546 - Remote key 2
          B147A 18 [00001000] - Current Too Low
                    Reset counter: 102
                    Mileage: 167063 km
                    Date: 2025.12.05
                    Time: 13:42:21
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    Voltage: 12.6 V
                    Outside temperature: 19.5 °C
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000137088R18297 Dataset Number: V03935280JG 0001
   Coding: 0471255811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CCA0D51764CA2EA63B-8018
   Component: ACCCONTIMQB   H02 0233
   Dataset Number: V03935279GP 0001
   Coding: 320000C158FF8728749C8145304097
   VCID: 3E2E579930F0007AFDF-806A
196743 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FCTSEN_INC_BLOCKAGE]
                    Reset counter: 87
                    Mileage: 183547 km
                    Date: 2026.06.15
                    Time: 05:07:35
                    Voltage terminal 15: 13.7 V
                    Control Module temperature: 43 °C
                    Velocity_vehicle_reference: 36.90 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.16 m/s²
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    005 0338
   Serial number: 003NUM0CCRTT Dataset Number: V03935265ZU 0001
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   VCID: 055CF87515A693A2FC5-8050
   Serial number: IBH00000000000AFC9MS
   Coding: 303352
   Subsystem 2 - Part No SW: -----------    HW: 480 000 808 18
   Serial number: 357000000006E5AC733W
   Subsystem 3 - Part No SW: -----------    HW: 480 000 808 18
   Serial number: 35800000000BB948F23-
   Subsystem 4 - Part No SW: -----------    HW: 480 400 507 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011A2B6D2F31660
   Subsystem 5 - Part No SW: -----------    HW: 480 401 607 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001102B6D2E123CZ
   Subsystem 6 - Part No SW: -----------    HW: 480 400 609 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001AF2BB7283D1CN
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 609 18
   Component: FrontSensor_P  003 6149
   Serial number: 3560001AF2BB7285437E
   Part No SW: 5NA 920 891 C    HW: 5NA 920 891 C
   Component: KOMBI         403 4191
   Coding: 0BA4041AEF88CF0502886B0B54010000A0000000
   VCID: 44DA25715E1C6AAAABB-8010
9456128 - Engine Control Module (ECM) not Authorized
          B104A 00 [00001000] - -
                    Mileage: 166297 km
                    Date: 2025.11.23
                    Time: 14:13:28
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 03101800840241 Dataset Number: V03935286KX 0001
   Coding: 030500347F085900FB03225A1E0F00010001070000000000000000000000
   GVL: 01C63C000800060040DC80008002C80010000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D2C50953DF61B62E45-8068
   Generator:
   Component: 1-00-0d-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H06 0025
   Serial number: 2331811563701292FG2B
   Coding: 2E0000
   Serial number: 1524546100
   Serial number: HA1-00009.07.18 Dataset Number: v1260x015G0 0000
   Coding: 0101
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45DC3875552653A2BC5-8010
   Serial number: 18000280913006
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 333876AD0BB2DD12021-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RGK22792
   Coding: 0010000000000500018280808080000000008101000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0493587105 Dataset Number: V03935276UZ 0001
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Component: HRE_Slave  H12 0081
   Serial number: 0490975693
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038829301274 Dataset Number: V03935287NS 0001
   Coding: 003F1B205200048000000000
   VCID: 4FF01A5D875A99F2069-801A
196665 - Switch for Central Locking
          B122D 29 [00001001] - Signal Implausible
                    Fault Frequency: 65
                    Reset counter: 72
                    Mileage: 165200 km
                    Date: 2025.11.07
                    Time: 17:37:15
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1081
   Dataset Number: V03935286UH 0001
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F219219A64860A1F3-8004
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD03229/ Dataset Number: V03935266BX 0001
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 2E0E67D9E090F0FA6DF-807A
   Component: FCM MQB Low   002 0342
   Serial number: 09101800840357 Dataset Number: V03935286DD 0001
   Coding: 0000000509001D5200210F01090000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002004
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353C48B505C6C3222C5-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038829101772 Dataset Number: V03935287NU 0001
   Coding: 003F13205E00048000000000
   VCID: 4ECE0759805090FA0DF-801A
196650 - Motors for Central Locking
          B122B 12 [00001000] - Short to Plus
                    Reset counter: 99
                    Mileage: 184307 km
                    Date: 2026.06.26
                    Time: 06:53:56
196651 - Motors for Central Locking
          B122B 11 [00001000] - Short to Ground
                    Reset counter: 87
                    Mileage: 183514 km
                    Date: 2026.06.15
                    Time: 04:47:09
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Serial number:                Dataset Number: V03935281LN 0001
   Coding: 027306020000000051220002001808001F0506E401200405C6
   Shop #: WSC 00066 790 00317
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  252 8130
   Serial number: VWZ6ZMV2905134
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
                    Reset counter: 241
                    Mileage: 164884 km
                    Date: 2025.11.04
                    Time: 10:49:52
                    Voltage terminal 30: 13.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 105 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG036566 Dataset Number: V03935282NB 0001
   Coding: 01230601A20F20003000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
   VCID: 3924448529DE2742C8D-806C
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0266
   Revision: --------    Serial number: A2-C758-8700-2 Dataset Number: V03935276HY 0001
   Coding: 0A28
   VCID: 46DE3F79682058BAB5F-8012
Address 75: Telematics (J949)       Labels:| 5QE-035-28X-V1.clb
   Component: OCULowMQBUS   009 0570
   Dataset Number: V03935268PZ 0001
   Coding: 02230602C2823A037F1E06020000
   ROD: EV_OCULowMQB_VW37.rod
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
   Serial number: 19061841P12271 Dataset Number: V03935276DX 0001
   Coding: 0003070601020201002213548150490084000E200120
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 5Q4 959 595 G    HW: 8W0 959 595 F
   Component: TSG HFS       005 0247
   Serial number: 58028829008104 Dataset Number: V03935287QF 0001
   Coding: 002011200101048000000000
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 4BC80E4D7342A5D26A1-801E
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS      005 0247
   Serial number: 58028829013205 Dataset Number: V03935287QD 0001
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: V03935292EQ 0001
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_006_VW37.rod
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481_VW37.rod
   VCID: 0052E9610A84B68ACF3-8054
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481_VW37.rod
End----------(Elapsed Time: 02:27, VBatt start/end: 12.0V/12.1V)-----------
------------------------------14 Faults Found------------------------------
nugentp
C?ID=6386
Intermittent faults can be just a bad/dirty connection causing the fault condition to be triggered for a short time before clearing by itself. You can clear the codes and see what comes back... whatever returns points to a connection issue that may need to be addressed.
TTT
C?ID=547002
Clear<br><br>7661 - Secondary Air Injection Solenoid Valve (N112)<br> P1432 00 [11101000] - Open Circuit<br> MIL ON
MIL ON
MIL ON
There are so many good videos out there, from South Main Auto. Pretty basic test tbh, for a solenoid valve.
Ignore the ones that don't have any freeze-frame data for the time being. Concentrate on the two that do, particularly the one that's flagged "MIL ON".
nonpoint505
Phoenix, AZ, USA
C?ID=653417
I cleared the faults today when I got home. I did remove my maf a few days ago so I could clean it along with my air filter so when I checked that connection I did forget to push the tab in, so im hoping that might be what caused it. Im gonna drive it around over the weekend to see if they come back.
nonpoint505
Phoenix, AZ, USA
C?ID=653417
What exactly does MIL ON mean?
nonpoint505
Phoenix, AZ, USA
C?ID=653417
So after clearing faults and driving for a day my CEL came back on and now I am just getting the one code. I guess I am going to have to start troubleshooting the secondary air solenoid valve. Anybody have any good links that they know of right away that will help with this process?
Tuesday,14,July,2026,17:29:28:31576
Mileage: 185044km-114981mi   Repair Order:
VIN: 3VV4B7AXXKM038028   Mileage: 185044km-114981miles
          P1432 00 [11101100] - Open Circuit
                    Fault Frequency: 48
                    Mileage: 184931 km
                    Date: 2026.07.14
                    Time: 04:57:00
                    Engine speed: 4940.00 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 137 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 12.900 V
Readiness: 0000 0100
   CVN: 2408AAFC
   Coding: 132C2C0723
                    Reset counter: 116
                    Mileage: 184969 km
                    Date: 2026.07.14
                    Time: 05:13:48
                    Outside temperature: 29.0 °C
                    Voltage terminal 30: 13.1 V
                    System run time-Engine running time: 253 s
   Coding: 00A8DD
   Coding: 0471255811
   Coding: 303352
   Generator:
   Coding: 2E0000
   Coding: 0101
   Coding: 02011103
   Coding: 020111
                    Reset counter: 76
                    Mileage: 184980 km
                    Date: 2026.07.14
                    Time: 05:22:30
   Coding: 911F0000
                    Reset counter: 116
                    Mileage: 184980 km
                    Date: 2026.07.14
                    Time: 05:22:29
                    Reset counter: 75
                    Mileage: 184904 km
                    Date: 2026.07.10
                    Time: 12:41:28
                    Voltage terminal 30: 12.2 V
                    SDARS_tuner_status_2-Antenna current: 108 mA
                    SDARS_tuner_status_2-Reception quality: weak_signal
   Coding: 0A28
End----------(Elapsed Time: 02:28, VBatt start/end: 12.3V/12.2V)-----------
------------------------------5 Faults Found-------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
Find the valve check wiring and valve pretty straight forward.
  • Agree
nonpoint505
Phoenix, AZ, USA
C?ID=653417
So I did some testing today. Relays and fuses in fuse box tested good. I do not see any loose wires or damaged connections. I manually started the SAI system and relay along with the combi valve using VCDS. In the first video link below you can hear the pump and the relay clicking. Im not sure if the pump is supposed to sound like that or not??? In the second video you can hear the solenoid clicking on and off which to me tells me its working. Does anyone have any thoughts or input on this?
https://www.facebook.com/552345767/...KX8cLXrFrZJCAadxf-42k6nYKb1rnX4&__tn__=*b0H-R
https://www.facebook.com/552345767/...KX8cLXrFrZJCAadxf-42k6nYKb1rnX4&__tn__=*b1H-R
