2013 VW Jetta GLI 2.0T CCTA - Valvoline Restore and Protect
davealf12
Laredo, TX, USA
C?ID=649243
What's the consensus on using Valvoline Restore and Protect 5w30 on a 2013 VW Jetta GLI 2.0T CCTA? Car has 130,000 miles. I have been using Liqui-Moly Molygen 5w40 for the past two oil changes. Bought it used last year with 123,000 miles. The RaP does not have the VW 502 00 spec/certification and Valvoline doesn't seem to make RaP for Euro spec vehicles.
All opinions are welcome.
BlueR32
C?ID=58325
According to independent lab testing Valvoline's claims of cleaning the engine internally are true. Personally I would stick with a VW 502 spec oil. The RaP wouldn't provide any advantage unless the engine has built up carbon deposits - which would typically be from the incorrect engine oil and/or poor quality fuel. The oil chemistry is what's most important and why VW/Audi/Porsche and most Euro car makers have very specific oil spec requirements.
There are effective and VW approved fuel additives like Techron to remove piston/valve carbon deposits. Redline's fuel system cleaner contains the most PEA (the active and effective cleaning chemical) of the many fuel system cleaners independently tested and reported online that I have seen.
Were you having a specific issue that you felt the RaP would address?
Eric
HC800000
davealf12
Laredo, TX, USA
C?ID=649243
Thank you all for the info.
I'm not experiencing any issues with vehicle. The vehicle itself was maintained properly, with all oil changes at VW dealerships. My concern is the oil changes were done every 10k miles, which the factory interval. I myself prefer 3k-5k mile intervals. There has been a lot of info lately stating that 10k intervals are not the best, even though that's what the manufacturer recommends. But looks like I'll wait for the 5w40 and take it from there. Thanks again lads!
10,000 mile intervals are good enough to get the engine past any possible manufacturer's warranty, just like "lifetime fill" of the fluid in an automatic transmission.
From the car manufacturers' perspective, the longer a car lasts, the fewer new ones they get to sell...
BlueR32
C?ID=58325
Good to hear that there are no engine issues to report. There are engine oil flushes available to clean an engine internally that may have sludge build-up but it's often better to use a quality oil that has natural cleaning action so you don't load the oil filter with a mass of sludge that can plug the filter and force the oil bypass to open which then pumps the dirty oil thru the engine unfiltered.
Hear's the executive overview on long OCIs... They are intended to reduce the quantity of drain oil, viewed by some folks as an environmental issue. That being said VW/Audi/Porsche conduct extensive engine testing to define the oil properties required for their engines to operate properly long term. Long term in the auto industry is typically a min. of 100,000 miles IME.
The 10K OCI specified for U.S. model VWs is actually much shorter than the extended 15K-20K specified for some Euro models or a variation of same via an in engine oil use sensor and algorithm. To safely handle these extended OCI's Euro oil suppliers had to develop durable oils with additional quantities of the additive package. Oil doesn't wear out per se the additive package is consumed over the course of operation.
So the bottom line is that in typical use applications the factory OCI recommendations are perfectly fine if you use the correct VW spec oil for your specific engine. In severe applications like for instance towing a trailer all the time or taxi service in a metro area, then changing the oil sooner than the recommended service interval COULD be prudent.
There is a very easy and scientific means to know what is a safe OCI for any engine and that is a Used Oil Analysis, (UOA) test. This test tells exactly what the condition of the OIL is and if it is suitable for a longer OCI. These tests typically cost $35-$60 in the U.S. depending on what UOA lab you use. Changing the oil more frequently than necessary provides no benefit to the engine, it just increases maintenance costs. However not using the correct spec oil for your engine CAN prove costly. A specific oil might be the best oil available but if it's chemistry is not suitable for your specific engine then operational issues can occur. Using the incorrect oil and changing it weekly will not properly protect your engine if it does not have the correct chemistry.
I have been using UOA on all of my German vehicles since the 90's. For me it confirms that my OCI is correct for the application and the VW spec oil that I am using. And for the record a UOA does NOT tell you if one oil reduces engine wear vs. another brand or viscosity. To accurately determine engine wear vs. specific oil type/viscosity requires thousands of dollars of industry testing that a $35 UOA is not intended for and cannot provide. A UOA tells you if the oil is still good for longer service and what contaminants are in the oil such as H20, fuel, metals, etc. That is all it can tell you.
I have used/tested a number of UOA labs over the past decades and I can recommend Titan Labs in CO and SPEEDiagnostix if you want a slightly quicker UOA result but at a premium price. There is another popular UOA lab often recommended in VW / oil forums that I do not recommend as I have found their use on non-std. SAE J300 viscosity references for used oil and other issues in their UOA analysis to be inconsistent with industry standards. So I do not recommend them. I have NO association with any of these UOA labs.
Sorry for the long response but using the proper oil in an engine is important for long term reliability and minimal wear. There is a lot of conflicting info. online so hopefully this eliminates a lot of the "noise".
It also gets dirty; i.e. contaminated.
You're telling is the amount of wear metals in the used oil is not an indication of engine wear? :confused:
BlueR32
C?ID=58325
Of course oil gets contaminated. That's why you have an oil filter that removes particulate down to 20 microns. ;)
The amount of wear metals in a UOA sample varies from one test to another of the same sample as well as from sample to sample. So NO a UOA is not a valid wear test indicator. By definition a UOA test is a used OIL test intended to determine if the oil is still good for extended service. UOA is often "sold" by those who financially profit from conducting UOA as a means to determine if one oil reduces wear over another but it absolutely cannot do this.
The quantity/type of wear metals in a UOA sample can tell you if you have an internal engine issue developing or that has occurred. For instance, if you have an unusually high copper level you might have some unusual valve guide or bearing wear. If you have an unusually high iron wear you might have some cyl. or piston ring issue. NONE of these however tell you if one oil or viscosity reduces wear over another. That requires precision lab testing. Again for clarity: A UOA test by definition is NOT a wear test, it is an OIL test to determine if the oil is still serviceable.
As an example you can use the exact same oil but drive under different climatic conditions and see different wear metal figures. You can also drive more aggressively such as track driving vs. typical street driving and again see different metals figures (typically higher iron due to valve spring surging). It's quite simple, an OIL test is not a WEAR test. If it were oil and auto companies could save million in analysis costs annually.
I have just imported the first batch of R&P into the UK and I have a couple of cars I want to try it on. I have a feeling it will be most successful in engines with piston cooling jets.
Does anyone else watch the motor oil geek?
BlueR32
C?ID=58325
Yes.
Lake Speed Jr. is a certified tribologist and the owner of SPEEDiagnostix. He does some excellent videos. I don't always 100% agree with his conclusions but it's nice that someone who can afford to have the testing performed, understands the subject matter and has industry connections, (because he did racing oil development for NASCAR engines when he worked at Joe Gibbs Racing), gives us useful tech info.
RGH0
Australia
C?ID=433612
Yes he is one of the few places to get real oil technical data / information and not interweb myths and BS
Every time I watch him, Mrs Crasher says “Heh billy bob”
Nah.. here's Billy-Bob:
I hope Jessa is going to be OK with his cancer diagnosis.
