Looking for CAN bus data for MLB evo platform vehicles.
vkar9898
Sydney, Australia
Hey everyone! I've got an Audi Q7 4M dashboard bench (no car sadly), and so far I've managed to make it work mostly. RPM moves, speedo moves (but it drops to zero for some reason but I think I may have a solution), and most warnings are gone. There are still a few minor ones such as Audi Pre-sense, distance warning, TPMS, but these are all ignorable but one, it being 'Vehicle lights: Malfunction'. The issue with this warning is that every 2-3 seconds (DTC 92 38 08), it pops up on the main dash screen, and makes a loud chime. I've already tried LWR_AFS_01 (0x395), with no success.
So far, I've been using info that roli has gathered for his CarCluster project, as the MQB platform appeared to be very similar to mine, however it is not perfect, unfortunately. I have also scoured the internet for any Q7 related CAN dumps, and there is almost none, and those that exist, are mostly useless. This is what it looks like right now:
It is vital that your vehicle has adaptive headlights, without them I don't think I can fix it.
If you match these specifications and are able to help me, I very kindly ask you to perform a quick sniff. All you need to do, is begin a continuous CAN log, turn on the vehicle, turn on the headlights, turn them off (if there is a way to turn on/off Audi Adaptive lights, please press it too and inform me), turn on and off the high beams, press most of the steering wheel buttons one at a time, with 2 seconds interval (preferably in the order of: menu, up, right, down, left, OK, then any others [please list!]). If you are willing to, you may also perform a sniff while the car is moving. This would also help me tremendously, but not required. A simple CAN dump is okay, I can filter through it by myself.
If possible, please create a file through openpilot, that would be easiest, however I can work with different format.
Thank you so much to anyone who is willing to help me!
estoniandude
Tallinn, Estonia
Hey! Could you please share how you silenced the airbag warning, I have an MLB cluster on the bench and I can not silence it.
Thanks in advance!
vkar9898
Sydney, Australia
Thanks in advance!
Hey! Happy to help. For the airbag warning I send Airbag_01 (0x040) continuously at 50ms, all-zero payload except byte1 which carries a rolling counter (increments each send), and the frame is CRC-protected using the standard VW MQB checksum (the mqbSign / 0x2F poly with the per-message init value for 0x040).
By the way, since you've got an MLB cluster going too, would you be up for swapping notes? I'm stuck on the "Vehicle lights: Malfunction" popup (DTC 92 38 08) and haven't cracked it. Would you mind sharing which CAN IDs you're using to clear your warnings, and your sketch/code if you're willing? I'd love to compare, as you might have MLBevo-specific frames I haven't found, and I'm glad to share everything I've got in return.
estoniandude
Tallinn, Estonia
Hey! Sorry for the late reply, absolutely forgot about this project.
Sadly, it didn't work, the airbag light still blinks.
As for the light malfunction it never showed up on my ckuster, but you can try my sketch here
vkar9898
Sydney, Australia
Okay, thank you, I'll check it out soon. Would you still like my sketch?
estoniandude
Tallinn, Estonia
Hey, sorry for the late reply! Could you send me your sketch, I received an Audi A6 C7 cluster, and I wanna test it out.
