Hi, quick question.
I've always followed this to the letter:
https://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8R/8K)_Parking_Brake_EPB-4
"Turn ignition off and leave battery charger connected."
How necessary is this? I need to remove the rear subframe for a few days (at best, a week or more depending on what I find) to replace the rear brake pipes. I'd rather not tie up my only charger or have to buy a new one.
I guess I could leave the EPB engaged while the subframe is dropped which would negate any risk but then it'll be detached from the car with no way to disengage (should I find a reason to, but I think the rear calipers could do with a rebuild and now is the prime time to do it).
Cheers. Attached is a scan from last year in case anyone needs the install list/coding, ignore any faults, think it was just after disconnecting the battery. Just a scan I happen to have to hand, it's currently got a clean bill of health except for the air quality sensor.
Sunday,13,July,2025,13:54:38:30949
VCDS Version: 24.5.0.0 (x64)
VIN: WAUZZZ8K09A242007 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K09A242007 Mileage: 275750km-171343miles
Address 01: Engine (J623-CAGA) Labels:| 03L-906-022-CAG.clb
Part No SW: 03L 906 022 MJ HW: 03L 906 022 B
Component: R4 2.0l TDI H01 9978
Revision: 11H01--- CVN: B5EFDC53
Coding: 0104002C18072118
Shop #: WSC 01930 002 1048576
ASAM Dataset: EV_ECM20TDI03L906022MJ A01011
ROD: EV_ECM20TDI03L906022.rod
VCID: 79F866FCF8A1B75E04-802C
VINID: 9D196AAAA21B0094421020001C3E2CD0FF
5213 - Fuel Rail/System Pressure
P0088 00 [01100000] - Too High
5227 - Fuel Rail/System Pressure
P0087 00 [01100000] - Too Low
5231 - Fuel Rail/System Pressure
5334 - Turbocharger Boost Control Position Sensor Circuit
P2564 00 [00100000] - Signal too Low
Mileage: 275577 km
Date: 2025.06.20
Time: 15:34:04
Engine RPM: 928.00 /min
Normed load value: 24.3 %
Coolant temperature: 25 °C
Intake air temperature: 28 °C
Voltage terminal 30: 11.300 V
Unlearning counter according OBD: 29
Crankshaft speed (RPM): 928.0 /min
Vehicle speed: 0.00 km/h
Vehicle voltage terminal 30: 11300 mV
Charge Pressure Actuator: activation: 100.00 %
Trb Ch r Drft Clsd mp: 9.41 %
Charge pressure adjuster position sensor: 1.0 mV
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE
Component: ESP8 front H04 0240
Coding: 160500
Shop #: WSC 06325 000 00000
VCID: 7CF67FE8FF9382761F-8028
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H80 0145
Coding: 031100
VCID: 306E9BD8635BB616F3-8064
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000023173018
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H36 0042
Serial number: 0209000027859011
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0150
Revision: D0000000 Serial number: 01140520090754
Coding: 34040000
VCID: 428AC110DDF7348615-8016
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 141
Mileage: 267862 km
Date: 2024.01.26
Time: 14:50:46
Part No SW: 8K0 907 063 HW: 8K0 907 063
Component: BCM1 1.0 H26 0253
Revision: 01026001 Serial number: 00000000266562
Coding: 690040B10134BF000001000000005F5F001D020800000141000000
Shop #: WSC 06325 123 12345
VCID: 6CD64FA88FF312F68F-8038
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 080509 H05 0070
Serial number: SWF09050085441
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10464619
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0090
Serial number: 00000000000605091945
014 - Defective
Fault Status: 01101110
Reset counter: 141
Mileage: 267862 km
Date: 2024.01.26
Time: 14:50:00
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H37 0520
Serial number: 003EFD02J0H/ Dataset Number: 8K0909602F 0004
Coding: 30363435363030303030554A3052384B3053
VCID: 4188CE1CD0F12F9E0C-8014
Serial number: 6334MSME474423355
Serial number: 6344MSME4734347EK
Serial number: 6352QSME7F29193E.
Serial number: 6362QSME0A293F30K
Serial number: 63732SME6626101CX
Serial number: 63832SME5D2648364
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IE50005O
Coding: 000016
VCID: 3D70B2ECA4094B7E68-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H18 0224
Revision: 00200000 Serial number: 9E3105A59
Coding: 2F1D080002002600010001
VCID: 31689EDC6851BF1EFC-8064
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G09509805C
Coding: 000303
VCID: 4B94EC34EABDF5CEE6-801E
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 190773A0150409
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 154
Mileage: 273399 km
Date: 2024.12.25
Time: 17:30:00
Fault Frequency: 17
Reset counter: 173
Mileage: 273437 km
Date: 2024.12.29
Time: 15:03:00
Part No SW: 8K0 959 793 E HW: 8K0 959 793 E
Component: TSG FA H11 0250
Revision: Serial number: 0000008807776
Coding: 011002204001410001
Revision: 00002001 Serial number: 0118097417
Coding: 011B062200390440012001
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6ED245A0B9EFE0E6A1-803A
Part No SW: 8K0 959 792 E HW: 8K0 959 792 E
Component: TSG BF H11 0250
Revision: Serial number: 0000008892402
Coding: 011002204C01410001
VCID: 4188CE1CD8F12F9E0C-8014
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 10000000224623
VCID: 336494D4924D8D0E8E-8066
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Fault Status: 00101011
Reset counter: 86
Mileage: 274443 km
Date: 2008.05.31
Time: 07:23:22
Voltage: 12.80 V
Count: 29
Hex Value: 0x0173
Hex Value: 0x0008
Hex Value: 0x0101
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Reset counter: 86
Mileage: 274443 km
Date: 2008.05.31
Time: 07:23:22
Voltage: 12.80 V
Count: 28
Hex Value: 0x0163
Hex Value: 0x0008
Hex Value: 0x0101
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 195 AA HW: 8T2 035 195 AA
Component: Symphony3 H02 0310
Revision: 00000005 Serial number: AUZ5Z4I1104501
Coding: 0502008201018D008359070000
VCID: 77FC60C4C6B5A12E72-8022
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Reset counter: 141
Mileage: 267862 km
Date: 2024.01.26
Time: 14:50:00
Bin. Bits: 00000000
Bin. Bits: 00000001
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000101110886
Coding: 010002204001210001
VCID: 4486C708C7E33AB627-8010
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000101110889
Part No SW: 8T0 862 335 C HW: 8T0 862 335 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005075212
Coding: 0010320
VCID: 3A7AB9F075277C464D-806E
End-------------------------(Elapsed Time: 03:05)--------------------------
