I bought VCDS to help with this new to me car. After running a full scan, I looked at the cam phase angle to check the health of the timing chain.
The full scan showed many faults most of which were from me disconnecting the battery during the DSG service. The timing chain numbers look OK but here's the problem:
After the scan and clearing the faults, the radio no longer powers up and the FOB no longer works remotely. I can still open the doors with the key and start the car but no FOB response.
Any ideas?
Thanks,
Todd
Any ideas?
Thanks,
Todd
Tuesday,07,July,2026,17:56:52:37891
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4713.5
VIN: WAUKF78P69A019268 License Plate:
Mileage: 178860km-111138mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 42 44 46 52 55 56 62 65
72 77
VIN: WAUKF78P69A019268 Mileage: 178860km-111138miles
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 1010
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 8P0 907 115 AG HW: 8P0 907 115 Q
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: AUX7Z0H6FNF0CY
Coding: 0103010A1C0F0160
Shop #: WSC 06314 000 00000
VCID: 77AC0A9683C40482FE9-8022
VINID: 9D195B58722018944004908620F2E87D97
005386 - Engine Off Timer Performance
P150A - 000 - - Intermittent
Mileage: 178752 km
Date: 2026.06.27
Time: 00:11:36
RPM: 974 /min
Load: 28.2 %
Temperature: 55.0°C
Temperature: 48.0°C
Absolute Pres.: 820.0 mbar
Voltage: 13.970 V
U0155 - 000 - - Intermittent
Mileage: 178752 km
Date: 2026.06.27
Time: 00:00:20
Temperature: 60.0°C
Temperature: 48.0°C
Voltage: 12.446 V
Part No SW: 02E 300 011 DC HW: 02E 927 770 AT
Component: GSG DSG AG6 541 1972
Revision: 06454104 Serial number: 00002201260511
Shop #: WSC 04940 001 00001
VCID: 53F49E0677FC08A2221-8006
18082 - Powertrain Data Bus
P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
Fault Frequency: 255
Reset counter: 31
Mileage: 178752 km
Date: 2026.06.27
Time: 00:00:20
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
Reset counter: 31
Mileage: 178752 km
Date: 2026.06.27
Time: 00:00:20
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-EC1-V1.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 1442601249230003280D06EA922100413900
Shop #: WSC 29988 002 1048576
VCID: 005E614ADA0A433ACF3-8054
Reset counter: 31
Mileage: 178752 km
Date: 2026.06.27
Time: 00:00:20
Count: 14
Count: 12288
Count: 8208
Count: 44800
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000599 Serial number: 8P0820043BH
VCID: 73B43E8697BC68A2C21-8026
01272 - Positioning Motor for Central Flap (V70)
Fault Status: 00100011
Fault Frequency: 194
Mileage: 173581 km
Date: 2026.01.18
Time: 14:38:50
Voltage: 14.30 V
Temperature: 25.5°C
(no units): 134.0
(no units): 134.0
Temperature: 8.0°C
Reset counter: 16
Mileage: 178579 km
Date: 2026.06.11
Time: 12:03:33
Reset counter: 16
Mileage: 178579 km
Date: 2026.06.11
Time: 12:03:33
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 P HW: 8P0 907 279 P
Component: Bordnetz-SG H53 2902
Revision: 00H53000 Serial number: 00000008618668
Coding: F18C1F81C0141380EF00000A0080000000284E0564164003643000000000
Shop #: WSC 06314 000 08192
VCID: 4ACA8362A0B6496A517-801E
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150573
Shop #: WSC 06314
Fault Status: 00101100
Fault Frequency: 17
Reset counter: 14
Mileage: 173607 km
Date: 2026.01.19
Time: 10:16:00
Voltage: 14.25 V
01259 - Fuel Pump Relay (J17)
Fault Status: 00101001
Reset counter: 14
Mileage: 178431 km
Date: 2026.06.08
Time: 17:22:00
Voltage: 12.45 V
Fault Frequency: 28
Reset counter: 20
Mileage: 178120 km
Date: 2026.05.14
Time: 21:43:00
Voltage: 12.90 V
Fault Frequency: 21
Reset counter: 18
Mileage: 178120 km
Date: 2026.05.14
Time: 21:43:00
Voltage: 12.85 V
Reset counter: 31
Mileage: 178752 km
Date: 2026.06.27
Voltage: 12.40 V
Reset counter: 16
Mileage: 177772 km
Date: 2026.04.29
Time: 12:12:00
Voltage: 14.25 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0362156
Coding: 0000100
VCID: 3334FE86D73C28A2021-8066
Fault Frequency: 20
Reset counter: 240
Mileage: 178689 km
Date: 2026.06.24
Time: 08:15:06
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 K HW: 8P0 959 655 K
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000 Dataset Number: 8P0909602J 0019
Coding: 303142393041303030374A55304C38503053
ROD: EV_Airba10AURB4_AU35.rod
VCID: 4ACA8362AC36496A517-801E
Seat occupant detection:
Subsystem 1 - Part No SW: 8P0 910 339 C HW: 8P0 959 339 C
Component: BF-Gewichtss. H02 0030
Serial number: 5810000R0000003903
Serial number: 3572DRB4000077E0819W
Serial number: 3582DRB40000D73CBA11
Serial number: 35128RB400003E54B0BN
Serial number: 35228RB400006D9B9AD4
Serial number: 35547RB400003E00E3ES
Serial number: 35647RB400003E01635D
12670208 - No Communication with Instrument Cluster
U0155 00 [00001000] - -
Reset counter: 31
Mileage: 178752 km
Date: 2026.06.27
Time: 00:00:20
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014142
VCID: 41D8A44E9D808A3280D-8014
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 G HW: 8P0 920 982 G
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2246H004000744
Coding: 0017288
Shop #: WSC 65536 645 577705
VCID: 3D20D8BEE178EED2E45-8068
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0871104E5
Coding: ED837F070007022102
VCID: 3530C09ED94836922C5-8060
Fault Frequency: 38
Reset counter: 32
Mileage: 178120 km
Date: 2026.05.14
Time: 21:43:16
Fault Frequency: 39
Reset counter: 33
Mileage: 178120 km
Date: 2026.05.14
Time: 21:43:16
Reset counter: 30
Date: 2026.06.27
Time: 00:00:20
Reset counter: 30
Date: 2026.06.27
Time: 00:00:20
Reset counter: 30
Date: 2026.06.27
Time: 00:00:20
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 43D4AE46879C9822921-8016
Reset counter: 1
Mileage: 178752 km
Date: 2026.06.27
Time: 00:00:20
Revision: D0H15004 Serial number: AUX7Z0H6FNF0CY
Shop #: WSC 00137 211 56823
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0001213
01706 - Switch for Mirror-Adjust (E43)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 K
Component: KSG H11 0080
Coding: 1B80228001382D090F0FCC8F0477
VCID: 44D6AD5A82929F1AABB-8010
00849 - S-contact at Ignition/Starter Switch (D)
00957 - Key 3
01179 - Incorrect Key Programming
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0001213
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Coding: 0000013
Reset counter: 31
Mileage: 178760 km
Date: 2026.06.27
Time: 00:00:19
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 Q HW: 8P0 035 186 Q
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H8962476
Coding: 0750202
VCID: 40DEA14A968A833A8F3-8014
Reset counter: 31
Mileage: 178752 km
Date: 2026.06.27
Time: 00:00:20
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0001176
Shop #: WSC 06314 000 1012544
02071 - Local Databus
Address 65: Tire Pressure Labels: 8J0-907-273.clb
Part No SW: 8J0 907 273 A HW: 8J0 907 273 A
Component: J502-RDK H03 0370
Revision: --H03-D0 Serial number: 12956781334046
Coding: 0860021
Shop #: WSC 06435 000 00000
VCID: 2F3CF2F63B140C42669-807A
Reset counter: 32
Bin. Bits: 00000000 00100101
Voltage: 12.20 V
Text: 36,0°C;n.erkannt; n.erkannt
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0001176
VCID: 42DAAB429886912A997-8016
Part No SW: 8P0 862 335 P HW: 8P0 862 335 P
Component: FSE_256x BT H34 0520
Revision: 00000000 Serial number: 00000005005383
Coding: 0001277
Reset counter: 31
End----------(Elapsed Time: 01:37, VBatt start/end: 12.1V/12.1V)-----------
------------------------------40 Faults Found------------------------------
Tuesday,07,July,2026,18:09:24:37891
Address 01: Engine (8P0 907 115 AG)
18:09:21
720 /min Engine Speed (G28)
5.9 % Cam. Adjustment Intake Bank 1
28.0°KW Cam. Adjustment Intake B1 (spec.)
28.0°KW Cam. Adjustment Intake B1 (act.)
-1.22° Phase Position Bank 1 Intake
Test OFF Cam. Adj. Test Bank 1 Intake
