2017 MK7 Golf R - ACC Radar Vertical Misalignment after Driving in the Rain (C1103)
Kushdaiin
CT, USA
C?ID=192983
I have a NAR 2017 VW Golf R that I was driving through heavy-ish rain yesterday and while traveling along a relatively smooth road, the following C1103 error in Module 13 showed up on the dash/VCDS. This shows that there's registered vertical misalignment of my ACC radar. I did a physical check of the radar and nothing appears to be misaligned or that it was damaged by some incidental impact that I was not aware of. I've since driven the car 20-30 miles with the hope that it might clear but alas, it is still locked in and unable to be cleared (makes sense).
At this point I am "assuming" (and hoping) that it was somehow jarred enough to just knock it out of the original calibration angle. I did a little bit of digging and found this previous post regarding a similar issue which points to this German wiki to statically or dynamically (re)calibrate the radar (5Q0907572H H10 0620). With the particular HW/SW model of radar it appears as if I can do either sort of calibration. I was looking for some guidance on which calibration I should try and perform first. If I do the dynamic calibration, should I be resetting the vertical and horizontal values to zero or just the vertical? If I do the static calibration, can I just place a sufficiently wide board 120 cm from the from of the car (with the assumption it's essentially vertical) as I don't have a garage and it would seem easier to place a board than moving a car? Any help would be greatly appreciated.
Monday,06,July,2026,20:00:23:28357
VCDS Version: https://urldefense.com/v3/__http://26.3.0.0__;!!KQQRbYJqkXCDY_8FAQ!Axfb-wxVVfyjJ42eIC3aaCIk4ZYwfpfvIZC1eSRJPaBE-su8Q3efmAYtBqQWd_Z-BcM53uUKP_r8mxmYol_bfR84bZaslUvyXcelbMA$ [26[.]3[.]0[.]0] (x64)  HEX-V2 CB: 0.4701.4
https://urldefense.com/v3/__http://www.Ross-Tech.com__;!!KQQRbYJqkXCDY_8FAQ!Axfb-wxVVfyjJ42eIC3aaCIk4ZYwfpfvIZC1eSRJPaBE-su8Q3efmAYtBqQWd_Z-BcM53uUKP_r8mxmYol_bfR84bZaslUvyjI0Ibtw$ [ross-tech[.]com]
VIN: WVWWF7AU1HW149710   License Plate:
Mileage: 152766km-94924mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F 65 6C 75 A5 A9
VIN: WVWWF7AU1HW149710   Mileage: 152766km-94924miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---    CVN: 4788C367
   Coding: 091900322446000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001005
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 48C95FE64235171A473-801C
   VINID: 9E69E75874650589C11091C100131EE2CF
20662 - Oxygen (Lambda) Sensor B1 S1
          P0131 00 [01100000] - Signal too Low
                    Mileage: 152661 km
                    Date: 2026.07.04
                    Time: 15:03:44
                    Engine speed: 1102.75 /min
                    Normed load value: 40.4 %
                    Vehicle speed: 3 km/h
                    Coolant temperature: 34  C
                    Intake air temperature: 39  C
                    Voltage terminal 30: 13.730 V
                    Unlearning counter according OBD: 37
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 5 s
                    MAP_MES_SAE: 67 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 0.000 V
                    TTIP_MES_LS_UP[1]: 646.0000  C
                    TEG_DYN_LS_UP[1]: 349.7250  C
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 63256000008869
   Coding: 01FA6BA154240975477E030140C36980D62A90E2C00296373440508440A8430000000012121212B835351919323200
   Shop #: WSC 61740 001 104857
   VCID: 78A9EF267255A79AF73-802C
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0424013287 Dataset Number: V03935252RB 0001
   Coding: 032C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B23302A03E34C82DA1-806E
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000410010001011500401211142A
   VCID: 6D87CE720D171232145-8038
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 4 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H06 0012
   Serial number: BA31921700PAG0MUFU04
329479 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [00001000] - Open or Short to Plus
                    Reset counter: 42
                    Mileage: 152693 km
                    Date: 2026.07.06
                    Time: 05:51:43
                    Voltage terminal 30: 13.6 V
                    Outside temperature: 18.0  C
                    Inside temperature: 26.2  C
                    Actual value for fresh air/recirculation air flow flap: 0.0 %
                    Actual value for fresh air/recirculation air flow flap: 49
                    Fresh air/recirculating air/back pressure door specified value: 50
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061632000280 Dataset Number: V03935237L  0001
   Coding: 00010E46C041A2F169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 04518BD63E9DF37AEBB-8050
   Component: WWS    161027  043 0551
   Serial number:         161112142417
   Component: RLHS  042 0105
   Serial number: S6Y16M11D23H16M26S22
   Coding: 06A8DD
560917 - Databus
                    Fault Frequency: 20
                    Reset counter: 3
                    Mileage: 152454 km
                    Date: 2026.06.29
                    Time: 10:39:45
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    Voltage: 12.1 V
                    Outside temperature: 24.5  C
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417319037 Dataset Number: ----------
   Coding: 0271667801
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: 51FF7282B16FD6D210D-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Dataset Number: V03935253UB 0001
   Coding: 2D0060C151FFC428949C810510301600000000000000000000
   VCID: 3C21333606ED4BBAD3B-8068
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_MISALIGNMENT_VERTICAL]
                    Reset counter: 3
                    Mileage: 152742 km
                    Date: 2026.07.06
                    Time: 17:08:32
                    Control Module temperature: 30  C
                    Voltage terminal 15: 14.1 V
                    Velocity_vehicle_reference: 8.19 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.12 m/s
   Serial number: 14101641350035 Dataset Number: V03935231PP 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292F2632D5679A373-806C
   Serial number: 003GCR06L212 Dataset Number: V03935221QJ 0001
   VCID: 47CB5CDA4F2B18624E9-8012
   Serial number: IBH000000000005ZWOU0
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 002 411 16
   Serial number: 35700000000B5805E02H
   Subsystem 3 - Part No SW: -----------    HW: 480 001 811 16
   Serial number: 35800000000590B00F1E
   Subsystem 4 - Part No SW: -----------    HW: 480 402 211 16
   Serial number: 3510001B522F976174F8
   Subsystem 5 - Part No SW: -----------    HW: 480 401 811 16
   Serial number: 3520001B523204B3A56U
   Subsystem 6 - Part No SW: -----------    HW: 480 401 411 16
   Serial number: 3550002C122E8E15611$
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 711 16
   Component: FrontSensor_P  000 6149
   Serial number: 3560001C323B3B54C10$
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 22111604221391
   Coding: 0C00
   VCID: 094F9AE219BFAE1298D-805C
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         409 3197
   Coding: 076D4092FE88CF4402847F0F4401000800000000
   VCID: 2A0D056EFC79C50AB17-807E
10485828 - Internal Control Module Memory Check Sum Error
          B2000 41 [00001001] - General Checksum Failure
          [Steuerger t defekt (Fehler durch Selbsttest entdeckt)]
                    Mileage: 148266 km
                    Date: 2026.01.18
                    Time: 19:19:53
          U1110 00 [00001000] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 39
                    Mileage: 152471 km
                    Date: 2026.06.30
                    Time: 16:04:37
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 11111610802901 Dataset Number: V03935242HR 0001
   Coding: 0101000838085900FB00023A880F00000001050000000000000000000000
   GVL: 01DC3C100000060040CC900080024C0000000000000000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CA1F336466D8BBA93B-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29160003055210106456
   Coding: 34FFFF
131595 - Tire Pressure Monitoring Module
          U0127 00 [00001000] - No Communications
          [Timeout Knoten 0x0B / 65 - Steuerger t f r Reifendruck berwachung]
                    Fault Frequency: 88
                    Reset counter: 43
                    Mileage: 152454 km
                    Date: 2026.06.29
                    Time: 10:41:40
                    Terminal 30 power supply: 12.6 V
                    Terminal 15: OFF
          U1101 00 [00001001] - Active
                    Reset counter: 3
                    Mileage: 152454 km
                    Date: 2026.06.29
                    Time: 10:40:01
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: On
   Serial number: HA1-00002.11.16 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4ACD65EE5C39E50A517-801E
   Revision: 00000000    Serial number: 16000196591010
   Coding: 5500000000000000
   VCID: 34311B162EBD83FA1BB-8060
   Serial number: 0422386557 Dataset Number: V03935221MX 0001
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Serial number: 0422370730
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Serial number: 111116EKB02623 Dataset Number: V03935248YZ 0001
   Coding: 003F1320D000040000000000
   VCID: 43D348CA7B133442921-8016
   Serial number: 00000000000012329432
   Coding: 111000
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [00001000] - Electrical Failure
                    Fault Frequency: 11
                    Reset counter: 43
                    Mileage: 152667 km
                    Date: 2026.07.06
                    Time: 04:16:12
   Dataset Number: V03935249RP 0001
   Coding: 9302
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D352E0CD9758AC17-806E
   Revision: 00000001    Serial number: VWZ8Z1GBA02V197 Dataset Number: V03935253GC 0001
   Coding: 1200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   Serial number: 121116EKC08275 Dataset Number: V03935249AG 0001
   Coding: 003F1320DE00040000800000
   VCID: 42DD4DCE64093D4A997-8016
   Serial number: 00000000000012443399
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935237WR 0021
   Coding: 022202107F000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40D947C66A052F5A8F3-8014
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Part No SW: 5NA 035 047 C    HW: 5NA 035 047
   Component: MU-H-NS-US    H51 1126
   Serial number: P065J0GB010073
   Coding: 027310020000000051220002001808201F0007E471708405DE
   Shop #: WSC 00256 168 00001
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 606 C    HW: 5G6 919 606 C
   Component: ABT_High-2  280 9304
   Serial number: VWZ6ZMY3005349
   Subsystem 2 - Part No SW: V03 959 821 DC    HW: -----------
   Component: NAR 2024/2025  --- 0376
   Compact disc data bank:
   Component: Gracenote2  --- 3011
          B201A 00 [00001001] - -
                    Fault Frequency: 11
                    Reset counter: 3
                    Mileage: 152454 km
                    Date: 2026.06.29
                    Time: 10:40:35
                    Voltage terminal 30: 12.3 V
                    Status_Software_Version_Management-module_name: MDUV669/Main
          [Anti-theft protection - component protection active (0xEA6100)]
                    Reset counter: 252
                    Mileage: 152454 km
                    Date: 2026.06.29
                    Time: 10:40:30
2571 - Navigation System
          B126C F2 [00001000] - Navigation Database not Enabled
                    Reset counter: 39
                    Mileage: 152471 km
                    Date: 2026.06.30
                    Time: 09:42:44
                    Voltage terminal 30: 12.7 V
                    Reset counter: 252
                    Mileage: 152454 km
                    Date: 2026.06.29
                    Time: 10:48:56
                    Voltage terminal 30: 12.8 V
0009 - Antenna for Satellite Radio
          B10F4 13 [00001001] - Open Circuit
                    Reset counter: 3
                    Mileage: 152454 km
                    Date: 2026.06.29
                    Time: 10:40:30
7225 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Range data (0x39) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 252
                    Mileage: 152454 km
                    Date: 2026.06.29
                    Time: 10:40:31
                    BAP-BAP_Function_ID: 02
   Serial number: 30000000343204 Dataset Number: v09600047P6 0204
   ROD: EV_RDKBERU30_006_VW37.rod
   Dataset Number: 81A909460E  0001
   Coding: 01000001C2002017040060
   Shop #: WSC 12345 123 61029
   VCID: 392F2A2209DF7E92C8D-806C
Address 75: Telematics (J949)       Labels:| 5QE-035-28X-V1.clb
   Dataset Number: V03935236TB 0001
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB_VW37.rod
   Serial number: 22111612K23470 Dataset Number: V03935243PV 0001
   Coding: 000307000000020100221354C040890084000E120040
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 161103202521
   VCID: 2F3B147AC79BA022669-807A
End----------(Elapsed Time: 02:13, VBatt start/end: 12.3V/12.3V)-----------
------------------------------15 Faults Found------------------------------
Monday,06,July,2026,20:06:37:28357
          5F 65 6C 75 A5 A9
Readiness: 1110 0101
   Coding: 032C0C
   Revision: 00001K08
   Air quality sensor:
   Coding: 06A8DD
560917 - Databus
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:18
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 12.2 V
   Coding: 0271667801
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:18
                    Control Module temperature: 27  C
                    Voltage terminal 15: 12.1 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
   Coding: 30324E
   Coding: 0C00
                    Mileage: 148266 km
                    Date: 2026.01.18
                    Time: 19:19:53
   Generator:
   Coding: 34FFFF
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:19
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: On
   Coding: 0001
   Coding: 02011103
   Coding: 020111
   Coding: 111000
   Coding: 9302
   Coding: 091000
   Coding: 900000
   Coding: 900000
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:27
                    Voltage terminal 30: 12.4 V
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:22
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:22
                    Reset counter: 3
                    Mileage: 152766 km
                    Date: 2026.07.06
                    Time: 20:02:24
End----------(Elapsed Time: 02:12, VBatt start/end: 12.2V/12.2V)-----------
------------------------------8 Faults Found-------------------------------
Kushdaiin
CT, USA
C?ID=192983
Any thoughts?
Kushdaiin
CT, USA
C?ID=192983
Just to follow up, I followed the procedure in the link to the German website and my vertical misalignment was out by (+)4.5 degrees. Under the surrounding cover, I was able to dial it down to (-)0.58 degrees by turning the upper right screw (3.5mm) 6.5 turns Clockwise (CW). Another dynamic calibration and the error has yet to return. I've read several accounts now of the grill mounted radar requiring recalibration after driving through heavy rain. I've seen it on our previous badge-mounted radared cars, which always cleared itself pretty quickly. However, this was the first calibration issues I've ever dealt with on this car after 95,000 miles. In the end, a pretty easy resolution with VCDS.
It makes no sense to me that rain would knock it out by 4.5 degrees, requiring 6+ turns of the screw.
  • Agree
Reactions: TTT
Kushdaiin
CT, USA
C?ID=192983
I agree with you. My first thought with that error was that water either got into the connector or into the housing but those both appeared to be intact. My only guess is that if the water or rain is dense enough, the calibration parameters go haywire, similar to the later radars located in the badge but this version doesn't auto calibrate. I honestly don't know.
