Cant seem to figure out P2004, P2005
ijkkiing1144
C?ID=580608
Saturday,04,July,2026,11:51:41:12837
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.4
VIN: WAU2GAFC1EN003413   License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
          53 55 56 5F 62 6C 6D 72 8F 90
VIN: WAU2GAFC1EN003413   Mileage: 170125km-105710miles
Address 01: Engine (J623-CTUA)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 J    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---    CVN: B51FF266
   Coding: 1A2A0034052601060000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551J 001004
   ROD: EV_ECM30TFS0214G0907551J.rod
   VCID: 30390706FAA071DA7F3-8064
   VINID: 9D19425D15930557800031010C992F533A
6425 - Intake Manifold Flap; Bank 1
          P2004 00 [00100100] - Stuck Open
                    Mileage: 170125 km
                    Date: 2026.07.04
                    Time: 09:41:03
                    Engine speed: 1309.00 /min
                    Normed load value: 14.1 %
                    Coolant temperature: 28  C
                    Intake air temperature: 29  C
                    Voltage terminal 30: 12.796 V
                    Engine speed: actual: 1280 /min
                    MAF_ENVD: 250.56470 mg/stroke
                    Coolant temperature (unfiltered): 28.50  C
                    Engine: operating status: IS
                    V_PORT_1_ENVD: 3.53516 V
                    Vehicle speed: actual: 0 km/h
6426 - Intake Manifold Flap; Bank 2
          P2005 00 [00100100] - Stuck Open
                    Mileage: 170125 km
                    Date: 2026.07.04
                    Time: 09:41:03
                    V_PORT_2_ENVD: 3.69141 V
7814 - Coolant Pump for Intercooler
          P190C 00 [00101111] - No Signal
                    Mileage: 170125 km
                    Date: 2026.07.03
                    Time: 13:25:51
                    Engine speed: 700.00 /min
                    Normed load value: 16.5 %
                    Coolant temperature: 74  C
                    Intake air temperature: 33  C
                    Voltage terminal 30: 13.913 V
                    Engine speed: actual: 896 /min
                    MAF_ENVD: 92.60000 mg/stroke
                    Coolant temperature (unfiltered): 49.50  C
                    Engine load: 8.203125 %
20136 - PCV Valve Malfunction
          P052E 00 [00100111] - -
                    Mileage: 170125 km
                    Date: 2026.07.04
                    Time: 11:48:26
                    Engine speed: 697.00 /min
                    Normed load value: 16.9 %
                    Coolant temperature: 69  C
                    Intake air temperature: 39  C
                    Voltage terminal 30: 13.202 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 163.41176 mg/stroke
                    Coolant temperature (unfiltered): 69.75  C
                    Engine load: 16.796875 %
Readiness: 1110 1101
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---    CVN: 06AF4385
   Coding: 000002
   VCID: 2D071E72ED921C32545-8078
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 44A7970322E5E9C05B00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A2D252E2CDCBB8AC17-806E
0785 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [SCL_LWR_Hoehenwert_VL_Error]
                    Reset counter: 7
                    Mileage: 170125 km
                    Date: 2026.07.03
                    Time: 13:25:46
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E5
                    Uz: B5
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H33 0433
   Coding: 0DAA2046000000000000
   VCID: 7BA3E02A63E642829A1-802E
   Serial number: 2313000073920016
   Part No SW: 4G0 820 043 AF    HW: 4G0 820 043 AF
   Component: KLIMA 4 ZONEN H13 0087
   Serial number: 21051300040370
   Coding: 668320BA49
   ASAM Dataset: EV_AirCondiComfoUDS 002040
   VCID: 6393B84AFBD69A42B21-8036
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [00001001] - Signal Amplitude Too Low
                    Reset counter: 9
                    Mileage: 170125 km
                    Date: 2026.07.03
                    Time: 13:25:46
                    Compressor current: actual value: 0 mA
                    Outside temperature: 33.5  C
                    Temperature downstream of evaporator: 26.50  C
                    Engine speed: 705 /min
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001560809
   Coding: 0200A091173C8FE0C1008884A0003928CF9CD208A6080225800008406000
   VCID: 6FBBC47A279E2E22269-803A
   Component: WWS57X 130502  H36 0080
   Serial number:         130503235318
   Coding: 0045F7
   Serial number: 21302293
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 AK    HW: 4G0 941 531 AK
   Component: E1 - LDS  H07 0044
   Serial number: 04 02 2015  00000016
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R5S3402
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0060618315
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA106240000003558878
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 1A2888A6000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061313400107
   Coding: A8C304
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFC202312A38D230D-8024
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D80030V6L Dataset Number: 4G8909602D  0004
   Coding: 303145313131303030394A55304C34473853
   VCID: 3333080A0BB64AC2021-8066
   Seat occupant detection:
   Serial number: 6940000Y130000TWLS0
   Serial number: 3575HRB401850FBEH1E-
   Serial number: 3585HRB401850G08HGI/
   Serial number: 3515JRB401C50HHO98LH
   Serial number: 3525JRB401450I3SA1J-
   Serial number: 3554VRB400I50H9IG0ST
   Serial number: 3564VRB400I50H9I71D7
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372MDP001HM
   Coding: 000414
   VCID: 38293F261250A99A373-806C
   Subsystem 1 - Part No SW: 4G0 951 528 F    HW: 4G0 951 528 F
   Component: E221 - MFL  H09 0010
   Serial number: 10 04 2013  C1078376
   Part No SW: 4G8 920 984 K    HW: 4G8 920 984 K
   Component: TBenUsa       H80 0618
   Revision: 30460230    Serial number: 658100513596040
   Coding: 03EF01060B43D705020100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3E25293E30F497AAFDF-806A
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000934619 Dataset Number: 4G8909515J  0062
   Coding: 00CD073000
   GVL: FDA1E84CFE63600D0000
   ASAM Dataset: EV_GatewPkoUDS 001018
   Control module for battery monitoring:
   Serial number: 3206820503
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 130320000000000001C1
          U140B 00 [00001000] - -
          [Powermanagement active]
                    Reset counter: 49
                    Mileage: 170125 km
                    Date: 2026.07.04
                    Time: 11:04:45
                    Voltage terminal 30: 11.5 V
                    Voltage terminal 15: 11.4 V
                    Control Module temperature: 34  C
                    System status: Terminal 15 on
                    Engine is running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0087
   Serial number: 17051300041625
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
   VCID: 372B3C1A1FCEA6E23E9-8062
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000059344714
   Coding: C0581B008F006001000001010101102030303232203232
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA8203JPLT Dataset Number: 4G8909573A  0001
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3635311E18C45FEA25F-8062
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0060
   Revision: 00H04000    Serial number: 6PZ 010 287-08
   Coding: 0000007
   VCID: 3635311E14445FEA25F-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H04 0060
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F09.05.1300H04000AMS15568
   Subsystem 4 - Serial number: S15568
   Component: TSG FA        H03 0507
   Coding: 011F57025E00628002000412
   VCID: 47CB4CDA6FAED6624E9-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0009479149 Dataset Number: 4G8909852J  0028
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D0D0EF4AC43CA097-8066
   Revision: 00002001    Serial number: 0307248076
   Coding: 0126063A20FAF08582B00A8402030D470000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000149993
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO21847084
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00003483451
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA106021000003547839
   Subsystem 6 - Part No SW: 3AA 962 243 B    HW: 3AA 962 243 B
   Component: GEB.F.Heckoef  H16 0810
   Serial number: 93002570
   Revision: CJ007001    Serial number: 00000000055104
   Coding: 030000
   VCID: 1D67CEB29DB2ECB2C45-8048
   Component: TSG BF        H03 0507
   Coding: 011F57025E00628002000402
   VCID: 46D541DE68A4CF6AB5F-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000685773 Dataset Number: 4G8909522C  0006
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C011376D688153A43B-8078
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 130514-0004-033
   Coding: 1223A633701AA500
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU57.rod
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
126984 - Front Left Ride-Height Sensor
          C1034 29 [10001001] - Signal Implausible
                    Reset counter: 9
                    Mileage: 170125 km
                    Date: 2026.07.04
                    Time: 09:49:48
   Revision: AB001007    Serial number: 156E+0D7801991
   Coding: 020007010000000001
   VCID: 2411FB56BED8DD7A8BB-8070
   Part No SW: 4G0 035 746 E    HW: 4G0 035 746 E
   Component: H-BNT-NA      H40 0735
   Revision: --------    Serial number: 194E 0DB000487
   Coding: 090200040003E1EF55128B1E00000003100001000000000000
   VCID: 290FEA62D9FA0012B8D-807C
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD001B434
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349ME80002J
   Component: CD-Database  5298
   Component: TSG HL        H03 0507
   Coding: 010F17024000628002000002
   VCID: 49CF4AE279BA201258D-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H07---    Serial number: 525 PA8J35G0DQ
   Coding: 1080013
   VCID: 2615E15EC4E42F6A95F-8072
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 124300946 Dataset Number: 4G8909541F  0023
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 44D15BD65E18FD7AABB-8010
   Component: TSG HR        H03 0507
   Dataset Number: 4G0909614C  0001
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F0202F1AA78D270D-8064
   Dataset Number: 4G0909615C  0001
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:41, VBatt start/end: 13.5V/14.0V)-----------
------------------------------8 Faults Found-------------------------------
Finished an engine rebuild for a C7 A7 and keep getting P2004, P2005. I double checked that the flaps are not stuck and made sure the lines going to the flaps held vacuum fine. To ensure that there was no kink in the air hose I had held the hose under vacuum and pulled air hose going to each one of the flaps and ensured that the vacuum had dropped back to ambient. I had already replaced out N316 as I thought this was the issue since I ruled out the air hose as well as the manifolds being stuck. I also found it suspicious that both are stuck open at all times leading me to believe that N316 was not functioning correctly to bleed off the vacuum. Any ideas?
ijkkiing1144
C?ID=580608
Sorry had just realized this is posted in the wrong section. Could someone please move?
ijkkiing1144
C?ID=580608
Bump
Ziddywerks
Northern NJ USA
C?ID=208579
I will bet good money either a vacuum lines is off somewhere or the lines are mixed up at the solenoids, did we also remember to hold flaps open when reinstalling into cylinder heads? If not then that could be a problem.
ijkkiing1144
C?ID=580608
I will recheck the lines to see if theres anything pinched. If the flaps were installed without holding open, from previous experience, it would show flaps stuck closed not open right?
ijkkiing1144
C?ID=580608
Following up on this. Checked pinched lines and didnt find anything. Also checked solenoids to make sure all was right. Hooked up a gauge to the vac lines and it seems to be pulling good vacuum. Is it possible this is maybe a faulty front solenoid i.e the one that is hooked up to the water pump. Could that be the cause? If I were to forget to open the flaps when reinstalling, wouldnt that be a stuck close error code not stuck open @Ziddywerks ?
ijkkiing1144
C?ID=580608
Another thought came across my head. Is there any relearning procedure? I did disassemble everything and did a cleaning of all carbon. Wondering if I would need to do some relearning after?
ijkkiing1144
C?ID=580608
@stefdds The error is flaps stuck open not closed
I wouldn't take those fault codes so literally. Did you remember to do that procedure or not?
Ziddywerks
Northern NJ USA
C?ID=208579
Pull vacuum line from solenoid and put flaps into vacuum watch both banks make sure they move and hold. Solenoid is possible. You swap them they are all the same pn afaik. I find it highly unlikely that a solenoid went bad all of a suddenly immediately after such repair. Simple logic dictates connectors are mixed up or vacuum lines, crossed disconnected or not holding vacuum or flaps were not held open when installing its as simple as that.
